[0000.071] C> I2C command failed
[0000.074] C> block index = (4) and rail_id = (1)
[0000.079] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.195] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-2c57a56c)
[0000.203] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.208] I> DMA Heap @ [0x84a00000 - 0x85300000]
[0000.213] I> bit @ 0xd480000
[0000.215] I> BR-BCT relocated to 0xd7220000
[0000.220] I> Boot-device: eMMC
[0000.223] I> sdmmc bdev is already initialized
[0000.228] I> pmic: reset reason (nverc) : 0x40
[0000.232] I> Reading GPT from 512 for device 00000003
[0000.238] I> Reading GPT from 8388096 for device 00000003
[0000.245] I> Found 6 partitions in 00000003 device
[0000.250] I> Reading GPT from 512 for device 00010003
[0000.257] I> Found 17 partitions in 00010003 device
[0000.262] W> No valid slot number is found in scratch register
[0000.267] W> Return default slot: _a
[0000.271] I> A/B: bin_type (16) slot 0
[0000.274] I> Loading partition bpmp-fw at 0xd7800000
[0000.279] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.285] I> Addr: 0xd7800000, start-block: 58740229, num_blocks: 1
[0000.300] I> Binary(16) of size 528400 is loaded @ 0xd7800000
[0000.305] W> No valid slot number is found in scratch register
[0000.311] W> Return default slot: _a
[0000.314] I> A/B: bin_type (17) slot 0
[0000.318] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.323] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.329] I> Addr: 0xd79f0000, start-block: 58741437, num_blocks: 1
[0000.343] I> Binary(17) of size 465760 is loaded @ 0xd798e200
[0000.521] I> BPMP-FW load address = 0xd7800000
[0000.526] I> BPMP-FW DTB load address = 0x5018e200
[0000.531] I> Loading SCE-FW ...
[0000.534] W> No valid slot number is found in scratch register
[0000.539] W> Return default slot: _a
[0000.543] I> A/B: bin_type (12) slot 0
[0000.546] I> Loading partition sce-fw at 0xd7300000
[0000.551] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.557] I> Addr: 0xd7300000, start-block: 58742437, num_blocks: 1
[0000.565] I> Binary(12) of size 76592 is loaded @ 0xd7300000
[0000.571] I> Init SCE
[0000.573] I> Copy BTCM section
[0000.576] W> No valid slot number is found in scratch register
[0000.582] W> Return default slot: _a
[0000.585] I> A/B: bin_type (13) slot 0
[0000.589] I> Loading partition cpu-bootloader at 0x96000000
[0000.594] I> Reading two headers - addr:0x96000000 blocks:1
[0000.600] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.610] I> Binary(13) of size 221728 is loaded @ 0x96000000
[0000.616] W> No valid slot number is found in scratch register
[0000.622] W> Return default slot: _a
[0000.625] I> A/B: bin_type (20) slot 0
[0000.629] I> Loading partition bootloader-dtb at 0x85300000
[0000.634] I> Reading two headers - addr:0x85300000 blocks:1
[0000.640] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.651] I> Binary(20) of size 267872 is loaded @ 0x85300000
[0000.656] I> MB2-params(VA) @ 0xd7200000
[0000.660] I> CPUBL-params(VA) @ 0xd7200000
[0000.664] I> CPUBL-params(PA) @ 0x277200000
[0000.668] I> CPU-BL loaded @ PA 0x96000000
[0000.672] I> Loading TOS ...
[0000.675] W> No valid slot number is found in scratch register
[0000.681] W> Return default slot: _a
[0000.684] I> A/B: bin_type (14) slot 0
[0000.688] I> Loading partition secure-os at 0x84a0f400
[0000.693] I> Reading two headers - addr:0x84a0f400 blocks:1
[0000.698] I> Addr: 0x84a0f400, start-block: 58734081, num_blocks: 1
[0000.707] I> Binary(14) of size 58480 is loaded @ 0x84a0f400
[0000.712] I> Copying Monitor (length: 0xe270) from 0x84a0f600 to 0x40000000
[0000.719] I> Erasing Monitor @ 0x84a0f600
[0000.724] I> Unhalting SCE
[0000.726] I> Primary Memory Start:80000000 Size:70000000
[0000.732] I> Extended Memory Start:f0110000 Size:185ef0000
[0000.738] I> Waypoint2-ACK: 0x520120b0
[0000.742] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):cc5fd7c
NOTICE: BL31: Built : 00:44:34, Jul 20 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0000.989] I> Welcome to Cboot
[0000.992] I> Cboot Version: 00.00.2014.50-t186-96ecc32e
[0000.997] I> CPU-BL Params @ 0x277200000
[0001.000] I> 0) Base:0x00000000 Size:0x00000000
[0001.005] I> 1) Base:0x277f00000 Size:0x00100000
[0001.009] I> 2) Base:0x277e00000 Size:0x00100000
[0001.014] I> 3) Base:0x277d00000 Size:0x00100000
[0001.018] I> 4) Base:0x277c00000 Size:0x00100000
[0001.023] I> 5) Base:0x277b00000 Size:0x00100000
[0001.027] I> 6) Base:0x277800000 Size:0x00200000
[0001.032] I> 7) Base:0x277400000 Size:0x00400000
[0001.036] I> 8) Base:0x277a00000 Size:0x00100000
[0001.041] I> 9) Base:0x277300000 Size:0x00100000
[0001.045] I> 10) Base:0x276800000 Size:0x00800000
[0001.050] I> 11) Base:0x30000000 Size:0x00040000
[0001.054] I> 12) Base:0xf0000000 Size:0x00100000
[0001.059] I> 13) Base:0x30040000 Size:0x00001000
