Support told me to post here. Essentially I have a jetson tx2 developer board that is less than a week old. I was using when it locked up and would not reboot. I attempted to reflash, but i recieved this error from the console:
[0199.795] I> Welcome to MB2(TBoot-BPMP) Recovery(version: 01.00.160913-t186-M-)
[0199.804] I> Default Heap @ [0xd486400 - 0xd488400]
[0199.809] I> DMA Heap @ [0x85200000 - 0x86200000]
[0199.813] I> bit @ 0xd480000
[0199.816] I> BR-BCT relocated to 0xd7020000
[0199.821] I> Boot-device: eMMC
[0199.967] E> Error opening sdmmc-3
[0199.970] E> Failed to initialize boot device
[0199.974] C> ERROR: Highest Layer Module = 0xf, Lowest Layer Module = 0xf,
Aux Info = 0x2, Reason = 0x2
[0199.984] C> Hang
I am using Jetson 3.2.1 on Ubuntu 16.04. I’ve also tried to flash with ‘sudo ./flash.sh -S 29318MiB jetson-tx2 mmcblk0p1’ after reviewing devtalk.
On the host it hangs at
“[ 3.9517 ] tegrarcm_v2 --boot recovery
[ 3.9540 ] Applet version 01.00.0000
[ 4.2640 ]
[ 4.2670 ] tegrarcm_v2 --isapplet”
Thank you for your help in advance.
That’s a very early boot failure, it’s kind of unusual. It looks like eMMC might be bad. Do you have a complete log of the hang during flash? I’m curious if the steps leading up to that point went as expected.
Console:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 11:59:31
Press CTRL-A Z for help on special keys
[0010.238] I> Welcome to MB1-recovery(prd-version : 14.01.171031-t186-M-00.00-6)
[0010.246] I> rst_source : 0x0
[0010.249] I> rst_level : 0x0
[0010.252] I> Read lock all AES keyslots
[0010.255] I> Read lock all RSA keyslots
[0010.259] I> Clear SE keyslots left open by BR
[0010.264] I> Boot-device: eMMC
[0010.266] I> Entering into 3p server..
[0010.270] I> Transport interface is USB
[0010.274] I> tegrabl_usbf_priv_init:2576 full init:: [0010.278] I> HIGH SPEED
[0010.741] W> Get desc.Unsupported req: desc_index = 0
[0010.748] I> transport_usbf_priv_open USB configuration success
[0011.835] I> Populate eeprom info for module cvm
[0059.821] I> bit @ 0xd480000
[0059.824] I> Downloading bct_bootrom at 0x000000004004e800
[0059.831] I> downloaded image bct_bootrom successfully
[0059.837] I> Downloading bct_mb1 at 0x0000000040000000
[0059.847] I> MB1-BCT relocated to 0xd48bc00 from 0x40000000
[0059.852] I> Supported mb1-bct versions 9-14
[0059.857] I> Version of mb1 bct binary 14
[0059.860] W> MB1 BCT does not have controller prod config data
[0059.866] I> Bootrom patch version : 31 (correctly patched)
[0059.872] I> ATE fuse revision : 0x520a0
[0059.875] I> chip revision : A02P
[0059.879] I> disabled_core_mask: 0xffffff0c
[0059.883] I> Enabled Cores: 0xf3
[0059.886] I> TPC disable fuse status: 0
[0059.889] I> Booting Parker Sku
[0059.892] I> Ram repair fuse : 0x0
[0059.896] I> Mem length:2000
[0059.898] I> tegrabl_ast_init_mapper: AST-cache dump
[0059.903] I> allocated(CO:30) base:0x278000000 size:0x8000000 align: 0x8000000
[0059.911] I> allocated(CO:23) base:0xf0100000 size:0x10000 align: 0x10000
[0059.917] I> allocated(CO:31) base:0x0 size:0x0 align: 0x0
[0059.923] I> allocated(CO:1) base:0x277f00000 size:0x100000 align: 0x100000
[0059.930] I> allocated(CO:2) base:0x277e00000 size:0x100000 align: 0x100000
[0059.936] I> allocated(CO:3) base:0x277d00000 size:0x100000 align: 0x100000
[0059.943] I> allocated(CO:4) base:0x277c00000 size:0x100000 align: 0x100000
[0059.950] I> allocated(CO:5) base:0x277b00000 size:0x100000 align: 0x100000
[0059.957] I> allocated(CO:27) base:0x0 size:0x0 align: 0x0
[0059.962] I> allocated(CO:6) base:0x277800000 size:0x200000 align: 0x200000
[0059.969] I> allocated(CO:7) base:0x277400000 size:0x400000 align: 0x400000
[0059.976] I> allocated(CO:8) base:0x277a00000 size:0x100000 align: 0x100000
[0059.983] I> allocated(CO:9) base:0x277300000 size:0x100000 align: 0x100000
[0059.990] I> allocated(CO:10) base:0x276800000 size:0x800000 align: 0x800000
[0059.997] I> allocated(CO:11) base:0x30000000 size:0x40000 align: 0x0
[0060.003] I> allocated(CO:12) base:0xf0000000 size:0x100000 align: 0x100000
[0060.010] I> allocated(CO:13) base:0x30040000 size:0x1000 align: 0x0
[0060.017] I> allocated(CO:14) base:0x30048000 size:0x1000 align: 0x0
[0060.023] I> allocated(CO:15) base:0x30049000 size:0x1000 align: 0x0
[0060.029] I> allocated(CO:16) base:0x3004a000 size:0x1000 align: 0x0
[0060.035] I> allocated(CO:17) base:0x3004b000 size:0x1000 align: 0x0
[0060.042] I> allocated(CO:19) base:0x3004d000 size:0x1000 align: 0x0
[0060.048] I> allocated(CO:18) base:0x3004c000 size:0x1000 align: 0x0
[0060.054] I> allocated(CO:20) base:0x3004e000 size:0x1000 align: 0x0
[0060.060] I> allocated(CO:21) base:0x3004f000 size:0x1000 align: 0x0
[0060.067] I> allocated(CO:22) base:0x0 size:0x0 align: 0x0
[0060.072] I> allocated(CO:32) base:0x276000000 size:0x600000 align: 0x400000
[0060.079] I> allocated(CO:24) base:0x0 size:0x0 align: 0x0
[0060.084] I> allocated(CO:25) base:0x0 size:0x0 align: 0x0
[0060.090] I> allocated(CO:26) base:0x0 size:0x0 align: 0x0
[0060.095] I> allocated(CO:39) base:0x96000000 size:0x2400000 align: 0x2000000
[0060.102] I> allocated(CO:38) base:0x84000000 size:0x400000 align: 0x400000
[0060.109] I> allocated(CO:37) base:0x2772e0000 size:0x20000 align: 0x20000
[0060.116] I> allocated(CO:40) base:0x85000000 size:0x1200000 align: 0x1000000
[0060.123] I> allocated(CO:41) base:0x277000000 size:0x280000 align: 0x200000
[0060.130] I> allocated(CO:28) base:0x84400000 size:0x400000 align: 0x400000
[0060.137] W> MB1 PMIC CFG is version 1.2
[0060.141] W> Rail ID 7 is not found on MB1 BCT
[0060.146] W> MB1 PMIC CFG is version 1.2
[0060.152] W> MB1 PMIC CFG is version 1.2
[0060.159] W> MB1 PMIC CFG is version 1.2
[0060.163] I> sdram slot : 1
[0060.166] I> Initializing SDRAM
[0060.172] I> mss encrypt status check successful
[0060.177] I> downloaded image bct_mb1 successfully
[0060.626] I> Downloading blob at 0x0000000084800000
[0061.031] I> downloaded image blob successfully
[0061.299] I> exiting nv3p server
[0061.302] I> MB1-recovery(prd-version : 14.01.171031-t186-M-00.00-6b33ecf5)
[0061.309] I> disabled_core_mask: 0xffffff0c
[0061.313] I> Enabled Cores: 0xf3
[0061.316] I> TPC disable fuse status: 0
[0061.320] I> Booting Parker Sku
[0061.323] I> Setup temp. GSC#29 (base:0x30000000, size:0x00010000)
[0061.329] I> Loading preboot
[0061.333] I> Binary(1) of size 62224 is loaded @ 0x40000000
[0061.339] I> Restrict GSC#29 access to DPMU only
[0061.343] I> Updated LSR_DVCOMP_PARAMS: 0xc0740e85c
