usb2.0 cannot be used normally when upgrade from jetpack3.0 to jetpack3.1 in TX1
Hello everyone, I have encountered a very difficult problem and I hope to get everyone’s help. I have such a board on my hand. When using tx1 jetpack3.0, both usb2.0 interfaces can be used normally. When upgrading to jetpack3.1, one of them can be used normally and one cannot be used. When using tx2, both jetpack3.0 and jetpack3.1 can use usb2.0 normally.
The normal usb interface has kernel print information when there is a device access. This unusable USB interface does not have any response when the mouse is inserted.
the message kernel print out:
[2018 03 29 10:29:03][2018 03 29_10:29:03]
[2018 03 29 10:29:07][0000.190] [TegraBoot] (version 00.00.2014.50-mobile-d44d4bf0)
[2018 03 29 10:29:07][0000.196] Processing in cold boot mode Bootloader 2
[2018 03 29 10:29:07][0000.200] A02 Bootrom Patch rev = 63
[2018 03 29 10:29:07][0000.204] Power-up reason: usb hotplug
[2018 03 29 10:29:07][0000.207] No Battery Present
[2018 03 29 10:29:07][0000.210] RamCode = 0
[2018 03 29 10:29:07][0000.212] Platform has Ddr4 type ram
[2018 03 29 10:29:07][0000.216] max77620 disabling SD1 Remote Sense
[2018 03 29 10:29:07][0000.220] Setting Ddr voltage to 1125mv
[2018 03 29 10:29:07][0000.224] Serial Number of Pmic Max77663: 0xe0bb5
[2018 03 29 10:29:07][0000.231] Entering ramdump check
[2018 03 29 10:29:07][0000.234] Get RamDumpCarveOut = 0xff23f000
[2018 03 29 10:29:08][0000.238] RamDumpCarveOut=0xff23f000, RamDumperFlag=0xffffffff
[2018 03 29 10:29:08][0000.244] Last reboot was clean, booting normally!
[2018 03 29 10:29:08][0000.249] Sdram initialization is successful
[2018 03 29 10:29:08][0000.253] SecureOs Carveout Base=0xff800000 Size=0x00800000
[2018 03 29 10:29:08][0000.258] GSC1 Carveout Base=0xff700000 Size=0x00100000
[2018 03 29 10:29:08][0000.263] GSC2 Carveout Base=0xff600000 Size=0x00100000
[2018 03 29 10:29:08][0000.269] GSC3 Carveout Base=0xff500000 Size=0x00100000
[2018 03 29 10:29:08][0000.274] GSC4 Carveout Base=0xff400000 Size=0x00100000
[2018 03 29 10:29:08][0000.279] GSC5 Carveout Base=0xff300000 Size=0x00100000
[2018 03 29 10:29:08][0000.284] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[2018 03 29 10:29:08][0000.289] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[2018 03 29 10:29:08][0000.305] RamDump Carveout Base=0xff23f000 Size=0x00080000
[2018 03 29 10:29:08][0000.310] Platform-DebugCarveout: 0
[2018 03 29 10:29:08][0000.313] Nck Carveout Base=0xff03f000 Size=0x00200000
[2018 03 29 10:29:08][0000.318] Non secure mode, and RB not enabled.
[2018 03 29 10:29:08][0000.368] Using GPT Primary to query partitions
[2018 03 29 10:29:08][0000.374] Loading Tboot-CPU binary
[2018 03 29 10:29:08][0000.423] Verifying bootloader in OdmNonSecureSBK mode
[2018 03 29 10:29:08][0000.433] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[2018 03 29 10:29:08][0000.440] Bootloader downloaded successfully.
[2018 03 29 10:29:08][0000.444] Downloaded Tboot-CPU binary to 0xa0000258
[2018 03 29 10:29:08][0000.449] MAX77620_GPIO1 Configured.
[2018 03 29 10:29:08][0000.452] MAX77620_GPIO5 Configured.
[2018 03 29 10:29:08][0000.456] CPU power rail is up
[2018 03 29 10:29:08][0000.459] CPU clock enabled
[2018 03 29 10:29:08][0000.462] Performing RAM repair
[2018 03 29 10:29:08][0000.465] Updating A64 Warmreset Address to 0xa00002e9
[2018 03 29 10:29:08][0000.494] Bootloader DTB Load Address: 0x83000000
[2018 03 29 10:29:08][0000.522] Kernel DTB Load Address: 0x83100000
[2018 03 29 10:29:08][0000.527] Loading cboot binary
[2018 03 29 10:29:08][0000.620] Verifying bootloader in OdmNonSecureSBK mode
[2018 03 29 10:29:08][0000.659] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[2018 03 29 10:29:08][0000.666] Bootloader downloaded successfully.
[2018 03 29 10:29:08][0000.670] GPT: Partition NOT found !
[2018 03 29 10:29:08][0000.673] Find Partition via GPT Failed
[2018 03 29 10:29:08][0000.677] Find Partition via PT Failed
[2018 03 29 10:29:08][0000.681] function NvTbootGetBinaryOffsets: 0x1 error
[2018 03 29 10:29:08][0000.685] Error in NvTbootLoadBinary: 0x1 !
[2018 03 29 10:29:08][0000.689] Next binary entry address: 0x92c00258
[2018 03 29 10:29:08][0000.694] BoardId: 2180
[2018 03 29 10:29:08][0000.699] dram memory type is 3
[2018 03 29 10:29:08][0000.703] WB0 init successful
[2018 03 29 10:29:08][0000.729] Bpmp FW successfully loaded
[2018 03 29 10:29:08][0000.732] Set NvDecSticky Bits
[2018 03 29 10:29:08][0000.735] GSC1 address : ff700000
[2018 03 29 10:29:08][0000.739] GSC2 address ff63fffc value c0edbbcc
[2018 03 29 10:29:08][0000.744] GSC2 address : ff600000
[2018 03 29 10:29:08][0000.747] GSC3 address : ff500000
[2018 03 29 10:29:08][0000.751] GSC4 address : ff400000
[2018 03 29 10:29:08][0000.755] GSC5 address : ff300000
[2018 03 29 10:29:08][0000.758] GSC MC Settings done
[2018 03 29 10:29:08][0000.762] TOS plaintext Image length 28752
[2018 03 29 10:29:08][0000.765] Monitor size 28752
[2018 03 29 10:29:08][0000.768] OS size 0
[2018 03 29 10:29:08][0000.772] *** Secure OS image signature not verified ***
[2018 03 29 10:29:08][0000.777] Loading and Validation of Secure OS Successful
[2018 03 29 10:29:08][0000.782] NvTbootPackSdramParams: start.
[2018 03 29 10:29:08][0000.787] NvTbootPackSdramParams: done.
[2018 03 29 10:29:08][0000.790] Tegraboot started after 170476 us
[2018 03 29 10:29:08][0000.794] Basic modules init took 311702 us
[2018 03 29 10:29:08][0000.798] Sec Bootdevice Read Time = 216 ms, Read Size = 9476 KB
[2018 03 29 10:29:08][0000.804] Sec Bootdevice Write Time = -1940251271 ms, Write Size = -68719477 KB
[2018 03 29 10:29:08][0000.812] Next stage binary read took 23840 us
[2018 03 29 10:29:08][0000.816] Carveout took 207243 us
[2018 03 29 10:29:08][0000.819] CPU initialization took 96693 us
[2018 03 29 10:29:08][0000.823] Total time taken by TegraBoot 639478 us
[2018 03 29 10:29:08][0000.828] Starting CPU & Halting co-processor
[2018 03 29 10:29:08]64NOTICE: BL31: v1.2(release):cc5fd7c
[2018 03 29 10:29:08]NOTICE: BL31: Built : 00:37:02, Jul 20 2017
[2018 03 29 10:29:08]NOTICE: Trusty image missing.
