I just flashed the board with R28.1. After booting, on of USB ports stopped working.
Did anyone have the same problem? How can I fix it?
Can you post a copy of “dmesg” after a fresh boot? I’m assuming you can use ssh or serial console if USB keyboard is failing.
Also, does your keyboard have any lights which function when you toggle caps lock or num lock?
When I toggle caps lock or num lock, the lights don’t function.
This dmesg:
[code]
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38+ (mmalc@mmalc-VirtualBox) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Wed Jul 26 15:11:21 CEST 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] On node 0 totalpages: 1043456
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=c001ff17000000248997 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3372524K/4173824K available (11017K kernel code, 1804K rwdata, 6404K rodata, 1208K init, 645K bss, 96788K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
.init : 0xffffffc001184000 - 0xffffffc0012b2000 ( 1208 KB)
.text : 0xffffffc000080000 - 0xffffffc001183c04 ( 17424 KB)
.data : 0xffffffc0012cc000 - 0xffffffc00148f1b0 ( 1805 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001708] Console: colour dummy device 80x25
[ 0.002576] console [tty0] enabled
[ 0.002607] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002644] pid_max: default: 32768 minimum: 301
[ 0.002731] Security Framework initialized
[ 0.002751] SELinux: Initializing.
[ 0.002823] SELinux: Starting in permissive mode
[ 0.002861] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002886] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003552] Initializing cgroup subsys freezer
[ 0.003582] Initializing cgroup subsys debug
[ 0.003852] CPU0 ipc=1024
[ 0.003889] CPU1 ipc=1024
[ 0.003921] CPU2 ipc=1024
[ 0.003953] CPU3 ipc=1024
[ 0.004016] ASID allocator initialised with 65536 entries
[ 0.027048] tegra-id: chipid=22117.
[ 0.027076] tegra-id: opt_subrevision=0.
[ 0.027106] Tegra Speedo/IDDQ fuse revision 4
[ 0.027125] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.027146] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.027167] Tegra: CPU Speedo Value 2021, SoC Speedo Value 1907, GPU Speedo Value 2020
[ 0.027195] Tegra: CPU IDDQ Value 1940, SoC IDDQ Value 2060, GPU IDDQ Value 2600
[ 0.027236] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.028572] DTS File Name: /home/mmalc/jetpack31/64_TX1/Linux_for_Tegra_64_tx1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.028623] DTB Build time: Jul 26 2017 15:23:05
[ 0.044815] CPU1: Booted secondary processor [411fd071]
[ 0.056781] CPU2: Booted secondary processor [411fd071]
[ 0.068781] CPU3: Booted secondary processor [411fd071]
[ 0.068865] Brought up 4 CPUs
[ 0.068931] SMP: Total of 4 processors activated.
[ 0.068955] CPU: All CPU(s) started at EL2
[ 0.068995] alternatives: patching kernel code
[ 0.071408] devtmpfs: initialized
[ 0.143264] Initilizing CustomIPI irq domain
[ 0.143612] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.155995] pinctrl core: initialized pinctrl subsystem
[ 0.156263] OS set in device tree is L4T.
[ 0.156657] regulator-dummy: no parameters
[ 0.156881] Initializing plugin-manager
[ 0.156953] Plugin module not found
[ 0.158490] node /plugin-manager/fragement@4 match with odm-data l4t
[ 0.158744] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[ 0.159301] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.159347] Adding domain adsp-pd to PM domain ape-pd
[ 0.164681] NET: Registered protocol family 16
[ 0.166493] console [pstore-1] enabled
[ 0.166515] pstore: Registered ramoops as persistent store backend
[ 0.166539] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.176242] cpuidle: using governor ladder
[ 0.188230] cpuidle: using governor menu
[ 0.188601] bpmp: mail init ok
[ 0.189718] vdso: 2 pages (1 code @ ffffffc0012d1000, 1 data @ ffffffc0012d0000)
[ 0.189778] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.192133] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.193106] tegra_powergate_init: DONE
[ 0.193147] DTS File Name: /home/mmalc/jetpack31/64_TX1/Linux_for_Tegra_64_tx1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.193199] DTB Build time: Jul 26 2017 15:23:05
[ 0.194230] Error: Driver ‘tegra-mc’ is already registered, aborting…
[ 0.195880] platform tegra-carveouts: SMMU isn’t ready yet
[ 0.196659] platform tegra-carveouts: domain=ffffffc0fa178318 allocates as[0]=ffffffc0fa18c0a8
[ 0.196729] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.196969] platform smmu_test: domain=ffffffc0fa178618 allocates as[0]=ffffffc0fa18c110
[ 0.197308] platform 70016000.bpmp: domain=ffffffc0fa178918 allocates as[0]=ffffffc0fa18c178
[ 0.198029] bpmp: ping status is 0
[ 0.198134] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.198393] bpmp 70016000.bpmp: probe ok
[ 0.199064] mc: mapped MMIO address: 0xffffff800007e000 → 0x70019000
[ 0.199170] mc: mapped MMIO address: 0xffffff80000b6000 → 0x7001c000
[ 0.199269] mc: mapped MMIO address: 0xffffff80000dc000 → 0x7001d000
[ 0.199357] mc-err: Set intmask: 0x23d40
[ 0.210900] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.210947] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.210992] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.211033] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.211075] GPIO line 148 (cam0-rst) hogged as output/low
[ 0.211114] GPIO line 151 (cam0-pwdn) hogged as output/low
[ 0.211152] GPIO line 149 (cam1-rst) hogged as output/low
[ 0.211190] GPIO line 152 (cam1-pwdn) hogged as output/low
[ 0.211310] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.213849] platform 70006000.serial: domain=ffffffc0fa189e18 allocates as[0]=ffffffc0fa18c1e0
[ 0.214993] platform sound: domain=ffffffc0fa1f0718 allocates as[0]=ffffffc0fa18c248
[ 0.217481] platform tegradc.1: domain=ffffffc0fa234918 allocates as[0]=ffffffc0fa18c2b0
[ 0.218091] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.220869] platform 57000000.gpu: domain=ffffffc0fa262d18 allocates as[0]=ffffffc0fa18c318
