Xavier dev kit external PCIe and UFS card are Not Detected
According to the documentation provided by nvidia, any external pcie card and a UFS card can be installed.
But In our Dev kit, the device is not detected.
But M.2 NVMe cards do. anyone had this problem?
Hi archcafe,
Please provide the details of which PCIe card you’re trying to use, also provide kernel log.
You can refer to below link to get the log and attach at here:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fsubmit_bug_report.html%23
Searching for pci devices using the lspci command does not detect external PCIE and UFS cards.
We used PCIe card UFS card Part number are below.
PCIe card P/N : intel XL710
UFS card P/N : Samsung UFS 128G
-Kernel Log-
[code][0000.086] I> MB1 (prd-version: 1.0.0.0-t194-41334769-a3872862)
[0000.091] I> Boot-mode: L0 coldboot
[0000.094] I> chip revision : A02
[0000.097] I> Bootrom patch version : 7 (correctly patched)
[0000.103] I> ATE fuse revision : 0x200
[0000.106] I> Ram repair fuse : 0x1
[0000.109] I> Ram Code : 0x0
[0000.112] I> rst_source : 0x0
[0000.114] I> rst_level : 0x0
[0000.118] I> Boot-device: eMMC
[0000.121] W> DEVICE_PROD: device prod is not initialized.
[0000.126] W> DEVICE_PROD: device prod is not initialized.
[0000.143] I> Sdmmc: DDR50 mode
[0000.147] W> DEVICE_PROD: device prod is not initialized.
[0000.152] I> Active boot chain: 0
[0000.155] I> Active boot chain: 0
[0000.158] I> magic:0x43424e00, version: 3, num_slots: 1
[0000.163] W> No valid slot number is found in scratch register
[0000.169] W> Return default slot: _a
[0000.172] I> Boot chain slot 0
[0000.175] I> Boot-device: eMMC
[0000.179] E> No fuse-bypass data
[0000.182] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.188] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0000.196] I> temperature = 23500
[0000.199] W> Skipping boost for clk:bpmp_cpu_nic
[0000.203] W> Skipping boost for clk:bpmp_apb
[0000.207] W> Skipping boost for clk:axi_cbb
[0000.211] W> Skipping boost for clk:aon_cpu_nic
[0000.215] W> Skipping boost for clk:aon_can0
[0000.219] W> Skipping boost for clk:aon_can1
[0000.223] I> Boot-device: eMMC
[0000.226] I> Boot-device: eMMC
[0000.236] I> Sdmmc: HS400 mode enabled
[0000.244] I> ECC region[0]: Start:0x0, End:0x0
[0000.248] I> ECC region[1]: Start:0x0, End:0x0
[0000.252] I> ECC region[2]: Start:0x0, End:0x0
[0000.256] I> ECC region[3]: Start:0x0, End:0x0
[0000.260] I> ECC region[4]: Start:0x0, End:0x0
[0000.265] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.270] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.275] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.279] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.284] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.290] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0000.297] E> FAILED: Thermal config
[0000.300] W> DEVICE_PROD: device prod is not initialized.
[0000.305] W> DEVICE_PROD: device prod is not initialized.
[0000.314] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0000.321] E> FAILED: MEMIO rail config
[0000.335] I> scrub mode: full dram
[0000.339] E> FUSE: Failed to verify ECID.
[0000.352] I> WP-0 triggered
[0000.354] I> WP-0 ACK received :)
[0000.358] I> sdmmc bdev is already initialized
[0000.391] I> WP-1 triggered
[0000.397] W> No fuse-bypass data
[0000.400] I> SC7 context save done
[0000.407] I> WP-1 ACK received :)
[0000.410] W> MB1_PLATFORM_CONFIG: Rail ID 8 not found in pmic rail config table.
[0000.417] I> MTS carveout BOM: 0xf8000000
[0000.421] I> WP1.5 triggered
[0000.472] I> WP1.5 ACK received :)
[0000.477] I> MB1 done
??ain enter
SPE VERSION #: R01.00.10 Created: May 31 2018 @ 13:05:12
HW Function test
Start Scheduler.
in late init
?[0000.484] I> Welcome to MB2(TBoot-BPMP)
[0000.485] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.485] W> Device prod registration failed
[0000.486] I> Boot-device: eMMC
[0000.486] I> Boot_device: SDMMC_BOOT instance: 3
[0000.494] I> sdmmc-3 params source = boot args
[0000.495] I> sdmmc bdev is already initialized
[0000.499] I> sdmmc-3 params source = boot args
[0000.506] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0000.512] I> Found 36 partitions in SDMMC_BOOT (instance 3)
[0000.515] W> No valid slot number is found in scratch register
[0000.520] W> Return default slot: _a
[0000.523] I> Active Boot chain : 0
[0000.527] I> Binary@ device:1/3 block-58750712 (partition size: 0x100000)
[0000.543] I> Binary@ device:1/3 block-58754808 (partition size: 0x100000)
[0000.582] I> Binary@ device:1/3 block-58759928 (partition size: 0x80000)
[0000.586] I> Binary@ device:1/3 block-58738680 (partition size: 0x80000)
[0000.591] I> Binary@ device:1/3 block-58740728 (partition size: 0x60000)
[0000.595] I> BL-DTB loaded successfully
[0000.596] I> Relocating BR-BCT
[0000.597] I> Binary@ device:1/3 block-58742264 (partition size: 0x200000)
[0000.605] I> Unhalting RCE
?OTICE: BL31: v1.3(release):9fc2cdf
NOTICE: BL31: Built : 15:08:58, Oct 31 2018
ERROR: Error initializing runtime service trusty_fast
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is 588c62054ecdba8a44cb9d6ff5d04cb0
tag_show initialized
dt initialized
WARNING: at platform/drivers/mailbox/mail_mach.c:514
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
vmon_soc_self_check: vmon_vsoc: self-check passed
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
warning: aon_cpu_nic do not permit ‘allowed-parents’ property
387 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
mrq initialized
?[0001.119] I> Welcome to Cboot
[0001.119] I> Cboot Version: 4e3f0bea4cf94837f65ddb512d987e4e8589e811.10.31.2018.43-t194-3d46
?mon_post initialized
?0001.120] I> CPU-BL Params @ 0xf2820000
[0001.120] I> 0) Base:0x00000000 Size:0x00000000
[0001.123] I> 1) Base:0xf2100000 Size:0x00100000
[0001.127] I> 2) Base:0xf2000000 Size:0x00100000
[0001.133] I> 3) Base:0xf1300000 Size:0x00100000
