My machine: thinkpad X280, host ubuntu16.06, not VM; Target board is Nvidia AGX Xavier,
First,install sdkmanager and install all software,then download.
- 10:19:43 SUMMARY: Drivers for Jetson: Install completed successfully.
- 10:19:43 SUMMARY: File System and OS: Install completed successfully.
- 10:19:43 SUMMARY: CUDA on Host: Install completed successfully.
- 10:19:43 SUMMARY: CUDA Cross Compile Package on Host: Install completed successfully.
- 10:19:43 SUMMARY: VisionWorks on Host: Install completed successfully.
- 10:19:43 SUMMARY: VPI on Host: Install completed successfully.
- 10:19:43 SUMMARY: NVIDIA Nsight Graphics: Install completed successfully.
- 10:19:43 SUMMARY: NVIDIA Nsight Systems: Install completed successfully.
- 10:19:44 SUMMARY: Device Mode Host Setup in Flash: Install completed successfully.
- 10:19:58 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Failed to execute commands with GenericInstaller
- 10:19:58 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
- 10:19:58 SUMMARY: Multimedia API: Depends on failed component
- 10:19:58 SUMMARY: TensorRT on Target: Depends on failed component
- 10:19:58 SUMMARY: VisionWorks on Target: Depends on failed component
- 10:19:58 SUMMARY: VPI on Target: Depends on failed component
- 10:19:58 SUMMARY: CUDA Toolkit for L4T: Depends on failed component
- 10:19:58 SUMMARY: cuDNN on Target: Depends on failed component
- 10:19:58 SUMMARY: OpenCV on Target: Depends on failed component
- 10:19:58 SUMMARY: DateTime Target Setup: Depends on failed component
- 10:19:58 SUMMARY: Device Mode Host Setup in Target SDK: Depends on failed component
- 10:19:59 SUMMARY: Multimedia API: Depends on failed component
- 10:19:59 SUMMARY: VisionWorks on Target: Depends on failed component
- 10:19:59 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
- 10:19:59 SUMMARY: VPI on Target: Depends on failed component
- 10:19:59 SUMMARY: cuDNN on Target: Depends on failed component
- 10:19:59 SUMMARY: TensorRT on Target: Depends on failed component
- 10:19:59 SUMMARY: OpenCV on Target: Depends on failed component
- 10:19:59 SUMMARY: DateTime Target Setup: Depends on failed component
- 10:20:00 SUMMARY: VisionWorks on Target: Depends on failed component
- 10:20:00 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
- 10:20:00 SUMMARY: VPI on Target: Depends on failed component
- 10:20:00 SUMMARY: CUDA Toolkit for L4T: Depends on failed component
- 10:20:00 SUMMARY: Multimedia API: Depends on failed component
- 10:20:00 SUMMARY: TensorRT on Target: Depends on failed component
- 10:20:00 SUMMARY: cuDNN on Target: Depends on failed component
- 10:20:00 SUMMARY: OpenCV on Target: Depends on failed component
- 10:21:17 SUMMARY: CUDA on Host: Install completed successfully.
- 10:21:17 SUMMARY: CUDA Cross Compile Package on Host: Install completed successfully.
- 10:21:17 SUMMARY: VisionWorks on Host: Install completed successfully.
- 10:21:17 SUMMARY: VPI on Host: Install completed successfully.
- 10:21:17 SUMMARY: NVIDIA Nsight Graphics: Install completed successfully.
- 10:21:17 SUMMARY: NVIDIA Nsight Systems: Install completed successfully.
- 10:22:04 SUMMARY: Drivers for Jetson: Install completed successfully.
- 10:26:27 SUMMARY: File System and OS: Install completed successfully.
- 10:26:28 SUMMARY: Device Mode Host Setup in Flash: Install completed successfully.
- 10:27:29 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Failed to execute commands with GenericInstaller
- 10:27:29 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
- 10:27:29 SUMMARY: Multimedia API: Depends on failed component
- 10:27:29 SUMMARY: TensorRT on Target: Depends on failed component
- 10:27:29 SUMMARY: VisionWorks on Target: Depends on failed component
- 10:27:29 SUMMARY: VPI on Target: Depends on failed component
- 10:27:29 SUMMARY: CUDA Toolkit for L4T: Depends on failed component
- 10:27:29 SUMMARY: cuDNN on Target: Depends on failed component
- 10:27:29 SUMMARY: OpenCV on Target: Depends on failed component
- 10:27:29 SUMMARY: DateTime Target Setup: Depends on failed component
- 10:27:29 SUMMARY: Device Mode Host Setup in Target SDK: Depends on failed component
- 10:27:30 SUMMARY: Multimedia API: Depends on failed component
- 10:27:30 SUMMARY: TensorRT on Target: Depends on failed component
- 10:27:30 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
- 10:27:30 SUMMARY: VisionWorks on Target: Depends on failed component
- 10:27:30 SUMMARY: VPI on Target: Depends on failed component
- 10:27:30 SUMMARY: cuDNN on Target: Depends on failed component
- 10:27:30 SUMMARY: OpenCV on Target: Depends on failed component
- 10:27:30 SUMMARY: DateTime Target Setup: Depends on failed component
- 10:27:31 SUMMARY: Multimedia API: Depends on failed component
- 10:27:31 SUMMARY: VisionWorks on Target: Depends on failed component
- 10:27:31 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta): Depends on failed component
- 10:27:31 SUMMARY: VPI on Target: Depends on failed component
- 10:27:31 SUMMARY: CUDA Toolkit for L4T: Depends on failed component
- 10:27:31 SUMMARY: TensorRT on Target: Depends on failed component
- 10:27:31 SUMMARY: cuDNN on Target: Depends on failed component
- 10:27:32 SUMMARY: OpenCV on Target: Depends on failed component
- 10:27:32 SUMMARY: VPI on Target: Depends on failed component
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
