Here is the output from the console:
[0000.705] [TegraBoot] (version 23.00.2015.14-mobile-90b91e54)
[0000.711] Processing in cold boot mode Bootloader 2
[0000.715] A01 Bootrom Patch rev = 63
[0000.719] Power-up reason: on button
[0000.722] No Battery Present
[0000.725] Platform has Ddr4 type ram
[0000.728] max77620 disabling SD1 Remote Sense
[0000.733] Setting Ddr voltage to 1125mv
[0000.737] Serial Number of Pmic Max77663: 0x20ab6
[0000.745] Entering ramdump check
[0000.748] Get RamDumpCarveOut = 0xff63f000
[0000.752] RamDumpCarveOut=0xff63f000, RamDumperFlag=0xffffffff
[0000.757] Last reboot was clean, booting normally!
[0000.762] Sdram initialization is successful
[0000.766] SecureOs Carveout Base=0xffc00000 Size=0x00400000
[0000.772] GSC1 Carveout Base=0xffb00000 Size=0x00100000
[0000.797] GSC2 Carveout Base=0xffa00000 Size=0x00100000
[0000.823] GSC3 Carveout Base=0xff900000 Size=0x00100000
[0000.828] GSC4 Carveout Base=0xff800000 Size=0x00100000
[0000.834] GSC5 Carveout Base=0xff700000 Size=0x00100000
[0000.839] BpmpFw Carveout Base=0xff6c0000 Size=0x00040000
[0000.844] Lp0 Carveout Base=0xff6bf000 Size=0x00001000
[0000.859] RamDump Carveout Base=0xff63f000 Size=0x00080000
[0000.865] Platform-DebugCarveout: 0
[0000.868] Nck Carveout Base=0xff43f000 Size=0x00200000
[0000.898] Using GPT Primary to query partitions
[0000.904] Loading Tboot-CPU binary
[0000.913] Verifying bootloader in OdmNonSecureSBK mode
[0000.923] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.932] Bootloader downloaded successfully.
[0000.936] Downloaded Tboot-CPU binary to 0xa0000258
[0000.941] MAX77620_GPIO1 Configured.
[0000.945] MAX77620_GPIO5 Configured.
[0000.949] CPU power rail is up
[0000.951] CPU clock enabled
[0000.955] Performing RAM repair
[0000.958] Updating A64 Warmreset Address to 0xa00002e9
[0000.975] Bootloader DTB Load Address: 0x83000000
[0000.992] Kernel DTB Load Address: 0x83080000
[0000.997] Loading cboot binary
[0001.046] Verifying bootloader in OdmNonSecureSBK mode
[0001.077] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0001.086] Bootloader downloaded successfully.
[0001.136] Next binary entry address: 0x92c00258
[0001.141] BoardId: 2180
[0001.146] dram memory type is 3
[0001.150] WB0 init successful
[0001.176] Bpmp FW successfully loaded
[0001.179] Set NvDecSticky Bits
[0001.182] GSC1 address : ffb00000
[0001.186] GSC2 address : ffa00000
[0001.190] GSC3 address : ff900000
[0001.194] GSC4 address : ff800000
[0001.197] GSC5 address : ff700000
[0001.201] GSC MC Settings done
[0001.204] TOS old plaintext Image length 61440
[0001.210] *** Secure OS image signature not verified ***
[0001.216] Loading and Validation of Secure OS Successful
[0001.221] NvTbootPackSdramParams: start.
[0001.226] NvTbootPackSdramParams: done.
[0001.229] Tegraboot started after 94516 us
[0001.233] Basic modules init took 892462 us
[0001.237] Sec Bootdevice Read Time = 154 ms, Read Size = 6623 KB
[0001.243] Next stage binary read took 12265 us
[0001.247] Carveout took 171750 us
[0001.251] CPU initialization took 88399 us
[0001.254] Total time taken by TegraBoot 1164876 us
[0001.259] Starting CPU & Halting co-processor
64b[0001.395] LPDDR4 Training: Number of tables = 10
[0001.399] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.405] EMC Training Successful
[0001.408] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.414] EMC Training Successful
[0001.417] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.428] EMC Training Successful
[0001.431] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.454] EMC Training Successful
[0001.457] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.479] EMC Training Successful
[0001.482] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.501] EMC Training Successful
[0001.505] Switching to 800000 KHz Success
[0001.538] LPDDR4 Training: Number of tables = 10
[0001.581]
[0001.582] Debug Init done
[0001.585] Marked DTB cacheable
[0001.588] Bootloader DTB loaded at 0x83000000
[0001.593] Marked DTB cacheable
[0001.596] Kernel DTB loaded at 0x83080000
[0001.599] DeviceTree Init done
[0001.615] Pinmux applied successfully
[0001.621] gicd_base: 0x50041000
[0001.625] gicc_base: 0x50042000
[0001.628] Interrupts Init done
[0001.633] Using base:0x60005008 & irq:33 for tick-timer
[0001.638] Using base:0x60005000 for delay-timer
[0001.642] platform_init_timer: DONE
[0001.646] Timer(tick) Init done
[0001.651] osc freq = 38400 khz
[0001.654]
[0001.655] welcome to cboot
[0001.657]
[0001.658] Cboot Version: 23.00.2015.14-t210-36d61cd0
[0001.663] calling constructors
[0001.666] initializing heap
[0001.669] initializing threads
[0001.672] initializing timers
[0001.675] creating bootstrap completion thread
[0001.679] top of bootstrap2()
[0001.682] CPU: ARM Cortex A57
[0001.685] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.690] initializing platform
[0001.716] config for ddr50 mode completed
[0001.720] sdmmc bdev is already initialized
[0001.724] Enable APE clock
[0001.726] Un-powergate APE partition
[0001.730] of_register: registering tegra_udc to of_hal
[0001.735] of_register: registering inv20628-driver to of_hal
[0001.741] of_register: registering ads1015-driver to of_hal
[0001.746] of_register: registering lp8557-bl-driver to of_hal
[0001.752] of_register: registering bq2419x_charger to of_hal
[0001.758] of_register: registering cpc to of_hal
[0001.762] of_register: registering bq27441_fuel_gauge to of_hal
[0001.777] gpio framework initialized
[0001.781] of_register: registering i2c_bus_driver to of_hal
[0001.786] of_register: registering i2c_bus_driver to of_hal
[0001.792] of_register: registering i2c_bus_driver to of_hal
[0001.797] pmic framework initialized
[0001.801] of_register: registering max77620_pmic to of_hal
[0001.806] regulator framework initialized
[0001.810] initializing target
[0001.818] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.828] fixed regulator driver initialized
[0001.897] initializing OF layer
[0001.900] shim_invoke:Calling dts_overrides
[0001.904] dts_overrides: Original DTS size 253463
[0001.908] dts_override_props_based: No node name for offset 0
[0001.920] dts_override_props_based: Enabling node udc@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0001.933] dts_override_props_based: Enabling node otg@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0001.946] dts_override_props_based: Enabling node watchdog@60005100 based on odm data odm-data: mask: val = (0x00094000:0x00010000:0x00010000)
[0001.963] dts_override_debug_console: SQA Automation port: UARTA
[0001.971] TegraNctInit: nct_ptr = 0xff43f000
[0001.975] TegraNctInit: magic(0x7443566e),vid(0xffff),pid(0xffff),ver(V1.0),rev(44)
[0001.992] dts_override: Node with path /i2c@7000c400/ina226@46 not found.