[0001.136] I> 4) Base:0xf1200000 Size:0x00100000
[0001.142] I> 5) Base:0xf1100000 Size:0x00100000
[0001.145] I> 6) Base:0xf3800000 Size:0x00400000
[0001.150] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.154] I> 8) Base:0xf1000000 Size:0x00100000
?lk_dt_late initialized
?0001.159] I> 9) Base:0xf0f00000 Size:0x00100000?arveout 25 misconfigured: 0x0@0x000000000
?arveout 25 access not ok (reg 0x2610 = 0x0, bit 27)
?0001.170] I> 10) Base:0xf3000000 Size:0x00800000
?arveout 25 access not ok (reg 0x2610 = 0x0, bit 28)
?0001.179] I> 11) Base:0x40000000 Size:0x00040000?arveout 25 access not ok (reg 0x2610 = 0x0, bit 19)
?arveout 25 access not ok (reg 0x2610 = 0x0, bit 20)
?0001.194] I> 12) Base:0xf0e00000 Size:0x00100000
?achine_check initialized
?0001.204] I> 13) Base:0x40046000 Size:0x00002000?m_post initialized
?bells initialized
?0001.213] I> 14) Base:0x40048000 Size:0x00002000
?vfs_clk_platform_post initialized
?0001.220] I> 15) Base:0xaa000000 Size:0x00004000?mce initialized
?vc initialized
?0001.229] I> 16) Base:0x4004a000 Size:0x00002000
?cplex_avfs_hw_init: nafll_cluster0: not monitored
?0001.236] I> 17) Base:0xf0d00000 Size:0x00100000
?cplex_avfs_hw_init: nafll_cluster1: not monitored
?0001.245] I> 18) Base:0x4004c000 Size:0x00002000
?cplex_avfs_hw_init: nafll_cluster2: not monitored
?0001.254] I> 19) Base:0xf2200000 Size:0x00600000
?cplex_avfs_hw_init: nafll_cluster3: not monitored
?0001.264] I> 20) Base:0x4004e000 Size:0x00002000
[0001.273] I> 21) Base:0xf0cd0000 Size:0x0000c000
?vfs_clk_mach_post initialized
ulator_post initialized
?0001.278] I> 22) Base:0x00000000 Size:0x00000000
?m initialized
?0001.287] I> 23) Base:0xf0ce0000 Size:0x00020000
?c7_diag initialized
?0001.294] I> 24) Base:0xf6000000 Size:0x02000000
?hermal_test initialized
?0001.300] I> 25) Base:0x00000000 Size:0x00000000
?erial_late initialized
?0001.307] I> 26) Base:0x40040000 Size:0x00006000
?lk_post initialized
?0001.314] I> 27) Base:0xf1800000 Size:0x00400000
?lk_dt_post initialized
?0001.321] I> 28) Base:0xf4c00000 Size:0x01400000
?c_pcie initialized
?0001.328] I> 29) Base:0xf1400000 Size:0x00400000
[0001.335] I> 30) Base:0x00000000 Size:0x00000000
?g_post initialized
?0001.339] I> 31) Base:0x00000000 Size:0x00000000
?ku_debugfs initialized
?0001.346] I> 32) Base:0xf8000000 Size:0x08000000
?peedo_debugfs initialized
?0001.353] I> 33) Base:0x00000000 Size:0x00000000
?dc_debugfs initialized
?0001.360] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.367] I> 35) Base:0x00000000 Size:0x00000000
[0001.372] I> 36) Base:0xa0000000 Size:0x09000000
[0001.376] I> 37) Base:0xf2800000 Size:0x00800000
[0001.381] I> 38) Base:0x80000000 Size:0x20000000
[0001.385] I> 39) Base:0xb0000000 Size:0x08000000
?lk_debugfs initialized
?0001.390] I> 40) Base:0x00000000 Size:0x00000000
[0001.397] I> 41) Base:0x00000000 Size:0x00000000
[0001.401] I> 42) Base:0x00000000 Size:0x00000000
[0001.405] I> 43) Base:0x00000000 Size:0x00000000
[0001.410] I> 44) Base:0x00000000 Size:0x00000000
[0001.414] I> 45) Base:0x00000000 Size:0x00000000
[0001.419] GIC-SPI Target CPU: 0
[0001.422] Interrupts Init done
[0001.425] calling constructors
[0001.428] initializing heap
[0001.430] I> Heap: [0xa06872c8 … 0xa8f00000]
[0001.435] initializing threads
[0001.437] initializing timers
[0001.440] creating bootstrap completion thread
[0001.444] top of bootstrap2()
[0001.447] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.452] initializing platform
[0001.455] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.460] W> device prod register failed
[0001.464] I> Bl_dtb @0xa8f00000
?mc_debugfs initialized
?0001.467] I> gpio framework initialized
?vs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
?0001.480] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
?g_debugfs initialized
profile_fs initialized
debugfs_cons initialized
?0001.494] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
?ail_fs initialized
file initialized
?0001.502] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
?vc_debugfs initialized
dmce_debugfs initialized
?0001.516] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
?c_debugfs initialized
soctherm_debug initialized
?0001.528] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
?r_reader initialized
s initialized
?0001.538] W> tegrabl_tca9539_init: failed to fetch phandle from dt
?t_fs initialized
?0001.547] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
?ebugfs_mrq initialized
initializing target
?0001.558] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
?alling apps_init()
rting app shell
?0001.569] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
?ntering main console loop
?0001.579] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.590] I> fixed regulator driver initialized
[0001.604] I> register ‘maxim’ power off handle
[0001.606] I> virtual i2c enabled
[0001.606] I> registered ‘maxim,max20024’ pmic
[0001.606] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.611] I> Boot-device: eMMC
[0001.613] I> Boot_device: SDMMC_BOOT instance: 3
[0001.620] I> sdmmc-3 params source = boot args
[0001.622] I> sdmmc bdev is already initialized
[0001.626] I> sdmmc-3 params source = boot args
[0001.633] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.638] I> Found 36 partitions in SDMMC_BOOT (instance 3)
[0001.642] I> Load in CBoot Boot Options partition and parse it
[0001.654] E> Error -9 when finding node with path /boot-configuration
[0001.654] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0001.662] E> “plugin-manager” doesn’t exist, creating
[0001.666] E> “ids” doesn’t exist, creating
[0001.670] E> “connection” doesn’t exist, creating
[0001.674] E> “configs” doesn’t exist, creating
[0001.681] I> Find /i2c@3160000’s alias i2c0
[0001.683] I> Reading eeprom i2c=0 address=0x50
[0001.713] I> Device at /i2c@3160000:0x50
[0001.714] I> Reading eeprom i2c=0 address=0x56
[0001.714] E> I2C: slave not found in slaves.
