im using my own carrier with nearly the same usb connections as the nvidia carrier board (only missing INA3221). i only need one usb 2.0 connector - so my USB 2.0 connector is conneted to A38 and A39.
With L4T 27.1 i could fix this with the Jetson/TX2 USB - eLinux.org device tree patch for vbus-2-supply = <&battery_reg>;
But with 28.2.1 the usb is not working any more.
perhaps someone can help me.
thanks
[ 13.666280] fuse init (API version 7.23)<\r><\n>
<\r><\r><\n>
Ubuntu 16.04 LTS tegra-ubuntu ttyS0<\r><\n>
<\r><\n>
tegra-ubuntu login: nvidia (automatic login)<\r><\n>
<\r><\r><\n>
Last login: Fri Jul 27 08:35:47 UTC 2018 on ttyS0<\r><\n>
Welcome to Ubuntu 16.04 LTS (GNU/Linux 4.4.38-tegra aarch64)<\r><\n>
<\r><\n>
* Documentation: https://help.ubuntu.com/<\r><\n>
<\r><\n>
607 packages can be updated.<\r><\n>
323 updates are security updates.<\r><\n>
<\r><\n>
nvidia@tegra-ubuntu:~$ [ 16.195475] IPVS: Creating netns size=1424 id=2<\r><\n>
[ 16.342404] tegradc 15210000.nvdisplay: blank - powerdown<\r><\n>
[ 16.411312] PD DISP2 index4 DOWN<\r><\n>
[ 16.411406] PD DISP1 index3 DOWN<\r><\n>
[ 16.411490] PD DISP0 index2 DOWN<\r><\n>
[ 16.427922] tegradc 15210000.nvdisplay: unblank<\r><\n>
[ 16.427935] PD DISP0 index2 UP<\r><\n>
[ 16.429720] PD DISP1 index3 UP<\r><\n>
[ 16.429805] PD DISP2 index4 UP<\r><\n>
[ 16.436506] Parent Clock set for DC plld2<\r><\n>
[ 16.438289] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M<\r><\n>
[ 16.498346] tegradc 15210000.nvdisplay: unblank<\r><\n>
[ 17.182613] IPVS: Creating netns size=1424 id=3<\r><\n>
<\0>[0000.140] C> I2C command failed<\r><\n>
[0000.143] C> block index = (4) and rail_id = (1)<\r><\n>
[0000.148] C> Addr: Reg = [0xe8:0x07]: 336166925<\r><\n>
[0000.265] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c4328dc3)<\r><\n>
[0000.273] I> Default Heap @ [0xd486400 - 0xd488400]<\r><\n>
[0000.278] I> DMA Heap @ [0x85200000 - 0x86200000]<\r><\n>
[0000.283] I> bit @ 0xd480000<\r><\n>
[0000.286] I> BR-BCT relocated to 0xd7020000<\r><\n>
[0000.290] I> Boot-device: eMMC<\r><\n>
[0000.294] I> sdmmc bdev is already initialized<\r><\n>
[0000.298] I> pmic: reset reason (nverc)<9>: 0x80<\r><\n>
[0000.303] I> Reading GPT from 512 for device 00000003<\r><\n>
[0000.308] I> Reading GPT from 8388096 for device 00000003<\r><\n>
[0000.316] I> Found 13 partitions in 00000003 device<\r><\n>
[0000.320] I> Reading GPT from 512 for device 00010003<\r><\n>
[0000.327] I> Found 29 partitions in 00010003 device<\r><\n>
[0000.332] W> No valid slot number is found in scratch register<\r><\n>
[0000.338] W> Return default slot: _a<\r><\n>
[0000.342] I> A/B: bin_type (16) slot 0<\r><\n>
[0000.345] I> Loading partition bpmp-fw at 0xd7800000<\r><\n>
[0000.350] I> Reading two headers - addr:0xd7800000 blocks:1<\r><\n>
[0000.355] I> Addr: 0xd7800000, start-block: 58761217, num_blocks: 1<\r><\n>
[0000.370] I> Binary(16) of size 529040 is loaded @ 0xd7800000<\r><\n>
[0000.376] W> No valid slot number is found in scratch register<\r><\n>
[0000.382] W> Return default slot: _a<\r><\n>
[0000.385] I> A/B: bin_type (17) slot 0<\r><\n>
[0000.389] I> Loading partition bpmp-fw-dtb at 0xd79f0000<\r><\n>
[0000.394] I> Reading two headers - addr:0xd79f0000 blocks:1<\r><\n>
[0000.399] I> Addr: 0xd79f0000, start-block: 58763633, num_blocks: 1<\r><\n>
[0000.413] I> Binary(17) of size 465760 is loaded @ 0xd798e200<\r><\n>
[0000.591] I> BPMP-FW load address = 0xd7800000<\r><\n>
[0000.595] I> BPMP-FW DTB load address = 0x5018e200<\r><\n>
[0000.600] I> Loading SCE-FW ...<\r><\n>
[0000.603] W> No valid slot number is found in scratch register<\r><\n>
[0000.609] W> Return default slot: _a<\r><\n>
[0000.612] I> A/B: bin_type (12) slot 0<\r><\n>
[0000.616] I> Loading partition sce-fw at 0xd7300000<\r><\n>
[0000.621] I> Reading two headers - addr:0xd7300000 blocks:1<\r><\n>
[0000.626] I> Addr: 0xd7300000, start-block: 58765633, num_blocks: 1<\r><\n>
[0000.635] I> Binary(12) of size 76592 is loaded @ 0xd7300000<\r><\n>
[0000.640] I> Init SCE<\r><\n>
[0000.643] I> Copy BTCM section<\r><\n>
[0000.646] W> No valid slot number is found in scratch register<\r><\n>
[0000.651] W> Return default slot: _a<\r><\n>
[0000.655] I> A/B: bin_type (13) slot 0<\r><\n>
[0000.658] I> Loading partition cpu-bootloader at 0x96000000<\r><\n>
[0000.664] I> Reading two headers - addr:0x96000000 blocks:1<\r><\n>
[0000.669] I> Addr: 0x96000000, start-block: 58740737, num_blocks: 1<\r><\n>
[0000.681] I> Binary(13) of size 282736 is loaded @ 0x96000000<\r><\n>
[0000.686] W> No valid slot number is found in scratch register<\r><\n>
[0000.692] W> Return default slot: _a<\r><\n>
[0000.695] I> A/B: bin_type (20) slot 0<\r><\n>
[0000.699] I> Loading partition bootloader-dtb at 0x8520f400<\r><\n>
[0000.704] I> Reading two headers - addr:0x8520f400 blocks:1<\r><\n>
[0000.710] I> Addr: 0x8520f400, start-block: 58742785, num_blocks: 1<\r><\n>
[0000.721] I> Binary(20) of size 279264 is loaded @ 0x8520f400<\r><\n>
[0000.727] I> MB2-params(VA) @ 0xd7000000<\r><\n>
[0000.731] I> CPUBL-params(VA) @ 0xd7000000<\r><\n>
[0000.735] I> CPUBL-params(PA) @ 0x277000000<\r><\n>
[0000.739] I> CPU-BL loaded @ PA 0x96000000<\r><\n>
[0000.743] I> Loading TOS ...<\r><\n>
[0000.746] W> No valid slot number is found in scratch register<\r><\n>
[0000.751] W> Return default slot: _a<\r><\n>
[0000.755] I> A/B: bin_type (14) slot 0<\r><\n>
[0000.758] I> Loading partition secure-os at 0x8530f600<\r><\n>
[0000.763] I> Reading two headers - addr:0x8530f600 blocks:1<\r><\n>
[0000.769] I> Addr: 0x8530f600, start-block: 58744833, num_blocks: 1<\r><\n>
[0000.777] I> Binary(14) of size 62576 is loaded @ 0x8530f600<\r><\n>
