I used JetPack3.3 on my board,but can’t display; I found that the log on the development board more lines, as follows:
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=tty
S0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegra
fb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0
x2772e0000 gpt tegra_fbmem2=0x800000@0x969ee000 lut_mem2=0x2008@0x969eb000 tegr
aid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetv
alues=0.2.1 androidboot.serialno=0324817094137 bl_prof_dataptr=0x10000@0x277040
000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstyp
e=ext4
[ 0.209125] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ee000(800000)
[ 0.209146] platform 15210000.nvdisplay: IOVA linear map 0x00000000969eb000(3000)
But,Don’t the log on my board.I feel no mapping,but I don’t know why?
I joined in the uboot command line parameters:
BUt,Into the kernel,This parameter was done not have on my board.
I used JetPack3.0 on my board,HDMI display is normal.Is JetPack3.0 and JetPack3.3 in HDMI implementation mechanism not the same?
How should I solve it?
Thank you!
wawxh1101,
Please share full log of your dmesg of Jetpack3.0 and Jetpack3.3.
JetPack3.0 log:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.15-tegra (buildbrain@mobile-u64-1423) (gcc ver
sion 4.8.5 (GCC) ) #1 SMP PREEMPT Wed Mar 1 21:09:29 PST 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible i
d nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000f2000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1ffdf9000 s31104 r8192 d30
336 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa
ges: 2019520
[ 0.000000] Kernel command line: fbcon=map:0 net.ifnames=0 console=tty0 OS=l
4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon
=uart8250,mmio32,0x03100000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcp
us=6 android.kerneltype=normal androidboot.serialno=0335115020673 vpr_resize ro
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byt
es)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes
[ 0.000000] Memory: 7969692K/8206336K available (10164K kernel code, 1653K r
wdata, 5424K rodata, 1132K init, 679K bss, 171108K reserved, 65536K cma-reserve
d)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246
GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8
GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdca000000 ( 128
MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108
KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16
MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64
MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc200000000 ( 8192
MB)
[ 0.000000] .init : 0xffffffc000fba000 - 0xffffffc0010d5000 ( 1132
KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc000fba000 ( 15592
KB)
[ 0.000000] .data : 0xffffffc0010f4000 - 0xffffffc0012915b0 ( 1654
KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles
: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398
046511088ns
[ 0.008884] tegra-id: chipid=21817.
[ 0.012715] tegra-id: opt_subrevision=1.
[ 0.017532] Console: colour dummy device 80x25
[ 0.022466] console [tty0] enabled
[ 0.026000] kmemleak: Kernel memory leak detector disabled
[ 0.031696] Calibrating delay loop (skipped), value calculated using timer f
requency… 62.50 BogoMIPS (lpj=125000)
[ 0.042449] pid_max: default: 32768 minimum: 301
[ 0.047274] Security Framework initialized
[ 0.051548] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.058689] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byt
es)
[ 0.066623] Initializing cgroup subsys freezer
[ 0.071247] Initializing cgroup subsys debug
[ 0.075806] CPU0 ipc=752
[ 0.078446] CPU1 ipc=1024
[ 0.081168] CPU2 ipc=1024
[ 0.083884] CPU3 ipc=752
[ 0.086517] CPU4 ipc=752
[ 0.089149] CPU5 ipc=752
[ 0.091804] ASID allocator initialised with 65536 entries
[ 0.133969] CPU1: Booted secondary processor [4e0f0030]
[ 0.145578] CPU2: Booted secondary processor [4e0f0030]
[ 0.157390] CPU3: Booted secondary processor [411fd073]
[ 0.169378] CPU4: Booted secondary processor [411fd073]
[ 0.181379] CPU5: Booted secondary processor [411fd073]
[ 0.181418] Brought up 6 CPUs
[ 0.211625] SMP: Total of 6 processors activated.
[ 0.216512] CPU: All CPU(s) started at EL2
[ 0.221135] devtmpfs: initialized
[ 0.247762] Initilizing CustomIPI irq domain
[ 0.252447] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, m
ax_idle_ns: 7645041785100000 ns
[ 0.264919] pinctrl core: initialized pinctrl subsystem
[ 0.270691] OS set in device tree is L4T.
[ 0.275370] regulator-dummy: no parameters
[ 0.280272] Initializing plugin-manager
[ 0.284348] Plugin module not found
[ 0.288364] node /plugin-manager/soc-prod-a02-fragment match with chip-id A0
2P
[ 0.296299] node /plugin-manager/fragement@0 match with odm-data enable-tegr
a-wdt
[ 0.304677] node /plugin-manager/fragement@4 match with odm-data enable-tegr
a-wdt
[ 0.313224] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with b
oard >=3310-1000-300
[ 0.322806] node /plugin-manager/fragement-pmon-p3310-1000-300 match with bo
ard >=3310-1000-300
[ 0.332106] node /plugin-manager/fragement-pmon-p3310-1000-800 match with bo
ard >=3310-1000-800
[ 0.341338] node /plugin-manager/fragment-devslp@0 match with board >=3310-1
000-200
[ 0.349644] node /plugin-manager/fragment-500-pcie-config match with board >
=3310-1000-500
[ 0.358606] node /plugin-manager/fragment-500-xusb-config match with board >
=3310-1000-500
[ 0.367464] node /plugin-manager/fragment-500-e3325-pcie match with board >=
3310-1000-500
[ 0.376118] node /plugin-manager/fragment-p3310-c00-comm match with board >=
3310-1000-800
[ 0.384827] node /plugin-manager/fragment-p3310-c01 match with board >=3310-
1000-900
[ 0.393089] node /plugin-manager/fragment-p3310-c03 match with board >=3310-
1000-B00
[ 0.402196] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.410410] node /plugin-manager/fragment-p3310-c00-camera match with board
=3310-1000-800
[ 0.422062] Adding domain adsp-pd to PM domain ape-pd
[ 0.431574] NET: Registered protocol family 16
[ 0.437751] console [pstore-1] enabled
[ 0.441693] pstore: Registered ramoops as persistent store backend
[ 0.448155] ramoops: attached 0x200000@0x100000000, ecc: 0/0
[ 0.461602] cpuidle: using governor ladder
[ 0.473595] cpuidle: using governor menu
[ 0.479432] bpmp: waiting for handshake
[ 0.483477] bpmp: handshake completed
[ 0.487349] bpmp: synchronizing channels
[ 0.491462] bpmp: channels synchronized
[ 0.495467] bpmp: connect returned 0
[ 0.499752] tegra186-pmc device create success
[ 0.504404] scratch reg offset dts data not present
[ 0.509605] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl register
ed
[ 0.517154] PMC: configuring io pad defaults
[ 0.521648] T186 pmc padctrl driver initialized
[ 0.526381] ### PMC reset source: Software reset
[ 0.531195] ### PMC reset level: L1
[ 0.534836] ### PMC reset status reg: 0x2d
[ 0.539778] vdso: 2 pages (1 code @ ffffffc0010f9000, 1 data @ ffffffc0010f8
[ 0.547564] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.556178] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atom
ic allocations
[ 0.566324] tegra_powergate_init: DONE
[ 0.570364] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4
/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kern
el-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.589209] DTB Build time: Mar 1 2017 21:10:33
[ 0.595428] Tegra reboot handler registered.
[ 0.601306] Registering Tegra186 clocks (this may take a while)…done
[ 0.609865] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.616683] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.621624] arm-smmu 12000000.iommu: stage 1 translation
[ 0.627282] arm-smmu 12000000.iommu: stage 2 translation
[ 0.632936] arm-smmu 12000000.iommu: nested translation
[ 0.638503] arm-smmu 12000000.iommu: stream matching with 128 regist
er groups, mask 0x7f80
[ 0.647277] arm-smmu 12000000.iommu: SMMU address space size (0x800000) diff
ers from mapped region size (0x1000000)!
