Hi
I tried the changes in the POST#3, as well as other changes mentioned in the links in POST#2.
None of them make USB0 work on my custom carrier board. So I flashed the original device tree to get the dmesg output and share it.
Here is the dmesg output:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5403-d8000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sat Feb 19 08:58:27 PST 2022
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2055168
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 24008 pages used for memmap
[ 0.000000] Normal zone: 1531392 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[ 0.000000] pcpu-alloc: s57624 r8192 d32488 u98304 alloc=24*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2022968
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 nv-auto-config video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 nv-auto-config
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29836(91%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7277628K/8220672K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 189380K reserved, 753664K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f80000 ( 15360 KB)
[ 0.000000] .rodata : 0xffffff8008f80000 - 0xffffff8009610000 ( 6720 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e80000 ( 8640 KB)
[ 0.000000] .data : 0xffffff8009e80000 - 0xffffff800a163008 ( 2957 KB)
[ 0.000000] .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4 ( 613 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001626] Console: colour dummy device 80x25
[ 0.001631] console [tty0] enabled
[ 0.001634] bootconsole [uart8250] disabled
[ 0.001642] kmemleak: Kernel memory leak detector disabled
[ 0.001652] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.001659] pid_max: default: 32768 minimum: 301
[ 0.001967] Security Framework initialized
[ 0.002121] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002125] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002715] ftrace: allocating 47098 entries in 184 pages
[ 0.124994] sched-energy: Sched-energy-costs installed from DT
[ 0.125003] ASID allocator initialised with 65536 entries
[ 0.164256] tegra-id: chipid=21817.
[ 0.164263] tegra-id: opt_subrevision=1.
[ 0.164280] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.164288] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.164294] DTB Build time: Feb 19 2022 09:00:51
[ 0.214747] CPU1: Booted secondary processor [4e0f0030]
[ 0.246152] CPU2: Booted secondary processor [4e0f0030]
[ 0.277166] CPU3: Booted secondary processor [411fd073]
[ 0.309131] CPU4: Booted secondary processor [411fd073]
[ 0.341121] CPU5: Booted secondary processor [411fd073]
[ 0.341178] Brought up 6 CPUs
[ 0.341182] SMP: Total of 6 processors activated.
[ 0.341187] CPU features: detected feature: 32-bit EL0 Support
[ 0.343259] CPU: All CPU(s) started at EL2
[ 0.343402] alternatives: patching kernel code
[ 0.346391] devtmpfs: initialized
[ 0.385933] Initilizing CustomIPI irq domain
[ 0.386087] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.386096] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.394382] pinctrl core: initialized pinctrl subsystem
[ 0.394628] OS set in device tree is not L4T.
[ 0.394785] regulator-dummy: no parameters
[ 0.394924] Initializing plugin-manager
[ 0.394986] Plugin module not found
[ 0.395024] Plugin-manager status disabled
[ 0.396977] NET: Registered protocol family 16
[ 0.397975] pstore: using zlib compression
[ 0.397988] console [pstore-1] enabled
[ 0.397991] pstore: Registered ramoops as persistent store backend
[ 0.397994] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[ 0.413176] cpuidle: using governor menu
[ 0.414736] bpmp: waiting for handshake
[ 0.414740] bpmp: handshake completed
[ 0.414757] bpmp: synchronizing channels
[ 0.414771] bpmp: channels synchronized
[ 0.414774] bpmp: mail init ok
[ 0.416965] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.416969] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.416974] arm-smmu 12000000.iommu: stage 1 translation
[ 0.416977] arm-smmu 12000000.iommu: stage 2 translation
[ 0.416980] arm-smmu 12000000.iommu: nested translation
[ 0.416986] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.416992] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.416996] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.417001] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.417005] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.419298] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[ 0.419312] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.421416] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.423593] Registering BPMP clocks...
[ 0.423681] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.424667] Serial: AMBA PL011 UART driver
[ 0.425815] tegra_powergate_init: DONE
[ 0.425823] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.425828] DTB Build time: Feb 19 2022 09:00:51
[ 0.428090] Tegra reboot handler registered.
