Thanks for your fast reply linuxdev,
I have run the commands you suggested, however it appears that the flashing was unsuccessful again. I attempted both Jetpack 4.4 and 4.4.1, with and without the installation of Jetson SDK Components. The logs from just flashing the Jetson OS (no Jetson SDK Components) were as follows:
09:57:24 INFO: Install pre check Access to APT repository and ability to install Debian packages with it. verify succeed.
09:57:24 SUMMARY: CUDA on Host: Install completed successfully.
09:57:24 SUMMARY: CUDA Cross Compile Package on Host: Install completed successfully.
09:57:24 SUMMARY: VisionWorks on Host: Install completed successfully.
09:57:24 SUMMARY: NVIDIA Nsight Graphics: Install completed successfully.
09:57:24 SUMMARY: NVIDIA Nsight Systems: Install completed successfully.
09:57:24 INFO: Drivers for Jetson: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/T194/Jetson_Linux_R32.4.3_aarch64.tbz2 to /home/sam/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2
09:57:24 INFO: File System and OS: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/T194/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2 to /home/sam/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2
09:57:24 INFO: VPI on Host: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/vpi-lib-0.3.7-cuda10-x86_64-linux.deb to /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb
09:57:24 INFO: VPI on Host: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/vpi-dev-0.3.7-cuda10-x86_64-linux.deb to /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb
09:57:24 INFO: VPI on Host: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/vpi-samples-0.3.7-cuda10-x86_64-linux.deb to /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb
09:57:25 INFO: VPI on Host: verifying checksum of /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb
09:57:26 INFO: VPI on Host: download /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb successfully, checksum is correct
09:57:43 INFO: VPI on Host: verifying checksum of /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb
09:57:43 INFO: VPI on Host: download /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb successfully, checksum is correct
09:57:46 INFO: VPI on Host: verifying checksum of /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb
09:57:46 INFO: VPI on Host: download /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb successfully, checksum is correct
09:57:46 DEBUG: running command < true >
09:57:46 INFO: command finished successfully
09:57:46 DEBUG: VPI on Host: using adapter to install NV_VPI_HOST_COMP@host to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux
09:57:46 INFO: VPI on Host: [host] [ Disk Avail:89.17 GB ]
09:57:46 INFO: VPI on Host: Using GenericInstaller to Install NV_VPI_HOST_COMP
09:57:46 INFO: VPI on Host: NV_VPI_HOST_COMP include 3 package
09:57:46 INFO: VPI on Host: [ Package Install Started ]
09:57:46 INFO: VPI on Host: deb installer start to install
09:57:46 INFO: VPI on Host: exec_command: dpkg -f /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb Package | tr -d '\n'
09:57:46 INFO: VPI on Host: exec_command: dpkg -f /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb Version | tr -d '\n'
09:57:46 INFO: VPI on Host: deb file /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb, package name [vpi], package version [0.3.7]
09:57:46 INFO: VPI on Host: exec_command: sudo -E apt-get install -y --allow-downgrades '/home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb'
09:57:46 INFO: VPI on Host: [host] [sudo] password for sam:
09:57:46 INFO: VPI on Host: Reading package lists...
09:57:46 INFO: VPI on Host: Building dependency tree...
09:57:46 INFO: VPI on Host: Reading state information...
09:57:47 INFO: VPI on Host: The following packages were automatically installed and are no longer required:
09:57:47 INFO: VPI on Host: libcv-dev libcvaux-dev libdc1394-22 libdc1394-22-dev libgtkglext1
09:57:47 INFO: VPI on Host: libhighgui-dev libilmbase-dev libopencv-calib3d-dev libopencv-calib3d2.4v5
09:57:47 INFO: VPI on Host: libopencv-contrib-dev libopencv-contrib2.4v5 libopencv-core-dev
09:57:47 INFO: VPI on Host: libopencv-dev libopencv-features2d-dev libopencv-features2d2.4v5
09:57:47 INFO: VPI on Host: libopencv-flann-dev libopencv-flann2.4v5 libopencv-gpu-dev
09:57:47 INFO: VPI on Host: libopencv-gpu2.4v5 libopencv-highgui-dev libopencv-highgui2.4v5
09:57:47 INFO: VPI on Host: libopencv-imgproc-dev libopencv-legacy-dev libopencv-legacy2.4v5
09:57:47 INFO: VPI on Host: libopencv-ml-dev libopencv-ml2.4v5 libopencv-objdetect-dev
09:57:47 INFO: VPI on Host: libopencv-objdetect2.4v5 libopencv-ocl-dev libopencv-ocl2.4v5
09:57:47 INFO: VPI on Host: libopencv-photo-dev libopencv-photo2.4v5 libopencv-stitching-dev
09:57:47 INFO: VPI on Host: libopencv-stitching2.4v5 libopencv-superres-dev libopencv-superres2.4v5
09:57:47 INFO: VPI on Host: libopencv-ts-dev libopencv-ts2.4v5 libopencv-video-dev libopencv-video2.4v5
09:57:47 INFO: VPI on Host: libopencv-videostab-dev libopencv-videostab2.4v5 libopencv2.4-java
09:57:47 INFO: VPI on Host: libopencv2.4-jni libopenexr-dev libraw1394-dev libraw1394-tools opencv-data
09:57:47 INFO: VPI on Host: Use 'sudo apt autoremove' to remove them.
09:57:47 INFO: VPI on Host: The following packages will be REMOVED:
09:57:47 INFO: VPI on Host: vpi-cross-aarch64-l4t vpi-dev vpi-samples
09:57:47 INFO: VPI on Host: The following packages will be DOWNGRADED:
09:57:47 INFO: VPI on Host: 0 upgraded, 0 newly installed, 1 downgraded, 3 to remove and 233 not upgraded.
09:57:47 INFO: VPI on Host: Need to get 0 B/25.1 MB of archives.
09:57:47 INFO: VPI on Host: After this operation, 284 MB disk space will be freed.
