Resolve Stopping During Boot.
Changed the contents of the panel-n-wqxga-6-0.dtsi file that supports DSC to panel information.
But, There is no DSI screen.
boot message
[0000.174] [TegraBoot] (version 00.00.2014.50-mobile-d44d4bf0)
[0000.180] Processing in cold boot mode Bootloader 2
[0000.184] A02 Bootrom Patch rev = 63
[0000.188] Power-up reason: software reset
[0000.191] No Battery Present
[0000.194] RamCode = 0
[0000.196] Platform has Ddr4 type ram
[0000.200] max77620 disabling SD1 Remote Sense
[0000.204] Setting Ddr voltage to 1125mv
[0000.208] Serial Number of Pmic Max77663: 0x1d1bad
[0000.216] Entering ramdump check
[0000.219] Get RamDumpCarveOut = 0xff23f000
[0000.223] RamDumpCarveOut=0xff23f000, RamDumperFlag=0x0
[0000.228] Last reboot was clean, booting normally!
[0000.232] Sdram initialization is successful
[0000.236] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.242] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.247] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.252] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.257] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.262] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.268] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.273] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.288] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.294] Platform-DebugCarveout: 0
[0000.297] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.302] Non secure mode, and RB not enabled.
[0000.342] Using GPT Primary to query partitions
[0000.347] Loading Tboot-CPU binary
[0000.396] Verifying bootloader in OdmNonSecureSBK mode
[0000.406] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.413] Bootloader downloaded successfully.
[0000.417] Downloaded Tboot-CPU binary to 0xa0000258
[0000.422] MAX77620_GPIO1 Configured.
[0000.426] MAX77620_GPIO5 Configured.
[0000.429] CPU power rail is up
[0000.432] CPU clock enabled
[0000.436] Performing RAM repair
[0000.439] Updating A64 Warmreset Address to 0xa00002e9
[0000.467] Bootloader DTB Load Address: 0x83000000
[0000.495] Kernel DTB Load Address: 0x83100000
[0000.500] Loading cboot binary
[0000.594] Verifying bootloader in OdmNonSecureSBK mode
[0000.632] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.639] Bootloader downloaded successfully.
[0000.643] GPT: Partition NOT found !
[0000.647] Find Partition via GPT Failed
[0000.651] Find Partition via PT Failed
[0000.654] function NvTbootGetBinaryOffsets: 0x1 error
[0000.659] Error in NvTbootLoadBinary: 0x1 !
[0000.663] Next binary entry address: 0x92c00258
[0000.667] BoardId: 2180
[0000.672] dram memory type is 3
[0000.676] WB0 init successful
[0000.702] Bpmp FW successfully loaded
[0000.706] Set NvDecSticky Bits
[0000.709] GSC1 address : ff700000
[0000.712] GSC2 address ff63fffc value c0edbbcc
[0000.717] GSC2 address : ff600000
[0000.721] GSC3 address : ff500000
[0000.725] GSC4 address : ff400000
[0000.728] GSC5 address : ff300000
[0000.731] GSC MC Settings done
[0000.735] TOS plaintext Image length 28752
[0000.739] Monitor size 28752
[0000.742] OS size 0
[0000.745] *** Secure OS image signature not verified ***
[0000.750] Loading and Validation of Secure OS Successful
[0000.755] NvTbootPackSdramParams: start.
[0000.760] NvTbootPackSdramParams: done.
[0000.764] Tegraboot started after 154044 us
[0000.768] Basic modules init took 300980 us
[0000.772] Sec Bootdevice Read Time = 216 ms, Read Size = 9476 KB
[0000.778] Sec Bootdevice Write Time = -1940251271 ms, Write Size = -68719477 KB
[0000.785] Next stage binary read took 23829 us
[0000.789] Carveout took 207236 us
[0000.792] CPU initialization took 96692 us
[0000.796] Total time taken by TegraBoot 628737 us
[0000.801] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.2(release):cc5fd7c
NOTICE: BL31: Built : 00:37:02, Jul 20 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0000.942] RamCode = 0
[0000.963] LPDDR4 Training: Read DT: Number of tables = 10
[0000.968] EMC Training (SRC-freq: 204000; DST-freq: 40800)
[0000.973] EMC Training Skipped
[0000.976] EMC Training (SRC-freq: 204000; DST-freq: 68000)
[0000.981] EMC Training Skipped
[0000.984] EMC Training (SRC-freq: 204000; DST-freq: 102000)
[0000.989] EMC Training Skipped
[0000.992] EMC Training (SRC-freq: 204000; DST-freq: 204000)
[0000.997] EMC Training Skipped
[0001.000] EMC Training (SRC-freq: 204000; DST-freq: 408000)
[0001.006] EMC Training Successful
[0001.009] EMC Training (SRC-freq: 204000; DST-freq: 665600)
[0001.015] EMC Training Successful
[0001.018] EMC Training (SRC-freq: 204000; DST-freq: 800000)
[0001.029] EMC Training Successful
[0001.032] EMC Training (SRC-freq: 204000; DST-freq: 1065600)
[0001.055] EMC Training Successful
[0001.058] EMC Training (SRC-freq: 204000; DST-freq: 1331200)
[0001.080] EMC Training Successful
[0001.083] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.102] EMC Training Successful
[0001.106] Switching to 800000 KHz Success
[0001.115] RamCode = 0
[0001.119] DT Write: emc-table@40800 succeeded
[0001.125] DT Write: emc-table@68000 succeeded
[0001.131] DT Write: emc-table@102000 succeeded
[0001.137] DT Write: emc-table@204000 succeeded
[0001.143] DT Write: emc-table@408000 succeeded
[0001.150] DT Write: emc-table@665600 succeeded
[0001.156] DT Write: emc-table@800000 succeeded
[0001.162] DT Write: emc-table@1065600 succeeded
[0001.168] DT Write: emc-table@1331200 succeeded
[0001.174] DT Write: emc-table@1600000 succeeded
[0001.178] LPDDR4 Training: Write DT: Number of tables = 10
[0001.214]
[0001.215] Debug Init done
[0001.217] Marked DTB cacheable
