1.our Carrier board remove the pd controller,and now usb2.0 and pcie do not work
2.we use lsusb and lspci we can see nothing
3.can you provide some docs about modifying the device tree to let these function work
thank you
thank you
xubin4952,
Please share the dmesg with us. As for usb configuration, it depends on your design, so please share your usb hardware design. Thanks.
hi WayneWWW,
you can reference the link below.
https://devtalk.nvidia.com/default/topic/1051490/could-not-get-extcon-dev-xhci-3610000-id-0-/?offset=4#5336878
Please refer to xavier adaptation guide from download center.
https://developer.nvidia.com/embedded/dlc/l4t-driver-package-agx-xavier-adaptation-guide
hi WayneWWW,
I reference the link below ,and now the usb can work ,but lspci ,I can not see anything in our bored,but use the demo board of nvidia ,I can see the information about pcie.Can you provide some help about pcie.
nvidia demo board information :lspci
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1)
0001:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9171 (rev 13)
fix usb problem:
https://devtalk.nvidia.com/default/topic/1047678/jetson-agx-xavier/usb-does-not-working-on-jatson-agx-xavier-/post/5322298/#5322298
The usb pd controller should not affect the PCIe. Please share the dmesg.
Hi WayneWWW,
below is the infomation of dmesg.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.108 (jason@ubuntu) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #11 SMP PREEMPT Sun May 12 20:58:30 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2a000000
[ 0.000000] OF: fdt: - aa200000 , 46a00000
[ 0.000000] OF: fdt: - 100000000 , 380000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a0791000
[ 0.000000] Found lut_mem: 00002008@a078e000
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000ec800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc3ffdb4000 s54424 r8192 d31592 u94208
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4066272
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa078e000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Memory: 16124888K/16523264K available (15358K kernel code, 2944K rwdata, 6704K rodata, 8512K init, 1625K bss, 332840K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e60000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a140008 ( 2945 KB)
[ 0.000000] .bss : 0xffffff800a140008 - 0xffffff800a2d6584 ( 1626 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000048] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009259] Console: colour dummy device 80x25
[ 0.012609] console [tty0] enabled
[ 0.016052] bootconsole [tegra_comb_uart0] disabled
<hit enter to activate fiq debugger>
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.020790] kmemleak: Kernel memory leak detector disabled
[ 0.020898] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.020975] pid_max: default: 32768 minimum: 301
[ 0.022256] Security Framework initialized
[ 0.022965] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023025] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025542] ftrace: allocating 48016 entries in 188 pages
[ 0.516237] sched-energy: Sched-energy-costs installed from DT
[ 0.516309] ASID allocator initialised with 65536 entries
[ 0.558514] tegra-id: chipid=21917.
[ 0.558598] tegra-id: opt_subrevision=0.
[ 0.558643] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.558714] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.558763] DTB Build time: May 14 2019 03:14:33
[ 0.559796] tegra-roc-flush: DT required.
[ 0.610988] CPU1: Booted secondary processor [4e0f0040]
[ 0.644530] CPU2: Booted secondary processor [4e0f0040]
[ 0.676745] CPU3: Booted secondary processor [4e0f0040]
[ 0.708875] CPU4: Booted secondary processor [4e0f0040]
[ 0.741074] CPU5: Booted secondary processor [4e0f0040]
[ 0.773685] CPU6: Booted secondary processor [4e0f0040]
[ 0.805799] CPU7: Booted secondary processor [4e0f0040]
[ 0.806707] Brought up 8 CPUs
[ 0.806983] SMP: Total of 8 processors activated.
[ 0.807020] CPU features: detected feature: Privileged Access Never
[ 0.807056] CPU features: detected feature: LSE atomic instructions
[ 0.807131] CPU features: detected feature: User Access Override
[ 0.807165] CPU features: detected feature: 32-bit EL0 Support
[ 0.812329] CPU: All CPU(s) started at EL2
[ 0.812449] alternatives: patching kernel code
[ 0.827380] devtmpfs: initialized
[ 0.901643] Initilizing CustomIPI irq domain
[ 0.902404] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.902467] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.904073] pinctrl core: initialized pinctrl subsystem
[ 0.904328] OS set in device tree is not L4T.
[ 0.904634] regulator-dummy: no parameters
[ 0.904902] Initializing plugin-manager
[ 0.904975] Plugin module not found
[ 0.905027] Plugin-manager status disabled
[ 0.906692] NET: Registered protocol family 16
[ 0.908392] pstore: using zlib compression
[ 0.909390] console [pstore-1] enabled
[ 0.909417] pstore: Registered ramoops as persistent store backend
[ 0.909448] ramoops: attached 0x200000@0xf0a00000, ecc: 0/0
[ 0.927306] cpuidle: using governor menu
[ 0.928957] bpmp: waiting for handshake
[ 0.928992] bpmp: handshake completed
[ 0.929090] bpmp: synchronizing channels
[ 0.929119] bpmp: channels synchronized
[ 0.929146] bpmp: mail init ok
[ 0.933636] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.934074] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.934114] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.934145] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.934177] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.934207] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.934240] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.934281] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.934325] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.934359] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.934398] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.938527] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e64000)
[ 0.938638] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.945302] atomic_pool_init():622: DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.946689] Registering BPMP clocks...
[ 0.946868] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.947445] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.948061] tegra_powergate_init: DONE
[ 0.948104] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.948212] DTB Build time: May 14 2019 03:14:33
[ 0.951978] tegra_debug_uart_syscore_init: stdout-path property missing
[ 0.952040] Tegra reboot handler registered.
[ 0.962868] iommu: Adding device 14180000.pcie to group 0
[ 0.964150] iommu: Adding device 14100000.pcie to group 1
[ 0.965088] iommu: Adding device 14140000.pcie to group 2
[ 0.966005] iommu: Adding device 141a0000.pcie to group 3
[ 0.968414] iommu: Adding device 2490000.ether_qos to group 4
[ 0.969139] iommu: Adding device 3100000.serial to group 5
[ 0.969877] iommu: Adding device 3110000.serial to group 6
[ 0.970452] iommu: Adding device 3140000.serial to group 7
[ 0.971495] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.971846] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.971900] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.971923] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.971945] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.972040] tegra-pmc: PMC Prod config success
[ 0.972332] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.972380] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.972869] iommu: Adding device 3460000.sdhci to group 8
[ 0.973604] iommu: Adding device 3400000.sdhci to group 9
[ 0.974298] iommu: Adding device 3210000.spi to group 10
[ 0.974848] iommu: Adding device c260000.spi to group 11
[ 0.975531] iommu: Adding device 3230000.spi to group 12
[ 0.976129] iommu: Adding device 3270000.spi to group 13
[ 0.976732] iommu: Adding device 3300000.spi to group 14
[ 0.977812] iommu: Adding device 3160000.i2c to group 15
[ 0.978346] iommu: Adding device c240000.i2c to group 16
[ 0.978937] iommu: Adding device 3180000.i2c to group 17
[ 0.979556] iommu: Adding device 3190000.i2c to group 18
[ 0.980302] iommu: Adding device 31b0000.i2c to group 19
[ 0.980880] iommu: Adding device 31c0000.i2c to group 20
[ 0.981416] iommu: Adding device c250000.i2c to group 21
[ 0.981963] iommu: Adding device 31e0000.i2c to group 22
[ 0.983006] iommu: Adding device sound to group 23
[ 0.983744] iommu: Adding device 3510000.hda to group 24
[ 0.984502] iommu: Adding device bc00000.rtcpu to group 25
[ 0.987529] iommu: Adding device 13e10000.host1x to group 26
[ 0.988097] iommu: Adding device 13e10000.host1x:ctx0 to group 27
[ 0.989346] iommu: Adding device 13e10000.host1x:ctx1 to group 28
[ 0.990548] iommu: Adding device 13e10000.host1x:ctx2 to group 29
[ 0.991977] iommu: Adding device 13e10000.host1x:ctx3 to group 30
[ 0.993174] iommu: Adding device 13e10000.host1x:ctx4 to group 31
[ 0.994413] iommu: Adding device 13e10000.host1x:ctx5 to group 32
[ 0.995755] iommu: Adding device 13e10000.host1x:ctx6 to group 33
[ 0.997094] iommu: Adding device 13e10000.host1x:ctx7 to group 34
[ 0.998588] iommu: Adding device 15340000.vic to group 35
[ 0.999867] iommu: Adding device 15380000.nvjpg to group 36
[ 1.000264] iommu: Adding device 15500000.tsec to group 37
[ 1.000664] iommu: Adding device 15100000.tsecb to group 38
[ 1.001066] iommu: Adding device 15480000.nvdec to group 39
[ 1.001449] iommu: Adding device 15140000.nvdec1 to group 40
[ 1.001859] iommu: Adding device 154c0000.nvenc to group 41
[ 1.002246] iommu: Adding device 15a80000.nvenc1 to group 42
[ 1.002830] iommu: Adding device 15880000.nvdla0 to group 43
[ 1.003403] iommu: Adding device 158c0000.nvdla1 to group 44
[ 1.004239] iommu: Adding device 15200000.nvdisplay to group 45
[ 1.004583] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0791000(800000)
[ 1.004648] platform 15200000.nvdisplay: IOVA linear map 0x00000000a078e000(3000)
[ 1.004679] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 1.005294] iommu: Adding device 15210000.nvdisplay to group 46
[ 1.005384] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 1.005938] iommu: Adding device 15220000.nvdisplay to group 47
[ 1.006003] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 1.008840] iommu: Adding device 15c10000.vi to group 48
[ 1.010349] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 1.010924] iommu: Adding device 14800000.isp to group 49
[ 1.012839] iommu: Adding device 16000000.pva0 to group 50
[ 1.013605] iommu: Adding device 16800000.pva1 to group 51
[ 1.014173] iommu: Adding device 15810000.se to group 52
[ 1.014795] iommu: Adding device 15820000.se to group 53
[ 1.015178] iommu: Adding device 15830000.se to group 54
[ 1.015637] iommu: Adding device 15840000.se to group 55
[ 1.016037] iommu: Adding device c1a0000.aon to group 56
[ 1.018012] iommu: Adding device d000000.bpmp to group 57
[ 1.018481] bpmp: ping status is 0
[ 1.018686] bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
[ 1.023920] bpmp d000000.bpmp: probe ok
[ 1.026029] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.026660] iommu: Adding device smmu_test to group 58
[ 1.027971] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
[ 1.028029] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
[ 1.028099] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
[ 1.028186] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 1.028235] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 1.028283] mc: mapped MMIO address: 0xffffff800b210000 -> 0x2b80000
[ 1.028332] mc: mapped MMIO address: 0xffffff800b230000 -> 0x2b90000
[ 1.028380] mc: mapped MMIO address: 0xffffff800b250000 -> 0x2ba0000
[ 1.028427] mc: mapped MMIO address: 0xffffff800b270000 -> 0x2bb0000
[ 1.028473] mc: mapped MMIO address: 0xffffff800b290000 -> 0x1700000
[ 1.028523] mc: mapped MMIO address: 0xffffff800b2b0000 -> 0x1710000
[ 1.028570] mc: mapped MMIO address: 0xffffff800b2d0000 -> 0x1720000