[0000.783] I> Copying Monitor (length: 0xf270) from 0x8530f800 to 0x40000000<\r><\n>
[0000.790] I> Erasing Monitor @ 0x8530f800<\r><\n>
[0000.794] I> Unhalting SCE<\r><\n>
[0000.797] I> Primary Memory Start:80000000 Size:70000000<\r><\n>
[0000.802] I> Extended Memory Start:f0110000 Size:185ef0000<\r><\n>
[0000.809] I> Waypoint2-ACK: 0x52012714<\r><\n>
[0000.813] I> MB2(TBoot-BPMP) done<\r><\n>
<\r><\n>
NOTICE: BL31: v1.2(release):e1e4477<\r><\n>
NOTICE: BL31: Built : 00:08:30, May 17 2018<\r><\n>
NOTICE: Trusty image missing.<\r><\n>
ERROR: Error initializing runtime service trusty_fast<\r><\n>
[0001.173] I> Welcome to Cboot<\r><\n>
[0001.176] I> Cboot Version: 00.00.2014.50-t186-0c600f85<\r><\n>
[0001.181] I> CPU-BL Params @ 0x277000000<\r><\n>
[0001.184] I> 0) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.189] I> 1) Base:0x277f00000 Size:0x00100000<\r><\n>
[0001.193] I> 2) Base:0x277e00000 Size:0x00100000<\r><\n>
[0001.198] I> 3) Base:0x277d00000 Size:0x00100000<\r><\n>
[0001.202] I> 4) Base:0x277c00000 Size:0x00100000<\r><\n>
[0001.207] I> 5) Base:0x277b00000 Size:0x00100000<\r><\n>
[0001.211] I> 6) Base:0x277800000 Size:0x00200000<\r><\n>
[0001.216] I> 7) Base:0x277400000 Size:0x00400000<\r><\n>
[0001.220] I> 8) Base:0x277a00000 Size:0x00100000<\r><\n>
[0001.225] I> 9) Base:0x277300000 Size:0x00100000<\r><\n>
[0001.229] I> 10) Base:0x276800000 Size:0x00800000<\r><\n>
[0001.234] I> 11) Base:0x30000000 Size:0x00040000<\r><\n>
[0001.238] I> 12) Base:0xf0000000 Size:0x00100000<\r><\n>
[0001.243] I> 13) Base:0x30040000 Size:0x00001000<\r><\n>
[0001.247] I> 14) Base:0x30048000 Size:0x00001000<\r><\n>
[0001.252] I> 15) Base:0x30049000 Size:0x00001000<\r><\n>
[0001.256] I> 16) Base:0x3004a000 Size:0x00001000<\r><\n>
[0001.261] I> 17) Base:0x3004b000 Size:0x00001000<\r><\n>
[0001.265] I> 18) Base:0x3004c000 Size:0x00001000<\r><\n>
[0001.269] I> 19) Base:0x3004d000 Size:0x00001000<\r><\n>
[0001.274] I> 20) Base:0x3004e000 Size:0x00001000<\r><\n>
[0001.278] I> 21) Base:0x3004f000 Size:0x00001000<\r><\n>
[0001.283] I> 22) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.287] I> 23) Base:0xf0100000 Size:0x00010000<\r><\n>
[0001.292] I> 24) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.296] I> 25) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.300] I> 26) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.305] I> 27) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.309] I> 28) Base:0x84400000 Size:0x00400000<\r><\n>
[0001.314] I> 29) Base:0x30000000 Size:0x00010000<\r><\n>
[0001.318] I> 30) Base:0x278000000 Size:0x08000000<\r><\n>
[0001.323] I> 31) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.327] I> 32) Base:0x276000000 Size:0x00600000<\r><\n>
[0001.332] I> 33) Base:0x80000000 Size:0x70000000<\r><\n>
[0001.336] I> 34) Base:0xf0110000 Size:0x185ef0000<\r><\n>
[0001.341] I> 35) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.345] I> 36) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.349] I> 37) Base:0x2772e0000 Size:0x00020000<\r><\n>
[0001.354] I> 38) Base:0x84000000 Size:0x00400000<\r><\n>
[0001.358] I> 39) Base:0x96000000 Size:0x02400000<\r><\n>
[0001.363] I> 40) Base:0x85000000 Size:0x01200000<\r><\n>
[0001.367] I> 41) Base:0x277000000 Size:0x00280000<\r><\n>
[0001.372] I> 42) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.376] I> 43) Base:0x00000000 Size:0x00000000<\r><\n>
[0001.381] GIC-SPI Target CPU: 4<\r><\r><\n>
[0001.384] Interrupts Init done<\r><\r><\n>
[0001.387] calling constructors<\r><\r><\n>
[0001.390] initializing heap<\r><\n>
[0001.393] initializing threads<\r><\r><\n>
[0001.396] initializing timers<\r><\r><\n>
[0001.399] creating bootstrap completion thread<\r><\r><\n>
[0001.404] top of bootstrap2()<\r><\r><\n>
[0001.407] CPU: ARM Cortex A57<\r><\r><\n>
[0001.410] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100<\r><\r><\n>
[0001.415] initializing platform<\r><\r><\n>
[0001.419] I> Boot-device: eMMC<\r><\n>
[0001.422] I> sdmmc bdev is already initialized<\r><\n>
[0001.427] I> Reading GPT from 512 for device 00000003<\r><\n>
[0001.432] I> Reading GPT from 8388096 for device 00000003<\r><\n>
[0001.439] I> Found 13 partitions in 00000003 device<\r><\n>
[0001.444] I> Reading GPT from 512 for device 00010003<\r><\n>
[0001.450] I> Found 29 partitions in 00010003 device<\r><\n>
[0001.454] W> opt-in fuse is not set, skip fuse_burning<\r><\n>
[0001.459] I> Bl_dtb @0x8520f400<\r><\n>
[0001.462] I> gpio framework initialized<\r><\n>
[0001.466] I> tegrabl_gpio_driver_register: register 'tegra_gpio_main_driver' driver<\r><\n>
[0001.473] I> tegrabl_gpio_driver_register: register 'tegra_gpio_aon_driver' driver<\r><\n>
[0001.481] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee<\r><\n>
[0001.488] E> i2c dev write failed<\r><\n>
[0001.491] E> tca9539_device_init: failed to write polar reg<\r><\n>
[0001.496] E> tegrabl_tca9539_init: failed to init device!<\r><\n>
[0001.501] E> GPIO TCA9539 driver init failed<\r><\n>
[0001.618] I> decompressor handler not found<\r><\n>
[0001.625] I> fixed regulator driver initialized<\r><\n>
[0001.661] I> register 'maxim' power off handle<\r><\n>
[0001.667] I> virtual i2c enabled<\r><\n>
[0001.670] I> registered 'maxim,max77620' pmic<\r><\n>
[0001.674] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver<\r><\n>
[0001.685] I> Find /i2c@c250000's alias i2c7<\r><\n>
[0001.689] I> Reading eeprom i2c=7 address=0x50<\r><\n>
[0001.719] I> Device at /i2c@c250000:0x50<\r><\n>
[0001.723] I> Reading eeprom i2c=7 address=0x57<\r><\n>
[0001.728] E> i2c dev read failed<\r><\n>
[0001.731] E> eeprom: Failed to read I2C slave device<\r><\n>
