I copied from the terminal. Please find below the updated dmesg log :
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (root@elma-ThinkPad-T440) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc0
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 145600000
[ 0.000000] OF: fdt: - 235e00000 , 200000
[ 0.000000] OF: fdt: - 236600000 , 200000
[ 0.000000] OF: fdt: - 237000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb2_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 1793024
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 523776 pages, LIFO batch:31
[ 0.000000] Normal zone: 19912 pages used for memmap
[ 0.000000] Normal zone: 1269248 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 25 pages/cpu @ffffffc1b676a000 s61656 r8192 d32552 u102400
[ 0.000000] pcpu-alloc: s61656 r8192 d32552 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1764920
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware root=/dev/mmcblk0p1 rw
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29208(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6936680K/7172096K available (15294K kernel code, 2934K rwdata, 6708K rodata, 8576K init, 609K bss, 169880K reserved, 6)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14d808 ( 2935 KB)
[ 0.000000] .bss : 0xffffff800a14d808 - 0xffffff800a1e5f7c ( 610 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf06dc8000 ( 109 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1b7200000 ( 7026 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.001562] Console: colour dummy device 80x25
[ 0.001568] console [tty0] enabled
[ 0.001572] bootconsole [uart8250] disabled
[ 0.001579] kmemleak: Kernel memory leak detector disabled
[ 0.001589] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.001597] pid_max: default: 32768 minimum: 301
[ 0.001913] Security Framework initialized
[ 0.002072] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002077] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.002709] ftrace: allocating 47104 entries in 185 pages
[ 0.128905] sched-energy: Sched-energy-costs installed from DT
[ 0.128915] ASID allocator initialised with 65536 entries
[ 0.168174] tegra-id: chipid=21817.
[ 0.168180] tegra-id: opt_subrevision=1.
[ 0.168195] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.168203] DTS File Name: /home/elma/nvidia/JetPack_4.4_Linux_JETSON_TX2I/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/.s
[ 0.168209] DTB Build time:
[ 0.217738] CPU1: Booted secondary processor [4e0f0030]
[ 0.249350] CPU2: Booted secondary processor [4e0f0030]
[ 0.281132] CPU3: Booted secondary processor [411fd073]
[ 0.313113] CPU4: Booted secondary processor [411fd073]
[ 0.345111] CPU5: Booted secondary processor [411fd073]
[ 0.345167] Brought up 6 CPUs
[ 0.345170] SMP: Total of 6 processors activated.
[ 0.345175] CPU features: detected feature: 32-bit EL0 Support
[ 0.345908] CPU: All CPU(s) started at EL2
[ 0.345953] alternatives: patching kernel code
[ 0.348921] devtmpfs: initialized
[ 0.387899] Initilizing CustomIPI irq domain
[ 0.388095] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.388103] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.389018] pinctrl core: initialized pinctrl subsystem
[ 0.389254] OS set in device tree is not L4T.
[ 0.389418] regulator-dummy: no parameters
[ 0.389556] Initializing plugin-manager
[ 0.389613] Plugin module not found
[ 0.389649] Plugin-manager status disabled
[ 0.391470] NET: Registered protocol family 16
[ 0.392247] pstore: using zlib compression
[ 0.392260] console [pstore-1] enabled
[ 0.392263] pstore: Registered ramoops as persistent store backend
[ 0.392267] ramoops: attached 0x200000@0x235880000, ecc: 0/0
[ 0.405146] cpuidle: using governor menu
[ 0.406743] bpmp: waiting for handshake
[ 0.406746] bpmp: handshake completed
[ 0.406757] bpmp: synchronizing channels
[ 0.406776] bpmp: channels synchronized
[ 0.406778] bpmp: mail init ok
[ 0.408895] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.408900] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.408903] arm-smmu 12000000.iommu: stage 1 translation
[ 0.408907] arm-smmu 12000000.iommu: stage 2 translation
[ 0.408909] arm-smmu 12000000.iommu: nested translation
[ 0.408915] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.408920] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.408924] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.408928] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.408932] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.411209] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[ 0.411221] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413428] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415555] Registering BPMP clocks…
[ 0.415648] tegra_bpmp_clk_init: clock init ok (638 clks)
[ 0.416630] Serial: AMBA PL011 UART driver
[ 0.417708] tegra_powergate_init: DONE
[ 0.417716] DTS File Name: /home/elma/nvidia/JetPack_4.4_Linux_JETSON_TX2I/Linux_for_Tegra/sources/kernel/kernel-4.9/arch/arm64/boot/dts/.s
[ 0.417721] DTB Build time:
[ 0.419941] Tegra reboot handler registered.