[0061.348] I> Updated LSR_DVCOMP_PARAMS: 0xc0760ec5c
[0061.353] I> WP0 triggered
[0061.356] I> Waypoint-0 ACK received :)
[0061.359] I> WP0.5 triggered
[0061.363] I> Initialized SCRs
[0061.366] W> MB1 PMIC CFG is version 1.2
[0061.373] W> MB1 PMIC CFG is version 1.2
[0061.425] I> Waypoint-0.5 ACK received :)
[0061.429] I> Setup temp. GSC#28 (base:0x84400000, size:0x00400000)
[0061.435] I> Loading MTS-DMCE
[0061.449] I> Binary(2) of size 265472 is loaded @ 0x84400000
[0061.455] I> disabled_core_mask: 0xffffff0c
[0061.459] I> Loading MTS-PROPER
[0061.462] I> Binary(3) of size 1810512 is loaded @ 0x0
[0061.467] I> Restrict GSC#28 access to DPMU only
[0061.471] I> disabled_core_mask: 0xffffff0c
[0061.475] I> WP1 triggered
[0061.478] I> Loading MB2
[0061.481] I> Binary(8) of size 79200 is loaded @ 0x84000000
[0061.486] W> MB1 PMIC CFG is version 1.2
[0061.491] I> Configure DMCE carveout GSC#13
[0061.495] I> CPU reset vector: 0x96000000
[0061.499] I> MB2-params @ 0xd7000000
[0061.503] I> Waypoint-1 ACK received :)
[0061.507] I> Configure SC7 carveout GSC#23
[0061.511] I> MB1 (recovery) done
[0061.517] I> Welcome to MB2(TBoot-BPMP) Recovery(version: 01.00.160913-t186-M-)
[0061.526] I> Default Heap @ [0xd486400 - 0xd488400]
[0061.531] I> DMA Heap @ [0x85200000 - 0x86200000]
[0061.536] I> bit @ 0xd480000
[0061.539] I> BR-BCT relocated to 0xd7020000
[0061.543] I> Boot-device: eMMC
[0061.688] E> Error opening sdmmc-3
[0061.691] E> Failed to initialize boot device
[0061.695] C> ERROR: Highest Layer Module = 0xf, Lowest Layer Module = 0xf,
[0061.705] C> Hang
Host:
[code]Board ID(3310) version(B02)
copying bctfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Making system.img…
populating rootfs from /home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4255744( 1039 blks) ==> 28:4255756
1: SKP: 24576( 6 blks) ==> 4255784:12
2: RAW: 4096( 1 blks) ==> 4255796:4108
3: SKP: 61440( 15 blks) ==> 4259904:12
4: RAW: 4096( 1 blks) ==> 4259916:4108
5: SKP: 33550336( 8191 blks) ==> 4264024:12
6: RAW: 24576( 6 blks) ==> 4264036:24588
7: SKP: 96292864( 23509 blks) ==> 4288624:12
8: RAW: 20480( 5 blks) ==> 4288636:20492
9: SKP: 4194304( 1024 blks) ==> 4309128:12
10: RAW: 1146880( 280 blks) ==> 4309140:1146892
11: SKP: 667648( 163 blks) ==> 5456032:12
12: RAW: 86016( 21 blks) ==> 5456044:86028
13: SKP: 24576( 6 blks) ==> 5542072:12
14: RAW: 143360( 35 blks) ==> 5542084:143372
15: SKP: 16384( 4 blks) ==> 5685456:12
16: RAW: 8192( 2 blks) ==> 5685468:8204
17: SKP: 4096( 1 blks) ==> 5693672:12
18: RAW: 1253376( 306 blks) ==> 5693684:1253388
19: SKP: 20480( 5 blks) ==> 6947072:12
20: RAW: 4096( 1 blks) ==> 6947084:4108
21: SKP: 40960( 10 blks) ==> 6951192:12
22: RAW: 4096( 1 blks) ==> 6951204:4108
23: SKP: 4096( 1 blks) ==> 6955312:12
24: RAW: 114688( 28 blks) ==> 6955324:114700
25: SKP: 4096( 1 blks) ==> 7070024:12
26: RAW: 126976( 31 blks) ==> 7070036:126988
27: SKP: 4096( 1 blks) ==> 7197024:12
28: RAW: 278528( 68 blks) ==> 7197036:278540
29: SKP: 221184( 54 blks) ==> 7475576:12
30: RAW: 11980800( 2925 blks) ==> 7475588:11980812
31: SKP: 4096( 1 blks) ==> 19456400:12
32: RAW: 4096( 1 blks) ==> 19456412:4108
33: SKP: 4096( 1 blks) ==> 19460520:12
34: RAW: 638976( 156 blks) ==> 19460532:638988
35: SKP: 4096( 1 blks) ==> 20099520:12
36: RAW: 4452352( 1087 blks) ==> 20099532:4452364
37: SKP: 4096( 1 blks) ==> 24551896:12
38: RAW: 4120576( 1006 blks) ==> 24551908:4120588
39: SKP: 73728( 18 blks) ==> 28672496:12
40: RAW: 11456512( 2797 blks) ==> 28672508:11456524
41: SKP: 811008( 198 blks) ==> 40129032:12
42: RAW: 4554752( 1112 blks) ==> 40129044:4554764
43: SKP: 8192( 2 blks) ==> 44683808:12
44: RAW: 11063296( 2701 blks) ==> 44683820:11063308
45: SKP: 4096( 1 blks) ==> 55747128:12
46: RAW: 57344( 14 blks) ==> 55747140:57356
47: SKP: 4096( 1 blks) ==> 55804496:12
48: RAW: 1089536( 266 blks) ==> 55804508:1089548
49: SKP: 12288( 3 blks) ==> 56894056:12
50: RAW: 4096( 1 blks) ==> 56894068:4108
51: SKP: 12288( 3 blks) ==> 56898176:12
52: RAW: 4096( 1 blks) ==> 56898188:4108
53: SKP: 12288( 3 blks) ==> 56902296:12
54: RAW: 16384( 4 blks) ==> 56902308:16396
55: SKP: 16711680( 4080 blks) ==> 56918704:12
56: RAW: 13959168( 3408 blks) ==> 56918716:13959180
57: SKP: 4096( 1 blks) ==> 70877896:12
58: RAW: 733184( 179 blks) ==> 70877908:733196
59: SKP: 2080768( 508 blks) ==> 71611104:12
60: RAW: 14102528( 3443 blks) ==> 71611116:14102540
61: SKP: 20480( 5 blks) ==> 85713656:12
62: RAW: 249856( 61 blks) ==> 85713668:249868
63: SKP: 8192( 2 blks) ==> 85963536:12
64: RAW: 184320( 45 blks) ==> 85963548:184332
65: SKP: 4096( 1 blks) ==> 86147880:12
66: RAW: 172032( 42 blks) ==> 86147892:172044
67: SKP: 2035712( 497 blks) ==> 86319936:12
68: RAW: 43556864( 10634 blks) ==> 86319948:43556876
69: SKP: 4096( 1 blks) ==> 129876824:12
70: RAW: 9244672( 2257 blks) ==> 129876836:9244684
71: SKP: 8192( 2 blks) ==> 139121520:12
72: RAW: 4096( 1 blks) ==> 139121532:4108
73: SKP: 8192( 2 blks) ==> 139125640:12
74: RAW: 16384( 4 blks) ==> 139125652:16396
75: SKP: 4096( 1 blks) ==> 139142048:12
76: RAW: 348160( 85 blks) ==> 139142060:348172
77: SKP: 4096( 1 blks) ==> 139490232:12
78: RAW: 4096( 1 blks) ==> 139490244:4108
79: SKP: 4096( 1 blks) ==> 139494352:12
80: RAW: 409600( 100 blks) ==> 139494364:409612
81: SKP: 4096( 1 blks) ==> 139903976:12
82: RAW: 229376( 56 blks) ==> 139903988:229388
83: SKP: 4096( 1 blks) ==> 140133376:12
84: RAW: 155648( 38 blks) ==> 140133388:155660
85: SKP: 8192( 2 blks) ==> 140289048:12
86: RAW: 180224( 44 blks) ==> 140289060:180236
87: SKP: 8192( 2 blks) ==> 140469296:12
88: RAW: 12288( 3 blks) ==> 140469308:12300
89: SKP: 4096( 1 blks) ==> 140481608:12
90: RAW: 32768( 8 blks) ==> 140481620:32780
91: SKP: 12288( 3 blks) ==> 140514400:12
92: RAW: 36864( 9 blks) ==> 140514412:36876
93: SKP: 4096( 1 blks) ==> 140551288:12
94: RAW: 135168( 33 blks) ==> 140551300:135180
95: SKP: 8192( 2 blks) ==> 140686480:12
96: RAW: 520192( 127 blks) ==> 140686492:520204
97: SKP: 4096( 1 blks) ==> 141206696:12
98: RAW: 28672( 7 blks) ==> 141206708:28684
99: SKP: 4096( 1 blks) ==> 141235392:12
100: RAW: 36864( 9 blks) ==> 141235404:36876
101: SKP: 4096( 1 blks) ==> 141272280:12
102: RAW: 565248( 138 blks) ==> 141272292:565260
103: SKP: 3104768( 758 blks) ==> 141837552:12
104: RAW: 9310208( 2273 blks) ==> 141837564:9310220
105: SKP: 16384( 4 blks) ==> 151147784:12
106: RAW: 49152( 12 blks) ==> 151147796:49164
107: SKP: 4096( 1 blks) ==> 151196960:12
108: RAW: 929792( 227 blks) ==> 151196972:929804
109: SKP: 12288( 3 blks) ==> 152126776:12
