I am using a MacBook Pro (mid 2009) as my host and have it booting up with Ubuntu 16.04. That is I’m not using VM at all.
I was able to download the NVIDA SDK installer and install the files on my Mac. But when I actually try to flash the installer fails when trying to connect to the board. When I view the output of lsusb on the Mac I do not see an NVIDA device. The cable is connected as required.
Maybe this is a quirk of the Mac book hardware. The usb ports on the mac do work for other devices like a SansDisk usb and mouse. But it doesn’t see the TX2.
Below is the ouptut of dmesg from the TX2. Is there any indication of a usb port problem on the TX2?
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-1279) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Fri Jul 28 09:55:22 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2051072
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519408 pages, LIFO batch:31
[ 0.000000] Normal zone: 23933 pages used for memmap
[ 0.000000] Normal zone: 1531664 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf3000 s31232 r8192 d30208 u69632
[ 0.000000] pcpu-alloc: s31232 r8192 d30208 u69632 alloc=174096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0425018066421 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7972328K/8204288K available (10976K kernel code, 1817K rwdata, 5712K rodata, 1164K init, 682K bss, 166424K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
.init : 0xffffffc0010cd000 - 0xffffffc0011f0000 ( 1164 KB)
.text : 0xffffffc000080000 - 0xffffffc0010cd000 ( 16692 KB)
.data : 0xffffffc001211000 - 0xffffffc0013d7430 ( 1818 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.010013] Console: colour dummy device 80x25
[ 0.014673] console [tty0] enabled
[ 0.018229] bootconsole [uart0] disabled
[ 0.022332] kmemleak: Kernel memory leak detector disabled
[ 0.022343] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022357] pid_max: default: 32768 minimum: 301
[ 0.022404] Security Framework initialized
[ 0.022434] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022444] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022814] Initializing cgroup subsys freezer
[ 0.022828] Initializing cgroup subsys debug
[ 0.022975] CPU0 ipc=752
[ 0.022984] CPU1 ipc=1024
[ 0.022992] CPU2 ipc=1024
[ 0.023003] CPU3 ipc=752
[ 0.023012] CPU4 ipc=752
[ 0.023023] CPU5 ipc=752
[ 0.023059] ASID allocator initialised with 65536 entries
[ 0.047227] tegra-id: chipid=21817.
[ 0.047240] tegra-id: opt_subrevision=1.
[ 0.047250] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.047932] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.047955] DTB Build time: Jul 28 2017 09:56:32
[ 0.062830] CPU1: Booted secondary processor [4e0f0030]
[ 0.074273] CPU2: Booted secondary processor [4e0f0030]
[ 0.085939] CPU3: Booted secondary processor [411fd073]
[ 0.097945] CPU4: Booted secondary processor [411fd073]
[ 0.109942] CPU5: Booted secondary processor [411fd073]
[ 0.110012] Brought up 6 CPUs
[ 0.110065] SMP: Total of 6 processors activated.
[ 0.110077] CPU: All CPU(s) started at EL2
[ 0.110540] devtmpfs: initialized
[ 0.138441] Initilizing CustomIPI irq domain
[ 0.138655] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.139579] pinctrl core: initialized pinctrl subsystem
[ 0.139782] OS set in device tree is L4T.
[ 0.140003] regulator-dummy: no parameters
[ 0.140115] Initializing plugin-manager
[ 0.140180] Plugin module not found
[ 0.140600] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.140959] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.141628] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.142832] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.143211] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.143482] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.143713] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.144149] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.144608] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.144902] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.145276] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.145543] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.145766] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.146027] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.147587] node /plugin-manager/fragment-e3326@0 match with board 3326-
[ 0.148736] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.150679] Adding domain adsp-pd to PM domain ape-pd
[ 0.153366] NET: Registered protocol family 16
[ 0.154112] console [pstore-1] enabled
[ 0.154125] pstore: Registered ramoops as persistent store backend
[ 0.154138] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.165432] cpuidle: using governor ladder
[ 0.169937] cpuidle: using governor menu
[ 0.171322] bpmp: waiting for handshake
[ 0.171339] bpmp: handshake completed
[ 0.171380] bpmp: synchronizing channels
[ 0.171406] bpmp: channels synchronized
[ 0.171417] bpmp: mail init ok
[ 0.171756] vdso: 2 pages (1 code @ ffffffc001219000, 1 data @ ffffffc001218000)
[ 0.171792] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.172732] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.174299] tegra_powergate_init: DONE
[ 0.174323] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.174348] DTB Build time: Jul 28 2017 09:56:32
[ 0.175462] Tegra reboot handler registered.