[ 0.421488] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.421555] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[ 0.421567] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[ 0.421570] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[ 0.421572] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.421722] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.421732] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.422067] iommu: Adding device 3460000.sdhci to group 0
[ 0.422527] iommu: Adding device 3440000.sdhci to group 1
[ 0.422974] iommu: Adding device 3400000.sdhci to group 2
[ 0.424036] iommu: Adding device 3507000.ahci-sata to group 3
[ 0.424049] arm-smmu: forcing sodev map for 3507000.ahci-sata
[ 0.424501] iommu: Adding device 3160000.i2c to group 4
[ 0.424961] iommu: Adding device c240000.i2c to group 5
[ 0.425332] iommu: Adding device 3180000.i2c to group 6
[ 0.425668] iommu: Adding device 3190000.i2c to group 7
[ 0.426081] iommu: Adding device 31b0000.i2c to group 8
[ 0.426415] iommu: Adding device 31c0000.i2c to group 9
[ 0.426745] iommu: Adding device c250000.i2c to group 10
[ 0.427081] iommu: Adding device 31e0000.i2c to group 11
[ 0.428553] iommu: Adding device 3210000.spi to group 12
[ 0.428893] iommu: Adding device c260000.spi to group 13
[ 0.429267] iommu: Adding device 3240000.spi to group 14
[ 0.429982] iommu: Adding device 3100000.serial to group 15
[ 0.430334] iommu: Adding device 3110000.serial to group 16
[ 0.430676] iommu: Adding device c280000.serial to group 17
[ 0.431029] iommu: Adding device 3130000.serial to group 18
[ 0.432373] iommu: Adding device 2490000.ether_qos to group 19
[ 0.432385] arm-smmu: forcing sodev map for 2490000.ether_qos
[ 0.433059] iommu: Adding device b000000.rtcpu to group 20
[ 0.435323] iommu: Adding device 13e10000.host1x to group 21
[ 0.435651] iommu: Adding device 13e10000.host1x:ctx0 to group 22
[ 0.435959] iommu: Adding device 13e10000.host1x:ctx1 to group 23
[ 0.436264] iommu: Adding device 13e10000.host1x:ctx2 to group 24
[ 0.436570] iommu: Adding device 13e10000.host1x:ctx3 to group 25
[ 0.436900] iommu: Adding device 13e10000.host1x:ctx4 to group 26
[ 0.437264] iommu: Adding device 13e10000.host1x:ctx5 to group 27
[ 0.437579] iommu: Adding device 13e10000.host1x:ctx6 to group 28
[ 0.437905] iommu: Adding device 13e10000.host1x:ctx7 to group 29
[ 0.438391] iommu: Adding device 150c0000.nvcsi to group 30
[ 0.439038] iommu: Adding device 15700000.vi to group 31
[ 0.439397] iommu: Adding device 15600000.isp to group 32
[ 0.439851] iommu: Adding device 15210000.nvdisplay to group 33
[ 0.440474] iommu: Adding device 15340000.vic to group 34
[ 0.440693] iommu: Adding device 154c0000.nvenc to group 35
[ 0.440914] iommu: Adding device 15480000.nvdec to group 36
[ 0.441287] iommu: Adding device 15380000.nvjpg to group 37
[ 0.441508] iommu: Adding device 15500000.tsec to group 38
[ 0.441718] iommu: Adding device 15100000.tsecb to group 39
[ 0.442616] iommu: Adding device 15810000.se to group 40
[ 0.442849] iommu: Adding device 15820000.se to group 41
[ 0.443063] iommu: Adding device 15830000.se to group 42
[ 0.443279] iommu: Adding device 15840000.se to group 43
[ 0.444160] iommu: Adding device smmu_test to group 44
[ 0.444784] mc: mapped MMIO address: 0xffffff800a6e0000 → 0x2c10000
[ 0.444796] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2c20000
[ 0.444806] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2c30000
[ 0.444817] mc: mapped MMIO address: 0xffffff800b110000 → 0x2c40000
[ 0.444827] mc: mapped MMIO address: 0xffffff800b130000 → 0x2c50000
[ 0.444836] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.444845] mc-err: mcerr ops are set to t18x
[ 0.444989] dram-ecc: DRAM ECC enabled-MC_ECC_CONTROL:0x0000000d
[ 0.445015] dram-ecc: SCE-R5 is booted with Camera FW
[ 0.445018] dram-ecc: DRAM ECC interrupts handled in Camera FW
[ 0.446203] iommu: Adding device 3530000.xhci to group 45
[ 0.446215] arm-smmu: forcing sodev map for 3530000.xhci
[ 0.446667] iommu: Adding device 3550000.xudc to group 46
[ 0.446677] arm-smmu: forcing sodev map for 3550000.xudc
[ 0.447393] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.447399] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[ 0.447980] iommu: Adding device 17000000.gp10b to group 47
[ 0.449041] tegra-reset 5000000.clock: registered 193 resets.
[ 0.451269] iommu: Adding device d000000.bpmp to group 48
[ 0.451485] bpmp: ping status is 0
[ 0.451587] bpmp d000000.bpmp: firmware tag is 4208eb5c85fe47a2235fbc0b8eb87dca
[ 0.454222] bpmp d000000.bpmp: probe ok
[ 0.457465] iommu: Adding device 2600000.dma to group 49
[ 0.458642] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[ 0.458668] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[ 0.458698] GPIO line 461 (camera-control-output-low) hogged as output/low
[ 0.458722] GPIO line 456 (camera-control-output-low) hogged as output/low
[ 0.458746] GPIO line 457 (camera-control-output-low) hogged as output/low
[ 0.458767] GPIO line 426 (camera-control-output-low) hogged as output/low
[ 0.458928] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[ 0.462654] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[ 0.464206] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.464221] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 0.464559] iommu: Adding device sound to group 51
[ 0.464950] iommu: Adding device 3510000.hda to group 52
[ 0.472458] iommu: Adding device c1a0000.aon to group 53
[ 0.472952] vdd-ac-bat: 5000 mV
[ 0.474640] vdd-1v8-ap: 1800 mV
[ 0.501141] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.504209] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.504412] SCSI subsystem initialized
[ 0.504538] libata version 3.00 loaded.