[ 0.220948] platform 57000000.gpu: domain=ffffffc0fa262d18 allocates as[1]=ffffffc0fa18c380
[ 0.221022] platform 57000000.gpu: domain=ffffffc0fa262d18 allocates as[2]=ffffffc0fa18c3e8
[ 0.221090] platform 57000000.gpu: domain=ffffffc0fa262d18 allocates as[3]=ffffffc0fa18c450
[ 0.221873] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.221917] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.221942] tegra-pmc: ### PMC reset source: Power on reset
[ 0.221963] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.222341] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.222375] tegra-pmc: Clear bootloader IO dpd settings
[ 0.224347] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[ 0.228324] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[ 0.232323] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[ 0.236321] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[ 0.236351] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[ 0.240322] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[ 0.244321] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[ 0.248320] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[ 0.248350] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[ 0.252320] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[ 0.256324] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[ 0.256350] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.256420] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.259550] platform 1003000.pcie-controller: domain=ffffffc0fa26ae18 allocates as[0]=ffffffc0fa18c4b8
[ 0.261913] platform sdhci-tegra.3: domain=ffffffc0fa272f18 allocates as[0]=ffffffc0fa18c520
[ 0.262523] platform sdhci-tegra.0: domain=ffffffc0fa278318 allocates as[0]=ffffffc0fa18c588
[ 0.267961] vdd-ac-bat: 5000 mV
[ 0.269238] vdd-cpu-fixed: 1000 mV
[ 0.273179] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.273532] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.297491] ACPI: Interpreter disabled.
[ 0.298317] SCSI subsystem initialized
[ 0.298388] libata version 3.00 loaded.
[ 0.298611] usbcore: registered new interface driver usbfs
[ 0.298685] usbcore: registered new interface driver hub
[ 0.298787] usbcore: registered new device driver usb
[ 0.301421] tegra-i2c 7000c400.i2c: no acknowledge from address 0x74
[ 0.301493] pca953x 1-0074: failed reading register
[ 0.301576] pca953x: probe of 1-0074 failed with error -121
[ 0.302034] tegra-i2c 7000c400.i2c: no acknowledge from address 0x77
[ 0.302100] pca953x 1-0077: failed reading register
[ 0.302170] pca953x: probe of 1-0077 failed with error -121
[ 0.304832] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.306640] GPIO line 506 (spmic-default-output-high) hogged as output/high
[ 0.306763] gpiochip_add_data: registered GPIOs 504 to 511 on device: max77620-gpio
[ 0.312407] vdd-core: 600 <–> 1400 mV at 1125 mV
[ 0.316351] vddio-ddr: at 1125 mV
[ 0.317202] vdd-pre-reg: 1350 mV
[ 0.320225] vdd-1v8: 1800 mV
[ 0.324227] avdd-sys: 1200 mV
[ 0.328227] vdd-pex: 1050 mV
[ 0.328866] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.329712] vdd-cam-hv: 2800 mV
[ 0.332226] vdd-rtc: 850 mV
[ 0.333068] avdd-ts-hv: 3300 mV
[ 0.333907] vdd-ts: 1800 mV
[ 0.336227] vdd-gen-pll-edp: 1050 mV
[ 0.340226] vdd-hdmi-dp: 1050 mV
[ 0.340876] max77620 4-003c: max77620 probe successful
[ 0.342860] media: Linux media interface: v0.10
[ 0.342938] Linux video capture interface: v2.00
[ 0.350805] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.351146] Advanced Linux Sound Architecture Driver Initialized.
[ 0.354604] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.354654] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.354742] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.354785] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.357673] regulator_get() failed for (dvfs,vdd-cpu), -19
[ 0.357701] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.360233] vdd-3v3: 3300 mV
[ 0.364224] max77620-gpio7: 1050 mV
[ 0.364548] lcd-bl-en: 1800 mV
[ 0.364876] en-vdd-sd: 3300 mV
[ 0.368226] vdd-sys-boost: 5000 mV
[ 0.368614] aux-3v3: 3300 mV
[ 0.368847] snsr_pm: 3300 mV
[ 0.372227] vdd-disp-3v0: 3000 mV
[ 0.372647] usb-vbus1: 5000 mV
[ 0.373677] rtl-5v0: 5000 mV
[ 0.373969] en-usb-vbus2: 5000 mV
[ 0.374372] en-vdd-vcm-2v8: 2800 mV
[ 0.377150] extcon-gpio-states extcon:extcon@1: Cable state 2
[ 0.378530] clocksource: Switched to clocksource arch_sys_counter
[ 0.417682] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.418070] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.418259] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.418287] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.418318] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.418378] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.418413] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.418758] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.419474] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.420174] pnp: PnP ACPI: disabled
[ 0.432124] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.433951] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.434355] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.434619] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.436219] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.436480] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.436712] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.437861] isomgr_init(): iso emc max clk=1600000KHz
[ 0.437885] isomgr_init(): max_iso_bw=11520000KB
[ 0.438024] NET: Registered protocol family 2
[ 0.438637] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.438823] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.439094] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.439196] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.439259] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.439512] NET: Registered protocol family 1
[ 0.439827] RPC: Registered named UNIX socket transport module.