[ 1.028617] mc: mapped MMIO address: 0xffffff800b2f0000 -> 0x1730000
[ 1.028664] mc: mapped MMIO address: 0xffffff800b310000 -> 0x1740000
[ 1.028710] mc: mapped MMIO address: 0xffffff800b330000 -> 0x1750000
[ 1.028756] mc: mapped MMIO address: 0xffffff800b350000 -> 0x1760000
[ 1.028803] mc: mapped MMIO address: 0xffffff800b370000 -> 0x1770000
[ 1.028936] mc-err: mcerr ops are set to t19x
[ 1.037308] iommu: Adding device 2600000.dma to group 59
[ 1.045407] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.046022] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.054281] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.054895] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.057688] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.057728] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.058846] iommu: Adding device 3550000.xudc to group 60
[ 1.060080] iommu: Adding device 3610000.xhci to group 61
[ 1.061695] arm64_ras arm64_ras: RAS driver enabled
[ 1.062499] carmel_ras_enable:RAS enabled on cpu0
[ 1.062845] carmel_ras_enable:RAS enabled on cpu1
[ 1.063143] carmel_ras_enable:RAS enabled on cpu2
[ 1.063515] carmel_ras_enable:RAS enabled on cpu3
[ 1.063849] carmel_ras_enable:RAS enabled on cpu4
[ 1.064185] carmel_ras_enable:RAS enabled on cpu5
[ 1.064503] carmel_ras_enable:RAS enabled on cpu6
[ 1.064807] carmel_ras_enable:RAS enabled on cpu7
[ 1.065109] carmel_ras_enable:RAS enabled on cpu0
[ 1.065362] carmel_ras_enable:RAS enabled on cpu1
[ 1.065598] carmel_ras_enable:RAS enabled on cpu2
[ 1.065848] carmel_ras_enable:RAS enabled on cpu3
[ 1.066082] carmel_ras_enable:RAS enabled on cpu4
[ 1.066337] carmel_ras_enable:RAS enabled on cpu5
[ 1.066563] carmel_ras_enable:RAS enabled on cpu6
[ 1.066837] carmel_ras_enable:RAS enabled on cpu7
[ 1.067009] carmel_ras carmel_ras: probed
[ 1.068870] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 1.069954] tegra-cbb c600000.aon-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 1.071228] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.072709] tegra-cbb be00000.rce-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.073890] tegra-cbb b600000.sce-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.074607] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.078090] vdd-3v3-cvb: 3300 mV
[ 1.078712] vdd-1v8-cvb: 1800 mV
[ 1.079173] vdd-1v8-sd: 1800 mV
[ 1.079777] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.079856] vdd-epb-1v0: 1000 mV
[ 1.080330] vdd-sdmmc1-sw: 3300 mV
[ 1.081187] avdd-cam-2v8: 2800 mV
[ 1.081674] vdd-sata-1v5: 1500 mV
[ 1.082250] vdd-1v8-slt: 1800 mV
[ 1.082698] vdd-3v3-slt: 3300 mV
[ 1.083117] vdd-fan: 5000 mV
[ 1.083740] vdd-hdmi-5v0: 5000 mV
[ 1.084445] vdd_sys_en: 1200 mV
[ 1.085296] vdd-5v-sata: 5000 mV
[ 1.086012] vdd-ac-bat: 5000 mV
[ 1.086278] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.088041] vdd-usb20-5v0: supplied by vdd-ac-bat
[ 1.088131] vdd-usb20-5v0: 5000 mV
[ 1.131133] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.131724] SCSI subsystem initialized
[ 1.132291] usbcore: USB support
[ 1.132337] usbcore: usb_acpi_register
[ 1.132443] usbcore: bus_register_notifier
[ 1.132466] usbcore: usb_major_init
[ 1.132496] usbcore: usb_register
[ 1.132694] usbcore: registered new interface driver usbfs
[ 1.132718] usbcore: usb_devio_init
[ 1.132746] usbcore: usb_hub_init
[ 1.132931] usbcore: registered new interface driver hub
[ 1.133049] usbcore: usb_register_device_driver
[ 1.133234] usbcore: registered new device driver usb
[ 1.147052] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.150446] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.160742] vdd-1v0: at 1000 mV
[ 1.168634] vdd-1v8-hs: at 1800 mV
[ 1.176608] vdd-1v8-ls: at 1800 mV
[ 1.184636] vdd-1v8-ao: at 1800 mV
[ 1.192650] vddio-ddr-1v1: at 1100 mV
[ 1.200434] vdd-rtc: at 800 mV
[ 1.201924] spmic-ldo1: at 2375 mV
[ 1.212791] vdd-ao-3v3: at 3300 mV
[ 1.224885] vddio-emmc-3v3: at 3300 mV
[ 1.226451] spmic-ldo4: at 1587 mV
[ 1.236979] vdd-usb-3v3: at 3300 mV
[ 1.248989] vddio-sdmmc1-3v3: at 3300 mV
[ 1.257034] vdd-csi-1v2: at 1200 mV
[ 1.259008] spmic-ldo8: at 1800 mV
[ 1.261429] GPIO line 246 (gpio_default) hogged as output/high
[ 1.263059] GPIO line 247 (gpio_default) hogged as output/high
[ 1.263736] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.267515] max77620 4-003c: max77620 probe successful
[ 1.268362] media: Linux media interface: v0.10
[ 1.268458] Linux video capture interface: v2.00
[ 1.270306] pps_core: LinuxPPS API ver. 1 registered
[ 1.270333] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.270434] PTP clock support registered
[ 1.271510] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.271576] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.273537] tegra_fiq_debugger_init: found FIQ source (IRQ 472)
[ 1.275341] Advanced Linux Sound Architecture Driver Initialized.
[ 1.276053] Bluetooth: Core ver 2.22
[ 1.276121] NET: Registered protocol family 31
[ 1.276144] Bluetooth: HCI device and connection manager initialized
[ 1.276189] Bluetooth: HCI socket layer initialized
[ 1.276225] Bluetooth: L2CAP socket layer initialized
[ 1.276279] Bluetooth: SCO socket layer initialized
[ 1.279475] camchar: rtcpu character device driver loaded
[ 1.281454] clocksource: Switched to clocksource arch_sys_counter
[ 1.335561] VFS: Disk quotas dquot_6.6.0
[ 1.335753] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.336119] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.338549] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.338713] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.338749] nvmap_page_pool_init: Total RAM pages: 4047606
[ 1.338770] nvmap_page_pool_init: nvmap page pool size: 505950 pages (1976 MB)
[ 1.339284] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.340842] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.356103] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.356797] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.357331] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.357756] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.358382] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.358822] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.359203] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.374167] la/ptsa driver initialized.
[ 1.374649] NET: Registered protocol family 2
[ 1.375847] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.376585] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.377534] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.377605] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.377928] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.378589] NET: Registered protocol family 1
[ 1.379546] RPC: Registered named UNIX socket transport module.
[ 1.379572] RPC: Registered udp transport module.
[ 1.379593] RPC: Registered tcp transport module.
[ 1.379612] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.379883] Trying to unpack rootfs image as initramfs...
[ 1.398496] random: fast init done
[ 1.403293] host1x 13e10000.host1x: initialized
[ 1.405626] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.410531] audit: initializing netlink subsys (disabled)
[ 1.410627] audit: type=2000 audit(0.936:1): initialized
[ 1.411609] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.421410] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.422803] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.423576] 9p: Installing v9fs 9p2000 file system support
[ 1.428827] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.429046] io scheduler noop registered
[ 1.429325] io scheduler cfq registered (default)
[ 1.433956] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.474460] iommu: Adding device 2993000.adsp to group 62
[ 1.578271] iommu: Adding device aconnect@2a41000:adsp_audio to group 63
[ 1.579427] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.594986] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.595605] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.596237] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.599943] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.600334] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.600370] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.604585] tsec 15500000.tsec: initialized
[ 1.607213] tsec 15100000.tsecb: initialized
[ 1.612981] nvdec 15480000.nvdec: initialized
[ 1.616871] nvdec 15140000.nvdec1: initialized
[ 1.623903] falcon 15340000.vic: initialized
[ 1.626681] falcon 15380000.nvjpg: initialized
[ 1.628793] falcon 154c0000.nvenc: initialized
[ 1.631265] falcon 15a80000.nvenc1: initialized
[ 1.634476] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.637002] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.639682] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.642271] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.644920] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.647560] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.650181] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.652292] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.656769] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.662527] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.662972] scare-pigeon 14b00000.isp-thi: initialized
[ 1.673838] pva 16000000.pva0: initialized
[ 1.706360] pva 16800000.pva1: initialized
[ 1.737969] nvdla 15880000.nvdla0: initialized
[ 1.769752] nvdla 158c0000.nvdla1: initialized
[ 1.773863] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.774010] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.774038] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.774067] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.775744] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.775790] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.775874] tegradccommon 15200000.dc_common: dma mapping done
[ 1.776308] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.776432] generic_infoframe_type: 0x87
[ 1.776675] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.776771] tegradc 15200000.nvdisplay: Display dc.ffffff800bfd0000 registered with id=0
[ 1.784763] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.784845] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.784872] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.785198] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.785232] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.787032] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.788051] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.789432] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.790169] kfuse 3830000.kfuse: initialized
[ 1.790558] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.790600] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.794983] tegradc 15200000.nvdisplay: probed
[ 1.797931] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.801579] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.803014] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.804180] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.271354] console [ttyTCU0] enabled
[ 4.272012] Console: switching to colour frame buffer device 240x67
[ 4.275410] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:290 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.275410]
[ 4.295128] tegradc 15200000.nvdisplay: fb registered
[ 4.300648] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.307556] brd: module loaded
[ 4.315076] loop: module loaded
[ 4.315320] tegra_profiler: version: 1.128, samples/io: 44/25
[ 4.317711] tegra_profiler: auth: init
[ 4.321324] nct1008_nct72 4-004c: starting parse dt
[ 4.321936] THERMAL EST: found 3 subdevs
[ 4.321941] THERMAL EST num_resources: 0
[ 4.321945] [THERMAL EST subdev 0]
[ 4.321949] [THERMAL EST subdev 1]
[ 4.321952] [THERMAL EST subdev 2]
[ 4.322348] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.322351] THERMAL EST: thz register success.