[ 0.429719] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.429786] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.429798] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.429801] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[ 0.429803] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.429956] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.429966] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.430291] iommu: Adding device 3460000.sdhci to group 0
[ 0.430987] iommu: Adding device 3400000.sdhci to group 1
[ 0.432068] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.432082] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.432547] iommu: Adding device 3160000.i2c to group 3
[ 0.433023] iommu: Adding device c240000.i2c to group 4
[ 0.433418] iommu: Adding device 3180000.i2c to group 5
[ 0.433769] iommu: Adding device 3190000.i2c to group 6
[ 0.434187] iommu: Adding device 31b0000.i2c to group 7
[ 0.434518] iommu: Adding device 31c0000.i2c to group 8
[ 0.434856] iommu: Adding device c250000.i2c to group 9
[ 0.435191] iommu: Adding device 31e0000.i2c to group 10
[ 0.436706] iommu: Adding device 3210000.spi to group 11
[ 0.437046] iommu: Adding device c260000.spi to group 12
[ 0.437411] iommu: Adding device 3240000.spi to group 13
[ 0.438107] iommu: Adding device 3100000.serial to group 14
[ 0.438451] iommu: Adding device 3110000.serial to group 15
[ 0.438783] iommu: Adding device c280000.serial to group 16
[ 0.439116] iommu: Adding device 3130000.serial to group 17
[ 0.440499] iommu: Adding device 2490000.ether_qos to group 18
[ 0.440512] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.441415] iommu: Adding device b000000.rtcpu to group 19
[ 0.443645] iommu: Adding device 13e10000.host1x to group 20
[ 0.443958] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[ 0.444276] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[ 0.444581] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[ 0.444889] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[ 0.445230] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[ 0.445542] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[ 0.445844] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[ 0.446165] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[ 0.446636] iommu: Adding device 150c0000.nvcsi to group 29
[ 0.447280] iommu: Adding device 15700000.vi to group 30
[ 0.447641] iommu: Adding device 15600000.isp to group 31
[ 0.447859] iommu: Adding device 15200000.dc_common to group 32
[ 0.448479] iommu: Adding device 15210000.nvdisplay to group 33
[ 0.448836] iommu: Adding device 15340000.vic to group 34
[ 0.449058] iommu: Adding device 154c0000.nvenc to group 35
[ 0.449303] iommu: Adding device 15480000.nvdec to group 36
[ 0.449657] iommu: Adding device 15380000.nvjpg to group 37
[ 0.449871] iommu: Adding device 15500000.tsec to group 38
[ 0.450079] iommu: Adding device 15100000.tsecb to group 39
[ 0.450777] iommu: Adding device 15810000.se to group 40
[ 0.450995] iommu: Adding device 15820000.se to group 41
[ 0.451212] iommu: Adding device 15830000.se to group 42
[ 0.451436] iommu: Adding device 15840000.se to group 43
[ 0.452368] iommu: Adding device smmu_test to group 44
[ 0.453019] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c10000
[ 0.453030] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c20000
[ 0.453041] mc: mapped MMIO address: 0xffffff800b110000 -> 0x2c30000
[ 0.453051] mc: mapped MMIO address: 0xffffff800b130000 -> 0x2c40000
[ 0.453060] mc: mapped MMIO address: 0xffffff800b150000 -> 0x2c50000
[ 0.453068] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.453077] mc-err: mcerr ops are set to t18x
[ 0.453243] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.454402] iommu: Adding device 3530000.xhci to group 45
[ 0.454416] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.454861] iommu: Adding device 3550000.xudc to group 46
[ 0.454872] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.455585] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[ 0.455591] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.455596] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.456233] iommu: Adding device 17000000.gp10b to group 47
[ 0.457340] tegra-reset 5000000.clock: registered 193 resets.
[ 0.459566] iommu: Adding device d000000.bpmp to group 48
[ 0.459767] bpmp: ping status is 0
[ 0.459867] bpmp d000000.bpmp: firmware tag is 91572a54614f84d0fd0c270beec2c56f
[ 0.462444] bpmp d000000.bpmp: probe ok
[ 0.465630] iommu: Adding device 2600000.dma to group 49
[ 0.466518] gpio gpiochip0: gpio-line-names specifies 180 line names but there are 192 lines on the chip
[ 0.467015] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.467046] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.467076] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.467104] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.467134] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.467162] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.467191] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.467350] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.471005] gpio gpiochip1: gpio-line-names specifies 60 line names but there are 64 lines on the chip
[ 0.471124] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.471278] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.472969] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.472984] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.473356] iommu: Adding device sound to group 51
[ 0.473723] iommu: Adding device 3510000.hda to group 52
[ 0.481385] iommu: Adding device c1a0000.aon to group 53
[ 0.481837] vdd-ac-bat: 5000 mV
[ 0.483530] vdd-1v8-ap: 1800 mV
[ 0.502256] random: fast init done
[ 0.509736] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.512433] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.512623] SCSI subsystem initialized
[ 0.512798] libata version 3.00 loaded.
[ 0.512982] usbcore: registered new interface driver usbfs
[ 0.513013] usbcore: registered new interface driver hub
[ 0.513041] usbcore: registered new device driver usb
[ 0.515226] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.515256] pca953x 0-0074: failed reading register
[ 0.515306] pca953x: probe of 0-0074 failed with error -121
[ 0.515636] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.515664] pca953x 0-0077: failed reading register
[ 0.515700] pca953x: probe of 0-0077 failed with error -121
[ 0.525740] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.528851] vddio-ddr: at 1125 mV
[ 0.532710] avdd_dsi_csi: 1200 mV
[ 0.536696] vdd-1v8: 1800 mV
[ 0.540694] vdd-3v3-sys: 3300 mV
[ 0.541539] spmic-ldo0: at 1800 mV
[ 0.542244] spmic-ldo1: at 800 mV
[ 0.544697] vddio-3v3: 3300 mV
[ 0.545425] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.548697] vdd-rtc: at 800 mV
[ 0.549305] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.552698] spmic-ldo6: at 1500 mV
[ 0.556695] vdd-pex-1v00: 1000 mV
[ 0.557333] dvdd-pex: 1000 mV
[ 0.559729] GPIO line 253 (spmic_gpio_input) hogged as input
[ 0.559887] GPIO line 254 (spmic_gpio_input) hogged as input
[ 0.560046] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[ 0.560218] max77620 4-003c: max77620 probe successful
[ 0.560609] media: Linux media interface: v0.10
[ 0.560636] Linux video capture interface: v2.00
[ 0.564332] pps_core: LinuxPPS API ver. 1 registered
[ 0.564335] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.564353] PTP clock support registered
[ 0.564580] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.564817] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.564833] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.566252] trusty trusty: trusty version: Built: 08:57:14 Feb 19 2022
[ 0.566269] trusty trusty: selected api version: 3 (requested 3)
[ 0.567082] Advanced Linux Sound Architecture Driver Initialized.