[ 0.439853] RPC: Registered udp transport module.
[ 0.439874] RPC: Registered tcp transport module.
[ 0.439894] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.439932] PCI: CLS 0 bytes, default 128
[ 0.440137] Trying to unpack rootfs image as initramfs…
[ 0.451275] host1x 50000000.host1x: initialized
[ 0.453108] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.456352] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.456478] audit: initializing netlink subsys (disabled)
[ 0.456538] audit: type=2000 audit(0.451:1): initialized
[ 0.468643] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.469133] fuse init (API version 7.23)
[ 0.469644] SELinux: Registering netfilter hooks
[ 0.471864] io scheduler noop registered (default)
[ 0.471898] io scheduler deadline registered
[ 0.472223] io scheduler cfq registered
[ 0.477710] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.477758] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x9228c13
[ 0.477792] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.479309] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.479346] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.479375] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.479411] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.479457] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.479491] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.479526] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.479568] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.479613] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.479660] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.479705] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.479751] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.479796] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.479843] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.480268] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.481298] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[ 0.482396] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.483200] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.487690] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.487758] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.487786] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.491260] tsec 54500000.tsec: initialized
[ 0.492588] tsec 54100000.tsecb: initialized
[ 0.495416] nvdec 54480000.nvdec: initialized
[ 0.500811] falcon 54340000.vic: initialized
[ 0.502538] falcon 544c0000.nvenc: initialized
[ 0.503683] falcon 54380000.nvjpg: initialized
[ 0.505617] DC OR NODE connected to /host1x/sor1
[ 0.505712] display board info: id 0xffff, fab 0x0
[ 0.505766] panel_select fail by _node_status
[ 0.505824] display board info: id 0xffff, fab 0x0
[ 0.505870] panel_select fail by _node_status
[ 0.506047] tegradc tegradc.1: DT parsed successfully
[ 0.506104] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
[ 0.506432] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.507218] display board info: id 0xffff, fab 0x0
[ 0.507274] panel_select fail by _node_status
[ 0.507367] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.507601] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[ 0.512202] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.514206] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.515743] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.516044] kfuse 7000fc00.kfuse: initialized
[ 0.517888] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.518917] clk_cbus_round_rate: no gbus parent
[ 0.518945] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.519460] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.519493] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.519555] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.520706] vdd-gpu: applied init 1000000uV constraint
[ 0.520738] vdd-gpu: 710 <–> 1320 mV at 1000 mV
[ 0.520799] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.521201] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.521347] No Device Node present for smmu client: serial8250 !!
[ 0.521376] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.521413] No Device Node present for smmu client: serial8250 !!
[ 0.521437] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.522513] No Device Node present for smmu client: serial8250 !!
[ 0.522599] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.522650] No Device Node present for smmu client: serial8250 !!
[ 0.522676] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.523322] console [ttyS0] disabled
[ 0.523389] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 0.533673] Unsupported HDMI VIC 208, ignoring
[ 0.533677] Unsupported HDMI VIC 114, ignoring
[ 0.533679] Unsupported HDMI VIC 28, ignoring
[ 0.533682] Unsupported HDMI VIC 22, ignoring
[ 0.534853] tegradc tegradc.1: probed
[ 2.555175] console [ttyS0] enabled
[ 2.556555] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 2.557026] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 2.557371] serial-tegra 70006300.serial: RX in PIO mode
[ 2.557473] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 2.563918] gk20a 57000000.gpu: platform probe failed
[ 2.569658] brd: module loaded
[ 2.575185] loop: module loaded
[ 2.575792] zram: Added device: zram0
[ 2.575804] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[ 2.576008] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.576014] nct1008_nct72 0-004c: starting parse dt
[ 2.576090] nct1008_nct72 0-004c: success parsing dt
[ 2.576331] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 2.581130] Console: switching to colour frame buffer device 240x67
[ 2.662879] tmp451: Enabled overheat logging at 102.00C
[ 2.669250] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 2.703317] tegradc tegradc.1: fb registered
[ 2.708861] THERMAL EST: found 2 subdevs
[ 2.712893] THERMAL EST num_resources: 0
[ 2.716906] [THERMAL EST subdev 0]
[ 2.720386] [THERMAL EST subdev 1]
[ 2.724213] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.732080] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 2.732943] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 2.752025] THERMAL EST: thz register success.