[0001.736] I> Eeprom read failed 0x1a89800d<\r><\n>
[0001.740] I> Find /i2c@c240000's alias i2c1<\r><\n>
[0001.744] I> Reading eeprom i2c=1 address=0x51<\r><\n>
[0001.750] E> i2c dev read failed<\r><\n>
[0001.753] E> eeprom: Retry to read I2C slave device.<\r><\n>
[0001.758] E> i2c dev read failed<\r><\n>
[0001.761] E> eeprom: Failed to read I2C slave device<\r><\n>
[0001.766] I> Eeprom read failed 0x1a89800d<\r><\n>
[0001.770] I> Find /i2c@3160000's alias i2c0<\r><\n>
[0001.774] I> Reading eeprom i2c=0 address=0x50<\r><\n>
[0001.779] E> i2c dev read failed<\r><\n>
[0001.782] E> eeprom: Failed to read I2C slave device<\r><\n>
[0001.787] I> Eeprom read failed 0x1a89800d<\r><\n>
[0001.792] I> Find /i2c@3180000's alias i2c2<\r><\n>
[0001.796] I> Reading eeprom i2c=2 address=0x54<\r><\n>
[0001.800] I> Enabling gpio chip_id = 2, gpio pin = 9<\r><\n>
[0001.805] C> GPIO driver for chip_id 0x2 could not be found<\r><\n>
[0001.810] E> cam_eeprom_read: Can't get gpio driver<\r><\n>
[0001.815] I> Eeprom read failed 0x2693400d<\r><\n>
[0001.819] I> create_pm_ids: id: 3310-1000-B02-B, len: 15<\r><\n>
[0001.824] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93<\r><\n>
[0001.839] I> found one nvdisp nodes at offset = 104144<\r><\n>
[0001.844] I> found one nvdisp nodes at offset = 105060<\r><\n>
[0001.854] I> enabling 'vdd-hdmi' regulator<\r><\n>
[0001.858] C> GPIO driver for chip_id 0x3 could not be found<\r><\n>
[0001.863] I> found one nvdisp nodes at offset = 105864<\r><\n>
[0001.868] I> no valid display unit config found in dtb<\r><\n>
[0001.873] W> display init failed<\r><\n>
[0001.876] initializing target<\r><\r><\n>
[0001.879] calling apps_init()<\r><\r><\n>
[0001.882] starting app android_boot_app<\r><\r><\n>
[0001.886] I> Gpio keyboard init success<\r><\n>
[0001.890] I> Kernel type = Normal<\r><\n>
[0001.893] I> Loading kernel/boot.img from storage ...<\r><\n>
[0001.898] W> No valid slot number is found in scratch register<\r><\n>
[0001.904] W> Return default slot: _a<\r><\n>
[0001.907] I> A/B: bin_type (0) slot 0<\r><\n>
[0001.911] I> Loading partition kernel at 0xa8000000<\r><\n>
[0002.671] I> tegrabl_auth_payload: partition kernel (bin_type 0)<\r><\n>
[0002.678] W> No valid slot number is found in scratch register<\r><\n>
[0002.684] W> Return default slot: _a<\r><\n>
[0002.687] I> A/B: bin_type (1) slot 0<\r><\n>
[0002.690] I> Loading partition kernel-dtb at 0x92000000<\r><\n>
[0002.702] I> tegrabl_auth_payload: partition kernel-dtb (bin_type 1)<\r><\n>
[0002.709] I> Kernel DTB @ 0x92000000<\r><\n>
[0002.712] I> Checking boot.img header magic ... [0002.717] I> [OK]<\r><\n>
[0002.718] I> Valid boot.img @ 0xa8000000<\r><\n>
[0002.722] I> decompressor handler not found<\r><\n>
[0002.726] I> Copying kernel image (488466 bytes) from 0xa8000800 to 0x80080000 ... [0002.734] I> Done<\r><\n>
[0002.735] I> Move ramdisk (len: 0) from 0xa8078000 to 0x9d000000<\r><\n>
[0002.742] I> Updated bpmp info to DTB<\r><\n>
[0002.748] I> Ramdisk: Base: 0x9d000000; Size: 0x0<\r><\n>
[0002.753] I> Updated initrd info to DTB<\r><\n>
[0002.756] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params<\r><\n>
[0002.764] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params<\r><\n>
[0002.771] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params<\r><\n>
[0002.778] I> disabled_core_mask: 0xffffff0c<\r><\n>
[0002.782] W> No valid slot number is found in scratch register<\r><\n>
[0002.788] W> Return default slot: _a<\r><\n>
[0002.791] I> Active slot suffix: <\r><\n>
[0002.794] I> add_boot_slot_suffix: slot_suffix = <\r><\n>
[0002.799] I> add_serialno: Serial Num = 0323717014692<\r><\n>
[0002.804] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323717014692 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 <\r><\n>
[0002.842] I> Updated bootarg info to DTB<\r><\n>
[0002.846] E> "plugin-manager" doesn't exist, creating<\r><\n>
[0002.851] E> "odm-data" doesn't exist, creating<\r><\n>
[0002.857] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8d:48:fc<\r><\n>
[0002.863] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8d:48:fd<\r><\n>
[0002.869] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8d:48:fe<\r><\n>
[0002.875] E> "ids" doesn't exist, creating<\r><\n>
[0002.879] E> "connection" doesn't exist, creating<\r><\n>
[0002.884] E> "configs" doesn't exist, creating<\r><\n>
[0002.888] I> create_pm_ids: id: 3310-1000-B02-B, len: 15<\r><\n>
[0002.893] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93<\r><\n>
[0002.904] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50<\r><\n>
[0002.911] E> "i2c@c250000" doesn't exist, creating<\r><\n>
[0002.916] E> "module@0x50" doesn't exist, creating<\r><\n>
[0002.923] I> Adding plugin-manager/ids/3310-1000-B02-B<\r><\n>
[0002.930] I> Adding plugin-manager/configs/3310-mem-type 00<\r><\n>
[0002.935] I> Adding plugin-manager/configs/3310-power-config 00<\r><\n>
[0002.941] I> Adding plugin-manager/configs/3310-misc-config 00<\r><\n>
[0002.947] I> Adding plugin-manager/configs/3310-modem-config 00<\r><\n>
[0002.953] I> Adding plugin-manager/configs/3310-touch-config 00<\r><\n>
[0002.958] I> Adding plugin-manager/configs/3310-display-config 00<\r><\n>
[0002.964] E> "chip-id" doesn't exist, creating<\r><\n>
[0002.969] I> Adding plugin-manager/chip-id/A02P<\r><\n>
[0002.975] I> added [base:0x80000000, size:0x70000000] to /memory<\r><\n>
[0002.981] I> added [base:0xf0200000, size:0x185e00000] to /memory<\r><\n>
[0002.987] I> added [base:0x276600000, size:0x200000] to /memory<\r><\n>
[0002.993] E> WARNING: Failed to pass NS DRAM ranges to TOS<\r><\n>
[0002.998] I> Updated memory info to DTB<\r><\n>