[0001.220] Bootloader DTB loaded at 0x83000000
[0001.225] Marked DTB cacheable
[0001.228] Kernel DTB loaded at 0x83100000
[0001.232] DeviceTree Init done
[0001.251] Pinmux applied successfully
[0001.257] gicd_base: 0x50041000
[0001.261] gicc_base: 0x50042000
[0001.264] Interrupts Init done
[0001.270] Using base:0x60005008 & irq:33 for tick-timer
[0001.275] Using base:0x60005000 for delay-timer
[0001.280] platform_init_timer: DONE
[0001.283] Timer(tick) Init done
[0001.288] osc freq = 38400 khz
[0001.294]
[0001.295] welcome to cboot
[0001.297]
[0001.298] Cboot Version: 00.00.2014.50-t210-fadd1be5
[0001.303] calling constructors
[0001.306] initializing heap
[0001.309] initializing threads
[0001.312] initializing timers
[0001.315] creating bootstrap completion thread
[0001.319] top of bootstrap2()
[0001.322] CPU: ARM Cortex A57
[0001.325] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.330] initializing platform
[0001.366] config for ddr50 mode completed
[0001.370] sdmmc bdev is already initialized
[0001.374] Enable APE clock
[0001.377] Un-powergate APE partition
[0001.380] of_register: registering tegra_udc to of_hal
[0001.385] of_register: registering inv20628-driver to of_hal
[0001.391] of_register: registering ads1015-driver to of_hal
[0001.396] of_register: registering lp8557-bl-driver to of_hal
[0001.402] of_register: registering bq2419x_charger to of_hal
[0001.408] of_register: registering cpc to of_hal
[0001.412] of_register: registering bq27441_fuel_gauge to of_hal
[0001.432] gpio framework initialized
[0001.436] of_register: registering tca9539_gpio to of_hal
[0001.441] of_register: registering tca9539_gpio to of_hal
[0001.446] of_register: registering i2c_bus_driver to of_hal
[0001.452] of_register: registering i2c_bus_driver to of_hal
[0001.457] of_register: registering i2c_bus_driver to of_hal
[0001.463] pmic framework initialized
[0001.466] of_register: registering max77620_pmic to of_hal
[0001.472] regulator framework initialized
[0001.476] of_register: registering tegra_xhci to of_hal
[0001.481] initializing target
[0001.490] gpio_driver_register: register 'tegra_gpio_driver' driver
[0001.502] fixed regulator driver initialized
[0001.574] initializing OF layer
[0001.577] NCK carveout not present
[0001.580] Skipping dts_overrides
[0001.585] of_children_init: Ops found for compatible string nvidia,tegra210-xhci
[0001.593] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.624] I2C Bus Init done
[0001.627] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.642] I2C Bus Init done
[0001.645] of_children_init: Ops found for compatible string ti,tca9539
[0001.659] tca9539_init: i2c bus: 2, slave addr: 0xe8
[0001.665] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.671] of_children_init: Ops found for compatible string ti,tca9539
[0001.685] tca9539_init: i2c bus: 2, slave addr: 0xee
[0001.691] gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.697] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.712] I2C Bus Init done
[0001.715] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.730] I2C Bus Init done
[0001.733] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.748] I2C Bus Init done
[0001.751] of_children_init: Ops found for compatible string maxim,max77620
[0001.767] max77620_init using irq 118
[0001.771] register 'maxim,max77620' pmic
[0001.776] gpio_driver_register: register 'max77620-gpio' driver
[0001.782] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.797] I2C Bus Init done
[0001.802] NCK carveout not present
[0001.806] shim_invoke: No NCT, Calling dts updates
[0001.827] Find /i2c@7000c000's alias i2c0
[0001.831] get eeprom at 1-a2, size 256, type 0
[0001.835] get eeprom at 1-ae, size 256, type 0
[0001.851] Find /i2c@7000c400's alias i2c1
[0001.855] get eeprom at 2-a0, size 256, type 0
[0001.871] Find /i2c@7000c500's alias i2c2
[0001.874] get eeprom at 3-a0, size 256, type 0
[0001.879] get eeprom at 3-ae, size 256, type 0
[0001.891] Find /host1x/i2c@546c0000's alias i2c6
[0001.895] get eeprom at 7-a8, size 256, type 0
[0001.900] pm_ids_update: Updating 1,a2, size 256, type 0
[0001.905] I2C slave not started
[0001.908] I2C write failed
[0001.911] Writing offset failed
[0001.914] eeprom_init: EEPROM read failed
[0001.918] pm_ids_update: eeprom init failed
[0001.922] pm_ids_update: Updating 1,ae, size 256, type 0
[0001.927] I2C slave not started
[0001.930] I2C write failed
[0001.933] Writing offset failed
[0001.936] eeprom_init: EEPROM read failed
[0001.940] pm_ids_update: eeprom init failed
[0001.944] pm_ids_update: Updating 2,a0, size 256, type 0
[0001.949] I2C slave not started
[0001.952] I2C write failed
[0001.955] Writing offset failed
[0001.958] eeprom_init: EEPROM read failed
[0001.962] pm_ids_update: eeprom init failed
[0001.966] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.996] pm_ids_update: The pm board id is 2180-1000-100
[0002.005] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0002.015] pm_ids_update: pm id update successful
[0002.020] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.050] pm_ids_update: The pm board id is 2597-0000-302
[0002.057] Adding plugin-manager/ids/2597-0000-302=/i2c@7000c500:module@0x57
[0002.066] pm_ids_update: pm id update successful
[0002.071] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.078] I2C slave not started
[0002.081] I2C write failed
[0002.084] Writing offset failed
[0002.087] eeprom_init: EEPROM read failed
[0002.091] pm_ids_update: eeprom init failed
[0002.125] updating /chosen/nvidia,wifi-mac node 00:04:4b:63:41:05
[0002.134] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:63:41:06