[ 0.176798] Registering Tegra186 clocks (this may take a while)…done
[ 0.179294] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.179315] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.179327] arm-smmu 12000000.iommu: stage 1 translation
[ 0.179340] arm-smmu 12000000.iommu: stage 2 translation
[ 0.179351] arm-smmu 12000000.iommu: nested translation
[ 0.179365] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.179383] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.179400] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.179413] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.179425] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.228415] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.234260] iommu: Adding device 3460000.sdhci to group 0
[ 0.235212] iommu: Adding device 3400000.sdhci to group 1
[ 0.239239] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.239751] iommu: Adding device 3160000.i2c to group 3
[ 0.240233] iommu: Adding device c240000.i2c to group 4
[ 0.240598] iommu: Adding device 3180000.i2c to group 5
[ 0.240949] iommu: Adding device 3190000.i2c to group 6
[ 0.241411] iommu: Adding device 31b0000.i2c to group 7
[ 0.241740] iommu: Adding device 31c0000.i2c to group 8
[ 0.242105] iommu: Adding device c250000.i2c to group 9
[ 0.242464] iommu: Adding device 31e0000.i2c to group 10
[ 0.244504] iommu: Adding device 3210000.spi to group 11
[ 0.244845] iommu: Adding device c260000.spi to group 12
[ 0.245143] iommu: Adding device 3240000.spi to group 13
[ 0.245948] iommu: Adding device 3100000.serial to group 14
[ 0.246293] iommu: Adding device 3110000.serial to group 15
[ 0.246606] iommu: Adding device c280000.serial to group 16
[ 0.247001] iommu: Adding device 3130000.serial to group 17
[ 0.248209] iommu: Adding device 2490000.ether_qos to group 18
[ 0.248825] iommu: Adding device b000000.rtcpu to group 19
[ 0.249320] iommu: Adding device c1a0000.aon to group 20
[ 0.250154] Wake73 for irq=42
[ 0.250470] iommu: Adding device smmu_test to group 21
[ 0.251028] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.251065] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.251103] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.251159] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.251192] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.251226] mc-err: Set intmask: 0xf3140
[ 0.251436] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.252214] Wake76 for irq=199
[ 0.252235] Wake77 for irq=199
[ 0.252254] Wake78 for irq=199
[ 0.252292] Wake79 for irq=199
[ 0.252310] Wake80 for irq=199
[ 0.252326] Wake81 for irq=199
[ 0.252342] Wake82 for irq=199
[ 0.252472] iommu: Adding device 3530000.xhci to group 22
[ 0.252811] iommu: Adding device 3550000.xudc to group 23
[ 0.253595] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.253627] tegra-pmc: ### PMC reset source: Power on reset
[ 0.253648] tegra-pmc: ### PMC reset level: L0
[ 0.253667] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.253933] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.253997] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.254159] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.254186] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.254649] iommu: Adding device 13e10000.host1x to group 24
[ 0.254922] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.255187] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.255439] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.255689] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.255897] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.256135] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.256358] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.256574] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.257036] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.257532] iommu: Adding device 15700000.vi to group 34
[ 0.257921] iommu: Adding device 15600000.isp to group 35
[ 0.258224] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.258417] iommu: Adding device 15340000.vic to group 37
[ 0.258632] iommu: Adding device 154c0000.nvenc to group 38
[ 0.258873] iommu: Adding device 15480000.nvdec to group 39
[ 0.259181] iommu: Adding device 15380000.nvjpg to group 40
[ 0.259403] iommu: Adding device 15500000.tsec to group 41
[ 0.259653] iommu: Adding device 15100000.tsecb to group 42
[ 0.260320] iommu: Adding device 15810000.se to group 43
[ 0.260545] iommu: Adding device 15820000.se to group 44
[ 0.260728] iommu: Adding device 15830000.se to group 45
[ 0.260934] iommu: Adding device 15840000.se to group 46
[ 0.261408] iommu: Adding device 17000000.gp10b to group 47
[ 0.262751] tegra-reset 5000000.clock: registered 193 resets.
[ 0.264779] iommu: Adding device d000000.bpmp to group 48
[ 0.265024] bpmp: ping status is 0
[ 0.265219] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.265599] bpmp d000000.bpmp: probe ok
[ 0.268197] iommu: Adding device 2600000.dma to group 49
[ 0.269062] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.269123] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.269199] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.269248] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.269310] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.269364] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.269417] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.269573] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.271507] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.271658] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.272534] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.272820] iommu: Adding device sound to group 51
[ 0.274488] iommu: Adding device 3510000.hda to group 52
[ 0.275674] iommu: Adding device adsp_audio to group 53
[ 0.277342] iommu: Adding device 2993000.adsp to group 54
[ 0.288033] vdd-ac-bat: 5000 mV
[ 0.290307] vdd-1v8-ap: 1800 mV
[ 0.291616] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.291939] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.308980] SCSI subsystem initialized
[ 0.309161] libata version 3.00 loaded.
