Hi,bellow is booting log and dmesg about “lspci -vv”,sorry about taht i don’t know how to attach a fie.I want to use pcie C0x4 to connect with FPGA,but there is no C0 itself and device (FPGA).And the hardware designer said there is no PEX_CLK0_P/N output ,does the pair of pins need pinmux configuratons or not? Thanks!
[BEGIN] 2019/9/21 15:49:04
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
?[0000.717] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-28aef4f2)
[0000.718] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.719] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.719] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.725] W> device prod register failed
[0000.729] I> Boot-device: eMMC
[0000.732] I> Boot_device: SDMMC_BOOT instance: 3
[0000.738] I> sdmmc-3 params source = boot args
[0000.741] I> sdmmc bdev is already initialized
[0000.745] I> sdmmc-3 params source = boot args
[0000.751] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0000.758] I> Found 37 partitions in SDMMC_USER (instance 3)
[0000.761] W> No valid slot number is found in scratch register
[0000.766] W> Return default slot: _a
[0000.769] I> Active Boot chain : 0
[0000.773] I> parsing oem signed section of bpmp-fw header done
[0000.778] I> bpmp-fw binary init read from storage
[0000.783] I> oem authentication of bpmp-fw header done
[0000.790] I> bpmp-fw binary done read from storage
[0000.792] I> bpmp-fw: Authentication init Done
[0000.797] I> parsing oem signed section of cpubl header done
[0000.802] I> cpubl binary init read from storage
[0000.807] I> bpmp-fw: Authentication Finalize Done
[0000.812] I> oem authentication of cpubl header done
[0000.816] I> cpubl binary done read from storage
[0000.821] I> cpubl: Authentication init Done
[0000.825] I> parsing oem signed section of rce header done
[0000.830] I> rce binary init read from storage
[0000.835] I> Relocating BR-BCT
[0000.837] I> cpubl: Authentication Finalize Done
[0000.842] I> oem authentication of rce header done
[0000.846] I> rce binary done read from storage
[0000.851] I> rce: Authentication init Done
[0000.855] I> parsing oem signed section of tos header done
[0000.860] I> tos binary init read from storage
[0000.864] I> rce: Authentication Finalize Done
[0000.869] I> oem authentication of tos header done
[0000.873] I> tos binary done read from storage
[0000.877] I> tos: Authentication init Done
[0000.882] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.887] I> bpmp-fw-dtb binary init read from storage
[0000.892] I> tos: Authentication Finalize Done
[0000.898] I> oem authentication of bpmp-fw-dtb header done
[0000.905] I> bpmp-fw-dtb binary done read from storage
[0000.907] I> bpmp-fw-dtb: Authentication init Done
[0000.912] I> parsing oem signed section of cpubl-dtb header done
[0000.917] I> cpubl-dtb binary init read from storage
[0000.922] I> bpmp-fw-dtb: Authentication Finalize Done
[0000.960] I> oem authentication of cpubl-dtb header done
[0000.961] I> cpubl-dtb binary done read from storage
[0000.961] I> cpubl-dtb: Authentication init Done
[0000.963] I> parsing oem signed section of eks header done
[0000.964] I> eks binary init read from storage
[0000.964] I> cpubl-dtb: Authentication Finalize Done
[0000.965] I> oem authentication of eks header done
[0000.969] I> eks binary done read from storage
[0000.973] I> eks: Authentication init Done
[0000.977] I> eks: Authentication Finalize Done
[0000.981] I> EKB detected (length: 0x410) @ VA:0x5270a400
銷OTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:56:20, Jul 16 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea88ed58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is c1b4e372932429f2737cf722e1219e71
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
392 clocks registered
WARNING: pll_c4 has no dyn ramp
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg initialized
mrq initialized
?[0001.455] I> Welcome to Cboot
[0001.455] I> Cboot Version: t194-fd5a836a
鈌mon_post initialized
醄0001.456] I> CPU-BL Params @ 0xea820000
[0001.456] I> 0) Base:0x00000000 Size:0x00000000
[0001.457] I> 1) Base:0xe9100000 Size:0x00100000
[0001.462] I> 2) Base:0xea000000 Size:0x00200000
[0001.466] I> 3) Base:0xe9200000 Size:0x00200000
[0001.470] I> 4) Base:0xe9000000 Size:0x00100000
[0001.475] I> 5) Base:0xe8f00000 Size:0x00100000
[0001.479] I> 6) Base:0xeb800000 Size:0x00400000
[0001.484] I> 7) Base:0xe9c00000 Size:0x00400000鈉lk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster1: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
clk_debugfs initialized
?[0001.553] I> 8) Base:0xe8e00000 Size:0x00100000
[0001.558] I> 9) Base:0xe8d00000 Size:0x00100000
[0001.562] I> 10) Base:0xeb000000 Size:0x00800000
[0001.566] I> 11) Base:0x40000000 Size:0x00040000
[0001.571] I> 12) Base:0xe8c00000 Size:0x00100000
[0001.575] I> 13) Base:0x40046000 Size:0x00002000
[0001.580] I> 14) Base:0x40048000 Size:0x00002000
[0001.584] I> 15) Base:0xab000000 Size:0x00004000
[0001.589] I> 16) Base:0x4004a000 Size:0x00002000
[0001.593] I> 17) Base:0xe8b00000 Size:0x00100000
[0001.598] I> 18) Base:0x4004c000 Size:0x00002000
[0001.602] I> 19) Base:0xea200000 Size:0x00600000
[0001.607] I> 20) Base:0x4004e000 Size:0x00002000
鈋mc_debugfs initialized
醄0001.611] I> 21) Base:0xe8ad0000 Size:0x0000c000
