Jetson TX2 does not boot after flash
I made an image from my Jetson TX2 with Jetpack 3.3, since this is the jetpack version of the Jetson TX2. Then I took the image and flashed it with the same Jetpack version to a new Jetson TX2. The flashing process worked absolutely fine, but when I try to boot the new Jetson TX2, it hangs in the NVIDIA start screen and I’m not able to connect to SSH.
What kind of things do I have to consider when I flash a new Jetson TX2 with an older image?
My serial output when booting the new Jetson TX2:
[0000.271] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-050b21a4)
[0000.280] I> bit @ 0xd480000
[0000.283] I> Boot-device: eMMC
[0000.290] I> sdmmc bdev is already initialized
[0000.295] I> pmic: reset reason (nverc)        : 0x50
[0000.326] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.345] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.351] W> No valid slot number is found in scratch register
[0000.357] W> Return default slot: _a
[0000.360] I> A/B: bin_type (16) slot 0
[0000.364] I> Loading partition bpmp-fw at 0xd7800000
[0000.369] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.374] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.399] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.404] W> No valid slot number is found in scratch register
[0000.410] W> Return default slot: _a
[0000.413] I> A/B: bin_type (17) slot 0
[0000.417] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.422] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.428] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.454] I> Binary(17) of size 604720 is loaded @ 0xd796c400
[0000.684] I> Loading SCE-FW ...
[0000.687] W> No valid slot number is found in scratch register
[0000.693] W> Return default slot: _a
[0000.696] I> A/B: bin_type (12) slot 0
[0000.700] I> Loading partition sce-fw at 0xd7300000
[0000.704] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.710] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.729] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.735] I> Init SCE
[0000.737] I> Loading APE-FW ...
[0000.740] W> No valid slot number is found in scratch register
[0000.746] W> Return default slot: _a
[0000.749] I> A/B: bin_type (11) slot 0
[0000.753] I> Loading partition adsp-fw at 0xd7400000
[0000.758] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.763] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.782] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.788] I> Copy BTCM section
[0000.791] W> No valid slot number is found in scratch register
[0000.797] W> Return default slot: _a
[0000.800] I> A/B: bin_type (13) slot 0
[0000.804] I> Loading partition cpu-bootloader at 0x96000000
[0000.809] I> Reading two headers - addr:0x96000000 blocks:1
[0000.815] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.836] I> Binary(13) of size 284288 is loaded @ 0x96000000
[0000.841] W> No valid slot number is found in scratch register
[0000.847] W> Return default slot: _a
[0000.850] I> A/B: bin_type (20) slot 0
[0000.854] I> Loading partition bootloader-dtb at 0x8520f400
[0000.859] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.865] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.887] I> Binary(20) of size 371456 is loaded @ 0x8520f400
[0000.893] W> No valid slot number is found in scratch register
[0000.898] W> Return default slot: _a
[0000.902] I> A/B: bin_type (14) slot 0
[0000.905] I> Loading partition secure-os at 0x8530f600
[0000.910] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.916] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.938] I> Binary(14) of size 366000 is loaded @ 0x8530f600
[0000.945] I> TOS boot-params @ 0x85000000
[0000.949] I> TOS params prepared
[0000.952] I> Loading EKS ...
[0000.955] I> A/B: bin_type (15) slot 0
[0000.959] I> Loading partition eks at 0x8590f800
[0000.963] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.969] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.987] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.993] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.998] I> Copied encrypted keys
[0001.002] I> boot profiler @ 0x275844000
[0001.006] I> boot profiler for TOS @ 0x275844000
[0001.010] I> Unhalting SCE
[0001.013] I> Primary Memory Start:80000000 Size:70000000
[0001.018] I> Extended Memory Start:f0110000 Size:1856f0000
[0001.025] I> MB2(TBoot-BPMP) done
NOTICE:  BL31: v1.3(release):fe06da916
NOTICE:  BL31: Built : 18:07:10, Apr  8 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing .......
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.398] I> Welcome to Cboot
[0001.400] I> Cboot Version: t186-da7af280
[0001.404] I> CPU-BL Params @ 0x275800000
[0001.408] I>  0) Base:0x00000000 Size:0x00000000
[0001.412] I>  1) Base:0x277f00000 Size:0x00100000
[0001.417] I>  2) Base:0x277e00000 Size:0x00100000
[0001.421] I>  3) Base:0x277d00000 Size:0x00100000
[0001.426] I>  4) Base:0x277c00000 Size:0x00100000
[0001.430] I>  5) Base:0x277b00000 Size:0x00100000
[0001.435] I>  6) Base:0x277800000 Size:0x00200000
[0001.439] I>  7) Base:0x277400000 Size:0x00400000
[0001.444] I>  8) Base:0x277a00000 Size:0x00100000
[0001.449] I>  9) Base:0x277300000 Size:0x00100000
[0001.453] I> 10) Base:0x276800000 Size:0x00800000
[0001.458] I> 11) Base:0x30000000 Size:0x00040000
[0001.462] I> 12) Base:0xf0000000 Size:0x00100000
[0001.466] I> 13) Base:0x30040000 Size:0x00001000
[0001.471] I> 14) Base:0x30048000 Size:0x00001000
[0001.475] I> 15) Base:0x30049000 Size:0x00001000
[0001.480] I> 16) Base:0x3004a000 Size:0x00001000
[0001.484] I> 17) Base:0x3004b000 Size:0x00001000
[0001.489] I> 18) Base:0x3004c000 Size:0x00001000
[0001.493] I> 19) Base:0x3004d000 Size:0x00001000
[0001.497] I> 20) Base:0x3004e000 Size:0x00001000
[0001.502] I> 21) Base:0x3004f000 Size:0x00001000
[0001.506] I> 22) Base:0x00000000 Size:0x00000000
[0001.511] I> 23) Base:0xf0100000 Size:0x00010000
[0001.515] I> 24) Base:0x00000000 Size:0x00000000
[0001.520] I> 25) Base:0x00000000 Size:0x00000000
[0001.524] I> 26) Base:0x00000000 Size:0x00000000
[0001.528] I> 27) Base:0x00000000 Size:0x00000000
[0001.533] I> 28) Base:0x84400000 Size:0x00400000
[0001.537] I> 29) Base:0x30000000 Size:0x00010000
[0001.542] I> 30) Base:0x278000000 Size:0x08000000
[0001.546] I> 31) Base:0x00000000 Size:0x00000000
[0001.551] I> 32) Base:0x276000000 Size:0x00600000
[0001.555] I> 33) Base:0x80000000 Size:0x70000000
[0001.560] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.564] I> 35) Base:0x00000000 Size:0x00000000
[0001.569] I> 36) Base:0x00000000 Size:0x00000000
[0001.573] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.578] I> 38) Base:0x84000000 Size:0x00400000
[0001.582] I> 39) Base:0x96000000 Size:0x02000000
[0001.586] I> 40) Base:0x85000000 Size:0x01200000
[0001.591] I> 41) Base:0x275800000 Size:0x00500000
[0001.595] I> 42) Base:0x00000000 Size:0x00000000
[0001.600] I> 43) Base:0x00000000 Size:0x00000000
[0001.604] GIC-SPI Target CPU: 4
[0001.608] Interrupts Init done
[0001.611] calling constructors
[0001.614] initializing heap
[0001.617] initializing threads
[0001.620] initializing timers
[0001.623] creating bootstrap completion thread
[0001.628] top of bootstrap2()
[0001.631] CPU: ARM Cortex A57
[0001.634] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.639] initializing platform
[0001.642] I> Bl_dtb @0x8520f400
[0001.645] I> gpio framework initialized
[0001.652] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.662] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.669] I> GPIO framework and drivers are initialized.
[0001.674] I> Boot-device: eMMC
[0001.681] I> sdmmc bdev is already initialized
[0001.712] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0001.729] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.735] W> opt-in fuse is not set, skip fuse_burning
[0001.740] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.746] W> No valid slot number is found in scratch register
[0001.751] W> Return default slot: _a
[0001.755] I> A/B: bin_type (21) slot 0
[0001.758] I> Loading kernel-dtb from partition
[0001.762] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.780] I> Kernel_dtb @0x80000000
[0001.783] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.794] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.801] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.810] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.820] I> fixed regulator driver initialized
[0001.852] I> register 'maxim' power off handle
[0001.858] I> virtual i2c enabled
[0001.861] I> registered 'maxim,max77620' pmic
[0001.866] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.879] I> Find /i2c@c250000's alias i2c7
[0001.883] I> Reading eeprom i2c=7 address=0x50
[0001.912] I> Device at /i2c@c250000:0x50
[0001.916] I> Reading eeprom i2c=7 address=0x57
[0001.945] I> Device at /i2c@c250000:0x57
[0001.949] I> Find /i2c@c240000's alias i2c1
[0001.953] I> Reading eeprom i2c=1 address=0x51
[0001.958] E> I2C: slave not found in slaves.
[0001.962] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.970] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.976] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.985] E> eeprom: Retry to read I2C slave device.
[0001.990] E> I2C: slave not found in slaves.
[0001.994] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0002.002] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.008] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0002.017] E> eeprom: Failed to read I2C slave device
[0002.022] I> Eeprom read failed 0x3526070d
[0002.027] I> Find /i2c@3160000's alias i2c0
[0002.031] I> Reading eeprom i2c=0 address=0x50
[0002.035] E> I2C: slave not found in slaves.
[0002.039] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.047] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.053] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0002.062] E> eeprom: Failed to read I2C slave device
[0002.067] I> Eeprom read failed 0x3526070d
[0002.072] I> Find /i2c@3180000's alias i2c2
[0002.076] I> Reading eeprom i2c=2 address=0x54
[0002.080] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.111] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.116] I> Device at /i2c@3180000:0x54
[0002.120] I> Reading eeprom i2c=2 address=0x57
[0002.124] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.129] E> I2C: slave not found in slaves.