[ 0.567414] Bluetooth: Core ver 2.22
[ 0.567443] NET: Registered protocol family 31
[ 0.567445] Bluetooth: HCI device and connection manager initialized
[ 0.567452] Bluetooth: HCI socket layer initialized
[ 0.567456] Bluetooth: L2CAP socket layer initialized
[ 0.567470] Bluetooth: SCO socket layer initialized
[ 0.568219] en-vdd-sd: 3300 mV
[ 0.568617] vdd-usb0-5v: 5000 mV
[ 0.568892] vdd-usb1-5v: 5000 mV
[ 0.569395] vdd-3v3: 3300 mV
[ 0.569642] en-vdd-vcm-2v8: 2800 mV
[ 0.569880] vdd-sys-bl: 3300 mV
[ 0.571900] camchar: rtcpu character device driver loaded
[ 0.572458] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.574229] extcon-gpio-states external-connection:extcon@1: Cable state:0, cable id:0
[ 0.575158] clocksource: Switched to clocksource arch_sys_counter
[ 0.597412] VFS: Disk quotas dquot_6.6.0
[ 0.597485] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.597732] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.598256] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.598365] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.598369] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.598376] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.598381] nvmap_page_pool_init: Total RAM pages: 2007823
[ 0.598384] nvmap_page_pool_init: nvmap page pool size: 250977 pages (980 MB)
[ 0.598429] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.598896] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.600961] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.606425] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.606645] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.607064] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.607159] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.607269] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.607369] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.607531] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.607731] la/ptsa driver initialized.
[ 0.607740] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[ 0.607743] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[ 0.608031] NET: Registered protocol family 2
[ 0.608093] IP idents hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.610552] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.610858] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.611483] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.611536] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.611651] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.612033] NET: Registered protocol family 1
[ 0.612394] RPC: Registered named UNIX socket transport module.
[ 0.612397] RPC: Registered udp transport module.
[ 0.612399] RPC: Registered tcp transport module.
[ 0.612402] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.612407] PCI: CLS 0 bytes, default 64
[ 0.612519] Trying to unpack rootfs image as initramfs...
[ 0.821933] Freeing initrd memory: 7068K
[ 0.837943] host1x 13e10000.host1x: initialized
[ 0.839454] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.841584] audit: initializing netlink subsys (disabled)
[ 0.841616] audit: type=2000 audit(0.732:1): initialized
[ 0.842011] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.848537] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.849476] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.849977] 9p: Installing v9fs 9p2000 file system support
[ 0.852082] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.852147] io scheduler noop registered
[ 0.852346] io scheduler cfq registered (default)
[ 0.855655] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.962374] iommu: Adding device aconnect@2a41000:adsp_audio to group 54
[ 0.997286] iommu: Adding device 2993000.adsp to group 55
[ 0.998380] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 1.000769] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.004751] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.005932] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 1.007011] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 1.008075] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.010603] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 1.011597] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 1.011935] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 1.012048] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.012157] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 1.012162] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 1.014422] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 1.015727] tsec 15500000.tsec: initialized
[ 1.016846] tsec 15100000.tsecb: initialized
[ 1.020419] nvdec 15480000.nvdec: initialized
[ 1.026559] falcon 15340000.vic: initialized
[ 1.027938] falcon 154c0000.nvenc: initialized
[ 1.029168] falcon 15380000.nvjpg: initialized
[ 1.031083] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 1.032588] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 1.034028] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 1.035487] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 1.036925] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 1.038370] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 1.039890] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 1.041292] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.044567] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.044574] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.044601] tegradccommon 15200000.dc_common: dma mapping done
[ 1.045418] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=391
[ 1.045591] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.045632] generic_infoframe_type: 0x87
[ 1.045709] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.045727] tegradc 15210000.nvdisplay: Display dc.ffffff800b3e0000 registered with id=0
[ 1.046103] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.046938] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.046952] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.047108] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.047142] tegra_cec 3960000.tegra_cec: probed
[ 1.051258] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 1.051262] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 1.051265] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 1.051434] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[ 1.051439] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[ 1.052191] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 1.057487] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[ 1.057491] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 1.062148] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.062799] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.062825] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.063241] kfuse 3830000.kfuse: initialized
[ 1.064567] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.067355] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.069736] console [ttyS0] disabled
[ 1.069770] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.088973] console [ttyS0] enabled
[ 1.090303] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.091165] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.091393] serial-tegra 3130000.serial: RX in PIO mode
[ 1.092132] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.093161] [drm] Initialized
[ 1.099924] brd: module loaded
[ 1.103211] loop: module loaded
[ 1.103258] tegra_profiler: version: 1.145, samples/io: 49/28
[ 1.103334] tegra_profiler: auth: init
[ 1.103662] nct1008_nct72 7-004c: starting parse dt
[ 1.103763] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.103768] nct1008_nct72 7-004c: success parsing dt
[ 1.103878] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.104221] THERMAL EST: found 3 subdevs
[ 1.104225] THERMAL EST num_resources: 0
[ 1.104228] [THERMAL EST subdev 0]
[ 1.104233] [THERMAL EST subdev 1]
[ 1.104237] [THERMAL EST subdev 2]
[ 1.104491] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.104494] THERMAL EST: thz register success.