鈊vs_debugfs initialized
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] 醄0001.618] I> 22) Base:0x00000000 Size:0x00000000
[0001.671] I> 23) Base:0xe8ae0000 Size:0x00020000
[0001.675] I> 24) Base:0xee000000 Size:0x02000000
[0001.680] I> 25) Base:0x40050000 Size:0x00002000
[0001.684] I> 26) Base:0x40040000 Size:0x00006000
[0001.689] I> 27) Base:0xe9800000 Size:0x00400000
[0001.693] I> 28) Base:0xecc00000 Size:0x01400000
[0001.698] I> 29) Base:0xe9400000 Size:0x00400000
[0001.702] I> 30) Base:0x00000000 Size:0x00000000
[0001.706] I> 31) Base:0x00000000 Size:0x00000000
[0001.711] I> 32) Base:0xf8000000 Size:0x08000000
[0001.715] I> 33) Base:0xf0000000 Size:0x08000000
[0001.720] I> 34) Base:0xebc00000 Size:0x01000000
[0001.724] I> 35) Base:0xaa000000 Size:0x01000000
[0001.729] I> 36) Base:0xa0000000 Size:0x0a000000
[0001.733] I> 37) Base:0xea800000 Size:0x00800000
[0001.738] I> 38) Base:0x80000000 Size:0x20000000
[0001.742] I> 39) Base:0xb0000000 Size:0x08000000
[0001.747] I> 40) Base:0x00000000 Size:0x00000000
[0001.751] I> 41) Base:0x00000000 Size:0x00000000
[0001.756] I> 42) Base:0x00000000 Size:0x00000000
[0001.760] I> 43) Base:0x00000000 Size:0x00000000
[0001.765] I> 44) Base:0x00000000 Size:0x00000000
[0001.769] I> 45) Base:0x00000000 Size:0x00000000
[0001.773] GIC-SPI Target CPU: 0
[0001.776] Interrupts Init done
[0001.779] calling constructors
[0001.782] initializing heap
[0001.785] I> Heap: [0xa068d470 … 0xaa000000]
[0001.789] initializing threads
[0001.792] initializing timers
[0001.795] creating bootstrap completion thread
[0001.799] top of bootstrap2()
[0001.802] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.807] initializing platform
[0001.809] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.815] W> device prod register failed
[0001.819] I> Bl_dtb @0xa9f00000
[0001.822] I> gpio framework initialized
[0001.833] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0001.840] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0001.840] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.856] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.862] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.863] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.868] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.878] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.886] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.890] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.900] I> fixed regulator driver initialized
[0001.911] I> register ‘maxim’ power off handle
[0001.912] I> virtual i2c enabled
[0001.912] I> registered ‘maxim,max20024’ pmic
[0001.913] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0001.919] I> Boot-device: eMMC
[0001.922] I> Boot_device: SDMMC_BOOT instance: 3
[0001.928] I> sdmmc-3 params source = boot args
[0001.930] I> sdmmc bdev is already initialized
[0001.935] I> sdmmc-3 params source = boot args
[0001.941] I> Found 15 partitions in SDMMC_BOOT (instance 3)
[0001.946] I> Found 37 partitions in SDMMC_USER (instance 3)
[0001.950] E> “plugin-manager” doesn’t exist, creating
[0001.955] E> “ids” doesn’t exist, creating
[0001.959] E> “connection” doesn’t exist, creating
[0001.963] E> “configs” doesn’t exist, creating
[0001.969] I> Find /i2c@3160000’s alias i2c0
[0001.971] I> Reading eeprom i2c=0 address=0x50
[0002.001] I> Device at /i2c@3160000:0x50
[0002.001] I> Reading eeprom i2c=0 address=0x56
[0002.002] E> I2C: slave not found in slaves.
[0002.002] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.003] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.004] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.011] E> eeprom: Failed to read I2C slave device
[0002.016] I> Eeprom read failed 0x3526070d
[0002.021] I> Find /i2c@3180000’s alias i2c2
[0002.024] I> Reading eeprom i2c=2 address=0x54
[0002.029] E> I2C: slave not found in slaves.
[0002.032] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0002.040] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.046] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0002.055] E> eeprom: Failed to read I2C slave device
[0002.060] I> Eeprom read failed 0x3526070d
[0002.064] I> Reading eeprom i2c=2 address=0x57
[0002.068] E> I2C: slave not found in slaves.
[0002.072] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.080] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.086] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.095] E> eeprom: Failed to read I2C slave device
[0002.100] I> Eeprom read failed 0x3526070d
[0002.104] I> Reading eeprom i2c=2 address=0x52
[0002.108] E> I2C: slave not found in slaves.
[0002.112] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.120] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.126] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0002.135] E> eeprom: Failed to read I2C slave device
[0002.140] I> Eeprom read failed 0x3526070d
[0002.145] I> Find /i2c@c240000’s alias i2c1
[0002.148] I> Reading eeprom i2c=1 address=0x52
[0002.154] E> I2C: slave not found in slaves.
[0002.156] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.164] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.170] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.179] E> eeprom: Retry to read I2C slave device.