[ 0.504669] usbcore: registered new interface driver usbfs
[ 0.504702] usbcore: registered new interface driver hub
[ 0.504757] usbcore: registered new device driver usb
[ 0.505355] random: fast init done
[ 0.507849] GPIO line 241 (touch-rails) hogged as output/high
[ 0.508250] GPIO line 242 (touch-rails) hogged as output/high
[ 0.508408] gpiochip_setup_dev: registered GPIOs 240 to 255 on device: gpiochip2 (tca9539)
[ 0.509739] GPIO line 228 (lcd-bias-rails) hogged as output/high
[ 0.509874] gpiochip_setup_dev: registered GPIOs 224 to 239 on device: gpiochip3 (tca9539)
[ 0.519623] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.524829] vddio-ddr: at 1125 mV
[ 0.528709] avdd_dsi_csi: 1200 mV
[ 0.532684] vdd-1v8: 1800 mV
[ 0.536685] vdd-3v3-sys: 3300 mV
[ 0.537237] max77620-sd4: at 600 mV
[ 0.538213] spmic-ldo0: at 1800 mV
[ 0.538902] spmic-ldo1: at 800 mV
[ 0.540685] vddio-3v3: 3300 mV
[ 0.541271] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.544706] vdd-rtc: at 800 mV
[ 0.545448] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.548685] spmic-ldo6: at 1500 mV
[ 0.552687] vdd-pex-1v00: 1000 mV
[ 0.553315] dvdd-pex: 1000 mV
[ 0.555457] GPIO line 221 (spmic_gpio_input) hogged as input
[ 0.555602] GPIO line 222 (spmic_gpio_input) hogged as input
[ 0.555757] gpiochip_setup_dev: registered GPIOs 216 to 223 on device: gpiochip4 (max77620-gpio)
[ 0.555934] max77620 4-003c: max77620 probe successful
[ 0.556316] media: Linux media interface: v0.10
[ 0.556343] Linux video capture interface: v2.00
[ 0.559882] pps_core: LinuxPPS API ver. 1 registered
[ 0.559885] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.559901] PTP clock support registered
[ 0.560088] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.560291] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.560309] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.561764] trusty trusty: trusty version: Built: 21:16:26 Jun 25 2020
[ 0.561779] trusty trusty: selected api version: 3 (requested 3)
[ 0.562590] Advanced Linux Sound Architecture Driver Initialized.
[ 0.562906] Bluetooth: Core ver 2.22
[ 0.562932] NET: Registered protocol family 31
[ 0.562935] Bluetooth: HCI device and connection manager initialized
[ 0.562942] Bluetooth: HCI socket layer initialized
[ 0.562946] Bluetooth: L2CAP socket layer initialized
[ 0.562960] Bluetooth: SCO socket layer initialized
[ 0.563694] en-vdd-sd: 3300 mV
[ 0.564390] en-vdd-cam: 1800 mV
[ 0.569168] vdd-hdmi: 5000 mV
[ 0.569491] vdd-usb0-5v: 5000 mV
[ 0.569802] vdd-usb1-5v: 5000 mV
[ 0.573123] en-vdd-ts-1v8: 1800 mV
[ 0.577120] en-vdd-ts-hv-3v3: 3300 mV
[ 0.577803] en-vdd-disp-3v3: 3300 mV
[ 0.578460] en-mdm-pwr-3v7: 3700 mV
[ 0.579129] en-vdd-disp-1v8: 1800 mV
[ 0.579808] en-vdd-cam-hv-2v8: 2800 mV
[ 0.580480] en-vdd-cam-1v2: 1200 mV
[ 0.581169] vdd-fan: 5000 mV
[ 0.581428] vdd-3v3: 3300 mV
[ 0.582316] dis-vdd-1v2: 1200 mV
[ 0.582579] en-vdd-vcm-2v8: 2800 mV
[ 0.583277] vdd-usb2-5v: 5000 mV
[ 0.583541] vdd-sys-bl: 3300 mV
[ 0.584237] en-vdd-sys: 1200 mV
[ 0.586404] camchar: rtcpu character device driver loaded
[ 0.586930] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.588581] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 0.589418] clocksource: Switched to clocksource arch_sys_counter
[ 0.612093] VFS: Disk quotas dquot_6.6.0
[ 0.612165] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.612415] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.612953] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[ 0.612959] nvmap_page_pool_init: Total RAM pages: 1750554
[ 0.612962] nvmap_page_pool_init: nvmap page pool size: 218819 pages (854 MB)
[ 0.613031] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.615539] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 0.621070] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.621236] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.621636] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.621711] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.621811] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.621911] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.622065] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.622219] la/ptsa driver initialized.
[ 0.622228] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.622231] pre_t19x_iso_plat_init(): max_iso_bw=7680000KB
[ 0.622541] NET: Registered protocol family 2
[ 0.623147] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.623451] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.624042] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.624096] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.624211] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.624550] NET: Registered protocol family 1
[ 0.624936] RPC: Registered named UNIX socket transport module.
[ 0.624939] RPC: Registered udp transport module.
[ 0.624942] RPC: Registered tcp transport module.
[ 0.624944] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.624951] PCI: CLS 0 bytes, default 64
[ 0.625080] Trying to unpack rootfs image as initramfs…
[ 0.792059] Freeing initrd memory: 5432K
[ 0.807794] host1x 13e10000.host1x: initialized
[ 0.809052] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.811204] audit: initializing netlink subsys (disabled)
[ 0.811231] audit: type=2000 audit(0.704:1): initialized
[ 0.811668] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.818252] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.819247] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.819750] 9p: Installing v9fs 9p2000 file system support
[ 0.821914] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.821996] io scheduler noop registered
[ 0.822207] io scheduler cfq registered (default)
[ 0.825513] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 0.925257] iommu: Adding device aconnect@2a41000:adsp_audio to group 54
[ 0.958233] iommu: Adding device 2993000.adsp to group 55
[ 0.959255] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 0.961744] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[ 0.965224] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.966413] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.967456] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.968490] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.970690] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 0.971630] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 0.971951] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 0.972091] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.972200] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.972205] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[ 0.974416] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 0.975621] tsec 15500000.tsec: initialized
[ 0.976584] tsec 15100000.tsecb: initialized
[ 0.980014] nvdec 15480000.nvdec: initialized
[ 0.986004] falcon 15340000.vic: initialized
[ 0.987188] falcon 154c0000.nvenc: initialized
[ 0.988273] falcon 15380000.nvjpg: initialized
[ 0.990179] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.991517] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.992837] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.994190] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.995522] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.996834] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.998157] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.999478] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 1.002624] tegradccommon 15200000.dc_common: host1x channel mapped
[ 1.002632] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[ 1.002659] tegradccommon 15200000.dc_common: dma mapping done
[ 1.003292] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=391
[ 1.003453] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[ 1.003488] tegradc 15210000.nvdisplay: tegra_dc_parse_panel_ops: panel: /host1x/sor1/hdmi-display is not active
[ 1.003510] tegradc 15210000.nvdisplay: err:-19 parsing panel_ops
[ 1.003889] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.004088] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.004104] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.004262] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.004265] tegra_cec 3960000.tegra_cec: probed
[ 1.014132] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[ 1.014734] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[ 1.014762] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 1.015171] kfuse 3830000.kfuse: initialized
[ 1.016519] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 1.019409] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.021782] console [ttyS0] disabled
[ 1.021827] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[ 1.038137] console [ttyS0] enabled
[ 1.039455] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 1.040317] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 1.040477] serial-tegra 3130000.serial: RX in PIO mode
[ 1.041221] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 1.042214] [drm] Initialized
[ 1.048977] brd: module loaded
[ 1.052465] loop: module loaded
[ 1.052530] tegra_profiler: version: 1.141, samples/io: 48/28
[ 1.052605] tegra_profiler: auth: init
[ 1.052951] nct1008_nct72 7-004c: starting parse dt
[ 1.053047] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[ 1.053052] nct1008_nct72 7-004c: success parsing dt
[ 1.053152] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 1.053527] THERMAL EST: found 3 subdevs
[ 1.053531] THERMAL EST num_resources: 0
[ 1.053535] [THERMAL EST subdev 0]
[ 1.053539] [THERMAL EST subdev 1]
[ 1.053543] [THERMAL EST subdev 2]
[ 1.053798] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 1.053800] THERMAL EST: thz register success.
