I used l4t 27.1, the tree that I changed, but USB still couldn’t work.
The device tree is changed according to this website.https://elinux.org/Jetson/TX2_DTB#TX2
This is the boot message.
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.15-tegra (buildbrain@mobile-u64-1423) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Wed Mar 1 21:09:29 PST 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000f2000000
[ 0.000000] On node 0 totalpages: 2051584
[ 0.000000] DMA zone: 7488 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 479232 pages, LIFO batch:31
[ 0.000000] Normal zone: 24576 pages used for memmap
[ 0.000000] Normal zone: 1572352 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1ffcab000 s31104 r8192 d30336 u69632
[ 0.000000] pcpu-alloc: s31104 r8192 d30336 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019520
[ 0.000000] Kernel command line: fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 android.kerneltype=normal androidboot.serialno=0335115020673 vpr_resize root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7286340K/8206336K available (10164K kernel code, 1653K rwdata, 5424K rodata, 1132K init, 679K bss, 166332K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdca000000 ( 128 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192 MB)
.init : 0xffffffc000fba000 - 0xffffffc0010d5000 ( 1132 KB)
.text : 0xffffffc000080000 - 0xffffffc000fba000 ( 15592 KB)
.data : 0xffffffc0010f4000 - 0xffffffc0012915b0 ( 1654 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.008882] tegra-id: chipid=21817.
[ 0.012714] tegra-id: opt_subrevision=1.
[ 0.017515] Console: colour dummy device 80x25
[ 0.022459] console [tty0] enabled
[ 0.025990] kmemleak: Kernel memory leak detector disabled
[ 0.031687] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.042437] pid_max: default: 32768 minimum: 301
[ 0.047263] Security Framework initialized
[ 0.051539] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058678] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.066619] Initializing cgroup subsys freezer
[ 0.071241] Initializing cgroup subsys debug
[ 0.075800] CPU0 ipc=752
[ 0.078438] CPU1 ipc=1024
[ 0.081160] CPU2 ipc=1024
[ 0.083876] CPU3 ipc=752
[ 0.086508] CPU4 ipc=752
[ 0.089142] CPU5 ipc=752
[ 0.091796] ASID allocator initialised with 65536 entries
[ 0.133961] CPU1: Booted secondary processor [4e0f0030]
[ 0.145566] CPU2: Booted secondary processor [4e0f0030]
[ 0.157377] CPU3: Booted secondary processor [411fd073]
[ 0.169368] CPU4: Booted secondary processor [411fd073]
[ 0.181367] CPU5: Booted secondary processor [411fd073]
[ 0.181405] Brought up 6 CPUs
[ 0.211606] SMP: Total of 6 processors activated.
[ 0.216491] CPU: All CPU(s) started at EL2
[ 0.221125] devtmpfs: initialized
[ 0.247851] Initilizing CustomIPI irq domain
[ 0.252494] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.272739] pinctrl core: initialized pinctrl subsystem
[ 0.278573] OS set in device tree is L4T.
[ 0.283291] regulator-dummy: no parameters
[ 0.287852] Initializing plugin-manager
[ 0.291939] Plugin module not found
[ 0.295976] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.303918] node /plugin-manager/fragement@0 match with odm-data enable-tegra-wdt
[ 0.312143] node /plugin-manager/fragement@4 match with odm-data enable-tegra-wdt
[ 0.320786] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.330401] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.339751] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.349003] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.357308] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.366264] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.374937] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.383676] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.392008] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.401334] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.413173] Adding domain adsp-pd to PM domain ape-pd
[ 0.422483] NET: Registered protocol family 16
[ 0.428762] console [pstore-1] enabled
[ 0.432726] pstore: Registered ramoops as persistent store backend
[ 0.439211] ramoops: attached 0x200000@0x100000000, ecc: 0/0
[ 0.453620] cpuidle: using governor ladder
[ 0.465598] cpuidle: using governor menu
[ 0.471494] bpmp: waiting for handshake
[ 0.475514] bpmp: handshake completed
[ 0.479364] bpmp: synchronizing channels
[ 0.483471] bpmp: channels synchronized
[ 0.487477] bpmp: connect returned 0
[ 0.491764] tegra186-pmc device create success
[ 0.496423] scratch reg offset dts data not present
[ 0.501638] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.509186] PMC: configuring io pad defaults
[ 0.513800] T186 pmc padctrl driver initialized
[ 0.518541] ### PMC reset source: Power on reset
[ 0.523364] ### PMC reset level: L0
[ 0.527007] ### PMC reset status reg: 0x0
[ 0.531492] vdso: 2 pages (1 code @ ffffffc0010f9000, 1 data @ ffffffc0010f8000)
[ 0.539293] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.548513] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.558676] tegra_powergate_init: DONE
[ 0.562765] DTS File Name: /usr/mg/27.1/Linux_for_Tegra_tx2/sources/kernel_source/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-tx2-cti-base.dts
[ 0.581648] DTB Build time: <unknown>
[ 0.586981] Tegra reboot handler registered.