[ 0.658277] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 onl
y)
[ 0.665208] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IP
A
[ 0.672040] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit P
A
[ 0.719519] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.729956] iommu: Adding device 3460000.sdhci to group 0
[ 0.736180] iommu: Adding device 3400000.sdhci to group 1
[ 0.744489] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.750881] iommu: Adding device 3160000.i2c to group 3
[ 0.756683] iommu: Adding device c240000.i2c to group 4
[ 0.762425] iommu: Adding device 3180000.i2c to group 5
[ 0.768164] iommu: Adding device 3190000.i2c to group 6
[ 0.773991] iommu: Adding device 31b0000.i2c to group 7
[ 0.779748] iommu: Adding device 31c0000.i2c to group 8
[ 0.785487] iommu: Adding device c250000.i2c to group 9
[ 0.791229] iommu: Adding device 31e0000.i2c to group 10
[ 0.798469] iommu: Adding device 3210000.spi to group 11
[ 0.804338] iommu: Adding device c260000.spi to group 12
[ 0.810166] iommu: Adding device 3240000.spi to group 13
[ 0.816420] iommu: Adding device 3100000.serial to group 14
[ 0.822530] iommu: Adding device 3110000.serial to group 15
[ 0.828639] iommu: Adding device 3130000.serial to group 16
[ 0.835469] iommu: Adding device 2490000.ether_qos to group 17
[ 0.842002] iommu: Adding device b000000.rtcpu to group 18
[ 0.848510] Wake73 for irq=42
[ 0.851900] iommu: Adding device smmu_test to group 19
[ 0.857763] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.864413] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.871064] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.877713] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.884353] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.890998] mc-err: Set intmask: 0xf3140
[ 0.895276] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.902163] Wake76 for irq=199
[ 0.905354] Wake77 for irq=199
[ 0.908541] Wake78 for irq=199
[ 0.911728] Wake79 for irq=199
[ 0.914913] Wake80 for irq=199
[ 0.918099] Wake81 for irq=199
[ 0.921284] Wake82 for irq=199
[ 0.924615] iommu: Adding device 3530000.xhci to group 20
[ 0.930588] iommu: Adding device 3550000.xudc to group 21
[ 0.936943] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.943129] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.950934] iommu: Adding device 13e10000.host1x to group 22
[ 0.957097] iommu: Adding device 13e10000.host1x:ctx0 to group 23
[ 0.963656] iommu: Adding device 13e10000.host1x:ctx1 to group 24
[ 0.970206] iommu: Adding device 13e10000.host1x:ctx2 to group 25
[ 0.976757] iommu: Adding device 13e10000.host1x:ctx3 to group 26
[ 0.983364] iommu: Adding device 13e10000.host1x:ctx4 to group 27
[ 0.989920] iommu: Adding device 13e10000.host1x:ctx5 to group 28
[ 0.996488] iommu: Adding device 13e10000.host1x:ctx6 to group 29
[ 1.003097] iommu: Adding device 13e10000.host1x:ctx7 to group 30
[ 1.009864] iommu: Adding device 150c0000.nvcsi to group 31
[ 1.016124] iommu: Adding device 15700000.vi to group 32
[ 1.021979] iommu: Adding device 15600000.isp to group 33
[ 1.027923] iommu: Adding device 15210000.nvdisplay to group 34
[ 1.034300] iommu: Adding device 15340000.vic to group 35
[ 1.040107] iommu: Adding device 154c0000.nvenc to group 36
[ 1.046111] iommu: Adding device 15480000.nvdec to group 37
[ 1.052241] iommu: Adding device 15380000.nvjpg to group 38
[ 1.058232] iommu: Adding device 15500000.tsec to group 39
[ 1.064144] iommu: Adding device 15100000.tsecb to group 40
[ 1.070530] iommu: Adding device 15810000.se to group 41
[ 1.076300] iommu: Adding device 15820000.se to group 42
[ 1.082034] iommu: Adding device 15830000.se to group 43
[ 1.087784] iommu: Adding device 15840000.se to group 44
[ 1.093816] iommu: Adding device 17000000.gp10b to group 45
[ 1.100757] tegra-reset 5000000.clock: registered 193 resets.
[ 1.108016] iommu: Adding device d000000.bpmp to group 46
[ 1.113852] bpmp: ping status is 0
[ 1.117549] bpmp d000000.bpmp: firmware tag is c11dd04ae487c849cc552f8f702ed
830
[ 1.127610] iommu: Adding device 2600000.dma to group 47
[ 1.134245] GPIO line 424 (wifi-enable) hogged as output/high
[ 1.140293] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 1.146239] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 1.152813] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-
gpio
[ 1.162338] GPIO line 315 (wifi-wake-ap) hogged as input
[ 1.167988] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-
gpio-aon
[ 1.177003] iommu: Adding device 10003000.pcie-controller to group 48
[ 1.183978] iommu: Adding device sound to group 49
[ 1.190552] iommu: Adding device 3510000.hda to group 50
[ 1.197132] iommu: Adding device adsp_audio to group 51
[ 1.203783] iommu: Adding device 2993000.adsp to group 52
[ 1.214656] iommu: Adding device c160000.aon to group 53
[ 1.222198] vdd-ac-bat: 5000 mV
[ 1.227274] vdd-1v8-ap: 1800 mV
[ 1.231618] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 1.237443] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 1.259883] SCSI subsystem initialized
[ 1.264151] usbcore: registered new interface driver usbfs
[ 1.269943] usbcore: registered new interface driver hub
[ 1.275592] usbcore: registered new device driver usb
[ 1.283967] GPIO line 241 (touch-rail-1) hogged as output/high
[ 1.290314] GPIO line 242 (touch-rail-2) hogged as output/high
[ 1.296494] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca953
9
[ 1.304731] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca953
9
[ 1.312369] tps65132 0-003e: No active discharge gpio for regulator tps65132
-outp
[ 1.320325] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.327424] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.334381] outp: 4000 <–> 6000 mV
[ 1.338158] tps65132 0-003e: No active discharge gpio for regulator tps65132
-outn
[ 1.346129] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.353222] tegra-i2c 3160000.i2c: no acknowledge from address 0x3e
[ 1.360172] outn: 4000 <–> 6000 mV
[ 1.374650] media: Linux media interface: v0.10
[ 1.379459] Linux video capture interface: v2.00
[ 1.388057] pps_core: LinuxPPS API ver. 1 registered
[ 1.393251] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom
etti giometti@linux.it
[ 1.402812] PTP clock support registered
[ 1.408607] Tegra WDT setup timeout = 120 seconds.
[ 1.413636] tegra_wdt_t18x 30c0000.watchdog: tegra_wdt_t18x_probe done
[ 1.421843] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 1.429711] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 1.435957] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 1.442177] gpiochip_add_data: registered GPIOs 216 to 223 on device: max776
20-gpio
[ 1.453750] vddio-ddr: at 1125 mV
[ 1.461596] avdd_dsi_csi: 1200 mV
[ 1.469595] vdd-1v8: 1800 mV
[ 1.477597] vdd-3v3-sys: 3300 mV
[ 1.482104] spmic-ldo0: at 1800 mV
[ 1.486482] spmic-ldo1: at 800 mV
[ 1.493598] vddio-3v3: 3300 mV
[ 1.497492] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 1.505596] vdd-rtc: 1000 mV
[ 1.509452] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 1.517600] spmic-ldo6: at 1500 mV
[ 1.522023] vdd-pex-1v05: 1000 mV
[ 1.526201] dvdd-pex: 1000 mV
[ 1.529770] max77620 4-003c: max77620 probe successful
[ 1.535453] Advanced Linux Sound Architecture Driver Initialized.