[ 1.053884] THERMAL EST: end of probe, return err: 0
[ 1.054509] sd: No Scsi addr parsed to reserve index
[ 1.054529] hisi_sas: driver version v1.6
[ 1.058085] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 1.058093] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 1.058820] scsi host0: tegra_ahci
[ 1.059191] scsi host1: tegra_ahci
[ 1.059322] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[ 1.059325] ata2: DUMMY
[ 1.064422] libphy: Fixed MDIO Bus: probed
[ 1.064973] tun: Universal TUN/TAP device driver, 1.6
[ 1.064976] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 1.065655] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.065658] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.065691] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.065693] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.065723] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.065726] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.065755] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 1.065757] Copyright(c) 1999 - 2017 Intel Corporation.
[ 1.073622] eqos 2490000.ether_qos: can’t get pllrefe_vcoout clk (-2)
[ 1.076352] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a9 31 b4
[ 1.076452] libphy: dwc_phy: probed
[ 1.076746] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 1.078620] PPP generic driver version 2.4.2
[ 1.078728] PPP BSD Compression module registered
[ 1.078731] PPP Deflate Compression module registered
[ 1.078746] PPP MPPE Compression module registered
[ 1.078750] NET: Registered protocol family 24
[ 1.078787] usbcore: registered new interface driver r8152
[ 1.078818] usbcore: registered new interface driver asix
[ 1.078845] usbcore: registered new interface driver ax88179_178a
[ 1.078869] usbcore: registered new interface driver cdc_ether
[ 1.078892] usbcore: registered new interface driver net1080
[ 1.078916] usbcore: registered new interface driver cdc_subset
[ 1.078943] usbcore: registered new interface driver zaurus
[ 1.078976] usbcore: registered new interface driver cdc_ncm
[ 1.079072] VFIO - User Level meta-driver version: 0.3
[ 1.079867] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.079879] ehci-pci: EHCI PCI platform driver
[ 1.079911] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.079917] ohci-pci: OHCI PCI platform driver
[ 1.079944] ohci-platform: OHCI generic platform driver
[ 1.084676] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[ 1.085564] nct1008_nct72 7-004c: LOC shutdown limit 110
[ 1.086042] nct1008_nct72 7-004c: EXT shutdown limit 110
[ 1.086339] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ac47b400 id
[ 1.087033] usbcore: registered new interface driver uas
[ 1.087071] usbcore: registered new interface driver usb-storage
[ 1.087133] usbcore: registered new interface driver usbserial
[ 1.088728] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-10-31 05:52:15 UTC, Version: 55.17 release
[ 1.091466] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.092459] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.092787] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.092918] mousedev: PS/2 mouse device common for all mice
[ 1.092966] usbcore: registered new interface driver xpad
[ 1.094599] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.117753] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.117774] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[ 1.118467] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[ 1.118498] tegra-xusb 3530000.xhci: irq 71, io mem 0x03530000
[ 1.118628] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.118634] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.118638] usb usb1: Product: xHCI Host Controller
[ 1.118642] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.118645] usb usb1: SerialNumber: 3530000.xhci
[ 1.118751] nct1008_nct72 7-004c: initial LOC temp: 42000
[ 1.118965] hub 1-0:1.0: USB hub found
[ 1.118993] hub 1-0:1.0: 4 ports detected
[ 1.119048] nct1008_nct72 7-004c: initial EXT temp: 54250
[ 1.119314] tegra-xusb 3530000.xhci: xHCI Host Controller
[ 1.119322] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[ 1.119453] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.119458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.119461] usb usb2: Product: xHCI Host Controller
[ 1.119465] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.119468] usb usb2: SerialNumber: 3530000.xhci
[ 1.119622] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[ 1.119757] hub 2-0:1.0: USB hub found
[ 1.119791] hub 2-0:1.0: 3 ports detected
[ 1.119903] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 1.120078] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 1.193294] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 1.194255] Wake73 for irq=42
[ 1.195492] rtc rtc1: alarm rtc device
[ 1.195503] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 1.195519] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.195723] i2c /dev entries driver
[ 1.197386] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 1.202259] parse_throttle_dt_data: Num cap clks = 4
[ 1.202264] parse_throttle_dt_data: clk=mcpu type=1
[ 1.202267] parse_throttle_dt_data: clk=bcpu type=2
[ 1.202274] parse_throttle_dt_data: clk=gpu type=4
[ 1.202276] parse_throttle_dt_data: clk=emc type=3
[ 1.203264] tegra_throttle_probe: probe successful. #cdevs=4
[ 1.203834] FAN dev name: pwm-fan
[ 1.203897] FAN:gpio request success.