[ 0.592836] Registering Tegra186 clocks (this may take a while)...done
[ 0.601931] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.608758] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.613702] arm-smmu 12000000.iommu: stage 1 translation
[ 0.619362] arm-smmu 12000000.iommu: stage 2 translation
[ 0.625017] arm-smmu 12000000.iommu: nested translation
[ 0.630588] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.639330] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.650333] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.657266] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.664103] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.711297] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.721868] iommu: Adding device 3460000.sdhci to group 0
[ 0.728141] iommu: Adding device 3400000.sdhci to group 1
[ 0.736555] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.742947] iommu: Adding device 3160000.i2c to group 3
[ 0.748790] iommu: Adding device c240000.i2c to group 4
[ 0.754538] iommu: Adding device 3180000.i2c to group 5
[ 0.760252] iommu: Adding device 3190000.i2c to group 6
[ 0.766118] iommu: Adding device 31b0000.i2c to group 7
[ 0.771932] iommu: Adding device 31c0000.i2c to group 8
[ 0.777681] iommu: Adding device c250000.i2c to group 9
[ 0.783466] iommu: Adding device 31e0000.i2c to group 10
[ 0.790805] iommu: Adding device 3210000.spi to group 11
[ 0.796670] iommu: Adding device c260000.spi to group 12
[ 0.802534] iommu: Adding device 3240000.spi to group 13
[ 0.808725] iommu: Adding device 3100000.serial to group 14
[ 0.814900] iommu: Adding device 3110000.serial to group 15
[ 0.821048] iommu: Adding device 3130000.serial to group 16
[ 0.827862] iommu: Adding device 2490000.ether_qos to group 17
[ 0.834394] iommu: Adding device b000000.rtcpu to group 18
[ 0.840888] Wake73 for irq=42
[ 0.844309] iommu: Adding device smmu_test to group 19
[ 0.850179] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.856837] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.863480] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.870121] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.876762] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.883405] mc-err: Set intmask: 0xf3140
[ 0.887692] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.894581] Wake76 for irq=199
[ 0.897774] Wake77 for irq=199
[ 0.900960] Wake78 for irq=199
[ 0.904145] Wake79 for irq=199
[ 0.907332] Wake80 for irq=199
[ 0.910517] Wake81 for irq=199
[ 0.913704] Wake82 for irq=199
[ 0.917062] iommu: Adding device 3530000.xhci to group 20
[ 0.923022] iommu: Adding device 3550000.xudc to group 21
[ 0.929382] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.935576] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.943386] iommu: Adding device 13e10000.host1x to group 22
[ 0.949582] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.956135] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.962689] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.969248] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.975818] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.982405] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.988963] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 0.995556] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 1.002328] iommu: Adding device 150c0000.nvcsi to group 31
[ 1.008585] iommu: Adding device 15700000.vi to group 32
[ 1.014436] iommu: Adding device 15600000.isp to group 33
[ 1.020351] iommu: Adding device 15210000.nvdisplay to group 34
[ 1.026752] iommu: Adding device 15340000.vic to group 35
[ 1.032585] iommu: Adding device 154c0000.nvenc to group 36
[ 1.038563] iommu: Adding device 15480000.nvdec to group 37
[ 1.044721] iommu: Adding device 15380000.nvjpg to group 38
[ 1.050735] iommu: Adding device 15500000.tsec to group 39
[ 1.056635] iommu: Adding device 15100000.tsecb to group 40
[ 1.062987] iommu: Adding device 15810000.se to group 41
[ 1.068745] iommu: Adding device 15820000.se to group 42
[ 1.074490] iommu: Adding device 15830000.se to group 43
[ 1.080250] iommu: Adding device 15840000.se to group 44
[ 1.086253] iommu: Adding device 17000000.gp10b to group 45
[ 1.093185] tegra-reset 5000000.clock: registered 193 resets.
[ 1.100790] iommu: Adding device d000000.bpmp to group 46
[ 1.106648] bpmp: ping status is 0
[ 1.110358] bpmp d000000.bpmp: firmware tag is c11dd04ae487c849cc552f8f702ed830
[ 1.120693] iommu: Adding device 2600000.dma to group 47
[ 1.126944] GPIO line 461 (cam0-rst) hogged as output/high
[ 1.132722] GPIO line 424 (wifi-enable) hogged as output/high
[ 1.138765] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 1.144715] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 1.151261] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 1.160707] GPIO line 315 (wifi-wake-ap) hogged as input
[ 1.166356] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 1.175200] iommu: Adding device 10003000.pcie-controller to group 48
[ 1.182154] iommu: Adding device sound to group 49
[ 1.188654] iommu: Adding device 3510000.hda to group 50
[ 1.195199] iommu: Adding device adsp_audio to group 51
[ 1.201891] iommu: Adding device 2993000.adsp to group 52
[ 1.212739] iommu: Adding device c160000.aon to group 53
[ 1.220288] vdd-ac-bat: 5000 mV
[ 1.225586] vdd-1v8-ap: 1800 mV
[ 1.229923] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.235746] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 1.256259] SCSI subsystem initialized
[ 1.260351] libata version 3.00 loaded.
