I connect a GPIO Breakout T-Cobbler Plus in the jetson tx2 and stopped showing the image by hdmi, try to install the jetpack 3.3 but it gives me error
What error do you hit?
Could you share the flash error and the HDMI error?
Error: Return value 8Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct mb1 mb1 bct_MB1_sigheader.bct.encrypt Failed flashing t186ref and
the error of the hdmi is that it does not show the image
I was asking if you could dump the error log from your device. Current information for you error is not enough.
Do you have UART debugger to dump the kernel log? or at least find device IP and ssh to device.
i dont have, host machine ubuntu 14.04 64bits
L4T BSP Information:
R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64,
DATE: Thu May 17 07:29:06 UTC 2018
Target Board Information:
Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x18 --applet “/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0013 ] Generating RCM messages
[ 0.0020 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0025 ] RCM 0 is saved as rcm_0.rcm
[ 0.0032 ] RCM 1 is saved as rcm_1.rcm
[ 0.0032 ] List of rcm files are saved in rcm_list.xml
[ 0.0032 ]
[ 0.0032 ] Signing RCM messages
[ 0.0136 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0141 ] Assuming zero filled SBK key
[ 0.0182 ]
[ 0.0182 ] Copying signature to RCM mesages
[ 0.0188 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0196 ]
[ 0.0196 ] Boot Rom communication
[ 0.0202 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0207 ] RCM version 0X180001
[ 0.0217 ] Boot Rom communication completed
[ 1.0279 ]
[ 1.0288 ] tegrarcm_v2 --isapplet
[ 1.0293 ] Applet version 01.00.0000
[ 1.0399 ]
[ 1.0406 ] Retrieving EEPROM data
[ 1.0406 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0412 ] Applet version 01.00.0000
[ 1.0640 ] Saved platform info in /home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1414 ]
Board ID(3310) version(B02)
copying bctfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/ubuntu/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/ubuntu/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Making system.img…
populating rootfs from /home/ubuntu/64_TX2/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4239360( 1035 blks) ==> 28:4239372
1: SKP: 24576( 6 blks) ==> 4239400:12
2: RAW: 4096( 1 blks) ==> 4239412:4108
3: SKP: 61440( 15 blks) ==> 4243520:12
4: RAW: 4096( 1 blks) ==> 4243532:4108
5: SKP: 33550336( 8191 blks) ==> 4247640:12
6: RAW: 24576( 6 blks) ==> 4247652:24588
7: SKP: 96309248( 23513 blks) ==> 4272240:12
8: RAW: 12288( 3 blks) ==> 4272252:12300
9: SKP: 4186112( 1022 blks) ==> 4284552:12
10: RAW: 1146880( 280 blks) ==> 4284564:1146892
11: SKP: 667648( 163 blks) ==> 5431456:12
12: RAW: 86016( 21 blks) ==> 5431468:86028
13: SKP: 24576( 6 blks) ==> 5517496:12
14: RAW: 143360( 35 blks) ==> 5517508:143372
15: SKP: 16384( 4 blks) ==> 5660880:12
16: RAW: 8192( 2 blks) ==> 5660892:8204
17: SKP: 4096( 1 blks) ==> 5669096:12
18: RAW: 1253376( 306 blks) ==> 5669108:1253388
19: SKP: 20480( 5 blks) ==> 6922496:12
20: RAW: 4096( 1 blks) ==> 6922508:4108
21: SKP: 40960( 10 blks) ==> 6926616:12
22: RAW: 4096( 1 blks) ==> 6926628:4108
23: SKP: 4096( 1 blks) ==> 6930736:12
24: RAW: 114688( 28 blks) ==> 6930748:114700
25: SKP: 4096( 1 blks) ==> 7045448:12
26: RAW: 126976( 31 blks) ==> 7045460:126988
27: SKP: 4096( 1 blks) ==> 7172448:12
28: RAW: 278528( 68 blks) ==> 7172460:278540
29: SKP: 237568( 58 blks) ==> 7451000:12
30: RAW: 11980800( 2925 blks) ==> 7451012:11980812
31: SKP: 4096( 1 blks) ==> 19431824:12
32: RAW: 4096( 1 blks) ==> 19431836:4108
33: SKP: 4096( 1 blks) ==> 19435944:12
34: RAW: 638976( 156 blks) ==> 19435956:638988
35: SKP: 4096( 1 blks) ==> 20074944:12
36: RAW: 4452352( 1087 blks) ==> 20074956:4452364
37: SKP: 4096( 1 blks) ==> 24527320:12
38: RAW: 4120576( 1006 blks) ==> 24527332:4120588
39: SKP: 73728( 18 blks) ==> 28647920:12
40: RAW: 12238848( 2988 blks) ==> 28647932:12238860
41: SKP: 28672( 7 blks) ==> 40886792:12
42: RAW: 4554752( 1112 blks) ==> 40886804:4554764
43: SKP: 8192( 2 blks) ==> 45441568:12
44: RAW: 11063296( 2701 blks) ==> 45441580:11063308
45: SKP: 4096( 1 blks) ==> 56504888:12
46: RAW: 57344( 14 blks) ==> 56504900:57356
47: SKP: 4096( 1 blks) ==> 56562256:12
48: RAW: 1089536( 266 blks) ==> 56562268:1089548
49: SKP: 12288( 3 blks) ==> 57651816:12
50: RAW: 4096( 1 blks) ==> 57651828:4108
51: SKP: 12288( 3 blks) ==> 57655936:12
52: RAW: 4096( 1 blks) ==> 57655948:4108
53: SKP: 12288( 3 blks) ==> 57660056:12
54: RAW: 16384( 4 blks) ==> 57660068:16396
55: SKP: 16711680( 4080 blks) ==> 57676464:12
56: RAW: 17383424( 4244 blks) ==> 57676476:17383436
57: SKP: 7782400( 1900 blks) ==> 75059912:12
58: RAW: 41377792( 10102 blks) ==> 75059924:41377804
59: SKP: 565248( 138 blks) ==> 116437728:12
60: RAW: 15020032( 3667 blks) ==> 116437740:15020044
61: SKP: 1757184( 429 blks) ==> 131457784:12
62: RAW: 22491136( 5491 blks) ==> 131457796:22491148
63: SKP: 20480( 5 blks) ==> 153948944:12
64: RAW: 249856( 61 blks) ==> 153948956:249868
65: SKP: 8192( 2 blks) ==> 154198824:12
66: RAW: 184320( 45 blks) ==> 154198836:184332
67: SKP: 4096( 1 blks) ==> 154383168:12
68: RAW: 172032( 42 blks) ==> 154383180:172044
69: SKP: 2035712( 497 blks) ==> 154555224:12
70: RAW: 43556864( 10634 blks) ==> 154555236:43556876
71: SKP: 4096( 1 blks) ==> 198112112:12
72: RAW: 9244672( 2257 blks) ==> 198112124:9244684
73: SKP: 8192( 2 blks) ==> 207356808:12
74: RAW: 4096( 1 blks) ==> 207356820:4108
75: SKP: 8192( 2 blks) ==> 207360928:12
76: RAW: 16384( 4 blks) ==> 207360940:16396
77: SKP: 4096( 1 blks) ==> 207377336:12
78: RAW: 348160( 85 blks) ==> 207377348:348172
79: SKP: 4096( 1 blks) ==> 207725520:12
80: RAW: 4096( 1 blks) ==> 207725532:4108
81: SKP: 4096( 1 blks) ==> 207729640:12
82: RAW: 409600( 100 blks) ==> 207729652:409612
83: SKP: 4096( 1 blks) ==> 208139264:12
84: RAW: 229376( 56 blks) ==> 208139276:229388
85: SKP: 4096( 1 blks) ==> 208368664:12
86: RAW: 155648( 38 blks) ==> 208368676:155660
87: SKP: 8192( 2 blks) ==> 208524336:12
88: RAW: 180224( 44 blks) ==> 208524348:180236
89: SKP: 8192( 2 blks) ==> 208704584:12
90: RAW: 12288( 3 blks) ==> 208704596:12300
91: SKP: 4096( 1 blks) ==> 208716896:12
92: RAW: 32768( 8 blks) ==> 208716908:32780
93: SKP: 12288( 3 blks) ==> 208749688:12
94: RAW: 36864( 9 blks) ==> 208749700:36876
95: SKP: 4096( 1 blks) ==> 208786576:12
96: RAW: 135168( 33 blks) ==> 208786588:135180
