I am using custom carrier board with Jetson TX2i, sometime it get stuck during booting. Please find log when it boots successfully
[code]
[0000.097] C> I2C command failed
[0000.100] C> block index = (4) and rail_id = (1)
[0000.104] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.109] C> I2C command failed
[0000.112] C> block index = (5) and rail_id = (1)
[0000.116] C> Addr: Reg = [0xe8:0x07]: 336166925
[0009.463] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-c4328dc3)
[0009.472] I> Default Heap @ [0xd486400 - 0xd488400]
[0009.477] I> DMA Heap @ [0x85200000 - 0x86200000]
[0009.481] I> bit @ 0xd480000
[0009.484] I> BR-BCT relocated to 0xd7020000
[0009.488] I> Boot-device: eMMC
[0009.492] I> sdmmc bdev is already initialized
[0009.497] I> pmic: reset reason (nverc) : 0x40
[0009.501] I> Reading GPT from 512 for device 00000003
[0009.507] I> Reading GPT from 16776704 for device 00000003
[0009.514] I> Found 13 partitions in 00000003 device
[0009.519] I> Reading GPT from 512 for device 00010003
[0009.526] I> Found 29 partitions in 00010003 device
[0009.531] I> OEM carveouts init scrub in progress…
[0009.612] I> Mb2 SDRAM scrub successful
[0009.616] W> No valid slot number is found in scratch register
[0009.622] W> Return default slot: _a
[0009.625] I> A/B: bin_type (16) slot 0
[0009.629] I> Loading partition bpmp-fw at 0xd7800000
[0009.634] I> Reading two headers - addr:0xd7800000 blocks:1
[0009.639] I> Addr: 0xd7800000, start-block: 58761217, num_blocks: 1
[0009.654] I> Binary(16) of size 529040 is loaded @ 0xd7800000
[0009.660] W> No valid slot number is found in scratch register
[0009.665] W> Return default slot: _a
[0009.669] I> A/B: bin_type (17) slot 0
[0009.672] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0009.678] I> Reading two headers - addr:0xd79f0000 blocks:1
[0009.683] I> Addr: 0xd79f0000, start-block: 58763633, num_blocks: 1
[0009.692] I> Binary(17) of size 75472 is loaded @ 0xd79ed600
[0009.726] I> BPMP-FW load address = 0xd7800000
[0009.731] I> BPMP-FW DTB load address = 0x501ed600
[0009.736] I> Loading SCE-FW …
[0009.739] W> No valid slot number is found in scratch register
[0009.744] W> Return default slot: _a
[0009.748] I> A/B: bin_type (12) slot 0
[0009.751] I> Loading partition sce-fw at 0xd7300000
[0009.756] I> Reading two headers - addr:0xd7300000 blocks:1
[0009.762] I> Addr: 0xd7300000, start-block: 58765633, num_blocks: 1
[0009.770] I> Binary(12) of size 76592 is loaded @ 0xd7300000
[0009.776] I> Init SCE
[0009.778] I> Copy BTCM section
[0009.781] W> No valid slot number is found in scratch register
[0009.787] W> Return default slot: _a
[0009.790] I> A/B: bin_type (13) slot 0
[0009.794] I> Loading partition cpu-bootloader at 0x96000000
[0009.799] I> Reading two headers - addr:0x96000000 blocks:1
[0009.805] I> Addr: 0x96000000, start-block: 58740737, num_blocks: 1
[0009.816] I> Binary(13) of size 282736 is loaded @ 0x96000000
[0009.822] W> No valid slot number is found in scratch register
[0009.828] W> Return default slot: _a
[0009.831] I> A/B: bin_type (20) slot 0
[0009.835] I> Loading partition bootloader-dtb at 0x8520f400
[0009.840] I> Reading two headers - addr:0x8520f400 blocks:1
[0009.845] I> Addr: 0x8520f400, start-block: 58742785, num_blocks: 1
[0009.857] I> Binary(20) of size 275504 is loaded @ 0x8520f400
[0009.862] I> MB2-params(VA) @ 0xd7000000
[0009.866] I> CPUBL-params(VA) @ 0xd7000000
[0009.870] I> CPUBL-params¶ @ 0x237000000
[0009.874] I> CPU-BL loaded @ PA 0x96000000
[0009.878] I> Loading TOS …
[0009.881] W> No valid slot number is found in scratch register
[0009.887] W> Return default slot: _a
[0009.890] I> A/B: bin_type (14) slot 0
[0009.894] I> Loading partition secure-os at 0x8530f600
[0009.899] I> Reading two headers - addr:0x8530f600 blocks:1
[0009.904] I> Addr: 0x8530f600, start-block: 58744833, num_blocks: 1
[0009.913] I> Binary(14) of size 62576 is loaded @ 0x8530f600
[0009.919] I> Copying Monitor (length: 0xf270) from 0x8530f800 to 0x40000000
[0009.926] I> Erasing Monitor @ 0x8530f800
[0009.930] I> Unhalting SCE
[0009.933] I> Primary Memory Start:80000000 Size:70000000
[0009.938] I> Extended Memory Start:f0110000 Size:145ef0000
[0009.944] I> Waypoint2-ACK: 0x52012714
[0009.948] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):e1e4477
NOTICE: BL31: Built : 00:08:30, May 17 2018
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0010.152] I> Welcome to Cboot