09:57:47 INFO: VPI on Host: Get:1 /home/sam/Downloads/nvidia/sdkm_downloads/vpi-lib-0.3.7-cuda10-x86_64-linux.deb vpi amd64 0.3.7 [25.1 MB]
09:57:48 INFO: VPI on Host: (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 343077 files and directories currently installed.)
09:57:48 INFO: VPI on Host: Removing vpi-cross-aarch64-l4t (0.4.4) ...
09:57:48 INFO: VPI on Host: Removing vpi-samples (0.4.4) ...
09:57:48 INFO: VPI on Host: Removing vpi-dev (0.4.4) ...
09:57:48 INFO: VPI on Host: dpkg: warning: downgrading vpi from 0.4.4 to 0.3.7
09:57:48 INFO: VPI on Host: (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 342964 files and directories currently installed.)
09:57:48 INFO: VPI on Host: Preparing to unpack .../vpi-lib-0.3.7-cuda10-x86_64-linux.deb ...
09:57:48 INFO: VPI on Host: Unpacking vpi (0.3.7) over (0.4.4) ...
09:57:49 INFO: VPI on Host: dpkg: warning: unable to delete old directory '/opt/nvidia/vpi-0.4': Directory not empty
09:57:49 INFO: VPI on Host: Setting up vpi (0.3.7) ...
09:57:49 INFO: VPI on Host: update-alternatives: using /opt/nvidia/vpi-0.4 to provide /opt/nvidia/vpi-0.3 (vpi) in auto mode
09:57:49 INFO: VPI on Host: update-alternatives: warning: not replacing /opt/nvidia/vpi-0.3 with a link
09:57:49 INFO: VPI on Host: update-alternatives: warning: skip creation of /usr/lib/libnvvpi.so.0.4.4 because associated file /opt/nvidia/vpi-0.4/targets/x86_64-linux/lib/libnvvpi.so.0.4.4 (of link group vpi) doesn't exist
09:57:49 INFO: VPI on Host: update-alternatives: warning: skip creation of /usr/lib/libnvvpi.so.0 because associated file /opt/nvidia/vpi-0.4/targets/x86_64-linux/lib/libnvvpi.so.0 (of link group vpi) doesn't exist
09:57:49 INFO: VPI on Host: update-alternatives: warning: forcing reinstallation of alternative /opt/nvidia/vpi-0.4 because link group vpi is broken
09:57:49 INFO: VPI on Host: update-alternatives: warning: skip creation of /usr/lib/libnvvpi.so.0.3.7 because associated file /opt/nvidia/vpi-0.4/targets/x86_64-linux/lib/libnvvpi.so.0.4.4 (of link group vpi) doesn't exist
09:57:50 INFO: VPI on Host: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' vpi
09:57:50 INFO: VPI on Host: Host Deb package NV_VPI_HOST_COMP vpi-lib-0.3.7-cuda10-x86_64-linux.deb installed successfully.
09:57:50 INFO: VPI on Host: [ Package Install Finished Successfully ]
09:57:50 INFO: VPI on Host: [ Package PreInstall Started ]
09:57:50 INFO: VPI on Host: current working directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux
09:57:50 INFO: VPI on Host: exec_command [host]:
09:57:50 INFO: VPI on Host: **********************
09:57:50 INFO: VPI on Host: #!/bin/bash
09:57:50 INFO: VPI on Host: set -e
09:57:50 INFO: VPI on Host: function safe_apt_install {
09:57:50 INFO: VPI on Host: echo "*begin $1, $2"
09:57:50 INFO: VPI on Host: tmp_log=/tmp/jetpack_dpkg_log.txt
09:57:50 INFO: VPI on Host: sudo rm -f $tmp_log
09:57:50 INFO: VPI on Host: set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
09:57:50 INFO: VPI on Host: while [ ${CMD_STATUS} -ne 0 ]; do
09:57:50 INFO: VPI on Host: if grep -q -e "is locked by another process" -e "E: Could not get lock /var/" $tmp_log; then
09:57:50 INFO: VPI on Host: echo "Waiting $2 seconds for apt to be available"; sleep ${2}
09:57:50 INFO: VPI on Host: else
09:57:50 INFO: VPI on Host: echo "Unhandled error when running $1"; exit 1
09:57:50 INFO: VPI on Host: fi
09:57:50 INFO: VPI on Host: done
09:57:50 INFO: VPI on Host: }
09:57:50 INFO: VPI on Host: safe_apt_install "sudo apt-get install -y cmake g++" 5
09:57:50 INFO: VPI on Host: exec_command: /tmp/tmp_NV_VPI_HOST_COMP.sh
09:57:50 INFO: VPI on Host: *begin sudo apt-get install -y cmake g++, 5
09:57:50 INFO: VPI on Host: Reading package lists...
09:57:51 INFO: VPI on Host: Building dependency tree...
09:57:51 INFO: VPI on Host: Reading state information...
09:57:51 INFO: VPI on Host: g++ is already the newest version (4:5.3.1-1ubuntu1).
09:57:51 INFO: VPI on Host: cmake is already the newest version (3.5.1-1ubuntu3).