[ 2.756713] THERMAL EST: end of probe, return err: 0
[ 2.761867] tegra_profiler: Branch: Dev
[ 2.765791] tegra_profiler: Version: 1.109
[ 2.769975] tegra_profiler: Samples version: 37
[ 2.774599] tegra_profiler: IO version: 21
[ 2.778783] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.783235] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.790331] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.794811] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.801914] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.806364] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.813459] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.823342] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.836076] tegra_profiler: auth: init
[ 2.845871] tegra-ahci 70027000.sata: Missing devslp-active state
[ 2.855987] Unsupported HDMI VIC 208, ignoring
[ 2.855990] Unsupported HDMI VIC 114, ignoring
[ 2.855993] Unsupported HDMI VIC 28, ignoring
[ 2.855995] Unsupported HDMI VIC 22, ignoring
[ 2.898698] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 2.903356] spi-tegra114 7000d400.spi: Static pin configuration used
[ 2.904248] spi-tegra114 7000da00.spi: Static pin configuration used
[ 2.905787] tun: Universal TUN/TAP device driver, 1.6
[ 2.905791] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.906278] PPP generic driver version 2.4.2
[ 2.906468] PPP BSD Compression module registered
[ 2.906479] PPP Deflate Compression module registered
[ 2.906509] PPP MPPE Compression module registered
[ 2.906558] NET: Registered protocol family 24
[ 2.906665] usbcore: registered new interface driver r8152
[ 2.906728] usbcore: registered new interface driver asix
[ 2.906775] usbcore: registered new interface driver ax88179_178a
[ 2.906828] usbcore: registered new interface driver cdc_ether
[ 2.906890] usbcore: registered new interface driver smsc95xx
[ 2.906936] usbcore: registered new interface driver net1080
[ 2.906982] usbcore: registered new interface driver cdc_subset
[ 2.907028] usbcore: registered new interface driver zaurus
[ 2.907113] usbcore: registered new interface driver cdc_ncm
[ 2.907265] usbcore: registered new interface driver usb-storage
[ 2.907371] usbcore: registered new interface driver usbserial
[ 2.907420] usbcore: registered new interface driver ftdi_sio
[ 2.907455] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.907497] usbcore: registered new interface driver option
[ 2.907528] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.907570] usbcore: registered new interface driver pl2303
[ 2.907599] usbserial: USB Serial support registered for pl2303
[ 2.908813] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 2.918646] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 3.076072] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 3.098878] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 3.098911] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.099473] i2c /dev entries driver
[ 3.101482] IR NEC protocol handler initialized
[ 3.101492] IR Sharp protocol handler initialized
[ 3.101501] IR XMP protocol handler initialized
[ 3.101594] usbcore: registered new interface driver uvcvideo
[ 3.101596] USB Video Class driver (1.1.1)
[ 3.107068] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.183218] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.183225] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 3.183779] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.183815] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.183826] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.184046] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.184058] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.184066] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.184323] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.184329] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 3.184337] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.184344] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.184755] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.186406] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.186478] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.186487] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.186494] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.187334] FAN: coudln’t get the regulator
[ 3.188476] tegra-wdt 60005000.timer: initialized (heartbeat = 120 sec, nowayout = 1)
[ 3.188950] device-mapper: uevent: version 1.0.3
[ 3.189304] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.197260] sdhci: Secure Digital Host Controller Interface driver
[ 3.197263] sdhci: Copyright(c) Pierre Ossman
[ 3.197274] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.204692] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 3.204762] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 3.205147] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 3.207530] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.208211] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.210948] usbcore: registered new interface driver usbhid
[ 3.210950] usbhid: USB HID core driver
[ 3.218191] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
[ 3.218242] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[ 3.218579] ina3221x: probe of 1-0042 failed with error -121
[ 3.229086] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
[ 3.229135] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
[ 3.229436] ina3221x: probe of 1-0043 failed with error -121
[ 3.229919] parse_throttle_dt_data: Num cap clks = 6
[ 3.229925] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.229935] parse_throttle_dt_data: clk=gpu type=4
[ 3.229974] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.230009] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.230049] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.230053] parse_throttle_dt_data: clk=emc type=3
[ 3.240121] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.240392] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.241395] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.242954] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 3.251008] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.251016] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.251025] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.251031] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.251261] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.251268] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.251306] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.251312] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.275664] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 3.285403] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 3.285692] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 3.286087] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 3.291381] OPE platform probe
[ 3.291571] OPE platform probe successful
[ 3.291625] OPE platform probe
[ 3.291797] OPE platform probe successful
[ 3.293582] tegra-snd-t210ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 3.328837] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.329076] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.329300] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.329530] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.329756] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.329987] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.330214] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.330440] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.330696] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.330926] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.333532] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 3.334027] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 3.334049] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 3.357354] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input1
[ 3.357903] tegra-snd-t210ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.357908] tegra-snd-t210ref-mobile-rt565x sound: This is a dummy codec
[ 3.358783] GACT probability NOT on
[ 3.358795] Mirror/redirect action on
[ 3.358812] u32 classifier
[ 3.358814] Actions configured
[ 3.358827] Netfilter messages via NETLINK v0.30.
[ 3.358880] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.359311] ctnetlink v0.93: registering with nfnetlink.