[0010.155] I> Cboot Version: 00.00.2014.50-t186-0c600f85
[0010.160] I> CPU-BL Params @ 0x237000000
[0010.164] I> 0) Base:0x00000000 Size:0x00000000
[0010.168] I> 1) Base:0x237f00000 Size:0x00100000
[0010.173] I> 2) Base:0x237e00000 Size:0x00100000
[0010.177] I> 3) Base:0x237d00000 Size:0x00100000
[0010.182] I> 4) Base:0x237c00000 Size:0x00100000
[0010.186] I> 5) Base:0x237b00000 Size:0x00100000
[0010.191] I> 6) Base:0x237800000 Size:0x00200000
[0010.195] I> 7) Base:0x237400000 Size:0x00400000
[0010.200] I> 8) Base:0x237a00000 Size:0x00100000
[0010.205] I> 9) Base:0x237300000 Size:0x00100000
[0010.209] I> 10) Base:0x236800000 Size:0x00800000
[0010.214] I> 11) Base:0x30000000 Size:0x00040000
[0010.218] I> 12) Base:0xf0000000 Size:0x00100000
[0010.222] I> 13) Base:0x30040000 Size:0x00001000
[0010.227] I> 14) Base:0x30048000 Size:0x00001000
[0010.231] I> 15) Base:0x30049000 Size:0x00001000
[0010.236] I> 16) Base:0x3004a000 Size:0x00001000
[0010.240] I> 17) Base:0x3004b000 Size:0x00001000
[0010.245] I> 18) Base:0x3004c000 Size:0x00001000
[0010.249] I> 19) Base:0x3004d000 Size:0x00001000
[0010.253] I> 20) Base:0x3004e000 Size:0x00001000
[0010.258] I> 21) Base:0x3004f000 Size:0x00001000
[0010.262] I> 22) Base:0x00000000 Size:0x00000000
[0010.267] I> 23) Base:0xf0100000 Size:0x00010000
[0010.271] I> 24) Base:0x00000000 Size:0x00000000
[0010.276] I> 25) Base:0x00000000 Size:0x00000000
[0010.280] I> 26) Base:0x00000000 Size:0x00000000
[0010.284] I> 27) Base:0x00000000 Size:0x00000000
[0010.289] I> 28) Base:0x84400000 Size:0x00400000
[0010.293] I> 29) Base:0x30000000 Size:0x00010000
[0010.298] I> 30) Base:0x238000000 Size:0x08000000
[0010.302] I> 31) Base:0x00000000 Size:0x00000000
[0010.307] I> 32) Base:0x236000000 Size:0x00600000
[0010.311] I> 33) Base:0x80000000 Size:0x70000000
[0010.316] I> 34) Base:0xf0110000 Size:0x145ef0000
[0010.320] I> 35) Base:0x00000000 Size:0x00000000
[0010.325] I> 36) Base:0x00000000 Size:0x00000000
[0010.329] I> 37) Base:0x2372e0000 Size:0x00020000
[0010.333] I> 38) Base:0x84000000 Size:0x00400000
[0010.338] I> 39) Base:0x96000000 Size:0x02400000
[0010.342] I> 40) Base:0x85000000 Size:0x01200000
[0010.347] I> 41) Base:0x237000000 Size:0x00280000
[0010.351] I> 42) Base:0x00000000 Size:0x00000000
[0010.356] I> 43) Base:0x00000000 Size:0x00000000
[0010.360] GIC-SPI Target CPU: 4
[0010.363] Interrupts Init done
[0010.367] calling constructors
[0010.370] initializing heap
[0010.372] initializing threads
[0010.376] initializing timers
[0010.379] creating bootstrap completion thread
[0010.383] top of bootstrap2()
[0010.386] CPU: ARM Cortex A57
[0010.389] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0010.394] initializing platform
[0010.398] I> Boot-device: eMMC
[0010.401] I> Dram Scrub in progress
[0015.675] I> DRAM Scrub Successfull
[0015.678] I> sdmmc bdev is already initialized
[0015.682] I> Reading GPT from 512 for device 00000003
[0015.688] I> Reading GPT from 16776704 for device 00000003
[0015.695] I> Found 13 partitions in 00000003 device
[0015.699] I> Reading GPT from 512 for device 00010003
[0015.705] I> Found 29 partitions in 00010003 device
[0015.710] W> opt-in fuse is not set, skip fuse_burning
[0015.715] I> Bl_dtb @0x8520f400
[0015.718] I> gpio framework initialized
[0015.721] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0015.729] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0015.736] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0015.743] E> i2c dev write failed
[0015.746] E> tca9539_device_init: failed to write polar reg
[0015.752] E> tegrabl_tca9539_init: failed to init device!
[0015.757] E> GPIO TCA9539 driver init failed
[0015.874] I> decompressor handler not found
[0015.881] I> fixed regulator driver initialized
[0015.916] I> register ‘maxim’ power off handle
[0015.922] I> virtual i2c enabled
[0015.925] I> registered ‘maxim,max77620’ pmic
[0015.930] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0015.941] I> Find /i2c@c250000’s alias i2c7
[0015.945] I> Reading eeprom i2c=7 address=0x50
[0015.975] I> Device at /i2c@c250000:0x50
[0015.979] I> Reading eeprom i2c=7 address=0x57
[0015.983] E> i2c dev read failed
[0015.986] E> eeprom: Failed to read I2C slave device
[0015.991] I> Eeprom read failed 0x1a89800d
[0015.996] I> Find /i2c@c240000’s alias i2c1
[0016.000] I> Reading eeprom i2c=1 address=0x51
[0016.005] E> i2c dev read failed
[0016.008] E> eeprom: Retry to read I2C slave device.
