Hi Team,
I am trying access the serial console of Tegra A processor in NVDIA PX2-P2379 board over ttyUSB2. After bootup the board, dmesg logs are stuck and further logs are not displayed in serial console. So, I am unable to access the file system of PX2 board. I am trying to bootup the board with the inbuild firmware only. Please help me to resolve this issue.
For more details, see the below serial console logs,
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB2, 18:00:59
Press CTRL-A Z for help on special keys
I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-E-00.00-embedded-0829dade)
I> Default Heap @ [0xd486400 - 0xd488400]
I> DMA Heap @ [0x84a00000 - 0x85300000]
W> KEK fuse not blown, Skipping RPMB provisioning
I> bit @ 0xd480000
I> BR-BCT relocated to 0xf7f20000
I> Boot-device: QSPI
I> Qspi using bpmp-dma
I> Qspi clock source : pllp
I> Qspi initialized successfully
I> Found 36 partitions in 00030000 device
I> Loading partition bpmp-fw at 0xebe00000
I> Reading two headers - addr:0xebe00000 blocks:1
I> Addr: 0xebe00000, start-block: 17408, num_blocks: 1
I> Binary(16) of size 527504 is loaded @ 0xebe00000
I> Loading partition bpmp-fw-dtb at 0xebff0000
I> Reading two headers - addr:0xebff0000 blocks:1
I> Addr: 0xebff0000, start-block: 20992, num_blocks: 1
I> Binary(17) of size 67376 is loaded @ 0xebfef600
I> BPMP-FW load address = 0xebe00000
I> BPMP-FW DTB load address = 0x501ef600
I> Loading SCE-FW …
I> Loading partition sce-fw at 0xebc00000
I> Reading two headers - addr:0xebc00000 blocks:1
I> Addr: 0xebc00000, start-block: 22016, num_blocks: 1
I> Binary(12) of size 72448 is loaded @ 0xebc00000
I> Init SCE
I> Loading APE-FW …
I> Loading partition adsp-fw at 0xeb800000
I> Reading two headers - addr:0xeb800000 blocks:1
I> Addr: 0xeb800000, start-block: 23040, num_blocks: 1
I> Binary(11) of size 100000 is loaded @ 0xeb800000
I> Copy BTCM section
I> Loading partition cpu-bootloader at 0x96000000
I> Reading two headers - addr:0x96000000 blocks:1
I> Addr: 0x96000000, start-block: 31232, num_blocks: 1
I> Binary(13) of size 139120 is loaded @ 0x96000000
I> MB2-params(VA) @ 0xf7f00000
I> CPUBL-params(VA) @ 0xf7f00000
I> CPUBL-params(PA) @ 0xf7f00000
I> CPU-BL loaded @ PA 0x96000000
I> Loading TOS …
I> Loading partition secure-os at 0x84a01800
I> Reading two headers - addr:0x84a01800 blocks:1
I> Addr: 0x84a01800, start-block: 32256, num_blocks: 1
I> Binary(14) of size 1181232 is loaded @ 0x84a01800
I> TOS boot-params @ 0x84800000
I> TOS params prepared
I> Loading EKS …
I> Loading partition eks at 0x85001a00
I> Reading two headers - addr:0x85001a00 blocks:1
I> Addr: 0x85001a00, start-block: 40448, num_blocks: 1
I> Binary(15) of size 1344 is loaded @ 0x85001a00
I> EKS (length: 0x5000) @ 0x85001a00
I> Copied encrypted keys
I> Copying Monitor (length: 0xe270) from 0x84a01a00 to 0x40000000
I> Erasing Monitor @ 0x84a01a00
I> Unhalting SCE
I> Primary Memory Start:80000000 Size:6a800000
I> Extended Memory Start:100000000 Size:180000000
I> Waypoint2-ACK: 0x5200acdc
I> MB2(TBoot-BPMP) done
I> No golden regs to dumpNOTICE: BL31: v1.2(release):30aa19d
NOTICE: BL31: Built : 12:10:23, Jul 20 2017
����mem_cache_init : bsize [0x10] num_elements [126]
mem_cache_init : element_size_log2 [16] bitmap [0x801810030] area_start [0x801810040]
mem_cache_init: addr_aligned [0x801820000] cache_size [0x7e0000] diff [0x0000ffc0]
579361|HV/c0: Start…
606535|HV/c0: WARNING: Boot time longer than 25ms (27ms).
�Registered governor: pid_thermal_gov
trip_update_worker: Failed to get current temperature for zone 1
�MMFLAGS=1
Starting RM server
Done…
�[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-rt49-tegra (buildbrain@mobile-u64-366) (gcc version 4.9.2 (GCC) ) #1 SMP PREEMPT RT Tue Jul 25 09
:26:02 PDT 2017
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3110000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node generic_carveout, compatible id nvidia,generic_carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 256 MiB at 0x00000000efc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 18 pages/cpu @ffffffc1dd203000 s33536 r8192 d32000 u73728
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1721664
[ 0.000000] Kernel command line: root=/dev/mmcblk0p3 earlycon=uart8250,mmio32,0x03110000 console=ttyS0,115200n8 no_console_suspend
=1 tegra_keep_boot_clocks cma=268435456 tegraid=18.1.2.0.0 ratchet_status=0x0 uid=1642d98421c0000001fe0200 earlycon=uart8250,mmio32,
0x03110000 bl_prof_dataptr=65536@0x25e6a0000
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 6551948K/6995968K available (11876K kernel code, 1845K rwdata, 5452K rodata, 1180K init, 2923K bss, 181876K re
served, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9750000 ( 119 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1dd400000 ( 7636 MB)
[ 0.000000] .init : 0xffffffc00116d000 - 0xffffffc001294000 ( 1180 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc00116d000 ( 17332 KB)
[ 0.000000] .data : 0xffffffc0012a9000 - 0xffffffc0014765d0 ( 1846 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000196] Console: colour dummy device 80x25
[ 0.347593] kmemleak: Kernel memory leak detector disabled
[ 0.347599] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.347601] pid_max: default: 32768 minimum: 301
[ 0.347635] Security Framework initialized
[ 0.347638] SELinux: Initializing.
[ 0.347697] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.347699] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.348004] Initializing cgroup subsys io
[ 0.348009] Initializing cgroup subsys memory
[ 0.348026] Initializing cgroup subsys devices
[ 0.348029] Initializing cgroup subsys freezer
[ 0.348032] Initializing cgroup subsys pids
[ 0.348036] Initializing cgroup subsys debug
[ 0.348162] CPU0 ipc=752
[ 0.418022] CPU1 ipc=1024
[ 0.420633] CPU2 ipc=1024
[ 0.423245] CPU3 ipc=752
[ 0.425689] CPU4 ipc=752
[ 0.428296] CPU5 ipc=752
[ 0.430761] ASID allocator initialised with 65536 entries
[ 0.466680] tegra-id: chipid=21817.
[ 0.466914] tegra-id: opt_subrevision=1.
[ 0.470718] Tegra Revision: A02p SKU: 0x90 CPU Process: 0 SoC Process: 0
[ 0.477743] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvid
ia/platform/t18x/vcm/kernel-dts/tegra186-vcm31-p2379-0000-c01-00-base-a-vm.dts
[ 0.496045] DTB Build time: Jul 25 2017 16:20:20
[ 0.520986] CPU1: Booted secondary processor [4e0f0030]
[ 0.536920] CPU2: Booted secondary processor [4e0f0030]
[ 0.552822] CPU3: Booted secondary processor [411fd073]
[ 0.568848] CPU4: Booted secondary processor [411fd073]
[ 0.584884] CPU5: Booted secondary processor [411fd073]
[ 0.584953] Brought up 6 CPUs
[ 0.610750] SMP: Total of 6 processors activated.