[ 1.543303] en-vdd-sd: 3300 mV
[ 1.547078] en-vdd-cam: 1800 mV
[ 1.550922] vdd-hdmi: 5000 mV
[ 1.554366] vdd-usb0-5v: 5000 mV
[ 1.558084] vdd-usb1-5v: 5000 mV
[ 1.565598] en-vdd-ts-1v8: 1800 mV
[ 1.573597] en-vdd-ts-hv-3v3: 3300 mV
[ 1.577948] en-vdd-disp-3v3: 3300 mV
[ 1.582213] en-mdm-pwr-3v7: 3700 mV
[ 1.586380] en-vdd-disp-1v8: 1800 mV
[ 1.590626] en-vdd-cam-hv-2v8: 2800 mV
[ 1.595090] en-vdd-cam-1v2: 1200 mV
[ 1.599255] vdd-fan: 5000 mV
[ 1.602524] vdd-3v3: 3300 mV
[ 1.606174] dis-vdd-1v2: 1200 mV
[ 1.609824] en-vdd-vcm-2v8: 2800 mV
[ 1.613991] vdd-usb2-5v: 5000 mV
[ 1.617624] vdd-sys-bl: 3300 mV
[ 1.621438] en-vdd-sys: 1200 mV
[ 1.625812] gpio tegra-gpio wake53 for gpio=159(X:5)
[ 1.632784] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 1.640356] clocksource: Switched to clocksource arch_sys_counter
[ 1.676891] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 1.683959] nvmap_page_pool_init: Total RAM pages: 2008807
[ 1.689678] nvmap_page_pool_init: nvmap page pool size: 251100 pages (980 MB
[ 1.692018] Wake76 for irq=199
[ 1.692022] Wake77 for irq=199
[ 1.692024] Wake78 for irq=199
[ 1.692025] Wake79 for irq=199
[ 1.692027] Wake80 for irq=199
[ 1.692029] Wake81 for irq=199
[ 1.692031] Wake82 for irq=199
[ 1.693305] thermal thermal_zone0: Registering thermal zone thermal_zone0 fo
r type BCPU-therm
[ 1.693535] thermal thermal_zone1: Registering thermal zone thermal_zone1 fo
r type MCPU-therm
[ 1.693644] thermal thermal_zone2: Registering thermal zone thermal_zone2 fo
r type GPU-therm
[ 1.693734] thermal thermal_zone3: Registering thermal zone thermal_zone3 fo
r type PLL-therm
[ 1.694136] thermal thermal_zone4: Registering thermal zone thermal_zone4 fo
r type AO-therm
[ 1.694269] thermal thermal_zone5: Registering thermal zone thermal_zone5 fo
r type Tboard_tegra
[ 1.694398] thermal thermal_zone6: Registering thermal zone thermal_zone6 fo
r type Tdiode_tegra
[ 1.694530] thermal thermal_zone7: Registering thermal zone thermal_zone7 fo
r type PMIC-Die
[ 1.694556] isomgr_init(): iso emc max clk=1866000KHz
[ 1.694558] isomgr_init(): max_iso_bw=26870400KB
[ 1.694777] tegra186-pmc-iopower pmc-iopower: Rail iopower-sys is having fix
ed voltage 1800000
[ 1.694871] tegra186-pmc-iopower pmc-iopower: Rail iopower-uart is having fi
xed voltage 1800000
[ 1.694931] tegra186-pmc-iopower pmc-iopower: Rail iopower-conn is having fi
xed voltage 1800000
[ 1.694986] tegra186-pmc-iopower pmc-iopower: Rail iopower-edp is having fix
ed voltage 1800000
[ 1.695046] tegra186-pmc-iopower pmc-iopower: Rail iopower-pex-ctrl-audio is
having fixed voltage 1800000
[ 1.695105] tegra186-pmc-iopower pmc-iopower: Rail iopower-ufs is having fix
ed voltage 1800000
[ 1.695174] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr0 is having fi
xed voltage 0
[ 1.695222] tegra186-pmc-iopower pmc-iopower: Rail iopower-ddr1 is having fi
xed voltage 0
[ 1.695269] tegra186-pmc-iopower pmc-iopower: Rail iopower-csi-dsi is having
fixed voltage 1200000
[ 1.695326] tegra186-pmc-iopower pmc-iopower: Rail iopower-cam is having fix
ed voltage 1800000
[ 1.695389] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc4 is having
[ 1.695452] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc1-hv is havi
ng voltages: 1800000:3300000
[ 1.695513] tegra186-pmc-iopower pmc-iopower: Rail iopower-audio-hv is havin
[ 1.695570] tegra186-pmc-iopower pmc-iopower: Rail iopower-dbg is having fix
ed voltage 1800000
[ 1.695660] tegra186-pmc-iopower pmc-iopower: Rail iopower-spi is having fix
ed voltage 1800000
[ 1.695719] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao is having fixe
d voltage 1800000
[ 1.695793] tegra186-pmc-iopower pmc-iopower: Rail iopower-ao-hv is having f
ixed voltage 3300000
[ 1.695857] tegra186-pmc-iopower pmc-iopower: Rail iopower-dmic-hv is having
[ 1.695914] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc2-hv is havi
ng fixed voltage 3300000
[ 1.695965] tegra186-pmc-iopower pmc-iopower: Rail iopower-sdmmc3-hv is havi
[ 1.695975] tegra186-pmc-iopower pmc-iopower: NO_IO_POWER setting 0x00000000
[ 1.696230] NET: Registered protocol family 2
[ 1.696848] TCP established hash table entries: 65536 (order: 7, 524288 byte
s)
[ 1.697630] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 1.698893] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.698964] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.699192] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 1.699497] NET: Registered protocol family 1
[ 1.699830] RPC: Registered named UNIX socket transport module.
[ 1.699833] RPC: Registered udp transport module.
[ 1.699835] RPC: Registered tcp transport module.
[ 1.699837] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.700009] Unpacking initramfs…
[ 1.873877] Freeing initrd memory: 6104K (ffffffc018000000 - ffffffc0185f600
0)
[ 1.889210] host1x 13e10000.host1x: initialized
[ 1.899471] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters a
vailable
[ 1.900479] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 1.900608] audit: initializing netlink subsys (disabled)
[ 1.900650] audit: type=2000 audit(1.860:1): initialized
[ 1.908336] io scheduler noop registered (default)
[ 1.913892] Adding domain tsec-pd to PM domain host-pd
[ 1.916488] tsec 15500000.tsec: initialized
[ 1.917786] tsec 15100000.tsecb: initialized
[ 1.918126] Adding domain nvdec-pd to PM domain host-pd
[ 1.919968] nvdec 15480000.nvdec: initialized
[ 1.920641] Adding domain vic03-pd to PM domain host-pd
[ 1.920664] Adding domain msenc-pd to PM domain host-pd
[ 1.920686] Adding domain nvjpg-pd to PM domain host-pd
[ 1.924291] falcon 15340000.vic: initialized
[ 1.925494] falcon 154c0000.nvenc: initialized
[ 1.926693] falcon 15380000.nvjpg: initialized
[ 1.927779] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56
[ 1.928679] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57
[ 1.929480] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58
[ 1.930281] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59
[ 1.931075] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60
[ 1.931856] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61
[ 1.932642] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62
[ 1.933414] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63
[ 1.934883] tegradc 15210000.nvdisplay: Display dc.15210000 registered with
id=0
[ 1.934890] DC OR NODE connected to /host1x/sor1
[ 1.934926] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:
camera_platform_driver probe
[ 1.934954] parse_tmds_config: No tmds-config node
[ 1.935048] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=
1250000, vi_iso_bw=1500000, max_bw=1500000
[ 1.935051] tegradc 15210000.nvdisplay: DT parsed successfully
[ 1.941869] tegra_nvdisp_bandwidth_register_max_config: max config iso bw =
16727000 KB/s
[ 1.941871] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor
= 665600000 Hz
[ 1.941873] tegra_nvdisp_bandwidth_register_max_config: max config hubclk =
357620000 Hz
[ 1.941903] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 1.941908] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 1.943590] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 1.944267] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initi
alized
[ 1.944569] PD DISP0 index2 UP
[ 1.944677] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.944973] PD DISP1 index3 UP
[ 1.945048] PD DISP2 index4 UP
[ 1.947045] console [ttyS0] disabled
[ 1.971731] PD DISP2 index4 DOWN
[ 1.971826] PD DISP1 index3 DOWN
[ 1.971907] PD DISP0 index2 DOWN
[ 1.973513] tegradc 15210000.nvdisplay: probed
[ 2.348925] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 2
5500000) is a Tegra
[ 2.349068] nvmap_background_zero_thread: PP zeroing thread starting.
[ 2.362836] Console: switching to colour frame buffer device 240x67
[ 2.398281] tegradc 15210000.nvdisplay: fb registered
[ 2.408654] console [ttyS0] enabled
[ 2.408708] gpio tegra-gpio wake21 for gpio=121(P:2)
[ 2.408745] PD DISP0 index2 UP
[ 2.415802] PD DISP1 index3 UP
[ 2.425959] PD DISP2 index4 UP
[ 2.444731] bootconsole [uart0] disabled
[ 2.459172] rate get on hub 408000000
[ 2.459785] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud =
0) is a TEGRA_UART
[ 2.459950] serial-tegra 3130000.serial: RX in PIO mode
[ 2.460715] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 38, base_baud =
0) is a TEGRA_UART
[ 2.463254] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.463267] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.463269] nct1008_nct72 7-004c: starting parse dt
[ 2.463331] nct1008_nct72 7-004c: success parsing dt
[ 2.463431] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.489601] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.498093] tmp451: Enabled overheat logging at 104.00C
[ 2.498183] gpio tegra-gpio-aon wake35 for gpio=16(V:2)
[ 2.498208] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.500552] THERMAL EST: found 3 subdevs
[ 2.500556] THERMAL EST num_resources: 0
[ 2.500558] [THERMAL EST subdev 0]
[ 2.500561] [THERMAL EST subdev 1]
[ 2.500563] [THERMAL EST subdev 2]
[ 2.500770] thermal thermal_zone8: Registering thermal zone thermal_zone8 fo
r type thermal-fan-est
[ 2.500772] THERMAL EST: thz register success.
[ 2.500866] THERMAL EST: end of probe, return err: 0
[ 2.501037] tegra_profiler: Branch: Dev
[ 2.501039] tegra_profiler: Version: 1.109
[ 2.501040] tegra_profiler: Samples version: 37
[ 2.501041] tegra_profiler: IO version: 20
[ 2.501045] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.501047] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.501049] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.501051] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 2.501053] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.501054] armv8_pmu: arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 2.501056] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.501058] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.501060] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.501061] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.501063] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.501064] armv8_pmu: arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.501186] tegra_profiler: auth: init
[ 2.503766] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3
Gbps 0x1 impl platform mode
[ 2.503773] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp p
io slum part deso sadm apst
[ 2.504452] scsi host0: tegra_ahci
[ 2.504717] scsi host1: tegra_ahci
[ 2.504833] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x
100 irq 24
[ 2.504835] ata2: DUMMY
[ 2.505451] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.505805] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.506112] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.506727] tun: Universal TUN/TAP device driver, 1.6
[ 2.506728] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.506827] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 2.506828] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 2.506859] igb: Intel® Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.506860] igb: Copyright © 2007-2014 Intel Corporation.
