Xavier Devkit J512 does not detect USB-SATA drive on L4T 35.1.0
I am attempting to connect a USB-C to SATA adapter to my Jetson AGX Xavier via port J512. The Jetson is running L4T 35.1.0. There is a SATA SSD attached to the adapter.
The Jetson does not seem to recognize that the SSD is connected when I connect the adapter to port J512. udevadm monitor does not show any events when I disconnect or connect the adapter. lsusb also does not show an entry for the SSD. The drive is not listed as a block device in lsblk. However, a power indicator light on the adapter does illuminate when plugged into J512.
Connecting the drive to the devkit’s other USB-C port yields a lot of errors (in dmesg):
[    9.105378] sd 0:0:0:0: [sda] tag#3 data cmplt err -71 uas-tag 1 inflight: CMD
[    9.105568] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   10.123837] sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 1 inflight: CMD
[   10.124035] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   10.124231] sd 0:0:0:0: [sda] tag#0 uas_eh_abort_handler 0 uas-tag 2 inflight: CMD OUT
[   10.124392] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 03 a3 81 2a 98 00 00 00 18 00 00
[   10.301065] sd 0:0:0:0: [sda] tag#28 data cmplt err -71 uas-tag 1 inflight: CMD
[   10.301249] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   12.529453] sd 0:0:0:0: [sda] tag#28 uas_zap_pending 0 uas-tag 1 inflight: CMD
[   12.529614] sd 0:0:0:0: [sda] tag#28 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   12.529801] sd 0:0:0:0: [sda] tag#29 uas_zap_pending 0 uas-tag 2 inflight: CMD
[   12.529953] sd 0:0:0:0: [sda] tag#29 CDB: opcode=0x8a 8a 00 00 00 00 03 a3 81 2a 98 00 00 00 18 00 00
[   12.684992] sd 0:0:0:0: [sda] tag#1 data cmplt err -71 uas-tag 1 inflight: CMD
[   12.685157] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   14.832815] sd 0:0:0:0: [sda] tag#1 uas_zap_pending 0 uas-tag 1 inflight: CMD
[   14.832973] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   14.833144] sd 0:0:0:0: [sda] tag#2 uas_zap_pending 0 uas-tag 2 inflight: CMD
[   14.833282] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x8a 8a 00 00 00 00 03 a3 81 2a 98 00 00 00 18 00 00
[   14.988970] sd 0:0:0:0: [sda] tag#0 data cmplt err -71 uas-tag 1 inflight: CMD
[   14.989148] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   17.136782] sd 0:0:0:0: [sda] tag#0 uas_zap_pending 0 uas-tag 1 inflight: CMD
[   17.136938] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   17.137111] sd 0:0:0:0: [sda] tag#1 uas_zap_pending 0 uas-tag 2 inflight: CMD
[   17.137249] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x8a 8a 00 00 00 00 03 a3 81 2a 98 00 00 00 18 00 00
[   17.292997] sd 0:0:0:0: [sda] tag#2 data cmplt err -71 uas-tag 1 inflight: CMD
[   17.293175] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   19.440825] sd 0:0:0:0: [sda] tag#2 uas_zap_pending 0 uas-tag 1 inflight: CMD
[   19.441000] sd 0:0:0:0: [sda] tag#2 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   19.441179] sd 0:0:0:0: [sda] tag#3 uas_zap_pending 0 uas-tag 2 inflight: CMD
[   19.441321] sd 0:0:0:0: [sda] tag#3 CDB: opcode=0x8a 8a 00 00 00 00 03 a3 81 2a 98 00 00 00 18 00 00
[   19.596988] sd 0:0:0:0: [sda] tag#24 data cmplt err -71 uas-tag 1 inflight: CMD
[   19.597155] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   21.744746] sd 0:0:0:0: [sda] tag#24 uas_zap_pending 0 uas-tag 1 inflight: CMD
[   21.744900] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
[   21.745075] sd 0:0:0:0: [sda] tag#25 uas_zap_pending 0 uas-tag 2 inflight: CMD
[   21.745236] sd 0:0:0:0: [sda] tag#25 CDB: opcode=0x8a 8a 00 00 00 00 03 a3 81 2a 98 00 00 00 18 00 00
[   21.895659] sd 0:0:0:0: [sda] tag#24 timing out command, waited 6s
[   21.895811] sd 0:0:0:0: [sda] tag#24 UNKNOWN(0x2003) Result: hostbyte=0x08 driverbyte=0x00 cmd_age=12s
[   21.895989] sd 0:0:0:0: [sda] tag#24 CDB: opcode=0x8a 8a 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00
This hardware configuration worked well on L4T 32.7.1. What do I need to do to get the Jetson to correctly detect this device on this port?
Hi jack31,
Are you using the devkit or custom board for AGX Xavier?
Could you help to verify with latest R35.3.1?
Do you configure anything in device tree with R32.7.1?
Is there any dmesg when you use it as expected with this release?
We are using the AGX Xavier devkit. Our software team is working on an upgrade to 35.1.1 now but I expect this may take some time. Any input on potential fixes at 35.1.0 would be greatly appreciated.
We did not have to change the device-tree for 32.7.1 to get this behavior working.
On 35.1.0, dmesg | grep sda does not return any messages.
Could you share the full dmesg when it is working in R32.7.1?
and also the full dmesg when it is not working in R35.1?
@KevinFFF
dmesg from 32.7.1:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.253-l4t-r32.7+gac2a37e8219a (oe-user@oe-host) (gcc version 11.2.0 (GCC) ) #1 SMP PREEMPT Fri Mar 11 13:27:19 UTC 2022
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] On node 0 totalpages: 8324608
[    0.000000]   DMA zone: 7192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 460288 pages, LIFO batch:31
[    0.000000]   Normal zone: 122880 pages used for memmap
[    0.000000]   Normal zone: 7864320 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57752 r8192 d32360 u98304
[    0.000000] pcpu-alloc: s57752 r8192 d32360 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8194536
[    0.000000] Kernel command line: console=ttyTCU0,115200 console=tty0 fbcon=map:0 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 root=/dev/mmcblk0p1 vpr_resize sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 30264(92%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Memory: 31923428K/33298432K available (16190K kernel code, 2960K rwdata, 10100K rodata, 14016K init, 610K bss, 621340K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8009050000   ( 16192 KB)
[    0.000000]     .rodata : 0xffffff8009050000 - 0xffffff8009a40000   ( 10176 KB)
[    0.000000]       .init : 0xffffff8009a40000 - 0xffffff800a7f0000   ( 14016 KB)
[    0.000000]       .data : 0xffffff800a7f0000 - 0xffffff800aad4008   (  2961 KB)
[    0.000000]        .bss : 0xffffff800aad4008 - 0xffffff800ab6cb5c   (   611 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf20000000   (   512 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc800000000   ( 32768 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000007] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.008272] Console: colour dummy device 80x25
[    0.012453] console [tty0] enabled
[    0.015836] bootconsole [tegra_comb_uart0] disabled
[    0.020595] kmemleak: Kernel memory leak detector disabled
[    0.020649] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.020740] pid_max: default: 32768 minimum: 301
[    0.022016] Security Framework initialized
[    0.022677] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.022748] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.025118] ftrace: allocating 48946 entries in 192 pages
[    0.476158] sched-energy: Sched-energy-costs installed from DT
[    0.476270] ASID allocator initialised with 65536 entries
[    0.516026] tegra-id: chipid=21917.
[    0.516060] tegra-id: opt_subrevision=1.
[    0.516107] Tegra Revision: A02p SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.516193] DTS File Name: /home/jack/vehicle-platform/poky/build/tmp/work-shared/jetson-agx-xavier-devkit/kernel-source/arch/arm64/boot/dts/../../../../nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[    0.516294] DTB Build time: Mar 11 2022 13:27:19
[    0.563928] CPU1: Booted secondary processor [4e0f0040]
[    0.596135] CPU2: Booted secondary processor [4e0f0040]
[    0.628332] CPU3: Booted secondary processor [4e0f0040]
[    0.660660] CPU4: Booted secondary processor [4e0f0040]
[    0.692823] CPU5: Booted secondary processor [4e0f0040]
[    0.725170] CPU6: Booted secondary processor [4e0f0040]
[    0.757406] CPU7: Booted secondary processor [4e0f0040]
[    0.757815] Brought up 8 CPUs
[    0.758080] SMP: Total of 8 processors activated.
[    0.758129] CPU features: detected feature: Privileged Access Never
[    0.758172] CPU features: detected feature: LSE atomic instructions
[    0.758243] CPU features: detected feature: User Access Override
[    0.758292] CPU features: detected feature: 32-bit EL0 Support
[    0.760388] CPU: All CPU(s) started at EL2
[    0.760493] alternatives: patching kernel code
[    0.773727] devtmpfs: initialized
[    0.839473] Initilizing CustomIPI irq domain
[    0.839826] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.839945] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.856262] pinctrl core: initialized pinctrl subsystem
[    0.856645] OS set in device tree is not L4T.
[    0.857031] regulator-dummy: no parameters
[    0.857449] Initializing plugin-manager
[    0.857565] Plugin module not found
[    0.857656] Plugin-manager status disabled
[    0.859230] NET: Registered protocol family 16
[    0.860390] persistent_ram: found existing invalid buffer, size 1610612736, start 0
[    0.860581] persistent_ram: found existing invalid buffer, size 1090519040, start 0
[    0.869949] pstore: using zlib compression
[    0.871031] console [pstore-1] enabled
[    0.871074] pstore: Registered ramoops as persistent store backend
[    0.871144] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[    0.890759] cpuidle: using governor menu
[    0.892135] bpmp: waiting for handshake
[    0.892187] bpmp: handshake completed
[    0.892251] bpmp: synchronizing channels
[    0.892319] bpmp: channels synchronized
[    0.892360] bpmp: mail init ok
[    0.895624] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.895863] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.895916] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.895960] t19x-arm-smmu 12000000.iommu: 	stage 1 translation
[    0.896017] t19x-arm-smmu 12000000.iommu: 	stage 2 translation
[    0.896074] t19x-arm-smmu 12000000.iommu: 	nested translation
[    0.896123] t19x-arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.896189] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.896278] t19x-arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.896329] t19x-arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.896379] t19x-arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.901158] vdso: 2 pages (1 code @ ffffff8009057000, 1 data @ ffffff800a7f4000)
[    0.901249] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.904887] atomic_pool_init():621: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.906304] tegra_aon_clk_init: ok
[    0.906357] Registering BPMP clocks...
[    0.906505] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.907234] Serial: AMBA PL011 UART driver
[    0.907472] tegra_powergate_init: DONE
[    0.907580] DTS File Name: /home/jack/vehicle-platform/poky/build/tmp/work-shared/jetson-agx-xavier-devkit/kernel-source/arch/arm64/boot/dts/../../../../nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[    0.907712] DTB Build time: Mar 11 2022 13:27:19
[    0.912156] Tegra reboot handler registered.
[    0.921765] iommu: Adding device 14180000.pcie to group 0
[    0.922664] iommu: Adding device 14100000.pcie to group 1
[    0.923558] iommu: Adding device 14140000.pcie to group 2
[    0.924511] iommu: Adding device 141a0000.pcie to group 3
[    0.926155] iommu: Adding device 2490000.ether_qos to group 4
[    0.926860] iommu: Adding device 3100000.serial to group 5
[    0.927737] iommu: Adding device 3110000.serial to group 6
[    0.928246] iommu: Adding device 3140000.serial to group 7
[    0.929099] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.929365] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.929462] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.929512] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.929559] tegra-pmc: ### PMC reset status reg: 0x0
[    0.929685] tegra-pmc: PMC Prod config success
[    0.930014] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.930101] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.930536] iommu: Adding device 3460000.sdhci to group 8
[    0.931343] iommu: Adding device 3400000.sdhci to group 9
[    0.932050] iommu: Adding device 2450000.ufshci to group 10
[    0.932922] iommu: Adding device 3210000.spi to group 11
[    0.934267] iommu: Adding device 3160000.i2c to group 12
[    0.934832] iommu: Adding device c240000.i2c to group 13
[    0.935438] iommu: Adding device 3180000.i2c to group 14
[    0.935933] iommu: Adding device 3190000.i2c to group 15
[    0.936638] iommu: Adding device 31b0000.i2c to group 16
[    0.937179] iommu: Adding device 31c0000.i2c to group 17
[    0.937721] iommu: Adding device c250000.i2c to group 18
[    0.938340] iommu: Adding device 31e0000.i2c to group 19
[    0.939521] iommu: Adding device sound to group 20
[    0.940429] iommu: Adding device 3510000.hda to group 21
[    0.941164] iommu: Adding device bc00000.rtcpu to group 22
[    0.943500] iommu: Adding device 13e10000.host1x to group 23
[    0.944126] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[    0.944703] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[    0.945272] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[    0.945944] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[    0.946611] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[    0.947299] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[    0.948019] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[    0.948743] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[    0.949591] iommu: Adding device 15340000.vic to group 32
[    0.950160] iommu: Adding device 15380000.nvjpg to group 33
[    0.950623] iommu: Adding device 15500000.tsec to group 34
[    0.951029] iommu: Adding device 15100000.tsecb to group 35
[    0.951481] iommu: Adding device 15480000.nvdec to group 36
[    0.952072] iommu: Adding device 15140000.nvdec1 to group 37
[    0.952492] iommu: Adding device 154c0000.nvenc to group 38
[    0.953020] iommu: Adding device 15a80000.nvenc1 to group 39
[    0.953608] iommu: Adding device 15880000.nvdla0 to group 40
[    0.954308] iommu: Adding device 158c0000.nvdla1 to group 41
[    0.955094] iommu: Adding device 15200000.nvdisplay to group 42
[    0.959671] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    0.959848] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    0.960598] iommu: Adding device 15210000.nvdisplay to group 43
[    0.960718] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    0.961248] iommu: Adding device 15220000.nvdisplay to group 44
[    0.961363] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[    0.964081] iommu: Adding device 15c10000.vi to group 45
[    0.964420] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    0.965008] iommu: Adding device 14800000.isp to group 46
[    0.966455] iommu: Adding device 16000000.pva0 to group 47
[    0.967222] iommu: Adding device 16800000.pva1 to group 48
[    0.967845] iommu: Adding device 15810000.se to group 49
[    0.968402] iommu: Adding device 15820000.se to group 50
[    0.968865] iommu: Adding device 15830000.se to group 51
[    0.969250] iommu: Adding device 15840000.se to group 52
[    0.969633] iommu: Adding device c1a0000.aon to group 53
[    0.972059] iommu: Adding device d000000.bpmp to group 54
[    0.972542] bpmp: ping status is 0
[    0.972737] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[    0.976447] bpmp d000000.bpmp: probe ok
[    0.978801] tegra-reset 0.bpmp_reset: registered 190 resets.