[0002.001] create_node: Adding node /nct in the device tree
[0002.011] TegraNctReadItem: index err(0x5/0x0)
[0002.015] set_node_prop: Error(-2) reading factory-mode from NCT
[0002.025] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.047] I2C Bus Init done
[0002.050] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.062] I2C Bus Init done
[0002.064] of_children_init: Ops found for compatible string ti,lp8557
[0002.071] I2C slave not started
[0002.074] I2C write failed
[0002.076] Writing offset failed
[0002.079] failed to read 0x 0
[0002.082] lp8557: Couldn’t turn off backlight: -3
[0002.087] lp8557: device config err: -3of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.102] I2C Bus Init done
[0002.105] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.117] I2C Bus Init done
[0002.120] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.132] I2C Bus Init done
[0002.135] of_children_init: Ops found for compatible string maxim,max77620
[0002.147] max77620_init using irq 118
[0002.152] register ‘maxim,max77620’ pmic
[0002.156] gpio_driver_register: register ‘max77620-gpio’ driver
[0002.162] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.175] I2C Bus Init done
[0002.177] of_children_init: Ops found for compatible string nvidia,tegra210-udc
[0002.186] shim_invoke:Calling dts updates
[0002.204] updating /chosen/nvidia,wifi-mac node 00:04:4b:63:58:fe
[0002.212] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:63:58:ff
[0002.221] updating /chosen/nvidia,ethernet-mac node 00:04:4b:63:59:00
[0002.227] I2C slave not started
[0002.230] I2C write failed
[0002.233] Writing offset failed
[0002.236] detect_super_modual : Cannnot find the Super Module
[0002.242] I2C slave not started
[0002.245] I2C write failed
[0002.247] Writing offset failed
[0002.251] detect_m2e_board : Cannnot find the M.2E Board
[0002.256] Chip UID is 00000001640d06c82400000003fe8280
[0002.263] shim_cmdline_install: /chosen/bootargs: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-se
cure
[0002.276] calling apps_init()
[0002.281] Found 20 GPT partitions in “sdmmc3_user”
[0002.286] Proceeding to Cold Boot
[0002.289] starting app android_boot_app
[0002.293] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.300] BMP partition read failed!
[0002.304] blob_init: blob-partition BMP header read failed
[0002.309] load_bmp_blob: BMP blob initialization failed
[0002.314] Could not load/initialize BMP blob…ignoring
[0002.319] bl_battery_charging: connected to external power supply
[0002.325] display_console_ioctl: No display init
[0002.330] switch_backlight failed
[0002.3[0002.340] DT entry for leds-pwm not found
34] blob_init: USP partition does not have valid Blob
[0002.350] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.358] BMP partition read failed!
[0002.361] blob_init: blob-partition BMP header read failed
[0002.367] load_bmp_blob: BMP blob initialization failed
[0002.372] bmp blob is not loaded and initialized
[0002.377] Failed to display boot-logo
[0002.380] Loading android kernel
[0002.384] kernel load address: 0x80080000, size: 19962264 bytes
[0002.390] ramdisk load address: 0x84100000, size: 1089024 bytes
[0002.629] Successfully loaded kernel and ramdisk images
[0002.634] shim_invoke:Calling dts_overrides
[0002.638] dts_overrides: Original DTS size 253463
[0002.643] dts_override_props_based: No node name for offset 0
[0002.654] dts_override_props_based: Enabling node udc@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0002.667] dts_override_props_based: Enabling node otg@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0002.681] dts_override_props_based: Enabling node watchdog@60005100 based on odm data odm-data: mask: val = (0x00094000:0x00010000:0x00010000)
[0002.697] dts_override_debug_console: SQA Automation port: UARTA
[0002.715] dts_override: Node with path /i2c@7000c400/ina226@46 not found.
[0002.724] create_node: Adding node /nct in the device tree
[0002.734] TegraNctReadItem: index err(0x5/0x0)
[0002.738] set_node_prop: Error(-2) reading factory-mode from NCT
[0002.746] shim_invoke:Calling dts updates
[0002.752] updating /chosen/nvidia,wifi-mac node 00:04:4b:63:58:fe
[0002.760] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:63:58:ff
[0002.769] updating /chosen/nvidia,ethernet-mac node 00:04:4b:63:59:00
[0002.775] I2C slave not started
[0002.778] I2C write failed
[0002.781] Writing offset failed
[0002.784] detect_super_modual : Cannnot find the Super Module
[0002.790] I2C slave not started
[0002.793] I2C write failed
[0002.795] Writing offset failed
[0002.798] detect_m2e_board : Cannnot find the M.2E Board
[0002.804] Chip UID is 00000001640d06c82400000003fe8280
[0002.811] shim_cmdline_install: /chosen/bootargs: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-se
cure
[0002.825] Updated bpmp info to DTB
[0002.830] Updated initrd info to DTB
[0002.834] “proc-board” doesn’t exist, creating
[0002.840] Updated board info to DTB
[0002.843] “pmu-board” doesn’t exist, creating
[0002.850] Updated board info to DTB
[0002.853] “display-board” doesn’t exist, creating
[0002.859] Updated board info to DTB
[0002.862] “reset” doesn’t exist, creating
[0002.867] Updated reset info to DTB
[0002.870] display_console_ioctl: No display init
[0002.875] display_console_ioctl: No display init
[0002.879] display_console_ioctl: No display init
[0002.886] display_console_ioctl: No display init
[0002.890] Cmdline: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=
2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=teg
rafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_firs
t=1 lp0_vec=0x1000@0xff6bf000 nvdumper_reserved=0xff63f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_ven
dor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:power_on_reset,pmic:0x40
[0002.953] Updated bootarg info to DTB
[0002.959] Updated memory info to DTB
[0002.966] set vdd_core voltage to 1125 mv
[0002.970] setting ‘vdd_core’ regulator to 1125000 micro volts
[0002.976] nvdumper Carveout: Base = 0xff63f000 and Size = 0x80000
[0002.983] bct_init bctinit
[0002.985] bct_init bctinit
[0003.107] Starting Bpmp FW
[0003.110] BPMP-FW Carveout: Base = 0xff6c0000 and Size = 0x40000
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.67-gbc79444 (andersm@andersm-linux) (gcc version 4.9 20140514 (prerelease) (GCC) ) #1 SMP PREEMPT Wed May 4 09
:12:13 CST 2016
[ 0.000000] CPU: Cortex A57 Processor [411fd071] revision 1
[ 0.000000] alternative: enabling workaround for ARM erratum 832075