[ 4.322701] THERMAL EST: end of probe, return err: 0
[ 4.323678] hisi_sas: driver version v1.6
[ 4.366126] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.366360] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.378285] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.383105] Parent Clock set for DC plld3
[ 4.388635] nct1008_nct72 4-004c: success parsing dt
[ 4.390896] tegra-qspi 3270000.spi: Prod settings list not found
[ 4.396327] tegra-qspi 3300000.spi: Prod settings list not found
[ 4.403063] libphy: Fixed MDIO Bus: probed
[ 4.403785] tun: Universal TUN/TAP device driver, 1.6
[ 4.403788] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.404640] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.404643] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.404703] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.404708] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.404749] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.404751] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.404797] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.404799] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.405120] sky2: driver version 1.30
[ 4.406703] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.406785] PPP generic driver version 2.4.2
[ 4.407016] PPP BSD Compression module registered
[ 4.407019] PPP Deflate Compression module registered
[ 4.407047] PPP MPPE Compression module registered
[ 4.407051] NET: Registered protocol family 24
[ 4.407113] usbcore: registered new interface driver r8152
[ 4.407158] usbcore: registered new interface driver asix
[ 4.407198] usbcore: registered new interface driver ax88179_178a
[ 4.407248] usbcore: registered new interface driver cdc_ether
[ 4.407278] usbcore: registered new interface driver net1080
[ 4.407312] usbcore: registered new interface driver cdc_subset
[ 4.407343] usbcore: registered new interface driver zaurus
[ 4.407388] usbcore: registered new interface driver cdc_ncm
[ 4.407614] VFIO - User Level meta-driver version: 0.3
[ 4.409491] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.409502] ehci-pci: EHCI PCI platform driver
[ 4.409549] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.409555] ohci-pci: OHCI PCI platform driver
[ 4.409633] ohci-platform: OHCI generic platform driver
[ 4.411111] eqos 2490000.ether_qos: No prod values found
[ 4.411781] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb ad 2f
[ 4.412007] libphy: dwc_phy: probed
[ 4.419412] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 4.422494] tegra-xusb 3610000.xhci: Direct firmware load for tegra19x_xusb_firmware failed with error -2
[ 4.422499] tegra-xusb 3610000.xhci: Falling back to user helper
[ 4.422938] usbcore: registered new int▒▒WARNING: clk_get_rate: clk_power_ungate on gated domain 27 for gpcclk
▒▒erface driver uas
[ 4.423030] usbcore: registered new interface driver usb-storage
[ 4.423137] usbcore: registered new interface driver usbserial
[ 4.423191] usbcore: registered new interface driver option
[ 4.423252] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.427673] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 4.428391] mousedev: PS/2 mouse device common for all mice
[ 4.443926] tegradc 15200000.nvdisplay: hdmi: tmds rate:148367K prod-setting:prod_c_hdmi_111m_223m
[ 4.445583] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 4.445801] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 4.560984] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.562810] Wake73 for irq=42
[ 4.564200] rtc rtc1: alarm rtc device
[ 4.564216] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.564263] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.564416] i2c /dev entries driver
[ 4.567471] max77620-power max20024-power: Event recorder REG_NVERC : 0xff
[ 4.572605] FAN dev name: pwm-fan
[ 4.572672] FAN:gpio request success.
[ 4.572681] FAN: can't find tach_gpio
[ 4.572755] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.572978] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.572984] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.573369] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.573376] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.573381] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.573385] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.573389] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.573393] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.573396] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.573400] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.573404] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.573407] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.574379] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.574792] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
[ 4.578057] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 4.631180] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 4.631224] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 4.631229] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 4.631328] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 4.631386] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 4.631390] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 4.631883] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 4.631979] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 4.631984] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 4.632395] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 4.632458] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 4.632462] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 4.632904] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 4.632973] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 4.632978] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 4.633343] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 4.635209] device-mapper: uevent: version 1.0.3
[ 4.635788] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.642414] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.648781] cpuidle: Initializing cpuidle driver
[ 4.662755] sdhci: Secure Digital Host Controller Interface driver
[ 4.662757] sdhci: Copyright(c) Pierre Ossman
[ 4.662758] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.664066] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.666458] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.667872] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.669409] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 4.672177] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.673183] tegra-se-nvhost 15810000.se: initialized
[ 4.674657] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.675691] tegra-se-nvhost 15820000.se: initialized
[ 4.676951] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.677842] tegra-se-nvhost 15830000.se: initialized
[ 4.678526] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.679403] tegra-se-nvhost 15840000.se: initialized
[ 4.680251] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.680483] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.681968] usbcore: registered new interface driver usbhid
[ 4.681969] usbhid: USB HID core driver
[ 4.687932] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.688901] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.689334] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.689923] denver_knobs_init:MTS_VERSION:43306594
[ 4.690128] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 4.691108] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.691525] t19x_cache tegra-cache: probed
[ 4.697853] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.697873] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.705490] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.720272] nvpmodel: initialized successfully
[ 4.721364] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.721565] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 4.721621] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.721710] usbcore: registered new interface driver snd-usb-audio
[ 4.740519] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.740705] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.740854] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.740981] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.798725] mmc0: periodic cache flush enabled
[ 4.798738] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.799198] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 4.799449] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 4.799678] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 4.799893] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 4.801522] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36
▒▒WARNING: pll_d3 has no dyn ramp
▒▒[ 5.311069] tegradc 15200000.nvdisplay: blank - powerdown
[ 5.311305] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 5.312266] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 5.313659] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 5.347195] nct1008_nct72 4-004c: initial LOC temp: 37000
[ 5.347862] nct1008_nct72 4-004c: initial EXT temp: 51000
[ 5.349177] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 5.350194] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 5.370828] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 5.371929] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 5.372937] tegradc 15200000.nvdisplay: blank - normal
[ 5.382567] tegradc 15200000.nvdisplay: unblank
[ 5.383878] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 5.384096] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 5.388864] Parent Clock set for DC plld3
[ 5.400097] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 6.409544] tegradc 15200000.nvdisplay: unblank
[ 6.575242] gpio tegra-gpio wake12 for gpio=149(S:5)
[ 6.708106] OPE platform probe
[ 6.708231] OPE platform probe successful
[ 6.845800] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 6.845909] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 6.845981] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 6.846056] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 6.846149] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 6.846214] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 6.846284] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 6.846362] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 6.846442] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 6.846504] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 6.846583] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 6.846667] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 6.846725] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 6.846786] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 6.846873] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 6.846946] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 6.847048] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 6.847106] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 6.847163] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 6.847220] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 6.885589] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[ 6.886945] u32 classifier
[ 6.886947] Actions configured
[ 6.887000] Initializing XFRM netlink socket
[ 6.887388] NET: Registered protocol family 10
[ 6.888058] NET: Registered protocol family 17
[ 6.888068] NET: Registered protocol family 15
[ 6.888111] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.888180] Bluetooth: RFCOMM socket layer initialized
[ 6.888189] Bluetooth: RFCOMM ver 1.11
[ 6.888198] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.888202] Bluetooth: HIDP socket layer initialized
[ 6.888215] 9pnet: Installing 9P2000 support
[ 6.888248] Key type dns_resolver registered
[ 6.888745] Registered cp15_barrier emulation handler
[ 6.888789] Registered setend emulation handler
[ 6.890219] registered taskstats version 1
[ 6.890684] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 6.891772] OF: PCI: host bridge /pcie@14180000 ranges:
[ 6.891804] OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
[ 6.891812] OF: PCI: MEM 0x38200000..0x39ffffff -> 0x38200000
[ 6.891815] OF: PCI: MEM 0x1800000000..0x1bffffffff -> 0x1800000000
[ 7.401100] tegra-pcie-dw 14180000.pcie: link is down
[ 7.401266] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 7.401271] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 7.401276] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 7.401279] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
[ 7.401281] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
[ 7.401707] iommu: Adding device 0000:00:00.0 to group 64
[ 7.401936] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 7.401960] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.402138] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.402610] iommu: Removing device 0000:00:00.0 from group 64
[ 7.402910] tegra-pcie-dw 14180000.pcie: PCIe link is not up...!
[ 7.403635] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 7.404657] OF: PCI: host bridge /pcie@14100000 ranges:
[ 7.404671] OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
[ 7.404677] OF: PCI: MEM 0x30200000..0x31ffffff -> 0x30200000
[ 7.404680] OF: PCI: MEM 0x1200000000..0x123fffffff -> 0x1200000000
[ 7.782528] tegradc 15200000.nvdisplay: hdmi: plugged
[ 7.916021] tegra-pcie-dw 14100000.pcie: link is down
[ 7.917391] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 7.918501] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 7.919527] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 7.920651] pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
[ 7.921719] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
[ 7.923206] iommu: Adding device 0001:00:00.0 to group 64
[ 7.924489] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 7.926680] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.928072] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.929719] iommu: Removing device 0001:00:00.0 from group 64
[ 7.931226] tegra-pcie-dw 14100000.pcie: PCIe link is not up...!
[ 7.933805] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 7.936628] OF: PCI: host bridge /pcie@14140000 ranges:
[ 7.937866] OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
[ 7.939061] OF: PCI: MEM 0x34200000..0x35ffffff -> 0x34200000
[ 7.940268] OF: PCI: MEM 0x1280000000..0x12bfffffff -> 0x1280000000
[ 8.453178] tegra-pcie-dw 14140000.pcie: link is down
[ 8.454628] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0002:00
[ 8.455897] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 8.457119] pci_bus 0002:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 8.458434] pci_bus 0002:00: root bus resource [mem 0x34200000-0x35ffffff]
[ 8.459732] pci_bus 0002:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
[ 8.461426] iommu: Adding device 0002:00:00.0 to group 64
[ 8.462937] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[ 8.464264] pci 0002:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.465848] pcieport 0002:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.467688] iommu: Removing device 0002:00:00.0 from group 64
[ 8.469371] tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
[ 8.472159] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 8.474691] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 8.476060] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 8.477390] OF: PCI: MEM 0x3a200000..0x3bffffff -> 0x3a200000
[ 8.478790] OF: PCI: MEM 0x1c00000000..0x1fffffffff -> 0x1c00000000
[ 8.988933] tegra-pcie-dw 141a0000.pcie: link is down
[ 8.990531] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0003:00
[ 8.991875] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 8.993174] pci_bus 0003:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 8.994598] pci_bus 0003:00: root bus resource [mem 0x3a200000-0x3bffffff]
[ 8.995965] pci_bus 0003:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
[ 8.997865] iommu: Adding device 0003:00:00.0 to group 64
[ 8.999451] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 9.000908] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.002548] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 9.004391] iommu: Removing device 0003:00:00.0 from group 64
[ 9.006671] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 9.021326] tegra-cbb 14040000.cv-noc: noc_secure_irq = 101, noc_nonsecure_irq = 100>
[ 9.030168] tegra194-isp5 14800000.isp: initialized
[ 9.044320] tegra194-vi5 15c10000.vi: initialized
[ 9.052079] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 9.053580] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 9.055649] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 9.056523] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 9.056549] tegra186-cam-rtcpu bc00000.rtcpu: Coverage buffer configured at IOVA=0xbfef8000
[ 9.058813] tegra186-cam-rtcpu bc00000.rtcpu: IOVM setup error: 130
[ 9.058816] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU coverage: IOVM setup error : 4294967291
[ 9.058818] tegra186-cam-rtcpu bc00000.rtcpu: (expected if RTCPU was not built with coverage enabled)
[ 9.058820] tegra186-cam-rtcpu bc00000.rtcpu: coverage boot sync status: -5
[ 9.058996] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 9.059317] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 9.059390] tegra-ivc-cdev ivc-bc00000.rtcpu:echo@0: probing /dev/camchar-echo
[ 9.059491] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 9.059558] tegra-ivc-cdev ivc-bc00000.rtcpu:dbg@1: probing /dev/camchar-dbg
[ 9.059717] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 9.060043] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 9.060106] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 9.060282] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (72)
[ 9.060284] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 9.061125] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=5d9f1c48356a1dad5a597123920f5319cb04aa87
[ 9.061944] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 9.062004] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 9.062160] input: gpio-keys as /devices/gpio-keys/input/input5
[ 9.095948] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:15 UTC (946688415)
[ 9.096559] mmcblk mmc0:0001: Card claimed for testing.