97: SKP: 8192( 2 blks) ==> 208921768:12
98: RAW: 520192( 127 blks) ==> 208921780:520204
99: SKP: 4096( 1 blks) ==> 209441984:12
100: RAW: 28672( 7 blks) ==> 209441996:28684
101: SKP: 4096( 1 blks) ==> 209470680:12
102: RAW: 36864( 9 blks) ==> 209470692:36876
103: SKP: 4096( 1 blks) ==> 209507568:12
104: RAW: 565248( 138 blks) ==> 209507580:565260
105: SKP: 3104768( 758 blks) ==> 210072840:12
106: RAW: 25178112( 6147 blks) ==> 210072852:25178124
107: SKP: 4186112( 1022 blks) ==> 235250976:12
108: RAW: 5570560( 1360 blks) ==> 235250988:5570572
109: SKP: 4096( 1 blks) ==> 240821560:12
110: RAW: 6889472( 1682 blks) ==> 240821572:6889484
111: SKP: 114688( 28 blks) ==> 247711056:12
112: RAW: 33198080( 8105 blks) ==> 247711068:33198092
113: SKP: 4096( 1 blks) ==> 280909160:12
114: RAW: 10960896( 2676 blks) ==> 280909172:10960908
115: SKP: 4096( 1 blks) ==> 291870080:12
116: RAW: 69632( 17 blks) ==> 291870092:69644
117: SKP: 4096( 1 blks) ==> 291939736:12
118: RAW: 16384( 4 blks) ==> 291939748:16396
119: SKP: 4096( 1 blks) ==> 291956144:12
120: RAW: 90112( 22 blks) ==> 291956156:90124
121: SKP: 4096( 1 blks) ==> 292046280:12
122: RAW: 221184( 54 blks) ==> 292046292:221196
123: SKP: 12288( 3 blks) ==> 292267488:12
124: RAW: 135168( 33 blks) ==> 292267500:135180
125: SKP: 32768( 8 blks) ==> 292402680:12
126: RAW: 1527808( 373 blks) ==> 292402692:1527820
127: SKP: 12288( 3 blks) ==> 293930512:12
128: RAW: 8192( 2 blks) ==> 293930524:8204
129: SKP: 4096( 1 blks) ==> 293938728:12
130: RAW: 28672( 7 blks) ==> 293938740:28684
131: SKP: 12288( 3 blks) ==> 293967424:12
132: RAW: 16384( 4 blks) ==> 293967436:16396
133: SKP: 8192( 2 blks) ==> 293983832:12
134: RAW: 40960( 10 blks) ==> 293983844:40972
135: SKP: 4096( 1 blks) ==> 294024816:12
136: RAW: 4096( 1 blks) ==> 294024828:4108
137: SKP: 4096( 1 blks) ==> 294028936:12
138: RAW: 45056( 11 blks) ==> 294028948:45068
139: SKP: 4096( 1 blks) ==> 294074016:12
140: RAW: 8192( 2 blks) ==> 294074028:8204
141: SKP: 4096( 1 blks) ==> 294082232:12
142: RAW: 98304( 24 blks) ==> 294082244:98316
143: SKP: 16384( 4 blks) ==> 294180560:12
144: RAW: 16384( 4 blks) ==> 294180572:16396
145: SKP: 12288( 3 blks) ==> 294196968:12
146: RAW: 4096( 1 blks) ==> 294196980:4108
147: SKP: 8192( 2 blks) ==> 294201088:12
148: RAW: 356352( 87 blks) ==> 294201100:356364
149: SKP: 4096( 1 blks) ==> 294557464:12
150: RAW: 4096( 1 blks) ==> 294557476:4108
151: SKP: 4096( 1 blks) ==> 294561584:12
152: RAW: 4096( 1 blks) ==> 294561596:4108
153: SKP: 8192( 2 blks) ==> 294565704:12
154: RAW: 49152( 12 blks) ==> 294565716:49164
155: SKP: 12288( 3 blks) ==> 294614880:12
156: RAW: 1327104( 324 blks) ==> 294614892:1327116
157: SKP: 12288( 3 blks) ==> 295942008:12
158: RAW: 462848( 113 blks) ==> 295942020:462860
159: SKP: 1441792( 352 blks) ==> 296404880:12
160: RAW: 23306240( 5690 blks) ==> 296404892:23306252
161: SKP: 8192( 2 blks) ==> 319711144:12
162: RAW: 57344( 14 blks) ==> 319711156:57356
163: SKP: 1794048( 438 blks) ==> 319768512:12
164: RAW: 23715840( 5790 blks) ==> 319768524:23715852
165: SKP: 8192( 2 blks) ==> 343484376:12
166: RAW: 57344( 14 blks) ==> 343484388:57356
167: SKP: 1384448( 338 blks) ==> 343541744:12
168: RAW: 21766144( 5314 blks) ==> 343541756:21766156
169: SKP: 8192( 2 blks) ==> 365307912:12
170: RAW: 876544( 214 blks) ==> 365307924:876556
171: SKP: 49152( 12 blks) ==> 366184480:12
172: RAW: 4096( 1 blks) ==> 366184492:4108
173: SKP: 172032( 42 blks) ==> 366188600:12
174: RAW: 20480( 5 blks) ==> 366188612:20492
175: SKP: 61440( 15 blks) ==> 366209104:12
176: RAW: 122880( 30 blks) ==> 366209116:122892
177: SKP: 4096( 1 blks) ==> 366332008:12
178: RAW: 479232( 117 blks) ==> 366332020:479244
179: SKP: 49152( 12 blks) ==> 366811264:12
180: RAW: 4096( 1 blks) ==> 366811276:4108
181: SKP: 204800( 50 blks) ==> 366815384:12
182: RAW: 245760( 60 blks) ==> 366815396:245772
183: SKP: 90112( 22 blks) ==> 367061168:12
184: RAW: 282624( 69 blks) ==> 367061180:282636
185: SKP: 24576( 6 blks) ==> 367343816:12
186: RAW: 8192( 2 blks) ==> 367343828:8204
187: SKP: 86016( 21 blks) ==> 367352032:12
188: RAW: 4096( 1 blks) ==> 367352044:4108
189: SKP: 12288( 3 blks) ==> 367356152:12
190: RAW: 4096( 1 blks) ==> 367356164:4108
191: SKP: 61440( 15 blks) ==> 367360272:12
192: RAW: 4096( 1 blks) ==> 367360284:4108
193: SKP: 77824( 19 blks) ==> 367364392:12
194: RAW: 4096( 1 blks) ==> 367364404:4108
195: SKP: 4096( 1 blks) ==> 367368512:12
196: RAW: 4096( 1 blks) ==> 367368524:4108
197: SKP: 28672( 7 blks) ==> 367372632:12
198: RAW: 16384( 4 blks) ==> 367372644:16396
199: SKP: 385024( 94 blks) ==> 367389040:12
200: RAW: 48467968( 11833 blks) ==> 367389052:48467980
201: SKP: 4096( 1 blks) ==> 415857032:12
202: RAW: 339968( 83 blks) ==> 415857044:339980
203: SKP: 16384( 4 blks) ==> 416197024:12
204: RAW: 180224( 44 blks) ==> 416197036:180236
205: SKP: 32768( 8 blks) ==> 416377272:12
206: RAW: 65536( 16 blks) ==> 416377284:65548
207: SKP: 4096( 1 blks) ==> 416442832:12
208: RAW: 434176( 106 blks) ==> 416442844:434188
209: SKP: 4096( 1 blks) ==> 416877032:12
210: RAW: 180224( 44 blks) ==> 416877044:180236
211: SKP: 4096( 1 blks) ==> 417057280:12
212: RAW: 16384( 4 blks) ==> 417057292:16396
213: SKP: 4096( 1 blks) ==> 417073688:12
214: RAW: 393216( 96 blks) ==> 417073700:393228
215: SKP: 8192( 2 blks) ==> 417466928:12
216: RAW: 77824( 19 blks) ==> 417466940:77836
217: SKP: 4096( 1 blks) ==> 417544776:12
218: RAW: 36864( 9 blks) ==> 417544788:36876
219: SKP: 4096( 1 blks) ==> 417581664:12
220: RAW: 180224( 44 blks) ==> 417581676:180236
221: SKP: 16384( 4 blks) ==> 417761912:12
222: RAW: 49152( 12 blks) ==> 417761924:49164
223: SKP: 4096( 1 blks) ==> 417811088:12
224: RAW: 929792( 227 blks) ==> 417811100:929804
225: SKP: 12288( 3 blks) ==> 418740904:12
226: RAW: 20480( 5 blks) ==> 418740916:20492
227: SKP: 4096( 1 blks) ==> 418761408:12
228: RAW: 110592( 27 blks) ==> 418761420:110604
229: SKP: 4096( 1 blks) ==> 418872024:12
230: RAW: 73728( 18 blks) ==> 418872036:73740
231: SKP: 4096( 1 blks) ==> 418945776:12
232: RAW: 4096( 1 blks) ==> 418945788:4108
233: SKP: 86016( 21 blks) ==> 418949896:12
234: RAW: 16384( 4 blks) ==> 418949908:16396
235: SKP: 4096( 1 blks) ==> 418966304:12
236: RAW: 4096( 1 blks) ==> 418966316:4108
237: SKP: 12288( 3 blks) ==> 418970424:12
238: RAW: 4096( 1 blks) ==> 418970436:4108
239: SKP: 4096( 1 blks) ==> 418974544:12
240: RAW: 8192( 2 blks) ==> 418974556:8204
241: SKP: 4096( 1 blks) ==> 418982760:12
242: RAW: 20480( 5 blks) ==> 418982772:20492