[2018 03 29 10:29:08]ERROR: Error initializing runtime service trusty_fast
[2018 03 29 10:29:08][0000.968] RamCode = 0
[2018 03 29 10:29:08][0000.989] LPDDR4 Training: Read DT: Number of tables = 10
[2018 03 29 10:29:08][0000.994] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[2018 03 29 10:29:08][0000.999] EMC Training Skipped
[2018 03 29 10:29:08][0001.002] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[2018 03 29 10:29:08][0001.007] EMC Training Skipped
[2018 03 29 10:29:08][0001.010] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[2018 03 29 10:29:08][0001.016] EMC Training Skipped
[2018 03 29 10:29:08][0001.018] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[2018 03 29 10:29:08][0001.024] EMC Training Skipped
[2018 03 29 10:29:08][0001.026] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[2018 03 29 10:29:08][0001.033] EMC Training Successful
[2018 03 29 10:29:08][0001.036] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[2018 03 29 10:29:08][0001.041] EMC Training Successful
[2018 03 29 10:29:08][0001.044] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[2018 03 29 10:29:08][0001.056] EMC Training Successful
[2018 03 29 10:29:08][0001.059] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[2018 03 29 10:29:08][0001.082] EMC Training Successful
[2018 03 29 10:29:08][0001.085] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[2018 03 29 10:29:08][0001.106] EMC Training Successful
[2018 03 29 10:29:08][0001.109] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[2018 03 29 10:29:08][0001.129] EMC Training Successful
[2018 03 29 10:29:08][0001.132] Switching to 800000 KHz Success
[2018 03 29 10:29:08][0001.142] RamCode = 0
[2018 03 29 10:29:08][0001.146] DT Write: emc-table@40800 succeeded
[2018 03 29 10:29:08][0001.152] DT Write: emc-table@68000 succeeded
[2018 03 29 10:29:08][0001.158] DT Write: emc-table@102000 succeeded
[2018 03 29 10:29:08][0001.164] DT Write: emc-table@204000 succeeded
[2018 03 29 10:29:08][0001.170] DT Write: emc-table@408000 succeeded
[2018 03 29 10:29:08][0001.176] DT Write: emc-table@665600 succeeded
[2018 03 29 10:29:08][0001.182] DT Write: emc-table@800000 succeeded
[2018 03 29 10:29:08][0001.188] DT Write: emc-table@1065600 succeeded
[2018 03 29 10:29:08][0001.194] DT Write: emc-table@1331200 succeeded
[2018 03 29 10:29:08][0001.200] DT Write: emc-table@1600000 succeeded
[2018 03 29 10:29:08][0001.205] LPDDR4 Training: Write DT: Number of tables = 10
[2018 03 29 10:29:08][0001.241]
[2018 03 29 10:29:08][0001.242] Debug Init done
[2018 03 29 10:29:09][0001.244] Marked DTB cacheable
[2018 03 29 10:29:09][0001.247] Bootloader DTB loaded at 0x83000000
[2018 03 29 10:29:09][0001.252] Marked DTB cacheable
[2018 03 29 10:29:09][0001.255] Kernel DTB loaded at 0x83100000
[2018 03 29 10:29:09][0001.259] DeviceTree Init done
[2018 03 29 10:29:09][0001.278] Pinmux applied successfully
[2018 03 29 10:29:09][0001.284] gicd_base: 0x50041000
[2018 03 29 10:29:09][0001.289] gicc_base: 0x50042000
[2018 03 29 10:29:09][0001.292] Interrupts Init done
[2018 03 29 10:29:09][0001.297] Using base:0x60005008 & irq:33 for tick-timer
[2018 03 29 10:29:09][0001.302] Using base:0x60005000 for delay-timer
[2018 03 29 10:29:09][0001.307] platform_init_timer: DONE
[2018 03 29 10:29:09][0001.310] Timer(tick) Init done
[2018 03 29 10:29:09][0001.315] osc freq = 38400 khz
[2018 03 29 10:29:09][0001.321]
[2018 03 29 10:29:09][0001.322] welcome to cboot
[2018 03 29 10:29:09][0001.324]
[2018 03 29 10:29:09][0001.326] Cboot Version: 00.00.2014.50-t210-fadd1be5
[2018 03 29 10:29:09][0001.330] calling constructors
[2018 03 29 10:29:09][0001.333] initializing heap
[2018 03 29 10:29:09][0001.336] initializing threads
[2018 03 29 10:29:09][0001.339] initializing timers
[2018 03 29 10:29:09][0001.342] creating bootstrap completion thread
[2018 03 29 10:29:09][0001.346] top of bootstrap2()
[2018 03 29 10:29:09][0001.349] CPU: ARM Cortex A57
[2018 03 29 10:29:09][0001.352] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[2018 03 29 10:29:09][0001.357] initializing platform
[2018 03 29 10:29:09][0001.403] config for ddr50 mode completed
[2018 03 29 10:29:09][0001.407] sdmmc bdev is already initialized
[2018 03 29 10:29:09][0001.411] Enable APE clock
[2018 03 29 10:29:09][0001.414] Un-powergate APE partition
[2018 03 29 10:29:09][0001.417] of_register: registering tegra_udc to of_hal
[2018 03 29 10:29:09][0001.422] of_register: registering inv20628-driver to of_hal
[2018 03 29 10:29:09][0001.428] of_register: registering ads1015-driver to of_hal
[2018 03 29 10:29:09][0001.434] of_register: registering lp8557-bl-driver to of_hal
[2018 03 29 10:29:09][0001.439] of_register: registering bq2419x_charger to of_hal
[2018 03 29 10:29:09][0001.445] of_register: registering cpc to of_hal
[2018 03 29 10:29:09][0001.450] of_register: registering bq27441_fuel_gauge to of_hal
[2018 03 29 10:29:09][0001.469] gpio framework initialized
[2018 03 29 10:29:09][0001.472] of_register: registering tca9539_gpio to of_hal
[2018 03 29 10:29:09][0001.478] of_register: registering tca9539_gpio to of_hal
[2018 03 29 10:29:09][0001.483] of_register: registering i2c_bus_driver to of_hal
[2018 03 29 10:29:09][0001.489] of_register: registering i2c_bus_driver to of_hal
[2018 03 29 10:29:09][0001.494] of_register: registering i2c_bus_driver to of_hal
[2018 03 29 10:29:09][0001.500] pmic framework initialized
[2018 03 29 10:29:09][0001.503] of_register: registering max77620_pmic to of_hal
[2018 03 29 10:29:09][0001.509] regulator framework initialized
[2018 03 29 10:29:09][0001.513] of_register: registering tegra_xhci to of_hal
[2018 03 29 10:29:09][0001.518] initializing target
[2018 03 29 10:29:09][0001.527] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[2018 03 29 10:29:09][0001.539] fixed regulator driver initialized
[2018 03 29 10:29:09][0001.610] initializing OF layer
[2018 03 29 10:29:09][0001.613] NCK carveout not present
[2018 03 29 10:29:09][0001.616] Skipping dts_overrides
[2018 03 29 10:29:09][0001.620] of_children_init: Ops found for compatible string nvidia,tegra210-xhci
[2018 03 29 10:29:09][0001.629] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[2018 03 29 10:29:09][0001.659] I2C Bus Init done
[2018 03 29 10:29:09][0001.662] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[2018 03 29 10:29:09][0001.677] I2C Bus Init done
[2018 03 29 10:29:09][0001.680] of_children_init: Ops found for compatible string ti,tca9539
[2018 03 29 10:29:09][0001.694] tca9539_init: i2c bus: 2, slave addr: 0xe8
[2018 03 29 10:29:09][0001.699] gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[2018 03 29 10:29:09][0001.706] of_children_init: Ops found for compatible string ti,tca9539
[2018 03 29 10:29:09][0001.720] tca9539_init: i2c bus: 2, slave addr: 0xee
[2018 03 29 10:29:09][0001.725] gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[2018 03 29 10:29:09][0001.732] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[2018 03 29 10:29:09][0001.747] I2C Bus Init done
[2018 03 29 10:29:09][0001.749] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[2018 03 29 10:29:09][0001.764] I2C Bus Init done
[2018 03 29 10:29:09][0001.767] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[2018 03 29 10:29:09][0001.782] I2C Bus Init done
[2018 03 29 10:29:09][0001.785] of_children_init: Ops found for compatible string maxim,max77620
[2018 03 29 10:29:09][0001.800] max77620_init using irq 118
[2018 03 29 10:29:09][0001.805] register ‘maxim,max77620’ pmic
[2018 03 29 10:29:09][0001.810] gpio_driver_register: register ‘max77620-gpio’ driver
[2018 03 29 10:29:09][0001.816] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[2018 03 29 10:29:09][0001.831] I2C Bus Init done
[2018 03 29 10:29:09][0001.836] NCK carveout not present
[2018 03 29 10:29:09][0001.839] shim_invoke: No NCT, Calling dts updates
[2018 03 29 10:29:09][0001.860] Find /i2c@7000c000’s alias i2c0
[2018 03 29 10:29:09][0001.864] get eeprom at 1-a2, size 256, type 0
[2018 03 29 10:29:09][0001.869] get eeprom at 1-ae, size 256, type 0
[2018 03 29 10:29:09][0001.884] Find /i2c@7000c400’s alias i2c1
[2018 03 29 10:29:09][0001.888] get eeprom at 2-a0, size 256, type 0
[2018 03 29 10:29:09][0001.903] Find /i2c@7000c500’s alias i2c2
[2018 03 29 10:29:09][0001.907] get eeprom at 3-a0, size 256, type 0
