Can't use USB2 Pins on M.2 connector for Tx2 4GB dev kit
I’m trying to use a Wifi/Bluetooth module through the M.2 connector on a dev kit board that we replaced the TX2 module with a TX2 4GB module running on L4T32.2. The BT uses USB for the HCI interface, and the wifi through PCIe. The Wifi portion works, but I’ve not had any success with using the BT. I’ve checked the following two forum posts:
The device tree file that is used by my board is tegra186-quill-p3489-0888-a00-00-base.dtb and I’ve tried mimic-ing the changes mentioned in those two links onto the p3489 dtb and dtsi.
Any help is appreciated.
Here are the relevant (I think?) snippits post fixes:
xusb_padctl@3520000 {
		compatible = "nvidia,tegra18x-xusb-padctl";
		reg = <0x0 0x3520000 0x0 0x1000 0x0 0x3540000 0x0 0x1000>;
		reg-names = "padctl", "ao";
		resets = <0x10 0x37>;
		reset-names = "padctl";
		status = "okay";
		avdd_usb-supply = <0x13>;
		vclamp_usb-supply = <0x12>;
		avdd_pll_erefeut-supply = <0x12>;
		pinctrl-0 = <0xaa>;
		pinctrl-1 = <0xab>;
		pinctrl-2 = <0xac>;
		pinctrl-3 = <0xad>;
		pinctrl-4 = <0xae>;
		pinctrl-5 = <0xaf>;
		pinctrl-names = "vbus_en0_default", "vbus_en1_default", "vbus_en0_sfio_tristate", "vbus_en1_sfio_tristate", "vbus_en0_sfio_passthrough", "vbus_en1_sfio_passthrough";
		linux,phandle = <0xa7>;
		phandle = <0xa7>;
		pads {
			usb2 {
				clocks = <0x10 0x87>;
				clock-names = "trk";
				lanes {
					usb2-0 {
						status = "okay";
						#phy-cells = <0x0>;
						nvidia,function = "xusb";
						linux,phandle = <0xa6>;
						phandle = <0xa6>;
					usb2-1 {
						status = "okay";
						#phy-cells = <0x0>;
						linux,phandle = <0xb3>;
						phandle = <0xb3>;
					usb2-2 {
						status = "okay";
						#phy-cells = <0x0>;
						linux,phandle = <0xb4>;
						phandle = <0xb4>;
			usb3 {
				lanes {
					usb3-0 {
						status = "okay";
						#phy-cells = <0x0>;
						linux,phandle = <0xb5>;
						phandle = <0xb5>;
					usb3-1 {
						status = "okay";
						#phy-cells = <0x0>;
					usb3-2 {
						status = "okay";
						#phy-cells = <0x0>;
			hsic {
				status = "disabled";
				clocks = <0x10 0x86>;
				lanes {
					hsic-0 {
						#phy-cells = <0x0>;
		ports {
			usb2-0 {
				status = "okay";
				mode = "otg";
				vbus-supply = <0xb0>;
				nvidia,oc-pin = <0x0>;
			usb2-1 {
				status = "okay";
				mode = "host";
				vbus-supply = <0xb1>;
				nvidia,oc-pin = <0x1>;
			usb2-2 {
				status = "okay";
				mode = "host";
				vbus-supply = <0x26>;
			usb3-0 {
				status = "okay";
				nvidia,usb2-companion = <0x1>;
			usb3-1 {
			usb3-2 {
			hsic-0 {
		prod-settings {
			#prod-cells = <0x4>;
			prod_c_bias {
				prod = <0x0 0x284 0x38 0x38>;
			prod_c_hsic0 {
				prod = <0x0 0x344 0x7f 0x2d>;
			prod_c_utmi0 {
				prod = <0x0 0x88 0x1fe0000 0xcc0000>;
			prod_c_utmi1 {
				prod = <0x0 0xc8 0x1fe0000 0xcc0000>;
			prod_c_utmi2 {
				prod = <0x0 0x108 0x1fe0000 0xcc0000>;
xhci@3530000 {
		compatible = "nvidia,tegra186-xhci";
		reg = <0x0 0x3530000 0x0 0x8000 0x0 0x3538000 0x0 0x1000>;
		interrupt-parent = <0x3a>;
		iommus = <0x11 0x1b>;
		iommu_sodev_map;
		status = "okay";
		otg-controller = <0xb2>;
		interrupts = <0x0 0xa3 0x4 0x0 0xa4 0x4 0x0 0xa7 0x4>;
		clocks = <0x10 0x71 0x10 0xf4 0x10 0x72 0x10 0xf2 0x10 0x261 0x10 0xf5 0x10 0x215 0x10 0x261 0x10 0x200>;
		clock-names = "xusb_host", "xusb_falcon_src", "xusb_ss", "xusb_ss_src", "xusb_hs_src", "xusb_fs_src", "pll_u_480m", "clk_m", "pll_e";
		nvidia,xusb-padctl = <0xa7>;
		extcon-cables = <0xa8 0x1>;
		extcon-cable-names = "id";
		#extcon-cells = <0x1>;
		avddio_usb-supply = <0x13>;
		avdd_pll_utmip-supply = <0x12>;
		hvdd_usb-supply = <0x12>;
		phys = <0xa6 0xb3 0xb4 0xb5>;
		phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0";
		linux,phandle = <0x106>;
		phandle = <0x106>;
If this is devkit, you could just change the ODMDATA to config #1 and then it should work.
Hi WayneWWW,
The ODMDATA has been changed to config #1, that’s why the wifi is working, since that communicates over PCIe. The problem that i’m facing is that the bluetooth HCI interface is not coming up, which looks to be a USB issues related to the USB2_D+ and USB2_D- module pins.
Looking at the 2 forums I’ve linked in post #1, it looks like other people have something similar, although their solutions have not worked for me.
Yes, what I said in #2 is also for usb2 on m.2 slot on devkit.
You don’t need to change the dts because plugin-manager would help handle.
Please use the pure jetpack and change odmdata to config#1. If still no help, please share your boot log (bootloader log) with us.
Also, you could dump the runtime device tree by reading the node /proc/device-tree.
I’ve used a fresh L4T32.2 with the sample rootfs.
I changed odmdata to config #1 by modifying p2771-0000.conf.common and changed ODMDATA to 0x90000 for {bid} == 3489. This is the same steps I’ve done previously to get PCIe running for the M.2 connector.
What should I look for in proc/device-tree to verify that the USB bus is setup correctly at the device tree level?
Below is the log from journalctl (one thing that seems weird is the plugin manager disabled):
-- Logs begin at Sun 2018-01-28 10:58:17 EST, end at Sun 2018-01-28 11:00:44 EST. --
Jan 28 10:58:17 j-desktop kernel: Booting Linux on physical CPU 0x100
Jan 28 10:58:17 j-desktop kernel: Linux version 4.9.140-tegra (root@jeffreylinux) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Nov 6 00:20:51 PST 2019
Jan 28 10:58:17 j-desktop kernel: Boot CPU: AArch64 Processor [411fd073]
Jan 28 10:58:17 j-desktop kernel: OF: fdt:memory scan node memory@80000000, reg size 16416,
Jan 28 10:58:17 j-desktop kernel: OF: fdt: - 80000000 ,  70000000
Jan 28 10:58:17 j-desktop kernel: OF: fdt: - f0200000 ,  85600000
Jan 28 10:58:17 j-desktop kernel: OF: fdt: - 175e00000 ,  200000
Jan 28 10:58:17 j-desktop kernel: OF: fdt: - 176600000 ,  200000
Jan 28 10:58:17 j-desktop kernel: OF: fdt: - 177000000 ,  200000
Jan 28 10:58:17 j-desktop kernel: earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
Jan 28 10:58:17 j-desktop kernel: bootconsole [uart8250] enabled
Jan 28 10:58:17 j-desktop kernel: Found tegra_fbmem2: 00800000@9607b000
Jan 28 10:58:17 j-desktop kernel: Found lut_mem2: 00002008@96078000
Jan 28 10:58:17 j-desktop kernel: OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
Jan 28 10:58:17 j-desktop kernel: OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
Jan 28 10:58:17 j-desktop kernel: OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Jan 28 10:58:17 j-desktop kernel: cma: Reserved 64 MiB at 0x00000000fc000000
Jan 28 10:58:17 j-desktop kernel: On node 0 totalpages: 1004541
Jan 28 10:58:17 j-desktop kernel:   DMA zone: 8192 pages used for memmap
Jan 28 10:58:17 j-desktop kernel:   DMA zone: 0 pages reserved
Jan 28 10:58:17 j-desktop kernel:   DMA zone: 521725 pages, LIFO batch:31
Jan 28 10:58:17 j-desktop kernel:   Normal zone: 7624 pages used for memmap
Jan 28 10:58:17 j-desktop kernel:   Normal zone: 482816 pages, LIFO batch:31
Jan 28 10:58:17 j-desktop kernel: psci: probing for conduit method from DT.
Jan 28 10:58:17 j-desktop kernel: psci: PSCIv1.0 detected in firmware.
Jan 28 10:58:17 j-desktop kernel: psci: Using standard PSCI v0.2 function IDs
Jan 28 10:58:17 j-desktop kernel: psci: MIGRATE_INFO_TYPE not supported.