[ 2.506991] PPP generic driver version 2.4.2
[ 2.507075] PPP BSD Compression module registered
[ 2.507078] PPP Deflate Compression module registered
[ 2.507087] PPP MPPE Compression module registered
[ 2.507093] NET: Registered protocol family 24
[ 2.507128] usbcore: registered new interface driver asix
[ 2.507148] usbcore: registered new interface driver ax88179_178a
[ 2.507168] usbcore: registered new interface driver cdc_ether
[ 2.507202] usbcore: registered new interface driver smsc95xx
[ 2.507222] usbcore: registered new interface driver net1080
[ 2.507241] usbcore: registered new interface driver cdc_subset
[ 2.507260] usbcore: registered new interface driver zaurus
[ 2.507295] usbcore: registered new interface driver cdc_ncm
[ 2.507587] usbcore: registered new interface driver usb-storage
[ 2.507632] usbcore: registered new interface driver usbserial
[ 2.507652] usbcore: registered new interface driver ftdi_sio
[ 2.507667] usbserial: USB Serial support registered for FTDI USB Serial Dev
ice
[ 2.507685] usbcore: registered new interface driver option
[ 2.507697] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.507714] usbcore: registered new interface driver pl2303
[ 2.507727] usbserial: USB Serial support registered for pl2303
[ 2.507886] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.509748] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.641389] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as
rtc0
[ 2.643885] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.643897] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.644048] i2c /dev entries driver
[ 2.644828] [OV5693]: probing v4l2 sensor.
[ 2.824381] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.052631] Parent Clock set for DC plld2
[ 3.063972] dc clk 148500000
[ 3.072468] tegradc 15210000.nvdisplay: Link compression not supported by th
e panel
[ 3.082039] rate get on compclk 148500000
[ 3.104064] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 3.120728] tegradc 15210000.nvdisplay: Window 4 assigned to head 1
[ 3.137385] tegradc 15210000.nvdisplay: Window 5 assigned to head 1
[ 3.271021] tegradc 15210000.nvdisplay: vrr_setup failed
[ 3.428719] gspca_main: v2.14.0 registered
[ 3.428760] usbcore: registered new interface driver gspca_zc3xx
[ 3.429047] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.430660] FAN dev name: pwm-fan
[ 3.430701] FAN:gpio request success.
[ 3.430707] FAN: can’t find tach_gpio
[ 3.430723] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.430867] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.430871] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.430874] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.431156] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, s
tate:2
[ 3.431160] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2,
state:2
[ 3.431163] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1
, state:2
[ 3.431166] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1
, state:2
[ 3.431169] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1
, state:3
[ 3.431171] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1
, state:3
[ 3.431174] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1
, state:3
[ 3.431177] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1
, state:4
[ 3.431180] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=
1, state:4
[ 3.431183] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=
1, state:4
[ 3.431590] device-mapper: uevent: version 1.0.3
[ 3.431763] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-
devel@redhat.com
[ 3.431963] sdhci: Secure Digital Host Controller Interface driver
[ 3.431964] sdhci: Copyright© Pierre Ossman
[ 3.431968] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.432236] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.432503] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=19624
9804
[ 3.432855] sdhci-tegra 3460000.sdhci: Client registration for eMC Successfu
l
[ 3.432924] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.433372] hidraw: raw HID events driver © Jiri Kosina
[ 3.434845] sdhci-tegra 3460000.sdhci: voltage switch failed in probe, err:
-524
[ 3.434878] usbcore: registered new interface driver usbhid
[ 3.434879] usbhid: USB HID core driver
[ 3.437149] nvadsp 2993000.adsp: in probe()…
[ 3.438017] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.438045] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.438166] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.438630] tegra_central_actmon d230000.actmon: in probe()…
[ 3.440764] tegra_central_actmon d230000.actmon: initialization Completed fo
r the device mc_all
[ 3.441202] kfuse 3830000.kfuse: initialized
[ 3.441514] Denver: backdoor interface is NOT available.
[ 3.442502] coresight-tmc 8030000.etf: TMC initialized
[ 3.442814] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.443243] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.443603] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.443984] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.444544] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.445025] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.445504] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.445986] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.446009] Module initialized successfully
[ 3.449486] camchar: rtcpu character device driver loaded
[ 3.451250] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.451381] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.451445] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.452005] **** A57 ECC: Enabled
[ 3.452007] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 3.452132] parse_throttle_dt_data: Num cap clks = 4
[ 3.452134] parse_throttle_dt_data: clk=mcpu type=1
[ 3.452136] parse_throttle_dt_data: clk=bcpu type=2
[ 3.452141] parse_throttle_dt_data: clk=gpu type=4
[ 3.452143] parse_throttle_dt_data: clk=emc type=3
[ 3.452577] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.452766] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 co
unters available
[ 3.453184] Adding domain se-pd to PM domain host-pd
[ 3.454626] tegra-se-nvhost 15810000.se: initialized
[ 3.455023] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.455316] tegra-se-nvhost 15820000.se: initialized
[ 3.455764] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.456024] tegra-se-nvhost 15830000.se: initialized
[ 3.456329] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.456608] tegra-se-nvhost 15840000.se: initialized
[ 3.456998] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.460841] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.463146] cpufreq: platform driver Initialization: pass
[ 3.463381] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x00000000035
20000 end 0x0000000003520fff
[ 3.463385] tegra186-padctl 3520000.pinctrl: ao mmio start 0x000000000354000
0 end 0x0000000003540fff
[ 3.463415] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ca895
[ 3.463417] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.464570] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.465569] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supporte
d
[ 3.466845] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.466972] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.468314] tachometer tegra-tachometer: Tachometer driver tegra-tachometer
registered
[ 3.468320] Tachometer driver initialized with pulse_per_rev: 1 and win_len:
1
[ 3.468366] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using AD
MA 64-bit with 64 bit addr
[ 3.468515] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.469754] sdhci-tegra 3440000.sdhci: Client registration for eMC Successfu
l
[ 3.470171] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 ca fd
[ 3.470774] libphy: dwc_phy: probed
[ 3.471688] sdhci-tegra 3440000.sdhci: voltage switch failed in probe, err:
-524
[ 3.472163] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.472711] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 3.472711] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec
1
[ 3.472943] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.473245] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.473503] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec
1
[ 3.476616] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.476620] tegra210-adsp adsp_audio: adma channel page address dt entry not
found
[ 3.476622] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.477616] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.477616] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/car
d0/input0
[ 3.477735] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/car
d0/input1
[ 3.486120] OPE platform probe
[ 3.486187] OPE platform probe successful
[ 3.496378] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO
, should be handled by codec
[ 3.504373] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using AD
[ 3.504630] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.504667] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.504721] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.504787] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 247
[ 3.504989] sdhci-tegra 3400000.sdhci: Client registration for eMC Successfu
l
[ 3.506743] mmc0: MAN_BKOPS_EN bit is not set
[ 3.506808] sdhci-tegra 3400000.sdhci: voltage switch failed in probe, err:
-524
[ 3.513845] mmc0: Skipping tuning since strobe enabled
[ 3.521292] mmc0: periodic cache flush enabled
[ 3.521300] mmc0: new HS400 MMC card at address 0001
[ 3.521578] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.521711] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.522724] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
p17
[ 3.533619] pad_id 28: PMC_IMPL_E_33V_PWR_0 = [0x39]
[ 3.533619] gpio tegra-gpio wake18 for gpio=101(M:3)
[ 3.533787] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 3.542685] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mappi
ng ok
[ 3.542761] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mappi
ng ok
[ 3.542827] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mappi
ng ok
[ 3.542893] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mappi
ng ok
[ 3.542965] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mappi
ng ok
[ 3.543031] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mappi
ng ok
[ 3.543099] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mappi
ng ok
[ 3.543167] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mappi
ng ok
[ 3.543233] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mappi
ng ok
[ 3.543301] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 map
ping ok
[ 3.543372] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 map
ping ok
[ 3.543442] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 map
ping ok
[ 3.543514] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 map
ping ok
[ 3.543580] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 map
ping ok
[ 3.543648] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 map
ping ok
[ 3.543715] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 map
ping ok
[ 3.543786] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 map
ping ok
[ 3.543854] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 map
ping ok
[ 3.543922] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 map
ping ok
[ 3.543990] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 map
ping ok
[ 3.544457] gpio tegra-gpio wake71 for gpio=125(P:6)
[ 3.544487] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using AD
[ 3.545048] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 ma
pping ok
[ 3.545120] t
JetPack3.3
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc vers
ion 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[ 0.000000] Found tegra_fbmem2: 00800000@969ee000
[ 0.000000] Found lut_mem2: 00002008@969eb000
d nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30
080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=174096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
ges: 2019936
e=ext4
es)
[ 0.000000] Memory: 7967768K/8208384K available (11296K kernel code, 1841K r
wdata, 5796K rodata, 1168K init, 691K bss, 175080K reserved, 65536K cma-reserve
d)
GB)
GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125
MB actual)
KB)
MB)
MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040
MB)
.init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168
KB)
.text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096
KB)
.data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842
KB)
046511088ns
[ 0.009853] Console: colour dummy device 80x25
[ 0.014513] console [tty0] enabled
[ 0.018070] bootconsole [uart0] disabled
[ 0.022174] kmemleak: Kernel memory leak detector disabled
[ 0.022186] Calibrating delay loop (skipped), value calculated using timer f
[ 0.022198] pid_max: default: 32768 minimum: 301
[ 0.022247] Security Framework initialized
[ 0.022285] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022296] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byt
es)
[ 0.022676] Initializing cgroup subsys io
[ 0.022690] Initializing cgroup subsys memory
[ 0.022706] Initializing cgroup subsys devices
[ 0.022715] Initializing cgroup subsys freezer
[ 0.022724] Initializing cgroup subsys net_cls
[ 0.022734] Initializing cgroup subsys perf_event
[ 0.022743] Initializing cgroup subsys net_prio
[ 0.022753] Initializing cgroup subsys pids
[ 0.022762] Initializing cgroup subsys debug
[ 0.022902] CPU0 ipc=752
[ 0.022911] CPU1 ipc=1024
[ 0.022919] CPU2 ipc=1024
[ 0.022928] CPU3 ipc=752
[ 0.022936] CPU4 ipc=752
[ 0.022946] CPU5 ipc=752
[ 0.022982] ASID allocator initialised with 65536 entries
[ 0.046211] tegra-id: chipid=21817.
