dmesg.log (63.3 KB)
This is dmesg log.
[BEGIN] 2021/5/6 10:46:02
nvidia@nvidia:~/Desktop$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-5285-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 0.000000] Found tegra_fbmem: 00800000@a06a0000
[ 0.000000] Found lut_mem: 00002008@a069a000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb3_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[ 0.000000] On node 0 totalpages: 2031101
[ 0.000000] DMA zone: 7160 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 458237 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572864 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] pcpu-alloc: s57560 r8192 d32552 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1999365
us=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29180(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7182604K/8124404K available (15294K kernel code, 2942K rwdata, 6664K rodata, 8576K init, 609K bss, 188136K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009600000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009600000 - 0xffffff8009e60000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e60000 - 0xffffff800a13f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a13f808 - 0xffffff800a1d7cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf08000000 ( 128 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000004] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000727] Console: colour dummy device 80x25
[ 0.000738] console [tty0] enabled
[ 0.000746] bootconsole [tegra_comb_uart0] disabled
[ 0.000759] kmemleak: Kernel memory leak detector disabled
[ 0.000777] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.000792] pid_max: default: 32768 minimum: 301
[ 0.001914] Security Framework initialized
[ 0.002525] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002535] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.004169] ftrace: allocating 47208 entries in 185 pages
[ 0.405869] sched-energy: Sched-energy-costs installed from DT
[ 0.405887] ASID allocator initialised with 65536 entries
[ 0.440916] tegra-id: chipid=21917.
[ 0.440927] tegra-id: opt_subrevision=1.
[ 0.440955] Tegra Revision: A02p SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.440986] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.440997] DTB Build time: Feb 19 2021 08:44:25
[ 0.488832] CPU1: Booted secondary processor [4e0f0040]
[ 0.520976] CPU2: Booted secondary processor [4e0f0040]
[ 0.553122] CPU3: Booted secondary processor [4e0f0040]
[ 0.585287] CPU4: Booted secondary processor [4e0f0040]
[ 0.617334] CPU5: Booted secondary processor [4e0f0040]
[ 0.617551] Brought up 6 CPUs
[ 0.617588] SMP: Total of 6 processors activated.
[ 0.617610] CPU features: detected feature: Privileged Access Never
[ 0.617619] CPU features: detected feature: LSE atomic instructions
[ 0.617628] CPU features: detected feature: User Access Override
[ 0.617636] CPU features: detected feature: 32-bit EL0 Support
[ 0.619040] CPU: All CPU(s) started at EL2
[ 0.619118] alternatives: patching kernel code
[ 0.625638] devtmpfs: initialized
[ 0.666751] Initilizing CustomIPI irq domain
[ 0.667007] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.667021] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.678947] pinctrl core: initialized pinctrl subsystem
[ 0.679153] OS set in device tree is not L4T.
[ 0.679443] regulator-dummy: no parameters
[ 0.679689] Initializing plugin-manager
[ 0.679737] Plugin module not found
[ 0.679774] Plugin-manager status disabled
[ 0.681128] NET: Registered protocol family 16
[ 0.682551] pstore: using zlib compression
[ 0.682570] console [pstore-1] enabled
[ 0.682575] pstore: Registered ramoops as persistent store backend
[ 0.682582] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[ 0.704668] cpuidle: using governor menu
[ 0.705685] bpmp: waiting for handshake
[ 0.705693] bpmp: handshake completed
[ 0.705707] bpmp: synchronizing channels
[ 0.705715] bpmp: channels synchronized
[ 0.705721] bpmp: mail init ok
[ 0.708170] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[ 0.708329] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.708336] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.708343] t19x-arm-smmu 12000000.iommu: stage 1 translation
[ 0.708348] t19x-arm-smmu 12000000.iommu: stage 2 translation
[ 0.708354] t19x-arm-smmu 12000000.iommu: nested translation
[ 0.708363] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.708374] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.708407] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.708414] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.708420] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.711689] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e64000)
[ 0.711712] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.714223] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.715346] tegra_aon_clk_init: ok
[ 0.715355] Registering BPMP clocks…
[ 0.715494] tegra_bpmp_clk_init: clock init ok (400 clks)
[ 0.716084] Serial: AMBA PL011 UART driver
[ 0.716206] tegra_powergate_init: DONE
[ 0.716291] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
[ 0.716302] DTB Build time: Feb 19 2021 08:44:25
[ 0.718968] Tegra reboot handler registered.
