No usb after boot
I am porting a Jetson 3.3 project to 4.2.
After booting I see ubuntu screen with System Configuration box. But usb mouse or keyboard does not work.
Please can you help me?
[code][ 0.450656] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.451700] iommu: Adding device 3530000.xhci to group 44
[ 0.451723] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.452149] iommu: Adding device 3550000.xudc to group 45
[ 0.452172] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.452873] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.452891] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.453470] iommu: Adding device 17000000.gp10b to group 46
[ 0.454464] tegra-reset 5000000.clock: registered 193 resets.
[ 0.456542] iommu: Adding device d000000.bpmp to group 47
[ 0.456758] bpmp: ping status is 0
[ 0.456858] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.460138] bpmp d000000.bpmp: probe ok
[ 0.465581] iommu: Adding device 2600000.dma to group 48
[ 0.467378] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.467443] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.467499] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.467936] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.474716] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.475065] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.477582] iommu: Adding device 10003000.pcie-controller to group 49
[ 0.477640] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.478231] iommu: Adding device sound to group 50
[ 0.478677] iommu: Adding device 3510000.hda to group 51
[ 0.490167] iommu: Adding device c1a0000.aon to group 52
[ 0.490849] vdd-ac-bat: 5000 mV
[ 0.493306] vdd-1v8-ap: 1800 mV
[ 0.517518] random: fast init done
[ 0.526834] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.532214] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.532712] SCSI subsystem initialized
[ 0.533170] usbcore: registered new interface driver usbfs
[ 0.533244] usbcore: registered new interface driver hub
[ 0.533380] usbcore: registered new device driver usb
[ 0.536948] GPIO line 241 (touch-rails) hogged as output/high
[ 0.537231] GPIO line 242 (touch-rails) hogged as output/high
[ 0.537524] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.538628] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.538900] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.550569] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.558028] vddio-ddr: at 1125 mV
[ 0.561868] avdd_dsi_csi: 1200 mV
[ 0.565879] vdd-1v8: 1800 mV
[ 0.569900] vdd-3v3-sys: 3300 mV
[ 0.571362] spmic-ldo0: at 1800 mV
[ 0.572373] spmic-ldo1: at 800 mV
[ 0.577896] vddio-3v3: 3300 mV
[ 0.578772] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.581877] vdd-rtc: at 800 mV
[ 0.582867] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.585872] spmic-ldo6: at 1500 mV
[ 0.589876] vdd-pex-1v00: 1000 mV
[ 0.590643] dvdd-pex: 1000 mV
[ 0.591288] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.591518] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.591912] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.594243] max77620 4-003c: max77620 probe successful
[ 0.594811] media: Linux media interface: v0.10
[ 0.594903] Linux video capture interface: v2.00
[ 0.597949] pps_core: LinuxPPS API ver. 1 registered
[ 0.597991] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.598054] PTP clock support registered
[ 0.598637] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.598721] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.601423] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[ 0.605925] Advanced Linux Sound Architecture Driver Initialized.
[ 0.606626] Bluetooth: Core ver 2.22
[ 0.606755] NET: Registered protocol family 31
[ 0.606785] Bluetooth: HCI device and connection manager initialized
[ 0.606821] Bluetooth: HCI socket layer initialized
[ 0.606851] Bluetooth: L2CAP socket layer initialized
[ 0.606896] Bluetooth: SCO socket layer initialized
[ 0.607934] en-vdd-sd: 3300 mV
[ 0.608734] en-vdd-cam: 1800 mV
[ 0.613872] vdd-hdmi: 5000 mV
[ 0.614355] vdd-usb0-5v: 5000 mV
[ 0.614722] vdd-usb1-5v: 5000 mV
[ 0.617869] en-vdd-ts-1v8: 1800 mV
[ 0.621885] en-vdd-ts-hv-3v3: 3300 mV
[ 0.622550] en-vdd-disp-3v3: 3300 mV
[ 0.623135] en-mdm-pwr-3v7: 3700 mV
[ 0.623723] en-vdd-disp-1v8: 1800 mV
[ 0.624357] en-vdd-cam-hv-2v8: 2800 mV
[ 0.624924] en-vdd-cam-1v2: 1200 mV
[ 0.625530] vdd-fan: 5000 mV
[ 0.625876] vdd-3v3: 3300 mV
[ 0.626627] dis-vdd-1v2: 1200 mV
[ 0.627010] en-vdd-vcm-2v8: 2800 mV
[ 0.627653] vdd-usb2-5v: 5000 mV
[ 0.628044] vdd-sys-bl: 3300 mV
[ 0.628724] en-vdd-sys: 1200 mV
[ 0.631797] camchar: rtcpu character device driver loaded
[ 0.632455] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.634523] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.635508] clocksource: Switched to clocksource arch_sys_counter
[ 0.674979] VFS: Disk quotas dquot_6.6.0
[ 0.675301] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.675951] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.676945] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.676985] nvmap_page_pool_init: Total RAM pages: 2008258
[ 0.677015] nvmap_page_pool_init: nvmap page pool size: 251032 pages (980 MB)
[ 0.677214] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.681044] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.692917] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.693137] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.693612] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.693736] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.693894] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.694055] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.694262] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.694556] la/ptsa driver initialized.
[ 0.694585] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.694607] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.695802] NET: Registered protocol family 2
[ 0.697805] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.698409] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.699206] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.699277] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.699419] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.700369] NET: Registered protocol family 1
[ 0.701517] RPC: Registered named UNIX socket transport module.
[ 0.701545] RPC: Registered udp transport module.
[ 0.701566] RPC: Registered tcp transport module.