[0001.063] I> 14) Base:0x30048000 Size:0x00001000
[0001.068] I> 15) Base:0x30049000 Size:0x00001000
[0001.072] I> 16) Base:0x3004a000 Size:0x00001000
[0001.077] I> 17) Base:0x3004b000 Size:0x00001000
[0001.081] I> 18) Base:0x3004c000 Size:0x00001000
[0001.085] I> 19) Base:0x3004d000 Size:0x00001000
[0001.090] I> 20) Base:0x3004e000 Size:0x00001000
[0001.094] I> 21) Base:0x3004f000 Size:0x00001000
[0001.099] I> 22) Base:0x00000000 Size:0x00000000
[0001.103] I> 23) Base:0xf0100000 Size:0x00010000
[0001.108] I> 24) Base:0x00000000 Size:0x00000000
[0001.112] I> 25) Base:0x00000000 Size:0x00000000
[0001.116] I> 26) Base:0x00000000 Size:0x00000000
[0001.121] I> 27) Base:0x00000000 Size:0x00000000
[0001.125] I> 28) Base:0x84400000 Size:0x00400000
[0001.130] I> 29) Base:0x30000000 Size:0x00010000
[0001.134] I> 30) Base:0x278000000 Size:0x08000000
[0001.139] I> 31) Base:0x00000000 Size:0x00000000
[0001.143] I> 32) Base:0x276000000 Size:0x00600000
[0001.148] I> 33) Base:0x80000000 Size:0x70000000
[0001.152] I> 34) Base:0xf0110000 Size:0x185ef0000
[0001.157] I> 35) Base:0x00000000 Size:0x00000000
[0001.161] I> 36) Base:0x00000000 Size:0x00000000
[0001.165] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.170] I> 38) Base:0x84000000 Size:0x00400000
[0001.174] I> 39) Base:0x96000000 Size:0x02000000
[0001.179] I> 40) Base:0x84800000 Size:0x00b00000
[0001.183] I> 41) Base:0x277200000 Size:0x00080000
[0001.188] I> 42) Base:0x00000000 Size:0x00000000
[0001.192] I> 43) Base:0x00000000 Size:0x00000000
[0001.197] GIC-SPI Target CPU: 4
[0001.200] Interrupts Init done
[0001.203] calling constructors
[0001.207] initializing heap
[0001.209] initializing threads
[0001.212] initializing timers
[0001.216] creating bootstrap completion thread
[0001.220] top of bootstrap2()
[0001.224] CPU: ARM Cortex A57
[0001.227] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.232] initializing platform
[0001.235] I> Boot-device: eMMC
[0001.239] I> sdmmc bdev is already initialized
[0001.244] I> Reading GPT from 512 for device 00000003
[0001.249] I> Reading GPT from 8388096 for device 00000003
[0001.256] I> Found 6 partitions in 00000003 device
[0001.261] I> Reading GPT from 512 for device 00010003
[0001.267] I> Found 17 partitions in 00010003 device
[0001.271] W> No valid slot number is found in scratch register
[0001.277] W> Return default slot: _a
[0001.280] I> A/B: bin_type (1) slot 0
[0001.284] I> Loading partition kernel-dtb at 0x92000000
[0001.296] I> Kernel_dtb @0x92000000
[0001.299] I> Bl_dtb @0x85300000
[0001.302] I> gpio framework initialized
[0001.306] I> tegrabl_gpio_driver_register: register 'tegra_gpio_main_driver' driver
[0001.313] I> tegrabl_gpio_driver_register: register 'tegra_gpio_aon_driver' driver
[0001.321] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.330] E> i2c dev write failed
[0001.333] E> tca9539_device_init: failed to write polar reg
[0001.338] E> tegrabl_tca9539_init: failed to init device!
[0001.343] E> GPIO TCA9539 driver init failed
[0001.348] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.355] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.361] W> Loading bmp blob to memory failed
[0001.368] I> fixed regulator driver initialized
[0001.404] I> register 'maxim' power off handle
[0001.410] I> virtual i2c enabled
[0001.413] I> registered 'maxim,max77620' pmic
[0001.417] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.428] I> Find /i2c@c250000's alias i2c7
[0001.432] I> Reading eeprom i2c=7 address=0x50
[0001.463] I> Device at /i2c@c250000:0x50
[0001.467] I> Reading eeprom i2c=7 address=0x57
[0001.496] I> Device at /i2c@c250000:0x57
[0001.501] I> Find /i2c@c240000's alias i2c1
[0001.505] I> Reading eeprom i2c=1 address=0x51
[0001.512] E> i2c dev read failed
[0001.515] E> eeprom: Failed to read I2C slave device
[0001.520] I> Eeprom read failed 0x1a89800d
[0001.524] I> Find /i2c@3160000's alias i2c0
[0001.528] I> Reading eeprom i2c=0 address=0x50
[0001.533] E> i2c dev read failed
[0001.536] E> eeprom: Failed to read I2C slave device
[0001.541] I> Eeprom read failed 0x1a89800d
[0001.546] I> Find /i2c@3180000's alias i2c2
[0001.550] I> Reading eeprom i2c=2 address=0x54
[0001.554] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.559] C> GPIO driver for chip_id 0x2 could not be found
[0001.565] E> cam_eeprom_read: Can't get gpio driver
[0001.569] I> Eeprom read failed 0x2693400d
[0001.573] I> create_pm_ids: id: 3310-1000-B01-D, len: 15
[0001.578] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.589] I> create_pm_ids: id: 2597-0000-500-C, len: 15
[0001.594] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.605] initializing target
[0001.608] calling apps_init()
[0001.612] starting app android_boot_app
[0001.616] I> Gpio keyboard init success
[0001.619] I> Kernel type = Normal
[0001.623] I> Loading kernel/boot.img from storage ...
