Hi Guys.
I’m trying to change tegradc.1 to dsi on my custom board.
(DSI LCD is Raspberry Pi LCD : https://kr.element14.com/raspberry-pi/raspberrypi-display/raspberry-pi-7inch-touchscreen/dp/2473872)
I’ve followed advises from (DSI initialization) topic.
I’ve modified below files and copied the files to fit each location.
panel-itall-dsipilcd.c (2.6 KB)
panel-itall-dsipilcd.dtsi (2.3 KB)
tegra210-p3448-0000-p3449-0000-b00.dts (3.5 KB)
tegra210-p3448-0000-p3449-0000-b00-hdmi-dsi.dts (1.8 KB)
But it wasn’t set up to dsi.
Which part should I change to get the results I want?
Is there anyone who solved this problem?
type or paste code here
U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: NVIDIA P3450-0000
DRAM: 4 GiB
MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1147 bytes read in 27 ms (41 KiB/s)
L4T boot options
1: primary kernel
2: Custom 40-pin Header Config
Enter choice: 2: Custom 40-pin Header Config
Retrieving file: /boot/initrd
7159841 bytes read in 329 ms (20.8 MiB/s)
Retrieving file: /boot/Image
34535432 bytes read in 1520 ms (21.7 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Retrieving file: /boot/kernel_tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb
244763 bytes read in 35 ms (6.7 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000083000000, end 000000008303ec1a
copying carveout for /host1x@50000000/dc@54200000...
copying carveout for /host1x@50000000/dc@54240000...
DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
DT property /chosen/nvidia,wifi-mac missing in source; can't copy
DT property /psci/nvidia,system-lp0-disable missing in source; can't copy
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (root@nano-desktop) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) ) #3 SMP PREEMPT Thu Jul 8 12:36:35 KST 2021
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29552(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3568352K/4159488K available (15294K kernel code, 2942K rwdata, 6888K rodata, 8576K init, 609K bss, 116000K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009630000 ( 6912 KB)
[ 0.000000] .init : 0xffffff8009630000 - 0xffffff8009e90000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e90000 - 0xffffff800a16f808 ( 2943 KB)
[ 0.000000] .bss : 0xffffff800a16f808 - 0xffffff800a207cbc ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.010032] Console: colour dummy device 80x25
[ 0.014676] console [tty0] enabled
[ 0.018189] bootconsole [uart8250] disabled
[ 0.022510] kmemleak: Kernel memory leak detector disabled
[ 0.022537] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.022560] pid_max: default: 32768 minimum: 301
[ 0.023013] Security Framework initialized
[ 0.023240] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.023256] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.024361] ftrace: allocating 47214 entries in 185 pages
[ 0.192697] ASID allocator initialised with 65536 entries
[ 0.232075] tegra-id: chipid=22117.
[ 0.232104] tegra-id: opt_subrevision=0.
[ 0.232128] Tegra Speedo/IDDQ fuse revision 4
[ 0.232137] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.232148] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.232159] Tegra: CPU Speedo Value 2042, SoC Speedo Value 1937, GPU Speedo Value 2046
[ 0.232171] Tegra: CPU IDDQ Value 1924, SoC IDDQ Value 2168, GPU IDDQ Value 2590
[ 0.232196] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 0
[ 0.232219] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.232238] DTB Build time: Feb 19 2021 08:42:41
[ 0.281288] CPU1: Booted secondary processor [411fd071]
[ 0.313207] CPU2: Booted secondary processor [411fd071]
[ 0.345156] CPU3: Booted secondary processor [411fd071]
[ 0.345246] Brought up 4 CPUs
[ 0.345299] SMP: Total of 4 processors activated.
[ 0.345317] CPU features: detected feature: 32-bit EL0 Support
[ 0.345596] CPU: All CPU(s) started at EL2
[ 0.345624] alternatives: patching kernel code
[ 0.353841] devtmpfs: initialized
[ 0.394811] Initilizing CustomIPI irq domain
[ 0.395222] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.395265] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.407230] pinctrl core: initialized pinctrl subsystem
[ 0.407856] OS set in device tree is not L4T.