[ 0.701585] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.701884] Trying to unpack rootfs image as initramfs…
[ 0.721890] host1x 13e10000.host1x: initialized
[ 0.723305] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.727673] audit: initializing netlink subsys (disabled)
[ 0.727746] audit: type=2000 audit(0.616:1): initialized
[ 0.728424] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.740059] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.742689] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.744534] 9p: Installing v9fs 9p2000 file system support
[ 0.750707] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.750884] io scheduler noop registered
[ 0.751553] io scheduler cfq registered (default)
[ 0.756491] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.817941] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[ 0.857903] iommu: Adding device 2993000.adsp to group 54
[ 0.859124] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.862659] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.866914] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.868463] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.869846] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.871199] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.874004] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.875148] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.875708] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.876014] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.876193] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=4500000, max_bw=4500000
[ 0.878159] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.879721] tsec 15500000.tsec: initialized
[ 0.880932] tsec 15100000.tsecb: initialized
[ 0.883657] nvdec 15480000.nvdec: initialized
[ 0.888330] falcon 15340000.vic: initialized
[ 0.889982] falcon 154c0000.nvenc: initialized
[ 0.891550] falcon 15380000.nvjpg: initialized
[ 0.895619] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.897304] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.898985] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.900625] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.902298] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.903942] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.905478] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.907078] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.910138] tegradccommon 15200000.dc_common: host1x channel mapped
[ 0.910186] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 0.910241] tegradccommon 15200000.dc_common: dma mapping done
[ 0.912076] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 0.912230] generic_infoframe_type: 0x87
[ 0.912480] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.912568] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
[ 0.922333] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.922386] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.922423] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.922749] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 0.922780] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 0.924442] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.924487] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.925483] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.926236] kfuse 3830000.kfuse: initialized
[ 0.927935] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 0.927974] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 0.928249] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.932257] tegradc 15210000.nvdisplay: probed
[ 0.939992] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.943430] console [ttyS0] disabled
[ 0.943582] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.349627] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.758093] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.166673] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.168713] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.575205] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.982895] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.239918] console [ttyS0] enabled
[ 3.241170] Console: switching to colour frame buffer device 240x67
[ 3.242611] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 3.244646] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.245097] serial-tegra 3130000.serial: RX in PIO mode
[ 3.246087] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.251814] [drm] Initialized
[ 3.282833] brd: module loaded
[ 3.289479] tegradc 15210000.nvdisplay: fb registered
[ 3.291242] loop: module loaded
[ 3.291368] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.291459] tegra_profiler: auth: init
[ 3.291888] nct1008_nct72 7-004c: starting parse dt
[ 3.291990] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 3.291999] nct1008_nct72 7-004c: success parsing dt
[ 3.292095] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.292366] THERMAL EST: found 3 subdevs
[ 3.292370] THERMAL EST num_resources: 0
[ 3.292373] [THERMAL EST subdev 0]
[ 3.292378] [THERMAL EST subdev 1]
[ 3.292381] [THERMAL EST subdev 2]
[ 3.292703] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 3.292705] THERMAL EST: thz register success.
[ 3.292853] THERMAL EST: end of probe, return err: 0
[ 3.293800] hisi_sas: driver version v1.6
[ 3.297823] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.297834] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.303293] scsi host0: tegra_ahci
[ 3.308334] scsi host1: tegra_ahci
[ 3.308513] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 3.308517] ata2: DUMMY
[ 3.314101] libphy: Fixed MDIO Bus: probed
[ 3.314472] tun: Universal TUN/TAP device driver, 1.6
[ 3.314475] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.319155] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.319158] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.319208] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.319210] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.319240] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.319242] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.319294] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.319296] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.320473] eqos 2490000.ether_qos: no PHY interrupt found
[ 3.320746] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 3.324366] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 3.324852] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 3.327763] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c4 e8 17
[ 3.327879] libphy: dwc_phy: probed
[ 3.328287] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.330631] PPP generic driver version 2.4.2
[ 3.330937] PPP BSD Compression module registered
[ 3.330941] PPP Deflate Compression module registered
[ 3.330958] PPP MPPE Compression module registered
[ 3.330962] NET: Registered protocol family 24
[ 3.331015] usbcore: registered new interface driver r8152
[ 3.331042] usbcore: registered new interface driver asix
[ 3.331066] usbcore: registered new interface driver ax88179_178a
[ 3.331086] usbcore: registered new interface driver cdc_ether
[ 3.331111] usbcore: registered new interface driver net1080
[ 3.331131] usbcore: registered new interface driver cdc_subset
[ 3.331152] usbcore: registered new interface driver zaurus
[ 3.331182] usbcore: registered new interface driver cdc_ncm
[ 3.331486] VFIO - User Level meta-driver version: 0.3
[ 3.337230] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.337250] ehci-pci: EHCI PCI platform driver
[ 3.337275] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.337283] ohci-pci: OHCI PCI platform driver
[ 3.337312] ohci-platform: OHCI generic platform driver
[ 3.342250] usbcore: registered new interface driver uas
[ 3.342381] usbcore: registered new interface driver usb-storage
[ 3.342553] usbcore: registered new interface driver usbserial
[ 3.346713] tegra-xudc-new 3550000.xudc: device count: 1
[ 3.348461] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 3.348486] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.350093] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.350258] mousedev: PS/2 mouse device common for all mice
[ 3.350369] usbcore: registered new interface driver xpad
[ 3.357580] nct1008_nct72 7-004c: initial LOC temp: 37000
[ 3.357882] nct1008_nct72 7-004c: initial EXT temp: 50000
[ 3.358480] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 3.358770] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.358947] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.483012] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.484240] Wake73 for irq=42
[ 3.485539] rtc rtc1: alarm rtc device
[ 3.485553] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.485593] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.485800] i2c /dev entries driver
[ 3.488025] pca954x 2-0071: vcc-pullup regulator not found
[ 3.488038] pca954x 2-0071: pca954x_probe: forcing device bus number, start 30.