[0001.627] W> No valid slot number is found in scratch register
[0001.633] W> Return default slot: _a
[0001.636] I> A/B: bin_type (0) slot 0
[0001.640] I> Loading partition kernel at 0xa8000000
[0001.651] W> No valid slot number is found in scratch register
[0001.657] W> Return default slot: _a
[0001.660] I> A/B: bin_type (1) slot 0
[0001.664] I> Loading partition kernel-dtb at 0x92000000
[0001.676] I> Kernel DTB @ 0x92000000
[0001.679] I> Checking boot.img header magic ... [0001.683] I> [OK]
[0001.685] I> Valid boot.img @ 0xa8000000
[0001.689] I> decompressor handler not found
[0001.693] I> Copying kernel image (460026 bytes) from 0xa8000800 to 0x80080000 ... [0001.701] I> Done
[0001.703] I> Move ramdisk (len: 0) from 0xa8071000 to 0x9c000000
[0001.710] I> Updated bpmp info to DTB
[0001.716] I> Ramdisk: Base: 0x9c000000; Size: 0x0
[0001.720] I> Updated initrd info to DTB
[0001.724] I> disabled_core_mask: 0xffffff0c
[0001.728] I> add_serialno: Serial Num = 0322417111608
[0001.733] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0322417111608 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1
[0001.768] I> Updated bootarg info to DTB
[0001.773] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8c:cf:65
[0001.779] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8c:cf:66
[0001.785] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8c:cf:67
[0001.791] E> "ids" doesn't exist, creating
[0001.795] E> "connection" doesn't exist, creating
[0001.800] E> "configs" doesn't exist, creating
[0001.804] I> create_pm_ids: id: 3310-1000-B01-D, len: 15
[0001.809] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.820] I> create_pm_ids: id: 2597-0000-500-C, len: 15
[0001.825] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.836] I> Adding plugin-manager/ids/3310-1000-B01=/i2c@c250000:module@0x50
[0001.843] E> "i2c@c250000" doesn't exist, creating
[0001.848] E> "module@0x50" doesn't exist, creating
[0001.853] I> Adding plugin-manager/ids/2597-0000-500=/i2c@c250000:module@0x57
[0001.860] E> "module@0x57" doesn't exist, creating
[0001.866] I> Adding plugin-manager/ids/3310-1000-B01-D
[0001.873] I> Adding plugin-manager/configs/3310-mem-type 00
[0001.879] I> Adding plugin-manager/configs/3310-power-config 00
[0001.885] I> Adding plugin-manager/configs/3310-misc-config 00
[0001.890] I> Adding plugin-manager/configs/3310-modem-config 00
[0001.896] I> Adding plugin-manager/configs/3310-touch-config 00
[0001.902] I> Adding plugin-manager/configs/3310-display-config 00
[0001.908] E> "chip-id" doesn't exist, creating
[0001.912] I> Adding plugin-manager/chip-id/A02P
[0001.919] I> Updated memory info to DTB
[0001.925] E> "reset" doesn't exist, creating
[0001.929] E> "pmc-reset-reason" doesn't exist, creating
[0001.934] E> "pmic-reset-reason" doesn't exist, creating
[0001.939] I> disabled_core_mask: 0xffffff0c
[0001.951] I> Add serial number as DT property
[0001.956] I> tegrabl_load_kernel_and_dtb: Done
U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:45:25 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 2 1 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 79 ms (2 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
20280368 bytes read in 543 ms (35.6 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0322417111608 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
## Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 00000000920465fb
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-553) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf4000 s31232 r8192 d30208 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0322417111608 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7972328K/8204288K available (10976K kernel code, 1817K rwdata, 5712K rodata, 1164K init, 682K bss, 166424K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
[ 0.000000] .init : 0xffffffc0010cd000 - 0xffffffc0011f0000 ( 1164 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010cd000 ( 16692 KB)
[ 0.000000] .data : 0xffffffc001211000 - 0xffffffc0013d7430 ( 1818 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.010361] Console: colour dummy device 80x25
[ 0.015081] console [tty0] enabled
[ 0.018648] bootconsole [uart0] disabled
[ 0.022767] kmemleak: Kernel memory leak detector disabled
[ 0.022786] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022802] pid_max: default: 32768 minimum: 301
[ 0.022885] Security Framework initialized
[ 0.022940] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022950] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.023715] Initializing cgroup subsys freezer
[ 0.023739] Initializing cgroup subsys debug
[ 0.024134] CPU0 ipc=752
[ 0.024149] CPU1 ipc=1024
[ 0.024160] CPU2 ipc=1024
[ 0.024171] CPU3 ipc=752
[ 0.024184] CPU4 ipc=752
[ 0.024196] CPU5 ipc=752
[ 0.024282] ASID allocator initialised with 65536 entries
[ 0.052766] tegra-id: chipid=21817.
[ 0.052801] tegra-id: opt_subrevision=1.
[ 0.052814] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.053514] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.053535] DTB Build time: Sep 19 2017 09:28:46
[ 0.074358] CPU1: Booted secondary processor [4e0f0030]
[ 0.087996] CPU2: Booted secondary processor [4e0f0030]
[ 0.099192] CPU3: Booted secondary processor [411fd073]
[ 0.111144] CPU4: Booted secondary processor [411fd073]
[ 0.123154] CPU5: Booted secondary processor [411fd073]
[ 0.123347] Brought up 6 CPUs
[ 0.123419] SMP: Total of 6 processors activated.
[ 0.123432] CPU: All CPU(s) started at EL2
[ 0.124571] devtmpfs: initialized
[ 0.159302] Initilizing CustomIPI irq domain
[ 0.159740] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.161552] pinctrl core: initialized pinctrl subsystem
[ 0.162227] OS set in device tree is L4T.