[    0.979535] iommu: Adding device smmu_test to group 55
[    0.981191] mc: mapped MMIO address: 0xffffff800af40000 -> 0x2c10000
[    0.981283] mc: mapped MMIO address: 0xffffff800af60000 -> 0x2c20000
[    0.981365] mc: mapped MMIO address: 0xffffff800af80000 -> 0x2c30000
[    0.981453] mc: mapped MMIO address: 0xffffff800afa0000 -> 0x2c40000
[    0.981532] mc: mapped MMIO address: 0xffffff800afc0000 -> 0x2c50000
[    0.981617] mc: mapped MMIO address: 0xffffff800afe0000 -> 0x2b80000
[    0.981697] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x2b90000
[    0.981775] mc: mapped MMIO address: 0xffffff800b1d0000 -> 0x2ba0000
[    0.981853] mc: mapped MMIO address: 0xffffff800b1f0000 -> 0x2bb0000
[    0.981933] mc: mapped MMIO address: 0xffffff800b210000 -> 0x1700000
[    0.982015] mc: mapped MMIO address: 0xffffff800b230000 -> 0x1710000
[    0.982100] mc: mapped MMIO address: 0xffffff800b250000 -> 0x1720000
[    0.982204] mc: mapped MMIO address: 0xffffff800b270000 -> 0x1730000
[    0.982288] mc: mapped MMIO address: 0xffffff800b290000 -> 0x1740000
[    0.982371] mc: mapped MMIO address: 0xffffff800b2b0000 -> 0x1750000
[    0.982474] mc: mapped MMIO address: 0xffffff800b2d0000 -> 0x1760000
[    0.982555] mc: mapped MMIO address: 0xffffff800b2f0000 -> 0x1770000
[    0.982726] mc-err: mcerr ops are set to t19x
[    0.990009] iommu: Adding device 2600000.dma to group 56
[    0.995793] gpio gpiochip0: gpio-line-names specifies 210 line names but there are 224 lines on the chip
[    0.997012] GPIO line 339 (wifi-enable) hogged as output/high
[    0.997125] GPIO line 350 (rst-deser1) hogged as output/high
[    0.997563] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    1.007526] gpio gpiochip1: gpio-line-names specifies 30 line names but there are 40 lines on the chip
[    1.007794] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    1.008367] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    1.011584] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    1.011675] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    1.011757] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    1.012969] iommu: Adding device 3550000.xudc to group 57
[    1.013881] iommu: Adding device 3610000.xhci to group 58
[    1.016587] arm64_ras arm64_ras: probed
[    1.017248] ras_fhi_enable: FHI 478 enabled on CPU0
[    1.017348] ras_fhi_enable: FHI 479 enabled on CPU1
[    1.017483] ras_fhi_enable: FHI 480 enabled on CPU2
[    1.017627] ras_fhi_enable: FHI 481 enabled on CPU3
[    1.017736] ras_fhi_enable: FHI 482 enabled on CPU4
[    1.017857] ras_fhi_enable: FHI 483 enabled on CPU5
[    1.017965] ras_fhi_enable: FHI 484 enabled on CPU6
[    1.018146] ras_fhi_enable: FHI 485 enabled on CPU7
[    1.018441] carmel_ras_enable: RAS enabled on cpu0
[    1.018720] carmel_ras_enable: RAS enabled on cpu1
[    1.019003] carmel_ras_enable: RAS enabled on cpu2
[    1.019297] carmel_ras_enable: RAS enabled on cpu3
[    1.019571] carmel_ras_enable: RAS enabled on cpu4
[    1.019832] carmel_ras_enable: RAS enabled on cpu5
[    1.020138] carmel_ras_enable: RAS enabled on cpu6
[    1.020382] carmel_ras_enable: RAS enabled on cpu7
[    1.020555] carmel_ras carmel_ras: probed
[    1.021926] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 487, noc_nonsecure_irq = 486>
[    1.022664] tegra-cbb c600000.aon-noc: noc_secure_irq = 489, noc_nonsecure_irq = 488>
[    1.023743] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 491, noc_nonsecure_irq = 490>
[    1.024704] tegra-cbb be00000.rce-noc: noc_secure_irq = 493, noc_nonsecure_irq = 492>
[    1.025578] tegra-cbb b600000.sce-noc: noc_secure_irq = 495, noc_nonsecure_irq = 494>
[    1.026047] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    1.030426] vdd-3v3-cvb: 3300 mV
[    1.030945] vdd-1v8-cvb: 1800 mV
[    1.031507] vdd-1v8-sd: 1800 mV
[    1.032042] vdd-epb-1v0: 1000 mV
[    1.032323] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    1.032692] vdd-sdmmc1-sw: 3300 mV
[    1.033280] avdd-cam-2v8: 2800 mV
[    1.033852] vdd-sata-1v5: 1500 mV
[    1.034372] vdd-1v8-slt: 1800 mV
[    1.034838] vdd-3v3-slt: 3300 mV
[    1.035372] vdd-fan: 5000 mV
[    1.035967] vdd-hdmi-5v0: 5000 mV
[    1.036524] vdd_sys_en: 1200 mV
[    1.037089] vdd-5v-sata: 5000 mV
[    1.037774] vdd-3v3-pcie: 3300 mV
[    1.038412] vdd-12v-pcie: 1200 mV
[    1.038949] vdd-ac-bat: 5000 mV
[    1.039292] vdd-5v-sata: supplied by vdd-ac-bat
[    1.076346] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.082018] eventlib_kernel: keventlib is initialized, test id: 0
[    1.082548] SCSI subsystem initialized
[    1.082857] libata version 3.00 loaded.
[    1.083111] usbcore: registered new interface driver usbfs
[    1.083235] usbcore: registered new interface driver hub
[    1.083346] usbcore: registered new device driver usb
[    1.095998] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    1.099127] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    1.104709] vdd-1v0: at 1000 mV
[    1.108706] vdd-1v8-hs: at 1800 mV
[    1.112738] vdd-1v8-ls: at 1800 mV
[    1.116797] vdd-1v8-ao: at 1800 mV
[    1.120814] vddio-ddr-1v1: at 1100 mV
[    1.124609] vdd-rtc: at 800 mV
[    1.126034] spmic-ldo1: at 2375 mV
[    1.132620] vdd-ao-3v3: at 3300 mV
[    1.140674] vddio-emmc-3v3: at 3300 mV
[    1.142121] spmic-ldo4: at 1587 mV
[    1.148733] vdd-usb-3v3: at 3300 mV
[    1.156780] vddio-sdmmc1-3v3: at 3300 mV
[    1.160805] vdd-csi-1v2: at 1200 mV
[    1.162527] spmic-ldo8: at 1800 mV
[    1.168027] GPIO line 246 (gpio_default) hogged as output/high
[    1.169579] GPIO line 247 (gpio_default) hogged as output/high
[    1.170114] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    1.170675] max77620 4-003c: max77620 probe successful
[    1.171656] media: Linux media interface: v0.10
[    1.171770] Linux video capture interface: v2.00
[    1.173324] pps_core: LinuxPPS API ver. 1 registered
[    1.173376] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.173494] PTP clock support registered
[    1.173841] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    1.174279] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    1.174376] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    1.177286] trusty trusty: trusty version: Built: 08:57:16 Feb 19 2022
[    1.177432] trusty trusty: selected api version: 3 (requested 3)
[    1.178886] Advanced Linux Sound Architecture Driver Initialized.
[    1.179563] Bluetooth: Core ver 2.22
[    1.179691] NET: Registered protocol family 31
[    1.179744] Bluetooth: HCI device and connection manager initialized
[    1.179808] Bluetooth: HCI socket layer initialized
[    1.179870] Bluetooth: L2CAP socket layer initialized
[    1.179955] Bluetooth: SCO socket layer initialized
[    1.182994] camchar: rtcpu character device driver loaded
[    1.184270] clocksource: Switched to clocksource arch_sys_counter
[    1.244801] VFS: Disk quotas dquot_6.6.0
[    1.244991] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.245470] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.247194] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    1.247340] dma_declare_coherent_resizable_cma_memory:323: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    1.247805] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    1.247898] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    1.248028] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    1.248105] nvmap_page_pool_init: Total RAM pages: 8169273
[    1.248154] nvmap_page_pool_init: nvmap page pool size: 1021159 pages (3988 MB)
[    1.248476] nvmap_background_zero_thread: PP zeroing thread starting.
[    1.249018] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    1.250687] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    1.267385] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    1.267844] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    1.268328] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    1.268692] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    1.268980] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.269187] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[    1.269400] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[    1.271734] la/ptsa driver initialized.
[    1.272317] NET: Registered protocol family 2
[    1.272487] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[    1.279001] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[    1.280145] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.280986] TCP: Hash tables configured (established 262144 bind 65536)
[    1.281098] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[    1.281587] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[    1.282514] NET: Registered protocol family 1
[    1.283246] RPC: Registered named UNIX socket transport module.
[    1.283350] RPC: Registered udp transport module.
[    1.283395] RPC: Registered tcp transport module.
[    1.283435] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.283485] PCI: CLS 0 bytes, default 64
[    1.489099] Trying to unpack rootfs image as initramfs...
[    1.510037] random: fast init done
[    1.514661] host1x 13e10000.host1x: initialized
[    1.516808] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.523456] audit: initializing netlink subsys (disabled)
[    1.523557] audit: type=2000 audit(1.080:1): initialized
[    1.524476] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    1.535956] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.537643] ntfs: driver 2.1.32 [Flags: R/W].
[    1.538534] 9p: Installing v9fs 9p2000 file system support
[    1.545017] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.545246] io scheduler noop registered
[    1.545571] io scheduler cfq registered (default)
[    1.551209] gic 2a41000.agic-controller: GIC IRQ controller registered
[    1.588518] iommu: Adding device 2993000.adsp to group 59
[    1.708668] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[    1.709790] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.726169] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.726775] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.727499] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.728069] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.732002] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.732403] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[    1.732476] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=6666665, max_bw=6666665
[    1.735603] tsec 15500000.tsec: initialized
[    1.737763] tsec 15100000.tsecb: initialized
[    1.741903] nvdec 15480000.nvdec: initialized
[    1.744998] nvdec 15140000.nvdec1: initialized
[    1.751428] falcon 15340000.vic: initialized
[    1.753938] falcon 15380000.nvjpg: initialized
[    1.756450] falcon 154c0000.nvenc: initialized
[    1.758785] falcon 15a80000.nvenc1: initialized
[    1.763126] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    1.765308] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    1.767405] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    1.769545] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    1.771572] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    1.773717] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    1.775642] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    1.777563] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    1.781709] t194-nvcsi 15a00000.nvcsi: initialized
[    1.787337] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    1.787785] scare-pigeon 14b00000.isp-thi: initialized
[    1.797839] pva 16000000.pva0: initialized
[    1.828352] pva 16800000.pva1: initialized
[    1.858788] nvdla 15880000.nvdla0: initialized
[    1.889379] nvdla 158c0000.nvdla1: initialized
[    1.891070] tegradccommon 15200000.dc_common: host1x channel mapped
[    1.891124] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    1.891259] tegradccommon 15200000.dc_common: dma mapping done
[    1.891977] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[    1.892073] generic_infoframe_type: 0x87
[    1.892207] tegradc 15200000.nvdisplay: DT parsed successfully
[    1.892333] tegradc 15200000.nvdisplay: Display dc.ffffff800c690000 registered with id=0
[    1.896564] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    1.896621] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[    1.896661] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[    1.896952] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    1.896993] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    1.900136] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[    1.900190] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    1.904137] tegradc 15200000.nvdisplay: probed
[    1.905029] Console: switching to colour frame buffer device 80x30
[    1.905116] tegradc 15200000.nvdisplay: fb registered
[    1.905488] gpio tegra-gpio wake71 for gpio=98(M:2)
[    1.906067] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[    1.906431] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[    1.906778] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=84
[    1.906834] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    1.907165] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    1.907395] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    1.907536] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    1.907573] tegra_cec 3960000.tegra_cec: probed
[    1.918355] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    1.919118] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    1.919159] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    1.919535] kfuse 3830000.kfuse: initialized
[    1.927108] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.930635] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 51, base_baud = 0) is a TEGRA_UART
[    1.931953] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 52, base_baud = 0) is a TEGRA_UART
[    1.933057] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 53, base_baud = 0) is a TEGRA_UART
[    2.936390] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    2.936423] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    4.451358] console [ttyTCU0] enabled
[    4.455820] [drm] Initialized
[    4.473156] brd: module loaded
[    4.479881] loop: module loaded
[    4.480070] tegra_profiler: version: 1.145, samples/io: 49/28
[    4.480460] tegra_profiler: auth: init
[    4.481036] nct1008_nct72 4-004c: starting parse dt
[    4.481308] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[    4.481397] THERMAL EST: found 3 subdevs
[    4.481403] THERMAL EST num_resources: 0
[    4.481410] [THERMAL EST subdev 0]
[    4.481417] [THERMAL EST subdev 1]
[    4.481422] [THERMAL EST subdev 2]
[    4.481433] THERMAL EST: Found 2 profiles, default profile is quiet
[    4.481803] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    4.481807] THERMAL EST: thz register success.
