Hi Wayne,
I've been backing the kernel to the official. The problems still existed.
The full log is as follow:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.159 (xiaochuan@xiaochuan-latitude-5450) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #8 SMP PREEMPT Wed Oct 30 18:56:57 CST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31128 r8192 d30312 u69632
[ 0.000000] pcpu-alloc: s31128 r8192 d30312 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0421119043600 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7975856K/8208384K available (11692K kernel code, 1761K rwdata, 5616K rodata, 1152K init, 690K bss, 166992K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001168000 - 0xffffffc001288000 ( 1152 KB)
.text : 0xffffffc000080000 - 0xffffffc001168000 ( 17312 KB)
.data : 0xffffffc0012aa000 - 0xffffffc0014626e0 ( 1762 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009791] Console: colour dummy device 80x25
[ 0.014445] console [tty0] enabled
[ 0.017998] bootconsole [uart0] disabled
[ 0.022097] kmemleak: Kernel memory leak detector disabled
[ 0.022110] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022123] pid_max: default: 32768 minimum: 301
[ 0.022175] Security Framework initialized
[ 0.022210] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022221] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022588] Initializing cgroup subsys io
[ 0.022601] Initializing cgroup subsys memory
[ 0.022619] Initializing cgroup subsys devices
[ 0.022629] Initializing cgroup subsys freezer
[ 0.022640] Initializing cgroup subsys net_cls
[ 0.022649] Initializing cgroup subsys perf_event
[ 0.022659] Initializing cgroup subsys net_prio
[ 0.022669] Initializing cgroup subsys pids
[ 0.022677] Initializing cgroup subsys debug
[ 0.022825] CPU0 ipc=752
[ 0.022835] CPU1 ipc=1024
[ 0.022843] CPU2 ipc=1024
[ 0.022852] CPU3 ipc=752
[ 0.022861] CPU4 ipc=752
[ 0.022870] CPU5 ipc=752
[ 0.022910] ASID allocator initialised with 65536 entries
[ 0.046210] tegra-id: chipid=21817.
[ 0.046228] tegra-id: opt_subrevision=1.
[ 0.046243] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046919] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046941] DTB Build time: Oct 30 2019 18:53:14
[ 0.062430] CPU1: Booted secondary processor [4e0f0030]
[ 0.074086] CPU2: Booted secondary processor [4e0f0030]
[ 0.085753] CPU3: Booted secondary processor [411fd073]
[ 0.097768] CPU4: Booted secondary processor [411fd073]
[ 0.109767] CPU5: Booted secondary processor [411fd073]
[ 0.109835] Brought up 6 CPUs
[ 0.109897] SMP: Total of 6 processors activated.
[ 0.109911] CPU: All CPU(s) started at EL2
[ 0.110366] devtmpfs: initialized
[ 0.136691] Initilizing CustomIPI irq domain
[ 0.136885] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.136915] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.137794] pinctrl core: initialized pinctrl subsystem
[ 0.137960] OS set in device tree is not L4T.
[ 0.138156] regulator-dummy: no parameters
[ 0.138259] Initializing plugin-manager
[ 0.138314] Plugin module not found
[ 0.138729] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139079] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.139688] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.140847] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141191] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141466] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.141693] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142116] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142555] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.142833] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143215] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143460] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.143680] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.143940] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.145875] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.147660] Adding domain adsp-pd to PM domain ape-pd
[ 0.150009] NET: Registered protocol family 16
[ 0.150789] console [pstore-1] enabled
[ 0.150801] pstore: Registered ramoops as persistent store backend
[ 0.150816] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161309] cpuidle: using governor ladder
[ 0.165753] cpuidle: using governor menu
[ 0.166877] bpmp: waiting for handshake
[ 0.166892] bpmp: handshake completed
[ 0.166934] bpmp: synchronizing channels
[ 0.166963] bpmp: channels synchronized
[ 0.166975] bpmp: mail init ok
[ 0.167285] vdso: 2 pages (1 code @ ffffffc0012b1000, 1 data @ ffffffc0012b0000)
[ 0.167321] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168269] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169696] tegra_powergate_init: DONE
[ 0.169717] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169741] DTB Build time: Oct 30 2019 18:53:14
[ 0.170675] Tegra reboot handler registered.
