there is no hdmi display on R28.2_kernel
hello,
I update the kernel on tx2 with following step:
1.#sudo cp Image /boot
#sudo cp zImage /boot
#sync
#sudo reboot
2.flash kernel-dtb
#sudo cp kernel_out/…/dts/tegra186-quill-p3310-1000-c03-base.dtb Linux_for_Tegra/kernel/dtb/
#cd Linux_for_Tegra
#sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
Then,the board start success with hdmi-display.
I unplug the power.
I plugged the power in a few hours later. But there is no hdmi-display.
I’m very confused.
How to solve this problem?
Thankyou very much.
The message of mincom:
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (root@lfh-MS-7996) (gcc version 4.8.5 (GCC) ) #2 SMP PREEMPT Thu Mar 29 03:05:54 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f6654000 s31360 r8192 d30080 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0324417129065 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7976724K/8208384K available (11148K kernel code, 1798K rwdata, 5744K rodata, 1164K init, 690K bss, 166124K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
[ 0.000000] .init : 0xffffffc001100000 - 0xffffffc001223000 ( 1164 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001100000 ( 16896 KB)
[ 0.000000] .data : 0xffffffc001244000 - 0xffffffc001405928 ( 1799 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009458] Console: colour dummy device 80x25
[ 0.014114] console [tty0] enabled
[ 0.017668] bootconsole [uart0] disabled
[ 0.021771] kmemleak: Kernel memory leak detector disabled
[ 0.021784] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.021796] pid_max: default: 32768 minimum: 301
[ 0.021845] Security Framework initialized
[ 0.021882] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.021893] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022274] Initializing cgroup subsys io
[ 0.022286] Initializing cgroup subsys memory
[ 0.022303] Initializing cgroup subsys devices
[ 0.022312] Initializing cgroup subsys freezer
[ 0.022321] Initializing cgroup subsys net_cls
[ 0.022331] Initializing cgroup subsys perf_event
[ 0.022340] Initializing cgroup subsys net_prio
[ 0.022350] Initializing cgroup subsys pids
[ 0.022359] Initializing cgroup subsys debug
[ 0.022500] CPU0 ipc=752
[ 0.022509] CPU1 ipc=1024
[ 0.022518] CPU2 ipc=1024
[ 0.022526] CPU3 ipc=752
[ 0.022536] CPU4 ipc=752
[ 0.022546] CPU5 ipc=752
[ 0.022585] ASID allocator initialised with 65536 entries
[ 0.044698] tegra-id: chipid=21817.
[ 0.044716] tegra-id: opt_subrevision=1.
[ 0.044729] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.045208] DTS File Name: /home/lfh/TX2_R28.2/kernel_soure_xue/kernel_src/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.045234] DTB Build time: Mar 29 2018 02:30:43
[ 0.062390] CPU1: Booted secondary processor [4e0f0030]
[ 0.073904] CPU2: Booted secondary processor [4e0f0030]
[ 0.085613] CPU3: Booted secondary processor [411fd073]
[ 0.097641] CPU4: Booted secondary processor [411fd073]
[ 0.109619] CPU5: Booted secondary processor [411fd073]
[ 0.109682] Brought up 6 CPUs
[ 0.109738] SMP: Total of 6 processors activated.
[ 0.109750] CPU: All CPU(s) started at EL2
[ 0.110214] devtmpfs: initialized
[ 0.129266] Initilizing CustomIPI irq domain
[ 0.129488] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.130281] pinctrl core: initialized pinctrl subsystem
[ 0.130456] OS set in device tree is not L4T.
[ 0.130646] regulator-dummy: no parameters
[ 0.130748] Initializing plugin-manager
[ 0.130800] Plugin module not found
[ 0.131194] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.131498] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.132073] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.133179] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.133503] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.133770] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.133983] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.134385] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.134804] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.135071] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.135433] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.135665] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.135874] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.136114] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.138125] Adding domain adsp-pd to PM domain ape-pd
[ 0.139781] NET: Registered protocol family 16
[ 0.140589] console [pstore-1] enabled
[ 0.140602] pstore: Registered ramoops as persistent store backend
[ 0.140615] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.145616] cpuidle: using governor ladder
[ 0.153613] cpuidle: using governor menu
[ 0.154434] bpmp: waiting for handshake
[ 0.154448] bpmp: handshake completed
[ 0.154492] bpmp: synchronizing channels
[ 0.154518] bpmp: channels synchronized
[ 0.154529] bpmp: mail init ok
[ 0.154857] vdso: 2 pages (1 code @ ffffffc001249000, 1 data @ ffffffc001248000)
[ 0.154887] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.155814] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.157231] tegra_powergate_init: DONE
[ 0.157253] DTS File Name: /home/lfh/TX2_R28.2/kernel_soure_xue/kernel_src/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.157280] DTB Build time: Mar 29 2018 02:30:43
[ 0.158133] Tegra reboot handler registered.