[0002.134] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.141] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.147] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0002.157] E> eeprom: Failed to read I2C slave device
[0002.161] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.167] I> Eeprom read failed 0x00000000
[0002.170] I> create_pm_ids: id: 3310-1000-D00-J, len: 15
[0002.176] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.187] I> create_pm_ids: id: 2597-0000-900-E, len: 15
[0002.192] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.203] I> create_pm_ids: id: 3326-1000-000-M, len: 15
[0002.208] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0002.242] I> enabling 'vdd-hdmi' regulator
[0002.257] I> regulator 'vdd-hdmi' already enabled
[0002.262] I> hdmi cable connected
[0002.271] I> setting 'vdd-pex-1v00' regulator to 1000000 micro volts
[0002.282] I> setting 'vdd-1v8' regulator to 1800000 micro volts
[0002.291] E> cannot find any other nvdisp nodes
[0002.312] I> edid read success
[0002.327] I> edid read success
[0002.330] I> width = 640, height = 480, frequency = 25174825
[0002.336] I> width = 640, height = 480, frequency = 25174825
[0002.341] I> width = 640, height = 480, frequency = 25174825
[0002.347] I> width = 640, height = 480, frequency = 25174825
[0002.352] I> width = 1920, height = 1080, frequency = 148500000
[0002.358] I> width = 720, height = 480, frequency = 27000000
[0002.363] I> width = 640, height = 480, frequency = 25174825
[0002.369] I> width = 720, height = 480, frequency = 26973026
[0002.374] I> width = 720, height = 480, frequency = 26973026
[0002.380] I> width = 1280, height = 720, frequency = 74175824
[0002.385] I> width = 1920, height = 1080, frequency = 148351648
[0002.391] I> width = 720, height = 576, frequency = 26973026
[0002.396] I> width = 720, height = 576, frequency = 26973026
[0002.402] I> width = 1280, height = 720, frequency = 74175824
[0002.408] I> width = 1920, height = 1080, frequency = 148351648
[0002.413] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.423] I> hdmi_enable, starting HDMI initialisation
[0002.431] I> hdmi_enable, HDMI initialisation complete
[0002.444] initializing target
[0002.447] calling apps_init()
[0002.450] starting app kernel_boot_app
[0002.472] I> found decompressor handler: lz4-legacy
[0002.477] I> decompressing BMP blob ...
[0002.487] I> Kernel type = Normal
[0002.490] I> Loading kernel-bootctrl from partition
[0002.495] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.509] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.516] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.523] I> ########## Fixed storage boot ##########
[0002.528] W> No valid slot number is found in scratch register
[0002.534] W> Return default slot: _a
[0002.537] I> A/B: bin_type (24) slot 0
[0002.553] I> Boot image size read from image header: 74aba
[0002.558] I> Boot image load address: 0x80400000
[0002.562] I> Loading kernel from partition
[0002.566] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.508] I> Validate kernel ...
[0003.511] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.519] I> kernel-dtb is already loaded
[0003.523] I> Validate kernel-dtb ...
[0003.526] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.534] I> Checking boot.img header magic ... [0003.538] I> [OK]
[0003.540] I> Kernel hdr @0x80400000
[0003.543] I> Kernel dtb @0x80000000
[0003.546] I> decompressor handler not found
[0003.550] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80600000 ... [0003.558] I> Done
[0003.560] I> Move ramdisk (len: 0) from 0x80475800 to 0x947b0000
[0003.567] I> Updated bpmp info to DTB
[0003.573] I> Ramdisk: Base: 0x947b0000; Size: 0x0
[0003.577] I> Updated initrd info to DTB
[0003.581] W> WARN: Fail to override "console=none" in commandline
[0003.587] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.594] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0003.601] I> disabled_core_mask: 0xffffff0c
[0003.605] W> No valid slot number is found in scratch register
[0003.611] W> Return default slot: _a
[0003.614] I> Active slot suffix:
[0003.617] I> add_boot_slot_suffix: slot_suffix =
[0003.622] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart825
[0003.665] I> Updated bootarg info to DTB
[0003.669] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:f8:4b:18
[0003.675] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:f8:4b:19
[0003.681] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:f8:4b:1a
[0003.687] E> Found no plugin manager ids in source DT
[0003.692] W> Add plugin manager ids from board info
[0003.697] E> "plugin-manager" doesn't exist, creating
[0003.702] E> "ids" doesn't exist, creating
[0003.706] E> "connection" doesn't exist, creating
[0003.710] E> "configs" doesn't exist, creating
[0003.715] I> create_pm_ids: id: 3310-1000-D00-J, len: 15
[0003.720] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.731] I> create_pm_ids: id: 2597-0000-900-E, len: 15
[0003.736] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.747] I> create_pm_ids: id: 3326-1000-000-M, len: 15
[0003.752] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0003.763] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0003.770] E> "i2c@c250000" doesn't exist, creating
[0003.775] E> "module@0x50" doesn't exist, creating
[0003.780] I> Adding plugin-manager/ids/2597-0000-900=/i2c@c250000:module@0x57
[0003.787] E> "module@0x57" doesn't exist, creating
[0003.792] I> Adding plugin-manager/ids/3326-1000-000=/i2c@3180000:module@0x54
[0003.799] E> "i2c@3180000" doesn't exist, creating
[0003.804] E> "module@0x54" doesn't exist, creating
[0003.811] I> Adding plugin-manager/ids/3310-1000-D00-J
[0003.818] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.823] I> Adding plugin-manager/configs/3310-power-config 00
[0003.829] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.835] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.841] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.847] I> Adding plugin-manager/configs/3310-display-config 00
[0003.853] I> Adding plugin-manager/cvm
[0003.857] E> "chip-id" doesn't exist, creating
[0003.861] I> Adding plugin-manager/chip-id/A02P
[0003.866] E> "odm-data" doesn't exist, creating
[0003.870] I> Adding /chosen/plugin-manager/odm-data
[0003.880] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.886] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.892] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.898] I> added [base:0x276600000, size:0x200000] to /memory
[0003.903] I> added [base:0x277000000, size:0x200000] to /memory
[0003.909] I> Updated memory info to DTB
[0003.914] E> add_disp_param: failed to get display params for du=1
[0003.922] E> "reset" doesn't exist, creating
[0003.926] E> "pmc-reset-reason" doesn't exist, creating
[0003.931] E> "pmic-reset-reason" doesn't exist, creating
[0003.938] I> Adding ecid(00000001646574090000000015ff8500) to DT
[0003.943] I> disabled_core_mask: 0xffffff0c
[0003.957] I> Add serial number:1420820036745 as DT property
[0003.966] I> Plugin-manager override starting
[0003.971] I> node /plugin-manager/fragement@0 matches
[0003.981] I> node /plugin-manager/fragement@4 matches
[0003.994] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0004.014] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0004.023] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0004.032] I> node /plugin-manager/fragment-devslp@0 matches
[0004.044] I> node /plugin-manager/fragment-500-pcie-config matches
[0004.059] I> node /plugin-manager/fragment-500-xusb-config matches
[0004.081] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0004.094] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0004.105] I> node /plugin-manager/fragment-p3310-c01 matches
[0004.118] I> node /plugin-manager/fragment-p3310-c03 matches
[0004.152] I> node /plugin-manager/fragment-e3326@0 matches
[0004.232] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0004.258] I> Disable plugin-manager status in FDT
[0004.263] I> Plugin-manager override finished successfully
[0004.268] I> tegrabl_load_kernel_and_dtb: Done
[0004.318] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2016.07-g45dfa3dff4 (Apr 08 2020 - 18:06:40 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM:  7.8 GiB
MC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@2490000
Hit any key to stop autoboot:  0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 98 ms (2 KiB/s)
1:      primary kernel
Retrieving file: /boot/Image
20727600 bytes read in 538 ms (36.7 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nv4
## Flattened Device Tree blob at 80000000
   Booting using the fdt blob at 0x80000000
   reserving fdt memory region: addr=80000000 size=10000
   Using Device Tree in place at 0000000080000000, end 000000008005fa9f
Starting kernel ...
There are dependencies between boot content and part of the rootfs. On the other Jetson did you also flash with JetPack3.3/L4T R28.2? If so, then it should have worked. Basically your bootloader worked up until it tried to hand off to the Linux kernel, and then it stops, and so nothing could execute from the kernel code, or else the kernel was never found. If you are trying to use an older rootfs with a newer JetPack/SDK Manager, then failing would be expected.
I took this tool to find out which Jetpack Installation was used: GitHub - jetsonhacks/jetsonUtilities: Get information about the NVIDIA Jetson OS environment. Lists L4T and JetPack versions, along with major libraries.
Then I used this Jetpack version with the SDKManager 1.0.1 to take the image and then flash it using this commands:
TX2 Cloning
How far does the SDK Manager version relates with the Jetpack? Shouldn’t the version of the SDK Manager be independent of the Jetpack’s?
There are also two different versions of the Jetpack: Jetpack 3.3.1 and Jetpack 3.3.2, but jetsonUtilities only prints 3.3.
After flashing the Jetson TX2 with the Jetpack 3.3.2 about the SDK manager (using the default system.img) and then flashing the Jetson TX2 with my backup .img, the Jetson TX2 is now booting. Then after a few seconds I get a kernel panic error:
Starting kernel …
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Found tegra_fbmem2: 00800000@969f0000
[    0.000000] Found lut_mem2: 00002008@969ed000
[    0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2019936
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmi4
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7967764K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 175084K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc2000000 - 0xffffffbdc9da0000   (   125 MB actual)
[    0.000000]     fixed   : 0xffffffbffa7fd000 - 0xffffffbffac00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
[    0.000000]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc1f6800000   (  8040 MB)
[    0.000000]       .init : 0xffffffc001132000 - 0xffffffc001256000   (  1168 KB)
[    0.000000]       .text : 0xffffffc000080000 - 0xffffffc001132000   ( 17096 KB)
[    0.000000]       .data : 0xffffffc001278000 - 0xffffffc001444730   (  1842 KB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.009860] Console: colour dummy device 80x25
[    0.014520] console [tty0] enabled
[    0.018078] bootconsole [uart0] disabled
[    0.022182] kmemleak: Kernel memory leak detector disabled
[    0.022195] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.022207] pid_max: default: 32768 minimum: 301
[    0.022255] Security Framework initialized
[    0.022294] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.022305] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.022692] Initializing cgroup subsys io
[    0.022705] Initializing cgroup subsys memory
[    0.022723] Initializing cgroup subsys devices
[    0.022733] Initializing cgroup subsys freezer
[    0.022742] Initializing cgroup subsys net_cls
[    0.022753] Initializing cgroup subsys perf_event
[    0.022762] Initializing cgroup subsys net_prio
[    0.022773] Initializing cgroup subsys pids
[    0.022781] Initializing cgroup subsys debug
[    0.022922] CPU0 ipc=752
[    0.022931] CPU1 ipc=1024
[    0.022939] CPU2 ipc=1024
[    0.022949] CPU3 ipc=752
[    0.022958] CPU4 ipc=752
[    0.022968] CPU5 ipc=752
[    0.023004] ASID allocator initialised with 65536 entries
[    0.046299] tegra-id: chipid=21817.