[ 0.615452] CPU: All CPU(s) started at EL1
[ 0.620153] devtmpfs: initialized
[ 0.632028] Initilizing CustomIPI irq domain
[ 0.633156] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.644990] pinctrl core: initialized pinctrl subsystem
[ 0.648207] regulator-dummy: no parameters
[ 0.652070] Initializing plugin-manager
[ 0.655941] Plugin module not found
[ 0.659523] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.666775] node /plugin-manager/board-soc-prod-a02-fragment match with chip-id A02P
[ 0.674601] Adding domain adsp-pd to PM domain ape-pd
[ 0.680335] tegra_hv: adding ivc0: rx_base=ffffff8000080000 tx_base = ffffff8000088000 size=8000 irq = 5 (320)
[ 0.689430] tegra_hv: added ivc0
[ 0.692595] tegra_hv: adding ivc1: rx_base=ffffff8000090000 tx_base = ffffff8000098000 size=8000 irq = 6 (321)
[ 0.702661] tegra_hv: added ivc1
[ 0.705828] tegra_hv: adding ivc2: rx_base=ffffff80000a0000 tx_base = ffffff80000a8000 size=8000 irq = 7 (322)
[ 0.715895] tegra_hv: added ivc2
[ 0.719057] tegra_hv: adding ivc3: rx_base=ffffff80000b0000 tx_base = ffffff80000b8000 size=8000 irq = 8 (323)
[ 0.729127] tegra_hv: added ivc3
[ 0.732289] tegra_hv: adding ivc4: rx_base=ffffff80000c0000 tx_base = ffffff80000c8000 size=8000 irq = 9 (324)
[ 0.742360] tegra_hv: added ivc4
[ 0.745524] tegra_hv: adding ivc5: rx_base=ffffff80000d0000 tx_base = ffffff80000d8000 size=8000 irq = 10 (325)
[ 0.755598] tegra_hv: added ivc5
[ 0.758925] tegra_hv: adding ivc6: rx_base=ffffff80000e0000 tx_base = ffffff80000e8000 size=8000 irq = 11 (326)
[ 0.769000] tegra_hv: added ivc6
[ 0.772161] tegra_hv: adding ivc7: rx_base=ffffff80000f0000 tx_base = ffffff80000f8000 size=8000 irq = 12 (327)
[ 0.782238] tegra_hv: added ivc7
[ 0.785564] tegra_hv: adding ivc8: rx_base=ffffff8000100000 tx_base = ffffff8000108000 size=8000 irq = 13 (328)
[ 0.795641] tegra_hv: added ivc8
[ 0.798802] tegra_hv: adding ivc9: rx_base=ffffff8000110000 tx_base = ffffff8000118000 size=8000 irq = 14 (329)
[ 0.808879] tegra_hv: added ivc9
[ 0.812205] tegra_hv: adding ivc10: rx_base=ffffff8000120000 tx_base = ffffff8000128000 size=8000 irq = 15 (330)
[ 0.822286] tegra_hv: added ivc10
[ 0.825616] tegra_hv: adding ivc11: rx_base=ffffff8000130000 tx_base = ffffff8000138000 size=8000 irq = 16 (331)
[ 0.835863] tegra_hv: added ivc11
[ 0.839192] tegra_hv: adding ivc12: rx_base=ffffff8000140000 tx_base = ffffff8000148000 size=8000 irq = 17 (332)
[ 0.849274] tegra_hv: added ivc12
[ 0.852603] tegra_hv: adding ivc13: rx_base=ffffff8000150000 tx_base = ffffff8000158000 size=8000 irq = 18 (333)
[ 0.862851] tegra_hv: added ivc13
[ 0.866180] tegra_hv: adding ivc28: rx_base=ffffff8000180000 tx_base = ffffff8000188000 size=8000 irq = 19 (334)
[ 0.876262] tegra_hv: added ivc28
[ 0.879593] tegra_hv: adding ivc29: rx_base=ffffff8000190000 tx_base = ffffff8000198000 size=8000 irq = 20 (335)
[ 0.889838] tegra_hv: added ivc29
[ 0.893180] tegra_hv: adding ivc30: rx_base=ffffff80001a0000 tx_base = ffffff80001a8000 size=8000 irq = 21 (336)
[ 0.903251] tegra_hv: added ivc30
[ 0.906581] tegra_hv: adding ivc31: rx_base=ffffff80001b0000 tx_base = ffffff80001b8000 size=8000 irq = 22 (337)
[ 0.916826] tegra_hv: added ivc31
[ 0.920161] tegra_hv: adding ivc32: rx_base=ffffff8000060000 tx_base = ffffff8000068000 size=8000 irq = 23 (338)
[ 0.930239] tegra_hv: added ivc32
[ 0.933569] tegra_hv: adding ivc33: rx_base=ffffff8000200000 tx_base = ffffff8000218000 size=18000 irq = 24 (339)
[ 0.943820] tegra_hv: added ivc33
[ 0.947152] tegra_hv: adding ivc56: rx_base=ffffff80001c0000 tx_base = ffffff80001c8000 size=8000 irq = 25 (340)
[ 0.957395] tegra_hv: added ivc56
[ 0.960726] tegra_hv: adding ivc76: rx_base=ffffff8000240000 tx_base = ffffff8000250000 size=10000 irq = 26 (341)
[ 0.970977] tegra_hv: added ivc76
[ 0.974307] tegra_hv: adding ivc100: rx_base=ffffff80001d0000 tx_base = ffffff80001d8000 size=8000 irq = 27 (342)
[ 0.984558] tegra_hv: added ivc100
[ 0.987893] tegra_hv: adding ivc102: rx_base=ffffff8000160000 tx_base = ffffff8000168000 size=8000 irq = 28 (343)
[ 0.998144] tegra_hv: added ivc102
[ 1.001622] tegra_hv: added mempool 0: ipa=25d5f0000 size=400000 peer=2
[ 1.008238] tegra_hv: added mempool 1: ipa=25d9f0000 size=800000 peer=2
[ 1.014855] tegra_hv: added mempool 2: ipa=25e1f0000 size=10000 peer=2
[ 1.021302] tegra_hv: added mempool 3: ipa=25e200000 size=400000 peer=1
[ 1.027918] tegra_hv: added mempool 5: ipa=25e600000 size=40000 peer=5
[ 1.034529] tegra_hv: initialized
[ 1.038055] NET: Registered protocol family 16
[ 1.043633] console [pstore-1] enabled
[ 1.045950] pstore: Registered ramoops as persistent store backend
[ 1.052210] ramoops: attached 0x200000@0xffc00000, ecc: 0/0
[ 1.069457] cpuidle: using governor ladder
[ 1.084629] cpuidle: using governor menu
[ 1.091350] bpmp: mail init ok
[ 1.092349] vdso: 2 pages (1 code @ ffffffc0012b1000, 1 data @ ffffffc0012b0000)
[ 1.098564] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 1.107436] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 1.116422] tegra_powergate_init: DONE
[ 1.117360] DTS File Name: /dvs/git/dirty/git-master_modular/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvid
[ 1.135814] DTB Build time: Jul 25 2017 16:20:20
[ 1.142221] Tegra reboot handler registered.