[ 0.408266] regulator-dummy: no parameters
[ 0.408548] Initializing plugin-manager
[ 0.408713] Plugin module not found
[ 0.408909] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.409484] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.410483] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[ 0.410701] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[ 0.411319] node /plugin-manager/fragement@10 match with board >=3448-0000-300
[ 0.413257] node /plugin-manager/fragement@13 match with board >=3448-0000-300
[ 0.416948] NET: Registered protocol family 16
[ 0.418156] pstore: using zlib compression
[ 0.418661] console [pstore-1] enabled
[ 0.418678] pstore: Registered ramoops as persistent store backend
[ 0.418695] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.433306] cpuidle: using governor menu
[ 0.436678] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.438517] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e94000)
[ 0.438562] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.441705] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.444198] Serial: AMBA PL011 UART driver
[ 0.444725] tegra_powergate_init: DONE
[ 0.444758] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[ 0.444792] DTB Build time: Feb 19 2021 08:42:41
[ 0.446817] Tegra reboot handler registered.
[ 0.451380] iommu: Adding device tegra-carveouts to group 0
[ 0.451542] platform tegra-carveouts: domain=ffffffc0f94653d8 allocates as[0]=ffffffc0f947c0a8
[ 0.451904] iommu: Adding device smmu_test to group 1
[ 0.451969] platform smmu_test: domain=ffffffc0f9465618 allocates as[0]=ffffffc0f947c110
[ 0.452810] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[ 0.452886] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[ 0.452957] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[ 0.452978] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.453011] mc-err: mcerr ops are set to t21x
[ 0.460923] iommu: Adding device 70090000.xusb to group 2
[ 0.461254] iommu: Adding device 70006000.serial to group 3
[ 0.461349] platform 70006000.serial: domain=ffffffc0f9b89618 allocates as[0]=ffffffc0f947c178
[ 0.461794] iommu: Adding device 70006040.serial to group 4
[ 0.462080] iommu: Adding device 70006200.serial to group 5
[ 0.462316] iommu: Adding device sound to group 6
[ 0.462379] platform sound: domain=ffffffc0f9b89b58 allocates as[0]=ffffffc0f947c1e0
[ 0.462954] iommu: Adding device 7000d400.spi to group 7
[ 0.463216] iommu: Adding device 7000d600.spi to group 8
[ 0.463502] iommu: Adding device 70410000.spi to group 9
[ 0.463819] iommu: Adding device 50000000.host1x to group 10
[ 0.464095] iommu: Adding device 54080000.vi to group 11
[ 0.464501] iommu: Adding device 54600000.isp to group 12
[ 0.464779] iommu: Adding device 54680000.isp to group 13
[ 0.465089] iommu: Adding device tegradc.0 to group 14
[ 0.465159] platform tegradc.0: domain=ffffffc0f94e3a98 allocates as[0]=ffffffc0f947c248
[ 0.465726] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.466051] iommu: Adding device tegradc.1 to group 15
[ 0.466115] platform tegradc.1: domain=ffffffc0f94e3cd8 allocates as[0]=ffffffc0f947c2b0
[ 0.466634] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.466886] iommu: Adding device 54340000.vic to group 16
[ 0.467111] iommu: Adding device 544c0000.nvenc to group 17
[ 0.467310] iommu: Adding device 54500000.tsec to group 18
[ 0.467521] iommu: Adding device 54100000.tsecb to group 19
[ 0.467724] iommu: Adding device 54480000.nvdec to group 20
[ 0.467964] iommu: Adding device 54380000.nvjpg to group 21
[ 0.469047] iommu: Adding device 546c0000.i2c to group 22
[ 0.469588] iommu: Adding device 57000000.gpu to group 23
[ 0.469658] platform 57000000.gpu: domain=ffffffc0f94edcd8 allocates as[0]=ffffffc0f947c318
[ 0.469714] platform 57000000.gpu: domain=ffffffc0f94edcd8 allocates as[1]=ffffffc0f947c380
[ 0.469769] platform 57000000.gpu: domain=ffffffc0f94edcd8 allocates as[2]=ffffffc0f947c3e8
[ 0.469823] platform 57000000.gpu: domain=ffffffc0f94edcd8 allocates as[3]=ffffffc0f947c450
[ 0.470762] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.470802] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.470829] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.470848] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.470864] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.521365] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.521397] tegra-pmc: Clear bootloader IO dpd settings
[ 0.521429] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.521501] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.521809] iommu: Adding device 70012000.se to group 24
[ 0.522586] iommu: Adding device 7000c000.i2c to group 25
[ 0.522856] iommu: Adding device 7000c400.i2c to group 26
[ 0.523121] iommu: Adding device 7000c500.i2c to group 27
[ 0.523381] iommu: Adding device 7000c700.i2c to group 28
[ 0.523682] iommu: Adding device 7000d000.i2c to group 29
[ 0.523943] iommu: Adding device 7000d100.i2c to group 30
[ 0.524234] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.524308] platform sdhci-tegra.0: domain=ffffffc0f9523e58 allocates as[0]=ffffffc0f947c4b8
[ 0.525171] iommu: Adding device 700d0000.xudc to group 32
[ 0.528389] vdd-ac-bat: 5000 mV
[ 0.528756] vdd-5v0-sys: 5000 mV
[ 0.529743] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.529824] vdd-5v0-hdmi: 5000 mV