[ 0.171710] Registering Tegra186 clocks (this may take a while)...done
[ 0.173206] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.173224] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173238] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173252] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173265] arm-smmu 12000000.iommu: nested translation
[ 0.173280] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173300] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.173321] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.173336] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.173349] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.216667] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.221667] iommu: Adding device 3460000.sdhci to group 0
[ 0.222535] iommu: Adding device 3400000.sdhci to group 1
[ 0.226044] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.226507] iommu: Adding device 3160000.i2c to group 3
[ 0.226915] iommu: Adding device c240000.i2c to group 4
[ 0.227236] iommu: Adding device 3180000.i2c to group 5
[ 0.227584] iommu: Adding device 3190000.i2c to group 6
[ 0.228030] iommu: Adding device 31b0000.i2c to group 7
[ 0.228356] iommu: Adding device 31c0000.i2c to group 8
[ 0.228679] iommu: Adding device c250000.i2c to group 9
[ 0.228993] iommu: Adding device 31e0000.i2c to group 10
[ 0.230943] iommu: Adding device 3210000.spi to group 11
[ 0.231300] iommu: Adding device c260000.spi to group 12
[ 0.231617] iommu: Adding device 3240000.spi to group 13
[ 0.232505] iommu: Adding device 3100000.serial to group 14
[ 0.232801] iommu: Adding device 3110000.serial to group 15
[ 0.233164] iommu: Adding device c280000.serial to group 16
[ 0.233461] iommu: Adding device 3130000.serial to group 17
[ 0.234709] iommu: Adding device 2490000.ether_qos to group 18
[ 0.235400] iommu: Adding device b000000.rtcpu to group 19
[ 0.235858] iommu: Adding device c1a0000.aon to group 20
[ 0.236722] Wake73 for irq=42
[ 0.237083] iommu: Adding device smmu_test to group 21
[ 0.237595] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.237637] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.237674] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.237709] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.237765] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.237990] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.238840] Wake76 for irq=199
[ 0.238870] Wake77 for irq=199
[ 0.238892] Wake78 for irq=199
[ 0.238914] Wake79 for irq=199
[ 0.238963] Wake80 for irq=199
[ 0.238986] Wake81 for irq=199
[ 0.239006] Wake82 for irq=199
[ 0.239120] iommu: Adding device 3530000.xhci to group 22
[ 0.239503] iommu: Adding device 3550000.xudc to group 23
[ 0.240306] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.241644] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.241688] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.241714] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.241738] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.242026] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.242066] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.242554] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.242588] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.243058] iommu: Adding device 13e10000.host1x to group 24
[ 0.243333] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.243612] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.243839] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.244097] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.244320] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.244568] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.244790] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.245057] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.245497] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.245996] iommu: Adding device 15700000.vi to group 34
[ 0.246318] iommu: Adding device 15600000.isp to group 35
[ 0.246771] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.246974] iommu: Adding device 15340000.vic to group 37
[ 0.247206] iommu: Adding device 154c0000.nvenc to group 38
[ 0.247409] iommu: Adding device 15480000.nvdec to group 39
[ 0.247729] iommu: Adding device 15380000.nvjpg to group 40
[ 0.247935] iommu: Adding device 15500000.tsec to group 41
[ 0.248135] iommu: Adding device 15100000.tsecb to group 42
[ 0.248834] iommu: Adding device 15810000.se to group 43
[ 0.249039] iommu: Adding device 15820000.se to group 44
[ 0.249264] iommu: Adding device 15830000.se to group 45
[ 0.249471] iommu: Adding device 15840000.se to group 46
[ 0.249978] iommu: Adding device 17000000.gp10b to group 47
[ 0.251298] tegra-reset 5000000.clock: registered 193 resets.