[ 0.000000] Machine: jetson_cv
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: ff6bf000 - ff6bffff
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: f6600000 - fadfffff
[ 0.000000] 2nd Framebuffer: fae00000 - ff5fffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 0b9fffff
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] Bootloader Debug Data: 00000000 - 00000000
[ 0.000000] Nvdumper: ff63f000 - ff63ffff
[ 0.000000] cma: CMA: reserved 188 MiB at ea800000
[ 0.000000] cma: CMA: reserved 16 MiB at e9800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] DTS File Name: /home/andersm/share/repo/rel-23-mfg/kernel/arch/arm64/boot/dts/tegra210-jetson-cv-p2597-2180-a00.dts
[ 0.000000] DTB Build time: May 4 2016 09:09:49
[ 0.000000] Tegra21: Speedo/IDDQ fuse revision 4
[ 0.000000] Tegra21: CPU Speedo ID 7, Soc Speedo ID 0, Gpu Speedo ID 2
[ 0.000000] Tegra21: CPU Process ID 0, Soc Process ID 0, Gpu Process ID 0
[ 0.000000] Tegra21: CPU Speedo value 2007, Soc Speedo value 1890, Gpu Speedo value 2004
[ 0.000000] Tegra21: CPU IDDQ 1660, Soc IDDQ 1824, Gpu IDDQ 2240
[ 0.000000] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 Core Process: 0
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] pll_x boot misc1 0x0 : expected 0x20
[ 0.000000] (comparison mask = 0xffffff)
[ 0.000000] pll_c4 rates match 266000000 max sdmmc: vco=796800000 out0=199200000 out3=199200000
[ 0.000000] Lowering vic03 maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering nvjpg maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering se maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering tsecb maximum rate from 1000000000 to 627200000
[ 0.000000] Lowering msenc maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering nvdec maximum rate from 1000000000 to 716800000
[ 0.000000] Lowering vi maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering isp maximum rate from 1000000000 to 793600000
[ 0.000000] Lowering adsp_bus maximum rate from 1200000000 to 844800000
[ 0.000000] Lowering sbus maximum rate from 600000000 to 408000000
[ 0.000000] Lowering host1x maximum rate from 600000000 to 408000000
[ 0.000000] Lowering pll_c maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1130000000
[ 0.000000] Lowering pll_d2 maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering pll_dp maximum rate from 1500000000 to 1130000000
[ 0.000000] Lowering sor0 maximum rate from 600000000 to 540000000
[ 0.000000] Lowering sor1 maximum rate from 600000000 to 594000000
[ 0.000000] Lowering dmic1 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic2 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering dmic3 maximum rate from 12288000 to 12190000
[ 0.000000] Lowering hda maximum rate from 102000000 to 51000000
[ 0.000000] Lowering sdmmc2 maximum rate from 266000000 to 204000000
[ 0.000000] Lowering qspi maximum rate from 133000000 to 116600000
[ 0.000000] Lowering gbus maximum rate from 1300000000 to 998400000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 1734000000
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1132800000
[ 0.000000] tegra dvfs: vdd_cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_core: nominal 1125mV, offset 0uV, step 12500uV, scaling enabled
[ 0.000000] tegra dvfs: vdd_gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 13 pages/cpu @ffffffc03feb3000 s21696 r8192 d23360 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 994850
[ 0.000000] Kernel command line: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-secure tegraid=21.
1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_i
d=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore
.old_scheme_first=1 lp0_vec=0x1000@0xff6bf000 nvdumper_reserved=0xff63f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal andro
idboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:power_on_reset,pmic:0x40
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 1892MB 2048MB = 3940MB total
[ 0.000000] Memory: 3732408k/3732408k available, 302152k reserved
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 MB)
[ 0.000000] vmemmap : 0xffffffbc01c00000 - 0xffffffbc05400000 ( 56 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001158000 - 0xffffffc0011ce4c0 ( 474 kB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0011571a4 ( 17245 kB)
[ 0.000000] .data : 0xffffffc0011e1000 - 0xffffffc001389878 ( 1699 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] NR_IRQS:960 nr_irqs:960 0
[ 0.000000] the number of interrupt controllers found is 6
[ 0.000000] Architected local timer running at 19.20MHz (phys).
[ 0.000000] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000000] Wake16 for irq=34
[ 0.000000] Enabling wake16
[ 0.009578] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=192000
[ 0.017511] pid_max: default: 32768 minimum: 301
[ 0.022245] Security Framework initialized
[ 0.026187] SELinux: Initializing.
[ 0.029724] Mount-cache hash table entries: 256
[ 0.082029] Initializing cgroup subsys debug
[ 0.084306] Initializing cgroup subsys freezer
[ 0.088971] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.130356] ftrace: Allocated trace_printk buffers
[ 0.1
[16:01:41] /mods
uname -a
Linux tinylinux 3.10.67-gbc79444 #1 SMP PREEMPT Wed May 4 09:12:13 CST 2016 aarch64 GNU/Linux
[16:01:48] /mods
poweroff
[16:02:50] /mods
Stopping ld_xusb_fw… OK
Stopping fan… OK
Stopping adb…[ 179.626166] ffs_data_put(): freeing
OK
Stopping mods… OK
Stopping bash… OK
Stopping net.lo…[ 179.663121] oz_net_notifier: event NETDEV_DOWN
[ 179.667956] oz_binding_remove: Remove binding: ‘lo’
OK
Stopping hostname… OK
Stopping syslogd… OK
Stopping mount… OK
The system is going down NOW!
Sent SIGTERM to all processes
exit
Sent SIGKILL to all processes
Requesting system poweroff
[ 181.746483] nvdumper: rebooting cleanly.
[ 181.750583] nvdumper: set_dirty_state 0xf000caf3
[ 181.761733] therm-fan-est: shutting down
[ 181.765809] wifi_platform_set_power = 0
[ 181.769780] pcl-generic pcl-generic: camera_shutdown locked.
[ 181.776618] tegra-vii2c 546c0000.i2c: Bus is shutdown down..
[ 181.782311] gk20a gpu.0: shutting down
[ 181.899822] late_shutdown started
[ 181.903141] tegra-i2c 7000d100.i2c: Bus is shutdown down..
[ 181.908625] tegra-i2c 7000d000.i2c: Bus is shutdown down..
[ 181.914123] tegra-i2c 7000c700.i2c: Bus is shutdown down..
[ 181.919616] tegra-i2c 7000c500.i2c: Bus is shutdown down..
[ 181.925100] tegra-i2c 7000c400.i2c: Bus is shutdown down..
[ 181.930595] tegra-i2c 7000c000.i2c: Bus is shutdown down..