[0016.013] E> i2c dev read failed
[0016.016] E> eeprom: Failed to read I2C slave device
[0016.021] I> Eeprom read failed 0x1a89800d
[0016.026] I> Find /i2c@3160000’s alias i2c0
[0016.030] I> Reading eeprom i2c=0 address=0x50
[0016.034] E> i2c dev read failed
[0016.037] E> eeprom: Failed to read I2C slave device
[0016.042] I> Eeprom read failed 0x1a89800d
[0016.047] I> Find /i2c@3180000’s alias i2c2
[0016.051] I> Reading eeprom i2c=2 address=0x54
[0016.055] I> Enabling gpio chip_id = 2, gpio pin = 9
[0016.060] C> GPIO driver for chip_id 0x2 could not be found
[0016.065] E> cam_eeprom_read: Can’t get gpio driver
[0016.070] I> Eeprom read failed 0x2693400d
[0016.074] I> create_pm_ids: id: 3489-0000-300-M, len: 15
[0016.079] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0016.094] I> found one nvdisp nodes at offset = 103404
[0016.099] I> found one nvdisp nodes at offset = 104320
[0016.109] I> enabling ‘vdd-hdmi’ regulator
[0016.113] C> GPIO driver for chip_id 0x3 could not be found
[0016.118] I> found one nvdisp nodes at offset = 105124
[0016.123] I> no valid display unit config found in dtb
[0016.128] W> display init failed
[0016.131] initializing target
[0016.134] calling apps_init()
[0016.137] starting app android_boot_app
[0016.141] I> Gpio keyboard init success
[0016.145] I> Kernel type = Normal
[0016.148] I> Loading kernel/boot.img from storage …
[0016.153] W> No valid slot number is found in scratch register
[0016.159] W> Return default slot: _a
[0016.162] I> A/B: bin_type (0) slot 0
[0016.166] I> Loading partition kernel at 0xa8000000
[0016.926] I> tegrabl_auth_payload: partition kernel (bin_type 0)
[0016.966] W> No valid slot number is found in scratch register
[0016.971] W> Return default slot: _a
[0016.975] I> A/B: bin_type (1) slot 0
[0016.978] I> Loading partition kernel-dtb at 0x92000000
[0016.990] I> tegrabl_auth_payload: partition kernel-dtb (bin_type 1)
[0016.997] I> Kernel DTB @ 0x92000000
[0017.000] I> Checking boot.img header magic … [0017.004] I> [OK]
[0017.006] I> Valid boot.img @ 0xa8000000
[0017.010] I> decompressor handler not found
[0017.014] I> Copying kernel image (20468480 bytes) from 0xa8000800 to 0x80080000 … [0017.028] I> Done
[0017.029] I> Move ramdisk (len: 0) from 0xa9386000 to 0x9d000000
[0017.036] I> Updated bpmp info to DTB
[0017.042] I> Ramdisk: Base: 0x9d000000; Size: 0x0
[0017.047] I> Updated initrd info to DTB
[0017.050] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0017.058] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0017.065] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0017.072] I> disabled_core_mask: 0xffffff0c
[0017.076] W> No valid slot number is found in scratch register
[0017.082] W> Return default slot: _a
[0017.085] I> Active slot suffix:
[0017.088] I> add_boot_slot_suffix: slot_suffix =
[0017.093] I> add_serialno: Serial Num = 0422918060756
[0017.098] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2372e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0422918060756 bl_prof_dataptr=0x10000@0x237040000 sdhci_tegra.en_boot_part_access=1
[0017.136] I> Updated bootarg info to DTB
[0017.140] E> “plugin-manager” doesn’t exist, creating
[0017.145] E> “odm-data” doesn’t exist, creating
[0017.151] I> eeprom_get_mac_addr: MAC (type: 0): 00:ff:ff:ff:ff:ff
[0017.157] I> eeprom_get_mac_addr: MAC (type: 1): 00:ff:ff:ff:ff:ff
[0017.163] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:a9:2f:19
[0017.169] E> “ids” doesn’t exist, creating
[0017.173] E> “connection” doesn’t exist, creating
[0017.178] E> “configs” doesn’t exist, creating
[0017.182] I> create_pm_ids: id: 3489-0000-300-M, len: 15
[0017.187] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0017.198] I> Adding plugin-manager/ids/3489-0000-300=/i2c@c250000:module@0x50
[0017.205] E> “i2c@c250000” doesn’t exist, creating
[0017.210] E> “module@0x50” doesn’t exist, creating
[0017.217] I> Adding plugin-manager/ids/3489-0000-300-M
[0017.224] I> Adding plugin-manager/configs/3489-mem-type 00
[0017.229] I> Adding plugin-manager/configs/3489-power-config 00
[0017.235] I> Adding plugin-manager/configs/3489-misc-config 00
[0017.241] I> Adding plugin-manager/configs/3489-modem-config 00
[0017.246] I> Adding plugin-manager/configs/3489-touch-config 00
[0017.252] I> Adding plugin-manager/configs/3489-display-config 00
[0017.258] E> “chip-id” doesn’t exist, creating
[0017.263] I> Adding plugin-manager/chip-id/A02P
[0017.269] I> added [base:0x80000000, size:0x70000000] to /memory
[0017.275] I> added [base:0xf0200000, size:0x145e00000] to /memory
[0017.281] I> added [base:0x236600000, size:0x200000] to /memory
[0017.286] E> WARNING: Failed to pass NS DRAM ranges to TOS
[0017.292] I> Updated memory info to DTB
[0017.297] E> “reset” doesn’t exist, creating
[0017.302] E> “pmc-reset-reason” doesn’t exist, creating