[ 9.131868] bpmp: mounted debugfs mirror
[ 9.137730] vdd-1v8-cvb: disabling
[ 9.137737] vdd-1v8-sd: disabling
[ 9.137742] vdd-epb-1v0: disabling
[ 9.137745] vdd-sdmmc1-sw: disabling
[ 9.137749] avdd-cam-2v8: disabling
[ 9.137755] vdd-sata-1v5: disabling
[ 9.137759] vdd-3v3-slt: disabling
[ 9.137762] vdd-fan: disabling
[ 9.137766] vdd_sys_en: disabling
[ 9.137775] ALSA device list:
[ 9.137779] #0: tegra-hda-galen-t194 at 0x3518000 irq 71
[ 9.137783] #1: tegra-snd-t19x-mobile-rt565x
[ 9.250316] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 9.256901] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 9.263433] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 9.270813] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 9.277630] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 9.322024] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.323544] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.326362] devtmpfs: mounted
[ 9.329256] Freeing unused kernel memory: 8512K
[ 9.421612] systemd[1]: System time before build time, advancing clock.
[ 9.438396] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.442146] cgroup: cgroup2: unknown option "nsdelegate"
[ 9.451275] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 9.455240] systemd[1]: Detected architecture arm64.
[ 9.470199] systemd[1]: Set hostname to <jetson-0423518031540>.
[ 9.534469] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.536402] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 9.633085] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.635041] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.639544] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.641180] systemd[1]: Reached target Swap.
[ 9.644537] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.646213] systemd[1]: Reached target User and Group Name Lookups.
[ 9.654612] systemd[1]: Created slice User and Session Slice.
[ 9.658949] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.705207] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 9.707991] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 9.708407] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 9.711615] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.679612] spidev: module is already loaded
[ 10.730091] spidev: module is already loaded
[ 10.731105] bmi160 8-0069: nvs_vregs_init vdd err=-19
[ 10.731114] bmi160 8-0069: nvs_vregs_init vdd_IO err=-19
[ 10.785652] tegra-i2c 31e0000.i2c: no acknowledge from address 0x69
[ 10.786094] spidev: module is already loaded
[ 10.788072] bmi160 8-0069: bmi_i2c_rd ERR: 0x00
[ 10.789255] bmi160 8-0069: bmi_init _id_i2c ERR
[ 10.792811] bmi160 8-0069: bmi_pm pm_en=0 ERR=-22
[ 10.796482] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 10.798135] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 10.825913] spidev: module is already loaded
[ 10.865948] spidev: module is already loaded
[ 10.905850] spidev: module is already loaded
[ 10.922641] random: crng init done
[ 10.922643] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.943835] spidev: module is already loaded
[ 11.299959] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 11.302299] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 11.306023] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 11.306340] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 11.744429] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 11.744743] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 11.745407] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 11.745735] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 12.102833] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 12.103065] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 12.320851] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 12.321064] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 12.387064] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[ 12.387383] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[ 15.666575] CPU4: shutdown
[ 15.710666] CPU5: shutdown
[ 15.894521] CPU6: shutdown
[ 15.954753] CPU7: shutdown
I remind that all custom carrier board needs this patch if you are using rel-32.1.
diff --git a/common/tegra194-p2888-0000-a00.dtsi b/common/tegra194-p2888-0000-a00.dtsi
index 6bbb033..e5771e6 100644
--- a/common/tegra194-p2888-0000-a00.dtsi
+++ b/common/tegra194-p2888-0000-a00.dtsi
@@ -86,7 +86,7 @@
TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW>;
label = "pcie-3v3-reg", "pcie-12v-reg";
output-high;
- status = "disabled";
+ status = "okay";
@@ -108,10 +108,10 @@
status = "okay";
vddio-pex-ctl-supply = <&p2888_spmic_sd3>;
- nvidia,disable-aspm-states = <0xf>;
+ nvidia,disable-aspm-states = <0xc>;
nvidia,enable-power-down;
- nvidia,max-speed = <1>;
+ nvidia,max-speed = <2>;
phys = <&p2u_0>;
phy-names = "pcie-p2u-0";
@@ -137,6 +137,12 @@
+ nvidia,plat-gpios =
+ <&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 2) GPIO_ACTIVE_HIGH /* 3V3 */
+ &tegra_main_gpio TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW /* 12V */
+ /*&tegra_main_gpio TEGRA194_MAIN_GPIO(Y, 4) GPIO_ACTIVE_HIGH */ /* I2C */
phys = <&p2u_12>,
<&p2u_13>,
<&p2u_14>,
diff --git a/common/tegra194-p2888-p2822-pcie-plugin-manager.dtsi b/common/tegra194-p2888-p2822-pcie-plugin-manager.dtsi
index 2033df6..e131371 100644
--- a/common/tegra194-p2888-p2822-pcie-plugin-manager.dtsi
+++ b/common/tegra194-p2888-p2822-pcie-plugin-manager.dtsi
@@ -15,38 +15,34 @@
plugin-manager {
fragment-pcie-c1-rp {
- ids = ">=2822-0000-200";
+ ids = "<2822-0000-200";
override@0 {
target = <&{/pcie@14100000}>;
_overlay_ {
- nvidia,max-speed = <2>;
+ nvidia,max-speed = <1>;
- fragment-pcie-p2822-B00 {
- ids = ">=2822-0000-400";
+ fragment-pcie-older-than-p2822-B00 {
+ ids = "<2822-0000-400";
override@0 {
_overlay_ {
- nvidia,disable-aspm-states = <0xc>;
+ nvidia,disable-aspm-states = <0xf>;
override@1 {
target = <&{/pcie@141a0000}>;
_overlay_ {
- nvidia,plat-gpios =
- <&tegra_main_gpio TEGRA194_MAIN_GPIO(Z, 2) GPIO_ACTIVE_HIGH /* 3V3 */
- &tegra_main_gpio TEGRA194_MAIN_GPIO(A, 1) GPIO_ACTIVE_LOW /* 12V */
- /*&tegra_main_gpio TEGRA194_MAIN_GPIO(Y, 4) GPIO_ACTIVE_HIGH */ /* I2C */
+ delete-target-property = "nvidia,plat-gpios";
override@2 {
target = <&{/gpio@2200000}>;
_overlay_ {
pcie-reg-enable {
- status = "okay";
+ status = "disabled";
thank you ,I will try this patch ,now I use jetpack 4.1,should I execute this patch?
Yes, you need. For all xavier on custom board, this patch is needed. This patch will be merged in next release (after jetpack4.2).
Hi WayneWWW,
It seems not work ,I can not see information when I execute lspci,after executing the patch.
below is the dmesg:
[ 0.000000] Linux version 4.9.108 (jason@ubuntu) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #13 SMP PREEMPT Mon May 20 02:39:04 PDT 2019
[ 0.000000] On node 0 totalpages: 4130816
[ 0.000000] DMA zone: 7200 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 460800 pages, LIFO batch:31
[ 0.000000] Normal zone: 57344 pages used for memmap
[ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s54424 r8192 d31592 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000000] ** **
[ 0.000008] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009306] Console: colour dummy device 80x25
[ 0.015792] bootconsole [tegra_comb_uart0] disabled
[ 0.021071] kmemleak: Kernel memory leak detector disabled
[ 0.021145] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.021210] pid_max: default: 32768 minimum: 301
[ 0.022476] Security Framework initialized
[ 0.023150] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.023191] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.025340] ftrace: allocating 48016 entries in 188 pages
[ 0.497099] sched-energy: Sched-energy-costs installed from DT
[ 0.497238] ASID allocator initialised with 65536 entries
[ 0.536488] tegra-id: chipid=21917.
[ 0.536552] tegra-id: opt_subrevision=0.
[ 0.536650] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.536786] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.536863] DTB Build time: May 21 2019 00:32:00
[ 0.537961] tegra-roc-flush: DT required.
[ 0.586388] CPU1: Booted secondary processor [4e0f0040]
[ 0.618471] CPU2: Booted secondary processor [4e0f0040]
[ 0.650813] CPU3: Booted secondary processor [4e0f0040]
[ 0.683311] CPU4: Booted secondary processor [4e0f0040]
[ 0.715651] CPU5: Booted secondary processor [4e0f0040]
[ 0.747889] CPU6: Booted secondary processor [4e0f0040]
[ 0.780435] CPU7: Booted secondary processor [4e0f0040]
[ 0.781413] Brought up 8 CPUs
[ 0.781699] SMP: Total of 8 processors activated.
[ 0.781739] CPU features: detected feature: Privileged Access Never
[ 0.781777] CPU features: detected feature: LSE atomic instructions
[ 0.781814] CPU features: detected feature: User Access Override
[ 0.781851] CPU features: detected feature: 32-bit EL0 Support
[ 0.785646] CPU: All CPU(s) started at EL2
[ 0.785809] alternatives: patching kernel code
[ 0.802287] devtmpfs: initialized
[ 0.876481] Initilizing CustomIPI irq domain
[ 0.877431] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.877487] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.879342] pinctrl core: initialized pinctrl subsystem
[ 0.879643] OS set in device tree is not L4T.