[ 3.488147] tegra-i2c 3180000.i2c: no acknowledge from address 0x71
[ 3.488180] pca954x 2-0071: probe failed
[ 3.488729] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.492914] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.493455] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.494914] parse_throttle_dt_data: Num cap clks = 4
[ 3.494918] parse_throttle_dt_data: clk=mcpu type=1
[ 3.494921] parse_throttle_dt_data: clk=bcpu type=2
[ 3.494928] parse_throttle_dt_data: clk=gpu type=4
[ 3.494931] parse_throttle_dt_data: clk=emc type=3
[ 3.496151] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.496730] FAN dev name: pwm-fan
[ 3.496790] FAN:gpio request success.
[ 3.496798] FAN: can’t find tach_gpio
[ 3.496831] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.497127] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 3.497132] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.497491] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.497496] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.497525] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.497529] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.497534] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.497537] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.497541] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.497544] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.497549] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.497554] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.499424] device-mapper: uevent: version 1.0.3
[ 3.500913] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.522184] cpufreq: platform driver Initialization: pass
[ 3.526977] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.527093] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.532456] sdhci: Secure Digital Host Controller Interface driver
[ 3.532458] sdhci: Copyright(c) Pierre Ossman
[ 3.532459] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.533978] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.535943] CMDQ: cmdq_platfm_init successful
[ 3.537145] CQE: CMD_TIMING bit set for R1B DCMD
[ 3.539951] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.543736] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.543775] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.544371] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.546036] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[ 3.550773] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.587522] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.587587] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.599593] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.599632] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.620758] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.641907] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.647072] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.647079] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.663807] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 3.665053] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 3.773848] mmc0: periodic cache flush enabled
[ 3.773863] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 3.774558] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.774801] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.774998] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.775218] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.777894] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[ 3.922364] mmc1: Applying tuning correction
[ 3.922391] mmc1: Tap value after applying correction 61
[ 3.922398] mmc1: hw tuning done …
[ 3.929667] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.140914] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 4.146502] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.152603] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.158699] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 4.166268] Parent Clock set for DC plld2
[ 4.225258] tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 4.234782] tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
[ 4.242719] tegradc 15210000.nvdisplay: hdmi: BL set VIC 0
[ 4.248220] tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
[ 4.256777] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.264045] Extcon AUX1(HDMI) enable
[ 4.268820] tegra-se-nvhost 15810000.se: initialized
[ 4.274978] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.282046] tegra-se-nvhost 15820000.se: initialized
[ 4.288206] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.295254] tegra-se-nvhost 15830000.se: initialized
[ 4.300894] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.307861] tegra-se-nvhost 15840000.se: initialized
[ 4.313824] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.320244] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.326916] usbcore: registered new interface driver usbhid
[ 4.332514] usbhid: USB HID core driver
[ 4.342192] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.353215] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 4.361722] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.373849] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 4.384631] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 4.397365] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 4.407820] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.407895] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 4.407966] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 4.408015] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 4.411596] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 4.412143] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 4.412146] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.413021] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 4.414314] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.414875] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.415043] register_ari_mca_banks: Registered MCA ROC:IOB
[ 4.415113] register_ari_mca_banks: Registered MCA ROC:CCE
[ 4.415396] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415399] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 4.415401] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 4.415458] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415460] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 4.415462] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 4.415546] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415548] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 4.415550] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 4.415604] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415607] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 4.415609] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 4.415667] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415670] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 4.415671] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 4.415723] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415727] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 4.415729] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 4.415785] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415790] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 4.415792] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 4.415842] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415847] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 4.415848] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 4.415902] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415907] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 4.415909] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 4.415968] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.415971] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 4.415972] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 4.416023] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.416029] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 4.416030] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 4.416080] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.416086] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 4.416087] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 4.416140] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.416146] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 4.416148] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 4.416198] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.416203] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 4.416205] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 4.416253] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 4.416258] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 4.416260] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 4.416310] tegra18_a57_serr_init: on CPU 1 a Denver Core
[ 4.416363] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 4.416970] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.417360] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 4.417459] denver_knobs_init:MTS_VERSION:43068234
[ 4.418952] nvpmodel: initialized successfully
[ 4.420347] usbcore: registered new interface driver snd-usb-audio
[ 4.437867] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.438096] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.442327] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 4.442330] Extcon AUX1(HDMI) disable
[ 4.466882] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 4.468100] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.468624] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.492262] tegradc 15210000.nvdisplay: unblank
[ 4.494216] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.494309] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.494404] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 4.496025] Parent Clock set for DC plld2
[ 4.501629] tegradc 15210000.nvdisplay: hdmi: tmds rate:154000K prod-setting:prod_c_hdmi_111m_223m
[ 4.503133] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[ 4.503154] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.507077] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.507079] Extcon AUX1(HDMI) enable
[ 4.510453] OPE platform probe
[ 4.510546] OPE platform probe successful
[ 4.512520] tegra-asoc: sound: This is a dummy codec
[ 4.563799] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.563887] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.563971] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.564080] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.564170] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.564256] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.564336] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.564422] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.564503] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.564584] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.564671] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.564768] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.564851] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.564940] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.565026] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.565129] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.565217] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.565297] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.565380] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.565462] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.609601] u32 classifier
[ 4.609604] Actions configured
[ 4.609682] Initializing XFRM netlink socket
[ 4.611302] NET: Registered protocol family 10
[ 4.612584] NET: Registered protocol family 17
[ 4.612596] NET: Registered protocol family 15
[ 4.612800] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.612881] Bluetooth: RFCOMM socket layer initialized
[ 4.612895] Bluetooth: RFCOMM ver 1.11
[ 4.612899] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.612907] Bluetooth: HIDP socket layer initialized
[ 4.612926] 9pnet: Installing 9P2000 support
[ 4.612969] Key type dns_resolver registered
[ 4.613211] Registered cp15_barrier emulation handler
[ 4.613225] Registered setend emulation handler
[ 4.614700] registered taskstats version 1
[ 4.618301] isp 15600000.isp: initialized
[ 4.622940] nvcsi 150c0000.nvcsi: initialized
[ 4.629792] tegra-vi4 15700000.vi: initialized
[ 4.630734] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 4.630802] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 4.630866] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 4.631011] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.631132] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi–1 bound
[ 4.664178] tegra_rtc c2a0000.rtc: setting system clock to 2019-04-08 14:24:34 UTC (1554733474)
[ 4.665081] mmcblk mmc0:0001: Card claimed for testing.