[ 0.158762] Registering Tegra186 clocks (this may take a while)…done
[ 0.160084] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.160101] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.160115] arm-smmu 12000000.iommu: stage 1 translation
[ 0.160127] arm-smmu 12000000.iommu: stage 2 translation
[ 0.160139] arm-smmu 12000000.iommu: nested translation
[ 0.160154] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.160173] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.160192] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.160206] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.160220] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.196791] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.198978] iommu: Adding device 3460000.sdhci to group 0
[ 0.199403] iommu: Adding device 3400000.sdhci to group 1
[ 0.200711] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.200967] iommu: Adding device 3160000.i2c to group 3
[ 0.201205] iommu: Adding device c240000.i2c to group 4
[ 0.201410] iommu: Adding device 3180000.i2c to group 5
[ 0.201624] iommu: Adding device 3190000.i2c to group 6
[ 0.201890] iommu: Adding device 31b0000.i2c to group 7
[ 0.202085] iommu: Adding device 31c0000.i2c to group 8
[ 0.202300] iommu: Adding device c250000.i2c to group 9
[ 0.202499] iommu: Adding device 31e0000.i2c to group 10
[ 0.203585] iommu: Adding device 3210000.spi to group 11
[ 0.203784] iommu: Adding device c260000.spi to group 12
[ 0.203982] iommu: Adding device 3240000.spi to group 13
[ 0.204450] iommu: Adding device 3100000.serial to group 14
[ 0.204653] iommu: Adding device 3110000.serial to group 15
[ 0.204860] iommu: Adding device c280000.serial to group 16
[ 0.205055] iommu: Adding device 3130000.serial to group 17
[ 0.205952] iommu: Adding device 2490000.ether_qos to group 18
[ 0.206310] iommu: Adding device b000000.rtcpu to group 19
[ 0.206597] iommu: Adding device c1a0000.aon to group 20
[ 0.207208] Wake73 for irq=42
[ 0.207398] iommu: Adding device smmu_test to group 21
[ 0.207752] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.207773] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.207793] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.207812] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.207834] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.207854] mc-err: Set intmask: 0xf3140
[ 0.208097] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.209758] Wake76 for irq=199
[ 0.209805] Wake77 for irq=199
[ 0.209827] Wake78 for irq=199
[ 0.209849] Wake79 for irq=199
[ 0.209869] Wake80 for irq=199
[ 0.209889] Wake81 for irq=199
[ 0.209916] Wake82 for irq=199
[ 0.210119] iommu: Adding device 3530000.xhci to group 22
[ 0.210788] iommu: Adding device 3550000.xudc to group 23
[ 0.211986] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.212019] tegra-pmc: ### PMC reset source: Power on reset
[ 0.212044] tegra-pmc: ### PMC reset level: L0
[ 0.212066] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.212377] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.212418] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.212607] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.212637] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.213282] iommu: Adding device 13e10000.host1x to group 24
[ 0.213554] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.213844] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.214095] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.214433] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.214699] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.214956] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.215215] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.215477] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.215975] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.216600] iommu: Adding device 15700000.vi to group 34
[ 0.216978] iommu: Adding device 15600000.isp to group 35
[ 0.217403] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.217658] iommu: Adding device 15340000.vic to group 37
[ 0.217890] iommu: Adding device 154c0000.nvenc to group 38
[ 0.218111] iommu: Adding device 15480000.nvdec to group 39
[ 0.218522] iommu: Adding device 15380000.nvjpg to group 40
[ 0.218732] iommu: Adding device 15500000.tsec to group 41
[ 0.218992] iommu: Adding device 15100000.tsecb to group 42
[ 0.219804] iommu: Adding device 15810000.se to group 43
[ 0.220036] iommu: Adding device 15820000.se to group 44
[ 0.220267] iommu: Adding device 15830000.se to group 45
[ 0.220457] iommu: Adding device 15840000.se to group 46
[ 0.221036] iommu: Adding device 17000000.gp10b to group 47
[ 0.222533] tegra-reset 5000000.clock: registered 193 resets.