[ 0.880056] regulator-dummy: no parameters
[ 0.880413] Initializing plugin-manager
[ 0.880523] Plugin module not found
[ 0.880579] Plugin-manager status disabled
[ 0.882214] NET: Registered protocol family 16
[ 0.884080] pstore: using zlib compression
[ 0.885292] console [pstore-1] enabled
[ 0.885325] pstore: Registered ramoops as persistent store backend
[ 0.885361] ramoops: attached 0x200000@0xf0a00000, ecc: 0/0
[ 0.904754] cpuidle: using governor menu
[ 0.906497] bpmp: waiting for handshake
[ 0.906572] bpmp: handshake completed
[ 0.906668] bpmp: synchronizing channels
[ 0.906708] bpmp: channels synchronized
[ 0.906780] bpmp: mail init ok
[ 0.911411] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.911820] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.911877] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.911922] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.911969] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.912014] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.912063] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.912128] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.912200] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.912253] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.912304] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.916748] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e64000)
[ 0.916867] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.923714] atomic_pool_init():622: DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.925214] Registering BPMP clocks...
[ 0.925391] tegra_bpmp_clk_init: clock init ok (395 clks)
[ 0.926000] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.926585] tegra_powergate_init: DONE
[ 0.926632] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[ 0.926749] DTB Build time: May 21 2019 00:32:00
[ 0.930847] tegra_debug_uart_syscore_init: stdout-path property missing
[ 0.930904] Tegra reboot handler registered.
[ 0.942010] iommu: Adding device 14180000.pcie to group 0
[ 0.943242] iommu: Adding device 14100000.pcie to group 1
[ 0.944269] iommu: Adding device 14140000.pcie to group 2
[ 0.945345] iommu: Adding device 141a0000.pcie to group 3
[ 0.947598] iommu: Adding device 2490000.ether_qos to group 4
[ 0.948361] iommu: Adding device 3100000.serial to group 5
[ 0.949174] iommu: Adding device 3110000.serial to group 6
[ 0.949829] iommu: Adding device 3140000.serial to group 7
[ 0.950705] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.951014] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.951092] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.951138] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.951182] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.951277] tegra-pmc: PMC Prod config success
[ 0.951624] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.951699] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.952634] iommu: Adding device 3460000.sdhci to group 8
[ 0.953741] iommu: Adding device 3400000.sdhci to group 9
[ 0.954666] iommu: Adding device 3210000.spi to group 10
[ 0.955255] iommu: Adding device c260000.spi to group 11
[ 0.955868] iommu: Adding device 3230000.spi to group 12
[ 0.956444] iommu: Adding device 3270000.spi to group 13
[ 0.957113] iommu: Adding device 3300000.spi to group 14
[ 0.958270] iommu: Adding device 3160000.i2c to group 15
[ 0.958884] iommu: Adding device c240000.i2c to group 16
[ 0.959528] iommu: Adding device 3180000.i2c to group 17
[ 0.960160] iommu: Adding device 3190000.i2c to group 18
[ 0.961133] iommu: Adding device 31b0000.i2c to group 19
[ 0.961798] iommu: Adding device 31c0000.i2c to group 20
[ 0.962343] iommu: Adding device c250000.i2c to group 21
[ 0.963008] iommu: Adding device 31e0000.i2c to group 22
[ 0.964245] iommu: Adding device sound to group 23
[ 0.965057] iommu: Adding device 3510000.hda to group 24
[ 0.965897] iommu: Adding device bc00000.rtcpu to group 25
[ 0.968567] iommu: Adding device 13e10000.host1x to group 26
[ 0.969227] iommu: Adding device 13e10000.host1x:ctx0 to group 27
[ 0.970509] iommu: Adding device 13e10000.host1x:ctx1 to group 28
[ 0.971853] iommu: Adding device 13e10000.host1x:ctx2 to group 29
[ 0.973358] iommu: Adding device 13e10000.host1x:ctx3 to group 30
[ 0.974782] iommu: Adding device 13e10000.host1x:ctx4 to group 31
[ 0.976076] iommu: Adding device 13e10000.host1x:ctx5 to group 32
[ 0.977506] iommu: Adding device 13e10000.host1x:ctx6 to group 33
[ 0.978896] iommu: Adding device 13e10000.host1x:ctx7 to group 34
[ 0.980777] iommu: Adding device 15340000.vic to group 35
[ 0.982253] iommu: Adding device 15380000.nvjpg to group 36
[ 0.982773] iommu: Adding device 15500000.tsec to group 37
[ 0.983194] iommu: Adding device 15100000.tsecb to group 38
[ 0.983661] iommu: Adding device 15480000.nvdec to group 39
[ 0.984114] iommu: Adding device 15140000.nvdec1 to group 40
[ 0.984523] iommu: Adding device 154c0000.nvenc to group 41
[ 0.984954] iommu: Adding device 15a80000.nvenc1 to group 42
[ 0.985561] iommu: Adding device 15880000.nvdla0 to group 43
[ 0.986201] iommu: Adding device 158c0000.nvdla1 to group 44
[ 0.987222] iommu: Adding device 15200000.nvdisplay to group 45
[ 0.987635] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0791000(800000)
[ 0.987710] platform 15200000.nvdisplay: IOVA linear map 0x00000000a078e000(3000)
[ 0.987776] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.988378] iommu: Adding device 15210000.nvdisplay to group 46
[ 0.988477] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.989049] iommu: Adding device 15220000.nvdisplay to group 47
[ 0.989144] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[ 0.991904] iommu: Adding device 15c10000.vi to group 48
[ 0.992199] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.992763] iommu: Adding device 14800000.isp to group 49
[ 0.994924] iommu: Adding device 16000000.pva0 to group 50
[ 0.995777] iommu: Adding device 16800000.pva1 to group 51
[ 0.996459] iommu: Adding device 15810000.se to group 52
[ 0.997089] iommu: Adding device 15820000.se to group 53
[ 0.997587] iommu: Adding device 15830000.se to group 54
[ 0.998035] iommu: Adding device 15840000.se to group 55
[ 0.998460] iommu: Adding device c1a0000.aon to group 56
[ 1.000762] iommu: Adding device d000000.bpmp to group 57
[ 1.001248] bpmp: ping status is 0
[ 1.001510] bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
[ 1.005542] bpmp d000000.bpmp: probe ok
[ 1.008171] tegra-reset 0.bpmp_reset: registered 186 resets.
[ 1.009264] iommu: Adding device smmu_test to group 58
[ 1.011020] mc: mapped MMIO address: 0xffffff800a690000 -> 0x2c10000
[ 1.011111] mc: mapped MMIO address: 0xffffff800a6b0000 -> 0x2c20000
[ 1.011209] mc: mapped MMIO address: 0xffffff800a6d0000 -> 0x2c30000
[ 1.011287] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c40000
[ 1.011365] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c50000
[ 1.011440] mc: mapped MMIO address: 0xffffff800b210000 -> 0x2b80000
[ 1.011515] mc: mapped MMIO address: 0xffffff800b230000 -> 0x2b90000
[ 1.011588] mc: mapped MMIO address: 0xffffff800b250000 -> 0x2ba0000
[ 1.011662] mc: mapped MMIO address: 0xffffff800b270000 -> 0x2bb0000
[ 1.011735] mc: mapped MMIO address: 0xffffff800b290000 -> 0x1700000
[ 1.011831] mc: mapped MMIO address: 0xffffff800b2b0000 -> 0x1710000
[ 1.011910] mc: mapped MMIO address: 0xffffff800b2d0000 -> 0x1720000
[ 1.011979] mc: mapped MMIO address: 0xffffff800b2f0000 -> 0x1730000
[ 1.012046] mc: mapped MMIO address: 0xffffff800b310000 -> 0x1740000
[ 1.012113] mc: mapped MMIO address: 0xffffff800b330000 -> 0x1750000
[ 1.012191] mc: mapped MMIO address: 0xffffff800b350000 -> 0x1760000
[ 1.012263] mc: mapped MMIO address: 0xffffff800b370000 -> 0x1770000
[ 1.012421] mc-err: mcerr ops are set to t19x
[ 1.020748] iommu: Adding device 2600000.dma to group 59
[ 1.027431] GPIO line 490 (pcie-reg-enable) hogged as output/high
[ 1.027533] GPIO line 289 (pcie-reg-enable) hogged as output/high
[ 1.027634] GPIO line 339 (wifi-enable) hogged as output/high
[ 1.028059] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 1.036989] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 1.037544] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 1.040211] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 1.040273] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 1.041229] iommu: Adding device 3550000.xudc to group 60
[ 1.042467] iommu: Adding device 3610000.xhci to group 61
[ 1.044075] arm64_ras arm64_ras: RAS driver enabled
[ 1.044816] carmel_ras_enable:RAS enabled on cpu0
[ 1.045163] carmel_ras_enable:RAS enabled on cpu1
[ 1.045566] carmel_ras_enable:RAS enabled on cpu2
[ 1.045981] carmel_ras_enable:RAS enabled on cpu3
[ 1.046295] carmel_ras_enable:RAS enabled on cpu4
[ 1.046579] carmel_ras_enable:RAS enabled on cpu5
[ 1.046866] carmel_ras_enable:RAS enabled on cpu6
[ 1.047250] carmel_ras_enable:RAS enabled on cpu7
[ 1.047556] carmel_ras_enable:RAS enabled on cpu0
[ 1.047853] carmel_ras_enable:RAS enabled on cpu1
[ 1.048143] carmel_ras_enable:RAS enabled on cpu2
[ 1.048436] carmel_ras_enable:RAS enabled on cpu3
[ 1.048698] carmel_ras_enable:RAS enabled on cpu4
[ 1.048918] carmel_ras_enable:RAS enabled on cpu5
[ 1.049183] carmel_ras_enable:RAS enabled on cpu6
[ 1.049443] carmel_ras_enable:RAS enabled on cpu7
[ 1.049590] carmel_ras carmel_ras: probed
[ 1.051300] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 1.052233] tegra-cbb c600000.aon-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 1.053502] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 1.054876] tegra-cbb be00000.rce-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[ 1.056019] tegra-cbb b600000.sce-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[ 1.056601] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 1.060316] vdd-3v3-cvb: 3300 mV
[ 1.060832] vdd-1v8-cvb: 1800 mV
[ 1.061344] vdd-1v8-sd: 1800 mV
[ 1.062072] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 1.062205] vdd-epb-1v0: 1000 mV
[ 1.062942] vdd-sdmmc1-sw: 3300 mV
[ 1.063588] avdd-cam-2v8: 2800 mV
[ 1.064170] vdd-sata-1v5: 1500 mV
[ 1.064683] vdd-1v8-slt: 1800 mV
[ 1.065256] vdd-3v3-slt: 3300 mV
[ 1.065876] vdd-fan: 5000 mV
[ 1.066528] vdd-hdmi-5v0: 5000 mV
[ 1.067053] vdd_sys_en: 1200 mV
[ 1.067844] vdd-5v-sata: 5000 mV
[ 1.068435] vdd-ac-bat: 5000 mV
[ 1.068824] vdd-5v-sata: supplied by vdd-ac-bat
[ 1.070606] vdd-usb20-5v0: supplied by vdd-ac-bat
[ 1.070723] vdd-usb20-5v0: 5000 mV
[ 1.113885] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.114483] SCSI subsystem initialized
[ 1.114802] libata version 3.00 loaded.