[ 3.359947] xt_time: kernel timezone is -0000
[ 3.360106] ipip: IPv4 over IPv4 tunneling driver
[ 3.360834] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.360968] arp_tables: (C) 2002 David S. Miller
[ 3.361044] Initializing XFRM netlink socket
[ 3.361884] NET: Registered protocol family 10
[ 3.362884] mip6: Mobile IPv6
[ 3.362908] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.363080] sit: IPv6 over IPv4 tunneling driver
[ 3.364146] NET: Registered protocol family 17
[ 3.364170] NET: Registered protocol family 15
[ 3.364205] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.364233] Key type dns_resolver registered
[ 3.371565] Registered cp15_barrier emulation handler
[ 3.379416] isp 54600000.isp: initialized
[ 3.380835] isp 54680000.isp: initialized
[ 3.384744] clk_cbus_recalc_rate: no gbus parent
[ 3.384751] clk_cbus_round_rate: no gbus parent
[ 3.384754] clk_cbus_round_rate: no gbus parent
[ 3.384762] clk_cbus_recalc_rate: no gbus parent
[ 3.399731] clk_cbus_recalc_rate: no gbus parent
[ 3.399736] clk_cbus_round_rate: no gbus parent
[ 3.399739] clk_cbus_round_rate: no gbus parent
[ 3.399746] clk_cbus_recalc_rate: no gbus parent
[ 3.399770] tegra_dvfs: GPU-cap: registered
[ 3.399859] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 3.399864] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 3.399868] tegra dvfs: vdd-gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 3.442317] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 3.443334] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.443388] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 3.443432] tegra_dvfs: vdd-gpu-vts: registered
[ 3.443477] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 3.443545] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 3.443569] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.444244] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 3.445785] en-vdd-sd: supplied by vdd-3v3
[ 3.448479] xhci-tegra 70090000.xusb: can’t get usb3-0 phy (-517)
[ 3.449108] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 3.449119] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x9228c13
[ 3.449127] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 3.450476] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 3.450486] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 3.450493] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 3.450508] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 3.450584] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 3.450592] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 3.450606] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 3.450619] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 3.450634] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 3.450651] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 3.450667] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 3.450683] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 3.450699] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 3.450717] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 3.451416] usb-vbus1: supplied by vdd-3v3
[ 3.453762] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 3.456435] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 3.456665] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 3.457386] clk_cbus_round_rate: no gbus parent
[ 3.457393] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 3.457774] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 3.459662] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 3.460049] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 3.460218] tegra-ahci 70027000.sata: Missing devslp-active state
[ 3.470424] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.470436] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.474819] scsi host0: tegra_ahci
[ 3.475504] scsi host1: tegra_ahci
[ 3.475740] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 370
[ 3.475743] ata2: DUMMY
[ 3.482699] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.482925] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 3.483545] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[ 3.483928] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 3.513040] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 3.527734] mmc0: MAN_BKOPS_EN bit is not set
[ 3.528756] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 3.529206] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.556284] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.556420] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.562745] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 3.562747] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 3.565452] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.565455] xhci-tegra 70090000.xusb: Falling back to user helper
[ 3.632013] mmc0: Skipping tuning since strobe enabled
[ 3.634142] input: gpio-keys as /devices/gpio-keys/input/input2
[ 3.686242] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:15 UTC (946688415)
[ 3.687083] vi 54080000.vi: vi_probe: ++
[ 3.735964] mmc0: new HS400 MMC card at address 0001
[ 3.736395] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 3.736633] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 3.749423] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 3.794599] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.884931] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 4.125534] vi 54080000.vi: initialized
[ 4.175751] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 4.277884] vi 54080000.vi: all channel register failed
[ 4.283216] Disable partitions left on by BL
[ 4.283217] disb
[ 4.294593] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 4.296581] DRAM derating cdev registered.
[ 4.297400] vdd-cpu-fixed: disabling
[ 4.297409] vdd-cam-hv: disabling
[ 4.303002] avdd-ts-hv: disabling
[ 4.309386] vdd-ts: disabling
[ 4.324011] max77620-gpio7: disabling
[ 4.337351] lcd-bl-en: disabling
[ 4.337357] aux-3v3: disabling
[ 4.337358] snsr_pm: disabling
[ 4.337360] vdd-disp-3v0: disabling
[ 4.337362] usb-vbus1: disabling
[ 4.337364] rtl-5v0: disabling
[ 4.337365] en-usb-vbus2: disabling
[ 4.337366] en-vdd-vcm-2v8: disabling
[ 4.362885] ALSA device list:
[ 4.362887] #0: tegra-hda at 0x70038000 irq 348
[ 4.362889] #1: tegra-snd-t210ref-mobile-rt565x
[ 4.704308] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 4.706358] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 5.112495] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.193036] tegradc tegradc.1: hdmi: plugged
[ 5.200846] EXT4-fs (mmcblk0p1): couldn’t mount as ext3 due to feature incompatibilities
[ 5.212213] EXT4-fs (mmcblk0p1): couldn’t mount as ext2 due to feature incompatibilities
[ 5.227380] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.237765] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.248594] devtmpfs: mounted
[ 5.254147] Freeing unused kernel memory: 1208K (ffffffc001184000 - ffffffc0012b2000)
[ 5.264260] Freeing alternatives memory: 76K (ffffffc0012b2000 - ffffffc0012c5000)
[ 5.318152] systemd[1]: System time before build time, advancing clock.
[ 5.340765] random: systemd: uninitialized urandom read (16 bytes read, 65 bits of entropy available)
[ 5.354033] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.374835] systemd[1]: Detected architecture arm64.
[ 5.393267] systemd[1]: Set hostname to .