[0002.144] updating /chosen/nvidia,ethernet-mac node 00:04:4b:63:41:07
[0002.150] Plugin Manager: Parse ODM data 0x00084000
[0002.186] Find /i2c@7000c000's alias i2c0
[0002.190] get eeprom at 1-a2, size 256, type 0
[0002.194] get eeprom at 1-ae, size 256, type 0
[0002.210] Find /i2c@7000c400's alias i2c1
[0002.214] get eeprom at 2-a0, size 256, type 0
[0002.230] Find /i2c@7000c500's alias i2c2
[0002.233] get eeprom at 3-a0, size 256, type 0
[0002.238] get eeprom at 3-ae, size 256, type 0
[0002.250] Find /host1x/i2c@546c0000's alias i2c6
[0002.254] get eeprom at 7-a8, size 256, type 0
[0002.259] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.264] I2C slave not started
[0002.267] I2C write failed
[0002.270] Writing offset failed
[0002.273] eeprom_init: EEPROM read failed
[0002.277] pm_ids_update: eeprom init failed
[0002.281] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.286] I2C slave not started
[0002.289] I2C write failed
[0002.292] Writing offset failed
[0002.295] eeprom_init: EEPROM read failed
[0002.299] pm_ids_update: eeprom init failed
[0002.303] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.308] I2C slave not started
[0002.311] I2C write failed
[0002.314] Writing offset failed
[0002.317] eeprom_init: EEPROM read failed
[0002.321] pm_ids_update: eeprom init failed
[0002.325] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.355] pm_ids_update: The pm board id is 2180-1000-100
[0002.363] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0002.370] pm_ids_update: pm id update successful
[0002.374] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.404] pm_ids_update: The pm board id is 2597-0000-302
[0002.412] Adding plugin-manager/ids/2597-0000-302=/i2c@7000c500:module@0x57
[0002.419] pm_ids_update: pm id update successful
[0002.423] pm_ids_update: Updating 7,a8, size 256, type 0
[0002.431] I2C slave not started
[0002.434] I2C write failed
[0002.437] Writing offset failed
[0002.440] eeprom_init: EEPROM read failed
[0002.444] pm_ids_update: eeprom init failed
[0002.477] Chip UID is 00000001640d06c90000000006038100
[0002.485] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03218160289850008103 androidboot.security=non-secure
[0002.509] Add serial number:03218160289850008103 as DT property
[0002.517] calling apps_init()
[0002.521] Found 18 GPT partitions in "sdmmc3_user"
[0002.526] Proceeding to Cold Boot
[0002.529] starting app android_boot_app
[0002.533] Device state: unlocked
[0002.536] display console init
[0002.542] skip-display-init in bootloader
[0002.545] set_instance_and_out_type: invalid out_type
[0002.550] display_console_init: No display init
[0002.561] Gpio keyboard init success
[0002.565] bct_init bctinit
[0002.567] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0[0002.583] DT entry for leds-pwm not found
002.575] BMP partition read failed!
[0002.590] blob_init: blob-partition BMP header read failed
[0002.596] load_bmp_blob: BMP blob initialization failed
[0002.601] Could not load/initialize BMP blob...ignoring
[0002.606] bl_battery_charging: connected to external power supply
[0002.618] display_console_ioctl: No display init
[0002.622] switch_backlight failed
[0002.625] bct_init bctinit
[0002.628] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0002.635] MSC Partition not found
[0002.639] bct_init bctinit
[0002.641] bct_init bctinit
[0002.645] blob_init: USP partition does not have valid Blob
[0002.650] Loading android kernel
[0002.654] Default: NOT skip verified boot.
[0002.658] Verified boot state = Orange
[0002.665] display_console_clear: No display init
[0002.669] kernel load address: 0x80080000, size: 503741 bytes
[0002.675] ramdisk load address: 0x84100000, size: 0 bytes
[0002.680] load kernel from storage
[0002.685] decompressor handler not found
[0002.695] Successfully loaded kernel and ramdisk images
[0002.703] bct_init bctinit
[0002.705] device_query_partition_size: failed to open partition sdmmc3_user:BMP !
[0002.713] BMP partition read failed!
[0002.716] blob_init: blob-partition BMP header read failed
[0002.722] load_bmp_blob: BMP blob initialization failed
[0002.727] bmp blob is not loaded and initialized
[0002.732] Failed to display boot-logo
[0002.735] NCK carveout not present
[0002.738] Skipping dts_overrides
[0002.742] NCK carveout not present
[0002.745] shim_invoke: No NCT, Calling dts updates
[0002.767] Find /i2c@7000c000's alias i2c0
[0002.771] get eeprom at 1-a2, size 256, type 0
[0002.775] get eeprom at 1-ae, size 256, type 0
[0002.792] Find /i2c@7000c400's alias i2c1
[0002.796] get eeprom at 2-a0, size 256, type 0
[0002.812] Find /i2c@7000c500's alias i2c2
[0002.816] get eeprom at 3-a0, size 256, type 0
[0002.820] get eeprom at 3-ae, size 256, type 0
[0002.833] Find /host1x/i2c@546c0000's alias i2c6
[0002.837] get eeprom at 7-a8, size 256, type 0
[0002.842] pm_ids_update: Updating 1,a2, size 256, type 0
[0002.847] I2C slave not started
[0002.850] I2C write failed
[0002.853] Writing offset failed
[0002.856] eeprom_init: EEPROM read failed
[0002.860] pm_ids_update: eeprom init failed
[0002.864] pm_ids_update: Updating 1,ae, size 256, type 0
[0002.869] I2C slave not started
[0002.872] I2C write failed
[0002.875] Writing offset failed
[0002.878] eeprom_init: EEPROM read failed
[0002.882] pm_ids_update: eeprom init failed
[0002.886] pm_ids_update: Updating 2,a0, size 256, type 0
[0002.891] I2C slave not started
[0002.894] I2C write failed
[0002.897] Writing offset failed
[0002.900] eeprom_init: EEPROM read failed
[0002.904] pm_ids_update: eeprom init failed