[ 1.114950] usbcore: USB support
[ 1.114993] usbcore: usb_acpi_register
[ 1.115110] usbcore: bus_register_notifier
[ 1.115138] usbcore: usb_major_init
[ 1.115173] usbcore: usb_register
[ 1.115376] usbcore: registered new interface driver usbfs
[ 1.115405] usbcore: usb_devio_init
[ 1.115436] usbcore: usb_hub_init
[ 1.115554] usbcore: registered new interface driver hub
[ 1.115686] usbcore: usb_register_device_driver
[ 1.115869] usbcore: registered new device driver usb
[ 1.129467] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 1.132903] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 1.143983] vdd-1v0: at 1000 mV
[ 1.151948] vdd-1v8-hs: at 1800 mV
[ 1.160054] vdd-1v8-ls: at 1800 mV
[ 1.168071] vdd-1v8-ao: at 1800 mV
[ 1.176103] vddio-ddr-1v1: at 1100 mV
[ 1.183925] vdd-rtc: at 800 mV
[ 1.185935] spmic-ldo1: at 2375 mV
[ 1.196095] vdd-ao-3v3: at 3300 mV
[ 1.208088] vddio-emmc-3v3: at 3300 mV
[ 1.209836] spmic-ldo4: at 1587 mV
[ 1.220203] vdd-usb-3v3: at 3300 mV
[ 1.232346] vddio-sdmmc1-3v3: at 3300 mV
[ 1.240452] vdd-csi-1v2: at 1200 mV
[ 1.242637] spmic-ldo8: at 1800 mV
[ 1.245050] GPIO line 246 (gpio_default) hogged as output/high
[ 1.246772] GPIO line 247 (gpio_default) hogged as output/high
[ 1.247568] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 1.251409] max77620 4-003c: max77620 probe successful
[ 1.252527] media: Linux media interface: v0.10
[ 1.252647] Linux video capture interface: v2.00
[ 1.254552] pps_core: LinuxPPS API ver. 1 registered
[ 1.254606] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.254753] PTP clock support registered
[ 1.255855] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.256001] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 1.257773] tegra_fiq_debugger_init: found FIQ source (IRQ 472)
[ 1.259557] Advanced Linux Sound Architecture Driver Initialized.
[ 1.260318] Bluetooth: Core ver 2.22
[ 1.260402] NET: Registered protocol family 31
[ 1.260443] Bluetooth: HCI device and connection manager initialized
[ 1.260509] Bluetooth: HCI socket layer initialized
[ 1.260618] Bluetooth: L2CAP socket layer initialized
[ 1.260696] Bluetooth: SCO socket layer initialized
[ 1.264455] camchar: rtcpu character device driver loaded
[ 1.266138] clocksource: Switched to clocksource arch_sys_counter
[ 1.319750] VFS: Disk quotas dquot_6.6.0
[ 1.319967] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.320511] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.323129] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.323311] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.323389] nvmap_page_pool_init: Total RAM pages: 4047606
[ 1.323435] nvmap_page_pool_init: nvmap page pool size: 505950 pages (1976 MB)
[ 1.323853] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.326381] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.343220] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.343759] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.344111] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.344624] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.345259] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 1.345643] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 1.345945] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 1.361402] la/ptsa driver initialized.
[ 1.361945] NET: Registered protocol family 2
[ 1.363352] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.364099] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.365013] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.365100] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.365436] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[ 1.366255] NET: Registered protocol family 1
[ 1.367282] RPC: Registered named UNIX socket transport module.
[ 1.367320] RPC: Registered udp transport module.
[ 1.367350] RPC: Registered tcp transport module.
[ 1.367378] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.367414] PCI: CLS 0 bytes, default 128
[ 1.367694] Trying to unpack rootfs image as initramfs...
[ 1.391261] random: fast init done
[ 1.395983] host1x 13e10000.host1x: initialized
[ 1.399003] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.405565] audit: initializing netlink subsys (disabled)
[ 1.405688] audit: type=2000 audit(0.944:1): initialized
[ 1.406760] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.419403] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.421016] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.421930] 9p: Installing v9fs 9p2000 file system support
[ 1.428639] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.428989] io scheduler noop registered
[ 1.429335] io scheduler cfq registered (default)
[ 1.434345] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.475768] iommu: Adding device 2993000.adsp to group 62
[ 1.584734] iommu: Adding device aconnect@2a41000:adsp_audio to group 63
[ 1.585946] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.603665] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.604322] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.605117] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.609461] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.609980] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.610092] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.614295] tsec 15500000.tsec: initialized
[ 1.616727] tsec 15100000.tsecb: initialized
[ 1.622378] nvdec 15480000.nvdec: initialized
[ 1.625948] nvdec 15140000.nvdec1: initialized
[ 1.633215] falcon 15340000.vic: initialized
[ 1.636003] falcon 15380000.nvjpg: initialized
[ 1.638549] falcon 154c0000.nvenc: initialized
[ 1.640951] falcon 15a80000.nvenc1: initialized
[ 1.644318] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.647040] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.649611] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.652325] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.655025] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.657607] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.660363] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.663036] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.667779] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.675247] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.675998] scare-pigeon 14b00000.isp-thi: initialized
[ 1.686917] pva 16000000.pva0: initialized
[ 1.719758] pva 16800000.pva1: initialized
[ 1.750844] nvdla 15880000.nvdla0: initialized
[ 1.782176] nvdla 158c0000.nvdla1: initialized
[ 1.786391] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 1.786637] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
[ 1.786694] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
[ 1.786755] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 1.787988] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.788102] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.788252] tegradccommon 15200000.dc_common: dma mapping done
[ 1.789235] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[ 1.789388] generic_infoframe_type: 0x87
[ 1.789594] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.789712] tegradc 15200000.nvdisplay: Display dc.ffffff800bfd0000 registered with id=0
[ 1.797190] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 1.797267] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 1.797332] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 1.797719] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.797783] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.799964] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.800655] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 1.802425] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.803222] kfuse 3830000.kfuse: initialized
[ 1.803424] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.803504] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.807701] tegradc 15200000.nvdisplay: probed
[ 1.812629] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.816816] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
[ 1.818614] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
[ 1.819787] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
[ 4.299144] console [ttyTCU0] enabled
[ 4.300026] Console: switching to colour frame buffer device 240x67
[ 4.303960] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:290 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 4.323132] tegradc 15200000.nvdisplay: fb registered
[ 4.328579] gpio tegra-gpio wake71 for gpio=98(M:2)
[ 4.340970] brd: module loaded
[ 4.349067] loop: module loaded
[ 4.349402] tegra_profiler: version: 1.128, samples/io: 44/25
[ 4.350010] tegra_profiler: auth: init
[ 4.350772] nct1008_nct72 4-004c: starting parse dt
[ 4.351311] THERMAL EST: found 3 subdevs
[ 4.351314] THERMAL EST num_resources: 0
[ 4.351318] [THERMAL EST subdev 0]
[ 4.351323] [THERMAL EST subdev 1]
[ 4.351326] [THERMAL EST subdev 2]
[ 4.351729] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 4.351731] THERMAL EST: thz register success.
[ 4.352069] THERMAL EST: end of probe, return err: 0
[ 4.353008] hisi_sas: driver version v1.6
[ 4.394514] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 4.400449] nct1008_nct72 4-004c: success parsing dt
[ 4.401390] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.401638] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.417403] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 4.418804] Parent Clock set for DC plld3
[ 4.424909] tegra-qspi 3270000.spi: Prod settings list not found
[ 4.431258] tegra-qspi 3300000.spi: Prod settings list not found
[ 4.438161] libphy: Fixed MDIO Bus: probed
[ 4.441031] tun: Universal TUN/TAP device driver, 1.6
[ 4.441033] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.441860] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.441895] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.441947] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.441949] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.441991] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.441993] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.442041] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.442044] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.442476] sky2: driver version 1.30
[ 4.443945] PPP generic driver version 2.4.2
[ 4.444295] PPP BSD Compression module registered
[ 4.444298] PPP Deflate Compression module registered
[ 4.444315] PPP MPPE Compression module registered
[ 4.444319] NET: Registered protocol family 24
[ 4.444384] usbcore: registered new interface driver r8152
[ 4.444436] eqos 2490000.ether_qos: no PHY interrupt found
[ 4.444456] usbcore: registered new interface driver asix
[ 4.444504] usbcore: registered new interface driver ax88179_178a
[ 4.444571] usbcore: registered new interface driver cdc_ether
[ 4.444615] usbcore: registered new interface driver net1080
[ 4.444667] usbcore: registered new interface driver cdc_subset
[ 4.444759] usbcore: registered new interface driver zaurus
[ 4.444824] usbcore: registered new interface driver cdc_ncm
[ 4.445110] VFIO - User Level meta-driver version: 0.3
[ 4.446706] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.446722] ehci-pci: EHCI PCI platform driver
[ 4.446763] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.446770] ohci-pci: OHCI PCI platform driver
[ 4.446811] ohci-platform: OHCI generic platform driver
[ 4.449023] eqos 2490000.ether_qos: No prod values found
[ 4.449827] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb ad 2f
[ 4.449981] libphy: dwc_phy: probed
[ 4.455399] tegra-xusb 3610000.xhci: No USB port has OTG_CAP
[ 4.458663] tegra-xusb 3610000.xhci: Direct firmware load for tegra19x_xusb_firmware failed with error -2
[ 4.458669] tegra-xusb 3610000.xhci: Falling back to user helper
[ 4.459095] usbcore: registered new interface driver uas
[ 4.459163] usbcore: registered new interface driver usb-storage
[ 4.459267] usbcore: registered new interface driver usbserial
[ 4.459348] usbcore: registered new interface driver option
[ 4.459391] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4.463167] tegra-xudc-new 3550000.xudc: extcon_get_extcon_dev_by_cable failed -19
[ 4.464049] mousedev: PS/2 mouse device common for all mice
[ 4.471114] tegradc 15200000.nvdisplay: hdmi: tmds rate:148367K prod-setting:prod_c_hdmi_111m_223m
[ 4.597623] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.599501] Wake73 for irq=42
[ 4.600911] rtc rtc1: alarm rtc device
[ 4.600929] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.600994] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.601162] i2c /dev entries driver
[ 4.604472] max77620-power max20024-power: Event recorder REG_NVERC : 0xef
[ 4.609485] FAN dev name: pwm-fan
[ 4.609551] FAN:gpio request success.