[0017.307] E> “pmic-reset-reason” doesn’t exist, creating
[0017.312] I> disabled_core_mask: 0xffffff0c
[0017.324] I> Add serial number as DT property
[0017.329] I> tegrabl_load_kernel_and_dtb: Done
[0017.333] E> tegrabl_display_clear: display is not initialized
[0017.339] W> Boot logo display failed…
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (chetan@chetan-pc) (gcc version 4.8.5 (GCC) ) #2 SMP PREEMPT Tue Dec 24 15:58:47 IST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1b5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1761888
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2372e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0422918060756 bl_prof_dataptr=0x10000@0x237040000 sdhci_tegra.en_boot_part_access=1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6944076K/7159808K available (11144K kernel code, 1800K rwdata, 5744K rodata, 1164K init, 692K bss, 150196K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc8da0000 ( 109 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1b6800000 ( 7016 MB)
[ 0.000000] .init : 0xffffffc0010ff000 - 0xffffffc001222000 ( 1164 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010ff000 ( 16892 KB)
[ 0.000000] .data : 0xffffffc001243000 - 0xffffffc001405300 ( 1801 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009767] Console: colour dummy device 80x25
[ 0.014393] console [tty0] enabled
[ 0.017922] bootconsole [uart0] disabled
[ 0.021996] kmemleak: Kernel memory leak detector disabled
[ 0.022008] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022021] pid_max: default: 32768 minimum: 301
[ 0.022070] Security Framework initialized
[ 0.022109] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022120] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022516] Initializing cgroup subsys io
[ 0.022530] Initializing cgroup subsys memory
[ 0.022548] Initializing cgroup subsys devices
[ 0.022558] Initializing cgroup subsys freezer
[ 0.022567] Initializing cgroup subsys net_cls
[ 0.022578] Initializing cgroup subsys perf_event
[ 0.022587] Initializing cgroup subsys net_prio
[ 0.022598] Initializing cgroup subsys pids
[ 0.022607] Initializing cgroup subsys debug
[ 0.022755] CPU0 ipc=752
[ 0.022765] CPU1 ipc=1024
[ 0.022773] CPU2 ipc=1024
[ 0.022782] CPU3 ipc=752
[ 0.022792] CPU4 ipc=752
[ 0.022802] CPU5 ipc=752
[ 0.022843] ASID allocator initialised with 65536 entries
[ 0.046279] tegra-id: chipid=21817.
[ 0.046298] tegra-id: opt_subrevision=1.
[ 0.046311] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.046988] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
[ 0.047014] DTB Build time:
[ 0.062575] CPU1: Booted secondary processor [4e0f0030]
[ 0.074040] CPU2: Booted secondary processor [4e0f0030]
[ 0.085756] CPU3: Booted secondary processor [411fd073]
[ 0.097764] CPU4: Booted secondary processor [411fd073]
[ 0.109763] CPU5: Booted secondary processor [411fd073]
[ 0.109831] Brought up 6 CPUs
[ 0.109889] SMP: Total of 6 processors activated.
[ 0.109901] CPU: All CPU(s) started at EL2
[ 0.110375] devtmpfs: initialized
[ 0.136745] Initilizing CustomIPI irq domain
[ 0.136950] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.137796] pinctrl core: initialized pinctrl subsystem
[ 0.137975] OS set in device tree is not L4T.
[ 0.138173] regulator-dummy: no parameters
[ 0.138285] Initializing plugin-manager
[ 0.138339] Plugin module not found
[ 0.138744] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139089] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.139693] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.140842] node /plugin-manager/fragment-500-e3325-pcie match with board >=3489-0000-200
[ 0.141226] node /plugin-manager/fragment-p3489-A00 match with board >=3489-0000-200
[ 0.143665] node /plugin-manager/fragment-p3310-c00-camera match with board >=3489-0000-200
[ 0.145475] Adding domain adsp-pd to PM domain ape-pd
[ 0.147833] NET: Registered protocol family 16
[ 0.148620] console [pstore-1] enabled
[ 0.148633] pstore: Registered ramoops as persistent store backend
[ 0.148647] ramoops: attached 0x200000@0x237080000, ecc: 0/0
[ 0.157279] cpuidle: using governor ladder
[ 0.161756] cpuidle: using governor menu
[ 0.162932] bpmp: waiting for handshake
[ 0.162946] bpmp: handshake completed
[ 0.162980] bpmp: synchronizing channels
[ 0.162995] bpmp: channels synchronized
[ 0.163006] bpmp: mail init ok
[ 0.163324] vdso: 2 pages (1 code @ ffffffc001249000, 1 data @ ffffffc001248000)
[ 0.163358] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.164362] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.165722] tegra_powergate_init: DONE
[ 0.165756] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3489-1000-a00-00-base.dts
[ 0.165782] DTB Build time:
[ 0.166765] Tegra reboot handler registered.