[0002.184] E> I2C: slave not found in slaves.
[0002.188] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0002.196] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.202] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0002.211] E> eeprom: Failed to read I2C slave device
[0002.216] I> Eeprom read failed 0x3526070d
[0002.220] I> Reading eeprom i2c=1 address=0x50
[0002.224] E> I2C: slave not found in slaves.
[0002.228] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.236] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.242] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.251] E> eeprom: Retry to read I2C slave device.
[0002.256] E> I2C: slave not found in slaves.
[0002.260] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.268] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.274] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0002.283] E> eeprom: Failed to read I2C slave device
[0002.288] I> Eeprom read failed 0x3526070d
[0002.292] I> create_pm_ids: id: 2888-0001-400-J, len: 15
[0002.297] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.308] I> Adding plugin-manager/ids/2888-0001-400=/i2c@3160000:module@0x50
[0002.316] E> “i2c@3160000” doesn’t exist, creating
[0002.320] E> “module@0x50” doesn’t exist, creating
[0002.326] I> Adding plugin-manager/cvm
[0002.328] E> “chip-id” doesn’t exist, creating
[0002.332] I> Adding plugin-manager/chip-id/A02
[0002.337] I> Plugin-manager override starting
[0002.342] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.351] I> node /plugin-manager/fragement-soft-wdt matches
[0002.358] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.362] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.368] I> node /plugin-manager/fragment-p2888@0 matches
[0002.382] I> Disable plugin-manager status in FDT
[0002.382] I> Plugin-manager override finished successfully
[0002.396] I> enabling ‘vdd-hdmi-5v0’ regulator
[0002.402] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.403] I> hdmi cable connected
[0002.406] E> set volts not configured for ‘vdd-1v0’
[0002.408] E> set volts not configured for ‘vdd-1v8-hs’
[0002.414] E> invalid display type
[0002.419] E> invalid display type
[0002.421] E> cannot find any other nvdisp nodes
[0002.426] E> I2C: Timeout while polling for bus clear. Last value 0x00000000.
[0002.426] E> I2C: Failed to clear bus for instance 6.
[0002.427] E> I2C: Failed to clear bus for instance 6.
[0002.429] E> I2C_DEV: Failed to initialize instance 6.
[0002.434] E> read_edid, invalid i2c handle
[0002.441] I> hdmi_enable, starting HDMI initialisation
[0002.447] I> hdmi_enable, HDMI initialisation complete
[0002.456] I> Load in CBoot Boot Options partition and parse it
[0002.457] E> Error -9 when finding node with path /boot-configuration
[0002.459] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.467] I> Hit any key to stop autoboot: 4 3 2 1
[0004.475] initializing target
[0004.475] calling apps_init()
[0004.476] starting app kernel_boot_app
[0004.479] I> found decompressor handler: lz4-legacy
[0004.480] I> decompressing BMP blob …
[0004.484] I> Kernel type = Normal
[0004.485] I> Loading kernel & kernel-dtb from removable storage (5)
[0004.485] I> No sdcard
[0004.485] I> -0 params source =
[0004.486] E> Blockdev open: exit error
[0004.486] I> Loading kernel & kernel-dtb from removable storage (6)
[0004.497] W> No valid slot number is found in scratch register
[0004.497] W> Return default slot: _a
[0004.502] I> USB Firmware Version: 60.05 release
[0004.957] E> failed to initialize xhci controller
[0004.958] E> Error in init of XUSB host driver, err: 79790026
[0004.958] W> Failed to initialize device 6-0
[0004.958] I> Loading kernel from partition …
[0004.959] W> No valid slot number is found in scratch register
[0004.959] W> Return default slot: _a
[0004.960] I> A/B: bin_type (37) slot 0
[0004.963] I> Loading partition kernel at 0xa4ad0000 from device(0x1)
[0005.346] I> T19x: Authenticate kernel (bin_type: 37), max size 0x4000000
[0005.747] I> Loading kernel-dtb from partition …
[0005.747] W> No valid slot number is found in scratch register
[0005.748] W> Return default slot: _a
[0005.748] I> A/B: bin_type (38) slot 0
[0005.748] I> Loading partition kernel-dtb at 0x90000000 from device(0x1)
[0005.753] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0005.758] I> Kernel hdr @0xa4ad0000
[0005.759] I> Kernel dtb @0x90000000
[0005.759] I> Checking boot.img header magic … [0005.764] I> [OK]
[0005.766] I> Valid boot.img @ 0xa4ad0000
[0005.769] I> decompressor handler not found
[0005.773] I> Copying kernel image (34179080 bytes) from 0xa4ad0800 to 0x80080000 … [0005.798] I> Done
[0005.798] I> Move ramdisk (len: 5564673) from 0xa6b69800 to 0x91000000
[0005.802] I> Updated bpmp info to DTB
[0005.804] I> Ramdisk: Base: 0x91000000; Size: 0x54e901
[0005.804] I> Updated initrd info to DTB
[0005.804] W> WARN: Fail to override “console=none” in commandline
[0005.807] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0005.814] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0005.822] W> No valid slot number is found in scratch register
[0005.827] W> Return default slot: _a
[0005.831] I> Active slot suffix:
[0005.834] I> add_boot_slot_suffix: slot_suffix =
[0005.838] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[0005.878] I> Updated bootarg info to DTB
[0005.882] W> MAC addr invalid!