[ 181.936149] Shutting down tegra …
[ 181.939650] reboot: Power down
[ 181.942713] max77620-power-off max77620-power-off.4: Powering off system
[ 181.949410] max77620 4-003c: Xfer without lock
[ 181.956298] max77620 4-003c: Xfer without lock
[ 181.963163] max77620 4-003c: Xfer without lock
[ 181.970030] max77620-power-off max77620-power-off.4: Preparing power-off from PMIC
[ 181.977591] max77620 4-003c: Xfer without lock
[0000.116] [TegraBoot] (version 23.00.2015.14-mobile-90b91e54)
[0000.122] Processing in cold boot mode Bootloader 2
[0000.127] A01 Bootrom Patch rev = 63
[0000.130] Power-up reason: on button
[0000.133] No Battery Present
[0000.136] Platform has Ddr4 type ram
[0000.139] max77620 disabling SD1 Remote Sense
[0000.144] Setting Ddr voltage to 1125mv
[0000.148] Serial Number of Pmic Max77663: 0x20ab6
[0000.156] Entering ramdump check
[0000.159] Get RamDumpCarveOut = 0xff63f000
[0000.163] RamDumpCarveOut=0xff63f000, RamDumperFlag=0xffffffff
[0000.168] Last reboot was clean, booting normally!
[0000.173] Sdram initialization is successful
[0000.177] SecureOs Carveout Base=0xffc00000 Size=0x00400000
[0000.183] GSC1 Carveout Base=0xffb00000 Size=0x00100000
[0000.208] GSC2 Carveout Base=0xffa00000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0xff900000 Size=0x00100000
[0000.239] GSC4 Carveout Base=0xff800000 Size=0x00100000
[0000.245] GSC5 Carveout Base=0xff700000 Size=0x00100000
[0000.250] BpmpFw Carveout Base=0xff6c0000 Size=0x00040000
[0000.255] Lp0 Carveout Base=0xff6bf000 Size=0x00001000
[0000.270] RamDump Carveout Base=0xff63f000 Size=0x00080000
[0000.276] Platform-DebugCarveout: 0
[0000.279] Nck Carveout Base=0xff43f000 Size=0x00200000
[0000.309] Using GPT Primary to query partitions
[0000.315] Loading Tboot-CPU binary
[0000.324] Verifying bootloader in OdmNonSecureSBK mode
[0000.334] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.343] Bootloader downloaded successfully.
[0000.347] Downloaded Tboot-CPU binary to 0xa0000258
[0000.352] MAX77620_GPIO1 Configured.
[0000.356] MAX77620_GPIO5 Configured.
[0000.360] CPU power rail is up
[0000.362] CPU clock enabled
[0000.366] Performing RAM repair
[0000.369] Updating A64 Warmreset Address to 0xa00002e9
[0000.386] Bootloader DTB Load Address: 0x83000000
[0000.403] Kernel DTB Load Address: 0x83080000
[0000.408] Loading cboot binary
[0000.457] Verifying bootloader in OdmNonSecureSBK mode
[0000.488] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.497] Bootloader downloaded successfully.
[0000.547] Next binary entry address: 0x92c00258
[0000.552] BoardId: 2180
[0000.557] dram memory type is 3
[0000.560] WB0 init successful
[0000.587] Bpmp FW successfully loaded
[0000.590] Set NvDecSticky Bits
[0000.593] GSC1 address : ffb00000
[0000.597] GSC2 address : ffa00000
[0000.601] GSC3 address : ff900000
[0000.605] GSC4 address : ff800000
[0000.608] GSC5 address : ff700000
[0000.611] GSC MC Settings done
[0000.615] TOS old plaintext Image length 61440
[0000.621] *** Secure OS image signature not verified ***
[0000.626] Loading and Validation of Secure OS Successful
[0000.631] NvTbootPackSdramParams: start.
[0000.637] NvTbootPackSdramParams: done.
[0000.640] Tegraboot started after 94521 us
[0000.644] Basic modules init took 289303 us
[0000.648] Sec Bootdevice Read Time = 154 ms, Read Size = 6623 KB
[0000.654] Next stage binary read took 12265 us
[0000.658] Carveout took 171712 us
[0000.661] CPU initialization took 88300 us
[0000.665] Total time taken by TegraBoot 561580 us
[0000.670] Starting CPU & Halting co-processor
64b[0000.805] LPDDR4 Training: Number of tables = 10
[0000.810] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0000.816] EMC Training Successful
[0000.819] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0000.825] EMC Training Successful
[0000.828] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0000.839] EMC Training Successful
[0000.842] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0000.865] EMC Training Successful
[0000.868] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0000.890] EMC Training Successful
[0000.893] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0000.912] EMC Training Successful
[0000.915] Switching to 800000 KHz Success
[0000.949] LPDDR4 Training: Number of tables = 10
[0000.978]
[0000.979] Debug Init done
[0000.981] Marked DTB cacheable
[0000.984] Bootloader DTB loaded at 0x83000000
[0000.989] Marked DTB cacheable
[0000.992] Kernel DTB loaded at 0x83080000
[0000.996] DeviceTree Init done
[0001.012] Pinmux applied successfully
[0001.017] gicd_base: 0x50041000
[0001.021] gicc_base: 0x50042000
[0001.024] Interrupts Init done
[0001.029] Using base:0x60005008 & irq:33 for tick-timer
[0001.034] Using base:0x60005000 for delay-timer
[0001.039] platform_init_timer: DONE
[0001.042] Timer(tick) Init done
[0001.047] osc freq = 38400 khz
[0001.050]
[0001.051] welcome to cboot
[0001.054]
[0001.055] Cboot Version: 23.00.2015.14-t210-36d61cd0
[0001.060] calling constructors
[0001.063] initializing heap
[0001.066] initializing threads
[0001.069] initializing timers
[0001.071] creating bootstrap completion thread
[0001.076] top of bootstrap2()
[0001.079] CPU: ARM Cortex A57
[0001.081] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.086] initializing platform
[0001.112] config for ddr50 mode completed
[0001.116] sdmmc bdev is already initialized
[0001.120] Enable APE clock
[0001.123] Un-powergate APE partition
[0001.127] of_register: registering tegra_udc to of_hal
[0001.132] of_register: registering inv20628-driver to of_hal
[0001.137] of_register: registering ads1015-driver to of_hal
[0001.143] of_register: registering lp8557-bl-driver to of_hal
[0001.149] of_register: registering bq2419x_charger to of_hal
[0001.154] of_register: registering cpc to of_hal
[0001.159] of_register: registering bq27441_fuel_gauge to of_hal
[0001.174] gpio framework initialized
[0001.177] of_register: registering i2c_bus_driver to of_hal
[0001.183] of_register: registering i2c_bus_driver to of_hal
[0001.188] of_register: registering i2c_bus_driver to of_hal
[0001.194] pmic framework initialized
[0001.197] of_register: registering max77620_pmic to of_hal
[0001.203] regulator framework initialized
[0001.207] initializing target
[0001.215] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.225] fixed regulator driver initialized
[0001.293] initializing OF layer
[0001.296] shim_invoke:Calling dts_overrides
[0001.300] dts_overrides: Original DTS size 253463
[0001.305] dts_override_props_based: No node name for offset 0
[0001.316] dts_override_props_based: Enabling node udc@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0001.329] dts_override_props_based: Enabling node otg@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0001.343] dts_override_props_based: Enabling node watchdog@60005100 based on odm data odm-data: mask: val = (0x00094000:0x00010000:0x00010000)
[0001.359] dts_override_debug_console: SQA Automation port: UARTA
[0001.368] TegraNctInit: nct_ptr = 0xff43f000
[0001.372] TegraNctInit: magic(0x7443566e),vid(0xffff),pid(0xffff),ver(V1.0),rev(44)
[0001.389] dts_override: Node with path /i2c@7000c400/ina226@46 not found.