110: RAW: 20480( 5 blks) ==> 152126788:20492
111: SKP: 4096( 1 blks) ==> 152147280:12
112: RAW: 110592( 27 blks) ==> 152147292:110604
113: SKP: 4096( 1 blks) ==> 152257896:12
114: RAW: 73728( 18 blks) ==> 152257908:73740
115: SKP: 4096( 1 blks) ==> 152331648:12
116: RAW: 4096( 1 blks) ==> 152331660:4108
117: SKP: 86016( 21 blks) ==> 152335768:12
118: RAW: 16384( 4 blks) ==> 152335780:16396
119: SKP: 4096( 1 blks) ==> 152352176:12
120: RAW: 4096( 1 blks) ==> 152352188:4108
121: SKP: 12288( 3 blks) ==> 152356296:12
122: RAW: 4096( 1 blks) ==> 152356308:4108
123: SKP: 4096( 1 blks) ==> 152360416:12
124: RAW: 8192( 2 blks) ==> 152360428:8204
125: SKP: 4096( 1 blks) ==> 152368632:12
126: RAW: 20480( 5 blks) ==> 152368644:20492
127: SKP: 8192( 2 blks) ==> 152389136:12
128: RAW: 8192( 2 blks) ==> 152389148:8204
129: SKP: 8192( 2 blks) ==> 152397352:12
130: RAW: 49152( 12 blks) ==> 152397364:49164
131: SKP: 12288( 3 blks) ==> 152446528:12
132: RAW: 4096( 1 blks) ==> 152446540:4108
133: SKP: 8192( 2 blks) ==> 152450648:12
134: RAW: 36864( 9 blks) ==> 152450660:36876
135: SKP: 4096( 1 blks) ==> 152487536:12
136: RAW: 4096( 1 blks) ==> 152487548:4108
137: SKP: 20480( 5 blks) ==> 152491656:12
138: RAW: 4096( 1 blks) ==> 152491668:4108
139: SKP: 12288( 3 blks) ==> 152495776:12
140: RAW: 12288( 3 blks) ==> 152495788:12300
141: SKP: 4096( 1 blks) ==> 152508088:12
142: RAW: 4096( 1 blks) ==> 152508100:4108
143: SKP: 4096( 1 blks) ==> 152512208:12
144: RAW: 4096( 1 blks) ==> 152512220:4108
145: SKP: 36864( 9 blks) ==> 152516328:12
146: RAW: 4096( 1 blks) ==> 152516340:4108
147: SKP: 4096( 1 blks) ==> 152520448:12
148: RAW: 4096( 1 blks) ==> 152520460:4108
149: SKP: 24576( 6 blks) ==> 152524568:12
150: RAW: 8192( 2 blks) ==> 152524580:8204
151: SKP: 4096( 1 blks) ==> 152532784:12
152: RAW: 73728( 18 blks) ==> 152532796:73740
153: SKP: 4096( 1 blks) ==> 152606536:12
154: RAW: 4096( 1 blks) ==> 152606548:4108
155: SKP: 4096( 1 blks) ==> 152610656:12
156: RAW: 16384( 4 blks) ==> 152610668:16396
157: SKP: 4096( 1 blks) ==> 152627064:12
158: RAW: 57344( 14 blks) ==> 152627076:57356
159: SKP: 40960( 10 blks) ==> 152684432:12
160: RAW: 12288( 3 blks) ==> 152684444:12300
161: SKP: 4096( 1 blks) ==> 152696744:12
162: RAW: 491520( 120 blks) ==> 152696756:491532
163: SKP: 28672( 7 blks) ==> 153188288:12
164: RAW: 192512( 47 blks) ==> 153188300:192524
165: SKP: 4096( 1 blks) ==> 153380824:12
166: RAW: 8192( 2 blks) ==> 153380836:8204
167: SKP: 16384( 4 blks) ==> 153389040:12
168: RAW: 8192( 2 blks) ==> 153389052:8204
169: SKP: 36864( 9 blks) ==> 153397256:12
170: RAW: 16384( 4 blks) ==> 153397268:16396
171: SKP: 32768( 8 blks) ==> 153413664:12
172: RAW: 32768( 8 blks) ==> 153413676:32780
173: SKP: 4096( 1 blks) ==> 153446456:12
174: RAW: 16384( 4 blks) ==> 153446468:16396
175: SKP: 8192( 2 blks) ==> 153462864:12
176: RAW: 225280( 55 blks) ==> 153462876:225292
177: SKP: 49152( 12 blks) ==> 153688168:12
178: RAW: 4096( 1 blks) ==> 153688180:4108
179: SKP: 172032( 42 blks) ==> 153692288:12
180: RAW: 1101824( 269 blks) ==> 153692300:1101836
181: SKP: 4096( 1 blks) ==> 154794136:12
182: RAW: 172032( 42 blks) ==> 154794148:172044
183: SKP: 8192( 2 blks) ==> 154966192:12
184: RAW: 184320( 45 blks) ==> 154966204:184332
185: SKP: 8192( 2 blks) ==> 155150536:12
186: RAW: 212992( 52 blks) ==> 155150548:213004
187: SKP: 16384( 4 blks) ==> 155363552:12
188: RAW: 16384( 4 blks) ==> 155363564:16396
189: SKP: 61440( 15 blks) ==> 155379960:12
190: RAW: 122880( 30 blks) ==> 155379972:122892
191: SKP: 4096( 1 blks) ==> 155502864:12
192: RAW: 479232( 117 blks) ==> 155502876:479244
193: SKP: 49152( 12 blks) ==> 155982120:12
194: RAW: 4096( 1 blks) ==> 155982132:4108
195: SKP: 204800( 50 blks) ==> 155986240:12
196: RAW: 245760( 60 blks) ==> 155986252:245772
197: SKP: 90112( 22 blks) ==> 156232024:12
198: RAW: 282624( 69 blks) ==> 156232036:282636
199: SKP: 24576( 6 blks) ==> 156514672:12
200: RAW: 8192( 2 blks) ==> 156514684:8204
201: SKP: 86016( 21 blks) ==> 156522888:12
202: RAW: 4096( 1 blks) ==> 156522900:4108
203: SKP: 12288( 3 blks) ==> 156527008:12
204: RAW: 4096( 1 blks) ==> 156527020:4108
205: SKP: 61440( 15 blks) ==> 156531128:12
206: RAW: 4096( 1 blks) ==> 156531140:4108
207: SKP: 77824( 19 blks) ==> 156535248:12
208: RAW: 4096( 1 blks) ==> 156535260:4108
209: SKP: 4096( 1 blks) ==> 156539368:12
210: RAW: 4096( 1 blks) ==> 156539380:4108
211: SKP: 28672( 7 blks) ==> 156543488:12
212: RAW: 16384( 4 blks) ==> 156543500:16396
213: SKP: 598016( 146 blks) ==> 156559896:12
214: RAW: 31690752( 7737 blks) ==> 156559908:31690764
215: SKP: 4096( 1 blks) ==> 188250672:12
216: RAW: 339968( 83 blks) ==> 188250684:339980
217: SKP: 16384( 4 blks) ==> 188590664:12
218: RAW: 180224( 44 blks) ==> 188590676:180236
219: SKP: 32768( 8 blks) ==> 188770912:12
220: RAW: 65536( 16 blks) ==> 188770924:65548
221: SKP: 4096( 1 blks) ==> 188836472:12
222: RAW: 434176( 106 blks) ==> 188836484:434188
223: SKP: 4096( 1 blks) ==> 189270672:12
224: RAW: 180224( 44 blks) ==> 189270684:180236
225: SKP: 4096( 1 blks) ==> 189450920:12
226: RAW: 16384( 4 blks) ==> 189450932:16396
227: SKP: 4096( 1 blks) ==> 189467328:12
228: RAW: 393216( 96 blks) ==> 189467340:393228
229: SKP: 8192( 2 blks) ==> 189860568:12
230: RAW: 77824( 19 blks) ==> 189860580:77836
231: SKP: 4096( 1 blks) ==> 189938416:12
232: RAW: 36864( 9 blks) ==> 189938428:36876
233: SKP: 4096( 1 blks) ==> 189975304:12
234: RAW: 16252928( 3968 blks) ==> 189975316:16252940
235: SKP: 12288( 3 blks) ==> 206228256:12
236: RAW: 73728( 18 blks) ==> 206228268:73740
237: SKP: 12288( 3 blks) ==> 206302008:12
238: RAW: 73728( 18 blks) ==> 206302020:73740
239: SKP: 12288( 3 blks) ==> 206375760:12
240: RAW: 69632( 17 blks) ==> 206375772:69644
241: SKP: 16384( 4 blks) ==> 206445416:12
242: RAW: 69632( 17 blks) ==> 206445428:69644
243: SKP: 16384( 4 blks) ==> 206515072:12
244: RAW: 61440( 15 blks) ==> 206515084:61452
245: SKP: 16384( 4 blks) ==> 206576536:12
246: RAW: 65536( 16 blks) ==> 206576548:65548
247: SKP: 4096( 1 blks) ==> 206642096:12
248: RAW: 19386368( 4733 blks) ==> 206642108:19386380
249: SKP: 4096( 1 blks) ==> 226028488:12
250: RAW: 2560000( 625 blks) ==> 226028500:2560012
251: SKP: 8192( 2 blks) ==> 228588512:12
252: RAW: 2871296( 701 blks) ==> 228588524:2871308
253: SKP: 4096( 1 blks) ==> 231459832:12
254: RAW: 16384( 4 blks) ==> 231459844:16396
255: SKP: 4096( 1 blks) ==> 231476240:12
256: RAW: 344064( 84 blks) ==> 231476252:344076
257: SKP: 4096( 1 blks) ==> 231820328:12