[ 1.104583] THERMAL EST: end of probe, return err: 0
[ 1.105199] sd: No Scsi addr parsed to reserve index
[ 1.105221] hisi_sas: driver version v1.6
[ 1.108656] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.108664] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.109356] scsi host0: tegra_ahci
[ 1.109722] scsi host1: tegra_ahci
[ 1.109856] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.109858] ata2: DUMMY
[ 1.114955] libphy: Fixed MDIO Bus: probed
[ 1.115651] tun: Universal TUN/TAP device driver, 1.6
[ 1.115655] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.116328] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.116331] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.116364] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.116366] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.116396] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.116398] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.116431] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 1.116433] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 1.123283] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[ 1.125677] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.126159] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 1c f4 3c
[ 1.126188] Using phyrst_lpmode = 0 from DT
[ 1.126257] libphy: dwc_phy: probed
[ 1.126534] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.128403] PPP generic driver version 2.4.2
[ 1.128517] PPP BSD Compression module registered
[ 1.128520] PPP Deflate Compression module registered
[ 1.128533] PPP MPPE Compression module registered
[ 1.128537] NET: Registered protocol family 24
[ 1.128577] usbcore: registered new interface driver r8152
[ 1.128607] usbcore: registered new interface driver asix
[ 1.128640] usbcore: registered new interface driver ax88179_178a
[ 1.128666] usbcore: registered new interface driver cdc_ether
[ 1.128692] usbcore: registered new interface driver net1080
[ 1.128720] usbcore: registered new interface driver cdc_subset
[ 1.128744] usbcore: registered new interface driver zaurus
[ 1.128780] usbcore: registered new interface driver cdc_ncm
[ 1.128880] VFIO - User Level meta-driver version: 0.3
[ 1.129712] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.129723] ehci-pci: EHCI PCI platform driver
[ 1.129754] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.129761] ohci-pci: OHCI PCI platform driver
[ 1.129793] ohci-platform: OHCI generic platform driver
[ 1.132351] usbcore: registered new interface driver uas
[ 1.132389] usbcore: registered new interface driver usb-storage
[ 1.132452] usbcore: registered new interface driver usbserial
[ 1.134073] tegra-usb-cd usb_cd: otg phy is not available yet
[ 1.136543] mousedev: PS/2 mouse device common for all mice
[ 1.136587] usbcore: registered new interface driver xpad
[ 1.139260] nct1008_nct72 7-004c: LOC shutdown limit 107
[ 1.139603] nct1008_nct72 7-004c: EXT shutdown limit 107
[ 1.175495] nct1008_nct72 7-004c: initial LOC temp: 37000
[ 1.175809] nct1008_nct72 7-004c: initial EXT temp: 38500
[ 1.176430] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.176734] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.176922] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.264874] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.265947] Wake73 for irq=42
[ 1.267211] rtc rtc1: alarm rtc device
[ 1.267222] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.267235] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.267455] i2c /dev entries driver
[ 1.269964] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 1.274736] parse_throttle_dt_data: Num cap clks = 4
[ 1.274740] parse_throttle_dt_data: clk=mcpu type=1
[ 1.274743] parse_throttle_dt_data: clk=bcpu type=2
[ 1.274750] parse_throttle_dt_data: clk=gpu type=4
[ 1.274752] parse_throttle_dt_data: clk=emc type=3
[ 1.275741] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.276286] FAN: coudln't get the regulator
[ 1.280929] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 1.281852] device-mapper: uevent: version 1.0.3
[ 1.282157] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.282399] CPU EMC frequency mapping table: from device tree
[ 1.288422] cpufreq: platform driver Initialization: pass
[ 1.289023] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.289140] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.289924] sdhci: Secure Digital Host Controller Interface driver
[ 1.289926] sdhci: Copyright(c) Pierre Ossman
[ 1.289928] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.291139] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.292880] CMDQ: cmdq_platfm_init successful
[ 1.293901] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.294133] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.299269] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.299320] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.299919] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.301648] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 258
[ 1.335134] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.343136] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.355206] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.355249] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.380800] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.395790] mmc0: periodic cache flush enabled
[ 1.395796] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.396096] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 1.400218] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 1.400308] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 1.404411] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 1.408814] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[ 1.421530] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.441128] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 1.588525] mmc1: hw tuning done ...