243: SKP: 8192( 2 blks) ==> 419003264:12
244: RAW: 8192( 2 blks) ==> 419003276:8204
245: SKP: 8192( 2 blks) ==> 419011480:12
246: RAW: 49152( 12 blks) ==> 419011492:49164
247: SKP: 12288( 3 blks) ==> 419060656:12
248: RAW: 4096( 1 blks) ==> 419060668:4108
249: SKP: 8192( 2 blks) ==> 419064776:12
250: RAW: 36864( 9 blks) ==> 419064788:36876
251: SKP: 4096( 1 blks) ==> 419101664:12
252: RAW: 4096( 1 blks) ==> 419101676:4108
253: SKP: 20480( 5 blks) ==> 419105784:12
254: RAW: 4096( 1 blks) ==> 419105796:4108
255: SKP: 12288( 3 blks) ==> 419109904:12
256: RAW: 12288( 3 blks) ==> 419109916:12300
257: SKP: 4096( 1 blks) ==> 419122216:12
258: RAW: 4096( 1 blks) ==> 419122228:4108
259: SKP: 4096( 1 blks) ==> 419126336:12
260: RAW: 4096( 1 blks) ==> 419126348:4108
261: SKP: 36864( 9 blks) ==> 419130456:12
262: RAW: 4096( 1 blks) ==> 419130468:4108
263: SKP: 4096( 1 blks) ==> 419134576:12
264: RAW: 4096( 1 blks) ==> 419134588:4108
265: SKP: 24576( 6 blks) ==> 419138696:12
266: RAW: 8192( 2 blks) ==> 419138708:8204
267: SKP: 4096( 1 blks) ==> 419146912:12
268: RAW: 73728( 18 blks) ==> 419146924:73740
269: SKP: 4096( 1 blks) ==> 419220664:12
270: RAW: 4096( 1 blks) ==> 419220676:4108
271: SKP: 4096( 1 blks) ==> 419224784:12
272: RAW: 16384( 4 blks) ==> 419224796:16396
273: SKP: 4096( 1 blks) ==> 419241192:12
274: RAW: 57344( 14 blks) ==> 419241204:57356
275: SKP: 40960( 10 blks) ==> 419298560:12
276: RAW: 12288( 3 blks) ==> 419298572:12300
277: SKP: 4096( 1 blks) ==> 419310872:12
278: RAW: 491520( 120 blks) ==> 419310884:491532
279: SKP: 28672( 7 blks) ==> 419802416:12
280: RAW: 192512( 47 blks) ==> 419802428:192524
281: SKP: 4096( 1 blks) ==> 419994952:12
282: RAW: 8192( 2 blks) ==> 419994964:8204
283: SKP: 16384( 4 blks) ==> 420003168:12
284: RAW: 8192( 2 blks) ==> 420003180:8204
285: SKP: 36864( 9 blks) ==> 420011384:12
286: RAW: 16384( 4 blks) ==> 420011396:16396
287: SKP: 32768( 8 blks) ==> 420027792:12
288: RAW: 32768( 8 blks) ==> 420027804:32780
289: SKP: 4096( 1 blks) ==> 420060584:12
290: RAW: 16384( 4 blks) ==> 420060596:16396
291: SKP: 8192( 2 blks) ==> 420076992:12
292: RAW: 479232( 117 blks) ==> 420077004:479244
293: SKP: 49152( 12 blks) ==> 420556248:12
294: RAW: 4096( 1 blks) ==> 420556260:4108
295: SKP: 208896( 51 blks) ==> 420560368:12
296: RAW: 307200( 75 blks) ==> 420560380:307212
297: SKP: 86016( 21 blks) ==> 420867592:12
298: RAW: 282624( 69 blks) ==> 420867604:282636
299: SKP: 24576( 6 blks) ==> 421150240:12
300: RAW: 8192( 2 blks) ==> 421150252:8204
301: SKP: 57344( 14 blks) ==> 421158456:12
302: RAW: 4096( 1 blks) ==> 421158468:4108
303: SKP: 12288( 3 blks) ==> 421162576:12
304: RAW: 4096( 1 blks) ==> 421162588:4108
305: SKP: 45056( 11 blks) ==> 421166696:12
306: RAW: 4096( 1 blks) ==> 421166708:4108
307: SKP: 61440( 15 blks) ==> 421170816:12
308: RAW: 12288( 3 blks) ==> 421170828:12300
309: SKP: 28672( 7 blks) ==> 421183128:12
310: RAW: 16384( 4 blks) ==> 421183140:16396
311: SKP: 3756032( 917 blks) ==> 421199536:12
312: RAW: 27701248( 6763 blks) ==> 421199548:27701260
313: SKP: 4096( 1 blks) ==> 448900808:12
314: RAW: 2560000( 625 blks) ==> 448900820:2560012
315: SKP: 8192( 2 blks) ==> 451460832:12
316: RAW: 2871296( 701 blks) ==> 451460844:2871308
317: SKP: 4096( 1 blks) ==> 454332152:12
318: RAW: 16384( 4 blks) ==> 454332164:16396
319: SKP: 4096( 1 blks) ==> 454348560:12
320: RAW: 344064( 84 blks) ==> 454348572:344076
321: SKP: 4096( 1 blks) ==> 454692648:12
322: RAW: 12288( 3 blks) ==> 454692660:12300
323: SKP: 24576( 6 blks) ==> 454704960:12
324: RAW: 19079168( 4658 blks) ==> 454704972:19079180
325: SKP: 4096( 1 blks) ==> 473784152:12
326: RAW: 1413120( 345 blks) ==> 473784164:1413132
327: SKP: 4096( 1 blks) ==> 475197296:12
328: RAW: 1146880( 280 blks) ==> 475197308:1146892
329: SKP: 8192( 2 blks) ==> 476344200:12
330: RAW: 2760704( 674 blks) ==> 476344212:2760716
331: SKP: 4096( 1 blks) ==> 479104928:12
332: RAW: 16384( 4 blks) ==> 479104940:16396
333: SKP: 4096( 1 blks) ==> 479121336:12
334: RAW: 344064( 84 blks) ==> 479121348:344076
335: SKP: 4096( 1 blks) ==> 479465424:12
336: RAW: 12288( 3 blks) ==> 479465436:12300
337: SKP: 86016( 21 blks) ==> 479477736:12
338: RAW: 122880( 30 blks) ==> 479477748:122892
339: SKP: 4096( 1 blks) ==> 479600640:12
340: RAW: 7962624( 1944 blks) ==> 479600652:7962636
341: SKP: 12288( 3 blks) ==> 487563288:12
342: RAW: 73728( 18 blks) ==> 487563300:73740
343: SKP: 12288( 3 blks) ==> 487637040:12
344: RAW: 73728( 18 blks) ==> 487637052:73740
345: SKP: 12288( 3 blks) ==> 487710792:12
346: RAW: 69632( 17 blks) ==> 487710804:69644
347: SKP: 16384( 4 blks) ==> 487780448:12
348: RAW: 69632( 17 blks) ==> 487780460:69644
349: SKP: 16384( 4 blks) ==> 487850104:12
350: RAW: 61440( 15 blks) ==> 487850116:61452
351: SKP: 16384( 4 blks) ==> 487911568:12
352: RAW: 65536( 16 blks) ==> 487911580:65548
353: SKP: 4096( 1 blks) ==> 487977128:12
354: RAW: 86016( 21 blks) ==> 487977140:86028
355: SKP: 4186112( 1022 blks) ==> 488063168:12
356: RAW: 1081344( 264 blks) ==> 488063180:1081356
357: SKP: 4096( 1 blks) ==> 489144536:12
358: RAW: 172032( 42 blks) ==> 489144548:172044
359: SKP: 8192( 2 blks) ==> 489316592:12
360: RAW: 184320( 45 blks) ==> 489316604:184332
361: SKP: 8192( 2 blks) ==> 489500936:12
362: RAW: 212992( 52 blks) ==> 489500948:213004
363: SKP: 16384( 4 blks) ==> 489713952:12
364: RAW: 765952( 187 blks) ==> 489713964:765964
365: SKP: 1736704( 424 blks) ==> 490479928:12
366: RAW: 35323904( 8624 blks) ==> 490479940:35323916
367: SKP: 8192( 2 blks) ==> 525803856:12
368: RAW: 118784( 29 blks) ==> 525803868:118796
369: SKP: 4096( 1 blks) ==> 525922664:12
370: RAW: 53248( 13 blks) ==> 525922676:53260
371: SKP: 90112( 22 blks) ==> 525975936:12
372: RAW: 12288( 3 blks) ==> 525975948:12300
373: SKP: 4096( 1 blks) ==> 525988248:12
374: RAW: 16384( 4 blks) ==> 525988260:16396
375: SKP: 12288( 3 blks) ==> 526004656:12
376: RAW: 16384( 4 blks) ==> 526004668:16396
377: SKP: 4096( 1 blks) ==> 526021064:12
378: RAW: 8192( 2 blks) ==> 526021076:8204
379: SKP: 4096( 1 blks) ==> 526029280:12
380: RAW: 4096( 1 blks) ==> 526029292:4108
381: SKP: 4096( 1 blks) ==> 526033400:12
382: RAW: 8192( 2 blks) ==> 526033412:8204
383: SKP: 8192( 2 blks) ==> 526041616:12
384: RAW: 8192( 2 blks) ==> 526041628:8204
385: SKP: 4096( 1 blks) ==> 526049832:12
386: RAW: 8192( 2 blks) ==> 526049844:8204
387: SKP: 4096( 1 blks) ==> 526058048:12
388: RAW: 8192( 2 blks) ==> 526058060:8204
389: SKP: 8192( 2 blks) ==> 526066264:12