Jan 28 10:58:17 j-desktop kernel: psci: SMC Calling Convention v1.1
Jan 28 10:58:17 j-desktop kernel: percpu: Embedded 25 pages/cpu @ffffffc0f676a000 s61592 r8192 d32616 u102400
Jan 28 10:58:17 j-desktop kernel: pcpu-alloc: s61592 r8192 d32616 u102400 alloc=25*4096
Jan 28 10:58:17 j-desktop kernel: pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Jan 28 10:58:17 j-desktop kernel: Speculative Store Bypass Disable mitigation not required
Jan 28 10:58:17 j-desktop kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 988725
Jan 28 10:58:17 j-desktop kernel: Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt tegra_fbmem2=0x800000@0x9607b000 lut_mem2=0x2008@0x96078000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet
Jan 28 10:58:17 j-desktop kernel: log_buf_len individual max cpu contribution: 32768 bytes
Jan 28 10:58:17 j-desktop kernel: log_buf_len total cpu_extra contributions: 163840 bytes
Jan 28 10:58:17 j-desktop kernel: log_buf_len min size: 32768 bytes
Jan 28 10:58:17 j-desktop kernel: log_buf_len: 262144 bytes
Jan 28 10:58:17 j-desktop kernel: early log buf free: 29524(90%)
Jan 28 10:58:17 j-desktop kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
Jan 28 10:58:17 j-desktop kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jan 28 10:58:17 j-desktop kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Jan 28 10:58:17 j-desktop kernel: Memory: 3838296K/4018164K available (15230K kernel code, 2914K rwdata, 6680K rodata, 8576K init, 609K bss, 114332K reserved, 65536K cma-reserved)
Jan 28 10:58:17 j-desktop kernel: Virtual kernel memory layout:
Jan 28 10:58:17 j-desktop kernel:     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
Jan 28 10:58:17 j-desktop kernel:     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
Jan 28 10:58:17 j-desktop kernel:       .text : 0xffffff8008080000 - 0xffffff8008f60000   ( 15232 KB)
Jan 28 10:58:17 j-desktop kernel:     .rodata : 0xffffff8008f60000 - 0xffffff80095f0000   (  6720 KB)
Jan 28 10:58:17 j-desktop kernel:       .init : 0xffffff80095f0000 - 0xffffff8009e50000   (  8576 KB)
Jan 28 10:58:17 j-desktop kernel:       .data : 0xffffff8009e50000 - 0xffffff800a128808   (  2915 KB)
Jan 28 10:58:17 j-desktop kernel:        .bss : 0xffffff800a128808 - 0xffffff800a1c0dbc   (   610 KB)
Jan 28 10:58:17 j-desktop kernel:     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
Jan 28 10:58:17 j-desktop kernel:     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
Jan 28 10:58:17 j-desktop kernel:     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
Jan 28 10:58:17 j-desktop kernel:               0xffffffbf00000000 - 0xffffffbf03dc8000   (    61 MB actual)
Jan 28 10:58:17 j-desktop kernel:     memory  : 0xffffffc000000000 - 0xffffffc0f7200000   (  3954 MB)
Jan 28 10:58:17 j-desktop kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Jan 28 10:58:17 j-desktop kernel: Preemptible hierarchical RCU implementation.
Jan 28 10:58:17 j-desktop kernel:         Build-time adjustment of leaf fanout to 64.
Jan 28 10:58:17 j-desktop kernel:         RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
Jan 28 10:58:17 j-desktop kernel: RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
Jan 28 10:58:17 j-desktop kernel: NR_IRQS:64 nr_irqs:64 0
Jan 28 10:58:17 j-desktop kernel: GIC: Using split EOI/Deactivate mode
Jan 28 10:58:17 j-desktop kernel: arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
Jan 28 10:58:17 j-desktop kernel: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
Jan 28 10:58:17 j-desktop kernel: sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Jan 28 10:58:17 j-desktop kernel: Console: colour dummy device 80x25
Jan 28 10:58:17 j-desktop kernel: console [tty0] enabled
Jan 28 10:58:17 j-desktop kernel: bootconsole [uart8250] disabled
Jan 28 10:58:17 j-desktop kernel: kmemleak: Kernel memory leak detector disabled
Jan 28 10:58:17 j-desktop kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
Jan 28 10:58:17 j-desktop kernel: pid_max: default: 32768 minimum: 301
Jan 28 10:58:17 j-desktop kernel: Security Framework initialized
Jan 28 10:58:17 j-desktop kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
Jan 28 10:58:17 j-desktop kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
Jan 28 10:58:17 j-desktop kernel: ftrace: allocating 46935 entries in 184 pages
Jan 28 10:58:17 j-desktop kernel: sched-energy: Sched-energy-costs installed from DT
Jan 28 10:58:17 j-desktop kernel: ASID allocator initialised with 65536 entries
Jan 28 10:58:17 j-desktop kernel: tegra-id: chipid=21817.
Jan 28 10:58:17 j-desktop kernel: tegra-id: opt_subrevision=1.
Jan 28 10:58:17 j-desktop kernel: Tegra Revision: A02p SKU: 0x94 CPU Process: 0 SoC Process: 0
Jan 28 10:58:17 j-desktop kernel: DTS File Name: /home/jeffrey/co/jetson_linux_32.2.0/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts
Jan 28 10:58:17 j-desktop kernel: DTB Build time: <unknown>
Jan 28 10:58:17 j-desktop kernel: CPU1: Booted secondary processor [4e0f0030]
Jan 28 10:58:17 j-desktop kernel: CPU2: Booted secondary processor [4e0f0030]
Jan 28 10:58:17 j-desktop kernel: CPU3: Booted secondary processor [411fd073]
Jan 28 10:58:17 j-desktop kernel: CPU4: Booted secondary processor [411fd073]
Jan 28 10:58:17 j-desktop kernel: CPU5: Booted secondary processor [411fd073]
Jan 28 10:58:17 j-desktop kernel: Brought up 6 CPUs
Jan 28 10:58:17 j-desktop kernel: SMP: Total of 6 processors activated.
Jan 28 10:58:17 j-desktop kernel: CPU features: detected feature: 32-bit EL0 Support
Jan 28 10:58:17 j-desktop kernel: CPU: All CPU(s) started at EL2
Jan 28 10:58:17 j-desktop kernel: alternatives: patching kernel code
Jan 28 10:58:17 j-desktop kernel: devtmpfs: initialized
Jan 28 10:58:17 j-desktop kernel: Initilizing CustomIPI irq domain
Jan 28 10:58:17 j-desktop kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan 28 10:58:17 j-desktop kernel: futex hash table entries: 2048 (order: 5, 131072 bytes)
Jan 28 10:58:17 j-desktop kernel: pinctrl core: initialized pinctrl subsystem
Jan 28 10:58:17 j-desktop kernel: OS set in device tree is not L4T.
Jan 28 10:58:17 j-desktop kernel: regulator-dummy: no parameters
Jan 28 10:58:17 j-desktop kernel: Initializing plugin-manager
Jan 28 10:58:17 j-desktop kernel: Plugin module not found
Jan 28 10:58:17 j-desktop kernel: Plugin-manager status disabled
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 16
Jan 28 10:58:17 j-desktop kernel: pstore: using zlib compression
Jan 28 10:58:17 j-desktop kernel: console [pstore-1] enabled
Jan 28 10:58:17 j-desktop kernel: pstore: Registered ramoops as persistent store backend
Jan 28 10:58:17 j-desktop kernel: ramoops: attached 0x200000@0x175880000, ecc: 0/0
Jan 28 10:58:17 j-desktop kernel: cpuidle: using governor menu
Jan 28 10:58:17 j-desktop kernel: bpmp: waiting for handshake
Jan 28 10:58:17 j-desktop kernel: bpmp: handshake completed
Jan 28 10:58:17 j-desktop kernel: bpmp: synchronizing channels
Jan 28 10:58:17 j-desktop kernel: bpmp: channels synchronized
Jan 28 10:58:17 j-desktop kernel: bpmp: mail init ok
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu: probing hardware configuration...
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu: SMMUv2 with:
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         stage 1 translation
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         stage 2 translation
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         nested translation
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         stream matching with 128 register groups, mask 0x7f80
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         64 context banks (0 stage-2 only)
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         Stage-1: 39-bit VA -> 48-bit IPA
Jan 28 10:58:17 j-desktop kernel: arm-smmu 12000000.iommu:         Stage-2: 39-bit IPA -> 48-bit PA
Jan 28 10:58:17 j-desktop kernel: vdso: 2 pages (1 code @ ffffff8008f67000, 1 data @ ffffff8009e54000)
Jan 28 10:58:17 j-desktop kernel: hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jan 28 10:58:17 j-desktop kernel: atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
Jan 28 10:58:17 j-desktop kernel: Registering BPMP clocks...
Jan 28 10:58:17 j-desktop kernel: tegra_bpmp_clk_init: clock init ok (638 clks)
Jan 28 10:58:17 j-desktop kernel: tegra_powergate_init: DONE
Jan 28 10:58:17 j-desktop kernel: Tegra reboot handler registered.
Jan 28 10:58:17 j-desktop kernel: tegra-pmc c360000.pmc: scratch reg offset dts data not present
Jan 28 10:58:17 j-desktop kernel: tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
Jan 28 10:58:17 j-desktop kernel: tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
Jan 28 10:58:17 j-desktop kernel: tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
Jan 28 10:58:17 j-desktop kernel: tegra-pmc: ### PMC reset status reg: 0x2d
Jan 28 10:58:17 j-desktop kernel: padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Jan 28 10:58:17 j-desktop kernel: tegra-pmc c360000.pmc: IO padctrl driver initialized
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3460000.sdhci to group 0
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3440000.sdhci to group 1
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3400000.sdhci to group 2
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3507000.ahci-sata to group 3
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 3507000.ahci-sata
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3160000.i2c to group 4
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device c240000.i2c to group 5
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3180000.i2c to group 6
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3190000.i2c to group 7
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 31b0000.i2c to group 8
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 31c0000.i2c to group 9
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device c250000.i2c to group 10
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 31e0000.i2c to group 11
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3210000.spi to group 12
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device c260000.spi to group 13
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3240000.spi to group 14
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3100000.serial to group 15
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3110000.serial to group 16
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device c280000.serial to group 17
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3130000.serial to group 18
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 2490000.ether_qos to group 19
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 2490000.ether_qos
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device b000000.rtcpu to group 20
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x to group 21
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx0 to group 22
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx1 to group 23
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx2 to group 24
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx3 to group 25
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx4 to group 26
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx5 to group 27
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx6 to group 28
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 13e10000.host1x:ctx7 to group 29
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 150c0000.nvcsi to group 30
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15700000.vi to group 31
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15600000.isp to group 32
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15210000.nvdisplay to group 33
Jan 28 10:58:17 j-desktop kernel: platform 15210000.nvdisplay: OF IOVA linear map 0x9607b000 size (0x800000)
Jan 28 10:58:17 j-desktop kernel: platform 15210000.nvdisplay: OF IOVA linear map 0x96078000 size (0x2008)
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15340000.vic to group 34
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 154c0000.nvenc to group 35
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15480000.nvdec to group 36
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15380000.nvjpg to group 37
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15500000.tsec to group 38
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15100000.tsecb to group 39
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15810000.se to group 40
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15820000.se to group 41
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15830000.se to group 42
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 15840000.se to group 43
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device smmu_test to group 44
Jan 28 10:58:17 j-desktop kernel: mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c10000
Jan 28 10:58:17 j-desktop kernel: mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c20000
Jan 28 10:58:17 j-desktop kernel: mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c30000
Jan 28 10:58:17 j-desktop kernel: mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c40000
Jan 28 10:58:17 j-desktop kernel: mc: mapped MMIO address: 0xffffff800b110000 -> 0x2c50000
Jan 28 10:58:17 j-desktop kernel: nv-tegra-mc 2c10000.mc: No mssnvlink node
Jan 28 10:58:17 j-desktop kernel: mc-err: mcerr ops are set to t18x
Jan 28 10:58:17 j-desktop kernel: dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3530000.xhci to group 45
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 3530000.xhci
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3550000.xudc to group 46
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 3550000.xudc
Jan 28 10:58:17 j-desktop kernel: tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
Jan 28 10:58:17 j-desktop kernel: tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 17000000.gp10b to group 47
Jan 28 10:58:17 j-desktop kernel: tegra-reset 5000000.clock: registered 193 resets.