[ 1.592437] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.844502] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.059154] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[ 2.059159] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.249274] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 2.251289] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 2.653758] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.058594] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.463352] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 3.465365] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 3.670513] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 3.670761] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 11.083137] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.089500] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 11.096122] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 11.101173] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.107784] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.113268] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.119011] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 11.124148] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 11.129400] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 11.138174] tegradc 15210000.nvdisplay: probed
[ 11.138432] Console: switching to colour frame buffer device 80x30
[ 11.138447] tegradc 15210000.nvdisplay: fb registered
[ 11.138586] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 11.139393] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 11.139485] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 11.139566] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 11.140784] Parent Clock set for DC plld2
[ 11.143603] edid invalid
[ 11.144304] tegradc 15210000.nvdisplay: hdmi: tmds rate:25200K prod-setting:prod_c_hdmi_0m_54m
[ 11.145533] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 21.323127] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.329484] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 21.336098] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 21.341148] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.347758] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.353242] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.358984] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 21.364120] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 21.369372] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.379336] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 21.379340] Extcon AUX1(HDMI) enable
[ 21.380633] tegra-se-nvhost 15810000.se: initialized
[ 21.381764] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 21.382419] tegra-se-nvhost 15820000.se: initialized
[ 21.383425] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 21.383988] tegra-se-nvhost 15830000.se: initialized
[ 21.384776] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 21.385317] tegra-se-nvhost 15840000.se: initialized
[ 21.386220] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 21.387004] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 21.387200] hidraw: raw HID events driver (C) Jiri Kosina
[ 21.388027] usbcore: registered new interface driver usbhid
[ 21.388029] usbhid: USB HID core driver
[ 21.390260] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 21.390289] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 21.396844] ina3221x: probe of 0-0042 failed with error -121
[ 21.397070] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 21.397097] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 21.403649] ina3221x: probe of 0-0043 failed with error -121
[ 21.406252] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 21.408414] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 21.408663] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 21.408780] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 21.408974] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 21.409668] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 21.409737] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 21.409817] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 21.409891] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 21.410016] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 21.410355] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 21.410358] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 21.410832] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=c73bbe92930645be44530c166eb578bfbb9499c3
[ 21.412574] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 21.413012] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 21.413399] register_ari_mca_banks: Registered MCA ROC:IOB
[ 21.413686] register_ari_mca_banks: Registered MCA ROC:CCE
[ 21.414382] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414385] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[ 21.414387] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 21.414450] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414452] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[ 21.414454] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 21.414504] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414506] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[ 21.414508] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 21.414554] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414557] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[ 21.414558] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 21.414606] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414608] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[ 21.414610] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 21.414659] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414664] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[ 21.414666] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 21.414711] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414716] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[ 21.414718] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 21.414764] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414768] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[ 21.414770] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 21.414818] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414822] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[ 21.414824] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 21.414868] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414871] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[ 21.414872] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 21.414917] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414922] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[ 21.414924] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 21.414969] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.414974] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[ 21.414975] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 21.415020] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.415025] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[ 21.415027] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 21.415072] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.415077] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[ 21.415079] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 21.415158] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[ 21.415163] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[ 21.415165] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 21.415226] **** A57 ECC: Enabled
[ 21.415228] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 21.415293] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 21.415739] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 21.416179] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 21.416300] denver_knobs_init:MTS_VERSION:55941701
[ 21.418405] nvpmodel: initialized successfully
[ 21.419316] trusty-virtio trusty:virtio: initializing
[ 21.419420] trusty_ipc virtio0: vring0: va(pa) ffffffc1e8f46000(0) qsz 32 notifyid 1
[ 21.419426] trusty_ipc virtio0: vring1: va(pa) ffffffc1e8f4c000(0) qsz 32 notifyid 2
[ 21.419491] trusty-virtio trusty:virtio: initializing done
[ 21.419584] trusty_ipc virtio0: is online
[ 21.421031] usbcore: registered new interface driver snd-usb-audio
[ 21.428279] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 21.428402] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 21.509966] OPE platform probe
[ 21.510033] OPE platform probe successful
[ 21.564022] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 21.564095] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 21.564164] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 21.564231] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 21.564297] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 21.564361] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 21.564427] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 21.564498] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 21.564562] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 21.564629] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 21.564696] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 21.564764] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 21.564830] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 21.564898] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 21.564963] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 21.565028] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 21.565095] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 21.565161] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 21.565229] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 21.565294] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 21.584161] u32 classifier
[ 21.584164] Actions configured
[ 21.584223] Initializing XFRM netlink socket
[ 21.584765] NET: Registered protocol family 10
[ 21.585338] NET: Registered protocol family 17
[ 21.585348] NET: Registered protocol family 15
[ 21.585405] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 21.585440] Bluetooth: RFCOMM socket layer initialized
[ 21.585449] Bluetooth: RFCOMM ver 1.11
[ 21.585452] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 21.585456] Bluetooth: HIDP socket layer initialized
[ 21.585470] 9pnet: Installing 9P2000 support
[ 21.585502] Key type dns_resolver registered
[ 21.585783] Registered cp15_barrier emulation handler
[ 21.585797] Registered setend emulation handler
[ 21.586635] registered taskstats version 1
[ 21.590320] isp 15600000.isp: initialized
[ 21.594862] nvcsi 150c0000.nvcsi: initialized
[ 21.596772] tegra-vi4 15700000.vi: using default number of vi channels,15
[ 21.600860] tegra-vi4 15700000.vi: initialized
[ 21.601719] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 21.601723] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 21.602448] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.604497] tegra-usb-cd usb_cd: otg phy is not available yet
[ 21.607898] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.608726] Wake83 for irq=51
[ 21.608798] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 21.608874] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 21.608949] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 21.609066] input: gpio-keys as /devices/gpio-keys/input/input2
[ 21.610735] tegra-usb-cd usb_cd: otg phy is not available yet
[ 21.614094] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.639800] tegra_rtc c2a0000.rtc: setting system clock to 2022-05-04 10:43:05 UTC (1651660985)
[ 21.641180] mmcblk mmc0:0001: Card claimed for testing.