[ 1.145388] Registering Tegra186 clocks (this may take a while)…done
[ 1.153258] arm-smmu 12000000.iommu: probing hardware configuration…
[ 1.157825] arm-smmu 12000000.iommu: SMMUv2 with:
[ 1.162531] arm-smmu 12000000.iommu: stage 1 translation
[ 1.167920] arm-smmu 12000000.iommu: stream indexing with 128 indices
[ 1.174399] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 1.184986] arm-smmu 12000000.iommu: 32 context banks (0 stage-2 only)
[ 1.191629] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 1.222353] arm-smmu 12000000.iommu: registered 76 master devices
[ 1.229105] iommu: Adding device 3460000.sdhci to group 0
[ 1.233045] iommu: Adding device 3160000.i2c to group 1
[ 1.236835] iommu: Adding device c240000.i2c to group 2
[ 1.241869] iommu: Adding device 3180000.i2c to group 3
[ 1.247187] iommu: Adding device 3190000.i2c to group 4
[ 1.252442] iommu: Adding device 31b0000.i2c to group 5
[ 1.257604] iommu: Adding device 31c0000.i2c to group 6
[ 1.262761] iommu: Adding device c250000.i2c to group 7
[ 1.268062] iommu: Adding device 31e0000.i2c to group 8
[ 1.274265] iommu: Adding device 3210000.spi to group 9
[ 1.278520] iommu: Adding device 3230000.spi to group 10
[ 1.283973] iommu: Adding device 3110000.serial to group 11
[ 1.290002] iommu: Adding device 2490000.ether_qos to group 12
[ 1.295477] iommu: Adding device b000000.rtcpu to group 13
[ 1.300874] iommu: Adding device smmu_test to group 14
[ 1.305920] mc: mapped MMIO address: 0xffffff8000720000 -> 0x2c10000
[ 1.311877] mc: mapped MMIO address: 0xffffff8000740000 -> 0x2c20000
[ 1.318310] mc: mapped MMIO address: 0xffffff8000760000 -> 0x2c30000
[ 1.324588] mc: mapped MMIO address: 0xffffff80017a0000 -> 0x2c40000
[ 1.331016] mc: mapped MMIO address: 0xffffff80017c0000 -> 0x2c50000
[ 1.337315] mc-err: Set intmask: 0xf3140
[ 1.341760] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 1.347834] Wake76 for irq=199
[ 1.347836] Wake77 for irq=199
[ 1.347838] Wake78 for irq=199
[ 1.347839] Wake79 for irq=199
[ 1.347840] Wake80 for irq=199
[ 1.347842] Wake81 for irq=199
[ 1.347843] Wake82 for irq=199
[ 1.347922] iommu: Adding device 3530000.xhci to group 15
[ 1.374433] iommu: Adding device 3550000.xudc to group 16
[ 1.380013] tegra-pmc c360000.pmc: create /sys/kernel/debug/PMC/boot-chain-type
[ 1.386743] tegra-pmc: ### PMC reset source: Power on reset
[ 1.392312] tegra-pmc: ### PMC reset level: L0
[ 1.396824] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.401872] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 1.409018] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 1.415209] iommu: Adding device 13e10000.host1x to group 17
[ 1.420903] iommu: Adding device 13e10000.host1x:ctx0 to group 18
[ 1.426959] iommu: Adding device 13e10000.host1x:ctx1 to group 19
[ 1.433205] iommu: Adding device 13e10000.host1x:ctx2 to group 20
[ 1.439143] iommu: Adding device 13e10000.host1x:ctx3 to group 21
[ 1.445231] iommu: Adding device 13e10000.host1x:ctx4 to group 22
[ 1.451419] iommu: Adding device 13e10000.host1x:ctx5 to group 23
[ 1.457494] iommu: Adding device 13e10000.host1x:ctx6 to group 24
[ 1.463560] iommu: Adding device 13e10000.host1x:ctx7 to group 25
[ 1.469724] iommu: Adding device 150c0000.nvcsi to group 26
[ 1.477238] tegra-reset 5000000.clock: registered 193 resets.
[ 1.481168] iommu: Adding device 3270000.spi to group 27
[ 1.487542] bpmp d000000.bpmp: Found mempool with id 3
[ 1.491201] bpmp d000000.bpmp: ivm 0x000000025e200000
[ 1.496538] bpmp: ping status is 0
[ 1.499712] bpmp d000000.bpmp: firmware tag is 236a68cf596478aaecc3fb00541997a7
[ 1.507110] bpmp d000000.bpmp: probe ok
[ 1.512839] iommu: Adding device 2600000.dma to group 28
[ 1.516837] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 1.526468] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 1.532496] iommu: Adding device 10003000.pcie-controller to group 29
[ 1.538907] iommu: Adding device c1a0000.aon to group 30
[ 1.543795] sys-3v3: 3300 mV
[ 1.546100] sys-5v0: 5000 mV
[ 1.550886] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 1.551460] iommu: Adding device 13e20000.host1xb to group 31
[ 1.560307] iommu: Adding device 15600000.isp to group 32
[ 1.565586] iommu: Adding device 15340000.vic to group 33
[ 1.570907] iommu: Adding device 154c0000.nvenc to group 34
[ 1.576553] iommu: Adding device 15480000.nvdec to group 35
[ 1.582105] iommu: Adding device 15380000.nvjpg to group 36
[ 1.587651] iommu: Adding device 15500000.tsec to group 37
[ 1.593088] iommu: Adding device 15100000.tsecb to group 38
[ 1.599338] iommu: Adding device vse@15810000 to group 39
[ 1.604096] iommu: Adding device vse@15820000 to group 40
[ 1.609504] iommu: Adding device vse@15830000 to group 41
[ 1.614903] iommu: Adding device vse@15840000 to group 42
[ 1.639177] max929x_i2c_client_init: called
[ 1.640212] vdd-1v1: 1100 mV
[ 1.643119] vdd-1v2: 1200 mV
[ 1.646099] vdd-1v8-ddr: 1800 mV
[ 1.649363] vdd-3v3: 3300 mV
[ 1.652401] spmic-sd4: 1100 mV
[ 1.655468] vdd-1v8-pll: 1800 mV
[ 1.658761] spmic-ldo1: 800 mV
[ 1.661978] vdd-v3v-ao: 3300 mV
[ 1.665187] en-vdd-rtc: 800 mV
[ 1.668263] vdd-1v8-ao: 1800 mV
[ 1.671478] vdd-1v05: 1050 mV
[ 1.674521] spmic-ldo8: 800 mV
[ 1.678191] SCSI subsystem initialized
[ 1.681832] usbcore: registered new interface driver usbfs
[ 1.686795] usbcore: registered new interface driver hub
[ 1.692450] usbcore: registered new device driver usb
[ 1.716690] max929x_i2c_probe: returning 0