[ 0.309365] usbcore: registered new interface driver usbfs
[ 0.309426] usbcore: registered new interface driver hub
[ 0.309535] usbcore: registered new device driver usb
[ 0.313635] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.314087] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.314189] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.315588] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.315714] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.328549] media: Linux media interface: v0.10
[ 0.328622] Linux video capture interface: v2.00
[ 0.332609] pps_core: LinuxPPS API ver. 1 registered
[ 0.332641] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.332684] PTP clock support registered
[ 0.333615] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.333658] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.335156] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.337091] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.337301] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.337426] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.343003] vddio-ddr: at 1125 mV
[ 0.346837] avdd_dsi_csi: 1200 mV
[ 0.350837] vdd-1v8: 1800 mV
[ 0.354835] vdd-3v3-sys: 3300 mV
[ 0.355941] spmic-ldo0: at 1800 mV
[ 0.356730] spmic-ldo1: at 800 mV
[ 0.362835] vddio-3v3: 3300 mV
[ 0.363473] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.365953] vdd-rtc: at 800 mV
[ 0.366647] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.369950] spmic-ldo6: at 1500 mV
[ 0.373947] vdd-pex-1v05: 1000 mV
[ 0.374507] dvdd-pex: 1000 mV
[ 0.374796] max77620 4-003c: max77620 probe successful
[ 0.375089] Advanced Linux Sound Architecture Driver Initialized.
[ 0.376187] en-vdd-sd: 3300 mV
[ 0.376874] en-vdd-cam: 1800 mV
[ 0.381946] vdd-hdmi: 5000 mV
[ 0.382144] vdd-usb0-5v: 5000 mV
[ 0.382333] vdd-usb1-5v: 5000 mV
[ 0.385946] en-vdd-ts-1v8: 1800 mV
[ 0.389946] en-vdd-ts-hv-3v3: 3300 mV
[ 0.390472] en-vdd-disp-3v3: 3300 mV
[ 0.390991] en-mdm-pwr-3v7: 3700 mV
[ 0.391529] en-vdd-disp-1v8: 1800 mV
[ 0.392068] en-vdd-cam-hv-2v8: 2800 mV
[ 0.392602] en-vdd-cam-1v2: 1200 mV
[ 0.393151] vdd-fan: 5000 mV
[ 0.393272] vdd-3v3: 3300 mV
[ 0.394023] dis-vdd-1v2: 1200 mV
[ 0.394143] en-vdd-vcm-2v8: 2800 mV
[ 0.394690] vdd-usb2-5v: 5000 mV
[ 0.394811] vdd-sys-bl: 3300 mV
[ 0.395374] en-vdd-sys: 1200 mV
[ 0.397435] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.399132] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.399537] clocksource: Switched to clocksource arch_sys_counter
[ 0.421471] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.421794] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.422281] nvmap_page_pool_init: Total RAM pages: 2009466
[ 0.422298] nvmap_page_pool_init: nvmap page pool size: 251183 pages (981 MB)
[ 0.422512] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.427457] Wake76 for irq=199
[ 0.427471] Wake77 for irq=199
[ 0.427481] Wake78 for irq=199
[ 0.427491] Wake79 for irq=199
[ 0.427500] Wake80 for irq=199
[ 0.427509] Wake81 for irq=199
[ 0.427518] Wake82 for irq=199
[ 0.428390] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.428606] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.428729] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.428809] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.429223] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.429374] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.429518] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.429679] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.429979] isomgr_init(): iso emc max clk=1866000KHz
[ 0.429990] isomgr_init(): max_iso_bw=26870400KB
[ 0.430086] NET: Registered protocol family 2
[ 0.430434] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.430662] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.430987] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.431046] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.431101] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.431269] NET: Registered protocol family 1
[ 0.431490] RPC: Registered named UNIX socket transport module.
[ 0.431523] RPC: Registered udp transport module.
[ 0.431545] RPC: Registered tcp transport module.