390: RAW: 8192( 2 blks) ==> 526066276:8204
391: SKP: 12288( 3 blks) ==> 526074480:12
392: RAW: 28672( 7 blks) ==> 526074492:28684
393: SKP: 4096( 1 blks) ==> 526103176:12
394: RAW: 69632( 17 blks) ==> 526103188:69644
395: SKP: 12288( 3 blks) ==> 526172832:12
396: RAW: 4096( 1 blks) ==> 526172844:4108
397: SKP: 8192( 2 blks) ==> 526176952:12
398: RAW: 16384( 4 blks) ==> 526176964:16396
399: SKP: 4096( 1 blks) ==> 526193360:12
400: RAW: 8192( 2 blks) ==> 526193372:8204
401: SKP: 16384( 4 blks) ==> 526201576:12
402: RAW: 8192( 2 blks) ==> 526201588:8204
403: SKP: 4096( 1 blks) ==> 526209792:12
404: RAW: 8192( 2 blks) ==> 526209804:8204
405: SKP: 8192( 2 blks) ==> 526218008:12
406: RAW: 4096( 1 blks) ==> 526218020:4108
407: SKP: 20480( 5 blks) ==> 526222128:12
408: RAW: 4096( 1 blks) ==> 526222140:4108
409: SKP: 8192( 2 blks) ==> 526226248:12
410: RAW: 4096( 1 blks) ==> 526226260:4108
411: SKP: 12288( 3 blks) ==> 526230368:12
412: RAW: 8192( 2 blks) ==> 526230380:8204
413: SKP: 4096( 1 blks) ==> 526238584:12
414: RAW: 4096( 1 blks) ==> 526238596:4108
415: SKP: 12288( 3 blks) ==> 526242704:12
416: RAW: 4096( 1 blks) ==> 526242716:4108
417: SKP: 45056( 11 blks) ==> 526246824:12
418: RAW: 8192( 2 blks) ==> 526246836:8204
419: SKP: 28672( 7 blks) ==> 526255040:12
420: RAW: 4096( 1 blks) ==> 526255052:4108
421: SKP: 57344( 14 blks) ==> 526259160:12
422: RAW: 20480( 5 blks) ==> 526259172:20492
423: SKP: 8192( 2 blks) ==> 526279664:12
424: RAW: 16384( 4 blks) ==> 526279676:16396
425: SKP: 4096( 1 blks) ==> 526296072:12
426: RAW: 16384( 4 blks) ==> 526296084:16396
427: SKP: 20480( 5 blks) ==> 526312480:12
428: RAW: 4096( 1 blks) ==> 526312492:4108
429: SKP: 8192( 2 blks) ==> 526316600:12
430: RAW: 8192( 2 blks) ==> 526316612:8204
431: SKP: 4096( 1 blks) ==> 526324816:12
432: RAW: 524288( 128 blks) ==> 526324828:524300
433: SKP: 4096( 1 blks) ==> 526849128:12
434: RAW: 57344( 14 blks) ==> 526849140:57356
435: SKP: 32768( 8 blks) ==> 526906496:12
436: RAW: 147456( 36 blks) ==> 526906508:147468
437: SKP: 8192( 2 blks) ==> 527053976:12
438: RAW: 212992( 52 blks) ==> 527053988:213004
439: SKP: 24576( 6 blks) ==> 527266992:12
440: RAW: 2244608( 548 blks) ==> 527267004:2244620
441: SKP: 16384( 4 blks) ==> 529511624:12
442: RAW: 20480( 5 blks) ==> 529511636:20492
443: SKP: 4096( 1 blks) ==> 529532128:12
444: RAW: 184320( 45 blks) ==> 529532140:184332
445: SKP: 2158592( 527 blks) ==> 529716472:12
446: RAW: 30138368( 7358 blks) ==> 529716484:30138380
447: SKP: 16384( 4 blks) ==> 559854864:12
448: RAW: 8192( 2 blks) ==> 559854876:8204
449: SKP: 16384( 4 blks) ==> 559863080:12
450: RAW: 32768( 8 blks) ==> 559863092:32780
451: SKP: 4096( 1 blks) ==> 559895872:12
452: RAW: 4096( 1 blks) ==> 559895884:4108
453: SKP: 12288( 3 blks) ==> 559899992:12
454: RAW: 8192( 2 blks) ==> 559900004:8204
455: SKP: 12288( 3 blks) ==> 559908208:12
456: RAW: 8192( 2 blks) ==> 559908220:8204
457: SKP: 8192( 2 blks) ==> 559916424:12
458: RAW: 28672( 7 blks) ==> 559916436:28684
459: SKP: 4096( 1 blks) ==> 559945120:12
460: RAW: 4096( 1 blks) ==> 559945132:4108
461: SKP: 12288( 3 blks) ==> 559949240:12
462: RAW: 8192( 2 blks) ==> 559949252:8204
463: SKP: 12288( 3 blks) ==> 559957456:12
464: RAW: 32768( 8 blks) ==> 559957468:32780
465: SKP: 12288( 3 blks) ==> 559990248:12
466: RAW: 8192( 2 blks) ==> 559990260:8204
467: SKP: 12288( 3 blks) ==> 559998464:12
468: RAW: 4096( 1 blks) ==> 559998476:4108
469: SKP: 12288( 3 blks) ==> 560002584:12
470: RAW: 8192( 2 blks) ==> 560002596:8204
471: SKP: 12288( 3 blks) ==> 560010800:12
472: RAW: 8192( 2 blks) ==> 560010812:8204
473: SKP: 12288( 3 blks) ==> 560019016:12
474: RAW: 4096( 1 blks) ==> 560019028:4108
475: SKP: 12288( 3 blks) ==> 560023136:12
476: RAW: 8192( 2 blks) ==> 560023148:8204
477: SKP: 12288( 3 blks) ==> 560031352:12
478: RAW: 8192( 2 blks) ==> 560031364:8204
479: SKP: 12288( 3 blks) ==> 560039568:12
480: RAW: 4096( 1 blks) ==> 560039580:4108
481: SKP: 12288( 3 blks) ==> 560043688:12
482: RAW: 8192( 2 blks) ==> 560043700:8204
483: SKP: 12288( 3 blks) ==> 560051904:12
484: RAW: 8192( 2 blks) ==> 560051916:8204
485: SKP: 12288( 3 blks) ==> 560060120:12
486: RAW: 4096( 1 blks) ==> 560060132:4108
487: SKP: 12288( 3 blks) ==> 560064240:12
488: RAW: 8192( 2 blks) ==> 560064252:8204
489: SKP: 12288( 3 blks) ==> 560072456:12
490: RAW: 8192( 2 blks) ==> 560072468:8204
491: SKP: 12288( 3 blks) ==> 560080672:12
492: RAW: 4096( 1 blks) ==> 560080684:4108
493: SKP: 12288( 3 blks) ==> 560084792:12
494: RAW: 8192( 2 blks) ==> 560084804:8204
495: SKP: 12288( 3 blks) ==> 560093008:12
496: RAW: 4096( 1 blks) ==> 560093020:4108
497: SKP: 12288( 3 blks) ==> 560097128:12
498: RAW: 8192( 2 blks) ==> 560097140:8204
499: SKP: 12288( 3 blks) ==> 560105344:12
500: RAW: 4096( 1 blks) ==> 560105356:4108
501: SKP: 12288( 3 blks) ==> 560109464:12
502: RAW: 8192( 2 blks) ==> 560109476:8204
503: SKP: 12288( 3 blks) ==> 560117680:12
504: RAW: 4096( 1 blks) ==> 560117692:4108
505: SKP: 12288( 3 blks) ==> 560121800:12
506: RAW: 8192( 2 blks) ==> 560121812:8204
507: SKP: 12288( 3 blks) ==> 560130016:12
508: RAW: 8192( 2 blks) ==> 560130028:8204
509: SKP: 8192( 2 blks) ==> 560138232:12
510: RAW: 8192( 2 blks) ==> 560138244:8204
511: SKP: 4096( 1 blks) ==> 560146448:12
512: RAW: 4096( 1 blks) ==> 560146460:4108
513: SKP: 16384( 4 blks) ==> 560150568:12
514: RAW: 16384( 4 blks) ==> 560150580:16396
515: SKP: 12288( 3 blks) ==> 560166976:12
516: RAW: 8192( 2 blks) ==> 560166988:8204
517: SKP: 4096( 1 blks) ==> 560175192:12
518: RAW: 8192( 2 blks) ==> 560175204:8204
519: SKP: 12288( 3 blks) ==> 560183408:12
520: RAW: 12288( 3 blks) ==> 560183420:12300
521: SKP: 12288( 3 blks) ==> 560195720:12
522: RAW: 8192( 2 blks) ==> 560195732:8204
523: SKP: 12288( 3 blks) ==> 560203936:12
524: RAW: 8192( 2 blks) ==> 560203948:8204
525: SKP: 12288( 3 blks) ==> 560212152:12
526: RAW: 8192( 2 blks) ==> 560212164:8204
527: SKP: 12288( 3 blks) ==> 560220368:12
528: RAW: 8192( 2 blks) ==> 560220380:8204
529: SKP: 12288( 3 blks) ==> 560228584:12
530: RAW: 4096( 1 blks) ==> 560228596:4108
531: SKP: 12288( 3 blks) ==> 560232704:12
532: RAW: 8192( 2 blks) ==> 560232716:8204
533: SKP: 12288( 3 blks) ==> 560240920:12
534: RAW: 8192( 2 blks) ==> 560240932:8204
535: SKP: 12288( 3 blks) ==> 560249136:12
536: RAW: 4096( 1 blks) ==> 560249148:4108
537: SKP: 12288( 3 blks) ==> 560253256:12
538: RAW: 8192( 2 blks) ==> 560253268:8204
539: SKP: 12288( 3 blks) ==> 560261472:12
540: RAW: 4096( 1 blks) ==> 560261484:4108