[ 0.726893] iommu: Adding device 14160000.pcie to group 0
[ 0.727533] iommu: Adding device 141a0000.pcie to group 1
[ 0.728919] iommu: Adding device 2490000.ether_qos to group 2
[ 0.729450] iommu: Adding device 3100000.serial to group 3
[ 0.729895] iommu: Adding device 3110000.serial to group 4
[ 0.730349] iommu: Adding device 3140000.serial to group 5
[ 0.730933] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.731169] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.731192] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.731200] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.731207] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.731257] tegra-pmc: PMC Prod config success
[ 0.731463] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.731475] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.731783] iommu: Adding device 3460000.sdhci to group 6
[ 0.732323] iommu: Adding device 3210000.spi to group 7
[ 0.732883] iommu: Adding device 3230000.spi to group 8
[ 0.733610] iommu: Adding device 3270000.spi to group 9
[ 0.734770] iommu: Adding device 3160000.i2c to group 10
[ 0.735165] iommu: Adding device c240000.i2c to group 11
[ 0.735553] iommu: Adding device 3180000.i2c to group 12
[ 0.735968] iommu: Adding device 3190000.i2c to group 13
[ 0.736479] iommu: Adding device 31b0000.i2c to group 14
[ 0.736893] iommu: Adding device 31c0000.i2c to group 15
[ 0.737337] iommu: Adding device c250000.i2c to group 16
[ 0.737718] iommu: Adding device 31e0000.i2c to group 17
[ 0.738293] iommu: Adding device sound to group 18
[ 0.738819] iommu: Adding device 3510000.hda to group 19
[ 0.739351] iommu: Adding device bc00000.rtcpu to group 20
[ 0.741426] iommu: Adding device 13e10000.host1x to group 21
[ 0.741855] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.742225] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.742585] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.742980] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.743397] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.743760] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.744159] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.744511] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.745080] iommu: Adding device 15340000.vic to group 30
[ 0.745454] iommu: Adding device 15380000.nvjpg to group 31
[ 0.745777] iommu: Adding device 15500000.tsec to group 32
[ 0.746052] iommu: Adding device 15100000.tsecb to group 33
[ 0.746327] iommu: Adding device 15480000.nvdec to group 34
[ 0.746587] iommu: Adding device 15140000.nvdec1 to group 35
[ 0.746854] iommu: Adding device 154c0000.nvenc to group 36
[ 0.747110] iommu: Adding device 15a80000.nvenc1 to group 37
[ 0.747536] iommu: Adding device 15880000.nvdla0 to group 38
[ 0.747980] iommu: Adding device 158c0000.nvdla1 to group 39
[ 0.748558] iommu: Adding device 15200000.nvdisplay to group 40
[ 0.748721] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a0000(800000)
[ 0.748732] platform 15200000.nvdisplay: IOVA linear map 0x00000000a069a000(3000)
[ 0.752689] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.752765] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[ 0.753483] iommu: Adding device 15210000.nvdisplay to group 41
[ 0.753540] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[ 0.755244] iommu: Adding device 15c10000.vi to group 42
[ 0.755388] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[ 0.755806] iommu: Adding device 14800000.isp to group 43
[ 0.756738] iommu: Adding device 16000000.pva0 to group 44
[ 0.757268] iommu: Adding device 16800000.pva1 to group 45
[ 0.757630] iommu: Adding device 15810000.se to group 46
[ 0.758031] iommu: Adding device 15820000.se to group 47
[ 0.758309] iommu: Adding device 15830000.se to group 48
[ 0.758593] iommu: Adding device 15840000.se to group 49
[ 0.758880] iommu: Adding device c1a0000.aon to group 50
[ 0.760507] iommu: Adding device d000000.bpmp to group 51
[ 0.760856] bpmp: ping status is 0
[ 0.760997] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[ 0.764131] bpmp d000000.bpmp: probe ok
[ 0.766630] tegra-reset 0.bpmp_reset: registered 190 resets.
[ 0.767171] iommu: Adding device smmu_test to group 52
[ 0.768399] mc: mapped MMIO address: 0xffffff800a590000 → 0x2c10000
[ 0.768424] mc: mapped MMIO address: 0xffffff800a5b0000 → 0x2c20000
[ 0.768446] mc: mapped MMIO address: 0xffffff800a5d0000 → 0x2c30000
[ 0.768475] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c40000
[ 0.768496] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c50000
[ 0.768521] mc: mapped MMIO address: 0xffffff800b010000 → 0x2b80000
[ 0.768540] mc: mapped MMIO address: 0xffffff800b030000 → 0x2b90000
[ 0.768559] mc: mapped MMIO address: 0xffffff800b050000 → 0x2ba0000
[ 0.768578] mc: mapped MMIO address: 0xffffff800b070000 → 0x2bb0000
[ 0.768599] mc: mapped MMIO address: 0xffffff800b090000 → 0x1700000
[ 0.768618] mc: mapped MMIO address: 0xffffff800b0b0000 → 0x1710000