[ 0.431556] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.431576] PCI: CLS 0 bytes, default 128
[ 0.431676] Trying to unpack rootfs image as initramfs…
[ 0.446497] host1x 13e10000.host1x: initialized
[ 0.447400] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.449779] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.449885] audit: initializing netlink subsys (disabled)
[ 0.449918] audit: type=2000 audit(0.436:1): initialized
[ 0.456680] io scheduler noop registered (default)
[ 0.459755] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.461023] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.462140] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.463222] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.467195] tsec 15500000.tsec: initialized
[ 0.468468] tsec 15100000.tsecb: initialized
[ 0.471414] nvdec 15480000.nvdec: initialized
[ 0.475797] falcon 15340000.vic: initialized
[ 0.476870] falcon 154c0000.nvenc: initialized
[ 0.477896] falcon 15380000.nvjpg: initialized
[ 0.478786] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.479297] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.479817] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.480318] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.480815] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.481313] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.481812] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.482311] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.485727] DC OR NODE connected to /host1x/sor1
[ 0.485899] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.485972] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.486003] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.486017] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.486036] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.493828] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.493849] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.493864] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.493909] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.493924] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.494064] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.496652] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.496690] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.496710] PD DISP0 index2 UP
[ 0.497592] PD DISP1 index3 UP
[ 0.497814] PD DISP2 index4 UP
[ 0.497833] kfuse 3830000.kfuse: initialized
[ 0.499347] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.499883] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.501929] console [ttyS0] disabled
[ 0.501979] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.549706] Unsupported HDMI VIC 64, ignoring
[ 0.549716] PD DISP2 index4 DOWN
[ 0.549884] PD DISP1 index3 DOWN
[ 0.550034] PD DISP0 index2 DOWN
[ 0.551976] tegradc 15210000.nvdisplay: probed
[ 2.593034] console [ttyS0] enabled
[ 2.595287] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.596410] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.596665] serial-tegra 3130000.serial: RX in PIO mode
[ 2.597574] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.606789] Console: switching to colour frame buffer device 240x67
[ 2.608144] brd: module loaded
[ 2.612727] loop: module loaded
[ 2.612979] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.612998] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.613010] nct1008_nct72 7-004c: starting parse dt
[ 2.613098] nct1008_nct72 7-004c: success parsing dt
[ 2.613219] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.625721] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.650158] tmp451: Enabled overheat logging at 104.00C
[ 2.650282] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.650350] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.652998] THERMAL EST: found 3 subdevs
[ 2.653002] THERMAL EST num_resources: 0
[ 2.653005] [THERMAL EST subdev 0]
[ 2.653010] [THERMAL EST subdev 1]
[ 2.653014] [THERMAL EST subdev 2]
[ 2.653359] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.653361] THERMAL EST: thz register success.
[ 2.653499] THERMAL EST: end of probe, return err: 0
[ 2.653738] tegra_profiler: Branch: Dev
[ 2.653740] tegra_profiler: Version: 1.109
[ 2.653742] tegra_profiler: Samples version: 37
[ 2.653744] tegra_profiler: IO version: 21
[ 2.653752] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.653755] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.653759] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.653763] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.653766] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.653769] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.653773] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.653776] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.653780] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.653782] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.653785] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.653788] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.653960] tegra_profiler: auth: init
[ 2.657614] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.657626] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.658725] scsi host0: tegra_ahci
[ 2.659100] scsi host1: tegra_ahci
[ 2.659256] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.659259] ata2: DUMMY
[ 2.660243] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.660726] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.661181] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.662089] tun: Universal TUN/TAP device driver, 1.6
[ 2.662091] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.662286] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.662288] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.662328] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.662330] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.663389] PPP generic driver version 2.4.2
[ 2.663519] PPP BSD Compression module registered
[ 2.663556] PPP Deflate Compression module registered
[ 2.663580] PPP MPPE Compression module registered
[ 2.663597] NET: Registered protocol family 24
[ 2.663743] usbcore: registered new interface driver r8152
[ 2.663780] usbcore: registered new interface driver asix
[ 2.663807] usbcore: registered new interface driver ax88179_178a
[ 2.663833] usbcore: registered new interface driver cdc_ether
[ 2.663870] usbcore: registered new interface driver smsc95xx
[ 2.663898] usbcore: registered new interface driver net1080
[ 2.663925] usbcore: registered new interface driver cdc_subset
[ 2.663952] usbcore: registered new interface driver zaurus
[ 2.663999] usbcore: registered new interface driver cdc_ncm
[ 2.664314] Wake76 for irq=199
[ 2.664316] Wake77 for irq=199
[ 2.664319] Wake78 for irq=199
[ 2.664321] Wake79 for irq=199
[ 2.664323] Wake80 for irq=199
[ 2.664324] Wake81 for irq=199
[ 2.664326] Wake82 for irq=199
[ 2.664381] tegra-xotg xotg: usb2 phy is not available yet
[ 2.665158] usbcore: registered new interface driver usb-storage
[ 2.665224] usbcore: registered new interface driver usbserial
[ 2.665250] usbcore: registered new interface driver ftdi_sio
[ 2.665271] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.665299] usbcore: registered new interface driver option
[ 2.665318] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.665343] usbcore: registered new interface driver pl2303
[ 2.665361] usbserial: USB Serial support registered for pl2303
[ 2.665558] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.666668] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c7 5 76
[ 2.667240] libphy: dwc_phy: probed
[ 2.668064] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.728579] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 2.728726] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.784902] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.787120] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.787137] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.787327] i2c /dev entries driver
[ 2.788168] [OV5693]: probing v4l2 sensor.
[ 2.979574] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.262484] tegradc 15210000.nvdisplay: fb registered
[ 3.269340] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.275865] PD DISP0 index2 UP
[ 3.281420] PD DISP1 index3 UP
[ 3.286139] PD DISP2 index4 UP
[ 3.299803] Parent Clock set for DC plld2
[ 3.309392] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 3.461607] Unsupported HDMI VIC 64, ignoring
[ 3.590533] gspca_main: v2.14.0 registered
[ 3.590583] usbcore: registered new interface driver gspca_zc3xx
[ 3.590929] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.592875] FAN dev name: pwm-fan
[ 3.592928] FAN:gpio request success.