[ 0.253205] iommu: Adding device d000000.bpmp to group 48
[ 0.253459] bpmp: ping status is 0
[ 0.253648] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[ 0.253997] bpmp d000000.bpmp: probe ok
[ 0.256994] iommu: Adding device 2600000.dma to group 49
[ 0.257835] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.257896] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.258046] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.258102] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.258160] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.258216] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.258272] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.258406] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.260300] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.260405] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.261291] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.261594] iommu: Adding device sound to group 51
[ 0.263250] iommu: Adding device 3510000.hda to group 52
[ 0.264346] iommu: Adding device adsp_audio to group 53
[ 0.265719] iommu: Adding device 2993000.adsp to group 54
[ 0.274536] vdd-ac-bat: 5000 mV
[ 0.276608] vdd-1v8-ap: 1800 mV
[ 0.296655] SCSI subsystem initialized
[ 0.296830] libata version 3.00 loaded.
[ 0.297029] usbcore: registered new interface driver usbfs
[ 0.297095] usbcore: registered new interface driver hub
[ 0.297216] usbcore: registered new device driver usb
[ 0.299902] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.300110] pca953x 0-0074: failed reading register
[ 0.300188] pca953x: probe of 0-0074 failed with error -121
[ 0.300563] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.300763] pca953x 0-0077: failed reading register
[ 0.300830] pca953x: probe of 0-0077 failed with error -121
[ 0.311262] media: Linux media interface: v0.10
[ 0.311338] Linux video capture interface: v2.00
[ 0.315269] pps_core: LinuxPPS API ver. 1 registered
[ 0.315361] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.315421] PTP clock support registered
[ 0.316255] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.316332] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.317854] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.319970] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.320169] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.320258] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.326602] vddio-ddr: at 1125 mV
[ 0.330439] avdd_dsi_csi: 1200 mV
[ 0.334439] vdd-1v8: 1800 mV
[ 0.338440] vdd-3v3-sys: 3300 mV
[ 0.339488] spmic-ldo0: at 1800 mV
[ 0.340236] spmic-ldo1: at 800 mV
[ 0.342441] vddio-3v3: 3300 mV
[ 0.343208] vddio-sdmmc1: 1800 <--> 3300 mV at 1800 mV
[ 0.346442] vdd-rtc: at 800 mV
[ 0.347204] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.349774] spmic-ldo6: at 1500 mV
[ 0.353772] vdd-pex-1v00: 1000 mV
[ 0.354319] dvdd-pex: 1000 mV
[ 0.354578] max77620 4-003c: max77620 probe successful
[ 0.354835] Advanced Linux Sound Architecture Driver Initialized.
[ 0.355173] Bluetooth: Core ver 2.21
[ 0.355201] NET: Registered protocol family 31
[ 0.355214] Bluetooth: HCI device and connection manager initialized
[ 0.355230] Bluetooth: HCI socket layer initialized
[ 0.355245] Bluetooth: L2CAP socket layer initialized
[ 0.355270] Bluetooth: SCO socket layer initialized
[ 0.355935] en-vdd-sd: 3300 mV
[ 0.356206] vdd-usb0-5v: 5000 mV
[ 0.356372] vdd-usb1-5v: 5000 mV
[ 0.356718] vdd-3v3: 3300 mV
[ 0.356860] en-vdd-vcm-2v8: 2800 mV
[ 0.357000] vdd-sys-bl: 3300 mV
[ 0.360335] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.360696] clocksource: Switched to clocksource arch_sys_counter
[ 0.379871] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.380143] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.380619] nvmap_page_pool_init: Total RAM pages: 2010348
[ 0.380637] nvmap_page_pool_init: nvmap page pool size: 251293 pages (981 MB)
[ 0.380850] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.385360] Wake76 for irq=199
[ 0.385376] Wake77 for irq=199
[ 0.385388] Wake78 for irq=199
[ 0.385398] Wake79 for irq=199
[ 0.385408] Wake80 for irq=199
[ 0.385418] Wake81 for irq=199
[ 0.385428] Wake82 for irq=199
[ 0.386165] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.386353] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.386717] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.386796] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.386937] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.387074] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.387219] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.387518] isomgr_init(): iso emc max clk=1866000KHz
[ 0.387531] isomgr_init(): max_iso_bw=26870400KB
[ 0.387613] NET: Registered protocol family 2
[ 0.387963] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.388288] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.388972] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.389033] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.389166] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.389409] NET: Registered protocol family 1
[ 0.389614] RPC: Registered named UNIX socket transport module.