[ 0.224480] iommu: Adding device d000000.bpmp to group 48
[ 0.224739] bpmp: ping status is 0
[ 0.224941] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.225287] bpmp d000000.bpmp: probe ok
[ 0.227707] iommu: Adding device 2600000.dma to group 49
[ 0.228514] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.228568] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.228618] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.228725] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.230539] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.230675] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.231602] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.231856] iommu: Adding device sound to group 51
[ 0.233545] iommu: Adding device 3510000.hda to group 52
[ 0.234646] iommu: Adding device adsp_audio to group 53
[ 0.235945] iommu: Adding device 2993000.adsp to group 54
[ 0.246055] vdd-ac-bat: 5000 mV
[ 0.248398] vdd-1v8-ap: 1800 mV
[ 0.268595] SCSI subsystem initialized
[ 0.268992] usbcore: registered new interface driver usbfs
[ 0.269064] usbcore: registered new interface driver hub
[ 0.269192] usbcore: registered new device driver usb
[ 0.271921] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.272129] pca953x 0-0074: failed reading register
[ 0.272208] pca953x: probe of 0-0074 failed with error -121
[ 0.272592] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.272790] pca953x 0-0077: failed reading register
[ 0.272858] pca953x: probe of 0-0077 failed with error -121
[ 0.276524] i2c i2c-2: of_i2c: modalias failure on /i2c@3180000/i2c@2
[ 0.281613] i2c i2c-7: of_i2c: modalias failure on /i2c@c250000/i2c@7
[ 0.283642] media: Linux media interface: v0.10
[ 0.283716] Linux video capture interface: v2.00
[ 0.287735] pps_core: LinuxPPS API ver. 1 registered
[ 0.287780] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.287845] PTP clock support registered
[ 0.288773] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.288847] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.290394] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.292540] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.292740] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.292860] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.298581] vddio-ddr: at 1125 mV
[ 0.302410] avdd_dsi_csi: 1200 mV
[ 0.306406] vdd-1v8: 1800 mV
[ 0.310405] vdd-3v3-sys: 3300 mV
[ 0.311561] spmic-ldo0: at 1800 mV
[ 0.312403] spmic-ldo1: at 800 mV
[ 0.318404] vddio-3v3: 3300 mV
[ 0.319064] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.321649] vdd-rtc: at 800 mV
[ 0.322332] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.325645] spmic-ldo6: at 1500 mV
[ 0.329645] vdd-pex-1v05: 1000 mV
[ 0.330181] dvdd-pex: 1000 mV
[ 0.330455] max77620 4-003c: max77620 probe successful
[ 0.330698] Advanced Linux Sound Architecture Driver Initialized.
[ 0.331653] en-vdd-sd: 3300 mV
[ 0.331919] vdd-usb0-5v: 5000 mV
[ 0.332084] vdd-usb1-5v: 5000 mV
[ 0.332428] vdd-3v3: 3300 mV
[ 0.332568] en-vdd-vcm-2v8: 2800 mV
[ 0.332705] vdd-sys-bl: 3300 mV
[ 0.335810] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.336200] clocksource: Switched to clocksource arch_sys_counter
[ 0.354502] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.354767] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.355213] nvmap_page_pool_init: Total RAM pages: 2010565
[ 0.355229] nvmap_page_pool_init: nvmap page pool size: 251320 pages (981 MB)
[ 0.355398] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.359724] Wake76 for irq=199
[ 0.359738] Wake77 for irq=199
[ 0.359749] Wake78 for irq=199
[ 0.359760] Wake79 for irq=199
[ 0.359770] Wake80 for irq=199
[ 0.359779] Wake81 for irq=199
[ 0.359789] Wake82 for irq=199
[ 0.360485] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.360675] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.361006] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.361085] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.361231] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.361373] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.361508] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.361801] isomgr_init(): iso emc max clk=1866000KHz
[ 0.361814] isomgr_init(): max_iso_bw=26870400KB
[ 0.361893] NET: Registered protocol family 2
[ 0.362235] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.362440] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.362733] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.362784] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.362838] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.362996] NET: Registered protocol family 1
[ 0.363176] RPC: Registered named UNIX socket transport module.
[ 0.363192] RPC: Registered udp transport module.
[ 0.363202] RPC: Registered tcp transport module.
[ 0.363213] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.363332] Trying to unpack rootfs image as initramfs…
[ 0.376380] host1x 13e10000.host1x: initialized
[ 0.377132] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.378870] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.378972] audit: initializing netlink subsys (disabled)
[ 0.379002] audit: type=2000 audit(0.364:1): initialized
[ 0.385888] io scheduler noop registered
[ 0.385993] io scheduler cfq registered (default)
[ 0.388907] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.390075] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.391122] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.392154] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.394971] tsec 15500000.tsec: initialized
[ 0.396025] tsec 15100000.tsecb: initialized
[ 0.397663] nvdec 15480000.nvdec: initialized
[ 0.400413] falcon 15340000.vic: initialized
[ 0.401369] falcon 154c0000.nvenc: initialized
[ 0.402382] falcon 15380000.nvjpg: initialized
[ 0.403057] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.403561] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.404060] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.404573] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.405072] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.405566] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.406064] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.406560] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.407637] DC OR NODE connected to /host1x/sor1
[ 0.407761] generic_infoframe_type: 0x87
[ 0.407770] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.407856] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1000000, vi_iso_bw=3000000, max_bw=3000000
[ 0.407871] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.407899] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.414994] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.415014] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.415031] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.415073] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.415088] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.415308] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.415431] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.417189] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.417414] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.417510] V_REF_TO_SYNC >= 1; H_REF_TO_SYNC < 0
[ 0.417524] tegradc 15210000.nvdisplay: Display timing doesn’t meet restrictions.
