The dmesg is showing below, does anybody can tell what’s the problem!
[code][0000.268] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-175b7c7b)
[0000.277] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.282] I> DMA Heap @ [0x85200000 - 0x86200000]
[0000.286] I> bit @ 0xd480000
[0000.289] I> BR-BCT relocated to 0xd7020000
[0000.293] I> Boot-device: eMMC
[0000.297] I> sdmmc bdev is already initialized
[0000.302] I> pmic: reset reason (nverc) : 0x4
[0000.306] I> Reading GPT from 512 for device 00000003
[0000.312] I> Reading GPT from 8388096 for device 00000003
[0000.319] I> Found 13 partitions in 00000003 device
[0000.324] I> Reading GPT from 512 for device 00010003
[0000.330] I> Found 29 partitions in 00010003 device
[0000.336] W> No valid slot number is found in scratch register
[0000.341] W> Return default slot: _a
[0000.345] I> A/B: bin_type (16) slot 0
[0000.348] I> Loading partition bpmp-fw at 0xd7800000
[0000.353] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.359] I> Addr: 0xd7800000, start-block: 58761217, num_blocks: 1
[0000.374] I> Binary(16) of size 529040 is loaded @ 0xd7800000
[0000.379] W> No valid slot number is found in scratch register
[0000.385] W> Return default slot: _a
[0000.388] I> A/B: bin_type (17) slot 0
[0000.392] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.397] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.403] I> Addr: 0xd79f0000, start-block: 58763633, num_blocks: 1
[0000.417] I> Binary(17) of size 465760 is loaded @ 0xd798e200
[0000.592] I> BPMP-FW load address = 0xd7800000
[0000.596] I> BPMP-FW DTB load address = 0x5018e200
[0000.601] I> Loading SCE-FW …
[0000.604] W> No valid slot number is found in scratch register
[0000.610] W> Return default slot: _a
[0000.613] I> A/B: bin_type (12) slot 0
[0000.617] I> Loading partition sce-fw at 0xd7300000
[0000.621] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.627] I> Addr: 0xd7300000, start-block: 58765633, num_blocks: 1
[0000.636] I> Binary(12) of size 76592 is loaded @ 0xd7300000
[0000.641] I> Init SCE
[0000.644] I> Copy BTCM section
[0000.646] W> No valid slot number is found in scratch register
[0000.652] W> Return default slot: _a
[0000.656] I> A/B: bin_type (13) slot 0
[0000.659] I> Loading partition cpu-bootloader at 0x96000000
[0000.665] I> Reading two headers - addr:0x96000000 blocks:1
[0000.670] I> Addr: 0x96000000, start-block: 58740737, num_blocks: 1
[0000.681] I> Binary(13) of size 275984 is loaded @ 0x96000000
[0000.687] W> No valid slot number is found in scratch register
[0000.693] W> Return default slot: _a
[0000.696] I> A/B: bin_type (20) slot 0
[0000.700] I> Loading partition bootloader-dtb at 0x8520f400
[0000.705] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.711] I> Addr: 0x8520f400, start-block: 58742785, num_blocks: 1
[0000.722] I> Binary(20) of size 279264 is loaded @ 0x8520f400
[0000.728] I> MB2-params(VA) @ 0xd7000000
[0000.732] I> CPUBL-params(VA) @ 0xd7000000
[0000.736] I> CPUBL-params¶ @ 0x277000000
[0000.740] I> CPU-BL loaded @ PA 0x96000000
[0000.744] I> Loading TOS …
[0000.746] W> No valid slot number is found in scratch register
[0000.752] W> Return default slot: _a
[0000.755] I> A/B: bin_type (14) slot 0
[0000.759] I> Loading partition secure-os at 0x8530f600
[0000.764] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.770] I> Addr: 0x8530f600, start-block: 58744833, num_blocks: 1
[0000.778] I> Binary(14) of size 62576 is loaded @ 0x8530f600
[0000.784] I> Copying Monitor (length: 0xf270) from 0x8530f800 to 0x40000000
[0000.791] I> Erasing Monitor @ 0x8530f800
[0000.795] I> Unhalting SCE
[0000.798] I> Primary Memory Start:80000000 Size:70000000
[0000.803] I> Extended Memory Start:f0110000 Size:185ef0000
[0000.810] I> Waypoint2-ACK: 0x52012664
[0000.813] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):e1e4477
NOTICE: BL31: Built : 20:40:15, Mar 1 2018
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0001.174] I> Welcome to Cboot
[0001.176] I> Cboot Version: 00.00.2014.50-t186-491395e7
[0001.181] I> CPU-BL Params @ 0x277000000
[0001.185] I> 0) Base:0x00000000 Size:0x00000000
[0001.190] I> 1) Base:0x277f00000 Size:0x00100000
[0001.194] I> 2) Base:0x277e00000 Size:0x00100000