[ 0.389630] RPC: Registered udp transport module.
[ 0.389642] RPC: Registered tcp transport module.
[ 0.389654] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.389674] PCI: CLS 0 bytes, default 128
[ 0.389772] Trying to unpack rootfs image as initramfs...
[ 0.403695] host1x 13e10000.host1x: initialized
[ 0.404480] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.406654] audit: initializing netlink subsys (disabled)
[ 0.406691] audit: type=2000 audit(0.392:1): initialized
[ 0.418450] io scheduler noop registered
[ 0.418653] io scheduler cfq registered (default)
[ 0.422224] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.423696] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.425022] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.426338] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.430997] tsec 15500000.tsec: initialized
[ 0.432489] tsec 15100000.tsecb: initialized
[ 0.435270] nvdec 15480000.nvdec: initialized
[ 0.439306] falcon 15340000.vic: initialized
[ 0.440559] falcon 154c0000.nvenc: initialized
[ 0.441810] falcon 15380000.nvjpg: initialized
[ 0.443575] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.444324] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.445102] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.445854] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.446570] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.447364] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.448077] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.448797] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.450728] DC OR NODE connected to /host1x/sor1
[ 0.450905] generic_infoframe_type: 0x87
[ 0.451004] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.451018] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.451050] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.451209] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.451248] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.459556] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.459580] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.459598] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.459646] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.459663] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.460064] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ 0.460789] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.462144] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.462747] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.463153] kfuse 3830000.kfuse: initialized
[ 0.464889] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.465500] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.467954] console [ttyS0] disabled
[ 0.468092] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.497459] tegradc 15210000.nvdisplay: probed
[ 2.534622] console [ttyS0] enabled
[ 2.536455] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.537523] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.537715] serial-tegra 3130000.serial: RX in PIO mode
[ 2.538554] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.543054] Console: switching to colour frame buffer device 240x67
[ 2.548367] brd: module loaded
[ 2.552229] loop: module loaded
[ 2.552468] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.552472] nct1008_nct72 7-004c: starting parse dt
[ 2.552549] nct1008_nct72 7-004c: success parsing dt
[ 2.552731] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.559576] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.589317] tmp451: Enabled overheat logging at 104.00C
[ 2.589464] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.591637] THERMAL EST: found 3 subdevs
[ 2.591640] THERMAL EST num_resources: 0
[ 2.591644] [THERMAL EST subdev 0]
[ 2.591648] [THERMAL EST subdev 1]
[ 2.591652] [THERMAL EST subdev 2]
[ 2.591916] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.591919] THERMAL EST: thz register success.
[ 2.592108] THERMAL EST: end of probe, return err: 0
[ 2.592154] tegra_profiler: Branch: Dev
[ 2.592156] tegra_profiler: Version: 1.121
[ 2.592159] tegra_profiler: Samples version: 42
[ 2.592161] tegra_profiler: IO version: 24
[ 2.592170] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.592174] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), pmuver: 0x1
[ 2.592184] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), pmuver: 0x1
[ 2.592189] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.592192] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.592196] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, pmuver: 0x1
[ 2.592375] tegra_profiler: auth: init
[ 2.596257] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.596270] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.597393] scsi host0: tegra_ahci
[ 2.597747] scsi host1: tegra_ahci
[ 2.597883] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.597886] ata2: DUMMY
[ 2.598802] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.599222] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.599656] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.600535] tun: Universal TUN/TAP device driver, 1.6
[ 2.600537] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.600795] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.600797] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.600852] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.600853] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.601839] PPP generic driver version 2.4.2
[ 2.602017] PPP BSD Compression module registered
[ 2.602025] PPP Deflate Compression module registered
[ 2.602048] PPP MPPE Compression module registered
[ 2.602060] NET: Registered protocol family 24
[ 2.602120] usbcore: registered new interface driver r8152
[ 2.602161] usbcore: registered new interface driver asix
[ 2.602191] usbcore: registered new interface driver ax88179_178a
[ 2.602225] usbcore: registered new interface driver cdc_ether
[ 2.602266] usbcore: registered new interface driver smsc75xx
[ 2.602299] usbcore: registered new interface driver net1080
[ 2.602325] usbcore: registered new interface driver cdc_subset
[ 2.602377] usbcore: registered new interface driver zaurus
[ 2.602435] usbcore: registered new interface driver cdc_ncm
[ 2.602723] Wake76 for irq=199
[ 2.602725] Wake77 for irq=199
[ 2.602727] Wake78 for irq=199
[ 2.602730] Wake79 for irq=199
[ 2.602732] Wake80 for irq=199
[ 2.602733] Wake81 for irq=199
[ 2.602735] Wake82 for irq=199
[ 2.602787] tegra-xotg xotg: usb2 phy is not available yet
[ 2.603359] usbcore: registered new interface driver cdc_acm
[ 2.603362] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.603413] usbcore: registered new interface driver usb-storage
[ 2.603501] usbcore: registered new interface driver usbserial
[ 2.603526] usbcore: registered new interface driver ch341
[ 2.603544] usbserial: USB Serial support registered for ch341-uart
[ 2.603567] usbcore: registered new interface driver cp210x
[ 2.603585] usbserial: USB Serial support registered for cp210x
[ 2.603611] usbcore: registered new interface driver ftdi_sio