[ 1.717588] sn65dsi85_dsi2lvds_panel_create_debugfs: dsi2lvds->debugdir = ffffffc1d3524780
[ 1.725801] sn65dsi85_dsi2lvds_panel_create_debugfs: debugfs_create_file returned ffffffc1d3524870
[ 1.734679] sn65dsi85_i2c_probe: returning with err=0
[ 1.740479] media: Linux media interface: v0.10
[ 1.744283] Linux video capture interface: v2.00
[ 1.749657] pps_core: LinuxPPS API ver. 1 registered
[ 1.753910] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 1.762988] PTP clock support registered
[ 1.767504] trusty trusty: trusty version: Built: 12:11:13 Jul 20 2017
[ 1.773530] trusty trusty: selected api version: 3 (requested 3)
[ 1.780764] tegra_hv_wdt tegra_hv_wdt: id=32 irq=23 peer=3 num=1 size=128
[ 1.780856] tegra_hv_wdt tegra_hv_wdt: ivc channel ready
[ 1.794299] max77620 4-003c: PMIC Version OTP:0x4A and ES:0x1
[ 1.798912] gpiochip_add_data: registered GPIOs 248 to 255 on device: max20024-gpio
[ 1.807858] i2c i2c-4: deserialize_i2c ret -22
[ 1.809545] i2c i2c-4: — message dump for debugging —
[ 1.814942] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.819997] i2c i2c-4: 0d
[ 1.822776] i2c i2c-4: ef
[ 1.825393] i2c i2c-4:
[ 1.827834] max77620 4-003c: Failed to sync masks in d
[ 1.834494] max77620-sd0: at 1125 mV
[ 1.837817] max77620-sd1: at 1200 mV
[ 1.841354] max77620-sd2: at 1800 mV
[ 1.845059] max77620-sd3: at 3300 mV
[ 1.848658] max77620-sd4: at 600 mV
[ 1.851855] max77620-ldo0: at 1800 mV
[ 1.855598] max77620-ldo1: at 800 mV
[ 1.859388] max77620-ldo2: at 3300 mV
[ 1.863492] i2c i2c-4: deserialize_i2c ret -22
[ 1.866766] i2c i2c-4: — message dump for debugging —
[ 1.872148] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.877359] i2c i2c-4: 29
[ 1.880060] i2c i2c-4: f2
[ 1.882679] i2c i2c-4:
[ 1.885120] max77620-pmic max20024-pmic: Regulator 8 mode set failed: -22
[ 1.891908] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo3
[ 1.900723] max77620-ldo3: at 3300 mV
[ 1.905125] max77620-ldo4: at 800 mV
[ 1.909034] i2c i2c-4: deserialize_i2c ret -22
[ 1.912445] i2c i2c-4: — message dump for debugging —
[ 1.917844] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 1.922902] i2c i2c-4: 2d
[ 1.925678] i2c i2c-4: f2
[ 1.928296] i2c i2c-4:
[ 1.930737] max77620-pmic max20024-pmic: Regulator 10 mode set failed: -22
[ 1.937694] max77620-pmic max20024-pmic: driver callback failed to parse DT for regulator ldo5
[ 1.946350] max77620-ldo5: at 3300 mV
[ 1.950655] max77620-ldo6: at 1800 mV
[ 1.954438] max77620-ldo7: at 1000 mV
[ 1.958097] max77620-ldo8: at 800 mV
[ 1.961387] max77620 4-003c: max77620 probe successful
[ 1.967672] vdd-1v8: 1800 mV
[ 1.969361] vdd-rtc: no parameters
[ 1.973038] vdd-usb2-5v: 5000 mV
[ 2.080023] mxm-pwr-gpio-1: 5000 mV
[ 2.185081] mxm-pwr_en: 5000 mV
[ 2.187504] clocksource: Switched to clocksource arch_sys_counter
[ 2.211126] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 2.214572] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 2.219665] Wake76 for irq=199
[ 2.219667] Wake77 for irq=199
[ 2.219667] Wake78 for irq=199
[ 2.219668] Wake79 for irq=199
[ 2.219668] Wake80 for irq=199
[ 2.219669] Wake81 for irq=199
[ 2.219670] Wake82 for irq=199
[ 2.219861] vdd-1v8: supplied by vdd-1v8-ddr
[ 2.220513] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 2.220597] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 2.220649] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 2.220691] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 2.220775] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 2.220954] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 2.221041] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tj-therm
[ 2.221123] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type Tegra_tx
[ 2.221217] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type Tegra_rx
[ 2.221502] isomgr_init(): iso emc max clk=1600000KHz
[ 2.221504] isomgr_init(): max_iso_bw=23040000KB
[ 2.221678] NET: Registered protocol family 2
[ 2.222021] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.222223] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 2.223181] TCP: Hash tables configured (established 65536 bind 65536)
[ 2.223232] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 2.223379] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 2.223740] NET: Registered protocol family 1
[ 2.224011] RPC: Registered named UNIX socket transport module.
[ 2.224012] RPC: Registered udp transport module.
[ 2.224014] RPC: Registered tcp transport module.
[ 2.224015] RPC: Registered tcp NFSv4.1 backchannel tr�� 3984709|HV/c4: padctl: Ignoring write by Guest 0 to address 2430008 with
val 401 actual value 1!
�ansport module.
[ 2.224151] Unpacking initramfs…
[ 2.232364] Freeing initrd memory: 4628K (ffffffc003420000 - ffffffc0038a5000)
[ 2.243530] host1x 13e10000.host1x: initialized
[ 2.251182] genirq: Flags mismatch irq 65. 00002000 (host_status) vs. 00002000 (host_status)
[ 2.251533] host1x 13e20000.host1xb: initialized
[ 2.251994] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.253766] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 2.253864] audit: initializing netlink subsys (disabled)
[ 2.253886] audit: type=2000 audit(2.244:1): initialized
[ 2.258124] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.258667] NFS: Registering the id_resolver key type
[ 2.258681] Key type id_resolver registered
[ 2.258687] Key type id_legacy registered
[ 2.258694] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 2.258719] ntfs: driver 2.1.32 [Flags: R/O].