[ 21.669868] bpmp: mounted debugfs mirror
[ 21.671065] bwmgr: missing cdev-type property
[ 21.677551] ALSA device list:
[ 21.677555] #0: tegra-hda at 0x3518000 irq 384
[ 21.677557] #1: tegra-snd-t186ref-mobile-rt565x
[ 21.679997] Freeing unused kernel memory: 8640K
[ 21.701587] Root device found: mmcblk0p1
[ 21.702669] Found dev node: /dev/mmcblk0p1
[ 21.721949] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 21.723748] Rootfs mounted over mmcblk0p1
[ 21.743246] Switching from initrd to actual rootfs
[ 21.849564] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 21.858451] cgroup: cgroup2: unknown option "nsdelegate"
[ 21.872189] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 21.872946] systemd[1]: Detected architecture arm64.
[ 21.892624] systemd[1]: Set hostname to <ubuntu>.
[ 21.981087] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 21.981096] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 22.095903] random: systemd: uninitialized urandom read (16 bytes read)
[ 22.097395] systemd[1]: Created slice System Slice.
[ 22.097524] random: systemd: uninitialized urandom read (16 bytes read)
[ 22.098135] systemd[1]: Created slice User and Session Slice.
[ 22.098161] random: systemd: uninitialized urandom read (16 bytes read)
[ 22.098256] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 22.099789] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 22.099954] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 22.159328] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 22.251633] tegra-usb-cd usb_cd: otg phy is not available yet
[ 22.256664] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.353770] systemd-journald[2285]: Received request to flush runtime journal from PID 1
[ 22.971783] random: crng init done
[ 22.975193] random: 7 urandom warning(s) missed due to ratelimiting
[ 23.919428] bcpu-throttle-alert cooling device registered.
[ 23.921232] tegra-usb-cd usb_cd: otg phy is not available yet
[ 23.924272] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 23.928208] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.930429] tegra-usb-cd usb_cd: otg phy is not available yet
[ 23.935843] mcpu-throttle-alert cooling device registered.
[ 23.938959] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.941629] tegra-usb-cd usb_cd: otg phy is not available yet
[ 23.970248] gpu-throttle-alert cooling device registered.