[0001.714] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0001.715] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.716] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0001.723] E> eeprom: Failed to read I2C slave device
[0001.728] I> Eeprom read failed 0x3526070d
[0001.733] I> Find /i2c@3180000’s alias i2c2
[0001.736] I> Reading eeprom i2c=2 address=0x54
[0001.742] E> I2C: slave not found in slaves.
[0001.745] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.753] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.758] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.767] E> eeprom: Failed to read I2C slave device
[0001.772] I> Eeprom read failed 0x3526070d
[0001.776] I> Reading eeprom i2c=2 address=0x57
[0001.781] E> I2C: slave not found in slaves.
[0001.785] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.792] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.798] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.808] E> eeprom: Failed to read I2C slave device
[0001.812] I> Eeprom read failed 0x3526070d
[0001.816] I> Reading eeprom i2c=2 address=0x52
[0001.821] E> I2C: slave not found in slaves.
[0001.825] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.833] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.838] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.848] E> eeprom: Failed to read I2C slave device
[0001.852] I> Eeprom read failed 0x3526070d
[0001.857] I> Find /i2c@c240000’s alias i2c1
[0001.860] I> Reading eeprom i2c=1 address=0x52
[0001.866] E> I2C: slave not found in slaves.
[0001.869] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.877] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.882] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.892] E> eeprom: Retry to read I2C slave device.
[0001.897] E> I2C: slave not found in slaves.
[0001.901] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.909] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.914] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.924] E> eeprom: Failed to read I2C slave device
[0001.928] I> Eeprom read failed 0x3526070d
[0001.932] I> Reading eeprom i2c=1 address=0x50
[0001.937] E> I2C: slave not found in slaves.
[0001.941] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.949] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.954] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.964] E> eeprom: Retry to read I2C slave device.
[0001.969] E> I2C: slave not found in slaves.
[0001.973] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.980] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.986] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.995] E> eeprom: Failed to read I2C slave device
[0002.000] I> Eeprom read failed 0x3526070d
[0002.004] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0002.009] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.020] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0002.028] E> “i2c@3160000” doesn’t exist, creating
[0002.032] E> “module@0x50” doesn’t exist, creating
[0002.038] I> Adding plugin-manager/cvm
[0002.041] E> “chip-id” doesn’t exist, creating
[0002.045] I> Adding plugin-manager/chip-id/A02
[0002.049] I> Plugin-manager override starting
[0002.055] I> node /plugin-manager/fragment-p2888@0 matches
[0002.074] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.077] I> node /plugin-manager/fragement-soft-wdt matches
[0002.083] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.092] I> Disable plugin-manager status in FDT
[0002.092] I> Plugin-manager override finished successfully
[0002.104] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.110] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.110] I> hdmi cable connected
[0002.113] E> set volts not configured for ‘vdd-1v0’
[0002.115] E> set volts not configured for ‘vdd-1v8-hs’
[0002.121] E> invalid display type
[0002.125] E> invalid display type
[0002.127] E> cannot find any other nvdisp nodes
[0002.143] I> edid read success
[0002.156] I> edid read success
[0002.156] I> width = 640, height = 480, frequency = 25174825
[0002.157] I> width = 640, height = 480, frequency = 25174825
[0002.158] I> width = 1920, height = 1080, frequency = 148500000
[0002.161] I> width = 1280, height = 720, frequency = 74250000
[0002.167] I> width = 1280, height = 720, frequency = 74250000
[0002.173] I> width = 1920, height = 1080, frequency = 148351648
[0002.178] I> width = 1280, height = 720, frequency = 74175824
[0002.184] I> width = 1920, height = 1080, frequency = 148351648
[0002.190] I> width = 1280, height = 720, frequency = 74175824
[0002.195] I> width = 720, height = 576, frequency = 26973026
[0002.201] I> width = 720, height = 480, frequency = 26973026
[0002.206] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.217] I> hdmi_enable, starting HDMI initialisation
[0002.222] I> hdmi_enable, HDMI initialisation complete
[0002.229] initializing target
[0002.230] calling apps_init()
[0002.231] starting app kernel_boot_app
[0002.289] I> decompressor handler not found
[0002.290] I> Kernel type = Normal
[0002.290] I> Loading kernel & kernel-dtb from removable storage (5)
[0002.291] I> Found sdcard
[0002.294] I> enabling ‘vdd-sdmmc1-sw’ regulator
[0002.301] I> regulator ‘vdd-sdmmc1-sw’ already enabled
[0002.303] E> Error in command_complete 18000 int_status
[0002.303] E> Sending CMD_SD_SEND_IF_COND failed
[0002.313] W> Error opening sdcard-0
[0002.314] I> -0 params source =
[0002.314] W> Failed to initialize device 5-0
[0002.314] I> Loading kernel & kernel-dtb from removable storage (6)
[0002.321] W> No valid slot number is found in scratch register
[0002.321] W> Return default slot: _a
[0002.326] I> USB Firmware Version: 60.05 release
[0002.847] I> USB 2.0 port 4 new high-speed USB device detected
[0002.848] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa1926600, cmd_ring.dma = 0xa1926640
[0002.849] E> slot id is 1
[0002.850] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa1926600, cmd_ring.dma = 0xa1926640
[0002.858] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa1926600, cmd_ring.dma = 0xa1926640
[0002.860] I>
[0002.860] I> Enumerated USB Device 0bda:5411
[0002.864] I>
[0002.865] E> Enumerated device doesn’t belong to MSD class!!