[ 0.046229] tegra-id: opt_subrevision=1.
[ 0.046242] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046935] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4
[ 0.046960] DTB Build time: May 17 2018 00:17:47
[ 0.062570] CPU1: Booted secondary processor [4e0f0030]
[ 0.074127] CPU2: Booted secondary processor [4e0f0030]
[ 0.085800] CPU3: Booted secondary processor [411fd073]
[ 0.097815] CPU4: Booted secondary processor [411fd073]
[ 0.109802] CPU5: Booted secondary processor [411fd073]
[ 0.109865] Brought up 6 CPUs
[ 0.109921] SMP: Total of 6 processors activated.
[ 0.109933] CPU: All CPU(s) started at EL2
[ 0.110353] devtmpfs: initialized
[ 0.137006] Initilizing CustomIPI irq domain
[ 0.137204] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, m
[ 0.137988] pinctrl core: initialized pinctrl subsystem
[ 0.138165] OS set in device tree is not L4T.
[ 0.138356] regulator-dummy: no parameters
[ 0.138461] Initializing plugin-manager
[ 0.138514] Plugin module not found
[ 0.138934] node /plugin-manager/soc-prod-a02-fragment match with chip-id A0
2P
[ 0.139275] node /plugin-manager/fragement@0 match with odm-data enable-denv
er-wdt
[ 0.139900] node /plugin-manager/fragement@4 match with odm-data enable-denv
er-wdt
[ 0.141089] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with b
[ 0.141465] node /plugin-manager/fragement-pmon-p3310-1000-300 match with bo
ard >=3310-1000-300
[ 0.141728] node /plugin-manager/fragement-pmon-p3310-1000-800 match with bo
ard >=3310-1000-800
[ 0.141952] node /plugin-manager/fragment-devslp@0 match with board >=3310-1
000-200
[ 0.142383] node /plugin-manager/fragment-500-pcie-config match with board >
=3310-1000-500
[ 0.142837] node /plugin-manager/fragment-500-xusb-config match with board >
=3310-1000-500
[ 0.143118] node /plugin-manager/fragment-500-e3325-pcie match with board >=
3310-1000-500
[ 0.143508] node /plugin-manager/fragment-p3310-c00-comm match with board >=
3310-1000-800
[ 0.143758] node /plugin-manager/fragment-p3310-c00-pmic match with board >=
3310-1000-800
[ 0.143984] node /plugin-manager/fragment-p3310-c01 match with board >=3310-
1000-900
[ 0.144246] node /plugin-manager/fragment-p3310-c03 match with board >=3310-
1000-B00
[ 0.145857] node /plugin-manager/fragment-e3326@0 match with board 3326-
[ 0.146966] node /plugin-manager/fragment-p3310-c00-camera match with board
=3310-1000-800
[ 0.148791] Adding domain adsp-pd to PM domain ape-pd
[ 0.151185] NET: Registered protocol family 16
[ 0.152031] console [pstore-1] enabled
[ 0.152044] pstore: Registered ramoops as persistent store backend
[ 0.152057] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161352] cpuidle: using governor ladder
[ 0.165800] cpuidle: using governor menu
[ 0.166935] bpmp: waiting for handshake
[ 0.166950] bpmp: handshake completed
[ 0.166990] bpmp: synchronizing channels
[ 0.167019] bpmp: channels synchronized
[ 0.167030] bpmp: mail init ok
[ 0.167394] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c
[ 0.167427] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168370] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atom
ic allocations
[ 0.169808] tegra_powergate_init: DONE
[ 0.169829] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4
[ 0.169856] DTB Build time: May 17 2018 00:17:47
[ 0.170795] Tegra reboot handler registered.
[ 0.171863] Registering Tegra186 clocks (this may take a while)…done
[ 0.174008] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.174026] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174040] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174052] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174064] arm-smmu 12000000.iommu: nested translation
[ 0.174078] arm-smmu 12000000.iommu: stream matching with 128 regist
[ 0.174097] arm-smmu 12000000.iommu: SMMU address space size (0x800000) diff
[ 0.174116] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 onl
y)
[ 0.174130] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IP
A
[ 0.174143] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit P
A
[ 0.192687] /iommu@12000000: could not get #stream-id-cells for /pcie-contro
ller@10003000
[ 0.192706] arm-smmu 12000000.iommu: registered 40 master devices
[ 0.195316] iommu: Adding device 3460000.sdhci to group 0
[ 0.195764] iommu: Adding device 3400000.sdhci to group 1
[ 0.202174] iommu: Adding device 2490000.ether_qos to group 2
[ 0.203396] Wake73 for irq=42
[ 0.203581] iommu: Adding device smmu_test to group 3
[ 0.203961] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.203983] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.204002] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.204021] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.204042] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.204061] mc-err: Set intmask: 0xf3140
[ 0.204204] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.204804] Wake76 for irq=199
[ 0.204817] Wake77 for irq=199
[ 0.204827] Wake78 for irq=199
[ 0.204837] Wake79 for irq=199
[ 0.204846] Wake80 for irq=199
[ 0.204856] Wake81 for irq=199
[ 0.204865] Wake82 for irq=199
[ 0.204933] iommu: Adding device 3530000.xhci to group 4
[ 0.205197] iommu: Adding device 3550000.xudc to group 5
[ 0.205710] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.205726] tegra-pmc: ### PMC reset source: Power on reset
[ 0.205738] tegra-pmc: ### PMC reset level: L0
[ 0.205748] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.205905] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl register
ed
[ 0.205925] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.206025] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.206041] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.206364] iommu: Adding device 13e10000.host1x to group 6
[ 0.206508] iommu: Adding device 13e10000.host1x:ctx0 to group 7
[ 0.206667] iommu: Adding device 13e10000.host1x:ctx1 to group 8
[ 0.206813] iommu: Adding device 13e10000.host1x:ctx2 to group 9
[ 0.206959] iommu: Adding device 13e10000.host1x:ctx3 to group 10
[ 0.207112] iommu: Adding device 13e10000.host1x:ctx4 to group 11
[ 0.207257] iommu: Adding device 13e10000.host1x:ctx5 to group 12
[ 0.207405] iommu: Adding device 13e10000.host1x:ctx6 to group 13
[ 0.207558] iommu: Adding device 13e10000.host1x:ctx7 to group 14
[ 0.207862] iommu: Adding device 150c0000.nvcsi to group 15
[ 0.208270] iommu: Adding device 15700000.vi to group 16
[ 0.208498] iommu: Adding device 15600000.isp to group 17
[ 0.208727] iommu: Adding device 15210000.nvdisplay to group 18
[ 0.208806] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ee000(
800000)
[ 0.208827] platform 15210000.nvdisplay: IOVA linear map 0x00000000969eb000(
3000)
[ 0.208943] iommu: Adding device 15340000.vic to group 19
[ 0.209081] iommu: Adding device 154c0000.nvenc to group 20
[ 0.209206] iommu: Adding device 15480000.nvdec to group 21
[ 0.209449] iommu: Adding device 15380000.nvjpg to group 22
[ 0.209577] iommu: Adding device 15500000.tsec to group 23
[ 0.209708] iommu: Adding device 15100000.tsecb to group 24
[ 0.210227] iommu: Adding device 15810000.se to group 25
[ 0.210357] iommu: Adding device 15820000.se to group 26
[ 0.210489] iommu: Adding device 15830000.se to group 27
[ 0.210760] iommu: Adding device 15840000.se to group 28
[ 0.211991] iommu: Adding device 17000000.gp10b to group 29
[ 0.214845] tegra-reset 5000000.clock: registered 193 resets.