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device d000000.bpmp to group 48
Jan 28 10:58:17 j-desktop kernel: bpmp: ping status is 0
Jan 28 10:58:17 j-desktop kernel: bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
Jan 28 10:58:17 j-desktop kernel: bpmp d000000.bpmp: probe ok
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 2600000.dma to group 49
Jan 28 10:58:17 j-desktop kernel: GPIO line 459 (pcie0_lane2_mux) hogged as output/low
Jan 28 10:58:17 j-desktop kernel: GPIO line 445 (sdmmc-wake-support-input) hogged as input
Jan 28 10:58:17 j-desktop kernel: GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
Jan 28 10:58:17 j-desktop kernel: GPIO line 461 (camera-control-output-low) hogged as output/low
Jan 28 10:58:17 j-desktop kernel: GPIO line 456 (camera-control-output-low) hogged as output/low
Jan 28 10:58:17 j-desktop kernel: GPIO line 457 (camera-control-output-low) hogged as output/low
Jan 28 10:58:17 j-desktop kernel: GPIO line 426 (camera-control-output-low) hogged as output/low
Jan 28 10:58:17 j-desktop kernel: gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
Jan 28 10:58:17 j-desktop kernel: gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 10003000.pcie-controller to group 50
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 10003000.pcie-controller
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device sound to group 51
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 3510000.hda to group 52
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device c1a0000.aon to group 53
Jan 28 10:58:17 j-desktop kernel: vdd-ac-bat: 5000 mV
Jan 28 10:58:17 j-desktop kernel: vdd-1v8-ap: 1800 mV
Jan 28 10:58:17 j-desktop kernel: random: fast init done
Jan 28 10:58:17 j-desktop kernel: HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jan 28 10:58:17 j-desktop kernel: eventlib_kernel: keventlib is initialized, test id: 0
Jan 28 10:58:17 j-desktop kernel: SCSI subsystem initialized
Jan 28 10:58:17 j-desktop kernel: libata version 3.00 loaded.
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver usbfs
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver hub
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new device driver usb
Jan 28 10:58:17 j-desktop kernel: GPIO line 241 (touch-rails) hogged as output/high
Jan 28 10:58:17 j-desktop kernel: GPIO line 242 (touch-rails) hogged as output/high
Jan 28 10:58:17 j-desktop kernel: gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
Jan 28 10:58:17 j-desktop kernel: GPIO line 228 (lcd-bias-rails) hogged as output/high
Jan 28 10:58:17 j-desktop kernel: gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
Jan 28 10:58:17 j-desktop kernel: max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
Jan 28 10:58:17 j-desktop kernel: vddio-ddr: at 1125 mV
Jan 28 10:58:17 j-desktop kernel: avdd_dsi_csi: 1200 mV
Jan 28 10:58:17 j-desktop kernel: vdd-1v8: 1800 mV
Jan 28 10:58:17 j-desktop kernel: vdd-3v3-sys: 3300 mV
Jan 28 10:58:17 j-desktop kernel: max77620-sd4: at 600 mV
Jan 28 10:58:17 j-desktop kernel: spmic-ldo0: at 1800 mV
Jan 28 10:58:17 j-desktop kernel: spmic-ldo1: at 800 mV
Jan 28 10:58:17 j-desktop kernel: vddio-3v3: 3300 mV
Jan 28 10:58:17 j-desktop kernel: vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
Jan 28 10:58:17 j-desktop kernel: vdd-rtc: at 800 mV
Jan 28 10:58:17 j-desktop kernel: avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
Jan 28 10:58:17 j-desktop kernel: spmic-ldo6: at 1500 mV
Jan 28 10:58:17 j-desktop kernel: vdd-pex-1v00: 1000 mV
Jan 28 10:58:17 j-desktop kernel: dvdd-pex: 1000 mV
Jan 28 10:58:17 j-desktop kernel: GPIO line 221 (spmic_gpio_input) hogged as input
Jan 28 10:58:17 j-desktop kernel: GPIO line 222 (spmic_gpio_input) hogged as input
Jan 28 10:58:17 j-desktop kernel: gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
Jan 28 10:58:17 j-desktop kernel: max77620 4-003c: max77620 probe successful
Jan 28 10:58:17 j-desktop kernel: media: Linux media interface: v0.10
Jan 28 10:58:17 j-desktop kernel: Linux video capture interface: v2.00
Jan 28 10:58:17 j-desktop kernel: pps_core: LinuxPPS API ver. 1 registered
Jan 28 10:58:17 j-desktop kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan 28 10:58:17 j-desktop kernel: PTP clock support registered
Jan 28 10:58:17 j-desktop kernel: tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
Jan 28 10:58:17 j-desktop kernel: tegra_wdt_t18x 30c0000.watchdog: Registered successfully
Jan 28 10:58:17 j-desktop kernel: tegra_fiq_debugger_init: found FIQ source (IRQ 386)
Jan 28 10:58:17 j-desktop kernel: trusty trusty: trusty version: Built: 16:57:40 Jul 16 2019
Jan 28 10:58:17 j-desktop kernel: trusty trusty: selected api version: 3 (requested 3)
Jan 28 10:58:17 j-desktop kernel: Advanced Linux Sound Architecture Driver Initialized.
Jan 28 10:58:17 j-desktop kernel: Bluetooth: Core ver 2.22
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 31
Jan 28 10:58:17 j-desktop kernel: Bluetooth: HCI device and connection manager initialized
Jan 28 10:58:17 j-desktop kernel: Bluetooth: HCI socket layer initialized
Jan 28 10:58:17 j-desktop kernel: Bluetooth: L2CAP socket layer initialized
Jan 28 10:58:17 j-desktop kernel: Bluetooth: SCO socket layer initialized
Jan 28 10:58:17 j-desktop kernel: en-vdd-sd: 3300 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-cam: 1800 mV
Jan 28 10:58:17 j-desktop kernel: vdd-hdmi: 5000 mV
Jan 28 10:58:17 j-desktop kernel: vdd-usb0-5v: 5000 mV
Jan 28 10:58:17 j-desktop kernel: vdd-usb1-5v: 5000 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-ts-1v8: 1800 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-ts-hv-3v3: 3300 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-disp-3v3: 3300 mV
Jan 28 10:58:17 j-desktop kernel: en-mdm-pwr-3v7: 3700 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-disp-1v8: 1800 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-cam-hv-2v8: 2800 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-cam-1v2: 1200 mV
Jan 28 10:58:17 j-desktop kernel: vdd-fan: 5000 mV
Jan 28 10:58:17 j-desktop kernel: vdd-3v3: 3300 mV
Jan 28 10:58:17 j-desktop kernel: dis-vdd-1v2: 1200 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-vcm-2v8: 2800 mV
Jan 28 10:58:17 j-desktop kernel: vdd-usb2-5v: 5000 mV
Jan 28 10:58:17 j-desktop kernel: vdd-sys-bl: 3300 mV
Jan 28 10:58:17 j-desktop kernel: en-vdd-sys: 1200 mV
Jan 28 10:58:17 j-desktop kernel: camchar: rtcpu character device driver loaded
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio wake53 for gpio=159(X:7)
Jan 28 10:58:17 j-desktop kernel: extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
Jan 28 10:58:17 j-desktop kernel: clocksource: Switched to clocksource arch_sys_counter
Jan 28 10:58:17 j-desktop kernel: VFS: Disk quotas dquot_6.6.0
Jan 28 10:58:17 j-desktop kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jan 28 10:58:17 j-desktop kernel: nvmap_heap_init: nvmap_heap_init: created heap block cache
Jan 28 10:58:17 j-desktop kernel: nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
Jan 28 10:58:17 j-desktop kernel: nvmap_page_pool_init: Total RAM pages: 975958
Jan 28 10:58:17 j-desktop kernel: nvmap_page_pool_init: nvmap page pool size: 121994 pages (476 MB)
Jan 28 10:58:17 j-desktop kernel: nvmap_background_zero_thread: PP zeroing thread starting.
Jan 28 10:58:17 j-desktop kernel: tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
Jan 28 10:58:17 j-desktop kernel: la/ptsa driver initialized.
Jan 28 10:58:17 j-desktop kernel: pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
Jan 28 10:58:17 j-desktop kernel: pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 2
Jan 28 10:58:17 j-desktop kernel: TCP established hash table entries: 32768 (order: 6, 262144 bytes)
Jan 28 10:58:17 j-desktop kernel: TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
Jan 28 10:58:17 j-desktop kernel: TCP: Hash tables configured (established 32768 bind 32768)
Jan 28 10:58:17 j-desktop kernel: UDP hash table entries: 2048 (order: 4, 65536 bytes)
Jan 28 10:58:17 j-desktop kernel: UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
Jan 28 10:58:17 j-desktop kernel: RPC: Registered named UNIX socket transport module.