[0001.397] create_node: Adding node /nct in the device tree
[0001.407] TegraNctReadItem: index err(0x5/0x0)
[0001.412] set_node_prop: Error(-2) reading factory-mode from NCT
[0001.422] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.443] I2C Bus Init done
[0001.446] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.458] I2C Bus Init done
[0001.461] of_children_init: Ops found for compatible string ti,lp8557
[0001.467] I2C slave not started
[0001.470] I2C write failed
[0001.473] Writing offset failed
[0001.476] failed to read 0x 0
[0001.479] lp8557: Couldn’t turn off backlight: -3
[0001.484] lp8557: device config err: -3of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.499] I2C Bus Init done
[0001.501] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.513] I2C Bus Init done
[0001.516] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.529] I2C Bus Init done
[0001.531] of_children_init: Ops found for compatible string maxim,max77620
[0001.544] max77620_init using irq 118
[0001.548] register ‘maxim,max77620’ pmic
[0001.553] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.559] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.571] I2C Bus Init done
[0001.574] of_children_init: Ops found for compatible string nvidia,tegra210-udc
[0001.582] shim_invoke:Calling dts updates
[0001.601] updating /chosen/nvidia,wifi-mac node 00:04:4b:63:58:fe
[0001.609] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:63:58:ff
[0001.618] updating /chosen/nvidia,ethernet-mac node 00:04:4b:63:59:00
[0001.624] I2C slave not started
[0001.627] I2C write failed
[0001.630] Writing offset failed
[0001.633] detect_super_modual : Cannnot find the Super Module
[0001.638] I2C slave not started
[0001.641] I2C write failed
[0001.644] Writing offset failed
[0001.647] detect_m2e_board : Cannnot find the M.2E Board
[0001.652] Chip UID is 00000001640d06c82400000003fe8280
[0001.659] shim_cmdline_install: /chosen/bootargs: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-se
cure
[0001.673] calling apps_init()
[0001.678] Found 20 GPT partitions in “sdmmc3_user”
[0001.682] Proceeding to Cold Boot
[0001.685] starting app android_boot_app
[0001.689] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0001.697] BMP partition read failed!
[0001.700] blob_init: blob-partition BMP header read failed
[0001.706] load_bmp_blob: BMP blob initialization failed
[0001.711] Could not load/initialize BMP blob…ignoring
[0001.716] bl_battery_charging: connected to external power supply
[0001.722] display_console_ioctl: No display init
[0001.727] switch_backlight failed
[0001.7[0001.736] DT entry for leds-pwm not found
31] blob_init: USP partition does not have valid Blob
[0001.747] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0001.754] BMP partition read failed!
[0001.758] blob_init: blob-partition BMP header read failed
[0001.763] load_bmp_blob: BMP blob initialization failed
[0001.769] bmp blob is not loaded and initialized
[0001.773] Failed to display boot-logo
[0001.777] Loading android kernel
[0001.781] kernel load address: 0x80080000, size: 19962264 bytes
[0001.787] ramdisk load address: 0x84100000, size: 1089024 bytes
[0002.026] Successfully loaded kernel and ramdisk images
[0002.031] shim_invoke:Calling dts_overrides
[0002.035] dts_overrides: Original DTS size 253463
[0002.040] dts_override_props_based: No node name for offset 0
[0002.051] dts_override_props_based: Enabling node udc@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0002.064] dts_override_props_based: Enabling node otg@7d000000 based on odm data odm-data: mask: val = (0x00094000:0x01000000:0x00000000)
[0002.077] dts_override_props_based: Enabling node watchdog@60005100 based on odm data odm-data: mask: val = (0x00094000:0x00010000:0x00010000)
[0002.094] dts_override_debug_console: SQA Automation port: UARTA
[0002.112] dts_override: Node with path /i2c@7000c400/ina226@46 not found.
[0002.120] create_node: Adding node /nct in the device tree
[0002.130] TegraNctReadItem: index err(0x5/0x0)
[0002.135] set_node_prop: Error(-2) reading factory-mode from NCT
[0002.143] shim_invoke:Calling dts updates
[0002.149] updating /chosen/nvidia,wifi-mac node 00:04:4b:63:58:fe
[0002.157] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:63:58:ff
[0002.166] updating /chosen/nvidia,ethernet-mac node 00:04:4b:63:59:00
[0002.172] I2C slave not started
[0002.175] I2C write failed
[0002.178] Writing offset failed
[0002.181] detect_super_modual : Cannnot find the Super Module
[0002.186] I2C slave not started
[0002.189] I2C write failed
[0002.192] Writing offset failed
[0002.195] detect_m2e_board : Cannnot find the M.2E Board
[0002.200] Chip UID is 00000001640d06c82400000003fe8280
[0002.207] shim_cmdline_install: /chosen/bootargs: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-se
cure
[0002.221] Updated bpmp info to DTB
[0002.227] Updated initrd info to DTB
[0002.230] “proc-board” doesn’t exist, creating
[0002.237] Updated board info to DTB
[0002.240] “pmu-board” doesn’t exist, creating
[0002.246] Updated board info to DTB
[0002.250] “display-board” doesn’t exist, creating
[0002.256] Updated board info to DTB
[0002.259] “reset” doesn’t exist, creating
[0002.264] Updated reset info to DTB
[0002.267] display_console_ioctl: No display init
[0002.272] display_console_ioctl: No display init
[0002.276] display_console_ioctl: No display init
[0002.283] display_console_ioctl: No display init
[0002.287] Cmdline: androidboot.modem=none androidboot.serialno=032211605316708082fe androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=
dor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:power_on_reset,pmic:0x41
[0002.350] Updated bootarg info to DTB
[0002.355] Updated memory info to DTB
[0002.363] set vdd_core voltage to 1125 mv
[0002.367] setting ‘vdd_core’ regulator to 1125000 micro volts
[0002.372] nvdumper Carveout: Base = 0xff63f000 and Size = 0x80000
[0002.379] bct_init bctinit
[0002.382] bct_init bctinit
[0002.501] Starting Bpmp FW
[0002.503] BPMP-FW Carveout: Base = 0xff6c0000 and Size = 0x40000
:12:13 CST 2016
idboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:power_on_reset,pmic:0x41
[ 0.009583] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=192000
[ 0.017510] pid_max: default: 32768 minimum: 301
[ 0.022244] Security Framework initialized
[ 0.026188] SELinux: Initializing.