[ 2.258846] fuse init (API version 7.23)
[ 2.261158] NET: Registered protocol family 38
[ 2.261176] io scheduler noop registered
[ 2.261180] io scheduler deadline registered
[ 2.261262] io scheduler cfq registered (default)
[ 2.261712] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 2.262564] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 2.264684] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 2.367577] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 2.369346] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 2.369639] tsec 15500000.tsec: initialized
[ 2.375581] tsec 15100000.tsecb: initialized
[ 2.377803] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 2.378639] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 2.379434] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 2.380383] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 2.381185] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 2.381988] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 2.382802] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 2.383629] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 2.385658] vhost-client 15340000.vic: initialized
[ 2.386450] vhost-client 154c0000.nvenc: initialized
[ 2.389841] vhost-client 15480000.nvdec: initialized
[ 2.390721] vhost-client 15380000.nvjpg: initialized
[ 2.391116] scrncapt: init (heads:3 wins:6 planes:4)
[ 2.391236] ds90ub947_probe: entered
[ 2.391510] DC OR NODE connected to /host1x/sor
[ 2.391605] tegradc 15200000.nvdisplay: DT parsed successfully
[ 2.391636] tegradc 15200000.nvdisplay: Display dc.ffffff8001f60000 registered with id=0
[ 2.396312] ds90ub947-q1 6-000c: initializing registers failed
[ 2.396317] ds90ub947_probe: returning -5
[ 2.396957] ds90ub947-q1: probe of 6-000c failed with error -5
[ 2.397628] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 2.398058] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=2090250, vi_iso_bw=2577095, max_bw=2577095
[ 2.401787] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 2.401789] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 2.401790] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 2.401826] tegradc 15200000.nvdisplay: vblank syncpt # 7 for dc 0
[ 2.401830] tegradc 15200000.nvdisplay: vpulse3 syncpt # 8 for dc 0
[ 2.401911] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 2.402760] kfuse 3830000.kfuse: initialized
[ 2.404445] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.407532] tegradc 15200000.nvdisplay: probed
[ 2.407716] console [ttyS0] disabled
[ 2.593900] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.593907] pci_bus 0000:00: root bus resource [mem 0x50100000-0x57ffffff]
[ 2.593912] pci_bus 0000:00: root bus resource [mem 0x58000000-0x7fffffff pref]
[ 2.593918] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.593922] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 2.594196] iommu: Adding device 0000:00:01.0 to group 43
[ 2.594366] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.594795] iommu: Adding device 0000:01:00.0 to group 44
[ 2.599566] pci 0000:01:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.600174] iommu: Adding device 0000:02:02.0 to group 45
[ 2.600748] iommu: Adding device 0000:02:0a.0 to group 46
[ 2.601450] pci 0000:02:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.601461] pci 0000:02:0a.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.602020] iommu: Adding device 0000:03:00.0 to group 47
[ 2.608062] iommu: Adding device 0000:04:00.0 to group 48
[ 2.615799] pci 0000:00:01.0: BAR 9: assigned [mem 0x58000000-0x77ffffff 64bit pref]
[ 2.615805] pci 0000:00:01.0: BAR 8: assigned [mem 0x50200000-0x51ffffff]
[ 2.615810] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 2.615819] pci 0000:01:00.0: BAR 9: assigned [mem 0x58000000-0x77ffffff 64bit pref]
[ 2.615824] pci 0000:01:00.0: BAR 8: assigned [mem 0x50400000-0x51ffffff]
[ 2.615829] pci 0000:01:00.0: BAR 0: assigned [mem 0x50200000-0x5023ffff]
[ 2.615837] pci 0000:01:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 2.615846] pci 0000:02:0a.0: BAR 9: assigned [mem 0x58000000-0x6fffffff 64bit pref]
[ 2.615851] pci 0000:02:0a.0: BAR 8: assigned [mem 0x50800000-0x51ffffff]
[ 2.615855] pci 0000:02:02.0: BAR 8: assigned [mem 0x50400000-0x504fffff]
[ 2.615861] pci 0000:02:02.0: BAR 9: assigned [mem 0x70000000-0x702fffff 64bit pref]
[ 2.615866] pci 0000:02:0a.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 2.615874] pci 0000:03:00.0: BAR 0: assigned [mem 0x70000000-0x701fffff 64bit pref]
[ 2.615891] pci 0000:03:00.0: BAR 6: assigned [mem 0x50400000-0x5047ffff pref]
[ 2.615897] pci 0000:03:00.0: BAR 4: assigned [mem 0x70200000-0x70203fff 64bit pref]
[ 2.615914] pci 0000:02:02.0: PCI bridge to [bus 03]
[ 2.615922] pci 0000:02:02.0: bridge window [mem 0x50400000-0x504fffff]
[ 2.615928] pci 0000:02:02.0: bridge window [mem 0x70000000-0x702fffff 64bit pref]
[ 2.615941] pci 0000:04:00.0: BAR 1: assigned [mem 0x60000000-0x6fffffff 64bit pref]
[ 2.615956] pci 0000:04:00.0: BAR 3: assigned [mem 0x58000000-0x59ffffff 64bit pref]
[ 2.615970] pci 0000:04:00.0: BAR 0: assigned [mem 0x51000000-0x51ffffff]
[ 2.615979] pci 0000:04:00.0: BAR 6: assigned [mem 0x50800000-0x5087ffff pref]
[ 2.615984] pci 0000:04:00.0: BAR 5: assigned [io 0x1000-0x107f]
[ 2.615991] pci 0000:02:0a.0: PCI bridge to [bus 04]
[ 2.615996] pci 0000:02:0a.0: bridge window [io 0x1000-0x1fff]
[ 2.616003] pci 0000:02:0a.0: bridge window [mem 0x50800000-0x51ffffff]
[ 2.616009] pci 0000:02:0a.0: bridge window [mem 0x58000000-0x6fffffff 64bit pref]
[ 2.616017] pci 0000:01:00.0: PCI bridge to [bus 02-04]
[ 2.616023] pci 0000:01:00.0: bridge window [io 0x1000-0x1fff]
[ 2.616030] pci 0000:01:00.0: bridge window [mem 0x50400000-0x51ffffff]
[ 2.616036] pci 0000:01:00.0: bridge window [mem 0x58000000-0x77ffffff 64bit pref]
[ 2.616044] pci 0000:00:01.0: PCI bridge to [bus 01-04]
[ 2.616048] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 2.616054] pci 0000:00:01.0: bridge window [mem 0x50200000-0x51ffffff]
[ 2.616060] pci 0000:00:01.0: bridge window [mem 0x58000000-0x77ffffff 64bit pref]
[ 2.616353] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 2.616358] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.616361] pci 0000:02:02.0: Signaling PME through PCIe PME interrupt
[ 2.616364] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 2.616367] pci 0000:02:0a.0: Signaling PME through PCIe PME interrupt
[ 2.616370] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 2.617305] tegra-pcie 10003000.pcie-controller: speed change : Gen-1 -> Gen-2
[ 3.137348] tegradc 15200000.nvdisplay: fb registered
[ 3.137406] 3110000.serial: ttyS0 at MMIO 0x3110000 (irq = 44, base_baud = 25500000) is a Tegra
[ 3.137555] tegra-carveouts tegra-carveouts: generic-0 :dma coherent mem declare 0x00000000a7300000,822083584
[ 3.137557] tegra-carveouts tegra-carveouts: assigned reserved memory node generic_carveout
[ 3.137568] nvmap_page_pool_init: Total RAM pages: 1704680
[ 3.137569] nvmap_page_pool_init: nvmap page pool size: 213085 pages (832 MB)
[ 3.137785] nvmap_background_zero_thread: PP zeroing thread starting.
[ 3.138118] misc nvmap: created heap generic-0 base 0x00000000a7300000 size (802816KiB)
[ 3.196439] console [ttyS0] enabled
[ 3.197123] gpio tegra-gpio wake19 for gpio=120(P:1)
[ 3.197317] DC OR NODE connected to /host1x/dsi
[ 3.197463] tegradc 15210000.nvdisplay: DT parsed successfully
[ 3.197485] tegradc 15210000.nvdisplay: Display dc.ffffff8002060000 registered with id=1
[ 3.197626] tegradc 15210000.nvdisplay: vblank syncpt # 9 for dc 1
[ 3.197630] tegradc 15210000.nvdisplay: vpulse3 syncpt # 11 for dc 1
[ 3.198808] tegradc 15210000.nvdisplay: DSI: HS clock rate is 445500
[ 3.200306] tegradc 15210000.nvdisplay: probed
[ 3.296885] bootconsole [uart0] disabled
[ 3.304718] tegradc 15210000.nvdisplay: fb registered
[ 3.304941] PD DISP0 index2 UP
[ 3.305983] PD DISP1 index3 UP
[ 3.306376] PD DISP2 index4 UP
[ 3.307378] rate get on hub 307200000
[ 3.310599] dc clk 145500000
[ 3.310600] rate get on compclk 145500000
[ 3.311544] tegradc 15210000.nvdisplay: Link compression not supported by the panel
[ 3.316319] rate get on compclk 40322555
[ 3.326044] rate get on compclk 40322555
[ 3.347708] rate get on compclk 40454456
[ 3.348048] nvgpu 0000:04:00.0: enabling device (0000 -> 0003)
[ 3.356906] zram: Added device: zram0
[ 3.359240] rate get on compclk 148333007
[ 3.359457] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 3.359473] nct1008_nct72 0-004c: starting parse dt
[ 3.359536] nct1008_nct72 0-004c: success parsing dt
[ 3.359727] nct1008_nct72 0-004c: success in enabling nct72 VDD rail
[ 3.417303] nct72: Enabled overheat logging at 102.00C
[ 3.419824] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 3.426333] THERMAL EST: found 2 subdevs
[ 3.428658] THERMAL EST num_resources: 0
[ 3.432660] [THERMAL EST subdev 0]
[ 3.435970] [THERMAL EST subdev 1]
[ 3.439621] thermal thermal_zone9: Registering thermal zone thermal_zone9 for type thermal-fan-est
[ 3.448338] THERMAL EST: thz register success.