[ 0.530235] vdd-1v8-sys: 1800 mV
[ 0.530755] vdd-fan: supplied by vdd-5v0-sys
[ 0.530806] vdd-fan: 5000 mV
[ 0.531217] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.531288] vdd-usb-vbus: 5000 mV
[ 0.531940] vdd-usb-vbus2: 5000 mV
[ 0.562361] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.564888] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[ 0.566125] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.566167] GPIO line 152 (camera-control-output-low) hogged as output/low
[ 0.566218] GPIO line 6 (system-suspend-gpio) hogged as output/high
[ 0.566585] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.574476] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.574842] SCSI subsystem initialized
[ 0.575313] usbcore: registered new interface driver usbfs
[ 0.575382] usbcore: registered new interface driver hub
[ 0.575473] usbcore: registered new device driver usb
[ 0.579324] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.584461] random: fast init done
[ 0.584610] vdd-core: 600 <--> 1162 mV at 1125 mV
[ 0.585691] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.589177] vdd-ddr-1v1: 1150 mV
[ 0.593175] vdd-pre-reg-1v35: 1350 mV
[ 0.597173] vdd-1v8: 1800 mV
[ 0.601181] avdd-sys-1v2: 1200 mV
[ 0.605174] vdd-pex-1v0: 1050 mV
[ 0.605837] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[ 0.606437] max77620-ldo3: at 3100 mV
[ 0.609176] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[ 0.609732] max77620-ldo5: at 3100 mV
[ 0.613174] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[ 0.617174] avdd-1v05-pll: 1050 mV
[ 0.621172] avdd-io-hdmi-dp: 1050 mV
[ 0.623829] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.624119] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.624425] max77620 4-003c: max77620 probe successful
[ 0.627058] media: Linux media interface: v0.10
[ 0.627134] Linux video capture interface: v2.00
[ 0.627993] pps_core: LinuxPPS API ver. 1 registered
[ 0.628020] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.628059] PTP clock support registered
[ 0.631277] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.632132] Advanced Linux Sound Architecture Driver Initialized.
[ 0.632768] Bluetooth: Core ver 2.22
[ 0.632830] NET: Registered protocol family 31
[ 0.632846] Bluetooth: HCI device and connection manager initialized
[ 0.632869] Bluetooth: HCI socket layer initialized
[ 0.632888] Bluetooth: L2CAP socket layer initialized
[ 0.632925] Bluetooth: SCO socket layer initialized
[ 0.634788] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.634825] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.634885] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.634911] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.638727] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.639865] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.639945] vdd-3v3-sys: 3300 mV
[ 0.640222] vdd-1v8-sys: supplied by vdd-3v3-sys
[ 0.645379] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.645871] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.645950] vdd-3v3-sd: 3300 mV
[ 0.647008] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.647070] avdd-io-edp-1v05: 1050 mV
[ 0.647507] vdd-usb-hub-en: supplied by vdd-1v8-sys
[ 0.647559] vdd-usb-hub-en: 5000 mV
[ 0.648983] camchar: rtcpu character device driver loaded
[ 0.649844] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[ 0.651101] clocksource: Switched to clocksource arch_sys_counter
[ 0.690833] VFS: Disk quotas dquot_6.6.0
[ 0.691001] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.691544] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.691927] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.691967] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.692223] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.692247] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.692273] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.692323] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.692347] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.692377] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.692398] nvmap_page_pool_init: Total RAM pages: 1010872
[ 0.692414] nvmap_page_pool_init: nvmap page pool size: 126359 pages (493 MB)
[ 0.692507] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.692970] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.693834] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.702177] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.702688] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.703118] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.703443] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.703643] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.703937] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.703955] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[ 0.704403] NET: Registered protocol family 2
[ 0.705400] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.705635] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.706148] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.706309] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.706402] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.706820] NET: Registered protocol family 1
[ 0.707648] RPC: Registered named UNIX socket transport module.