[0005.885] E> Failed to get WIFI MAC address
[0005.889] W> MAC addr invalid!
[0005.892] E> Failed to get Bluetooth MAC address
[0005.896] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:cb:e7:ef
[0005.903] E> “plugin-manager” doesn’t exist, creating
[0005.908] I> Adding /chosen/plugin-manager/cvm
[0005.912] E> “chip-id” doesn’t exist, creating
[0005.916] I> Adding /chosen/plugin-manager/chip-id
[0005.921] E> “configs” doesn’t exist, creating
[0005.925] I> Adding /chosen/plugin-manager/configs
[0005.930] E> “ids” doesn’t exist, creating
[0005.934] I> Adding /chosen/plugin-manager/ids
[0005.938] E> “odm-data” doesn’t exist, creating
[0005.942] I> Adding /chosen/plugin-manager/odm-data
[0005.950] E> “memory” doesn’t exist, creating
[0005.952] I> [0] START: 0x80000000, END: 0xab000000
[0005.956] I> [1] START: 0xab004000, END: 0xe8ad0000
[0005.960] I> [2] START: 0xe8adc000, END: 0xe8ae0000
[0005.965] I> dram_block larger than 80000000
[0005.969] I> [3] START: 0x100000000, END: 0x480000000
[0005.974] I> added [base:0x80000000, size:0x2b000000] to /memory
[0005.980] I> added [base:0xab200000, size:0x3d800000] to /memory
[0005.986] I> added [base:0x100000000, size:0x380000000] to /memory
[0005.993] I> Updated memory info to DTB
[0005.996] E> add_disp_param: failed to get display params for du=1
[0006.002] E> “reset” doesn’t exist, creating
[0006.007] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0006.011] I> Enabled cpu-0 (mpidr: 0x0) node in FDT
[0006.015] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0006.020] I> Enabled cpu-1 (mpidr: 0x1) node in FDT
[0006.025] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0006.029] I> Enabled cpu-2 (mpidr: 0x100) node in FDT
[0006.034] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0006.039] I> Enabled cpu-3 (mpidr: 0x101) node in FDT
[0006.044] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0006.049] I> Enabled cpu-4 (mpidr: 0x200) node in FDT
[0006.054] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0006.058] I> Enabled cpu-5 (mpidr: 0x201) node in FDT
[0006.063] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0006.068] I> Enabled cpu-6 (mpidr: 0x300) node in FDT
[0006.073] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0006.078] I> Enabled cpu-7 (mpidr: 0x301) node in FDT
[0006.084] E> “misc-data” doesn’t exist, creating
[0006.087] I> Boot-device: eMMC
[0006.090] I> Add boot-sdmmc to plugin-manager/misc-data
[0006.095] I> Add storage-sdmmc to plugin-manager/misc-data
[0006.100] W> Unknown storage device
[0006.104] I> Add serial number:0424318032264 as DT property
[0006.111] I> Plugin-manager override starting
[0006.114] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0006.121] I> node /plugin-manager/fragement-soft-wdt matches
[0006.129] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0006.134] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0006.141] I> node /plugin-manager/fragment-p2888@0 matches
[0006.154] I> Disable plugin-manager status in FDT
[0006.154] I> Plugin-manager override finished successfully
[0006.155] I> tegrabl_load_kernel_and_dtb: Done
[0006.181] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-922) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jul 16 17:09:53 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2b000000
[ 0.000000] OF: fdt: - ab200000 , 3d800000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0697000
[ 0.000000] Found lut_mem: 00002008@a0692000
[ 0.000000] Found vpr, start=0xf0000000 size=8000000[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000e4800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc3ffd95000 s61592 r8192 d32616 u102400
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4031493
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0697000 lut_mem=0x2008@0xa0692000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr=0x8000000@0xf0000000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29212(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 15987120K/16381940K available (15230K kernel code, 2914K rwdata, 6628K rodata, 8576K init, 609K bss, 329284K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f60000 ( 15232 KB)
[ 0.000000] .rodata : 0xffffff8008f60000 - 0xffffff80095e0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095e0000 - 0xffffff8009e40000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e40000 - 0xffffff800a118808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a118808 - 0xffffff800a1b0dbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000009] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009394] Console: colour dummy device 80x25
[ 0.012429] console [tty0] enabled
[ 0.015626] bootconsole [tegra_comb_uart0] disabled
[ 0.020892] kmemleak: Kernel memory leak detector disabled
[ 0.020980] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021033] pid_max: default: 32768 minimum: 301
[ 0.022454] Security Framework initialized
[ 0.023180] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023222] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025636] ftrace: allocating 46935 entries in 184 pages
[ 0.494282] sched-energy: Sched-energy-costs installed from DT
[ 0.494515] ASID allocator initialised with 65536 entries
[ 0.533521] tegra-id: chipid=21917.
[ 0.533597] tegra-id: opt_subrevision=0.
[ 0.533659] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.533755] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.533845] DTB Build time: Sep 20 2019 19:42:31
[ 0.583604] CPU1: Booted secondary processor [4e0f0040]
[ 0.617394] CPU2: Booted secondary processor [4e0f0040]
[ 0.648136] CPU3: Booted secondary processor [4e0f0040]
[ 0.680562] CPU4: Booted secondary processor [4e0f0040]
[ 0.712764] CPU5: Booted secondary processor [4e0f0040]
[ 0.745152] CPU6: Booted secondary processor [4e0f0040]
[ 0.777403] CPU7: Booted secondary processor [4e0f0040]
[ 0.777738] Brought up 8 CPUs
[ 0.778066] SMP: Total of 8 processors activated.