[ 2.603627] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.603650] usbcore: registered new interface driver option
[ 2.603665] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.603691] usbcore: registered new interface driver pl2303
[ 2.603715] usbserial: USB Serial support registered for pl2303
[ 2.603927] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.604830] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b dd 7c f9
[ 2.605334] libphy: dwc_phy: probed
[ 2.606092] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.669869] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.733013] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.735228] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.735243] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.735390] i2c /dev entries driver
[ 2.736383] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.738209] FAN: coudln't get the regulator
[ 2.738934] device-mapper: uevent: version 1.0.3
[ 2.739111] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.739440] sdhci: Secure Digital Host Controller Interface driver
[ 2.739441] sdhci: Copyright(c) Pierre Ossman
[ 2.739444] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.739665] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.739930] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.740142] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.776722] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.777007] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.777311] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.812711] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.812951] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.813003] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.813082] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.813114] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.813377] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.815251] mmc0: MAN_BKOPS_EN bit is not set
[ 2.825462] mmc0: Skipping tuning since strobe enabled
[ 2.833853] mmc0: periodic cache flush enabled
[ 2.833863] mmc0: new HS400 MMC card at address 0001
[ 2.834241] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 2.834440] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 2.834637] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 2.834812] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 2.836321] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.856812] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.858710] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.858853] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.860323] usbcore: registered new interface driver usbhid
[ 2.860324] usbhid: USB HID core driver
[ 2.863054] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 2.863240] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 2.863363] ina3221x: probe of 0-0042 failed with error -121
[ 2.863722] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 2.863900] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 2.863999] ina3221x: probe of 0-0043 failed with error -121
[ 2.874946] Denver: backdoor interface is NOT available.
[ 2.877648] coresight-tmc 8030000.etf: TMC initialized
[ 2.878539] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 2.879890] coresight-tmc 8050000.etr: TMC initialized
[ 2.880384] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.881022] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.881543] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.882035] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.882508] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.883218] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.883837] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.884459] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.885119] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.885153] Module initialized successfully
[ 2.889252] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.890902] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.891887] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.892274] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.892325] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.892369] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.892411] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.892449] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.892488] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.892531] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.892711] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.892713] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.893411] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.893414] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.893417] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.893419] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.893423] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.893425] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.893428] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.893457] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.900443] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.901933] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.902041] camchar: rtcpu character device driver loaded
[ 2.908204] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.908644] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.908900] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.909568] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.909600] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.909628] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.909653] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.909682] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.909731] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.909762] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.909788] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.909814] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.909841] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.909868] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.909897] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.909925] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.909956] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.909982] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.910036] **** A57 ECC: Enabled
[ 2.910039] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 2.910214] parse_throttle_dt_data: Num cap clks = 4
[ 2.910217] parse_throttle_dt_data: clk=mcpu type=1
[ 2.910219] parse_throttle_dt_data: clk=bcpu type=2
[ 2.910228] parse_throttle_dt_data: clk=gpu type=4
[ 2.910230] parse_throttle_dt_data: clk=emc type=3
[ 2.910910] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.911012] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 2.914543] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.918619] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.920742] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.077397] mmc1 tuning done saved tap delay=64
[ 3.077400] mmc1: hw tuning done ...