[ 4.702804] bpmp: mounted debugfs mirror
[ 4.704807] bwmgr: missing cdev-type property
[ 4.710580] spmic-ldo0: disabling
[ 4.710786] spmic-ldo1: disabling
[ 4.710959] en-vdd-sd: disabling
[ 4.710961] en-vdd-cam: disabling
[ 4.710964] vdd-usb0-5v: disabling
[ 4.710967] vdd-usb1-5v: disabling
[ 4.710971] en-vdd-disp-3v3: disabling
[ 4.710973] en-mdm-pwr-3v7: disabling
[ 4.710975] en-vdd-disp-1v8: disabling
[ 4.710977] en-vdd-cam-hv-2v8: disabling
[ 4.710980] en-vdd-cam-1v2: disabling
[ 4.710982] vdd-fan: disabling
[ 4.710984] vdd-3v3: disabling
[ 4.710987] en-vdd-vcm-2v8: disabling
[ 4.710989] vdd-usb2-5v: disabling
[ 4.710991] vdd-sys-bl: disabling
[ 4.710994] en-vdd-sys: disabling
[ 4.710997] ALSA device list:
[ 4.711002] #0: tegra-hda at 0x3518000 irq 383
[ 4.711004] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.707541] random: crng init done
[ 7.632134] extcon-disp-state external-connection:disp-state: cable 40 state 1
[ 7.640344] Extcon HDMI: HPD enabled
[ 7.644964] tegradc 15210000.nvdisplay: hdmi: plugged
[ 7.661864] EXT4-fs (mmcblk0p1): 3 orphan inodes deleted
[ 7.668351] EXT4-fs (mmcblk0p1): recovery complete
[ 7.678353] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.687569] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.700258] devtmpfs: mounted
[ 7.706461] Freeing unused kernel memory: 8448K
[ 7.896518] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.947487] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.976922] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.004175] systemd[1]: Detected architecture arm64.
[ 8.105757] systemd[1]: Set hostname to .
[ 8.200089] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 8.218687] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 8.423917] systemd[1]: Reached target Swap.
[ 8.435185] systemd[1]: Created slice System Slice.
[ 8.444070] systemd[1]: Reached target Slices.
[ 8.453993] systemd[1]: Listening on udev Control Socket.
[ 8.463178] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 8.544996] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 8.569978] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.713611] systemd-journald[2217]: Received request to flush runtime journal from PID 1
[ 9.796157] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[ 9.804136] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[ 9.813091] bmi160 1-0069: bmi_init _id_i2c ERR
[ 14.367140] vdd-1v8: voltage operation not allowed
[ 14.373434] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.399771] vdd-1v8: voltage operation not allowed
[ 14.406203] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.432646] vdd-1v8: voltage operation not allowed
[ 14.438962] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.449614] vdd-1v8: voltage operation not allowed
[ 14.456473] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.570809] vdd-1v8: voltage operation not allowed
[ 14.577113] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.587999] vdd-1v8: voltage operation not allowed
[ 14.594327] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 14.604068] vdd-1v8: voltage operation not allowed
[ 14.610396] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[0000.197] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-1b47d5d9)
[0000.206] I> bit @ 0xd480000
[0000.208] I> Boot-device: eMMC
[0000.212] I> sdmmc bdev is already initialized
[0000.217] I> pmic: reset reason (nverc) : 0x40
[0000.224] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.231] I> Found 31 partitions in SDMMC_USER (instance 3)
[0000.237] I> A/B: bin_type (16) slot 0
[0000.241] I> Loading partition bpmp-fw at 0xd7800000
[0000.246] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.251] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.266] I> Binary(16) of size 532656 is loaded @ 0xd7800000
[0000.272] I> A/B: bin_type (17) slot 0
[0000.276] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.281] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.286] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.300] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.478] I> Loading SCE-FW …
[0000.481] I> A/B: bin_type (12) slot 0
[0000.485] I> Loading partition sce-fw at 0xd7300000
[0000.489] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.495] I> Addr: 0xd7300000, start-block: 58782024, num_blocks: 1
[0000.504] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.510] I> Init SCE
[0000.512] I> Loading APE-FW …
[0000.515] I> A/B: bin_type (11) slot 0
[0000.519] I> Loading partition adsp-fw at 0xd7400000
[0000.524] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.529] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.538] I> Binary(11) of size 106240 is loaded @ 0xd7400000
[0000.544] I> Copy BTCM section
[0000.547] I> A/B: bin_type (13) slot 0
[0000.551] I> Loading partition cpu-bootloader at 0x96000000
[0000.556] I> Reading two headers - addr:0x96000000 blocks:1
[0000.562] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.573] I> Binary(13) of size 275920 is loaded @ 0x96000000
[0000.579] I> A/B: bin_type (20) slot 0
[0000.582] I> Loading partition bootloader-dtb at 0x8520f400
[0000.588] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.593] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.604] I> Binary(20) of size 256048 is loaded @ 0x8520f400
[0000.610] I> A/B: bin_type (14) slot 0
[0000.614] I> Loading partition secure-os at 0x8530f600