[ 1.203906] FAN: can’t find tach_gpio
[ 1.203929] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.204112] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.204117] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.204681] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.204686] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.204690] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.204694] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.204697] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.204701] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.204705] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.204709] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.204712] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.204716] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 1.205691] device-mapper: uevent: version 1.0.3
[ 1.206018] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 1.206265] CPU EMC frequency mapping table: default setting
[ 1.208341] cpufreq: platform driver Initialization: pass
[ 1.208950] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 1.209092] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 1.209907] sdhci: Secure Digital Host Controller Interface driver
[ 1.209910] sdhci: Copyright(c) Pierre Ossman
[ 1.209911] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.211101] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 1.212827] CMDQ: cmdq_platfm_init successful
[ 1.213751] CQE: CMD_TIMING bit set for R1B DCMD
[ 1.214002] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 1.221226] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 1.221276] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 1.221591] usb usb1: usb_suspend_both: status 0
[ 1.223026] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 1.224695] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 258
[ 1.229001] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 1.229845] tegra-se-nvhost 15810000.se: initialized
[ 1.231006] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 1.231604] tegra-se-nvhost 15820000.se: initialized
[ 1.232609] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 1.233183] tegra-se-nvhost 15830000.se: initialized
[ 1.234062] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 1.234638] tegra-se-nvhost 15840000.se: initialized
[ 1.235607] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 1.235859] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.238029] usbcore: registered new interface driver usbhid
[ 1.238032] usbhid: USB HID core driver
[ 1.241360] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 1.241384] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 1.247962] ina3221x: probe of 0-0042 failed with error -121
[ 1.248192] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 1.248213] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 1.254738] ina3221x: probe of 0-0043 failed with error -121
[ 1.257448] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.257567] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 1.259910] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[ 1.260149] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 1.260281] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[ 1.260485] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[ 1.261241] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[ 1.261338] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[ 1.261392] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[ 1.261434] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.261464] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[ 1.261575] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[ 1.262003] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[ 1.262006] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 1.262623] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[ 1.264525] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 1.264993] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 1.265180] register_ari_mca_banks: Registered MCA ROC:IOB
[ 1.265256] register_ari_mca_banks: Registered MCA ROC:CCE
[ 1.265650] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.265654] tegra18-bridge 2390000.axi2apb: enabled timeout = 16684000
[ 1.265656] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 1.265714] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.265717] tegra18-bridge 23a0000.axi2apb: enabled timeout = 16684000
[ 1.265719] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 1.265773] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.265775] tegra18-bridge 23b0000.axi2apb: enabled timeout = 16684000
[ 1.265777] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 1.265825] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.265827] tegra18-bridge 23c0000.axi2apb: enabled timeout = 16684000
[ 1.265829] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 1.265876] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.265878] tegra18-bridge 23d0000.axi2apb: enabled timeout = 16684000
[ 1.265880] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 1.265948] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.265952] tegra18-bridge 2100000.axip2p: enabled timeout = 16684000
[ 1.265954] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 1.266001] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266005] tegra18-bridge 2110000.axip2p: enabled timeout = 16684000
[ 1.266007] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 1.266054] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266058] tegra18-bridge 2120000.axip2p: enabled timeout = 16684000
[ 1.266060] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 1.266112] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266116] tegra18-bridge 2130000.axip2p: enabled timeout = 16684000
[ 1.266118] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 1.266167] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266170] tegra18-bridge 2140000.axip2p: enabled timeout = 16684000
[ 1.266172] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 1.266218] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266223] tegra18-bridge 2150000.axip2p: enabled timeout = 16684000
[ 1.266224] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 1.266276] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266294] tegra18-bridge 2160000.axip2p: enabled timeout = 16684000
[ 1.266296] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 1.266346] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266351] tegra18-bridge 2170000.axip2p: enabled timeout = 16684000
[ 1.266353] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 1.266400] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266405] tegra18-bridge 2180000.axip2p: enabled timeout = 16684000
[ 1.266406] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 1.266462] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 172 MHZ, timeout = 97000 useconds
[ 1.266466] tegra18-bridge 2190000.axip2p: enabled timeout = 16684000
[ 1.266468] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 1.266527] **** A57 ECC: Enabled
[ 1.266529] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 1.266595] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 1.267106] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 1.267573] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 1.267699] denver_knobs_init:MTS_VERSION:47926945
[ 1.269790] nvpmodel: initialized successfully
[ 1.271293] trusty-virtio trusty:virtio: initializing
[ 1.271398] trusty_ipc virtio0: vring0: va¶ ffffffc1aa35e000(0) qsz 32 notifyid 1
[ 1.271405] trusty_ipc virtio0: vring1: va¶ ffffffc1aa368000(0) qsz 32 notifyid 2
[ 1.271468] trusty-virtio trusty:virtio: initializing done
[ 1.273497] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 1.273545] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 1.273645] usbcore: registered new interface driver snd-usb-audio
[ 1.274444] trusty_ipc virtio0: is online
[ 1.281359] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 1.281573] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 1.306829] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 1.319903] mmc0: periodic cache flush enabled
[ 1.319913] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 1.320372] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 1.320510] mmcblk0boot0: mmc0:0001 032G34 partition 1 8.00 MiB
[ 1.320638] mmcblk0boot1: mmc0:0001 032G34 partition 2 8.00 MiB
[ 1.324764] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 1.328312] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p3
[ 1.335736] OPE platform probe
[ 1.335803] OPE platform probe successful
[ 1.371840] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.388618] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 1.388696] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 1.388769] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 1.388836] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 1.388905] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 1.388976] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 1.389047] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 1.389115] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 1.389184] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 1.389254] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 1.389326] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 1.389404] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 1.389511] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 1.389584] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 1.389652] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 1.389722] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 1.389792] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 1.389862] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 1.389931] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 1.390002] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 1.402446] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 1.410810] u32 classifier
[ 1.410815] Actions configured
[ 1.410876] Initializing XFRM netlink socket
[ 1.411448] NET: Registered protocol family 10
[ 1.412086] NET: Registered protocol family 17
[ 1.412099] NET: Registered protocol family 15
[ 1.412162] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need.
