Previously successful flashed Xavier with Jetson 4.2
However with the same laptop and usb cable I am no longer able to
flash.sh jetson-xavier mmcblk0p1 finished with error
Xavier in recovery mode.
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 0955:7019 NVidia Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 8087:0a2b Intel Corp.
Bus 001 Device 004: ID 0b05:1837 ASUSTek Computer, Inc.
Bus 001 Device 003: ID 0bda:57fa Realtek Semiconductor Corp.
Bus 001 Device 002: ID 0458:0137 KYE Systems Corp. (Mouse Systems)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
23:28:16 INFO : Device Mode Host Setup in Flash : [ Disk Avail:47.64 GB ]
23:28:16 INFO : Device Mode Host Setup in Flash : Using GenericInstaller to Install NV_DEVICE_MODE_SETUP_IMAGE_COMP
23:28:16 INFO : Device Mode Host Setup in Flash : change working directory to /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888
23:28:16 INFO : Device Mode Host Setup in Flash : [ Component Install Started ]
23:28:16 INFO : Device Mode Host Setup in Flash : current working directory is /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888
23:28:16 INFO : Device Mode Host Setup in Flash : exec_command [host]:
23:28:16 INFO : Device Mode Host Setup in Flash : **********************
23:28:16 INFO : Device Mode Host Setup in Flash : #!/bin/bash
23:28:16 INFO : Device Mode Host Setup in Flash : set -e
23:28:16 INFO : Device Mode Host Setup in Flash : set +e
23:28:16 INFO : Device Mode Host Setup in Flash : eth_port_name=$(ip route show default | awk ‘/default via/ {print $5; exit}’)
23:28:16 INFO : Device Mode Host Setup in Flash : if [[ $eth_port_name == ‘’ ]]; then
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘Can not found route default $eth_port_name, device mode setup failed!’
23:28:16 INFO : Device Mode Host Setup in Flash : exit 0
23:28:16 INFO : Device Mode Host Setup in Flash : fi
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘Found route default’ $eth_port_name’, setting up device mode’
23:28:16 INFO : Device Mode Host Setup in Flash : setup_t=‘192.168.55.0/24’
23:28:16 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
23:28:16 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
23:28:16 INFO : Device Mode Host Setup in Flash : sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
23:28:16 INFO : Device Mode Host Setup in Flash : sudo sysctl -w net.ipv4.ip_forward=1
23:28:16 INFO : Device Mode Host Setup in Flash : check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
23:28:16 INFO : Device Mode Host Setup in Flash : if [[ $check_google_dns == ‘Got answer’ ]]; then
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS 8.8.8.8!’
23:28:16 INFO : Device Mode Host Setup in Flash : else
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘Default google DNS is not working, trying to find a valid server in local host settings!’
23:28:16 INFO : Device Mode Host Setup in Flash : dns_list=$(nmcli -t device show $eth_port_name | grep ‘DNS’ | grep -o ‘[^:]*$’)
23:28:16 INFO : Device Mode Host Setup in Flash : for dns in $dns_list; do
23:28:16 INFO : Device Mode Host Setup in Flash : check_dns=$(dig @$dns nvidia.com || true)
23:28:16 INFO : Device Mode Host Setup in Flash : if [[ $check_dns == ‘Got answer’ ]]; then
23:28:16 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
23:28:16 INFO : Device Mode Host Setup in Flash : sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘Device mode on host successfuly set with DNS’ $dns’!’
23:28:16 INFO : Device Mode Host Setup in Flash : done
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘Can not found a valid DNS server, device mode setup failed!’
23:28:16 INFO : Device Mode Host Setup in Flash : echo ‘If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.’
23:28:16 INFO : Device Mode Host Setup in Flash : exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
23:28:16 INFO : Device Mode Host Setup in Flash : Found route default enp4s0, setting up device mode
23:28:16 INFO : Device Mode Host Setup in Flash : [host] [sudo] password for tdwebste:
23:28:16 INFO : Device Mode Host Setup in Flash : net.ipv4.ip_forward = 1
23:28:16 INFO : Device Mode Host Setup in Flash : Device mode on host successfuly set with DNS 8.8.8.8!