[0000.619] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.624] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.633] I> Binary(14) of size 83360 is loaded @ 0x8530f600
[0000.641] I> boot profiler @ 0x275844000
[0000.645] I> Unhalting SCE
[0000.648] I> Primary Memory Start:80000000 Size:70000000
[0000.653] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.660] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):eca0c5e
NOTICE: BL31: Built : 00:20:29, Mar 13 2019
ERROR: Error initializing runtime service trusty_fast
[0001.018] I> Welcome to Cboot
[0001.021] I> Cboot Version: t186-13ef9e7a
[0001.025] I> CPU-BL Params @ 0x275800000
[0001.029] I> 0) Base:0x00000000 Size:0x00000000
[0001.033] I> 1) Base:0x277f00000 Size:0x00100000
[0001.038] I> 2) Base:0x277e00000 Size:0x00100000
[0001.042] I> 3) Base:0x277d00000 Size:0x00100000
[0001.047] I> 4) Base:0x277c00000 Size:0x00100000
[0001.051] I> 5) Base:0x277b00000 Size:0x00100000
[0001.056] I> 6) Base:0x277800000 Size:0x00200000
[0001.060] I> 7) Base:0x277400000 Size:0x00400000
[0001.065] I> 8) Base:0x277a00000 Size:0x00100000
[0001.069] I> 9) Base:0x277300000 Size:0x00100000
[0001.074] I> 10) Base:0x276800000 Size:0x00800000
[0001.078] I> 11) Base:0x30000000 Size:0x00040000
[0001.083] I> 12) Base:0xf0000000 Size:0x00100000
[0001.087] I> 13) Base:0x30040000 Size:0x00001000
[0001.092] I> 14) Base:0x30048000 Size:0x00001000
[0001.096] I> 15) Base:0x30049000 Size:0x00001000
[0001.101] I> 16) Base:0x3004a000 Size:0x00001000
[0001.105] I> 17) Base:0x3004b000 Size:0x00001000
[0001.109] I> 18) Base:0x3004c000 Size:0x00001000
[0001.114] I> 19) Base:0x3004d000 Size:0x00001000
[0001.118] I> 20) Base:0x3004e000 Size:0x00001000
[0001.123] I> 21) Base:0x3004f000 Size:0x00001000
[0001.127] I> 22) Base:0x00000000 Size:0x00000000
[0001.132] I> 23) Base:0xf0100000 Size:0x00010000
[0001.136] I> 24) Base:0x00000000 Size:0x00000000
[0001.140] I> 25) Base:0x00000000 Size:0x00000000
[0001.145] I> 26) Base:0x00000000 Size:0x00000000
[0001.149] I> 27) Base:0x00000000 Size:0x00000000
[0001.154] I> 28) Base:0x84400000 Size:0x00400000
[0001.158] I> 29) Base:0x30000000 Size:0x00010000
[0001.163] I> 30) Base:0x278000000 Size:0x08000000
[0001.167] I> 31) Base:0x00000000 Size:0x00000000
[0001.172] I> 32) Base:0x276000000 Size:0x00600000
[0001.176] I> 33) Base:0x80000000 Size:0x70000000
[0001.181] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.185] I> 35) Base:0x00000000 Size:0x00000000
[0001.189] I> 36) Base:0x00000000 Size:0x00000000
[0001.194] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.198] I> 38) Base:0x84000000 Size:0x00400000
[0001.203] I> 39) Base:0x96000000 Size:0x02000000
[0001.207] I> 40) Base:0x85000000 Size:0x01200000
[0001.212] I> 41) Base:0x275800000 Size:0x00500000
[0001.216] I> 42) Base:0x00000000 Size:0x00000000
[0001.221] I> 43) Base:0x00000000 Size:0x00000000
[0001.225] GIC-SPI Target CPU: 4
[0001.228] Interrupts Init done
[0001.232] calling constructors
[0001.235] initializing heap
[0001.237] initializing threads
[0001.241] initializing timers
[0001.244] creating bootstrap completion thread
[0001.248] top of bootstrap2()
[0001.252] CPU: ARM Cortex A57
[0001.255] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.260] initializing platform
[0001.263] I> Boot-device: eMMC
[0001.267] I> sdmmc bdev is already initialized
[0001.273] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.279] I> Found 31 partitions in SDMMC_USER (instance 3)
[0001.285] W> opt-in fuse is not set, skip fuse_burning
[0001.290] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.295] W> No valid slot number is found in scratch register
[0001.301] W> Return default slot: _a
[0001.304] I> A/B: bin_type (21) slot 0
[0001.308] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.321] I> Kernel_dtb @0x80000000
[0001.325] I> Bl_dtb @0x8520f400
[0001.328] I> gpio framework initialized
[0001.333] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ driver
[0001.342] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio-aon’ driver
[0001.350] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.361] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.368] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.377] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.387] I> fixed regulator driver initialized
[0001.415] I> register ‘maxim’ power off handle
[0001.420] I> virtual i2c enabled
[0001.423] I> registered ‘maxim,max77620’ pmic
[0001.427] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.438] I> Find /i2c@c250000’s alias i2c7
[0001.442] I> Reading eeprom i2c=7 address=0x50
[0001.472] I> Device at /i2c@c250000:0x50
[0001.476] I> Reading eeprom i2c=7 address=0x57
[0001.505] I> Device at /i2c@c250000:0x57
[0001.510] I> Find /i2c@c240000’s alias i2c1
[0001.514] I> Reading eeprom i2c=1 address=0x51
[0001.519] E> I2C: slave not found in slaves.
[0001.523] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.531] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.537] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.546] E> eeprom: Retry to read I2C slave device.
[0001.551] E> I2C: slave not found in slaves.
[0001.555] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.563] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.569] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.578] E> eeprom: Failed to read I2C slave device
[0001.583] I> Eeprom read failed 0x3526070d
[0001.588] I> Find /i2c@3160000’s alias i2c0
[0001.592] I> Reading eeprom i2c=0 address=0x50
[0001.596] E> I2C: slave not found in slaves.