[ 4.609568] FAN: can't find tach_gpio
[ 4.609600] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 4.609858] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 4.609864] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.610283] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.610289] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[ 4.610295] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 4.610300] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 4.610304] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.610309] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.610314] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.610319] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.610324] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.610328] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.611372] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.611812] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
[ 4.615215] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[ 4.669664] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[ 4.669715] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 4.669721] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 4.669914] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[ 4.670011] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 4.670050] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 4.670478] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[ 4.670539] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 4.670548] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 4.670865] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[ 4.670923] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 4.670930] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 4.671378] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 4.671460] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 4.671466] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 4.671831] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[ 4.673871] device-mapper: uevent: version 1.0.3
[ 4.674502] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 4.683913] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.690765] cpuidle: Initializing cpuidle driver
[ 4.705982] sdhci: Secure Digital Host Controller Interface driver
[ 4.705984] sdhci: Copyright(c) Pierre Ossman
[ 4.705985] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.707436] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.709848] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 4.711535] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 4.711980] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.713278] tegra-se-nvhost 15810000.se: initialized
[ 4.713471] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 4.714805] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.715563] tegra-se-nvhost 15820000.se: initialized
[ 4.716453] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.717253] tegra-se-nvhost 15830000.se: initialized
[ 4.717742] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.718556] tegra-se-nvhost 15840000.se: initialized
[ 4.719357] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.719607] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.720971] usbcore: registered new interface driver usbhid
[ 4.720972] usbhid: USB HID core driver
[ 4.726905] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.727948] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.728373] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.728944] denver_knobs_init:MTS_VERSION:43306594
[ 4.729160] tegra19x_actmon d230000.actmon: in actmon_register()...
[ 4.730000] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.730330] t19x_cache tegra-cache: probed
[ 4.736461] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 4.736484] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 4.738548] nvpmodel: initialized successfully
[ 4.739412] tegra-hda 3510000.hda: Override SDO lines to 4
[ 4.739649] usbcore: registered new interface driver snd-usb-audio
[ 4.752273] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.752562] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.752728] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 4.752859] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 4.754175] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.770229] gpio tegra-gpio wake8 for gpio=55(G:7)
[ 4.770298] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 4.847845] mmc0: periodic cache flush enabled
[ 4.847879] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 4.848413] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 4.848708] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[ 4.848976] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[ 4.849170] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[ 4.850724] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36
[ 5.325889] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 5.332295] nct1008_nct72 4-004c: EXT shutdown limit 109
[ 5.369826] nct1008_nct72 4-004c: initial LOC temp: 39000
[ 5.371077] nct1008_nct72 4-004c: initial EXT temp: 53750
[ 5.372448] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[ 5.373759] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 6.592654] gpio tegra-gpio wake12 for gpio=149(S:5)
[ 6.699941] OPE platform probe
[ 6.700129] OPE platform probe successful
[ 6.834362] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 6.834643] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 6.835077] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 6.835316] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 6.835633] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 6.835861] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 6.836056] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 6.836318] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 6.836550] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 6.836883] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 6.837142] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 6.837523] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 6.837721] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 6.837953] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 6.838218] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 6.838444] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 6.838716] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 6.842412] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 6.848694] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 6.854488] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 6.901084] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[ 6.902776] u32 classifier
[ 6.902860] Actions configured
[ 6.902993] Initializing XFRM netlink socket
[ 6.903564] NET: Registered protocol family 10
[ 6.904429] NET: Registered protocol family 17
[ 6.904546] NET: Registered protocol family 15
[ 6.904679] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.906048] Bluetooth: RFCOMM socket layer initialized
[ 6.911411] Bluetooth: RFCOMM ver 1.11
[ 6.915238] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.921195] Bluetooth: HIDP socket layer initialized
[ 6.926210] 9pnet: Installing 9P2000 support
[ 6.930609] Key type dns_resolver registered
[ 6.935247] Registered cp15_barrier emulation handler
[ 6.940113] Registered setend emulation handler
[ 6.946713] registered taskstats version 1
[ 6.949351] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[ 6.957187] OF: PCI: host bridge /pcie@14180000 ranges:
[ 6.960929] OF: PCI: IO 0x38100000..0x381fffff -> 0x38100000
[ 6.966970] OF: PCI: MEM 0x38200000..0x39ffffff -> 0x38200000
[ 6.972912] OF: PCI: MEM 0x1800000000..0x1bffffffff -> 0x1800000000
[ 7.490488] tegra-pcie-dw 14180000.pcie: link is down
[ 7.490885] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[ 7.491029] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 7.491129] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 7.491297] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
[ 7.491438] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
[ 7.491614] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 7.491762] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 7.492035] iommu: Adding device 0000:00:00.0 to group 64
[ 7.492365] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 7.492480] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.492856] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 7.492978] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
[ 7.493054] aer 0000:00:00.0:pcie002: service driver aer loaded
[ 7.493222] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
[ 7.493262] aer 0000:00:00.0:pcie002: unloading service driver aer
[ 7.493345] pci_bus 0000:01: busn_res: [bus 01-ff] is released
[ 7.493405] iommu: Removing device 0000:00:00.0 from group 64
[ 7.493546] pci_bus 0000:00: busn_res: [bus 00-ff] is released
[ 7.493767] tegra-pcie-dw 14180000.pcie: PCIe link is not up...!
[ 7.494824] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[ 7.496093] OF: PCI: host bridge /pcie@14100000 ranges:
[ 7.496231] OF: PCI: IO 0x30100000..0x301fffff -> 0x30100000
[ 7.496622] OF: PCI: MEM 0x30200000..0x31ffffff -> 0x30200000
[ 7.502530] OF: PCI: MEM 0x1200000000..0x123fffffff -> 0x1200000000
[ 8.022222] tegra-pcie-dw 14100000.pcie: link is down
[ 8.022542] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[ 8.022669] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 8.022770] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 8.022936] pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
[ 8.023069] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
[ 8.023235] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 8.023390] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.023617] iommu: Adding device 0001:00:00.0 to group 64
[ 8.023967] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 8.024083] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.024457] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.024599] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.024675] aer 0001:00:00.0:pcie002: service driver aer loaded
[ 8.024836] pcie_pme 0001:00:00.0:pcie001: unloading service driver pcie_pme
[ 8.024877] aer 0001:00:00.0:pcie002: unloading service driver aer
[ 8.024940] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 8.024997] iommu: Removing device 0001:00:00.0 from group 64
[ 8.025137] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 8.025361] tegra-pcie-dw 14100000.pcie: PCIe link is not up...!
[ 8.026314] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[ 8.027480] OF: PCI: host bridge /pcie@14140000 ranges:
[ 8.027600] OF: PCI: IO 0x34100000..0x341fffff -> 0x34100000
[ 8.028652] OF: PCI: MEM 0x34200000..0x35ffffff -> 0x34200000
[ 8.034575] OF: PCI: MEM 0x1280000000..0x12bfffffff -> 0x1280000000
[ 8.553967] tegra-pcie-dw 14140000.pcie: link is down
[ 8.554248] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0002:00
[ 8.554374] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 8.554475] pci_bus 0002:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 8.554640] pci_bus 0002:00: root bus resource [mem 0x34200000-0x35ffffff]
[ 8.554760] pci_bus 0002:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
[ 8.554928] pci 0002:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 8.555069] pci 0002:00:00.0: PME# supported from D0 D3hot D3cold
[ 8.555276] iommu: Adding device 0002:00:00.0 to group 64
[ 8.555594] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[ 8.555725] pci 0002:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.556042] pcieport 0002:00:00.0: Signaling PME through PCIe PME interrupt
[ 8.556163] pcie_pme 0002:00:00.0:pcie001: service driver pcie_pme loaded
[ 8.556236] aer 0002:00:00.0:pcie002: service driver aer loaded
[ 8.556382] pcie_pme 0002:00:00.0:pcie001: unloading service driver pcie_pme
[ 8.556422] aer 0002:00:00.0:pcie002: unloading service driver aer
[ 8.556485] pci_bus 0002:01: busn_res: [bus 01-ff] is released
[ 8.556542] iommu: Removing device 0002:00:00.0 from group 64
[ 8.556667] pci_bus 0002:00: busn_res: [bus 00-ff] is released
[ 8.556909] tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
[ 8.557966] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 8.559436] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 8.559560] OF: PCI: IO 0x3a100000..0x3a1fffff -> 0x3a100000
[ 8.560125] OF: PCI: MEM 0x3a200000..0x3bffffff -> 0x3a200000
[ 8.566026] OF: PCI: MEM 0x1c00000000..0x1fffffffff -> 0x1c00000000
[ 9.081621] tegra-pcie-dw 141a0000.pcie: link is down
[ 9.081936] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0003:00
[ 9.082073] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 9.082219] pci_bus 0003:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 9.082386] pci_bus 0003:00: root bus resource [mem 0x3a200000-0x3bffffff]
[ 9.082504] pci_bus 0003:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
[ 9.082654] pci 0003:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 9.082791] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 9.083180] iommu: Adding device 0003:00:00.0 to group 64
[ 9.083545] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 9.083651] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.084005] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[ 9.084148] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
[ 9.084260] aer 0003:00:00.0:pcie002: service driver aer loaded
[ 9.084490] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
[ 9.084537] aer 0003:00:00.0:pcie002: unloading service driver aer
[ 9.084596] pci_bus 0003:01: busn_res: [bus 01-ff] is released
[ 9.084655] iommu: Removing device 0003:00:00.0 from group 64
[ 9.084781] pci_bus 0003:00: busn_res: [bus 00-ff] is released
[ 9.084964] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[ 9.097989] tegra-cbb 14040000.cv-noc: noc_secure_irq = 101, noc_nonsecure_irq = 100>
[ 9.105234] tegra194-isp5 14800000.isp: initialized
[ 9.117216] tegra194-vi5 15c10000.vi: initialized
[ 9.124423] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[ 9.124620] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@1/endpoint.
[ 9.126439] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 9.126638] tegra186-cam-rtcpu bc00000.rtcpu: Coverage buffer configured at IOVA=0xbfef8000
[ 9.131141] tegra186-cam-rtcpu bc00000.rtcpu: IOVM setup error: 130
[ 9.131267] tegra186-cam-rtcpu bc00000.rtcpu: RTCPU coverage: IOVM setup error : 4294967291
[ 9.137992] tegra186-cam-rtcpu bc00000.rtcpu: (expected if RTCPU was not built with coverage enabled)
[ 9.147455] tegra186-cam-rtcpu bc00000.rtcpu: coverage boot sync status: -5
[ 9.154650] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 9.163275] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 9.173364] tegra-ivc-cdev ivc-bc00000.rtcpu:echo@0: probing /dev/camchar-echo
[ 9.180736] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 9.190841] tegra-ivc-cdev ivc-bc00000.rtcpu:dbg@1: probing /dev/camchar-dbg
[ 9.197985] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 9.208681] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 9.219810] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 9.231476] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (72)
[ 9.237944] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 9.246409] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=5d9f1c48356a1dad5a597123920f5319cb04aa87
[ 9.257946] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 9.261468] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 9.267327] input: gpio-keys as /devices/gpio-keys/input/input5
[ 9.308071] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:16 UTC (946688416)
[ 9.308767] mmcblk mmc0:0001: Card claimed for testing.