[    4.482010] THERMAL EST: end of probe, return err: 0
[    4.482847] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[    4.482859] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    4.483630] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 460
[    4.483643] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[    4.494828] sd: No Scsi addr parsed to reserve index
[    4.494860] hisi_sas: driver version v1.6
[    4.505384] libphy: Fixed MDIO Bus: probed
[    4.506143] tun: Universal TUN/TAP device driver, 1.6
[    4.506147] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.507846] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.507852] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.507897] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    4.507901] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.507956] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.507960] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.508012] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    4.508015] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    4.519427] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    4.520048] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3a a5 51
[    4.520066] Using phyrst_lpmode = 1 from DT
[    4.520193] libphy: dwc_phy: probed
[    4.523225] PPP generic driver version 2.4.2
[    4.523478] PPP BSD Compression module registered
[    4.523485] PPP Deflate Compression module registered
[    4.523504] PPP MPPE Compression module registered
[    4.523511] NET: Registered protocol family 24
[    4.523599] usbcore: registered new interface driver r8152
[    4.523657] usbcore: registered new interface driver asix
[    4.523721] usbcore: registered new interface driver ax88179_178a
[    4.523757] usbcore: registered new interface driver cdc_ether
[    4.523792] usbcore: registered new interface driver net1080
[    4.523827] usbcore: registered new interface driver cdc_subset
[    4.523862] usbcore: registered new interface driver zaurus
[    4.523910] usbcore: registered new interface driver cdc_ncm
[    4.524192] VFIO - User Level meta-driver version: 0.3
[    4.526569] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.526588] ehci-pci: EHCI PCI platform driver
[    4.526625] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.526635] ohci-pci: OHCI PCI platform driver
[    4.526706] ohci-platform: OHCI generic platform driver
[    4.532144] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    4.532151] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[    4.535328] Could not get extcon-dev /xhci@3610000:id(0)
[    4.538864] usbcore: registered new interface driver uas
[    4.538928] usbcore: registered new interface driver usb-storage
[    4.539045] usbcore: registered new interface driver usbserial
[    4.542615] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    4.542655] Could not get extcon-dev /xudc@3550000:vbus(0)
[    4.545939] ucsi_ccg 1-0008: FW1 Version: gn v12.06, [Base 3.1.2.1487]
[    4.545951] ucsi_ccg 1-0008: FW2 Version: gn v12.06, [Base 3.1.2.1487]
[    4.547064] ucsi_ccg 1-0008: fw_mode: 2
[    4.547070] ucsi_ccg 1-0008: fw1_invalid: 0
[    4.547075] ucsi_ccg 1-0008: fw2_invalid: 0
[    4.547082] ucsi_ccg 1-0008: silicon_id: 0x1f00
[    4.547251] ucsi_ccg 1-0008: typec-port0 extcon dev created
[    4.547429] ucsi_ccg 1-0008: typec-port1 extcon dev created
[    4.547570] ucsi_ccg 1-0008: typec-pd extcon dev created
[    4.547764] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[    4.550091] ucsi_ccg 1-0008: dev event code: 0x80, data len: 0
[    4.551243] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:2
[    4.551701] ucsi_ccg 1-0008: CCG reset complete
[    4.554477] ucsi_ccg 1-0008: FW1 Version: gn v12.06, [Base 3.1.2.1487]
[    4.554487] ucsi_ccg 1-0008: FW2 Version: gn v12.06, [Base 3.1.2.1487]
[    4.556447] ucsi_ccg 1-0008: fw_mode: 2
[    4.556453] ucsi_ccg 1-0008: fw1_invalid: 0
[    4.556458] ucsi_ccg 1-0008: fw2_invalid: 0
[    4.556463] ucsi_ccg 1-0008: silicon_id: 0x1f00
[    4.556469] ucsi_ccg 1-0008: Reset Complete.
[    4.559612] ucsi_ccg 1-0008: HPI Command Success.
[    4.562190] ucsi_ccg 1-0008: HPI Command Success.
[    4.562207] ucsi_ccg 1-0008: ucsi_ccg_init: complete
[    4.562867] mousedev: PS/2 mouse device common for all mice
[    4.562939] usbcore: registered new interface driver xpad
[    4.695639] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    4.697387] Wake73 for irq=42
[    4.698707] rtc rtc1: alarm rtc device
[    4.698723] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    4.698758] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    5.024370] nct1008_nct72 4-004c: success parsing dt
[    5.029292] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[    5.071066] nct1008_nct72 4-004c: LOC shutdown limit 107
[    5.071889] nct1008_nct72 4-004c: EXT shutdown limit 109
[    5.108671] nct1008_nct72 4-004c: initial LOC temp: 41000
[    5.109299] nct1008_nct72 4-004c: initial EXT temp: 52750
[    5.110412] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[    5.111433] nct1008_nct72 4-004c: nct1008_probe: initialized
[   17.263236] max77620-power max20024-power: Event recorder REG_NVERC : 0x44
[   17.271197] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[   17.271812] FAN dev name: pwm-fan
[   17.271965] FAN:gpio request success.
[   17.272051] FAN: can't find tach_gpio
[   17.272139] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[   17.272340] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[   17.272692] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[   17.272834] pwm_fan_driver pwm-fan: tach period: 1000
[   17.273575] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[   17.273733] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[   17.273894] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[   17.274036] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[   17.274188] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[   17.274327] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[   17.282117] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[   17.289638] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[   17.297510] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[   17.305236] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[   17.314141] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[   17.321290] device-mapper: uevent: version 1.0.3
[   17.325757] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[   17.347063] tegra194_cpufreq_probe: platform driver Initialization: pass
[   17.348549] cpuidle: Initializing cpuidle driver
[   17.349533] sdhci: Secure Digital Host Controller Interface driver
[   17.351807] sdhci: Copyright(c) Pierre Ossman
[   17.356282] sdhci-pltfm: SDHCI platform and OF driver helper
[   17.363191] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[   17.371204] CMDQ: cmdq_platfm_init successful
[   17.374204] sdhci-tegra 3400000.sdhci: Got CD GPIO
[   17.381849] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[   17.387403] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 255
[   17.395817] tegra-se-nvhost 15810000.se: initialized
[   17.398034] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[   17.403772] tegra-se-nvhost 15820000.se: initialized
[   17.409017] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[   17.414455] tegra-se-nvhost 15830000.se: initialized
[   17.419711] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[   17.420296] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[   17.435181] tegra-se-nvhost 15840000.se: initialized
[   17.440174] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[   17.440394] gpio tegra-gpio wake8 for gpio=55(G:7)
[   17.440450] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[   17.460820] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[   17.466152] hidraw: raw HID events driver (C) Jiri Kosina
[   17.473894] usbcore: registered new interface driver usbhid
[   17.477398] usbhid: USB HID core driver
[   17.486965] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[   17.489757] tegra_aon c1a0000.aon: tegra aon driver probe OK
[   17.495020] tegra186-aondbg aondbg: aondbg driver probe() OK
[   17.501029] denver_knobs_init:MTS_VERSION:54811859
[   17.502100] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[   17.512769] tegra19x_actmon d230000.actmon: in actmon_register()...
[   17.514118] mmc0: periodic cache flush enabled
[   17.514129] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[   17.514545] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[   17.514739] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[   17.514967] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[   17.515148] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[   17.519045]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35
[   17.566487] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[   17.574380] t19x_cache tegra-cache: probed
[   17.584725] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[   17.585625] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[   17.593984] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[   17.599557] PLL_AON clock registered
[   17.605531] Clocks initialized successfully
[   17.608540] nvpmodel: initialized successfully
[   17.612347] trusty-virtio trusty:virtio: initializing
[   17.616310] trusty_ipc virtio0: vring0: va(pa)  ffffffc7d75e2000(0) qsz 32 notifyid 1
[   17.624058] trusty_ipc virtio0: vring1: va(pa)  ffffffc7d75e4000(0) qsz 32 notifyid 2
[   17.631879] trusty-virtio trusty:virtio: initializing done
[   17.631986] trusty_ipc virtio0: is online
[   17.642218] usbcore: registered new interface driver snd-usb-audio
[   17.648210] tegra-hda 3510000.hda: Override SDO lines to 4
[   17.664870] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[   17.665230] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[   17.670812] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[   17.679748] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[   19.501813] gpio tegra-gpio wake12 for gpio=149(S:5)
[   19.594949] OPE platform probe
[   19.595179] OPE platform probe successful
[   19.725011] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[   19.725276] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[   19.725473] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[   19.725705] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[   19.725940] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[   19.726145] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[   19.726339] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[   19.726535] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[   19.726745] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[   19.726939] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[   19.727170] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[   19.727376] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[   19.727596] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[   19.727801] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[   19.728010] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[   19.728238] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[   19.728476] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[   19.733326] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[   19.739331] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[   19.745103] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[   19.761173] tegra-asoc: sound: ASoC: no sink widget found for z Headphone Jack
[   19.761352] tegra-asoc: sound: ASoC: Failed to add route z HPO L Playback -> direct -> z Headphone Jack
[   19.767725] tegra-asoc: sound: ASoC: no sink widget found for z Headphone Jack
[   19.775192] tegra-asoc: sound: ASoC: Failed to add route z HPO R Playback -> direct -> z Headphone Jack
[   19.784247] tegra-asoc: sound: ASoC: no source widget found for z Mic Jack
[   19.791482] tegra-asoc: sound: ASoC: Failed to add route z Mic Jack -> direct -> z IN1P
[   19.799563] tegra-asoc: sound: ASoC: no source widget found for z Mic Jack
[   19.806455] tegra-asoc: sound: ASoC: Failed to add route z Mic Jack -> direct -> z IN2P
[   19.814553] tegra-asoc: sound: ASoC: no sink widget found for z Int Spk
[   19.820975] tegra-asoc: sound: ASoC: Failed to add route z SPO Playback -> direct -> z Int Spk
[   19.829567] tegra-asoc: sound: ASoC: no source widget found for z Int Mic
[   19.836357] tegra-asoc: sound: ASoC: Failed to add route z Int Mic -> direct -> z DMIC L1
[   19.844718] tegra-asoc: sound: ASoC: no source widget found for z Int Mic
[   19.851776] tegra-asoc: sound: ASoC: Failed to add route z Int Mic -> direct -> z DMIC L2
[   19.860028] tegra-asoc: sound: ASoC: no source widget found for z Int Mic
[   19.866724] tegra-asoc: sound: ASoC: Failed to add route z Int Mic -> direct -> z DMIC R1
[   19.874986] tegra-asoc: sound: ASoC: no source widget found for z Int Mic
[   19.881417] tegra-asoc: sound: ASoC: Failed to add route z Int Mic -> direct -> z DMIC R2
[   19.912386] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[   19.913908] drop_monitor: Initializing network drop monitor service
[   19.914085] u32 classifier
[   19.914150]     Actions configured
[   19.914278] Initializing XFRM netlink socket
[   19.916134] NET: Registered protocol family 10
[   19.920923] NET: Registered protocol family 17
[   19.924652] NET: Registered protocol family 15
[   19.928973] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   19.941963] Bluetooth: RFCOMM socket layer initialized
[   19.947142] Bluetooth: RFCOMM ver 1.11
[   19.951068] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   19.956935] Bluetooth: HIDP socket layer initialized
[   19.961925] 9pnet: Installing 9P2000 support
[   19.966165] Key type dns_resolver registered
[   19.970936] Registered cp15_barrier emulation handler
[   19.975671] Registered setend emulation handler
[   19.981981] registered taskstats version 1
[   19.985100] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[   19.992747] OF: PCI: host bridge /pcie@14180000 ranges:
[   19.996757] OF: PCI:    IO 0x38100000..0x381fffff -> 0x38100000
[   20.002808] OF: PCI:   MEM 0x1b40000000..0x1bffffffff -> 0x40000000
[   20.008746] OF: PCI:   MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[   20.124321] tegra-pcie-dw 14180000.pcie: link is up
[   20.124727] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[   20.124854] pci_bus 0000:00: root bus resource [bus 00-ff]
[   20.124955] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[   20.125115] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[   20.125288] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[   20.125440] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[   20.125584] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[   20.125777] iommu: Adding device 0000:00:00.0 to group 61
[   20.126241] pci 0000:01:00.0: [144d:a808] type 00 class 0x010802
[   20.126365] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[   20.127364] iommu: Adding device 0000:01:00.0 to group 62
[   20.137217] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[   20.137378] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[   20.137597] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[   20.137699] pci 0000:00:00.0:   bridge window [mem 0x1b40000000-0x1b400fffff]
[   20.137836] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   20.138046] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[   20.138408] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[   20.140368] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[   20.147022] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[   20.147117] aer 0000:00:00.0:pcie002: service driver aer loaded
[   20.147496] nvme nvme0: pci function 0000:01:00.0
[   20.151697] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[   20.151916] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[   20.152775] OF: PCI: host bridge /pcie@14100000 ranges:
[   20.152793] OF: PCI:    IO 0x30100000..0x301fffff -> 0x30100000
[   20.152805] OF: PCI:   MEM 0x1230000000..0x123fffffff -> 0x40000000
[   20.152826] OF: PCI:   MEM 0x1200000000..0x122fffffff -> 0x1200000000
[   20.260329] tegra-pcie-dw 14100000.pcie: link is up
[   20.260714] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[   20.260873] pci_bus 0001:00: root bus resource [bus 00-ff]
[   20.260986] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[   20.261163] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[   20.261336] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[   20.261487] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[   20.261645] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[   20.261832] iommu: Adding device 0001:00:00.0 to group 63
[   20.262301] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[   20.262411] pci 0001:01:00.0: reg 0x10: [io  0x8000-0x8007]
[   20.262491] pci 0001:01:00.0: reg 0x14: [io  0x8040-0x8043]
[   20.262556] pci 0001:01:00.0: reg 0x18: [io  0x8100-0x8107]
[   20.262620] pci 0001:01:00.0: reg 0x1c: [io  0x8140-0x8143]
[   20.262684] pci 0001:01:00.0: reg 0x20: [io  0x800000-0x80000f]
[   20.262748] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[   20.262813] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[   20.263164] pci 0001:01:00.0: PME# supported from D3hot
[   20.263380] iommu: Adding device 0001:01:00.0 to group 64
