I’m trying to get my AGX working for the first time.
It is connected by USB-C to my host computer (a laptop running Ubuntu 18.04.6 LTS). It has 120GB free disk space.
Nothing is coming out of the HDMI but I can confirm that the system is in FRM using lsusb:
Bus 001 Device 053: ID 0955:7019 NVidia Corp.
Using SDK Manager 1.6.1.8175, the flash fails. The ERROR log shows:
11:47:39 ERROR: Flash Jetson AGX Xavier - flash: Board ID(2888) version(400) sku(0004) revision(L.0)
11:47:41 ERROR: Flash Jetson AGX Xavier - flash: 30412 blocks
11:47:46 ERROR: Flash Jetson AGX Xavier - flash: 66117 blocks
11:47:46 ERROR: Flash Jetson AGX Xavier - flash: 20+0 records in
11:48:08 ERROR: Flash Jetson AGX Xavier - flash: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/flash.sh: line 512: 31484 Killed ./mksparse ${blblksizeoption} --fillpattern=${__fillpat} ${__localsysfile}.raw ${__localsysfile}
11:48:08 ERROR: Flash Jetson AGX Xavier - flash: command terminated with error
11:48:08 SUMMARY: Flash Jetson AGX Xavier - flash: First Error: Installation failed.
The full log is as follows:
13:15:51 INFO: Flash Jetson AGX Xavier - flash: [ 0.0054 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
13:15:51 INFO: Flash Jetson AGX Xavier - flash: [ 0.0135 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
13:15:51 INFO: Flash Jetson AGX Xavier - flash: [ 0.0307 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
13:15:51 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
13:15:51 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: chip 0x19: add 0x45651 to offset 0x8 in sig file
13:15:51 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
13:15:51 INFO: Flash Jetson AGX Xavier - flash: done.
13:15:51 INFO: Flash Jetson AGX Xavier - flash: populating kernel to rootfs... done.
13:15:51 INFO: Flash Jetson AGX Xavier - flash: populating initrd to rootfs... done.
13:15:51 INFO: Flash Jetson AGX Xavier - flash: Making system.img...
13:16:14 INFO: Flash Jetson AGX Xavier - flash: populating rootfs from /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
13:16:14 INFO: Flash Jetson AGX Xavier - flash: generating sig file of Image ... /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign ./boot/Image kernel
13:16:14 INFO: Flash Jetson AGX Xavier - flash: [ 0.0057 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
13:16:14 INFO: Flash Jetson AGX Xavier - flash: [ 0.0111 ] tegrahost_v2 --chip 0x19 --align 1_Image
13:16:14 INFO: Flash Jetson AGX Xavier - flash: [ 0.0163 ] adding BCH for 1_Image
13:16:15 INFO: Flash Jetson AGX Xavier - flash: [ 0.5867 ] Assuming zero filled SBK key : not reading
13:16:15 INFO: Flash Jetson AGX Xavier - flash: [ 0.6771 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
13:16:15 INFO: Flash Jetson AGX Xavier - flash: [ 1.0202 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
13:16:15 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate header for Image_sigheader.encrypt
13:16:15 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
13:16:15 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: the sign header is saved at ./boot/Image.sig
13:16:15 INFO: Flash Jetson AGX Xavier - flash: done.
13:16:15 INFO: Flash Jetson AGX Xavier - flash: generating sig file of kernel_tegra194-p2888-0001-p2822-0000.dtb ... /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign ./boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
13:16:15 INFO: Flash Jetson AGX Xavier - flash: [ 0.0062 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
13:16:15 INFO: Flash Jetson AGX Xavier - flash: [ 0.0377 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0557 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0660 ] Assuming zero filled SBK key : not reading
13:16:16 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
13:16:16 INFO: Flash Jetson AGX Xavier - flash: done.
13:16:16 INFO: Flash Jetson AGX Xavier - flash: generating sig file of initrd ... /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/initrd data
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0520 ] tegrahost_v2 --chip 0x19 --align 1_initrd
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0680 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0698 ] adding BCH for 1_initrd
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.4870 ] Assuming zero filled SBK key : not reading
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.5048 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.5738 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
13:16:16 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate 16-byte-size-aligned base file for initrd_sigheader.encrypt
13:16:16 INFO: Flash Jetson AGX Xavier - flash: generating sig file of extlinux.conf ... /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --cmd sign ./boot/extlinux/extlinux.conf data
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0054 ] tegrahost_v2 --chip 0x19 --align 1_extlinux.conf
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0101 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0152 ] Assuming zero filled SBK key : not reading
13:16:16 INFO: Flash Jetson AGX Xavier - flash: [ 0.0202 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
13:16:16 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: chip 0x19: add 0x360 to offset 0x8 in sig file
13:16:16 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: Generate 16-byte-size-aligned base file for extlinux_sigheader.conf.encrypt
13:16:16 INFO: Flash Jetson AGX Xavier - flash: l4t_sign_image.sh: the sign header is saved at ./boot/extlinux/extlinux.conf.sig
13:16:21 INFO: Flash Jetson AGX Xavier - flash: Sync'ing system.img ... done.