[0001.600] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.608] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.614] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.623] E> eeprom: Failed to read I2C slave device
[0001.628] I> Eeprom read failed 0x3526070d
[0001.633] I> Find /i2c@3180000’s alias i2c2
[0001.637] I> Reading eeprom i2c=2 address=0x54
[0001.641] I> Enabling gpio chip_id = 2, gpio pin = 9
[1125.528] E> Blob is not set
[1126.330] I> Welcome to MB2(TBoot-BPMP) Recovery(version: 01.00.160913-t186-M-00.00-mobile-65342981)
[1126.339] I> bit @ 0xd480000
[1126.342] I> Boot-device: eMMC
[1126.367] I> sdmmc DDR50 mode
[1126.370] I> sdmmc bdev is already initialized
[1126.375] I> pmic: reset reason (nverc) : 0x80
[1126.382] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[1126.389] I> Found 31 partitions in SDMMC_USER (instance 3)
[1126.398] I> Binary(16) of size 532656 is loaded @ 0xd7800000
[1126.406] I> Binary(17) of size 465840 is loaded @ 0xd798e440
[1126.584] I> Copy BTCM section
[1126.588] I> Binary(13) of size 202432 is loaded @ 0x96000000
[1126.595] I> Binary(20) of size 256048 is loaded @ 0x8520f400
[1126.602] I> Binary(14) of size 83360 is loaded @ 0x8530f600
[1126.610] I> boot profiler @ 0x275844000
[1126.614] I> Unhalting SCE
[1126.617] I> Primary Memory Start:80000000 Size:70000000
[1126.622] I> Extended Memory Start:f0110000 Size:1856f0000
[1126.629] I> MB2(TBoot-BPMP) Recovery done
[1126.988] I> Welcome to TBoot-CPU Recovery(version: 01.00.160913-t186-M-00.00-mobile-44236992)
[1126.996] I> gpio framework initialized
[1127.000] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ driver
[1127.007] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio-aon’ driver
[1127.015] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[1127.024] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[1127.031] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[1127.039] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[1127.046] I> CPU: ARM Cortex A57
[1127.050] I> CPU: MIDR: 0x411fd073, MPIDR: 0x80000100
[1127.054] I> L2 ECC enabled : yes
[1127.058] I> CPU-BL Params @ 0x275800000
[1127.061] I> 0) Base:0x00000000 Size:0x00000000
[1127.066] I> 1) Base:0x277f00000 Size:0x00100000
[1127.070] I> 2) Base:0x277e00000 Size:0x00100000
[1127.075] I> 3) Base:0x277d00000 Size:0x00100000
[1127.079] I> 4) Base:0x277c00000 Size:0x00100000
[1127.084] I> 5) Base:0x277b00000 Size:0x00100000
[1127.088] I> 6) Base:0x277800000 Size:0x00200000
[1127.093] I> 7) Base:0x277400000 Size:0x00400000
[1127.097] I> 8) Base:0x277a00000 Size:0x00100000
[1127.102] I> 9) Base:0x277300000 Size:0x00100000
[1127.106] I> 10) Base:0x276800000 Size:0x00800000
[1127.111] I> 11) Base:0x30000000 Size:0x00040000
[1127.115] I> 12) Base:0xf0000000 Size:0x00100000
[1127.120] I> 13) Base:0x30040000 Size:0x00001000
[1127.124] I> 14) Base:0x30048000 Size:0x00001000
[1127.129] I> 15) Base:0x30049000 Size:0x00001000
[1127.133] I> 16) Base:0x3004a000 Size:0x00001000
[1127.138] I> 17) Base:0x3004b000 Size:0x00001000
[1127.142] I> 18) Base:0x3004c000 Size:0x00001000
[1127.146] I> 19) Base:0x3004d000 Size:0x00001000
[1127.151] I> 20) Base:0x3004e000 Size:0x00001000
[1127.155] I> 21) Base:0x3004f000 Size:0x00001000
[1127.160] I> 22) Base:0x00000000 Size:0x00000000
[1127.164] I> 23) Base:0xf0100000 Size:0x00010000
[1127.169] I> 24) Base:0x00000000 Size:0x00000000
[1127.173] I> 25) Base:0x00000000 Size:0x00000000
[1127.177] I> 26) Base:0x00000000 Size:0x00000000
[1127.182] I> 27) Base:0x00000000 Size:0x00000000
[1127.186] I> 28) Base:0x84400000 Size:0x00400000
[1127.191] I> 29) Base:0x30000000 Size:0x00010000
[1127.195] I> 30) Base:0x278000000 Size:0x08000000
[1127.200] I> 31) Base:0x00000000 Size:0x00000000
[1127.204] I> 32) Base:0x276000000 Size:0x00600000
[1127.209] I> 33) Base:0x80000000 Size:0x70000000
[1127.213] I> 34) Base:0xf0110000 Size:0x1856f0000
[1127.218] I> 35) Base:0x00000000 Size:0x00000000
[1127.222] I> 36) Base:0x00000000 Size:0x00000000
[1127.226] I> 37) Base:0x2772e0000 Size:0x00020000
[1127.231] I> 38) Base:0x84000000 Size:0x00400000
[1127.235] I> 39) Base:0x96000000 Size:0x02000000
[1127.240] I> 40) Base:0x85000000 Size:0x01200000
[1127.244] I> 41) Base:0x275800000 Size:0x00500000
[1127.249] I> 42) Base:0x00000000 Size:0x00000000
[1127.253] I> 43) Base:0x00000000 Size:0x00000000
[1127.258] I> Boot-device: eMMC
[1127.283] I> sdmmc DDR50 mode
[1127.286] I> sdmmc bdev is already initialized
[1127.292] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[1127.299] I> Found 31 partitions in SDMMC_USER (instance 3)
[1127.304] I> bl dtb load address = @0x8520f400
[1127.308] I> Recovery boot_type: 0
[1127.314] I> fixed regulator driver initialized
[1127.350] I> register ‘maxim’ power off handle
[1127.356] I> virtual i2c enabled
[1127.359] I> registered ‘maxim,max77620’ pmic
[1127.363] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[1127.370] I> Entering 3p server
[1127.373] I> SUPER SPEED
[1127.894] I> USB configuration success
[1128.177] I> Writing kernel-dtb partition.