[   20.273129] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[   20.273276] pci 0001:00:00.0: BAR 13: assigned [io  0x100000-0x100fff]
[   20.273393] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[   20.273531] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[   20.273732] pci 0001:01:00.0: BAR 4: assigned [io  0x100000-0x10000f]
[   20.279385] pci 0001:01:00.0: BAR 0: assigned [io  0x100010-0x100017]
[   20.285840] pci 0001:01:00.0: BAR 2: assigned [io  0x100018-0x10001f]
[   20.291987] pci 0001:01:00.0: BAR 1: assigned [io  0x100020-0x100023]
[   20.298561] pci 0001:01:00.0: BAR 3: assigned [io  0x100024-0x100027]
[   20.305149] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[   20.310301] pci 0001:00:00.0:   bridge window [io  0x100000-0x100fff]
[   20.316523] pci 0001:00:00.0:   bridge window [mem 0x1230000000-0x12300fffff]
[   20.324057] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   20.332885] pci 0001:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[   20.341269] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[   20.348194] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[   20.354667] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[   20.354773] aer 0001:00:00.0:pcie002: service driver aer loaded
[   20.355255] ahci 0001:01:00.0: version 3.0
[   20.355733] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[   20.362747] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[   20.371598] scsi host1: ahci
[   20.373800] ata1: SATA max UDMA/133 abar m512@0x1230010000 port 0x1230010100 irq 820
[   20.381214]  nvme0n1: p1 p2
[   20.381344] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[   20.382152] OF: PCI: host bridge /pcie@14140000 ranges:
[   20.382168] OF: PCI:    IO 0x34100000..0x341fffff -> 0x34100000
[   20.382176] OF: PCI:   MEM 0x12b0000000..0x12bfffffff -> 0x40000000
[   20.382183] OF: PCI:   MEM 0x1280000000..0x12afffffff -> 0x1280000000
[   20.492343] tegra-pcie-dw 14140000.pcie: link is up
[   20.492733] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[   20.492879] pci_bus 0003:00: root bus resource [bus 00-ff]
[   20.492989] pci_bus 0003:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[   20.493153] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[   20.493326] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[   20.493479] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[   20.493632] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[   20.493812] iommu: Adding device 0003:00:00.0 to group 65
[   20.494302] pci 0003:01:00.0: [8086:2723] type 00 class 0x028000
[   20.494438] pci 0003:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[   20.495139] pci 0003:01:00.0: PME# supported from D0 D3hot D3cold
[   20.495412] iommu: Adding device 0003:01:00.0 to group 66
[   20.505193] pci 0003:00:00.0: BAR 14: assigned [mem 0x12b0000000-0x12b00fffff]
[   20.505332] pci 0003:01:00.0: BAR 0: assigned [mem 0x12b0000000-0x12b0003fff 64bit]
[   20.505552] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[   20.505657] pci 0003:00:00.0:   bridge window [mem 0x12b0000000-0x12b00fffff]
[   20.505814] pci 0003:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[   20.507102] pci 0003:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  128
[   20.516106] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[   20.522570] pci 0003:01:00.0: Signaling PME through PCIe PME interrupt
[   20.529223] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[   20.529309] aer 0003:00:00.0:pcie002: service driver aer loaded
[   20.529978] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[   20.644615] OF: PCI: host bridge /pcie@141a0000 ranges:
[   20.644755] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[   20.644861] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[   20.644969] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[   20.695788] ata1: SATA link down (SStatus 0 SControl 300)
[   21.157668] tegra-pcie-dw 141a0000.pcie: link is down
[   21.157987] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[   21.158110] pci_bus 0005:00: root bus resource [bus 00-ff]
[   21.158208] pci_bus 0005:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[   21.158386] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[   21.158555] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[   21.158702] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[   21.158858] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[   21.159017] iommu: Adding device 0005:00:00.0 to group 67
[   21.159475] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[   21.159583] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[   21.159932] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[   21.160052] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[   21.160164] aer 0005:00:00.0:pcie002: service driver aer loaded
[   21.160362] pcie_pme 0005:00:00.0:pcie001: unloading service driver pcie_pme
[   21.160414] aer 0005:00:00.0:pcie002: unloading service driver aer
[   21.160494] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[   21.160596] iommu: Removing device 0005:00:00.0 from group 67
[   21.160752] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[   21.162835] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[   21.176509] tegra-cbb 14040000.cv-noc: noc_secure_irq = 99, noc_nonsecure_irq = 98>
[   21.182218] tegra194-isp5 14800000.isp: initialized
[   21.187959] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[   21.190955] tegra194-vi5 15c10000.vi: initialized
[   21.276533] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[   21.277783] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[   21.277787] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[   21.280398] tegra-xusb 3610000.xhci: extcon 0: ffffffc7d79b9000 id
[   21.280772] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[   21.280792] tegra-xudc-new 3550000.xudc: device count: 1
[   21.281581] tegra-xudc-new 3550000.xudc: vbus state: 0
[   21.281588] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[   21.281709] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[   21.281785] tegra-xudc-new 3550000.xudc: entering ELPG
[   21.282009] tegra-xudc-new 3550000.xudc: entering ELPG done
[   21.283070] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[   21.283102] tegra-xusb 3610000.xhci: xHCI Host Controller
[   21.283114] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[   21.283772] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[   21.283799] tegra-xusb 3610000.xhci: irq 473, io mem 0x03610000
[   21.283974] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   21.283978] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   21.283981] usb usb1: Product: xHCI Host Controller
[   21.283984] usb usb1: Manufacturer: Linux 4.9.253-l4t-r32.7+gac2a37e8219a xhci-hcd
[   21.283987] usb usb1: SerialNumber: 3610000.xhci
[   21.284294] hub 1-0:1.0: USB hub found
[   21.284325] hub 1-0:1.0: 4 ports detected
[   21.284635] tegra-xusb 3610000.xhci: xHCI Host Controller
[   21.284642] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[   21.284648] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[   21.284803] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[   21.284807] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   21.284810] usb usb2: Product: xHCI Host Controller
[   21.284813] usb usb2: Manufacturer: Linux 4.9.253-l4t-r32.7+gac2a37e8219a xhci-hcd
[   21.284815] usb usb2: SerialNumber: 3610000.xhci
[   21.285028] hub 2-0:1.0: USB hub found
[   21.285053] hub 2-0:1.0: 4 ports detected
[   21.285641] Wake76 for irq=199
[   21.285644] Wake77 for irq=199
[   21.285646] Wake78 for irq=199
[   21.285648] Wake79 for irq=199
[   21.285650] Wake80 for irq=199
[   21.285652] Wake81 for irq=199
[   21.285654] Wake82 for irq=199
[   21.285698] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[   21.285702] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[   21.336572] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[   21.336589] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[   21.336593] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[   21.336647] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[   21.336676] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[   21.336679] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[   21.392614] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[   21.392656] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[   21.392660] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[   21.393181] usb usb2: usb_suspend_both: status 0
[   21.393203] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[   21.393234] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[   21.393237] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[   21.393680] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[   21.393715] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[   21.393718] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[   21.394039] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[   21.394735] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[   21.466918] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[   21.467178] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   21.467334] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[   21.467445] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[   21.467840] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[   21.467971] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[   21.468214] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (70)
[   21.468217] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[   21.468987] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=1d7bd17f78528535d57449fa59ec355e37add4f8
[   21.469313] Wake83 for irq=211
[   21.469380] gpio tegra-gpio wake67 for gpio=48(G:0)
[   21.469477] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[   21.469621] input: gpio-keys as /devices/gpio-keys/input/input5
[   21.504808] tegra_rtc c2a0000.rtc: setting system clock to 2023-07-29 20:54:33 UTC (1690664073)
[   21.505234] mmcblk mmc0:0001: Card claimed for testing.
[   21.548877] bpmp: mounted debugfs mirror
[   21.554720] ALSA device list:
[   21.554724]   #0: tegra-hda-galen-t194 at 0x3518000 irq 69
[   21.554727]   #1: tegra-snd-t19x-mobile-rt565x
[   21.800886] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[   21.808335] tegradc 15210000.nvdisplay: DT parsed successfully
[   21.814587] tegradc 15210000.nvdisplay: Display dc.ffffff8010d10000 registered with id=1
[   21.822546] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[   21.828643] tegradc 15210000.nvdisplay: vpulse3 syncpt # 15 for dc 1
[   21.842999] tegradc 15210000.nvdisplay: probed
[   21.843267] tegradc 15210000.nvdisplay: fb registered
[   21.848018] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[   21.851834] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[   21.852400] tegradc 15220000.nvdisplay: disp2 connected to head2->/host1x/sor1
[   21.852417] tegradc 15220000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[   21.852470] tegradc 15220000.nvdisplay: DT parsed successfully
[   21.852498] tegradc 15220000.nvdisplay: Display dc.ffffff8010e90000 registered with id=2
[   21.852626] tegradc 15220000.nvdisplay: vblank syncpt # 16 for dc 2
[   21.852630] tegradc 15220000.nvdisplay: vpulse3 syncpt # 17 for dc 2
[   21.901306] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[   21.906634] tegradc 15210000.nvdisplay: blank - powerdown
[   21.911704] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[   21.919926] Extcon DP: HPD disabled
[   21.923853] hpd: hpd_switch 0
[   21.927018] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[   21.933490] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[   21.939787] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[   21.940931] tegradc 15220000.nvdisplay: probed
[   21.951104] tegradc 15220000.nvdisplay: fb registered
[   21.959865] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[   21.963670] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[   21.967540] Freeing unused kernel memory: 14016K
[   21.976112] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[   21.981306] tegradc 15220000.nvdisplay: blank - powerdown
[   21.986794] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[   21.994881] Extcon DP: HPD disabled
[   21.998522] hpd: hpd_switch 0
[   22.001750] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[   22.008493] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[   22.014347] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[   22.364580] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[   22.385308] usb 2-3: New USB device found, idVendor=14b0, idProduct=0208
[   22.385459] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[   22.385580] usb 2-3: Product: SSD 870 QVO 8TB
[   22.385667] usb 2-3: Manufacturer: Samsung
[   22.385757] usb 2-3: SerialNumber: 123456494A81
[   22.391311] scsi host2: uas
[   22.396472] scsi 2:0:0:0: Direct-Access     Samsung  SSD 870 QVO 8TB  0    PQ: 0 ANSI: 6
[   22.410361] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[   22.410950] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[   22.426699] EXT4-fs (mmcblk0p1): recovery complete
[   22.427531] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   22.430316] platform_update: Checking for pending platform update
[   22.448649] sd 2:0:0:0: [sda] 15628053168 512-byte logical blocks: (8.00 TB/7.28 TiB)
[   22.453535] sd 2:0:0:0: [sda] Write Protect is off
[   22.453650] sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
[   22.455542] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[   22.457415] sd 2:0:0:0: [sda] Optimal transfer size 33553920 bytes
[   22.471726]  sda: sda1 sda2
[   22.473849] sd 2:0:0:0: [sda] Attached SCSI disk
[   22.508321] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[   22.531007] usb 1-3: New USB device found, idVendor=8087, idProduct=0029
[   22.531162] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   22.721166] EXT4-fs (nvme0n1p2): couldn't mount as ext3 due to feature incompatibilities
[   22.721496] EXT4-fs (nvme0n1p2): couldn't mount as ext2 due to feature incompatibilities
[   22.796352] usb 1-4: new high-speed USB device number 4 using tegra-xusb
[   22.801380] EXT4-fs (nvme0n1p2): recovery complete
[   22.809470] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[   22.810058] platform_update: Mounting /dev/nvme0n1p2 on /.nvme_external
[   22.817000] usb 1-4: config 1 interface 0 altsetting 0 bulk endpoint 0x1 has invalid maxpacket 64
[   22.817179] usb 1-4: config 1 interface 0 altsetting 0 bulk endpoint 0x81 has invalid maxpacket 64
[   22.817889] usb 1-4: New USB device found, idVendor=1199, idProduct=9070
[   22.818006] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   22.818134] usb 1-4: Product: EM7455
[   22.818207] usb 1-4: Manufacturer: Sierra Wireless, Incorporated
[   22.862525] platform-pre-switchroot: no APP_b partition detected, booting without rootfs overlay
[   22.872128] EXT4-fs (nvme0n1p1): couldn't mount as ext3 due to feature incompatibilities
[   22.872541] EXT4-fs (nvme0n1p1): couldn't mount as ext2 due to feature incompatibilities
[   22.883344] EXT4-fs (nvme0n1p1): recovery complete
[   22.883462] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[   22.883901] platform-pre-switchroot: Mounting /dev/nvme0n1p1 on /mnt/.nvme_sync
[   22.891940] EXT4-fs (nvme0n1p2): couldn't mount as ext3 due to feature incompatibilities
[   22.892307] EXT4-fs (nvme0n1p2): couldn't mount as ext2 due to feature incompatibilities
[   22.939560] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[   22.940199] platform-pre-switchroot: Mounting /dev/nvme0n1p2 on /mnt/.nvme_external
[   22.964466] usb 1-4: USB disconnect, device number 4
[   22.989693] EXT4-fs (sda1): couldn't mount as ext3 due to feature incompatibilities
[   22.990217] EXT4-fs (sda1): couldn't mount as ext2 due to feature incompatibilities
[   23.192413] EXT4-fs (sda1): recovery complete
[   23.193929] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   23.194540] platform-pre-switchroot: Mounting /dev/sda1 on /mnt/.sata_logs
[   23.222724] EXT4-fs (sda2): couldn't mount as ext3 due to feature incompatibilities
[   23.223258] EXT4-fs (sda2): couldn't mount as ext2 due to feature incompatibilities
[   23.465494] EXT4-fs (sda2): recovery complete
[   23.465645] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[   23.466323] platform-pre-switchroot: Mounting /dev/sda2 on /mnt/.sata_sync
[   23.749441] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[   23.750050] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[   23.753607] EXT4-fs (mmcblk0p2): recovery complete
[   23.753724] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   23.754180] platform-pre-switchroot: Mounting /dev/mmcblk0p2 on /mnt/.mmc_data
[   23.842621] random: crng init done
[   24.049647] EXT4-fs (mmcblk0p3): couldn't mount as ext3 due to feature incompatibilities
[   24.050241] EXT4-fs (mmcblk0p3): couldn't mount as ext2 due to feature incompatibilities
[   24.057660] EXT4-fs (mmcblk0p3): recovery complete
[   24.058692] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[   24.059182] platform-pre-switchroot: Mounting /dev/mmcblk0p3 on /mnt/.mmc_config
[   24.296401] udevd[2494]: starting version 3.2.10
[   24.340438] udevd[2495]: starting eudev-3.2.10
[   24.447072] compat: loading out-of-tree module taints kernel.