[0001.199] I> 3) Base:0x277d00000 Size:0x00100000
[0001.203] I> 4) Base:0x277c00000 Size:0x00100000
[0001.208] I> 5) Base:0x277b00000 Size:0x00100000
[0001.212] I> 6) Base:0x277800000 Size:0x00200000
[0001.217] I> 7) Base:0x277400000 Size:0x00400000
[0001.221] I> 8) Base:0x277a00000 Size:0x00100000
[0001.226] I> 9) Base:0x277300000 Size:0x00100000
[0001.230] I> 10) Base:0x276800000 Size:0x00800000
[0001.235] I> 11) Base:0x30000000 Size:0x00040000
[0001.239] I> 12) Base:0xf0000000 Size:0x00100000
[0001.244] I> 13) Base:0x30040000 Size:0x00001000
[0001.248] I> 14) Base:0x30048000 Size:0x00001000
[0001.252] I> 15) Base:0x30049000 Size:0x00001000
[0001.257] I> 16) Base:0x3004a000 Size:0x00001000
[0001.261] I> 17) Base:0x3004b000 Size:0x00001000
[0001.266] I> 18) Base:0x3004c000 Size:0x00001000
[0001.270] I> 19) Base:0x3004d000 Size:0x00001000
[0001.275] I> 20) Base:0x3004e000 Size:0x00001000
[0001.279] I> 21) Base:0x3004f000 Size:0x00001000
[0001.283] I> 22) Base:0x00000000 Size:0x00000000
[0001.288] I> 23) Base:0xf0100000 Size:0x00010000
[0001.292] I> 24) Base:0x00000000 Size:0x00000000
[0001.297] I> 25) Base:0x00000000 Size:0x00000000
[0001.301] I> 26) Base:0x00000000 Size:0x00000000
[0001.306] I> 27) Base:0x00000000 Size:0x00000000
[0001.310] I> 28) Base:0x84400000 Size:0x00400000
[0001.314] I> 29) Base:0x30000000 Size:0x00010000
[0001.319] I> 30) Base:0x278000000 Size:0x08000000
[0001.323] I> 31) Base:0x00000000 Size:0x00000000
[0001.328] I> 32) Base:0x276000000 Size:0x00600000
[0001.332] I> 33) Base:0x80000000 Size:0x70000000
[0001.337] I> 34) Base:0xf0110000 Size:0x185ef0000
[0001.341] I> 35) Base:0x00000000 Size:0x00000000
[0001.346] I> 36) Base:0x00000000 Size:0x00000000
[0001.350] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.355] I> 38) Base:0x84000000 Size:0x00400000
[0001.359] I> 39) Base:0x96000000 Size:0x02400000
[0001.364] I> 40) Base:0x85000000 Size:0x01200000
[0001.368] I> 41) Base:0x277000000 Size:0x00280000
[0001.373] I> 42) Base:0x00000000 Size:0x00000000
[0001.377] I> 43) Base:0x00000000 Size:0x00000000
[0001.381] GIC-SPI Target CPU: 4
[0001.385] Interrupts Init done
[0001.388] calling constructors
[0001.391] initializing heap
[0001.394] initializing threads
[0001.397] initializing timers
[0001.400] creating bootstrap completion thread
[0001.405] top of bootstrap2()
[0001.408] CPU: ARM Cortex A57
[0001.411] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.416] initializing platform
[0001.419] I> Boot-device: eMMC
[0001.423] I> sdmmc bdev is already initialized
[0001.427] I> Reading GPT from 512 for device 00000003
[0001.433] I> Reading GPT from 8388096 for device 00000003
[0001.440] I> Found 13 partitions in 00000003 device
[0001.444] I> Reading GPT from 512 for device 00010003
[0001.450] I> Found 29 partitions in 00010003 device
[0001.455] W> opt-in fuse is not set, skip fuse_burning
[0001.460] I> Bl_dtb @0x8520f400
[0001.463] I> gpio framework initialized
[0001.467] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.474] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.481] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.490] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.498] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.506] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.513] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xec
[0001.519] E> i2c dev write failed
[0001.522] E> tca9539_device_init: failed to write polar reg
[0001.528] E> tegrabl_tca9539_init: failed to init device!
[0001.533] E> GPIO TCA9539 driver init failed
[0001.649] I> decompressor handler not found
[0001.656] I> fixed regulator driver initialized
[0001.693] I> register ‘maxim’ power off handle
[0001.698] I> virtual i2c enabled
[0001.701] I> registered ‘maxim,max77620’ pmic
[0001.706] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.717] I> Find /i2c@c250000’s alias i2c7
[0001.721] I> Reading eeprom i2c=7 address=0x50
[0001.751] I> Device at /i2c@c250000:0x50
[0001.755] I> Reading eeprom i2c=7 address=0x57
[0001.784] I> Device at /i2c@c250000:0x57
[0001.789] I> Find /i2c@c240000’s alias i2c1
[0001.793] I> Reading eeprom i2c=1 address=0x51
[0001.798] E> i2c dev read failed
[0001.801] E> eeprom: Retry to read I2C slave device.