[ 0.707675] RPC: Registered udp transport module.
[ 0.707691] RPC: Registered tcp transport module.
[ 0.707705] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.707956] Trying to unpack rootfs image as initramfs...
[ 1.012627] Freeing initrd memory: 6992K
[ 1.022397] host1x 50000000.host1x: initialized
[ 1.024137] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.027421] audit: initializing netlink subsys (disabled)
[ 1.027540] audit: type=2000 audit(0.871:1): initialized
[ 1.028278] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.038070] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.039611] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.040408] 9p: Installing v9fs 9p2000 file system support
[ 1.043878] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.044048] io scheduler noop registered
[ 1.044361] io scheduler cfq registered (default)
[ 1.046941] gic 702f9000.agic: GIC IRQ controller registered
[ 1.049763] iommu: Adding device 702ef000.adsp to group 33
[ 1.057915] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 1.058064] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 1.058671] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9a8a413
[ 1.058701] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 1.060506] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 1.060646] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 1.060763] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 1.060976] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 1.061098] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 1.061210] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 1.061322] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 1.061437] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 1.061552] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 1.061657] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 1.067865] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 1.069591] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 1.071521] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[ 1.072827] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[ 1.073195] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[ 1.074384] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 1.074648] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 1.074950] Adding domain tsec-pd to PM domain host1x-pd
[ 1.077403] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[ 1.078417] tsec 54500000.tsec: initialized
[ 1.080022] tsec 54100000.tsecb: initialized
[ 1.080746] Adding domain nvdec-pd to PM domain host1x-pd
[ 1.084350] nvdec 54480000.nvdec: initialized
[ 1.085430] Adding domain vic03-pd to PM domain host1x-pd
[ 1.085632] Adding domain msenc-pd to PM domain host1x-pd
[ 1.085803] Adding domain nvjpg-pd to PM domain host1x-pd
[ 1.089957] falcon 54340000.vic: initialized
[ 1.091241] falcon 544c0000.nvenc: initialized
[ 1.092584] falcon 54380000.nvjpg: initialized
[ 1.096888] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[ 1.096965] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[ 1.097012] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[ 1.097026] tegradc tegradc.0: [cavo] 1
[ 1.097029] tegradc tegradc.0: [cavo] 1
[ 1.097033] tegradc tegradc.0: [cavo] 3
[ 1.097049] tegradc tegradc.0: [cavo] 4
[ 1.097077] tegradc tegradc.0: [cavo] 5
[ 1.097145] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 1.097253] display board info: id 0x0, fab 0x0
[ 1.097324] generic_infoframe_type: 0x87
[ 1.097343] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[ 1.097364] tegra_cec 70015000.tegra_cec: probed
[ 1.097470] tegradc tegradc.0: DT parsed successfully
[ 1.097488] tegradc tegradc.0: [cavo] 6
[ 1.097543] tegradc tegradc.0: [cavo] Display dc.ffffff800abc0000 registered with id=0
[ 1.105214] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 1.105698] tegradc tegradc.0: probed
[ 1.106425] Console: switching to colour frame buffer device 80x30
[ 1.106476] tegradc tegradc.0: fb registered
[ 1.107888] tegradc tegradc.1: [cavo] 1
[ 1.107914] tegradc tegradc.1: [cavo] 1
[ 1.107930] tegradc tegradc.1: [cavo] 3
[ 1.107957] tegradc tegradc.1: [cavo] 4
[ 1.108007] tegradc tegradc.1: [cavo] 5
[ 1.108073] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 1.108167] tegradc tegradc.1: No lt-data, using default setting
[ 1.108209] tegradc tegradc.1: No hpd-gpio in DT
[ 1.108248] tegradc tegradc.1: DT parsed successfully
[ 1.108260] tegradc tegradc.1: [cavo] 6
[ 1.108325] tegradc tegradc.1: [cavo] Display dc.ffffff800ad40000 registered with id=1
[ 1.109860] tegradc tegradc.1: dpd enable lookup fail:-19