[ 0.167841] Registering Tegra186 clocks (this may take a while)…done
[ 0.169442] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.169460] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.169474] arm-smmu 12000000.iommu: stage 1 translation
[ 0.169487] arm-smmu 12000000.iommu: stage 2 translation
[ 0.169499] arm-smmu 12000000.iommu: nested translation
[ 0.169513] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.169532] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.169551] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.169566] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.169579] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.219751] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.224905] iommu: Adding device 3460000.sdhci to group 0
[ 0.225741] iommu: Adding device 3400000.sdhci to group 1
[ 0.229249] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.229659] iommu: Adding device 3160000.i2c to group 3
[ 0.230071] iommu: Adding device c240000.i2c to group 4
[ 0.230446] iommu: Adding device 3180000.i2c to group 5
[ 0.230837] iommu: Adding device 3190000.i2c to group 6
[ 0.231338] iommu: Adding device 31b0000.i2c to group 7
[ 0.231670] iommu: Adding device 31c0000.i2c to group 8
[ 0.232017] iommu: Adding device c250000.i2c to group 9
[ 0.232339] iommu: Adding device 31e0000.i2c to group 10
[ 0.234401] iommu: Adding device 3210000.spi to group 11
[ 0.234764] iommu: Adding device c260000.spi to group 12
[ 0.235085] iommu: Adding device 3240000.spi to group 13
[ 0.235919] iommu: Adding device 3100000.serial to group 14
[ 0.236257] iommu: Adding device 3110000.serial to group 15
[ 0.236578] iommu: Adding device c280000.serial to group 16
[ 0.236879] iommu: Adding device 3130000.serial to group 17
[ 0.238210] iommu: Adding device 2490000.ether_qos to group 18
[ 0.238892] iommu: Adding device b000000.rtcpu to group 19
[ 0.239521] iommu: Adding device c1a0000.aon to group 20
[ 0.240388] Wake73 for irq=42
[ 0.240712] iommu: Adding device smmu_test to group 21
[ 0.241225] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.241270] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.241306] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.241362] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.241398] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.241432] mc-err: Set intmask: 0xf3140
[ 0.241704] ecc-err: dram ecc enabled-MC_ECC_CONTROL:0x0000000d
[ 0.241829] ecc-err: ecc_err_irq = 56
[ 0.242074] ecc-err: EMC_INTMASK = 0x00001c00
[ 0.242100] ecc-err: EMC_NONCRITICAL_INTMASK = 0x00000000
[ 0.242124] ecc-err: EMC_CRITICAL_INTMASK = 0x00000000
[ 0.243050] Wake76 for irq=199
[ 0.243080] Wake77 for irq=199
[ 0.243101] Wake78 for irq=199
[ 0.243122] Wake79 for irq=199
[ 0.243143] Wake80 for irq=199
[ 0.243163] Wake81 for irq=199
[ 0.243184] Wake82 for irq=199
[ 0.243297] iommu: Adding device 3530000.xhci to group 22
[ 0.243686] iommu: Adding device 3550000.xudc to group 23
[ 0.244512] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.244544] tegra-pmc: ### PMC reset source: Power on reset
[ 0.244568] tegra-pmc: ### PMC reset level: L0
[ 0.244591] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.244888] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.244928] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.245124] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.245154] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.245591] iommu: Adding device 13e10000.host1x to group 24
[ 0.245877] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.246171] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.246398] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.246672] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.246927] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.247176] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.247434] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.247662] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.248113] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.248637] iommu: Adding device 15700000.vi to group 34
[ 0.248999] iommu: Adding device 15600000.isp to group 35
[ 0.249359] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.249572] iommu: Adding device 15340000.vic to group 37
[ 0.249799] iommu: Adding device 154c0000.nvenc to group 38
[ 0.249995] iommu: Adding device 15480000.nvdec to group 39
[ 0.250362] iommu: Adding device 15380000.nvjpg to group 40
[ 0.250595] iommu: Adding device 15500000.tsec to group 41
[ 0.250850] iommu: Adding device 15100000.tsecb to group 42
[ 0.251546] iommu: Adding device 15810000.se to group 43
[ 0.251743] iommu: Adding device 15820000.se to group 44
[ 0.251972] iommu: Adding device 15830000.se to group 45
[ 0.252162] iommu: Adding device 15840000.se to group 46
[ 0.252650] iommu: Adding device 17000000.gp10b to group 47
[ 0.254111] tegra-reset 5000000.clock: registered 193 resets.