[0001.807] E> i2c dev read failed
[0001.810] E> eeprom: Failed to read I2C slave device
[0001.814] I> Eeprom read failed 0x1a89800d
[0001.819] I> Find /i2c@3160000’s alias i2c0
[0001.823] I> Reading eeprom i2c=0 address=0x50
[0001.828] E> i2c dev read failed
[0001.831] E> eeprom: Failed to read I2C slave device
[0001.835] I> Eeprom read failed 0x1a89800d
[0001.840] I> Find /i2c@3180000’s alias i2c2
[0001.844] I> Reading eeprom i2c=2 address=0x54
[0001.848] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.855] E> i2c dev read failed
[0001.858] E> eeprom: Failed to read I2C slave device
[0001.863] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.868] I> Eeprom read failed 0x00000000
[0001.872] I> create_pm_ids: id: 3310-1000-B02-B, len: 15
[0001.877] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.888] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0001.893] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.908] I> found one nvdisp nodes at offset = 104144
[0001.913] I> found one nvdisp nodes at offset = 105060
[0001.923] I> enabling ‘vdd-hdmi’ regulator
[0001.938] I> regulator ‘vdd-hdmi’ already enabled
[0001.942] I> hdmi cable connected
[0001.950] I> setting ‘vdd-pex-1v05’ regulator to 1000000 micro volts
[0001.960] I> setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0001.966] I> found one nvdisp nodes at offset = 105864
[0001.985] I> edid read success
[0002.001] I> edid read success
[0002.004] I> width = 640, height = 480, frequency = 25174825
[0002.009] I> width = 640, height = 480, frequency = 25174825
[0002.015] I> width = 640, height = 480, frequency = 25174825
[0002.020] I> width = 640, height = 480, frequency = 25174825
[0002.026] I> width = 1920, height = 1080, frequency = 148500000
[0002.032] I> Best mode Width = 640, Height = 480, freq = 25174825
[0002.041] I> hdmi_enable, starting HDMI initialisation
[0002.449] I> hdmi_enable, HDMI initialisation complete
[0002.454] initializing target
[0002.457] calling apps_init()
[0002.461] starting app android_boot_app
[0002.465] I> Gpio keyboard init success
[0002.468] I> Kernel type = Normal
[0002.471] I> Loading kernel/boot.img from storage …
[0002.476] W> No valid slot number is found in scratch register
[0002.482] W> Return default slot: _a
[0002.485] I> A/B: bin_type (0) slot 0
[0002.489] I> Loading partition kernel at 0xa8000000
[0003.249] I> tegrabl_auth_payload: partition kernel (bin_type 0)
[0003.255] W> No valid slot number is found in scratch register
[0003.261] W> Return default slot: _a
[0003.264] I> A/B: bin_type (1) slot 0
[0003.267] I> Loading partition kernel-dtb at 0x92000000
[0003.279] I> tegrabl_auth_payload: partition kernel-dtb (bin_type 1)
[0003.286] I> Kernel DTB @ 0x92000000
[0003.289] I> Checking boot.img header magic … [0003.293] I> [OK]
[0003.295] I> Valid boot.img @ 0xa8000000
[0003.299] I> decompressor handler not found
[0003.303] I> Copying kernel image (488466 bytes) from 0xa8000800 to 0x80080000 … [0003.310] I> Done
[0003.312] I> Move ramdisk (len: 0) from 0xa8078000 to 0x9d000000
[0003.319] I> Updated bpmp info to DTB
[0003.325] I> Ramdisk: Base: 0x9d000000; Size: 0x0
[0003.329] I> Updated initrd info to DTB
[0003.333] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.340] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.347] I> disabled_core_mask: 0xffffff0c
[0003.351] W> No valid slot number is found in scratch register
[0003.357] W> Return default slot: _a
[0003.360] I> Active slot suffix:
[0003.363] I> add_boot_slot_suffix: slot_suffix =
[0003.368] I> add_serialno: Serial Num = 0323717014666
[0003.373] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x140000@0x969ec000 lut_mem2=0x2008@0x969e9000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323717014666 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1
[0003.417] I> Updated bootarg info to DTB
[0003.421] E> “plugin-manager” doesn’t exist, creating
[0003.425] E> “odm-data” doesn’t exist, creating
[0003.431] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8d:49:23
[0003.438] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8d:49:24
[0003.444] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8d:49:25
[0003.450] E> “ids” doesn’t exist, creating
[0003.454] E> “connection” doesn’t exist, creating
[0003.458] E> “configs” doesn’t exist, creating
[0003.463] I> create_pm_ids: id: 3310-1000-B02-B, len: 15
[0003.468] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.479] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0003.484] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.495] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50
[0003.502] E> “i2c@c250000” doesn’t exist, creating
[0003.506] E> “module@0x50” doesn’t exist, creating
[0003.511] I> Adding plugin-manager/ids/2597-0000-501=/i2c@c250000:module@0x57
[0003.518] E> “module@0x57” doesn’t exist, creating
[0003.525] I> Adding plugin-manager/ids/3310-1000-B02-B
[0003.532] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.538] I> Adding plugin-manager/configs/3310-power-config 00
[0003.543] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.549] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.555] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.561] I> Adding plugin-manager/configs/3310-display-config 00
[0003.567] E> “chip-id” doesn’t exist, creating
[0003.571] I> Adding plugin-manager/chip-id/A02P
[0003.578] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.583] I> added [base:0xf0200000, size:0x185e00000] to /memory
[0003.589] I> added [base:0x276600000, size:0x200000] to /memory
[0003.595] E> WARNING: Failed to pass NS DRAM ranges to TOS