[ 1.260559] usbcore: registered new interface driver usbfs
[ 1.266358] usbcore: registered new interface driver hub
[ 1.272023] usbcore: registered new device driver usb
[ 1.279751] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 1.286701] pca953x 0-0074: failed reading register
[ 1.291887] pca953x: probe of 0-0074 failed with error -121
[ 1.297990] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 1.304987] pca953x 0-0077: failed reading register
[ 1.310160] pca953x: probe of 0-0077 failed with error -121
[ 1.316176] tps65132 0-003e: No active discharge gpio for regulator tps65132-outp
[ 1.324143] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.331254] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.338234] outp: 4000 <--> 6000 mV
[ 1.342009] tps65132 0-003e: No active discharge gpio for regulator tps65132-outn
[ 1.349978] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.357056] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.364010] outn: 4000 <--> 6000 mV
[ 1.378509] media: Linux media interface: v0.10
[ 1.383315] Linux video capture interface: v2.00
[ 1.391943] pps_core: LinuxPPS API ver. 1 registered
[ 1.397145] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.406716] PTP clock support registered
[ 1.412542] Tegra WDT setup timeout = 120 seconds.
[ 1.417624] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 1.425890] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 1.433691] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 1.439952] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 1.446191] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 1.457768] vddio-ddr: at 1125 mV
[ 1.465587] avdd_dsi_csi: 1200 mV
[ 1.473586] vdd-1v8: 1800 mV
[ 1.481585] vdd-3v3-sys: 3300 mV
[ 1.486043] spmic-ldo0: at 1800 mV
[ 1.490460] spmic-ldo1: at 800 mV
[ 1.497590] vddio-3v3: 3300 mV
[ 1.501621] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 1.509587] vdd-rtc: 1000 mV
[ 1.513529] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 1.521589] spmic-ldo6: at 1500 mV
[ 1.525991] vdd-pex-1v05: 1000 mV
[ 1.530417] dvdd-pex: 1000 mV
[ 1.533944] max77620 4-003c: max77620 probe successful
[ 1.539607] Advanced Linux Sound Architecture Driver Initialized.
[ 1.547385] en-vdd-sd: 3300 mV
[ 1.551037] vdd-usb0-5v: 5000 mV
[ 1.554734] vdd-usb1-5v: 5000 mV
[ 1.558675] vdd-3v3: 3300 mV
[ 1.561994] en-vdd-vcm-2v8: 2800 mV
[ 1.565927] vdd-sys-bl: 3300 mV
[ 1.570265] gpio tegra-gpio wake53 for gpio=159(X:5)
[ 1.577264] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 1.584877] clocksource: Switched to clocksource arch_sys_counter
[ 1.621985] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.629072] dma_declare_coherent_resizable_cma_memory:288: resizable heap=vpr, base=0x00000000ae000000, size=0x2a000000
[ 1.637526] Wake76 for irq=199
[ 1.637528] Wake77 for irq=199
[ 1.637531] Wake78 for irq=199
[ 1.637532] Wake79 for irq=199
[ 1.637534] Wake80 for irq=199
[ 1.637536] Wake81 for irq=199
[ 1.637538] Wake82 for irq=199
[ 1.638655] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 1.638850] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 1.638952] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 1.639014] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 1.639380] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 1.639516] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 1.639675] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 1.639805] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 1.639832] isomgr_init(): iso emc max clk=1866000KHz
[ 1.639835] isomgr_init(): max_iso_bw=26870400KB
[ 1.640036] tegra186-pmc-iopower pmc-iopower: Rail iopower-sys is having fixed voltage 1800000
[ 1.640097] tegra186-pmc-iopower pmc-iopower: Rail iopower-uart is having fixed voltage 1800000
[ 1.640154] tegra186-pmc-iopower pmc-iopower: Rail iopower-conn is having fixed voltage 1800000
[ 1.640220] tegra186-pmc-iopower pmc-iopower: Rail iopower-edp is having fixed voltage 1800000
[ 1.640281] tegra186-pmc-iopower pmc-iopower: Rail iopower-pex-ctrl-audio is having fixed voltage 1800000
[ 1.640339] tegra186-pmc-iopower pmc-iopower: Rail iopower-ufs is having fixed voltage 1800000
[ 1.640392] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr0 is having fixed voltage 0
[ 1.640435] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr1 is having fixed voltage 0
[ 1.640483] tegra186-pmc-iopower pmc-iopower: Rail iopower-csi-dsi is having fixed voltage 1200000
[ 1.640544] tegra186-pmc-iopower pmc-iopower: Rail iopower-cam is having fixed voltage 1800000
[ 1.640601] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 1.640663] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc1-hv is having voltages: 1800000:3300000
[ 1.640756] tegra186-pmc-iopower pmc-iopower: Rail iopower-audio-hv is having fixed voltage 1800000
[ 1.640814] tegra186-pmc-iopower pmc-iopower: Rail iopower-dbg is having fixed voltage 1800000
[ 1.640906] tegra186-pmc-iopower pmc-iopower: Rail iopower-spi is having fixed voltage 1800000
[ 1.640973] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao is having fixed voltage 1800000
[ 1.641026] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao-hv is having fixed voltage 3300000
[ 1.641084] tegra186-pmc-iopower pmc-iopower: Rail iopower-dmic-hv is having fixed voltage 1800000
[ 1.641132] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc2-hv is having fixed voltage 3300000
[ 1.641181] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc3-hv is having voltages: 1800000:3300000
[ 1.641192] tegra186-pmc-iopower pmc-iopower: NO_IO_POWER setting 0x00000000
[ 1.641453] NET: Registered protocol family 2
[ 1.642040] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.642815] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.643867] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.643942] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.644169] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.644482] NET: Registered protocol family 1
[ 1.644853] RPC: Registered named UNIX socket transport module.