[ 0.217659] bpmp: ping status is 0
[ 0.217954] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 0.217979] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x0000
0000, GFSYNR1 0x00001432, GFSYNR2 0x00000000
[ 0.218046] bpmp d000000.bpmp: firmware tag is
[ 0.218097] (255) csw_bpmpw: MC request violates VPR requirements
[ 0.218111] status = 0x00337094; addr = 0x3ffffffc0
[ 0.218144] secure: yes, access-type: write
[ 0.218159] unknown mcerr fault, int_status=0x00000000, ch_int_status=0x0000
0000, hubc_int_status=0x00000000
[ 0.218186] unknown mcerr fault, int_status=0x00000000, ch_int_status=0x0000
[ 0.218196] unknown mcerr fault, int_status=0x00000000, ch_int_status=0x0000
[ 0.218206] mc-err: Too many MC errors; throttling prints
[ 0.218697] bpmp d000000.bpmp: probe ok
[ 0.222631] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.222691] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.222760] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.222807] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.222866] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.222915] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.222965] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.223089] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-
gpio
[ 0.224949] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.225048] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-
gpio-aon
[ 0.226084] iommu: Adding device sound to group 30
[ 0.227939] iommu: Adding device 3510000.hda to group 31
[ 0.229106] iommu: Adding device adsp_audio to group 32
[ 0.230578] iommu: Adding device 2993000.adsp to group 33
[ 0.240353] vdd-ac-bat: 5000 mV
[ 0.243111] vdd-1v8-ap: 1800 mV
[ 0.260758] SCSI subsystem initialized
[ 0.260979] libata version 3.00 loaded.
[ 0.261156] usbcore: registered new interface driver usbfs
[ 0.261219] usbcore: registered new interface driver hub
[ 0.261343] usbcore: registered new device driver usb
[ 0.265497] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.265951] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.266067] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca953
9
[ 0.267509] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.267633] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca953
9
[ 0.278585] media: Linux media interface: v0.10
[ 0.278693] Linux video capture interface: v2.00
[ 0.281784] pps_core: LinuxPPS API ver. 1 registered
[ 0.281824] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom
[ 0.281883] PTP clock support registered
[ 0.282914] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 se
c
[ 0.282990] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.284565] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.286629] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.286852] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.286971] gpiochip_add_data: registered GPIOs 216 to 223 on device: max776
20-gpio
[ 0.294752] vddio-ddr: at 1125 mV
[ 0.298585] avdd_dsi_csi: 1200 mV
[ 0.302598] vdd-1v8: 1800 mV
[ 0.306592] vdd-3v3-sys: 3300 mV
[ 0.307725] spmic-ldo0: at 1800 mV
[ 0.308576] spmic-ldo1: at 800 mV
[ 0.314582] vddio-3v3: 3300 mV
[ 0.315215] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.317349] vdd-rtc: at 800 mV
[ 0.318044] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.321348] spmic-ldo6: at 1500 mV
[ 0.325347] vdd-pex-1v05: 1000 mV
[ 0.325894] dvdd-pex: 1000 mV
[ 0.326148] max77620 4-003c: max77620 probe successful
[ 0.326403] Advanced Linux Sound Architecture Driver Initialized.
[ 0.327356] en-vdd-sd: 3300 mV
[ 0.327954] en-vdd-cam: 1800 mV
[ 0.329803] vdd-hdmi: 5000 mV
[ 0.329985] vdd-usb0-5v: 5000 mV
[ 0.330155] vdd-usb1-5v: 5000 mV
[ 0.333803] en-vdd-ts-1v8: 1800 mV
[ 0.337802] en-vdd-ts-hv-3v3: 3300 mV
[ 0.338321] en-vdd-disp-3v3: 3300 mV
[ 0.338830] en-mdm-pwr-3v7: 3700 mV
[ 0.339346] en-vdd-disp-1v8: 1800 mV
[ 0.339881] en-vdd-cam-hv-2v8: 2800 mV
[ 0.340405] en-vdd-cam-1v2: 1200 mV
[ 0.340930] vdd-fan: 5000 mV
[ 0.341041] vdd-3v3: 3300 mV
[ 0.341771] dis-vdd-1v2: 1200 mV
[ 0.341893] en-vdd-vcm-2v8: 2800 mV
[ 0.342429] vdd-usb2-5v: 5000 mV
[ 0.342539] vdd-sys-bl: 3300 mV
[ 0.343067] en-vdd-sys: 1200 mV
[ 0.346429] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.346850] clocksource: Switched to clocksource arch_sys_counter
[ 0.365072] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.365355] nvmap: nvmap_override_cache_ops() set roc flush ops to replace c
ache ops by set/ways
[ 0.365848] nvmap_page_pool_init: Total RAM pages: 2008326
[ 0.365866] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB
[ 0.366098] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.370553] Wake76 for irq=199
[ 0.370567] Wake77 for irq=199
[ 0.370578] Wake78 for irq=199
[ 0.370589] Wake79 for irq=199
[ 0.370599] Wake80 for irq=199
[ 0.370609] Wake81 for irq=199
[ 0.370618] Wake82 for irq=199
[ 0.371388] thermal thermal_zone0: Registering thermal zone thermal_zone0 fo
r type BCPU-therm
[ 0.371583] thermal thermal_zone1: Registering thermal zone thermal_zone1 fo
r type MCPU-therm
[ 0.371973] thermal thermal_zone2: Registering thermal zone thermal_zone2 fo
r type GPU-therm
[ 0.372052] thermal thermal_zone3: Registering thermal zone thermal_zone3 fo
r type PLL-therm
[ 0.372197] thermal thermal_zone4: Registering thermal zone thermal_zone4 fo
r type Tboard_tegra
[ 0.372340] thermal thermal_zone5: Registering thermal zone thermal_zone5 fo
r type Tdiode_tegra
[ 0.372487] thermal thermal_zone6: Registering thermal zone thermal_zone6 fo
r type PMIC-Die
[ 0.372778] isomgr_init(): iso emc max clk=1866000KHz
[ 0.372791] isomgr_init(): max_iso_bw=26870400KB
[ 0.372875] NET: Registered protocol family 2
[ 0.373185] TCP established hash table entries: 65536 (order: 7, 524288 byte
s)
[ 0.373415] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.373714] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.373772] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.373826] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.373994] NET: Registered protocol family 1
[ 0.374192] RPC: Registered named UNIX socket transport module.
[ 0.374208] RPC: Registered udp transport module.
[ 0.374220] RPC: Registered tcp transport module.
[ 0.374231] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.374252] PCI: CLS 0 bytes, default 128
[ 0.374347] Trying to unpack rootfs image as initramfs…
[ 0.388061] host1x 13e10000.host1x: initialized
[ 0.388915] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters a
vailable
[ 0.390786] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.390947] audit: initializing netlink subsys (disabled)
[ 0.390980] audit: type=2000 audit(0.380:1): initialized
[ 0.397778] io scheduler noop registered
[ 0.397886] io scheduler cfq registered (default)
[ 0.400766] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.401934] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.402994] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.404039] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.407487] tsec 15500000.tsec: initialized
[ 0.408609] tsec 15100000.tsecb: initialized
[ 0.410930] nvdec 15480000.nvdec: initialized
[ 0.414550] falcon 15340000.vic: initialized
[ 0.415548] falcon 154c0000.nvenc: initialized
[ 0.416532] falcon 15380000.nvjpg: initialized
[ 0.417287] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56
[ 0.417786] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57
[ 0.418278] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58
[ 0.418772] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59
[ 0.419284] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60
[ 0.419782] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61
[ 0.420273] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62
[ 0.420762] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63
[ 0.423332] DC OR NODE connected to /host1x/sor1
[ 0.423457] generic_infoframe_type: 0x87
[ 0.423468] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:
[ 0.423562] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso
= 3916800KBs
[ 0.423577] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.423593] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=
4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.423609] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 register
ed with id=0
[ 0.431174] tegra_nvdisp_bandwidth_register_max_config: max config iso bw =
16727000 KB/s
[ 0.431196] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor
= 665600000 Hz
[ 0.431213] tegra_nvdisp_bandwidth_register_max_config: max config hubclk =
357620000 Hz
[ 0.431261] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.431277] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.431505] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.431673] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.432173] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Dete
cted mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.433941] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initi
alized
[ 0.434275] kfuse 3830000.kfuse: initialized
[ 0.434282] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use d
efault range
[ 0.435654] tegradc 15210000.nvdisplay: probed
[ 0.436104] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.436567] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.438477] console [ttyS0] disabled
[ 0.438530] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 2
5500000) is a Tegra
[ 2.531569] console [ttyS0] enabled
[ 2.533744] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud =
0) is a TEGRA_UART
[ 2.534887] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud =
0) is a TEGRA_UART
[ 2.535129] serial-tegra 3130000.serial: RX in PIO mode
[ 2.536132] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud =
0) is a TEGRA_UART
[ 2.546427] Console: switching to colour frame buffer device 240x67
[ 2.547895] brd: module loaded
[ 2.553004] loop: module loaded
[ 2.553234] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.553238] nct1008_nct72 7-004c: starting parse dt
[ 2.553319] nct1008_nct72 7-004c: success parsing dt
[ 2.553440] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.620405] tmp451: Enabled overheat logging at 104.00C
[ 2.620492] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.622555] THERMAL EST: found 3 subdevs
[ 2.622558] THERMAL EST num_resources: 0
[ 2.622561] [THERMAL EST subdev 0]
[ 2.622564] [THERMAL EST subdev 1]
[ 2.622566] [THERMAL EST subdev 2]
[ 2.622650] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.622803] thermal thermal_zone7: Registering thermal zone thermal_zone7 fo
[ 2.622805] THERMAL EST: thz register success.