[ 3.077408] mmc1: tuning_window[0]: 0xffffffff
[ 3.077415] mmc1: tuning_window[1]: 0xfffff1ff
[ 3.077420] mmc1: tuning_window[2]: 0xfc3fffff
[ 3.077426] mmc1: tuning_window[3]: 0x7fffffff
[ 3.077431] mmc1: tuning_window[4]: 0x0
[ 3.077436] mmc1: tuning_window[5]: 0x0
[ 3.077442] mmc1: tuning_window[6]: 0x0
[ 3.077447] mmc1: tuning_window[7]: 0x0
[ 3.084091] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.084143] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.143302] tegradc 15210000.nvdisplay: fb registered
[ 4.150088] PD DISP0 index2 UP
[ 4.155673] PD DISP1 index3 UP
[ 4.160157] PD DISP2 index4 UP
[ 4.166408] Parent Clock set for DC plld2
[ 4.175091] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 4.203234] tegra-se-nvhost 15810000.se: initialized
[ 4.210683] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.218655] tegra-se-nvhost 15820000.se: initialized
[ 4.226109] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.233988] tegra-se-nvhost 15830000.se: initialized
[ 4.241075] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.248954] tegra-se-nvhost 15840000.se: initialized
[ 4.256341] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.265870] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.277357] cpufreq: platform driver Initialization: pass
[ 4.283817] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[ 4.291189] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.298079] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.308420] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.318505] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30c419
[ 4.326364] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.333688] tegradc 15210000.nvdisplay: blank - normal
[ 4.335156] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.335803] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.336952] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.337356] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.339141] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.339260] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.340358] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.340363] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.356260] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.356438] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.368525] OPE platform probe
[ 4.368630] OPE platform probe successful
[ 4.390431] PD DISP2 index4 DOWN
[ 4.390532] PD DISP1 index3 DOWN
[ 4.390619] PD DISP0 index2 DOWN
[ 4.397335] tegradc 15210000.nvdisplay: unblank
[ 4.397352] PD DISP0 index2 UP
[ 4.398247] PD DISP1 index3 UP
[ 4.398339] PD DISP2 index4 UP
[ 4.399962] Parent Clock set for DC plld2
[ 4.402104] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 4.413927] random: nonblocking pool is initialized
[ 4.442628] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.442725] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.442818] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.442905] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.442996] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.443085] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.443172] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.443262] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.443354] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.443444] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.443543] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.443659] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.443762] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.443851] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.443944] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.444035] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.444142] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.444233] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.444324] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.444425] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.475956] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.476888] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 4.476891] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.477385] GACT probability NOT on
[ 4.477397] Mirror/redirect action on
[ 4.477412] u32 classifier
[ 4.477413] Actions configured
[ 4.477447] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.478167] IPVS: Registered protocols ()
[ 4.478202] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 4.478279] IPVS: Creating netns size=1424 id=0
[ 4.478307] IPVS: ipvs loaded.
[ 4.478315] IPVS: [rr] scheduler registered.