[0003.600] I> Updated memory info to DTB
[0003.606] E> “reset” doesn’t exist, creating
[0003.610] E> “pmc-reset-reason” doesn’t exist, creating
[0003.615] E> “pmic-reset-reason” doesn’t exist, creating
[0003.621] I> disabled_core_mask: 0xffffff0c
[0003.633] I> Add serial number as DT property
[0003.637] I> tegrabl_load_kernel_and_dtb: Done
U-Boot 2016.07-g9c3b9a4 (Mar 01 2018 - 20:41:10 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 95 ms (2 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
20727600 bytes read in 547 ms (36.1 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x140000@0x969ec000 lut_mem2=0x2008@0x969e9000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323717014666 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
Flattened Device Tree blob at 92000000
Booting using the fdt blob at 0x92000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000092000000, end 0000000092049273
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-592) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Mar 1 20:49:20 PST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Found tegra_fbmem2: 00140000@969ec000
[ 0.000000] Found lut_mem2: 00002008@969e9000
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x140000@0x969ec000 lut_mem2=0x2008@0x969e9000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0323717014666 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7974684K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 168164K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
[ 0.000000] .init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)
[ 0.000000] .data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009816] Console: colour dummy device 80x25
[ 0.014476] console [tty0] enabled
[ 0.018034] bootconsole [uart0] disabled
[ 0.022139] kmemleak: Kernel memory leak detector disabled
[ 0.022151] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022163] pid_max: default: 32768 minimum: 301
[ 0.022212] Security Framework initialized
[ 0.022249] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022260] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022641] Initializing cgroup subsys io
[ 0.022655] Initializing cgroup subsys memory
[ 0.022672] Initializing cgroup subsys devices
[ 0.022681] Initializing cgroup subsys freezer
[ 0.022690] Initializing cgroup subsys net_cls
[ 0.022700] Initializing cgroup subsys perf_event
[ 0.022709] Initializing cgroup subsys net_prio
[ 0.022719] Initializing cgroup subsys pids
[ 0.022728] Initializing cgroup subsys debug
[ 0.022867] CPU0 ipc=752
[ 0.022877] CPU1 ipc=1024
[ 0.022885] CPU2 ipc=1024
[ 0.022894] CPU3 ipc=752
[ 0.022903] CPU4 ipc=752
[ 0.022912] CPU5 ipc=752
[ 0.022949] ASID allocator initialised with 65536 entries
[ 0.046070] tegra-id: chipid=21817.
[ 0.046088] tegra-id: opt_subrevision=1.
[ 0.046101] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046764] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046791] DTB Build time: Mar 1 2018 20:50:46
[ 0.062550] CPU1: Booted secondary processor [4e0f0030]
[ 0.074061] CPU2: Booted secondary processor [4e0f0030]
[ 0.085784] CPU3: Booted secondary processor [411fd073]
[ 0.097800] CPU4: Booted secondary processor [411fd073]
[ 0.109800] CPU5: Booted secondary processor [411fd073]
[ 0.109863] Brought up 6 CPUs
[ 0.109921] SMP: Total of 6 processors activated.
[ 0.109934] CPU: All CPU(s) started at EL2
[ 0.110391] devtmpfs: initialized
[ 0.137168] Initilizing CustomIPI irq domain
[ 0.137382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138135] pinctrl core: initialized pinctrl subsystem
[ 0.138305] OS set in device tree is not L4T.
[ 0.138493] regulator-dummy: no parameters
[ 0.138597] Initializing plugin-manager
[ 0.138649] Plugin module not found
[ 0.139054] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139396] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140019] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141195] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141580] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141844] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142070] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142500] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142952] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143237] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143624] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143876] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144102] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144365] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146303] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148072] Adding domain adsp-pd to PM domain ape-pd
[ 0.150406] NET: Registered protocol family 16
[ 0.151260] console [pstore-1] enabled
[ 0.151273] pstore: Registered ramoops as persistent store backend
[ 0.151286] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161329] cpuidle: using governor ladder
[ 0.165784] cpuidle: using governor menu
[ 0.166922] bpmp: waiting for handshake
[ 0.166937] bpmp: handshake completed
[ 0.166979] bpmp: synchronizing channels
[ 0.167003] bpmp: channels synchronized
[ 0.167014] bpmp: mail init ok
[ 0.167386] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167419] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168372] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169839] tegra_powergate_init: DONE
[ 0.169861] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169888] DTB Build time: Mar 1 2018 20:50:46
[ 0.170841] Tegra reboot handler registered.