09:57:51 INFO: VPI on Host: The following packages were automatically installed and are no longer required:
09:57:51 INFO: VPI on Host: libcv-dev libcvaux-dev libdc1394-22 libdc1394-22-dev libgtkglext1
09:57:51 INFO: VPI on Host: libhighgui-dev libilmbase-dev libopencv-calib3d-dev libopencv-calib3d2.4v5
09:57:51 INFO: VPI on Host: libopencv-contrib-dev libopencv-contrib2.4v5 libopencv-core-dev
09:57:51 INFO: VPI on Host: libopencv-dev libopencv-features2d-dev libopencv-features2d2.4v5
09:57:51 INFO: VPI on Host: libopencv-flann-dev libopencv-flann2.4v5 libopencv-gpu-dev
09:57:51 INFO: VPI on Host: libopencv-gpu2.4v5 libopencv-highgui-dev libopencv-highgui2.4v5
09:57:51 INFO: VPI on Host: libopencv-imgproc-dev libopencv-legacy-dev libopencv-legacy2.4v5
09:57:51 INFO: VPI on Host: libopencv-ml-dev libopencv-ml2.4v5 libopencv-objdetect-dev
09:57:51 INFO: VPI on Host: libopencv-objdetect2.4v5 libopencv-ocl-dev libopencv-ocl2.4v5
09:57:51 INFO: VPI on Host: libopencv-photo-dev libopencv-photo2.4v5 libopencv-stitching-dev
09:57:51 INFO: VPI on Host: libopencv-stitching2.4v5 libopencv-superres-dev libopencv-superres2.4v5
09:57:51 INFO: VPI on Host: libopencv-ts-dev libopencv-ts2.4v5 libopencv-video-dev libopencv-video2.4v5
09:57:51 INFO: VPI on Host: libopencv-videostab-dev libopencv-videostab2.4v5 libopencv2.4-java
09:57:51 INFO: VPI on Host: libopencv2.4-jni libopenexr-dev libraw1394-dev libraw1394-tools opencv-data
09:57:51 INFO: VPI on Host: Use 'sudo apt autoremove' to remove them.
09:57:51 INFO: VPI on Host: 0 upgraded, 0 newly installed, 0 to remove and 233 not upgraded.
09:57:51 INFO: VPI on Host: [ Package PreInstall Finished Successfully ]
09:57:51 INFO: VPI on Host: [ Package Install Started ]
09:57:51 INFO: VPI on Host: deb installer start to install
09:57:51 INFO: VPI on Host: exec_command: dpkg -f /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb Package | tr -d '\n'
09:57:51 INFO: VPI on Host: exec_command: dpkg -f /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb Version | tr -d '\n'
09:57:51 INFO: VPI on Host: deb file /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb, package name [vpi-dev], package version [0.3.7]
09:57:51 INFO: VPI on Host: exec_command: sudo -E apt-get install -y --allow-downgrades '/home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb'
09:57:51 INFO: VPI on Host: Reading package lists...
09:57:52 INFO: VPI on Host: Building dependency tree...
09:57:52 INFO: VPI on Host: Reading state information...
09:57:52 INFO: VPI on Host: The following packages were automatically installed and are no longer required:
09:57:52 INFO: VPI on Host: libcv-dev libcvaux-dev libdc1394-22 libdc1394-22-dev libgtkglext1
09:57:52 INFO: VPI on Host: libhighgui-dev libilmbase-dev libopencv-calib3d-dev libopencv-calib3d2.4v5
09:57:52 INFO: VPI on Host: libopencv-contrib-dev libopencv-contrib2.4v5 libopencv-core-dev
09:57:52 INFO: VPI on Host: libopencv-dev libopencv-features2d-dev libopencv-features2d2.4v5
09:57:52 INFO: VPI on Host: libopencv-flann-dev libopencv-flann2.4v5 libopencv-gpu-dev
09:57:52 INFO: VPI on Host: libopencv-gpu2.4v5 libopencv-highgui-dev libopencv-highgui2.4v5
09:57:52 INFO: VPI on Host: libopencv-imgproc-dev libopencv-legacy-dev libopencv-legacy2.4v5
09:57:52 INFO: VPI on Host: libopencv-ml-dev libopencv-ml2.4v5 libopencv-objdetect-dev
09:57:52 INFO: VPI on Host: libopencv-objdetect2.4v5 libopencv-ocl-dev libopencv-ocl2.4v5
09:57:52 INFO: VPI on Host: libopencv-photo-dev libopencv-photo2.4v5 libopencv-stitching-dev
09:57:52 INFO: VPI on Host: libopencv-stitching2.4v5 libopencv-superres-dev libopencv-superres2.4v5
09:57:52 INFO: VPI on Host: libopencv-ts-dev libopencv-ts2.4v5 libopencv-video-dev libopencv-video2.4v5
09:57:52 INFO: VPI on Host: libopencv-videostab-dev libopencv-videostab2.4v5 libopencv2.4-java
09:57:52 INFO: VPI on Host: libopencv2.4-jni libopenexr-dev libraw1394-dev libraw1394-tools opencv-data
09:57:52 INFO: VPI on Host: Use 'sudo apt autoremove' to remove them.
09:57:52 INFO: VPI on Host: The following NEW packages will be installed:
09:57:52 INFO: VPI on Host: vpi-dev
09:57:52 INFO: VPI on Host: 0 upgraded, 1 newly installed, 0 to remove and 233 not upgraded.
09:57:52 INFO: VPI on Host: Need to get 0 B/37.1 kB of archives.
09:57:52 INFO: VPI on Host: After this operation, 278 kB of additional disk space will be used.
09:57:52 INFO: VPI on Host: Get:1 /home/sam/Downloads/nvidia/sdkm_downloads/vpi-dev-0.3.7-cuda10-x86_64-linux.deb vpi-dev amd64 0.3.7 [37.1 kB]
09:57:52 INFO: VPI on Host: Selecting previously unselected package vpi-dev.
09:57:52 INFO: VPI on Host: (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 342964 files and directories currently installed.)
09:57:52 INFO: VPI on Host: Preparing to unpack .../vpi-dev-0.3.7-cuda10-x86_64-linux.deb ...
09:57:52 INFO: VPI on Host: Unpacking vpi-dev (0.3.7) ...
09:57:52 INFO: VPI on Host: Setting up vpi-dev (0.3.7) ...
09:57:52 INFO: VPI on Host: update-alternatives: using /opt/nvidia/vpi-0.3/include/vpi to provide /usr/include/vpi (vpi-dev) in auto mode
09:57:54 INFO: VPI on Host: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' vpi-dev
09:57:54 INFO: VPI on Host: Host Deb package NV_VPI_HOST_COMP vpi-dev-0.3.7-cuda10-x86_64-linux.deb installed successfully.