[ 0.162664] regulator-dummy: no parameters
[ 0.162864] Initializing plugin-manager
[ 0.162952] Plugin module not found
[ 0.163381] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.164179] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.164837] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.166108] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.166598] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.166923] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.167156] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.167637] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.168139] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.168474] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.168861] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.169138] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.169380] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.169706] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.171806] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.174722] Adding domain adsp-pd to PM domain ape-pd
[ 0.179343] NET: Registered protocol family 16
[ 0.180857] console [pstore-1] enabled
[ 0.180878] pstore: Registered ramoops as persistent store backend
[ 0.180896] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.189602] cpuidle: using governor ladder
[ 0.195160] cpuidle: using governor menu
[ 0.198116] bpmp: waiting for handshake
[ 0.198142] bpmp: handshake completed
[ 0.198203] bpmp: synchronizing channels
[ 0.198242] bpmp: channels synchronized
[ 0.198257] bpmp: mail init ok
[ 0.198696] vdso: 2 pages (1 code @ ffffffc001219000, 1 data @ ffffffc001218000)
[ 0.198762] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.202650] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.205304] tegra_powergate_init: DONE
[ 0.205339] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.205366] DTB Build time: Sep 19 2017 09:28:46
[ 0.207411] Tegra reboot handler registered.
[ 0.210781] Registering Tegra186 clocks (this may take a while)...done
[ 0.214657] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.214689] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.214711] arm-smmu 12000000.iommu: stage 1 translation
[ 0.214729] arm-smmu 12000000.iommu: stage 2 translation
[ 0.214745] arm-smmu 12000000.iommu: nested translation
[ 0.214767] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.214791] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.214815] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.214835] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.214852] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.265679] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.273545] iommu: Adding device 3460000.sdhci to group 0
[ 0.274707] iommu: Adding device 3400000.sdhci to group 1
[ 0.280804] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.281501] iommu: Adding device 3160000.i2c to group 3
[ 0.281984] iommu: Adding device c240000.i2c to group 4
[ 0.282365] iommu: Adding device 3180000.i2c to group 5
[ 0.282756] iommu: Adding device 3190000.i2c to group 6
[ 0.283221] iommu: Adding device 31b0000.i2c to group 7
[ 0.283608] iommu: Adding device 31c0000.i2c to group 8
[ 0.283960] iommu: Adding device c250000.i2c to group 9
[ 0.284310] iommu: Adding device 31e0000.i2c to group 10
[ 0.286574] iommu: Adding device 3210000.spi to group 11
[ 0.286954] iommu: Adding device c260000.spi to group 12
[ 0.287266] iommu: Adding device 3240000.spi to group 13
[ 0.288096] iommu: Adding device 3100000.serial to group 14
[ 0.288447] iommu: Adding device 3110000.serial to group 15
[ 0.288790] iommu: Adding device c280000.serial to group 16
[ 0.289150] iommu: Adding device 3130000.serial to group 17
[ 0.290495] iommu: Adding device 2490000.ether_qos to group 18
[ 0.291223] iommu: Adding device b000000.rtcpu to group 19
[ 0.291788] iommu: Adding device c1a0000.aon to group 20
[ 0.292803] Wake73 for irq=42
[ 0.293167] iommu: Adding device smmu_test to group 21
[ 0.293824] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.293871] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.293910] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.293955] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.294025] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.294106] mc-err: Set intmask: 0xf3140
[ 0.294572] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.295482] Wake76 for irq=199
[ 0.295508] Wake77 for irq=199
[ 0.295530] Wake78 for irq=199
[ 0.295551] Wake79 for irq=199
[ 0.295572] Wake80 for irq=199
[ 0.295592] Wake81 for irq=199
[ 0.295613] Wake82 for irq=199
[ 0.295742] iommu: Adding device 3530000.xhci to group 22
[ 0.296139] iommu: Adding device 3550000.xudc to group 23
[ 0.297039] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.297105] tegra-pmc: ### PMC reset source: Power on reset
[ 0.297129] tegra-pmc: ### PMC reset level: L0
[ 0.297152] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.297506] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.297745] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.297931] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.297963] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.298492] iommu: Adding device 13e10000.host1x to group 24
[ 0.298836] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.299110] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.299426] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.299737] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.300069] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.300349] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.300671] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.300991] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.301609] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.302400] iommu: Adding device 15700000.vi to group 34
[ 0.302765] iommu: Adding device 15600000.isp to group 35
[ 0.303152] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.303396] iommu: Adding device 15340000.vic to group 37
[ 0.303614] iommu: Adding device 154c0000.nvenc to group 38
[ 0.303848] iommu: Adding device 15480000.nvdec to group 39
[ 0.304233] iommu: Adding device 15380000.nvjpg to group 40
[ 0.304465] iommu: Adding device 15500000.tsec to group 41
[ 0.304701] iommu: Adding device 15100000.tsecb to group 42
[ 0.305434] iommu: Adding device 15810000.se to group 43
[ 0.305645] iommu: Adding device 15820000.se to group 44
[ 0.305889] iommu: Adding device 15830000.se to group 45
[ 0.306129] iommu: Adding device 15840000.se to group 46
[ 0.306799] iommu: Adding device 17000000.gp10b to group 47
[ 0.308679] tegra-reset 5000000.clock: registered 193 resets.