541: SKP: 12288( 3 blks) ==> 560265592:12
542: RAW: 8192( 2 blks) ==> 560265604:8204
543: SKP: 12288( 3 blks) ==> 560273808:12
544: RAW: 8192( 2 blks) ==> 560273820:8204
545: SKP: 8192( 2 blks) ==> 560282024:12
546: RAW: 8192( 2 blks) ==> 560282036:8204
547: SKP: 12288( 3 blks) ==> 560290240:12
548: RAW: 8192( 2 blks) ==> 560290252:8204
549: SKP: 12288( 3 blks) ==> 560298456:12
550: RAW: 4096( 1 blks) ==> 560298468:4108
551: SKP: 12288( 3 blks) ==> 560302576:12
552: RAW: 8192( 2 blks) ==> 560302588:8204
553: SKP: 12288( 3 blks) ==> 560310792:12
554: RAW: 4096( 1 blks) ==> 560310804:4108
555: SKP: 12288( 3 blks) ==> 560314912:12
556: RAW: 8192( 2 blks) ==> 560314924:8204
557: SKP: 12288( 3 blks) ==> 560323128:12
558: RAW: 4096( 1 blks) ==> 560323140:4108
559: SKP: 12288( 3 blks) ==> 560327248:12
560: RAW: 8192( 2 blks) ==> 560327260:8204
561: SKP: 12288( 3 blks) ==> 560335464:12
562: RAW: 4096( 1 blks) ==> 560335476:4108
563: SKP: 12288( 3 blks) ==> 560339584:12
564: RAW: 8192( 2 blks) ==> 560339596:8204
565: SKP: 12288( 3 blks) ==> 560347800:12
566: RAW: 8192( 2 blks) ==> 560347812:8204
567: SKP: 12288( 3 blks) ==> 560356016:12
568: RAW: 4096( 1 blks) ==> 560356028:4108
569: SKP: 12288( 3 blks) ==> 560360136:12
570: RAW: 8192( 2 blks) ==> 560360148:8204
571: SKP: 12288( 3 blks) ==> 560368352:12
572: RAW: 4096( 1 blks) ==> 560368364:4108
573: SKP: 12288( 3 blks) ==> 560372472:12
574: RAW: 4096( 1 blks) ==> 560372484:4108
575: SKP: 4096( 1 blks) ==> 560376592:12
576: RAW: 4096( 1 blks) ==> 560376604:4108
577: SKP: 12288( 3 blks) ==> 560380712:12
578: RAW: 4096( 1 blks) ==> 560380724:4108
579: SKP: 12288( 3 blks) ==> 560384832:12
580: RAW: 8192( 2 blks) ==> 560384844:8204
581: SKP: 12288( 3 blks) ==> 560393048:12
582: RAW: 8192( 2 blks) ==> 560393060:8204
583: SKP: 12288( 3 blks) ==> 560401264:12
584: RAW: 4096( 1 blks) ==> 560401276:4108
585: SKP: 12288( 3 blks) ==> 560405384:12
586: RAW: 8192( 2 blks) ==> 560405396:8204
587: SKP: 12288( 3 blks) ==> 560413600:12
588: RAW: 8192( 2 blks) ==> 560413612:8204
589: SKP: 12288( 3 blks) ==> 560421816:12
590: RAW: 4096( 1 blks) ==> 560421828:4108
591: SKP: 12288( 3 blks) ==> 560425936:12
592: RAW: 8192( 2 blks) ==> 560425948:8204
593: SKP: 12288( 3 blks) ==> 560434152:12
594: RAW: 8192( 2 blks) ==> 560434164:8204
595: SKP: 8192( 2 blks) ==> 560442368:12
596: RAW: 8192( 2 blks) ==> 560442380:8204
597: SKP: 12288( 3 blks) ==> 560450584:12
598: RAW: 8192( 2 blks) ==> 560450596:8204
599: SKP: 12288( 3 blks) ==> 560458800:12
600: RAW: 8192( 2 blks) ==> 560458812:8204
601: SKP: 12288( 3 blks) ==> 560467016:12
602: RAW: 4096( 1 blks) ==> 560467028:4108
603: SKP: 12288( 3 blks) ==> 560471136:12
604: RAW: 8192( 2 blks) ==> 560471148:8204
605: SKP: 12288( 3 blks) ==> 560479352:12
606: RAW: 4096( 1 blks) ==> 560479364:4108
607: SKP: 12288( 3 blks) ==> 560483472:12
608: RAW: 12288( 3 blks) ==> 560483484:12300
609: SKP: 12288( 3 blks) ==> 560495784:12
610: RAW: 8192( 2 blks) ==> 560495796:8204
611: SKP: 12288( 3 blks) ==> 560504000:12
612: RAW: 12288( 3 blks) ==> 560504012:12300
613: SKP: 12288( 3 blks) ==> 560516312:12
614: RAW: 8192( 2 blks) ==> 560516324:8204
615: SKP: 12288( 3 blks) ==> 560524528:12
616: RAW: 8192( 2 blks) ==> 560524540:8204
617: SKP: 12288( 3 blks) ==> 560532744:12
618: RAW: 4096( 1 blks) ==> 560532756:4108
619: SKP: 12288( 3 blks) ==> 560536864:12
620: RAW: 8192( 2 blks) ==> 560536876:8204
621: SKP: 12288( 3 blks) ==> 560545080:12
622: RAW: 8192( 2 blks) ==> 560545092:8204
623: SKP: 8192( 2 blks) ==> 560553296:12
624: RAW: 8192( 2 blks) ==> 560553308:8204
625: SKP: 12288( 3 blks) ==> 560561512:12
626: RAW: 12288( 3 blks) ==> 560561524:12300
627: SKP: 12288( 3 blks) ==> 560573824:12
628: RAW: 12288( 3 blks) ==> 560573836:12300
629: SKP: 12288( 3 blks) ==> 560586136:12
630: RAW: 8192( 2 blks) ==> 560586148:8204
631: SKP: 12288( 3 blks) ==> 560594352:12
632: RAW: 4096( 1 blks) ==> 560594364:4108
633: SKP: 12288( 3 blks) ==> 560598472:12
634: RAW: 8192( 2 blks) ==> 560598484:8204
635: SKP: 12288( 3 blks) ==> 560606688:12
636: RAW: 8192( 2 blks) ==> 560606700:8204
637: SKP: 12288( 3 blks) ==> 560614904:12
638: RAW: 4096( 1 blks) ==> 560614916:4108
639: SKP: 12288( 3 blks) ==> 560619024:12
640: RAW: 8192( 2 blks) ==> 560619036:8204
641: SKP: 12288( 3 blks) ==> 560627240:12
642: RAW: 8192( 2 blks) ==> 560627252:8204
643: SKP: 12288( 3 blks) ==> 560635456:12
644: RAW: 12288( 3 blks) ==> 560635468:12300
645: SKP: 12288( 3 blks) ==> 560647768:12
646: RAW: 8192( 2 blks) ==> 560647780:8204
647: SKP: 12288( 3 blks) ==> 560655984:12
648: RAW: 8192( 2 blks) ==> 560655996:8204
649: SKP: 4096( 1 blks) ==> 560664200:12
650: RAW: 8192( 2 blks) ==> 560664212:8204
651: SKP: 8192( 2 blks) ==> 560672416:12
652: RAW: 8192( 2 blks) ==> 560672428:8204
653: SKP: 12288( 3 blks) ==> 560680632:12
654: RAW: 8192( 2 blks) ==> 560680644:8204
655: SKP: 12288( 3 blks) ==> 560688848:12
656: RAW: 4096( 1 blks) ==> 560688860:4108
657: SKP: 12288( 3 blks) ==> 560692968:12
658: RAW: 8192( 2 blks) ==> 560692980:8204
659: SKP: 12288( 3 blks) ==> 560701184:12
660: RAW: 4096( 1 blks) ==> 560701196:4108
661: SKP: 12288( 3 blks) ==> 560705304:12
662: RAW: 8192( 2 blks) ==> 560705316:8204
663: SKP: 12288( 3 blks) ==> 560713520:12
664: RAW: 4096( 1 blks) ==> 560713532:4108
665: SKP: 12288( 3 blks) ==> 560717640:12
666: RAW: 8192( 2 blks) ==> 560717652:8204
667: SKP: 12288( 3 blks) ==> 560725856:12
668: RAW: 4096( 1 blks) ==> 560725868:4108
669: SKP: 12288( 3 blks) ==> 560729976:12
670: RAW: 8192( 2 blks) ==> 560729988:8204
671: SKP: 12288( 3 blks) ==> 560738192:12
672: RAW: 4096( 1 blks) ==> 560738204:4108
673: SKP: 12288( 3 blks) ==> 560742312:12
674: RAW: 8192( 2 blks) ==> 560742324:8204
675: SKP: 12288( 3 blks) ==> 560750528:12
676: RAW: 4096( 1 blks) ==> 560750540:4108
677: SKP: 12288( 3 blks) ==> 560754648:12
678: RAW: 8192( 2 blks) ==> 560754660:8204
679: SKP: 4096( 1 blks) ==> 560762864:12
680: RAW: 4096( 1 blks) ==> 560762876:4108
681: SKP: 12288( 3 blks) ==> 560766984:12
682: RAW: 4096( 1 blks) ==> 560766996:4108
683: SKP: 4096( 1 blks) ==> 560771104:12
684: RAW: 4096( 1 blks) ==> 560771116:4108
685: SKP: 12288( 3 blks) ==> 560775224:12
686: RAW: 16384( 4 blks) ==> 560775236:16396
687: SKP: 12288( 3 blks) ==> 560791632:12
688: RAW: 4096( 1 blks) ==> 560791644:4108
689: SKP: 4096( 1 blks) ==> 560795752:12
690: RAW: 4096( 1 blks) ==> 560795764:4108
691: SKP: 12288( 3 blks) ==> 560799872:12