[ 0.417526] kfuse 3830000.kfuse: initialized
[ 0.418800] tegradc 15210000.nvdisplay: probed
[ 0.418898] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.419350] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.421274] console [ttyS0] disabled
[ 0.421324] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.437645] V_REF_TO_SYNC >= 1; H_REF_TO_SYNC < 0
[ 0.437650] tegradc 15210000.nvdisplay: Display timing doesn’t meet restrictions.
[ 2.464558] console [ttyS0] enabled
[ 2.464653] V_REF_TO_SYNC >= 1; H_REF_TO_SYNC < 0
[ 2.464657] tegradc 15210000.nvdisplay: Display timing doesn’t meet restrictions.
[ 2.466559] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.467655] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.467911] serial-tegra 3130000.serial: RX in PIO mode
[ 2.468875] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.473414] Console: switching to colour frame buffer device 160x64
[ 2.480517] brd: module loaded
[ 2.485551] loop: module loaded
[ 2.485763] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.485767] nct1008_nct72 7-004c: starting parse dt
[ 2.485848] nct1008_nct72 7-004c: success parsing dt
[ 2.485961] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.496675] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.522466] tmp451: Enabled overheat logging at 104.00C
[ 2.522629] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.524783] THERMAL EST: found 3 subdevs
[ 2.524796] THERMAL EST num_resources: 0
[ 2.524806] [THERMAL EST subdev 0]
[ 2.524817] [THERMAL EST subdev 1]
[ 2.524843] [THERMAL EST subdev 2]
[ 2.525181] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.525183] THERMAL EST: thz register success.
[ 2.525314] THERMAL EST: end of probe, return err: 0
[ 2.525366] tegra_profiler: Branch: Dev
[ 2.525368] tegra_profiler: Version: 1.117
[ 2.525371] tegra_profiler: Samples version: 41
[ 2.525373] tegra_profiler: IO version: 22
[ 2.525381] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.525386] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.525390] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.525394] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.525397] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.525401] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.525404] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.525408] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.525411] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.525414] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.525417] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.525421] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.525632] tegra_profiler: auth: init
[ 2.529048] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.529059] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.530106] scsi host0: tegra_ahci
[ 2.530466] scsi host1: tegra_ahci
[ 2.530638] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.530641] ata2: DUMMY
[ 2.531532] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.531968] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.532400] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.533253] tun: Universal TUN/TAP device driver, 1.6
[ 2.533256] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.533429] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.533431] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.533468] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.533470] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.534438] PPP generic driver version 2.4.2
[ 2.534560] PPP BSD Compression module registered
[ 2.534567] PPP Deflate Compression module registered
[ 2.534588] PPP MPPE Compression module registered
[ 2.534600] NET: Registered protocol family 24
[ 2.534655] usbcore: registered new interface driver r8152
[ 2.534688] usbcore: registered new interface driver asix
[ 2.534718] usbcore: registered new interface driver ax88179_178a
[ 2.534744] usbcore: registered new interface driver cdc_ether
[ 2.534782] usbcore: registered new interface driver smsc75xx
[ 2.534817] usbcore: registered new interface driver net1080
[ 2.534867] usbcore: registered new interface driver cdc_subset
[ 2.534892] usbcore: registered new interface driver zaurus
[ 2.534936] usbcore: registered new interface driver cdc_ncm
[ 2.535177] Wake76 for irq=199
[ 2.535180] Wake77 for irq=199
[ 2.535182] Wake78 for irq=199
[ 2.535184] Wake79 for irq=199
[ 2.535186] Wake80 for irq=199
[ 2.535188] Wake81 for irq=199
[ 2.535189] Wake82 for irq=199
[ 2.535244] tegra-xotg xotg: usb2 phy is not available yet
[ 2.535933] usbcore: registered new interface driver cdc_acm
[ 2.535935] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.535974] usbcore: registered new interface driver usb-storage
[ 2.536035] usbcore: registered new interface driver usbserial
[ 2.536060] usbcore: registered new interface driver cp210x
[ 2.536080] usbserial: USB Serial support registered for cp210x
[ 2.536105] usbcore: registered new interface driver ftdi_sio
[ 2.536122] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.536145] usbcore: registered new interface driver option
[ 2.536166] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.536190] usbcore: registered new interface driver pl2303
[ 2.536242] usbserial: USB Serial support registered for pl2303
[ 2.536441] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.537335] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 87 92
[ 2.537842] libphy: dwc_phy: probed
[ 2.538627] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.601381] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.671039] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.673132] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.673144] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.673280] i2c /dev entries driver
[ 2.674059] tc358748_module_init:module init
[ 2.674088] tc358748_probe entry
[ 2.674117] tc358748_parse_dt:parse dt
[ 2.674119] tc358748_parse_dt done
[ 2.674125] tc358748_probe: gpio-CSI[A]=0
[ 2.674126] tc358748_probe: name tc358748_a
[ 2.674133] tc358748_ctrls_init: entry
[ 2.674135] tc358748_ctrls_init: numctrls 2
[ 2.674137] tc358748_ctrls_init: ctrl_config_list[i].id 10100745
[ 2.674143] tc358748_ctrls_init:init Gain ctrl
[ 2.674145] tc358748_ctrls_init: ctrl_config_list[i].id 10100740
[ 2.674147] tc358748_ctrls_init:init HDR enable ctrl
[ 2.674149] tc358748_probe:tc358748_ctrls_init: done
[ 2.674150] tc358748_probe:media_entity_init done
[ 2.674151] tc358748_probe:v4l2_async_register_subdev done
[ 2.674153] HD mode[0]
[ 2.674153] *******************************************************
[ 2.674154] *******************************************************
[ 2.674155] *******************************************************
[ 2.685239] tc358748_mipi 2-000e:
[ 2.685239] tc358748_probe:Detected tc358748 sensor
[ 2.685241] tc358748_probe:Complete!!!