[ 0.029723] Mount-cache hash table entries: 256
[ 0.081993] Initializing cgroup subsys debug
[ 0.084270] Initializing cgroup subsys freezer
[ 0.088932] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[ 0.191120] Brought up 4 CPUs
[ 0.192095] SMP: Total of 4 processors activated.
[ 0.196795] alternatives: patching kernel code
[ 0.204467] devtmpfs: initialized
[ 0.219104] pinctrl core: initialized pinctrl subsystem
[ 0.222682] regulator-dummy: ; Rail ON
[ 0.231225] NET: Registered protocol family 16
[ 0.236598] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.242352] console [pstore-1] enabled
[ 0.245461] ramoops: attached 0x200000@0xf6400000, ecc: 0/0
[ 0.251150] I2C first dynamic bus number based on alias = 7
[ 0.256434] cpuidle: using governor ladder
[ 0.260468] cpuidle: using governor menu
[ 0.265080] PMC: Setting PMIC interrupt active-low
[ 0.269782] tegra-pmc device create success
[ 0.273304] tegra-pmc: prod list not found: -19
[ 0.277939] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.285081] Clear bootloader IO dpd settings
[ 0.289315] PMC: configuring io pad defaults
[ 0.293771] PMC: IO pad audio voltage is 1800000
[ 0.298254] PMC: IO pad cam voltage is 1800000
[ 0.302687] PMC: IO pad dbg voltage is 1800000
[ 0.307094] PMC: IO pad dmic voltage is 1800000
[ 0.311612] PMC: IO pad pex-ctrl voltage is 1800000
[ 0.316453] PMC: IO pad spi voltage is 1800000
[ 0.320885] PMC: IO pad uart voltage is 1800000
[ 0.325380] PMC: IO pad bb voltage is 1800000
[ 0.329714] PMC: IO pad audio-hv voltage is 1800000
[ 0.334579] PMC: IO pad spi-hv voltage is 1800000
[ 0.339247] PMC: IO pad gpio voltage is 1800000
[ 0.343764] PMC: IO pad sdmmc3 voltage is 1800000
[ 0.348341] PMC: IO pad pex-bias power is disable
[ 0.353031] PMC: IO pad pex-clk1 power is disable
[ 0.357700] PMC: IO pad pex-clk2 power is disable
[ 0.362382] T210 pmc padctrl driver initialized
[ 0.366901] T210 pmc config for bootrom command passed
[ 0.373352] INFO: pinmux CLAMP_INPUTS_WHEN_TRISTATED: disabled
[ 0.379942] clk_init_from_dt_table: clocks are set from t210-clk-init-table:clkinit-0
[ 0.388419] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.392553] platform bpmp.15: No iommus property found in DT node, got swgids from fixup(2)
[ 0.400774] platform bpmp.15: No iommus property found in DT node, got swgids from fixup(2)
[ 0.409155] platform bpmp.15: domain=ffffffc0ff0b5c58 allocates as[0]=ffffffc0ff0b80a8
[ 0.417203] platform bpmp.15: IOVA linear map 0x00000000ff6c0000(40000)
[ 0.423622] bpmp bpmp.15: No iommus property found in DT node, got swgids from fixup(2)
[ 0.431994] bpmp bpmp.15: bpmp_connect returned 0
[ 0.436218] bpmp bpmp.15: No iommus property found in DT node, got swgids from fixup(2)
[ 0.444792] MC mapped MMIO address: 0xffffff800003c000
[ 0.449360] MC0 mapped MMIO address: 0xffffff8000074000
[ 0.454573] MC1 mapped MMIO address: 0xffffff800009a000
[ 0.468910] tegra210-pinctrl 700008d4.pinmux: lookup the user state drive not found
[ 0.474681] tegra210-pinctrl 700008d4.pinmux: Probed Tegra pinctrl driver
[ 0.481842] GPIO chip tegra-gpio: created GPIO range 0->245 ==> 700008d4.pinmux PIN 0->245
[ 0.489612] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name wlan-default
[ 0.497173] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.506756] Wake44 for irq=81
[ 0.507763] Wake40 for irq=53
[ 0.510675] Wake41 for irq=53
[ 0.513622] Wake42 for irq=53
[ 0.516568] Wake43 for irq=53
[ 0.520045] platform 70006000.serial: domain=ffffffc0ff1c5ed8 allocates as[0]=ffffffc0ff0b8110
[ 0.530804] platform tegradc.0: domain=ffffffc0ff1c5958 allocates as[0]=ffffffc0ff0b8178
[ 0.540442] platform tegradc.0: IOVA linear map 0x00000000f6600000(4800000)
[ 0.548930] platform tegradc.0: IOVA linear map 0x00000000fae00000(4800000)
[ 0.554070] platform tegradc.0: IOVA linear map 0x00000000ea800000(bc00000)
[ 0.561113] platform tegradc.1: Failed IOVA linear map 0x00000000f6600000(4800000)
[ 0.568368] platform tegradc.1: Failed IOVA linear map 0x00000000fae00000(4800000)
[ 0.575920] platform tegradc.1: Failed IOVA linear map 0x00000000ea800000(bc00000)
[ 0.585493] platform gpu.0: domain=ffffffc0ff1c56d8 allocates as[0]=ffffffc0ff0b81e0
[ 0.591293] platform gpu.0: domain=ffffffc0ff1c56d8 allocates as[1]=ffffffc0ff0b8248
[ 0.598986] platform gpu.0: domain=ffffffc0ff1c56d8 allocates as[2]=ffffffc0ff0b82b0
[ 0.606719] platform gpu.0: domain=ffffffc0ff1c56d8 allocates as[3]=ffffffc0ff0b8318
[ 0.615300] platform tegra21-se: No iommus property found in DT node, got swgids from fixup(4800004000)
[ 0.623755] platform tegra21-se: No iommus property found in DT node, got swgids from fixup(4800004000)
[ 0.633447] platform tegra30-hda: No iommus property found in DT node, got swgids from fixup(80)
[ 0.641869] platform tegra30-hda: No iommus property found in DT node, got swgids from fixup(80)
[ 0.650869] platform adsp_audio.3: domain=ffffffc0ff1c5558 allocates as[0]=ffffffc0ff0b8380
[ 0.661629] platform sdhci-tegra.3: domain=ffffffc0ff223ed8 allocates as[0]=ffffffc0ff0b83e8
[ 0.668516] platform sdhci-tegra.0: domain=ffffffc0ff223cd8 allocates as[0]=ffffffc0ff0b8450
[ 0.676648] platform tegra-fuse: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.685765] platform tegra-fuse: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.695155] Wake39 for irq=52
[ 0.698040] platform tegra-udc.0: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.707348] platform tegra-udc.0: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.716874] platform tegra-otg: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.725893] platform tegra-otg: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.737540] platform spdif-dit.0: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.744951] platform spdif-dit.0: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.754453] platform spdif-dit.1: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.763668] platform spdif-dit.1: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.773190] platform spdif-dit.2: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.782392] platform spdif-dit.2: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.791910] platform spdif-dit.3: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.801107] platform spdif-dit.3: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.815630] gpio wake52 for gpio=61
[ 0.817415] gpio wake8 for gpio=58
[ 0.820542] gpio wake8 for gpio=58
[ 0.825025] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.829943] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.835913] board_info: id:sku:fab:major:minor = 0x0884:0x03e8:0x00:0x00:0x00
[ 0.842806] PMC dt information non-NULL tegra_init_suspend
[ 0.855753] Loading EMC tables…
[ 0.857161] tegra: Using EMC sequence ‘21021’ for Rev. 7 tables
[ 0.862993] tegra: emc: Derated table is valid.