[2018 03 29 10:29:09][0001.912] get eeprom at 3-ae, size 256, type 0
[2018 03 29 10:29:09][0001.923] Find /host1x/i2c@546c0000’s alias i2c6
[2018 03 29 10:29:09][0001.928] get eeprom at 7-a8, size 256, type 0
[2018 03 29 10:29:09][0001.932] pm_ids_update: Updating 1,a2, size 256, type 0
[2018 03 29 10:29:09][0001.937] I2C slave not started
[2018 03 29 10:29:09][0001.940] I2C write failed
[2018 03 29 10:29:09][0001.943] Writing offset failed
[2018 03 29 10:29:09][0001.946] eeprom_init: EEPROM read failed
[2018 03 29 10:29:09][0001.950] pm_ids_update: eeprom init failed
[2018 03 29 10:29:09][0001.954] pm_ids_update: Updating 1,ae, size 256, type 0
[2018 03 29 10:29:09][0001.959] I2C slave not started
[2018 03 29 10:29:09][0001.962] I2C write failed
[2018 03 29 10:29:09][0001.965] Writing offset failed
[2018 03 29 10:29:09][0001.968] eeprom_init: EEPROM read failed
[2018 03 29 10:29:09][0001.972] pm_ids_update: eeprom init failed
[2018 03 29 10:29:09][0001.976] pm_ids_update: Updating 2,a0, size 256, type 0
[2018 03 29 10:29:09][0001.988] pm_ids_update: The pm board id is 65535-65535-X
[2018 03 29 10:29:09][0001.997] Adding plugin-manager/ids/65535-65535-X=/i2c@7000c400:module@0x50
[2018 03 29 10:29:09][0002.007] pm_ids_update: pm id update successful
[2018 03 29 10:29:09][0002.011] pm_ids_update: Updating 3,a0, size 256, type 0
[2018 03 29 10:29:09][0002.041] pm_ids_update: The pm board id is 2180-1000-400
[2018 03 29 10:29:09][0002.049] Adding plugin-manager/ids/2180-1000-400=/i2c@7000c500:module@0x50
[2018 03 29 10:29:09][0002.058] pm_ids_update: pm id update successful
[2018 03 29 10:29:09][0002.063] pm_ids_update: Updating 3,ae, size 256, type 0
[2018 03 29 10:29:09][0002.068] I2C slave not started
[2018 03 29 10:29:09][0002.071] I2C write failed
[2018 03 29 10:29:09][0002.074] Writing offset failed
[2018 03 29 10:29:09][0002.077] eeprom_init: EEPROM read failed
[2018 03 29 10:29:09][0002.081] pm_ids_update: eeprom init failed
[2018 03 29 10:29:09][0002.085] pm_ids_update: Updating 7,a8, size 256, type 0
[2018 03 29 10:29:09][0002.092] I2C slave not started
[2018 03 29 10:29:09][0002.095] I2C write failed
[2018 03 29 10:29:09][0002.098] Writing offset failed
[2018 03 29 10:29:09][0002.101] eeprom_init: EEPROM read failed
[2018 03 29 10:29:09][0002.105] pm_ids_update: eeprom init failed
[2018 03 29 10:29:09][0002.139] updating /chosen/nvidia,wifi-mac node 00:04:4b:66:59:b7
[2018 03 29 10:29:09][0002.148] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:66:59:b8
[2018 03 29 10:29:09][0002.157] updating /chosen/nvidia,ethernet-mac node 00:04:4b:66:59:b9
[2018 03 29 10:29:09][0002.164] Plugin Manager: Parse ODM data 0x00084000
[2018 03 29 10:29:09][0002.199] Find /i2c@7000c000’s alias i2c0
[2018 03 29 10:29:09][0002.203] get eeprom at 1-a2, size 256, type 0
[2018 03 29 10:29:09][0002.207] get eeprom at 1-ae, size 256, type 0
[2018 03 29 10:29:09][0002.223] Find /i2c@7000c400’s alias i2c1
[2018 03 29 10:29:09][0002.226] get eeprom at 2-a0, size 256, type 0
[2018 03 29 10:29:09][0002.242] Find /i2c@7000c500’s alias i2c2
[2018 03 29 10:29:10][0002.246] get eeprom at 3-a0, size 256, type 0
[2018 03 29 10:29:10][0002.250] get eeprom at 3-ae, size 256, type 0
[2018 03 29 10:29:10][0002.262] Find /host1x/i2c@546c0000’s alias i2c6
[2018 03 29 10:29:10][0002.266] get eeprom at 7-a8, size 256, type 0
[2018 03 29 10:29:10][0002.271] pm_ids_update: Updating 1,a2, size 256, type 0
[2018 03 29 10:29:10][0002.276] I2C slave not started
[2018 03 29 10:29:10][0002.279] I2C write failed
[2018 03 29 10:29:10][0002.282] Writing offset failed
[2018 03 29 10:29:10][0002.285] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.289] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.293] pm_ids_update: Updating 1,ae, size 256, type 0
[2018 03 29 10:29:10][0002.298] I2C slave not started
[2018 03 29 10:29:10][0002.301] I2C write failed
[2018 03 29 10:29:10][0002.304] Writing offset failed
[2018 03 29 10:29:10][0002.307] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.311] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.315] pm_ids_update: Updating 2,a0, size 256, type 0
[2018 03 29 10:29:10][0002.326] pm_ids_update: The pm board id is 65535-65535-X
[2018 03 29 10:29:10][0002.334] Adding plugin-manager/ids/65535-65535-X=/i2c@7000c400:module@0x50
[2018 03 29 10:29:10][0002.341] pm_ids_update: pm id update successful
[2018 03 29 10:29:10][0002.346] pm_ids_update: Updating 3,a0, size 256, type 0
[2018 03 29 10:29:10][0002.376] pm_ids_update: The pm board id is 2180-1000-400
[2018 03 29 10:29:10][0002.383] Adding plugin-manager/ids/2180-1000-400=/i2c@7000c500:module@0x50
[2018 03 29 10:29:10][0002.390] pm_ids_update: pm id update successful
[2018 03 29 10:29:10][0002.395] pm_ids_update: Updating 3,ae, size 256, type 0
[2018 03 29 10:29:10][0002.400] I2C slave not started
[2018 03 29 10:29:10][0002.403] I2C write failed
[2018 03 29 10:29:10][0002.406] Writing offset failed
[2018 03 29 10:29:10][0002.409] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.413] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.417] pm_ids_update: Updating 7,a8, size 256, type 0
[2018 03 29 10:29:10][0002.425] I2C slave not started
[2018 03 29 10:29:10][0002.428] I2C write failed
[2018 03 29 10:29:10][0002.430] Writing offset failed
[2018 03 29 10:29:10][0002.433] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.437] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.471] Chip UID is 00000001642897c00400000015ff0240
[2018 03 29 10:29:10][0002.478] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.mode[2018 03 29 10:29:10]m=none androidboot.serialno=032361612352804002ff androidboot.security=non-secure
[2018 03 29 10:29:10][0002.502] Add serial number:032361612352804002ff as DT property
[2018 03 29 10:29:10][0002.510] calling apps_init()
[2018 03 29 10:29:10][0002.515] Found 18 GPT partitions in “sdmmc3_user”
[2018 03 29 10:29:10][0002.519] Proceeding to Cold Boot
[2018 03 29 10:29:10][0002.522] starting app android_boot_app
[2018 03 29 10:29:10][0002.526] Device state: unlocked
[2018 03 29 10:29:10][0002.529] display console init
[2018 03 29 10:29:10][0002.535] skip-display-init in bootloader
[2018 03 29 10:29:10][0002.539] set_instance_and_out_type: invalid out_type
[2018 03 29 10:29:10][0002.544] display_console_init: No display init
[2018 03 29 10:29:10][0002.554] Gpio keyboard init success
[2018 03 29 10:29:10][0002.558] bct_init bctinit
[2018 03 29 10:29:10][0002.560] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[2018 03 29 10:29:10][0002.568] BMP partition read failed!
[2018 03 29 10:29:10][0002.57[0002.580] DT entry for leds-pwm not found
[2018 03 29 10:29:10]1] blob_init: blob-partition BMP header read failed
[2018 03 29 10:29:10][0002.589] load_bmp_blob: BMP blob initialization failed
[2018 03 29 10:29:10][0002.594] Could not load/initialize BMP blob…ignoring
[2018 03 29 10:29:10][0002.599] bl_battery_charging: connected to external power supply
[2018 03 29 10:29:10][0002.610] fastboot: usb cable is not connected
[2018 03 29 10:29:10][0002.614] display_console_ioctl: No display init
[2018 03 29 10:29:10][0002.619] switch_backlight failed
[2018 03 29 10:29:10][0002.622] bct_init bctinit
[2018 03 29 10:29:10][0002.625] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[2018 03 29 10:29:10][0002.632] MSC Partition not found
[2018 03 29 10:29:10][0002.636] bct_init bctinit
[2018 03 29 10:29:10][0002.638] bct_init bctinit
[2018 03 29 10:29:10][0002.642] blob_init: USP partition does not have valid Blob
[2018 03 29 10:29:10][0002.647] Loading android kernel
[2018 03 29 10:29:10][0002.651] Default: NOT skip verified boot.
[2018 03 29 10:29:10][0002.655] Verified boot state = Orange
[2018 03 29 10:29:10][0002.662] display_console_clear: No display init
[2018 03 29 10:29:10][0002.666] kernel load address: 0x80080000, size: 503741 bytes
[2018 03 29 10:29:10][0002.672] ramdisk load address: 0x84100000, size: 0 bytes
[2018 03 29 10:29:10][0002.677] load kernel from storage
[2018 03 29 10:29:10][0002.682] decompressor handler not found
[2018 03 29 10:29:10][0002.692] Successfully loaded kernel and ramdisk images
[2018 03 29 10:29:10][0002.700] bct_init bctinit
[2018 03 29 10:29:10][0002.702] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[2018 03 29 10:29:10][0002.710] BMP partition read failed!