[ 1.644856] RPC: Registered udp transport module.
[ 1.644858] RPC: Registered tcp transport module.
[ 1.644860] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.644905] PCI: CLS 0 bytes, default 128
[ 1.660157] host1x 13e10000.host1x: initialized
[ 1.662526] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.663404] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 1.663532] audit: initializing netlink subsys (disabled)
[ 1.663566] audit: type=2000 audit(1.616:1): initialized
[ 1.671311] io scheduler noop registered (default)
[ 1.676985] Adding domain tsec-pd to PM domain host-pd
[ 1.679490] tsec 15500000.tsec: initialized
[ 1.680757] tsec 15100000.tsecb: initialized
[ 1.681132] Adding domain nvdec-pd to PM domain host-pd
[ 1.682992] nvdec 15480000.nvdec: initialized
[ 1.683592] Adding domain vic03-pd to PM domain host-pd
[ 1.683614] Adding domain msenc-pd to PM domain host-pd
[ 1.683635] Adding domain nvjpg-pd to PM domain host-pd
[ 1.687192] falcon 15340000.vic: initialized
[ 1.688419] falcon 154c0000.nvenc: initialized
[ 1.689641] falcon 15380000.nvjpg: initialized
[ 1.690718] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.691499] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.692301] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.693126] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.693936] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.694735] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.695502] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.696232] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.697651] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.697727] tegradc 15210000.nvdisplay: Display dc.15210000 registered with id=0
[ 1.697733] DC OR NODE connected to /host1x/sor1
[ 1.697803] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1250000, vi_iso_bw=1500000, max_bw=1500000
[ 1.697805] parse_tmds_config: No tmds-config node
[ 1.697885] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.705036] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.705038] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.705040] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.705071] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 1.705076] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 1.705439] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ 1.706862] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 1.707364] PD DISP0 index2 UP
[ 1.707380] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.707692] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.707777] PD DISP1 index3 UP
[ 1.707860] PD DISP2 index4 UP
[ 1.710044] console [ttyS0] disabled
[ 1.734580] PD DISP2 index4 DOWN
[ 1.734675] PD DISP1 index3 DOWN
[ 1.734756] PD DISP0 index2 DOWN
[ 1.736355] tegradc 15210000.nvdisplay: probed
[ 2.286600] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 2.286691] cma: enabled page replacement for spfn=ae000, epfn=d8000
[ 2.286703] dma_declare_coherent_resizable_cma_memory:335: resizable cma heap=vpr create successful
[ 2.286704] nvmap_page_pool_init: Total RAM pages: 2010001
[ 2.286707] nvmap_page_pool_init: nvmap page pool size: 251250 pages (981 MB)
[ 2.286855] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.287350] misc nvmap: created heap vpr base 0x00000000ae000000 size (688128KiB)
[ 2.300648] Console: switching to colour frame buffer device 240x67
[ 2.373426] console [ttyS0] enabled
[ 2.373458] tegradc 15210000.nvdisplay: fb registered
[ 2.373725] gpio tegra-gpio wake21 for gpio=121(P:2)
[ 2.373780] PD DISP0 index2 UP
[ 2.374202] PD DISP1 index3 UP
[ 2.374333] PD DISP2 index4 UP
[ 2.381570] rate get on hub 408000000
[ 2.381953] Parent Clock set for DC plld2
[ 2.384337] dc clk 148500000
[ 2.387830] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 2.387835] rate get on compclk 148500000
[ 2.402850] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 2.419510] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 2.436171] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 2.504239] bootconsole [uart0] disabled
[ 2.514370] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 2.523563] serial-tegra 3130000.serial: RX in PIO mode
[ 2.529945] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.540790] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.546177] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.552580] nct1008_nct72 7-004c: starting parse dt
[ 2.557645] nct1008_nct72 7-004c: success parsing dt
[ 2.562854] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.581096] tegradc 15210000.nvdisplay: vrr_setup failed
[ 2.604472] tmp451: Enabled overheat logging at 104.00C
[ 2.604568] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.604611] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.607344] THERMAL EST: found 3 subdevs
[ 2.607348] THERMAL EST num_resources: 0
[ 2.607351] [THERMAL EST subdev 0]
[ 2.607356] [THERMAL EST subdev 1]
[ 2.607381] [THERMAL EST subdev 2]
[ 2.607608] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.607610] THERMAL EST: thz register success.