13:16:22 ERROR: Flash Jetson AGX Xavier - flash: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/flash.sh: line 512: 16726 Killed ./mksparse ${blblksizeoption} --fillpattern=${__fillpat} ${__localsysfile}.raw ${__localsysfile}
13:16:22 ERROR: Flash Jetson AGX Xavier - flash: command terminated with error
13:16:22 SUMMARY: DateTime Target Setup - target: Depends on failed component
I tried manually flashing with sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1. Here is the whole output:
# L4T BSP Information:
# R32 , REVISION: 6.1
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0025 ] Generating RCM messages
[ 0.0038 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0048 ] Header already present for /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0089 ]
[ 0.0113 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0115 ] Assuming zero filled SBK key
[ 0.0141 ] tegrasign_v3.py --file /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0141 ] Assuming zero filled SBK key
[ 0.0196 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0227 ]
[ 0.0253 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0263 ]
[ 0.0283 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0291 ] RCM 0 is saved as rcm_0.rcm
[ 0.0314 ] RCM 1 is saved as rcm_1.rcm
[ 0.0314 ] RCM 2 is saved as rcm_2.rcm
[ 0.0314 ] List of rcm files are saved in rcm_list.xml
[ 0.0314 ]
[ 0.0314 ] Signing RCM messages
[ 0.0338 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0338 ] Assuming zero filled SBK key
[ 0.0400 ] Copying signature to RCM mesages
[ 0.0424 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0439 ]
[ 0.0439 ] Boot Rom communication
[ 0.0459 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0469 ] RCM version 0X190001
[ 0.4247 ] Boot Rom communication completed
[ 1.4411 ]
[ 2.4452 ] tegrarcm_v2 --isapplet
[ 2.4462 ] Applet version 01.00.0000
[ 3.2427 ]
[ 3.2451 ] tegrarcm_v2 --ismb2
[ 4.0743 ]
[ 4.0768 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 4.0777 ]
[ 4.0799 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 4.0809 ] adding BCH for nvtboot_applet_t194.bin
[ 4.0887 ]
[ 4.0922 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.0923 ] Assuming zero filled SBK key
[ 4.0975 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 4.0999 ]
[ 4.1020 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 4.1029 ] Applet version 01.00.0000
[ 4.9098 ] Sending mb2
[ 4.9100 ] [................................................] 100%
[ 4.9259 ]
[ 4.9311 ] tegrarcm_v2 --boot recovery
[ 4.9346 ] Applet version 01.00.0000
[ 5.7459 ]
[ 6.7529 ] tegrarcm_v2 --isapplet
[ 7.5540 ]
[ 7.5565 ] tegrarcm_v2 --ismb2
[ 7.5574 ] MB2 Applet version 01.00.0000
[ 8.3872 ]
[ 8.3928 ] tegrarcm_v2 --ismb2
[ 8.3966 ] MB2 Applet version 01.00.0000
[ 9.2184 ]
[ 9.2208 ] Retrieving board information
[ 9.2231 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 9.2240 ] MB2 Applet version 01.00.0000
[ 10.0563 ] Saved platform info in chip_info.bin
[ 10.0601 ] Chip minor revision: 2
[ 10.0601 ] Bootrom revision: 0xf
[ 10.0602 ] Ram code: 0x2
[ 10.0603 ] Chip sku: 0xd0
[ 10.0603 ] Chip Sample: non es
[ 10.0607 ]
[ 10.0609 ] Retrieving EEPROM data
[ 10.0609 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 10.0623 ] MB2 Applet version 01.00.0000
[ 10.8890 ] Saved platform info in /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 10.9232 ]
[ 10.9234 ] Rebooting to recovery mode
[ 10.9288 ] tegrarcm_v2 --ismb2
[ 10.9325 ] MB2 Applet version 01.00.0000
[ 11.7267 ]
[ 11.7267 ] Rebooting to recovery mode
[ 11.7292 ] tegrarcm_v2 --reboot recovery
[ 11.7300 ] MB2 Applet version 01.00.0000
[ 12.5647 ]
Copy /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
copying bctfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0003 ] Generating signature
[ 0.0032 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0033 ] Assuming zero filled SBK key : not reading
[ 0.0033 ] Generating ratchet blob
[ 0.0055 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0069 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0072 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0072 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0072 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0072 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0072 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0072 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0073 ]
[ 0.0074 ] header_magic: 414e4452
[ 0.0099 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[ 0.0109 ]
[ 0.0134 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[ 0.0142 ] adding BCH for 1_boot.img
[ 0.6320 ]
[ 0.6359 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.6360 ] Assuming zero filled SBK key : not reading
[ 0.7026 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 1.0272 ]
[ 1.0503 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset 0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
66117 blocks
Making Recovery image...