Jan 28 10:58:17 j-desktop kernel: RPC: Registered udp transport module.
Jan 28 10:58:17 j-desktop kernel: RPC: Registered tcp transport module.
Jan 28 10:58:17 j-desktop kernel: RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 28 10:58:17 j-desktop kernel: PCI: CLS 0 bytes, default 64
Jan 28 10:58:17 j-desktop kernel: Trying to unpack rootfs image as initramfs...
Jan 28 10:58:17 j-desktop kernel: Freeing initrd memory: 5432K
Jan 28 10:58:17 j-desktop kernel: host1x 13e10000.host1x: initialized
Jan 28 10:58:17 j-desktop kernel: hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jan 28 10:58:17 j-desktop kernel: audit: initializing netlink subsys (disabled)
Jan 28 10:58:17 j-desktop kernel: audit: type=2000 audit(0.816:1): initialized
Jan 28 10:58:17 j-desktop kernel: workingset: timestamp_bits=46 max_order=20 bucket_order=0
Jan 28 10:58:17 j-desktop kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 28 10:58:17 j-desktop kernel: ntfs: driver 2.1.32 [Flags: R/W].
Jan 28 10:58:17 j-desktop kernel: 9p: Installing v9fs 9p2000 file system support
Jan 28 10:58:17 j-desktop kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
Jan 28 10:58:17 j-desktop kernel: io scheduler noop registered
Jan 28 10:58:17 j-desktop kernel: io scheduler cfq registered (default)
Jan 28 10:58:17 j-desktop kernel: gic 2a41000.agic-controller: GIC IRQ controller registered
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device aconnect@2a41000:adsp_audio to group 54
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 2993000.adsp to group 55
Jan 28 10:58:17 j-desktop kernel: tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
Jan 28 10:58:17 j-desktop kernel: tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
Jan 28 10:58:17 j-desktop kernel: tegra-pwm 3280000.pwm: PWM clk can sleep in ops
Jan 28 10:58:17 j-desktop kernel: tegra-pwm 3290000.pwm: PWM clk can sleep in ops
Jan 28 10:58:17 j-desktop kernel: tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
Jan 28 10:58:17 j-desktop kernel: tegra-pwm c340000.pwm: PWM clk can sleep in ops
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
Jan 28 10:58:17 j-desktop kernel: tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Jan 28 10:58:17 j-desktop kernel: misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
Jan 28 10:58:17 j-desktop kernel: misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
Jan 28 10:58:17 j-desktop kernel: tsec 15500000.tsec: initialized
Jan 28 10:58:17 j-desktop kernel: tsec 15100000.tsecb: initialized
Jan 28 10:58:17 j-desktop kernel: nvdec 15480000.nvdec: initialized
Jan 28 10:58:17 j-desktop kernel: falcon 15340000.vic: initialized
Jan 28 10:58:17 j-desktop kernel: falcon 154c0000.nvenc: initialized
Jan 28 10:58:17 j-desktop kernel: falcon 15380000.nvjpg: initialized
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
Jan 28 10:58:17 j-desktop kernel: iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
Jan 28 10:58:17 j-desktop kernel: tegradccommon 15200000.dc_common: host1x channel mapped
Jan 28 10:58:17 j-desktop kernel: tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
Jan 28 10:58:17 j-desktop kernel: tegradccommon 15200000.dc_common: dma mapping done
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
Jan 28 10:58:17 j-desktop kernel: generic_infoframe_type: 0x87
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: DT parsed successfully
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: Display dc.ffffff800b650000 registered with id=0
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
Jan 28 10:58:17 j-desktop kernel: tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
Jan 28 10:58:17 j-desktop kernel: tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
Jan 28 10:58:17 j-desktop kernel: kfuse 3830000.kfuse: initialized
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
Jan 28 10:58:17 j-desktop kernel: tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
Jan 28 10:58:17 j-desktop kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: probed
Jan 28 10:58:17 j-desktop kernel: console [ttyS0] disabled
Jan 28 10:58:17 j-desktop kernel: 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
Jan 28 10:58:17 j-desktop kernel: console [ttyS0] enabled
Jan 28 10:58:17 j-desktop kernel: 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
Jan 28 10:58:17 j-desktop kernel: c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
Jan 28 10:58:17 j-desktop kernel: serial-tegra 3130000.serial: RX in PIO mode
Jan 28 10:58:17 j-desktop kernel: 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
Jan 28 10:58:17 j-desktop kernel: [drm] Initialized
Jan 28 10:58:17 j-desktop kernel: Console: switching to colour frame buffer device 240x67
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: fb registered
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio wake21 for gpio=121(P:1)
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
Jan 28 10:58:17 j-desktop kernel: Parent Clock set for DC plld2
Jan 28 10:58:17 j-desktop kernel: brd: module loaded
Jan 28 10:58:17 j-desktop kernel: loop: module loaded
Jan 28 10:58:17 j-desktop kernel: tegra_profiler: version: 1.134, samples/io: 47/26
Jan 28 10:58:17 j-desktop kernel: tegra_profiler: auth: init
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: starting parse dt
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: !!!Found deprecated property!!!
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: success parsing dt
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
Jan 28 10:58:17 j-desktop kernel: THERMAL EST: found 3 subdevs
Jan 28 10:58:17 j-desktop kernel: THERMAL EST num_resources: 0
Jan 28 10:58:17 j-desktop kernel: [THERMAL EST subdev 0]
Jan 28 10:58:17 j-desktop kernel: [THERMAL EST subdev 1]
Jan 28 10:58:17 j-desktop kernel: [THERMAL EST subdev 2]
Jan 28 10:58:17 j-desktop kernel: thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
Jan 28 10:58:17 j-desktop kernel: THERMAL EST: thz register success.
Jan 28 10:58:17 j-desktop kernel: THERMAL EST: end of probe, return err: 0
Jan 28 10:58:17 j-desktop kernel: hisi_sas: driver version v1.6
Jan 28 10:58:17 j-desktop kernel: tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
Jan 28 10:58:17 j-desktop kernel: tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
Jan 28 10:58:17 j-desktop kernel: scsi host0: tegra_ahci
Jan 28 10:58:17 j-desktop kernel: scsi host1: tegra_ahci
Jan 28 10:58:17 j-desktop kernel: ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
Jan 28 10:58:17 j-desktop kernel: ata2: DUMMY
Jan 28 10:58:17 j-desktop kernel: libphy: Fixed MDIO Bus: probed
Jan 28 10:58:17 j-desktop kernel: tun: Universal TUN/TAP device driver, 1.6
Jan 28 10:58:17 j-desktop kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jan 28 10:58:17 j-desktop kernel: e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jan 28 10:58:17 j-desktop kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jan 28 10:58:17 j-desktop kernel: igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
Jan 28 10:58:17 j-desktop kernel: igb: Copyright (c) 2007-2014 Intel Corporation.
Jan 28 10:58:17 j-desktop kernel: igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jan 28 10:58:17 j-desktop kernel: igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jan 28 10:58:17 j-desktop kernel: Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
Jan 28 10:58:17 j-desktop kernel: Copyright(c) 1999 - 2017 Intel Corporation.
Jan 28 10:58:17 j-desktop kernel: eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
Jan 28 10:58:17 j-desktop kernel: eqos 2490000.ether_qos: Setting local MAC: 0 4 4b e4 d0 a2
Jan 28 10:58:17 j-desktop kernel: libphy: dwc_phy: probed
Jan 28 10:58:17 j-desktop kernel: bcm54xx_low_power_mode(): put phy in iddq-lp mode
Jan 28 10:58:17 j-desktop kernel: PPP generic driver version 2.4.2
Jan 28 10:58:17 j-desktop kernel: PPP BSD Compression module registered
Jan 28 10:58:17 j-desktop kernel: PPP Deflate Compression module registered
Jan 28 10:58:17 j-desktop kernel: PPP MPPE Compression module registered
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 24
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver r8152
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver asix
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver ax88179_178a
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver cdc_ether
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver net1080
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver cdc_subset
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver zaurus
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver cdc_ncm
Jan 28 10:58:17 j-desktop kernel: VFIO - User Level meta-driver version: 0.3
Jan 28 10:58:17 j-desktop kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 28 10:58:17 j-desktop kernel: ehci-pci: EHCI PCI platform driver
Jan 28 10:58:17 j-desktop kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 28 10:58:17 j-desktop kernel: ohci-pci: OHCI PCI platform driver
Jan 28 10:58:17 j-desktop kernel: ohci-platform: OHCI generic platform driver
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: LOC shutdown limit 107
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: EXT shutdown limit 107
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: extcon 0: ffffffc0ef5da400 id
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver uas
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver usb-storage
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver usbserial
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
Jan 28 10:58:17 j-desktop kernel: tegra-xudc-new 3550000.xudc: device count: 1
Jan 28 10:58:17 j-desktop kernel: tegra-xudc-new 3550000.xudc: vbus state: 1
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: get RGB quant from REG programmed by BL.
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: get YCC quant from REG programmed by BL.