[ 0.310925] iommu: Adding device d000000.bpmp to group 48
[ 0.311304] bpmp: ping status is 0
[ 0.311714] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.312201] bpmp d000000.bpmp: probe ok
[ 0.314920] iommu: Adding device 2600000.dma to group 49
[ 0.315995] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.316093] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.316160] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.316220] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.316304] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.316369] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.316433] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.316564] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.318790] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.318914] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.320058] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.320449] iommu: Adding device sound to group 51
[ 0.322579] iommu: Adding device 3510000.hda to group 52
[ 0.324096] iommu: Adding device adsp_audio to group 53
[ 0.325816] iommu: Adding device 2993000.adsp to group 54
[ 0.339751] vdd-ac-bat: 5000 mV
[ 0.342603] vdd-1v8-ap: 1800 mV
[ 0.344412] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.344841] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.366253] SCSI subsystem initialized
[ 0.366941] usbcore: registered new interface driver usbfs
[ 0.367017] usbcore: registered new interface driver hub
[ 0.367170] usbcore: registered new device driver usb
[ 0.372583] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.373404] pca953x 0-0074: failed reading register
[ 0.373526] pca953x: probe of 0-0074 failed with error -121
[ 0.373946] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.374745] pca953x 0-0077: failed reading register
[ 0.374814] pca953x: probe of 0-0077 failed with error -121
[ 0.395992] media: Linux media interface: v0.10
[ 0.396150] Linux video capture interface: v2.00
[ 0.401994] pps_core: LinuxPPS API ver. 1 registered
[ 0.402045] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.402101] PTP clock support registered
[ 0.403796] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.403898] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.406252] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.409333] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.409620] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.409750] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.418574] vddio-ddr: at 1125 mV
[ 0.422336] avdd_dsi_csi: 1200 mV
[ 0.426334] vdd-1v8: 1800 mV
[ 0.430335] vdd-3v3-sys: 3300 mV
[ 0.431969] spmic-ldo0: at 1800 mV
[ 0.433001] spmic-ldo1: at 800 mV
[ 0.437584] vddio-3v3: 3300 mV
[ 0.438361] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.441581] vdd-rtc: at 800 mV
[ 0.442549] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.445580] spmic-ldo6: at 1500 mV
[ 0.449581] vdd-pex-1v05: 1000 mV
[ 0.450376] dvdd-pex: 1000 mV
[ 0.450828] max77620 4-003c: max77620 probe successful
[ 0.451615] Advanced Linux Sound Architecture Driver Initialized.
[ 0.453850] en-vdd-sd: 3300 mV
[ 0.454302] vdd-usb0-5v: 5000 mV
[ 0.454573] vdd-usb1-5v: 5000 mV
[ 0.455135] vdd-3v3: 3300 mV
[ 0.455385] en-vdd-vcm-2v8: 2800 mV
[ 0.455581] vdd-sys-bl: 3300 mV
[ 0.460433] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.462930] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.463545] clocksource: Switched to clocksource arch_sys_counter
[ 0.499443] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.500388] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.501949] nvmap_page_pool_init: Total RAM pages: 2009466
[ 0.501985] nvmap_page_pool_init: nvmap page pool size: 251183 pages (981 MB)
[ 0.502475] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.508388] Wake76 for irq=199
[ 0.508406] Wake77 for irq=199
[ 0.508420] Wake78 for irq=199
[ 0.508435] Wake79 for irq=199
[ 0.508448] Wake80 for irq=199
[ 0.508462] Wake81 for irq=199
[ 0.508475] Wake82 for irq=199
[ 0.509913] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.510168] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.510317] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.510417] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.510905] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.511112] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.511289] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.511485] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.511994] isomgr_init(): iso emc max clk=0KHz
[ 0.512011] isomgr_init(): max_iso_bw=0KB
[ 0.512189] NET: Registered protocol family 2
[ 0.512900] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.513159] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.514272] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.514447] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.514516] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.514877] NET: Registered protocol family 1
[ 0.515423] RPC: Registered named UNIX socket transport module.
[ 0.515451] RPC: Registered udp transport module.
[ 0.515469] RPC: Registered tcp transport module.
[ 0.515486] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.515833] Trying to unpack rootfs image as initramfs...
[ 0.546426] host1x 13e10000.host1x: initialized
[ 0.549040] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.555066] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.555338] audit: initializing netlink subsys (disabled)
[ 0.555462] audit: type=2000 audit(0.540:1): initialized
[ 0.568767] io scheduler noop registered (default)
[ 0.575109] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.578110] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.580578] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.582997] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.594130] tsec 15500000.tsec: initialized
[ 0.597415] tsec 15100000.tsecb: initialized
[ 0.604905] nvdec 15480000.nvdec: initialized
[ 0.614672] falcon 15340000.vic: initialized
[ 0.617140] falcon 154c0000.nvenc: initialized
[ 0.619712] falcon 15380000.nvjpg: initialized