[ 0.768637] mc: mapped MMIO address: 0xffffff800b0d0000 → 0x1720000
[ 0.768655] mc: mapped MMIO address: 0xffffff800b0f0000 → 0x1730000
[ 0.768674] mc: mapped MMIO address: 0xffffff800b110000 → 0x1740000
[ 0.768693] mc: mapped MMIO address: 0xffffff800b130000 → 0x1750000
[ 0.768711] mc: mapped MMIO address: 0xffffff800b150000 → 0x1760000
[ 0.768743] mc: mapped MMIO address: 0xffffff800b170000 → 0x1770000
[ 0.768823] mc-err: mcerr ops are set to t19x
[ 0.774898] iommu: Adding device 2600000.dma to group 53
[ 0.780975] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 224 lines on the chip
[ 0.782164] GPIO line 339 (wifi-enable) hogged as output/high
[ 0.782220] GPIO line 412 (camera-control-output-low) hogged as output/low
[ 0.782259] GPIO line 413 (camera-control-output-low) hogged as output/low
[ 0.782594] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.792021] gpio gpiochip1: gpio-line-names specifies 21 line names but there are 40 lines on the chip
[ 0.792126] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[ 0.792163] GPIO line 266 (w-disable1) hogged as output/high
[ 0.792198] GPIO line 264 (w-disable2) hogged as output/high
[ 0.792235] GPIO line 265 (suspend-led-gpio) hogged as output/high
[ 0.792573] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[ 0.795084] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.795097] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.795108] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.796053] iommu: Adding device 3550000.xudc to group 54
[ 0.796812] iommu: Adding device 3610000.xhci to group 55
[ 0.798993] arm64_ras arm64_ras: probed
[ 0.799394] ras_fhi_enable: FHI 469 enabled on CPU0
[ 0.799466] ras_fhi_enable: FHI 470 enabled on CPU1
[ 0.799571] ras_fhi_enable: FHI 471 enabled on CPU2
[ 0.799650] ras_fhi_enable: FHI 472 enabled on CPU3
[ 0.799721] ras_fhi_enable: FHI 473 enabled on CPU4
[ 0.799776] ras_fhi_enable: FHI 474 enabled on CPU5
[ 0.799983] carmel_ras_enable: RAS enabled on cpu0
[ 0.800184] carmel_ras_enable: RAS enabled on cpu1
[ 0.800388] carmel_ras_enable: RAS enabled on cpu2
[ 0.800616] carmel_ras_enable: RAS enabled on cpu3
[ 0.800813] carmel_ras_enable: RAS enabled on cpu4
[ 0.801011] carmel_ras_enable: RAS enabled on cpu5
[ 0.801094] carmel_ras carmel_ras: probed
[ 0.802194] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
[ 0.802774] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
[ 0.803673] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
[ 0.804692] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
[ 0.805501] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
[ 0.805867] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[ 0.807171] vdd-ac-bat: 5000 mV
[ 0.807660] vdd-sdmmc1-sw: 3300 mV
[ 0.808016] vdd-1v8-sd: 1800 mV
[ 0.808356] vdd-3v3-cvb: 3300 mV
[ 0.808693] vdd-1v8-cvb: 1800 mV
[ 0.809074] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.809111] vdd-epb-1v0: 1000 mV
[ 0.809488] avdd-cam-2v8: 2800 mV
[ 0.809847] vdd-fan: 5000 mV
[ 0.810156] vdd-hdmi-5v0: 5000 mV
[ 0.810466] vdd_sys_en: 1200 mV
[ 0.853406] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.858054] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.858372] SCSI subsystem initialized
[ 0.858633] libata version 3.00 loaded.
[ 0.858980] usbcore: registered new interface driver usbfs
[ 0.859047] usbcore: registered new interface driver hub
[ 0.859148] usbcore: registered new device driver usb
[ 0.869706] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[ 0.872568] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 0.880880] vdd-1v0: at 1000 mV
[ 0.884842] vdd-1v8-hs: at 1800 mV
[ 0.888883] vdd-1v8-ls: at 1800 mV
[ 0.892891] vdd-1v8-ao: at 1800 mV
[ 0.896937] vddio-ddr-1v1: at 1100 mV
[ 0.900691] vdd-rtc: at 800 mV
[ 0.901674] spmic-ldo1: at 2375 mV
[ 0.908747] vdd-ao-3v3: at 3300 mV
[ 0.916764] vddio-emmc-3v3: at 3300 mV
[ 0.917862] spmic-ldo4: at 1587 mV
[ 0.924801] vdd-usb-3v3: at 3300 mV
[ 0.932840] vddio-sdmmc1-3v3: at 3300 mV
[ 0.936855] vdd-csi-1v2: at 1200 mV
[ 0.937834] spmic-ldo8: at 1800 mV
[ 0.942002] GPIO line 246 (gpio_default) hogged as output/high
[ 0.942959] GPIO line 247 (gpio_default) hogged as output/high
[ 0.943284] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[ 0.943661] max77620 4-003c: max77620 probe successful
[ 0.944076] media: Linux media interface: v0.10
[ 0.944137] Linux video capture interface: v2.00
[ 0.945412] pps_core: LinuxPPS API ver. 1 registered
[ 0.945419] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.945437] PTP clock support registered
[ 0.945652] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.945881] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.945910] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.948495] trusty trusty: trusty version: Built: 08:40:57 Feb 19 2021
[ 0.948556] trusty trusty: selected api version: 3 (requested 3)
[ 0.949704] Advanced Linux Sound Architecture Driver Initialized.