[ 2.685279] tc358748_probe entry
[ 2.685297] tc358748_parse_dt:parse dt
[ 2.685298] tc358748_parse_dt done
[ 2.685302] tc358748_probe: name tc358748_c
[ 2.685318] tc358748_ctrls_init: entry
[ 2.685320] tc358748_ctrls_init: numctrls 2
[ 2.685321] tc358748_ctrls_init: ctrl_config_list[i].id 10100745
[ 2.685326] tc358748_ctrls_init:init Gain ctrl
[ 2.685328] tc358748_ctrls_init: ctrl_config_list[i].id 10100740
[ 2.685330] tc358748_ctrls_init:init HDR enable ctrl
[ 2.685331] tc358748_probe:tc358748_ctrls_init: done
[ 2.685333] tc358748_probe:media_entity_init done
[ 2.685334] tc358748_probe:v4l2_async_register_subdev done
[ 2.685335] HD mode[1]
[ 2.685336] *******************************************************
[ 2.685337] *******************************************************
[ 2.685338] *******************************************************
[ 2.696351] tc358748_mipi 7-000e:
[ 2.696351] tc358748_probe:Detected tc358748 sensor
[ 2.696352] tc358748_probe:Complete!!!
[ 2.696383] tc358748_module_init:module init done err[0]
[ 2.696414] gspca_main: v2.14.0 registered
[ 2.696460] usbcore: registered new interface driver gspca_zc3xx
[ 2.696706] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.698435] FAN: coudln’t get the regulator
[ 2.699111] device-mapper: uevent: version 1.0.3
[ 2.699287] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.699619] sdhci: Secure Digital Host Controller Interface driver
[ 2.699620] sdhci: Copyright(c) Pierre Ossman
[ 2.699623] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.699856] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.700109] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.700341] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.703431] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.703578] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.705232] usbcore: registered new interface driver usbhid
[ 2.705234] usbhid: USB HID core driver
[ 2.708030] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 2.708956] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 2.709089] ina3221x: probe of 0-0042 failed with error -121
[ 2.709454] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 2.709676] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 2.709774] ina3221x: probe of 0-0043 failed with error -121
[ 2.710244] nvadsp 2993000.adsp: in probe()…
[ 2.723900] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.723933] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.724144] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.735438] Denver: backdoor interface is NOT available.