[   24.451287] Loading modules backported from iwlwifi
[   24.451436] iwlwifi-stack-public:release/core52:8470:f4c7b3b5
[   24.496878] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   24.499517] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   24.505517] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   24.505740] cfg80211: failed to load regulatory.db
[   24.506205] cpu-throttle-alert cooling device registered.
[   24.506585] gpu-throttle-alert cooling device registered.
[   24.506971] aux-throttle-alert cooling device registered.
[   24.528679] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:289  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[   24.538506] Intel(R) Wireless WiFi driver for Linux
[   24.538652] Copyright(c) 2003- 2015 Intel Corporation
[   24.538983] iwlwifi 0003:01:00.0: enabling device (0000 -> 0002)
[   24.547410] iwlwifi 0003:01:00.0: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
[   24.587631] iwlwifi 0003:01:00.0: api flags index 2 larger than supported by driver
[   24.587907] iwlwifi 0003:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[   24.588057] iwlwifi 0003:01:00.0: Found debug destination: EXTERNAL_DRAM
[   24.588169] iwlwifi 0003:01:00.0: Found debug configuration: 0
[   24.588868] iwlwifi 0003:01:00.0: loaded firmware version 55.d9698065.0 cc-a0-55.ucode op_mode iwlmvm
[   24.589097] iwlwifi 0003:01:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[   24.612490] CAN device driver interface
[   24.744453] Release 3.2.0 from 19.12.2014
[   24.749011] net can0: mttcan device registered (regs=ffffff800e20c000, irq=67)
[   24.758401] 	 Message RAM Configuration
               	| base addr   |0x0c322000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
[   24.794085] Release 3.2.0 from 19.12.2014
[   24.798275] net can1: mttcan device registered (regs=ffffff800e23e000, irq=68)
[   24.840482] iwlwifi 0003:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   24.859065] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   24.879412] usb 1-3: USB disconnect, device number 3
[   25.025843] iwlwifi 0003:01:00.0: base HW address: dc:71:96:a2:87:cb
[   25.032370] usb usb1: usb_suspend_both: status 0
[   25.043438] thermal thermal_zone8: failed to read out thermal zone (-61)
[   25.043589] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type iwlwifi_1
[   26.141244] gpio tegra-gpio wake20 for gpio=52(G:4)
[   26.144414] net eth0: get_configure_l3v4_filter -->
[   26.145675] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   26.441872] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   26.445113] Bluetooth: BNEP socket layer initialized
[   26.623431] tegradc 15200000.nvdisplay: blank - powerdown
[   26.623573] tegradc 15210000.nvdisplay: blank - powerdown
[   26.623668] tegradc 15220000.nvdisplay: blank - powerdown
[   27.067188] tegradc 15200000.nvdisplay: blank - powerdown
[   27.067320] tegradc 15210000.nvdisplay: blank - powerdown
[   27.067413] tegradc 15220000.nvdisplay: blank - powerdown
[   27.072485] tegradc 15200000.nvdisplay: blank - powerdown
[   29.250337] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   29.251117] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   31.696067] usb 1-4: new high-speed USB device number 5 using tegra-xusb
[   31.716660] usb 1-4: config 1 has an invalid interface number: 12 but max is 4
[   31.716816] usb 1-4: config 1 has an invalid interface number: 13 but max is 4
[   31.716963] usb 1-4: config 1 has an invalid interface number: 13 but max is 4
[   31.717086] usb 1-4: config 1 has no interface number 1
[   31.717172] usb 1-4: config 1 has no interface number 4
[   31.717676] usb 1-4: New USB device found, idVendor=1199, idProduct=9071
[   31.717805] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   31.717923] usb 1-4: Product: EM7455
[   31.717987] usb 1-4: Manufacturer: Sierra Wireless, Incorporated
[   31.726652] usbcore: registered new interface driver cdc_wdm
[   31.728123] usbcore: registered new interface driver qcserial
[   52.631126] vdd-1v8-sd: disabling
[   52.631244] vdd-epb-1v0: disabling
[   52.631309] avdd-cam-2v8: disabling
[   52.631395] vdd-sata-1v5: disabling
[   52.631460] vdd-1v8-slt: disabling
[   52.631522] vdd-3v3-slt: disabling
[   52.631583] vdd-fan: disabling
[   52.631640] vdd_sys_en: disabling
[   52.631724] vdd-3v3-pcie: disabling
[   52.631792] vdd-12v-pcie: disabling
[   56.568851] ip_tables: (C) 2000-2006 Netfilter Core Team
[   56.594023] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
dmesg from 35.1.0:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[    0.000000] Linux version 5.10.104-l4t-r35.1+gc7f946aacc63 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Sun Oct 2 11:31:33 UTC 2022
[    0.000000] Machine model: Jetson-AGX
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x859c59498 SMBIOS=0xc7db0000 SMBIOS 3.0=0x87c240000 MEMATTR=0x858dd2018 ESRT=0x85811e518 RNG=0x87c286f18 MEMRESERVE=0x858dd7f18
[    0.000000] efi: seeding entropy pool
[    0.000000] esrt: Reserving ESRT space from 0x000000085811e518 to 0x000000085811e550.
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000087fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af010000-0x00000000c7bfffff]
[    0.000000]   node   0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[    0.000000]   node   0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[    0.000000]   node   0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x0000000858346fff]
[    0.000000]   node   0: [mem 0x0000000858347000-0x000000085854afff]
[    0.000000]   node   0: [mem 0x000000085854b000-0x00000008587dffff]
[    0.000000]   node   0: [mem 0x00000008587e0000-0x00000008587effff]
[    0.000000]   node   0: [mem 0x00000008587f0000-0x0000000858d8ffff]
[    0.000000]   node   0: [mem 0x0000000858d90000-0x0000000858dbffff]
[    0.000000]   node   0: [mem 0x0000000858dc0000-0x0000000858ddffff]
[    0.000000]   node   0: [mem 0x0000000858de0000-0x0000000858dfffff]
[    0.000000]   node   0: [mem 0x0000000858e00000-0x0000000858eaffff]
[    0.000000]   node   0: [mem 0x0000000858eb0000-0x000000085901ffff]
[    0.000000]   node   0: [mem 0x0000000859020000-0x000000085912ffff]
[    0.000000]   node   0: [mem 0x0000000859130000-0x000000085923ffff]
[    0.000000]   node   0: [mem 0x0000000859240000-0x000000085925ffff]
[    0.000000]   node   0: [mem 0x0000000859260000-0x000000085934ffff]
[    0.000000]   node   0: [mem 0x0000000859350000-0x000000085937ffff]
[    0.000000]   node   0: [mem 0x0000000859380000-0x000000085941ffff]
[    0.000000]   node   0: [mem 0x0000000859420000-0x000000085946ffff]
[    0.000000]   node   0: [mem 0x0000000859470000-0x000000085964ffff]
[    0.000000]   node   0: [mem 0x0000000859650000-0x000000085967ffff]
[    0.000000]   node   0: [mem 0x0000000859680000-0x00000008596cffff]
[    0.000000]   node   0: [mem 0x00000008596d0000-0x00000008596dffff]
[    0.000000]   node   0: [mem 0x00000008596e0000-0x000000085970ffff]
[    0.000000]   node   0: [mem 0x0000000859710000-0x0000000859bcffff]
[    0.000000]   node   0: [mem 0x0000000859bd0000-0x0000000859c1ffff]
[    0.000000]   node   0: [mem 0x0000000859c20000-0x0000000859c2ffff]
[    0.000000]   node   0: [mem 0x0000000859c30000-0x0000000859c4ffff]
[    0.000000]   node   0: [mem 0x0000000859c50000-0x0000000859ebffff]
[    0.000000]   node   0: [mem 0x0000000859ec0000-0x0000000859f5ffff]
[    0.000000]   node   0: [mem 0x0000000859f60000-0x000000085a00ffff]
[    0.000000]   node   0: [mem 0x000000085a010000-0x000000085a0affff]
[    0.000000]   node   0: [mem 0x000000085a0b0000-0x000000085a13ffff]
[    0.000000]   node   0: [mem 0x000000085a140000-0x000000085a1dffff]
[    0.000000]   node   0: [mem 0x000000085a1e0000-0x000000085aaaffff]
[    0.000000]   node   0: [mem 0x000000085aab0000-0x000000085ac8ffff]
[    0.000000]   node   0: [mem 0x000000085ac90000-0x000000087c23ffff]
[    0.000000]   node   0: [mem 0x000000087c240000-0x000000087c28ffff]
[    0.000000]   node   0: [mem 0x000000087c290000-0x000000087fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[    0.000000] On node 0 totalpages: 8159920
[    0.000000]   DMA zone: 4619 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 295600 pages, LIFO batch:63
[    0.000000]   Normal zone: 122880 pages used for memmap
[    0.000000]   Normal zone: 7864320 pages, LIFO batch:63
[    0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] pcpu-alloc: s90392 r8192 d32488 u131072 alloc=32*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8032421
[    0.000000] Kernel command line: mminit_loglevel=4 console=tty0 console=ttyTCU0,115200 fbcon=map:0 sdhci_tegra.en_boot_part_access=1
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[    0.000000] Memory: 31680644K/32639680K available (18048K kernel code, 3144K rwdata, 7084K rodata, 3904K init, 1095K bss, 893500K reserved, 65536K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x49c with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000565] Console: colour dummy device 80x25
[    0.001891] printk: console [tty0] enabled
[    0.001963] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.001995] pid_max: default: 32768 minimum: 301
[    0.002153] LSM: Security Framework initializing
[    0.002213] Yama: becoming mindful.
[    0.002250] SELinux:  Initializing.
[    0.002413] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002490] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.005252] rcu: Hierarchical SRCU implementation.
[    0.005504] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.006024] DTS File Name: tegra194-p2888-0001-p2822-0000.dts
[    0.006049] DTB Build time: Oct  2 2022 11:31:33
[    0.008178] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.008419] Remapping and enabling EFI services.
[    0.009769] smp: Bringing up secondary CPUs ...
[    0.042919] Detected PIPT I-cache on CPU1
[    0.043016] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[    0.072455] Detected PIPT I-cache on CPU2
[    0.072552] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[    0.102048] Detected PIPT I-cache on CPU3
[    0.102139] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[    0.131716] Detected PIPT I-cache on CPU4
[    0.131886] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[    0.161533] Detected PIPT I-cache on CPU5
[    0.161664] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[    0.191342] Detected PIPT I-cache on CPU6
[    0.191523] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[    0.222122] Detected PIPT I-cache on CPU7
[    0.222210] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[    0.222664] smp: Brought up 1 node, 8 CPUs
[    0.222928] SMP: Total of 8 processors activated.
[    0.222968] CPU features: detected: Privileged Access Never
[    0.222986] CPU features: detected: LSE atomic instructions
[    0.222998] CPU features: detected: User Access Override
[    0.223010] CPU features: detected: 32-bit EL0 Support
[    0.223021] CPU features: detected: RAS Extension Support
[    0.223032] CPU features: detected: CRC32 instructions
[    0.223044] CPU features: detected: 32-bit EL1 Support
[    0.281732] CPU: All CPU(s) started at EL2
[    0.292533] devtmpfs: initialized
[    0.329781] Registered cp15_barrier emulation handler
[    0.329887] Registered setend emulation handler
[    0.329912] KASLR enabled
[    0.330128] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.330159] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.331311] pinctrl core: initialized pinctrl subsystem
[    0.332272] SMBIOS 3.0.0 present.
[    0.332292] DMI: Unknown Jetson-AGX/Jetson-AGX, BIOS 1.0-d7fb19b 08/10/2022
[    0.332838] NET: Registered protocol family 16
[    0.335203] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.336736] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.338278] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.338333] audit: initializing netlink subsys (disabled)
[    0.338590] audit: type=2000 audit(0.336:1): state=initialized audit_enabled=0 res=1
[    0.339007] thermal_sys: Registered thermal governor 'step_wise'
[    0.339013] thermal_sys: Registered thermal governor 'power_allocator'
[    0.339028] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.341001] cpuidle: using governor menu
[    0.341315] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.341834] ASID allocator initialised with 32768 entries
[    0.342039] Serial: AMBA PL011 UART driver
[    0.344855] Tegra reboot handler registered.