[ 1.412204] Bluetooth: RFCOMM socket layer initialized
[ 1.412212] Bluetooth: RFCOMM ver 1.11
[ 1.412216] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.412220] Bluetooth: HIDP socket layer initialized
[ 1.412236] 9pnet: Installing 9P2000 support
[ 1.412270] Key type dns_resolver registered
[ 1.412548] Registered cp15_barrier emulation handler
[ 1.412559] Registered setend emulation handler
[ 1.413450] registered taskstats version 1
[ 1.417253] isp 15600000.isp: initialized
[ 1.421869] nvcsi 150c0000.nvcsi: initialized
[ 1.423790] tegra-vi4 15700000.vi: using default number of vi channels,15
[ 1.426565] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.426637] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 1.426718] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 1.426855] input: gpio-keys as /devices/gpio-keys/input/input2
[ 1.428948] tegra-vi4 15700000.vi: initialized
[ 1.429754] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 1.429759] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[ 1.458090] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:33:16 UTC (946690396)
[ 1.459450] mmcblk mmc0:0001: Card claimed for testing.
[ 1.483803] bpmp: mounted debugfs mirror
[ 1.485103] bwmgr: missing cdev-type property
[ 1.489668] spmic-ldo0: disabling
[ 1.489868] spmic-ldo1: disabling
[ 1.490000] en-vdd-sd: disabling
[ 1.490002] en-vdd-cam: disabling
[ 1.490005] vdd-usb0-5v: disabling
[ 1.490007] vdd-usb1-5v: disabling
[ 1.490010] en-vdd-disp-3v3: disabling
[ 1.490013] en-mdm-pwr-3v7: disabling
[ 1.490015] en-vdd-disp-1v8: disabling
[ 1.490017] en-vdd-cam-hv-2v8: disabling
[ 1.490019] en-vdd-cam-1v2: disabling
[ 1.490021] vdd-fan: disabling
[ 1.490023] vdd-3v3: disabling
[ 1.490025] en-vdd-vcm-2v8: disabling
[ 1.490028] vdd-sys-bl: disabling
[ 1.490031] en-vdd-sys: disabling
[ 1.490033] ALSA device list:
[ 1.490037] #0: tegra-hda at 0x3518000 irq 384
[ 1.490039] #1: tegra-snd-t186ref-mobile-rt565x
[ 1.492472] Freeing unused kernel memory: 8576K
[ 1.515147] Root device found: mmcblk0p1
[ 1.516036] Found dev node: /dev/mmcblk0p1
[ 1.805501] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 1.908914] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[ 1.908919] EXT4-fs (mmcblk0p1): recovery complete
[ 1.912157] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.912923] Rootfs mounted over mmcblk0p1
[ 1.927823] Switching from initrd to actual rootfs
[ 2.013076] systemd[1]: System time before build time, advancing clock.
[ 2.021443] tegra_cec 3960000.tegra_cec: Can’t find physical addresse.
[ 2.021447] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.041450] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.050779] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.065851] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GC)
[ 2.066669] systemd[1]: Detected architecture arm64.
[ 2.085898] systemd[1]: Set hostname to .
[ 2.175964] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local .
[ 2.175973] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalli)
[ 2.215368] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 2.217390] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 2.285877] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.285909] systemd[1]: Reached target Swap.
[ 2.286113] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.286131] systemd[1]: Reached target User and Group Name Lookups.
[ 2.286151] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.287665] systemd[1]: Created slice User and Session Slice.
[ 2.289284] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.289490] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.322452] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 2.331031] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.331036] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.331039] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[ 2.331041] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[ 2.331044] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.331067] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[ 2.331147] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.331493] iommu: Adding device 0000:00:01.0 to group 56
[ 2.331503] arm-smmu: forcing sodev map for 0000:00:01.0
[ 2.331583] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.331740] pci 0000:01:00.0: [10b5:8714] type 01 class 0x060400
[ 2.331774] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0003ffff]
[ 2.332013] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 2.332288] iommu: Adding device 0000:01:00.0 to group 57
[ 2.332295] arm-smmu: forcing sodev map for 0000:01:00.0
[ 2.341563] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.341764] pci 0000:02:01.0: [10b5:8714] type 01 class 0x060400
[ 2.342039] pci 0000:02:01.0: PME# supported from D0 D3hot D3cold
[ 2.342413] iommu: Adding device 0000:02:01.0 to group 58
[ 2.342422] arm-smmu: forcing sodev map for 0000:02:01.0
[ 2.342520] pci 0000:02:02.0: [10b5:8714] type 01 class 0x060400
[ 2.342791] pci 0000:02:02.0: PME# supported from D0 D3hot D3cold
[ 2.343076] iommu: Adding device 0000:02:02.0 to group 59
[ 2.343083] arm-smmu: forcing sodev map for 0000:02:02.0
[ 2.343171] pci 0000:02:03.0: [10b5:8714] type 01 class 0x060400
[ 2.343440] pci 0000:02:03.0: PME# supported from D0 D3hot D3cold
[ 2.343703] iommu: Adding device 0000:02:03.0 to group 60