[ 0.622576] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.624094] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.625464] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.626835] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.628366] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.629680] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.631027] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.632469] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.640300] DC OR NODE connected to /host1x/sor1
[ 0.640858] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.640867] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.640992] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.641324] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.641371] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.641414] max_iso_bw is relaxed to 4687500KB from 0KB
[ 0.641545] ------------[ cut here ]------------
[ 0.641582] WARNING: at ffffffc00086f850 [verbose debug info unavailable]
[ 0.641603] Modules linked in:
[ 0.641632]
[ 0.641663] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.38-tegra #1
[ 0.641685] Hardware name: quill (DT)
[ 0.641706] task: ffffffc1ece70000 ti: ffffffc1ece78000 task.ti: ffffffc1ece78000
[ 0.641753] PC is at __tegra_isomgr_register+0x30c/0x4d4
[ 0.641776] LR is at __tegra_isomgr_register+0x30c/0x4d4
[ 0.641797] pc : [<ffffffc00086f850>] lr : [<ffffffc00086f850>] pstate: 60000045
[ 0.641826] sp : ffffffc1ece7bb10
[ 0.641846] x29: ffffffc1ece7bb10 x28: 0000000000000380
[ 0.641883] x27: ffffffc001467000 x26: ffffffc0013a7000
[ 0.641918] x25: ffffffc000c2d000 x24: 0000000000000000
[ 0.641951] x23: 0000000000000000 x22: 0000000000000008
[ 0.641985] x21: 000000000047868c x20: ffffffc001467718
[ 0.642019] x19: ffffffc001467af8 x18: 000000000000000b
[ 0.642053] x17: 0000000000000a3f x16: ffffffc000b38a60
[ 0.642089] x15: 00000000fa83b2da x14: 73696765725f7267
[ 0.642123] x13: 6d6f73695f617265 x12: 6d61635f61726765
[ 0.642157] x11: 74203a6c7274635f x10: ffffffc001400e88
[ 0.642195] x9 : 000000000000014c x8 : 0000000000000002
[ 0.642228] x7 : ffffffc0012342a8 x6 : 000000000000003a
[ 0.642262] x5 : 0000000000000000 x4 : 0000000000000000
[ 0.642296] x3 : 0000000000000000 x2 : 0000000000000000
[ 0.642330] x1 : 0000000000000000 x0 : 000000000000002b
[ 0.642375]
[ 0.642422] ---[ end trace 3d544e56bf34c56b ]---
[ 0.642444] Call trace:
[ 0.642514] [<ffffffc00086f850>] __tegra_isomgr_register+0x30c/0x4d4
[ 0.642538] [<ffffffc00086fa34>] tegra_isomgr_register+0x1c/0x2c
[ 0.642577] [<ffffffc000440cd4>] tegra_camera_probe+0x2a4/0x4c4
[ 0.642619] [<ffffffc00056a28c>] platform_drv_probe+0x50/0xbc
[ 0.642648] [<ffffffc000567d1c>] driver_probe_device+0xc8/0x408
[ 0.642670] [<ffffffc0005680f8>] __driver_attach+0x9c/0xa0
[ 0.642693] [<ffffffc000565d98>] bus_for_each_dev+0x58/0x98
[ 0.642717] [<ffffffc0005677c4>] driver_attach+0x20/0x28
[ 0.642738] [<ffffffc000567334>] bus_add_driver+0x1f0/0x294
[ 0.642760] [<ffffffc000568f78>] driver_register+0x68/0x108
[ 0.642782] [<ffffffc00056a1d0>] __platform_driver_register+0x54/0x5c
[ 0.642811] [<ffffffc0010fa9d8>] tegra_camera_init+0x18/0x20
[ 0.642845] [<ffffffc000081ab4>] do_one_initcall+0xc8/0x1c0
[ 0.642877] [<ffffffc0010cdb6c>] kernel_init_freeable+0x1dc/0x280
[ 0.642912] [<ffffffc000b27a14>] kernel_init+0x10/0xe0
[ 0.642937] [<ffffffc000084f90>] ret_from_fork+0x10/0x40
[ 0.642961] __tegra_isomgr_register(): ISO BW usage:
[ 0.642983] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 0.643004] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 0.643025] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 0.643046] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 0.643068] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=4687500KB
[ 0.643097] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 0.643119] __tegra_isomgr_register(): client=eqos, iso dedi bw=0KB
[ 0.643139] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 0.657629] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.657681] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.658521] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ 0.661279] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.663110] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.663163] PD DISP0 index2 UP
[ 0.664700] PD DISP1 index3 UP
[ 0.665173] PD DISP2 index4 UP
[ 0.666379] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.667038] kfuse 3830000.kfuse: initialized
[ 0.669379] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.670233] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.674928] console [ttyS0] disabled
[ 0.675123] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.692670] Unsupported HDMI VIC 15, ignoring
[ 0.692673] Unsupported HDMI VIC 29, ignoring
[ 0.692675] Unsupported HDMI VIC 114, ignoring
[ 0.692677] Unsupported HDMI VIC 81, ignoring
[ 0.692699] PD DISP2 index4 DOWN
[ 0.693008] PD DISP1 index3 DOWN
[ 0.693297] PD DISP0 index2 DOWN
[ 0.696400] tegradc 15210000.nvdisplay: probed
[ 3.000151] console [ttyS0] enabled
[ 3.004117] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 3.005947] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 3.006221] serial-tegra 3130000.serial: RX in PIO mode
[ 3.007808] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 3.015970] Console: switching to colour frame buffer device 240x67
[ 3.021435] brd: module loaded
[ 3.027393] loop: module loaded
[ 3.028339] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.028366] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 3.028417] nct1008_nct72 7-004c: starting parse dt
[ 3.028553] nct1008_nct72 7-004c: success parsing dt
[ 3.028860] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 3.107026] tegradc 15210000.nvdisplay: fb registered
[ 3.108756] tmp451: Enabled overheat logging at 104.00C
[ 3.108904] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 3.108964] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 3.112560] THERMAL EST: found 3 subdevs
[ 3.112566] THERMAL EST num_resources: 0
[ 3.112571] [THERMAL EST subdev 0]
[ 3.112580] [THERMAL EST subdev 1]
[ 3.112585] [THERMAL EST subdev 2]
[ 3.112956] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 3.112958] THERMAL EST: thz register success.