[ 23.973690] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.976535] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.035095] dhd_module_init in
[ 24.038518] found wifi platform device bcmdhd_wlan
[ 24.040733] wifi_platform_get_country_code_map: could not get country_code_map
[ 24.040740] wifi_plat_dev_drv_probe:platform country code map is not available
[ 24.040760] Power-up adapter 'DHD generic adapter'
[ 24.040768] wifi_platform_set_power = 1
[ 24.083496] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.099400] CPU1: shutdown
[ 24.102469] psci: CPU1 killed (polled 0 ms)
[ 24.164928] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 24.167893] net eth0: get_configure_l3v4_filter -->
[ 24.168502] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.187651] CPU2: shutdown
[ 24.190425] psci: CPU2 killed (polled 0 ms)
[ 24.247736] wifi_platform_bus_enumerate device present 1
[ 24.266496] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.270156] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.301808] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.306210] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.330378] wifi_platform_bus_enumerate device present 0
[ 24.333705] F1 signature read @0x18000000=0x17214354
[ 24.341279] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.345143] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.413482] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 24.428743] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 24.428988] wifi_platform_get_mac_addr
[ 24.467612] ids dhd_log_netlink_init
[ 24.491531] wl_event_handler :
[ 24.491537] tsk Enter, tsk = 0xffffffc1c9101a90
[ 24.494938] wl_create_event_handler(): thread:wl_event_handler:160c started
[ 24.503244] dhd_attach(): thread:dhd_watchdog_thread:1613 started
[ 24.504581] dhd_attach(): thread:dhd_dpc:1616 started
[ 24.509801] dhd_attach(): thread:dhd_rxf:1617 started
[ 24.509815] dhd_deferred_work_init: work queue initialized
[ 24.511772]
Dongle Host Driver, version 1.201.82 (r)
Compiled from
[ 24.527059] Register interface [wlan0] MAC: 48:b0:2d:1c:f4:3a
[ 24.527068] dhd_prot_ioctl : bus is down. we have nothing to do
[ 24.529220] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 60
[ 24.530356] zram: Added device: zram0
[ 24.531571] wifi_platform_set_power = 0
[ 24.533965] zram: Added device: zram1
[ 24.537255] zram: Added device: zram2
[ 24.538624] zram: Added device: zram3
[ 24.587186] zram0: detected capacity change from 0 to 1030017024
[ 24.700457] Adding 1005872k swap on /dev/zram0. Priority:5 extents:1 across:1005872k SS
[ 24.715706] zram1: detected capacity change from 0 to 1030017024
[ 24.745747] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.748131] Adding 1005872k swap on /dev/zram1. Priority:5 extents:1 across:1005872k SS
[ 24.749867] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.761640] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.765726] tegra-usb-cd usb_cd: otg phy is not available yet
[ 24.793163] zram2: detected capacity change from 0 to 1030017024
[ 24.832184] Adding 1005872k swap on /dev/zram2. Priority:5 extents:1 across:1005872k SS
[ 24.839808] zram3: detected capacity change from 0 to 1030017024
[ 24.862316] Adding 1005872k swap on /dev/zram3. Priority:5 extents:1 across:1005872k SS
[ 25.363831] Bridge firewalling registered
[ 25.409381] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 25.743390] tegradc 15210000.nvdisplay: unblank
[ 26.578336] Netfilter messages via NETLINK v0.30.
[ 26.584591] ctnetlink v0.93: registering with nfnetlink.
[ 27.974797] fuse init (API version 7.26)
[ 28.645401] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 29.777730] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 29.777965]
Compiled from
[ 29.777984] wl_android_wifi_on in
[ 29.777993] wifi_platform_set_power = 1
[ 30.153110] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 60
[ 30.153959] F1 signature read @0x18000000=0x17214354
[ 30.160842] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 30.161879] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 30.261125] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 30.325952] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 30.326335] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 30.326447] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 30.326451] Enabling wake69
[ 30.327707] wifi_platform_get_mac_addr
[ 30.330422] Firmware up: op_mode=0x0005, MAC=48:b0:2d:1c:f4:3a
[ 30.337540] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[ 30.337629] Skipping the clm download. len:0 memblk: (null)
[ 30.340894] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 30.347414] Firmware version = wl0: Jul 21 2020 16:35:45 version 7.35.349.94 (r726700 CY) FWID 01-aa356e32
[ 30.353895] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 30.448336] Bluetooth: HCI UART driver ver 2.3
[ 30.448348] Bluetooth: HCI UART protocol H4 registered
[ 30.448352] Bluetooth: HCI UART protocol BCSP registered
[ 30.448355] Bluetooth: HCI UART protocol LL registered
[ 30.448358] Bluetooth: HCI UART protocol ATH3K registered
[ 30.448967] Bluetooth: HCI UART protocol Intel registered
[ 30.449345] Bluetooth: HCI UART protocol Broadcom registered
[ 30.449351] Bluetooth: HCI UART protocol QCA registered
[ 30.547797] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[ 30.547806] P2P interface registered
[ 30.595606] WLC_E_IF: NO_IF set, event Ignored
[ 30.636748] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 30.958519] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 30.958544] Bluetooth: BNEP socket layer initialized
[ 31.563219] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 31.569675] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 31.583246] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 31.588403] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 31.595183] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 31.603927] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 31.609800] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 31.615029] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 31.622900] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 32.518319] [05-04 10:43:16.378] wl_cfg80211_connect: Connectting with 00:1f:fb:f1:2d:8a channel (1) ssid "Irancell-TD-GP2101PLUS-5834", len (27)
[ 32.605379] [05-04 10:43:16.465] wl_notify_connect_status: wl_bss_connect_done succeeded with 00:1f:fb:f1:2d:8a
[ 32.630353] wl_bss_connect_done :
[ 32.630367] Report connect result - connection succeeded
[ 32.660624] [05-04 10:43:16.520] wl_notify_connect_status: wl_bss_connect_done succeeded with 00:1f:fb:f1:2d:8a
[ 32.703947] [05-04 10:43:16.564] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M1 of 4way
[ 32.705057] [05-04 10:43:16.565] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M2 of 4way
[ 32.709254] [05-04 10:43:16.569] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [RX] : M3 of 4way
[ 32.709690] [05-04 10:43:16.569] dhd_dump_eapol_4way_message: ifidx: 0 ETHER_TYPE_802_1X [TX] : M4 of 4way
[ 32.727107] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 32.786748] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 32.786776] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 32.885944] ifidx:0 DHCP - REQUEST [TX]
[ 32.899845] ifidx:0 DHCP - ACK [RX]
[ 35.434279] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 35.434303] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 35.435391] dhd_ndo_add_ip: ndo ip addr add failed, ret = -23
[ 35.435407] dhd_inet6_work_handler: Adding host ip for NDO failed -23
[ 35.963041] tegradc 15210000.nvdisplay: unblank
[ 41.803298] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 41.809724] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 41.818395] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 41.828753] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 41.838715] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 41.846235] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 41.857371] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 41.862752] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 41.868184] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 52.043547] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 52.050429] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 52.057502] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 52.062751] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.069518] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 52.075076] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 52.080869] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 52.086050] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 52.091388] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 52.300338] spmic-ldo0: disabling
[ 52.302594] spmic-ldo1: disabling
[ 52.303634] en-vdd-sd: disabling
[ 52.303658] vdd-usb0-5v: disabling
[ 52.303684] vdd-usb1-5v: disabling
[ 52.303708] vdd-3v3: disabling
[ 52.303729] en-vdd-vcm-2v8: disabling