[0002.908] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.938] pm_ids_update: The pm board id is 2180-1000-100
[0002.947] Adding plugin-manager/ids/2180-1000-100=/i2c@7000c500:module@0x50
[0002.957] pm_ids_update: pm id update successful
[0002.962] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.992] pm_ids_update: The pm board id is 2597-0000-302
[0003.000] Adding plugin-manager/ids/2597-0000-302=/i2c@7000c500:module@0x57
[0003.009] pm_ids_update: pm id update successful
[0003.013] pm_ids_update: Updating 7,a8, size 256, type 0
[0003.021] I2C slave not started
[0003.024] I2C write failed
[0003.026] Writing offset failed
[0003.029] eeprom_init: EEPROM read failed
[0003.033] pm_ids_update: eeprom init failed
[0003.068] updating /chosen/nvidia,wifi-mac node 00:04:4b:63:41:05
[0003.077] updating /chosen/nvidia,bluetooth-mac node 00:04:4b:63:41:06
[0003.086] updating /chosen/nvidia,ethernet-mac node 00:04:4b:63:41:07
[0003.092] Plugin Manager: Parse ODM data 0x00084000
[0003.115] shim_cmdline_install: /chosen/bootargs: androidboot.modem=none androidboot.serialno=03218160289850008103 androidboot.security=non-secure
[0003.129] Add serial number:03218160289850008103 as DT property
[0003.137] Updated bpmp info to DTB
[0003.144] Updated initrd info to DTB
[0003.147] "proc-board" doesn't exist, creating
[0003.155] Updated board info to DTB
[0003.158] "pmu-board" doesn't exist, creating
[0003.166] Updated board info to DTB
[0003.169] "display-board" doesn't exist, creating
[0003.176] Updated board info to DTB
[0003.179] "reset" doesn't exist, creating
[0003.184] Updated reset info to DTB
[0003.187] display_console_ioctl: No display init
[0003.192] display_console_ioctl: No display init
[0003.196] display_console_ioctl: No display init
[0003.204] display_console_ioctl: No display init
[0003.211] Cmdline: androidboot.modem=none androidboot.serialno=03218160289850008103 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange
[0003.276] Updated bootarg info to DTB
[0003.283] Updated memory info to DTB
[0003.292] set vdd_core voltage to 1075 mv
[0003.296] setting 'vdd-core' regulator to 1075000 micro volts
[0003.302] nvdumper Carveout: Base = 0xff23f000 and Size = 0x80000
[0003.309] bct_init bctinit
[0003.311] Starting Bpmp FW
[0003.314] BPMP-FW Carveout: Base = 0xff2c0000 and Size = 0x40000
U-Boot 2016.07-g0ce7ca2 (Jul 20 2017 - 00:37:03 -0700)
TEGRA210
Model: NVIDIA P2371-2180
Board: NVIDIA P2371-2180
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
223 bytes read in 82 ms (2 KiB/s)
p2371-2180 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/initrd
0 bytes read in 72 ms (0 Bytes/s)
Retrieving file: /boot/Image
21033520 bytes read in 529 ms (37.9 MiB/s)
append: androidboot.modem=none androidboot.serialno=03218160289850008103 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
## Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831b03bb
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (root@hong-H61H2-M2) (gcc version 4.8.5 (GCC) ) #7 SMP PREEMPT Tue Sep 5 16:18:42 KST 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31360 r8192 d30080 u69632
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: androidboot.modem=none androidboot.serialno=03218160289850008103 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1075 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3372500K/4173824K available (11009K kernel code, 1816K rwdata, 6400K rodata, 1208K init, 644K bss, 96812K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001181000 - 0xffffffc0012af000 ( 1208 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001180c04 ( 17412 KB)
[ 0.000000] .data : 0xffffffc0012c9000 - 0xffffffc00148f230 ( 1817 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001709] Console: colour dummy device 80x25
[ 0.001735] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001749] pid_max: default: 32768 minimum: 301
[ 0.001825] Security Framework initialized
[ 0.001837] SELinux: Initializing.
[ 0.001935] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.001946] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002596] Initializing cgroup subsys freezer
[ 0.002613] Initializing cgroup subsys debug
[ 0.002868] CPU0 ipc=1024
[ 0.002892] CPU1 ipc=1024
[ 0.002913] CPU2 ipc=1024
[ 0.002935] CPU3 ipc=1024
[ 0.002996] ASID allocator initialised with 65536 entries
[ 0.026992] tegra-id: chipid=22117.
[ 0.027007] tegra-id: opt_subrevision=0.
[ 0.027027] Tegra Speedo/IDDQ fuse revision 4
[ 0.027037] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.027045] Tegra: CPU Process ID 1, SoC Process ID 1, GPU Process ID 0
[ 0.027053] Tegra: CPU Speedo Value 2132, SoC Speedo Value 2015, GPU Speedo Value 2137
[ 0.027061] Tegra: CPU IDDQ Value 2868, SoC IDDQ Value 2984, GPU IDDQ Value 4040
[ 0.027084] Tegra Revision: A02 SKU: 0x17 CPU Process: 1 SoC Process: 1
[ 0.028419] DTS File Name: /home/hong/jetpack_3.1/64_TX1/Linux_for_Tegra_64_tx1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.028432] DTB Build time: Sep 6 2017 10:34:34
[ 0.044789] CPU1: Booted secondary processor [411fd071]
[ 0.056755] CPU2: Booted secondary processor [411fd071]
[ 0.068754] CPU3: Booted secondary processor [411fd071]
[ 0.068841] Brought up 4 CPUs
[ 0.068863] SMP: Total of 4 processors activated.
[ 0.068875] CPU: All CPU(s) started at EL2
[ 0.068905] alternatives: patching kernel code
[ 0.071311] devtmpfs: initialized
[ 0.143835] Initilizing CustomIPI irq domain
[ 0.144167] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.157125] pinctrl core: initialized pinctrl subsystem
[ 0.157335] OS set in device tree is not L4T.