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: xHCI Host Controller
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
Jan 28 10:58:17 j-desktop kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 28 10:58:17 j-desktop kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 10:58:17 j-desktop kernel: usb usb1: Product: xHCI Host Controller
Jan 28 10:58:17 j-desktop kernel: usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
Jan 28 10:58:17 j-desktop kernel: usb usb1: SerialNumber: 3530000.xhci
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: initial LOC temp: 42000
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: initial EXT temp: 44250
Jan 28 10:58:17 j-desktop kernel: hub 1-0:1.0: USB hub found
Jan 28 10:58:17 j-desktop kernel: hub 1-0:1.0: 4 ports detected
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: hi_b:-11, lo_b:0
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
Jan 28 10:58:17 j-desktop kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Jan 28 10:58:17 j-desktop kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jan 28 10:58:17 j-desktop kernel: usb usb2: Product: xHCI Host Controller
Jan 28 10:58:17 j-desktop kernel: usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
Jan 28 10:58:17 j-desktop kernel: usb usb2: SerialNumber: 3530000.xhci
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio-aon wake35 for gpio=16(V:0)
Jan 28 10:58:17 j-desktop kernel: nct1008_nct72 7-004c: nct1008_probe: initialized
Jan 28 10:58:17 j-desktop kernel: hub 2-0:1.0: USB hub found
Jan 28 10:58:17 j-desktop kernel: hub 2-0:1.0: 3 ports detected
Jan 28 10:58:17 j-desktop kernel: extcon-disp-state external-connection:disp-state: cable 47 state 1
Jan 28 10:58:17 j-desktop kernel: Extcon AUX1(HDMI) enable
Jan 28 10:58:17 j-desktop kernel: tegra-usb-cd usb_cd: notification status (0x0, 0x1)
Jan 28 10:58:17 j-desktop kernel: tegra-usb-cd usb_cd: connected to SDP
Jan 28 10:58:17 j-desktop kernel: tegra-xudc-new 3550000.xudc: device mode on: 0
Jan 28 10:58:17 j-desktop kernel: tegra-xudc-new 3550000.xudc: active: 0 => 1
Jan 28 10:58:17 j-desktop kernel: mousedev: PS/2 mouse device common for all mice
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver xpad
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: blank - powerdown
Jan 28 10:58:17 j-desktop kernel: extcon-disp-state external-connection:disp-state: cable 47 state 0
Jan 28 10:58:17 j-desktop kernel: Extcon AUX1(HDMI) disable
Jan 28 10:58:17 j-desktop kernel: max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Jan 28 10:58:17 j-desktop kernel: Wake73 for irq=42
Jan 28 10:58:17 j-desktop kernel: rtc rtc1: alarm rtc device
Jan 28 10:58:17 j-desktop kernel: tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
Jan 28 10:58:17 j-desktop kernel: tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
Jan 28 10:58:17 j-desktop kernel: i2c /dev entries driver
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
Jan 28 10:58:17 j-desktop kernel: tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
Jan 28 10:58:17 j-desktop kernel: max77620-power max20024-power: Event recorder REG_NVERC : 0x0
Jan 28 10:58:17 j-desktop kernel: parse_throttle_dt_data: Num cap clks = 4
Jan 28 10:58:17 j-desktop kernel: parse_throttle_dt_data: clk=mcpu type=1
Jan 28 10:58:17 j-desktop kernel: parse_throttle_dt_data: clk=bcpu type=2
Jan 28 10:58:17 j-desktop kernel: parse_throttle_dt_data: clk=gpu type=4
Jan 28 10:58:17 j-desktop kernel: parse_throttle_dt_data: clk=emc type=3
Jan 28 10:58:17 j-desktop kernel: tegra_throttle_probe: probe successful. #cdevs=4
Jan 28 10:58:17 j-desktop kernel: ata1: SATA link down (SStatus 0 SControl 300)
Jan 28 10:58:17 j-desktop kernel: FAN dev name: pwm-fan
Jan 28 10:58:17 j-desktop kernel: FAN:gpio request success.
Jan 28 10:58:17 j-desktop kernel: FAN: can't find tach_gpio
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: tach period: 1000
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
Jan 28 10:58:17 j-desktop kernel: pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
Jan 28 10:58:17 j-desktop kernel: device-mapper: uevent: version 1.0.3
Jan 28 10:58:17 j-desktop kernel: device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: link 0 down, retrying
Jan 28 10:58:17 j-desktop kernel: cpufreq: platform driver Initialization: pass
Jan 28 10:58:17 j-desktop kernel: cpuidle: Initializing cpuidle driver init for Denver cluster
Jan 28 10:58:17 j-desktop kernel: cpuidle: Initializing cpuidle driver init for A57 cluster
Jan 28 10:58:17 j-desktop kernel: sdhci: Secure Digital Host Controller Interface driver
Jan 28 10:58:17 j-desktop kernel: sdhci: Copyright(c) Pierre Ossman
Jan 28 10:58:17 j-desktop kernel: sdhci-pltfm: SDHCI platform and OF driver helper
Jan 28 10:58:17 j-desktop kernel: sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
Jan 28 10:58:17 j-desktop kernel: CMDQ: cmdq_platfm_init successful
Jan 28 10:58:17 j-desktop kernel: CQE: CMD_TIMING bit set for R1B DCMD
Jan 28 10:58:17 j-desktop kernel: sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
Jan 28 10:58:17 j-desktop kernel: sdhci-tegra 3400000.sdhci: Got CD GPIO
Jan 28 10:58:17 j-desktop kernel: sdhci-tegra 3400000.sdhci: Got WP GPIO
Jan 28 10:58:17 j-desktop kernel: sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
Jan 28 10:58:17 j-desktop kernel: sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
Jan 28 10:58:17 j-desktop kernel: tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: unblank
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15810000.se: initialized
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15810000.se: tegra_se_probe: complete
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15820000.se: initialized
Jan 28 10:58:17 j-desktop kernel: usb 1-2: new high-speed USB device number 2 using tegra-xusb
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15820000.se: tegra_se_probe: complete
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15830000.se: initialized
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: tmds rate:319750K prod-setting:prod_c_hdmi_300m_600m
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15830000.se: tegra_se_probe: complete
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15840000.se: initialized
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
Jan 28 10:58:17 j-desktop kernel: tegra-se-nvhost 15840000.se: tegra_se_probe: complete
Jan 28 10:58:17 j-desktop kernel: hidraw: raw HID events driver (C) Jiri Kosina
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver usbhid
Jan 28 10:58:17 j-desktop kernel: usbhid: USB HID core driver
Jan 28 10:58:17 j-desktop kernel: tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
Jan 28 10:58:17 j-desktop kernel: tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
Jan 28 10:58:17 j-desktop kernel: tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
Jan 28 10:58:17 j-desktop kernel: tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
Jan 28 10:58:17 j-desktop kernel: tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
Jan 28 10:58:17 j-desktop kernel: mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 28 10:58:17 j-desktop kernel: usb 1-2: New USB device found, idVendor=1a40, idProduct=0101
Jan 28 10:58:17 j-desktop kernel: usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Jan 28 10:58:17 j-desktop kernel: usb 1-2: Product: USB 2.0 Hub
Jan 28 10:58:17 j-desktop kernel: tegra_aon c1a0000.aon: tegra aon driver probe OK
Jan 28 10:58:17 j-desktop kernel: hub 1-2:1.0: USB hub found
Jan 28 10:58:17 j-desktop kernel: hub 1-2:1.0: 4 ports detected
Jan 28 10:58:17 j-desktop kernel: mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 28 10:58:17 j-desktop kernel: tegra186-aondbg aondbg: aondbg driver probe() OK
Jan 28 10:58:17 j-desktop kernel: register_ari_mca_banks: Registered MCA ROC:IOB
Jan 28 10:58:17 j-desktop kernel: register_ari_mca_banks: Registered MCA ROC:CCE
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2390000.axi2apb: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23a0000.axi2apb: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23b0000.axi2apb: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23c0000.axi2apb: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 23d0000.axi2apb: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2100000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2110000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2120000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2130000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2140000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2150000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2160000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2170000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2180000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
Jan 28 10:58:17 j-desktop kernel: tegra18-bridge 2190000.axip2p: bridge probed OK
Jan 28 10:58:17 j-desktop kernel: tegra18_a57_serr_init: on CPU 2 a Denver Core
Jan 28 10:58:17 j-desktop kernel: tegra18x_actmon d230000.actmon: in actmon_register()...
Jan 28 10:58:17 j-desktop kernel: tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
Jan 28 10:58:17 j-desktop kernel: hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
Jan 28 10:58:17 j-desktop kernel: denver_knobs_init:MTS_VERSION:43068234
Jan 28 10:58:17 j-desktop kernel: nvpmodel: initialized successfully
Jan 28 10:58:17 j-desktop kernel: trusty-virtio trusty:virtio: initializing
Jan 28 10:58:17 j-desktop kernel: trusty_ipc virtio0: vring0: va(pa)  ffffffc0eb3a4000(0) qsz 32 notifyid 1
Jan 28 10:58:17 j-desktop kernel: trusty_ipc virtio0: vring1: va(pa)  ffffffc0eb3a6000(0) qsz 32 notifyid 2
Jan 28 10:58:17 j-desktop kernel: trusty-virtio trusty:virtio: initializing done
Jan 28 10:58:17 j-desktop kernel: trusty_ipc virtio0: is online
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio wake71 for gpio=125(P:5)
Jan 28 10:58:17 j-desktop kernel: mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 28 10:58:17 j-desktop kernel: usbcore: registered new interface driver snd-usb-audio
Jan 28 10:58:17 j-desktop kernel: input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
Jan 28 10:58:17 j-desktop kernel: input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
Jan 28 10:58:17 j-desktop kernel: mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
Jan 28 10:58:17 j-desktop kernel: mmc0: periodic cache flush enabled
Jan 28 10:58:17 j-desktop kernel: mmc0: new HS400 Enhanced strobe MMC card at address 0001
Jan 28 10:58:17 j-desktop kernel: mmcblk0: mmc0:0001 DG4016 14.7 GiB
Jan 28 10:58:17 j-desktop kernel: mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
Jan 28 10:58:17 j-desktop kernel: mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
Jan 28 10:58:17 j-desktop kernel: mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
Jan 28 10:58:17 j-desktop kernel:  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
Jan 28 10:58:17 j-desktop kernel: OPE platform probe
Jan 28 10:58:17 j-desktop kernel: OPE platform probe successful
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: This is a dummy codec
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
Jan 28 10:58:17 j-desktop kernel: tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
Jan 28 10:58:17 j-desktop kernel: u32 classifier
Jan 28 10:58:17 j-desktop kernel:     Actions configured
Jan 28 10:58:17 j-desktop kernel: Initializing XFRM netlink socket
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 10
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 17
Jan 28 10:58:17 j-desktop kernel: NET: Registered protocol family 15
Jan 28 10:58:17 j-desktop kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Jan 28 10:58:17 j-desktop kernel: Bluetooth: RFCOMM socket layer initialized
Jan 28 10:58:17 j-desktop kernel: Bluetooth: RFCOMM ver 1.11
Jan 28 10:58:17 j-desktop kernel: Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Jan 28 10:58:17 j-desktop kernel: Bluetooth: HIDP socket layer initialized
Jan 28 10:58:17 j-desktop kernel: 9pnet: Installing 9P2000 support
Jan 28 10:58:17 j-desktop kernel: Key type dns_resolver registered
Jan 28 10:58:17 j-desktop kernel: Registered cp15_barrier emulation handler
Jan 28 10:58:17 j-desktop kernel: Registered setend emulation handler
Jan 28 10:58:17 j-desktop kernel: registered taskstats version 1
Jan 28 10:58:17 j-desktop kernel: isp 15600000.isp: initialized
Jan 28 10:58:17 j-desktop kernel: nvcsi 150c0000.nvcsi: initialized
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
Jan 28 10:58:17 j-desktop kernel: gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
Jan 28 10:58:17 j-desktop kernel: input: gpio-keys as /devices/gpio-keys/input/input2
Jan 28 10:58:17 j-desktop kernel: tegra-vi4 15700000.vi: initialized
Jan 28 10:58:17 j-desktop kernel: tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
Jan 28 10:58:17 j-desktop kernel: tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
Jan 28 10:58:17 j-desktop kernel: tegra_rtc c2a0000.rtc: setting system clock to 2000-01-21 10:26:01 UTC (948450361)
Jan 28 10:58:17 j-desktop kernel: mmcblk mmc0:0001: Card claimed for testing.