[2018 03 29 10:29:10][0002.713] blob_init: blob-partition BMP header read failed
[2018 03 29 10:29:10][0002.719] load_bmp_blob: BMP blob initialization failed
[2018 03 29 10:29:10][0002.724] bmp blob is not loaded and initialized
[2018 03 29 10:29:10][0002.729] Failed to display boot-logo
[2018 03 29 10:29:10][0002.732] NCK carveout not present
[2018 03 29 10:29:10][0002.736] Skipping dts_overrides
[2018 03 29 10:29:10][0002.739] NCK carveout not present
[2018 03 29 10:29:10][0002.742] shim_invoke: No NCT, Calling dts updates
[2018 03 29 10:29:10][0002.764] Find /i2c@7000c000’s alias i2c0
[2018 03 29 10:29:10][0002.768] get eeprom at 1-a2, size 256, type 0
[2018 03 29 10:29:10][0002.772] get eeprom at 1-ae, size 256, type 0
[2018 03 29 10:29:10][0002.788] Find /i2c@7000c400’s alias i2c1
[2018 03 29 10:29:10][0002.792] get eeprom at 2-a0, size 256, type 0
[2018 03 29 10:29:10][0002.808] Find /i2c@7000c500’s alias i2c2
[2018 03 29 10:29:10][0002.812] get eeprom at 3-a0, size 256, type 0
[2018 03 29 10:29:10][0002.816] get eeprom at 3-ae, size 256, type 0
[2018 03 29 10:29:10][0002.829] Find /host1x/i2c@546c0000’s alias i2c6
[2018 03 29 10:29:10][0002.833] get eeprom at 7-a8, size 256, type 0
[2018 03 29 10:29:10][0002.837] pm_ids_update: Updating 1,a2, size 256, type 0
[2018 03 29 10:29:10][0002.843] I2C slave not started
[2018 03 29 10:29:10][0002.846] I2C write failed
[2018 03 29 10:29:10][0002.848] Writing offset failed
[2018 03 29 10:29:10][0002.851] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.855] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.859] pm_ids_update: Updating 1,ae, size 256, type 0
[2018 03 29 10:29:10][0002.865] I2C slave not started
[2018 03 29 10:29:10][0002.868] I2C write failed
[2018 03 29 10:29:10][0002.870] Writing offset failed
[2018 03 29 10:29:10][0002.873] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.877] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.881] pm_ids_update: Updating 2,a0, size 256, type 0
[2018 03 29 10:29:10][0002.893] pm_ids_update: The pm board id is 65535-65535-X
[2018 03 29 10:29:10][0002.902] Adding plugin-manager/ids/65535-65535-X=/i2c@7000c400:module@0x50
[2018 03 29 10:29:10][0002.912] pm_ids_update: pm id update successful
[2018 03 29 10:29:10][0002.917] pm_ids_update: Updating 3,a0, size 256, type 0
[2018 03 29 10:29:10][0002.947] pm_ids_update: The pm board id is 2180-1000-400
[2018 03 29 10:29:10][0002.955] Adding plugin-manager/ids/2180-1000-400=/i2c@7000c500:module@0x50
[2018 03 29 10:29:10][0002.964] pm_ids_update: pm id update successful
[2018 03 29 10:29:10][0002.968] pm_ids_update: Updating 3,ae, size 256, type 0
[2018 03 29 10:29:10][0002.973] I2C slave not started
[2018 03 29 10:29:10][0002.976] I2C write failed
[2018 03 29 10:29:10][0002.979] Writing offset failed
[2018 03 29 10:29:10][0002.982] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0002.986] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0002.990] pm_ids_update: Updating 7,a8, size 256, type 0
[2018 03 29 10:29:10][0002.998] I2C slave not started
[2018 03 29 10:29:10][0003.001] I2C write failed
[2018 03 29 10:29:10][0003.003] Writing offset failed
[2018 03 29 10:29:10][0003.006] eeprom_init: EEPROM read failed
[2018 03 29 10:29:10][0003.010] pm_ids_update: eeprom init failed
[2018 03 29 10:29:10][0003.044] updating /chosen/nvidia,wifi-mac node 00:04:4b:66:59:b7
[2018 03 29 10:29:10][0003.053] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:66:59:b8
[2018 03 29 10:29:10][0003.063] updating /chosen/nvidia,ethernet-mac node 00:04:4b:66:59:b9
[2018 03 29 10:29:10][0003.069] Plugin Manager: Parse ODM data 0x00084000
[2018 03 29 10:29:10][0003.091] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.mode[2018 03 29 10:29:10]m=none androidboot.serialno=032361612352804002ff androidboot.security=non-secure
[2018 03 29 10:29:10][0003.114] Add serial number:032361612352804002ff as DT property
[2018 03 29 10:29:10][0003.123] Updated bpmp info to DTB
[2018 03 29 10:29:10][0003.129] Updated initrd info to DTB
[2018 03 29 10:29:10][0003.133] “proc-board” doesn’t exist, creating
[2018 03 29 10:29:10][0003.140] Updated board info to DTB
[2018 03 29 10:29:10][0003.143] “pmu-board” doesn’t exist, creating
[2018 03 29 10:29:10][0003.151] Updated board info to DTB
[2018 03 29 10:29:10][0003.154] “display-board” doesn’t exist, creating
[2018 03 29 10:29:10][0003.161] Updated board info to DTB
[2018 03 29 10:29:10][0003.164] “reset” doesn’t exist, creating
[2018 03 29 10:29:10][0003.169] Updated reset info to DTB
[2018 03 29 10:29:10][0003.172] display_console_ioctl: No display init
[2018 03 29 10:29:10][0003.177] display_console_ioctl: No display init
[2018 03 29 10:29:10][0003.182] display_console_ioctl: No display init
[2018 03 29 10:29:10][0003.189] display_console_ioctl: No display init
[2018 03 29 10:29:10][0003.196] Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=032361[2018 03 29 10:29:10]612352804002ff androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owne[2018 03 29 10:29:10]r_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1[2018 03 29 10:29:11] lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_pan[2018 03 29 10:29:11]el_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange
[2018 03 29 10:29:11][0003.269] Updated bootarg info to DTB
[2018 03 29 10:29:11][0003.276] Updated memory info to DTB
[2018 03 29 10:29:11][0003.285] set vdd_core voltage to 1125 mv
[2018 03 29 10:29:11][0003.289] setting ‘vdd-core’ regulator to 1125000 micro volts
[2018 03 29 10:29:11][0003.295] nvdumper Carveout: Base = 0xff23f000 and Size = 0x80000
[2018 03 29 10:29:11][0003.302] bct_init bctinit
[2018 03 29 10:29:11][0003.304] Starting Bpmp FW
[2018 03 29 10:29:11][0003.307] BPMP-FW Carveout: Base = 0xff2c0000 and Size = 0x40000
[2018 03 29 10:29:11]U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:37:03 -0700)
[2018 03 29 10:29:11]TEGRA210
[2018 03 29 10:29:11]Model: NVIDIA P2371-2180
[2018 03 29 10:29:11]Board: NVIDIA P2371-2180
[2018 03 29 10:29:11]DRAM: 4 GiB
[2018 03 29 10:29:11]MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
[2018 03 29 10:29:11]*** Warning - bad CRC, using default environment
[2018 03 29 10:29:11]In: serial
[2018 03 29 10:29:11]Out: serial
[2018 03 29 10:29:11]Err: serial
[2018 03 29 10:29:11]Net: No ethernet found.
[2018 03 29 10:29:13]Hit any key to stop autoboot: 0
[2018 03 29 10:29:13]MMC: no card present
[2018 03 29 10:29:13]switch to partitions #0, OK
[2018 03 29 10:29:13]mmc0(part 0) is current device
[2018 03 29 10:29:14]Scanning mmc 0:1…
[2018 03 29 10:29:14]Found /boot/extlinux/extlinux.conf
[2018 03 29 10:29:14]Retrieving file: /boot/extlinux/extlinux.conf
[2018 03 29 10:29:14]223 bytes read in 66 ms (2.9 KiB/s)
[2018 03 29 10:29:14]p2371-2180 eMMC boot options
[2018 03 29 10:29:14]1: primary kernel
[2018 03 29 10:29:17]Enter choice: 1: primary kernel
[2018 03 29 10:29:17]Retrieving file: /boot/initrd
[2018 03 29 10:29:17]0 bytes read in 63 ms (0 Bytes/s)
[2018 03 29 10:29:17]Retrieving file: /boot/Image
[2018 03 29 10:29:18]21068648 bytes read in 530 ms (37.9 MiB/s)
[2018 03 29 10:29:18]append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=032361612352804002[2018 03 29 10:29:18]ff androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc[2018 03 29 10:29:18]max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1[2018 03 29 10:29:18]000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 and[2018 03 29 10:29:18]roidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[2018 03 29 10:29:18]## Flattened Device Tree blob at 83100000
[2018 03 29 10:29:18] Booting using the fdt blob at 0x83100000
[2018 03 29 10:29:18] reserving fdt memory region: addr=80000000 size=20000
[2018 03 29 10:29:18] Using Device Tree in place at 0000000083100000, end 00000000831aee77
[2018 03 29 10:29:18]Starting kernel …
[2018 03 29 10:29:19][ 0.000000] Booting Linux on physical CPU 0x0
[2018 03 29 10:29:19][ 0.000000] Initializing cgroup subsys cpu
[2018 03 29 10:29:19][ 0.000000] Initializing cgroup subsys cpuacct
[2018 03 29 10:29:19][ 0.000000] Linux version 4.4.38-tegra (tx1-jetpack31@tx1jetpack31-virtual-machine) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #11 SMP PREEMPT Mon Mar 19 16[2018 03 29 10:29:19]:14:32 CST 2018
[2018 03 29 10:29:19][ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[2018 03 29 10:29:19][ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[2018 03 29 10:29:19][ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[2018 03 29 10:29:19][ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[2018 03 29 10:29:19][ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[2018 03 29 10:29:19][ 0.000000] psci: probing for conduit method from DT.
[2018 03 29 10:29:19][ 0.000000] psci: PSCIv1.0 detected in firmware.
[2018 03 29 10:29:19][ 0.000000] psci: Using standard PSCI v0.2 function IDs
[2018 03 29 10:29:19][ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[2018 03 29 10:29:19][ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[2018 03 29 10:29:19][ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[2018 03 29 10:29:19][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[2018 03 29 10:29:19][ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot[2018 03 29 10:29:19].serialno=032361612352804002ff androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner
[2018 03 29 10:29:19]info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.ol[2018 03 29 10:29:19]d_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 andro[2018 03 29 10:29:19]idboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwai[2018 03 29 10:29:19]t
[2018 03 29 10:29:19][ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[2018 03 29 10:29:19][ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[2018 03 29 10:29:19][ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[2018 03 29 10:29:19][ 0.000000] Memory: 3372492K/4173824K available (11017K kernel code, 1806K rwdata, 6444K rodata, 1200K init, 642K bss, 96820K reserved, 704512K cma-reserved)
[2018 03 29 10:29:19][ 0.000000] Virtual kernel memory layout:
[2018 03 29 10:29:19][ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[2018 03 29 10:29:19][ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[2018 03 29 10:29:19][ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
[2018 03 29 10:29:19][ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[2018 03 29 10:29:19][ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[2018 03 29 10:29:19][ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[2018 03 29 10:29:19][ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[2018 03 29 10:29:19][ 0.000000] .init : 0xffffffc00118e000 - 0xffffffc0012ba000 ( 1200 KB)
[2018 03 29 10:29:19][ 0.000000] .text : 0xffffffc000080000 - 0xffffffc00118dc04 ( 17464 KB)
[2018 03 29 10:29:19][ 0.000000] .data : 0xffffffc0012d4000 - 0xffffffc001497b68 ( 1807 KB)
[2018 03 29 10:29:19][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[2018 03 29 10:29:19][ 0.000000] Preemptible hierarchical RCU implementation.