[ 0.157723] regulator-dummy: no parameters
[ 0.157933] Initializing plugin-manager
[ 0.157991] Plugin module not found
[ 0.160043] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.160077] Adding domain adsp-pd to PM domain ape-pd
[ 0.165161] NET: Registered protocol family 16
[ 0.181870] console [pstore-1] enabled
[ 0.181880] pstore: Registered ramoops as persistent store backend
[ 0.181891] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.192236] cpuidle: using governor ladder
[ 0.204226] cpuidle: using governor menu
[ 0.204572] bpmp: mail init ok
[ 0.205524] vdso: 2 pages (1 code @ ffffffc0012d1000, 1 data @ ffffffc0012d0000)
[ 0.205565] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.207904] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.208827] tegra_powergate_init: DONE
[ 0.208855] DTS File Name: /home/hong/jetpack_3.1/64_TX1/Linux_for_Tegra_64_tx1/sources/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-p2597-2180-a01-devkit.dts
[ 0.208870] DTB Build time: Sep 6 2017 10:34:34
[ 0.209886] Error: Driver 'tegra-mc' is already registered, aborting...
[ 0.211530] platform tegra-carveouts: SMMU isn't ready yet
[ 0.212288] platform tegra-carveouts: domain=ffffffc0fa10f318 allocates as[0]=ffffffc0fa1440a8
[ 0.212336] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.212562] platform smmu_test: domain=ffffffc0fa10f618 allocates as[0]=ffffffc0fa144110
[ 0.212880] platform 70016000.bpmp: domain=ffffffc0fa10f918 allocates as[0]=ffffffc0fa144178
[ 0.213582] bpmp: ping status is 0
[ 0.213680] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.213920] bpmp 70016000.bpmp: probe ok
[ 0.214580] mc: mapped MMIO address: 0xffffff800007e000 -> 0x70019000
[ 0.214675] mc: mapped MMIO address: 0xffffff80000b6000 -> 0x7001c000
[ 0.214767] mc: mapped MMIO address: 0xffffff80000dc000 -> 0x7001d000
[ 0.214841] mc-err: Set intmask: 0x23d40
[ 0.226485] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.226516] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.226548] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.226576] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.226606] GPIO line 148 (cam0-rst) hogged as output/low
[ 0.226632] GPIO line 151 (cam0-pwdn) hogged as output/low
[ 0.226658] GPIO line 149 (cam1-rst) hogged as output/low
[ 0.226684] GPIO line 152 (cam1-pwdn) hogged as output/low
[ 0.226788] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.229323] platform 70006000.serial: domain=ffffffc0fa1afe18 allocates as[0]=ffffffc0fa1441e0
[ 0.230473] platform sound: domain=ffffffc0fa218718 allocates as[0]=ffffffc0fa144248
[ 0.232987] platform tegradc.0: domain=ffffffc0fa21e918 allocates as[0]=ffffffc0fa1442b0
[ 0.233577] platform tegradc.0: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.233968] platform tegradc.1: domain=ffffffc0fa21ec18 allocates as[0]=ffffffc0fa144318
[ 0.234559] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.237541] platform 57000000.gpu: domain=ffffffc0fa22b118 allocates as[0]=ffffffc0fa144380
[ 0.237596] platform 57000000.gpu: domain=ffffffc0fa22b118 allocates as[1]=ffffffc0fa1443e8
[ 0.237649] platform 57000000.gpu: domain=ffffffc0fa22b118 allocates as[2]=ffffffc0fa144450
[ 0.237696] platform 57000000.gpu: domain=ffffffc0fa22b118 allocates as[3]=ffffffc0fa1444b8
[ 0.238480] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.238501] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.238512] tegra-pmc: ### PMC reset source: Software reset
[ 0.238522] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.238863] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.238875] tegra-pmc: Clear bootloader IO dpd settings
[ 0.240341] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[ 0.244317] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[ 0.248315] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[ 0.252315] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[ 0.252330] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[ 0.256314] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[ 0.260317] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[ 0.264315] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[ 0.264330] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[ 0.268313] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[ 0.272313] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[ 0.272326] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.272385] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.275537] platform 1003000.pcie-controller: domain=ffffffc0fa278218 allocates as[0]=ffffffc0fa144520
[ 0.277904] platform sdhci-tegra.3: domain=ffffffc0fa27e318 allocates as[0]=ffffffc0fa144588
[ 0.278496] platform sdhci-tegra.0: domain=ffffffc0fa27e718 allocates as[0]=ffffffc0fa1445f0
[ 0.284116] vdd-ac-bat: 5000 mV
[ 0.285359] vdd-cpu-fixed: 1000 mV
[ 0.289241] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.289581] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.313443] ACPI: Interpreter disabled.
[ 0.314260] SCSI subsystem initialized
[ 0.314557] usbcore: registered new interface driver usbfs
[ 0.314619] usbcore: registered new interface driver hub
[ 0.314709] usbcore: registered new device driver usb
[ 0.317904] gpiochip_add_data: registered GPIOs 496 to 511 on device: tca9539
[ 0.319375] gpiochip_add_data: registered GPIOs 480 to 495 on device: tca9539
[ 0.322518] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.324159] GPIO line 474 (spmic-default-output-high) hogged as output/high
[ 0.324294] gpiochip_add_data: registered GPIOs 472 to 479 on device: max77620-gpio
[ 0.328351] vdd-core: 600 <--> 1400 mV at 1075 mV
[ 0.332343] vddio-ddr: at 1125 mV
[ 0.333081] vdd-pre-reg: 1350 mV
[ 0.336220] vdd-1v8: 1800 mV
[ 0.340221] avdd-sys: 1200 mV
[ 0.344219] vdd-pex: 1050 mV
[ 0.344823] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.345522] vdd-cam-hv: 2800 mV
[ 0.348221] vdd-rtc: 850 mV
[ 0.348931] avdd-ts-hv: 3300 mV
[ 0.349638] vdd-ts: 1800 mV
[ 0.352220] vdd-gen-pll-edp: 1050 mV
[ 0.356220] vdd-hdmi-dp: 1050 mV
[ 0.356856] max77620 4-003c: max77620 probe successful
[ 0.358799] media: Linux media interface: v0.10
[ 0.358860] Linux video capture interface: v2.00
[ 0.366493] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.366828] Advanced Linux Sound Architecture Driver Initialized.