Jan 28 10:58:17 j-desktop kernel: bpmp: mounted debugfs mirror
Jan 28 10:58:17 j-desktop kernel: bwmgr: missing cdev-type property
Jan 28 10:58:17 j-desktop kernel: spmic-ldo0: disabling
Jan 28 10:58:17 j-desktop kernel: spmic-ldo1: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-sd: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-cam: disabling
Jan 28 10:58:17 j-desktop kernel: vdd-usb0-5v: disabling
Jan 28 10:58:17 j-desktop kernel: vdd-usb1-5v: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-disp-3v3: disabling
The log was too big, so i’m continuing it here:
Jan 28 10:58:17 j-desktop kernel: en-mdm-pwr-3v7: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-disp-1v8: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-cam-hv-2v8: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-cam-1v2: disabling
Jan 28 10:58:17 j-desktop kernel: vdd-fan: disabling
Jan 28 10:58:17 j-desktop kernel: vdd-3v3: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-vcm-2v8: disabling
Jan 28 10:58:17 j-desktop kernel: vdd-usb2-5v: disabling
Jan 28 10:58:17 j-desktop kernel: vdd-sys-bl: disabling
Jan 28 10:58:17 j-desktop kernel: en-vdd-sys: disabling
Jan 28 10:58:17 j-desktop kernel: ALSA device list:
Jan 28 10:58:17 j-desktop kernel:   #0: tegra-hda at 0x3518000 irq 383
Jan 28 10:58:17 j-desktop kernel:   #1: tegra-snd-t186ref-mobile-rt565x
Jan 28 10:58:17 j-desktop kernel: usb 1-2.1: new low-speed USB device number 3 using tegra-xusb
Jan 28 10:58:17 j-desktop kernel: usb 1-2.1: New USB device found, idVendor=04f2, idProduct=0939
Jan 28 10:58:17 j-desktop kernel: usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 28 10:58:17 j-desktop kernel: usb 1-2.1: Product: USB Optical Mouse
Jan 28 10:58:17 j-desktop kernel: usb 1-2.1: Manufacturer: PixArt
Jan 28 10:58:17 j-desktop kernel: input: PixArt USB Optical Mouse as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:04F2:0939.0001/input/input3
Jan 28 10:58:17 j-desktop kernel: hid-generic 0003:04F2:0939.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3530000.xhci-2.1/input0
Jan 28 10:58:17 j-desktop kernel: usb 1-2.2: new low-speed USB device number 4 using tegra-xusb
Jan 28 10:58:17 j-desktop kernel: usb 1-2.2: New USB device found, idVendor=413c, idProduct=2113
Jan 28 10:58:17 j-desktop kernel: usb 1-2.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Jan 28 10:58:17 j-desktop kernel: usb 1-2.2: Product: Dell KB216 Wired Keyboard
Jan 28 10:58:17 j-desktop kernel: input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:413C:2113.0002/input/input4
Jan 28 10:58:17 j-desktop kernel: hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3530000.xhci-2.2/input0
Jan 28 10:58:17 j-desktop kernel: input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:413C:2113.0003/input/input5
Jan 28 10:58:17 j-desktop kernel: hid-generic 0003:413C:2113.0003: input,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3530000.xhci-2.2/input1
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
Jan 28 10:58:17 j-desktop kernel: usb 1-2.3: new full-speed USB device number 5 using tegra-xusb
Jan 28 10:58:17 j-desktop kernel: tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
Jan 28 10:58:17 j-desktop kernel: pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
Jan 28 10:58:17 j-desktop kernel: pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
Jan 28 10:58:17 j-desktop kernel: pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
Jan 28 10:58:17 j-desktop kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
Jan 28 10:58:17 j-desktop kernel: pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
Jan 28 10:58:17 j-desktop kernel: pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 0000:00:03.0 to group 56
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 0000:00:03.0
Jan 28 10:58:17 j-desktop kernel: pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: [1b4b:2b42] type 00 class 0x020000
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit pref]
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit pref]
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: supports D1 D2
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
Jan 28 10:58:17 j-desktop kernel: iommu: Adding device 0000:01:00.0 to group 57
Jan 28 10:58:17 j-desktop kernel: arm-smmu: forcing sodev map for 0000:01:00.0
Jan 28 10:58:17 j-desktop kernel: usb 1-2.3: New USB device found, idVendor=05ac, idProduct=1393
Jan 28 10:58:17 j-desktop kernel: usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 28 10:58:17 j-desktop kernel: usb 1-2.3: Product: AirPod Case
Jan 28 10:58:17 j-desktop kernel: usb 1-2.3: Manufacturer: Apple Inc.
Jan 28 10:58:17 j-desktop kernel: usb 1-2.3: SerialNumber: DLCW1H5JH8TT
Jan 28 10:58:17 j-desktop kernel: hid-generic 0003:05AC:1393.0004: hidraw3: USB HID v1.11 Device [Apple Inc. AirPod Case] on usb-3530000.xhci-2.3/input0
Jan 28 10:58:17 j-desktop kernel: pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Jan 28 10:58:17 j-desktop kernel: pci 0000:00:03.0: BAR 15: assigned [mem 0x48000000-0x481fffff 64bit pref]
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: BAR 0: assigned [mem 0x48000000-0x480fffff 64bit pref]
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: BAR 2: assigned [mem 0x48100000-0x481fffff 64bit pref]
Jan 28 10:58:17 j-desktop kernel: pci 0000:00:03.0: PCI bridge to [bus 01]
Jan 28 10:58:17 j-desktop kernel: pci 0000:00:03.0:   bridge window [mem 0x48000000-0x481fffff 64bit pref]
Jan 28 10:58:17 j-desktop kernel: pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
Jan 28 10:58:17 j-desktop kernel: pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
Jan 28 10:58:17 j-desktop kernel: pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
Jan 28 10:58:17 j-desktop kernel: aer 0000:00:03.0:pcie002: service driver aer loaded
Jan 28 10:58:17 j-desktop kernel: usb 1-2.4: new high-speed USB device number 6 using tegra-xusb
Jan 28 10:58:17 j-desktop kernel: usb 1-2.4: New USB device found, idVendor=090c, idProduct=1000
Jan 28 10:58:17 j-desktop kernel: usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 28 10:58:17 j-desktop kernel: usb 1-2.4: Product: Flash Drive DUO
Jan 28 10:58:17 j-desktop kernel: usb 1-2.4: Manufacturer: Samsung
Jan 28 10:58:17 j-desktop kernel: usb 1-2.4: SerialNumber: 0332316020046949
Jan 28 10:58:17 j-desktop kernel: usb-storage 1-2.4:1.0: USB Mass Storage device detected
Jan 28 10:58:17 j-desktop kernel: scsi host2: usb-storage 1-2.4:1.0
Jan 28 10:58:17 j-desktop kernel: extcon-disp-state external-connection:disp-state: cable 40 state 1
Jan 28 10:58:17 j-desktop kernel: Extcon HDMI: HPD enabled
Jan 28 10:58:17 j-desktop kernel: tegradc 15210000.nvdisplay: hdmi: plugged
Jan 28 10:58:17 j-desktop kernel: Freeing unused kernel memory: 8576K
Jan 28 10:58:17 j-desktop unknown: L4T-INITRD Build DATE: Fri Jan 21 10:26:03 UTC 2000
Jan 28 10:58:17 j-desktop unknown: Root device found: mmcblk0p1
Jan 28 10:58:17 j-desktop unknown: Found dev node: /dev/mmcblk0p1
Jan 28 10:58:17 j-desktop kernel: scsi 2:0:0:0: Direct-Access     Samsung  Flash Drive DUO  1100 PQ: 0 ANSI: 6
Jan 28 10:58:17 j-desktop kernel: sd 2:0:0:0: [sda] 125304832 512-byte logical blocks: (64.2 GB/59.8 GiB)
Jan 28 10:58:17 j-desktop kernel: sd 2:0:0:0: [sda] Write Protect is off
Jan 28 10:58:17 j-desktop kernel: sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
Jan 28 10:58:17 j-desktop kernel: sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 28 10:58:17 j-desktop kernel:  sda: sda1
Jan 28 10:58:17 j-desktop kernel: sd 2:0:0:0: [sda] Attached SCSI removable disk
Jan 28 10:58:17 j-desktop kernel: EXT4-fs (mmcblk0p1): 5 orphan inodes deleted
Jan 28 10:58:17 j-desktop kernel: EXT4-fs (mmcblk0p1): recovery complete
Jan 28 10:58:17 j-desktop kernel: EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Jan 28 10:58:17 j-desktop unknown: Rootfs mounted over mmcblk0p1
Jan 28 10:58:17 j-desktop kernel: random: crng init done
Jan 28 10:58:17 j-desktop unknown: Switching from initrd to actual rootfs
Jan 28 10:58:17 j-desktop systemd[1]: System time before build time, advancing clock.