[ 0.778121] CPU features: detected feature: Privileged Access Never
[ 0.778165] CPU features: detected feature: LSE atomic instructions
[ 0.778219] CPU features: detected feature: User Access Override
[ 0.778261] CPU features: detected feature: 32-bit EL0 Support
[ 0.780796] CPU: All CPU(s) started at EL2
[ 0.780926] alternatives: patching kernel code
[ 0.791125] devtmpfs: initialized
[ 0.873076] Initilizing CustomIPI irq domain
[ 0.873603] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.873694] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.875813] pinctrl core: initialized pinctrl subsystem
[ 0.876212] OS set in device tree is not L4T.
[ 0.876565] regulator-dummy: no parameters
[ 0.876914] Initializing plugin-manager
[ 0.876997] Plugin module not found
[ 0.877082] Plugin-manager status disabled
[ 0.878614] NET: Registered protocol family 16
[ 0.891332] pstore: using zlib compression
[ 0.893231] console [pstore-1] enabled
[ 0.893279] pstore: Registered ramoops as persistent store backend
[ 0.893338] ramoops: attached 0x200000@0xe8800000, ecc: 0/0
[ 0.907556] cpuidle: using governor menu
[ 0.908940] bpmp: waiting for handshake
[ 0.909034] bpmp: handshake completed
[ 0.909109] bpmp: synchronizing channels
[ 0.909174] bpmp: channels synchronized
[ 0.909230] bpmp: mail init ok
[ 0.913194] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.913605] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.913692] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.913758] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.913828] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.913894] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.913964] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.914054] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.914158] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.914234] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.914318] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.919906] vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e44000)
[ 0.920274] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.924675] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.926124] Registering BPMP clocks…
[ 0.926344] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.927331] tegra_powergate_init: DONE
[ 0.927519] DTS File Name: arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.927724] DTB Build time: Sep 20 2019 19:42:31
[ 0.931701] Tegra reboot handler registered.
[ 0.942125] iommu: Adding device 14180000.pcie to group 0
[ 0.943121] iommu: Adding device 14100000.pcie to group 1
[ 0.944141] iommu: Adding device 14140000.pcie to group 2
[ 0.945107] iommu: Adding device 141a0000.pcie to group 3
[ 0.947072] iommu: Adding device 2490000.ether_qos to group 4
[ 0.948051] iommu: Adding device 3100000.serial to group 5
[ 0.948820] iommu: Adding device 3110000.serial to group 6
[ 0.949461] iommu: Adding device 3140000.serial to group 7
[ 0.950311] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.950596] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.950689] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.950753] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.950826] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.950950] tegra-pmc: PMC Prod config success
[ 0.951353] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.951462] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.952064] iommu: Adding device 3460000.sdhci to group 8
[ 0.952875] iommu: Adding device 3400000.sdhci to group 9
[ 0.953697] iommu: Adding device 2450000.ufshci to group 10
[ 0.954497] iommu: Adding device c260000.spi to group 11
[ 0.955803] iommu: Adding device 3160000.i2c to group 12
[ 0.956488] iommu: Adding device c240000.i2c to group 13
[ 0.957093] iommu: Adding device 3180000.i2c to group 14
[ 0.957712] iommu: Adding device 3190000.i2c to group 15
[ 0.958518] iommu: Adding device 31b0000.i2c to group 16
[ 0.959105] iommu: Adding device 31c0000.i2c to group 17
[ 0.959736] iommu: Adding device c250000.i2c to group 18
[ 0.960376] iommu: Adding device 31e0000.i2c to group 19
[ 0.961591] iommu: Adding device sound to group 20
[ 0.962362] iommu: Adding device 3510000.hda to group 21
[ 0.963203] iommu: Adding device bc00000.rtcpu to group 22
[ 0.966142] iommu: Adding device 13e10000.host1x to group 23
[ 0.966795] iommu: Adding device 13e10000.host1x:ctx0 to group 24
[ 0.967454] iommu: Adding device 13e10000.host1x:ctx1 to group 25
[ 0.968118] iommu: Adding device 13e10000.host1x:ctx2 to group 26
[ 0.968698] iommu: Adding device 13e10000.host1x:ctx3 to group 27
[ 0.969336] iommu: Adding device 13e10000.host1x:ctx4 to group 28
[ 0.970123] iommu: Adding device 13e10000.host1x:ctx5 to group 29
[ 0.970811] iommu: Adding device 13e10000.host1x:ctx6 to group 30
[ 0.971420] iommu: Adding device 13e10000.host1x:ctx7 to group 31
[ 0.972336] iommu: Adding device 15340000.vic to group 32