[    0.046316] tegra-id: opt_subrevision=1.
[    0.046330] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.047022] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.s
[    0.047049] DTB Build time: Oct 31 2019 14:13:43
[    0.062471] CPU1: Booted secondary processor [4e0f0030]
[    0.074080] CPU2: Booted secondary processor [4e0f0030]
[    0.085799] CPU3: Booted secondary processor [411fd073]
[    0.097814] CPU4: Booted secondary processor [411fd073]
[    0.109810] CPU5: Booted secondary processor [411fd073]
[    0.109873] Brought up 6 CPUs
[    0.109932] SMP: Total of 6 processors activated.
[    0.109945] CPU: All CPU(s) started at EL2
[    0.110433] devtmpfs: initialized
[    0.137103] Initilizing CustomIPI irq domain
[    0.137312] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.138167] pinctrl core: initialized pinctrl subsystem
[    0.138346] OS set in device tree is not L4T.
[    0.138535] regulator-dummy: no parameters
[    0.138642] Initializing plugin-manager
[    0.138694] Plugin module not found
[    0.139100] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[    0.139435] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[    0.140039] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[    0.141183] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[    0.141550] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[    0.141806] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[    0.142024] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[    0.142444] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[    0.142884] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[    0.143160] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[    0.143536] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[    0.143781] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[    0.143999] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[    0.144257] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[    0.145812] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[    0.146890] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[    0.148684] Adding domain adsp-pd to PM domain ape-pd
[    0.151088] NET: Registered protocol family 16
[    0.151946] console [pstore-1] enabled
[    0.151958] pstore: Registered ramoops as persistent store backend
[    0.151971] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[    0.161347] cpuidle: using governor ladder
[    0.165800] cpuidle: using governor menu
[    0.167003] bpmp: waiting for handshake
[    0.167019] bpmp: handshake completed
[    0.167061] bpmp: synchronizing channels
[    0.167088] bpmp: channels synchronized
[    0.167099] bpmp: mail init ok
[    0.167464] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[    0.167497] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.168454] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.169877] tegra_powergate_init: DONE
[    0.169898] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.s
[    0.169925] DTB Build time: Oct 31 2019 14:13:43
[    0.170855] Tegra reboot handler registered.
[    0.171949] Registering Tegra186 clocks (this may take a while)...done
[    0.174096] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.174116] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.174129] arm-smmu 12000000.iommu:         stage 1 translation
[    0.174142] arm-smmu 12000000.iommu:         stage 2 translation
[    0.174154] arm-smmu 12000000.iommu:         nested translation
[    0.174168] arm-smmu 12000000.iommu:         stream matching with 128 register groups, mask 0x7f80
[    0.174188] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.174207] arm-smmu 12000000.iommu:         64 context banks (0 stage-2 only)
[    0.174221] arm-smmu 12000000.iommu:         Stage-1: 39-bit VA -> 48-bit IPA
[    0.174235] arm-smmu 12000000.iommu:         Stage-2: 39-bit IPA -> 48-bit PA
[    0.223373] arm-smmu 12000000.iommu: registered 67 master devices
[    0.228971] iommu: Adding device 3460000.sdhci to group 0
[    0.229841] iommu: Adding device 3400000.sdhci to group 1
[    0.233205] iommu: Adding device 3507000.ahci-sata to group 2
[    0.233663] iommu: Adding device 3160000.i2c to group 3
[    0.234077] iommu: Adding device c240000.i2c to group 4
[    0.234415] iommu: Adding device 3180000.i2c to group 5
[    0.234784] iommu: Adding device 3190000.i2c to group 6
[    0.235272] iommu: Adding device 31b0000.i2c to group 7
[    0.235598] iommu: Adding device 31c0000.i2c to group 8
[    0.235919] iommu: Adding device c250000.i2c to group 9
[    0.236279] iommu: Adding device 31e0000.i2c to group 10
[    0.238325] iommu: Adding device 3210000.spi to group 11
[    0.238659] iommu: Adding device c260000.spi to group 12
[    0.239005] iommu: Adding device 3240000.spi to group 13
[    0.239816] iommu: Adding device 3100000.serial to group 14
[    0.240117] iommu: Adding device 3110000.serial to group 15
[    0.240464] iommu: Adding device c280000.serial to group 16
[    0.240765] iommu: Adding device 3130000.serial to group 17
[    0.242003] iommu: Adding device 2490000.ether_qos to group 18
[    0.242660] iommu: Adding device b000000.rtcpu to group 19
[    0.243115] iommu: Adding device c1a0000.aon to group 20
[    0.243981] Wake73 for irq=42
[    0.244302] iommu: Adding device smmu_test to group 21
[    0.244806] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[    0.244848] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[    0.244883] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[    0.244918] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[    0.244964] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[    0.244997] mc-err: Set intmask: 0xf3140
[    0.245213] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[    0.246022] Wake76 for irq=199
[    0.246054] Wake77 for irq=199
[    0.246075] Wake78 for irq=199
[    0.246095] Wake79 for irq=199
[    0.246114] Wake80 for irq=199
[    0.246134] Wake81 for irq=199
[    0.246153] Wake82 for irq=199
[    0.246612] iommu: Adding device 3530000.xhci to group 22
[    0.246985] iommu: Adding device 3550000.xudc to group 23
[    0.247782] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.247817] tegra-pmc: ### PMC reset source: Power on reset
[    0.247841] tegra-pmc: ### PMC reset level: L0
[    0.247863] tegra-pmc: ### PMC reset status reg: 0x0
[    0.248143] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.248180] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.248334] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.248363] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.248853] iommu: Adding device 13e10000.host1x to group 24
[    0.249110] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[    0.249356] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[    0.249592] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[    0.249840] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[    0.250058] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[    0.250294] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[    0.250533] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[    0.250789] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[    0.251200] iommu: Adding device 150c0000.nvcsi to group 33
[    0.251746] iommu: Adding device 15700000.vi to group 34
[    0.252088] iommu: Adding device 15600000.isp to group 35
[    0.252417] iommu: Adding device 15210000.nvdisplay to group 36
[    0.252630] platform 15210000.nvdisplay: IOVA linear map 0x00000000969f0000(800000)
[    0.252673] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ed000(3000)
[    0.252882] iommu: Adding device 15340000.vic to group 37
[    0.253082] iommu: Adding device 154c0000.nvenc to group 38
[    0.253282] iommu: Adding device 15480000.nvdec to group 39
[    0.253622] iommu: Adding device 15380000.nvjpg to group 40
[    0.253820] iommu: Adding device 15500000.tsec to group 41
[    0.254034] iommu: Adding device 15100000.tsecb to group 42
[    0.254755] iommu: Adding device 15810000.se to group 43
[    0.255014] iommu: Adding device 15820000.se to group 44
[    0.255228] iommu: Adding device 15830000.se to group 45
[    0.255429] iommu: Adding device 15840000.se to group 46
[    0.256127] iommu: Adding device 17000000.gp10b to group 47
[    0.257737] tegra-reset 5000000.clock: registered 193 resets.
[    0.260042] iommu: Adding device d000000.bpmp to group 48
[    0.260275] bpmp: ping status is 0
[    0.260459] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[    0.260815] bpmp d000000.bpmp: probe ok
[    0.263360] iommu: Adding device 2600000.dma to group 49
[    0.264217] GPIO line 461 (cam0-rst) hogged as output/low
[    0.264281] GPIO line 456 (cam0-pwdn) hogged as output/low
[    0.264357] GPIO line 457 (cam1-rst) hogged as output/low
[    0.264410] GPIO line 426 (cam1-pwdn) hogged as output/low
[    0.264466] GPIO line 424 (wifi-enable) hogged as output/high
[    0.264521] GPIO line 445 (sdmmc-wake-input) hogged as input
[    0.264577] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[    0.264711] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[    0.266576] GPIO line 315 (wifi-wake-ap) hogged as input
[    0.266685] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[    0.267569] iommu: Adding device 10003000.pcie-controller to group 50
[    0.267894] iommu: Adding device sound to group 51
[    0.269540] iommu: Adding device 3510000.hda to group 52
[    0.270723] iommu: Adding device adsp_audio to group 53
[    0.272165] iommu: Adding device 2993000.adsp to group 54
[    0.281766] vdd-ac-bat: 5000 mV
[    0.283923] vdd-1v8-ap: 1800 mV
[    0.300458] SCSI subsystem initialized
[    0.300803] usbcore: registered new interface driver usbfs
[    0.300867] usbcore: registered new interface driver hub
[    0.300986] usbcore: registered new device driver usb
[    0.304835] GPIO line 241 (touch-rail-1) hogged as output/high
[    0.305287] GPIO line 242 (touch-rail-2) hogged as output/high
[    0.305391] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[    0.306815] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[    0.306914] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[    0.317756] media: Linux media interface: v0.10
[    0.317830] Linux video capture interface: v2.00
[    0.320902] pps_core: LinuxPPS API ver. 1 registered
[    0.320940] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.321016] PTP clock support registered
[    0.321895] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.321943] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.323416] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.325549] GPIO line 221 (spmic_gpio_input_5) hogged as input
[    0.325742] GPIO line 222 (spmic_gpio_input_6) hogged as input
[    0.325848] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[    0.330647] vddio-ddr: at 1125 mV
[    0.334481] avdd_dsi_csi: 1200 mV
[    0.338480] vdd-1v8: 1800 mV
[    0.342480] vdd-3v3-sys: 3300 mV
[    0.343604] spmic-ldo0: at 1800 mV
[    0.344398] spmic-ldo1: at 800 mV
[    0.346482] vddio-3v3: 3300 mV
[    0.347148] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.350483] vdd-rtc: at 800 mV
[    0.351352] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.354513] spmic-ldo6: at 1500 mV
[    0.358484] vdd-pex-1v00: 1000 mV
[    0.359113] dvdd-pex: 1000 mV
[    0.359393] max77620 4-003c: max77620 probe successful
[    0.359669] Advanced Linux Sound Architecture Driver Initialized.
[    0.360650] en-vdd-sd: 3300 mV
[    0.361217] en-vdd-cam: 1800 mV
[    0.365344] vdd-hdmi: 5000 mV
[    0.365527] vdd-usb0-5v: 5000 mV
[    0.365695] vdd-usb1-5v: 5000 mV
[    0.369343] en-vdd-ts-1v8: 1800 mV
[    0.373342] en-vdd-ts-hv-3v3: 3300 mV
[    0.373862] en-vdd-disp-3v3: 3300 mV
[    0.374386] en-mdm-pwr-3v7: 3700 mV
[    0.374917] en-vdd-disp-1v8: 1800 mV
[    0.375442] en-vdd-cam-hv-2v8: 2800 mV
[    0.375971] en-vdd-cam-1v2: 1200 mV
[    0.376499] vdd-fan: 5000 mV
[    0.376605] vdd-3v3: 3300 mV
[    0.377322] dis-vdd-1v2: 1200 mV
[    0.377444] en-vdd-vcm-2v8: 2800 mV
[    0.377960] vdd-usb2-5v: 5000 mV
[    0.378078] vdd-sys-bl: 3300 mV
[    0.378600] en-vdd-sys: 1200 mV
[    0.381938] extcon-gpio-states external-connection:extcon@1: Cable state 1
[    0.382351] clocksource: Switched to clocksource arch_sys_counter
[    0.400858] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.401123] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[    0.401600] nvmap_page_pool_init: Total RAM pages: 2008325
[    0.401618] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB)
[    0.401801] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.406285] Wake76 for irq=199
[    0.406298] Wake77 for irq=199
[    0.406309] Wake78 for irq=199
[    0.406320] Wake79 for irq=199
[    0.406329] Wake80 for irq=199
[    0.406339] Wake81 for irq=199
[    0.406349] Wake82 for irq=199
[    0.407086] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.407281] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.407666] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.407745] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.407888] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    0.408030] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    0.408177] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[    0.408469] isomgr_init(): iso emc max clk=1866000KHz
[    0.408482] isomgr_init(): max_iso_bw=26870400KB
[    0.408567] NET: Registered protocol family 2
[    0.408864] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.409189] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.409838] TCP: Hash tables configured (established 65536 bind 65536)
[    0.409896] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.410028] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.410268] NET: Registered protocol family 1
[    0.410486] RPC: Registered named UNIX socket transport module.
[    0.410502] RPC: Registered udp transport module.
[    0.410513] RPC: Registered tcp transport module.
[    0.410525] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.410641] Trying to unpack rootfs image as initramfs...
[    0.424196] host1x 13e10000.host1x: initialized
[    0.425064] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.426706] futex hash table entries: 2048 (order: 6, 262144 bytes)
[    0.426801] audit: initializing netlink subsys (disabled)
[    0.426833] audit: type=2000 audit(0.416:1): initialized
[    0.433822] io scheduler noop registered
[    0.433929] io scheduler cfq registered (default)
[    0.436826] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.438015] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.439075] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.440118] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.443609] tsec 15500000.tsec: initialized
[    0.444709] tsec 15100000.tsecb: initialized
[    0.447071] nvdec 15480000.nvdec: initialized
[    0.450759] falcon 15340000.vic: initialized
[    0.451777] falcon 154c0000.nvenc: initialized
[    0.452767] falcon 15380000.nvjpg: initialized
[    0.453554] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.454066] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.454591] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.455100] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.455610] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.456117] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.456626] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.457128] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.459807] DC OR NODE connected to /host1x/sor1
[    0.459932] generic_infoframe_type: 0x87
[    0.459942] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.460037] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    0.460052] tegradc 15210000.nvdisplay: DT parsed successfully
[    0.460069] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[    0.460083] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[    0.467404] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    0.467425] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    0.467442] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    0.467487] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[    0.467502] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[    0.467649] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[    0.468398] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[    0.470157] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.470525] kfuse 3830000.kfuse: initialized
[    0.470681] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[    0.472080] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.472086] tegradc 15210000.nvdisplay: probed
[    0.472830] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.474768] console [ttyS0] disabled
[    0.474823] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[    2.602283] console [ttyS0] enabled
[    2.604294] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[    2.605405] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[    2.605693] serial-tegra 3130000.serial: RX in PIO mode
[    2.606602] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[    2.616666] brd: module loaded
[    2.617149] Console: switching to colour frame buffer device 240x67
[    2.620952] loop: module loaded
[    2.621176] nct1008_nct72 7-004c: find device tree node, parsing dt
[    2.621180] nct1008_nct72 7-004c: starting parse dt
[    2.621260] nct1008_nct72 7-004c: success parsing dt
[    2.621389] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[    2.634405] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[    2.658162] tmp451: Enabled overheat logging at 104.00C
[    2.658314] nct1008_nct72 7-004c: nct1008_probe: initialized
[    2.660685] THERMAL EST: found 3 subdevs
[    2.660689] THERMAL EST num_resources: 0
[    2.660697] [THERMAL EST subdev 0]
[    2.660701] [THERMAL EST subdev 1]
[    2.660705] [THERMAL EST subdev 2]
[    2.660985] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    2.660987] THERMAL EST: thz register success.
[    2.661112] THERMAL EST: end of probe, return err: 0
[    2.661162] tegra_profiler: Branch: Dev
[    2.661164] tegra_profiler: Version: 1.117
[    2.661167] tegra_profiler: Samples version: 41
[    2.661169] tegra_profiler: IO version: 22
[    2.661176] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.661181] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.661184] armv8_pmu: imp: 0x4e, idcode: 0x1
[    2.661189] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[    2.661192] armv8_pmu: imp: 0x4e, idcode: 0x1
[    2.661195] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[    2.661199] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.661203] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.661206] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.661210] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.661212] armv8_pmu: imp: 0x41, idcode: 0x1
[    2.661216] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[    2.661406] tegra_profiler: auth: init
[    2.664738] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[    2.664750] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[    2.665684] scsi host0: tegra_ahci
[    2.666061] scsi host1: tegra_ahci
[    2.666199] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[    2.666202] ata2: DUMMY
[    2.667166] spi-tegra114 3210000.spi: Static pin configuration used
[    2.667654] spi-tegra114 c260000.spi: Static pin configuration used
[    2.668050] spi-tegra114 3240000.spi: Static pin configuration used
[    2.668844] tun: Universal TUN/TAP device driver, 1.6
[    2.668847] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.669011] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.669013] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.669050] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[    2.669052] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.670132] PPP generic driver version 2.4.2
[    2.670257] PPP BSD Compression module registered
[    2.670265] PPP Deflate Compression module registered
[    2.670287] PPP MPPE Compression module registered
[    2.670301] NET: Registered protocol family 24
[    2.670379] usbcore: registered new interface driver r8152
[    2.670412] usbcore: registered new interface driver asix
[    2.670445] usbcore: registered new interface driver ax88179_178a
[    2.670472] usbcore: registered new interface driver cdc_ether
[    2.670535] usbcore: registered new interface driver smsc75xx
[    2.670561] usbcore: registered new interface driver net1080
[    2.670590] usbcore: registered new interface driver cdc_subset
[    2.670618] usbcore: registered new interface driver zaurus
[    2.670662] usbcore: registered new interface driver cdc_ncm
[    2.670913] Wake76 for irq=199
[    2.670915] Wake77 for irq=199
[    2.670917] Wake78 for irq=199
[    2.670919] Wake79 for irq=199
[    2.670921] Wake80 for irq=199
[    2.670923] Wake81 for irq=199
[    2.670925] Wake82 for irq=199
[    2.670984] tegra-xotg xotg: usb2 phy is not available yet
[    2.671739] usbcore: registered new interface driver cdc_acm
[    2.671741] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.671784] usbcore: registered new interface driver usb-storage
[    2.671845] usbcore: registered new interface driver usbserial
[    2.671869] usbcore: registered new interface driver cp210x
[    2.671887] usbserial: USB Serial support registered for cp210x
[    2.671912] usbcore: registered new interface driver ftdi_sio
[    2.671932] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.671954] usbcore: registered new interface driver option
[    2.671970] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.671992] usbcore: registered new interface driver pl2303
[    2.672008] usbserial: USB Serial support registered for pl2303
[    2.672196] tegra-usb-cd usb_cd: otg phy is not available yet
[    2.673161] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b f8 4b 1a
[    2.673748] libphy: dwc_phy: probed
[    2.674649] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[    2.735526] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[    2.798679] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    2.800920] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    2.800933] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    2.801087] i2c /dev entries driver
[    2.801834] [OV5693]: probing v4l2 sensor.
[    2.982387] ata1: SATA link down (SStatus 0 SControl 300)
[    3.302776] tegradc 15210000.nvdisplay: fb registered
[    3.309481] PD DISP0 index2 UP
[    3.314653] PD DISP1 index3 UP
[    3.319187] PD DISP2 index4 UP
[    3.332823] Parent Clock set for DC plld2
[    3.339279] edid invalid
[    3.383632] edid invalid
[    3.387488] edid invalid
[    3.391342] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[    3.546619] tegradc 15210000.nvdisplay: blank - normal
[    3.550478] tegradc 15210000.nvdisplay: blank - powerdown
[    3.609185] PD DISP2 index4 DOWN
[    3.610254] PD DISP1 index3 DOWN
[    3.610822] PD DISP0 index2 DOWN
[    3.640610] tegradc 15210000.nvdisplay: unblank
[    3.640684] PD DISP0 index2 UP
[    3.647319] PD DISP1 index3 UP
[    3.647844] PD DISP2 index4 UP
[    3.663582] Parent Clock set for DC plld2
[    3.666548] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[    3.672664] gspca_main: v2.14.0 registered
[    3.672711] usbcore: registered new interface driver gspca_zc3xx
[    3.673046] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    3.675029] FAN dev name: pwm-fan
[    3.675078] FAN:gpio request success.
[    3.675083] FAN: can't find tach_gpio
[    3.675104] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    3.675267] pwm_fan_driver pwm-fan: got pwm for fan
[    3.675271] pwm_fan_driver pwm-fan: tach period: 1000
[    3.675588] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    3.675592] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    3.675595] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    3.675598] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    3.675600] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    3.675603] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    3.675606] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    3.675609] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    3.675612] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    3.675615] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    3.676401] device-mapper: uevent: version 1.0.3
[    3.676586] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.676960] sdhci: Secure Digital Host Controller Interface driver
[    3.676961] sdhci: Copyright(c) Pierre Ossman
[    3.676966] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.677253] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[    3.677549] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[    3.677788] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    3.679010] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    3.679134] hidraw: raw HID events driver (C) Jiri Kosina
[    3.680623] usbcore: registered new interface driver usbhid
[    3.680624] usbhid: USB HID core driver
[    3.685437] nvadsp 2993000.adsp: in probe()...
[    3.687349] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[    3.687375] nvadsp 2993000.adsp: AMC/ARAM initialized.
[    3.687560] nvadsp 2993000.adsp: nvadsp_app_module_probe
[    3.688308] Denver: backdoor interface is NOT available.
[    3.690021] coresight-tmc 8030000.etf: TMC initialized
[    3.690377] random: nonblocking pool is initialized
[    3.691182] coresight-tmc 8050000.etr: TMC initialized
[    3.691525] coresight-tpiu 8060000.tpiu: TPIU initialized
[    3.691812] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[    3.692028] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[    3.692239] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[    3.692625] coresight-replicator 8040000.replicator: REPLICATOR initialized
[    3.693053] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[    3.693410] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[    3.693770] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[    3.694131] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[    3.694154] Module initialized successfully
[    3.697469] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[    3.698666] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[    3.698853] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[    3.699260] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    3.699304] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[    3.699341] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[    3.699382] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[    3.699419] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[    3.699455] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[    3.699492] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[    3.699623] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[    3.699626] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    3.700561] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[    3.700564] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[    3.700566] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[    3.700568] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[    3.700571] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[    3.700573] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[    3.700575] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[    3.700600] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[    3.704504] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[    3.705274] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[    3.705384] camchar: rtcpu character device driver loaded
[    3.708851] tegra186-aondbg aondbg: aondbg driver probe() OK
[    3.709091] register_ari_mca_banks: Registered MCA ROC:IOB
[    3.709182] register_ari_mca_banks: Registered MCA ROC:CCE
[    3.709524] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    3.709553] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    3.709577] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    3.709600] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    3.709623] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    3.709649] tegra18-bridge 2100000.axip2p: bridge probed OK
[    3.709671] tegra18-bridge 2110000.axip2p: bridge probed OK
[    3.709694] tegra18-bridge 2120000.axip2p: bridge probed OK
[    3.709716] tegra18-bridge 2130000.axip2p: bridge probed OK
[    3.709739] tegra18-bridge 2140000.axip2p: bridge probed OK
[    3.709761] tegra18-bridge 2150000.axip2p: bridge probed OK
[    3.709782] tegra18-bridge 2160000.axip2p: bridge probed OK
[    3.709804] tegra18-bridge 2170000.axip2p: bridge probed OK
[    3.709827] tegra18-bridge 2180000.axip2p: bridge probed OK
[    3.709849] tegra18-bridge 2190000.axip2p: bridge probed OK
[    3.709900] **** A57 ECC: Enabled
[    3.709902] tegra18_a57_serr_init: on CPU 5 a A57 Core
[    3.710042] parse_throttle_dt_data: Num cap clks = 4
[    3.710045] parse_throttle_dt_data: clk=mcpu type=1
[    3.710047] parse_throttle_dt_data: clk=bcpu type=2
[    3.710052] parse_throttle_dt_data: clk=gpu type=4
[    3.710054] parse_throttle_dt_data: clk=emc type=3
[    3.710516] tegra_throttle_probe: probe successful. #cdevs=4
[    3.710602] tegra18x_actmon d230000.actmon: in actmon_register()...
[    3.713077] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    3.713392] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    3.714561] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.714892] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[    3.715187] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    3.716153] tegra-se-nvhost 15810000.se: initialized
[    3.716877] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    3.717205] tegra-se-nvhost 15820000.se: initialized
[    3.717638] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    3.717950] tegra-se-nvhost 15830000.se: initialized
[    3.718067] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    3.718394] tegra-se-nvhost 15840000.se: initialized
[    3.718776] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    3.722749] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    3.726125] cpufreq: platform driver Initialization: pass
[    3.726265] tegra_cluster_clk e090000.cluster_clk_priv: in probe()...
[    3.726315] tegra_cluster_clk e090000.cluster_clk_priv: passed
[    3.726514] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[    3.726518] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[    3.726553] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30c096
[    3.726556] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[    3.727755] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[    3.728277] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[    3.728786] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[    3.729168] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[    3.730734] cpuidle: Initializing cpuidle driver init for Denver cluster
[    3.730846] cpuidle: Initializing cpuidle driver init for A57 cluster
[    3.731736] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[    3.731739] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[    3.734540] tegra210_adsp_audio_platform_probe: platform probe started
[    3.735092] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[    3.735332] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[    3.735636] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[    3.735903] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[    3.738467] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[    3.738470] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[    3.738472] tegra210-adsp adsp_audio: using adma channel page 0
[    3.746685] tegra210_adsp_audio_platform_probe probe successfull.
[    3.746685] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    3.746846] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    3.749095] OPE platform probe
[    3.749167] OPE platform probe successful
[    3.750370] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.750600] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    3.750644] sdhci-tegra 3400000.sdhci: Got WP GPIO
[    3.750701] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[    3.750738] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[    3.751448] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    3.752655] mmc0: MAN_BKOPS_EN bit is not set
[    3.762762] mmc0: Skipping tuning since strobe enabled
[    3.770704] mmc0: periodic cache flush enabled
[    3.770713] mmc0: new HS400 MMC card at address 0001
[    3.771037] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[    3.771185] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[    3.771322] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[    3.771488] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[    3.772994]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[    3.790471] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.810765] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[    3.813494] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    3.813664] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    3.813835] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    3.814009] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    3.814151] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    3.814290] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    3.814463] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    3.814610] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    3.814729] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    3.814824] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    3.814925] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    3.815059] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    3.815162] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    3.815262] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    3.815380] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    3.815480] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    3.815590] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    3.815701] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    3.815801] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    3.815898] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    3.820260] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[    3.820367] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[    3.820396] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[    3.820421] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[    3.861037] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[    3.861781] tegra-snd-t186ref-mobile-rt565x sound: codec-dai "dit-hifi" registered
[    3.861784] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[    3.862637] GACT probability NOT on
[    3.862647] Mirror/redirect action on
[    3.862659] u32 classifier
[    3.862660]     Actions configured
[    3.862690] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[    3.863313] IPVS: Registered protocols ()
[    3.863350] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[    3.863419] IPVS: Creating netns size=1424 id=0
[    3.863449] IPVS: ipvs loaded.
[    3.863455] IPVS: [rr] scheduler registered.
[    3.863529] ipip: IPv4 over IPv4 tunneling driver
[    3.863861] Initializing XFRM netlink socket
[    3.864137] NET: Registered protocol family 10
[    3.864862] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.864934] NET: Registered protocol family 17
[    3.864948] NET: Registered protocol family 15
[    3.864972] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.864978] 8021q: 802.1Q VLAN Support v1.8
[    3.865622] Registered cp15_barrier emulation handler
[    3.865644] Registered setend emulation handler
[    3.867579] registered taskstats version 1
[    3.871184] isp 15600000.isp: initialized
[    3.875692] nvcsi 150c0000.nvcsi: initialized
[    3.876811] Wake76 for irq=199
[    3.876812] Wake77 for irq=199
[    3.876813] Wake78 for irq=199
[    3.876814] Wake79 for irq=199
[    3.876815] Wake80 for irq=199
[    3.876815] Wake81 for irq=199
[    3.876816] Wake82 for irq=199
[    3.877141] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[    3.877143] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[    3.898640] spi-tegra114 3210000.spi: Static pin configuration used
[    3.898792] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[    3.898794] xhci-tegra 3530000.xhci: Falling back to user helper
[    3.899290] spi-tegra114 c260000.spi: Static pin configuration used
[    3.900006] spi-tegra114 3240000.spi: Static pin configuration used
[    3.900730] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[    3.900764] tegra-xotg xotg: update_id_state: ID floating
[    3.900768] tegra-xotg xotg: update_vbus_state: VBUS detected
[    3.900781] tegra-xotg xotg: Nvidia XUSB OTG Controller
[    3.902504] tegra-xotg xotg: otg: gadget gadget registered
[    3.902506] tegra-xotg xotg: set gadget otg_caps from OTG controller
[    3.902507] tegra-xotg xotg: otg: host not registered yet
[    3.902509] tegra-xotg xotg: otg: start OTG finite state machine
[    3.902557] tegra-xudc-new 3550000.xudc: entering ELPG
[    3.903115] tegra-xudc-new 3550000.xudc: entering ELPG done
[    3.903539] input: gpio-keys as /devices/gpio-keys/input/input3
[    3.937351] tegra_rtc c2a0000.rtc: setting system clock to 2020-06-16 08:51:14 UTC (1592297474)
[    3.967578] bpmp: mounted debugfs mirror
[    3.968063] [dram-timers] DRAM derating cdev registered.
[    3.972372] spmic-ldo0: disabling
[    3.972577] spmic-ldo1: disabling
[    3.972754] en-vdd-cam: disabling
[    3.972757] vdd-usb0-5v: disabling
[    3.972758] vdd-usb1-5v: disabling
[    3.972761] en-vdd-disp-3v3: disabling
[    3.972762] en-mdm-pwr-3v7: disabling
[    3.972764] en-vdd-disp-1v8: disabling
[    3.972765] en-vdd-cam-hv-2v8: disabling
[    3.972766] en-vdd-cam-1v2: disabling
[    3.972768] vdd-fan: disabling
[    3.972769] vdd-3v3: disabling
[    3.972771] en-vdd-vcm-2v8: disabling
[    3.972772] vdd-usb2-5v: disabling
[    3.972774] vdd-sys-bl: disabling
[    3.972775] en-vdd-sys: disabling
[    3.978830] ALSA device list:
[    3.978832]   #0: tegra-hda at 0x3518000 irq 400
[    3.978833]   #1: tegra-snd-t186ref-mobile-rt565x
[    3.980219] tegra-vi4 15700000.vi: initialized
[    3.981378] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[    3.981381] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[    4.008600] mmc1 tuning done saved tap delay=60
[    4.008602] mmc1: hw tuning done ...
[    4.008609] mmc1: tuning_window[0]: 0xffffffff
[    4.008615] mmc1: tuning_window[1]: 0xfffffe7f
[    4.008619] mmc1: tuning_window[2]: 0xfff9ffff
[    4.008624] mmc1: tuning_window[3]: 0x63ffffff
[    4.008628] mmc1: tuning_window[4]: 0x0
[    4.008633] mmc1: tuning_window[5]: 0x0
[    4.008656] mmc1: tuning_window[6]: 0x0
[    4.008661] mmc1: tuning_window[7]: 0x0
[    4.008664] sdhci: Tap value: 60 | Trim value: 5
[    4.008667] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[    4.014486] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    4.014530] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    4.054412] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[    4.054416] tegra-usb-cd usb_cd: set current 0ma
[    4.054424] tegra-xudc-new 3550000.xudc: exiting ELPG
[    4.055429] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    4.055432] tegra-xudc-new 3550000.xudc: device mode on
[    6.680032] tegradc 15210000.nvdisplay: hdmi: plugged
[    6.817236] EXT4-fs (mmcblk0p1): recovery complete
[    6.823986] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    6.833474] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    6.841672] devtmpfs: mounted
[    6.846375] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[    6.855699] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[    6.875436] btb inv war enabled
[    6.943658] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -ID)
[    6.963708] systemd[1]: Detected architecture arm64.
[    6.980535] systemd[1]: Set hostname to <tegra-ubuntu>.
[    7.126048] systemd[1]: Reached target Swap.
[    7.133970] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.143872] systemd[1]: Created slice System Slice.
[    7.152223] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    7.163121] systemd[1]: Created slice User and Session Slice.
[    7.172337] systemd[1]: Reached target Encrypted Volumes.
[    7.182823] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.193203] systemd[1]: Reached target Slices.
[    7.200530] systemd[1]: Listening on udev Kernel Socket.
[    7.208577] systemd[1]: Listening on udev Control Socket.
[    7.217777] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.226891] systemd[1]: Listening on Syslog Socket.
[    7.234783] systemd[1]: Listening on Journal Socket.
[    7.244851] systemd[1]: Started Braille Device Support.
[    7.256032] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    7.271607] systemd[1]: Mounting Debug File System...
[    7.285530] systemd[1]: Starting Load Kernel Modules...
[    7.296653] systemd[1]: Mounting POSIX Message Queue File System...
[    7.301295] vcan: Virtual CAN interface driver
[    7.305594] can: controller area network core (rev 20120528 abi 9)
[    7.305632] NET: Registered protocol family 29
[    7.308329] can: raw protocol (rev 20120528)
[    7.310916] CAN device driver interface
[    7.322562]   Message RAM Configuration
[    7.322562]  | base addr   |0x0c312000|
[    7.322562]  | sidfc_flssa |0x00000000|
[    7.322562]  | xidfc_flesa |0x00000040|
[    7.322562]  | rxf0c_f0sa  |0x000000c0|
[    7.322562]  | rxf1c_f1sa  |0x00000300|
[    7.322562]  | rxbc_rbsa   |0x00000540|
[    7.322562]  | txefc_efsa  |0x00000780|
[    7.322562]  | txbc_tbsa   |0x00000800|
[    7.322562]  | tmc_tmsa    |0x00000c80|
[    7.322731] Release 3.2.0 from 19.12.2014
[    7.322957] net can0: mttcan device registered (regs=ffffff800247e000, irq=427)
[    7.324021]   Message RAM Configuration
[    7.324021]  | base addr   |0x0c322000|
[    7.324021]  | sidfc_flssa |0x00000000|
[    7.324021]  | xidfc_flesa |0x00000040|
[    7.324021]  | rxf0c_f0sa  |0x000000c0|
[    7.324021]  | rxf1c_f1sa  |0x00000300|
[    7.324021]  | rxbc_rbsa   |0x00000540|
[    7.324021]  | txefc_efsa  |0x00000780|
[    7.324021]  | txbc_tbsa   |0x00000800|
[    7.324021]  | tmc_tmsa    |0x00000c80|
[    7.324188] Release 3.2.0 from 19.12.2014
[    7.324363] net can1: mttcan device registered (regs=ffffff80026fe000, irq=428)
[    7.476639] systemd[1]: Starting Set console keymap...
[    7.485248] systemd[1]: Listening on Journal Audit Socket.
[    7.497193] systemd[1]: Starting Journal Service...
[    7.508569] systemd[1]: Mounting RPC Pipe File System...
[    7.519990] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.548434] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    7.551220] systemd[1]: Reached target User and Group Name Lookups.
[    7.568869] systemd[1]: Mounted RPC Pipe File System.
[    7.577178] systemd[1]: Mounted Debug File System.
[    7.584940] systemd[1]: Mounted POSIX Message Queue File System.
[    7.594018] systemd[1]: Started Journal Service.
[    7.683976] systemd-journald[296]: Received request to flush runtime journal from PID 1
[    7.959465] xhci-tegra 3530000.xhci: cannot find firmware....retry after 1 second
[    7.961326] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[    7.962207] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    7.962634] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[    7.964845] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    8.092120] dhd_module_init in
[    8.097297] tegra_net_perf_init: cannot get wifi sclk
[    8.104285] found wifi platform device bcmdhd_wlan
[    8.112163] wifi_platform_get_country_code_map: could not get country_code_map
[    8.121245] wifi_plat_dev_drv_probe:platform country code map is not available
[    8.121261] Power-up adapter 'DHD generic adapter'
[    8.121267] wifi_platform_set_power = 1
[    8.322367] wifi_platform_bus_enumerate device present 1
[    8.348798] wifi_platform_bus_enumerate device present 0
[    8.356300] F1 signature read @0x18000000=0x17214354
[    8.367973] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[    8.376697] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[    8.385474] wifi_platform_prealloc: failed to alloc static mem section 7
[    8.394030] wifi_platform_get_mac_addr
[    8.396365] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    8.644425] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[    8.656813] wl_create_event_handler(): thread:wl_event_handler:263 started
[    8.657022] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc070b41a70
[    8.675694] dhd_attach(): thread:dhd_watchdog_thread:264 started
[    8.684766] dhd_attach(): thread:dhd_dpc:265 started
[    8.691955] dhd_attach(): thread:dhd_rxf:266 started
[    8.698812] dhd_deferred_work_init: work queue initialized
[    8.707736] Dongle Host Driver, version 1.201.82 (r)
[    8.707736] Compiled in drivers/net/wireless/bcmdhd on May 17 2018 at 00:12:47
[    8.724165] tegra_sysfs_register
[    8.729391] Register interface [wlan0]  MAC: 00:04:4b:f8:4b:18
[    8.729391]
[    8.740520] dhd_prot_ioctl : bus is down. we have nothing to do
[    8.748898] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[    8.759914] wifi_platform_set_power = 0
[    8.798373] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    8.972134] node[604]: syscall 291
[    8.978256] Code: aa0503e4 aa0603e5 aa0703e6 d4000001 (b13ffc1f)
[    8.987736] CPU: 3 PID: 604 Comm: node Not tainted 4.4.38-tegra #1
[    8.995991] Hardware name: quill (DT)
[    9.001286] task: ffffffc06fea0000 ti: ffffffc0724bc000 task.ti: ffffffc0724bc000
[    9.010013] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[    9.012202] xhci-tegra 3530000.xhci: xHCI Host Controller
[    9.012217] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[    9.013009] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[    9.013033] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[    9.013160] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    9.013163] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.013165] usb usb1: Product: xHCI Host Controller
[    9.013167] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[    9.013168] usb usb1: SerialNumber: 3530000.xhci
[    9.013455] hub 1-0:1.0: USB hub found
[    9.013699] hub 1-0:1.0: 4 ports detected
[    9.050520] xhci-tegra 3530000.xhci: xHCI Host Controller
[    9.050526] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[    9.050647] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    9.050650] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.050652] usb usb2: Product: xHCI Host Controller
[    9.050654] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[    9.050656] usb usb2: SerialNumber: 3530000.xhci
[    9.050923] hub 2-0:1.0: USB hub found
[    9.050942] hub 2-0:1.0: 3 ports detected
[    9.051300] tegra-xotg xotg: otg: host 3530000.xhci registered
[    9.150534] xhci-tegra 3530000.xhci: entering ELPG
[    9.153104] xhci-tegra 3530000.xhci: entering ELPG done
[    9.183792] PC is at 0x7f7c0abb44
[    9.188527] LR is at 0x12a3fbc
[    9.188530] pc : [<0000007f7c0abb44>] lr : [<00000000012a3fbc>] pstate: 60000000
[    9.188551] sp : 0000007fc1a29bd0
[    9.188567] x29: 0000007fc1a29bd0 x28: 00000000819f9ee2
[    9.188572] x27: 0000007fc1a29e50 x26: 0000000000000000
[    9.188575] x25: 0000000000000004 x24: 00000000009edf90
[    9.188578] x23: 0000007fc1a29fa0 x22: 0000007fc1a2a020
[    9.188581] x21: 0000000002758000 x20: 0000007f7c41e748
[    9.188584] x19: 0000007fc1a29ec0 x18: 0000000000000000
[    9.188587] x17: 0000007f7c0abb20 x16: 000000000273fc88
[    9.188591] x15: 001dcd6500000000 x14: 000cb7e1e0000000
[    9.188594] x13: ffffffffa1177801 x12: 0000000000000017
[    9.188597] x11: 0000007fc1a2a648 x10: 000000000000000e
[    9.188600] x9 : 000000004d8ee587 x8 : 0000000000000123
[    9.188604] x7 : 732f6372732f7265 x6 : 732f6372732f7265
[    9.188607] x5 : 0000007fc1a2a048 x4 : 0000007fc1a29c10
[    9.188610] x3 : 0000000000000fff x2 : 0000000000000000
[    9.188613] x1 : 0000007fc1a2a020 x0 : 00000000ffffff9c
[    9.188614]
[    9.210436] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    9.212450] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[    9.612394] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[   10.022429] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[   10.404396] using random self ethernet address
[   10.410580] using random host ethernet address
[   10.431383] mttcan c310000.mttcan can0: Bitrate set
[   10.440351] mttcan_controller_config: ctrlmode 30
[   10.444103] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[   10.446118] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[   10.446124] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[   10.446480] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[   10.477905] mttcan c310000.mttcan can0: Bitrate set
[   10.491919] mttcan c320000.mttcan can1: Bitrate set
[   10.501105] mttcan_controller_config: ctrlmode 30
[   10.501259] Mass Storage Function, version: 2009/09/11
[   10.501262] LUN: removable file: (no medium)
[   10.505313] using random self ethernet address
[   10.505316] using random host ethernet address
[   10.529808] mttcan c320000.mttcan can1: Bitrate set
[   10.540486] usb0: HOST MAC 26:00:3d:59:cf:d1
[   10.546715] usb0: MAC ee:b4:61:12:69:d1
[   10.552690] usb1: HOST MAC f2:76:4d:f5:ee:31
[   10.558892] usb1: MAC 5a:f8:93:3a:c0:de
[   10.564563] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[   10.741760] device usb0 entered promiscuous mode
[   10.752557] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[   10.764545] device usb1 entered promiscuous mode
[   10.772013] android_work: did not send uevent (0 0           (null))
[   10.775049] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[   10.775054] l4tbr0: port 2(usb1) entered forwarding state
[   10.775067] l4tbr0: port 2(usb1) entered forwarding state
[   10.845000] android_work: sent uevent USB_STATE=CONNECTED
[   10.900108] android_work: sent uevent USB_STATE=DISCONNECTED
[   10.993148] android_work: sent uevent USB_STATE=CONNECTED
[   11.001655] configfs-gadget gadget: high-speed config #1: c
[   11.008975] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[   11.017407] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[   11.025821] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[   11.034376] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[   11.042775] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[   11.051157] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[   11.059632] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[   11.068085] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[   11.076518] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[   11.076565] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[   11.076630] l4tbr0: port 1(usb0) entered forwarding state
[   11.076648] l4tbr0: port 1(usb0) entered forwarding state
[   11.076699] android_work: sent uevent USB_STATE=CONFIGURED
[   11.116951] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[   11.125348] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[   11.133884] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[   12.183758] gk20a 17000000.gp10b: railgate is disabled.