[ 3.592935] FAN: can’t find tach_gpio
[ 3.592959] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.593114] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.593119] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.593123] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.593446] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.593450] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.593454] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.593457] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.593460] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.593463] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.593466] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.593469] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.593473] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.593477] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.594266] device-mapper: uevent: version 1.0.3
[ 3.594461] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.594923] sdhci: Secure Digital Host Controller Interface driver
[ 3.594924] sdhci: Copyright(c) Pierre Ossman
[ 3.594928] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.595271] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.595579] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.595854] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.597039] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.597188] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.598782] usbcore: registered new interface driver usbhid
[ 3.598784] usbhid: USB HID core driver
[ 3.602031] nvadsp 2993000.adsp: in probe()…
[ 3.604038] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.604070] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.604282] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.605071] Denver: backdoor interface is NOT available.
[ 3.606919] coresight-tmc 8030000.etf: TMC initialized
[ 3.608014] coresight-tmc 8050000.etr: TMC initialized
[ 3.608389] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.608888] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.609354] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.609784] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.610260] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.610899] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.611473] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.612070] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.612640] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.612667] Module initialized successfully
[ 3.616138] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.617513] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.617788] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.618189] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.618235] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.618278] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.618318] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.618355] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.618395] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.618435] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.618591] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.618593] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.619666] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.619669] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.619672] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.619675] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.619677] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.619680] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.619683] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.619711] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.623747] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.624517] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.624619] camchar: rtcpu character device driver loaded
[ 3.628388] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.628639] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.628740] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.629109] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.629136] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.629161] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.629186] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.629216] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.629241] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.629267] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.629292] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.629319] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.629343] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.629367] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.629394] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.629423] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.629449] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.629474] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.629524] **** A57 ECC: Enabled
[ 3.629527] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 3.629672] parse_throttle_dt_data: Num cap clks = 4
[ 3.629674] parse_throttle_dt_data: clk=mcpu type=1
[ 3.629676] parse_throttle_dt_data: clk=bcpu type=2
[ 3.629683] parse_throttle_dt_data: clk=gpu type=4
[ 3.629685] parse_throttle_dt_data: clk=emc type=3
[ 3.630178] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.630274] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.631559] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.632736] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.632828] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.632985] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.633267] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.635739] tegra-se-nvhost 15810000.se: initialized
[ 3.636275] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.636666] tegra-se-nvhost 15820000.se: initialized
[ 3.637195] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.637539] tegra-se-nvhost 15830000.se: initialized
[ 3.637673] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.637984] tegra-se-nvhost 15840000.se: initialized
[ 3.638359] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.642510] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.646228] cpufreq: platform driver Initialization: pass
[ 3.646409] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.646467] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.646682] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.646687] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.646726] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30c096
[ 3.646730] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 3.647937] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.648520] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.649113] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.651046] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.651161] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.652079] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.652081] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.655159] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.655736] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.655957] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.656261] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.656513] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.659734] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.659739] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.659740] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.667090] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.667090] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.667208] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.667554] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.667751] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.667797] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.667873] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.667893] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.668072] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.671571] OPE platform probe
[ 3.671650] OPE platform probe successful
[ 3.681483] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 3.701588] mmc0: MAN_BKOPS_EN bit is not set
[ 3.707640] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.707677] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.708961] mmc0: Skipping tuning since strobe enabled
[ 3.717569] mmc0: periodic cache flush enabled
[ 3.717579] mmc0: new HS400 MMC card at address 0001
[ 3.717891] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.718029] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.718174] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.718258] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.719339] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 3.748940] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.749121] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.749268] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.749413] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.749531] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.749657] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.749773] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.749872] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.749974] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.750083] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.750203] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.750306] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.750415] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.750518] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.750640] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.750739] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.750846] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.750947] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.751057] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.751175] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.755796] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.755919] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.755978] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.755982] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.756039] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.797622] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.798378] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.798382] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.799087] GACT probability NOT on
[ 3.799099] Mirror/redirect action on
[ 3.799111] u32 classifier
[ 3.799112] Actions configured
[ 3.799136] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.799929] ipip: IPv4 over IPv4 tunneling driver
[ 3.800277] Initializing XFRM netlink socket
[ 3.800649] NET: Registered protocol family 10
[ 3.801396] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.801458] NET: Registered protocol family 17
[ 3.801474] NET: Registered protocol family 15
[ 3.801497] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.801503] 8021q: 802.1Q VLAN Support v1.8
[ 3.801822] Registered cp15_barrier emulation handler
[ 3.801842] Registered setend emulation handler
[ 3.803643] registered taskstats version 1
[ 3.807783] isp 15600000.isp: initialized
[ 3.812280] nvcsi 150c0000.nvcsi: initialized
[ 3.813431] Wake76 for irq=199
[ 3.813432] Wake77 for irq=199
[ 3.813433] Wake78 for irq=199
[ 3.813433] Wake79 for irq=199
[ 3.813434] Wake80 for irq=199
[ 3.813435] Wake81 for irq=199
[ 3.813435] Wake82 for irq=199
[ 3.813800] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.813802] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.835601] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.835603] xhci-tegra 3530000.xhci: Falling back to user helper
[ 3.835958] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.836713] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.837378] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.838083] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 3.838134] tegra-xotg xotg: update_id_state: ID grounded
[ 3.838139] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 3.838154] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 3.840078] tegra-xotg xotg: otg: gadget gadget registered
[ 3.840080] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 3.840082] tegra-xotg xotg: otg: host not registered yet
[ 3.840083] tegra-xotg xotg: otg: start OTG finite state machine
[ 3.840133] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.840171] tegra-xotg xotg: FSM: can’t move to a_idle, host isn’t ready
[ 3.840762] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.840946] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.841034] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 3.841097] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.841243] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.875657] tegra_rtc c2a0000.rtc: setting system clock to 2019-03-31 17:34:56 UTC (1554053696)
[ 3.909525] bpmp: mounted debugfs mirror
[ 3.910003] [dram-timers] DRAM derating cdev registered.