[ 5.393597] mmc1 tuning done saved tap delay=45
[ 5.393598] mmc1: hw tuning done …
[ 5.393602] mmc1: tuning_window[0]: 0xf3ffffff
[ 5.393606] mmc1: tuning_window[1]: 0x7fffffff
[ 5.393609] mmc1: tuning_window[2]: 0xfffffffc
[ 5.393612] mmc1: tuning_window[3]: 0x7fffff1f
[ 5.393615] mmc1: tuning_window[4]: 0x0
[ 5.393619] mmc1: tuning_window[5]: 0x0
[ 5.393622] mmc1: tuning_window[6]: 0x0
[ 5.393625] mmc1: tuning_window[7]: 0x0
[ 5.393627] sdhci: Tap value: 45 | Trim value: 8
[ 5.393628] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 5.481033] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.486271] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 5.487165] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 5.488154] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[ 5.493727] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[ 5.497519] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[ 5.497592] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[ 5.497768] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[ 5.497908] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[ 5.498036] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 72 bits of entropy available)
[ 5.597261] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.634412] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.686852] systemd[1]: Listening on Journal Audit Socket.
[ 5.696431] systemd[1]: Reached target Encrypted Volumes.
[ 5.705771] systemd[1]: Reached target User and Group Name Lookups.
[ 5.716150] systemd[1]: Created slice User and Session Slice.
[ 5.725906] systemd[1]: Reached target Swap.
[ 5.734288] systemd[1]: Listening on udev Control Socket.
[ 5.743913] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.754799] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.766221] systemd[1]: Listening on LVM2 poll daemon socket.
[ 5.776518] systemd[1]: Listening on Syslog Socket.
[ 5.786000] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.796603] systemd[1]: Listening on udev Kernel Socket.
[ 5.806630] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 5.817574] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.830061] systemd[1]: Created slice System Slice.
[ 5.839939] systemd[1]: Created slice system-getty.slice.
[ 5.850281] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.861422] systemd[1]: Reached target Slices.
[ 5.870682] systemd[1]: Reached target Remote File Systems (Pre).
[ 5.881351] systemd[1]: Reached target Remote File Systems.
[ 5.891546] systemd[1]: Listening on Journal Socket.
[ 5.903414] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 5.920666] systemd[1]: Mounting Debug File System…
[ 5.932955] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 5.945427] systemd[1]: Started Braille Device Support.
[ 5.956809] systemd[1]: Starting Journal Service…
[ 5.968376] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 5.988421] systemd[1]: Starting Load Kernel Modules…
[ 6.001990] systemd[1]: Mounted Debug File System.
[ 6.012790] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.025861] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 6.041089] systemd[1]: Started Load Kernel Modules.
[ 6.052464] systemd[1]: Started Journal Service.
[ 6.060809] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 6.062861] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 6.062885] tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
[ 6.063914] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 6.178987] systemd-journald[210]: Received request to flush runtime journal from PID 1
[ 6.400990] xhci-tegra 70090000.xusb: cannot find firmware…retry after 1 second
[ 6.573463] dhd_module_init in
[ 6.579190] found wifi platform device bcmdhd_wlan
[ 6.587675] Power-up adapter ‘DHD generic adapter’
[ 6.595024] wifi_platform_set_power = 1
[ 6.765371] random: nonblocking pool is initialized
[ 6.802553] wifi_platform_bus_enumerate device present 1
[ 6.828811] wifi_platform_bus_enumerate device present 0
[ 6.829148] F1 signature read @0x18000000=0x17214354
[ 6.832565] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 6.833045] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 6.833101] wifi_platform_prealloc: failed to alloc static mem section 7
[ 6.833108] wifi_platform_get_mac_addr
[ 6.833155] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 6.833997] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 6.834475] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 6.933478] wl_create_event_handler(): thread:wl_event_handler:19f started
[ 6.933483] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc07a461a70
[ 6.933601] dhd_attach(): thread:dhd_watchdog_thread:1a0 started
[ 6.933630] dhd_attach(): thread:dhd_dpc:1a1 started
[ 6.933666] dhd_attach(): thread:dhd_rxf:1a2 started
[ 6.933671] dhd_deferred_work_init: work queue initialized
[ 6.933859] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Jul 26 2017 at 15:21:46
[ 6.934192] tegra_sysfs_register
[ 6.934225] Register interface [wlan0] MAC: 00:90:4c:11:22:33
[ 6.934229] dhd_prot_ioctl : bus is down. we have nothing to do
[ 6.934306] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 6.935350] wifi_platform_set_power = 0
[ 7.411714] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[ 7.430644] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.446860] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 7.473066] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 7.499855] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 7.510634] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.510638] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.510641] usb usb1: Product: xHCI Host Controller
[ 7.510643] usb usb1: Manufacturer: Linux 4.4.38+ xhci-hcd
[ 7.510645] usb usb1: SerialNumber: 70090000.xusb
[ 7.511014] hub 1-0:1.0: USB hub found
[ 7.511042] hub 1-0:1.0: 5 ports detected
[ 7.554628] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 7.554637] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 7.554833] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 7.554836] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.554839] usb usb2: Product: xHCI Host Controller
[ 7.554841] usb usb2: Manufacturer: Linux 4.4.38+ xhci-hcd
[ 7.554843] usb usb2: SerialNumber: 70090000.xusb
[ 7.555213] hub 2-0:1.0: USB hub found
[ 7.555238] hub 2-0:1.0: 4 ports detected
[ 7.670656] extcon-gpio-states extcon:extcon@1: Cable state 2
[ 7.783306] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.791829]
[ 7.814192] wl_android_wifi_on in
[ 7.819720] wifi_platform_set_power = 1
[ 7.867092] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 7.891811] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 7.891814] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 7.891817] usb 2-1: Product: USB 10/100/1000 LAN
[ 7.891819] usb 2-1: Manufacturer: Nvidia
[ 7.891821] usb 2-1: SerialNumber: 000001000000
[ 7.892405] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 7.894285] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 7.894817] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.007888] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
[ 8.065682] r8152 2-1:1.0 (unnamed net_device) (uninitialized): bad mac address at /chosen/nvidia,ethernet-mac: missing.