[ 0.972971] iommu: Adding device 15380000.nvjpg to group 33
[ 0.973427] iommu: Adding device 15500000.tsec to group 34
[ 0.973858] iommu: Adding device 15100000.tsecb to group 35
[ 0.974329] iommu: Adding device 15480000.nvdec to group 36
[ 0.974779] iommu: Adding device 15140000.nvdec1 to group 37
[ 0.975262] iommu: Adding device 154c0000.nvenc to group 38
[ 0.975695] iommu: Adding device 15a80000.nvenc1 to group 39
[ 0.976398] iommu: Adding device 15880000.nvdla0 to group 40
[ 0.977058] iommu: Adding device 158c0000.nvdla1 to group 41
[ 0.977925] iommu: Adding device 15200000.nvdisplay to group 42
[ 0.978351] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0697000(800000)
[ 0.978445] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0692000(3000)
[ 0.979746] platform 15200000.nvdisplay: IOVA linear map 0x00000000f0000000(8000000)
[ 0.979850] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.980568] iommu: Adding device 15210000.nvdisplay to group 43
[ 0.980694] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.981272] iommu: Adding device 15220000.nvdisplay to group 44
[ 0.981424] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.984086] iommu: Adding device 15c10000.vi to group 45
[ 0.984421] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.984999] iommu: Adding device 14800000.isp to group 46
[ 0.986819] iommu: Adding device 16000000.pva0 to group 47
[ 0.987676] iommu: Adding device 16800000.pva1 to group 48
[ 0.988366] iommu: Adding device 15810000.se to group 49
[ 0.988976] iommu: Adding device 15820000.se to group 50
[ 0.989442] iommu: Adding device 15830000.se to group 51
[ 0.989878] iommu: Adding device 15840000.se to group 52
[ 0.990311] iommu: Adding device c1a0000.aon to group 53
[ 0.992251] iommu: Adding device d000000.bpmp to group 54
[ 0.992796] bpmp: ping status is 0
[ 0.993002] bpmp d000000.bpmp: firmware tag is c1b4e372932429f2737cf722e1219e71
[ 0.997130] bpmp d000000.bpmp: probe ok
[ 0.999226] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 0.999924] iommu: Adding device smmu_test to group 55
[ 1.001533] mc: mapped MMIO address: 0xffffff800a580000 → 0x2c10000
[ 1.001629] mc: mapped MMIO address: 0xffffff800a5a0000 → 0x2c20000
[ 1.001717] mc: mapped MMIO address: 0xffffff800a5c0000 → 0x2c30000
[ 1.001804] mc: mapped MMIO address: 0xffffff800a5e0000 → 0x2c40000
[ 1.001893] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c50000
[ 1.001977] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2b80000
[ 1.002065] mc: mapped MMIO address: 0xffffff800b010000 → 0x2b90000
[ 1.002150] mc: mapped MMIO address: 0xffffff800b030000 → 0x2ba0000
[ 1.002248] mc: mapped MMIO address: 0xffffff800b050000 → 0x2bb0000
[ 1.002365] mc: mapped MMIO address: 0xffffff800b070000 → 0x1700000
[ 1.002500] mc: mapped MMIO address: 0xffffff800b090000 → 0x1710000
[ 1.002581] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1720000
[ 1.002666] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1730000
[ 1.002746] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1740000
[ 1.002825] mc: mapped MMIO address: 0xffffff800b110000 → 0x1750000
[ 1.002905] mc: mapped MMIO address: 0xffffff800b130000 → 0x1760000
[ 1.002985] mc: mapped MMIO address: 0xffffff800b150000 → 0x1770000
[ 1.003142] mc-err: mcerr ops are set to t19x
[ 1.011715] iommu: Adding device 2600000.dma to group 56
[ 1.019204] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.019342] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.019449] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.020024] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.030694] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.031172] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.034321] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.034386] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.035529] iommu: Adding device 3550000.xudc to group 57
[ 1.036646] iommu: Adding device 3610000.xhci to group 58
[ 1.039910] arm64_ras arm64_ras: probed
[ 1.040522] ras_fhi_enable: FHI 477 enabled on CPU0
[ 1.040668] ras_fhi_enable: FHI 478 enabled on CPU1
[ 1.040817] ras_fhi_enable: FHI 479 enabled on CPU2
[ 1.040946] ras_fhi_enable: FHI 480 enabled on CPU3
[ 1.041068] ras_fhi_enable: FHI 481 enabled on CPU4
[ 1.041192] ras_fhi_enable: FHI 482 enabled on CPU5
[ 1.041309] ras_fhi_enable: FHI 483 enabled on CPU6
[ 1.041439] ras_fhi_enable: FHI 484 enabled on CPU7
[ 1.041766] carmel_ras_enable: RAS enabled on cpu0
[ 1.042068] carmel_ras_enable: RAS enabled on cpu1
[ 1.042374] carmel_ras_enable: RAS enabled on cpu2
[ 1.042655] carmel_ras_enable: RAS enabled on cpu3
[ 1.042937] carmel_ras_enable: RAS enabled on cpu4
[ 1.043200] carmel_ras_enable: RAS enabled on cpu5
[ 1.043481] carmel_ras_enable: RAS enabled on cpu6
[ 1.043757] carmel_ras_enable: RAS enabled on cpu7
[ 1.043945] carmel_ras carmel_ras: probed