09:57:54 INFO: VPI on Host: [ Package Install Finished Successfully ]
09:57:54 INFO: VPI on Host: [ Package Install Started ]
09:57:54 INFO: VPI on Host: deb installer start to install
09:57:54 INFO: VPI on Host: exec_command: dpkg -f /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb Package | tr -d '\n'
09:57:54 INFO: VPI on Host: exec_command: dpkg -f /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb Version | tr -d '\n'
09:57:54 INFO: VPI on Host: deb file /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb, package name [vpi-samples], package version [0.3.7]
09:57:54 INFO: VPI on Host: exec_command: sudo -E apt-get install -y --allow-downgrades '/home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb'
09:57:54 INFO: VPI on Host: Reading package lists...
09:57:54 INFO: VPI on Host: Building dependency tree...
09:57:54 INFO: VPI on Host: Reading state information...
09:57:55 INFO: VPI on Host: The following NEW packages will be installed:
09:57:55 INFO: VPI on Host: vpi-samples
09:57:55 INFO: VPI on Host: 0 upgraded, 1 newly installed, 0 to remove and 233 not upgraded.
09:57:55 INFO: VPI on Host: Need to get 0 B/14.1 MB of archives.
09:57:55 INFO: VPI on Host: After this operation, 14.3 MB of additional disk space will be used.
09:57:55 INFO: VPI on Host: Get:1 /home/sam/Downloads/nvidia/sdkm_downloads/vpi-samples-0.3.7-cuda10-x86_64-linux.deb vpi-samples amd64 0.3.7 [14.1 MB]
09:57:55 INFO: VPI on Host: Selecting previously unselected package vpi-samples.
09:57:55 INFO: VPI on Host: (Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 343008 files and directories currently installed.)
09:57:55 INFO: VPI on Host: Preparing to unpack .../vpi-samples-0.3.7-cuda10-x86_64-linux.deb ...
09:57:55 INFO: VPI on Host: Unpacking vpi-samples (0.3.7) ...
09:57:55 INFO: VPI on Host: Setting up vpi-samples (0.3.7) ...
09:57:57 INFO: VPI on Host: exec_command: dpkg-query -W -f='${db:Status-abbrev} ${Version}' vpi-samples
09:57:57 INFO: VPI on Host: Host Deb package NV_VPI_HOST_COMP vpi-samples-0.3.7-cuda10-x86_64-linux.deb installed successfully.
09:57:57 INFO: VPI on Host: [ Package Install Finished Successfully ]
09:57:57 INFO: VPI on Host: [host] [ 34.76 MB released. Disk Avail: 89.20 GB ]
09:57:57 INFO: VPI on Host: [ NV_VPI_HOST_COMP Install took 12s ]
09:57:57 INFO: VPI on Host: command finished successfully
09:57:57 SUMMARY: VPI on Host: Install completed successfully.
09:59:48 INFO: Drivers for Jetson: verifying checksum of /home/sam/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2
09:59:48 INFO: Drivers for Jetson: download /home/sam/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2 successfully, checksum is correct
09:59:48 DEBUG: running command < true >
09:59:48 INFO: command finished successfully
09:59:48 DEBUG: Drivers for Jetson: using adapter to install NV_L4T_DRIVERS_T194_COMP@JETSON_AGX_XAVIER to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
09:59:48 INFO: Drivers for Jetson: [host] [ Disk Avail:88.74 GB ]
09:59:48 INFO: Drivers for Jetson: Using GenericInstaller to Install NV_L4T_DRIVERS_T194_COMP
09:59:48 INFO: Drivers for Jetson: NV_L4T_DRIVERS_T194_COMP include 1 package
09:59:48 INFO: Drivers for Jetson: change working directory to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
09:59:48 INFO: Drivers for Jetson: [ Package PreInstall Started ]
09:59:48 INFO: Drivers for Jetson: current working directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
09:59:48 INFO: Drivers for Jetson: exec_command: sudo rm -rf /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/
09:59:48 INFO: Drivers for Jetson: [ Package PreInstall Finished Successfully ]
09:59:48 INFO: Drivers for Jetson: [ Package Install Started ]
09:59:48 INFO: Drivers for Jetson: exec_command [host]:
09:59:48 INFO: Drivers for Jetson: **********************
09:59:48 INFO: Drivers for Jetson: #!/bin/bash
09:59:48 INFO: Drivers for Jetson: set -e
09:59:48 INFO: Drivers for Jetson: function safe_apt_install {
09:59:48 INFO: Drivers for Jetson: echo "*begin $1, $2"
09:59:48 INFO: Drivers for Jetson: tmp_log=/tmp/jetpack_dpkg_log.txt
09:59:48 INFO: Drivers for Jetson: sudo rm -f $tmp_log
09:59:48 INFO: Drivers for Jetson: set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
09:59:48 INFO: Drivers for Jetson: while [ ${CMD_STATUS} -ne 0 ]; do
09:59:48 INFO: Drivers for Jetson: if grep -q -e "is locked by another process" -e "E: Could not get lock /var/" $tmp_log; then
09:59:48 INFO: Drivers for Jetson: echo "Waiting $2 seconds for apt to be available"; sleep ${2}
09:59:48 INFO: Drivers for Jetson: else
09:59:48 INFO: Drivers for Jetson: echo "Unhandled error when running $1"; exit 1
09:59:48 INFO: Drivers for Jetson: fi
09:59:48 INFO: Drivers for Jetson: done
09:59:48 INFO: Drivers for Jetson: }
09:59:48 INFO: Drivers for Jetson: sudo apt-get update || true
09:59:48 INFO: Drivers for Jetson: safe_apt_install "sudo apt-get install -y pigz lbzip2" 5
09:59:48 INFO: Drivers for Jetson: tar xf /home/sam/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.4.3_aarch64.tbz2
09:59:48 INFO: Drivers for Jetson: exec_command: /tmp/tmp_NV_L4T_DRIVERS_T194_COMP.sh
09:59:48 INFO: Drivers for Jetson: Get:1 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