[ 2.343709] arm-smmu: forcing sodev map for 0000:02:03.0
[ 2.343797] pci 0000:02:04.0: [10b5:8714] type 01 class 0x060400
[ 2.344125] pci 0000:02:04.0: PME# supported from D0 D3hot D3cold
[ 2.344396] iommu: Adding device 0000:02:04.0 to group 61
[ 2.344402] arm-smmu: forcing sodev map for 0000:02:04.0
[ 2.344646] pci 0000:02:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.344869] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.344886] pci 0000:02:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.345014] pci 0000:02:04.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.345197] pci 0000:03:00.0: [1af2:a001] type 00 class 0xff0000
[ 2.345240] pci 0000:03:00.0: reg 0x10: [mem 0x00000000-0x0000ffff]
[ 2.345260] pci 0000:03:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 2.345977] iommu: Adding device 0000:03:00.0 to group 62
[ 2.345986] arm-smmu: forcing sodev map for 0000:03:00.0
[ 2.357593] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 2.357808] pci 0000:04:00.0: [8086:10d3] type 00 class 0x020000
[ 2.357854] pci 0000:04:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 2.357895] pci 0000:04:00.0: reg 0x18: [io 0x0000-0x001f]
[ 2.357917] pci 0000:04:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 2.358172] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 2.358551] iommu: Adding device 0000:04:00.0 to group 63
[ 2.358561] arm-smmu: forcing sodev map for 0000:04:00.0
[ 2.369598] pci_bus 0000:04: busn_res: [bus 04-ff] end is updated to 04
[ 2.369810] pci 0000:05:00.0: [8086:10d3] type 00 class 0x020000
[ 2.369857] pci 0000:05:00.0: reg 0x10: [mem 0x00000000-0x0001ffff]
[ 2.369898] pci 0000:05:00.0: reg 0x18: [io 0x0000-0x001f]
[ 2.369920] pci 0000:05:00.0: reg 0x1c: [mem 0x00000000-0x00003fff]
[ 2.370192] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 2.370555] iommu: Adding device 0000:05:00.0 to group 64
[ 2.370563] arm-smmu: forcing sodev map for 0000:05:00.0
[ 2.381646] pci_bus 0000:05: busn_res: [bus 05-ff] end is updated to 05
[ 2.381843] pci 0000:06:00.0: [1af2:a001] type 00 class 0xff0000
[ 2.381884] pci 0000:06:00.0: reg 0x10: [mem 0x00000000-0x0000ffff]
[ 2.381905] pci 0000:06:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 2.382702] iommu: Adding device 0000:06:00.0 to group 65
[ 2.382711] arm-smmu: forcing sodev map for 0000:06:00.0
[ 2.393620] pci_bus 0000:06: busn_res: [bus 06-ff] end is updated to 06
[ 2.393635] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 06
[ 2.393644] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 06
[ 2.393823] pci 0000:00:01.0: BAR 14: assigned [mem 0x40100000-0x405fffff]
[ 2.393827] pci 0000:00:01.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 2.393832] pci 0000:01:00.0: BAR 14: assigned [mem 0x40100000-0x404fffff]
[ 2.393835] pci 0000:01:00.0: BAR 0: assigned [mem 0x40500000-0x4053ffff]
[ 2.393844] pci 0000:01:00.0: BAR 13: assigned [io 0x1000-0x2fff]
[ 2.393849] pci 0000:02:01.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[ 2.393852] pci 0000:02:02.0: BAR 14: assigned [mem 0x40200000-0x402fffff]
[ 2.393856] pci 0000:02:03.0: BAR 14: assigned [mem 0x40300000-0x403fffff]
[ 2.393859] pci 0000:02:04.0: BAR 14: assigned [mem 0x40400000-0x404fffff]
[ 2.393862] pci 0000:02:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.393864] pci 0000:02:03.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 2.393868] pci 0000:03:00.0: BAR 0: assigned [mem 0x40100000-0x4010ffff]
[ 2.393878] pci 0000:03:00.0: BAR 1: assigned [mem 0x40110000-0x4011ffff]
[ 2.393888] pci 0000:02:01.0: PCI bridge to [bus 03]
[ 2.393899] pci 0000:02:01.0: bridge window [mem 0x40100000-0x401fffff]
[ 2.393918] pci 0000:04:00.0: BAR 0: assigned [mem 0x40200000-0x4021ffff]
[ 2.393929] pci 0000:04:00.0: BAR 3: assigned [mem 0x40220000-0x40223fff]
[ 2.393939] pci 0000:04:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 2.393949] pci 0000:02:02.0: PCI bridge to [bus 04]
[ 2.393954] pci 0000:02:02.0: bridge window [io 0x1000-0x1fff]
[ 2.393964] pci 0000:02:02.0: bridge window [mem 0x40200000-0x402fffff]
[ 2.393984] pci 0000:05:00.0: BAR 0: assigned [mem 0x40300000-0x4031ffff]
[ 2.393995] pci 0000:05:00.0: BAR 3: assigned [mem 0x40320000-0x40323fff]
[ 2.394005] pci 0000:05:00.0: BAR 2: assigned [io 0x2000-0x201f]
[ 2.394015] pci 0000:02:03.0: PCI bridge to [bus 05]
[ 2.394020] pci 0000:02:03.0: bridge window [io 0x2000-0x2fff]
[ 2.394030] pci 0000:02:03.0: bridge window [mem 0x40300000-0x403fffff]
[ 2.394048] pci 0000:06:00.0: BAR 0: assigned [mem 0x40400000-0x4040ffff]
[ 2.394058] pci 0000:06:00.0: BAR 1: assigned [mem 0x40410000-0x4041ffff]
[ 2.394067] pci 0000:02:04.0: PCI bridge to [bus 06]
[ 2.394077] pci 0000:02:04.0: bridge window [mem 0x40400000-0x404fffff]
[ 2.394095] pci 0000:01:00.0: PCI bridge to [bus 02-06]
[ 2.394100] pci 0000:01:00.0: bridge window [io 0x1000-0x2fff]
[ 2.394110] pci 0000:01:00.0: bridge window [mem 0x40100000-0x404fffff]
[ 2.394127] pci 0000:00:01.0: PCI bridge to [bus 01-06]
[ 2.394130] pci 0000:00:01.0: bridge window [io 0x1000-0x2fff]
[ 2.394135] pci 0000:00:01.0: bridge window [mem 0x40100000-0x405fffff]
[ 2.394767] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.394771] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.394774] pci 0000:02:01.0: Signaling PME through PCIe PME interrupt
[ 2.394777] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 2.394779] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