[ 2.622885] THERMAL EST: end of probe, return err: 0
[ 2.622930] tegra_profiler: Branch: Dev
[ 2.622932] tegra_profiler: Version: 1.117
[ 2.622933] tegra_profiler: Samples version: 41
[ 2.622934] tegra_profiler: IO version: 22
[ 2.622938] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.622940] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.622942] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.622944] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
, pmu ver: 0x1
[ 2.622946] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.622948] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
, pmu ver: 0x1
[ 2.622950] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.622952] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.622954] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.622955] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.622957] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.622959] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.623062] tegra_profiler: auth: init
[ 2.625735] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3
[ 2.625742] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp p
[ 2.632326] scsi host0: tegra_ahci
[ 2.632548] scsi host1: tegra_ahci
[ 2.632665] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x
100 irq 25
[ 2.632667] ata2: DUMMY
[ 2.633422] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.633771] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.634088] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.634703] tun: Universal TUN/TAP device driver, 1.6
[ 2.634704] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.634847] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 2.634848] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 2.634882] igb: Intel® Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.634883] igb: Copyright © 2007-2014 Intel Corporation.
[ 2.635672] PPP generic driver version 2.4.2
[ 2.635765] PPP BSD Compression module registered
[ 2.635771] PPP Deflate Compression module registered
[ 2.635787] PPP MPPE Compression module registered
[ 2.635798] NET: Registered protocol family 24
[ 2.635838] usbcore: registered new interface driver r8152
[ 2.635864] usbcore: registered new interface driver asix
[ 2.635893] usbcore: registered new interface driver ax88179_178a
[ 2.635918] usbcore: registered new interface driver cdc_ether
[ 2.635945] usbcore: registered new interface driver smsc75xx
[ 2.635968] usbcore: registered new interface driver net1080
[ 2.635990] usbcore: registered new interface driver cdc_subset
[ 2.636013] usbcore: registered new interface driver zaurus
[ 2.636071] usbcore: registered new interface driver cdc_ncm
[ 2.636264] Wake76 for irq=199
[ 2.636266] Wake77 for irq=199
[ 2.636267] Wake78 for irq=199
[ 2.636268] Wake79 for irq=199
[ 2.636269] Wake80 for irq=199
[ 2.636269] Wake81 for irq=199
[ 2.636270] Wake82 for irq=199
[ 2.636322] tegra-xotg xotg: usb2 phy is not available yet
[ 2.636796] usbcore: registered new interface driver cdc_acm
[ 2.636797] cdc_acm: USB Abstract Control Model driver for USB modems and IS
DN adapters
[ 2.636837] usbcore: registered new interface driver usb-storage
[ 2.636881] usbcore: registered new interface driver usbserial
[ 2.636901] usbcore: registered new interface driver cp210x
[ 2.636916] usbserial: USB Serial support registered for cp210x
[ 2.636934] usbcore: registered new interface driver ftdi_sio
[ 2.636947] usbserial: USB Serial support registered for FTDI USB Serial Dev
ice
[ 2.636975] usbcore: registered new interface driver option
[ 2.636989] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.637011] usbcore: registered new interface driver pl2303
[ 2.637024] usbserial: USB Serial support registered for pl2303
[ 2.637272] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.638933] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 ca fd
[ 2.639363] libphy: dwc_phy: probed
[ 2.639790] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.704011] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.763660] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as
rtc0
[ 2.765869] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.765883] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.766019] i2c /dev entries driver
[ 2.766766] [OV5693]: probing v4l2 sensor.
[ 2.950874] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.227864] tegradc 15210000.nvdisplay: fb registered
[ 3.234625] PD DISP0 index2 UP
[ 3.239843] PD DISP1 index3 UP
[ 3.244409] PD DISP2 index4 UP
[ 3.257564] hdmi: couldn’t get regulator avdd_hdmi
[ 3.264082] Parent Clock set for DC plld2
[ 3.270538] edid invalid
[ 3.316048] edid invalid
[ 3.319943] edid invalid
[ 3.323822] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting
:prod_c_150M
[ 3.479090] tegradc 15210000.nvdisplay: blank - normal
[ 3.482892] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.541402] PD DISP2 index4 DOWN
[ 3.542504] PD DISP1 index3 DOWN
[ 3.543165] PD DISP0 index2 DOWN
[ 3.577816] tegradc 15210000.nvdisplay: unblank
[ 3.577894] PD DISP0 index2 UP
[ 3.607456] PD DISP1 index3 UP
[ 3.608352] PD DISP2 index4 UP
[ 3.624598] hdmi: couldn’t get regulator avdd_hdmi
[ 3.624941] Parent Clock set for DC plld2
[ 3.628013] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting
:prod_c_150M
[ 3.640085] gspca_main: v2.14.0 registered
[ 3.640126] usbcore: registered new interface driver gspca_zc3xx
[ 3.640451] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.642405] FAN dev name: pwm-fan
[ 3.642454] FAN:gpio request success.
[ 3.642460] FAN: can’t find tach_gpio
[ 3.642484] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.642650] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.642654] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.642956] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, s
tate:2
[ 3.642959] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2,
state:2
[ 3.642962] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1
, state:2
[ 3.642965] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1
, state:2
[ 3.642968] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1
, state:3
[ 3.642971] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1
, state:3
[ 3.642974] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1
, state:3
[ 3.642977] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1
, state:4
[ 3.642980] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=
1, state:4
[ 3.642982] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=
1, state:4
[ 3.643729] device-mapper: uevent: version 1.0.3
[ 3.643920] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-
devel@redhat.com
[ 3.644306] sdhci: Secure Digital Host Controller Interface driver
[ 3.644307] sdhci: Copyright© Pierre Ossman
[ 3.644311] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.644552] random: nonblocking pool is initialized
[ 3.644607] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.644895] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=19624
9804
[ 3.645124] sdhci-tegra 3460000.sdhci: Client registration for eMC Successfu
l
[ 3.646254] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.646377] hidraw: raw HID events driver © Jiri Kosina
[ 3.647927] usbcore: registered new interface driver usbhid
[ 3.647929] usbhid: USB HID core driver
[ 3.652761] nvadsp 2993000.adsp: in probe()…
[ 3.666050] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.666078] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.666265] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.666999] Denver: backdoor interface is NOT available.