[ 3.452939] THERMAL EST: end of probe, return err: 0
[ 3.457948] tegra_profiler: Branch: Dev
[ 3.461567] tegra_profiler: Version: 1.112
[ 3.465739] tegra_profiler: Samples version: 39
[ 3.470266] tegra_profiler: IO version: 22
[ 3.474277] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.478632] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.485597] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.489948] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 3.490740] rate get on compclk 40322555
[ 3.501087] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 3.505439] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
[ 3.512411] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.516762] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.523730] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.528081] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.535047] armv8_pmu: imp: 0x41, idcode: 0x1
[ 3.538225] rate get on compclk 40454456
[ 3.542152] rate get on compclk 148333007
[ 3.547577] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 3.554706] tegra_profiler: auth: init
[ 3.559895] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.565055] tun: Universal TUN/TAP device driver, 1.6
[ 3.569526] tun: © 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.576076] e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
[ 3.580150] sn65dsi85_dsi2lvds: PLL not locked
[ 3.586062] e1000e: Copyright© 1999 - 2015 Intel Corporation.
[ 3.592141] igb: Intel® Gigabit Ethernet Network Driver - version 5.3.0-k
[ 3.598945] igb: Copyright © 2007-2014 Intel Corporation.
[ 3.603560] tegradc 15210000.nvdisplay: Window 2 assigned to head 1
[ 3.603641] tegradc 15210000.nvdisplay: Window 3 assigned to head 1
[ 3.608976] DC OR NODE connected to /host1x/sor1
[ 3.609068] tegradc 15220000.nvdisplay: DT parsed successfully
[ 3.609084] tegradc 15220000.nvdisplay: Display dc.ffffff8002240000 registered with id=2
[ 3.609221] tegradc 15220000.nvdisplay: vblank syncpt # 13 for dc 2
[ 3.609225] tegradc 15220000.nvdisplay: vpulse3 syncpt # 14 for dc 2
[ 3.612279] tegradc 15220000.nvdisplay: probed
[ 3.652611] tegradc 15220000.nvdisplay: fb registered
[ 3.653673] PPP generic driver version 2.4.2
[ 3.653850] PPP BSD Compression module registered
[ 3.653860] PPP Deflate Compression module registered
[ 3.654009] PPP MPPE Compression module registered
[ 3.654024] NET: Registered protocol family 24
[ 3.654260] usbcore: registered new interface driver asix
[ 3.654493] usbcore: registered new interface driver ax88179_178a
[ 3.654639] usbcore: registered new interface driver cdc_ether
[ 3.654684] usbcore: registered new interface driver smsc95xx
[ 3.654832] usbcore: registered new interface driver net1080
[ 3.654966] usbcore: registered new interface driver cdc_subset
[ 3.654994] usbcore: registered new interface driver zaurus
[ 3.655179] usbcore: registered new interface driver cdc_ncm
[ 3.656402] Wake76 for irq=199
[ 3.656405] Wake77 for irq=199
[ 3.656406] Wake78 for irq=199
[ 3.656471] Wake79 for irq=199
[ 3.656525] Wake80 for irq=199
[ 3.656528] Wake81 for irq=199
[ 3.656529] Wake82 for irq=199
[ 3.656807] tegra-xotg xotg: usb2 phy is not available yet
[ 3.657685] usbcore: registered new interface driver usb-storage
[ 3.659349] eqos 2490000.ether_qos: tx_tristate_enable DT property missing
[ 3.659395] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b ac 0 4c
[ 3.659976] libphy: dwc_phy: probed
[ 3.662241] tegra-xudc-new 3550000.xudc: usb3 phy is not available yet
[ 3.663122] mousedev: PS/2 mouse device common for all mice
[ 3.663229] usbcore: registered new interface driver xpad
[ 3.664913] i2c i2c-4: deserialize_i2c ret -22
[ 3.664918] i2c i2c-4: — message dump for debugging —
[ 3.664921] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 3.664943] i2c i2c-4: 0d
[ 3.664946] i2c i2c-4: e7
[ 3.664948] i2c i2c-4:
[ 3.664953] max77620 4-003c: Failed to sync masks in d
[ 3.791879] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.792541] i2c /dev entries driver
[ 3.793472] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 3.793606] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 3.793662] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 3.793840] isc-pwm isc_pwm_gen: isc_pwm_probeing…
[ 3.793888] isc-pwm isc_pwm_gen: isc_pwm_probe success to get PWM
[ 3.793956] usbcore: registered new interface driver uvcvideo
[ 3.793957] USB Video Class driver (1.1.1)
[ 3.794309] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 3.794519] tegra-tj-thermal tegra-tj: found thermal zone Tdiode_tegra + offset 0
[ 3.796043] FAN dev name: pwm-fan
[ 3.796075] FAN:gpio request success.