[ 0.867485] Lowering emc maximum rate from 1800000000 to 1600000000
[ 0.873735] tegra: validated EMC DFS table
[ 0.887394] swapper/0 isomgr_init(): iso emc max clk=1600000KHz
[ 0.891341] swapper/0 isomgr_init(): max_iso_bw=11520000KB
[ 2.153260] vdso: 2 pages (1 code, 1 data) at base ffffffc0011ea000
[ 2.157547] vdso32: 2 pages (1 code, 1 data) at base ffffffc0011e9000
[ 2.164007] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 2.170859] nvdumper: last reboot was unknown
[ 2.175067] nvdumper: set_dirty_state 0x2badface
[ 2.180044] Tegra restart notifier registered.
[ 2.195749] bio: create slab at 0
[ 2.199545] vdd-ac-bat: 5000 mV ; Rail ON
[ 2.202018] vdd-cpu-fixed: 1000 mV ; Rail ON
[ 2.206898] SCSI subsystem initialized
[ 2.209950] usbcore: registered new interface driver usbfs
[ 2.215243] usbcore: registered new interface driver hub
[ 2.220566] usbcore: registered new device driver usb
[ 2.226225] gpio wake33 for gpio=188
[ 2.231771] gpio wake21 for gpio=89
[ 2.233428] gpiochip_add: registered GPIOs 1008 to 1023 on device: tca9539
[ 2.241205] gpio wake36 for gpio=202
[ 2.243796] gpiochip_add: registered GPIOs 992 to 1007 on device: tca9539
[ 2.250842] tegra-i2c 7000c400.i2c: no acknowledge from address 0x24
[ 2.256800] pca953x 1-0024: failed reading register
[ 2.261643] pca953x: probe of 1-0024 failed with error -121
[ 2.267721] i2c i2c-3: of_i2c: modalias failure on /i2c@7000c700/prod-settings
[ 2.275462] max77620 4-003c: CID0: 0xb6
[ 2.278256] max77620 4-003c: CID1: 0x0a
[ 2.282093] max77620 4-003c: CID2: 0x02
[ 2.285877] max77620 4-003c: CID3: 0x59
[ 2.289690] max77620 4-003c: CID4: 0x35
[ 2.293549] max77620 4-003c: CID5: 0x80
[ 2.297316] max77620 4-003c: MAX77620 PMIC OTP Version is 0x35
[ 2.304733] max77620-pmic max77620-pmic: Consumer c2 does not have device name
[ 2.310369] max77620-pmic max77620-pmic: Consumer c0 does not have device name
[ 2.318431] vdd_core: 600 ↔ 1400 mV at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.326280] vddio-ddr: at 1125 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.332607] vdd-pre-reg: 1350 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.339567] vdd-1v8: 1800 mV with ramp delay 27500 uV/us ; Rail ON
[ 2.345428] avdd-sys: 1200 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.351039] avdd-sys: supplied by vdd-pre-reg
[ 2.355992] vdd-pex: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.361601] vdd-pex: supplied by vdd-pre-reg
[ 2.366239] vddio-sdmmc1: 1800 ↔ 3300 mV at 1800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.374894] vdd-cam-hv: 2800 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.381601] vdd-rtc: 850 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.387610] avdd-ts-hv: 3300 mV with ramp delay 100000 uV/us ; Rail OFF
[ 2.394361] vdd-ts: 1800 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.400604] vdd-gen-pll-edp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.406820] vdd-gen-pll-edp: supplied by vdd-pre-reg
[ 2.412258] vdd-hdmi-dp: 1050 mV with ramp delay 100000 uV/us ; Rail ON
[ 2.418347] vdd-hdmi-dp: supplied by vdd-pre-reg
[ 2.423413] max77620-gpio max77620-gpio.0: Initialising GPIO state 1: name gpio_default
[ 2.430963] gpiochip_add: registered GPIOs 984 to 991 on device: max77620-gpio
[ 2.439178] max77620-gpio max77620-gpio.0: max77620 gpio successfully initialized
[ 2.448926] max77620 4-003c: max77620 probe successfully
[ 2.452967] Linux video capture interface: v2.00
[ 2.456889] pps_core: LinuxPPS API ver. 1 registered
[ 2.461793] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 2.470907] PTP clock support registered
[ 2.475211] Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 2.480864] tegra_wdt 60005100.watchdog: tegra_wdt_probe done
[ 2.487691] Advanced Linux Sound Architecture Driver Initialized.