[ 4.478388] ipip: IPv4 over IPv4 tunneling driver
[ 4.478710] Initializing XFRM netlink socket
[ 4.479003] NET: Registered protocol family 10
[ 4.479656] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.479728] NET: Registered protocol family 17
[ 4.479741] NET: Registered protocol family 15
[ 4.479762] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.479831] Bluetooth: RFCOMM socket layer initialized
[ 4.479841] Bluetooth: RFCOMM ver 1.11
[ 4.479850] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.479855] Bluetooth: HIDP socket layer initialized
[ 4.479860] 8021q: 802.1Q VLAN Support v1.8
[ 4.480408] Registered cp15_barrier emulation handler
[ 4.480421] Registered setend emulation handler
[ 4.482343] registered taskstats version 1
[ 4.486026] isp 15600000.isp: initialized
[ 4.490254] nvcsi 150c0000.nvcsi: initialized
[ 4.492177] Wake76 for irq=199
[ 4.492179] Wake77 for irq=199
[ 4.492179] Wake78 for irq=199
[ 4.492180] Wake79 for irq=199
[ 4.492181] Wake80 for irq=199
[ 4.492182] Wake81 for irq=199
[ 4.492182] Wake82 for irq=199
[ 4.492410] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 4.492749] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.493353] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.494087] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.494546] Wake76 for irq=199
[ 4.494547] Wake77 for irq=199
[ 4.494548] Wake78 for irq=199
[ 4.494549] Wake79 for irq=199
[ 4.494549] Wake80 for irq=199
[ 4.494550] Wake81 for irq=199
[ 4.494551] Wake82 for irq=199
[ 4.494576] tegra-xotg xotg: usb2 phy is not available yet
[ 4.494706] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.495177] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.495321] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.495325] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.495359] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30c419
[ 4.495362] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.496037] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.498261] Wake76 for irq=199
[ 4.498261] Wake77 for irq=199
[ 4.498262] Wake78 for irq=199
[ 4.498263] Wake79 for irq=199
[ 4.498264] Wake80 for irq=199
[ 4.498264] Wake81 for irq=199
[ 4.498265] Wake82 for irq=199
[ 4.498454] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 4.499493] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.499798] Wake76 for irq=199
[ 4.499799] Wake77 for irq=199
[ 4.499800] Wake78 for irq=199
[ 4.499801] Wake79 for irq=199
[ 4.499801] Wake80 for irq=199
[ 4.499802] Wake81 for irq=199
[ 4.499803] Wake82 for irq=199
[ 4.499829] tegra-xotg xotg: usb2 phy is not available yet
[ 4.499936] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.500263] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.500394] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.500398] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.500431] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30c419
[ 4.500433] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.501168] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.503214] Wake76 for irq=199
[ 4.503214] Wake77 for irq=199
[ 4.503215] Wake78 for irq=199
[ 4.503216] Wake79 for irq=199
[ 4.503216] Wake80 for irq=199
[ 4.503217] Wake81 for irq=199
[ 4.503218] Wake82 for irq=199
[ 4.503393] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 4.533079] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 03:44:57 UTC (946698297)
[ 4.562986] bpmp: mounted debugfs mirror
[ 4.563528] [dram-timers] DRAM derating cdev registered.
[ 4.568364] spmic-ldo0: disabling
[ 4.568548] spmic-ldo1: disabling
[ 4.568713] en-vdd-sd: disabling
[ 4.568715] vdd-usb0-5v: disabling
[ 4.568717] vdd-usb1-5v: disabling
[ 4.568718] vdd-3v3: disabling
[ 4.568720] en-vdd-vcm-2v8: disabling
[ 4.568722] vdd-sys-bl: disabling
[ 4.574897] ALSA device list:
[ 4.574899] #0: tegra-hda at 0x3518000 irq 400
[ 4.574900] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.576619] tegra-vi4 15700000.vi: initialized
[ 4.577782] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 4.577785] tegra-vi4 15700000.vi: all channel register failed
[ 4.578086] Wake76 for irq=199
[ 4.578087] Wake77 for irq=199
[ 4.578088] Wake78 for irq=199
[ 4.578088] Wake79 for irq=199
[ 4.578089] Wake80 for irq=199
[ 4.578090] Wake81 for irq=199
[ 4.578090] Wake82 for irq=199
[ 4.578125] tegra-xotg xotg: usb2 phy is not available yet
[ 4.578336] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.578739] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.578905] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.578909] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.578946] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30c419
[ 4.578949] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.579703] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.582066] Wake76 for irq=199
[ 4.582067] Wake77 for irq=199
[ 4.582068] Wake78 for irq=199
[ 4.582069] Wake79 for irq=199
[ 4.582070] Wake80 for irq=199
[ 4.582070] Wake81 for irq=199
[ 4.582071] Wake82 for irq=199
[ 4.582260] xhci-tegra 3530000.xhci: can't get usb3-0 phy (-517)
[ 4.940901] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 6.470501] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.472563] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 6.472835] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 6.745995] EXT4-fs (mmcblk0p1): 12 orphan inodes deleted
[ 6.752451] EXT4-fs (mmcblk0p1): recovery complete
[ 6.762828] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.771969] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.779506] devtmpfs: mounted
[ 6.783877] Freeing unused kernel memory: 1152K
[ 6.789523] Freeing alternatives memory: 100K
[ 6.801859] btb inv war enabled
[ 6.841675] systemd[1]: System time before build time, advancing clock.