[0002.871] E> USBMSD: Failed to initialize enumerated usb device is not MSD.
[0002.877] E> USBMSD: Failed to open usbmsd open, 0.
[0002.882] E> Error opening USBMSD driver 0, err: 7c7c0312
[0002.887] W> Failed to initialize device 6-0
[0002.891] I> Loading kernel/boot.img from built-in storage …
[0002.897] W> No valid slot number is found in scratch register
[0002.903] W> Return default slot: _a
[0002.906] I> A/B: bin_type (37) slot 0
[0002.910] I> Loading partition kernel at 0xa1980000 from device(0x1)
[0003.293] I> T19x: Authenticate kernel (bin_type: 37), max size 0x4000000
[0003.638] W> No valid slot number is found in scratch register
[0003.639] W> Return default slot: _a
[0003.639] I> A/B: bin_type (38) slot 0
[0003.639] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0003.644] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x80000
[0003.647] I> Kernel hdr @0xa1980000
[0003.648] I> Kernel dtb @0x91000000
[0003.648] I> Checking boot.img header magic … [0003.650] I> [OK]
[0003.652] I> Valid boot.img @ 0xa1980000
[0003.656] I> decompressor handler not found
[0003.660] I> Copying kernel image (34404360 bytes) from 0xa1980800 to 0x80080000 … [0003.685] I> Done
[0003.685] I> Move ramdisk (len: 0) from 0xa3a50800 to 0x92000000
[0003.687] I> Updated bpmp info to DTB
[0003.688] I> Ramdisk: Base: 0x92000000; Size: 0x0
[0003.688] I> Updated initrd info to DTB
[0003.689] W> WARN: Fail to override “console=none” in commandline
[0003.693] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.700] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.707] W> No valid slot number is found in scratch register
[0003.713] W> Return default slot: _a
[0003.716] I> Active slot suffix:
[0003.720] I> add_boot_slot_suffix: slot_suffix =
[0003.724] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa078e000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
[0003.761] I> Updated bootarg info to DTB
[0003.765] W> MAC addr invalid!
[0003.768] E> Failed to get WIFI MAC address
[0003.772] W> MAC addr invalid!
[0003.775] E> Failed to get Bluetooth MAC address
[0003.779] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:a5:d3
[0003.786] E> “plugin-manager” doesn’t exist, creating
[0003.790] I> Adding /chosen/plugin-manager/cvm
[0003.794] E> “chip-id” doesn’t exist, creating
[0003.799] I> Adding /chosen/plugin-manager/chip-id
[0003.803] E> “configs” doesn’t exist, creating
[0003.808] I> Adding /chosen/plugin-manager/configs
[0003.812] E> “ids” doesn’t exist, creating
[0003.816] I> Adding /chosen/plugin-manager/ids
[0003.821] E> “odm-data” doesn’t exist, creating
[0003.825] I> Adding /chosen/plugin-manager/odm-data
[0003.833] E> “memory” doesn’t exist, creating
[0003.834] I> [0] START: 0x80000000, END: 0xaa000000
[0003.838] I> [1] START: 0xaa004000, END: 0xf0cd0000
[0003.843] I> [2] START: 0xf0cdc000, END: 0xf0ce0000
[0003.848] I> dram_block larger than 80000000
[0003.852] I> [3] START: 0x100000000, END: 0x480000000
[0003.857] I> added [base:0x80000000, size:0x2a000000] to /memory
[0003.863] I> added [base:0xaa200000, size:0x46a00000] to /memory
[0003.869] I> added [base:0x100000000, size:0x380000000] to /memory
[0003.875] I> Updated memory info to DTB
[0003.879] E> “reset” doesn’t exist, creating
[0003.883] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0003.887] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0003.892] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0003.897] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0003.901] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0003.906] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0003.911] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0003.916] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0003.921] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0003.925] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0003.930] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0003.935] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0003.940] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0003.945] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0003.950] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0003.954] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0003.961] E> “misc-data” doesn’t exist, creating
[0003.964] I> Boot-device: eMMC
[0003.966] I> Add boot-sdmmc to plugin-manager/misc-data
[0003.972] I> Add storage-sdmmc to plugin-manager/misc-data
[0003.977] W> Unknown storage device
[0003.980] I> Add serial number as DT property
[0003.986] I> Plugin-manager override starting
[0003.990] I> node /plugin-manager/fragment-p2888@0 matches
[0004.007] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0004.009] I> node /plugin-manager/fragement-soft-wdt matches
[0004.016] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0004.025] I> Disable plugin-manager status in FDT
[0004.026] I> Plugin-manager override finished successfully
[0004.050] I> Filling next stage params: ep: 0x80080000, dtb: 0x91000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.108-tegra (buildbrain@mobile-u64-2565) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Wed Oct 31 15:17:21 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2a000000
[ 0.000000] OF: fdt: - aa200000 , 46a00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0791000
[ 0.000000] Found lut_mem: 00002008@a078e000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000ec800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffdb5000 s54424 r8192 d31592 u94208
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4066272
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa078e000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 16124832K/16523264K available (15358K kernel code, 2942K rwdata, 6724K rodata, 8512K init, 1623K bss, 332896K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009620000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009620000 - 0xffffff8009e70000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a14f808 - 0xffffff800a2e5584 ( 1624 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009266] Console: colour dummy device 80x25
[ 0.012571] console [tty0] enabled
[ 0.016021] bootconsole [tegra_comb_uart0] disabled
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.020937] kmemleak: Kernel memory leak detector disabled
[ 0.021028] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021078] pid_max: default: 32768 minimum: 301
[ 0.022491] Security Framework initialized
[ 0.023194] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023234] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025520] ftrace: allocating 47985 entries in 188 pages
[ 0.501456] sched-energy: Sched-energy-costs installed from DT
[ 0.501666] ASID allocator initialised with 65536 entries
[ 0.544348] tegra-id: chipid=21917.