[ 0.950270] Bluetooth: Core ver 2.22
[ 0.950308] NET: Registered protocol family 31
[ 0.950314] Bluetooth: HCI device and connection manager initialized
[ 0.950324] Bluetooth: HCI socket layer initialized
[ 0.950358] Bluetooth: L2CAP socket layer initialized
[ 0.950383] Bluetooth: SCO socket layer initialized
[ 0.952883] camchar: rtcpu character device driver loaded
[ 0.953557] gpio tegra-gpio wake61 for gpio=201(Z:1)
[ 0.953655] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[ 0.955496] clocksource: Switched to clocksource arch_sys_counter
[ 1.006183] VFS: Disk quotas dquot_6.6.0
[ 1.006283] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.006671] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.007949] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[ 1.007995] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 1.008211] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 1.008218] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 1.008230] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[ 1.008237] nvmap_page_pool_init: Total RAM pages: 1984067
[ 1.008244] nvmap_page_pool_init: nvmap page pool size: 248008 pages (968 MB)
[ 1.008405] nvmap_background_zero_thread: PP zeroing thread starting.
[ 1.008848] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 1.011138] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 1.024365] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 1.024633] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 1.024886] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[ 1.025101] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[ 1.025328] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 1.026569] la/ptsa driver initialized.
[ 1.026961] NET: Registered protocol family 2
[ 1.028085] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.028437] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.029034] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.029074] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.029189] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.029675] NET: Registered protocol family 1
[ 1.030294] RPC: Registered named UNIX socket transport module.
[ 1.030300] RPC: Registered udp transport module.
[ 1.030306] RPC: Registered tcp transport module.
[ 1.030311] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.030321] PCI: CLS 0 bytes, default 64
[ 1.030544] Trying to unpack rootfs image as initramfs…
[ 1.261567] Freeing initrd memory: 7064K
[ 1.284286] host1x 13e10000.host1x: initialized
[ 1.285970] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.290348] audit: initializing netlink subsys (disabled)
[ 1.290389] audit: type=2000 audit(0.904:1): initialized
[ 1.291115] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.301202] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.302593] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.303234] 9p: Installing v9fs 9p2000 file system support
[ 1.308745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.308921] io scheduler noop registered
[ 1.309147] io scheduler cfq registered (default)
[ 1.312909] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 1.314022] random: fast init done
[ 1.347896] iommu: Adding device 2993000.adsp to group 56
[ 1.459595] iommu: Adding device aconnect@2a41000:adsp_audio to group 57
[ 1.460534] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.473981] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.474398] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.475101] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.475528] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.475957] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.479401] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.479713] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.482638] tsec 15500000.tsec: initialized
[ 1.484526] tsec 15100000.tsecb: initialized
[ 1.488563] nvdec 15480000.nvdec: initialized
[ 1.491316] nvdec 15140000.nvdec1: initialized
[ 1.496995] falcon 15340000.vic: initialized
[ 1.499095] falcon 15380000.nvjpg: initialized
[ 1.500962] falcon 154c0000.nvenc: initialized
[ 1.502700] falcon 15a80000.nvenc1: initialized
[ 1.506083] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.507726] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.509461] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.511196] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.512921] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.514587] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.516200] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.517691] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.521486] t194-nvcsi 15a00000.nvcsi: initialized
[ 1.526777] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 1.527187] scare-pigeon 14b00000.isp-thi: initialized
[ 1.532801] pva 16000000.pva0: initialized
[ 1.538791] pva 16800000.pva1: initialized
[ 1.543951] nvdla 15880000.nvdla0: initialized
[ 1.548666] nvdla 158c0000.nvdla1: initialized
[ 1.549911] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.549925] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.549954] tegradccommon 15200000.dc_common: dma mapping done
[ 1.550958] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor1
[ 1.550986] generic_infoframe_type: 0x87
[ 1.551048] tegradc 15200000.nvdisplay: DT parsed successfully
[ 1.551124] tegradc 15200000.nvdisplay: Display dc.ffffff800bd10000 registered with id=0
[ 1.554822] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 7088400 KB/s
[ 1.554829] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 800000000 Hz
[ 1.554836] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.555054] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[ 1.555064] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[ 1.555882] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 1.558208] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.558216] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.561477] tegradc 15200000.nvdisplay: probed
[ 1.599142] Console: switching to colour frame buffer device 240x67
[ 1.599279] tegradc 15200000.nvdisplay: fb registered
[ 1.599672] gpio tegra-gpio wake63 for gpio=97(M:1)
[ 1.600221] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.600308] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.602404] Parent Clock set for DC plld2
[ 1.654390] tegradc 15200000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 1.655038] tegradc 15200000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 1.655053] tegradc 15200000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 1.680691] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.680698] Extcon AUX1(HDMI) enable
[ 1.681161] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
[ 1.681191] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[ 1.681262] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.681325] tegradc 15210000.nvdisplay: Display dc.ffffff800be10000 registered with id=1
[ 1.681544] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
[ 1.681555] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
[ 1.689721] tegradc 15210000.nvdisplay: probed
[ 1.690063] tegradc 15210000.nvdisplay: fb registered
[ 1.693413] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.693424] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.693436] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.693452] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.693467] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.693473] Extcon DP: HPD disabled
[ 1.693478] hpd: hpd_switch 0
[ 1.693484] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.693495] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.693504] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.693794] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=77
[ 1.693805] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.694092] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.694213] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.694351] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.694359] tegra_cec 3960000.tegra_cec: probed
[ 1.703823] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.704484] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.704493] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.704854] kfuse 3830000.kfuse: initialized
[ 1.710663] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.713273] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.714380] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.715191] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.716235] console [ttyTCU0] enabled
[ 1.716476] [drm] Initialized
[ 1.727801] brd: module loaded
[ 1.732919] loop: module loaded
[ 1.733035] tegra_profiler: version: 1.143, samples/io: 48/28
[ 1.733146] tegra_profiler: auth: init
[ 1.733701] THERMAL EST: found 3 subdevs
[ 1.733708] THERMAL EST num_resources: 0
[ 1.733714] [THERMAL EST subdev 0]
[ 1.733760] [THERMAL EST subdev 1]
[ 1.733775] [THERMAL EST subdev 2]
[ 1.733796] THERMAL EST: Found 2 profiles, default profile is quiet
[ 1.734126] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 1.734131] THERMAL EST: thz register success.