[ 1.111430] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[ 1.112229] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[ 1.112249] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 1.112564] kfuse 7000fc00.kfuse: initialized
[ 1.615569] Host read timeout at address 545c00c4
[ 1.615889] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 1.616724] tegradc tegradc.1: probed
[ 1.616843] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.617105] tegradc tegradc.1: fb registered
[ 1.618036] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 1.618062] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 1.618438] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 1.619748] vdd-gpu: applied init 1000000uV constraint
[ 1.619768] vdd-gpu: 708 <--> 1323 mV at 997 mV
[ 1.620144] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 1.620319] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 1.620337] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 1.620356] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.620379] tegradc tegradc.1: blank - powerdown
[ 1.620407] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 1.620421] Extcon DP: HPD disabled
[ 1.620432] hpd: hpd_switch 0
[ 1.620444] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.620461] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.620476] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.623710] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.623834] No Device Node present for smmu client: serial8250 !!
[ 1.623855] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 1.623909] iommu: Adding device serial8250 to group 35
[ 1.626137] console [ttyS0] disabled
[ 1.626223] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 2.002937] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.111130] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[ 2.111136] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[ 2.406820] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.811154] tegra-pcie 1003000.pcie: link 0 down, retrying
[ 2.813170] tegra-pcie 1003000.pcie: link 0 down, ignoring
[ 2.919432] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[ 2.919443] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.919449] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.919454] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.919459] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.919851] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.931255] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.931261] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.931270] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.931291] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.931309] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.931320] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.931327] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.931334] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.931718] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.931723] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.212309] console [ttyS0] enabled
[ 4.217062] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 4.226265] serial-tegra 70006200.serial: RX in PIO mode
[ 4.231680] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 4.241512] [drm] Initialized
[ 4.254915] brd: module loaded
[ 4.263483] loop: module loaded
[ 4.266747] tegra_profiler: version: 1.143, samples/io: 48/28
[ 4.272640] tegra_profiler: auth: init
[ 4.277882] THERMAL EST: found 2 subdevs
[ 4.281857] THERMAL EST num_resources: 0
[ 4.285943] [THERMAL EST subdev 0]
[ 4.289358] [THERMAL EST subdev 1]
[ 4.293233] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.302209] THERMAL EST: thz register success.
[ 4.306848] THERMAL EST: end of probe, return err: 0
[ 4.313007] sd: No Scsi addr parsed to reserve index
[ 4.318036] hisi_sas: driver version v1.6
[ 4.326714] tegra-qspi 70410000.spi: Prod settings list not found
[ 4.333938] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 4.339385] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 4.354313] libphy: Fixed MDIO Bus: probed
[ 4.359402] tun: Universal TUN/TAP device driver, 1.6
[ 4.364471] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 4.371621] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.377470] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.383465] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.390433] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.396067] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.403900] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.409873] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 4.416840] Copyright(c) 1999 - 2017 Intel Corporation.