[ 2.736228] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.736546] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.736843] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.740932] coresight-tmc 8030000.etf: TMC initialized
[ 2.744462] coresight-tmc 8050000.etr: TMC initialized
[ 2.744869] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.745363] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.745606] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.745812] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.746212] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.746651] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.746997] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.747338] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.747684] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.747710] Module initialized successfully
[ 2.750952] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.752307] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.752510] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.752832] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.752877] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.752919] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.752966] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.753005] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.753044] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.753080] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.753205] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.753208] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.753785] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.753788] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.753790] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.753793] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.753795] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.753797] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.753799] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.753828] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.757753] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.758516] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.758627] camchar: rtcpu character device driver loaded
[ 2.762477] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.762781] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.762937] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.763393] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.763421] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.763450] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.763477] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.763502] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.763527] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.763551] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.763578] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.763602] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.763625] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.763649] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.763676] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.763700] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.763724] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.763747] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.763795] **** A57 ECC: Enabled
[ 2.763798] tegra18_a57_serr_init: on CPU 0 a A57 Core
[ 2.763951] parse_throttle_dt_data: Num cap clks = 4
[ 2.763954] parse_throttle_dt_data: clk=mcpu type=1
[ 2.763955] parse_throttle_dt_data: clk=bcpu type=2
[ 2.763962] parse_throttle_dt_data: clk=gpu type=4
[ 2.763963] parse_throttle_dt_data: clk=emc type=3
[ 2.764494] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.764608] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.767779] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.768564] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.780223] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.780431] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.780477] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.780550] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.780574] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.780823] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.798219] mmc0: MAN_BKOPS_EN bit is not set
[ 2.806875] mmc0: Skipping tuning since strobe enabled
[ 2.814507] mmc0: periodic cache flush enabled
[ 2.814515] mmc0: new HS400 MMC card at address 0001
[ 2.814851] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.815032] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.815211] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.815377] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.816726] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.824309] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.848241] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.860711] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.058609] mmc1 tuning done saved tap delay=20
[ 3.058612] mmc1: hw tuning done …
[ 3.058620] mmc1: tuning_window[0]: 0xffffffff
[ 3.058626] mmc1: tuning_window[1]: 0xfffff1ff
[ 3.058631] mmc1: tuning_window[2]: 0xff8fffff
[ 3.058636] mmc1: tuning_window[3]: 0x7fffffff
[ 3.058642] mmc1: tuning_window[4]: 0x0
[ 3.058647] mmc1: tuning_window[5]: 0x0
[ 3.058678] mmc1: tuning_window[6]: 0x0
[ 3.058683] mmc1: tuning_window[7]: 0x0
[ 3.058687] sdhci: Tap value: 20 | Trim value: 5
[ 3.058691] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.065499] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.065545] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.373261] tegradc 15210000.nvdisplay: fb registered
[ 4.379771] PD DISP0 index2 UP
[ 4.385145] PD DISP1 index3 UP
[ 4.389474] PD DISP2 index4 UP
[ 4.395402] Parent Clock set for DC plld2
[ 4.404803] tegradc 15210000.nvdisplay: hdmi: pclk:107964K, set prod-setting:prod_c_150M
[ 4.432136] tegra-se-nvhost 15810000.se: initialized
[ 4.439524] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.447822] tegra-se-nvhost 15820000.se: initialized
[ 4.455144] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.463589] tegra-se-nvhost 15830000.se: initialized
[ 4.470773] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.479126] tegra-se-nvhost 15840000.se: initialized
[ 4.486334] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.497940] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.509849] cpufreq: platform driver Initialization: pass
[ 4.516874] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 4.524798] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.532059] tegradc 15210000.nvdisplay: blank - normal
[ 4.532291] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.532299] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.532338] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28ac15
[ 4.532343] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.533852] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.534466] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 4.535361] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.535815] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.537679] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.537810] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.538994] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.539000] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.542555] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.547964] snd_hda_codec_hdmi hdaudioC0D4: HDMI: Unknown ELD version 0
[ 4.548082] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.548450] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.548591] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.548687] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.548767] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.548988] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.549228] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.549516] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.549520] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.549522] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.559104] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.559104] OPE platform probe
[ 4.559169] OPE platform probe successful
[ 4.619160] PD DISP2 index4 DOWN
[ 4.619262] PD DISP1 index3 DOWN
[ 4.619351] PD DISP0 index2 DOWN
[ 4.623431] tegradc 15210000.nvdisplay: unblank
[ 4.623442] PD DISP0 index2 UP
[ 4.623823] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.623895] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.623966] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.624036] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.624103] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.624173] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.624265] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.624334] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.624400] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.624424] PD DISP1 index3 UP
[ 4.624467] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.624511] PD DISP2 index4 UP
[ 4.624536] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.624603] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.624672] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.624738] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.624807] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.624875] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.624945] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.625014] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.625083] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.625160] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.625917] Parent Clock set for DC plld2
[ 4.628063] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.628136] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.628160] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.628181] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.628904] tegradc 15210000.nvdisplay: hdmi: pclk:107964K, set prod-setting:prod_c_150M
[ 4.660776] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.661533] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 4.661536] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.662098] GACT probability NOT on
[ 4.662109] Mirror/redirect action on
[ 4.662125] u32 classifier
[ 4.662127] Actions configured
[ 4.662157] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.662816] IPVS: Registered protocols ()
[ 4.662849] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 4.663033] IPVS: Creating netns size=1424 id=0
[ 4.663061] IPVS: ipvs loaded.
[ 4.663067] IPVS: [rr] scheduler registered.