[ 1.734265] THERMAL EST: end of probe, return err: 0
[ 1.734835] sd: No Scsi addr parsed to reserve index
[ 1.734864] hisi_sas: driver version v1.6
[ 1.744866] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 1.744875] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 1.744885] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 1.745092] 1 ofpart partitions found on MTD device spi6.0
[ 1.745098] Creating 1 MTD partitions on “spi6.0”:
[ 1.745116] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 1.747426] libphy: Fixed MDIO Bus: probed
[ 1.748251] tun: Universal TUN/TAP device driver, 1.6
[ 1.748256] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.749011] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.749017] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.749067] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.749072] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.749117] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.749121] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.749165] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.749169] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.818763] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.854787] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.854791] Extcon AUX1(HDMI) disable
[ 1.881202] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.882354] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.902986] tegradc 15200000.nvdisplay: unblank
[ 1.904488] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.904780] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.913365] Parent Clock set for DC plld2
[ 1.917864] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[ 1.919256] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.953864] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.953868] Extcon AUX1(HDMI) enable
[ 1.969594] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 1.991482] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 1.991488] Extcon HDMI: HPD enabled
[ 1.991512] tegradc 15200000.nvdisplay: hdmi: plugged
[ 1.994785] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.995393] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5 c5 d2
[ 1.995572] libphy: dwc_phy: probed
[ 1.998001] PPP generic driver version 2.4.2
[ 1.998391] PPP BSD Compression module registered
[ 1.998423] PPP Deflate Compression module registered
[ 1.998441] PPP MPPE Compression module registered
[ 1.998448] NET: Registered protocol family 24
[ 1.998516] usbcore: registered new interface driver r8152
[ 1.998550] usbcore: registered new interface driver asix
[ 1.998609] usbcore: registered new interface driver ax88179_178a
[ 1.998636] usbcore: registered new interface driver cdc_ether
[ 1.998662] usbcore: registered new interface driver net1080
[ 1.998691] usbcore: registered new interface driver cdc_subset
[ 1.998740] usbcore: registered new interface driver zaurus
[ 1.998785] usbcore: registered new interface driver cdc_ncm
[ 1.999248] VFIO - User Level meta-driver version: 0.3
[ 2.000438] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.000456] ehci-pci: EHCI PCI platform driver
[ 2.000487] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.000496] ohci-pci: OHCI PCI platform driver
[ 2.000528] ohci-platform: OHCI generic platform driver
[ 2.004984] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 2.007042] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4d96400 id
[ 2.007342] usbcore: registered new interface driver uas
[ 2.007419] usbcore: registered new interface driver usb-storage
[ 2.007521] usbcore: registered new interface driver usbserial
[ 2.010457] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 2.010489] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 2.010507] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 2.011244] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 2.011289] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 2.011628] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.011637] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.011668] usb usb1: Product: xHCI Host Controller
[ 2.011674] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 2.011680] usb usb1: SerialNumber: 3610000.xhci
[ 2.012184] hub 1-0:1.0: USB hub found
[ 2.012310] hub 1-0:1.0: 4 ports detected
[ 2.012399] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 2.012482] tegra-xudc-new 3550000.xudc: device count: 1
[ 2.012754] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 2.012767] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 2.012778] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.012980] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.012987] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.012993] usb usb2: Product: xHCI Host Controller
[ 2.012999] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 2.013005] usb usb2: SerialNumber: 3610000.xhci
[ 2.013423] tegra-xudc-new 3550000.xudc: vbus state: 1
[ 2.013445] tegra-xudc-new 3550000.xudc: device mode on: 0
[ 2.013524] hub 2-0:1.0: USB hub found
[ 2.013567] hub 2-0:1.0: 4 ports detected
[ 2.013698] tegra-xudc-new 3550000.xudc: active: 0 => 1
[ 2.013709] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 2.014474] mousedev: PS/2 mouse device common for all mice
[ 2.014513] Wake76 for irq=199
[ 2.014518] Wake77 for irq=199
[ 2.014522] Wake78 for irq=199
[ 2.014526] Wake79 for irq=199
[ 2.014530] Wake80 for irq=199
[ 2.014534] Wake81 for irq=199
[ 2.014538] Wake82 for irq=199
[ 2.014575] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 2.014582] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 2.014635] usbcore: registered new interface driver xpad
[ 2.115847] usb usb2: usb_suspend_both: status 0
[ 2.115917] usb usb1: usb_suspend_both: status 0
[ 2.146766] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.148290] Wake73 for irq=42
[ 2.149518] rtc rtc1: alarm rtc device
[ 2.149534] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.149558] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.149690] i2c /dev entries driver
[ 2.152118] i2c i2c-2: Added multiplexed i2c bus 9
[ 2.152495] i2c i2c-2: Added multiplexed i2c bus 10
[ 2.152504] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 2.153076] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.176541] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.176593] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.176961] imx219 9-0010: board setup failed
[ 2.177148] imx219: probe of 9-0010 failed with error -121
[ 2.177550] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.200868] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.200919] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.201251] imx219 10-0010: board setup failed
[ 2.201459] imx219: probe of 10-0010 failed with error -121
[ 2.202559] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.209263] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.209597] FAN dev name: pwm-fan
[ 2.209642] FAN:gpio request success.
[ 2.209652] FAN: can’t find tach_gpio