[ 3.113134] THERMAL EST: end of probe, return err: 0
[ 3.113540] tegra_profiler: Branch: Dev
[ 3.113541] tegra_profiler: Version: 1.109
[ 3.113543] tegra_profiler: Samples version: 37
[ 3.113544] tegra_profiler: IO version: 21
[ 3.113552] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.113556] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.113559] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.113561] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 3.113563] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.113565] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 3.113568] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.113570] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.113572] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.113574] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.113576] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.113578] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.113877] tegra_profiler: auth: init
[ 3.120547] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 3.123700] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 3.123711] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 3.124888] scsi host0: tegra_ahci
[ 3.125267] scsi host1: tegra_ahci
[ 3.125414] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 3.125416] ata2: DUMMY
[ 3.127039] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.127665] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.128156] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.129219] tun: Universal TUN/TAP device driver, 1.6
[ 3.129221] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.129470] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.129473] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.129516] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 3.129518] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.130682] PPP generic driver version 2.4.2
[ 3.130890] PPP BSD Compression module registered
[ 3.130896] PPP Deflate Compression module registered
[ 3.130934] PPP MPPE Compression module registered
[ 3.130950] NET: Registered protocol family 24
[ 3.131028] usbcore: registered new interface driver r8152
[ 3.131064] usbcore: registered new interface driver asix
[ 3.131089] usbcore: registered new interface driver ax88179_178a
[ 3.131122] usbcore: registered new interface driver cdc_ether
[ 3.131160] usbcore: registered new interface driver smsc95xx
[ 3.131186] usbcore: registered new interface driver net1080
[ 3.131210] usbcore: registered new interface driver cdc_subset
[ 3.131239] usbcore: registered new interface driver zaurus
[ 3.131299] usbcore: registered new interface driver cdc_ncm
[ 3.131722] Wake76 for irq=199
[ 3.131723] Wake77 for irq=199
[ 3.131725] Wake78 for irq=199
[ 3.131726] Wake79 for irq=199
[ 3.131727] Wake80 for irq=199
[ 3.131728] Wake81 for irq=199
[ 3.131730] Wake82 for irq=199
[ 3.131809] tegra-xotg xotg: usb2 phy is not available yet
[ 3.132474] usbcore: registered new interface driver usb-storage
[ 3.132570] usbcore: registered new interface driver usbserial
[ 3.132597] usbcore: registered new interface driver ftdi_sio
[ 3.132624] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 3.132647] usbcore: registered new interface driver option
[ 3.132664] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.132687] usbcore: registered new interface driver pl2303
[ 3.132711] usbserial: USB Serial support registered for pl2303
[ 3.133014] tegra-usb-cd usb_cd: otg phy is not available yet
[ 3.137025] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c cf 67
[ 3.137805] libphy: dwc_phy: probed
[ 3.138422] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 3.200654] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 3.200815] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.201673] max_iso_bw is relaxed to 4769420KB from 4687500KB
[ 3.201673] ------------[ cut here ]------------
[ 3.201677] WARNING: at ffffffc00086f850 [verbose debug info unavailable]
[ 3.201681] Modules linked in:
[ 3.201682]
[ 3.201694] CPU: 0 PID: 149 Comm: kworker/u12:4 Tainted: G W 4.4.38-tegra #1
[ 3.201695] Hardware name: quill (DT)
[ 3.201717] Workqueue: events_unbound async_run_entry_fn
[ 3.201719] task: ffffffc1e6068c80 ti: ffffffc1e607c000 task.ti: ffffffc1e607c000
[ 3.201732] PC is at __tegra_isomgr_register+0x30c/0x4d4
[ 3.201735] LR is at __tegra_isomgr_register+0x30c/0x4d4
[ 3.201737] pc : [<ffffffc00086f850>] lr : [<ffffffc00086f850>] pstate: 80000045
[ 3.201739] sp : ffffffc1e607fa70
[ 3.201742] x29: ffffffc1e607fa70 x28: 0000000000000460
[ 3.201747] x27: ffffffc001467000 x26: ffffffc0013a7000
[ 3.201749] x25: ffffffc000c2d000 x24: 0000000000000000
[ 3.201752] x23: 0000000000000000 x22: 000000000000000a
[ 3.201754] x21: 0000000000014000 x20: ffffffc001467718
[ 3.201757] x19: ffffffc001467bd8 x18: ffffffc000baa0e0
[ 3.201759] x17: 000000000000000e x16: ffffffc000b38a60
[ 3.201761] x15: ffffffc000b38a60 x14: 0000000000000002
[ 3.201764] x13: 00001bc1f46860b0 x12: 0000000000007fda
[ 3.201766] x11: 00000000000e67b9 x10: ffffffc001400e88
[ 3.201769] x9 : ffffffc1e607f910 x8 : 206d6f726620424b
[ 3.201771] x7 : 3032343936373420 x6 : ffffffc001401838
[ 3.201775] x5 : 0000000005f1c4cb x4 : 0000000000000000
[ 3.201777] x3 : 0000000000000000 x2 : 0000000000000000
[ 3.201779] x1 : 0000000000000000 x0 : 0000000000000031
[ 3.201781]
[ 3.201783] ---[ end trace 3d544e56bf34c56c ]---
[ 3.201788] Call trace:
[ 3.201791] [<ffffffc00086f850>] __tegra_isomgr_register+0x30c/0x4d4
[ 3.201795] [<ffffffc00086fa34>] tegra_isomgr_register+0x1c/0x2c
[ 3.201803] [<ffffffc000688a84>] eqos_probe+0xad0/0x11c4
[ 3.201815] [<ffffffc00056a28c>] platform_drv_probe+0x50/0xbc
[ 3.201823] [<ffffffc000567d1c>] driver_probe_device+0xc8/0x408
[ 3.201826] [<ffffffc0005680f8>] __driver_attach+0x9c/0xa0
[ 3.201831] [<ffffffc000565d98>] bus_for_each_dev+0x58/0x98
[ 3.201835] [<ffffffc0005677c4>] driver_attach+0x20/0x28
[ 3.201839] [<ffffffc000566254>] driver_attach_async+0x14/0x50
[ 3.201841] [<ffffffc0000c4264>] async_run_entry_fn+0x44/0x180
[ 3.201852] [<ffffffc0000bbc24>] process_one_work+0x154/0x434
[ 3.201854] [<ffffffc0000bc038>] worker_thread+0x134/0x40c
[ 3.201860] [<ffffffc0000c18c8>] kthread+0xe0/0xf4
[ 3.201869] [<ffffffc000084f90>] ret_from_fork+0x10/0x40
[ 3.201870] __tegra_isomgr_register(): ISO BW usage:
[ 3.201874] __tegra_isomgr_register(): client=disp_0, iso dedi bw=0KB
[ 3.201877] __tegra_isomgr_register(): client=disp_1, iso dedi bw=0KB
[ 3.201879] __tegra_isomgr_register(): client=disp_2, iso dedi bw=0KB
[ 3.201881] __tegra_isomgr_register(): client=isp_a, iso dedi bw=0KB
[ 3.201885] __tegra_isomgr_register(): client=tegra_camera_ctrl, iso dedi bw=4687500KB
[ 3.201887] __tegra_isomgr_register(): client=ape_adma, iso dedi bw=0KB
[ 3.201890] __tegra_isomgr_register(): client=eqos, iso dedi bw=81920KB
[ 3.201891] __tegra_isomgr_register(): revisit BW usage of iso clients
[ 3.272347] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.275070] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 3.275110] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 3.275320] i2c /dev entries driver
[ 3.276494] gspca_main: v2.14.0 registered
[ 3.276570] usbcore: registered new interface driver gspca_zc3xx
[ 3.276960] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.279722] FAN: coudln't get the regulator
[ 3.280594] device-mapper: uevent: version 1.0.3
[ 3.280868] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.281464] sdhci: Secure Digital Host Controller Interface driver
[ 3.281465] sdhci: Copyright(c) Pierre Ossman