[ 3.668679] coresight-tmc 8030000.etf: TMC initialized
[ 3.669768] coresight-tmc 8050000.etr: TMC initialized
[ 3.670112] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.670580] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.671038] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.671436] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.671844] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.672429] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.672946] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.673460] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.673975] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.673999] Module initialized successfully
[ 3.677058] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOV
A=0xfc300000
[ 3.678251] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.678338] tegra186-cam-rtcpu b000000.rtcpu: IOVM setup error: 131
[ 3.678341] tegra186-cam-rtcpu b000000.rtcpu: trace boot sync failed: -5
[ 3.678463] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xfc120000-0xfc12957
f size=38272
[ 3.678800] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=
0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.678856] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1
RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.678860] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using AD
[ 3.678901] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64
]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.678972] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 g
rp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.679012] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 g
rp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.679096] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.679099] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]
=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.679139] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]
=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.679335] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.679337] sdhci-tegra 3440000.sdhci: Client registration for eMC Successfu
l
[ 3.679338] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is suc
cessful
[ 3.680012] tegra186-cam-rtcpu b000000.rtcpu: IOVM setup error: 131
[ 3.680180] tegra186-cam-rtcpu b000000.rtcpu: ivc-bus boot sync failed: -5
[ 3.680188] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4
sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.680417] camchar: rtcpu character device driver loaded
[ 3.681794] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.681799] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x0000
0000, GFSYNR1 0x00001816, GFSYNR2 0x00000000
[ 3.681913] (255) csr_aonr: EMEM address decode error
[ 3.681932] status = 0x20367097; addr = 0x3ffffffc0
[ 3.681937] secure: yes, access-type: read
[ 3.681952] unknown mcerr fault, int_status=0x00000000, ch_int_status=0x0000
[ 3.681963] unknown mcerr fault, int_status=0x00000000, ch_int_status=0x0000
[ 3.681973] unknown mcerr fault, int_status=0x00000000, ch_int_status=0x0000
[ 3.681981] mc-err: Too many MC errors; throttling prints
[ 3.682289] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.682517] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.682608] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.682971] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.682999] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.683023] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.683046] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.683069] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.683093] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.683115] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.683137] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.683159] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.683182] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.683203] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.683228] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.683251] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.683275] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.683314] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.683365] **** A57 ECC: Enabled
[ 3.683367] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.683504] parse_throttle_dt_data: Num cap clks = 4
[ 3.683506] parse_throttle_dt_data: clk=mcpu type=1
[ 3.683508] parse_throttle_dt_data: clk=bcpu type=2
[ 3.683513] parse_throttle_dt_data: clk=gpu type=4
[ 3.683515] parse_throttle_dt_data: clk=emc type=3
[ 3.683981] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.684086] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.686569] tegra18x_actmon d230000.actmon: initialization Completed for the
device mc_all
[ 3.686883] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 co
unters available
[ 3.688930] tegra-se-nvhost 15810000.se: initialized
[ 3.689373] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.689701] tegra-se-nvhost 15820000.se: initialized
[ 3.690133] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.690416] tegra-se-nvhost 15830000.se: initialized
[ 3.690525] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.690796] tegra-se-nvhost 15840000.se: initialized
[ 3.691247] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.695006] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.696921] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.696926] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x0000
[ 3.696953] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.696957] arm-smmu 12000000.iommu: GFSR 0x00000002, GFSYNR0 0x0000
[ 3.696989] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.696991] arm-smmu 12000000.iommu: GFSR 0x00000002, GFSYNR0 0x0000
[ 3.697027] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.697029] arm-smmu 12000000.iommu: GFSR 0x00000002, GFSYNR0 0x0000
[ 3.697062] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.697065] arm-smmu 12000000.iommu: GFSR 0x00000002, GFSYNR0 0x0000
[ 3.697109] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.697112] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x0000
0002, GFSYNR1 0x00000032, GFSYNR2 0x00000000
[ 3.697206] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.697209] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x0000
0000, GFSYNR1 0x00001832, GFSYNR2 0x00000000
[ 3.697235] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this
could be serious
[ 3.697237] arm-smmu 12000000.iommu: GFSR 0x00000002, GFSYNR0 0x0000
[ 3.698806] cpufreq: platform driver Initialization: pass
[ 3.699291] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.699481] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.700091] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x00000000035
[ 3.700115] tegra186-padctl 3520000.pinctrl: ao mmio start 0x000000000354000
[ 3.700280] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ca895
[ 3.700293] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.703793] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.706314] tegra186-padctl 3520000.pinctrl: VBUS over-current detection ena
bled
[ 3.708072] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supporte
d
[ 3.709217] tegra-bpmp-thermal d000000.bpmp:
Log has been cut, please try to use the code block function to wrap your log.
This is code block
[code]3.3
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible i
d nvidia,ramoops
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
080 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa
ges: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=tty
S0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegra
fb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0
x2772e0000 gpt tegra_fbmem2=0x800000@0x969ee000 lut_mem2=0x2008@0x969eb000 tegr
aid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetv
alues=0.2.1 androidboot.serialno=0324817094137 bl_prof_dataptr=0x10000@0x277040
000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstyp
e=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byt
es)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes
d)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246
GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8
GB maximum)
MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108
KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16
MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64
MB)
MB)
KB)
KB)
KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles
: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398
046511088ns
requency… 62.50 BogoMIPS (lpj=125000)
es)
/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kern
el-dts/tegra186-quill-p3310-1000-c03-00-base.dts
ax_idle_ns: 7645041785100000 ns
2P
er-wdt
er-wdt
oard >=3310-1000-300
ard >=3310-1000-300
ard >=3310-1000-800
000-200
=3310-1000-500
=3310-1000-500
3310-1000-500
3310-1000-800
3310-1000-800
1000-900
1000-B00
=3310-1000-800
ic allocations
er groups, mask 0x7f80
ers from mapped region size (0x1000000)!
y)
A
A
ller@10003000
ed
800000)
3000)
could be serious
gpio
gpio-aon
9
9
etti giometti@linux.it
c
20-gpio
r type BCPU-therm
r type MCPU-therm
r type GPU-therm
r type PLL-therm
r type Tboard_tegra
r type Tdiode_tegra
r type PMIC-Die
s)
vailable
= 3916800KBs
ed with id=0
16727000 KB/s
= 665600000 Hz
357620000 Hz
alized
efault range
5500000) is a Tegra
0) is a TEGRA_UART
0) is a TEGRA_UART
0) is a TEGRA_UART
pmu ver: 0x1
, pmu ver: 0x1
, pmu ver: 0x1
pmu ver: 0x1
pmu ver: 0x1
pmu ver: 0x1
100 irq 25
DN adapters
ice
rtc0
:prod_c_150M
:prod_c_150M
tate:2
state:2
, state:2
, state:2
, state:3
, state:3
, state:3
, state:4
1, state:4
1, state:4
devel@redhat.com
9804
l
A=0xfc300000
f size=38272
l
cessful
could be serious
device mc_all
unters available
could be serious
could be serious
could be serious
could be serious
could be serious
could be serious
could be serious
could be serious
bled
d
[ 3.709217] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not suppo
log.zip (41.3 KB)
d nvidia,ramoops
080 u69632
ges: 2019936
e=ext4
es)
d)
GB)
GB maximum)
MB actual)
KB)
MB)
MB)
MB)
KB)
KB)
KB)
046511088ns
es)
2P
er-wdt
er-wdt
ard >=3310-1000-300
ard >=3310-1000-800
000-200
=3310-1000-500
=3310-1000-500
3310-1000-500
3310-1000-800
3310-1000-800
1000-900
1000-B00
=3310-1000-800
ic allocations
y)
A
A
ller@10003000
ed
800000)
3000)
could be serious
gpio
gpio-aon
9
9
c
20-gpio
r type BCPU-therm
r type MCPU-therm
r type GPU-therm
r type PLL-therm
r type Tboard_tegra
r type Tdiode_tegra
r type PMIC-Die
s)
vailable
= 3916800KBs
ed with id=0
16727000 KB/s
= 665600000 Hz
357620000 Hz
alized
efault range
5500000) is a Tegra
0) is a TEGRA_UART
0) is a TEGRA_UART
0) is a TEGRA_UART
pmu ver: 0x1
, pmu ver: 0x1
, pmu ver: 0x1
pmu ver: 0x1
pmu ver: 0x1
pmu ver: 0x1
100 irq 25
DN adapters
ice
rtc0
:prod_c_150M
:prod_c_150M
tate:2
state:2
, state:2
, state:2
, state:3
, state:3
, state:3
, state:4
1, state:4
1, state:4
devel@redhat.com
9804
l
A=0xfc300000
f size=38272
l
cessful
could be serious
device mc_all
unters available
could be serious
could be serious
could be serious
could be serious
could be serious
could be serious
could be serious
could be serious
bled
d
[ 3.709217] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supporte
d
Sorry,I’m not too will use!
No error from HDMI in your log, so here are some suggestions for you.
There are many changes in kernel and other userspace driver between jetpack3.0 (rel-27.1) and jetpack3.3(rel-28.2.1).
It might cause some monitors not working because we chose to support only CEA modes.
You could try to use other HDMI monitors and see if it can work.
As for the original monitor, please add below to xorg.conf and share Xorg.0.log.
#Add below option in /etc/X11/xorg.conf, more log will be shown in /var/log/Xorg.0.log
Option “ModeDebug”
First of all thank you for your answer!
On the development board,3.0 and 3.3 all normal,But,In my own design on the board,JetPack3.0 is normal,JetPack3.3 is not normal.
So,I think that has nothing to do with the HDMI display!There are some problems with my hardware must,Can I update uboot or update Image to improve this problem.
You might find this of interest:
https://elinux.org/Jetson_TX2/r28_Display_debug
An earlier comment suggests adding this to the “Device” section of the xorg.conf, and then checking Xorg.0.conf log after reboot:
Option "ModeDebug"
…this would be very enlightening as it would allow the driver to say what it thinks of each mode your monitor reports compatibility with.
If this only happens to your board, please check if your design is following OEM Design guide.
Also, just want to make sure… Were the logs in previous comment based on your board?