[1128.318] I> Rebooting : reset-coldboot
[0000.194] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-1b47d5d9)
[0000.203] I> bit @ 0xd480000
[0000.206] I> Boot-device: eMMC
[0000.209] I> sdmmc bdev is already initialized
[0000.214] I> pmic: reset reason (nverc) : 0x0
[0000.221] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.228] I> Found 31 partitions in SDMMC_USER (instance 3)
[0000.234] I> A/B: bin_type (16) slot 0
[0000.238] I> Loading partition bpmp-fw at 0xd7800000
[0000.243] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.248] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.263] I> Binary(16) of size 532656 is loaded @ 0xd7800000
[0000.269] I> A/B: bin_type (17) slot 0
[0000.273] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.278] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.283] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.297] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.475] I> Loading SCE-FW …
[0000.478] I> A/B: bin_type (12) slot 0
[0000.482] I> Loading partition sce-fw at 0xd7300000
[0000.486] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.492] I> Addr: 0xd7300000, start-block: 58782024, num_blocks: 1
[0000.501] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.507] I> Init SCE
[0000.509] I> Loading APE-FW …
[0000.512] I> A/B: bin_type (11) slot 0
[0000.516] I> Loading partition adsp-fw at 0xd7400000
[0000.521] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.526] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.535] I> Binary(11) of size 106240 is loaded @ 0xd7400000
[0000.541] I> Copy BTCM section
[0000.544] I> A/B: bin_type (13) slot 0
[0000.548] I> Loading partition cpu-bootloader at 0x96000000
[0000.553] I> Reading two headers - addr:0x96000000 blocks:1
[0000.559] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.570] I> Binary(13) of size 275920 is loaded @ 0x96000000
[0000.576] I> A/B: bin_type (20) slot 0
[0000.579] I> Loading partition bootloader-dtb at 0x8520f400
[0000.585] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.590] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.601] I> Binary(20) of size 256048 is loaded @ 0x8520f400
[0000.607] I> A/B: bin_type (14) slot 0
[0000.611] I> Loading partition secure-os at 0x8530f600
[0000.616] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.621] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.630] I> Binary(14) of size 83360 is loaded @ 0x8530f600
[0000.638] I> boot profiler @ 0x275844000
[0000.642] I> Unhalting SCE
[0000.645] I> Primary Memory Start:80000000 Size:70000000
[0000.650] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.657] I> MB2(TBoot-BPMP) done
[0001.015] I> Welcome to Cboot
[0001.018] I> Cboot Version: t186-13ef9e7a
[0001.022] I> CPU-BL Params @ 0x275800000
[0001.026] I> 0) Base:0x00000000 Size:0x00000000
[0001.030] I> 1) Base:0x277f00000 Size:0x00100000
[0001.035] I> 2) Base:0x277e00000 Size:0x00100000
[0001.039] I> 3) Base:0x277d00000 Size:0x00100000
[0001.044] I> 4) Base:0x277c00000 Size:0x00100000
[0001.048] I> 5) Base:0x277b00000 Size:0x00100000
[0001.053] I> 6) Base:0x277800000 Size:0x00200000
[0001.057] I> 7) Base:0x277400000 Size:0x00400000
[0001.062] I> 8) Base:0x277a00000 Size:0x00100000
[0001.066] I> 9) Base:0x277300000 Size:0x00100000
[0001.071] I> 10) Base:0x276800000 Size:0x00800000
[0001.075] I> 11) Base:0x30000000 Size:0x00040000
[0001.080] I> 12) Base:0xf0000000 Size:0x00100000
[0001.084] I> 13) Base:0x30040000 Size:0x00001000
[0001.089] I> 14) Base:0x30048000 Size:0x00001000
[0001.093] I> 15) Base:0x30049000 Size:0x00001000
[0001.097] I> 16) Base:0x3004a000 Size:0x00001000
[0001.102] I> 17) Base:0x3004b000 Size:0x00001000
[0001.106] I> 18) Base:0x3004c000 Size:0x00001000
[0001.111] I> 19) Base:0x3004d000 Size:0x00001000
[0001.115] I> 20) Base:0x3004e000 Size:0x00001000
[0001.120] I> 21) Base:0x3004f000 Size:0x00001000
[0001.124] I> 22) Base:0x00000000 Size:0x00000000
[0001.128] I> 23) Base:0xf0100000 Size:0x00010000
[0001.133] I> 24) Base:0x00000000 Size:0x00000000
[0001.137] I> 25) Base:0x00000000 Size:0x00000000
[0001.142] I> 26) Base:0x00000000 Size:0x00000000
[0001.146] I> 27) Base:0x00000000 Size:0x00000000
[0001.151] I> 28) Base:0x84400000 Size:0x00400000
[0001.155] I> 29) Base:0x30000000 Size:0x00010000
[0001.159] I> 30) Base:0x278000000 Size:0x08000000
[0001.164] I> 31) Base:0x00000000 Size:0x00000000
[0001.168] I> 32) Base:0x276000000 Size:0x00600000
[0001.173] I> 33) Base:0x80000000 Size:0x70000000
[0001.177] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.182] I> 35) Base:0x00000000 Size:0x00000000
[0001.186] I> 36) Base:0x00000000 Size:0x00000000
[0001.191] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.195] I> 38) Base:0x84000000 Size:0x00400000
[0001.200] I> 39) Base:0x96000000 Size:0x02000000
[0001.204] I> 40) Base:0x85000000 Size:0x01200000
[0001.209] I> 41) Base:0x275800000 Size:0x00500000
[0001.213] I> 42) Base:0x00000000 Size:0x00000000
[0001.217] I> 43) Base:0x00000000 Size:0x00000000
[0001.222] GIC-SPI Target CPU: 4
[0001.225] Interrupts Init done
[0001.228] calling constructors
[0001.232] initializing heap
[0001.234] initializing threads
[0001.237] initializing timers
[0001.241] creating bootstrap completion thread
[0001.245] top of bootstrap2()
[0001.248] CPU: ARM Cortex A57
[0001.252] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.257] initializing platform
[0001.260] I> Boot-device: eMMC
[0001.264] I> sdmmc bdev is already initialized
[0001.270] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.276] I> Found 31 partitions in SDMMC_USER (instance 3)
[0001.281] W> opt-in fuse is not set, skip fuse_burning
[0001.286] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.292] W> No valid slot number is found in scratch register
[0001.298] W> Return default slot: _a
[0001.301] I> A/B: bin_type (21) slot 0
[0001.305] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.318] I> Kernel_dtb @0x80000000
[0001.321] I> Bl_dtb @0x8520f400
[0001.324] I> gpio framework initialized
[0001.330] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ driver
[0001.339] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio-aon’ driver
[0001.347] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.358] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.365] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.374] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.383] I> fixed regulator driver initialized
[0001.411] I> register ‘maxim’ power off handle
[0001.417] I> virtual i2c enabled
[0001.420] I> registered ‘maxim,max77620’ pmic
[0001.424] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.435] I> Find /i2c@c250000’s alias i2c7
[0001.439] I> Reading eeprom i2c=7 address=0x50
[0001.469] I> Device at /i2c@c250000:0x50
[0001.473] I> Reading eeprom i2c=7 address=0x57
[0001.502] I> Device at /i2c@c250000:0x57
[0001.507] I> Find /i2c@c240000’s alias i2c1
[0001.511] I> Reading eeprom i2c=1 address=0x51
[0001.516] E> I2C: slave not found in slaves.