[ 0.544416] tegra-id: opt_subrevision=0.
[ 0.544513] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.544574] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.544637] DTB Build time: Oct 31 2018 15:19:25
[ 0.545910] tegra-roc-flush: DT required.
[ 0.595052] CPU1: Booted secondary processor [4e0f0040]
[ 0.626295] CPU2: Booted secondary processor [4e0f0040]
[ 0.658694] CPU3: Booted secondary processor [4e0f0040]
[ 0.691245] CPU4: Booted secondary processor [4e0f0040]
[ 0.723374] CPU5: Booted secondary processor [4e0f0040]
[ 0.756022] CPU6: Booted secondary processor [4e0f0040]
[ 0.787980] CPU7: Booted secondary processor [4e0f0040]
[ 0.789275] Brought up 8 CPUs
[ 0.789584] SMP: Total of 8 processors activated.
[ 0.789629] CPU features: detected feature: Privileged Access Never
[ 0.789666] CPU features: detected feature: LSE atomic instructions
[ 0.789703] CPU features: detected feature: User Access Override
[ 0.789739] CPU features: detected feature: 32-bit EL0 Support
[ 0.794664] CPU: All CPU(s) started at EL2
[ 0.794798] alternatives: patching kernel code
[ 0.811043] devtmpfs: initialized
[ 0.892503] Initilizing CustomIPI irq domain
[ 0.893205] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.893267] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.895134] pinctrl core: initialized pinctrl subsystem
[ 0.895499] OS set in device tree is not L4T.
[ 0.895957] regulator-dummy: no parameters
[ 0.896272] Initializing plugin-manager
[ 0.896343] Plugin module not found
[ 0.896397] Plugin-manager status disabled
[ 0.898128] NET: Registered protocol family 16
[ 0.900255] pstore: using zlib compression
[ 0.901508] console [pstore-1] enabled
[ 0.901536] pstore: Registered ramoops as persistent store backend
[ 0.901570] ramoops: attached 0x200000@0xf0a00000, ecc: 0/0
[ 0.915130] cpuidle: using governor menu
[ 0.916896] bpmp: waiting for handshake
[ 0.916991] bpmp: handshake completed
[ 0.917045] bpmp: synchronizing channels
[ 0.917078] bpmp: channels synchronized
[ 0.917113] bpmp: mail init ok
[ 0.921702] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.922075] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.922135] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.922168] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.922201] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.922232] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.922267] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.922316] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.922366] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.922435] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.922471] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.926781] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e74000)
[ 0.926912] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.933472] atomic_pool_init():622: DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.934900] Registering BPMP clocks…
[ 0.935111] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.935789] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.936332] tegra_powergate_init: DONE
[ 0.936394] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.936507] DTB Build time: Oct 31 2018 15:19:25
[ 0.940605] tegra_debug_uart_syscore_init: stdout-path property missing
[ 0.940662] Tegra reboot handler registered.