[ 0.171873] Registering Tegra186 clocks (this may take a while)…done
[ 0.173970] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173988] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174002] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174014] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174026] arm-smmu 12000000.iommu: nested translation
[ 0.174041] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.174059] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174078] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174092] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174105] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.222973] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.228473] iommu: Adding device 3460000.sdhci to group 0
[ 0.229360] iommu: Adding device 3400000.sdhci to group 1
[ 0.233020] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.233477] iommu: Adding device 3160000.i2c to group 3
[ 0.233884] iommu: Adding device c240000.i2c to group 4
[ 0.234264] iommu: Adding device 3180000.i2c to group 5
[ 0.234721] iommu: Adding device 3190000.i2c to group 6
[ 0.235219] iommu: Adding device 31b0000.i2c to group 7
[ 0.235611] iommu: Adding device 31c0000.i2c to group 8
[ 0.235972] iommu: Adding device c250000.i2c to group 9
[ 0.236304] iommu: Adding device 31e0000.i2c to group 10
[ 0.238336] iommu: Adding device 3210000.spi to group 11
[ 0.238705] iommu: Adding device c260000.spi to group 12
[ 0.239024] iommu: Adding device 3240000.spi to group 13
[ 0.239832] iommu: Adding device 3100000.serial to group 14
[ 0.240151] iommu: Adding device 3110000.serial to group 15
[ 0.240449] iommu: Adding device c280000.serial to group 16
[ 0.240779] iommu: Adding device 3130000.serial to group 17
[ 0.242101] iommu: Adding device 2490000.ether_qos to group 18
[ 0.242780] iommu: Adding device b000000.rtcpu to group 19
[ 0.243252] iommu: Adding device c1a0000.aon to group 20
[ 0.244157] Wake73 for irq=42
[ 0.244493] iommu: Adding device smmu_test to group 21
[ 0.245008] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.245047] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.245083] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.245118] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.245174] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.245207] mc-err: Set intmask: 0xf3140
[ 0.245420] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.246269] Wake76 for irq=199
[ 0.246293] Wake77 for irq=199
[ 0.246314] Wake78 for irq=199
[ 0.246333] Wake79 for irq=199
[ 0.246353] Wake80 for irq=199
[ 0.246393] Wake81 for irq=199
[ 0.246413] Wake82 for irq=199
[ 0.246530] iommu: Adding device 3530000.xhci to group 22
[ 0.246907] iommu: Adding device 3550000.xudc to group 23
[ 0.247718] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.247748] tegra-pmc: ### PMC reset source: Power on reset
[ 0.247771] tegra-pmc: ### PMC reset level: L0
[ 0.247817] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.248064] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.248102] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.248270] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.248299] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.248772] iommu: Adding device 13e10000.host1x to group 24
[ 0.249027] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.249307] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.249565] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.249800] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.250017] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.250303] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.250528] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.250829] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.251251] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.251815] iommu: Adding device 15700000.vi to group 34
[ 0.252133] iommu: Adding device 15600000.isp to group 35
[ 0.252495] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.252606] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ec000(140000)
[ 0.252682] platform 15210000.nvdisplay: IOVA linear map 0x00000000969e9000(3000)
[ 0.252906] iommu: Adding device 15340000.vic to group 37
[ 0.253126] iommu: Adding device 154c0000.nvenc to group 38
[ 0.253364] iommu: Adding device 15480000.nvdec to group 39
[ 0.253847] iommu: Adding device 15380000.nvjpg to group 40
[ 0.254072] iommu: Adding device 15500000.tsec to group 41
[ 0.254281] iommu: Adding device 15100000.tsecb to group 42
[ 0.255184] iommu: Adding device 15810000.se to group 43
[ 0.255401] iommu: Adding device 15820000.se to group 44
[ 0.255625] iommu: Adding device 15830000.se to group 45
[ 0.255812] iommu: Adding device 15840000.se to group 46
[ 0.256502] iommu: Adding device 17000000.gp10b to group 47
[ 0.258061] tegra-reset 5000000.clock: registered 193 resets.