[2018 03 29 10:29:19][ 0.000000] Build-time adjustment of leaf fanout to 64.
[2018 03 29 10:29:19][ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[2018 03 29 10:29:19][ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[2018 03 29 10:29:19][ 0.000000] NR_IRQS:64 nr_irqs:64 0
[2018 03 29 10:29:19][ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[2018 03 29 10:29:19][ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[2018 03 29 10:29:19][ 0.000000] clk_cbus_recalc_rate: no gbus parent
[2018 03 29 10:29:19][ 0.000000] kmemleak: Kernel memory leak detector disabled
[2018 03 29 10:29:19][ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[2018 03 29 10:29:19][ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[2018 03 29 10:29:19][ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[2018 03 29 10:29:19][ 0.001683] Console: colour dummy device 80x25
[2018 03 29 10:29:19][ 0.002621] console [tty0] enabled
[2018 03 29 10:29:19][ 0.002652] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[2018 03 29 10:29:19][ 0.002690] pid_max: default: 32768 minimum: 301
[2018 03 29 10:29:19][ 0.002771] Security Framework initialized
[2018 03 29 10:29:19][ 0.002792] SELinux: Initializing.
[2018 03 29 10:29:19][ 0.002895] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[2018 03 29 10:29:19][ 0.002919] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[2018 03 29 10:29:19][ 0.003600] Initializing cgroup subsys freezer
[2018 03 29 10:29:19][ 0.003630] Initializing cgroup subsys debug
[2018 03 29 10:29:19][ 0.003903] CPU0 ipc=1024
[2018 03 29 10:29:19][ 0.003939] CPU1 ipc=1024
[2018 03 29 10:29:19][ 0.003971] CPU2 ipc=1024
[2018 03 29 10:29:19][ 0.004003] CPU3 ipc=1024
[2018 03 29 10:29:19][ 0.004079] ASID allocator initialised with 65536 entries
[2018 03 29 10:29:19][ 0.031012] tegra-id: chipid=22117.
[2018 03 29 10:29:19][ 0.031042] tegra-id: opt_subrevision=0.
[2018 03 29 10:29:19][ 0.031072] Tegra Speedo/IDDQ fuse revision 4
[2018 03 29 10:29:19][ 0.031092] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[2018 03 29 10:29:19][ 0.031113] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[2018 03 29 10:29:19][ 0.031134] Tegra: CPU Speedo Value 2048, SoC Speedo Value 1927, GPU Speedo Value 2056
[2018 03 29 10:29:19][ 0.031163] Tegra: CPU IDDQ Value 2116, SoC IDDQ Value 2308, GPU IDDQ Value 2910
[2018 03 29 10:29:19][ 0.031206] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[2018 03 29 10:29:19][ 0.032525] DTS File Name: /home/tx1-jetpack31/JetPack-L4T-3.1/64_TX1/Linux_for_Tegra_64_tx1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nv[2018 03 29 10:29:19]idia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[2018 03 29 10:29:19][ 0.032588] DTB Build time: Mar 15 2018 17:26:35
[2018 03 29 10:29:19][ 0.048787] CPU1: Booted secondary processor [411fd071]
[2018 03 29 10:29:19][ 0.060755] CPU2: Booted secondary processor [411fd071]
[2018 03 29 10:29:19][ 0.072760] CPU3: Booted secondary processor [411fd071]
[2018 03 29 10:29:19][ 0.072837] Brought up 4 CPUs
[2018 03 29 10:29:19][ 0.072907] SMP: Total of 4 processors activated.
[2018 03 29 10:29:19][ 0.072930] CPU: All CPU(s) started at EL2
[2018 03 29 10:29:19][ 0.072972] alternatives: patching kernel code
[2018 03 29 10:29:19][ 0.075465] devtmpfs: initialized
[2018 03 29 10:29:19][ 0.142746] Initilizing CustomIPI irq domain
[2018 03 29 10:29:19][ 0.143087] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2018 03 29 10:29:19][ 0.155028] pinctrl core: initialized pinctrl subsystem
[2018 03 29 10:29:19][ 0.155257] OS set in device tree is L4T.
[2018 03 29 10:29:19][ 0.155644] regulator-dummy: no parameters
[2018 03 29 10:29:19][ 0.155865] Initializing plugin-manager
[2018 03 29 10:29:19][ 0.155939] Plugin module not found
[2018 03 29 10:29:19][ 0.156917] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[2018 03 29 10:29:19][ 0.157726] node /plugin-manager/fragement@4 match with odm-data l4t
[2018 03 29 10:29:19][ 0.157843] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[2018 03 29 10:29:19][ 0.158397] Adding domain ape-pd to PM domain mc-clk-pd
[2018 03 29 10:29:19][ 0.158442] Adding domain adsp-pd to PM domain ape-pd
[2018 03 29 10:29:19][ 0.163468] NET: Registered protocol family 16
[2018 03 29 10:29:19][ 0.165297] console [pstore-1] enabled
[2018 03 29 10:29:19][ 0.165321] pstore: Registered ramoops as persistent store backend
[2018 03 29 10:29:19][ 0.165345] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[2018 03 29 10:29:19][ 0.176238] cpuidle: using governor ladder
[2018 03 29 10:29:19][ 0.188227] cpuidle: using governor menu
[2018 03 29 10:29:19][ 0.188590] bpmp: mail init ok
[2018 03 29 10:29:19][ 0.189696] vdso: 2 pages (1 code @ ffffffc0012d9000, 1 data @ ffffffc0012d8000)
[2018 03 29 10:29:19][ 0.189760] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[2018 03 29 10:29:19][ 0.192078] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[2018 03 29 10:29:19][ 0.193025] tegra_powergate_init: DONE
[2018 03 29 10:29:19][ 0.193065] DTS File Name: /home/tx1-jetpack31/JetPack-L4T-3.1/64_TX1/Linux_for_Tegra_64_tx1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nv[2018 03 29 10:29:19]idia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[2018 03 29 10:29:19][ 0.193129] DTB Build time: Mar 15 2018 17:26:35
[2018 03 29 10:29:19][ 0.194137] Error: Driver ‘tegra-mc’ is already registered, aborting…
[2018 03 29 10:29:19][ 0.195733] platform tegra-carveouts: SMMU isn’t ready yet
[2018 03 29 10:29:19][ 0.196494] platform tegra-carveouts: domain=ffffffc0fa139318 allocates as[0]=ffffffc0fa14c0a8
[2018 03 29 10:29:19][ 0.196566] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[2018 03 29 10:29:19][ 0.196808] platform smmu_test: domain=ffffffc0fa139618 allocates as[0]=ffffffc0fa14c110
[2018 03 29 10:29:19][ 0.197141] platform 70016000.bpmp: domain=ffffffc0fa139918 allocates as[0]=ffffffc0fa14c178
[2018 03 29 10:29:19][ 0.197857] bpmp: ping status is 0
[2018 03 29 10:29:19][ 0.197965] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[2018 03 29 10:29:19][ 0.198217] bpmp 70016000.bpmp: probe ok
[2018 03 29 10:29:19][ 0.198844] mc: mapped MMIO address: 0xffffff800007e000 → 0x70019000
[2018 03 29 10:29:19][ 0.198943] mc: mapped MMIO address: 0xffffff80000b6000 → 0x7001c000
[2018 03 29 10:29:19][ 0.199038] mc: mapped MMIO address: 0xffffff80000dc000 → 0x7001d000
[2018 03 29 10:29:19][ 0.199126] mc-err: Set intmask: 0x23d40
[2018 03 29 10:29:20][ 0.210422] GPIO line 58 (wlan-default-input-h2) hogged as input
[2018 03 29 10:29:20][ 0.210475] GPIO line 65 (wlan-default-input-i1) hogged as input
[2018 03 29 10:29:20][ 0.210519] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[2018 03 29 10:29:20][ 0.210561] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[2018 03 29 10:29:20][ 0.210604] GPIO line 148 (cam0-rst) hogged as output/low
[2018 03 29 10:29:20][ 0.210642] GPIO line 151 (cam0-pwdn) hogged as output/low
[2018 03 29 10:29:20][ 0.210679] GPIO line 149 (cam1-rst) hogged as output/low
[2018 03 29 10:29:20][ 0.210716] GPIO line 152 (cam1-pwdn) hogged as output/low
[2018 03 29 10:29:20][ 0.210829] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[2018 03 29 10:29:20][ 0.213267] platform 70006000.serial: domain=ffffffc0fa1d6e18 allocates as[0]=ffffffc0fa14c1e0
[2018 03 29 10:29:20][ 0.214409] platform sound: domain=ffffffc0fa1f1718 allocates as[0]=ffffffc0fa14c248
[2018 03 29 10:29:20][ 0.216860] platform tegradc.1: domain=ffffffc0fa234918 allocates as[0]=ffffffc0fa14c2b0
[2018 03 29 10:29:20][ 0.217445] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[2018 03 29 10:29:20][ 0.220160] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[0]=ffffffc0fa14c318
[2018 03 29 10:29:20][ 0.220264] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[1]=ffffffc0fa14c380
[2018 03 29 10:29:20][ 0.220337] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[2]=ffffffc0fa14c3e8
[2018 03 29 10:29:20][ 0.220405] platform 57000000.gpu: domain=ffffffc0fa263d18 allocates as[3]=ffffffc0fa14c450
[2018 03 29 10:29:20][ 0.221176] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[2018 03 29 10:29:20][ 0.221221] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[2018 03 29 10:29:20][ 0.221245] tegra-pmc: ### PMC reset source: Power on reset
[2018 03 29 10:29:20][ 0.221267] tegra-pmc: ### PMC reset status reg: 0x0
[2018 03 29 10:29:20][ 0.221642] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[2018 03 29 10:29:20][ 0.221676] tegra-pmc: Clear bootloader IO dpd settings
[2018 03 29 10:29:20][ 0.224342] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[2018 03 29 10:29:20][ 0.228321] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[2018 03 29 10:29:20][ 0.232319] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[2018 03 29 10:29:20][ 0.236319] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[2018 03 29 10:29:20][ 0.236348] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[2018 03 29 10:29:20][ 0.240318] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[2018 03 29 10:29:20][ 0.244318] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[2018 03 29 10:29:20][ 0.248318] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[2018 03 29 10:29:20][ 0.248347] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[2018 03 29 10:29:20][ 0.252318] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[2018 03 29 10:29:20][ 0.256321] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[2018 03 29 10:29:20][ 0.256348] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[2018 03 29 10:29:20][ 0.256418] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[2018 03 29 10:29:20][ 0.259515] platform 1003000.pcie-controller: domain=ffffffc0fa26be18 allocates as[0]=ffffffc0fa14c4b8
[2018 03 29 10:29:20][ 0.261845] platform sdhci-tegra.3: domain=ffffffc0fa272f18 allocates as[0]=ffffffc0fa14c520
[2018 03 29 10:29:20][ 0.262453] platform sdhci-tegra.0: domain=ffffffc0fa279318 allocates as[0]=ffffffc0fa14c588
[2018 03 29 10:29:20][ 0.267646] vdd-ac-bat: 5000 mV
[2018 03 29 10:29:20][ 0.268855] vdd-cpu-fixed: 1000 mV
[2018 03 29 10:29:20][ 0.272578] irq: no irq domain found for /soctherm@0x700E2000 !