[ 2.607779] THERMAL EST: end of probe, return err: 0
[ 2.607956] tegra_profiler: Branch: Dev
[ 2.607958] tegra_profiler: Version: 1.109
[ 2.607960] tegra_profiler: Samples version: 37
[ 2.607962] tegra_profiler: IO version: 20
[ 2.607970] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.607973] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.607977] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.607980] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.607983] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.607986] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.607989] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.607991] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.607994] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.607996] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.607999] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.608002] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.608194] tegra_profiler: auth: init
[ 2.611291] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.611302] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.612108] scsi host0: tegra_ahci
[ 2.612395] scsi host1: tegra_ahci
[ 2.612517] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 2.612521] ata2: DUMMY
[ 2.613292] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.613714] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.614131] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.614925] tun: Universal TUN/TAP device driver, 1.6
[ 2.614927] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.615083] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.615085] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.615126] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.615161] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.615306] PPP generic driver version 2.4.2
[ 2.615411] PPP BSD Compression module registered
[ 2.615417] PPP Deflate Compression module registered
[ 2.615430] PPP MPPE Compression module registered
[ 2.615439] NET: Registered protocol family 24
[ 2.615484] usbcore: registered new interface driver asix
[ 2.615507] usbcore: registered new interface driver ax88179_178a
[ 2.615527] usbcore: registered new interface driver cdc_ether
[ 2.615555] usbcore: registered new interface driver smsc95xx
[ 2.615576] usbcore: registered new interface driver net1080
[ 2.615600] usbcore: registered new interface driver cdc_subset
[ 2.615621] usbcore: registered new interface driver zaurus
[ 2.615658] usbcore: registered new interface driver cdc_ncm
[ 2.615996] usbcore: registered new interface driver usb-storage
[ 2.616107] usbcore: registered new interface driver usbserial
[ 2.616129] usbcore: registered new interface driver ftdi_sio
[ 2.616145] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.616193] usbcore: registered new interface driver option
[ 2.616208] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.616227] usbcore: registered new interface driver pl2303
[ 2.616244] usbserial: USB Serial support registered for pl2303
[ 2.616452] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.618596] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.750766] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.753307] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.753321] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.753494] i2c /dev entries driver
[ 2.754317] gspca_main: v2.14.0 registered
[ 2.754357] usbcore: registered new interface driver gspca_zc3xx
[ 2.754604] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.756233] FAN: coudln't get the regulator
[ 2.756638] device-mapper: uevent: version 1.0.3
[ 2.756806] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.757063] sdhci: Secure Digital Host Controller Interface driver
[ 2.757064] sdhci: Copyright(c) Pierre Ossman
[ 2.757068] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.757340] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.757620] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.758058] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.758060] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.758486] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.759974] usbcore: registered new interface driver usbhid
[ 2.759975] usbhid: USB HID core driver
[ 2.759980] sdhci-tegra 3460000.sdhci: voltage switch failed in probe, err: -524
[ 2.761312] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 2.761700] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 2.761807] ina3221x: probe of 0-0042 failed with error -121
[ 2.762048] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 2.762400] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 2.762492] ina3221x: probe of 0-0043 failed with error -121
[ 2.762794] nvadsp 2993000.adsp: in probe()...
[ 2.763677] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.763704] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.763824] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.764269] tegra_central_actmon d230000.actmon: in probe()...
[ 2.766399] tegra_central_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.766834] kfuse 3830000.kfuse: initialized
[ 2.767138] Denver: backdoor interface is NOT available.
[ 2.768121] coresight-tmc 8030000.etf: TMC initialized
[ 2.768435] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.768830] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.769032] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.769386] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.769788] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.770135] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.770466] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.770807] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.770829] Module initialized successfully
[ 2.774357] camchar: rtcpu character device driver loaded
[ 2.776119] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.776250] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.776314] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.776888] **** A57 ECC: Enabled
[ 2.776890] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 2.777015] parse_throttle_dt_data: Num cap clks = 4
[ 2.777018] parse_throttle_dt_data: clk=mcpu type=1
[ 2.777020] parse_throttle_dt_data: clk=bcpu type=2
[ 2.777024] parse_throttle_dt_data: clk=gpu type=4
[ 2.777026] parse_throttle_dt_data: clk=emc type=3
[ 2.777482] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.777667] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.778087] Adding domain se-pd to PM domain host-pd
[ 2.779628] tegra-se-nvhost 15810000.se: initialized
[ 2.780036] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.780348] tegra-se-nvhost 15820000.se: initialized
[ 2.780776] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.781070] tegra-se-nvhost 15830000.se: initialized
[ 2.781376] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.781649] tegra-se-nvhost 15840000.se: initialized
[ 2.781999] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.785684] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 2.788156] cpufreq: platform driver Initialization: pass
[ 2.788423] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 2.788431] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 2.788462] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2aa896
[ 2.788464] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 2.789631] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 2.790653] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 2.791956] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 2.792083] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 2.792910] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.793479] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.793501] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 2.793505] Tachometer driver initialized with pulse_per_rev: 1 and win_len: 1
[ 2.793872] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.795832] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a5 42 9
[ 2.796947] sdhci-tegra 3440000.sdhci: voltage switch failed in probe, err: -524
[ 2.797238] libphy: dwc_phy: probed
[ 2.797736] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 2.797736] tegra210_adsp_audio_platform_probe: platform probe started
[ 2.798351] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 2.798590] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 2.798893] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 2.800943] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 2.801283] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 2.801287] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 2.801289] tegra210-adsp adsp_audio: using adma channel page 0
[ 2.803140] tegra210_adsp_audio_platform_probe probe successfull.