[ 3.914328] spmic-ldo0: disabling
[ 3.914551] spmic-ldo1: disabling
[ 3.914702] en-vdd-cam: disabling
[ 3.914705] vdd-usb0-5v: disabling
[ 3.914707] vdd-usb1-5v: disabling
[ 3.914710] en-vdd-disp-3v3: disabling
[ 3.914711] en-mdm-pwr-3v7: disabling
[ 3.914713] en-vdd-disp-1v8: disabling
[ 3.914714] en-vdd-cam-hv-2v8: disabling
[ 3.914716] en-vdd-cam-1v2: disabling
[ 3.914717] vdd-fan: disabling
[ 3.914719] vdd-3v3: disabling
[ 3.914721] en-vdd-vcm-2v8: disabling
[ 3.914722] vdd-usb2-5v: disabling
[ 3.914724] vdd-sys-bl: disabling
[ 3.914725] en-vdd-sys: disabling
[ 3.921875] ALSA device list:
[ 3.921877] #0: tegra-hda at 0x3518000 irq 400
[ 3.921879] #1: tegra-snd-t186ref-mobile-rt565x
[ 3.923688] tegra-vi4 15700000.vi: initialized
[ 3.953391] mmc1 tuning done saved tap delay=60
[ 3.953393] mmc1: hw tuning done …
[ 3.953399] mmc1: tuning_window[0]: 0xffffffff
[ 3.953404] mmc1: tuning_window[1]: 0xfffffe3f
[ 3.953408] mmc1: tuning_window[2]: 0xfffcffff
[ 3.953413] mmc1: tuning_window[3]: 0x78ffffff
[ 3.953438] mmc1: tuning_window[4]: 0x0
[ 3.953442] mmc1: tuning_window[5]: 0x0
[ 3.953446] mmc1: tuning_window[6]: 0x0
[ 3.953450] mmc1: tuning_window[7]: 0x0
[ 3.953453] sdhci: Tap value: 60 | Trim value: 5
[ 3.953456] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.959115] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.959158] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 11.444461] random: nonblocking pool is initialized
[ 12.395887] tegradc 15210000.nvdisplay: hdmi: plugged
[ 12.399803] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.399817] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 12.401648] devtmpfs: mounted
[ 12.401940] Freeing unused kernel memory: 1164K (ffffffc0010cd000 - ffffffc0011f0000)
[ 12.401964] Freeing alternatives memory: 96K (ffffffc0011f0000 - ffffffc001208000)
[ 12.461384] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 12.481476] systemd[1]: Detected architecture arm64.
[ 12.497375] systemd[1]: Set hostname to .
[ 12.603563] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.614190] systemd[1]: Reached target Remote File Systems (Pre).
[ 12.623889] systemd[1]: Listening on Journal Audit Socket.
[ 12.632970] systemd[1]: Listening on udev Kernel Socket.
[ 12.641829] systemd[1]: Reached target Swap.
[ 12.649716] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.662461] systemd[1]: Created slice User and Session Slice.
[ 12.671008] systemd[1]: Reached target Encrypted Volumes.
[ 12.679344] systemd[1]: Created slice System Slice.
[ 12.687015] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.695895] systemd[1]: Reached target Remote File Systems.
[ 12.704258] systemd[1]: Listening on Syslog Socket.
[ 12.712040] systemd[1]: Listening on Journal Socket.
[ 12.720955] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 12.732432] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 12.746218] systemd[1]: Started Braille Device Support.
[ 12.759726] systemd[1]: Starting Load Kernel Modules…
[ 12.770077] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 12.771420] systemd[1]: Reached target User and Group Name Lookups.