[0003.004] E> "reset" doesn't exist, creating<\r><\n>
[0003.008] E> "pmc-reset-reason" doesn't exist, creating<\r><\n>
[0003.013] E> "pmic-reset-reason" doesn't exist, creating<\r><\n>
[0003.019] I> disabled_core_mask: 0xffffff0c<\r><\n>
[0003.030] I> Add serial number as DT property<\r><\n>
[0003.035] I> tegrabl_load_kernel_and_dtb: Done<\r><\n>
[0003.039] E> tegrabl_display_clear: display is not initialized<\r><\n>
[0003.045] W> Boot logo display failed...<\r><\n>
<\r><\n>
<\r><\n>
U-Boot 2016.07-g9c3b9a4 (May 17 2018 - 00:08:48 -0700)<\r><\n>
<\r><\n>
TEGRA186<\r><\n>
Model: NVIDIA P2771-0000-500<\r><\n>
DRAM: 7.8 GiB<\r><\n>
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1<\r><\n>
*** Warning - bad CRC, using default environment<\r><\n>
<\r><\n>
In: serial<\r><\n>
Out: serial<\r><\n>
Err: serial<\r><\n>
Net: eth0: ethernet@2490000<\r><\n>
Hit any key to stop autoboot: 2 <\b><\b><\b> 1 <\b><\b><\b> 0 <\r><\n>
MMC: no card present<\r><\n>
switch to partitions #0, OK<\r><\n>
mmc0(part 0) is current device<\r><\n>
Scanning mmc 0:1...<\r><\n>
Found /boot/extlinux/extlinux.conf<\r><\n>
Retrieving file: /boot/extlinux/extlinux.conf<\r><\n>
213 bytes read in 91 ms (2 KiB/s)<\r><\n>
p2771-0000 eMMC boot options<\r><\n>
1:<9>primary kernel<\r><\n>
Enter choice: 1:<9>primary kernel<\r><\n>
Retrieving file: /boot/Image<\r><\n>
20727600 bytes read in 547 ms (36.1 MiB/s)<\r><\n>
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323717014692 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4<\r><\n>
## Flattened Device Tree blob at 92000000<\r><\n>
Booting using the fdt blob at 0x92000000<\r><\n>
reserving fdt memory region: addr=80000000 size=10000<\r><\n>
Using Device Tree in place at 0000000092000000, end 0000000092049273<\r><\n>
<\r><\n>
Starting kernel ...<\r><\n>
<\r><\n>
[ 0.000000] Booting Linux on physical CPU 0x100<\r><\n>
[ 0.000000] Initializing cgroup subsys cpuset<\r><\n>
[ 0.000000] Initializing cgroup subsys cpu<\r><\n>
[ 0.000000] Initializing cgroup subsys cpuacct<\r><\n>
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018<\r><\n>
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]<\r><\n>
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')<\r><\n>
[ 0.000000] bootconsole [uart0] enabled<\r><\n>
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops<\r><\n>
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000<\r><\n>
[ 0.000000] psci: probing for conduit method from DT.<\r><\n>
[ 0.000000] psci: PSCIv1.0 detected in firmware.<\r><\n>
[ 0.000000] psci: Using standard PSCI v0.2 function IDs<\r><\n>
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.<\r><\n>
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632<\r><\n>
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936<\r><\n>
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323717014692 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4<\r><\n>
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)<\r><\n>
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)<\r><\n>
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)<\r><\n>
[ 0.000000] Memory: 7975976K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 166872K reserved, 65536K cma-reserved)<\r><\n>
[ 0.000000] Virtual kernel memory layout:<\r><\n>
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)<\r><\n>
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)<\r><\n>
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)<\r><\n>
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)<\r><\n>
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)<\r><\n>
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)<\r><\n>
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)<\r><\n>
[ 0.000000] .init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)<\r><\n>
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)<\r><\n>
[ 0.000000] .data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)<\r><\n>
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1<\r><\n>
[ 0.000000] Preemptible hierarchical RCU implementation.<\r><\n>
[ 0.000000] <9>Build-time adjustment of leaf fanout to 64.<\r><\n>
[ 0.000000] <9>RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.<\r><\n>
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6<\r><\n>
[ 0.000000] NR_IRQS:64 nr_irqs:64 0<\r><\n>
[ 0.000000] GIC: Using split EOI/Deactivate mode<\r><\n>
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).<\r><\n>
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns<\r><\n>
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns<\r><\n>
[ 0.009826] Console: colour dummy device 80x25<\r><\n>
[ 0.014486] console [tty0] enabled<\r><\n>
[ 0.018041] bootconsole [uart0] disabled<\r><\n>
[ 0.022145] kmemleak: Kernel memory leak detector disabled<\r><\n>
[ 0.022157] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)<\r><\n>
[ 0.022169] pid_max: default: 32768 minimum: 301<\r><\n>
[ 0.022216] Security Framework initialized<\r><\n>
[ 0.022255] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)<\r><\n>
[ 0.022266] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)<\r><\n>
[ 0.022650] Initializing cgroup subsys io<\r><\n>
[ 0.022663] Initializing cgroup subsys memory<\r><\n>
[ 0.022679] Initializing cgroup subsys devices<\r><\n>
[ 0.022689] Initializing cgroup subsys freezer<\r><\n>
[ 0.022698] Initializing cgroup subsys net_cls<\r><\n>
[ 0.022709] Initializing cgroup subsys perf_event<\r><\n>
[ 0.022718] Initializing cgroup subsys net_prio<\r><\n>
[ 0.022728] Initializing cgroup subsys pids<\r><\n>
[ 0.022736] Initializing cgroup subsys debug<\r><\n>