[ 2.803140] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.803258] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.810800] OPE platform probe
[ 2.810864] OPE platform probe successful
[ 2.815720] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 2.828891] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.829173] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.829211] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.829266] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.829338] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 247
[ 2.829545] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.830850] mmc0: MAN_BKOPS_EN bit is not set
[ 2.831360] sdhci-tegra 3400000.sdhci: voltage switch failed in probe, err: -524
[ 2.837977] mmc0: Skipping tuning since strobe enabled
[ 2.845324] mmc0: periodic cache flush enabled
[ 2.845332] mmc0: new HS400 MMC card at address 0001
[ 2.845599] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.845704] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.846916] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 2.861968] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 2.861968] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.862041] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.862113] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.862130] gpio tegra-gpio wake18 for gpio=101(M:3)
[ 2.862193] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.862260] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.862299] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.862330] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.862396] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.862468] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.862536] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.862616] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.862689] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.862764] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.862836] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.862918] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.862990] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.863058] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.863129] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.863201] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.863269] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.863340] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.864356] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 2.864429] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 2.864455] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 2.864475] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 2.868935] gpio tegra-gpio wake71 for gpio=125(P:6)
[ 2.868963] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.885233] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 2.904164] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 2.905053] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 2.905056] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 2.905658] GACT probability NOT on
[ 2.905668] Mirror/redirect action on
[ 2.905679] u32 classifier
[ 2.905680] Actions configured
[ 2.905698] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 2.906348] Initializing XFRM netlink socket
[ 2.906633] NET: Registered protocol family 10
[ 2.907268] NET: Registered protocol family 17
[ 2.907283] NET: Registered protocol family 15
[ 2.907289] 8021q: 802.1Q VLAN Support v1.8
[ 2.907470] Registered cp15_barrier emulation handler
[ 2.907487] Registered setend emulation handler
[ 2.908744] registered taskstats version 1
[ 2.909329] Adding domain ispa-pd to PM domain host-pd
[ 2.911786] isp 15600000.isp: initialized
[ 2.912265] Adding domain ve-pd to PM domain host-pd
[ 2.915256] nvcsi 150c0000.nvcsi: initialized
[ 2.917141] Wake76 for irq=199
[ 2.917142] Wake77 for irq=199
[ 2.917143] Wake78 for irq=199
[ 2.917144] Wake79 for irq=199
[ 2.917144] Wake80 for irq=199
[ 2.917145] Wake81 for irq=199
[ 2.917146] Wake82 for irq=199
[ 2.917596] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 2.917598] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 2.920493] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.920627] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 2.920629] xhci-tegra 3530000.xhci: Falling back to user helper
[ 2.921097] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.921688] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.928911] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.081785] mmc1 tuning done saved tap delay=21
[ 3.081787] mmc1: hw tuning done ...
[ 3.081794] mmc1: tuning_window[0]: 0xfffffffe
[ 3.081798] mmc1: tuning_window[1]: 0xffffc7ff
[ 3.081802] mmc1: tuning_window[2]: 0xf0ffffff
[ 3.081806] mmc1: tuning_window[3]: 0x7fffffff
[ 3.081810] mmc1: tuning_window[4]: 0x0
[ 3.081813] mmc1: tuning_window[5]: 0x0
[ 3.081817] mmc1: tuning_window[6]: 0x0
[ 3.081820] mmc1: tuning_window[7]: 0x0
[ 3.081823] sdhci: Tap value: 21 | Trim value: 5
[ 3.081825] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.087221] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.087262] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 3.462959] tegra186-padctl 3520000.pinctrl: tegra_phy_xusb_utmi_pad_dcd: DCD timeout 418 ms
[ 3.504926] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 3.504929] tegra-usb-cd usb_cd: set current 0ma
[ 3.504936] tegra-xudc-new 3550000.xudc: device mode on
[ 3.508178] tegra186-cam-rtcpu b000000.rtcpu: booting sce with Camera RTCPU FW
[ 3.508194] tegra186-cam-rtcpu b000000.rtcpu: sce gets unhalted
[ 3.509423] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.510205] tegra-camera-rtcpu-character-device ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.510361] tegra186-cam-rtcpu b000000.rtcpu: enabling tracing
[ 3.510407] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.510654] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=2 ivc=2 sha1=fb16914d17f56e81ad21e716791045b9ac83064a
[ 3.512151] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.512204] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 3.512243] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.512328] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.545476] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:42 UTC (946688442)
[ 3.560205] tegra-vi4 15700000.vi: initialized
[ 3.564899] random: nonblocking pool is initialized
[ 3.575663] bpmp: mounted debugfs mirror
[ 3.576021] [dram-timers] DRAM derating cdev registered.