[    0.414033] tegra19x-cbb 2300000.cbb-noc: axi2apb bridge info present
[    0.414384] tegra19x-cbb 2300000.cbb-noc: secure_irq = 15, nonsecure_irq = 14>
[    0.414592] tegra19x-cbb c600000.aon-noc: axi2apb bridge info present
[    0.414644] tegra19x-cbb c600000.aon-noc: secure_irq = 17, nonsecure_irq = 16>
[    0.414751] tegra19x-cbb d600000.bpmp-noc: axi2apb bridge info present
[    0.414799] tegra19x-cbb d600000.bpmp-noc: secure_irq = 19, nonsecure_irq = 18>
[    0.414904] tegra19x-cbb be00000.rce-noc: axi2apb bridge info present
[    0.414953] tegra19x-cbb be00000.rce-noc: secure_irq = 21, nonsecure_irq = 20>
[    0.415073] tegra19x-cbb b600000.sce-noc: axi2apb bridge info present
[    0.415121] tegra19x-cbb b600000.sce-noc: secure_irq = 23, nonsecure_irq = 22>
[    0.417301] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[    0.417334] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[    0.417361] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[    0.417386] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[    0.417427] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[    0.417452] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[    0.417479] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[    0.417502] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[    0.417531] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[    0.417556] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[    0.417579] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[    0.417601] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[    0.417624] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[    0.417646] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[    0.417668] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[    0.417690] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[    0.417712] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[    0.417795] mc-err: mcerr ops are set to t19x
[    0.429894] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.429914] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.429925] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.429935] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.436076] ACPI: Interpreter disabled.
[    0.436915] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    0.438798] iommu: Default domain type: Translated
[    0.438866] eventlib_kernel: keventlib is initialized, test id: 0
[    0.439261] SCSI subsystem initialized
[    0.439423] usbcore: registered new interface driver usbfs
[    0.439467] usbcore: registered new interface driver hub
[    0.439511] usbcore: registered new device driver usb
[    0.439891] mc: Linux media interface: v0.10
[    0.439933] videodev: Linux video capture interface: v2.00
[    0.440205] pps_core: LinuxPPS API ver. 1 registered
[    0.440215] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.440233] PTP clock support registered
[    0.440416] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.440692] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.440766] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.441295] Registered efivars operations
[    0.441615] FPGA manager framework
[    0.441680] Advanced Linux Sound Architecture Driver Initialized.
[    0.442361] Bluetooth: Core ver 2.22
[    0.442394] NET: Registered protocol family 31
[    0.442404] Bluetooth: HCI device and connection manager initialized
[    0.442416] Bluetooth: HCI socket layer initialized
[    0.442430] Bluetooth: L2CAP socket layer initialized
[    0.442448] Bluetooth: SCO socket layer initialized
[    0.443706] camchar: rtcpu character device driver loaded
[    0.444403] clocksource: Switched to clocksource arch_sys_counter
[    0.698554] VFS: Disk quotas dquot_6.6.0
[    0.698620] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.698924] pnp: PnP ACPI: disabled
[    0.711973] la/ptsa driver initialized.
[    0.712101] NET: Registered protocol family 2
[    0.712354] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.720685] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.720916] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.721689] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.722033] TCP: Hash tables configured (established 262144 bind 65536)
[    0.722172] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.722431] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.722788] NET: Registered protocol family 1
[    0.723419] RPC: Registered named UNIX socket transport module.
[    0.723433] RPC: Registered udp transport module.
[    0.723442] RPC: Registered tcp transport module.
[    0.723450] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.723463] PCI: CLS 0 bytes, default 64
[    0.723655] Trying to unpack rootfs image as initramfs...
[    0.890476] Freeing initrd memory: 6192K
[    0.895915] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.896527] kvm [1]: IPA Size Limit: 40 bits
[    0.897117] kvm [1]: vgic interrupt IRQ9
[    0.897830] kvm [1]: VHE mode initialized successfully
[    0.899958] Initialise system trusted keyrings
[    0.900312] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.909224] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.910438] NFS: Registering the id_resolver key type
[    0.910478] Key type id_resolver registered
[    0.910495] Key type id_legacy registered
[    0.910606] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.910635] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.910677] ntfs: driver 2.1.32 [Flags: R/W].
[    0.921166] NET: Registered protocol family 38
[    0.921194] Key type asymmetric registered
[    0.921213] Asymmetric key parser 'x509' registered
[    0.921268] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.921479] io scheduler mq-deadline registered
[    0.921500] io scheduler kyber registered
[    0.932093] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.932275] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.932361] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    0.932484] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    0.938942] scrncapt: init (heads:4 wins:6 planes:4)
[    0.939095] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[    0.940309] EINJ: ACPI disabled.
[    0.944060] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.944087] tegra-pmc: ### PMC reset source: MAINSWRST
[    0.944103] tegra-pmc: ### PMC reset level: L1
[    0.944118] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.944172] tegra-pmc: PMC Prod config success
[    0.950517] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.958223] random: fast init done
[    0.963972] printk: console [ttyTCU0] enabled
[    2.532350] arm-smmu 10000000.iommu: probing hardware configuration...
[    2.536371] arm-smmu 10000000.iommu: SMMUv2 with:
[    2.540866] arm-smmu 10000000.iommu: 	stage 1 translation
[    2.546737] arm-smmu 10000000.iommu: 	stage 2 translation
[    2.551913] arm-smmu 10000000.iommu: 	nested translation
[    2.557520] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    2.564427] arm-smmu 10000000.iommu: 	64 context banks (0 stage-2 only)
[    2.576158] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    2.577521] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.584340] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.592428] arm-smmu 12000000.iommu: probing hardware configuration...
[    2.597120] arm-smmu 12000000.iommu: SMMUv2 with:
[    2.601846] arm-smmu 12000000.iommu: 	stage 1 translation
[    2.607611] arm-smmu 12000000.iommu: 	stage 2 translation
[    2.612781] arm-smmu 12000000.iommu: 	nested translation
[    2.618467] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    2.625648] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    2.636740] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    2.638745] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    2.645071] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    2.652805] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    2.663112] tegra_profiler: version: 1.147, samples/io: 49/28
[    2.665555] tegra_profiler: auth: init
[    2.669766] THERMAL EST: found 3 subdevs
[    2.673432] THERMAL EST num_resources: 0
[    2.677029] [THERMAL EST subdev 0]
[    2.680615] [THERMAL EST subdev 1]
[    2.683980] [THERMAL EST subdev 2]
[    2.686995] THERMAL EST: Found 2 profiles, default profile is quiet
[    2.693502] THERMAL EST: thz register success.
[    2.697699] THERMAL EST: end of probe, return err: 0
[    2.703392] nvsciipc: loaded module
[    2.710938] tun: Universal TUN/TAP device driver, 1.6
[    2.713018] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.718748] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.724559] e1000e: Intel(R) PRO/1000 Network Driver
[    2.729244] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.735608] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.740878] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.747091] PPP generic driver version 2.4.2
[    2.751079] PPP BSD Compression module registered
[    2.755595] PPP Deflate Compression module registered
[    2.760839] PPP MPPE Compression module registered
[    2.765860] usbcore: registered new interface driver r8152
[    2.771621] usbcore: registered new interface driver asix
[    2.776713] usbcore: registered new interface driver ax88179_178a
[    2.783086] usbcore: registered new interface driver cdc_ether
[    2.789067] usbcore: registered new interface driver net1080
[    2.794393] usbcore: registered new interface driver cdc_subset
[    2.800672] usbcore: registered new interface driver zaurus
[    2.806373] usbcore: registered new interface driver cdc_ncm
[    2.812046] usbcore: registered new interface driver aqc111
[    2.817721] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.823505] ohci-pci: OHCI PCI platform driver
[    2.828054] ohci-platform: OHCI generic platform driver
[    2.833854] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    2.840095] usbcore: registered new interface driver uas
[    2.844102] usbcore: registered new interface driver usb-storage
[    2.850518] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    2.856267] mousedev: PS/2 mouse device common for all mice
[    2.861262] usbcore: registered new interface driver xpad
[    2.869527] tegra_rtc c2a0000.rtc: registered as rtc1
[    2.872233] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:24 UTC (24)
[    2.879795] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.886549] i2c /dev entries driver
[    2.889945] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    2.895819] tegra-i2c c240000.i2c: Adding to iommu group 2
[    2.901089] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    2.906477] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    2.911877] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    2.917364] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    2.922457] tegra-i2c c250000.i2c: Adding to iommu group 2
[    2.936306] device-mapper: uevent: version 1.0.3
[    2.936814] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    2.943080] cpuidle: Initializing cpuidle driver
[    2.947329] sdhci: Secure Digital Host Controller Interface driver
[    2.951598] sdhci: Copyright(c) Pierre Ossman
[    2.955696] Synopsys Designware Multimedia Card Interface Driver
[    2.962168] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.968212] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[    2.968436] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[    2.969193] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[    2.970166] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[    2.993438] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    3.008010] vdd-1v0: supplied by regulator-dummy
[    3.013868] vdd-1v8-hs: supplied by regulator-dummy
[    3.018726] vdd-1v8-ls: supplied by regulator-dummy
[    3.023570] vdd-1v8-ao: supplied by regulator-dummy
[    3.027565] vddio-ddr-1v1: supplied by regulator-dummy
[    3.032069] vdd-rtc: supplied by regulator-dummy
[    3.033865] spmic-ldo1: supplied by regulator-dummy
[    3.035269] vdd-ao-3v3: supplied by regulator-dummy
[    3.043945] vddio-emmc-3v3: supplied by regulator-dummy
[    3.050265] spmic-ldo4: supplied by regulator-dummy
[    3.051558] vdd-usb-3v3: supplied by regulator-dummy
[    3.058798] vddio-sdmmc1-3v3: supplied by regulator-dummy
[    3.065023] vdd-csi-1v2: supplied by vdd-1v8-ls
[    3.070638] spmic-ldo8: supplied by vdd-1v8-ls
[    3.072174] gpio-510 (gpio_default): hogged as output/high
[    3.074035] gpio-511 (gpio_default): hogged as output/high
[    3.080711] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[    3.220437] max77686-rtc max77620-rtc: registered as rtc0
[    3.221810] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[    3.222182] max77620 4-003c: max77620 probe successful
[    4.008494] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    4.009477] hid: raw HID events driver (C) Jiri Kosina
[    4.010092] usbcore: registered new interface driver usbhid
[    4.010226] usbhid: USB HID core driver
[    4.012016] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[    4.013173] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    4.098402] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    4.098925] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    4.099848] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    4.100645] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    4.102254] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    4.102824] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    4.103317] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    4.104299] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (53)
[    4.104685] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    4.106594] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=d48f1e279e6679b09020947e8de088eabfeaa475
[    4.114062] tegra_aon c1a0000.aon: Adding to iommu group 6
[    4.120509] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    4.125693] tegra186-aondbg aondbg: aondbg driver probe() OK
[    4.132794] denver_knobs_init:MTS_VERSION:55637613
[    4.149057] t19x_cache tegra-cache: probed
[    4.153408] optee: probing for conduit method.
[    4.154254] optee: revision 3.16
[    4.155234] optee: dynamic shared memory is enabled
[    4.156875] optee: initialized driver
[    4.161288] nvpmodel: initialized successfully
[    4.161923] tegra_hv: get_hvd: not initialized yet
[    4.163960] user_ivc_mempool: hypervisor not present
[    4.170339] usbcore: registered new interface driver snd-usb-audio
[    4.176249] drop_monitor: Initializing network drop monitor service
[    4.181443] u32 classifier
[    4.184011]     input device check on
[    4.187752]     Actions configured
[    4.191582] Initializing XFRM netlink socket
[    4.196492] NET: Registered protocol family 10
[    4.203016] Segment Routing with IPv6
[    4.203761] NET: Registered protocol family 17
[    4.207868] NET: Registered protocol family 15
[    4.212463] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.225748] Bluetooth: RFCOMM socket layer initialized
[    4.230264] Bluetooth: RFCOMM ver 1.11
[    4.234362] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.240144] Bluetooth: HIDP socket layer initialized
[    4.245823] 9pnet: Installing 9P2000 support
[    4.249603] Key type dns_resolver registered
[    4.255075] registered taskstats version 1
[    4.258259] Loading compiled-in X.509 certificates
[    4.297395] Loaded X.509 cert 'Build time autogenerated kernel key: f63cf27c9cc308395e49a0c8f6516dea39df2e3e'
[    4.300162] tegra194-pcie 14180000.pcie: Adding to iommu group 7
[    4.306697] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[    4.307069] tegra194-pcie 14180000.pcie:       IO 0x0038100000..0x00381fffff -> 0x0038100000
[    4.307459] tegra194-pcie 14180000.pcie:      MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[    4.307869] tegra194-pcie 14180000.pcie:      MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[    4.420502] tegra194-pcie 14180000.pcie: Link up
[    4.423560] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[    4.423855] pci_bus 0000:00: root bus resource [bus 00-ff]
[    4.424084] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[    4.424362] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[    4.424633] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[    4.425114] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[    4.425579] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[    4.437898] pci 0000:01:00.0: [144d:a809] type 00 class 0x010802
[    4.438414] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    4.450713] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[    4.451035] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[    4.451367] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    4.451577] pci 0000:00:00.0:   bridge window [mem 0x1b40000000-0x1b400fffff]
[    4.452061] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    4.452611] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    4.454579] pcieport 0000:00:00.0: Adding to iommu group 7
[    4.455758] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[    4.457612] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[    4.461980] nvme 0000:01:00.0: Adding to iommu group 7
[    4.467360] nvme nvme0: pci function 0000:01:00.0
[    4.470896] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    4.472737] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[    4.482977] nvme nvme0: Shutdown timeout set to 8 seconds
[    4.487465] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    4.494611] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    4.502870] tegra194-pcie 14100000.pcie:      MEM 0x1200000000..0x122fffffff -> 0x1200000000
[    4.511528] tegra194-pcie 14100000.pcie:      MEM 0x1230000000..0x123fffffff -> 0x0040000000
[    4.543490] nvme nvme0: allocated 64 MiB host memory buffer.