23:28:16 INFO : Device Mode Host Setup in Flash : [ Component Install Finished Successfully ]
23:28:16 INFO : Device Mode Host Setup in Flash : [ 4.00 KB used. Disk Avail: 47.64 GB ]
23:28:16 INFO : Device Mode Host Setup in Flash : [ NV_DEVICE_MODE_SETUP_IMAGE_COMP Install took 0s ]
23:28:16 INFO : Device Mode Host Setup in Flash : command finished successfully
23:28:16 INFO : Device Mode Host Setup in Flash : install ‘Device Mode Host Setup in Flash’ success
23:28:16 INFO : Flash Jetson AGX Xavier : Start to install ‘Flash Jetson AGX Xavier’
23:28:16 DEBUG : Flash Jetson AGX Xavier : running command < cd ‘/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.3’ -l=‘/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/tdwebste/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘20094’ -t=‘P2888’ -e=‘undefined’ >
23:28:16 INFO : Flash Jetson AGX Xavier : [ Disk Avail:47.64 GB ]
23:28:16 INFO : Flash Jetson AGX Xavier : Using GenericInstaller to Install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP
23:28:16 INFO : Flash Jetson AGX Xavier : change working directory to /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra
23:28:16 INFO : Flash Jetson AGX Xavier : [ Component PreInstall Started ]
23:28:16 INFO : Flash Jetson AGX Xavier : current working directory is /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra
23:28:16 INFO : Flash Jetson AGX Xavier : exec_command: sudo apt-get install -y python
23:28:16 INFO : Flash Jetson AGX Xavier : Reading package lists…
23:28:16 INFO : Flash Jetson AGX Xavier : Building dependency tree…
23:28:16 INFO : Flash Jetson AGX Xavier : Reading state information…
23:28:16 INFO : Flash Jetson AGX Xavier : python is already the newest version (2.7.15~rc1-1).
23:28:16 INFO : Flash Jetson AGX Xavier : 0 upgraded, 0 newly installed, 0 to remove and 26 not upgraded.
23:28:16 INFO : Flash Jetson AGX Xavier : [ Component PreInstall Finished Successfully ]
23:28:16 INFO : Flash Jetson AGX Xavier : [ Component Install Started ]
23:28:16 INFO : Flash Jetson AGX Xavier : exec_command: sudo ./flash.sh jetson-xavier mmcblk0p1
23:28:16 INFO : Flash Jetson AGX Xavier : ###############################################################################
23:28:16 INFO : Flash Jetson AGX Xavier : # L4T BSP Information:
23:28:16 INFO : Flash Jetson AGX Xavier : # R32 , REVISION: 3.1
23:28:16 INFO : Flash Jetson AGX Xavier : # Target Board Information:
23:28:16 INFO : Flash Jetson AGX Xavier : # Name: jetson-xavier, Board Family: t186ref, SoC: Tegra 194,
23:28:16 INFO : Flash Jetson AGX Xavier : # OpMode: production, Boot Authentication: NS,
23:28:16 INFO : Flash Jetson AGX Xavier : copying soft_fuses(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
23:28:16 INFO : Flash Jetson AGX Xavier : ./tegraflash.py --chip 0x19 --applet “/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod.bin” --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins “mb2_applet nvtboot_applet_t194.bin” --cmd “dump eeprom boardinfo cvm.bin;reboot recovery”
23:28:17 INFO : Flash Jetson AGX Xavier : Welcome to Tegra Flash
23:28:17 INFO : Flash Jetson AGX Xavier : version 1.0.0
23:28:17 INFO : Flash Jetson AGX Xavier : Type ? or help for help and q or quit to exit
23:28:17 INFO : Flash Jetson AGX Xavier : Use ! to execute system commands
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0032 ] Generating RCM messages
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0207 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0217 ] Header already present for /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0478 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0674 ] tegrasign_v2 --key None --getmode mode.txt
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0683 ] Assuming zero filled SBK key
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0907 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0925 ] tegrasign_v2 --key None --file /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0938 ] Assuming zero filled SBK key
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0947 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.0963 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1035 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1204 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1235 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1252 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1267 ] RCM 0 is saved as rcm_0.rcm
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1339 ] RCM 1 is saved as rcm_1.rcm
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1339 ] RCM 2 is saved as rcm_2.rcm
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1339 ] List of rcm files are saved in rcm_list.xml
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1340 ] Signing RCM messages
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1356 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1371 ] Assuming zero filled SBK key
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1384 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1384 ] Copying signature to RCM mesages
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1400 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1425 ]
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1425 ] Boot Rom communication
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1441 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
23:28:17 INFO : Flash Jetson AGX Xavier : [ 0.1454 ] RCM version 0X190001
23:28:19 INFO : Flash Jetson AGX Xavier : [ 0.1470 ] Boot Rom communication completed
23:28:19 INFO : Flash Jetson AGX Xavier : [ 1.1614 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.1643 ] tegrarcm_v2 --isapplet
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.1658 ] Applet version 01.00.0000
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.1853 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.1878 ] tegrarcm_v2 --ismb2
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2254 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2277 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2404 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2426 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2441 ] adding BCH for nvtboot_applet_t194.bin
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2496 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2531 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2548 ] Assuming zero filled SBK key
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2557 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2580 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2635 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2651 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2664 ] Applet version 01.00.0000
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2813 ] Sending mb2
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2814 ] […] 100%
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2944 ]
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2960 ] tegrarcm_v2 --boot recovery
23:28:19 INFO : Flash Jetson AGX Xavier : [ 2.2972 ] Applet version 01.00.0000
23:28:20 INFO : Flash Jetson AGX Xavier : [ 2.3030 ]
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3060 ] tegrarcm_v2 --isapplet
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3103 ]
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3125 ] tegrarcm_v2 --ismb2
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3140 ] MB2 Applet version 01.00.0000
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3497 ]
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3518 ] tegrarcm_v2 --ismb2
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3533 ] MB2 Applet version 01.00.0000
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3738 ]
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3756 ] Retrieving EEPROM data
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3758 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/cvm.bin
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.3772 ] MB2 Applet version 01.00.0000
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4119 ] Saved platform info in /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/cvm.bin
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4464 ]
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4465 ] Rebooting to recovery mode
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4482 ] tegrarcm_v2 --ismb2
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4496 ] MB2 Applet version 01.00.0000
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4524 ]
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4524 ] Rebooting to recovery mode
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4548 ] tegrarcm_v2 --reboot recovery
23:28:20 INFO : Flash Jetson AGX Xavier : [ 3.4565 ] MB2 Applet version 01.00.0000
23:28:22 ERROR : Flash Jetson AGX Xavier : /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/tegraflash_internal.py:1845: SyntaxWarning: “is not” with a literal. Did you mean “!=”?
23:28:22 INFO : Flash Jetson AGX Xavier : if sig_type is not “zerosbk”:
23:28:22 INFO : Flash Jetson AGX Xavier : /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/tegraflash_internal.py:1848: SyntaxWarning: “is” with a literal. Did you mean “==”?
23:28:22 INFO : Flash Jetson AGX Xavier : if sig_type is “oem-rsa”:
23:28:22 INFO : Flash Jetson AGX Xavier : /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/tegraflash_internal.py:2279: SyntaxWarning: “is not” with a literal. Did you mean “!=”?
23:28:22 INFO : Flash Jetson AGX Xavier : while count is not 0 and not check_ismb2():
23:28:22 INFO : Flash Jetson AGX Xavier : /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/tegraflash_internal.py:2288: SyntaxWarning: “is not” with a literal. Did you mean “!=”?
23:28:22 INFO : Flash Jetson AGX Xavier : while count is not 0:
23:28:22 INFO : Flash Jetson AGX Xavier : [ 3.4969 ]
23:28:22 ERROR : Flash Jetson AGX Xavier : Board ID(2888) version(400) sku(0001) revision(L.0)
23:28:22 INFO : Flash Jetson AGX Xavier : creating dummy /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/badpage.bin
23:28:22 ERROR : Flash Jetson AGX Xavier : 1+0 records in
23:28:22 INFO : Flash Jetson AGX Xavier : 1+0 records out
23:28:22 INFO : Flash Jetson AGX Xavier : 4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000143792 s, 28.5 MB/s
23:28:22 INFO : Flash Jetson AGX Xavier : copying bctfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying bctfile1(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying uphy_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying device_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying misc_cold_boot_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying misc_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying pinmux_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying gpioint_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying pmic_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying pmc_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying prod_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying scr_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying scr_cold_boot_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying bootrom_config(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : copying dev_params(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)… done.
23:28:22 INFO : Flash Jetson AGX Xavier : Existing bootloader(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
23:28:22 INFO : Flash Jetson AGX Xavier : copying initrd(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
23:28:23 INFO : Flash Jetson AGX Xavier : populating kernel to rootfs… done.
23:28:24 INFO : Flash Jetson AGX Xavier : Welcome to Tegra Flash
23:28:24 INFO : Flash Jetson AGX Xavier : version 1.0.0
23:28:24 INFO : Flash Jetson AGX Xavier : Type ? or help for help and q or quit to exit
23:28:24 INFO : Flash Jetson AGX Xavier : Use ! to execute system commands
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0030 ] Generating signature
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0038 ] tegrasign_v2 --key --getmode mode.txt
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0044 ] Assuming zero filled SBK key
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0046 ]
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0048 ] header_magic: 805514
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0056 ] tegrahost_v2 --chip 0x19 --align 1_Image
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0066 ]
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0076 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.0082 ] adding BCH for 1_Image
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.7320 ]
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.7336 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
23:28:24 INFO : Flash Jetson AGX Xavier : [ 0.7343 ] Assuming zero filled SBK key
23:28:25 INFO : Flash Jetson AGX Xavier : [ 0.7662 ]
23:28:25 INFO : Flash Jetson AGX Xavier : [ 0.7672 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
23:28:25 INFO : Flash Jetson AGX Xavier : [ 1.5205 ]
23:28:25 INFO : Flash Jetson AGX Xavier : [ 1.5512 ] Signed file: /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
23:28:25 INFO : Flash Jetson AGX Xavier : Generate header for Image_sigheader.encrypt
23:28:25 INFO : Flash Jetson AGX Xavier : Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
23:28:26 INFO : Flash Jetson AGX Xavier : Remove temporary file
23:28:26 INFO : Flash Jetson AGX Xavier : done.
23:28:26 INFO : Flash Jetson AGX Xavier : populating initrd to rootfs… done.
23:28:26 INFO : Flash Jetson AGX Xavier : populating /home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs… done.
23:28:27 INFO : Flash Jetson AGX Xavier : Making Boot image… done.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing sosfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing tegraboot(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing cpu_bootloader(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing mb2blfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing mtspreboot(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing mcepreboot(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing mtsproper(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing mb1file(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing bpffile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : copying bpfdtbfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)… done.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing scefile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing camerafw(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing spefile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing drameccfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing badpagefile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/badpage.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing wb0boot(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing tosfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : Existing eksfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/eks.img) reused.
23:28:27 INFO : Flash Jetson AGX Xavier : copying soft_fuses(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)… done.
23:28:27 INFO : Flash Jetson AGX Xavier : copying dtbfile(/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)… done.
23:28:28 INFO : Flash Jetson AGX Xavier : Copying nv_boot_control.conf to rootfs
23:28:28 INFO : Flash Jetson AGX Xavier : Welcome to Tegra Flash
23:28:28 INFO : Flash Jetson AGX Xavier : version 1.0.0
23:28:28 INFO : Flash Jetson AGX Xavier : Type ? or help for help and q or quit to exit
23:28:28 INFO : Flash Jetson AGX Xavier : Use ! to execute system commands
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0028 ] Generating signature
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0036 ] tegrasign_v2 --key --getmode mode.txt
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0043 ] Assuming zero filled SBK key
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0044 ]
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0047 ] header_magic: d00dfeed
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0056 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0064 ]
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0072 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0078 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
23:28:28 INFO : Flash Jetson AGX Xavier : [ 0.0138 ]
3:50:19 INFO : Flash Jetson AGX Xavier : [ 1048.9097 ]
23:50:19 INFO : Flash Jetson AGX Xavier : Error: Return value 3
23:50:19 INFO : Flash Jetson AGX Xavier : Command tegradevflash_v2 --pt flash.xml.bin --create
23:50:19 INFO : Flash Jetson AGX Xavier : Failed flashing t186ref.
23:50:19 INFO : Flash Jetson AGX Xavier : exit status 1
23:50:19 INFO : Flash Jetson AGX Xavier : [ Component Install Finished with Error ]
23:50:19 INFO : Flash Jetson AGX Xavier : [ 228.00 KB used. Disk Avail: 47.64 GB ]
23:50:19 INFO : Flash Jetson AGX Xavier : [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 22m3s ]
23:50:19 ERROR : Flash Jetson AGX Xavier : Run commands failed at step Install: command sudo ./flash.sh jetson-xavier mmcblk0p1 finished with error
23:50:19 ERROR : Flash Jetson AGX Xavier : command terminated with error
23:50:19 ERROR : Flash Jetson AGX Xavier : install ‘Flash Jetson AGX Xavier’ failure, command < cd ‘/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ ; ‘/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter’ -a=‘install’ -c=‘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’ -i=‘NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP’ -v=‘32.3’ -l=‘/home/tdwebste/nvidia/nvidia_sdk/JetPack_4.3_Linux_P2888’ -L=‘/home/tdwebste/.nvsdkm/logs/JetPack_4.3_Linux’ -p=‘20094’ -t=‘P2888’ -e=‘undefined’ > terminated with error
23:50:19 INFO : Device Mode Host Setup in Target SDK : install ‘Device Mode Host Setup in Target SDK’ Skipped