[ 3.578865] outp: disabling
[ 3.578868] outn: disabling
[ 3.578875] spmic-ldo0: disabling
[ 3.579053] spmic-ldo1: disabling
[ 3.579200] en-vdd-sd: disabling
[ 3.579202] vdd-usb0-5v: disabling
[ 3.579205] vdd-3v3: disabling
[ 3.579207] en-vdd-vcm-2v8: disabling
[ 3.579209] vdd-sys-bl: disabling
[ 3.584721] ALSA device list:
[ 3.584723] #0: tegra-hda at 0x3518000 irq 391
[ 3.584724] #1: tegra-snd-t186ref-mobile-rt565x
[ 7.597839] tegradc 15210000.nvdisplay: blank - normal
[ 7.602822] tegradc 15210000.nvdisplay: unblank
[ 11.604774] tegradc 15210000.nvdisplay: hdmi: plugged
[ 11.608672] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 11.619934] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 11.634176] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.643822] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 11.653540] devtmpfs: mounted
[ 11.658426] Freeing unused kernel memory: 1132K (ffffffc000fba000 - ffffffc0010d5000)
[ 11.667945] Freeing alternatives memory: 92K (ffffffc0010d5000 - ffffffc0010ec000)
[ 11.723052] systemd[1]: System time before build time, advancing clock.
[ 11.749046] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 11.769295] systemd[1]: Detected architecture arm64.
[ 11.786863] systemd[1]: Set hostname to <tegra-ubuntu>.
[ 11.915561] systemd[1]: Listening on Journal Audit Socket.
[ 11.929012] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.944974] systemd[1]: Listening on udev Kernel Socket.
[ 11.960942] systemd[1]: Reached target Encrypted Volumes.
[ 11.977005] systemd[1]: Created slice User and Session Slice.
[ 11.992986] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.013013] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.033008] systemd[1]: Listening on Journal Socket.
[ 12.048989] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 12.064963] systemd[1]: Listening on Syslog Socket.
[ 12.076968] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.092932] systemd[1]: Reached target User and Group Name Lookups.
[ 12.108936] systemd[1]: Reached target Swap.
[ 12.120993] systemd[1]: Created slice System Slice.
[ 12.137006] systemd[1]: Created slice system-getty.slice.
[ 12.169227] systemd[1]: Starting Journal Service...
[ 12.186591] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 12.211279] systemd[1]: Starting Load Kernel Modules...
[ 12.219046] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 12.234092] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.253118] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 12.285132] systemd[1]: Started Braille Device Support.
[ 12.302225] systemd[1]: Mounting Debug File System...
[ 12.317149] systemd[1]: Listening on udev Control Socket.
[ 12.332968] systemd[1]: Reached target Slices.
[ 12.346827] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 12.381199] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 12.404962] systemd[1]: Reached target Remote File Systems (Pre).
[ 12.420960] systemd[1]: Reached target Remote File Systems.
[ 12.453749] systemd[1]: Mounted Debug File System.
[ 12.469072] systemd[1]: Started Journal Service.
[ 12.678903] systemd-journald[204]: Received request to flush runtime journal from PID 1
[ 12.861441] tegra-pcie 10003000.pcie-controller: 1x1, 1x1, 1x1 configuration
[ 12.877381] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[ 12.878798] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 12.879155] tegra-pcie 10003000.pcie-controller: probing port 0, using 1 lanes
[ 12.881057] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 13.009522] dhd_module_init in
[ 13.009555] tegra_net_perf_init: cannot get wifi sclk
[ 13.028696] found wifi platform device bcmdhd_wlan
[ 13.030203] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 13.030210] wifi_platform_get_country_code_map: could not get country_code_map
[ 13.030211] wifi_plat_dev_drv_probe:platform country code map is not available
[ 13.030221] Power-up adapter 'DHD generic adapter'
[ 13.031636] wifi_platform_set_power = 1
[ 13.232899] wifi_platform_bus_enumerate device present 1
[ 13.250330] wifi_platform_bus_enumerate device present 0
[ 13.250637] F1 signature read @0x18000000=0x17214354
[ 13.253508] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 13.253909] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 13.253955] wifi_platform_prealloc: failed to alloc static mem section 7
[ 13.253962] wifi_platform_get_mac_addr
[ 13.255432] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 13.255667] wl_create_event_handler(): thread:wl_event_handler:175 started
[ 13.255684] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1ec541a70
[ 13.255773] dhd_attach(): thread:dhd_watchdog_thread:176 started
[ 13.255812] dhd_attach(): thread:dhd_dpc:177 started
[ 13.255856] dhd_attach(): thread:dhd_rxf:178 started
[ 13.255860] dhd_deferred_work_init: work queue initialized
[ 13.255998] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Mar 1 2017 at 21:08:04
[ 13.256247] tegra_sysfs_register
[ 13.256273] Register interface [wlan0] MAC: 00:04:4b:a5:42:07
[ 13.256276] dhd_prot_ioctl : bus is down. we have nothing to do
[ 13.256347] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 21
[ 13.257377] wifi_platform_set_power = 0
[ 13.321045] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 13.723057] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 13.915052] xhci-tegra 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 13.916899] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 13.916917] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 13.917687] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 13.917709] xhci-tegra 3530000.xhci: irq 54, io mem 0x03530000
[ 13.917815] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 13.917818] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.917820] usb usb1: Product: xHCI Host Controller
[ 13.917821] usb usb1: Manufacturer: Linux 4.4.15-tegra xhci-hcd
[ 13.917823] usb usb1: SerialNumber: 3530000.xhci
[ 13.918096] hub 1-0:1.0: USB hub found
[ 13.918116] hub 1-0:1.0: 4 ports detected
[ 13.936896] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 13.936904] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 13.937012] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 13.937015] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 13.937017] usb usb2: Product: xHCI Host Controller
[ 13.937018] usb usb2: Manufacturer: Linux 4.4.15-tegra xhci-hcd
[ 13.937020] usb usb2: SerialNumber: 3530000.xhci
[ 13.937248] hub 2-0:1.0: USB hub found
[ 13.937264] hub 2-0:1.0: 3 ports detected
[ 14.041422] xhci-tegra 3530000.xhci: entering ELPG
[ 14.123997] xhci-tegra 3530000.xhci: entering ELPG done
[ 14.126351] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 14.128364] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 14.268136] cfg80211: World regulatory domain updated:
[ 14.268141] cfg80211: DFS Master region: unset
[ 14.268142] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 14.268147] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 14.268149] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 14.268151] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 14.268154] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 14.268157] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 14.268160] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 14.268162] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 14.268164] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 14.529586] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 14.933550] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 15.337990] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 15.340006] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
[ 15.340014] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 15.340183] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 15.966839] gk20a 17000000.gp10b: railgate is disabled.