692: RAW: 8192( 2 blks) ==> 560799884:8204
693: SKP: 12288( 3 blks) ==> 560808088:12
694: RAW: 4096( 1 blks) ==> 560808100:4108
695: SKP: 12288( 3 blks) ==> 560812208:12
696: RAW: 8192( 2 blks) ==> 560812220:8204
697: SKP: 12288( 3 blks) ==> 560820424:12
698: RAW: 4096( 1 blks) ==> 560820436:4108
699: SKP: 12288( 3 blks) ==> 560824544:12
700: RAW: 8192( 2 blks) ==> 560824556:8204
701: SKP: 12288( 3 blks) ==> 560832760:12
702: RAW: 8192( 2 blks) ==> 560832772:8204
703: SKP: 8192( 2 blks) ==> 560840976:12
704: RAW: 12288( 3 blks) ==> 560840988:12300
705: SKP: 12288( 3 blks) ==> 560853288:12
706: RAW: 8192( 2 blks) ==> 560853300:8204
707: SKP: 12288( 3 blks) ==> 560861504:12
708: RAW: 4096( 1 blks) ==> 560861516:4108
709: SKP: 12288( 3 blks) ==> 560865624:12
710: RAW: 8192( 2 blks) ==> 560865636:8204
711: SKP: 12288( 3 blks) ==> 560873840:12
712: RAW: 4096( 1 blks) ==> 560873852:4108
713: SKP: 12288( 3 blks) ==> 560877960:12
714: RAW: 8192( 2 blks) ==> 560877972:8204
715: SKP: 12288( 3 blks) ==> 560886176:12
716: RAW: 4096( 1 blks) ==> 560886188:4108
717: SKP: 12288( 3 blks) ==> 560890296:12
718: RAW: 8192( 2 blks) ==> 560890308:8204
719: SKP: 12288( 3 blks) ==> 560898512:12
720: RAW: 4096( 1 blks) ==> 560898524:4108
721: SKP: 12288( 3 blks) ==> 560902632:12
722: RAW: 8192( 2 blks) ==> 560902644:8204
723: SKP: 12288( 3 blks) ==> 560910848:12
724: RAW: 4096( 1 blks) ==> 560910860:4108
725: SKP: 12288( 3 blks) ==> 560914968:12
726: RAW: 8192( 2 blks) ==> 560914980:8204
727: SKP: 12288( 3 blks) ==> 560923184:12
728: RAW: 4096( 1 blks) ==> 560923196:4108
729: SKP: 12288( 3 blks) ==> 560927304:12
730: RAW: 8192( 2 blks) ==> 560927316:8204
731: SKP: 12288( 3 blks) ==> 560935520:12
732: RAW: 8192( 2 blks) ==> 560935532:8204
733: SKP: 8192( 2 blks) ==> 560943736:12
734: RAW: 8192( 2 blks) ==> 560943748:8204
735: SKP: 12288( 3 blks) ==> 560951952:12
736: RAW: 8192( 2 blks) ==> 560951964:8204
737: SKP: 12288( 3 blks) ==> 560960168:12
738: RAW: 4096( 1 blks) ==> 560960180:4108
739: SKP: 12288( 3 blks) ==> 560964288:12
740: RAW: 8192( 2 blks) ==> 560964300:8204
741: SKP: 12288( 3 blks) ==> 560972504:12
742: RAW: 4096( 1 blks) ==> 560972516:4108
743: SKP: 12288( 3 blks) ==> 560976624:12
744: RAW: 8192( 2 blks) ==> 560976636:8204
745: SKP: 12288( 3 blks) ==> 560984840:12
746: RAW: 4096( 1 blks) ==> 560984852:4108
747: SKP: 12288( 3 blks) ==> 560988960:12
748: RAW: 8192( 2 blks) ==> 560988972:8204
749: SKP: 12288( 3 blks) ==> 560997176:12
750: RAW: 4096( 1 blks) ==> 560997188:4108
751: SKP: 12288( 3 blks) ==> 561001296:12
752: RAW: 8192( 2 blks) ==> 561001308:8204
753: SKP: 12288( 3 blks) ==> 561009512:12
754: RAW: 4096( 1 blks) ==> 561009524:4108
755: SKP: 12288( 3 blks) ==> 561013632:12
756: RAW: 8192( 2 blks) ==> 561013644:8204
757: SKP: 12288( 3 blks) ==> 561021848:12
758: RAW: 8192( 2 blks) ==> 561021860:8204
759: SKP: 12288( 3 blks) ==> 561030064:12
760: RAW: 4096( 1 blks) ==> 561030076:4108
761: SKP: 12288( 3 blks) ==> 561034184:12
762: RAW: 8192( 2 blks) ==> 561034196:8204
763: SKP: 12288( 3 blks) ==> 561042400:12
764: RAW: 8192( 2 blks) ==> 561042412:8204
765: SKP: 12288( 3 blks) ==> 561050616:12
766: RAW: 4096( 1 blks) ==> 561050628:4108
767: SKP: 12288( 3 blks) ==> 561054736:12
768: RAW: 8192( 2 blks) ==> 561054748:8204
769: SKP: 12288( 3 blks) ==> 561062952:12
770: RAW: 4096( 1 blks) ==> 561062964:4108
771: SKP: 12288( 3 blks) ==> 561067072:12
772: RAW: 8192( 2 blks) ==> 561067084:8204
773: SKP: 12288( 3 blks) ==> 561075288:12
774: RAW: 8192( 2 blks) ==> 561075300:8204
775: SKP: 8192( 2 blks) ==> 561083504:12
776: RAW: 8192( 2 blks) ==> 561083516:8204
777: SKP: 12288( 3 blks) ==> 561091720:12
778: RAW: 8192( 2 blks) ==> 561091732:8204
779: SKP: 12288( 3 blks) ==> 561099936:12
780: RAW: 4096( 1 blks) ==> 561099948:4108
781: SKP: 12288( 3 blks) ==> 561104056:12
782: RAW: 8192( 2 blks) ==> 561104068:8204
783: SKP: 12288( 3 blks) ==> 561112272:12
784: RAW: 4096( 1 blks) ==> 561112284:4108
785: SKP: 12288( 3 blks) ==> 561116392:12
786: RAW: 8192( 2 blks) ==> 561116404:8204
787: SKP: 4096( 1 blks) ==> 561124608:12
788: RAW: 4096( 1 blks) ==> 561124620:4108
789: SKP: 12288( 3 blks) ==> 561128728:12
790: RAW: 8192( 2 blks) ==> 561128740:8204
791: SKP: 12288( 3 blks) ==> 561136944:12
792: RAW: 4096( 1 blks) ==> 561136956:4108
793: SKP: 12288( 3 blks) ==> 561141064:12
794: RAW: 4096( 1 blks) ==> 561141076:4108
795: SKP: 12288( 3 blks) ==> 561145184:12
796: RAW: 12288( 3 blks) ==> 561145196:12300
797: SKP: 12288( 3 blks) ==> 561157496:12
798: RAW: 4096( 1 blks) ==> 561157508:4108
799: SKP: 12288( 3 blks) ==> 561161616:12
800: RAW: 8192( 2 blks) ==> 561161628:8204
801: SKP: 12288( 3 blks) ==> 561169832:12
802: RAW: 4096( 1 blks) ==> 561169844:4108
803: SKP: 12288( 3 blks) ==> 561173952:12
804: RAW: 8192( 2 blks) ==> 561173964:8204
805: SKP: 12288( 3 blks) ==> 561182168:12
806: RAW: 8192( 2 blks) ==> 561182180:8204
807: SKP: 12288( 3 blks) ==> 561190384:12
808: RAW: 4096( 1 blks) ==> 561190396:4108
809: SKP: 12288( 3 blks) ==> 561194504:12
810: RAW: 8192( 2 blks) ==> 561194516:8204
811: SKP: 12288( 3 blks) ==> 561202720:12
812: RAW: 8192( 2 blks) ==> 561202732:8204
813: SKP: 12288( 3 blks) ==> 561210936:12
814: RAW: 4096( 1 blks) ==> 561210948:4108
815: SKP: 12288( 3 blks) ==> 561215056:12
816: RAW: 8192( 2 blks) ==> 561215068:8204
817: SKP: 12288( 3 blks) ==> 561223272:12
818: RAW: 8192( 2 blks) ==> 561223284:8204
819: SKP: 12288( 3 blks) ==> 561231488:12
820: RAW: 122880( 30 blks) ==> 561231500:122892
821: SKP: 12288( 3 blks) ==> 561354392:12
822: RAW: 8192( 2 blks) ==> 561354404:8204
823: SKP: 12288( 3 blks) ==> 561362608:12
824: RAW: 4096( 1 blks) ==> 561362620:4108
825: SKP: 12288( 3 blks) ==> 561366728:12
826: RAW: 8192( 2 blks) ==> 561366740:8204
827: SKP: 24576( 6 blks) ==> 561374944:12
828: RAW: 73728( 18 blks) ==> 561374956:73740
829: SKP: 12288( 3 blks) ==> 561448696:12
830: RAW: 8192( 2 blks) ==> 561448708:8204
831: SKP: 12288( 3 blks) ==> 561456912:12
832: RAW: 8192( 2 blks) ==> 561456924:8204
833: SKP: 12288( 3 blks) ==> 561465128:12
834: RAW: 4096( 1 blks) ==> 561465140:4108
835: SKP: 12288( 3 blks) ==> 561469248:12
836: RAW: 12288( 3 blks) ==> 561469260:12300
837: SKP: 8192( 2 blks) ==> 561481560:12
838: RAW: 12288( 3 blks) ==> 561481572:12300
839: SKP: 12288( 3 blks) ==> 561493872:12
840: RAW: 8192( 2 blks) ==> 561493884:8204
841: SKP: 12288( 3 blks) ==> 561502088:12
842: RAW: 8192( 2 blks) ==> 561502100:8204
843: SKP: 12288( 3 blks) ==> 561510304:12
844: RAW: 8192( 2 blks) ==> 561510316:8204
845: SKP: 12288( 3 blks) ==> 561518520:12
846: RAW: 4096( 1 blks) ==> 561518532:4108
847: SKP: 4096( 1 blks) ==> 561522640:12
848: RAW: 4096( 1 blks) ==> 561522652:4108
849: SKP: 12288( 3 blks) ==> 561526760:12
850: RAW: 4096( 1 blks) ==> 561526772:4108
851: SKP: 8192( 2 blks) ==> 561530880:12
852: RAW: 4096( 1 blks) ==> 561530892:4108
853: SKP: 4096( 1 blks) ==> 561535000:12
854: RAW: 4096( 1 blks) ==> 561535012:4108
855: SKP: 4096( 1 blks) ==> 561539120:12
856: RAW: 16384( 4 blks) ==> 561539132:16396
857: SKP: 4096( 1 blks) ==> 561555528:12
858: RAW: 4096( 1 blks) ==> 561555540:4108
859: SKP: 4096( 1 blks) ==> 561559648:12
860: RAW: 4096( 1 blks) ==> 561559660:4108
861: SKP: 8192( 2 blks) ==> 561563768:12
862: RAW: 12288( 3 blks) ==> 561563780:12300
863: SKP: 4096( 1 blks) ==> 561576080:12
864: RAW: 4096( 1 blks) ==> 561576092:4108
865: SKP: 4096( 1 blks) ==> 561580200:12
866: RAW: 4096( 1 blks) ==> 561580212:4108
867: SKP: 8192( 2 blks) ==> 561584320:12
868: RAW: 4096( 1 blks) ==> 561584332:4108
869: SKP: 4096( 1 blks) ==> 561588440:12
870: RAW: 4096( 1 blks) ==> 561588452:4108
871: SKP: 4096( 1 blks) ==> 561592560:12
872: RAW: 16384( 4 blks) ==> 561592572:16396
873: SKP: 4096( 1 blks) ==> 561608968:12
874: RAW: 4096( 1 blks) ==> 561608980:4108
875: SKP: 4096( 1 blks) ==> 561613088:12
876: RAW: 4096( 1 blks) ==> 561613100:4108
877: SKP: 4096( 1 blks) ==> 561617208:12
878: RAW: 16384( 4 blks) ==> 561617220:16396
879: SKP: 4096( 1 blks) ==> 561633616:12
880: RAW: 4096( 1 blks) ==> 561633628:4108
881: SKP: 4096( 1 blks) ==> 561637736:12
882: RAW: 4096( 1 blks) ==> 561637748:4108
883: SKP: 8192( 2 blks) ==> 561641856:12
884: RAW: 12288( 3 blks) ==> 561641868:12300
885: SKP: 4096( 1 blks) ==> 561654168:12
886: RAW: 4096( 1 blks) ==> 561654180:4108
887: SKP: 4096( 1 blks) ==> 561658288:12
888: RAW: 4096( 1 blks) ==> 561658300:4108
889: SKP: 8192( 2 blks) ==> 561662408:12
890: RAW: 4096( 1 blks) ==> 561662420:4108
891: SKP: 4096( 1 blks) ==> 561666528:12
892: RAW: 4096( 1 blks) ==> 561666540:4108
893: SKP: 4096( 1 blks) ==> 561670648:12
894: RAW: 12288( 3 blks) ==> 561670660:12300
895: SKP: 8192( 2 blks) ==> 561682960:12
896: RAW: 4096( 1 blks) ==> 561682972:4108
897: SKP: 4096( 1 blks) ==> 561687080:12
898: RAW: 4096( 1 blks) ==> 561687092:4108
899: SKP: 4096( 1 blks) ==> 561691200:12
900: RAW: 16384( 4 blks) ==> 561691212:16396
901: SKP: 4096( 1 blks) ==> 561707608:12
902: RAW: 4096( 1 blks) ==> 561707620:4108
903: SKP: 4096( 1 blks) ==> 561711728:12
904: RAW: 4096( 1 blks) ==> 561711740:4108
905: SKP: 8192( 2 blks) ==> 561715848:12
906: RAW: 12288( 3 blks) ==> 561715860:12300
907: SKP: 4096( 1 blks) ==> 561728160:12
908: RAW: 4096( 1 blks) ==> 561728172:4108
909: SKP: 4096( 1 blks) ==> 561732280:12
910: RAW: 4096( 1 blks) ==> 561732292:4108
911: SKP: 8192( 2 blks) ==> 561736400:12
912: RAW: 12288( 3 blks) ==> 561736412:12300
913: SKP: 4096( 1 blks) ==> 561748712:12
914: RAW: 4096( 1 blks) ==> 561748724:4108
915: SKP: 4096( 1 blks) ==> 561752832:12
916: RAW: 4096( 1 blks) ==> 561752844:4108
917: SKP: 8192( 2 blks) ==> 561756952:12
918: RAW: 4096( 1 blks) ==> 561756964:4108
919: SKP: 4096( 1 blks) ==> 561761072:12
920: RAW: 4096( 1 blks) ==> 561761084:4108
921: SKP: 4096( 1 blks) ==> 561765192:12
922: RAW: 16384( 4 blks) ==> 561765204:16396
923: SKP: 4096( 1 blks) ==> 561781600:12
924: RAW: 4096( 1 blks) ==> 561781612:4108
925: SKP: 4096( 1 blks) ==> 561785720:12
926: RAW: 4096( 1 blks) ==> 561785732:4108
927: SKP: 4096( 1 blks) ==> 561789840:12
928: RAW: 16384( 4 blks) ==> 561789852:16396
929: SKP: 4096( 1 blks) ==> 561806248:12
930: RAW: 4096( 1 blks) ==> 561806260:4108
931: SKP: 4096( 1 blks) ==> 561810368:12
932: RAW: 4096( 1 blks) ==> 561810380:4108
933: SKP: 8192( 2 blks) ==> 561814488:12
934: RAW: 12288( 3 blks) ==> 561814500:12300
935: SKP: 4096( 1 blks) ==> 561826800:12
936: RAW: 4096( 1 blks) ==> 561826812:4108
937: SKP: 4096( 1 blks) ==> 561830920:12
938: RAW: 4096( 1 blks) ==> 561830932:4108
939: SKP: 8192( 2 blks) ==> 561835040:12
940: RAW: 4096( 1 blks) ==> 561835052:4108
941: SKP: 4096( 1 blks) ==> 561839160:12
942: RAW: 4096( 1 blks) ==> 561839172:4108
943: SKP: 4096( 1 blks) ==> 561843280:12
944: RAW: 12288( 3 blks) ==> 561843292:12300
945: SKP: 8192( 2 blks) ==> 561855592:12
946: RAW: 4096( 1 blks) ==> 561855604:4108
947: SKP: 4096( 1 blks) ==> 561859712:12
948: RAW: 4096( 1 blks) ==> 561859724:4108
949: SKP: 4096( 1 blks) ==> 561863832:12
950: RAW: 16384( 4 blks) ==> 561863844:16396
951: SKP: 4096( 1 blks) ==> 561880240:12
952: RAW: 4096( 1 blks) ==> 561880252:4108
953: SKP: 4096( 1 blks) ==> 561884360:12
954: RAW: 4096( 1 blks) ==> 561884372:4108
955: SKP: 8192( 2 blks) ==> 561888480:12
956: RAW: 12288( 3 blks) ==> 561888492:12300
957: SKP: 4096( 1 blks) ==> 561900792:12
958: RAW: 4096( 1 blks) ==> 561900804:4108
959: SKP: 4096( 1 blks) ==> 561904912:12
960: RAW: 4096( 1 blks) ==> 561904924:4108
961: SKP: 8192( 2 blks) ==> 561909032:12
962: RAW: 4096( 1 blks) ==> 561909044:4108
963: SKP: 4096( 1 blks) ==> 561913152:12
964: RAW: 4096( 1 blks) ==> 561913164:4108
965: SKP: 4096( 1 blks) ==> 561917272:12
966: RAW: 12288( 3 blks) ==> 561917284:12300
967: SKP: 8192( 2 blks) ==> 561929584:12
968: RAW: 4096( 1 blks) ==> 561929596:4108
969: SKP: 4096( 1 blks) ==> 561933704:12
970: RAW: 4096( 1 blks) ==> 561933716:4108
971: SKP: 4096( 1 blks) ==> 561937824:12
972: RAW: 16384( 4 blks) ==> 561937836:16396
973: SKP: 4096( 1 blks) ==> 561954232:12
974: RAW: 4096( 1 blks) ==> 561954244:4108
975: SKP: 4096( 1 blks) ==> 561958352:12
976: RAW: 4096( 1 blks) ==> 561958364:4108
977: SKP: 8192( 2 blks) ==> 561962472:12
978: RAW: 12288( 3 blks) ==> 561962484:12300
979: SKP: 4096( 1 blks) ==> 561974784:12
980: RAW: 4096( 1 blks) ==> 561974796:4108
981: SKP: 4096( 1 blks) ==> 561978904:12
982: RAW: 4096( 1 blks) ==> 561978916:4108
983: SKP: 8192( 2 blks) ==> 561983024:12
984: RAW: 12288( 3 blks) ==> 561983036:12300
985: SKP: 4096( 1 blks) ==> 561995336:12
986: RAW: 4096( 1 blks) ==> 561995348:4108
987: SKP: 4096( 1 blks) ==> 561999456:12
988: RAW: 4096( 1 blks) ==> 561999468:4108
989: SKP: 8192( 2 blks) ==> 562003576:12
990: RAW: 4096( 1 blks) ==> 562003588:4108
991: SKP: 4096( 1 blks) ==> 562007696:12
992: RAW: 4096( 1 blks) ==> 562007708:4108
993: SKP: 4096( 1 blks) ==> 562011816:12
994: RAW: 16384( 4 blks) ==> 562011828:16396
995: SKP: 4096( 1 blks) ==> 562028224:12
996: RAW: 4096( 1 b
done.