[ 4.423040] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[ 4.428923] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 4.448943] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[ 4.461328] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:ec:7e:f2 from device tree
[ 4.473803] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 4.485253] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
[ 4.485253] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[ 4.485253] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 4.516591] PPP generic driver version 2.4.2
[ 4.521063] PPP BSD Compression module registered
[ 4.525787] PPP Deflate Compression module registered
[ 4.530880] PPP MPPE Compression module registered
[ 4.535684] NET: Registered protocol family 24
[ 4.540201] usbcore: registered new interface driver r8152
[ 4.545742] usbcore: registered new interface driver asix
[ 4.551203] usbcore: registered new interface driver ax88179_178a
[ 4.557342] usbcore: registered new interface driver cdc_ether
[ 4.563224] usbcore: registered new interface driver net1080
[ 4.568928] usbcore: registered new interface driver cdc_subset
[ 4.574889] usbcore: registered new interface driver zaurus
[ 4.580520] usbcore: registered new interface driver cdc_ncm
[ 4.586345] VFIO - User Level meta-driver version: 0.3
[ 4.592720] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.599282] ehci-pci: EHCI PCI platform driver
[ 4.603782] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.609975] ohci-pci: OHCI PCI platform driver
[ 4.614477] ohci-platform: OHCI generic platform driver
[ 4.622334] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 4.628720] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 4.637113] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f903c800 id
[ 4.645579] usbcore: registered new interface driver uas
[ 4.650949] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[ 4.650995] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 4.651024] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 4.651795] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 4.651859] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 4.652130] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.652136] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.652141] usb usb1: Product: xHCI Host Controller
[ 4.652145] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 4.652149] usb usb1: SerialNumber: 70090000.xusb
[ 4.662240] hub 1-0:1.0: USB hub found
[ 4.662282] hub 1-0:1.0: 5 ports detected
[ 4.662817] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 4.662830] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 4.662940] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.663044] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.663049] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.663053] usb usb2: Product: xHCI Host Controller
[ 4.663057] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[ 4.663060] usb usb2: SerialNumber: 70090000.xusb
[ 4.663506] hub 2-0:1.0: USB hub found
[ 4.663536] hub 2-0:1.0: 4 ports detected
[ 4.664259] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 4.664266] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 4.763178] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 4.771330] usb usb2: usb_suspend_both: status 0
[ 4.808956] usbcore: registered new interface driver usb-storage
[ 4.815116] usbcore: registered new interface driver usbserial
[ 4.824504] tegra-xudc-new 700d0000.xudc: device count: 1
[ 4.831561] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 4.838286] tegra-xudc-new 700d0000.xudc: vbus state: 0
[ 4.843552] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 4.849051] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 4.851777] mousedev: PS/2 mouse device common for all mice
[ 4.851879] usbcore: registered new interface driver xpad
[ 4.983046] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.987127] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 4.999544] rtc rtc1: alarm rtc device
[ 5.003330] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 5.009361] usb 1-2: New USB device found, idVendor=2109, idProduct=2817
[ 5.009368] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.009372] usb 1-2: Product: USB2.0 Hub
[ 5.009377] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 5.010538] hub 1-2:1.0: USB hub found
[ 5.010732] hub 1-2:1.0: 5 ports detected
[ 5.042659] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 5.049478] i2c /dev entries driver
[ 5.054868] i2c i2c-6: Added multiplexed i2c bus 7
[ 5.060055] i2c i2c-6: Added multiplexed i2c bus 8
[ 5.064866] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 5.072786] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 5.102057] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 5.108758] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 5.116356] imx219 7-0010: board setup failed
[ 5.120800] imx219: probe of 7-0010 failed with error -121
[ 5.126849] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 5.139245] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.156091] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 5.162715] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 5.170273] imx219 8-0010: board setup failed
[ 5.174711] imx219: probe of 8-0010 failed with error -121
[ 5.181463] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 5.190767] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 5.191052] usb 2-1: New USB device found, idVendor=2109, idProduct=0817
[ 5.191057] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.191062] usb 2-1: Product: USB3.0 Hub
[ 5.191066] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 5.192242] hub 2-1:1.0: USB hub found
[ 5.192448] hub 2-1:1.0: 4 ports detected
[ 5.230019] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 5.237504] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.246836] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 5.255813] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 5.264831] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.274157] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 5.283121] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 5.292141] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.301460] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 5.310420] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 5.318445] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 5.326373] tegra_aotag tegra-aotag: Registering sensor 0
[ 5.331877] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 5.337128] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 5.343655] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.352989] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 5.361216] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 5.369971] parse_throttle_dt_data: Num cap clks = 6
[ 5.374953] parse_throttle_dt_data: clk=cclk_g type=2
[ 5.380022] parse_throttle_dt_data: clk=gpu type=4
[ 5.384844] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 5.390958] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 5.397084] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 5.403097] parse_throttle_dt_data: clk=emc type=3
[ 5.408300] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.417718] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.427191] tegra_throttle_probe: probe successful. #cdevs=4
[ 5.433622] FAN dev name: pwm-fan
[ 5.437044] FAN:gpio request success.