[ 0.370174] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.370209] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.370280] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.370308] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.373162] regulator_get() failed for (dvfs,vdd-cpu), -19
[ 0.373175] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.376225] vdd-3v3: 3300 mV
[ 0.380219] max77620-gpio7: 1050 mV
[ 0.380530] lcd-bl-en: 1800 mV
[ 0.380827] en-vdd-sd: 3300 mV
[ 0.381496] en-vdd-cam: 1800 mV
[ 0.384220] vdd-sys-boost: 5000 mV
[ 0.384908] vdd-hdmi: 5000 mV
[ 0.385141] aux-3v3: 3300 mV
[ 0.385374] snsr_pm: 3300 mV
[ 0.388222] vdd-disp-3v0: 3000 mV
[ 0.388903] vdd-fan: 5000 mV
[ 0.389184] usb-vbus1: 5000 mV
[ 0.389855] en-vdd-ts-1v8: 1800 mV
[ 0.390511] en-vdd-ts-hv-3v3: 3300 mV
[ 0.391344] en-vdd-disp-3v3: 3300 mV
[ 0.391990] en-mdm-pwr-3v7: 3700 mV
[ 0.392846] en-vdd-disp-1v8: 1800 mV
[ 0.393515] en-vdd-cam-hv-2v8: 2800 mV
[ 0.393802] rtl-5v0: 5000 mV
[ 0.394089] en-usb-vbus2: 5000 mV
[ 0.394738] en-vdd-cam-1v2: 1200 mV
[ 0.395013] en-vdd-vcm-2v8: 2800 mV
[ 0.397810] extcon-gpio-states extcon:extcon@1: Cable state 1
[ 0.399007] clocksource: Switched to clocksource arch_sys_counter
[ 0.439053] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.439409] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.439573] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.439587] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.439602] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.439634] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.439647] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.439937] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.440634] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.441376] pnp: PnP ACPI: disabled
[ 0.453240] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.455149] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.455541] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.455722] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.457301] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.457528] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.457741] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.458923] isomgr_init(): iso emc max clk=1600000KHz
[ 0.458935] isomgr_init(): max_iso_bw=11520000KB
[ 0.459131] NET: Registered protocol family 2
[ 0.459676] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.459842] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.460102] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.460189] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.460240] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.460468] NET: Registered protocol family 1
[ 0.460758] RPC: Registered named UNIX socket transport module.
[ 0.460771] RPC: Registered udp transport module.
[ 0.460780] RPC: Registered tcp transport module.
[ 0.460790] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.461031] Trying to unpack rootfs image as initramfs...
[ 0.472217] host1x 50000000.host1x: initialized
[ 0.473769] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.476997] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.477112] audit: initializing netlink subsys (disabled)
[ 0.477157] audit: type=2000 audit(0.467:1): initialized
[ 0.489189] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.489673] fuse init (API version 7.23)
[ 0.492266] io scheduler noop registered (default)
[ 0.492285] io scheduler deadline registered
[ 0.492595] io scheduler cfq registered
[ 0.497750] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.497773] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x89eac12
[ 0.497786] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.499291] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.499311] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.499327] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.499350] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.499375] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.499388] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.499410] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.499431] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.499456] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.499484] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.499509] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.499535] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.499560] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.499589] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.500021] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.501053] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[ 0.502139] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.502867] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.507623] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.507676] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.507689] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.511256] tsec 54500000.tsec: initialized
[ 0.512573] tsec 54100000.tsecb: initialized
[ 0.515352] nvdec 54480000.nvdec: initialized
[ 0.521406] falcon 54340000.vic: initialized
[ 0.523045] falcon 544c0000.nvenc: initialized
[ 0.524177] falcon 54380000.nvjpg: initialized
[ 0.526111] DC OR NODE connected to /host1x/dsi
[ 0.526194] display board info: id 0xffff, fab 0x0
[ 0.526235] invalid panel compatible
[ 0.526279] display board info: id 0xffff, fab 0x0
[ 0.526312] invalid panel compatible
[ 0.526346] No ddc device node
[ 0.526526] DC OR NODE connected to /host1x/sor1
[ 0.526553] display board info: id 0xffff, fab 0x0
[ 0.526587] invalid panel compatible
[ 0.526630] display board info: id 0xffff, fab 0x0
[ 0.526662] invalid panel compatible
[ 0.526832] tegradc tegradc.1: DT parsed successfully
[ 0.526877] tegradc tegradc.1: Display dc.ffffff8000980000 registered with id=0
[ 0.527965] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.528138] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1020000, vi_iso_bw=750000, max_bw=1020000
[ 0.528937] display board info: id 0xffff, fab 0x0
[ 0.528975] invalid panel compatible
[ 0.534080] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.536208] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.537743] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.538028] kfuse 7000fc00.kfuse: initialized
[ 0.540015] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.540970] clk_cbus_round_rate: no gbus parent
[ 0.540986] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.541500] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.541517] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.541565] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.542990] vdd-gpu: applied init 1000000uV constraint
[ 0.543054] vdd-gpu: 710 <--> 1320 mV at 1000 mV
[ 0.543103] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.543474] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.543587] No Device Node present for smmu client: serial8250 !!
[ 0.543601] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.543615] No Device Node present for smmu client: serial8250 !!
[ 0.543627] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.544705] No Device Node present for smmu client: serial8250 !!
[ 0.544721] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.544747] No Device Node present for smmu client: serial8250 !!