[ 2.209663] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.209698] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.209909] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.209917] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.210526] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.210536] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.210543] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.210550] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.210556] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.210562] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.210568] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.210574] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.210580] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.210587] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.211451] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.212344] device-mapper: uevent: version 1.0.3
[ 2.212830] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 2.216337] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.217529] cpuidle: Initializing cpuidle driver
[ 2.218606] sdhci: Secure Digital Host Controller Interface driver
[ 2.218610] sdhci: Copyright(c) Pierre Ossman
[ 2.218614] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.219847] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.221744] CMDQ: cmdq_platfm_init successful
[ 2.226244] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.227248] tegra-se-nvhost 15810000.se: initialized
[ 2.228235] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.229041] tegra-se-nvhost 15820000.se: initialized
[ 2.230067] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.230667] tegra-se-nvhost 15830000.se: initialized
[ 2.231244] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.232272] tegra-se-nvhost 15840000.se: initialized
[ 2.233183] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.233598] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.235635] usbcore: registered new interface driver usbhid
[ 2.235640] usbhid: USB HID core driver
[ 2.239643] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.240729] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.241160] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.241784] denver_knobs_init:MTS_VERSION:51035886
[ 2.242003] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.242693] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.243054] t19x_cache tegra-cache: probed
[ 2.245843] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.245852] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.246451] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.246876] PLL_AON clock registered
[ 2.248281] Clocks initialized successfully
[ 2.249867] nvpmodel: initialized successfully
[ 2.251004] trusty-virtio trusty:virtio: initializing
[ 2.251226] trusty_ipc virtio0: vring0: va¶ ffffffc1e270c000(0) qsz 32 notifyid 1
[ 2.251236] trusty_ipc virtio0: vring1: va¶ ffffffc1e270e000(0) qsz 32 notifyid 2
[ 2.251395] trusty-virtio trusty:virtio: initializing done
[ 2.251746] trusty_ipc virtio0: is online
[ 2.252268] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.252739] usbcore: registered new interface driver snd-usb-audio
[ 2.263512] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.282275] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.282505] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.282674] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.282838] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.309818] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.322316] mmc0: periodic cache flush enabled
[ 2.322329] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.322910] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 2.323141] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 2.323371] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 2.323616] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 2.326100] OPE platform probe
[ 2.326253] OPE platform probe successful
[ 2.328511] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.400626] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.400756] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.400867] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.400969] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.401078] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.401188] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.401321] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.401464] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.401593] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.401704] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.401811] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.401924] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.402031] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.402137] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.402248] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.402361] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.402518] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.402609] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.402725] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.402835] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.431591] u32 classifier
[ 2.431618] Actions configured
[ 2.431767] Initializing XFRM netlink socket
[ 2.432314] NET: Registered protocol family 10
[ 2.433057] NET: Registered protocol family 17
[ 2.433077] NET: Registered protocol family 15
[ 2.433121] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.433226] Bluetooth: RFCOMM socket layer initialized
[ 2.433245] Bluetooth: RFCOMM ver 1.11
[ 2.433252] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.433267] Bluetooth: HIDP socket layer initialized
[ 2.433290] 9pnet: Installing 9P2000 support
[ 2.433330] Key type dns_resolver registered
[ 2.433609] Registered cp15_barrier emulation handler
[ 2.433633] Registered setend emulation handler
[ 2.435050] registered taskstats version 1
[ 2.435543] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.436683] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.436701] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.436709] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.436714] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.715540] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.780127] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.780134] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.951767] tegra-pcie-dw 14160000.pcie: link is down
[ 2.951948] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.951957] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.951966] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.951972] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.951977] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.952005] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.952196] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.952400] iommu: Adding device 0004:00:00.0 to group 58
[ 2.952675] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.952704] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 2.952897] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.952904] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.952987] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.953155] pcie_pme 0004:00:00.0:pcie001: unloading service driver pcie_pme
[ 2.953244] aer 0004:00:00.0:pcie002: unloading service driver aer
[ 2.953385] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 2.953531] iommu: Removing device 0004:00:00.0 from group 58
[ 2.953597] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 2.955122] tegra-pcie-dw 14160000.pcie: PCIe link is not up…!