[2018 03 29 10:29:20][ 0.272935] irq: no irq domain found for /soctherm@0x700E2000 !
[2018 03 29 10:29:20][ 0.293390] ACPI: Interpreter disabled.
[2018 03 29 10:29:20][ 0.294191] SCSI subsystem initialized
[2018 03 29 10:29:20][ 0.294464] usbcore: registered new interface driver usbfs
[2018 03 29 10:29:20][ 0.294532] usbcore: registered new interface driver hub
[2018 03 29 10:29:20][ 0.294628] usbcore: registered new device driver usb
[2018 03 29 10:29:20][ 0.297866] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
[2018 03 29 10:29:20][ 0.300363] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
[2018 03 29 10:29:20][ 0.303649] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[2018 03 29 10:29:20][ 0.305442] GPIO line 474 (spmic-default-output-high) hogged as output/high
[2018 03 29 10:29:20][ 0.305557] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
[2018 03 29 10:29:20][ 0.308358] vdd-core: 600 <–> 1400 mV at 1125 mV
[2018 03 29 10:29:20][ 0.312348] vddio-ddr: at 1125 mV
[2018 03 29 10:29:20][ 0.313186] vdd-pre-reg: 1350 mV
[2018 03 29 10:29:20][ 0.316223] vdd-1v8: 1800 mV
[2018 03 29 10:29:20][ 0.320226] avdd-sys: 1200 mV
[2018 03 29 10:29:20][ 0.324225] vdd-pex: 1050 mV
[2018 03 29 10:29:20][ 0.324829] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[2018 03 29 10:29:20][ 0.325657] vdd-cam-hv: 2800 mV
[2018 03 29 10:29:20][ 0.328223] vdd-rtc: 850 mV
[2018 03 29 10:29:20][ 0.329071] avdd-ts-hv: 3300 mV
[2018 03 29 10:29:20][ 0.329917] vdd-ts: 1800 mV
[2018 03 29 10:29:20][ 0.332224] vdd-gen-pll-edp: 1050 mV
[2018 03 29 10:29:20][ 0.336225] vdd-hdmi-dp: 1050 mV
[2018 03 29 10:29:20][ 0.336857] max77620 4-003c: max77620 probe successful
[2018 03 29 10:29:20][ 0.338749] media: Linux media interface: v0.10
[2018 03 29 10:29:20][ 0.338821] Linux video capture interface: v2.00
[2018 03 29 10:29:20][ 0.346500] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[2018 03 29 10:29:20][ 0.346826] Advanced Linux Sound Architecture Driver Initialized.
[2018 03 29 10:29:20][ 0.350278] tegra210_dvfs: no clock found for sdmmc2_ddr
[2018 03 29 10:29:20][ 0.350327] tegra210_dvfs: no clock found for sdmmc4_ddr
[2018 03 29 10:29:20][ 0.350420] tegra210_dvfs: no clock found for sdmmc1_ddr
[2018 03 29 10:29:20][ 0.350467] tegra210_dvfs: no clock found for sdmmc3_ddr
[2018 03 29 10:29:20][ 0.353429] regulator_get() failed for (dvfs,vdd-cpu), -19
[2018 03 29 10:29:20][ 0.353457] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[2018 03 29 10:29:20][ 0.356230] vdd-3v3: 3300 mV
[2018 03 29 10:29:20][ 0.360225] max77620-gpio7: 1050 mV
[2018 03 29 10:29:20][ 0.360540] lcd-bl-en: 1800 mV
[2018 03 29 10:29:20][ 0.360833] en-vdd-sd: 3300 mV
[2018 03 29 10:29:20][ 0.361505] en-vdd-cam: 1800 mV
[2018 03 29 10:29:20][ 0.364223] vdd-sys-boost: 5000 mV
[2018 03 29 10:29:20][ 0.364881] vdd-hdmi: 5000 mV
[2018 03 29 10:29:20][ 0.365139] aux-3v3: 3300 mV
[2018 03 29 10:29:20][ 0.365363] snsr_pm: 3300 mV
[2018 03 29 10:29:20][ 0.368226] vdd-disp-3v0: 3000 mV
[2018 03 29 10:29:20][ 0.368906] vdd-fan: 5000 mV
[2018 03 29 10:29:20][ 0.369193] usb-vbus1: 5000 mV
[2018 03 29 10:29:20][ 0.369839] en-vdd-ts-1v8: 1800 mV
[2018 03 29 10:29:20][ 0.370510] en-vdd-ts-hv-3v3: 3300 mV
[2018 03 29 10:29:20][ 0.371341] en-vdd-disp-3v3: 3300 mV
[2018 03 29 10:29:20][ 0.371989] en-mdm-pwr-3v7: 3700 mV
[2018 03 29 10:29:20][ 0.372843] en-vdd-disp-1v8: 1800 mV
[2018 03 29 10:29:20][ 0.373497] en-vdd-cam-hv-2v8: 2800 mV
[2018 03 29 10:29:20][ 0.373777] rtl-5v0: 5000 mV
[2018 03 29 10:29:20][ 0.374068] en-usb-vbus2: 5000 mV
[2018 03 29 10:29:20][ 0.374737] en-vdd-cam-1v2: 1200 mV
[2018 03 29 10:29:20][ 0.375020] en-vdd-vcm-2v8: 2800 mV
[2018 03 29 10:29:20][ 0.377800] extcon-gpio-states extcon:extcon@1: Cable state 0
[2018 03 29 10:29:20][ 0.379131] clocksource: Switched to clocksource arch_sys_counter
[2018 03 29 10:29:20][ 0.419450] nvmap_heap_init: nvmap_heap_init: created heap block cache
[2018 03 29 10:29:20][ 0.419824] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[2018 03 29 10:29:20][ 0.420010] cma: enabled page replacement for spfn=c6000, epfn=f0000
[2018 03 29 10:29:20][ 0.420036] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[2018 03 29 10:29:20][ 0.420068] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[2018 03 29 10:29:20][ 0.420129] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[2018 03 29 10:29:20][ 0.420164] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[2018 03 29 10:29:20][ 0.420470] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[2018 03 29 10:29:20][ 0.421187] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[2018 03 29 10:29:20][ 0.421924] pnp: PnP ACPI: disabled
[2018 03 29 10:29:20][ 0.433378] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[2018 03 29 10:29:20][ 0.435242] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[2018 03 29 10:29:20][ 0.435659] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[2018 03 29 10:29:20][ 0.435848] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[2018 03 29 10:29:20][ 0.437457] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[2018 03 29 10:29:20][ 0.437708] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[2018 03 29 10:29:20][ 0.437934] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[2018 03 29 10:29:20][ 0.439352] isomgr_init(): iso emc max clk=1600000KHz
[2018 03 29 10:29:20][ 0.439377] isomgr_init(): max_iso_bw=11520000KB
[2018 03 29 10:29:20][ 0.439515] NET: Registered protocol family 2
[2018 03 29 10:29:20][ 0.440051] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[2018 03 29 10:29:20][ 0.440243] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[2018 03 29 10:29:20][ 0.440491] TCP: Hash tables configured (established 32768 bind 32768)
[2018 03 29 10:29:20][ 0.440589] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[2018 03 29 10:29:20][ 0.440652] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[2018 03 29 10:29:20][ 0.440886] NET: Registered protocol family 1
[2018 03 29 10:29:20][ 0.441190] RPC: Registered named UNIX socket transport module.
[2018 03 29 10:29:20][ 0.441218] RPC: Registered udp transport module.
[2018 03 29 10:29:20][ 0.441238] RPC: Registered tcp transport module.
[2018 03 29 10:29:20][ 0.441259] RPC: Registered tcp NFSv4.1 backchannel transport module.
[2018 03 29 10:29:20][ 0.441513] Trying to unpack rootfs image as initramfs…
[2018 03 29 10:29:20][ 0.452340] host1x 50000000.host1x: initialized
[2018 03 29 10:29:20][ 0.454026] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[2018 03 29 10:29:20][ 0.457163] futex hash table entries: 1024 (order: 5, 131072 bytes)
[2018 03 29 10:29:20][ 0.457302] audit: initializing netlink subsys (disabled)
[2018 03 29 10:29:20][ 0.457360] audit: type=2000 audit(0.451:1): initialized
[2018 03 29 10:29:20][ 0.468600] ntfs: driver 2.1.32 [Flags: R/O].