[ 0.544759] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.545383] console [ttyS0] disabled
[ 0.545449] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 0.606281] tegradc tegradc.1: probed
[ 2.585332] console [ttyS0] enabled
[ 2.586733] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 2.587277] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 2.587628] serial-tegra 70006300.serial: RX in PIO mode
[ 2.587735] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 2.594126] gk20a 57000000.gpu: platform probe failed
[ 2.600819] brd: module loaded
[ 2.606350] loop: module loaded
[ 2.606973] zram: Added device: zram0
[ 2.606983] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[ 2.607228] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.607234] nct1008_nct72 0-004c: starting parse dt
[ 2.607314] nct1008_nct72 0-004c: success parsing dt
[ 2.607568] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 2.642387] tmp451: Enabled overheat logging at 102.00C
[ 2.642530] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 2.645359] THERMAL EST: found 2 subdevs
[ 2.645364] THERMAL EST num_resources: 0
[ 2.645369] [THERMAL EST subdev 0]
[ 2.645376] [THERMAL EST subdev 1]
[ 2.645715] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.645717] THERMAL EST: thz register success.
[ 2.645859] THERMAL EST: end of probe, return err: 0
[ 2.645942] tegra_profiler: Branch: Dev
[ 2.645945] tegra_profiler: Version: 1.109
[ 2.645947] tegra_profiler: Samples version: 37
[ 2.645949] tegra_profiler: IO version: 21
[ 2.645956] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645960] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.645965] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645969] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.645973] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645977] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.645981] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.645984] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.646192] tegra_profiler: auth: init
[ 2.646702] tegra-ahci 70027000.sata: Missing devslp-active state
[ 2.647641] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 2.648154] spi-tegra114 7000d400.spi: Static pin configuration used
[ 2.648959] spi-tegra114 7000da00.spi: Static pin configuration used
[ 2.650366] tun: Universal TUN/TAP device driver, 1.6
[ 2.650369] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.650787] PPP generic driver version 2.4.2
[ 2.650944] PPP BSD Compression module registered
[ 2.650952] PPP Deflate Compression module registered
[ 2.650976] PPP MPPE Compression module registered
[ 2.650991] NET: Registered protocol family 24
[ 2.651101] usbcore: registered new interface driver r8152
[ 2.651159] usbcore: registered new interface driver asix
[ 2.651214] usbcore: registered new interface driver ax88179_178a
[ 2.651259] usbcore: registered new interface driver cdc_ether
[ 2.651317] usbcore: registered new interface driver smsc95xx
[ 2.651361] usbcore: registered new interface driver net1080
[ 2.651406] usbcore: registered new interface driver cdc_subset
[ 2.651454] usbcore: registered new interface driver zaurus
[ 2.651529] usbcore: registered new interface driver cdc_ncm
[ 2.651668] usbcore: registered new interface driver usb-storage
[ 2.651774] usbcore: registered new interface driver usbserial
[ 2.651815] usbcore: registered new interface driver ftdi_sio
[ 2.651847] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.651896] usbcore: registered new interface driver option
[ 2.651925] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.651964] usbcore: registered new interface driver pl2303
[ 2.651993] usbserial: USB Serial support registered for pl2303
[ 2.653045] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 2.682549] Console: switching to colour frame buffer device 480x135
[ 2.786210] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 2.810624] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 2.810653] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 2.811167] i2c /dev entries driver
[ 2.813141] IR NEC protocol handler initialized
[ 2.813148] IR Sharp protocol handler initialized
[ 2.813155] IR XMP protocol handler initialized
[ 2.813231] usbcore: registered new interface driver uvcvideo
[ 2.813233] USB Video Class driver (1.1.1)
[ 2.814418] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.848424] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 2.848432] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 2.848938] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 2.848948] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 2.849184] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.849195] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 2.849203] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 2.849468] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 2.849474] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 2.849482] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 2.849489] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 2.849905] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 2.860737] tegra_aotag tegra-aotag: Registering sensor 0
[ 2.860806] tegra_aotag tegra-aotag: Invalid temp readout
[ 2.860813] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 2.860820] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 2.861649] FAN dev name: pwm-fan
[ 2.861694] FAN:gpio request success.
[ 2.861760] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.862044] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 2.862052] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.865293] pwm_fan_driver pwm-fan: fan tach request irq success
[ 2.865302] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.865394] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.865401] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.865408] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.865415] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.865422] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.865428] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.865435] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.865441] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.865448] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.865455] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.869266] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 2.869586] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 2.869910] device-mapper: uevent: version 1.0.3
[ 2.870226] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.879792] sdhci: Secure Digital Host Controller Interface driver
[ 2.879795] sdhci: Copyright(c) Pierre Ossman
[ 2.879804] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.880464] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 2.880516] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 2.880541] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 2.950334] tegra-se 70012000.se: tegra_se_probe: complete
[ 2.951087] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.951130] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 2.951475] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 2.951498] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 2.957519] usbcore: registered new interface driver usbhid
[ 2.957521] usbhid: USB HID core driver
[ 2.980662] parse_throttle_dt_data: Num cap clks = 6
[ 2.980668] parse_throttle_dt_data: clk=cclk_g type=2
[ 2.980677] parse_throttle_dt_data: clk=gpu type=4
[ 2.980718] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 2.980754] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 2.980796] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 2.980800] parse_throttle_dt_data: clk=emc type=3
[ 3.002858] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.003152] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 3.006904] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.008459] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 3.011648] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.011656] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.011664] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.011670] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.011897] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.011903] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.011937] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.011943] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.035110] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 3.035997] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.036051] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 3.036139] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 3.036195] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 3.036219] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.036929] tegra210-i2s tegra210-i2s.0: Missing prop fsync-width for I2S0
[ 3.038015] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 3.038294] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 3.038697] tegra210-i2s tegra210-i2s.4: Missing prop fsync-width for I2S4
[ 3.040003] en-vdd-sd: supplied by vdd-3v3
[ 3.044466] OPE platform probe
[ 3.044657] OPE platform probe successful
[ 3.044711] OPE platform probe
[ 3.044896] OPE platform probe successful
[ 3.046676] tegra-snd-t210ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 3.079590] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.079828] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.080054] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.080286] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.080512] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.080737] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.080970] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.081203] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.081442] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.081669] tegra-snd-t210ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.089920] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.102978] mmc0: MAN_BKOPS_EN bit is not set
[ 3.106053] input: tegra-snd-t210ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input0
[ 3.107262] tegra-snd-t210ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[ 3.107268] tegra-snd-t210ref-mobile-rt565x sound: This is a dummy codec
[ 3.108077] GACT probability NOT on
[ 3.108088] Mirror/redirect action on
[ 3.108103] u32 classifier
[ 3.108105] Actions configured
[ 3.108116] Netfilter messages via NETLINK v0.30.