[ 0.950412] iommu: Adding device 14180000.pcie to group 0
[ 0.951617] iommu: Adding device 14100000.pcie to group 1
[ 0.952549] iommu: Adding device 14140000.pcie to group 2
[ 0.953525] iommu: Adding device 141a0000.pcie to group 3
[ 0.955729] iommu: Adding device 2490000.ether_qos to group 4
[ 0.956533] iommu: Adding device 3100000.serial to group 5
[ 0.957335] iommu: Adding device 3110000.serial to group 6
[ 0.957982] iommu: Adding device 3140000.serial to group 7
[ 0.958839] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.959220] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.959305] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.959353] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.959399] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.959512] tegra-pmc: PMC Prod config success
[ 0.959866] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.959947] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.960552] iommu: Adding device 3460000.sdhci to group 8
[ 0.961320] iommu: Adding device 3400000.sdhci to group 9
[ 0.962152] iommu: Adding device c260000.spi to group 10
[ 0.963288] iommu: Adding device 3160000.i2c to group 11
[ 0.963938] iommu: Adding device c240000.i2c to group 12
[ 0.964492] iommu: Adding device 3180000.i2c to group 13
[ 0.965143] iommu: Adding device 3190000.i2c to group 14
[ 0.965831] iommu: Adding device 31b0000.i2c to group 15
[ 0.966497] iommu: Adding device 31c0000.i2c to group 16
[ 0.967081] iommu: Adding device c250000.i2c to group 17
[ 0.967704] iommu: Adding device 31e0000.i2c to group 18
[ 0.968890] iommu: Adding device sound to group 19
[ 0.969682] iommu: Adding device 3510000.hda to group 20
[ 0.970566] iommu: Adding device bc00000.rtcpu to group 21
[ 0.973651] iommu: Adding device 13e10000.host1x to group 22
[ 0.974317] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.975712] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.977093] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.978636] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.979854] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.981071] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.982356] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.983619] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 0.985103] iommu: Adding device 15340000.vic to group 31
[ 0.986444] iommu: Adding device 15380000.nvjpg to group 32
[ 0.986895] iommu: Adding device 15500000.tsec to group 33
[ 0.987349] iommu: Adding device 15100000.tsecb to group 34
[ 0.987810] iommu: Adding device 15480000.nvdec to group 35
[ 0.988225] iommu: Adding device 15140000.nvdec1 to group 36
[ 0.988690] iommu: Adding device 154c0000.nvenc to group 37
[ 0.989150] iommu: Adding device 15a80000.nvenc1 to group 38
[ 0.989835] iommu: Adding device 15880000.nvdla0 to group 39
[ 0.990457] iommu: Adding device 158c0000.nvdla1 to group 40
[ 0.991252] iommu: Adding device 15200000.nvdisplay to group 41
[ 0.991690] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0791000(800000)
[ 0.991768] platform 15200000.nvdisplay: IOVA linear map 0x00000000a078e000(3000)
[ 0.991831] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.992394] iommu: Adding device 15210000.nvdisplay to group 42
[ 0.992505] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.993076] iommu: Adding device 15220000.nvdisplay to group 43
[ 0.993168] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.995906] iommu: Adding device 15c10000.vi to group 44
[ 0.996188] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.996702] iommu: Adding device 14800000.isp to group 45
[ 0.998542] iommu: Adding device 16000000.pva0 to group 46
[ 0.999336] iommu: Adding device 16800000.pva1 to group 47
[ 0.999914] iommu: Adding device 15810000.se to group 48
[ 1.000523] iommu: Adding device 15820000.se to group 49
[ 1.000908] iommu: Adding device 15830000.se to group 50
[ 1.001360] iommu: Adding device 15840000.se to group 51
[ 1.001765] iommu: Adding device c1a0000.aon to group 52
[ 1.003955] iommu: Adding device d000000.bpmp to group 53
[ 1.004477] bpmp: ping status is 0
[ 1.004697] bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
[ 1.009405] bpmp d000000.bpmp: probe ok
[ 1.011712] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.012399] iommu: Adding device smmu_test to group 54
[ 1.013723] mc: mapped MMIO address: 0xffffff800a6c0000 → 0x2c10000
[ 1.013816] mc: mapped MMIO address: 0xffffff800a6e0000 → 0x2c20000
[ 1.013894] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c30000
[ 1.013970] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c40000
[ 1.014043] mc: mapped MMIO address: 0xffffff800b210000 → 0x2c50000
[ 1.014118] mc: mapped MMIO address: 0xffffff800b230000 → 0x2b80000
[ 1.014192] mc: mapped MMIO address: 0xffffff800b250000 → 0x2b90000
[ 1.014265] mc: mapped MMIO address: 0xffffff800b270000 → 0x2ba0000
[ 1.014337] mc: mapped MMIO address: 0xffffff800b290000 → 0x2bb0000
[ 1.014410] mc: mapped MMIO address: 0xffffff800b2b0000 → 0x1700000
[ 1.014508] mc: mapped MMIO address: 0xffffff800b2d0000 → 0x1710000
[ 1.014583] mc: mapped MMIO address: 0xffffff800b2f0000 → 0x1720000
[ 1.014657] mc: mapped MMIO address: 0xffffff800b310000 → 0x1730000
[ 1.014730] mc: mapped MMIO address: 0xffffff800b330000 → 0x1740000
[ 1.014805] mc: mapped MMIO address: 0xffffff800b350000 → 0x1750000
[ 1.014878] mc: mapped MMIO address: 0xffffff800b370000 → 0x1760000
[ 1.014950] mc: mapped MMIO address: 0xffffff800b390000 → 0x1770000
[ 1.015111] mc-err: mcerr ops are set to t19x
[ 1.023993] iommu: Adding device 2600000.dma to group 55