[2018 03 29 10:29:20][ 0.469071] fuse init (API version 7.23)
[2018 03 29 10:29:20][ 0.471623] io scheduler noop registered (default)
[2018 03 29 10:29:20][ 0.471655] io scheduler deadline registered
[2018 03 29 10:29:20][ 0.471955] io scheduler cfq registered
[2018 03 29 10:29:20][ 0.477382] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[2018 03 29 10:29:20][ 0.477430] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x8209c13
[2018 03 29 10:29:20][ 0.477465] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[2018 03 29 10:29:20][ 0.478909] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[2018 03 29 10:29:20][ 0.478944] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[2018 03 29 10:29:20][ 0.478972] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[2018 03 29 10:29:20][ 0.479008] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[2018 03 29 10:29:20][ 0.479052] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[2018 03 29 10:29:20][ 0.479085] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[2018 03 29 10:29:20][ 0.479146] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[2018 03 29 10:29:20][ 0.479190] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[2018 03 29 10:29:20][ 0.479236] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[2018 03 29 10:29:20][ 0.479282] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[2018 03 29 10:29:20][ 0.479327] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[2018 03 29 10:29:20][ 0.479371] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[2018 03 29 10:29:20][ 0.479416] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[2018 03 29 10:29:20][ 0.479462] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[2018 03 29 10:29:20][ 0.479897] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[2018 03 29 10:29:20][ 0.480898] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[2018 03 29 10:29:20][ 0.481961] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[2018 03 29 10:29:20][ 0.482674] Adding domain pcie-pd to PM domain mc-clk-pd
[2018 03 29 10:29:20][ 0.487307] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[2018 03 29 10:29:20][ 0.487377] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[2018 03 29 10:29:20][ 0.487404] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[2018 03 29 10:29:20][ 0.490818] tsec 54500000.tsec: initialized
[2018 03 29 10:29:20][ 0.492205] tsec 54100000.tsecb: initialized
[2018 03 29 10:29:20][ 0.494956] nvdec 54480000.nvdec: initialized
[2018 03 29 10:29:20][ 0.500511] falcon 54340000.vic: initialized
[2018 03 29 10:29:20][ 0.502192] falcon 544c0000.nvenc: initialized
[2018 03 29 10:29:20][ 0.503395] falcon 54380000.nvjpg: initialized
[2018 03 29 10:29:21][ 0.505285] DC OR NODE connected to /host1x/sor1
[2018 03 29 10:29:21][ 0.505387] display board info: id 0xffff, fab 0x0
[2018 03 29 10:29:21][ 0.505441] panel_select fail by _node_status
[2018 03 29 10:29:21][ 0.505500] display board info: id 0xffff, fab 0x0
[2018 03 29 10:29:21][ 0.505547] panel_select fail by _node_status
[2018 03 29 10:29:21][ 0.505732] tegradc tegradc.1: DT parsed successfully
[2018 03 29 10:29:21][ 0.505789] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
[2018 03 29 10:29:21][ 0.506644] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[2018 03 29 10:29:21][ 0.506838] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[2018 03 29 10:29:21][ 0.507698] display board info: id 0xffff, fab 0x0
[2018 03 29 10:29:21][ 0.507749] panel_select fail by _node_status
[2018 03 29 10:29:21][ 0.508586] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[2018 03 29 10:29:21][ 0.509721] tegradc tegradc.1: probed
[2018 03 29 10:29:21][ 0.515093] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[2018 03 29 10:29:21][ 0.517171] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[2018 03 29 10:29:21][ 0.518621] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[2018 03 29 10:29:21][ 0.518935] kfuse 7000fc00.kfuse: initialized
[2018 03 29 10:29:21][ 0.521014] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[2018 03 29 10:29:21][ 0.521994] clk_cbus_round_rate: no gbus parent
[2018 03 29 10:29:21][ 0.522024] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[2018 03 29 10:29:21][ 0.522561] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[2018 03 29 10:29:21][ 0.522594] vdd-cpu: 708 <–> 1322 mV at 708 mV
[2018 03 29 10:29:21][ 0.522659] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[2018 03 29 10:29:21][ 0.523892] vdd-gpu: applied init 1000000uV constraint
[2018 03 29 10:29:21][ 0.523924] vdd-gpu: 710 <–> 1320 mV at 1000 mV
[2018 03 29 10:29:21][ 0.523986] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[2018 03 29 10:29:21][ 0.524402] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[2018 03 29 10:29:21][ 0.524533] No Device Node present for smmu client: serial8250 !!
[2018 03 29 10:29:21][ 0.524561] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[2018 03 29 10:29:21][ 0.524599] No Device Node present for smmu client: serial8250 !!
[2018 03 29 10:29:21][ 0.524624] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[2018 03 29 10:29:21][ 0.525700] No Device Node present for smmu client: serial8250 !!
[2018 03 29 10:29:21][ 0.525729] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[2018 03 29 10:29:21][ 0.525779] No Device Node present for smmu client: serial8250 !!
[2018 03 29 10:29:21][ 0.525803] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[2018 03 29 10:29:21][ 0.526452] console [ttyS0] disabled
[2018 03 29 10:29:21][ 0.526523] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[2018 03 29 10:29:21][ 2.571140] console [ttyS0] enabled
[2018 03 29 10:29:21][ 2.572425] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[2018 03 29 10:29:21][ 2.572881] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[2018 03 29 10:29:21][ 2.573217] serial-tegra 70006300.serial: RX in PIO mode
[2018 03 29 10:29:21][ 2.573323] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[2018 03 29 10:29:21][ 2.574980] Console: switching to colour frame buffer device 80x30
[2018 03 29 10:29:21][ 2.579668] gk20a 57000000.gpu: platform probe failed
[2018 03 29 10:29:21][ 2.585011] brd: module loaded
[2018 03 29 10:29:21][ 2.656023] tegradc tegradc.1: fb registered
[2018 03 29 10:29:21][ 2.663301] loop: module loaded
[2018 03 29 10:29:21][ 2.669389] zram: Added device: zram0
[2018 03 29 10:29:21][ 2.675327] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[2018 03 29 10:29:21][ 2.687226] nct1008_nct72 0-004c: find device tree node, parsing dt
[2018 03 29 10:29:21][ 2.695796] nct1008_nct72 0-004c: starting parse dt
[2018 03 29 10:29:21][ 2.702952] nct1008_nct72 0-004c: success parsing dt
[2018 03 29 10:29:21][ 2.710311] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[2018 03 29 10:29:21][ 2.753739] tmp451: Enabled overheat logging at 102.00C
[2018 03 29 10:29:21][ 2.761212] nct1008_nct72 0-004c: nct1008_probe: initialized
[2018 03 29 10:29:21][ 2.771704] THERMAL EST: found 2 subdevs
[2018 03 29 10:29:21][ 2.777720] THERMAL EST num_resources: 0
[2018 03 29 10:29:21][ 2.783641] [THERMAL EST subdev 0]
[2018 03 29 10:29:21][ 2.789028] [THERMAL EST subdev 1]
[2018 03 29 10:29:21][ 2.794650] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[2018 03 29 10:29:21][ 2.807419] THERMAL EST: thz register success.
[2018 03 29 10:29:21][ 2.813865] THERMAL EST: end of probe, return err: 0
[2018 03 29 10:29:21][ 2.820741] tegra_profiler: Branch: Dev
[2018 03 29 10:29:21][ 2.826364] tegra_profiler: Version: 1.109
[2018 03 29 10:29:21][ 2.832166] tegra_profiler: Samples version: 37
[2018 03 29 10:29:21][ 2.838347] tegra_profiler: IO version: 21
[2018 03 29 10:29:21][ 2.844044] armv8_pmu: imp: 0x41, idcode: 0x1
[2018 03 29 10:29:21][ 2.849990] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[201
I’ve used that interface over many versions which worked…usually when something does not show up on USB of a devel carrier board there is something else going on at the same time. Is this the developer kit?
What does “lsusb -t” show with nothing plugged in to that port, and then again with the mouse on that port? If you move the mouse to the other port, what does “lsusb -t” show?
Of the devices used a keyboard or mouse will barely use any power at all, but sometimes USB power is insufficient for combinations of multiple devices or devices using more power (e.g., cameras and hard drives use more power). Be sure to try with all USB devices being only the minimal set (and then adding one device at a time). Better yet is to use a HUB which is externally powered.
thanks your answer.
1.nothing or plugged in to the board on the unnormal port with a mouse “lsusb -t” show:
nvidia@tegra-ubuntu:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/4p, 5000M
|__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/5p, 480M
2.plugged in to the board on the other port with a mouse “lsusb -t” show:
nvidia@tegra-ubuntu:~$ [69905.699444] usb 1-3: new low-speed USB device number 3 using xhci-tegra
[69905.730633] usb 1-3: New USB device found, idVendor=045e, idProduct=00cb
[69905.739048] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[69905.747373] usb 1-3: Product: Microsoft Basic Optical Mouse v2.0
[69905.753791] usb 1-3: Manufacturer: Microsoft
[69905.759440] usb 1-3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[69905.773882] input: Microsoft Microsoft Basic Optical Mouse v2.0 as /devices/70090000.xusb/usb1/1-3/1-3:1.0/0003:045E:00CB.0002/input/input4
[69905.787766] hid-generic 0003:045E:00CB.0002: input,hidraw0: USB HID v1.11 Mouse [Microsoft Microsoft Basic Optical Mouse v2.0 ] on usb-70090000.xusb-3/input0
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
when tx1 with jetpack3.0 on the same board “lsusb -t” show:
ubuntu@tegra-ubuntu:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/5p, 480M
|__ Port 4: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
when tx2 with jetpack3.1 on the same board “lsusb -t” show :
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/3p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-tegra/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
they all worked normally.