258: RAW: 12288( 3 blks) ==> 231820340:12300
259: SKP: 24576( 6 blks) ==> 231832640:12
260: RAW: 8409088( 2053 blks) ==> 231832652:8409100
261: SKP: 4194304( 1024 blks) ==> 240241752:12
262: RAW: 327680( 80 blks) ==> 240241764:327692
263: SKP: 49152( 12 blks) ==> 240569456:12
264: RAW: 4096( 1 blks) ==> 240569468:4108
265: SKP: 208896( 51 blks) ==> 240573576:12
266: RAW: 307200( 75 blks) ==> 240573588:307212
267: SKP: 86016( 21 blks) ==> 240880800:12
268: RAW: 282624( 69 blks) ==> 240880812:282636
269: SKP: 24576( 6 blks) ==> 241163448:12
270: RAW: 8192( 2 blks) ==> 241163460:8204
271: SKP: 57344( 14 blks) ==> 241171664:12
272: RAW: 4096( 1 blks) ==> 241171676:4108
273: SKP: 12288( 3 blks) ==> 241175784:12
274: RAW: 4096( 1 blks) ==> 241175796:4108
275: SKP: 45056( 11 blks) ==> 241179904:12
276: RAW: 4096( 1 blks) ==> 241179916:4108
277: SKP: 61440( 15 blks) ==> 241184024:12
278: RAW: 12288( 3 blks) ==> 241184036:12300
279: SKP: 28672( 7 blks) ==> 241196336:12
280: RAW: 16384( 4 blks) ==> 241196348:16396
281: SKP: 2629632( 642 blks) ==> 241212744:12
282: RAW: 10690560( 2610 blks) ==> 241212756:10690572
283: SKP: 4096( 1 blks) ==> 251903328:12
284: RAW: 1413120( 345 blks) ==> 251903340:1413132
285: SKP: 4096( 1 blks) ==> 253316472:12
286: RAW: 1146880( 280 blks) ==> 253316484:1146892
287: SKP: 8192( 2 blks) ==> 254463376:12
288: RAW: 2760704( 674 blks) ==> 254463388:2760716
289: SKP: 4096( 1 blks) ==> 257224104:12
290: RAW: 16384( 4 blks) ==> 257224116:16396
291: SKP: 4096( 1 blks) ==> 257240512:12
292: RAW: 344064( 84 blks) ==> 257240524:344076
293: SKP: 4096( 1 blks) ==> 257584600:12
294: RAW: 12288( 3 blks) ==> 257584612:12300
295: SKP: 86016( 21 blks) ==> 257596912:12
296: RAW: 122880( 30 blks) ==> 257596924:122892
297: SKP: 4096( 1 blks) ==> 257719816:12
298: RAW: 14286848( 3488 blks) ==> 257719828:14286860
299: SKP: 61440( 15 blks) ==> 272006688:12
300: RAW: 16384( 4 blks) ==> 272006700:16396
301: SKP: 45056( 11 blks) ==> 272023096:12
302: RAW: 139264( 34 blks) ==> 272023108:139276
303: SKP: 12288( 3 blks) ==> 272162384:12
304: RAW: 20480( 5 blks) ==> 272162396:20492
305: SKP: 12288( 3 blks) ==> 272182888:12
306: RAW: 4096( 1 blks) ==> 272182900:4108
307: SKP: 12288( 3 blks) ==> 272187008:12
308: RAW: 28672( 7 blks) ==> 272187020:28684
309: SKP: 4096( 1 blks) ==> 272215704:12
310: RAW: 8192( 2 blks) ==> 272215716:8204
311: SKP: 4096( 1 blks) ==> 272223920:12
312: RAW: 4096( 1 blks) ==> 272223932:4108
313: SKP: 4096( 1 blks) ==> 272228040:12
314: RAW: 12288( 3 blks) ==> 272228052:12300
315: SKP: 8192( 2 blks) ==> 272240352:12
316: RAW: 24576( 6 blks) ==> 272240364:24588
317: SKP: 12288( 3 blks) ==> 272264952:12
318: RAW: 49152( 12 blks) ==> 272264964:49164
319: SKP: 2158592( 527 blks) ==> 272314128:12
320: RAW: 4972544( 1214 blks) ==> 272314140:4972556
321: SKP: 16384( 4 blks) ==> 277286696:12
322: RAW: 8192( 2 blks) ==> 277286708:8204
323: SKP: 16384( 4 blks) ==> 277294912:12
324: RAW: 32768( 8 blks) ==> 277294924:32780
325: SKP: 4096( 1 blks) ==> 277327704:12
326: RAW: 4096( 1 blks) ==> 277327716:4108
327: SKP: 12288( 3 blks) ==> 277331824:12
328: RAW: 8192( 2 blks) ==> 277331836:8204
329: SKP: 12288( 3 blks) ==> 277340040:12
330: RAW: 8192( 2 blks) ==> 277340052:8204
331: SKP: 8192( 2 blks) ==> 277348256:12
332: RAW: 28672( 7 blks) ==> 277348268:28684
333: SKP: 4096( 1 blks) ==> 277376952:12
334: RAW: 4096( 1 blks) ==> 277376964:4108
335: SKP: 12288( 3 blks) ==> 277381072:12
336: RAW: 8192( 2 blks) ==> 277381084:8204
337: SKP: 12288( 3 blks) ==> 277389288:12
338: RAW: 32768( 8 blks) ==> 277389300:32780
339: SKP: 12288( 3 blks) ==> 277422080:12
340: RAW: 8192( 2 blks) ==> 277422092:8204
341: SKP: 12288( 3 blks) ==> 277430296:12
342: RAW: 4096( 1 blks) ==> 277430308:4108
343: SKP: 12288( 3 blks) ==> 277434416:12
344: RAW: 8192( 2 blks) ==> 277434428:8204
345: SKP: 12288( 3 blks) ==> 277442632:12
346: RAW: 8192( 2 blks) ==> 277442644:8204
347: SKP: 12288( 3 blks) ==> 277450848:12
348: RAW: 4096( 1 blks) ==> 277450860:4108
349: SKP: 12288( 3 blks) ==> 277454968:12
350: RAW: 8192( 2 blks) ==> 277454980:8204
351: SKP: 12288( 3 blks) ==> 277463184:12
352: RAW: 8192( 2 blks) ==> 277463196:8204
353: SKP: 12288( 3 blks) ==> 277471400:12
354: RAW: 4096( 1 blks) ==> 277471412:4108
355: SKP: 12288( 3 blks) ==> 277475520:12
356: RAW: 8192( 2 blks) ==> 277475532:8204
357: SKP: 12288( 3 blks) ==> 277483736:12
358: RAW: 8192( 2 blks) ==> 277483748:8204
359: SKP: 12288( 3 blks) ==> 277491952:12
360: RAW: 4096( 1 blks) ==> 277491964:4108
361: SKP: 12288( 3 blks) ==> 277496072:12
362: RAW: 8192( 2 blks) ==> 277496084:8204
363: SKP: 12288( 3 blks) ==> 277504288:12
364: RAW: 8192( 2 blks) ==> 277504300:8204
365: SKP: 12288( 3 blks) ==> 277512504:12
366: RAW: 4096( 1 blks) ==> 277512516:4108
367: SKP: 12288( 3 blks) ==> 277516624:12
368: RAW: 8192( 2 blks) ==> 277516636:8204
369: SKP: 12288( 3 blks) ==> 277524840:12
370: RAW: 4096( 1 blks) ==> 277524852:4108
371: SKP: 12288( 3 blks) ==> 277528960:12
372: RAW: 8192( 2 blks) ==> 277528972:8204
373: SKP: 12288( 3 blks) ==> 277537176:12
374: RAW: 4096( 1 blks) ==> 277537188:4108
375: SKP: 12288( 3 blks) ==> 277541296:12
376: RAW: 8192( 2 blks) ==> 277541308:8204
377: SKP: 12288( 3 blks) ==> 277549512:12
378: RAW: 4096( 1 blks) ==> 277549524:4108
379: SKP: 12288( 3 blks) ==> 277553632:12
380: RAW: 8192( 2 blks) ==> 277553644:8204
381: SKP: 12288( 3 blks) ==> 277561848:12
382: RAW: 8192( 2 blks) ==> 277561860:8204
383: SKP: 8192( 2 blks) ==> 277570064:12
384: RAW: 8192( 2 blks) ==> 277570076:8204
385: SKP: 4096( 1 blks) ==> 277578280:12
386: RAW: 4096( 1 blks) ==> 277578292:4108
387: SKP: 16384( 4 blks) ==> 277582400:12
388: RAW: 16384( 4 blks) ==> 277582412:16396
389: SKP: 12288( 3 blks) ==> 277598808:12
390: RAW: 8192( 2 blks) ==> 277598820:8204
391: SKP: 4096( 1 blks) ==> 277607024:12
392: RAW: 8192( 2 blks) ==> 277607036:8204
393: SKP: 12288( 3 blks) ==> 277615240:12
394: RAW: 12288( 3 blks) ==> 277615252:12300
395: SKP: 12288( 3 blks) ==> 277627552:12
396: RAW: 8192( 2 blks) ==> 277627564:8204
397: SKP: 12288( 3 blks) ==> 277635768:12
398: RAW: 8192( 2 blks) ==> 277635780:8204
399: SKP: 12288( 3 blks) ==> 277643984:12
400: RAW: 8192( 2 blks) ==> 277643996:8204
401: SKP: 12288( 3 blks) ==> 277652200:12
402: RAW: 8192( 2 blks) ==> 277652212:8204
403: SKP: 12288( 3 blks) ==> 277660416:12
404: RAW: 4096( 1 blks) ==> 277660428:4108
405: SKP: 12288( 3 blks) ==> 277664536:12
406: RAW: 8192( 2 blks) ==> 277664548:8204