[ 9.344686] bpmp: mounted debugfs mirror
[ 9.350934] vdd-1v8-cvb: disabling
[ 9.351027] vdd-1v8-sd: disabling
[ 9.351090] vdd-epb-1v0: disabling
[ 9.351149] vdd-sdmmc1-sw: disabling
[ 9.351221] avdd-cam-2v8: disabling
[ 9.351284] vdd-sata-1v5: disabling
[ 9.351350] vdd-3v3-slt: disabling
[ 9.351408] vdd-fan: disabling
[ 9.351488] vdd_sys_en: disabling
[ 9.351581] ALSA device list:
[ 9.351636] #0: tegra-hda-galen-t194 at 0x3518000 irq 71
[ 9.351743] #1: tegra-snd-t19x-mobile-rt565x
[ 9.460995] EXT4-fs (mmcblk0p1): 15 orphan inodes deleted
[ 9.461130] EXT4-fs (mmcblk0p1): recovery complete
[ 9.472463] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.472663] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 9.473923] devtmpfs: mounted
[ 9.475571] Freeing unused kernel memory: 8512K
[ 9.558315] systemd[1]: System time before build time, advancing clock.
[ 9.573305] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.575801] cgroup: cgroup2: unknown option "nsdelegate"
[ 9.585557] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 9.586821] systemd[1]: Detected architecture arm64.
[ 9.597534] systemd[1]: Set hostname to <jetson-0423518031540>.
[ 9.659136] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 9.659463] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 9.759553] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.760054] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.760586] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.765982] systemd[1]: Created slice User and Session Slice.
[ 9.766423] random: systemd: uninitialized urandom read (16 bytes read)
[ 9.766572] systemd[1]: Reached target Swap.
[ 9.766801] systemd[1]: Reached target User and Group Name Lookups.
[ 9.768267] systemd[1]: Created slice System Slice.
[ 9.802648] gpio tegra-gpio wake44 for gpio=192(Y:0)
[ 9.807138] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 10.014369] systemd-journald[2365]: Received request to flush runtime journal from PID 1
[ 10.654464] spidev: module is already loaded
[ 10.656710] bmi160 8-0069: nvs_vregs_init vdd err=-19
[ 10.656856] bmi160 8-0069: nvs_vregs_init vdd_IO err=-19
[ 10.669838] tegra-xusb 3610000.xhci: cannot find firmware....retry after 1 second
[ 10.691293] spidev: module is already loaded
[ 10.714378] tegra-i2c 31e0000.i2c: no acknowledge from address 0x69
[ 10.714580] bmi160 8-0069: bmi_i2c_rd ERR: 0x00
[ 10.714659] bmi160 8-0069: bmi_init _id_i2c ERR
[ 10.714738] bmi160 8-0069: bmi_pm pm_en=0 ERR=-22
[ 10.714817] bmi160 8-0069: bmi_remove
[ 10.714819] bmi160 8-0069: bmi_probe done
[ 10.725356] spidev: module is already loaded
[ 10.766696] spidev: module is already loaded
[ 10.780565] random: crng init done
[ 10.780663] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.810657] spidev: module is already loaded
[ 10.856140] spidev: module is already loaded
[ 10.902609] spidev: module is already loaded
[ 11.647943] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.649744] can: controller area network core (rev 20120528 abi 9)
[ 11.671187] CPU4: shutdown
[ 11.671317] psci: CPU4 killed.
[ 11.675300] NET: Registered protocol family 29
[ 11.694182] tegra-xusb 3610000.xhci: Firmware timestamp: 2018-03-29 14:24:42 UTC, Version: 60.05 release
[ 11.694205] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 11.709837] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 11.711078] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 11.711113] tegra-xusb 3610000.xhci: irq 475, io mem 0x03610000
[ 11.711248] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 11.711252] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.711255] usb usb1: Product: xHCI Host Controller
[ 11.711257] usb usb1: Manufacturer: Linux 4.9.108 xhci-hcd
[ 11.711259] usb usb1: SerialNumber: 3610000.xhci
[ 11.711663] usbcore hub_probe start
[ 11.711668] hub 1-0:1.0: USB hub found
[ 11.711739] hub 1-0:1.0: 4 ports detected
[ 11.712134] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 11.712143] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 11.712149] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 11.713078] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 11.713083] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 11.713087] usb usb2: Product: xHCI Host Controller
[ 11.713089] usb usb2: Manufacturer: Linux 4.9.108 xhci-hcd
[ 11.713091] usb usb2: SerialNumber: 3610000.xhci
[ 11.713450] usbcore hub_probe start
[ 11.713455] hub 2-0:1.0: USB hub found
[ 11.713508] hub 2-0:1.0: 4 ports detected
[ 11.717849] Wake76 for irq=199
[ 11.717854] Wake77 for irq=199
[ 11.717856] Wake78 for irq=199
[ 11.717858] Wake79 for irq=199
[ 11.717859] Wake80 for irq=199
[ 11.717860] Wake81 for irq=199
[ 11.717861] Wake82 for irq=199
[ 11.718993] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 11.723076] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.732400] CPU5: shutdown
[ 11.732501] psci: CPU5 killed.
[ 11.751289] can: raw protocol (rev 20120528)
[ 11.779083] CAN device driver interface
[ 11.793907] CPU6: shutdown
[ 11.794007] psci: CPU6 killed.
[ 11.812843] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x00000300|
| rxbc_rbsa |0x00000540|
| txefc_efsa |0x00000780|
| txbc_tbsa |0x00000800|
| tmc_tmsa |0x00000c80|
[ 11.812948] Release 3.2.0 from 19.12.2014
[ 11.813704] net can0: mttcan device registered (regs=ffffff800a597000, irq=69)
[ 11.819295] Message RAM Configuration
| base addr |0x0c322000|
[ 11.819392] Release 3.2.0 from 19.12.2014
[ 11.819738] net can1: mttcan device registered (regs=ffffff800a5b5000, irq=70)
[ 11.825122] mttcan c310000.mttcan can0: Bitrate set
[ 11.828683] mttcan c320000.mttcan can1: Bitrate set
[ 11.831332] mttcan_controller_config: ctrlmode 30
[ 11.831357] mttcan c310000.mttcan can0: Bitrate set
[ 11.833453] mttcan_controller_config: ctrlmode 30
[ 11.833478] mttcan c320000.mttcan can1: Bitrate set
[ 11.855985] CPU7: shutdown
[ 11.856125] psci: CPU7 killed.
[ 11.857765] nvgpu: 17000000.gv11b tpc_pg_mask_store:889 [INFO] no value change, same mask already set
[ 12.038235] usb 1-1: new low-speed USB device number 2 using tegra-xusb
[ 12.063937] usb 1-1: New USB device found, idVendor=046d, idProduct=c077
[ 12.063951] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 12.063956] usb 1-1: Product: USB Optical Mouse
[ 12.063961] usb 1-1: Manufacturer: Logitech
[ 12.068107] input: Logitech USB Optical Mouse as /devices/3610000.xhci/usb1/1-1/1-1:1.0/0003:046D:C077.0001/input/input6
[ 12.068704] hid-generic 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-3610000.xhci-1/input0
[ 12.190248] usb 1-4: new low-speed USB device number 3 using tegra-xusb
[ 12.219438] usb 1-4: New USB device found, idVendor=413c, idProduct=2113
[ 12.219456] usb 1-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 12.219461] usb 1-4: Product: Dell KB216 Wired Keyboard
[ 12.226313] input: Dell KB216 Wired Keyboard as /devices/3610000.xhci/usb1/1-4/1-4:1.0/0003:413C:2113.0002/input/input7
[ 12.291188] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3610000.xhci-4/input0
[ 12.299459] input: Dell KB216 Wired Keyboard as /devices/3610000.xhci/usb1/1-4/1-4:1.1/0003:413C:2113.0003/input/input8
[ 12.358885] hid-generic 0003:413C:2113.0003: input,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3610000.xhci-4/input1
[ 13.590290] tegradc 15200000.nvdisplay: blank - powerdown
[ 13.674941] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 13.675712] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 13.676491] tegradc 15200000.nvdisplay: unblank
[ 13.677580] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 13.677763] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 13.687273] Parent Clock set for DC plld3
[ 13.691048] edid invalid
[ 13.693011] tegradc 15200000.nvdisplay: hdmi: tmds rate:148367K prod-setting:prod_c_hdmi_111m_223m
[ 13.694978] tegradc 15200000.nvdisplay: unblank
[ 14.567612] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 14.568875] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.758335] tegra-i2c 31c0000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 14.758582] tegra-i2c 31c0000.i2c: --- register dump for debugging ----
[ 14.758705] tegra-i2c 31c0000.i2c: I2C_CNFG - 0x22c00
[ 14.758895] tegra-i2c 31c0000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 14.759019] tegra-i2c 31c0000.i2c: I2C_FIFO_CONTROL - 0x0
[ 14.759141] tegra-i2c 31c0000.i2c: I2C_FIFO_STATUS - 0x800080
[ 14.759258] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_CONTROL - 0x70000
[ 14.759368] tegra-i2c 31c0000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 14.759492] tegra-i2c 31c0000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
[ 14.759606] tegra-i2c 31c0000.i2c: I2C_INT_MASK - 0x7d
[ 14.759714] tegra-i2c 31c0000.i2c: I2C_INT_STATUS - 0x2
[ 14.759826] tegra-i2c 31c0000.i2c: i2c transfer timed out addr: 0x50
The log has some differences now.
Are you sure you are using those GPIO on your board? If same device tree can work on devkit, I would suggest you to review the hardware design.
BTW, what PCIe device do you connect on your board when boot up?
I will check the hardware .And I find the difference between the two dmesg.
demo board:
tegra-pcie-dw 14100000.pcie: link is up
our board:
xubin4952,
Do you connect any PCIe device on your board when you test?
Hi WayneWWW,
I did not connect any device on the board we designed ,and demo board.
You need to connect at least one device on it during test. Please try that first.
By default, the SATA port on devkit is actually going through a PCIe bridge. That is why you saw a pcie device in lspci.
we can see two device in demo board,one is the SATA port ,what is the another device(PCI bridge )? can we see this device in our board? I have communicated with our hardware colleague. we have a Ethernet card on the pcie.When I execute
lspci I can not see the information of this device.
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1)
0001:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9171 (rev 13)
Hi Jason,
Yes, as I said in #17, this pcie bridge is on devkit for eSATA. I don’t know if you could see that on your board. This is your board. You should know it better than I do. If you don’t have such bridge, then it is not possible shown.
Also, if you still cannot see anything when NIC card connected. Please dump the dmesg to us again(with card connected).
Hi Wayne,
We connect a ethernet on the pcie ,do we need to do some change to support this device ? or we can directly get information by the command lscpi.