[ 0.022876] CPU0 ipc=752<\r><\n>
[ 0.022885] CPU1 ipc=1024<\r><\n>
[ 0.022892] CPU2 ipc=1024<\r><\n>
[ 0.022901] CPU3 ipc=752<\r><\n>
[ 0.022910] CPU4 ipc=752<\r><\n>
[ 0.022920] CPU5 ipc=752<\r><\n>
[ 0.022958] ASID allocator initialised with 65536 entries<\r><\n>
[ 0.046129] tegra-id: chipid=21817.<\r><\n>
[ 0.046146] tegra-id: opt_subrevision=1.<\r><\n>
[ 0.046160] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0<\r><\n>
[ 0.046827] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts<\r><\n>
[ 0.046852] DTB Build time: May 17 2018 00:17:47<\r><\n>
[ 0.062560] CPU1: Booted secondary processor [4e0f0030]<\r><\n>
[ 0.074093] CPU2: Booted secondary processor [4e0f0030]<\r><\n>
[ 0.085819] CPU3: Booted secondary processor [411fd073]<\r><\n>
[ 0.097826] CPU4: Booted secondary processor [411fd073]<\r><\n>
[ 0.109820] CPU5: Booted secondary processor [411fd073]<\r><\n>
[ 0.109885] Brought up 6 CPUs<\r><\n>
[ 0.109945] SMP: Total of 6 processors activated.<\r><\n>
[ 0.109959] CPU: All CPU(s) started at EL2<\r><\n>
[ 0.110423] devtmpfs: initialized<\r><\n>
[ 0.138163] Initilizing CustomIPI irq domain<\r><\n>
[ 0.138358] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns<\r><\n>
[ 0.139109] pinctrl core: initialized pinctrl subsystem<\r><\n>
[ 0.139286] OS set in device tree is not L4T.<\r><\n>
[ 0.139480] regulator-dummy: no parameters<\r><\n>
[ 0.139589] Initializing plugin-manager<\r><\n>
[ 0.139644] Plugin module not found<\r><\n>
[ 0.140070] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P<\r><\n>
[ 0.140413] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt<\r><\n>
[ 0.141044] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt<\r><\n>
[ 0.142275] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300<\r><\n>
[ 0.142645] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300<\r><\n>
[ 0.142904] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800<\r><\n>
[ 0.143126] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200<\r><\n>
[ 0.143547] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500<\r><\n>
[ 0.143988] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500<\r><\n>
[ 0.144268] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500<\r><\n>
[ 0.144650] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800<\r><\n>
[ 0.144899] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800<\r><\n>
[ 0.145120] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900<\r><\n>
[ 0.145390] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00<\r><\n>
[ 0.147330] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800<\r><\n>
[ 0.149100] Adding domain adsp-pd to PM domain ape-pd<\r><\n>
[ 0.151380] NET: Registered protocol family 16<\r><\n>
[ 0.152209] console [pstore-1] enabled<\r><\n>
[ 0.152221] pstore: Registered ramoops as persistent store backend<\r><\n>
[ 0.152235] ramoops: attached 0x200000@0x277080000, ecc: 0/0<\r><\n>
[ 0.161341] cpuidle: using governor ladder<\r><\n>
[ 0.165819] cpuidle: using governor menu<\r><\n>
[ 0.166959] bpmp: waiting for handshake<\r><\n>
[ 0.166974] bpmp: handshake completed<\r><\n>
[ 0.167015] bpmp: synchronizing channels<\r><\n>
[ 0.167041] bpmp: channels synchronized<\r><\n>
[ 0.167052] bpmp: mail init ok<\r><\n>
[ 0.167395] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)<\r><\n>
[ 0.167427] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.<\r><\n>
[ 0.168360] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations<\r><\n>
[ 0.169802] tegra_powergate_init: DONE<\r><\n>
[ 0.169832] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts<\r><\n>
[ 0.169860] DTB Build time: May 17 2018 00:17:47<\r><\n>
[ 0.170774] Tegra reboot handler registered.<\r><\n>
[ 0.171817] Registering Tegra186 clocks (this may take a while)...done<\r><\n>
[ 0.173930] arm-smmu 12000000.iommu: probing hardware configuration...<\r><\n>
[ 0.173949] arm-smmu 12000000.iommu: SMMUv2 with:<\r><\n>
[ 0.173962] arm-smmu 12000000.iommu: <9>stage 1 translation<\r><\n>
[ 0.173975] arm-smmu 12000000.iommu: <9>stage 2 translation<\r><\n>
[ 0.173987] arm-smmu 12000000.iommu: <9>nested translation<\r><\n>
[ 0.174002] arm-smmu 12000000.iommu: <9>stream matching with 128 register groups, mask 0x7f80<\r><\n>
[ 0.174021] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!<\r><\n>
[ 0.174040] arm-smmu 12000000.iommu: <9>64 context banks (0 stage-2 only)<\r><\n>
[ 0.174055] arm-smmu 12000000.iommu: <9>Stage-1: 39-bit VA -> 48-bit IPA<\r><\n>
[ 0.174068] arm-smmu 12000000.iommu: <9>Stage-2: 39-bit IPA -> 48-bit PA<\r><\n>
[ 0.222659] arm-smmu 12000000.iommu: registered 67 master devices<\r><\n>
[ 0.228504] iommu: Adding device 3460000.sdhci to group 0<\r><\n>
[ 0.229400] iommu: Adding device 3400000.sdhci to group 1<\r><\n>
[ 0.232944] iommu: Adding device 3507000.ahci-sata to group 2<\r><\n>
[ 0.233403] iommu: Adding device 3160000.i2c to group 3<\r><\n>
[ 0.233807] iommu: Adding device c240000.i2c to group 4<\r><\n>
[ 0.234147] iommu: Adding device 3180000.i2c to group 5<\r><\n>
[ 0.234501] iommu: Adding device 3190000.i2c to group 6<\r><\n>
[ 0.235032] iommu: Adding device 31b0000.i2c to group 7<\r><\n>
[ 0.235369] iommu: Adding device 31c0000.i2c to group 8<\r><\n>
[ 0.235723] iommu: Adding device c250000.i2c to group 9<\r><\n>
[ 0.236119] iommu: Adding device 31e0000.i2c to group 10<\r><\n>
[ 0.238230] iommu: Adding device 3210000.spi to group 11<\r><\n>
[ 0.238590] iommu: Adding device c260000.spi to group 12<\r><\n>
[ 0.238913] iommu: Adding device 3240000.spi to group 13<\r><\n>
[ 0.239700] iommu: Adding device 3100000.serial to group 14<\r><\n>
[ 0.240031] iommu: Adding device 3110000.serial to group 15<\r><\n>