[ 8.099819] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 8.171675] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 8.172150] F1 signature read @0x18000000=0x17214354
[ 8.176081] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.176634] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.236759] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 8.298128] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 8.299290] wifi_platform_get_mac_addr
[ 8.299333] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 8.299343] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 8.300676] Firmware up: op_mode=0x0005, MAC=00:90:4c:16:70:01
[ 8.305844] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 8.309963] Firmware version = wl0: Sep 14 2016 11:38:27 version 7.35.221.18 (r657725) FWID 01-9001dfb5
[ 8.312084] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 8.312248] tegra_sysfs_on
[ 8.319601] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 8.320407] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 8.406562] wl_android_wifi_off in
[ 8.409962] tegra_sysfs_off
[ 8.412763] tegra_sysfs_rf_test_disable
[ 8.417318] dhd_wlfc_deinit():3437, maintain HOST RXRERODER flag in tvl
[ 8.424464] dhdsdio_isr : bus is down. we have nothing to do
[ 8.430291] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 8.440058] wifi_platform_set_power = 0
[ 8.647716]
[ 8.648920] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 8.648924] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
US6,570,884, US6,115,776, and US6,327,625.
[ 8.681918] dhd_set_mac_addr_handler: interface info not available/down
[ 8.688735] wl_android_wifi_on in
[ 8.692096] wifi_platform_set_power = 1
[ 8.779651] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.972125] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.050826] sdhci-tegra sdhci-tegra.1: Tuning already done, restoring the best tap value : 45
[ 9.060213] F1 signature read @0x18000000=0x17214354
[ 9.068690] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.075732] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.131322] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.199987] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.207158] wifi_platform_get_mac_addr
[ 9.210997] wifi_get_mac_address_dtb: bad mac address at /chosen/nvidia,wifi-mac: null.
[ 9.219059] wifi_get_mac_addr_file: cannot open /mnt/factory/wifi/wifi_mac.txt
[ 9.227875] Firmware up: op_mode=0x0005, MAC=00:90:4c:16:70:01
[ 9.239248] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.250533] Firmware version = wl0: Sep 14 2016 11:38:27 version 7.35.221.18 (r657725) FWID 01-9001dfb5
[ 9.262368] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.268927] tegra_sysfs_on
[ 9.319638] cfg80211: World regulatory domain updated:
[ 9.324792] cfg80211: DFS Master region: unset
[ 9.329154] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.338902] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.346903] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.354906] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.362913] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.372391] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.381866] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.389962] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.397967] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 9.618146] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 9.635374] WLC_E_IF: NO_IF set, event Ignored
[ 9.697871] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 9.726636] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.810887] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.942286] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 11.487652] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.534845] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.557375] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.583588] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.584894] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.586590] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.605840] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.607864] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.619097] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.656545] Setting pll_a = 45158400 Hz clk_out = 11289600 Hz
[ 11.696524] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 11.697363] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 15.496547] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.236005] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 16.625100] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.063664] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 17.159205] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 42.762736] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 48.521633] tegradc tegradc.1: hdmi: unplugged
[ 49.648101] Unsupported HDMI VIC 208, ignoring
[ 49.652549] Unsupported HDMI VIC 114, ignoring
[ 49.657104] Unsupported HDMI VIC 28, ignoring
[ 49.661518] Unsupported HDMI VIC 22, ignoring
[ 49.666023] tegradc tegradc.1: hdmi: plugged
[ 49.692997] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 49.693824] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 49.788534] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 49.863217] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 49.864037] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[ 77.318837] usb 1-3: new full-speed USB device number 2 using xhci-tegra
[ 77.340401] usb 1-3: New USB device found, idVendor=04b3, idProduct=301a
[ 77.347133] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 77.354528] usb 1-3: Product: USB 1.1 2port downstream low power hub
[ 77.361099] usb 1-3: Manufacturer: Lite-On Technology
[ 77.366586] usb 1-3: ep 0x81 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 77.376988] hub 1-3:1.0: USB hub found
[ 77.381049] hub 1-3:1.0: 3 ports detected
[ 77.654788] usb 1-3.1: new full-speed USB device number 3 using xhci-tegra
[ 77.676494] usb 1-3.1: New USB device found, idVendor=04b3, idProduct=301b
[ 77.683401] usb 1-3.1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 77.690996] usb 1-3.1: Product: USB Productivity Option Keyboard( has the hub in # 1 )
[ 77.698935] usb 1-3.1: Manufacturer: Lite-On Technology
[ 77.704640] usb 1-3.1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 77.713757] usb 1-3.1: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 77.725431] input: Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 ) as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.0/0003:04B3:301B.0001/input/input3