[    4.628533] nvme nvme0: 8/0/0 default/read/poll queues
[    4.628629] tegra194-pcie 14100000.pcie: Link up
[    4.628818] random: crng init done
[    4.631954] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    4.632313] pci_bus 0001:00: root bus resource [bus 00-ff]
[    4.632591] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[    4.632834] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[    4.633027] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[    4.633399] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[    4.634041] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[    4.646305] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[    4.646960] pci 0001:01:00.0: reg 0x10: [io  0x8000-0x8007]
[    4.647397] pci 0001:01:00.0: reg 0x14: [io  0x8040-0x8043]
[    4.647766] pci 0001:01:00.0: reg 0x18: [io  0x8100-0x8107]
[    4.647926]  nvme0n1: p1 p2
[    4.648151] pci 0001:01:00.0: reg 0x1c: [io  0x8140-0x8143]
[    4.648611] pci 0001:01:00.0: reg 0x20: [io  0x800000-0x80000f]
[    4.648901] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[    4.649304] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[    4.654281] pci 0001:01:00.0: PME# supported from D3hot
[    4.679534] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[    4.679925] pci 0001:00:00.0: BAR 13: assigned [io  0x100000-0x100fff]
[    4.680202] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[    4.680581] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[    4.687113] pci 0001:01:00.0: BAR 4: assigned [io  0x100000-0x10000f]
[    4.693725] pci 0001:01:00.0: BAR 0: assigned [io  0x100010-0x100017]
[    4.699946] pci 0001:01:00.0: BAR 2: assigned [io  0x100018-0x10001f]
[    4.706494] pci 0001:01:00.0: BAR 1: assigned [io  0x100020-0x100023]
[    4.712810] pci 0001:01:00.0: BAR 3: assigned [io  0x100024-0x100027]
[    4.719599] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    4.724807] pci 0001:00:00.0:   bridge window [io  0x100000-0x100fff]
[    4.731129] pci 0001:00:00.0:   bridge window [mem 0x1230000000-0x12300fffff]
[    4.738647] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    4.747058] pci 0001:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    4.757150] pcieport 0001:00:00.0: Adding to iommu group 8
[    4.761972] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[    4.767709] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[    4.774497] tegra194-pcie 14140000.pcie: Adding to iommu group 9
[    4.782343] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[    4.785647] tegra194-pcie 14140000.pcie:       IO 0x0034100000..0x00341fffff -> 0x0034100000
[    4.793947] tegra194-pcie 14140000.pcie:      MEM 0x1280000000..0x12afffffff -> 0x1280000000
[    4.802738] tegra194-pcie 14140000.pcie:      MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[    4.916474] tegra194-pcie 14140000.pcie: Link up
[    4.919069] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[    4.919341] pci_bus 0003:00: root bus resource [bus 00-ff]
[    4.919472] pci_bus 0003:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[    4.919768] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[    4.919990] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[    4.920305] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[    4.920843] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[    4.933570] pci 0003:01:00.0: [8086:2723] type 00 class 0x028000
[    4.934007] pci 0003:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    4.935553] pci 0003:01:00.0: PME# supported from D0 D3hot D3cold
[    4.946692] pci 0003:00:00.0: BAR 14: assigned [mem 0x12b0000000-0x12b00fffff]
[    4.947046] pci 0003:01:00.0: BAR 0: assigned [mem 0x12b0000000-0x12b0003fff 64bit]
[    4.947417] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[    4.947794] pci 0003:00:00.0:   bridge window [mem 0x12b0000000-0x12b00fffff]
[    4.948108] pci 0003:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    4.948826] pci 0003:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  128
[    4.950350] pcieport 0003:00:00.0: Adding to iommu group 9
[    4.952367] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[    4.958146] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[    4.965336] tegra194-pcie 141a0000.pcie: Adding to iommu group 10
[    4.970637] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[    4.999431] host1x 13e10000.host1x: Adding to iommu group 11
[    5.025066] host1x 13e10000.host1x: initialized
[    5.026792] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 12
[    5.027735] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    5.028926] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 13
[    5.029764] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    5.030720] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 14
[    5.031593] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    5.032875] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 15
[    5.037428] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    5.046723] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 16
[    5.053816] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    5.063928] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 17
[    5.071119] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[    5.080974] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 18
[    5.087847] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[    5.097648] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 19
[    5.104955] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[    5.114632] falcon 15340000.vic: Adding to iommu group 20
[    5.129903] falcon 15340000.vic: initialized
[    5.131144] falcon 15380000.nvjpg: Adding to iommu group 20
[    5.137073] falcon 15380000.nvjpg: initialized
[    5.137645] falcon 154c0000.nvenc: Adding to iommu group 20
[    5.148663] falcon 154c0000.nvenc: initialized
[    5.149271] falcon 15a80000.nvenc1: Adding to iommu group 20
[    5.157469] falcon 15a80000.nvenc1: initialized
[    5.158037] nvdec 15480000.nvdec: Adding to iommu group 20
[    5.170622] nvdec 15480000.nvdec: initialized
[    5.171196] nvdec 15140000.nvdec1: Adding to iommu group 20
[    5.180464] nvdec 15140000.nvdec1: initialized
[    5.181080] tsec 15500000.tsec: Adding to iommu group 21
[    5.187553] tsec 15500000.tsec: initialized
[    5.188010] tsec 15100000.tsecb: Adding to iommu group 22
[    5.195955] tsec 15100000.tsecb: initialized
[    5.200761] gic 2a41000.agic-controller: GIC IRQ controller registered
[    5.227419] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    5.236650] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[    5.245841] gpio-374 (wifi-enable): hogged as output/high
[    5.246255] gpio-462 (camera-control-output-low): hogged as output/low
[    5.247997] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[    5.250264] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[    5.250935] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    5.252744] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    5.255281] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    5.256912] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    5.260981] misc tegra_camera_ctrl: tegra_camera_isomgr_register: some fields not in DT.
[    5.263241] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=0, vi_iso_bw=6666665, max_bw=6666665
[    5.274745] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 23
[    5.286483] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    5.290865] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[    5.296525] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    5.304896] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[    5.314633] tegra194-vi5 15c10000.vi: Adding to iommu group 24
[    5.321704] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[    5.329296] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    5.335777] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[    5.345212] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[    5.351680] pva 16000000.pva0: Adding to iommu group 25
[    5.384001] pva 16000000.pva0: initialized
[    5.388558] pva 16800000.pva1: Adding to iommu group 26
[    5.402730] pva 16800000.pva1: initialized
[    5.406659] nvdla 15880000.nvdla0: Adding to iommu group 27
[    5.421166] nvdla 15880000.nvdla0: initialized
[    5.422523] nvdla 158c0000.nvdla1: Adding to iommu group 28
[    5.433348] nvdla 158c0000.nvdla1: initialized
[    5.439583] tegradccommon 15200000.display-hub: host1x channel mapped
[    5.440216] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=70
[    5.440247] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[    5.440563] tegradc 15200000.display: Adding to iommu group 29
[    5.440737] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[    5.441873] tegradccommon 15200000.display-hub: dma mapping done
[    5.443227] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    5.443723] tegradc 15200000.display: disp0 connected to head0->sor2
[    5.444174] generic_infoframe_type: 0x87
[    5.444612] tegradc 15210000.display: Adding to iommu group 29
[    5.445008] tegradc 15220000.display: Adding to iommu group 29
[    5.445026] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    5.445038] tegra_cec 3960000.tegra_cec: probed
[    5.445490] tegradc 15200000.display: DT parsed successfully
[    5.445926] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[    5.446209] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    5.448183] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    5.448592] kfuse 3830000.kfuse: initialized
[    5.449076] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    5.449605] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    5.450194] serial-tegra 3100000.serial: Adding to iommu group 2
[    5.451025] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[    5.452245] serial-tegra 3110000.serial: Adding to iommu group 2
[    5.457594] tegradc 15200000.display: Display dc.000000001fcb84fa registered with id=0
[    5.463740] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[    5.471103] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    5.474863] serial-tegra 3140000.serial: Adding to iommu group 2
[    5.479438] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[    5.485804] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[    5.491868] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[    5.493241] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[    5.508072] i2c i2c-1: of_i2c: modalias failure on /i2c@c240000/ucsi_ccg@8
[    5.509022] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[    5.509296] tegradc 15200000.display: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[    5.515330] i2c i2c-1: Failed to create I2C device for /i2c@c240000/ucsi_ccg@8
[    5.523957] tegradc 15200000.display: dc_probe: failed hotplug init, -517
[    5.536011] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[    5.540400] tegradc 15220000.display: disp0 connected to head2->sor1
[    5.546716] pca954x 2-0070: device detect skipped.
[    5.555152] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[    5.569644] tegradc 15220000.display: DT parsed successfully
[    5.586068] tegradc 15220000.display: dc.2 probe not in device tree order, deferring
[    5.599991] tegradc 15210000.display: disp0 connected to head1->sor
[    5.614812] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    5.628847] tegradc 15210000.display: DT parsed successfully
[    5.658348] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    5.659273] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[    5.685984] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2264000 KHz, changing to: 2265600 KHz
[    5.739366] tegra194-cpufreq ccplex: probed with BWMGR
[    5.744816] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[    5.745242] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[    5.745775] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    5.745834] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[    5.754952] irq: IRQ281: trimming hierarchy from :interrupt-controller@3881000
[    5.756333] reg-fixed-voltage fixed-regulators:regulator@106: nonexclusive access to GPIO for fixed-regulators:regulator@106
[    5.761255] mmc0: CQHCI version 5.10
[    5.763880] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 281
[    5.772171] vdd-5v-sata: supplied by vdd-ac-bat
[    5.789848] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[    5.797276] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[    5.816236] tegra194-vi5 15c10000.vi: initialized
[    5.817612] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[    5.817643] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x858ec9400, fsynr=0x240000, cbfrsynra=0x81b, cb=0
[    5.835038] arm-smmu 12000000.iommu: Unhandled context fault: fsr=0x80000402, iova=0x858ec7e00, fsynr=0xa0000, cbfrsynra=0x1b, cb=0
[    5.848779] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000000, hubc_int_status=0x00000000 sbs_int_status=0x00000000, hub_int_status=0x00000000
[    5.867573] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[    5.871852] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.877357] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    5.885342] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[    5.894462] tegra-xusb 3610000.xhci: irq 198, io mem 0x03610000
[    5.900703] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.908844] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.915761] usb usb1: Product: xHCI Host Controller
[    5.920998] usb usb1: Manufacturer: Linux 5.10.104-l4t-r35.1+gc7f946aacc63 xhci-hcd
[    5.928897] usb usb1: SerialNumber: 3610000.xhci
[    5.933871] hub 1-0:1.0: USB hub found
[    5.937594] hub 1-0:1.0: 4 ports detected
[    5.941628] tegra-xusb 3610000.xhci: xHCI Host Controller
[    5.946997] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    5.949021] mmc0: Command Queue Engine enabled
[    5.954615] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    5.958802] mmc0: periodic cache flush enabled
[    5.958814] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    5.966558] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    5.971265] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[    5.977198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.985674] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[    5.989899] usb usb2: Product: xHCI Host Controller
[    5.997458] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[    6.003264] usb usb2: Manufacturer: Linux 5.10.104-l4t-r35.1+gc7f946aacc63 xhci-hcd
[    6.008047] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB, chardev (510:0)
[    6.013593] usb usb2: SerialNumber: 3610000.xhci
[    6.033016]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37 p38 p39 p40 p41 p42
[    6.033837] hub 2-0:1.0: USB hub found
[    6.053700] hub 2-0:1.0: 4 ports detected
[    6.060871] tegradc 15200000.display: disp0 connected to head0->sor2
[    6.063908] generic_infoframe_type: 0x87
[    6.068146] tegradc 15200000.display: DT parsed successfully
[    6.073810] tegradc 15200000.display: Display dc.00000000d2a2034f registered with id=0
[    6.082141] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[    6.089731] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[    6.098623] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[    6.107013] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[    6.112734] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[    6.120118] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[    6.126458] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    6.136131] tegradc 15200000.display: probed
[    6.138739] Console: switching to colour frame buffer device 80x30
[    6.144332] tegradc 15200000.display: fb registered
[    6.149444] irq: IRQ282: trimming hierarchy from :pmc@c360000
[    6.155477] tegradc 15210000.display: disp1 connected to head1->sor
[    6.161313] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[    6.168547] tegradc 15210000.display: DT parsed successfully
[    6.174277] tegradc 15210000.display: Display dc.00000000bbee95f6 registered with id=1
[    6.182112] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[    6.188960] tegra194-pcie 141a0000.pcie:       IO 0x003a100000..0x003a1fffff -> 0x003a100000
[    6.189015] tegradc 15210000.display: vblank syncpt # 13 for dc 1
[    6.197599] tegra194-pcie 141a0000.pcie:      MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    6.203817] tegradc 15210000.display: vpulse3 syncpt # 14 for dc 1
[    6.212206] tegra194-pcie 141a0000.pcie:      MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[    6.228177] tegradc 15210000.display: probed
[    6.231949] tegradc 15210000.display: fb registered
[    6.240490] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    6.244034] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    6.251763] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    6.251930] tegradc 15220000.display: disp2 connected to head2->sor1
[    6.263509] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[    6.263525] tegradc 15210000.display: blank - powerdown
[    6.263567] tegradc 15220000.display: DT parsed successfully
[    6.270744] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    6.276007] tegradc 15220000.display: Display dc.0000000086b4ecd0 registered with id=2
[    6.281590] Extcon DP: HPD disabled
[    6.289983] tegradc 15220000.display: vblank syncpt # 15 for dc 2
[    6.297698] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    6.297706] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    6.301104] tegradc 15220000.display: vpulse3 syncpt # 16 for dc 2
[    6.307570] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    6.339180] tegradc 15220000.display: probed
[    6.339460] tegradc 15220000.display: fb registered
[    6.345984] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    6.350187] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    6.357804] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    6.363315] tegradc 15220000.display: blank - powerdown
[    6.368472] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[    6.376460] Extcon DP: HPD disabled
[    6.380100] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    6.386679] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    6.392642] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    6.464433] tegra_cec 3960000.tegra_cec: Can't find physical address.