[ 0.240325] iommu: Adding device c280000.serial to group 16<\r><\n>
[ 0.240645] iommu: Adding device 3130000.serial to group 17<\r><\n>
[ 0.241866] iommu: Adding device 2490000.ether_qos to group 18<\r><\n>
[ 0.242489] iommu: Adding device b000000.rtcpu to group 19<\r><\n>
[ 0.242986] iommu: Adding device c1a0000.aon to group 20<\r><\n>
[ 0.243890] Wake73 for irq=42<\r><\n>
[ 0.244249] iommu: Adding device smmu_test to group 21<\r><\n>
[ 0.244746] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000<\r><\n>
[ 0.244808] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000<\r><\n>
[ 0.244843] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000<\r><\n>
[ 0.244913] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000<\r><\n>
[ 0.244948] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000<\r><\n>
[ 0.244983] mc-err: Set intmask: 0xf3140<\r><\n>
[ 0.245261] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c<\r><\n>
[ 0.246140] Wake76 for irq=199<\r><\n>
[ 0.246170] Wake77 for irq=199<\r><\n>
[ 0.246193] Wake78 for irq=199<\r><\n>
[ 0.246240] Wake79 for irq=199<\r><\n>
[ 0.246261] Wake80 for irq=199<\r><\n>
[ 0.246281] Wake81 for irq=199<\r><\n>
[ 0.246302] Wake82 for irq=199<\r><\n>
[ 0.246424] iommu: Adding device 3530000.xhci to group 22<\r><\n>
[ 0.246827] iommu: Adding device 3550000.xudc to group 23<\r><\n>
[ 0.247638] tegra-pmc c360000.pmc: scratch reg offset dts data not present<\r><\n>
[ 0.247670] tegra-pmc: ### PMC reset source: Power on reset<\r><\n>
[ 0.247694] tegra-pmc: ### PMC reset level: L0<\r><\n>
[ 0.247717] tegra-pmc: ### PMC reset status reg: 0x0<\r><\n>
[ 0.247997] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered<\r><\n>
[ 0.248037] tegra-pmc c360000.pmc: IO padctrl driver initialized<\r><\n>
[ 0.248203] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3<\r><\n>
[ 0.248234] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320<\r><\n>
[ 0.248742] iommu: Adding device 13e10000.host1x to group 24<\r><\n>
[ 0.249060] iommu: Adding device 13e10000.host1x:ctx0 to group 25<\r><\n>
[ 0.249290] iommu: Adding device 13e10000.host1x:ctx1 to group 26<\r><\n>
[ 0.249550] iommu: Adding device 13e10000.host1x:ctx2 to group 27<\r><\n>
[ 0.249790] iommu: Adding device 13e10000.host1x:ctx3 to group 28<\r><\n>
[ 0.250040] iommu: Adding device 13e10000.host1x:ctx4 to group 29<\r><\n>
[ 0.250266] iommu: Adding device 13e10000.host1x:ctx5 to group 30<\r><\n>
[ 0.250519] iommu: Adding device 13e10000.host1x:ctx6 to group 31<\r><\n>
[ 0.250790] iommu: Adding device 13e10000.host1x:ctx7 to group 32<\r><\n>
[ 0.251246] iommu: Adding device 150c0000.nvcsi to group 33<\r><\n>
[ 0.251781] iommu: Adding device 15700000.vi to group 34<\r><\n>
[ 0.252098] iommu: Adding device 15600000.isp to group 35<\r><\n>
[ 0.252433] iommu: Adding device 15210000.nvdisplay to group 36<\r><\n>
[ 0.252671] iommu: Adding device 15340000.vic to group 37<\r><\n>
[ 0.252872] iommu: Adding device 154c0000.nvenc to group 38<\r><\n>
[ 0.253068] iommu: Adding device 15480000.nvdec to group 39<\r><\n>
[ 0.253376] iommu: Adding device 15380000.nvjpg to group 40<\r><\n>
[ 0.253649] iommu: Adding device 15500000.tsec to group 41<\r><\n>
[ 0.253857] iommu: Adding device 15100000.tsecb to group 42<\r><\n>
[ 0.254574] iommu: Adding device 15810000.se to group 43<\r><\n>
[ 0.254821] iommu: Adding device 15820000.se to group 44<\r><\n>
[ 0.255022] iommu: Adding device 15830000.se to group 45<\r><\n>
[ 0.255244] iommu: Adding device 15840000.se to group 46<\r><\n>
[ 0.255793] iommu: Adding device 17000000.gp10b to group 47<\r><\n>
[ 0.257150] tegra-reset 5000000.clock: registered 193 resets.<\r><\n>
[ 0.259289] iommu: Adding device d000000.bpmp to group 48<\r><\n>
[ 0.259523] bpmp: ping status is 0<\r><\n>
[ 0.259693] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e<\r><\n>
[ 0.260064] bpmp d000000.bpmp: probe ok<\r><\n>
[ 0.262716] iommu: Adding device 2600000.dma to group 49<\r><\n>
[ 0.263558] GPIO line 461 (cam0-rst) hogged as output/low<\r><\n>
[ 0.263620] GPIO line 456 (cam0-pwdn) hogged as output/low<\r><\n>
[ 0.263697] GPIO line 457 (cam1-rst) hogged as output/low<\r><\n>
[ 0.263751] GPIO line 426 (cam1-pwdn) hogged as output/low<\r><\n>
[ 0.263808] GPIO line 424 (wifi-enable) hogged as output/high<\r><\n>
[ 0.263888] GPIO line 445 (sdmmc-wake-input) hogged as input<\r><\n>
[ 0.263944] GPIO line 446 (sdmmc-wake-output) hogged as output/low<\r><\n>
[ 0.264053] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio<\r><\n>
[ 0.265913] GPIO line 315 (wifi-wake-ap) hogged as input<\r><\n>
[ 0.266040] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon<\r><\n>
[ 0.266932] iommu: Adding device 10003000.pcie-controller to group 50<\r><\n>
[ 0.267214] iommu: Adding device sound to group 51<\r><\n>
[ 0.268902] iommu: Adding device 3510000.hda to group 52<\r><\n>
[ 0.270215] iommu: Adding device adsp_audio to group 53<\r><\n>
[ 0.271821] iommu: Adding device 2993000.adsp to group 54<\r><\n>
[ 0.281621] vdd-ac-bat: 5000 mV <\r><\n>
[ 0.283815] vdd-1v8-ap: 1800 mV <\r><\n>
[ 0.300623] SCSI subsystem initialized<\r><\n>
[ 0.301015] usbcore: registered new interface driver usbfs<\r><\n>
[ 0.301075] usbcore: registered new interface driver hub<\r><\n>
[ 0.301196] usbcore: registered new device driver usb<\r><\n>
[ 0.303943] tegra-i2c 3160000.i2c: no acknowledge from address 0x74<\r><\n>
[ 0.304147] pca953x 0-0074: failed reading register<\r><\n>
[ 0.304224] pca953x: probe of 0-0074 failed with error -121<\r><\n>
[ 0.304585] tegra-i2c 3160000.i2c: no acknowledge from address 0x77<\r><\n>
[ 0.304782] pca953x 0-0077: failed reading register<\r><\n>