[ 77.795402] hid-generic 0003:04B3:301B.0001: input,hidraw0: USB HID v1.10 Keyboard [Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 )] on usb-70090000.xusb-3.1/input0
[ 77.814110] input: Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 ) as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.1/0003:04B3:301B.0002/input/input4
[ 77.883420] hid-generic 0003:04B3:301B.0002: input,hidraw1: USB HID v1.10 Device [Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 )] on usb-70090000.xusb-3.1/input1
[ 83.353936] usb 1-3: USB disconnect, device number 2
[ 83.358909] usb 1-3.1: USB disconnect, device number 3
[ 105.115090] usb 1-3: new full-speed USB device number 4 using xhci-tegra
[ 105.136622] usb 1-3: New USB device found, idVendor=04b3, idProduct=301a
[ 105.143367] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 105.150828] usb 1-3: Product: USB 1.1 2port downstream low power hub
[ 105.157281] usb 1-3: Manufacturer: Lite-On Technology
[ 105.162677] usb 1-3: ep 0x81 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 105.173175] hub 1-3:1.0: USB hub found
[ 105.177387] hub 1-3:1.0: 3 ports detected
[ 105.451061] usb 1-3.1: new full-speed USB device number 5 using xhci-tegra
[ 105.472534] usb 1-3.1: New USB device found, idVendor=04b3, idProduct=301b
[ 105.479414] usb 1-3.1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 105.486758] usb 1-3.1: Product: USB Productivity Option Keyboard( has the hub in # 1 )
[ 105.494695] usb 1-3.1: Manufacturer: Lite-On Technology
[ 105.500154] usb 1-3.1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 105.509054] usb 1-3.1: ep 0x82 - rounding interval to 1024 microframes, ep desc says 2040 microframes
[ 105.520707] input: Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 ) as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.0/0003:04B3:301B.0003/input/input5
[ 105.591449] hid-generic 0003:04B3:301B.0003: input,hidraw0: USB HID v1.10 Keyboard [Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 )] on usb-70090000.xusb-3.1/input0
[ 105.612482] input: Lite-On Technology USB Productivity Option Keyboard( has the hub in # 1 ) as /devices/70090000.xusb/usb1/1-3/1-3.1/1-3.1:1.1/0003:04B3:301B.0004/input/in
I don’t have a proper boot log yet (something I’ll do this weekend), so I’m not positive about what I see in the logs. I do see this, which might or might not be an issue:
…it could be it is intended to fall back.
Later on I also see a keyboard detected and correctly assigned as a human interface device…this would not be possible if the physical hardware had not at least queried the device and found a driver to claim it. A HUB is mentioned, but this could be part of the keyboard itself. Do you use an external HUB? If so, try plugging the keyboard directly into the Jetson, or perhaps use a powered HUB (keyboards would not require external power, they use so little…but it is a good debug test).
I connect the devices directly into Jetson. I tried both with the mouse and the keyboard. Both of them work properly in upper USB slot, and both of them don’t work in the lower one.
I’m not sure which is “upper” or “lower”. I have been assuming this is the developer carrier board, correct me if this is wrong. The developer carrier board has a full-sized USB type-A connector, plus a micro-OTG USB connector. The controller/lane mappings differ in configuring these two ports, so if one of those ports could be identified it would be a good debugging clue.
FYI, I have placed a USB1 mouse on both ports of a TX2 under R28.1 (should be the same as this release on TX1…not necessarily since the two use different driver packages during flash…haven’t flashed my TX1 yet), and both ports work. Have you tried any faster peripherals on the two ports (USB2)? If a USB2 device works on the port, then this is an indication of a software problem, whereas missing functionality of this as well might show a hardware problem.
If this is the micro-USB connector, then you cannot use the provided cable for connecting anything to the Jetson…this cable is for recovery mode only (the Jetson becomes a device in recovery mode). A micro-A connector must be used on this port for peripherals such as a keyboard or mouse. Usually (not always) there is an “A” or “B” visible at the connector to identify which standard it follows.
I use J120 carrier board for the NVIDIA Jetson TX1. https://auvidea.com/j120/
It has two USB type A connectors, placed one over the other.
The problem with USB started after flashing the board with R28.1. Before both the mouse and the keyboard worked properly.
There’s the issue…for a J120 board you need different device tree settings. You’ll need to use the BSP for the J120. It should work after you load the right software, but Auvideo will need to provide that update.
Thank You for Your answer.
Can I modify device tree myself? If I can, could You give me some reference where I could find the description how to do it?
If I cannot, where can I find rigth software. If I use Jetpack 3.1 will it load right software after the update is provided?
Device trees are easy to modify, but the values to use and which part to edit is not something I can guess at…the J120 support people would know what to change. Regardless of which JetPack version you use the device tree/BSP will differ between a developer carrier board and any board with a different layout. It depends on which module pin was wired to what connector or device on the carrier board.
Just for information, there are settings for hardware which need to be in place before a driver can use that hardware. For one example, GPIO might be used with a custom device…but if there are multiple GPIO pins, and if the device can be attached to any of those pins, then something has to set up the right pin to where the driver expects it; other settings like clock speed or rail voltage might also need setup to be compatible with some outside hardware. The device tree does this. Device tree has options as to where it can be set up. Typically U-Boot does this to some degree, and then you can load a dtb file from “/boot” as well (the “FDT” key/value pair in extlinux.conf).
Very likely Auvidia will release a file which can simply be copied in place in “/boot”. There may be other changes as well, but this part is the device tree. Under R28.1 the method of setup has changed somewhat, and you will need Auvidia to tell you what changes are required for R28.1. If you need to edit or modify the device tree by hand it is fairly simple, but you’ll need the information from them before it is known what has to be done.