407: SKP: 12288( 3 blks) ==> 277672752:12
408: RAW: 8192( 2 blks) ==> 277672764:8204
409: SKP: 12288( 3 blks) ==> 277680968:12
410: RAW: 4096( 1 blks) ==> 277680980:4108
411: SKP: 12288( 3 blks) ==> 277685088:12
412: RAW: 8192( 2 blks) ==> 277685100:8204
413: SKP: 12288( 3 blks) ==> 277693304:12
414: RAW: 4096( 1 blks) ==> 277693316:4108
415: SKP: 12288( 3 blks) ==> 277697424:12
416: RAW: 8192( 2 blks) ==> 277697436:8204
417: SKP: 12288( 3 blks) ==> 277705640:12
418: RAW: 8192( 2 blks) ==> 277705652:8204
419: SKP: 8192( 2 blks) ==> 277713856:12
420: RAW: 8192( 2 blks) ==> 277713868:8204
421: SKP: 12288( 3 blks) ==> 277722072:12
422: RAW: 8192( 2 blks) ==> 277722084:8204
423: SKP: 12288( 3 blks) ==> 277730288:12
424: RAW: 4096( 1 blks) ==> 277730300:4108
425: SKP: 12288( 3 blks) ==> 277734408:12
426: RAW: 8192( 2 blks) ==> 277734420:8204
427: SKP: 12288( 3 blks) ==> 277742624:12
428: RAW: 4096( 1 blks) ==> 277742636:4108
429: SKP: 12288( 3 blks) ==> 277746744:12
430: RAW: 8192( 2 blks) ==> 277746756:8204
431: SKP: 12288( 3 blks) ==> 277754960:12
432: RAW: 4096( 1 blks) ==> 277754972:4108
433: SKP: 12288( 3 blks) ==> 277759080:12
434: RAW: 8192( 2 blks) ==> 277759092:8204
435: SKP: 12288( 3 blks) ==> 277767296:12
436: RAW: 4096( 1 blks) ==> 277767308:4108
437: SKP: 12288( 3 blks) ==> 277771416:12
438: RAW: 8192( 2 blks) ==> 277771428:8204
439: SKP: 12288( 3 blks) ==> 277779632:12
440: RAW: 8192( 2 blks) ==> 277779644:8204
441: SKP: 12288( 3 blks) ==> 277787848:12
442: RAW: 4096( 1 blks) ==> 277787860:4108
443: SKP: 12288( 3 blks) ==> 277791968:12
444: RAW: 8192( 2 blks) ==> 277791980:8204
445: SKP: 12288( 3 blks) ==> 277800184:12
446: RAW: 4096( 1 blks) ==> 277800196:4108
447: SKP: 12288( 3 blks) ==> 277804304:12
448: RAW: 4096( 1 blks) ==> 277804316:4108
449: SKP: 4096( 1 blks) ==> 277808424:12
450: RAW: 4096( 1 blks) ==> 277808436:4108
451: SKP: 12288( 3 blks) ==> 277812544:12
452: RAW: 4096( 1 blks) ==> 277812556:4108
453: SKP: 12288( 3 blks) ==> 277816664:12
454: RAW: 8192( 2 blks) ==> 277816676:8204
455: SKP: 12288( 3 blks) ==> 277824880:12
456: RAW: 8192( 2 blks) ==> 277824892:8204
457: SKP: 12288( 3 blks) ==> 277833096:12
458: RAW: 4096( 1 blks) ==> 277833108:4108
459: SKP: 12288( 3 blks) ==> 277837216:12
460: RAW: 8192( 2 blks) ==> 277837228:8204
461: SKP: 12288( 3 blks) ==> 277845432:12
462: RAW: 8192( 2 blks) ==> 277845444:8204
463: SKP: 12288( 3 blks) ==> 277853648:12
464: RAW: 4096( 1 blks) ==> 277853660:4108
465: SKP: 12288( 3 blks) ==> 277857768:12
466: RAW: 8192( 2 blks) ==> 277857780:8204
467: SKP: 12288( 3 blks) ==> 277865984:12
468: RAW: 8192( 2 blks) ==> 277865996:8204
469: SKP: 8192( 2 blks) ==> 277874200:12
470: RAW: 8192( 2 blks) ==> 277874212:8204
471: SKP: 12288( 3 blks) ==> 277882416:12
472: RAW: 8192( 2 blks) ==> 277882428:8204
473: SKP: 12288( 3 blks) ==> 277890632:12
474: RAW: 8192( 2 blks) ==> 277890644:8204
475: SKP: 12288( 3 blks) ==> 277898848:12
476: RAW: 4096( 1 blks) ==> 277898860:4108
477: SKP: 12288( 3 blks) ==> 277902968:12
478: RAW: 8192( 2 blks) ==> 277902980:8204
479: SKP: 12288( 3 blks) ==> 277911184:12
480: RAW: 4096( 1 blks) ==> 277911196:4108
481: SKP: 12288( 3 blks) ==> 277915304:12
482: RAW: 12288( 3 blks) ==> 277915316:12300
483: SKP: 12288( 3 blks) ==> 277927616:12
484: RAW: 8192( 2 blks) ==> 277927628:8204
485: SKP: 12288( 3 blks) ==> 277935832:12
486: RAW: 12288( 3 blks) ==> 277935844:12300
487: SKP: 12288( 3 blks) ==> 277948144:12
488: RAW: 8192( 2 blks) ==> 277948156:8204
489: SKP: 12288( 3 blks) ==> 277956360:12
490: RAW: 8192( 2 blks) ==> 277956372:8204
491: SKP: 12288( 3 blks) ==> 277964576:12
492: RAW: 4096( 1 blks) ==> 277964588:4108
493: SKP: 12288( 3 blks) ==> 277968696:12
494: RAW: 8192( 2 blks) ==> 277968708:8204
495: SKP: 12288( 3 blks) ==> 277976912:12
496: RAW: 8192( 2 blks) ==> 277976924:8204
497: SKP: 8192( 2 blks) ==> 277985128:12
498: RAW: 8192( 2 blks) ==> 277985140:8204
499: SKP: 12288( 3 blks) ==> 277993344:12
500: RAW: 12288( 3 blks) ==> 277993356:12300
501: SKP: 12288( 3 blks) ==> 278005656:12
502: RAW: 12288( 3 blks) ==> 278005668:12300
503: SKP: 12288( 3 blks) ==> 278017968:12
504: RAW: 8192( 2 blks) ==> 278017980:8204
505: SKP: 12288( 3 blks) ==> 278026184:12
506: RAW: 4096( 1 blks) ==> 278026196:4108
507: SKP: 12288( 3 blks) ==> 278030304:12
508: RAW: 8192( 2 blks) ==> 278030316:8204
509: SKP: 12288( 3 blks) ==> 278038520:12
510: RAW: 8192( 2 blks) ==> 278038532:8204
511: SKP: 12288( 3 blks) ==> 278046736:12
512: RAW: 4096( 1 blks) ==> 278046748:4108
513: SKP: 12288( 3 blks) ==> 278050856:12
514: RAW: 8192( 2 blks) ==> 278050868:8204
515: SKP: 12288( 3 blks) ==> 278059072:12
516: RAW: 8192( 2 blks) ==> 278059084:8204
517: SKP: 12288( 3 blks) ==> 278067288:12
518: RAW: 12288( 3 blks) ==> 278067300:12300
519: SKP: 12288( 3 blks) ==> 278079600:12
520: RAW: 8192( 2 blks) ==> 278079612:8204
521: SKP: 12288( 3 blks) ==> 278087816:12
522: RAW: 8192( 2 blks) ==> 278087828:8204
523: SKP: 4096( 1 blks) ==> 278096032:12
524: RAW: 8192( 2 blks) ==> 278096044:8204
525: SKP: 8192( 2 blks) ==> 278104248:12
526: RAW: 8192( 2 blks) ==> 278104260:8204
527: SKP: 12288( 3 blks) ==> 278112464:12
528: RAW: 8192( 2 blks) ==> 278112476:8204
529: SKP: 12288( 3 blks) ==> 278120680:12
530: RAW: 4096( 1 blks) ==> 278120692:4108
531: SKP: 12288( 3 blks) ==> 278124800:12
532: RAW: 8192( 2 blks) ==> 278124812:8204
533: SKP: 12288( 3 blks) ==> 278133016:12
534: RAW: 4096( 1 blks) ==> 278133028:4108
535: SKP: 12288( 3 blks) ==> 278137136:12
536: RAW: 8192( 2 blks) ==> 278137148:8204
537: SKP: 12288( 3 blks) ==> 278145352:12
538: RAW: 4096( 1 blks) ==> 278145364:4108
539: SKP: 12288( 3 blks) ==> 278149472:12
540: RAW: 8192( 2 blks) ==> 278149484:8204
541: SKP: 12288( 3 blks) ==> 278157688:12
542: RAW: 4096( 1 blks) ==> 278157700:4108
543: SKP: 12288( 3 blks) ==> 278161808:12
544: RAW: 8192( 2 blks) ==> 278161820:8204
545: SKP: 12288( 3 blks) ==> 278170024:12
546: RAW: 4096( 1 blks) ==> 278170036:4108
547: SKP: 12288( 3 blks) ==> 278174144:12
548: RAW: 8192( 2 blks) ==> 278174156:8204
549: SKP: 12288( 3 blks) ==> 278182360:12
550: RAW: 4096( 1 blks) ==> 278182372:4108
551: SKP: 12288( 3 blks) ==> 278186480:12
552: RAW: 8192( 2 blks) ==> 278186492:8204
553: SKP: 4096( 1 blks) ==> 278194696:12
554: RAW: 4096( 1 blks) ==> 278194708:4108
555: SKP: 12288( 3 blks) ==> 278198816:12
556: RAW: 4096( 1 blks) ==> 278198828:4108
557: SKP: 4096( 1 blks) ==> 278202936:12
558: RAW: 4096( 1 blks) ==> 278202948:4108