[ 0.256303] iommu: Adding device d000000.bpmp to group 48
[ 0.256531] bpmp: ping status is 0
[ 0.256716] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.257084] bpmp d000000.bpmp: probe ok
[ 0.260334] iommu: Adding device 2600000.dma to group 49
[ 0.261141] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.261227] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.261280] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.261355] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.261409] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.261461] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.261567] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.263358] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.264191] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.264428] iommu: Adding device sound to group 51
[ 0.266110] iommu: Adding device 3510000.hda to group 52
[ 0.267392] iommu: Adding device adsp_audio to group 53
[ 0.268817] iommu: Adding device 2993000.adsp to group 54
[ 0.278112] vdd-ac-bat: 5000 mV
[ 0.280388] vdd-1v8-ap: 1800 mV
[ 0.296837] SCSI subsystem initialized
[ 0.297177] usbcore: registered new interface driver usbfs
[ 0.297233] usbcore: registered new interface driver hub
[ 0.297344] usbcore: registered new device driver usb
[ 0.300030] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.300225] pca953x 0-0074: failed reading register
[ 0.300295] pca953x: probe of 0-0074 failed with error -121
[ 0.300645] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.300829] pca953x 0-0077: failed reading register
[ 0.300887] pca953x: probe of 0-0077 failed with error -121
[ 0.311334] media: Linux media interface: v0.10
[ 0.311398] Linux video capture interface: v2.00
[ 0.315406] pps_core: LinuxPPS API ver. 1 registered
[ 0.315432] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.315476] PTP clock support registered
[ 0.316381] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.316433] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.317845] max77620 4-003c: PMIC Version OTP:0x4D and ES:0x1
[ 0.320092] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.320268] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.320354] gpiochip_add_data: registered GPIOs 248 to 255 on device: max20024-gpio
[ 0.326199] vddio-ddr: at 1125 mV
[ 0.330049] avdd_dsi_csi: 1200 mV
[ 0.334051] vdd-1v8: 1800 mV
[ 0.338047] vdd-3v3-sys: 3300 mV
[ 0.338733] max77620-sd4: at 600 mV
[ 0.339647] spmic-ldo0: at 1800 mV
[ 0.340411] spmic-ldo1: at 800 mV
[ 0.346046] vddio-3v3: 3300 mV
[ 0.346830] vddio-sdmmc1: 1800 <–> 3300 mV at 1800 mV
[ 0.350049] vdd-rtc: at 800 mV
[ 0.350803] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.353768] spmic-ldo6: at 1500 mV
[ 0.357764] vdd-pex-1v05: 1000 mV
[ 0.358286] dvdd-pex: 1000 mV
[ 0.358552] max77620 4-003c: max77620 probe successful
[ 0.358816] Advanced Linux Sound Architecture Driver Initialized.
[ 0.359795] en-vdd-sd: 3300 mV
[ 0.360060] vdd-usb0-5v: 5000 mV
[ 0.360245] vdd-usb1-5v: 5000 mV
[ 0.360616] vdd-3v3: 3300 mV
[ 0.360756] en-vdd-vcm-2v8: 2800 mV
[ 0.360892] vdd-sys-bl: 3300 mV
[ 0.364252] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.364611] clocksource: Switched to clocksource arch_sys_counter
[ 0.383436] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.383749] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.384232] nvmap_page_pool_init: Total RAM pages: 1752403
[ 0.384249] nvmap_page_pool_init: nvmap page pool size: 219050 pages (855 MB)
[ 0.384330] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.388992] Wake76 for irq=199
[ 0.389006] Wake77 for irq=199
[ 0.389017] Wake78 for irq=199
[ 0.389028] Wake79 for irq=199
[ 0.389038] Wake80 for irq=199
[ 0.389048] Wake81 for irq=199
[ 0.389058] Wake82 for irq=199
[ 0.389811] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.390014] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.390404] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.390483] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.390631] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.390772] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.390928] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.391157] isomgr_init(): iso emc max clk=1600000KHz
[ 0.391170] isomgr_init(): max_iso_bw=7680000KB
[ 0.391258] NET: Registered protocol family 2
[ 0.391626] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.391852] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.392177] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.392237] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.392292] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.392462] NET: Registered protocol family 1
[ 0.392700] RPC: Registered named UNIX socket transport module.
[ 0.392717] RPC: Registered udp transport module.
[ 0.392729] RPC: Registered tcp transport module.
[ 0.392741] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.392863] Trying to unpack rootfs image as initramfs…
[ 0.406779] host1x 13e10000.host1x: initialized
[ 0.407597] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.409767] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.409871] audit: initializing netlink subsys (disabled)
[ 0.409907] audit: type=2000 audit(0.396:1): initialized
[ 0.420041] io scheduler noop registered
[ 0.420195] io scheduler cfq registered (default)
[ 0.423609] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.425066] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.426369] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.427626] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.432022] tsec 15500000.tsec: initialized
[ 0.432954] tsec 15100000.tsecb: initialized
[ 0.435105] nvdec 15480000.nvdec: initialized
[ 0.439428] falcon 15340000.vic: initialized
[ 0.440382] falcon 154c0000.nvenc: initialized
[ 0.441294] falcon 15380000.nvjpg: initialized
[ 0.442881] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.443651] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.444396] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.445179] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.445946] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.446695] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.447441] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.448187] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.450204] DC OR NODE connected to /host1x/sor1
[ 0.450399] generic_infoframe_type: 0x87
[ 0.450502] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.450514] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.450551] tegradc 15210000.nvdisplay: Display dc.ffffff80023c0000 registered with id=0
[ 0.450724] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.450758] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.459086] __tegra_isomgr_register(): iso bandwidth 5924200KB is not available, client disp_0
[ 0.459108] __tegra_isomgr_register(): iso bandwidth 3136300KB is not available, client disp_0
[ 0.459346] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 2787800 KB/s
[ 0.459364] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 102000000 Hz
[ 0.459381] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 49070000 Hz
[ 0.459427] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.459442] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.459899] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.460058] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.462434] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.462566] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.463427] kfuse 3830000.kfuse: initialized
[ 0.465230] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.465857] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.466756] tegra-i2c 3190000.i2c: no acknowledge from address 0x50
[ 0.469059] console [ttyS0] disabled
[ 0.469154] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.469545] tegradc 15210000.nvdisplay: probed
[ 2.463688] console [ttyS0] enabled
[ 2.465782] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.466028] Console: switching to colour frame buffer device 80x30
[ 2.466798] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.467017] serial-tegra 3130000.serial: RX in PIO mode
[ 2.467869] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.493348] brd: module loaded
[ 2.495726] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.501613] loop: module loaded
[ 2.501854] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.501858] nct1008_nct72 7-004c: starting parse dt
[ 2.501935] nct1008_nct72 7-004c: success parsing dt
[ 2.502074] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.538621] tmp451: Enabled overheat logging at 107.00C
[ 2.538766] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.540939] THERMAL EST: found 3 subdevs
[ 2.540943] THERMAL EST num_resources: 0
[ 2.540947] [THERMAL EST subdev 0]
[ 2.540952] [THERMAL EST subdev 1]
[ 2.540955] [THERMAL EST subdev 2]
[ 2.541222] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.541224] THERMAL EST: thz register success.