[ 1.045547] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.046332] tegra-cbb c600000.aon-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.047510] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.048744] tegra-cbb be00000.rce-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[ 1.049934] tegra-cbb b600000.sce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[ 1.050533] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.054297] vdd-3v3-cvb: 3300 mV
[ 1.054829] vdd-1v8-cvb: 1800 mV
[ 1.055389] vdd-1v8-sd: 1800 mV
[ 1.056077] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.056189] vdd-epb-1v0: 1000 mV
[ 1.056711] vdd-sdmmc1-sw: 3300 mV
[ 1.057278] avdd-cam-2v8: 2800 mV
[ 1.057720] vdd-sata-1v5: 1500 mV
[ 1.058208] vdd-1v8-slt: 1800 mV
[ 1.058649] vdd-3v3-slt: 3300 mV
[ 1.059141] vdd-fan: 5000 mV
[ 1.059650] vdd-hdmi-5v0: 5000 mV
[ 1.060259] vdd_sys_en: 1200 mV
[ 1.060875] vdd-5v-sata: 5000 mV
[ 1.061390] vdd-ac-bat: 5000 mV
[ 1.061675] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.097510] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.103003] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.103659] SCSI subsystem initialized
[ 1.104427] usbcore: registered new interface driver usbfs
[ 1.104592] usbcore: registered new interface driver hub
[ 1.104784] usbcore: registered new device driver usb
[ 1.117685] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.120659] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.129572] vdd-1v0: at 1000 mV
[ 1.133632] vdd-1v8-hs: at 1800 mV
[ 1.137679] vdd-1v8-ls: at 1800 mV
[ 1.141708] vdd-1v8-ao: at 1800 mV
[ 1.145776] vddio-ddr-1v1: at 1100 mV
[ 1.149570] vdd-rtc: at 800 mV
[ 1.150965] spmic-ldo1: at 2375 mV
[ 1.157639] vdd-ao-3v3: at 3300 mV
[ 1.165712] vddio-emmc-3v3: at 3300 mV
[ 1.167240] spmic-ldo4: at 1587 mV
[ 1.173765] vdd-usb-3v3: at 3300 mV
[ 1.181859] vddio-sdmmc1-3v3: at 3300 mV
[ 1.185931] vdd-csi-1v2: at 1200 mV
[ 1.187636] spmic-ldo8: at 1800 mV
[ 1.189860] GPIO line 246 (gpio_default) hogged as output/high
[ 1.191461] GPIO line 247 (gpio_default) hogged as output/high
[ 1.192029] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.195608] max77620 4-003c: max77620 probe successful
[ 1.196371] media: Linux media interface: v0.10
[ 1.196513] Linux video capture interface: v2.00
[ 1.198317] pps_core: LinuxPPS API ver. 1 registered
[ 1.198405] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.198526] PTP clock support registered
[ 1.199200] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.199298] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.200677] tegra_fiq_debugger_init: found FIQ source (IRQ 469)
[ 1.204234] trusty trusty: trusty version: Built: 16:57:18 Jul 16 2019
[ 1.204396] trusty trusty: selected api version: 3 (requested 3)
[ 1.205778] Advanced Linux Sound Architecture Driver Initialized.
[ 1.206508] Bluetooth: Core ver 2.22
[ 1.206597] NET: Registered protocol family 31
[ 1.206643] Bluetooth: HCI device and connection manager initialized
[ 1.206709] Bluetooth: HCI socket layer initialized
[ 1.206762] Bluetooth: L2CAP socket layer initialized
[ 1.206835] Bluetooth: SCO socket layer initialized
[ 1.210365] camchar: rtcpu character device driver loaded
[ 1.211794] clocksource: Switched to clocksource arch_sys_counter
[ 1.275278] VFS: Disk quotas dquot_6.6.0
[ 1.275464] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.276064] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.278055] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.278217] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000f0000000,134217728
[ 1.278301] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.278389] nvmap_page_pool_init: Total RAM pages: 4013164
[ 1.278439] nvmap_page_pool_init: nvmap page pool size: 501645 pages (1959 MB)
[ 1.279111] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.279572] misc nvmap: created heap vpr base 0x00000000f0000000 size (131072KiB)
[ 1.281399] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.299153] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.299540] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.299958] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.300326] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.300892] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.301257] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.301467] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.302931] la/ptsa driver initialized.
[ 1.303513] NET: Registered protocol family 2
[ 1.304838] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.305735] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.306548] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.306656] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.306996] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.307741] NET: Registered protocol family 1
[ 1.308775] RPC: Registered named UNIX socket transport module.
[ 1.308832] RPC: Registered udp transport module.
[ 1.308878] RPC: Registered tcp transport module.