[ 12.789873] systemd[1]: Listening on udev Control Socket.
[ 12.798937] systemd[1]: Reached target Slices.
[ 12.809151] systemd[1]: Mounting Debug File System…
[ 12.819910] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.830563] systemd[1]: Starting Journal Service…
[ 12.839183] systemd[1]: Created slice system-getty.slice.
[ 12.850261] systemd[1]: Mounted Debug File System.
[ 12.859052] systemd[1]: Started Remount Root and Kernel File Systems.
[ 12.869684] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 12.883765] systemd[1]: Started Load Kernel Modules.
[ 12.892974] systemd[1]: Started Journal Service.
[ 12.970261] systemd-journald[275]: Received request to flush runtime journal from PID 1
[ 13.113419] cfg80211: World regulatory domain updated:
[ 13.121345] cfg80211: DFS Master region: unset
[ 13.121345] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 13.121349] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.121351] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.121352] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.121355] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 13.121357] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 13.121359] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.121360] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.121362] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 13.210531] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 13.212123] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 13.213213] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 13.215447] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 13.262885] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 13.400312] dhd_module_init in
[ 13.407400] tegra_net_perf_init: cannot get wifi sclk
[ 13.420276] found wifi platform device bcmdhd_wlan
[ 13.421810] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 13.421819] wifi_platform_get_country_code_map: could not get country_code_map
[ 13.421820] wifi_plat_dev_drv_probe:platform country code map is not available
[ 13.421835] Power-up adapter ‘DHD generic adapter’
[ 13.421840] wifi_platform_set_power = 1
[ 13.623573] wifi_platform_bus_enumerate device present 1
[ 13.641665] wifi_platform_bus_enumerate device present 0
[ 13.642087] F1 signature read @0x18000000=0x17214354
[ 13.646140] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 13.646799] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 13.646863] wifi_platform_prealloc: failed to alloc static mem section 7
[ 13.646869] wifi_platform_get_mac_addr
[ 13.647968] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 13.648176] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 13.648304] wl_create_event_handler(): thread:wl_event_handler:212 started
[ 13.648401] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc07a361a70
[ 13.648493] dhd_attach(): thread:dhd_watchdog_thread:213 started
[ 13.648524] dhd_attach(): thread:dhd_dpc:214 started
[ 13.648570] dhd_attach(): thread:dhd_rxf:215 started
[ 13.648576] dhd_deferred_work_init: work queue initialized
[ 13.648791] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Jul 28 2017 at 09:53:35
[ 13.649102] tegra_sysfs_register
[ 13.649129] Register interface [wlan0] MAC: 00:04:4b:c7:05:74
[ 13.649133] dhd_prot_ioctl : bus is down. we have nothing to do
[ 13.649244] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[ 13.650296] wifi_platform_set_power = 0
[ 14.051541] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 14.257593] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-03-31 06:21:56 UTC, Version: 55.07 release
[ 14.259572] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 14.259589] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 14.260410] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 14.260433] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 14.260570] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 14.260572] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.260575] usb usb1: Product: xHCI Host Controller
[ 14.260576] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 14.260578] usb usb1: SerialNumber: 3530000.xhci
[ 14.260883] hub 1-0:1.0: USB hub found
[ 14.260907] hub 1-0:1.0: 4 ports detected
[ 14.275811] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 14.275820] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 14.275969] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 14.275972] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.275974] usb usb2: Product: xHCI Host Controller
[ 14.275977] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 14.275978] usb usb2: SerialNumber: 3530000.xhci
[ 14.276265] hub 2-0:1.0: USB hub found
[ 14.276284] hub 2-0:1.0: 3 ports detected
[ 14.276680] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 14.287811] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 14.453570] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 14.455563] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 14.571549] usb 1-1: new high-speed USB device number 2 using xhci-tegra
[ 14.705891] usb 1-1: New USB device found, idVendor=0ea0, idProduct=2209
[ 14.705894] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 14.705896] usb 1-1: Product: Easy Suite
[ 14.705898] usb 1-1: Manufacturer:
[ 14.705900] usb 1-1: SerialNumber: F06058974C700020
[ 14.706518] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 14.706763] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 14.706901] scsi host2: usb-storage 1-1:1.0