[ 2.541408] THERMAL EST: end of probe, return err: 0
[ 2.541451] tegra_profiler: Branch: Dev
[ 2.541453] tegra_profiler: Version: 1.117
[ 2.541455] tegra_profiler: Samples version: 41
[ 2.541457] tegra_profiler: IO version: 22
[ 2.541466] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.541470] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.541475] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.541479] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.541482] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.541485] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.541488] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.541492] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.541495] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.541498] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.541502] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.541505] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.541691] tegra_profiler: auth: init
[ 2.544923] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.544934] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.545821] scsi host0: tegra_ahci
[ 2.546181] scsi host1: tegra_ahci
[ 2.546339] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.546341] ata2: DUMMY
[ 2.547143] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.547559] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.547944] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.548719] tun: Universal TUN/TAP device driver, 1.6
[ 2.548722] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.548881] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.548883] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.548917] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.548919] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.549895] PPP generic driver version 2.4.2
[ 2.550023] PPP BSD Compression module registered
[ 2.550030] PPP Deflate Compression module registered
[ 2.550052] PPP MPPE Compression module registered
[ 2.550062] NET: Registered protocol family 24
[ 2.550112] usbcore: registered new interface driver r8152
[ 2.550145] usbcore: registered new interface driver asix
[ 2.550171] usbcore: registered new interface driver ax88179_178a
[ 2.550195] usbcore: registered new interface driver cdc_ether
[ 2.550227] usbcore: registered new interface driver smsc75xx
[ 2.550252] usbcore: registered new interface driver net1080
[ 2.550280] usbcore: registered new interface driver cdc_subset
[ 2.550333] usbcore: registered new interface driver zaurus
[ 2.550374] usbcore: registered new interface driver cdc_ncm
[ 2.550585] Wake76 for irq=199
[ 2.550588] Wake77 for irq=199
[ 2.550590] Wake78 for irq=199
[ 2.550591] Wake79 for irq=199
[ 2.550593] Wake80 for irq=199
[ 2.550594] Wake81 for irq=199
[ 2.550596] Wake82 for irq=199
[ 2.550650] tegra-xotg xotg: usb2 phy is not available yet
[ 2.551270] usbcore: registered new interface driver cdc_acm
[ 2.551272] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.551306] usbcore: registered new interface driver usb-storage
[ 2.551368] usbcore: registered new interface driver usbserial
[ 2.551392] usbcore: registered new interface driver cp210x
[ 2.551410] usbserial: USB Serial support registered for cp210x
[ 2.551435] usbcore: registered new interface driver ftdi_sio
[ 2.551450] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.551473] usbcore: registered new interface driver option
[ 2.551489] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.551511] usbcore: registered new interface driver pl2303
[ 2.551525] usbserial: USB Serial support registered for pl2303
[ 2.551705] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.570537] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a9 2f 19
[ 2.571126] libphy: dwc_phy: probed
[ 2.571763] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.634014] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.703911] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.706150] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.706173] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.706316] i2c /dev entries driver
[ 2.707100] gspca_main: v2.14.0 registered
[ 2.707148] usbcore: registered new interface driver gspca_zc3xx
[ 2.707382] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.709200] FAN: coudln’t get the regulator
[ 2.709915] device-mapper: uevent: version 1.0.3
[ 2.710092] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.710457] sdhci: Secure Digital Host Controller Interface driver
[ 2.710458] sdhci: Copyright(c) Pierre Ossman
[ 2.710463] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.710724] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.711004] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.711228] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.712322] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.712438] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.713903] usbcore: registered new interface driver usbhid
[ 2.713904] usbhid: USB HID core driver
[ 2.718554] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 2.718696] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 2.718805] ina3221x: probe of 0-0042 failed with error -121
[ 2.719143] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 2.719277] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 2.719370] ina3221x: probe of 0-0043 failed with error -121
[ 2.719711] nvadsp 2993000.adsp: in probe()…
[ 2.720742] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.720767] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.720942] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.731524] Denver: backdoor interface is NOT available.