[ 5.440782] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 5.446763] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 5.453553] pwm_fan_driver pwm-fan: fan tach request irq success
[ 5.459575] pwm_fan_driver pwm-fan: tach period: 1000
[ 5.464740] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 5.472315] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 5.480065] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 5.487896] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 5.495731] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 5.503566] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 5.511400] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 5.519233] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 5.527064] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 5.534983] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 5.545623] device-mapper: uevent: version 1.0.3
[ 5.550745] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 5.564550] tegra210-cpufreq cpufreq: probe()...completed
[ 5.570721] sdhci: Secure Digital Host Controller Interface driver
[ 5.576902] sdhci: Copyright(c) Pierre Ossman
[ 5.581259] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.587419] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 5.592559] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 5.599815] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 5.609950] tegra-se 70012000.se: tegra_se_probe: complete
[ 5.616137] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.622821] usbcore: registered new interface driver usbhid
[ 5.628405] usbhid: USB HID core driver
[ 5.634319] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 5.640936] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 5.651203] nvpmodel: initialized successfully
[ 5.651245] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 5.666091] usbcore: registered new interface driver snd-usb-audio
[ 5.672386] No Device Node present for smmu client: snd-soc-dummy !!
[ 5.678763] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 5.689529] iommu: Adding device snd-soc-dummy to group 36
[ 5.696422] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 5.715246] usb 2-1: usb_suspend_both: status 0
[ 5.720028] usb usb2: usb_suspend_both: status 0
[ 5.721767] OPE platform probe
[ 5.721848] OPE platform probe successful
[ 5.722120] OPE platform probe
[ 5.722207] OPE platform probe successful
[ 5.747116] usb 1-2.3: new full-speed USB device number 3 using tegra-xusb
[ 5.748492] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.748625] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.748746] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.748868] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.748996] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.749117] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.749234] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.749357] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.749477] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.749598] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.761501] u32 classifier
[ 5.761503] Actions configured
[ 5.761573] Initializing XFRM netlink socket
[ 5.762277] NET: Registered protocol family 10
[ 5.762980] NET: Registered protocol family 17
[ 5.762990] NET: Registered protocol family 15
[ 5.763061] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.763129] Bluetooth: RFCOMM socket layer initialized
[ 5.763138] Bluetooth: RFCOMM ver 1.11
[ 5.763142] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.763146] Bluetooth: HIDP socket layer initialized
[ 5.763164] 9pnet: Installing 9P2000 support
[ 5.763197] Key type dns_resolver registered
[ 5.765503] Registered cp15_barrier emulation handler
[ 5.765513] Registered setend emulation handler
[ 5.766497] registered taskstats version 1
[ 5.767081] Adding domain ve2-pd to PM domain host1x-pd
[ 5.767340] Adding domain ve-pd to PM domain host1x-pd
[ 5.769393] isp 54600000.isp: initialized
[ 5.770317] isp 54680000.isp: initialized
[ 5.780529] last reset is due to power on reset
[ 5.780532] KERNEL: PMC reset status reg: 0x0
[ 5.780592] BL: PMC reset status reg: 0x0
[ 5.780594] BL: PMIC poweroff Event Recorder: 0x40
[ 5.782060] clk_cbus_recalc_rate: no gbus parent
[ 5.782065] clk_cbus_round_rate: no gbus parent
[ 5.782067] clk_cbus_round_rate: no gbus parent
[ 5.782073] clk_cbus_recalc_rate: no gbus parent
[ 5.782177] clk_cbus_recalc_rate: no gbus parent
[ 5.782180] clk_cbus_round_rate: no gbus parent
[ 5.782182] clk_cbus_round_rate: no gbus parent
[ 5.782185] clk_cbus_recalc_rate: no gbus parent
[ 5.782198] tegra_dvfs: GPU-cap: registered
[ 5.782256] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 5.782258] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 5.782260] tegra dvfs: vdd-gpu: nominal 1068mV, offset 708000uV, step 10000uV, scaling enabled
[ 5.831456] tegra_dvfs: vdd-gpu-vts: registered
[ 5.863606] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 5.864239] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 5.864758] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.909252] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:00:19 UTC (946688419)
[ 5.910274] vi 54080000.vi: vi_probe: ++
[ 6.023232] vi 54080000.vi: initialized
[ 6.040969] vi 54080000.vi: subdev nvcsi--2 bound
[ 6.045786] vi 54080000.vi: subdev nvcsi--1 bound
[ 6.051317] Disable partitions left on by BL
[ 6.055592] disb
[ 6.057637] bwmgr: missing cdev-type property
[ 6.062083] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 6.064746] usb 1-2.3: New USB device found, idVendor=0d8c, idProduct=013c
[ 6.064750] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.064752] usb 1-2.3: Product: USB PnP Sound Device
[ 6.064755] usb 1-2.3: Manufacturer: C-Media Electronics Inc.