559: SKP: 12288( 3 blks) ==> 278207056:12
560: RAW: 16384( 4 blks) ==> 278207068:16396
561: SKP: 12288( 3 blks) ==> 278223464:12
562: RAW: 4096( 1 blks) ==> 278223476:4108
563: SKP: 4096( 1 blks) ==> 278227584:12
564: RAW: 4096( 1 blks) ==> 278227596:4108
565: SKP: 12288( 3 blks) ==> 278231704:12
566: RAW: 8192( 2 blks) ==> 278231716:8204
567: SKP: 12288( 3 blks) ==> 278239920:12
568: RAW: 4096( 1 blks) ==> 278239932:4108
569: SKP: 12288( 3 blks) ==> 278244040:12
570: RAW: 8192( 2 blks) ==> 278244052:8204
571: SKP: 12288( 3 blks) ==> 278252256:12
572: RAW: 4096( 1 blks) ==> 278252268:4108
573: SKP: 12288( 3 blks) ==> 278256376:12
574: RAW: 8192( 2 blks) ==> 278256388:8204
575: SKP: 12288( 3 blks) ==> 278264592:12
576: RAW: 8192( 2 blks) ==> 278264604:8204
577: SKP: 8192( 2 blks) ==> 278272808:12
578: RAW: 12288( 3 blks) ==> 278272820:12300
579: SKP: 12288( 3 blks) ==> 278285120:12
580: RAW: 8192( 2 blks) ==> 278285132:8204
581: SKP: 12288( 3 blks) ==> 278293336:12
582: RAW: 4096( 1 blks) ==> 278293348:4108
583: SKP: 12288( 3 blks) ==> 278297456:12
584: RAW: 8192( 2 blks) ==> 278297468:8204
585: SKP: 12288( 3 blks) ==> 278305672:12
586: RAW: 4096( 1 blks) ==> 278305684:4108
587: SKP: 12288( 3 blks) ==> 278309792:12
588: RAW: 8192( 2 blks) ==> 278309804:8204
589: SKP: 12288( 3 blks) ==> 278318008:12
590: RAW: 4096( 1 blks) ==> 278318020:4108
591: SKP: 12288( 3 blks) ==> 278322128:12
592: RAW: 8192( 2 blks) ==> 278322140:8204
593: SKP: 12288( 3 blks) ==> 278330344:12
594: RAW: 4096( 1 blks) ==> 278330356:4108
595: SKP: 12288( 3 blks) ==> 278334464:12
596: RAW: 8192( 2 blks) ==> 278334476:8204
597: SKP: 12288( 3 blks) ==> 278342680:12
598: RAW: 4096( 1 blks) ==> 278342692:4108
599: SKP: 12288( 3 blks) ==> 278346800:12
600: RAW: 8192( 2 blks) ==> 278346812:8204
601: SKP: 12288( 3 blks) ==> 278355016:12
602: RAW: 4096( 1 blks) ==> 278355028:4108
603: SKP: 12288( 3 blks) ==> 278359136:12
604: RAW: 8192( 2 blks) ==> 278359148:8204
605: SKP: 12288( 3 blks) ==> 278367352:12
606: RAW: 8192( 2 blks) ==> 278367364:8204
607: SKP: 8192( 2 blks) ==> 278375568:12
608: RAW: 8192( 2 blks) ==> 278375580:8204
609: SKP: 12288( 3 blks) ==> 278383784:12
610: RAW: 8192( 2 blks) ==> 278383796:8204
611: SKP: 12288( 3 blks) ==> 278392000:12
612: RAW: 4096( 1 blks) ==> 278392012:4108
613: SKP: 12288( 3 blks) ==> 278396120:12
614: RAW: 8192( 2 blks) ==> 278396132:8204
615: SKP: 12288( 3 blks) ==> 278404336:12
616: RAW: 4096( 1 blks) ==> 278404348:4108
617: SKP: 12288( 3 blks) ==> 278408456:12
618: RAW: 8192( 2 blks) ==> 278408468:8204
619: SKP: 12288( 3 blks) ==> 278416672:12
620: RAW: 4096( 1 blks) ==> 278416684:4108
621: SKP: 12288( 3 blks) ==> 278420792:12
622: RAW: 8192( 2 blks) ==> 278420804:8204
623: SKP: 12288( 3 blks) ==> 278429008:12
624: RAW: 4096( 1 blks) ==> 278429020:4108
625: SKP: 12288( 3 blks) ==> 278433128:12
626: RAW: 8192( 2 blks) ==> 278433140:8204
627: SKP: 12288( 3 blks) ==> 278441344:12
628: RAW: 4096( 1 blks) ==> 278441356:4108
629: SKP: 12288( 3 blks) ==> 278445464:12
630: RAW: 8192( 2 blks) ==> 278445476:8204
631: SKP: 12288( 3 blks) ==> 278453680:12
632: RAW: 8192( 2 blks) ==> 278453692:8204
633: SKP: 12288( 3 blks) ==> 278461896:12
634: RAW: 4096( 1 blks) ==> 278461908:4108
635: SKP: 12288( 3 blks) ==> 278466016:12
636: RAW: 8192( 2 blks) ==> 278466028:8204
637: SKP: 12288( 3 blks) ==> 278474232:12
638: RAW: 8192( 2 blks) ==> 278474244:8204
639: SKP: 12288( 3 blks) ==> 278482448:12
640: RAW: 4096( 1 blks) ==> 278482460:4108
641: SKP: 12288( 3 blks) ==> 278486568:12
642: RAW: 8192( 2 blks) ==> 278486580:8204
643: SKP: 12288( 3 blks) ==> 278494784:12
644: RAW: 4096( 1 blks) ==> 278494796:4108
645: SKP: 12288( 3 blks) ==> 278498904:12
646: RAW: 8192( 2 blks) ==> 278498916:8204
647: SKP: 12288( 3 blks) ==> 278507120:12
648: RAW: 8192( 2 blks) ==> 278507132:8204
649: SKP: 8192( 2 blks) ==> 278515336:12
650: RAW: 8192( 2 blks) ==> 278515348:8204
651: SKP: 12288( 3 blks) ==> 278523552:12
652: RAW: 8192( 2 blks) ==> 278523564:8204
653: SKP: 12288( 3 blks) ==> 278531768:12
654: RAW: 4096( 1 blks) ==> 278531780:4108
655: SKP: 12288( 3 blks) ==> 278535888:12
656: RAW: 8192( 2 blks) ==> 278535900:8204
657: SKP: 12288( 3 blks) ==> 278544104:12
658: RAW: 4096( 1 blks) ==> 278544116:4108
659: SKP: 12288( 3 blks) ==> 278548224:12
660: RAW: 8192( 2 blks) ==> 278548236:8204
661: SKP: 4096( 1 blks) ==> 278556440:12
662: RAW: 4096( 1 blks) ==> 278556452:4108
663: SKP: 12288( 3 blks) ==> 278560560:12
664: RAW: 8192( 2 blks) ==> 278560572:8204
665: SKP: 12288( 3 blks) ==> 278568776:12
666: RAW: 4096( 1 blks) ==> 278568788:4108
667: SKP: 12288( 3 blks) ==> 278572896:12
668: RAW: 4096( 1 blks) ==> 278572908:4108
669: SKP: 12288( 3 blks) ==> 278577016:12
670: RAW: 12288( 3 blks) ==> 278577028:12300
671: SKP: 12288( 3 blks) ==> 278589328:12
672: RAW: 4096( 1 blks) ==> 278589340:4108
673: SKP: 12288( 3 blks) ==> 278593448:12
674: RAW: 8192( 2 blks) ==> 278593460:8204
675: SKP: 12288( 3 blks) ==> 278601664:12
676: RAW: 4096( 1 blks) ==> 278601676:4108
677: SKP: 12288( 3 blks) ==> 278605784:12
678: RAW: 8192( 2 blks) ==> 278605796:8204
679: SKP: 12288( 3 blks) ==> 278614000:12
680: RAW: 8192( 2 blks) ==> 278614012:8204
681: SKP: 12288( 3 blks) ==> 278622216:12
682: RAW: 4096( 1 blks) ==> 278622228:4108
683: SKP: 12288( 3 blks) ==> 278626336:12
684: RAW: 8192( 2 blks) ==> 278626348:8204
685: SKP: 12288( 3 blks) ==> 278634552:12
686: RAW: 8192( 2 blks) ==> 278634564:8204
687: SKP: 12288( 3 blks) ==> 278642768:12
688: RAW: 4096( 1 blks) ==> 278642780:4108
689: SKP: 12288( 3 blks) ==> 278646888:12
690: RAW: 8192( 2 blks) ==> 278646900:8204
691: SKP: 12288( 3 blks) ==> 278655104:12
692: RAW: 8192( 2 blks) ==> 278655116:8204
693: SKP: 12288( 3 blks) ==> 278663320:12
694: RAW: 122880( 30 blks) ==> 278663332:122892
695: SKP: 12288( 3 blks) ==> 278786224:12
696: RAW: 8192( 2 blks) ==> 278786236:8204
697: SKP: 12288( 3 blks) ==> 278794440:12
698: RAW: 4096( 1 blks) ==> 278794452:4108
699: SKP: 12288( 3 blks) ==> 278798560:12
700: RAW: 8192( 2 blks) ==> 278798572:8204
701: SKP: 24576( 6 blks) ==> 278806776:12
702: RAW: 73728( 18 blks) ==> 278806788:73740
703: SKP: 12288( 3 blks) ==> 278880528:12
704: RAW: 8192( 2 blks) ==> 278880540:8204
705: SKP: 12288( 3 blks) ==> 278888744:12
706: RAW: 8192( 2 blks) ==> 278888756:8204
707: SKP: 12288( 3 blks) ==> 278896960:12
708: RAW: 4096( 1 blks) ==> 278896972:4108
709: SKP: 12288( 3 blks) ==> 278901080:12
710: RAW: 12288( 3 blks) ==> 278901092:12300
711: SKP: 8192( 2 blks) ==> 278913392:12