[ 2.956217] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.957336] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.957355] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.957363] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.957369] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 3.067532] tegra-pcie-dw 141a0000.pcie: link is up
[ 3.067818] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 3.067827] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 3.067836] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 3.067863] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 3.067867] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 3.067891] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 3.068035] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 3.068227] iommu: Adding device 0005:00:00.0 to group 58
[ 3.068576] pci 0005:01:00.0: [126f:2263] type 00 class 0x010802
[ 3.068692] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 3.069553] iommu: Adding device 0005:01:00.0 to group 59
[ 3.080328] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 3.080336] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 3.080415] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 3.080423] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 3.080439] pci 0005:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 3.080482] pci 0005:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 3.080717] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.080723] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.080728] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 3.080817] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 3.081214] nvme nvme0: pci function 0005:01:00.0
[ 3.081256] nvme 0005:01:00.0: enabling device (0000 → 0002)
[ 3.090881] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 3.095332] tegra194-isp5 14800000.isp: initialized
[ 3.102486] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 3.108366] tegra194-vi5 15c10000.vi: initialized
[ 3.112770] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 3.112850] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 3.113089] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 3.117371] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 3.117387] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 3.117392] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 3.117467] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 3.117498] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 3.117502] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 3.121430] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 3.121490] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 3.121496] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 3.121794] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 3.121822] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 3.121826] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 3.122338] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 3.122372] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 3.122377] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 3.122655] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 3.123420] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.205834] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 3.206260] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.206570] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 3.206851] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 3.207206] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 3.207304] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 3.207589] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 3.207593] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.208747] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=cf2bef3ad10e437272857b76308abef8ffb80bda
[ 3.209382] Wake83 for irq=211
[ 3.209453] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 3.209591] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 3.209772] input: gpio-keys as /devices/gpio-keys/input/input4
[ 3.211527] nvme0n1: p1
[ 3.240523] tegra_rtc c2a0000.rtc: setting system clock to 2021-05-06 01:55:57 UTC (1620266157)
[ 3.241026] mmcblk mmc0:0001: Card claimed for testing.
[ 3.274449] bpmp: mounted debugfs mirror
[ 3.280806] ALSA device list:
[ 3.280813] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 3.280816] #1: jetson-xaviernx-ape
[ 3.282250] Freeing unused kernel memory: 8576K
[ 3.321578] Root device found: mmcblk0p1
[ 3.323516] Found dev node: /dev/mmcblk0p1
[ 3.346296] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 3.348890] Rootfs mounted over mmcblk0p1
[ 3.368747] Switching from initrd to actual rootfs
[ 3.490336] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.493499] cgroup: cgroup2: unknown option “nsdelegate”
[ 3.503029] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.503748] systemd[1]: Detected architecture arm64.
[ 3.509416] systemd[1]: Set hostname to .
[ 3.588232] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.588245] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.732047] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.732448] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.732565] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.732587] systemd[1]: Reached target Swap.
[ 3.732626] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.732773] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.735326] systemd[1]: Created slice User and Session Slice.
[ 3.736556] systemd[1]: Created slice System Slice.
[ 3.783763] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 3.826327] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 3.838541] cpu-throttle-alert cooling device registered.
[ 3.838922] gpu-throttle-alert cooling device registered.
[ 3.839268] aux-throttle-alert cooling device registered.