Jan 28 10:58:17 j-desktop kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 28 10:58:17 j-desktop kernel: cgroup: cgroup2: unknown option "nsdelegate"
Jan 28 10:58:17 j-desktop systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
Jan 28 10:58:17 j-desktop systemd[1]: Detected architecture arm64.
Jan 28 10:58:17 j-desktop systemd[1]: Set hostname to <j-desktop>.
Jan 28 10:58:17 j-desktop kernel: Wake76 for irq=199
Jan 28 10:58:17 j-desktop kernel: Wake77 for irq=199
Jan 28 10:58:17 j-desktop kernel: Wake78 for irq=199
Jan 28 10:58:17 j-desktop kernel: Wake79 for irq=199
Jan 28 10:58:17 j-desktop kernel: Wake80 for irq=199
Jan 28 10:58:17 j-desktop kernel: Wake81 for irq=199
Jan 28 10:58:17 j-desktop kernel: Wake82 for irq=199
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
Jan 28 10:58:17 j-desktop kernel: tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
Jan 28 10:58:17 j-desktop systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
Jan 28 10:58:17 j-desktop systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
Jan 28 10:58:17 j-desktop kernel: usb usb2: usb_suspend_both: status 0
Jan 28 10:58:17 j-desktop systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Jan 28 10:58:17 j-desktop systemd[1]: Reached target Swap.
Jan 28 10:58:17 j-desktop systemd[1]: Created slice System Slice.
Jan 28 10:58:17 j-desktop systemd[1]: Listening on RPCbind Server Activation Socket.
Jan 28 10:58:17 j-desktop systemd[1]: Listening on Syslog Socket.
Jan 28 10:58:17 j-desktop kernel: EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
Jan 28 10:58:17 j-desktop systemd-journald[2266]: Journal started
Jan 28 10:58:17 j-desktop systemd-journald[2266]: Runtime journal (/run/log/journal/c257cde8ebe24451b88f17bac5ac101c) is 8.0M, max 191.3M, 183.3M free.
Jan 28 10:58:17 j-desktop systemd-modules-load[2255]: Inserted module 'bluedroid_pm'
Jan 28 10:58:17 j-desktop systemd-modules-load[2255]: Module 'nvhost_vi' is builtin
Jan 28 10:58:17 j-desktop systemd-modules-load[2255]: Inserted module 'nvgpu'
Jan 28 10:58:17 j-desktop systemd-sysctl[2434]: Couldn't write '1' to 'net/ipv4/tcp_syncookies', ignoring: No such file or directory
Jan 28 10:58:17 j-desktop systemd-sysctl[2434]: Couldn't write '1' to 'kernel/yama/ptrace_scope', ignoring: No such file or directory
Jan 28 10:58:17 j-desktop systemd-sysctl[2434]: Couldn't write 'fq_codel' to 'net/core/default_qdisc', ignoring: No such file or directory
Jan 28 10:58:17 j-desktop systemd[1]: Started Apply Kernel Variables.
Jan 28 10:58:17 j-desktop systemd[1]: Starting Flush Journal to Persistent Storage...
Jan 28 10:58:17 j-desktop systemd[1]: Reached target Local File Systems (Pre).
Jan 28 10:58:17 j-desktop systemd[1]: Reached target Local File Systems.
Jan 28 10:58:17 j-desktop systemd[1]: Starting Preprocess NFS configuration...
Jan 28 10:58:17 j-desktop systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
Jan 28 10:58:17 j-desktop systemd[1]: Starting Set console font and keymap...
Jan 28 10:58:17 j-desktop systemd[1]: Starting Clean up any mess left by 0dns-up...
Jan 28 10:58:17 j-desktop systemd[1]: Starting udev Kernel Device Manager...
Jan 28 10:58:17 j-desktop systemd[1]: Started Preprocess NFS configuration.
Jan 28 10:58:17 j-desktop systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jan 28 10:58:17 j-desktop systemd[1]: Started Clean up any mess left by 0dns-up.
Jan 28 10:58:17 j-desktop systemd[1]: Starting Nameserver information manager...
Jan 28 10:58:17 j-desktop systemd[1]: Reached target NFS client services.
Jan 28 10:58:17 j-desktop systemd-udevd[3121]: Network interface NamePolicy= disabled on kernel command line, ignoring.
Jan 28 10:58:17 j-desktop systemd[1]: Started Flush Journal to Persistent Storage.
Jan 28 10:58:17 j-desktop systemd[1]: Starting Create Volatile Files and Directories...
Jan 28 10:58:17 j-desktop systemd[1]: Started Nameserver information manager.
Jan 28 10:58:17 j-desktop systemd[1]: Reached target Network (Pre).
Jan 28 10:58:17 j-desktop systemd[1]: Starting Raise network interfaces...
Jan 28 10:58:17 j-desktop systemd[1]: Started Create Volatile Files and Directories.
Jan 28 10:58:17 j-desktop systemd[1]: Started Entropy daemon using the HAVEGE algorithm.
Jan 28 10:58:17 j-desktop systemd[1]: Starting Update UTMP about System Boot/Shutdown...
Jan 28 10:58:17 j-desktop systemd[1]: Starting RPC bind portmap service...
Jan 28 10:58:17 j-desktop systemd[1]: Starting Network Name Resolution...
Jan 28 10:58:17 j-desktop systemd[1]: Starting Network Time Synchronization...
Jan 28 10:58:17 j-desktop systemd[1]: Started udev Kernel Device Manager.
Jan 28 10:58:17 j-desktop systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jan 28 10:58:17 j-desktop systemd[1]: Started RPC bind portmap service.
Jan 28 10:58:17 j-desktop systemd[1]: Reached target Remote File Systems (Pre).
Jan 28 10:58:17 j-desktop systemd[1]: Reached target Remote File Systems.
Jan 28 10:58:17 j-desktop systemd[1]: Reached target RPC Port Mapper.
Jan 28 10:58:18 j-desktop systemd-resolved[3304]: Positive Trust Anchors:
Jan 28 10:58:18 j-desktop systemd-resolved[3304]: . IN DS 19036 8 2 49aac11d7b6f6446702e54a1607371607a1a41855200fd2ce1cdde32f24e8fb5
Jan 28 10:58:18 j-desktop systemd-resolved[3304]: . IN DS 20326 8 2 e06d44b80b8f1d39a95c0b0d7c65d08458e880409bbc683457104237c7f8ec8d
Jan 28 10:58:18 j-desktop systemd-resolved[3304]: Negative trust anchors: 10.in-addr.arpa 16.172.in-addr.arpa 17.172.in-addr.arpa 18.172.in-addr.arpa 19.172.in-addr.arpa 20.172.in-addr.arpa 21.172.in-addr.arpa 22.172.in-addr.arpa 23.172.in-addr.arpa 24.172.in-addr.arpa 25.172.in-addr.arpa 26.172.in-addr.arpa 27.172.in-addr.arpa 28.172.in-addr.arpa 29.172.in-addr.arpa 30.172.in-addr.arpa 31.172.in-addr.arpa 168.192.in-addr.arpa d.f.ip6.arpa corp home internal intranet lan local private test
Jan 28 10:58:18 j-desktop systemd-resolved[3304]: Using system hostname 'j-desktop'.
Jan 28 10:58:18 j-desktop systemd[1]: Started Network Name Resolution.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Host and Network Name Lookups.
Jan 28 10:58:18 j-desktop systemd[1]: Started Raise network interfaces.
Jan 28 10:58:18 j-desktop systemd[1]: Started Network Time Synchronization.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target System Time Synchronized.
Jan 28 10:58:18 j-desktop systemd[1]: Started udev Coldplug all Devices.
Jan 28 10:58:18 j-desktop systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Local Encrypted Volumes.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target System Initialization.
Jan 28 10:58:18 j-desktop systemd[1]: anacron.timer: Not using persistent file timestamp Sun 2018-01-28 11:01:12 EST as it is in the future.
Jan 28 10:58:18 j-desktop systemd[1]: Started Trigger anacron every hour.
Jan 28 10:58:18 j-desktop systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Socket activation for snappy daemon.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Docker Socket for the API.
Jan 28 10:58:18 j-desktop systemd[1]: Started Message of the Day.
Jan 28 10:58:18 j-desktop systemd[1]: Listening on GPS (Global Positioning System) Daemon Sockets.
Jan 28 10:58:18 j-desktop systemd[1]: Listening on D-Bus System Message Bus Socket.
Jan 28 10:58:18 j-desktop systemd[1]: Started Daily Cleanup of Temporary Directories.
Jan 28 10:58:18 j-desktop systemd[1]: Started Daily apt download activities.
Jan 28 10:58:18 j-desktop systemd[1]: Started Daily apt upgrade and clean activities.
Jan 28 10:58:18 j-desktop systemd[1]: Started Discard unused blocks once a week.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Timers.
Jan 28 10:58:18 j-desktop systemd[1]: Started resolvconf-pull-resolved.path.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Paths.
Jan 28 10:58:18 j-desktop systemd[1]: Listening on Socket activation for snappy daemon.
Jan 28 10:58:18 j-desktop systemd[1]: Listening on Docker Socket for the API.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Sockets.
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Basic System.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Jan 28 10:58:18 j-desktop systemd[1]: Started Regular background program processing daemon.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Restore /etc/resolv.conf if the system crashed before the ppp link was shut down...
Jan 28 10:58:18 j-desktop systemd[1]: Started D-Bus System Message Bus.
Jan 28 10:58:18 j-desktop cron[4532]: (CRON) INFO (pidfile fd = 3)
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Found user 'avahi' (UID 114) and group 'avahi' (GID 119).
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Successfully dropped root privileges.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: avahi-daemon 0.7 starting up.
Jan 28 10:58:18 j-desktop cron[4532]: (CRON) INFO (Running @reboot jobs)
Jan 28 10:58:18 j-desktop systemd-udevd[3326]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Successfully called chroot().
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Successfully dropped remaining capabilities.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: No service file found in /etc/avahi/services.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Jan 28 10:58:18 j-desktop systemd[1]: Starting resolvconf-pull-resolved.service...