[ 3.796111] pwm_fan_driver pwm-fan: cap state:5, cap pwm:256
[ 3.796220] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.796392] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.796432] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.796442] pwm_fan_driver pwm-fan: tach period: 400
[ 3.797116] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=1400, rru=20, rrd=20, state:2
[ 3.797118] pwm_fan_driver pwm-fan: index 1: pwm=102, rpm=2300, rru=20, rrd=20, state:2
[ 3.797120] pwm_fan_driver pwm-fan: index 2: pwm=154, rpm=3700, rru=10, rrd=10, state:2
[ 3.797122] pwm_fan_driver pwm-fan: index 3: pwm=179, rpm=4500, rru=10, rrd=10, state:2
[ 3.797124] pwm_fan_driver pwm-fan: index 4: pwm=205, rpm=4900, rru=10, rrd=10, state:3
[ 3.797126] pwm_fan_driver pwm-fan: index 5: pwm=256, rpm=4900, rru=1, rrd=1, state:3
[ 3.797128] pwm_fan_driver pwm-fan: index 6: pwm=256, rpm=4900, rru=1, rrd=1, state:3
[ 3.797130] pwm_fan_driver pwm-fan: index 7: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 3.797132] pwm_fan_driver pwm-fan: index 8: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 3.797134] pwm_fan_driver pwm-fan: index 9: pwm=256, rpm=4900, rru=1, rrd=1, state:4
[ 3.797799] trusty-virtio trusty:virtio: initializing
[ 3.797898] trusty_ipc virtio0: vring0: va(pa) ffffffc1d0474000(0) qsz 32 notifyid 1
[ 3.797906] trusty_ipc virtio0: vring1: va(pa) ffffffc059384000(0) qsz 32 notifyid 2
[ 3.798016] trusty-virtio trusty:virtio: initializing done
[ 3.798125] trusty_ipc virtio0: is online
[ 3.798460] i2c i2c-4: deserialize_i2c ret -22
[ 3.798463] i2c i2c-4: — message dump for debugging —
[ 3.798465] i2c i2c-4: addr 0x3c flags 0x0 len 2 data:
[ 3.798466] i2c i2c-4: 42
[ 3.798468] i2c i2c-4: 43
[ 3.798469] i2c i2c-4:
[ 3.798471] max77620-watchdog max20024-watchdog: Failed to set WD_RST_WK: -22
[ 3.798476] max77620-watchdog: probe of max20024-watchdog failed with error -22
[ 3.798631] softdog-platform soft_watchdog: Software Watchdog Timer: initialized
[ 3.798762] device-mapper: uevent: version 1.0.3
[ 3.798924] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.799178] sdhci: Secure Digital Host Controller Interface driver
[ 3.799179] sdhci: Copyright© Pierre Ossman
[ 3.799181] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.799352] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.800315] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.801216] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.803070] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.803218] hidraw: raw HID events driver © Jiri Kosina
[ 3.804520] usbcore: registered new interface driver usbhid
[ 3.804521] usbhid: USB HID core driver
[ 3.804716] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 3.804944] ozwpan ozwpan: Ozmo Devices WPAN
[ 3.804948] ozwpan ozwpan: new USB bus registered, assigned bus number 1
[ 3.805024] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.805027] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.805029] usb usb1: Product: Ozmo Devices WPAN
[ 3.805030] usb usb1: Manufacturer: Linux 4.4.38-rt49-tegra Ozmo WPAN
[ 3.805032] usb usb1: SerialNumber: ozwpan
[ 3.805276] hub 1-0:1.0: USB hub found
[ 3.805288] hub 1-0:1.0: 4 ports detected
[ 3.805995] Denver: backdoor interface is NOT available.
[ 3.812429] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.812506] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.812883] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.812915] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.812950] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.812976] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.813003] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.813039] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.813066] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.813225] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (56)
[ 3.813226] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.815819] sdhci-tegra 3460000.sdhci: No vqmmc regulator found
[ 3.815821] sdhci-tegra 3460000.sdhci: No vmmc regulator found
[ 3.816175] tegra186-cam-rtcpu b000000.rtcpu: booting sce with Camera RTCPU FW
[ 3.816946] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 3.819566] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=3 sha1=b0f3761afb5af07ef39b52cf5e8e5a913ee161d9
[ 3.824755] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.825862] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.825947] camchar: rtcpu character device driver loaded
[ 3.829768] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.829920] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.829989] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.830073] tegra_mce_write_uncore_mca: failed (ret=-1)
[ 3.830095] tegra_mce_write_uncore_mca: failed (ret=-1)
[ 3.830207] **** A57 ECC: Enabled
[ 3.830209] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.830466] tegra_mce_write_uncore_perfmon: failed (ret=-1)
[ 3.830477] perfmon status error: 4294967295
[ 3.830482] ARI CMD:1 REG:6 CTR:0 Data:2
[ 3.830500] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.831110] tegra_hv_vse vse@15810000: Virtual SE Stream ID: 72
[ 3.831112] tegra_hv_vse vse@15810000: Virtual SE channel number: 76
[ 3.831608] tegra_hv_vse vse@15820000: Virtual SE Stream ID: 72
[ 3.832210] tegra_hv_vse vse@15830000: Virtual SE Stream ID: 72
[ 3.832640] tegra_hv_vse vse@15840000: Virtual SE Stream ID: 72
[ 3.840376] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.847542] tegra18x-cpufreq: Using hv path
[ 3.847599] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.847686] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.847825] qspi_mtd spi6.0: s25fs512s SSG 8 0 1000 4000000
[ 3.847827] qspi_mtd spi6.0: s25fs512s (65536 Kbytes)
[ 3.847830] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00040000 (256KiB) .numeraseregions = 0
[ 3.847839] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.847953] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848043] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848200] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848285] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848364] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848462] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848585] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848680] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848823] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848903] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.848986] cpufreq: platform driver Initialization: pass
[ 3.849030] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.849082] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.849115] tegra186-qspi 3270000.spi: failed to apply prod for qspi
[ 3.849147] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.849266] 1 ofpart partitions found on MTD device spi6.0
[ 3.849268] Creating 1 MTD partitions on “spi6.0”:
[ 3.849271] 0x000000000000-0x000004000000 : “Whole_flash”
[ 3.849281] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.849285] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.849324] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x249892
[ 3.849328] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.850869] tegra186-padctl 3520000.pinctrl: using UTMI port 2 for otg
[ 3.850871] tegra186-padctl 3520000.pinctrl: using USB3 port 0 for otg
[ 3.851116] vdd-usb2-5v: supplied by vdd-1v8
[ 3.852357] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.854332] GACT probability NOT on
[ 3.854338] Mirror/redirect action on
[ 3.854348] u32 classifier
[ 3.854348] Actions configured
[ 3.854355] Netfilter messages via NETLINK v0.30.
[ 3.854408] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.854734] ctnetlink v0.93: registering with nfnetlink.
[ 3.855224] xt_time: kernel timezone is -0000
[ 3.855230] IPVS: Registered protocols ()
[ 3.855260] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.855304] IPVS: Creating netns size=1760 id=0
[ 3.855320] IPVS: ipvs loaded.