[   12.616069] IPVS: Creating netns size=1424 id=1
[   13.091729] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.103084] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.652829] Bridge firewalling registered
[   15.429144] cfg80211: World regulatory domain updated:
[   15.429153] cfg80211:  DFS Master region: unset
[   15.429154] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   15.429163] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.429170] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   15.429176] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   15.429181] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   15.429188] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   15.429193] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   15.429197] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   15.429202] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   15.719217] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   15.732081]
[   15.732081] Dongle Host Driver, version 1.201.82 (r)
[   15.732081] Compiled in drivers/net/wireless/bcmdhd on May 17 2018 at 00:12:47
[   15.762869] wl_android_wifi_on in
[   15.771954] wifi_platform_set_power = 1
[   16.020972] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[   16.071515] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[   16.156783] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 60
[   16.179048] F1 signature read @0x18000000=0x17214354
[   16.214873] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[   16.229824] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   16.415194] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   16.510661] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   16.528145] Enabling wake69
[   16.539469] wifi_platform_get_mac_addr
[   16.558886] Firmware up: op_mode=0x0002, MAC=00:04:4b:f8:4b:18
[   16.609081] Bluetooth: Core ver 2.21
[   16.610201] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[   16.614878] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-e35dbe99
[   16.618132] dhd_interworking_enable: failed to set WNM info, ret=-23
[   16.618467] tegra_sysfs_on
[   16.672568] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.682640] NET: Registered protocol family 31
[   16.682647] Bluetooth: HCI device and connection manager initialized
[   16.682662] Bluetooth: HCI socket layer initialized
[   16.682680] Bluetooth: L2CAP socket layer initialized
[   16.682709] Bluetooth: SCO socket layer initialized
[   16.751547] Bluetooth: HCI UART driver ver 2.3
[   16.766445] Bluetooth: HCI UART protocol H4 registered
[   16.920526] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.938017] Bluetooth: BNEP socket layer initialized
Ubuntu 16.04.6 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: nvidia (automatic login)
Last login: Tue Jun 16 10:47:53 CEST 2020 on ttyS0
Welcome to Ubuntu 16.04.6 LTS (GNU/Linux 4.4.38-tegra aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
108 packages can be updated.
8 updates are security updates.
New release '18.04.4 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
nvidia@tegra-ubuntu:~$ se[   20.001083] Unable to handle kernel NULL pointer dereference at virtual address 00000068
[   20.009434] pgd = ffffffc06d9dc000
[   20.013016] [00000068] *pgd=00000000efc9b003, *pud=00000000efc9b003, *pmd=0000000000000000
[   20.021675] Internal error: Oops: 96000006 [#1] PREEMPT SMP
[   20.027376] Modules linked in: bnep hci_uart bluetooth nf_nat(+) br_netfilter overlay bcmdhd pci_tegra mttcan can_dev can_raw can vcan bluedroid_pm
[   20.041204] CPU: 0 PID: 849 Comm: python3 Not tainted 4.4.38-tegra #1
[   20.047783] Hardware name: quill (DT)
[   20.051533] task: ffffffc070b6f080 ti: ffffffc06d720000 task.ti: ffffffc06d720000
[   20.059184] PC is at fib_table_lookup+0x3c/0x3e8
[   20.063909] LR is at ip_route_input_noref+0x5bc/0x8b0
[   20.069067] pc : [<ffffffc000a88f40>] lr : [<ffffffc000a427b4>] pstate: 60000045
[   20.076612] sp : ffffffc06d7238f0
[   20.080005] x29: ffffffc06d7238f0 x28: ffffffc0012873c8
[   20.085477] x27: 0000000000000000 x26: ffffffc0013dfe00
[   20.090944] x25: ffffffc06d723990 x24: 0000000000000000
[   20.096411] x23: 00000000fffffff5 x22: 00000000ff01a8c0
[   20.101880] x21: 0000000000000001 x20: ffffffc06d7239c8
[   20.107370] x19: 0000000000000040 x18: 0000000000000001
[   20.112834] x17: 0000007f7c946340 x16: 0000000000743568
[   20.118326] x15: 0000000000000001 x14: 000000000005be68
[   20.123821] x13: 0000000000000001 x12: ffffffc06faeba78
[   20.129326] x11: 0000000000000004 x10: 00000000ffffff00
[   20.134824] x9 : ffffffc075e4a430 x8 : 00000000000000db
[   20.140286] x7 : 0000000000000002 x6 : 00000000000000db
[   20.145750] x5 : 0000000000000006 x4 : ffffffc001414518
[   20.151233] x3 : 0000000000000001 x2 : ffffffc06d7239c8
[   20.156738] x1 : 0000000000000000 x0 : 0000000000000040
[   20.162201]
[   20.163742] Process python3 (pid: 849, stack limit = 0xffffffc06d720020)
[   20.170583] Call trace:
[   20.173105] [<ffffffc000a88f40>] fib_table_lookup+0x3c/0x3e8
[   20.178895] [<ffffffc000a427b4>] ip_route_input_noref+0x5bc/0x8b0
[   20.185127] [<ffffffc000a45de8>] ip_rcv_finish+0xe4/0x2d4
[   20.190648] [<ffffffc000a46470>] ip_rcv+0x268/0x36c
[   20.195641] [<ffffffc0009e006c>] __netif_receive_skb_core+0x2b4/0xa1c
[   20.202241] [<ffffffc0009e2cfc>] __netif_receive_skb+0x2c/0x84
[   20.208218] [<ffffffc0009e2d94>] netif_receive_skb_internal+0x40/0xbc
[   20.214803] [<ffffffc0009e37a8>] napi_gro_receive+0xbc/0x198
[   20.220607] [<ffffffc0006af8b4>] process_rx_completions+0x43c/0x68c
[   20.227112] [<ffffffc0006acf20>] eqos_napi_mq+0xa0/0x254
[   20.232551] [<ffffffc0009e49a0>] net_rx_action+0x12c/0x364
[   20.238157] [<ffffffc0000a8cfc>] __do_softirq+0x10c/0x368
[   20.243669] [<ffffffc0000a91b0>] irq_exit+0x84/0xdc
[   20.248654] [<ffffffc0000f4f84>] __handle_domain_irq+0x6c/0xb4
[   20.254615] [<ffffffc000081774>] gic_handle_irq+0x5c/0xb4
[   20.260135] [<ffffffc000084dd8>] el0_irq_naked+0x1c/0x24
[   20.266245] ---[ end trace d68ad04dcb97bb80 ]---
[   20.274683] Kernel panic - not syncing: Fatal exception in interrupt
[   20.281191] CPU4: stopping
[   20.283997] CPU: 4 PID: 1281 Comm: modprobe Tainted: G      D         4.4.38-tegra #1
[   20.291989] Hardware name: quill (DT)
[   20.295733] Call trace:
[   20.298253] [<ffffffc000089860>] dump_backtrace+0x0/0x100
[   20.303771] [<ffffffc000089a28>] show_stack+0x14/0x1c
[   20.308937] [<ffffffc00033cdf8>] dump_stack+0x98/0xc0
[   20.314098] [<ffffffc00008f468>] handle_IPI+0x300/0x30c
[   20.319436] [<ffffffc0000817b4>] gic_handle_irq+0x9c/0xb4
[   20.324950] [<ffffffc000084740>] el1_irq+0x80/0xf8
[   20.329866] [<ffffffbffcef2060>] nf_nat_init+0x60/0xc0 [nf_nat]
[   20.335911] [<ffffffc000081c54>] do_one_initcall+0xc8/0x1c0
[   20.341607] [<ffffffc00016fd80>] do_init_module+0x64/0x1c0
[   20.347211] [<ffffffc000120f14>] load_module+0xda0/0x107c
[   20.352723] [<ffffffc00012140c>] SyS_finit_module+0x94/0xbc
[   20.358416] [<ffffffc000084ff0>] el0_svc_naked+0x24/0x28
[   20.369368] CPU3: stopping
[   20.378099] CPU: 3 PID: 1703 Comm: python3 Tainted: G      D         4.4.38-tegra #1
[   20.391975] Hardware name: quill (DT)
[   20.401615] Call trace:
[   20.409885] [<ffffffc000089860>] dump_backtrace+0x0/0x100                           +-----------------------------+
[   20.421094] [<ffffffc000089a28>] show_stack+0x14/0x1c                               |                             |
[   20.431853] [<ffffffc00033cdf8>] dump_stack+0x98/0xc0                               |  Cannot open /dev/ttyUSB0!  |
[   20.442406] [<ffffffc00008f468>] handle_IPI+0x300/0x30c                             |                             |
[   20.452938] [<ffffffc0000817b4>] gic_handle_irq+0x9c/0xb4                           +-----------------------------+
[   20.463600] [<ffffffc000084dd8>] el0_irq_naked+0x1c/0x24
[   20.474125] CPU1: stopping
[   20.481848] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D         4.4.38-tegra #1
[   20.494193] Hardware name: quill (DT)
[   20.502387] Call trace:
[   20.509334] [<ffffffc000089860>] dump_backtrace+0x0/0x100
[   20.519190] [<ffffffc000089a28>] show_stack+0x14/0x1c
[   20.528700] [<ffffffc00033cdf8>] dump_stack+0x98/0xc0
[   20.538183] [<ffffffc00008f468>] handle_IPI+0x300/0x30c
[   20.547822] [<ffffffc0000817b4>] gic_handle_irq+0x9c/0xb4
[   20.557640] [<ffffffc000084740>] el1_irq+0x80/0xf8
[   20.566839] [<ffffffc000820d20>] cpuidle_enter+0x18/0x20
[   20.576572] [<ffffffc0000e8354>] call_cpuidle+0x28/0x50
[   20.586223] [<ffffffc0000e84f8>] cpu_startup_entry+0x17c/0x340
[   20.596511] [<ffffffc00008ee44>] secondary_start_kernel+0x12c/0x164
[   20.607261] [<0000000080081acc>] 0x80081acc
[   20.615869] CPU5: stopping
[   20.623576] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G      D         4.4.38-tegra #1
[   20.636294] Hardware name: quill (DT)
[   20.645011] Call trace:
[   20.652511] [<ffffffc000089860>] dump_backtrace+0x0/0x100
[   20.663007] [<ffffffc000089a28>] show_stack+0x14/0x1c
[   20.673103] [<ffffffc00033cdf8>] dump_stack+0x98/0xc0
[   20.683130] [<ffffffc00008f468>] handle_IPI+0x300/0x30c
[   20.693284] [<ffffffc0000817b4>] gic_handle_irq+0x9c/0xb4
[   20.703594] [<ffffffc000084740>] el1_irq+0x80/0xf8
[   20.713287] [<ffffffc0000c94bc>] finish_task_switch+0xa0/0x1f0
[   20.724393] [<ffffffc000b78f3c>] __schedule+0x254/0x6d4