[ 4.063596] systemd-journald[2348]: Received request to flush runtime journal from PID 1
[ 4.187790] tegra-xusb 3610000.xhci: entering ELPG
[ 4.190633] tegra-xusb 3610000.xhci: entering ELPG done
[ 4.968167] random: crng init done
[ 4.968335] random: 7 urandom warning(s) missed due to ratelimiting
[ 5.048157] using random self ethernet address
[ 5.048328] using random host ethernet address
[ 5.085227] FAN rising trip_level:1 cur_temp:46900 trip_temps[2]:60000
[ 5.693608] Mass Storage Function, version: 2009/09/11
[ 5.693621] LUN: removable file: (no medium)
[ 5.700971] using random self ethernet address
[ 5.701129] using random host ethernet address
[ 5.729510] rndis0: HOST MAC da:79:1c:2d:6d:94
[ 5.729601] rndis0: MAC da:79:1c:2d:6d:95
[ 5.731168] usb0: HOST MAC da:79:1c:2d:6d:96
[ 5.731205] usb0: MAC da:79:1c:2d:6d:97
[ 5.731237] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 5.738258] l4tbr0: port 1(rndis0) entered blocking state
[ 5.738268] l4tbr0: port 1(rndis0) entered disabled state
[ 5.741010] device rndis0 entered promiscuous mode
[ 5.751143] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 5.755843] l4tbr0: port 2(usb0) entered blocking state
[ 5.755850] l4tbr0: port 2(usb0) entered disabled state
[ 5.756426] device usb0 entered promiscuous mode
[ 5.766314] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.887522] android_work: did not send uevent (0 0 (null))
[ 5.920861] android_work: sent uevent USB_STATE=CONNECTED
[ 5.956128] ras_fhi_disable: FHI 473 disabled
[ 5.956659] CPU4: shutdown
[ 5.956803] psci: CPU4 killed.
[ 5.997383] ras_fhi_disable: FHI 474 disabled
[ 6.003217] CPU5: shutdown
[ 6.023625] psci: Retrying again to check for CPU kill
[ 6.023644] psci: CPU5 killed.
[ 6.028313] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
[ 6.128817] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.279611] zram: Added device: zram0
[ 6.284073] zram: Added device: zram1
[ 6.287851] zram: Added device: zram2
[ 6.291962] zram: Added device: zram3
[ 6.317598] zram0: detected capacity change from 0 to 1017843712
[ 6.368961] Adding 993984k swap on /dev/zram0. Priority:5 extents:1 across:993984k SS
[ 6.373799] zram1: detected capacity change from 0 to 1017843712
[ 6.390927] Adding 993984k swap on /dev/zram1. Priority:5 extents:1 across:993984k SS
[ 6.399126] zram2: detected capacity change from 0 to 1017843712
[ 6.420926] Adding 993984k swap on /dev/zram2. Priority:5 extents:1 across:993984k SS
[ 6.425271] zram3: detected capacity change from 0 to 1017843712
[ 6.441178] gpio tegra-gpio wake20 for gpio=52(G:4)
[ 6.455708] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.465672] Adding 993984k swap on /dev/zram3. Priority:5 extents:1 across:993984k SS
[ 7.562702] tegradc 15200000.nvdisplay: unblank
[ 7.562715] tegradc 15210000.nvdisplay: blank - powerdown
[ 8.829299] fuse init (API version 7.26)
[ 9.392503] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ 9.393113] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.849953] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.849970] Bluetooth: BNEP socket layer initialized
[ 13.546244] tegradc 15200000.nvdisplay: unblank
[ 13.546257] tegradc 15210000.nvdisplay: blank - powerdown
[ 34.139659] vdd-sdmmc1-sw: disabling
[ 34.139668] vdd-1v8-sd: disabling
[ 34.139675] vdd-1v8-cvb: disabling
[ 34.139679] vdd-epb-1v0: disabling
[ 34.139684] avdd-cam-2v8: disabling
[ 34.139689] vdd_sys_en: disabling
[ 36.025058] android_work: sent uevent USB_STATE=DISCONNECTED
[ 36.058196] android_work: sent uevent USB_STATE=CONNECTED
[ 36.083058] configfs-gadget gadget: high-speed config #1: c
[ 36.083092] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 36.083105] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 36.083117] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 36.083204] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 36.083216] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 36.083227] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 36.083392] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 36.083414] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 36.083433] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 36.083585] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[ 36.083796] android_work: sent uevent USB_STATE=CONFIGURED
[ 38.400354] l4tbr0: port 1(rndis0) entered blocking state
[ 38.400361] l4tbr0: port 1(rndis0) entered forwarding state
[ 38.400497] IPv6: ADDRCONF(NETDEV_UP): l4tbr0: link is not ready
[ 38.400513] IPv6: ADDRCONF(NETDEV_CHANGE): l4tbr0: link becomes ready
[ 922.714087] tegradc 15200000.nvdisplay: blank - powerdown
[ 922.766275] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 922.766280] Extcon AUX1(HDMI) disable
[ 922.792045] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 922.793438] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 2018.538614] tegradc 15200000.nvdisplay: unblank
[ 2018.539843] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 2018.540181] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 2018.541989] Parent Clock set for DC plld2
[ 2018.546681] tegradc 15200000.nvdisplay: hdmi: tmds rate:85500K prod-setting:prod_c_hdmi_54m_111m
[ 2018.548227] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 2018.584972] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 2018.584976] Extcon AUX1(HDMI) enable
[ 2018.602522] tegradc 15200000.nvdisplay: unblank
[ 2018.602536] tegradc 15210000.nvdisplay: blank - powerdown
[ 2211.456363] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 2239.428083] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[END] 2021/5/6 10:46:12