[ 6.073049] input: C-Media Electronics Inc. USB PnP Sound Device as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.2/0003:0D8C:013C.0001/input/input2
[ 6.105714] mmc0: hw tuning done ...
[ 6.105746] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[ 6.106018] mmcblk0: mmc0:aaaa SB32G 29.7 GiB
[ 6.111531] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 6.131575] DRAM derating cdev registered.
[ 6.135428] hid-generic 0003:0D8C:013C.0001: input,hidraw0: USB HID v1.00 Device [C-Media Electronics Inc. USB PnP Sound Device] on usb-70090000.xusb-2.3/input2
[ 6.151521] ALSA device list:
[ 6.154485] #0: tegra-hda at 0x70038000 irq 83
[ 6.159107] #1: tegra-snd-t210ref-mobile-rt565x
[ 6.163808] #2: C-Media Electronics Inc. USB PnP Sound Device at usb-70090000.xusb-2.3, full sp
[ 6.175743] Freeing unused kernel memory: 8576K
[ 6.204407] Root device found: mmcblk0p1
[ 6.209774] Found dev node: /dev/mmcblk0p1
[ 6.223128] usb 1-2.5: new high-speed USB device number 4 using tegra-xusb
[ 6.248804] usb 1-2.5: New USB device found, idVendor=2109, idProduct=8817
[ 6.255702] usb 1-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.263081] usb 1-2.5: Product: USB Billboard Device
[ 6.268317] usb 1-2.5: Manufacturer: VIA Labs, Inc.
[ 6.273987] usb 1-2.5: SerialNumber: 0000000000000001
[ 7.309982] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 7.315307] EXT4-fs (mmcblk0p1): recovery complete
[ 7.334523] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.344588] Rootfs mounted over mmcblk0p1
[ 7.367926] Switching from initrd to actual rootfs
[ 7.573840] systemd[1]: System time before build time, advancing clock.
[ 7.607515] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.625014] cgroup: cgroup2: unknown option "nsdelegate"
[ 7.651913] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.674053] systemd[1]: Detected architecture arm64.
[ 7.708440] systemd[1]: Set hostname to <nano-desktop>.
[ 7.826817] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.844079] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 7.991614] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.998298] systemd[1]: Reached target Swap.
[ 8.003129] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.011582] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.021115] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.029692] systemd[1]: Created slice System Slice.
[ 8.034896] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.041891] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 8.128912] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.240143] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 8.258829] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.268655] cpu-throttle-alert cooling device registered.
[ 8.274248] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.285534] gpu-throttle-alert cooling device registered.
[ 8.291419] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.301027] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 8.310487] hot-surface-alert cooling device registered.
[ 9.407302] random: crng init done
[ 9.410705] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.636306] using random self ethernet address
[ 9.643607] using random host ethernet address
[ 10.648922] using random self ethernet address
[ 10.656025] using random host ethernet address
Ubuntu 18.04.5 LTS nano-desktop ttyS0
nano-desktop login:
