Which part would you like to see? The log is too long and I cant paste it all here:
This is the last part of the log:
pre-flash: duration: 00:01:17
post-flash: duration: 00:11:40
*** End of Dialogs Timing Summary ***
10:30:12.938 - info:
*** Download Summary ***
- Bundle: JetPack 5.0.2 (rev. 1) Linux for Jetson AGX Xavier modules
- Download server: DevZone
- 0B downloaded of 9.47GB
- Download started on: Mon Jan 16 2023 10:09:34 GMT+0800 (Singapore Standard Time).
- Download ended on: Mon Jan 16 2023 10:30:12 GMT+0800 (Singapore Standard Time).
- Download duration: 00:20:38.
- Average total download speed: 0B/s = total downloaded bytes / download duration.
- Average total bandwidth: 0B/s, average accumulation of all file chunk's speed, downloaded concurrently.
- Average file chunk's download speed: 0B/s, average of all downloaded file chunk's speed.
- Max 6 concurrent files using 12 threads.
Total 53 files:
- 0 downloaded, 35 cached, 0 failed, 18 skipped
Details:
- libnvonnxparsers8_8.4.1-1+cuda11.4_arm64.deb: Cached.
- libnvonnxparsers-dev_8.4.1-1+cuda11.4_arm64.deb: Cached.
- OpenCV-4.5.4-8-g3e4c170df4-aarch64-licenses.deb: Cached.
- OpenCV-4.5.4-8-g3e4c170df4-aarch64-dev.deb: Cached.
- OpenCV-4.5.4-8-g3e4c170df4-aarch64-samples.deb: Cached.
- libnvinfer-plugin8_8.4.1-1+cuda11.4_arm64.deb: Cached.
- OpenCV-4.5.4-8-g3e4c170df4-aarch64-python.deb: Cached.
- libnvinfer-plugin-dev_8.4.1-1+cuda11.4_arm64.deb: Cached.
- OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb: Cached.
- libnvparsers8_8.4.1-1+cuda11.4_arm64.deb: Cached.
- libnvparsers-dev_8.4.1-1+cuda11.4_arm64.deb: Cached.
- libnvinfer-bin_8.4.1-1+cuda11.4_arm64.deb: Cached.
- tensorrt_8.4.1.5-1+cuda11.4_arm64.deb: Cached.
- python3-libnvinfer_8.4.1-1+cuda11.4_arm64.deb: Cached.
- vpi-dev-2.1.6-aarch64-l4t.deb: Cached.
- vpi-python3.8-2.1.6-aarch64-l4t.deb: Cached.
- vpi-python3.9-2.1.6-aarch64-l4t.deb: Cached.
- graphsurgeon-tf_8.4.1-1+cuda11.4_arm64.deb: Cached.
- python3-libnvinfer-dev_8.4.1-1+cuda11.4_arm64.deb: Cached.
- uff-converter-tf_8.4.1-1+cuda11.4_arm64.deb: Cached.
- vpi-samples-2.1.6-aarch64-l4t.deb: Cached.
- vpi-demos-2.1.6-aarch64-l4t.deb: Cached.
- vpi-lib-2.1.6-aarch64-l4t.deb: Cached.
- libnvidia-container0_0.11.0+jetpack_arm64.deb: Cached.
- libnvidia-container-tools_1.10.0-1_arm64.deb: Cached.
- libnvidia-container1_1.10.0-1_arm64.deb: Cached.
- nvidia-container-runtime_3.9.0-1_all.deb: Cached.
- nvidia-container-toolkit_1.11.0_rc.1-1_arm64.deb: Cached.
- nvidia-docker2_2.11.0-1_all.deb: Cached.
- libnvinfer8_8.4.1-1+cuda11.4_arm64.deb: Cached.
- nvidia-l4t-jetson-multimedia-api_35.1.0-20220810203728_arm64.deb: Cached.
- libnvinfer-dev_8.4.1-1+cuda11.4_arm64.deb: Cached.
- libnvinfer-samples_8.4.1-1+cuda11.4_all.deb: Cached.
- cudnn-local-repo-ubuntu2004-8.4.1.50_1.0-1_arm64.deb: Cached.
- cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb: Cached.
*** End of Download Summary ***
10:30:12.939 - info:
*** Install summary of 21 components ***
Install Jetson - JetPack 5.0.2 (rev. 1) Linux for Jetson AGX Xavier modules - finished succeeded
Install started on: 10:10:51 GMT+0800 (Singapore Standard Time).
Install ended on: 10:30:12 GMT+0800 (Singapore Standard Time).
Install duration: 00:19:21.
Install idle time: 0.000s.
Real install duration (duration - idle time): 00:19:21.