712: RAW: 12288( 3 blks) ==> 278913404:12300
713: SKP: 12288( 3 blks) ==> 278925704:12
714: RAW: 8192( 2 blks) ==> 278925716:8204
715: SKP: 12288( 3 blks) ==> 278933920:12
716: RAW: 8192( 2 blks) ==> 278933932:8204
717: SKP: 12288( 3 blks) ==> 278942136:12
718: RAW: 8192( 2 blks) ==> 278942148:8204
719: SKP: 12288( 3 blks) ==> 278950352:12
720: RAW: 4096( 1 blks) ==> 278950364:4108
721: SKP: 4096( 1 blks) ==> 278954472:12
722: RAW: 4096( 1 blks) ==> 278954484:4108
723: SKP: 12288( 3 blks) ==> 278958592:12
724: RAW: 4096( 1 blks) ==> 278958604:4108
725: SKP: 8192( 2 blks) ==> 278962712:12
726: RAW: 4096( 1 blks) ==> 278962724:4108
727: SKP: 4096( 1 blks) ==> 278966832:12
728: RAW: 4096( 1 blks) ==> 278966844:4108
729: SKP: 4096( 1 blks) ==> 278970952:12
730: RAW: 16384( 4 blks) ==> 278970964:16396
731: SKP: 4096( 1 blks) ==> 278987360:12
732: RAW: 4096( 1 blks) ==> 278987372:4108
733: SKP: 4096( 1 blks) ==> 278991480:12
734: RAW: 4096( 1 blks) ==> 278991492:4108
735: SKP: 8192( 2 blks) ==> 278995600:12
736: RAW: 12288( 3 blks) ==> 278995612:12300
737: SKP: 4096( 1 blks) ==> 279007912:12
738: RAW: 4096( 1 blks) ==> 279007924:4108
739: SKP: 4096( 1 blks) ==> 279012032:12
740: RAW: 4096( 1 blks) ==> 279012044:4108
741: SKP: 8192( 2 blks) ==> 279016152:12
742: RAW: 4096( 1 blks) ==> 279016164:4108
743: SKP: 4096( 1 blks) ==> 279020272:12
744: RAW: 4096( 1 blks) ==> 279020284:4108
745: SKP: 4096( 1 blks) ==> 279024392:12
746: RAW: 16384( 4 blks) ==> 279024404:16396
747: SKP: 4096( 1 blks) ==> 279040800:12
748: RAW: 4096( 1 blks) ==> 279040812:4108
749: SKP: 4096( 1 blks) ==> 279044920:12
750: RAW: 4096( 1 blks) ==> 279044932:4108
751: SKP: 4096( 1 blks) ==> 279049040:12
752: RAW: 16384( 4 blks) ==> 279049052:16396
753: SKP: 4096( 1 blks) ==> 279065448:12
754: RAW: 4096( 1 blks) ==> 279065460:4108
755: SKP: 4096( 1 blks) ==> 279069568:12
756: RAW: 4096( 1 blks) ==> 279069580:4108
757: SKP: 8192( 2 blks) ==> 279073688:12
758: RAW: 12288( 3 blks) ==> 279073700:12300
759: SKP: 4096( 1 blks) ==> 279086000:12
760: RAW: 4096( 1 blks) ==> 279086012:4108
761: SKP: 4096( 1 blks) ==> 279090120:12
762: RAW: 4096( 1 blks) ==> 279090132:4108
763: SKP: 8192( 2 blks) ==> 279094240:12
764: RAW: 4096( 1 blks) ==> 279094252:4108
765: SKP: 4096( 1 blks) ==> 279098360:12
766: RAW: 4096( 1 blks) ==> 279098372:4108
767: SKP: 4096( 1 blks) ==> 279102480:12
768: RAW: 12288( 3 blks) ==> 279102492:12300
769: SKP: 8192( 2 blks) ==> 279114792:12
770: RAW: 4096( 1 blks) ==> 279114804:4108
771: SKP: 4096( 1 blks) ==> 279118912:12
772: RAW: 4096( 1 blks) ==> 279118924:4108
773: SKP: 4096( 1 blks) ==> 279123032:12
774: RAW: 16384( 4 blks) ==> 279123044:16396
775: SKP: 4096( 1 blks) ==> 279139440:12
776: RAW: 4096( 1 blks) ==> 279139452:4108
777: SKP: 4096( 1 blks) ==> 279143560:12
778: RAW: 4096( 1 blks) ==> 279143572:4108
779: SKP: 8192( 2 blks) ==> 279147680:12
780: RAW: 12288( 3 blks) ==> 279147692:12300
781: SKP: 4096( 1 blks) ==> 279159992:12
782: RAW: 4096( 1 blks) ==> 279160004:4108
783: SKP: 4096( 1 blks) ==> 279164112:12
784: RAW: 4096( 1 blks) ==> 279164124:4108
785: SKP: 8192( 2 blks) ==> 279168232:12
786: RAW: 12288( 3 blks) ==> 279168244:12300
787: SKP: 4096( 1 blks) ==> 279180544:12
788: RAW: 4096( 1 blks) ==> 279180556:4108
789: SKP: 4096( 1 blks) ==> 279184664:12
790: RAW: 4096( 1 blks) ==> 279184676:4108
791: SKP: 8192( 2 blks) ==> 279188784:12
792: RAW: 4096( 1 blks) ==> 279188796:4108
793: SKP: 4096( 1 blks) ==> 279192904:12
794: RAW: 4096( 1 blks) ==> 279192916:4108
795: SKP: 4096( 1 blks) ==> 279197024:12
796: RAW: 16384( 4 blks) ==> 279197036:16396
797: SKP: 4096( 1 blks) ==> 279213432:12
798: RAW: 4096( 1 blks) ==> 279213444:4108
799: SKP: 4096( 1 blks) ==> 279217552:12
800: RAW: 4096( 1 blks) ==> 279217564:4108
801: SKP: 4096( 1 blks) ==> 279221672:12
802: RAW: 16384( 4 blks) ==> 279221684:16396
803: SKP: 4096( 1 blks) ==> 279238080:12
804: RAW: 4096( 1 blks) ==> 279238092:4108
805: SKP: 4096( 1 blks) ==> 279242200:12
806: RAW: 4096( 1 blks) ==> 279242212:4108
807: SKP: 8192( 2 blks) ==> 279246320:12
808: RAW: 12288( 3 blks) ==> 279246332:12300
809: SKP: 4096( 1 blks) ==> 279258632:12
810: RAW: 4096( 1 blks) ==> 279258644:4108
811: SKP: 4096( 1 blks) ==> 279262752:12
812: RAW: 4096( 1 blks) ==> 279262764:4108
813: SKP: 8192( 2 blks) ==> 279266872:12
814: RAW: 4096( 1 blks) ==> 279266884:4108
815: SKP: 4096( 1 blks) ==> 279270992:12
816: RAW: 4096( 1 blks) ==> 279271004:4108
817: SKP: 4096( 1 blks) ==> 279275112:12
818: RAW: 12288( 3 blks) ==> 279275124:12300
819: SKP: 8192( 2 blks) ==> 279287424:12
820: RAW: 4096( 1 blks) ==> 279287436:4108
821: SKP: 4096( 1 blks) ==> 279291544:12
822: RAW: 4096( 1 blks) ==> 279291556:4108
823: SKP: 4096( 1 blks) ==> 279295664:12
824: RAW: 16384( 4 blks) ==> 279295676:16396
825: SKP: 4096( 1 blks) ==> 279312072:12
826: RAW: 4096( 1 blks) ==> 279312084:4108
827: SKP: 4096( 1 blks) ==> 279316192:12
828: RAW: 4096( 1 blks) ==> 279316204:4108
829: SKP: 8192( 2 blks) ==> 279320312:12
830: RAW: 12288( 3 blks) ==> 279320324:12300
831: SKP: 4096( 1 blks) ==> 279332624:12
832: RAW: 4096( 1 blks) ==> 279332636:4108
833: SKP: 4096( 1 blks) ==> 279336744:12
834: RAW: 4096( 1 blks) ==> 279336756:4108
835: SKP: 8192( 2 blks) ==> 279340864:12
836: RAW: 4096( 1 blks) ==> 279340876:4108
837: SKP: 4096( 1 blks) ==> 279344984:12
838: RAW: 4096( 1 blks) ==> 279344996:4108
839: SKP: 4096( 1 blks) ==> 279349104:12
840: RAW: 12288( 3 blks) ==> 279349116:12300
841: SKP: 8192( 2 blks) ==> 279361416:12
842: RAW: 4096( 1 blks) ==> 279361428:4108
843: SKP: 4096( 1 blks) ==> 279365536:12
844: RAW: 4096( 1 blks) ==> 279365548:4108
845: SKP: 4096( 1 blks) ==> 279369656:12
846: RAW: 16384( 4 blks) ==> 279369668:16396
847: SKP: 4096( 1 blks) ==> 279386064:12
848: RAW: 4096( 1 blks) ==> 279386076:4108
849: SKP: 4096( 1 blks) ==> 279390184:12
850: RAW: 4096( 1 blks) ==> 279390196:4108
851: SKP: 8192( 2 blks) ==> 279394304:12
852: RAW: 12288( 3 blks) ==> 279394316:12300
853:
-- Total: ---------------------------------------------------
2878 CHUNK 30064771072(7340032 blks) ==> 3498440452(854103 blks)
done.
system.img built successfully.
Existing tbcfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb"
saving flash command in /home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/flashcmd.txt
copying boot image (boot.img.sb)... done.
copying partition layout (flash.xml.sb)... done.
copying kernel dtb (tegra186-quill-p3310-1000-c03-00-base.dtb.sb)... done.