[ 0.260154] iommu: Adding device d000000.bpmp to group 48
[ 0.260427] bpmp: ping status is 0
[ 0.260637] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.260994] bpmp d000000.bpmp: probe ok
[ 0.263553] iommu: Adding device 2600000.dma to group 49
[ 0.264430] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.264620] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.264679] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.264731] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.264790] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.264863] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.264923] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.265032] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.266963] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.267080] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.268007] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.268267] iommu: Adding device sound to group 51
[ 0.270007] iommu: Adding device 3510000.hda to group 52
[ 0.271189] iommu: Adding device adsp_audio to group 53
[ 0.272651] iommu: Adding device 2993000.adsp to group 54
[ 0.281944] vdd-ac-bat: 5000 mV
[ 0.284292] vdd-1v8-ap: 1800 mV
[ 0.304549] SCSI subsystem initialized
[ 0.304961] usbcore: registered new interface driver usbfs
[ 0.305024] usbcore: registered new interface driver hub
[ 0.305139] usbcore: registered new device driver usb
[ 0.308924] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.309380] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.309497] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.310935] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.311043] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.321814] media: Linux media interface: v0.10
[ 0.321888] Linux video capture interface: v2.00
[ 0.325048] pps_core: LinuxPPS API ver. 1 registered
[ 0.325084] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.325137] PTP clock support registered
[ 0.326147] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.326194] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.327680] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.329847] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.330039] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.330152] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.334726] vddio-ddr: at 1125 mV
[ 0.338559] avdd_dsi_csi: 1200 mV
[ 0.342561] vdd-1v8: 1800 mV
[ 0.346560] vdd-3v3-sys: 3300 mV
[ 0.347650] spmic-ldo0: at 1800 mV
[ 0.348430] spmic-ldo1: at 800 mV
[ 0.354561] vddio-3v3: 3300 mV
[ 0.355279] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.358564] vdd-rtc: at 800 mV
[ 0.359337] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.361806] spmic-ldo6: at 1500 mV
[ 0.365804] vdd-pex-1v05: 1000 mV
[ 0.366351] dvdd-pex: 1000 mV
[ 0.366612] max77620 4-003c: max77620 probe successful
[ 0.366864] Advanced Linux Sound Architecture Driver Initialized.
[ 0.367809] en-vdd-sd: 3300 mV
[ 0.368455] en-vdd-cam: 1800 mV
[ 0.369804] vdd-hdmi: 5000 mV
[ 0.369979] vdd-usb0-5v: 5000 mV
[ 0.370147] vdd-usb1-5v: 5000 mV
[ 0.373802] en-vdd-ts-1v8: 1800 mV
[ 0.377804] en-vdd-ts-hv-3v3: 3300 mV
[ 0.378327] en-vdd-disp-3v3: 3300 mV
[ 0.378842] en-mdm-pwr-3v7: 3700 mV
[ 0.379353] en-vdd-disp-1v8: 1800 mV
[ 0.379870] en-vdd-cam-hv-2v8: 2800 mV
[ 0.380390] en-vdd-cam-1v2: 1200 mV
[ 0.380916] vdd-fan: 5000 mV
[ 0.381023] vdd-3v3: 3300 mV
[ 0.381749] dis-vdd-1v2: 1200 mV
[ 0.381869] en-vdd-vcm-2v8: 2800 mV
[ 0.382389] vdd-usb2-5v: 5000 mV
[ 0.382507] vdd-sys-bl: 3300 mV
[ 0.383027] en-vdd-sys: 1200 mV
[ 0.386352] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.386773] clocksource: Switched to clocksource arch_sys_counter
[ 0.405246] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.405507] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.405973] nvmap_page_pool_init: Total RAM pages: 2010055
[ 0.405990] nvmap_page_pool_init: nvmap page pool size: 251256 pages (981 MB)
[ 0.406188] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.410670] Wake76 for irq=199
[ 0.410684] Wake77 for irq=199
[ 0.410694] Wake78 for irq=199
[ 0.410704] Wake79 for irq=199
[ 0.410714] Wake80 for irq=199
[ 0.410723] Wake81 for irq=199
[ 0.410733] Wake82 for irq=199
[ 0.411505] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.411713] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.412110] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.412188] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.412337] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.412485] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.412637] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.412931] isomgr_init(): iso emc max clk=1866000KHz
[ 0.412944] isomgr_init(): max_iso_bw=26870400KB
[ 0.413030] NET: Registered protocol family 2
[ 0.413385] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.413617] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.413916] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.413973] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.414030] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.414199] NET: Registered protocol family 1
[ 0.414407] RPC: Registered named UNIX socket transport module.
[ 0.414423] RPC: Registered udp transport module.
[ 0.414434] RPC: Registered tcp transport module.
[ 0.414446] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.414561] Trying to unpack rootfs image as initramfs…
[ 0.429107] host1x 13e10000.host1x: initialized
[ 0.429956] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.432161] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.432256] audit: initializing netlink subsys (disabled)
[ 0.432287] audit: type=2000 audit(0.420:1): initialized
[ 0.439076] io scheduler noop registered
[ 0.439183] io scheduler cfq registered (default)
[ 0.442060] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.443237] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.444304] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.445342] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.448789] tsec 15500000.tsec: initialized
[ 0.449937] tsec 15100000.tsecb: initialized
[ 0.452246] nvdec 15480000.nvdec: initialized
[ 0.455801] falcon 15340000.vic: initialized
[ 0.456828] falcon 154c0000.nvenc: initialized
[ 0.457835] falcon 15380000.nvjpg: initialized
[ 0.458607] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.459132] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.459643] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.460154] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.460662] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.461173] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.461678] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.462210] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.464763] DC OR NODE connected to /host1x/sor1
[ 0.464889] generic_infoframe_type: 0x87
[ 0.464899] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.464997] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.465013] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.465029] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.465044] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.472404] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.472426] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.472442] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.472487] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.472502] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.472653] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.473374] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 640x480 (on 0x0mm) pclk=50347983
[ 0.475064] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.475405] kfuse 3830000.kfuse: initialized
[ 0.475525] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.476935] tegradc 15210000.nvdisplay: probed
[ 0.477119] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.477746] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.479697] console [ttyS0] disabled
[ 0.479748] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.600229] console [ttyS0] enabled
[ 2.602204] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.602354] Console: switching to colour frame buffer device 80x30
[ 2.603295] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.603522] serial-tegra 3130000.serial: RX in PIO mode
[ 2.604424] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.629743] brd: module loaded
[ 2.632469] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.635100] loop: module loaded
[ 2.635333] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.635338] nct1008_nct72 7-004c: starting parse dt
[ 2.635421] nct1008_nct72 7-004c: success parsing dt
[ 2.635541] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.672424] tmp451: Enabled overheat logging at 104.00C
[ 2.672576] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.674951] THERMAL EST: found 3 subdevs
[ 2.674954] THERMAL EST num_resources: 0
[ 2.674958] [THERMAL EST subdev 0]
[ 2.674963] [THERMAL EST subdev 1]
[ 2.674966] [THERMAL EST subdev 2]
[ 2.675309] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.675312] THERMAL EST: thz register success.