[ 3.108169] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.108588] ctnetlink v0.93: registering with nfnetlink.
[ 3.109229] xt_time: kernel timezone is -0000
[ 3.109379] ipip: IPv4 over IPv4 tunneling driver
[ 3.110013] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.110143] arp_tables: (C) 2002 David S. Miller
[ 3.110217] Initializing XFRM netlink socket
[ 3.111109] NET: Registered protocol family 10
[ 3.116278] mip6: Mobile IPv6
[ 3.116304] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.116494] sit: IPv6 over IPv4 tunneling driver
[ 3.117592] NET: Registered protocol family 17
[ 3.117619] NET: Registered protocol family 15
[ 3.117657] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.117688] Key type dns_resolver registered
[ 3.121275] Registered cp15_barrier emulation handler
[ 3.162867] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input1
[ 3.164840] mmc0: Skipping tuning since strobe enabled
[ 3.254452] mmc0: new HS400 MMC card at address 0001
[ 3.273009] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 3.289898] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 3.302486] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 3.587725] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 4.024521] tegradc tegradc.1: fb registered
[ 4.053332] tegradc tegradc.1: nominal-pclk:297000000 parent:297000000 div:1.0 pclk:297000000 294030000~323730000
[ 4.064481] tegradc tegradc.1: hdmi: pclk:297000K, set prod-setting:prod_c_hdmi_150m_300m
[ 4.075534] isp 54600000.isp: initialized
[ 4.081163] isp 54680000.isp: initialized
[ 4.089177] clk_cbus_recalc_rate: no gbus parent
[ 4.093876] clk_cbus_round_rate: no gbus parent
[ 4.098454] clk_cbus_round_rate: no gbus parent
[ 4.103050] clk_cbus_recalc_rate: no gbus parent
[ 4.108265] clk_cbus_recalc_rate: no gbus parent
[ 4.112955] clk_cbus_round_rate: no gbus parent
[ 4.117546] clk_cbus_round_rate: no gbus parent
[ 4.122143] clk_cbus_recalc_rate: no gbus parent
[ 4.126844] tegra_dvfs: GPU-cap: registered
[ 4.131232] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.139985] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.152142] tegra dvfs: vdd-gpu: nominal 1080mV, offset 710000uV, step 10000uV, scaling enabled
[ 4.171701] tegra_dvfs: vdd-gpu-vts: registered
[ 4.178264] xhci-tegra 70090000.xusb: can't get usb3-0 phy (-517)
[ 4.185166] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 4.195188] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x89eac12
[ 4.202860] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 4.208038] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 4.208049] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 4.208056] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 4.208070] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 4.208085] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 4.208092] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 4.208105] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 4.208119] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 4.208136] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 4.208155] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 4.208173] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 4.208190] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 4.208208] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 4.208228] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 4.208954] usb-vbus1: supplied by vdd-3v3
[ 4.211405] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 4.214184] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 4.214427] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 4.215172] clk_cbus_round_rate: no gbus parent
[ 4.215179] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 4.215513] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 4.215761] tegra-ahci 70027000.sata: Missing devslp-active state
[ 4.216723] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 4.216735] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 4.217619] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 4.223145] scsi host0: tegra_ahci
[ 4.224752] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 4.225362] tegradc tegradc.1: nominal-pclk:297000000 parent:297000000 div:1.0 pclk:297000000 294030000~323730000
[ 4.227723] scsi host1: tegra_ahci
[ 4.227972] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 371
[ 4.227976] ata2: DUMMY
[ 4.230982] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 4.231089] tegra-xudc-new 700d0000.xudc: device mode on
[ 4.232658] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 4.234071] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 4.234509] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 4.235318] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 4.239961] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 4.239964] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 4.242096] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 4.242098] xhci-tegra 70090000.xusb: Falling back to user helper
[ 4.244893] input: gpio-keys as /devices/gpio-keys/input/input2
[ 4.278919] tegra_rtc 7000e000.rtc: setting system clock to 2017-09-06 02:27:10 UTC (1504664830)
[ 4.279838] vi 54080000.vi: vi_probe: ++
[ 4.286261] vi 54080000.vi: initialized
[ 4.289362] vi 54080000.vi: all channel register failed
[ 4.291066] Disable partitions left on by BL
[ 4.291068] disb
[ 4.291468] mmc1 tuning done saved tap delay=49
[ 4.291469] mmc1: hw tuning done ...
[ 4.291473] mmc1: tuning_window[0]: 0x8fffffff
[ 4.291477] mmc1: tuning_window[1]: 0xffffffff
[ 4.291480] mmc1: tuning_window[2]: 0xffffff8f
[ 4.291484] mmc1: tuning_window[3]: 0x7fff8fff
[ 4.291487] mmc1: tuning_window[4]: 0x0
[ 4.291490] mmc1: tuning_window[5]: 0x0
[ 4.291493] mmc1: tuning_window[6]: 0x0
[ 4.291496] mmc1: tuning_window[7]: 0x0
[ 4.291498] sdhci: Tap value: 49 | Trim value: 8
[ 4.291500] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.294461] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.294493] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.301308] DRAM derating cdev registered.
[ 4.302169] vdd-cpu-fixed: disabling
[ 4.302179] vdd-cam-hv: disabling
[ 4.302262] avdd-ts-hv: disabling
[ 4.302327] vdd-ts: disabling
[ 4.302391] max77620-gpio7: disabling
[ 4.302532] lcd-bl-en: disabling
[ 4.302535] en-vdd-sd: disabling
[ 4.302536] en-vdd-cam: disabling
[ 4.302539] aux-3v3: disabling
[ 4.302541] snsr_pm: disabling
[ 4.302543] vdd-disp-3v0: disabling