Total 21 components: 1 installed, 11 up-to-date, 0 failed, 9 skipped, 0 dependency failures.
Install details:
- NV_CUDA_HOST_COMP@host: Up-to-date.
- NV_CUDA_CROSS_HOST_COMP@host: Up-to-date.
- NV_NVSCI_HOST_COMP@host: Up-to-date.
- NV_VPI_HOST_COMP@host: Up-to-date.
- NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP@host: Up-to-date.
- NV_L4T_NVIDIA_NSIGHT_GRAPHICS_HOST_COMP@host: Up-to-date.
- NV_NVIDIA_NSIGHT_COMPUTE_HOST_COMP@host: Up-to-date.
- NV_NVIDIA_CUPTI_HOST_COMP@host: Up-to-date.
- NV_NVIDIA_COMPUTE_SANITIZER_HOST_COMP@host: Up-to-date.
- NV_L4T_DRIVERS_T194_COMP@JETSON_AGX_XAVIER_TARGETS: Up-to-date.
- NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP@JETSON_AGX_XAVIER_TARGETS: Up-to-date.
- NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER_TARGETS: Installed - 00:07:40 -start: 10:10:51 GMT+0800 (Singapore Standard Time) - end: 10:18:32 GMT+0800 (Singapore Standard Time).
- NV_DATETIME_SETUP_TARGET_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_CUDNN_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_TENSORRT_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
- NV_L4T_BSP_PATCH_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS: Skipped.
*** End of Install Summary ***
10:30:12.941 - info: Event: Session ended
10:30:12.941 - info: Setting SessionInitialStatus with value: Download: 100. Install: 80
10:30:12.941 - info: Setting custom dimension: SessionInitialStatus - cd12, Download: 100. Install: 80
10:30:12.942 - info: target duration: all (end time - start time): 00:07:40. duration summary: 00:07:40
10:30:12.942 - info: Setting custom dimension: Step3Selection - cd15, Target: Skipped. Flash: Installed.
10:30:12.944 - info: Session timing is: 00:20:38
10:30:12.944 - info: Session timing WITHOUT dialogs is: 00:07:40
10:30:12.948 - info: Setting custom dimension: CurrentAction - cd11, None
10:30:12.949 - info:
********************** Completed install for bundle JetPack 5.0.2 (rev. 1) Linux for Jetson AGX Xavier modules time: 16-Jan-2023-10.30:12 is succeeded: true **********************
10:30:12.962 - info: All done!
10:30:12.968 - info: Engine.install is complete.
10:30:12.969 - info: skip install DateTime Target Setup
10:30:12.969 - info: skip install CUDA Toolkit for L4T
10:30:12.969 - info: skip install OpenCV
10:30:12.969 - info: skip install VPI on Target
10:30:12.969 - info: skip install NVIDIA Container Runtime with Docker integration (Beta)
10:30:12.969 - info: skip install Multimedia API
10:30:12.969 - info: skip install BSP Patch
10:30:12.969 - info: Event: NV_DATETIME_SETUP_TARGET_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.971 - info: Component install GA report: Component Install: NV_DATETIME_SETUP_TARGET_COMP#1.0 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.972 - info: Event: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.973 - info: Component install GA report: Component Install: NV_L4T_CUDA_TARGET_POST_INSTALL_COMP#11.4 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.974 - info: Event: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.976 - info: Component install GA report: Component Install: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP#4.5 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.977 - info: Event: NV_L4T_VPI_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.978 - info: Component install GA report: Component Install: NV_L4T_VPI_TARGET_POST_INSTALL_COMP#2.1 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.978 - info: Event: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.979 - info: Component install GA report: Component Install: NV_L4T_DOCKER_TARGET_POST_INSTALL_COMP#1.10 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.980 - info: Event: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.981 - info: Component install GA report: Component Install: NV_L4T_MULTIMEDIA_API_TARGET_POST_INSTALL_T194_COMP#35.1 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.982 - info: Event: NV_L4T_BSP_PATCH_TARGET_POST_INSTALL_COMP@JETSON_AGX_XAVIER_TARGETS - skip ended
10:30:12.983 - info: Component install GA report: Component Install: NV_L4T_BSP_PATCH_TARGET_POST_INSTALL_COMP#35.1 - finished succeeded Install succeeded. RetryNumber: 0
10:30:12.999 - info: Event sent successfully to visitor G-EY1DZEMDMN
10:30:34.011 - info: exporting logs from /home/erian/.nvsdkm
After flashing, I used manual setup but then it gives error message like this:
Not exactly one NVIDIA Jetson device is connected with USB. For using default Ipv4 address, please connect exactly one Jetson device.
After flashing, I cant see the NVIDIA in the lsusb command.