[ 6.862733] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.882262] systemd[1]: Detected architecture arm64.
[ 6.896031] systemd[1]: Set hostname to <jetson-0421119043600>.
[ 7.021525] systemd[1]: Listening on Journal Audit Socket.
[ 7.030363] systemd[1]: Created slice User and Session Slice.
[ 7.038926] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 7.047789] systemd[1]: Reached target User and Group Name Lookups.
[ 7.056898] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.066698] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.077170] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.086036] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.094980] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.110665] systemd[1]: Created slice System Slice.
[ 7.119238] systemd[1]: Reached target Slices.
[ 7.128071] systemd[1]: Created slice system-getty.slice.
[ 7.136920] systemd[1]: Listening on udev Kernel Socket.
[ 7.145636] systemd[1]: Listening on Journal Socket.
[ 7.156051] systemd[1]: Started Braille Device Support.
[ 7.167527] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.183593] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 7.193009] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.205248] systemd[1]: Mounting Debug File System...
[ 7.214152] systemd[1]: Reached target Encrypted Volumes.
[ 7.223363] systemd[1]: Listening on udev Control Socket.
[ 7.234356] systemd[1]: Mounting RPC Pipe File System...
[ 7.243653] systemd[1]: Reached target Swap.
[ 7.252645] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.262825] systemd[1]: Listening on Syslog Socket.
[ 7.273385] systemd[1]: Starting Journal Service...
[ 7.299560] systemd[1]: Starting Load Kernel Modules...
[ 7.311091] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 7.321806] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.334169] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.353709] systemd[1]: Mounted RPC Pipe File System.
[ 7.363565] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.373601] systemd[1]: Mounted Debug File System.
[ 7.383065] systemd[1]: Started Journal Service.
[ 7.647529] systemd-journald[272]: Received request to flush runtime journal from PID 1
[ 9.046499] gk20a 17000000.gp10b: railgate is disabled.
[ 9.077944] IPVS: Creating netns size=1424 id=1
[ 9.296295] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.306067] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.714724] tegradc 15210000.nvdisplay: blank - powerdown
[ 9.774434] PD DISP2 index4 DOWN
[ 9.774529] PD DISP1 index3 DOWN
[ 9.774606] PD DISP0 index2 DOWN
[ 9.790530] tegradc 15210000.nvdisplay: unblank
[ 9.790543] PD DISP0 index2 UP
[ 9.791333] PD DISP1 index3 UP
[ 9.791416] PD DISP2 index4 UP
[ 9.793307] Parent Clock set for DC plld2
[ 9.795288] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 9.941938] cfg80211: World regulatory domain updated:
[ 9.941954] cfg80211: DFS Master region: unset
[ 9.941956] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.941973] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.941983] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.941991] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.942003] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.942015] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.942024] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.942032] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.942040] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 10.925701] tegradc 15210000.nvdisplay: unblank
[ 11.061616] CPU1: shutdown
[ 11.064484] psci: CPU1 killed.
[ 11.096831] CPU2: shutdown
[ 11.099654] psci: CPU2 killed.
[ 12.204793] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.214072] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 15.499013] tegradc 15210000.nvdisplay: unblank
[ 15.622270] IPVS: Creating netns size=1424 id=2
[ 16.662692] IPVS: Creating netns size=1424 id=3
[ 26.373271] extcon-gpio-states external-connection:extcon@1: Cable state 2