[ 0.304846] pca953x: probe of 0-0077 failed with error -121<\r><\n>
[ 0.315535] media: Linux media interface: v0.10<\r><\n>
[ 0.315604] Linux video capture interface: v2.00<\r><\n>
[ 0.319568] pps_core: LinuxPPS API ver. 1 registered<\r><\n>
[ 0.319601] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it><\r><\n>
[ 0.319652] PTP clock support registered<\r><\n>
[ 0.320536] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec<\r><\n>
[ 0.320602] tegra_wdt_t18x 30c0000.watchdog: Registered successfully<\r><\n>
[ 0.322080] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8<\r><\n>
[ 0.324203] GPIO line 253 (spmic_gpio_input_5) hogged as input<\r><\n>
[ 0.324396] GPIO line 254 (spmic_gpio_input_6) hogged as input<\r><\n>
[ 0.324488] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio<\r><\n>
[ 0.330749] vddio-ddr: at 1125 mV <\r><\n>
[ 0.334574] avdd_dsi_csi: 1200 mV <\r><\n>
[ 0.338571] vdd-1v8: 1800 mV <\r><\n>
[ 0.342571] vdd-3v3-sys: 3300 mV <\r><\n>
[ 0.343668] spmic-ldo0: at 1800 mV <\r><\n>
[ 0.344442] spmic-ldo1: at 800 mV <\r><\n>
[ 0.350568] vddio-3v3: 3300 mV <\r><\n>
[ 0.351208] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV <\r><\n>
[ 0.354574] vdd-rtc: at 800 mV <\r><\n>
[ 0.355337] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV <\r><\n>
[ 0.357339] spmic-ldo6: at 1500 mV <\r><\n>
[ 0.361337] vdd-pex-1v05: 1000 mV <\r><\n>
[ 0.361884] dvdd-pex: 1000 mV <\r><\n>
[ 0.362156] max77620 4-003c: max77620 probe successful<\r><\n>
[ 0.362422] Advanced Linux Sound Architecture Driver Initialized.<\r><\n>
[ 0.363363] en-vdd-sd: 3300 mV <\r><\n>
[ 0.363631] vdd-usb0-5v: 5000 mV <\r><\n>
[ 0.363801] vdd-usb1-5v: 5000 mV <\r><\n>
[ 0.364147] vdd-3v3: 3300 mV <\r><\n>
[ 0.364290] en-vdd-vcm-2v8: 2800 mV <\r><\n>
[ 0.364419] vdd-sys-bl: 3300 mV <\r><\n>
[ 0.367743] extcon-gpio-states external-connection:extcon@1: Cable state 0<\r><\n>
[ 0.368132] clocksource: Switched to clocksource arch_sys_counter<\r><\n>
[ 0.386662] nvmap_heap_init: nvmap_heap_init: created heap block cache<\r><\n>
[ 0.386929] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways<\r><\n>
[ 0.387410] nvmap_page_pool_init: Total RAM pages: 2010378<\r><\n>
[ 0.387428] nvmap_page_pool_init: nvmap page pool size: 251297 pages (981 MB)<\r><\n>
[ 0.387632] nvmap_background_zero_thread: PP zeroing thread starting.<\r><\n>
[ 0.392137] Wake76 for irq=199<\r><\n>
[ 0.392151] Wake77 for irq=199<\r><\n>
[ 0.392162] Wake78 for irq=199<\r><\n>
[ 0.392172] Wake79 for irq=199<\r><\n>
[ 0.392183] Wake80 for irq=199<\r><\n>
[ 0.392192] Wake81 for irq=199<\r><\n>
[ 0.392202] Wake82 for irq=199<\r><\n>
[ 0.392929] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm<\r><\n>
[ 0.393131] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm<\r><\n>
[ 0.393513] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm<\r><\n>
[ 0.393591] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm<\r><\n>
[ 0.393732] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra<\r><\n>
[ 0.393877] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra<\r><\n>
[ 0.394022] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die<\r><\n>
[ 0.394314] isomgr_init(): iso emc max clk=1866000KHz<\r><\n>
[ 0.394326] isomgr_init(): max_iso_bw=26870400KB<\r><\n>
[ 0.394412] NET: Registered protocol family 2<\r><\n>
[ 0.394755] TCP established hash table entries: 65536 (order: 7, 524288 bytes)<\r><\n>
[ 0.394980] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)<\r><\n>
[ 0.395274] TCP: Hash tables configured (established 65536 bind 65536)<\r><\n>
[ 0.395327] UDP hash table entries: 4096 (order: 5, 131072 bytes)<\r><\n>
[ 0.395382] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)<\r><\n>
[ 0.395546] NET: Registered protocol family 1<\r><\n>
[ 0.395785] RPC: Registered named UNIX socket transport module.<\r><\n>
[ 0.395802] RPC: Registered udp transport module.<\r><\n>
[ 0.395814] RPC: Registered tcp transport module.<\r><\n>
[ 0.395826] RPC: Registered tcp NFSv4.1 backchannel transport module.<\r><\n>
[ 0.395955] Trying to unpack rootfs image as initramfs...<\r><\n>
[ 0.409656] host1x 13e10000.host1x: initialized<\r><\n>
[ 0.410478] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available<\r><\n>
[ 0.412219] futex hash table entries: 2048 (order: 6, 262144 bytes)<\r><\n>
[ 0.412315] audit: initializing netlink subsys (disabled)<\r><\n>
[ 0.412358] audit: type=2000 audit(0.400:1): initialized<\r><\n>
[ 0.419155] io scheduler noop registered<\r><\n>
[ 0.419261] io scheduler cfq registered (default)<\r><\n>
[ 0.422215] tegra-pwm 3280000.pwm: PWM clk can sleep in ops<\r><\n>
[ 0.423406] tegra-pwm 3290000.pwm: PWM clk can sleep in ops<\r><\n>
[ 0.424467] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops<\r><\n>
[ 0.425503] tegra-pwm c340000.pwm: PWM clk can sleep in ops<\r><\n>
[ 0.428891] tsec 15500000.tsec: initialized<\r><\n>
[ 0.430025] tsec 15100000.tsecb: initialized<\r><\n>
[ 0.432305] nvdec 15480000.nvdec: initialized<\r><\n>
[ 0.435884] falcon 15340000.vic: initialized<\r><\n>
[ 0.436924] falcon 154c0000.nvenc: initialized<\r><\n>
[ 0.437944] falcon 15380000.nvjpg: initialized<\r><\n>
[ 0.438720] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)<\r><\n>
[ 0.439234] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)<\r><\n>
[ 0.439738] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)<\r><\n>
[ 0.440249] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)<\r><\n>
[ 0.440743] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)<\r><\n>
[ 0.441238] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)<\r><\n>