[    6.464629] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    7.332707] tegra194-pcie 141a0000.pcie: Phy link never came up
[    7.332985] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[    7.333121] pci_bus 0005:00: root bus resource [bus 00-ff]
[    7.333231] pci_bus 0005:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[    7.333438] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    7.333591] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    7.333855] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[    7.334141] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[    7.342711] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    7.342882] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    7.343517] pcieport 0005:00:00.0: Adding to iommu group 10
[    7.343952] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[    7.344383] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[    7.344973] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[    7.345399] pci 0005:00:00.0: Removing from iommu group 10
[    7.345575] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[    7.350476] nvethernet 2490000.ethernet: Adding to iommu group 30
[    7.354729] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[    7.362496] nvethernet 2490000.ethernet: failed to read MDIO address
[    7.368799] nvethernet 2490000.ethernet: setting to default DMA bit mask
[    7.375891] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[    7.382006] nvethernet 2490000.ethernet: Setting default PTP RX queue
[    7.396491] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[    7.396685] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[    7.401618] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[    7.409910] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:3a:c0:b7
[    7.416010] -->macsec_probe()
[    7.416015] <--macsec_probe()
[    7.416020] nvethernet 2490000.ethernet: Macsec not supported
[    7.422922] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[    7.430590] irq: IRQ284: trimming hierarchy from :pmc@c360000
[    7.435603] irq: IRQ285: trimming hierarchy from :interrupt-controller@3881000
[    7.442499] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    7.450107] tegra-se-nvhost 15810000.se: Adding to iommu group 31
[    7.457180] tegra-se-nvhost 15810000.se: initialized
[    7.461966] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    7.467192] tegra-se-nvhost 15820000.se: Adding to iommu group 32
[    7.473427] tegra-se-nvhost 15820000.se: initialized
[    7.479454] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    7.484092] tegra-se-nvhost 15830000.se: Adding to iommu group 33
[    7.490597] tegra-se-nvhost 15830000.se: initialized
[    7.496234] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    7.501774] tegra-se-nvhost 15840000.se: Adding to iommu group 34
[    7.508236] tegra-se-nvhost 15840000.se: initialized
[    7.513924] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    7.519834] tegra_actmon d230000.actmon: in actmon_register()...
[    7.524549] tegra_actmon d230000.actmon: bwmgr_disable = 0
[    7.530459] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    7.538330] hvc_sysfs: hypervisor is not present
[    7.594335] ALSA device list:
[    7.594433]   No soundcards found.
[    7.595390] Freeing unused kernel memory: 3904K
[    7.595675] Run /init as init process
[    7.595781]   with arguments:
[    7.595784]     /init
[    7.595787]   with environment:
[    7.595790]     HOME=/
[    7.595793]     TERM=linux
[    7.595796]     mminit_loglevel=4
[    8.091228] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    8.095987] platform_update: Checking for pending platform update
[    8.110295] tegra-xusb 3610000.xhci: entering ELPG done
[    8.401908] platform_update: Mounting /dev/nvme0n1p2 on /.nvme_external
[    8.423525] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.431335] platform-pre-switchroot: no APP_b partition detected, booting without rootfs overlay
[    8.436723] platform-pre-switchroot: Mounting /dev/nvme0n1p1 on /mnt/.nvme_sync
[    8.456695] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    8.462986] platform-pre-switchroot: Mounting /dev/nvme0n1p2 on /mnt/.nvme_external
[    8.482879] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.484423] platform-pre-switchroot: partitioning /dev/sda
[    8.487863] wipefs:
[    8.487878] error: /dev/sda: probing initialization failed
[    8.487961] : No such file or directory
[    8.494670] Error
[    8.494684] :
[    8.494782] Could not stat device /dev/sda - No such file or directory.
[    8.500842] mke2fs 1.46.5 (30-Dec-2021)
[    8.501507] The file /dev/sda1 does not exist and no size was specified.
[    8.507437] mke2fs 1.46.5 (30-Dec-2021)
[    8.507933] The file /dev/sda2 does not exist and no size was specified.
[    8.513696] platform-pre-switchroot: Formating /dev/sda1 as ext4
[    8.518827] mke2fs 1.46.5 (30-Dec-2021)
[    8.519348] The file /dev/sda1 does not exist and no size was specified.
[    8.520412] platform-pre-switchroot: Mounting /dev/sda1 on /mnt/.sata_logs
[    8.533141] /dev/sda1: Can't open blockdev
[    8.533357] /dev/sda1: Can't open blockdev
[    8.533525] mount: mounting /dev/sda1 on /mnt/.sata_logs failed: No such file or directory
[    8.539031] platform-pre-switchroot: Formating /dev/sda2 as ext4
[    8.544088] mke2fs 1.46.5 (30-Dec-2021)
[    8.544667] The file /dev/sda2 does not exist and no size was specified.
[    8.545664] platform-pre-switchroot: Mounting /dev/sda2 on /mnt/.sata_sync
[    8.558341] /dev/sda2: Can't open blockdev
[    8.558566] /dev/sda2: Can't open blockdev
[    8.558743] mount: mounting /dev/sda2 on /mnt/.sata_sync failed: No such file or directory
[    8.855846] platform-pre-switchroot: Mounting /dev/mmcblk0p42 on /mnt/.mmc_data
[    8.868515] EXT4-fs (mmcblk0p42): mounted filesystem with ordered data mode. Opts: (null)
[    9.171630] platform-pre-switchroot: Mounting /dev/mmcblk0p41 on /mnt/.mmc_config
[    9.190588] EXT4-fs (mmcblk0p41): mounted filesystem with ordered data mode. Opts: (null)
[    9.559402] udevd[356]: starting version 3.2.10
[    9.607455] udevd[356]: specified group 'debug' unknown
[    9.610956] udevd[357]: starting eudev-3.2.10
[    9.828125] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[    9.842666] cpu-throttle-alert cooling device registered.
[    9.843614] gpu-throttle-alert cooling device registered.
[    9.844091] aux-throttle-alert cooling device registered.
[    9.844597] hot-surface-alert cooling device registered.
[    9.860469] irq: IRQ286: trimming hierarchy from :pmc@c360000
[    9.860643] nct1008_nct72 4-004c: starting parse dt
[    9.860815] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[    9.860939] nct1008_nct72 4-004c: success parsing dt
[    9.873296] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[    9.882359] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    9.882817] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[    9.883022] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    9.883185] nvmap_page_pool_init: Total RAM pages: 7939069
[    9.883296] nvmap_page_pool_init: nvmap page pool size: 992383 pages (3876 MB)
[    9.883728] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[    9.884074] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    9.884297] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    9.884832] nvmap_background_zero_thread: PP zeroing thread starting.
[    9.891728] irq: IRQ287: trimming hierarchy from :pmc@c360000
[    9.906961] CAN device driver interface
[    9.908786] nct1008_nct72 4-004c: LOC shutdown limit 107
[    9.910048] nct1008_nct72 4-004c: EXT shutdown limit 109
[    9.915894] libata version 3.00 loaded.
[    9.921121] nvadsp 2993000.adsp: Adding to iommu group 35
[    9.922873] nvadsp 2993000.adsp: in probe()...
[    9.936601] nvadsp 2993000.adsp: nvadsp_app_module_probe
[    9.940349] 	 Message RAM Configuration
               	| base addr   |0x0c312000|
               	| sidfc_flssa |0x00000000|
               	| xidfc_flesa |0x00000040|
               	| rxf0c_f0sa  |0x000000c0|
               	| rxf1c_f1sa  |0x000009c0|
               	| rxbc_rbsa   |0x000009c0|
               	| txefc_efsa  |0x000009c0|
               	| txbc_tbsa   |0x00000a40|
               	| tmc_tmsa    |0x00000ec0|
               	| mram size   |0x00001000|
[    9.947112] nct1008_nct72 4-004c: initial LOC temp: 45000
[    9.975443] Release 3.2.0 from 19.12.2014
[    9.981155] nct1008_nct72 4-004c: initial EXT temp: 46750
[    9.983996] net can0: mttcan device registered (regs=0000000022daee9a, irq=50)
[    9.990554] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[    9.998211] 	 Message RAM Configuration
               	| base addr   |0x0c322000|
[   10.044128] nct1008_nct72 4-004c: nct1008_probe: initialized
[   10.044808] Release 3.2.0 from 19.12.2014
[   10.065612] net can1: mttcan device registered (regs=00000000f57dcc31, irq=51)
[   10.085681] tegra-asoc: sound: Adding to iommu group 35
[   10.857818] tegra-hda 3510000.hda: Adding to iommu group 36
[   10.860532] tegra-hda 3510000.hda: Override SDO lines to 4
[   10.875115] ahci 0001:01:00.0: Adding to iommu group 8
[   10.875814] ahci 0001:01:00.0: version 3.0
[   10.876523] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[   10.876718] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[   10.878237] scsi host0: ahci
[   10.878582] ata1: SATA max UDMA/133 abar m512@0x1230010000 port 0x1230010100 irq 289
[   10.880750] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 35
[   10.881047] tegra210_adsp_audio_probe: platform probe started
[   10.886001] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[   10.889215] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[   10.893657] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[   10.894784] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[   10.896704] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[   10.902757] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[   10.902971] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[   10.903175] tegra210-adsp tegra210-adsp: using adma channel page 0
[   10.903445] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[   10.921849] Intel(R) Wireless WiFi driver for Linux
[   10.922588] iwlwifi 0003:01:00.0: Adding to iommu group 9
[   10.923073] iwlwifi 0003:01:00.0: enabling device (0000 -> 0002)
[   10.940785] iwlwifi 0003:01:00.0: api flags index 2 larger than supported by driver
[   10.941080] iwlwifi 0003:01:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[   10.941782] iwlwifi 0003:01:00.0: loaded firmware version 59.601f3a66.0 cc-a0-59.ucode op_mode iwlmvm
[   10.948364] [drm] Initialized tegra-udrm 0.0.0 20182809 for tegra_udrm on minor 0
[   10.948705] [drm] Initialized tegra-udrm 0.0.0 20182809 on minor 0
[   11.195803] ata1: SATA link down (SStatus 0 SControl 300)
[   11.218569] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input1
[   11.221844] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input2
[   11.222604] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input3
[   11.223450] input: NVIDIA Jetson AGX Xavier HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input4
[   11.228536] tegra210-adsp tegra210-adsp: Loaded app wire
[   11.228738] tegra210-adsp tegra210-adsp: Loaded app apm
[   11.228897] tegra210-adsp tegra210-adsp: Loaded app adma
[   11.229051] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[   11.229223] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 0000000097c4d896
[   11.234213] cryptd: max_cpu_qlen set to 1000
[   11.247559] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[   11.407661] iwlwifi 0003:01:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   11.598158] iwlwifi 0003:01:00.0: base HW address: b0:7d:64:f0:d0:02
[   11.612119] thermal thermal_zone8: failed to read out thermal zone (-61)
[   11.733142] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[   12.038812] input: NVIDIA Jetson AGX Xavier APE Headset Jack as /devices/platform/sound/sound/card1/input5
[   12.722390] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   14.615305] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[   14.805096] irq: IRQ300: trimming hierarchy from :interrupt-controller@3881000
[   14.806007] hwmon hwmon6: temp1_input not attached to any thermal zone
[   14.980443] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[   15.074930] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   15.075098] ACPI: <n/a>: failed to evaluate _DSM (0x1001)
[   17.549288] nvethernet 2490000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   17.549547] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   24.644336] FAT-fs (mmcblk0p40): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   24.921361] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   24.921515] Bluetooth: BNEP socket layer initialized
[   24.945218] tegradc 15200000.display: blank - powerdown
[   24.945367] tegradc 15210000.display: blank - powerdown
[   24.945486] tegradc 15220000.display: blank - powerdown
[   25.421291] tegradc 15200000.display: blank - powerdown
[   25.421444] tegradc 15210000.display: blank - powerdown
[   25.421568] tegradc 15220000.display: blank - powerdown
[   25.428791] tegradc 15200000.display: blank - powerdown
[   25.986772] nvgpu: 17000000.gv11b                 tpc_pg_mask_store:1067 [INFO]  no value change, same mask already set
[   37.790021] nfc: nfc_init: NFC Core ver 0.1
[   37.790254] NET: Registered protocol family 39
[   37.856503] vdd-3v3-cvb: disabling
[   37.856634] vdd-epb-1v0: disabling
[   37.856716] vdd-sata-1v5: disabling
[   37.856801] vdd-1v8-slt: disabling
[   37.856915] vdd-3v3-slt: disabling
[   62.099837] nvethernet 2490000.ethernet eth0: Link is Down
[   66.294473] nvethernet 2490000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
It seems your issue is caused from new_probe() function.
You could try to add some debug messages in new_probe() of wipefs.c.
Do you format it as ext4 before use?
R35.1.0 on the AGX Xavier devkit.
Slightly different to your situation.
I have a SATA to USB-A adapter, therefore, I add an USB-A to USB-C gender again for J512.
It works pretty well.
Do you mean that you could recognize the USB-SATA drive with R35.1 after using the adapter?
@KevinFFF
Yes I do.
I attach my devices here, an USB-SATA adapter with SATA HDD by yellow color marked and an USB-A to USB-C converter by green color.
I tested it with JAX devkit with R35.1.0;
- read/write
- file create/delete
- syslog
- file manager