system.img built successfully.
Existing tbcfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/ubuntu/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
copying cfgfile(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb”
saving flash command in /home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/flashcmd.txt
copying boot image (boot.img.sb)… done.
copying partition layout (flash.xml.sb)… done.
copying kernel dtb (tegra186-quill-p3310-1000-c03-00-base.dtb.sb)… done.
saving flash parameters in /home/ubuntu/64_TX2/Linux_for_Tegra/bootloader/flash_parameters.txt
–bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb”
*** Flashing target device started. ***
version 1.0.0
[ 0.0250 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0258 ] Assuming zero filled SBK key
[ 0.0267 ]
[ 0.0267 ] Generating RCM messages
[ 0.0353 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0359 ] RCM 0 is saved as rcm_0.rcm
[ 0.0407 ] RCM 1 is saved as rcm_1.rcm
[ 0.0407 ] List of rcm files are saved in rcm_list.xml
[ 0.0407 ]
[ 0.0407 ] Signing RCM messages
[ 0.0416 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0421 ] Assuming zero filled SBK key
[ 0.0450 ]
[ 0.0450 ] Copying signature to RCM mesages
[ 0.0456 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0468 ]
[ 0.0468 ] Parsing partition layout
[ 0.0610 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0630 ]
[ 0.0630 ] Creating list of images to be signed
[ 0.0698 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.2460 ]
[ 0.2460 ] Generating signatures
[ 0.2469 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2474 ] Assuming zero filled SBK key
[ 0.4581 ]
[ 0.4581 ] Generating br-bct
[ 0.4885 ] Updating dev and MSS params in BR BCT
[ 0.4885 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.5320 ]
[ 0.5320 ] Updating bl info
[ 0.5329 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.5339 ]
[ 0.5340 ] Updating smd info
[ 0.5348 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.5357 ]
[ 0.5357 ] Updating Odmdata
[ 0.5362 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 0.5369 ]
[ 0.5370 ] Get Signed section bct
[ 0.5374 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.5380 ]
[ 0.5380 ] Signing BCT
[ 0.5391 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.5396 ] Assuming zero filled SBK key
[ 0.5397 ]
[ 0.5397 ] Updating BCT with signature
[ 0.5402 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.5410 ]
[ 0.5410 ] Generating coldboot mb1-bct
[ 0.5415 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.5420 ] MB1-BCT version: 0xe
[ 0.5421 ] Copying Sdram info from 2 to 3 set
[ 0.5559 ] Packing sdram param for instance[0]
[ 0.5560 ] Packing sdram param for instance[1]
[ 0.5561 ] Packing sdram param for instance[2]
[ 0.5562 ] Packing sdram param for instance[3]
[ 0.5890 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.5892 ] Appending platform config data of size :- 2904
[ 0.6091 ] Parsing config file :mobile_scr.cfg
[ 0.6092 ] Appending platform config data of size :- 12240
[ 0.6361 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.6362 ] Appending platform config data of size :- 24
[ 0.6363 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.6365 ] Appending platform config data of size :- 708
[ 0.6367 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.6369 ] Appending platform config data of size :- 64
[ 0.6421 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.6423 ] Appending platform config data of size :- 1652
[ 0.6423 ]
[ 0.6424 ] Updating mb1-bct with firmware information
[ 0.6431 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.6436 ] MB1-BCT version: 0xe
[ 0.6440 ]
[ 0.6440 ] Updating mb1-bct with storage information
[ 0.6446 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.6451 ] MB1-BCT version: 0xe
[ 0.6454 ]
[ 0.6459 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.6465 ]
[ 0.6471 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.6477 ]
[ 0.6484 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.6489 ] Assuming zero filled SBK key
[ 0.6502 ]
[ 0.6510 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.6515 ]
[ 0.6516 ] Generating recovery mb1-bct
[ 0.6521 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.6526 ] MB1-BCT version: 0xe
[ 0.6527 ] Copying Sdram info from 2 to 3 set
[ 0.6670 ] Packing sdram param for instance[0]
[ 0.6671 ] Packing sdram param for instance[1]
[ 0.6672 ] Packing sdram param for instance[2]
[ 0.6674 ] Packing sdram param for instance[3]
[ 0.6675 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.6677 ] Appending platform config data of size :- 2904
[ 0.6679 ] Parsing config file :minimal_scr.cfg
[ 0.6680 ] Appending platform config data of size :- 12240
[ 0.6692 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.6694 ] Appending platform config data of size :- 24
[ 0.6696 ]
[ 0.6696 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.6696 ] Appending platform config data of size :- 708
[ 0.6696 ]
[ 0.6696 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.6696 ] Appending platform config data of size :- 64
[ 0.6696 ]
[ 0.6696 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.6696 ] Appending platform config data of size :- 1652
[ 0.6696 ]
[ 0.6696 ] Updating mb1-bct with firmware information
[ 0.6702 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.6708 ] MB1-BCT version: 0xe
[ 0.6714 ]
[ 0.6715 ] Updating mb1-bct with storage information
[ 0.6724 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.6729 ] MB1-BCT version: 0xe
[ 0.6733 ]
[ 0.6739 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 0.6744 ]
[ 0.6750 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.6756 ]
[ 0.6763 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.6768 ] Assuming zero filled SBK key
[ 0.6781 ]
[ 0.6788 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.6794 ]
[ 0.6794 ] Copying signatures
[ 0.6800 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.7078 ]
[ 0.7078 ] Boot Rom communication
[ 0.7091 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 0.7098 ] BootRom is not running
[ 1.7089 ]
[ 1.7098 ] tegrarcm_v2 --isapplet
[ 1.7102 ] Applet version 01.00.0000
[ 1.7229 ]
[ 1.7229 ] Retrieving board information
[ 1.7237 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 1.7242 ] Applet version 01.00.0000
[ 1.7470 ] Saved platform info in chip_info.bin
[ 1.7482 ] Chip minor revision: 2
[ 1.7489 ]
[ 1.7490 ] Sending BCTs
[ 1.7503 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 1.7508 ] Applet version 01.00.0000
[ 1.7749 ] Sending bct_bootrom
[ 1.7750 ] […] 100%
[ 1.7848 ] Sending bct_mb1
[ 1.7909 ] […] 100%
[ 2001.8012 ]
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing t186ref.
may I have an answer please???
Your log stops after sending bct_mb1 correctly. An excerpt of what should have been seen is this:
[ 3.9240 ] Sending bct_bootrom
[ 3.9241 ] [................................................] 100%
[ 3.9361 ] Sending bct_mb1
[ 3.9417 ] [................................................] 100%
...yours ends here...
[ 4.2920 ]
[ 4.2920 ] Generating blob
[ 4.2939 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
I don’t know what error 8 is. However, since there was an attempt to sign and write data to disk, how much disk space is left at this moment? If you run this command (assuming right after the failure), what do you see (adjust for your flash location)?
df -H -T /where/ever/you/flashed/from/Linux_for_Tegra
Does anyone know specifically what error 8 is (would there happen to be a table of error codes which could be published)?
Are you sure it is GPIO Breakout T-Cobbler that causes the problem?