[ 2.394781] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 2.394783] pci 0000:02:03.0: Signaling PME through PCIe PME interrupt
[ 2.394785] pci 0000:05:00.0: Signaling PME through PCIe PME interrupt
[ 2.394788] pci 0000:02:04.0: Signaling PME through PCIe PME interrupt
[ 2.394790] pci 0000:06:00.0: Signaling PME through PCIe PME interrupt
[ 2.394795] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[ 2.394897] aer 0000:00:01.0:pcie002: service driver aer loaded
[ 2.399551] e1000e 0000:04:00.0: enabling device (0000 → 0002)
[ 2.399765] e1000e 0000:04:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2.458610] e1000e 0000:04:00.0 0000:04:00.0 (uninitialized): registered PHC clock
[ 2.520156] e1000e 0000:04:00.0 eth1: (PCI Express:2.5GT/s:Width x1) 00:0c:8b:51:0a:24
[ 2.520164] e1000e 0000:04:00.0 eth1: Intel(R) PRO/1000 Network Connection
[ 2.520257] e1000e 0000:04:00.0 eth1: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
[ 2.520677] e1000e 0000:05:00.0: enabling device (0000 → 0002)
[ 2.520890] e1000e 0000:05:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2.556038] systemd-journald[2137]: Received request to flush runtime journal from PID 1
[ 2.576777] e1000e 0000:05:00.0 0000:05:00.0 (uninitialized): registered PHC clock
[ 2.636094] e1000e 0000:05:00.0 eth2: (PCI Express:2.5GT/s:Width x1) 00:0c:8b:51:0a:21
[ 2.636101] e1000e 0000:05:00.0 eth2: Intel(R) PRO/1000 Network Connection
[ 2.636194] e1000e 0000:05:00.0 eth2: MAC: 3, PHY: 8, PBA No: FFFFFF-0FF
[ 3.484125] using random self ethernet address
[ 3.497080] using random host ethernet address
[ 3.600808] random: crng init done
[ 3.604219] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.927023] Mass Storage Function, version: 2009/09/11
[ 3.927030] LUN: removable file: (no medium)
[ 3.933906] using random self ethernet address
[ 3.939464] using random host ethernet address
[ 3.983080] rndis0: HOST MAC 96:b3:7e:5c:e0:bc
[ 3.983276] rndis0: MAC 96:b3:7e:5c:e0:bd
[ 3.989281] usb0: HOST MAC 96:b3:7e:5c:e0:be
[ 3.989314] usb0: MAC 96:b3:7e:5c:e0:bf
[ 3.989339] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 3.998282] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 3.998301] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 3.998689] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.000083] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.000149] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.004072] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.004100] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.005486] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.013328] l4tbr0: port 1(rndis0) entered blocking state
[ 4.013335] l4tbr0: port 1(rndis0) entered disabled state
[ 4.013647] device rndis0 entered promiscuous mode
[ 4.044240] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 4.064759] l4tbr0: port 2(usb0) entered blocking state
[ 4.064766] l4tbr0: port 2(usb0) entered disabled state
[ 4.073735] device usb0 entered promiscuous mode
[ 4.092491] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 4.228246] CPU1: shutdown
[ 4.231832] psci: CPU1 killed.
[ 4.241824] Wake76 for irq=199
[ 4.241829] Wake77 for irq=199
[ 4.241831] Wake78 for irq=199
[ 4.241832] Wake79 for irq=199
[ 4.241833] Wake80 for irq=199
[ 4.241835] Wake81 for irq=199
[ 4.241836] Wake82 for irq=199
[ 4.241879] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[ 4.241883] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[ 4.257675] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 4.305207] CPU2: shutdown
[ 4.308059] psci: CPU2 killed.
[ 4.341671] usb usb2: usb_suspend_both: status 0
[ 4.368148] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 4.450814] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 4.458902] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.485608] zram: Added device: zram0
[ 4.490222] zram: Added device: zram1
[ 4.494312] zram: Added device: zram2
[ 4.496887] zram: Added device: zram3
[ 4.497500] usb 1-1: new high-speed USB device number 2 using tegra-xusb
[ 4.517803] usb 1-1: New USB device found, idVendor=0424, idProduct=2514
[ 4.517809] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.518601] hub 1-1:1.0: USB hub found
[ 4.518699] hub 1-1:1.0: 4 ports detected
[ 4.529096] zram0: detected capacity change from 0 to 898076672
[ 4.546455] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 4.580428] Adding 877024k swap on /dev/zram0. Priority:5 extents:1 across:877024k SS
[ 4.620960] zram1: detected capacity change from 0 to 898076672
[ 4.659174] Adding 877024k swap on /dev/zram1. Priority:5 extents:1 across:877024k SS
[ 4.661495] usb 1-1: usb_suspend_both: status 0
[ 4.661604] usb usb1: usb_suspend_both: status 0
[ 4.665522] zram2: detected capacity change from 0 to 898076672
[ 4.692079] Adding 877024k swap on /dev/zram2. Priority:5 extents:1 across:877024k SS
[ 4.705306] zram3: detected capacity change from 0 to 898076672
[ 4.721750] Adding 877024k swap on /dev/zram3. Priority:5 extents:1 across:877024k SS
[ 4.847801] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4.928977] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 4.934391] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.671820] fuse init (API version 7.26)
[ 6.981474] tegra-xusb 3530000.xhci: entering ELPG
[ 6.985250] tegra-xusb 3530000.xhci: entering ELPG done