[ 2.675442] THERMAL EST: end of probe, return err: 0
[ 2.675493] tegra_profiler: Branch: Dev
[ 2.675495] tegra_profiler: Version: 1.117
[ 2.675497] tegra_profiler: Samples version: 41
[ 2.675499] tegra_profiler: IO version: 22
[ 2.675506] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.675511] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.675515] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.675519] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.675523] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.675526] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.675529] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.675532] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.675535] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.675538] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.675541] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.675544] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.675720] tegra_profiler: auth: init
[ 2.679201] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.679212] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.680216] scsi host0: tegra_ahci
[ 2.680582] scsi host1: tegra_ahci
[ 2.680757] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.680760] ata2: DUMMY
[ 2.681715] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.682185] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.682660] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.683515] tun: Universal TUN/TAP device driver, 1.6
[ 2.683517] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.683697] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.683699] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.683735] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.683737] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.684993] PPP generic driver version 2.4.2
[ 2.685132] PPP BSD Compression module registered
[ 2.685139] PPP Deflate Compression module registered
[ 2.685163] PPP MPPE Compression module registered
[ 2.685176] NET: Registered protocol family 24
[ 2.685227] usbcore: registered new interface driver r8152
[ 2.685259] usbcore: registered new interface driver asix
[ 2.685287] usbcore: registered new interface driver ax88179_178a
[ 2.685313] usbcore: registered new interface driver cdc_ether
[ 2.685351] usbcore: registered new interface driver smsc75xx
[ 2.685378] usbcore: registered new interface driver net1080
[ 2.685405] usbcore: registered new interface driver cdc_subset
[ 2.685432] usbcore: registered new interface driver zaurus
[ 2.685478] usbcore: registered new interface driver cdc_ncm
[ 2.685818] Wake76 for irq=199
[ 2.685820] Wake77 for irq=199
[ 2.685822] Wake78 for irq=199
[ 2.685824] Wake79 for irq=199
[ 2.685826] Wake80 for irq=199
[ 2.685828] Wake81 for irq=199
[ 2.685829] Wake82 for irq=199
[ 2.685922] tegra-xotg xotg: usb2 phy is not available yet
[ 2.686519] usbcore: registered new interface driver cdc_acm
[ 2.686521] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.686561] usbcore: registered new interface driver usb-storage
[ 2.686620] usbcore: registered new interface driver usbserial
[ 2.686644] usbcore: registered new interface driver cp210x
[ 2.686662] usbserial: USB Serial support registered for cp210x
[ 2.686684] usbcore: registered new interface driver ftdi_sio
[ 2.686702] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.686723] usbcore: registered new interface driver option
[ 2.686739] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.686764] usbcore: registered new interface driver pl2303
[ 2.686811] usbserial: USB Serial support registered for pl2303
[ 2.687023] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.687897] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 49 25
[ 2.688439] libphy: dwc_phy: probed
[ 2.689380] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.751954] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.823601] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.825826] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.825848] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.825984] i2c /dev entries driver
[ 2.826722] gspca_main: v2.14.0 registered
[ 2.826778] usbcore: registered new interface driver gspca_zc3xx
[ 2.827014] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.828838] FAN dev name: pwm-fan
[ 2.828885] FAN:gpio request success.
[ 2.828891] FAN: can’t find tach_gpio
[ 2.828910] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 2.829068] pwm_fan_driver pwm-fan: got pwm for fan
[ 2.829072] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.829344] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.829347] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 2.829351] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 2.829354] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 2.829357] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.829360] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.829363] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.829366] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.829369] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.829372] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.830088] device-mapper: uevent: version 1.0.3
[ 2.830267] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.830603] sdhci: Secure Digital Host Controller Interface driver
[ 2.830604] sdhci: Copyright(c) Pierre Ossman
[ 2.830609] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.830900] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.831177] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.831404] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.834572] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.834735] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.836522] usbcore: registered new interface driver usbhid
[ 2.836524] usbhid: USB HID core driver
[ 2.841676] nvadsp 2993000.adsp: in probe()…
[ 2.843009] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.843044] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.843267] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.853955] Denver: backdoor interface is NOT available.