[ 14.815544] usb 1-2: new high-speed USB device number 3 using xhci-tegra
[ 14.857190] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 14.952794] usb 1-2: New USB device found, idVendor=05e3, idProduct=0608
[ 14.952798] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 14.952802] usb 1-2: Product: USB2.0 Hub
[ 14.953814] hub 1-2:1.0: USB hub found
[ 14.954082] hub 1-2:1.0: 4 ports detected
[ 15.227552] usb 1-2.2: new low-speed USB device number 4 using xhci-tegra
[ 15.265024] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 15.322395] usb 1-2.2: New USB device found, idVendor=045e, idProduct=00e3
[ 15.322399] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 15.322402] usb 1-2.2: Product: Microsoft Wireless Optical Desktop® 2.20
[ 15.322403] usb 1-2.2: Manufacturer: Microsft
[ 15.322616] usb 1-2.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 15.322632] usb 1-2.2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 15.326342] input: Microsft Microsoft Wireless Optical Desktop® 2.20 as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:045E:00E3.0001/input/input4
[ 15.379844] hid-generic 0003:045E:00E3.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsft Microsoft Wireless Optical Desktop® 2.20] on usb-3530000.xhci-2.2/input0
[ 15.400558] input: Microsft Microsoft Wireless Optical Desktop® 2.20 as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:045E:00E3.0002/input/input5
[ 15.455756] hid-generic 0003:045E:00E3.0002: input,hidraw1: USB HID v1.11 Mouse [Microsft Microsoft Wireless Optical Desktop® 2.20] on usb-3530000.xhci-2.2/input1
[ 15.527552] usb 1-2.3: new full-speed USB device number 5 using xhci-tegra
[ 15.671869] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 15.673888] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 15.673896] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 15.674096] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 15.705088] scsi 2:0:0:0: CD-ROM Easy Suite 2.00 PQ: 0 ANSI: 0
[ 15.923646] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 15.923649] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 15.939547] usb 1-2.3: new full-speed USB device number 6 using xhci-tegra
[ 16.030412] usb 1-2.3: New USB device found, idVendor=1b1c, idProduct=1b3d
[ 16.030415] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 16.030418] usb 1-2.3: Product: Corsair Gaming K55 RGB Keyboard
[ 16.030419] usb 1-2.3: Manufacturer: Corsair
[ 16.030421] usb 1-2.3: SerialNumber: AF060044589324E4F500194140048000
[ 16.032414] input: Corsair Corsair Gaming K55 RGB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.0/0003:1B1C:1B3D.0003/input/input6
[ 16.087779] hid-generic 0003:1B1C:1B3D.0003: input,hidraw2: USB HID v1.11 Keyboard [Corsair Corsair Gaming K55 RGB Keyboard] on usb-3530000.xhci-2.3/input0
[ 16.899427] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 16.899502]
[ 16.899504] wl_android_wifi_on in
[ 16.899507] wifi_platform_set_power = 1
[ 17.022236] gk20a 17000000.gp10b: railgate is disabled.
[ 17.172952] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 17.243808] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[ 17.245055] F1 signature read @0x18000000=0x17214354
[ 17.253472] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 17.254696] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 17.382264] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 17.444902] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 17.445450] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 17.445543] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 17.445549] Enabling wake69
[ 17.446925] wifi_platform_get_mac_addr
[ 17.450114] Firmware up: op_mode=0x0005, MAC=00:04:4b:c7:05:74
[ 17.459723] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 17.466993] Firmware version = wl0: May 4 2017 13:48:00 version 7.35.221.21 (r697384) FWID 01-58d9d0b3
[ 17.470841] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 17.471207] tegra_sysfs_on
[ 17.566548] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.568560] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 17.570557] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.662664] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 17.680257] WLC_E_IF: NO_IF set, event Ignored
[ 18.222589] CPU1: shutdown
[ 18.225368] psci: CPU1 killed.
[ 18.253709] CPU2: shutdown
[ 18.256507] psci: CPU2 killed.
[ 18.360861] PD DISP2 index4 DOWN
[ 18.361045] PD DISP1 index3 DOWN
[ 18.361133] PD DISP0 index2 DOWN
[ 18.371727] PD DISP0 index2 UP
[ 18.372694] PD DISP1 index3 UP
[ 18.374897] PD DISP2 index4 UP
[ 18.377426] Parent Clock set for DC plld2
[ 18.379412] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 20.821381] fuse init (API version 7.23)
[ 21.034374] CFG80211-ERROR) wl_cfg80211_connect : Connectting withc0:c1:c0:9d:9c:ae channel (9) ssid “GEB314”, len (6)
[ 21.102491] wl_bss_connect_done succeeded with c0:c1:c0:9d:9c:ae
[ 21.149412] wl_bss_connect_done succeeded with c0:c1:c0:9d:9c:ae
[ 21.214120] dhd_ndo_add_ip: ndo ip addr add failed, retcode = -23
[ 21.220317] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 26.087937] hid-generic 0003:1B1C:1B3D.0004: usb_submit_urb(ctrl) failed: -1
[ 26.095063] hid-generic 0003:1B1C:1B3D.0004: timeout initializing reports
[ 26.102476] input: Corsair Corsair Gaming K55 RGB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.3/1-2.3:1.1/0003:1B1C:1B3D.0004/input/input7
[ 26.167838] hid-generic 0003:1B1C:1B3D.0004: input,hidraw3: USB HID v1.11 Keyboard [Corsair Corsair Gaming K55 RGB Keyboard] on usb-35