saving flash parameters in /home/justin/Jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/flash_parameters.txt
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0012 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0018 ] Assuming zero filled SBK key
[ 0.0028 ]
[ 0.0028 ] Generating RCM messages
[ 0.0039 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0044 ] RCM 0 is saved as rcm_0.rcm
[ 0.0057 ] RCM 1 is saved as rcm_1.rcm
[ 0.0057 ] List of rcm files are saved in rcm_list.xml
[ 0.0057 ]
[ 0.0057 ] Signing RCM messages
[ 0.0063 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0070 ] Assuming zero filled SBK key
[ 0.0100 ]
[ 0.0100 ] Copying signature to RCM mesages
[ 0.0107 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0117 ]
[ 0.0118 ] Parsing partition layout
[ 0.0129 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0146 ]
[ 0.0146 ] Creating list of images to be signed
[ 0.0159 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.0389 ]
[ 0.0389 ] Generating signatures
[ 0.0397 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0404 ] Assuming zero filled SBK key
[ 0.2775 ]
[ 0.2775 ] Generating br-bct
[ 0.2787 ] Updating dev and MSS params in BR BCT
[ 0.2787 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.2975 ]
[ 0.2975 ] Updating bl info
[ 0.2983 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.2994 ]
[ 0.2994 ] Updating smd info
[ 0.3001 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.3009 ]
[ 0.3009 ] Updating Odmdata
[ 0.3015 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 0.3023 ]
[ 0.3023 ] Get Signed section bct
[ 0.3030 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.3037 ]
[ 0.3037 ] Signing BCT
[ 0.3048 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.3054 ] Assuming zero filled SBK key
[ 0.3055 ]
[ 0.3056 ] Updating BCT with signature
[ 0.3062 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.3069 ]
[ 0.3070 ] Generating coldboot mb1-bct
[ 0.3076 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.3082 ] MB1-BCT version: 0xe
[ 0.3083 ] Copying Sdram info from 2 to 3 set
[ 0.3230 ] Packing sdram param for instance[0]
[ 0.3233 ] Packing sdram param for instance[1]
[ 0.3235 ] Packing sdram param for instance[2]
[ 0.3236 ] Packing sdram param for instance[3]
[ 0.3238 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.3242 ] Appending platform config data of size :- 2904
[ 0.3245 ] Parsing config file :mobile_scr.cfg
[ 0.3248 ] Appending platform config data of size :- 12240
[ 0.3259 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.3264 ] Appending platform config data of size :- 24
[ 0.3264 ]
[ 0.3264 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.3264 ] Appending platform config data of size :- 708
[ 0.3264 ]
[ 0.3264 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.3264 ] Appending platform config data of size :- 64
[ 0.3264 ]
[ 0.3264 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.3264 ] Appending platform config data of size :- 1652
[ 0.3264 ]
[ 0.3264 ] Updating mb1-bct with firmware information
[ 0.3271 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.3276 ] MB1-BCT version: 0xe
[ 0.3279 ]
[ 0.3279 ] Updating mb1-bct with storage information
[ 0.3285 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.3290 ] MB1-BCT version: 0xe
[ 0.3293 ]
[ 0.3298 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.3304 ]
[ 0.3309 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.3316 ]
[ 0.3324 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.3330 ] Assuming zero filled SBK key
[ 0.3342 ]
[ 0.3351 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.3358 ]
[ 0.3358 ] Generating recovery mb1-bct
[ 0.3364 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.3370 ] MB1-BCT version: 0xe
[ 0.3371 ] Copying Sdram info from 2 to 3 set
[ 0.3524 ] Packing sdram param for instance[0]
[ 0.3527 ] Packing sdram param for instance[1]
[ 0.3530 ] Packing sdram param for instance[2]
[ 0.3533 ] Packing sdram param for instance[3]
[ 0.3536 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.3542 ] Appending platform config data of size :- 2904
[ 0.3546 ] Parsing config file :minimal_scr.cfg
[ 0.3550 ] Appending platform config data of size :- 12240
[ 0.3554 ]
[ 0.3554 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.3554 ] Appending platform config data of size :- 24
[ 0.3554 ]
[ 0.3554 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.3554 ] Appending platform config data of size :- 708
[ 0.3554 ]
[ 0.3554 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.3554 ] Appending platform config data of size :- 64
[ 0.3554 ]
[ 0.3554 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.3554 ] Appending platform config data of size :- 1652
[ 0.3554 ]
[ 0.3554 ] Updating mb1-bct with firmware information
[ 0.3562 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.3570 ] MB1-BCT version: 0xe
[ 0.3573 ]
[ 0.3573 ] Updating mb1-bct with storage information
[ 0.3579 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.3585 ] MB1-BCT version: 0xe
[ 0.3587 ]
[ 0.3594 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 0.3600 ]
[ 0.3606 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.3613 ]
[ 0.3621 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.3627 ] Assuming zero filled SBK key
[ 0.3640 ]
[ 0.3649 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.3657 ]
[ 0.3657 ] Copying signatures
[ 0.3663 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.3822 ]
[ 0.3822 ] Boot Rom communication
[ 0.3831 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 0.3838 ] BootRom is not running
[ 1.5703 ]
[ 1.5712 ] tegrarcm_v2 --isapplet
[ 1.5719 ] Applet version 01.00.0000
[ 1.8294 ]
[ 1.8295 ] Retrieving board information
[ 1.8303 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 1.8310 ] Applet version 01.00.0000
[ 2.1578 ] Saved platform info in chip_info.bin
[ 2.1592 ] Chip minor revision: 2
[ 2.1597 ]
[ 2.1598 ] Sending BCTs
[ 2.1607 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 2.1614 ] Applet version 01.00.0000
[ 2.4898 ] Sending bct_bootrom
[ 2.4899 ] [................................................] 100%
[ 2.4997 ] Sending bct_mb1
[ 2.5057 ] [................................................] 100%
[ 2.8519 ]
[ 2.8519 ] Generating blob
[ 2.8529 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 2.8537 ]
[ 2.8543 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 2.8553 ]
[ 2.8562 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 2.8568 ] Assuming zero filled SBK key
[ 2.8614 ]
[ 2.8623 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 2.8634 ]
[ 2.8641 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 2.8648 ]
[ 2.8655 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 2.8668 ]
[ 2.8679 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 2.8686 ] Assuming zero filled SBK key
[ 2.8707 ]
[ 2.8717 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 2.8726 ]
[ 2.8734 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 2.8742 ]
[ 2.8772 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 2.8781 ]
[ 2.8789 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 2.8796 ] Assuming zero filled SBK key
[ 2.8819 ]
[ 2.8836 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 2.8846 ]
[ 2.8854 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 2.8863 ]
[ 2.8870 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 2.8908 ]
[ 2.8919 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 2.8925 ] Assuming zero filled SBK key
[ 2.9425 ]
[ 2.9435 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 2.9463 ]
[ 2.9473 ] tegrahost_v2 --align blob_bpmp.bin
[ 2.9480 ]
[ 2.9486 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 2.9499 ]
[ 2.9508 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 2.9517 ] Assuming zero filled SBK key
[ 2.9652 ]
[ 2.9661 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 2.9674 ]
[ 2.9683 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 2.9689 ]
[ 2.9698 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 2.9715 ]
[ 2.9724 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 2.9731 ] Assuming zero filled SBK key
[ 2.9856 ]
[ 2.9868 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 2.9882 ]
[ 2.9891 ] tegrahost_v2 --align blob_tos.img
[ 2.9898 ]
[ 2.9904 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 2.9914 ]
[ 2.9922 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 2.9929 ] Assuming zero filled SBK key
[ 2.9946 ]
[ 2.9959 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 2.9969 ]
[ 2.9976 ] tegrahost_v2 --align blob_eks.img
[ 2.9983 ]
[ 2.9989 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 2.9997 ]
[ 3.0006 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 3.0013 ] Assuming zero filled SBK key
[ 3.0016 ]
[ 3.0027 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 3.0036 ]
[ 3.0044 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 3.0052 ]
[ 3.0060 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 3.0073 ]
[ 3.0084 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 3.0091 ] Assuming zero filled SBK key
[ 3.0162 ]
[ 3.0174 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 3.0188 ]
[ 3.0199 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 3.0205 ] number of images in blob are 9
[ 3.0208 ] blobsize is 3749384
[ 3.0209 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 190048
[ 3.0222 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 79600
[ 3.0226 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63024
[ 3.0230 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2076832
[ 3.0234 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 529440
[ 3.0237 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 3.0242 ] Added binary blob_tos_sigheader.img.encrypt of size 62976
[ 3.0246 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 3.0249 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 279664
[ 3.0262 ]
[ 3.0262 ] Sending bootloader and pre-requisite binaries
[ 3.0347 ] tegrarcm_v2 --download blob blob.bin
[ 3.0356 ] Applet version 01.00.0000
[ 3.2945 ] Sending blob
[ 3.2945 ] [................................................] 100%
[ 3.7057 ]
[ 3.7071 ] tegrarcm_v2 --boot recovery
[ 3.7084 ] Applet version 01.00.0000
It looks like it all worked correctly up until all of the data preparation and configuration successfully completed. Then it just stopped before going into a state acceptable for flash. Actual flash starts after “tegrarcm_v2 --boot recovery” (the point where the logs halt). This is the state the Jetson goes in when it is about to accept data for writing.
This is kind of unlikely, but by any chance did you try to flash this twice in a row without resetting the Jetson back to a fresh recovery mode? If so, then this is the only thing I can think of which might stop the flash other than hardware failure.
If you have done any previous operation on a recovery mode Jetson without restarting recovery it won’t work right, e.g., you can’t clone twice without a reset between clones, you can’t flash twice without a reset between flashes, and you can’t alternate between flash and clone without resetting recovery mode between operations. If this is the case, then you are probably in luck. If not, then it seems you may need to RMA. If you need to RMA search for “RMA” near the end of this:
[url]https://devtalk.nvidia.com/default/topic/793798/embedded-systems/some-jetson-web-links/[/url]
I doubt it would help, but perhaps one last test is to delete your JetPack directory completely and re-download it making sure there is nothing remaining from the previous run.
I did not do that. I did however try reinstalling jetpack. Anyway how would one recover from a double flash? I figure I can try it anyways as a last resort. Rather not deal with the RMA process if I can help it.
I also tried to flash an SD card, that failed too with the same problem.
Thanks for your help!
There isn’t a “double flash”, it’s just a case that if you go to flash and it fails, then trying to flash again without setting the Jetson back up with a brand new recovery mode would cause failure. Resetting power with the recovery button down or powering off and then back on with recovery button held down would satisfy the Jetson. I’ve personally tried to clone twice in a row (different partitions) and forgotten to restart the recovery mode and scratched my head and wondered until I discovered that.
FYI, when you flash to mmcblk1p1 (SD card) you aren’t really flashing the SD card itself…you’re telling the Jetson where to look for extlinux.conf. Some of this setup is still in hidden partitions of the Jetso’s eMMC, it doesn’t “all” go to SD. The SD card would still need a rootfs on it, but not the other partitions.
It really sounds like you will have to RMA.