[ 52.303756] vdd-sys-bl: disabling
[ 62.331638] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 62.338498] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 62.345439] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 62.350582] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 62.357275] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 62.362804] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 62.368650] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 62.373966] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 62.379706] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 72.586281] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 72.592721] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 72.599427] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 72.604575] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 72.611272] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 72.616844] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 72.622664] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 72.627857] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 72.633190] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 82.830297] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 82.837127] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 82.849263] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 82.854407] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 82.861070] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 82.866591] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 82.872364] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 82.877538] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 82.882921] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 93.070240] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 93.077017] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 93.083978] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 93.089179] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 93.095914] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 93.101457] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 93.107243] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 93.112419] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 93.117704] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 103.309459] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 103.315920] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 103.333471] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 103.338661] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 103.345481] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 103.352921] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 103.360444] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 103.367329] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 103.374447] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 113.549139] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 113.555571] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 113.562367] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 113.567491] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 113.574150] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 113.579681] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 113.585541] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 113.590725] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 113.596029] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 123.788988] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 123.795444] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 123.804240] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 123.809398] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 123.816249] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 123.821833] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 123.827680] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 123.833156] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 123.838563] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 123.845709] tegradc 15210000.nvdisplay: hdmi: edid read failed
[ 123.851853] tegradc 15210000.nvdisplay: hdmi: using fallback edid
[ 123.852053] tegradc 15210000.nvdisplay: blank - powerdown
[ 123.916929] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 123.916935] Extcon AUX1(HDMI) disable
[ 123.935609] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 123.935741] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 123.936926] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 123.961848] tegradc 15210000.nvdisplay: unblank
[ 123.965908] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 123.966060] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 123.966180] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 123.973694] Parent Clock set for DC plld2
[ 123.977352] tegradc 15210000.nvdisplay: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_111m
[ 123.979030] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 134.028721] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 134.028725] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 134.028731] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 134.028735] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 134.028739] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 134.028743] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 134.028747] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 134.028750] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 134.028785] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 134.032459] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 134.032461] Extcon AUX1(HDMI) enable
[ 134.085567] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 134.085571] Extcon HDMI: HPD enabled
[ 134.085611] tegradc 15210000.nvdisplay: hdmi: plugged
[ 134.095801] tegradc 15210000.nvdisplay: blank - powerdown
[ 134.162609] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 134.162612] Extcon AUX1(HDMI) disable
[ 134.185889] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 134.186001] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 134.186935] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 134.187216] tegradc 15210000.nvdisplay: unblank
[ 134.188363] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 134.188492] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 134.188616] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 134.198978] Parent Clock set for DC plld2
[ 134.202406] tegradc 15210000.nvdisplay: hdmi: tmds rate:25180K prod-setting:prod_c_hdmi_0m_54m
[ 134.203707] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 144.268656] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 144.268670] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 144.268684] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 144.268696] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 144.268708] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 144.268718] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 144.268729] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 144.268739] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 144.268785] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 144.277325] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 144.277330] Extcon AUX1(HDMI) enable
[ 144.330581] tegradc 15210000.nvdisplay: unblank
[ 144.372729] tegradc 15210000.nvdisplay: blank - powerdown
[ 144.436848] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 144.436875] Extcon AUX1(HDMI) disable
[ 144.451343] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[ 144.451453] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 144.452402] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 144.453291] tegradc 15210000.nvdisplay: unblank
[ 144.454475] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 144.454613] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 144.454864] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[ 144.462201] Parent Clock set for DC plld2
[ 144.465964] tegradc 15210000.nvdisplay: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_111m
[ 144.467250] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[ 154.507960] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 154.507973] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 154.507987] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 154.507998] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 154.508009] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 154.508020] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 154.508030] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 154.508041] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 154.508087] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 154.516379] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 154.516386] Extcon AUX1(HDMI) enable
[ 154.569390] tegradc 15210000.nvdisplay: unblank
The line:
may be related to my problem?