[ 0.441729] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)<\r><\n>
[ 0.442227] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)<\r><\n>
[ 0.444725] DC OR NODE connected to /host1x/sor1<\r><\n>
[ 0.444848] generic_infoframe_type: 0x87<\r><\n>
[ 0.444857] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe<\r><\n>
[ 0.444951] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs<\r><\n>
[ 0.444966] tegradc 15210000.nvdisplay: DT parsed successfully<\r><\n>
[ 0.444981] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500<\r><\n>
[ 0.444998] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0<\r><\n>
[ 0.452229] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s<\r><\n>
[ 0.452250] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz<\r><\n>
[ 0.452266] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz<\r><\n>
[ 0.452312] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1<\r><\n>
[ 0.452328] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1<\r><\n>
[ 0.452487] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels<\r><\n>
[ 0.452719] hdmi: couldn't get regulator vdd_hdmi_5v0: -517<\r><\n>
[ 0.454626] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized<\r><\n>
[ 0.454872] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range<\r><\n>
[ 0.454973] kfuse 3830000.kfuse: initialized<\r><\n>
[ 0.456144] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0<\r><\n>
[ 0.456541] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled<\r><\n>
[ 0.458429] console [ttyS0] disabled<\r><\n>
[ 0.458482] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra<\r><\n>
[ 0.490405] tegradc 15210000.nvdisplay: probed<\r><\n>
[ 2.500987] console [ttyS0] enabled<\r><\n>
[ 2.502879] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART<\r><\n>
[ 2.503950] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART<\r><\n>
[ 2.504176] serial-tegra 3130000.serial: RX in PIO mode<\r><\n>
[ 2.505079] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART<\r><\n>
[ 2.515200] brd: module loaded<\r><\n>
[ 2.516582] Console: switching to colour frame buffer device 240x75<\r><\n>
[ 2.520063] loop: module loaded<\r><\n>
[ 2.520341] nct1008_nct72 7-004c: find device tree node, parsing dt<\r><\n>
[ 2.520345] nct1008_nct72 7-004c: starting parse dt<\r><\n>
[ 2.520428] nct1008_nct72 7-004c: success parsing dt<\r><\n>
[ 2.520561] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail<\r><\n>
[ 2.532696] gk20a 17000000.gp10b: failed to allocate secure buffer -12<\r><\n>
[ 2.557469] tmp451: Enabled overheat logging at 104.00C<\r><\n>
[ 2.557639] nct1008_nct72 7-004c: nct1008_probe: initialized<\r><\n>
[ 2.560000] THERMAL EST: found 3 subdevs<\r><\n>
[ 2.560005] THERMAL EST num_resources: 0<\r><\n>
[ 2.560008] [THERMAL EST subdev 0]<\r><\n>
[ 2.560013] [THERMAL EST subdev 1]<\r><\n>
[ 2.560017] [THERMAL EST subdev 2]<\r><\n>
[ 2.560421] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est<\r><\n>
[ 2.560424] THERMAL EST: thz register success.<\r><\n>
[ 2.560562] THERMAL EST: end of probe, return err: 0<\r><\n>
[ 2.560620] tegra_profiler: Branch: Dev<\r><\n>
[ 2.560622] tegra_profiler: Version: 1.117<\r><\n>
[ 2.560624] tegra_profiler: Samples version: 41<\r><\n>
[ 2.560626] tegra_profiler: IO version: 22<\r><\n>
[ 2.560633] armv8_pmu: imp: 0x41, idcode: 0x1<\r><\n>
[ 2.560638] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1<\r><\n>
[ 2.560642] armv8_pmu: imp: 0x4e, idcode: 0x1<\r><\n>
[ 2.560647] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1<\r><\n>
[ 2.560650] armv8_pmu: imp: 0x4e, idcode: 0x1<\r><\n>
[ 2.560654] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1<\r><\n>
[ 2.560657] armv8_pmu: imp: 0x41, idcode: 0x1<\r><\n>
[ 2.560661] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1<\r><\n>
[ 2.560664] armv8_pmu: imp: 0x41, idcode: 0x1<\r><\n>
[ 2.560668] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1<\r><\n>
[ 2.560671] armv8_pmu: imp: 0x41, idcode: 0x1<\r><\n>
[ 2.560674] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1<\r><\n>
[ 2.560877] tegra_profiler: auth: init<\r><\n>
[ 2.564340] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode<\r><\n>
[ 2.564351] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst <\r><\n>
[ 2.565419] scsi host0: tegra_ahci<\r><\n>
[ 2.565771] scsi host1: tegra_ahci<\r><\n>
[ 2.565907] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25<\r><\n>
[ 2.565941] ata2: DUMMY<\r><\n>
[ 2.566893] spi-tegra114 3210000.spi: Static pin configuration used<\r><\n>
[ 2.567397] spi-tegra114 c260000.spi: Static pin configuration used<\r><\n>
[ 2.567845] spi-tegra114 3240000.spi: Static pin configuration used<\r><\n>
[ 2.568682] tun: Universal TUN/TAP device driver, 1.6<\r><\n>
[ 2.568684] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com><\r><\n>
[ 2.568857] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k<\r><\n>
[ 2.568859] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.<\r><\n>
[ 2.568894] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k<\r><\n>
[ 2.568896] igb: Copyright (c) 2007-2014 Intel Corporation.<\r><\n>
[ 2.569941] PPP generic driver version 2.4.2<\r><\n>
[ 2.570067] PPP BSD Compression module registered<\r><\n>
[ 2.570074] PPP Deflate Compression module registered<\r><\n>
[ 2.570097] PPP MPPE Compression module registered<\r><\n>
[ 2.570118] NET: Registered protocol family 24<\r><\n>
[ 2.570169] usbcore: registered new interface driver r8152<\r><\n>
[ 2.570201] usbcore: registered new interface driver asix<\r><\n>
[ 2.570234] usbcore: registered new interface driver ax88179_178a<\r><\n>
[ 2.570260] usbcore: registered new interface driver cdc_ether<\r><