[ 3.281470] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.281957] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.282504] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.283275] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.283440] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.283684] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.285552] usbcore: registered new interface driver usbhid
[ 3.285553] usbhid: USB HID core driver
[ 3.288108] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 3.289078] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 3.289259] ina3221x: probe of 0-0042 failed with error -121
[ 3.289704] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.290388] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.290491] ina3221x: probe of 0-0043 failed with error -121
[ 3.291112] nvadsp 2993000.adsp: in probe()...
[ 3.292754] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.292803] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.293112] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.306351] Denver: backdoor interface is NOT available.
[ 3.309087] coresight-tmc 8030000.etf: TMC initialized
[ 3.315229] coresight-tmc 8050000.etr: TMC initialized
[ 3.315947] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.316750] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.317450] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.318099] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.318690] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.319631] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.320415] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.321216] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.322012] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.322056] Module initialized successfully
[ 3.323586] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.325136] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.325566] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.327898] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.330232] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.330665] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.331205] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.331260] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.331333] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.331388] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.331433] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.331477] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.331526] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.331761] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.331764] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.332542] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.332545] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.332548] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.332551] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.332553] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.332555] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.332557] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.332596] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.338911] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.340075] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.340208] camchar: rtcpu character device driver loaded
[ 3.348307] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.348948] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.349399] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.350508] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.350547] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.350588] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.350625] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.350659] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.350696] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.350737] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.350771] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.350803] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.350835] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.350871] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.350905] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.350943] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.350977] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.351013] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.351070] **** A57 ECC: Enabled
[ 3.351074] tegra18_a57_serr_init: on CPU 3 a A57 Core
[ 3.351269] parse_throttle_dt_data: Num cap clks = 4
[ 3.351274] parse_throttle_dt_data: clk=mcpu type=1
[ 3.351276] parse_throttle_dt_data: clk=bcpu type=2
[ 3.351291] parse_throttle_dt_data: clk=gpu type=4
[ 3.351293] parse_throttle_dt_data: clk=emc type=3
[ 3.352079] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.352220] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 3.352821] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.358008] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.359631] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.362696] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.362773] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.362877] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.362929] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.363507] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.365734] mmc0: MAN_BKOPS_EN bit is not set
[ 3.374576] mmc0: Skipping tuning since strobe enabled
[ 3.384355] mmc0: periodic cache flush enabled
[ 3.384370] mmc0: new HS400 MMC card at address 0001
[ 3.384969] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.385154] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.385344] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.385550] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.387317] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 3.419690] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.419761] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.432247] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.443596] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.633267] mmc1 tuning done saved tap delay=64
[ 3.633276] mmc1: hw tuning done ...
[ 3.633286] mmc1: tuning_window[0]: 0xffffffff
[ 3.633293] mmc1: tuning_window[1]: 0xfffff8ff
[ 3.633299] mmc1: tuning_window[2]: 0xfe7fffff
[ 3.633305] mmc1: tuning_window[3]: 0x7fffffff
[ 3.633310] mmc1: tuning_window[4]: 0x0
[ 3.633322] mmc1: tuning_window[5]: 0x0
[ 3.633364] mmc1: tuning_window[6]: 0x0
[ 3.633370] mmc1: tuning_window[7]: 0x0
[ 3.633374] sdhci: Tap value: 64 | Trim value: 5
[ 3.633378] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.644713] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.644808] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 5.037017] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 5.049901] PD DISP0 index2 UP
[ 5.056026] PD DISP1 index3 UP
[ 5.060728] PD DISP2 index4 UP
[ 5.067015] Parent Clock set for DC plld2
[ 5.078798] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 5.107714] tegra-se-nvhost 15810000.se: initialized
[ 5.122405] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 5.137647] tegra-se-nvhost 15820000.se: initialized
[ 5.151963] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 5.167595] tegra-se-nvhost 15830000.se: initialized
[ 5.181512] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 5.197663] tegra-se-nvhost 15840000.se: initialized
[ 5.205323] tegra-se-nvhost 15840000.se: teg