[ 2.733173] coresight-tmc 8030000.etf: TMC initialized
[ 2.734164] coresight-tmc 8050000.etr: TMC initialized
[ 2.734482] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.734930] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.735317] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.735691] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.736095] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.736669] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.737174] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.737668] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.738221] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.738249] Module initialized successfully
[ 2.741475] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.742606] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.743065] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.743385] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.743429] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.743467] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.743508] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.743544] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.743581] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.743619] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.743740] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.743743] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.744281] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.744283] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.744285] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.744288] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.744290] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.744292] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.744294] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.744317] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.747703] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.748359] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.748471] camchar: rtcpu character device driver loaded
[ 2.751653] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.751875] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.751952] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.752281] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.752308] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.752330] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.752352] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.752374] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.752398] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.752420] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.752442] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.752464] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.752487] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.752510] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.752533] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.752554] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.752596] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.752607] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.752622] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.752683] **** A57 ECC: Enabled
[ 2.752685] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 2.752851] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.752940] parse_throttle_dt_data: Num cap clks = 4
[ 2.752942] parse_throttle_dt_data: clk=mcpu type=1
[ 2.752944] parse_throttle_dt_data: clk=bcpu type=2
[ 2.752949] parse_throttle_dt_data: clk=gpu type=4
[ 2.752951] parse_throttle_dt_data: clk=emc type=3
[ 2.753129] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.753471] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.753586] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.754350] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.757981] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.790588] mmc0: MAN_BKOPS_EN bit is not set
[ 2.796594] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.796871] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.796920] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.797001] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.797027] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.797851] mmc0: Skipping tuning since strobe enabled
[ 2.797948] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.805476] mmc0: periodic cache flush enabled
[ 2.805484] mmc0: new HS400 MMC card at address 0001
[ 2.805823] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.805993] mmcblk0boot0: mmc0:0001 032G34 partition 1 8.00 MiB
[ 2.806145] mmcblk0boot1: mmc0:0001 032G34 partition 2 8.00 MiB
[ 2.806311] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.807597] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.836688] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.864618] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.901473] tegradc 15210000.nvdisplay: fb registered
[ 3.908473] tegra-se-nvhost 15810000.se: initialized
[ 3.915031] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.922560] tegra-se-nvhost 15820000.se: initialized
[ 3.928900] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.936318] tegra-se-nvhost 15830000.se: initialized
[ 3.942409] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.949768] tegra-se-nvhost 15840000.se: initialized
[ 3.956019] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.966610] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.977750] cpufreq: platform driver Initialization: pass
[ 3.984104] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.991363] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.998126] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.009021] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.019708] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28ac16
[ 4.027395] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.036510] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.045585] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.053671] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.063020] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.070359] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.078433] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.087241] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.100116] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.108391] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.116871] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.126417] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.128438] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.128666] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.152342] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.160491] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.167735] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.176293] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.182808] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.201578] OPE platform probe
[ 4.205986] OPE platform probe successful
[ 4.307084] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.315758] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.324444] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.333126] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.341808] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.350508] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.359282] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.368086] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.376892] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.385722] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.394756] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.403795] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.412922] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.422061] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.431192] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.440319] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.449467] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.458607] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.467756] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.476891] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.489452] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.501845] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.511011] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.517566] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.558168] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.569667] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 4.578563] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.586480] GACT probability NOT on
[ 4.590630] Mirror/redirect action on
[ 4.594941] u32 classifier
[ 4.598272] Actions configured
[ 4.602310] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.609768] IPVS: Registered protocols ()
[ 4.614430] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 4.623060] IPVS: Creating netns size=1424 id=0
[ 4.628218] IPVS: ipvs loaded.
[ 4.631831] IPVS: [rr] scheduler registered.
[ 4.636755] ipip: IPv4 over IPv4 tunneling driver
[ 4.642324] Initializing XFRM netlink socket
[ 4.647442] NET: Registered protocol family 10
[ 4.653132] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.659174] NET: Registered protocol family 17
[ 4.664118] NET: Registered protocol family 15
[ 4.669101] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.682676] 8021q: 802.1Q VLAN Support v1.8
[ 4.688037] Registered cp15_barrier emulation handler
[ 4.693588] Registered setend emulation handler
[ 4.700616] registered taskstats version 1
[ 4.709160] isp 15600000.isp: initialized
[ 4.717807] nvcsi 150c0000.nvcsi: initialized
[ 4.724756] Wake76 for irq=199
[ 4.728556] Wake77 for irq=199
[ 4.732298] Wake78 for irq=199
[ 4.736026] Wake79 for irq=199
[ 4.739717] Wake80 for irq=199
[ 4.743375] Wake81 for irq=199
[ 4.746993] Wake82 for irq=199
[ 4.751015] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.757937] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.765431] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.773001] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.780357] Wake76 for irq=199
[ 4.783931] Wake77 for irq=199
[ 4.787505] Wake78 for irq=199
[ 4.791028] Wake79 for irq=199
[ 4.794536] Wake80 for irq=199
[ 4.798047] Wake81 for irq=199
[ 4.801519] Wake82 for irq=199
[ 4.805017] tegra-xotg xotg: usb2 phy is not available yet
[ 4.811363] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.818020] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.825062] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.835125] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.844910] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28ac16
[ 4.852134] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 4.859947] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.870100] Wake76 for irq=199
[ 4.873522] Wake77 for irq=199
[ 4.876922] Wake78 for irq=199
[ 4.880321] Wake79 for irq=199
[ 4.883704] Wake80 for irq=199
[ 4.887067] Wake81 for irq=199
[ 4.890429] Wake82 for irq=199
[ 4.894073] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.901728] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.908437] Wake76 for irq=199
[ 4.911837] Wake77 for irq=199
[ 4.915231] Wake78 for irq=199
[ 4.918619] Wake79 for irq=199
[ 4.922013] Wake80 for irq=199
[ 4.925400] Wake81 for irq=199
[ 4.928772] Wake82 for irq=199
[ 4.932215] tegra-xotg xotg: usb2 phy is not available yet
[ 4.938256] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.942678] random: nonblocking pool is initialized
[ 4.950013] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.957058] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x000000000352
Logs.zip (37.5 KB)