09:59:48 INFO: Drivers for Jetson: Ign:1 file:/var/cuda-repo-10-2-local-10.2.89-440.40 InRelease
09:59:48 INFO: Drivers for Jetson: Get:2 file:/var/cuda-repo-10-2-local-10.2.89-cross-aarch64 InRelease
09:59:48 INFO: Drivers for Jetson: Ign:2 file:/var/cuda-repo-10-2-local-10.2.89-cross-aarch64 InRelease
09:59:48 INFO: Drivers for Jetson: Get:3 file:/var/visionworks-repo InRelease
09:59:48 INFO: Drivers for Jetson: Ign:3 file:/var/visionworks-repo InRelease
09:59:48 INFO: Drivers for Jetson: Get:4 file:/var/visionworks-sfm-repo InRelease
09:59:48 INFO: Drivers for Jetson: Ign:4 file:/var/visionworks-sfm-repo InRelease
09:59:48 INFO: Drivers for Jetson: Get:5 file:/var/visionworks-tracking-repo InRelease
09:59:48 INFO: Drivers for Jetson: Ign:5 file:/var/visionworks-tracking-repo InRelease
09:59:48 INFO: Drivers for Jetson: Get:6 file:/var/cuda-repo-10-2-local-10.2.89-440.40 Release [574 B]
09:59:48 INFO: Drivers for Jetson: Get:7 file:/var/cuda-repo-10-2-local-10.2.89-cross-aarch64 Release [574 B]
09:59:48 INFO: Drivers for Jetson: Get:8 file:/var/visionworks-repo Release [1,999 B]
09:59:48 INFO: Drivers for Jetson: Get:9 file:/var/visionworks-sfm-repo Release [2,003 B]
09:59:48 INFO: Drivers for Jetson: Get:10 file:/var/visionworks-tracking-repo Release [2,008 B]
09:59:49 INFO: Drivers for Jetson: Hit:16 http://gb.archive.ubuntu.com/ubuntu xenial InRelease
09:59:49 INFO: Drivers for Jetson: Hit:17 http://security.ubuntu.com/ubuntu xenial-security InRelease
09:59:49 INFO: Drivers for Jetson: Hit:18 http://packages.microsoft.com/repos/vscode stable InRelease
09:59:49 INFO: Drivers for Jetson: Hit:19 http://gb.archive.ubuntu.com/ubuntu xenial-updates InRelease
09:59:49 INFO: Drivers for Jetson: Hit:20 http://ppa.launchpad.net/slimbook/slimbook/ubuntu xenial InRelease
09:59:49 INFO: Drivers for Jetson: Hit:21 http://gb.archive.ubuntu.com/ubuntu xenial-backports InRelease
09:59:49 INFO: Drivers for Jetson: Ign:22 http://www.openprinting.org/download/printdriver/debian lsb3.2 InRelease
09:59:49 INFO: Drivers for Jetson: Hit:23 http://dl.google.com/linux/chrome/deb stable InRelease
09:59:49 INFO: Drivers for Jetson: Hit:24 http://packages.ros.org/ros/ubuntu xenial InRelease
09:59:49 INFO: Drivers for Jetson: Hit:25 http://www.openprinting.org/download/printdriver/debian lsb3.2 Release
09:59:51 INFO: Drivers for Jetson: Reading package lists...
09:59:51 ERROR: Drivers for Jetson: W: http://www.openprinting.org/download/printdriver/debian/dists/lsb3.2/Release.gpg: Signature by key F8897B6F00075648E248B7EC24CBF5474CFD1E2F uses weak digest algorithm (SHA1)
09:59:51 INFO: Drivers for Jetson: *begin sudo apt-get install -y pigz lbzip2, 5
09:59:51 INFO: Drivers for Jetson: Building dependency tree...
09:59:51 INFO: Drivers for Jetson: Reading state information...
09:59:51 INFO: Drivers for Jetson: lbzip2 is already the newest version (2.5-1).
09:59:51 INFO: Drivers for Jetson: pigz is already the newest version (2.3.1-2).
09:59:51 INFO: Drivers for Jetson: 0 upgraded, 0 newly installed, 0 to remove and 233 not upgraded.
10:00:12 INFO: Drivers for Jetson: [ Package Install Finished Successfully ]
10:00:12 INFO: Drivers for Jetson: [host] [ 440.41 MB used. Disk Avail: 88.31 GB ]
10:00:12 INFO: Drivers for Jetson: [ NV_L4T_DRIVERS_T194_COMP Install took 23s ]
10:00:12 INFO: Drivers for Jetson: command finished successfully
10:00:12 SUMMARY: Drivers for Jetson: Install completed successfully.
10:03:37 INFO: File System and OS: verifying checksum of /home/sam/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2
10:03:39 INFO: File System and OS: download /home/sam/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2 successfully, checksum is correct
10:03:39 DEBUG: running command < true >
10:03:39 INFO: command finished successfully
10:03:39 DEBUG: File System and OS: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP@JETSON_AGX_XAVIER to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
10:03:39 INFO: File System and OS: [host] [ Disk Avail:87.46 GB ]
10:03:39 INFO: File System and OS: Using GenericInstaller to Install NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP
10:03:39 INFO: File System and OS: NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP include 1 package
10:03:39 INFO: File System and OS: change working directory to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs/
10:03:39 INFO: File System and OS: [ Package PreInstall Started ]
10:03:39 INFO: File System and OS: current working directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
10:03:39 INFO: File System and OS: exec_command: sudo apt-get install -y qemu-user-static
10:03:39 INFO: File System and OS: Reading package lists...
10:03:40 INFO: File System and OS: Building dependency tree...
10:03:40 INFO: File System and OS: Reading state information...
10:03:40 INFO: File System and OS: qemu-user-static is already the newest version (1:2.5+dfsg-5ubuntu10.47).
10:03:40 INFO: File System and OS: 0 upgraded, 0 newly installed, 0 to remove and 233 not upgraded.
10:03:40 INFO: File System and OS: exec_command: sudo apt-get install -y python
10:03:40 INFO: File System and OS: Reading package lists...
10:03:40 INFO: File System and OS: python is already the newest version (2.7.12-1~16.04).