[ 1.308923] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.309353] Trying to unpack rootfs image as initramfs…
[ 1.543542] Freeing initrd memory: 5432K
[ 1.565785] random: fast init done
[ 1.570956] host1x 13e10000.host1x: initialized
[ 1.573928] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.579768] audit: initializing netlink subsys (disabled)
[ 1.579905] audit: type=2000 audit(1.136:1): initialized
[ 1.580977] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.592941] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.594719] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.595627] 9p: Installing v9fs 9p2000 file system support
[ 1.602574] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.602894] io scheduler noop registered
[ 1.603250] io scheduler cfq registered (default)
[ 1.607526] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.647665] iommu: Adding device 2993000.adsp to group 59
[ 1.745879] iommu: Adding device aconnect@2a41000:adsp_audio to group 60
[ 1.746910] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.762468] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.763085] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.763968] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.764478] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.768130] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.768530] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.768617] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.773490] tsec 15500000.tsec: initialized
[ 1.776045] tsec 15100000.tsecb: initialized
[ 1.781942] nvdec 15480000.nvdec: initialized
[ 1.785629] nvdec 15140000.nvdec1: initialized
[ 1.792781] falcon 15340000.vic: initialized
[ 1.795122] falcon 15380000.nvjpg: initialized
[ 1.797317] falcon 154c0000.nvenc: initialized
[ 1.799612] falcon 15a80000.nvenc1: initialized
[ 1.804220] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.808102] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.812064] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.815319] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.817704] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.820068] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.822362] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.824765] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.829045] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.835523] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.836074] scare-pigeon 14b00000.isp-thi: initialized
[ 1.846884] pva 16000000.pva0: initialized
[ 1.879103] pva 16800000.pva1: initialized
[ 1.910615] nvdla 15880000.nvdla0: initialized
[ 1.941606] nvdla 158c0000.nvdla1: initialized
[ 1.945694] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.945960] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.946019] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.946083] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.947237] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.947307] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.947397] tegradccommon 15200000.dc_common: dma mapping done
[ 1.948711] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.948847] generic_infoframe_type: 0x87
[ 1.949006] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.949100] tegradc 15200000.nvdisplay: Display dc.ffffff800bdd0000 registered with id=0
[ 1.955095] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.955233] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.955315] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.956006] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.956078] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.957829] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.960844] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.960916] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.962222] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.963304] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.964199] kfuse 3830000.kfuse: initialized
[ 1.966809] tegradc 15200000.nvdisplay: probed
[ 1.971701] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.975512] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.977363] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.978599] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.470041] console [ttyTCU0] enabled
[ 4.470750] Console: switching to colour frame buffer device 240x67
[ 4.470838] [drm] Initialized
[ 4.482964] tegradc 15200000.nvdisplay: fb registered
[ 4.488529] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.489554] brd: module loaded
[ 4.496050] loop: module loaded
[ 4.496823] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.496925] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.511063] tegra_profiler: version: 1.134, samples/io: 47/26
[ 4.512141] Parent Clock set for DC plld3
[ 4.520930] tegra_profiler: auth: init
[ 4.525191] nct1008_nct72 4-004c: starting parse dt
[ 4.525562] THERMAL EST: found 3 subdevs
[ 4.525570] THERMAL EST num_resources: 0
[ 4.525576] [THERMAL EST subdev 0]
[ 4.525582] [THERMAL EST subdev 1]
[ 4.525588] [THERMAL EST subdev 2]
[ 4.525599] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.525938] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.525943] THERMAL EST: thz register success.
[ 4.526211] THERMAL EST: end of probe, return err: 0
[ 4.527110] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[ 4.527123] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[ 4.528050] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 459
[ 4.528063] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[ 4.541358] scsi host0: ufshcd
[ 4.552506] hisi_sas: driver version v1.6
[ 4.562885] libphy: Fixed MDIO Bus: probed
[ 4.563492] tun: Universal TUN/TAP device driver, 1.6
[ 4.563497] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 4.564685] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.564690] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.564726] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.564730] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.564765] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.564769] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.564813] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.564817] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.570507] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb e7 ef
[ 4.570625] libphy: dwc_phy: probed
[ 4.573155] PPP generic driver version 2.4.2
[ 4.573402] PPP BSD Compression module registered
[ 4.573408] PPP Deflate Compression module registered
[ 4.573469] PPP MPPE Compression module registered
[ 4.573476] NET: Registered protocol family 24
[ 4.573534] usbcore: registered new interface driver r8152
[ 4.573575] usbcore: registered new interface driver asix
[ 4.573613] usbcore: registered new interface driver ax88179_178a
[ 4.573647] usbcore: registered new interface driver cdc_ether
[ 4.573680] usbcore: registered new interface driver net1080
[ 4.573711] usbcore: registered new interface driver cdc_subset
[ 4.573742] usbcore: registered new interface driver zaurus
[ 4.573785] usbcore: registered new interface driver cdc_ncm
[ 4.574039] VFIO - User Level meta-driver version: 0.3
[ 4.575537] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.575555] ehci-pci: EHCI PCI platform driver
[ 4.575622] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.575634] ohci-pci: OHCI PCI platform driver
[ 4.575696] ohci-platform: OHCI generic platform driver
[ 4.578356] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.579170] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.579184] tegradc 15200000.nvdisplay: hdmi: BL set VIC 0
[ 4.579191] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.582740] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.582747] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[ 4.586207] Could not get extcon-dev /xhci@3610000:id(0)
[ 4.589703] usbcore: registered new interface driver uas
[ 4.589750] usbcore: registered new interface driver usb-storage
[ 4.589822] usbcore: registered new interface driver usbserial
[ 4.593282] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.593341] Could not get extcon-dev /xudc@3550000:vbus(0)
[ 4.593948] tegra-i2c c240000.i2c: no acknowledge from address 0x8
[ 4.593997] ucsi_ccg 1-0008: read version failed
[ 4.594004] ucsi_ccg 1-0008: get_fw_info fail, err=-121
[ 4.594039] ucsi_ccg: probe of 1-0008 failed with error -121
[ 4.594612] mousedev: PS/2 mouse device common for all mice
[ 4.594673] usbcore: registered new interface driver xpad
[ 4.729145] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.730871] Wake73 for irq=42
[ 4.732223] rtc rtc1: alarm rtc device
[ 4.732243] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.732270] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.732455] i2c /dev entries driver
[ 4.736460] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[ 4.744548] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 4.798651] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 4.798686] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 4.798693] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 4.798964] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 4.799042] tegra-thermal-throttle bthrot_cd
pcie.log (103 KB)