[0001.520] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.528] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.534] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.543] E> eeprom: Retry to read I2C slave device.
[0001.548] E> I2C: slave not found in slaves.
[0001.552] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.560] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.566] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.575] E> eeprom: Failed to read I2C slave device
[0001.580] I> Eeprom read failed 0x3526070d
[0001.585] I> Find /i2c@3160000’s alias i2c0
[0001.589] I> Reading eeprom i2c=0 address=0x50
[0001.593] E> I2C: slave not found in slaves.
[0001.597] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.605] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.611] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.620] E> eeprom: Failed to read I2C slave device
[0001.625] I> Eeprom read failed 0x3526070d
[0001.630] I> Find /i2c@3180000’s alias i2c2
[0001.634] I> Reading eeprom i2c=2 address=0x54
[0001.638] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.669] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.675] I> Device at /i2c@3180000:0x54
[0001.678] I> create_pm_ids: id: 3310-1000-B02-E, len: 15
[0001.684] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.694] I> create_pm_ids: id: 2597-0000-501-D, len: 15
[0001.700] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.711] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.716] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.747] I> hdmi cable connected
[0001.752] I> setting ‘vdd-pex-1v00’ regulator to 1000000 micro volts
[0001.761] I> setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0001.769] E> cannot find any other nvdisp nodes
[0001.783] E> I2C: Timeout while polling for transfer complete. Last value 0x00000002.
[0001.791] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.801] E> I2C: Timeout while polling for bus clear. Last value 0x00000000.
[0001.808] E> I2C: Failed to clear bus for instance 3.
[0001.813] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.819] E> I2C_DEV: Could not read 128 registers of size 1 from slave 0xa0 at 0x00000000 via instance 3.
[0001.829] E> could not read edid
[0001.836] I> hdmi_enable, starting HDMI initialisation
[0001.843] I> hdmi_enable, HDMI initialisation complete
[0001.856] initializing target
[0001.859] calling apps_init()
[0001.862] starting app kernel_boot_app
[0001.868] I> found decompressor handler: lz4-legacy
[0001.873] I> decompressing BMP blob …
[0001.883] I> Kernel type = Normal
[0001.886] I> Loading kernel/boot.img from built-in storage …
[0001.892] W> No valid slot number is found in scratch register
[0001.897] W> Return default slot: _a
[0001.901] I> A/B: bin_type (24) slot 0
[0002.660] I> Boot image size read from image header: f20d0
[0002.666] I> Boot image load address: 0x0x80400000
[0002.670] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.432] I> Kernel hdr @0x80400000
[0003.435] I> Kernel dtb @0x80000000
[0003.439] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0003.446] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 21), max size 0x100000
[0003.456] I> Checking boot.img header magic … [0003.460] I> [OK]
[0003.462] I> Valid boot.img @ 0x80400000
[0003.466] I> decompressor handler not found
[0003.470] I> Copying kernel image (474242 bytes) from 0x80400800 to 0x84600000 … [0003.477] I> Done
[0003.479] I> Move ramdisk (len: 0) from 0x80474800 to 0x98730000
[0003.486] I> Updated bpmp info to DTB
[0003.491] I> Ramdisk: Base: 0x98730000; Size: 0x0
[0003.495] I> Updated initrd info to DTB
[0003.499] W> WARN: Fail to override “console=none” in commandline
[0003.505] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.512] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.519] I> disabled_core_mask: 0xffffff0c
[0003.523] W> No valid slot number is found in scratch register
[0003.529] W> Return default slot: _a
[0003.533] I> Active slot suffix:
[0003.536] I> add_boot_slot_suffix: slot_suffix =
[0003.540] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x9607b000 lut_mem2=0x2008@0x96078000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x2758
nousb.log (125 KB)
Did you flash your own kernel?
What the uname -a shows?
No, I used the kernel of Jetpack 4.2.
How can I do uname -a without usb-keyboard?
Sorry, I rebuild the kernel-source with some changes.
The kernel image of Jetpack 4.2 works correct.
You can use ssh or serial console when USB fails.
If a different kernel fails, then probably you need to start with a matching configuration (the “/proc/config.gz”, after setting CONFIG_LOCALVERSION, is ideal as a starting point). “uname -r” is important because it says where modules will be searched for: “/lib/modules/$(uname -r)/”, and if you didn’t preserve CONFIG_LOCALVERSION, then you would need a complete module tree added even with the same kernel and starting config. “uname -a” just gives more information.
Export the LOCALVERSION to build the kernel for the module not loaded.
export LOCALVERSION=-tegra
make O=$TEGRA_KERNEL_OUT tegra_defconfig
Thanks for your help.
I found the problem: the device-tree was incorrect which gives the usb was not working.