10:03:40 INFO: File System and OS: [ Package PreInstall Finished Successfully ]
10:03:40 INFO: File System and OS: [ Package Install Started ]
10:03:40 INFO: File System and OS: current working directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
10:03:40 INFO: File System and OS: exec_command [host]:
10:03:40 INFO: File System and OS: **********************
10:03:40 INFO: File System and OS: #!/bin/bash
10:03:40 INFO: File System and OS: set -e
10:03:40 INFO: File System and OS: sudo tar xpf /home/sam/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.4.3_aarch64.tbz2
10:03:40 INFO: File System and OS: cd ..
10:03:40 INFO: File System and OS: sudo ./apply_binaries.sh
10:03:40 INFO: File System and OS: sudo mkdir -p rootfs/opt/nvidia/deb_repos
10:03:40 INFO: File System and OS: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP.sh
10:05:54 INFO: File System and OS: Using rootfs directory of: /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
10:05:54 INFO: File System and OS: /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
10:05:54 INFO: File System and OS: Root file system directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
10:05:54 INFO: File System and OS: Copying public debian packages to rootfs
10:05:54 INFO: File System and OS: Start L4T BSP package installation
10:05:54 INFO: File System and OS: QEMU binary is not available, looking for QEMU from host system
10:05:54 INFO: File System and OS: Found /usr/bin/qemu-aarch64-static
10:05:54 INFO: File System and OS: Installing QEMU binary in rootfs
10:05:54 INFO: File System and OS: ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
10:05:54 INFO: File System and OS: Installing BSP Debian packages in /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
10:05:54 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-core.
10:05:54 INFO: File System and OS: (Reading database ... 121860 files and directories currently installed.)
10:05:54 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-core_32.4.3-20200625213407_arm64.deb ...
10:05:54 INFO: File System and OS: Pre-installing... skip compatibility checking.
10:05:54 INFO: File System and OS: Unpacking nvidia-l4t-core (32.4.3-20200625213407) ...
10:05:56 INFO: File System and OS: Setting up nvidia-l4t-core (32.4.3-20200625213407) ...
10:05:56 INFO: File System and OS: Selecting previously unselected package jetson-gpio-common.
10:05:56 INFO: File System and OS: (Reading database ... 121908 files and directories currently installed.)
10:05:56 INFO: File System and OS: Preparing to unpack .../jetson-gpio-common_2.0.8_arm64.deb ...
10:05:56 INFO: File System and OS: Unpacking jetson-gpio-common (2.0.8) ...
10:05:56 INFO: File System and OS: Selecting previously unselected package python3-jetson-gpio.
10:05:56 INFO: File System and OS: Preparing to unpack .../python3-jetson-gpio_2.0.8_arm64.deb ...
10:05:56 INFO: File System and OS: Unpacking python3-jetson-gpio (2.0.8) ...
10:05:57 INFO: File System and OS: Selecting previously unselected package python-jetson-gpio.
10:05:57 INFO: File System and OS: Preparing to unpack .../python-jetson-gpio_2.0.8_arm64.deb ...
10:05:57 INFO: File System and OS: Unpacking python-jetson-gpio (2.0.8) ...
10:05:57 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-3d-core.
10:05:57 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-3d-core_32.4.3-20200625213407_arm64.deb ...
10:05:57 INFO: File System and OS: Unpacking nvidia-l4t-3d-core (32.4.3-20200625213407) ...
10:06:07 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-apt-source.
10:06:07 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-apt-source_32.4.3-20200625213407_arm64.deb ...
10:06:07 INFO: File System and OS: Unpacking nvidia-l4t-apt-source (32.4.3-20200625213407) ...
10:06:07 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-camera.
10:06:07 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-camera_32.4.3-20200625213407_arm64.deb ...
10:06:07 INFO: File System and OS: Unpacking nvidia-l4t-camera (32.4.3-20200625213407) ...
10:06:10 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-configs.
10:06:10 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-configs_32.4.3-20200625213407_arm64.deb ...
10:06:10 INFO: File System and OS: Unpacking nvidia-l4t-configs (32.4.3-20200625213407) ...
10:06:10 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-cuda.
10:06:10 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-cuda_32.4.3-20200625213407_arm64.deb ...
10:06:10 INFO: File System and OS: Unpacking nvidia-l4t-cuda (32.4.3-20200625213407) ...
10:06:12 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-firmware.
10:06:12 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-firmware_32.4.3-20200625213407_arm64.deb ...
10:06:12 INFO: File System and OS: Unpacking nvidia-l4t-firmware (32.4.3-20200625213407) ...
10:06:13 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-graphics-demos.
10:06:13 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-graphics-demos_32.4.3-20200625213407_arm64.deb ...
10:06:13 INFO: File System and OS: Unpacking nvidia-l4t-graphics-demos (32.4.3-20200625213407) ...
10:06:22 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-gstreamer.
10:06:22 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-gstreamer_32.4.3-20200625213407_arm64.deb ...
10:06:22 INFO: File System and OS: Unpacking nvidia-l4t-gstreamer (32.4.3-20200625213407) ...
10:06:22 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-init.
10:06:22 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-init_32.4.3-20200625213407_arm64.deb ...
10:06:22 INFO: File System and OS: Unpacking nvidia-l4t-init (32.4.3-20200625213407) ...
10:06:22 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-initrd.
10:06:22 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-initrd_32.4.3-20200625213407_arm64.deb ...
10:06:22 INFO: File System and OS: Unpacking nvidia-l4t-initrd (32.4.3-20200625213407) ...
10:06:24 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-jetson-io.
10:06:24 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-jetson-io_32.4.3-20200625213407_arm64.deb ...
10:06:24 INFO: File System and OS: Unpacking nvidia-l4t-jetson-io (32.4.3-20200625213407) ...
10:06:24 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-multimedia.
10:06:24 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-multimedia_32.4.3-20200625213407_arm64.deb ...
10:06:24 INFO: File System and OS: Unpacking nvidia-l4t-multimedia (32.4.3-20200625213407) ...
10:06:26 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-multimedia-utils.
10:06:26 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-multimedia-utils_32.4.3-20200625213407_arm64.deb ...
10:06:26 INFO: File System and OS: Unpacking nvidia-l4t-multimedia-utils (32.4.3-20200625213407) ...
10:06:26 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-oem-config.
10:06:26 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-oem-config_32.4.3-20200625213407_arm64.deb ...
10:06:26 INFO: File System and OS: Unpacking nvidia-l4t-oem-config (32.4.3-20200625213407) ...
10:06:26 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-tools.
10:06:26 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-tools_32.4.3-20200625213407_arm64.deb ...
10:06:26 INFO: File System and OS: Unpacking nvidia-l4t-tools (32.4.3-20200625213407) ...
10:06:27 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-wayland.
10:06:27 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-wayland_32.4.3-20200625213407_arm64.deb ...
10:06:27 INFO: File System and OS: Unpacking nvidia-l4t-wayland (32.4.3-20200625213407) ...
10:06:27 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-weston.
10:06:27 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-weston_32.4.3-20200625213407_arm64.deb ...
10:06:27 INFO: File System and OS: Unpacking nvidia-l4t-weston (32.4.3-20200625213407) ...
10:06:28 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-x11.
10:06:28 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-x11_32.4.3-20200625213407_arm64.deb ...
10:06:28 INFO: File System and OS: Unpacking nvidia-l4t-x11 (32.4.3-20200625213407) ...
10:06:28 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-xusb-firmware.
10:06:28 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-xusb-firmware_32.4.3-20200625213407_arm64.deb ...
10:06:28 INFO: File System and OS: Unpacking nvidia-l4t-xusb-firmware (32.4.3-20200625213407) ...
10:06:28 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-kernel.
10:06:28 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-kernel_4.9.140-tegra-32.4.3-20200625213407_arm64.deb ...
10:06:28 INFO: File System and OS: Unpacking nvidia-l4t-kernel (4.9.140-tegra-32.4.3-20200625213407) ...
10:06:40 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-kernel-dtbs.
10:06:40 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-kernel-dtbs_4.9.140-tegra-32.4.3-20200625213407_arm64.deb ...
10:06:40 INFO: File System and OS: Unpacking nvidia-l4t-kernel-dtbs (4.9.140-tegra-32.4.3-20200625213407) ...
10:06:40 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-kernel-headers.
10:06:40 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-kernel-headers_4.9.140-tegra-32.4.3-20200625213407_arm64.deb ...
10:06:40 INFO: File System and OS: Unpacking nvidia-l4t-kernel-headers (4.9.140-tegra-32.4.3-20200625213407) ...
10:06:50 INFO: File System and OS: Selecting previously unselected package nvidia-l4t-bootloader.
10:06:50 INFO: File System and OS: Preparing to unpack .../nvidia-l4t-bootloader_32.4.3-20200625213407_arm64.deb ...
10:06:50 INFO: File System and OS: Pre-installing bootloader package, skip flashing
10:06:50 INFO: File System and OS: Unpacking nvidia-l4t-bootloader (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up jetson-gpio-common (2.0.8) ...
10:07:00 INFO: File System and OS: Setting up python3-jetson-gpio (2.0.8) ...
10:07:00 INFO: File System and OS: Setting up python-jetson-gpio (2.0.8) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-apt-source (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Pre-installing... skip changing source list.
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-configs (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-firmware (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-init (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-multimedia-utils (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-oem-config (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-tools (32.4.3-20200625213407) ...
10:07:00 INFO: File System and OS: Setting up nvidia-l4t-wayland (32.4.3-20200625213407) ...
10:07:01 INFO: File System and OS: Setting up nvidia-l4t-weston (32.4.3-20200625213407) ...
10:07:01 INFO: File System and OS: Setting up nvidia-l4t-x11 (32.4.3-20200625213407) ...
10:07:01 INFO: File System and OS: Setting up nvidia-l4t-xusb-firmware (32.4.3-20200625213407) ...
10:07:01 INFO: File System and OS: Pre-installing xusb firmware package, skip flashing
10:07:01 INFO: File System and OS: Setting up nvidia-l4t-kernel (4.9.140-tegra-32.4.3-20200625213407) ...
10:07:02 INFO: File System and OS: Setting up nvidia-l4t-kernel-dtbs (4.9.140-tegra-32.4.3-20200625213407) ...
10:07:02 INFO: File System and OS: Setting up nvidia-l4t-kernel-headers (4.9.140-tegra-32.4.3-20200625213407) ...
10:07:02 INFO: File System and OS: Unpacking kernel headers...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-bootloader (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Pre-installing bootloader package, skip flashing
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-3d-core (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-cuda (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-graphics-demos (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-initrd (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-jetson-io (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-multimedia (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-camera (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Setting up nvidia-l4t-gstreamer (32.4.3-20200625213407) ...
10:07:03 INFO: File System and OS: Processing triggers for nvidia-l4t-kernel (4.9.140-tegra-32.4.3-20200625213407) ...
10:07:05 INFO: File System and OS: Processing triggers for libc-bin (2.27-3ubuntu1) ...
10:07:05 INFO: File System and OS: ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
10:07:05 INFO: File System and OS: Removing QEMU binary from rootfs
10:07:05 INFO: File System and OS: Removing stashed Debian packages from rootfs
10:07:05 INFO: File System and OS: L4T BSP package installation completed!
10:07:05 INFO: File System and OS: Rename ubuntu.desktop --> ux-ubuntu.desktop
10:07:05 INFO: File System and OS: Copying USB device mode filesystem image to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra/rootfs
10:07:05 INFO: File System and OS: Disabling NetworkManager-wait-online.service
10:07:05 INFO: File System and OS: Disable the ondemand service by changing the runlevels to 'K'
10:07:05 INFO: File System and OS: Installing extlinux.conf into /boot/extlinux in target rootfs
10:07:05 INFO: File System and OS: Success!
10:07:05 INFO: File System and OS: [ Package Install Finished Successfully ]
10:07:05 INFO: File System and OS: [host] [ 4.44 GB used. Disk Avail: 83.01 GB ]
10:07:05 INFO: File System and OS: [ NV_L4T_FILE_SYSTEM_AND_OS_T194_COMP Install took 3m26s ]
10:07:05 INFO: File System and OS: command finished successfully
10:07:05 SUMMARY: File System and OS: Install completed successfully.
10:07:05 INFO: Automatic trying to flash the target device with Manual Flash option...
10:07:05 INFO: Start to check if only one device connected...
10:07:05 DEBUG: running command < true >
10:07:05 INFO: command finished successfully
10:07:05 DEBUG: running command < [ `lsusb | grep -c "0955:"` -ne 1 ] >
10:07:05 DEBUG: command terminated with error
10:07:05 INFO: Only one NVIDIA device detected, as expected.
10:07:05 INFO: Start to check if in device recovery mode...
10:07:05 DEBUG: running command < lsusb | grep 0955:7020 >
10:07:05 INFO: Jetson device is in recovery mode.
10:07:05 INFO: Start to check if the right device connected...
10:07:05 DEBUG: running command < lsusb | grep 0955:7019 >
10:07:05 INFO: Bus 001 Device 020: ID 0955:7019 NVidia Corp.
10:07:05 INFO: Verified, 0955:7019 detected in recovery mode.
10:07:05 DEBUG: Device Mode Host Setup in Flash: using adapter to install NV_DEVICE_MODE_SETUP_IMAGE_COMP@JETSON_AGX_XAVIER to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
10:07:05 INFO: Device Mode Host Setup in Flash: [host] [ Disk Avail:83.01 GB ]
10:07:05 INFO: Device Mode Host Setup in Flash: Using GenericInstaller to Install NV_DEVICE_MODE_SETUP_IMAGE_COMP
10:07:05 INFO: Device Mode Host Setup in Flash: change working directory to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
10:07:05 INFO: Device Mode Host Setup in Flash: [ Component Install Started ]
10:07:05 INFO: Device Mode Host Setup in Flash: current working directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
10:07:05 INFO: Device Mode Host Setup in Flash: exec_command [host]:
10:07:05 INFO: Device Mode Host Setup in Flash: **********************
10:07:05 INFO: Device Mode Host Setup in Flash: #!/bin/bash
10:07:05 INFO: Device Mode Host Setup in Flash: set -e
10:07:05 INFO: Device Mode Host Setup in Flash: set +e
10:07:05 INFO: Device Mode Host Setup in Flash: eth_port_name=$(ip route show default | awk '/default via/ {print $5; exit}')
10:07:05 INFO: Device Mode Host Setup in Flash: if [[ $eth_port_name == '' ]]; then
10:07:05 INFO: Device Mode Host Setup in Flash: echo 'Can not found route default $eth_port_name, device mode setup failed!'
10:07:05 INFO: Device Mode Host Setup in Flash: exit 0
10:07:05 INFO: Device Mode Host Setup in Flash: fi
10:07:05 INFO: Device Mode Host Setup in Flash: exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
10:07:05 INFO: Device Mode Host Setup in Flash: Found route default wlp59s0, setting up device mode
10:07:05 INFO: Device Mode Host Setup in Flash: net.ipv4.ip_forward = 1
10:07:05 INFO: Device Mode Host Setup in Flash: Device mode on host successfuly set with DNS 8.8.8.8!
10:07:05 INFO: Device Mode Host Setup in Flash: [ Component Install Finished Successfully ]
10:07:05 INFO: Device Mode Host Setup in Flash: [host] [ 8.00 KB used. Disk Avail: 83.01 GB ]
10:07:05 INFO: Device Mode Host Setup in Flash: [ NV_DEVICE_MODE_SETUP_IMAGE_COMP Install took 0s ]
10:07:05 INFO: Device Mode Host Setup in Flash: command finished successfully
10:07:05 SUMMARY: Device Mode Host Setup in Flash: Install completed successfully.
10:07:05 DEBUG: Flash Jetson AGX Xavier 16GB/32GB: using adapter to install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP@JETSON_AGX_XAVIER to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: [host] [ Disk Avail:83.01 GB ]
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: Using GenericInstaller to Install NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: change working directory to /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ Component Install Started ]
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: current working directory is /home/sam/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: exec_command [host]:
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: **********************
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: #!/bin/bash
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: set -e
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: if [ -e ./bootloader/system.img ]; then
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: echo sudo ./flash.sh --no-systemimg jetson-xavier mmcblk0p1
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: sudo ./flash.sh --no-systemimg jetson-xavier mmcblk0p1
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: else
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: echo sudo ./flash.sh jetson-xavier mmcblk0p1
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: sudo ./flash.sh jetson-xavier mmcblk0p1
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: fi
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: sleep 20
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: exec_command: /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: ###############################################################################
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: # L4T BSP Information:
10:07:05 INFO: Flash Jetson AGX Xavier 16GB/32GB: # R32 , REVISION: 4.3
10:07:11 INFO: Flash Jetson AGX Xavier 16GB/32GB: Error: probing the target board failed.
10:07:11 INFO: Flash Jetson AGX Xavier 16GB/32GB: Make sure the target board is connected through
10:07:11 INFO: Flash Jetson AGX Xavier 16GB/32GB: USB port and is in recovery mode.
10:07:11 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ Component Install Finished with Error ]
10:07:11 INFO: Flash Jetson AGX Xavier 16GB/32GB: [host] [ 12.00 KB used. Disk Avail: 83.01 GB ]
10:07:11 INFO: Flash Jetson AGX Xavier 16GB/32GB: [ NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP Install took 5s ]
10:07:11 ERROR: Flash Jetson AGX Xavier 16GB/32GB: [error]: : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_WITH_OS_IMAGE_COMP.sh; [error]:
10:07:11 ERROR: Flash Jetson AGX Xavier 16GB/32GB: command terminated with error
10:07:11 SUMMARY: Flash Jetson AGX Xavier 16GB/32GB: Failed to execute commands with GenericInstaller
How would you suggest I proceed?
Many Thanks.