[ 4.663142] ipip: IPv4 over IPv4 tunneling driver
[ 4.663453] Initializing XFRM netlink socket
[ 4.663790] NET: Registered protocol family 10
[ 4.664481] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.664555] NET: Registered protocol family 17
[ 4.664568] NET: Registered protocol family 15
[ 4.664590] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.664596] 8021q: 802.1Q VLAN Support v1.8
[ 4.665234] Registered cp15_barrier emulation handler
[ 4.665250] Registered setend emulation handler
[ 4.666995] registered taskstats version 1
[ 4.669910] isp 15600000.isp: initialized
[ 4.673632] nvcsi 150c0000.nvcsi: initialized
[ 4.675504] Wake76 for irq=199
[ 4.675505] Wake77 for irq=199
[ 4.675506] Wake78 for irq=199
[ 4.675507] Wake79 for irq=199
[ 4.675508] Wake80 for irq=199
[ 4.675508] Wake81 for irq=199
[ 4.675509] Wake82 for irq=199
[ 4.675794] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.675796] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.700475] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.700616] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.700617] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.701060] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.701733] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.702325] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.702359] tegra-xotg xotg: update_id_state: ID grounded
[ 4.702364] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 4.702378] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.703841] tegra-xotg xotg: otg: gadget gadget registered
[ 4.703843] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.703844] tegra-xotg xotg: otg: host not registered yet
[ 4.703846] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.703885] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.703919] tegra-xotg xotg: FSM: can’t move to a_idle, host isn’t ready
[ 4.704227] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.706137] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.733225] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:44:24 UTC (946691064)
[ 4.762793] bpmp: mounted debugfs mirror
[ 4.763264] [dram-timers] DRAM derating cdev registered.
[ 4.767415] spmic-ldo0: disabling
[ 4.767583] spmic-ldo1: disabling
[ 4.767727] en-vdd-sd: disabling
[ 4.767729] vdd-usb0-5v: disabling
[ 4.767731] vdd-usb1-5v: disabling
[ 4.767732] vdd-3v3: disabling
[ 4.767734] en-vdd-vcm-2v8: disabling
[ 4.767735] vdd-sys-bl: disabling
[ 4.768430] random: nonblocking pool is initialized
[ 4.772978] ALSA device list:
[ 4.772980] #0: tegra-hda at 0x3518000 irq 400
[ 4.772981] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.774153] tegra-vi4 15700000.vi: initialized
[ 4.775404] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-0 bound
[ 4.775407] tegra-vi4 15700000.vi: subdev tc358748_mipi 2-000e bound
[ 4.775671] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.775674] tegra-vi4 15700000.vi: subdev tc358748_mipi 7-000e bound
[ 6.544773] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.681179] EXT4-fs (mmcblk0p1): recovery complete
[ 6.688654] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.698281] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.707691] devtmpfs: mounted
[ 6.712502] Freeing unused kernel memory: 1164K (ffffffc001100000 - ffffffc001223000)
[ 6.721937] Freeing alternatives memory: 96K (ffffffc001223000 - ffffffc00123b000)
[ 6.736541] btb inv war enabled
[ 6.773701] systemd[1]: System time before build time, advancing clock.
[ 6.796282] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.818073] systemd[1]: Detected architecture arm64.
[ 6.834630] systemd[1]: Set hostname to .
[ 6.957235] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.967113] systemd[1]: Reached target User and Group Name Lookups.
[ 6.977253] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.988814] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.999084] systemd[1]: Listening on Journal Audit Socket.
[ 7.009548] systemd[1]: Listening on udev Control Socket.
[ 7.017815] systemd[1]: Reached target Encrypted Volumes.
[ 7.026071] systemd[1]: Listening on udev Kernel Socket.
[ 7.034283] systemd[1]: Listening on Journal Socket.
[ 7.042033] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.050749] systemd[1]: Created slice System Slice.
[ 7.058597] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.067813] systemd[1]: Created slice system-getty.slice.
[ 7.079452] systemd[1]: Starting Load Kernel Modules…
[ 7.089579] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 7.100858] systemd[1]: Mounting Debug File System…
[ 7.109686] systemd[1]: Reached target Remote File Systems.
[ 7.118608] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.128821] systemd[1]: Reached target Swap.
[ 7.137858] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.147869] systemd[1]: Created slice User and Session Slice.
[ 7.156934] systemd[1]: Reached target Slices.
[ 7.167925] systemd[1]: Started Braille Device Support.
[ 7.178381] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.183455] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.196261] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.205769] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.217128] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 7.231067] systemd[1]: Listening on Syslog Socket.
[ 7.241009] systemd[1]: Starting Journal Service…
[ 7.253493] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.262979] systemd[1]: Mounted Debug File System.
[ 7.271295] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 7.282935] systemd[1]: Failed to start Load Kernel Modules.
[ 7.293714] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 7.302813] systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
[ 7.312804] systemd[1]: Started Create Static Device Nodes in /dev.
[ 7.324349] systemd[1]: Started Remount Root and Kernel File Systems.
[ 7.334626] systemd[1]: Started Journal Service.