In all cases the lsusb and dmesg output looked ok. Were any of those from a case of JetPack3.1 and the port where something appeared to not work? Keep in mind that other software also has configuration requirements for mouse and keyboard, e.g., the X11 GUI environment has additional software on top of USB. If your above information was from a case of something not working, then it isn’t the USB side which is failing…if this is the case, then it is the software using the device which failed.
There is not other software in my case.My case is appeared when update to JetPack3.1.I plugged two mouses in the board’s oorts,but it juest find one mouse.
Usually it must something print out when plugged into the board’s usb port with a mouse,like:
Nothing print out when plugged into the other port which is not working.The board can not identify the mouse.
Tip: If you are posting code (or “lsusb -t” which has indents for formatting), then you can highlight the code (or log output) with your mouse, and then click the “code” icon (looks like “</>”) in the upper right corner and formatting will be preserved…the indentation will remain and make it easier to see.
FYI, mice will show in lsusb as class “Human Interface Device” (HID). I’m trying to figure out how your particular setup is wired.
I’m looking closer at some of the logs and there is something of a clue. In the case where the mice worked you had this:
/:  Bus 02.Port 1: Dev 1, Class=<b>root_hub</b>, Driver=tegra-xhci/4p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=<b>root_hub</b>, Driver=tegra-xhci/5p, 480M
    |__ Port 3: Dev 3, If 0, Class=<b>Human Interface Device</b>, Driver=usbhid, 1.5M
    |__ Port 4: Dev 4, If 0, Class=<b>Human Interface Device</b>, Driver=usbhid, 1.5M
This actually shows both mice on the same USB2 port (running USB1 speeds as expected). What seems odd is that both mice are direct connections to the root_hub without an intervening HUB (a root_hub is internal to the Jetson)…this isn’t possible unless a single mouse cable has two mice. It isn’t unusual for a programmable keyboard or mouse to have two listings because of the ability of the mouse to emulate a keyboard or the case of a keyboard being able to emulate a mouse. But this would be a single physical device. In this case where it works both mice are on the same USB2 port (the micro-USB port), but must be wired in some odd manner…I’ve never heard of two mice within a single physical USB cable. For this case how are both mice connected without an intervening HUB? Is there anything special about the mice, e.g., are they programmable (“lsusb -t” would not distinguish between keyboard or mouse when calling it a human interface device)?
For this “working” example the USB3 port was not used…the r8152 is irrelevant because it is internal to the TX1 module…it is the wired ethernet and can be ignored.
In the example where it failed I see:
In this case the wired ethernet does not show up, but this is actually normal under some circumstances…more importantly, both mice are shown here. I don’t know why there would be no dmesg output for unplugging or plugging of the mouse if “lsusb -t” showed the mouse.
Somehow, in both working and non-working cases, two human interface devices are shown. If there is a keyboard there would be two mice plus a keyboard…three HID devices in total…without a keyboard there would be two mice…two HID devices in total. Something strange is happening.
Is there a HUB involved? Are any of the keyboard/mouse devices programmable? If you have two mice and you swap which mouse is in the full-size USB port versus which is in the micro-USB port, do both mice work when using the micro-USB port, or does failure follow a specific mouse?
Sorry, my description is not clear.
My carried board is making follow by “jetsonTX1_OEM_Product_DesignGuide.pdf”.
In my case the abnormal port is link “USB2_EN_OC#”.And the normal port is link “USB1_EN_OC#”.
Hi 1510738947,
Please share HW design of the USB2 pins(B39, B40, …)
Does the two USB2 ports USB2.0 type A?
Hi DanneLLL.
The two USB2.0 port are type A.
The normal port’s pins(A38,A39,).
The abnormal port’s pins(B42,B43).
Can you share your device tree for r28.1? Do you have other USB2/USB3 port on your board?
Hi DaneLLL,
There are two USB2 ports on my board.
Which dtsi file is contain usb port?
Hi DaneLLL,are these?
usb@c5000000 {
                compatible = "nvidia,tegra20-ehci", "usb-ehci";
                reg = <0xc5000000 0x4000>;
                interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
                phy_type = "utmi";
                nvidia,has-legacy-mode;
                clocks = <&tegra_car TEGRA20_CLK_USBD>;
                resets = <&tegra_car 22>;
                reset-names = "usb";
                nvidia,needs-double-reset;
                nvidia,phy = <&phy1>;
                status = "disabled";
phy1: usb-phy@c5000000 {
                compatible = "nvidia,tegra20-usb-phy";
                reg = <0xc5000000 0x4000 0xc5000000 0x4000>;
                phy_type = "utmi";
                clocks = <&tegra_car TEGRA20_CLK_USBD>,
                         <&tegra_car TEGRA20_CLK_PLL_U>,
                         <&tegra_car TEGRA20_CLK_CLK_M>,
                clock-names = "reg", "pll_u", "timer", "utmi-pads";
                resets = <&tegra_car 22>, <&tegra_car 22>;
                reset-names = "usb", "utmi-pads";
                nvidia,hssync-start-delay = <9>;
                nvidia,idle-wait-delay = <17>;
                nvidia,elastic-limit = <16>;
                nvidia,term-range-adj = <6>;
                nvidia,xcvr-setup = <9>;
                nvidia,xcvr-lsfslew = <1>;
                nvidia,xcvr-lsrslew = <1>;
                nvidia,has-utmi-pad-registers;
usb@c5004000 {
                reg = <0xc5004000 0x4000>;
                interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
                phy_type = "ulpi";
                clocks = <&tegra_car TEGRA20_CLK_USB2>;
                resets = <&tegra_car 58>;
                nvidia,phy = <&phy2>;
        phy2: usb-phy@c5004000 {
                phy_type = "ulpi";
                clocks = <&tegra_car TEGRA20_CLK_USB2>,
                         <&tegra_car TEGRA20_CLK_CDEV2>;
                clock-names = "reg", "pll_u", "ulpi-link";
                resets = <&tegra_car 58>, <&tegra_car 22>;
usb@c5008000 {
                reg = <0xc5008000 0x4000>;
                interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>;
                phy_type = "utmi";
                clocks = <&tegra_car TEGRA20_CLK_USB3>;
                resets = <&tegra_car 59>;
                nvidia,phy = <&phy3>;
        phy3: usb-phy@c5008000 {
                reg = <0xc5008000 0x4000 0xc5000000 0x4000>;
                phy_type = "utmi";
                clocks = <&tegra_car TEGRA20_CLK_USB3>,
                resets = <&tegra_car 59>, <&tegra_car 22>;
                nvidia,xcvr-lsfslew = <2>;
                nvidia,xcvr-lsrslew = <2>;
Do you configure device tree per oem design guide? http://developer.nvidia.com/embedded/dlc/jetson-tx1-oem-product-design-guide
Hi DaneLLL,
There is nothing about changing device tree in the oem design guide.
We just Connect pins(B42,B43) to usb(usbx_dp,usbx_dn)type A.
We do not change the device tree when tx1 setup with Jetpack3.0, but the port are working.
Which dtsi file I should change?
Hi DaneLLL,
Can pins(B42,B43) be used for USB port in JetPack3.1?
You need to modify device tree to have (B42,B43) work on r28.1/TX1. Please refer to
[url]https://devtalk.nvidia.com/default/topic/1023046/jetson-tx1/unable-to-recognize-any-devices-hooked-on-usb2-m-2-slot-/post/5210227/#5210227[/url]
Hi DaneLLL,
Thank you very much.
The port is working now.
I found a new question when I using hdmi.There is nothing display on the screen.
[  335.309312] tegradc tegradc.1: hdmi: plugged
[  335.351963] tegradc tegradc.1: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[  335.352816] tegradc tegradc.1: hdmi: pclk:148500K, set prod-setting:prod_c_hdmi_75m_150m
[  335.613693] tegradc tegradc.1: nominal-pclk:533280000 parent:533278125 div:1.0 pclk:533278125 527947200~581275200
[  335.614498] tegradc tegradc.1: hdmi: pclk:533280K, set prod-setting:prod_c_hdmi_300m_600m
[  337.423503] tegradc tegradc.1: hdmi: unplugged
[  337.918331] tegradc tegradc.1: hdmi: plugged
[  337.969114] tegradc tegradc.1: nominal-pclk:533280000 parent:533278125 div:1.0 pclk:533278125 527947200~581275200
[  337.970446] tegradc tegradc.1: hdmi: pclk:533280K, set prod-setting:prod_c_hdmi_300m_600m
[  338.150770] tegradc tegradc.1: nominal-pclk:533280000 parent:533278125 div:1.0 pclk:533278125 527947200~581275200
[  338.152054] tegradc tegradc.1: hdmi: pclk:533280K, set prod-setting:prod_c_hdmi_300m_600m
[  341.844282] tegradc tegradc.1: hdmi: unplugged
[  342.246474] tegradc tegradc.1: hdmi: plugged
[  342.256341] tegradc tegradc.1: nominal-pclk:533280000 parent:533278125 div:1.0 pclk:533278125 527947200~581275200
[  342.257721] tegradc tegradc.1: hdmi: pclk:533280K, set prod-setting:prod_c_hdmi_300m_600m
[  342.454247] tegradc tegradc.1: nominal-pclk:533280000 parent:533278125 div:1.0 pclk:533278125 527947200~581275200
[  342.455050] tegradc tegradc.1: hdmi: pclk:533280K, set prod-setting:prod_c_hdmi_300m_600m
[  347.494827] tegradc tegradc.1: hdmi: scdc scrambling status is reset, trying to reconfigure.
[  352.550871] tegradc tegradc.1: hdmi: scdc scrambling status is reset, trying to reconfigure.
[  355.830604] tegradc tegradc.1: hdmi: unplugged