[ 16.072468] Bluetooth: Core ver 2.21
[ 16.078115] NET: Registered protocol family 31
[ 16.084703] Bluetooth: HCI device and connection manager initialized
[ 16.084712] Bluetooth: HCI socket layer initialized
[ 16.084716] Bluetooth: L2CAP socket layer initialized
[ 16.084729] Bluetooth: SCO socket layer initialized
[ 16.364889] CPU1: shutdown
[ 16.369799] psci: CPU1 killed.
[ 16.376917] CPU2: shutdown
[ 16.383953] psci: CPU2 killed.
[ 16.498745] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 16.506855]
[ 16.506862] wl_android_wifi_on in
[ 16.506865] wifi_platform_set_power = 1
[ 16.713999] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 16.757041] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 16.786369] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 16.857495] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 21
[ 16.858355] F1 signature read @0x18000000=0x17214354
[ 16.864547] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 16.865510] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 16.963535] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 17.025636] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 17.026157] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 17.026251] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 17.026256] Enabling wake69
[ 17.027582] wifi_platform_get_mac_addr
[ 17.030653] Firmware up: op_mode=0x0005, MAC=00:04:4b:a5:42:07
[ 17.039964] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 17.047178] Firmware version = wl0: Feb 4 2017 14:39:11 version 7.35.221.11 (r623264) FWID 01-5b44953
[ 17.050930] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 17.051284] tegra_sysfs_on
[ 17.125533] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.190272] gpio tegra-gpio wake18 for gpio=101(M:3)
[ 17.193924] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.402630] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 17.402632] P2P interface registered
[ 17.414910] WLC_E_IF: NO_IF set, event Ignored
[ 17.883643] tegradc 15210000.nvdisplay: blank - powerdown
[ 17.977853] PD DISP2 index4 DOWN
[ 17.977967] PD DISP1 index3 DOWN
[ 17.977969] PD DISP0 index2 DOWN
[ 17.993267] tegradc 15210000.nvdisplay: unblank
[ 17.993275] PD DISP0 index2 UP
[ 17.993339] PD DISP1 index3 UP
[ 17.993340] PD DISP2 index4 UP
[ 17.994460] rate get on hub 408000000
[ 17.994748] Parent Clock set for DC plld2
[ 17.995068] dc clk 148500000
[ 17.997655] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 18.001614] rate get on compclk 148500000
[ 18.013320] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 18.029986] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 18.046653] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 19.101111] tegradc 15210000.nvdisplay: unblank
[ 19.710526] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.767891] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.807772] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.850369] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.860468] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.872186] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.907005] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.917342] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.932004] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 19.972628] pll_a_out0 = 22579200 Hz, aud_mclk = 11289600 Hz, codec rate = 44100 Hz
[ 20.054494] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.059862] Bluetooth: BNEP socket layer initialized
[ 21.018879] fuse init (API version 7.23)
[ 22.765464] tegradc 15210000.nvdisplay: blank - powerdown
[ 22.871576] PD DISP2 index4 DOWN
[ 22.871678] PD DISP1 index3 DOWN
[ 22.871680] PD DISP0 index2 DOWN
[ 22.887085] tegradc 15210000.nvdisplay: unblank
[ 22.887095] PD DISP0 index2 UP
[ 22.887143] PD DISP1 index3 UP
[ 22.887145] PD DISP2 index4 UP
[ 22.888264] rate get on hub 408000000
[ 22.888567] Parent Clock set for DC plld2
[ 22.888887] dc clk 148500000
[ 22.892921] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 22.892926] rate get on compclk 148500000
[ 22.907187] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 22.923857] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 22.940527] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 23.012172] tegradc 15210000.nvdisplay: unblank
[ 57.129370] eqos 2490000.ether_qos eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 57.138907] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 336.535985] tegradc 15210000.nvdisplay: blank - powerdown
[ 336.632582] PD DISP2 index4 DOWN
[ 336.632700] PD DISP1 index3 DOWN
[ 336.632702] PD DISP0 index2 DOWN