[ 1.031763] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.032513] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.042587] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.043062] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.046315] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.046384] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.047960] iommu: Adding device 3550000.xudc to group 56
[ 1.049056] iommu: Adding device 3610000.xhci to group 57
[ 1.050847] arm64_ras arm64_ras: RAS driver enabled
[ 1.051861] carmel_ras_enable:RAS enabled on cpu0
[ 1.052236] carmel_ras_enable:RAS enabled on cpu1
[ 1.052584] carmel_ras_enable:RAS enabled on cpu2
[ 1.053018] carmel_ras_enable:RAS enabled on cpu3
[ 1.053388] carmel_ras_enable:RAS enabled on cpu4
[ 1.053712] carmel_ras_enable:RAS enabled on cpu5
[ 1.054097] carmel_ras_enable:RAS enabled on cpu6
[ 1.054405] carmel_ras_enable:RAS enabled on cpu7
[ 1.054704] carmel_ras_enable:RAS enabled on cpu0
[ 1.054967] carmel_ras_enable:RAS enabled on cpu1
[ 1.055229] carmel_ras_enable:RAS enabled on cpu2
[ 1.055480] carmel_ras_enable:RAS enabled on cpu3
[ 1.055710] carmel_ras_enable:RAS enabled on cpu4
[ 1.055944] carmel_ras_enable:RAS enabled on cpu5
[ 1.056178] carmel_ras_enable:RAS enabled on cpu6
[ 1.056430] carmel_ras_enable:RAS enabled on cpu7
[ 1.056592] carmel_ras carmel_ras: probed
[ 1.058696] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 1.059612] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 1.061008] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 1.062585] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 1.063905] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.064590] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.068178] vdd-3v3-cvb: 3300 mV
[ 1.068699] vdd-1v8-cvb: 1800 mV
[ 1.069407] vdd-1v8-sd: 1800 mV
[ 1.070337] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.070497] vdd-epb-1v0: 1000 mV
[ 1.071133] vdd-sdmmc1-sw: 3300 mV
[ 1.071942] avdd-cam-2v8: 2800 mV
[ 1.072445] vdd-sata-1v5: 1500 mV
[ 1.073053] vdd-1v8-slt: 1800 mV
[ 1.073469] vdd-3v3-slt: 3300 mV
[ 1.074226] vdd-fan: 5000 mV
[ 1.074898] vdd-hdmi-5v0: 5000 mV
[ 1.075516] vdd_sys_en: 1200 mV
[ 1.076270] vdd-5v-sata: 5000 mV
[ 1.077215] vdd-ac-bat: 5000 mV
[ 1.077747] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.122514] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.123168] SCSI subsystem initialized
[ 1.123922] usbcore: registered new interface driver usbfs
[ 1.124174] usbcore: registered new interface driver hub
[ 1.124389] usbcore: registered new device driver usb
[ 1.139139] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.142568] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.151323] vdd-1v0: at 1000 mV
[ 1.155378] vdd-1v8-hs: at 1800 mV
[ 1.163643] vdd-1v8-ls: at 1800 mV
[ 1.171700] vdd-1v8-ao: at 1800 mV
[ 1.179704] vddio-ddr-1v1: at 1100 mV
[ 1.187464] vdd-rtc: at 800 mV
[ 1.189321] spmic-ldo1: at 2375 mV
[ 1.199531] vdd-ao-3v3: at 3300 mV
[ 1.211732] vddio-emmc-3v3: at 3300 mV
[ 1.213685] spmic-ldo4: at 1587 mV
[ 1.223797] vdd-usb-3v3: at 3300 mV
[ 1.235893] vddio-sdmmc1-3v3: at 3300 mV
[ 1.243894] vdd-csi-1v2: at 1200 mV
[ 1.246039] spmic-ldo8: at 1800 mV
[ 1.248825] GPIO line 246 (gpio_default) hogged as output/high
[ 1.250548] GPIO line 247 (gpio_default) hogged as output/high
[ 1.251440] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.255549] max77620 4-003c: max77620 probe successful
[ 1.256524] media: Linux media interface: v0.10
[ 1.256646] Linux video capture interface: v2.00
[ 1.258840] pps_core: LinuxPPS API ver. 1 registered
[ 1.258911] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.259035] PTP clock support registered
[ 1.260421] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.260563] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.262479] tegra_fiq_debugger_init: found FIQ source (IRQ 468)
[ 1.264266] Advanced Linux Sound Architecture Driver Initialized.
[ 1.265073] Bluetooth: Core ver 2.22
[ 1.265178] NET: Registered protocol family 31
[ 1.265231] Bluetooth: HCI device and connection manager initialized
[ 1.265320] Bluetooth: HCI socket layer initialized
[ 1.265389] Bluetooth: L2CAP socket layer initialized
[ 1.265546] Bluetooth: SCO socket layer initialized
[ 1.269429] camchar: rtcpu character device driver loaded
[ 1.271251] clocksource: Switched to clocksource arch_sys_counter
[ 1.328364] VFS: Disk quotas dquot_6.6.0
[ 1.328593] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.329174] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.331736] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.331930] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.332004] nvmap_page_pool_init: Total RAM pages: 4047592
[ 1.332053] nvmap_page_pool_init: nvmap page pool size: 505949 pages (1976 MB)
[ 1.332653] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.334260] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.352310] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.352945] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.353368] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.353956] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.354506] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.354949] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.355388] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.370731] la/ptsa driver initialized.
[ 1.371236] NET: Registered protocol family 2
[ 1.372437] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.373333] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.374250] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.374359] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.374738] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.375494] NET: Registered protocol family 1
[ 1.376509] RPC: Registered named UNIX socket transport module.
[ 1.376565] RPC: Registered udp transport module.
[ 1.376606] RPC: Registered tcp transport module.