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: New relevant interface lo.IPv6 for mDNS.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: New relevant interface lo.IPv4 for mDNS.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Network interface enumeration completed.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Disk Manager...
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Registering new address record for ::1 on lo.*.
Jan 28 10:58:18 j-desktop avahi-daemon[4524]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jan 28 10:58:18 j-desktop systemd[1]: Starting LSB: Speech Dispatcher...
Jan 28 10:58:18 j-desktop systemd[1]: Starting Login Service...
Jan 28 10:58:18 j-desktop systemd[1]: Starting Snappy daemon...
Jan 28 10:58:18 j-desktop systemd[1]: Starting Save/Restore Sound Card State...
Jan 28 10:58:18 j-desktop systemd[1]: Starting System Logging Service...
Jan 28 10:58:18 j-desktop systemd[1]: Started Configure USB flashing port for device mode.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Network Manager...
Jan 28 10:58:18 j-desktop systemd[1]: Starting NVIDIA specific early first-boot script...
Jan 28 10:58:18 j-desktop systemd[1]: Starting LSB: Record successful boot for GRUB...
Jan 28 10:58:18 j-desktop systemd[1]: Started NVIDIA weston service.
Jan 28 10:58:18 j-desktop systemd[1]: Starting Modem Manager...
Jan 28 10:58:18 j-desktop systemd[1]: Starting WPA supplicant...
Jan 28 10:58:18 j-desktop systemd[1]: Starting LSB: automatic crash report generation...
Jan 28 10:58:18 j-desktop systemd[1]: Starting Dispatcher daemon for systemd-networkd...
Jan 28 10:58:18 j-desktop systemd[1]: Started Run anacron jobs.
Jan 28 10:58:18 j-desktop anacron[4777]: Anacron 2.3 started on 2018-01-28
Jan 28 10:58:18 j-desktop haveged[3264]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 6.4.0 CTV); collect: 128K
Jan 28 10:58:18 j-desktop haveged[3264]: haveged: cpu: (VC); data: 32K (V); inst: 48K (V); idx: 27/40; sz: 47556/70644
Jan 28 10:58:18 j-desktop haveged[3264]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 7.99885
Jan 28 10:58:18 j-desktop haveged[3264]: haveged: fills: 0, generated: 0
Jan 28 10:58:18 j-desktop systemd[1]: Starting Accounts Service...
Jan 28 10:58:18 j-desktop anacron[4777]: Will run job `cron.daily' in 5 min.
Jan 28 10:58:18 j-desktop systemd[1]: Started Restore /etc/resolv.conf if the system crashed before the ppp link was shut down.
Jan 28 10:58:18 j-desktop anacron[4777]: Will run job `cron.weekly' in 10 min.
Jan 28 10:58:18 j-desktop systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Jan 28 10:58:18 j-desktop anacron[4777]: Will run job `cron.monthly' in 15 min.
Jan 28 10:58:18 j-desktop systemd[1]: Started NVIDIA specific early first-boot script.
Jan 28 10:58:18 j-desktop anacron[4777]: Jobs will be executed sequentially
Jan 28 10:58:18 j-desktop systemd[1]: Starting NVIDIA specific first-boot script...
Jan 28 10:58:18 j-desktop ModemManager[4747]: <info>  ModemManager (version 1.10.0) starting in system bus...
Jan 28 10:58:18 j-desktop rsyslogd[4670]: imuxsock: Acquired UNIX socket '/run/systemd/journal/syslog' (fd 3) from systemd.  [v8.32.0]
Jan 28 10:58:18 j-desktop speech-dispatcher[4604]:  * speech-dispatcher disabled; edit /etc/default/speech-dispatcher
Jan 28 10:58:18 j-desktop rsyslogd[4670]: rsyslogd's groupid changed to 114
Jan 28 10:58:18 j-desktop systemd[1]: Started System Logging Service.
Jan 28 10:58:18 j-desktop rsyslogd[4670]: rsyslogd's userid changed to 109
Jan 28 10:58:18 j-desktop rsyslogd[4670]:  [origin software="rsyslogd" swVersion="8.32.0" x-pid="4670" x-info="http://www.rsyslog.com"] start
Jan 28 10:58:18 j-desktop dbus-daemon[4534]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=4747 comm="/usr/sbin/ModemManager --filter-policy=strict ")
Jan 28 10:58:18 j-desktop wpa_supplicant[4750]: Successfully initialized wpa_supplicant
Jan 28 10:58:18 j-desktop systemd[1]: Started LSB: Speech Dispatcher.
Jan 28 10:58:18 j-desktop udisksd[4602]: udisks daemon version 2.7.6 starting
Jan 28 10:58:18 j-desktop systemd-logind[4627]: New seat seat0.
Jan 28 10:58:18 j-desktop systemd[1]: Started WPA supplicant.
Jan 28 10:58:18 j-desktop systemd[1]: Found device /dev/ttyS0.
Jan 28 10:58:18 j-desktop alsactl[4851]: /usr/sbin/alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
Jan 28 10:58:18 j-desktop systemd[1]: Reached target Sound Card.
Jan 28 10:58:18 j-desktop apport[4766]:  * Starting automatic crash report generation: apport
An examination of my device-tree shows the following for xusb_pad_ctl:
j@j-desktop:/proc/device-tree/xusb_padctl@3520000/pads$ ls
hsic  name  usb2  usb3
Sorry that what I need is the bootloader log. Do you have uart console to dump the log?
Please share the result of below
  1. nvidia@nvidia-desktop:/proc/device-tree/chosen/plugin-manager/odm-data$ ls
  2. nvidia@nvidia-desktop:/proc/device-tree/xhci@3530000$ xxd phy-names
I’ll get the logs, but here’s the device tree outputs for now.
j@j-desktop:/proc/device-tree/chosen/plugin-manager/odm-data$ ls
android-build       enable-debug-console       enable-pcie-on-uphy-lane2  no-battery
disable-pmic-wdt    enable-denver-wdt          enable-pcie-on-uphy-lane4  normal-flashed
disable-sdmmc-hwcq  enable-pcie-on-uphy-lane0  enable-sata-on-uphy-lane5
disable-tegra-wdt   enable-pcie-on-uphy-lane1  name
j@j-desktop:/proc/device-tree/xhci@3530000$ xxd phy-names
00000000: 7573 6232 2d30 0075 7362 322d 3100       usb2-0.usb2-1.
jchendev,
Looks like a bug. I will help check.
Could you fallback to rel-28 and see if it can work?
Found the root cause. Will share the solution later.
For context, can I get the expected output of the device tree data? It’s useful for me to understand what to look for to help pinpoint any issues with device tree moving forward. I.e. what do i look for to verify that the device tree is set up correctly for USB and it’s not a problem at another layer?
Thanks for your help, I’ve been scratching my head for the past bit.
Below is the patch you need. Please note that your change in #1 is totally correct.
However, there is a mechanism called plugin-manager which would override the device tree according to different ODMDATA during jetson boot up time.
That is why I told you the only thing you need to do is change the ODMDATA but no need to change the device tree because plugin-manager would help.
However, rel-32.2 plugin-manager dts is not correct and cause your problem.
diff --git a/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3489-1000-a00-plugin-manager.dtsi b/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3489-1000-a00-plugin-manager.dtsi
index d745d00..5173f8b 100644
--- a/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3489-1000-a00-plugin-manager.dtsi
+++ b/kernel-dts/t18x-common-plugin-manager/tegra186-quill-p3489-1000-a00-plugin-manager.dtsi
@@ -89,8 +89,9 @@
 #if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
 				_overlay_ {
 					phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
-						<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>;
-					phy-names = "usb2-0", "usb2-1";
+						<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
+						<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>;
+					phy-names = "usb2-0", "usb2-1", "usb2-2";
 #else
 				_overlay_ {
and this one
diff --git a/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts b/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts
index b5e6a3b..3a74123 100644
--- a/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts
+++ b/kernel-dts/tegra186-quill-p3489-0888-a00-00-base.dts
@@ -153,6 +153,11 @@
 				vbus-supply = <&vdd_usb1_5v>;
 				nvidia,oc-pin = <1>;
+			usb2-2 {
+				status = "okay";
+				mode = "host";
+				vbus-supply = <&vdd_usb2_5v>;
 			usb3-0 {
 				nvidia,usb2-companion = <1>;
 				status = "okay";
@@ -360,8 +365,9 @@
 	xhci@3530000 {
+			<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
 			<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>;
-		phy-names = "usb2-0", "usb2-1", "usb3-0";
+		phy-names = "usb2-0", "usb2-1", "usb2-2", "usb3-0";
 		status = "okay";
diff --git a/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts b/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
index e1d1b17..71316a8 100644
--- a/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
+++ b/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
+			usb2-2 {
+				status = "okay";
+				mode = "host";
 			usb3-0 {
 				status = "okay";
@@ -369,8 +374,9 @@
 	xhci@3530000 {
 		status = "okay";
Awesome, thanks so much. This solved the problem.
Hi WayneWWW,
I have the same problem with jeffrey. I modify my device-tree and it can work well when use tx2-8GB. Reference the topic what I create https://forums.developer.nvidia.com/t/usb-still-cannot-work-after-modify-device-tree/115408.
Now I want to use tx2-4GB modules. I modify the device-tree tegra186-quill-p3489-0888-a00-00-base.dts and part of USB port work well except USB in M.2.
I try to modify ODMDATA and plugin-manager but it doesn’t work. So could you give me some help ?
Regards.
Hi CalmCar,
A fast way is check the runtime device tree. Please check the device tree under /proc/device-tree and find the usb node for M.2. Check if the status is set to enabled.
Hi WayneWWW,
It seems only have usb2-0,usb2-1.
Screenshot from 2020-03-25 09-13-19
For tx2-8GB, it has usb2-0,usb2-1,usb2-2 and usb3-0.
Screenshot from 2020-03-25 09-25-23
Hi WayneWWW,
I modify tegra186-quill-p3489-0888-a00-00-base.dts to this
Screenshot from 2020-03-25 09-37-08
and remove usb plugin-manager fragment in tegra186-quill-p3489-1000-a00-plugin-manager.dtsi
Screenshot from 2020-03-25 09-57-18
and usb M.2 can work.