[ 2.856017] coresight-tmc 8030000.etf: TMC initialized
[ 2.860980] coresight-tmc 8050000.etr: TMC initialized
[ 2.861446] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.862050] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.862576] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.863103] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.863588] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.864302] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.864917] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.865569] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.866191] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.866222] Module initialized successfully
[ 2.870280] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.871896] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.872144] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.872507] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.872562] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.872606] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.872645] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.872699] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.872738] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.872776] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.872918] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.872921] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.873554] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.873557] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.873560] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.873562] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.873565] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.873567] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.873569] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.873610] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.874808] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.875237] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.876165] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.880723] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.881629] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.881760] camchar: rtcpu character device driver loaded
[ 2.886978] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.887272] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.887416] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.887873] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.887900] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.887928] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.887954] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.887978] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.888002] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.888030] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.888052] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.888076] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.888098] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.888126] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.888151] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.888176] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.888201] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.888228] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.888275] **** A57 ECC: Enabled
[ 2.888278] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 2.888416] parse_throttle_dt_data: Num cap clks = 4
[ 2.888419] parse_throttle_dt_data: clk=mcpu type=1
[ 2.888421] parse_throttle_dt_data: clk=bcpu type=2
[ 2.888428] parse_throttle_dt_data: clk=gpu type=4
[ 2.888429] parse_throttle_dt_data: clk=emc type=3
[ 2.888960] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.889051] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.892180] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.895220] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.922808] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.923078] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.923132] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.923213] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.923242] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.923477] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.932785] mmc0: MAN_BKOPS_EN bit is not set
[ 2.940041] mmc0: Skipping tuning since strobe enabled
[ 2.947456] mmc0: periodic cache flush enabled
[ 2.947464] mmc0: new HS400 MMC card at address 0001
[ 2.947811] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.947974] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.948139] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.948296] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.949618] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.974869] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.987295] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.006809] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.185173] mmc1 tuning done saved tap delay=57
[ 3.185177] mmc1: hw tuning done …
[ 3.185185] mmc1: tuning_window[0]: 0xffffffff
[ 3.185191] mmc1: tuning_window[1]: 0xffffff9f
[ 3.185197] mmc1: tuning_window[2]: 0xffff1fff
[ 3.185202] mmc1: tuning_window[3]: 0x7f9fffff
[ 3.185207] mmc1: tuning_window[4]: 0x0
[ 3.185212] mmc1: tuning_window[5]: 0x0
[ 3.185246] mmc1: tuning_window[6]: 0x0
[ 3.185252] mmc1: tuning_window[7]: 0x0
[ 3.185256] sdhci: Tap value: 57 | Trim value: 5
[ 3.185260] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.192137] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.192187] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.197074] tegradc 15210000.nvdisplay: fb registered
[ 4.202899] PD DISP0 index2 UP
[ 4.207196] PD DISP1 index3 UP
[ 4.210868] PD DISP2 index4 UP
[ 4.216713] Parent Clock set for DC plld2
[ 4.222270] edid invalid
[ 4.269480] edid invalid
[ 4.272461] edid invalid
[ 4.275429] tegradc 15210000.nvdisplay: hdmi: pclk:50349K, set prod-setting:prod_c_54M
[ 4.303753] tegra-se-nvhost 15810000.se: initialized
[ 4.309804] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.317017] tegra-se-nvhost 15820000.se: initialized
[ 4.323004] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.330088] tegra-se-nvhost 15830000.se: initialized
[ 4.335838] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.342927] tegra-se-nvhost 15840000.se: initialized
[ 4.348882] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.359025] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.369960] cpufreq: platform driver Initialization: pass
[ 4.376104] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 4.383202] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.389829] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.400517] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.410488] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28b094
[ 4.417789] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.426326] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.433307] tegradc 15210000.nvdisplay: blank - normal
[ 4.434181] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 4.435174] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.435637] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.436549] tegradc 15210000.nvdisplay: blank - powerdown
[ 4.440020] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.440155] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.441330] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.441334] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.445515] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.454953] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.455185] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.455478] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.455735] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.456027] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.456031] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.456032] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.457364] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.457365] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.457579] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.466028] OPE platform probe
[ 4.466090] OPE platform probe successful
[ 4.472726] random: nonblocking pool is initialized
[ 4.491052] PD DISP2 index4 DOWN
[ 4.491150] PD DISP1 index3 DOWN
[ 4.491236] PD DISP0 index2 DOWN
[ 4.501467] tegradc 15210000.nvdisplay: unblank
[ 4.501480] PD DISP0 index2 UP
[ 4.502476] PD DISP1 index3 UP
[ 4.502569] PD DISP2 index4 UP
[ 4.504123] Parent Clock set for DC plld2
[ 4.508767] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 4.531356] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.531433] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.531502] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.531571] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.531638] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.531703] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.531770] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.531839] tegra-snd-t1