[ 1.376646] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.377045] Trying to unpack rootfs image as initramfs…
[ 1.401978] random: fast init done
[ 1.406685] host1x 13e10000.host1x: initialized
[ 1.409142] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.415464] audit: initializing netlink subsys (disabled)
[ 1.415590] audit: type=2000 audit(0.956:1): initialized
[ 1.416538] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.429852] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.431527] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.432472] 9p: Installing v9fs 9p2000 file system support
[ 1.439390] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.439690] io scheduler noop registered
[ 1.440019] io scheduler cfq registered (default)
[ 1.444335] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.485344] iommu: Adding device 2993000.adsp to group 58
[ 1.587774] iommu: Adding device aconnect@2a41000:adsp_audio to group 59
[ 1.588969] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.605574] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.606205] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.606830] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.609949] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.610370] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.610447] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.614825] tsec 15500000.tsec: initialized
[ 1.617818] tsec 15100000.tsecb: initialized
[ 1.623549] nvdec 15480000.nvdec: initialized
[ 1.626981] nvdec 15140000.nvdec1: initialized
[ 1.633174] falcon 15340000.vic: initialized
[ 1.635830] falcon 15380000.nvjpg: initialized
[ 1.638079] falcon 154c0000.nvenc: initialized
[ 1.640540] falcon 15a80000.nvenc1: initialized
[ 1.643595] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.646163] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.648796] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.651431] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.654084] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.656538] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.658534] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.660536] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.665039] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.671513] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.672184] scare-pigeon 14b00000.isp-thi: initialized
[ 1.683076] pva 16000000.pva0: initialized
[ 1.716103] pva 16800000.pva1: initialized
[ 1.747866] nvdla 15880000.nvdla0: initialized
[ 1.779135] nvdla 158c0000.nvdla1: initialized
[ 1.783327] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.783592] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.783641] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.783698] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.785341] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.785413] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.785524] tegradccommon 15200000.dc_common: dma mapping done
[ 1.785991] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.786218] generic_infoframe_type: 0x87
[ 1.786451] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.786555] tegradc 15200000.nvdisplay: Display dc.ffffff800bf90000 registered with id=0
[ 1.794178] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.794259] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.794311] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.794655] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.794713] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.796854] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.797932] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.799137] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.799755] kfuse 3830000.kfuse: initialized
[ 1.800038] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.800097] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.804643] tegradc 15200000.nvdisplay: probed
[ 1.811117] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.814847] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.816635] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.817706] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.234888] console [ttyTCU0] enabled
[ 4.235611] Console: switching to colour frame buffer device 240x67
[ 4.239789] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:290 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.239789]
[ 4.258402] tegradc 15200000.nvdisplay: fb registered
[ 4.264009] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.268678] brd: module loaded
[ 4.279923] loop: module loaded
[ 4.280209] tegra_profiler: version: 1.128, samples/io: 44/25
[ 4.280923] tegra_profiler: auth: init
[ 4.284833] nct1008_nct72 4-004c: starting parse dt
[ 4.285400] THERMAL EST: found 3 subdevs
[ 4.285404] THERMAL EST num_resources: 0
[ 4.285407] [THERMAL EST subdev 0]
[ 4.285415] [THERMAL EST subdev 1]
[ 4.285419] [THERMAL EST subdev 2]
[ 4.285884] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.285886] THERMAL EST: thz register success.
[ 4.286167] THERMAL EST: end of probe, return err: 0
[ 4.287122] hisi_sas: driver version v1.6
[ 4.330064] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.335664] nct1008_nct72 4-004c: success parsing dt
[ 4.336477] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.336718] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.352806] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.353839] Parent Clock set for DC plld3
[ 4.356787] libphy: Fixed MDIO Bus: probed
[ 4.357490] tun: Universal TUN/TAP device driver, 1.6
[ 4.357492] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.358312] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.358315] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.358368] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.358370] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.358435] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.358437] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.358495] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.358497] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.362821] sky2: driver version 1.30
[ 4.364671] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.364851] PPP generic driver version 2.4.2
[ 4.365204] PPP BSD Compression module registered
[ 4.365210] PPP Deflate Compression module registered
[ 4.365230] PPP MPPE Compression module registered
[ 4.365234] NET: Registered protocol family 24
[ 4.365309] usbcore: registered new interface driver r8152
[ 4.365367] usbcore: registered new interface driver asix
[ 4.365480] usbcore: registered new interface driver ax88179_178a
[ 4.365533] usbcore: registered new interface driver cdc_ether
[ 4.365644] usbcore: registered new interface driver net1080
[ 4.365697] usbcore: registered new interface driver cdc_subset
[ 4.365735] usbcore: registered new interface driver zaurus
[ 4.365815] usbcore: registered new interface driver cdc_ncm
[ 4.366106] VFIO - User Level meta-driver version: 0.3
[ 4.367890] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.367907] ehci-pci: EHCI PCI platform driver
[ 4.367952] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.367959] ohci-pci: OHCI PCI platform driver
[ 4.368000] ohci-platform: OHCI generic platform driver
[ 4.369269] eqos 2490000.ether_qos: No prod values found
[ 4.369962] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb a5 d3
[ 4.370146] libphy: dwc_phy: probed
[ 4.377162] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.377167] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.380204] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.383776] usbcore: registered new interface driver uas
[ 4.383883] usbcore: registered new interface driver usb-storage
[ 4.383981] usbcore: registered new interface driver usbserial
[ 4.388070] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.391274] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.391282] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
[ 4.392398] ucsi_ccg 1-0008: fw_mode: 2
[ 4.392402] ucsi_ccg 1-0008: fw1_invalid: 0
[ 4.392406] ucsi_ccg 1-0008: fw2_invalid: 0
[ 4.392410] ucsi_ccg 1-0008: silicon_id: 0x1f00
[ 4.392607] ucsi_ccg 1-0008: typec-port0 extcon dev created
[ 4.392787] ucsi_ccg 1-0008: typec-port1 extcon dev created
[ 4.392938] ucsi_ccg 1-0008: typec-pd extcon dev created
[ 4.393113] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[ 4.398892] ucsi_ccg 1-0008: HPI Command Success.
[ 4.401440] ucsi_ccg 1-0008: HPI Command Success.
[ 4.401458] ucsi_ccg 1-0008: ucsi_ccg_init: complete
[ 4.402289] mousedev: PS/2 mouse device common for all mice
[ 4.419784] tegradc 15200000.nvdisplay: hdmi: tmds rate:148367K prod-setting:prod_c_hdmi_111m_223m
[ 4.421334] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 4.421387] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 4.421554] tegradc 15210000.nvdisplay: DT parsed successfully
[ 4.421612] tegradc 15210000.nvdisplay: Display dc.ffffff800d310000 registered with id=1
[ 4.421879] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 4.421886] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 4.428692] tegradc 15210000.nvdisplay: probed
[ 4.533125] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.534863] Wake73 for irq=42
[ 4.5
Your log is being truncated by the system. Please try to attach it or use the codeblock.
I attach a code.
XAVIER_Kernel.log (88.4 KB)
I saw some i2c errors. Is this a stock development kit, or does it use another carrier board? If a different carrier board, was the device tree updated for that board? For anything PCIe, is this an FPGA (or anything which needs the card to boot before the system can detect it)?
Hi archcafe,
Have you found the cause and resolved the problem?
Any result can be shared?