[ 7.459597] systemd-journald[291]: Received request to flush runtime journal from PID 1
[ 7.590744] tc358748_mipi 2-000e: tc358748_open:
[ 7.592685] tc358748_mipi 7-000e: tc358748_open:
[ 7.623670] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 8.187551] using random self ethernet address
[ 8.193280] using random host ethernet address
[ 8.208064] Mass Storage Function, version: 2009/09/11
[ 8.214984] LUN: removable file: (no medium)
[ 8.226143] using random self ethernet address
[ 8.232626] using random host ethernet address
[ 8.237262] usb0: HOST MAC de:32:b6:92:02:fc
[ 8.237284] usb0: MAC be:b6:16:f5:34:a8
[ 8.238887] usb1: HOST MAC aa:77:58:2a:68:01
[ 8.238905] usb1: MAC 42:ac:10:06:05:67
[ 8.238920] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 8.241564] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 8.241578] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.242176] tegra-xudc-new 3550000.xudc: entering ELPG
[ 8.248645] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 8.349592] device usb0 entered promiscuous mode
[ 8.373124] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.389777] device usb1 entered promiscuous mode
[ 8.412222] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.422157] l4tbr0: port 2(usb1) entered forwarding state
[ 8.429307] l4tbr0: port 2(usb1) entered forwarding state
[ 8.608024] IPVS: Creating netns size=1424 id=1
[ 8.633613] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 8.646972] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.654494] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.664791] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.664815] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.664921] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.664924] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.664926] usb usb1: Product: xHCI Host Controller
[ 8.664927] usb usb1: Manufacturer: Linux 4.4.38 xhci-hcd
[ 8.664929] usb usb1: SerialNumber: 3530000.xhci
[ 8.665389] hub 1-0:1.0: USB hub found
[ 8.665411] hub 1-0:1.0: 4 ports detected
[ 8.692342] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.692349] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.692508] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.692511] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.692513] usb usb2: Product: xHCI Host Controller
[ 8.692515] usb usb2: Manufacturer: Linux 4.4.38 xhci-hcd
[ 8.692516] usb usb2: SerialNumber: 3530000.xhci
[ 8.692805] hub 2-0:1.0: USB hub found
[ 8.692825] hub 2-0:1.0: 3 ports detected
[ 8.693183] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.704381] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 8.704385] tegra-xotg xotg: update_id_state: ID floating
[ 8.707738] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.710349] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 8.980235] usb 1-2: new high-speed USB device number 2 using xhci-tegra
[ 9.004808] gk20a 17000000.gp10b: railgate is disabled.
[ 9.146387] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 9.146391] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.146393] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 9.146395] usb 1-2: Manufacturer: Generic
[ 9.146932] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 9.147273] hub 1-2:1.0: USB hub found
[ 9.147829] hub 1-2:1.0: 4 ports detected
[ 9.236301] l4tbr0: port 2(usb1) entered disabled state
[ 9.420332] usb 1-2.1: new low-speed USB device number 3 using xhci-tegra
[ 9.528296] usb 1-2.1: New USB device found, idVendor=89e5, idProduct=101b
[ 9.528313] usb 1-2.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 9.528324] usb 1-2.1: Product: USB OPTICAL MOUSE
[ 9.529167] usb 1-2.1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 9.534235] input: USB OPTICAL MOUSE as /devices/3530000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:89E5:101B.0001/input/input4
[ 9.534878] hid-generic 0003:89E5:101B.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-3530000.xhci-2.1/input0
[ 9.620291] usb 1-2.2: new low-speed USB device number 4 using xhci-tegra
[ 9.730380] usb 1-2.2: New USB device found, idVendor=1c4f, idProduct=0002
[ 9.730395] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.730405] usb 1-2.2: Product: USB Keyboard
[ 9.730414] usb 1-2.2: Manufacturer: SIGMACHIP
[ 9.731185] usb 1-2.2: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 9.731259] usb 1-2.2: ep 0x82 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 9.736074] input: SIGMACHIP USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:1C4F:0002.0002/input/input5
[ 9.789471] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-3530000.xhci-2.2/input0
[ 9.794500] input: SIGMACHIP USB Keyboard as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:1C4F:0002.0003/input/input6
[ 9.848395] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-3530000.xhci-2.2/input1
[ 9.900127] cfg80211: World regulatory domain updated:
[ 9.900141] cfg80211: DFS Master region: unset
[ 9.900143] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.900158] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.900167] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.900174] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.900183] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.900193] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.900368] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.900372] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.900375] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 10.072305] tegradc 15210000.nvdisplay: unblank
[ 10.340239] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 10.340252] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 10.426210] CPU1: shutdown
[ 10.428964] psci: CPU1 killed.
[ 10.449717] CPU2: shutdo
[quote]
Starting kernel …
[ 10.
See [url]https://devtalk.nvidia.com/default/topic/1031604/jetson-tx2/tx2-display-abnormally-with-hdim_output/[/url]