[ 2.492779] Bluetooth: Core ver 2.16
[ 2.495956] NET: Registered protocol family 31
[ 2.500360] Bluetooth: HCI device and connection manager initialized
[ 2.506674] Bluetooth: HCI socket layer initialized
[ 2.511540] Bluetooth: L2CAP socket layer initialized
[ 2.516567] Bluetooth: SCO socket layer initialized
[ 2.521742] cfg80211: Calling CRDA to update world regulatory domain
[ 2.529115] vdd-3v3: 3300 mV ; Rail ON
[ 2.532799] max77620-gpio7: 1050 mV ; Rail ON
[ 2.535834] max77620-gpio7: supplied by vdd-gen-pll-edp
[ 2.541304] lcd-bl-en: 1800 mV ; Rail ON
[ 2.545134] en-vdd-sd: 3300 mV ; Rail OFF
[ 2.548924] en-vdd-sd: supplied by vdd-3v3
[ 2.553134] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 2.561169] en-vdd-cam: 1800 mV ; Rail OFF
[ 2.571604] vdd-sys-boost: 5000 mV ; Rail ON
[ 2.574419] vdd-hdmi: 5000 mV ; Rail OFF
[ 2.577820] vdd-hdmi: supplied by vdd-3v3
[ 2.582021] aux-3v3: 3300 mV ; Rail ON
[ 2.585681] snsr_pm: 3300 mV ; Rail ON
[ 2.589929] vdd-disp-3v0: 3000 mV ; Rail ON
[ 2.593924] vdd-fan: 5000 mV ; Rail OFF
[ 2.597435] usb-vbus1: 5000 mV ; Rail OFF
[ 2.601237] usb-vbus1: supplied by vdd-3v3
[ 2.605507] usb-vbus3: 5000 mV ; Rail OFF
[ 2.609278] usb-vbus3: supplied by vdd-3v3
[ 2.613880] en-vdd-ts-1v8: 1800 mV ; Rail OFF
[ 2.618168] en-vdd-ts-hv-3v3: 3300 mV ; Rail OFF
[ 2.622773] en-vdd-disp-3v3: 3300 mV ; Rail OFF
[ 2.627259] en-mdm-pwr-3v7: ; Rail OFF
[ 2.631015] en-vdd-disp-1v8: 1800 mV ; Rail OFF
[ 2.635491] en-vdd-cam-hv-2v8: ; Rail OFF
[ 2.639208] rtl-5v0: ; Rail OFF
[ 2.642346] en-usb-vbus2: ; Rail OFF
[ 2.646156] en-vdd-cam-1v2: ; Rail OFF
[ 2.649416] en-vdd-cam-1v2: supplied by vdd-3v3
[ 2.654602] regulator-pwm 0.pwm-regulator: PWM request deferred
[ 2.659776] platform 0.pwm-regulator: Driver regulator-pwm requests probe deferral
[ 2.667890] vdd_gpu: applied init 1000000uV constraint
[ 2.672440] vdd_gpu: 710 ↔ 1320 mV at 1000 mV ; Rail OFF
[ 2.678860] vdd_cpu: applied init 1000000uV constraint
[ 2.683100] vdd_cpu: 708 ↔ 1322 mV at 1000 mV normal ; Rail ON
[ 2.689741] max77620-wdt max77620-wdt.5: WDT node is disabled
[ 2.695525] gpio wake34 for gpio=200
[ 2.699803] extcon-gpio-states 1.extcon: Cable state 0
[ 2.705511] Switching to clocksource arch_sys_counter
[ 2.740827] FS-Cache: Loaded
[ 2.741896] CacheFiles: Loaded
[ 2.745308] No Device Node present for smmu client: tegra-carveouts !!
[ 2.751291] platform tegra-carveouts: No iommus property found in DT node, got swgids from fixup(42)
[ 2.760390] No Device Node present for smmu client: tegra-carveouts !!
[ 2.766854] platform tegra-carveouts: No iommus property found in DT node, got swgids from fixup(42)
[ 2.776088] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.782831] No Device Node present for smmu client: tegra-carveouts !!
[ 2.788975] tegra-carveouts tegra-carveouts: No iommus property found in DT node, got swgids from fixup(42)
[ 2.798692] dma_declare_coherent_resizable_cma_memory:278: resizable heap=vpr, base=0x0x00000000ea800000, size=0xbc00000
[ 2.809515] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (6) rem_chunk_size(0x1c00000)
[ 2.820255] cma: enabled page replacement for spfn=ea800, epfn=f6400
[ 2.826393] dma_declare_coherent_resizable_cma_memory:325: resizable cma heap=vpr create successful
[ 2.835251] nvmap_page_pool_init: Total RAM pages: 985326
[ 2.840792] nvmap_page_pool_init: nvmap page pool size: 123165 pages (481 MB)
[ 2.847969] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.848133] misc nvmap: iram :dma coherent mem declare 0x0000000040001000,258048
[ 2.848839] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 2.849290] misc nvmap: created heap vpr base 0x00000000ea800000 size (192512KiB)
[ 2.876424] nvmap:inner cache maint threshold=2097152
[ 2.876424] No Device Node present for smmu client: tegra-carveouts !!
[ 2.887945] tegra-carveouts tegra-carveouts: No iommus property found in DT node, got swgids from fixup(42)
[ 2.899132] tegra-otg tegra-otg: No iommus property found in DT node, got swgids from fixup(101004000)
[ 2.907351] Wake39 for irq=52
[ 2.909974] tegra-otg tegra-otg: otg transceiver registered
[ 2.915408] tegra-otg tegra-otg: No iommus property found in DT node, got swgids from fixup(101004000)
[ 2.925335] regulator_get() failed for (0-0070,vcc-pullup), -19
[ 2.930587] pca954x 0-0070: vcc-pullup regulator not found
[ 2.948718] tegra-i2c 7000c000.i2c: no acknowledge from address 0x70
[ 2.953159] pca954x 0-0070: Write to device failed: -121
[ 2.958504] pca954x: probe of 0-0070 failed with error -121
[ 2.964232] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 2.973272] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 2.980972] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.989249] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.997671] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 3.006784] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 3.014654] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 3.023981] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-sys is having fixed voltage 1800000
[ 3.032130] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-uart is having fixed voltage 1800000
[ 3.041050] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-audio is having fixed voltage 1800000
[ 3.050058] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-cam is having fixed voltage 1800000
[ 3.058906] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-pex-ctrl is having fixed voltage 1800000
[ 3.068159] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-sdmmc1 is having voltages: 1800000:3300000
[ 3.077630] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-sdmmc3 is having fixed voltage 1800000
[ 3.086724] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-sdmmc4 is having fixed voltage 1800000
[ 3.095825] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-audio-hv is having fixed voltage 1800000
[ 3.105109] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-debug is having fixed voltage 1800000
[ 3.114103] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-dmic is having fixed voltage 1800000
[ 3.123037] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-gpio is having fixed voltage 1800000
[ 3.131968] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-spi is having fixed voltage 1800000
[ 3.140804] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-spi-hv is having fixed voltage 1800000
[ 3.149897] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-sdmmc2 is having fixed voltage 1800000
[ 3.159006] tegra210-pmc-iopower pmc-iopower.17: Rail iopower-dp is having fixed voltage 1800000
[ 3.167661] tegra210-pmc-iopower pmc-iopower.17: NO_IO_POWER setting 0x1000
[ 3.174900] NET: Registered protocol family 2
[ 3.179688] TCP established hash table entries: 32768 (order: 7, 524288 bytes)
[ 3.186365] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 3.192972] TCP: Hash tables configured (established 32768 bind 32768)
[ 3.199303] TCP: reno registered
[ 3.202417] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 3.208429] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 3.215153] NET: Registered protocol family 1
[ 3.219517] RPC: Registered named UNIX socket transport module.
[ 3.225032] RPC: Registered udp transport module.
[ 3.229730] RPC: Registered tcp transport module.
[ 3.234390] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.241132] tegra-fuse tegra-fuse: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.250393] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 3.256760] tegra-fuse tegra-fuse: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.266648] Trying to unpack rootfs image as initramfs…
[ 3.274208] Freeing initrd memory: 1060K (ffffffc004100000 - ffffffc004209000)
[ 3.284213] host1x host1x: initialized
[ 3.290310] audit: initializing netlink socket (disabled)
[ 3.293745] type=2000 audit(3.279:1): initialized
[ 3.300387] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.304295] FS-Cache: Netfs ‘nfs’ registered for caching
[ 3.310037] FS-Cache: Netfs ‘cifs’ registered for caching
[ 3.315146] fuse init (API version 7.22)
[ 3.318980] msgmni has been set to 7699
[ 3.324305] io scheduler noop registered (default)
[ 3.327364] io scheduler d