[ 3.855441] ip_tables: © 2000-2006 Netfilter Core Team
[ 3.855549] arp_tables: © 2002 David S. Miller
[ 3.855567] Initializing XFRM netlink socket
[ 3.855880] NET: Registered protocol family 10
[ 3.856449] mip6: Mobile IPv6
[ 3.856462] ip6_tables: © 2000-2006 Netfilter Core Team
[ 3.856568] sit: IPv6 over IPv4 tunneling driver
[ 3.856965] ip6_gre: GRE over IPv6 tunneling driver
[ 3.857144] NET: Registered protocol family 17
[ 3.857155] NET: Registered protocol family 15
[ 3.857179] 8021q: 802.1Q VLAN Support v1.8
[ 3.857199] Key type dns_resolver registered
[ 3.857361] Registered cp15_barrier emulation handler
[ 3.857413] Registered setend emulation handler
[ 3.858643] registered taskstats version 1
[ 3.859524] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.861035] isp 15600000.isp: initialized
[ 3.870359] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 3.957934] mmc0: MAN_BKOPS_EN bit is not set
[ 3.958773] sdhci-tegra 3460000.sdhci: setting min_voltage: 1800000, max_voltage: 1800000
[ 3.997400] mmc0 tuning done saved tap delay=11
[ 3.997401] mmc0: hw tuning done …
[ 3.997404] mmc0: tuning_window[0]: 0xfffffffe
[ 3.997406] mmc0: tuning_window[1]: 0xffffc3ff
[ 3.997409] mmc0: tuning_window[2]: 0xf83fffff
[ 3.997411] mmc0: tuning_window[3]: 0xffffffff
[ 3.997413] mmc0: tuning_window[4]: 0xffffff87
[ 3.997415] mmc0: tuning_window[5]: 0xfff07fff
[ 3.997418] mmc0: tuning_window[6]: 0x7ffffff
[ 3.997420] mmc0: tuning_window[7]: 0x7fffffff
[ 3.997421] sdhci: Tap value: 11 | Trim value: 5
[ 3.997423] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.006420] mmc0: new HS400 MMC card at address 0001
[ 4.006800] mmcblk0: mmc0:0001 064G32 59.3 GiB
[ 4.007065] mmcblk0rpmb: mmc0:0001 064G32 partition 3 4.00 MiB
[ 4.008378] mmcblk0: p1 p2 p3 p4
[ 4.727554] eqos 2490000.ether_qos: tx_tristate_disable DT property missing
[ 4.727559] eqos 2490000.ether_qos eth0: Link is Up - Unsupported (update phy.c)/Half - flow control off
[ 4.917102] gpio tegra-gpio wake21 for gpio=121(P:2)
[ 4.917406] tegradc 15220000.nvdisplay: hdmi: plugged
[ 4.922374] nvcsi 150c0000.nvcsi: initialized
[ 4.923148] Wake76 for irq=199
[ 4.923156] Wake77 for irq=199
[ 4.923161] Wake78 for irq=199
[ 4.923168] Wake79 for irq=199
[ 4.923173] Wake80 for irq=199
[ 4.923178] Wake81 for irq=199
[ 4.923184] Wake82 for irq=199
[ 4.923579] xhci-tegra 3530000.xhci: UTMI port 2 has OTG_CAP
[ 4.923583] xhci-tegra 3530000.xhci: USB3 port 0 has OTG_CAP
[ 4.925020] xhci-tegra 3530000.xhci: Firmware timestamp: 2016-09-01 11:32:41 UTC, Version: 55.05 release
[ 4.925317] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.926548] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.926692] tegra-xotg xotg: update_id_state: ID grounded
[ 4.926697] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 4.926718] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.927058] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 4.927071] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 4.927852] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 4.928018] xhci-tegra 3530000.xhci: irq 61, io mem 0x03530000
[ 4.928152] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.928156] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.928160] usb usb2: Product: xHCI Host Controller
[ 4.928163] usb usb2: Manufacturer: Linux 4.4.38-rt49-tegra xhci-hcd
[ 4.928166] usb usb2: SerialNumber: 3530000.xhci
[ 4.928511] hub 2-0:1.0: USB hub found
[ 4.928537] hub 2-0:1.0: 4 ports detected
[ 4.930022] tegra-xudc-new 3550000.xudc: USB charger detection disabled
[ 4.930075] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.930414] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.930432] isc-mgr isc-mgr.0: isc_mgr_probeing…
[ 4.930499] isc-mgr isc-mgr.0: isc_mgr_probe: success to get PWM
[ 4.931344] isc-mgr isc-mgr.1: isc_mgr_probeing…
[ 4.931394] isc-mgr isc-mgr.1: isc_mgr_probe: success to get PWM
[ 4.932185] isc-mgr isc-mgr.2: isc_mgr_probeing…
[ 4.932232] isc-mgr isc-mgr.2: isc_mgr_probe: success to get PWM
[ 4.943564] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 4.943577] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 3
[ 4.943728] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.943733] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.943736] usb usb3: Product: xHCI Host Controller
[ 4.943739] usb usb3: Manufacturer: Linux 4.4.38-rt49-tegra xhci-hcd
[ 4.943742] usb usb3: SerialNumber: 3530000.xhci
[ 4.944161] hub 3-0:1.0: USB hub found
[ 4.944184] hub 3-0:1.0: 3 ports detected
[ 4.944625] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 4.944629] tegra-xotg xotg: otg: gadget not registered yet
[ 4.944632] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.949293] bpmp: mounted debugfs mirror
[ 4.949688] [dram-timers] DRAM derating cdev registered.
[ 4.952244] hvc_sysfs: log is available
[ 4.952247] hvc_sysfs: pct is available
[ 4.959110] tegra-vi4 15700000.vi: initialized
[ 5.207624] Freeing unused kernel memory: 1180K (ffffffc00116d000 - ffffffc001294000)
[ 5.214781] Freeing alternatives memory: 60K (ffffffc001294000 - ffffffc0012a3000)
[ 5.231190] INITRAMFS STARTS
Getting target_board from device-tree …
[ 5.341674] EXT4-fs (mmcblk0p3): couldn’t mount as ext3 due to feature incompatibilities
[ 5.347300] EXT4-fs (mmcblk0p3): couldn’t mount as ext2 due to feature incompatibilities
[ 5.378859] EXT4-fs (mmcblk0p3): recovery complete
[ 5.381392] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 5.423757] Trying chroot to /new_root
[ 5.424191] INITRAMFS END
[ 5.477498] systemd[1]: System time before build time, advancing clock.
[ 5.492480] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 5.505370] random: systemd: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 5.512813] random: systemd: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 5.521392] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTS
ETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.538850] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 16.04 LTS!
[ 5.553774] systemd[1]: Set hostname to .
[ 5.578847] random: systemd: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 5.580652] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 49 bits of entropy available)
[ 5.587790] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 49 bits of entropy available)
[ 5.602001] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 51 bits of entropy available)
[ 5.606132] random: lvm2-activation: uninitialized urandom read (4 bytes read, 51 bits of entropy available)
[ 5.625811] random: systemd: uninitialized urandom read (16 bytes read, 52 bits of entropy available)
[ 5.630219] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 52 bits of entropy available)
[ 5.630294] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 52 bits of entropy available)
[ 5.731907] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 5.743704] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 5.755654] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.771559] systemd[1]: Reached target Encrypted Volumes.
[ OK ] Reached target Encrypted Volumes.
[ 5.783567] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 5.795549] systemd[1]: Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems (Pre).
[ 5.807560] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ 5.816340] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 5.835796] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 5.863749] systemd[1]: Started Braille Device Support.
[ OK ] Started Braille Device Support.
[ 5.878423] systemd[1]: Starting nv-run-date.service…
[ 5.891841] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 5.903787] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ OK ] Created slice system-systemd\x2dfsck.slice.
[ 5.935663] systemd[1]: Mounting POSIX Message Queue File System…
[ 5.947931] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.956817] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 5.965881] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 6.003832] systemd[1]: Starting Load Kernel Modules…
[ 6.017208] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.020025] usbcore: registered new interface driver rndis_host
[ 6.039745] systemd[1]: Listening on LVM2 metadata daemon socket.
[ OK ] Listening on LVM2 metadata daemon socket.
[ 6.055690] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ OK ] Listening on Device-mapper event daemon FIFOs.
[ 6.087766] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
Starting Monitoring of LVM2 mirrors… dmeventd or progress polling…
[ 6.108864] systemd[1]: Mounting Debug File System…
[ 6.120907] systemd[1]: Starting Create list of required static device nodes for the current kernel…
Starting Create list of required st… nodes for the current kernel…
[ 6.139698] systemd[1]: Listening on fsck to fsckd communication Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ 6.155764] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 6.167618] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 6.179680] systemd[1]: Listening on LVM2 poll daemon socket.
[ OK ] Listening on LVM2 poll daemon socket.
[ 6.191755] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 6.203663] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.215642] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 6.225911] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 6.255847] syst