[   20.734866] [<ffffffc000b79400>] schedule+0x44/0xa8
[   20.745002] [<ffffffc000b797ec>] schedule_preempt_disabled+0x20/0x3c
[   20.756632] [<ffffffc0000e848c>] cpu_startup_entry+0x110/0x340
[   20.767731] [<ffffffc00008ee44>] secondary_start_kernel+0x12c/0x164
[   20.779263] [<0000000080081acc>] 0x80081acc
[   20.788697] CPU2: stopping
[   20.813480] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G      D         4.4.38-tegra #1
[   20.843428] Hardware name: quill (DT)
[   20.869169] Call trace:
[   20.893578] [<ffffffc000089860>] dump_backtrace+0x0/0x100
[   20.921292] [<ffffffc000089a28>] show_stack+0x14/0x1c
[   20.948600] [<ffffffc00033cdf8>] dump_stack+0x98/0xc0
[   20.975736] [<ffffffc00008f468>] handle_IPI+0x300/0x30c
[   21.002843] [<ffffffc0000817b4>] gic_handle_irq+0x9c/0xb4
[   21.029923] [<ffffffc000084740>] el1_irq+0x80/0xf8
[   21.056149] [<ffffffc000820d20>] cpuidle_enter+0x18/0x20
[   21.082730] [<ffffffc0000e8354>] call_cpuidle+0x28/0x50
[   21.109250] [<ffffffc0000e84f8>] cpu_startup_entry+0x17c/0x340
[   21.136384] [<ffffffc00008ee44>] secondary_start_kernel+0x12c/0x164
[   21.164019] [<0000000080081acc>] 0x80081acc
[   21.209127] Rebooting in 5 seconds..
What is going on there?
Is it possible to flash the kernel without flashing the image?
I figured out that the SDKManager 1.0.1 is using L4T 28.3.1, but on the Jetson TX2 I took the image from does have L4T 28.2.1, is this the source of the error? How can I select another version?
SDK Manager is just an addition or successor to JetPack. I don’t know the details, but so far as I know SDKM reuses most of JetPack, but adds some other features in support of newer L4T releases. SDKM became available starting with the L4T R32.x series.
If your original is R28.2.1, then the R28.3.x will probably have problems. The JetPack release which corresponds to R28.2.1 is JetPack3.3:
https://developer.nvidia.com/embedded/jetpack-3_3
(you will probably need to go to that URL, log in, and click the link again to see content)
There might be things you can do to get an R28.2.1 image to work with R28.3.1, but if you are making this upgrade to get a newer CUDA release, then this won’t work. The CUDA release is tightly coupled to other dependencies in the operating system.
On the other hand, if you have a raw image clone, then you can loopback mount this and copy various content into a new R28.3.1 environment. Sparse images won’t work for this. You might want to add details of your use case and why you want to use an R28.2.1 rootfs clone with R28.3.1 flash software.
Thanks for your reply again!
I will try jetpack-3.3 as soon as I’m back to office.
But for my understanding, shouldn’t be I able to flash the kernel, the image and other stuff from command line? In a way that I only flash what I really want and make it run that way? Withou SDK Manager and co.?
The requirements or availability of various kernel and device tree flashes changes depending on release, and I would have to look at a specific release and look closer at docs to give you a definite answer. In general though, the kernel Image file mostly just gets added to “/boot” (if your system boots and runs, then just copy the file and don’t worry about flashing and recovery mode).
There are places where device tree can be added to “/boot/dtb/”, or to a partition. If in a partition, then generally early boot stages need the tree, and the next stage actually inherits from the previous stage instead of loading directly from a file. Those earlier stages tend to make some edits to the tree before passing it on, and so it would depend on the particular part of the tree as to whether placing the content in “/boot/dtb/” would actually work.
Both of the above are complicated in cases where boot security is enabled. Even among releases this changes, but generally speaking, once signing became part of the boot, some methods stopped working without effort to sign. Again, this would require reading the docs to a particular release to know what works.
As far as flashing just a kernel goes, if it is just an Image file, then why not just copy to “/boot”? Then again, if you are using an initrd, then you have two places to update the kernel. If the initrd is part of signed boot content (and probably it is not, but you could do this if it is a partition and part of the pre-boot execution environment), then updating the kernel would also require signing (but an Image file in “/boot” would not require signing). It depends on which part of the boot is looking at the content.
The flash software works with multiple devices, and has evolved over a lot of releases (I have some Tegra 3 hardware here which used an R16.x release…and some of that content is still the same even now due to inheritance). Some of that content is leftover in the context of a particular hardware, or in the context of a particular release. The only way to know what you can truly do is to read the actual docs. If you don’t mind a risk of it not booting, e.g., you have a clone or you are just testing with no valuable content, then you can find out (probably faster than reading the docs) just by testing it. The best answer on this is read the docs for that release.
Btw, since the content other than kernel or rootfs is never used once boot completes, then the only reason you would avoid flashing it all would be to update in place where recovery mode and the micro-USB cannot be reached. There is hardly any flash time involved in updating those smaller partitions, and signing will be correct without having to manually sign anything. If your content is really valuable, then you need a clone anyway or you have a future disaster looking for a time to happen. If you have a clone in place, then you use the “-r” option to not regenerate the image, and flash time is faster (the “-r” implies you don’t generate a new image and use the image already there). If you are replacing a kernel, isn’t it easier to just copy “Image” to “/boot”? If you are adding a module, then isn’t it easier to just copy to the right location under “/lib/modules/$(uname -r)/kernel”?
I have not read the R28.x docs in some time, but just copying files tends to be easier in those releases, e.g., when device tree is named in extlinux.conf and no signing occurs.
Btw, you never need SDK Manager to flash. This is just a utility front end. If you are adding extra optional packages, then you need SDK Manager, but only after flash completes (newer releases can even skip this and use “apt-get” if you know what you want to add). It is the “driver package” and “sample rootfs” which are used for flash, where JetPack/SDKM downloads it and adds a GUI display. I run Fedora, and JetPack/SDKM won’t run on it, but unless I am dealing with an optional file I run flash.sh manually. It’s easier than SDKM in my opinion.
Now if you have a clone, then you don’t even need the sample rootfs.
Someone else may have better details for the R28.2.1 release, but even so, you would need to explain what use case you have which makes you want to use flash for a specific content instead of just copying files (or whatever you want to change relative to the official docs for that release).
Thanks for your detailed answer. Now I do understand much more.
I made anything work taking the snapshot and flashing it with the Jetpack version you posted. I wasn’t aware off that the version of the image goes in hand with the Jetpack version I flash the image with.
For me now it’s still interesting to understand the problem in more detail.
Is the problem there, that the Jetpack is flashing his own kernel and then the image does not fit the flashed kernel?
Yes, a certain rootfs (and other partition) size exists, and if non-default sizes exist, then you want to use the “-S size” to set this. This is a default TX2 flash on command line:
sudo ./flash.sh jetson-tx2 mmcblk0p1
For reference before explaining image sizes, a “raw” image and a “sparse” image flash and result in the same thing. A “raw” image though can be manipulated, examined, so on. A “sparse” image is much smaller (if not a full filesystem), and flashes faster, but has no difference in end partition size. A regular flash creates “Linux_for_Tegra/bootloader/system.img.raw” and “Linux_for_Tegra/bootloader/system.img”, where the sparse “.img” is created from the raw “.img.raw” is created. One could rename the “.img.raw” to “.img” and it would just take long to flash. The exact byte size of the raw image is used in custom partition size options after abbreviating for “MiB” or “GiB”. If defaults were used throughout, then specifying size does not matter.
If your “Linux_for_Tegra/bootloader/system.img.raw” size (or the raw clone used to create “Linux_for_Tegra/bootloader/system.img”) is exactly 30064771072 bytes, then the size, abbreviated, is either of:
  • 28672MiB (30064771072 divided twice by 1024).
  • 28GiB (30064771072 divided three times by 1024).
If I were to flash and specify this partition size, then either of these would work:
sudo ./flash.sh -S 28672MiB jetson-tx2 mmcblk0p1
sudo ./flash.sh -S 28GiB  jetson-tx2 mmcblk0p1
If your partition is already that size, then there is no need to specify, but any partition is a wrong size, then you risk either truncating an image or overwriting another partition. I’m not sure which would occur during a flash, possibly the flash would stop with a failure, possibly the flash would happily do the wrong thing.