copying recdtbfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000307464 s, 65.0 kB/s
Existing sosfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[ 0.0004 ] Generating signature
[ 0.0033 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0034 ] Assuming zero filled SBK key : not reading
[ 0.0060 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0072 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0073 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0074 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0074 ]
[ 0.0074 ] header_magic: d00dfeed
[ 0.0099 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0107 ]
[ 0.0117 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0125 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0170 ]
[ 0.0200 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0200 ] Assuming zero filled SBK key : not reading
[ 0.0252 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0285 ]
[ 0.0288 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0059 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0096 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0121 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0122 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0122 ]
[ 0.0131 ] header_magic: 405614
[ 0.0192 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0249 ]
[ 0.0310 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_Image zerosbk
[ 0.0348 ] adding BCH for 1_Image
[ 0.5857 ]
[ 0.5899 ] tegrasign_v3.py --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.5899 ] Assuming zero filled SBK key : not reading
[ 0.6491 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 0.9170 ]
[ 0.9381 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/Image_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x20e3008 to offset 0x8 in sig file
done.
done.
version 1.0.0
[ 0.0061 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 0.0070 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0071 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.0071 ]
[ 0.0076 ] header_magic: d00dfeed
[ 0.0086 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0101 ]
[ 0.0123 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0132 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0186 ]
[ 0.0217 ] tegrasign_v3.py --key --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0218 ] Assuming zero filled SBK key : not reading
[ 0.0271 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0303 ]
[ 0.0307 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the sign header is saved at ./boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb.sig
done.
done.
version 1.0.0
[ 0.0029 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0029 ] Assuming zero filled SBK key : not reading
[ 0.0032 ] header_magic: 1f8b0800
[ 0.0055 ] tegrahost_v2 --chip 0x19 --align 1_initrd
[ 0.0066 ]
[ 0.0088 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_initrd zerosbk
[ 0.0097 ] adding BCH for 1_initrd
[ 0.1219 ]
[ 0.1254 ] tegrasign_v3.py --key --list 1_initrd_sigheader_list.xml --pubkeyhash pub_key.key
[ 0.1254 ] Assuming zero filled SBK key : not reading
[ 0.1411 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_initrd_sigheader.encrypt 1_initrd_sigheader.hash zerosbk
[ 0.1990 ]
[ 0.2033 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/initrd_sigheader.encrypt
l4t_sign_image.sh: Generate header for initrd_sigheader.encrypt
l4t_sign_image.sh: chip 0x19: add 0x6e72c8 to offset 0x8 in sig file
l4t_sign_image.sh: the sign header is saved at ./boot/initrd.sig
done.
done.
version 1.0.0
[ 0.0032 ] Assuming zero filled SBK key : not reading
[ 0.0032 ] header_magic: 54494d45
[ 0.0063 ]
[ 0.0086 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_extlinux.conf zerosbk
[ 0.0096 ] adding BCH for 1_extlinux.conf
[ 0.0098 ]
[ 0.0124 ] tegrasign_v3.py --key --list 1_extlinux_sigheader.conf_list.xml --pubkeyhash pub_key.key
[ 0.0125 ] Assuming zero filled SBK key : not reading
[ 0.0174 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_extlinux_sigheader.conf.encrypt 1_extlinux_sigheader.conf.hash zerosbk
[ 0.0184 ]
[ 0.0186 ] Signed file: /home/rw9535/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mnt/extlinux_sigheader.conf.encrypt
l4t_sign_image.sh: Generate header for extlinux_sigheader.conf.encrypt
done.
done.
Converting RAW image to Sparse image... ./flash.sh: line 512: 13575 Killed ./mksparse ${blblksizeoption} --fillpattern=${__fillpat} ${__localsysfile}.raw ${__localsysfile}
failed.
