@WayneWWW ,it can go into system,uart print :
[0000.024] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 1.5.1.6-t194-41334769-1740dd39)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Chip revision : A02P
[0000.044] I> Bootrom patch version : 15 (correctly patched)
[0000.049] I> ATE fuse revision : 0x200
[0000.053] I> Ram repair fuse : 0x0
[0000.056] I> Ram Code : 0x0
[0000.058] I> rst_source : 0x0
[0000.061] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.067] I> Qspi flash params source = brbct
[0000.071] I> Qspi using bpmp-dma
[0000.074] I> Qspi clock source : pllp
[0000.078] I> QSPI Flash Size = 32 MB
[0000.081] I> Qspi initialized successfully
[0000.085] W> No valid slot number is found in scratch register
[0000.091] W> Return default slot: _a
[0000.094] I> Active Boot chain : 0
[0000.097] I> Boot-device: QSPI
[0000.100] I> Qspi flash params source = brbct
[0000.106] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.113] I> Temperature = 37500
[0000.116] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.121] W> Skipping boost for clk: BPMP_APB
[0000.125] W> Skipping boost for clk: AXI_CBB
[0000.129] W> Skipping boost for clk: AON_CPU_NIC
[0000.133] W> Skipping boost for clk: CAN1
[0000.137] W> Skipping boost for clk: CAN2
[0000.141] I> Boot-device: QSPI
[0000.144] I> Boot-device: QSPI
[0000.147] I> Qspi flash params source = mb1bct
[0000.151] I> Qspi using bpmp-dma
[0000.154] I> Qspi clock source : pllc_out0
[0000.158] I> Qspi reinitialized
[0000.160] I> Qspi flash params source = mb1bct
[0000.166] I> ECC region[0]: Start:0x0, End:0x0
[0000.170] I> ECC region[1]: Start:0x0, End:0x0
[0000.174] I> ECC region[2]: Start:0x0, End:0x0
[0000.178] I> ECC region[3]: Start:0x0, End:0x0
[0000.182] I> ECC region[4]: Start:0x0, End:0x0
[0000.186] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.192] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.197] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.201] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.206] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.211] E> FAILED: Thermal config
[0000.218] E> FAILED: MEMIO rail config
[0000.228] I> Boot-device: QSPI
[0000.231] I> Qspi flash params source = mb1bct
[0000.240] I> Qspi flash params source = mb1bct
[0000.252] I> Qspi flash params source = mb1bct
[0000.318] I> Qspi flash params source = mb1bct
[0000.327] I> Qspi flash params source = mb1bct
[0000.356] I> Qspi flash params source = mb1bct
[0000.368] I> MB1 done
ÿn enter
SPE VERSION #: R01.00.14 Created: Sep 19 2018 @ 11:03:21
HW Function test
Start Scheduler.
in late init
ÿ
ᙰ000.376] I> Welcome to MB2(TBoot-BPMP) (version: 00.00.2018.32-mobile-feba5943)
[0000.377] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.377] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.378] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.384] W> device prod register failed
[0000.387] I> Boot-device: QSPI
[0000.390] I> Boot_device: QSPI_FLASH instance: 0
[0000.395] I> QSPI Flash Size = 32 MB
[0000.401] I> Qspi initialized successfully
[0000.402] I> qspi flash-0 params source = boot args
[0000.786] I> sdmmc DDR50 mode
[0000.788] I> sdmmc-3 params source = safe params
[0000.793] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0000.795] W> Cannot find any partition table for 00000003
[0000.800] I> Found 11 partitions in SDMMC_USER (instance 3)
[0000.801] W> No valid slot number is found in scratch register
[0000.801] W> Return default slot: _a
[0000.801] I> Active Boot chain : 0
[0000.802] I> parsing oem signed section of bpmp-fw header done
[0000.803] I> bpmp-fw binary init read from storage
[0000.808] I> oem authentication of bpmp-fw header done
[0000.822] I> bpmp-fw binary done read from storage
[0000.822] I> bpmp-fw: Authentication init Done
[0000.823] I> parsing oem signed section of cpubl header done
[0000.827] I> cpubl binary init read from storage
[0000.831] I> bpmp-fw: Authentication Finalize Done
[0000.836] I> oem authentication of cpubl header done
[0000.844] I> cpubl binary done read from storage
[0000.845] I> cpubl: Authentication init Done
[0000.850] I> parsing oem signed section of rce header done
[0000.855] I> rce binary init read from storage
[0000.859] I> Relocating BR-BCT
[0000.862] I> cpubl: Authentication Finalize Done
[0000.866] I> oem authentication of rce header done
[0000.871] I> rce binary done read from storage
[0000.875] I> rce: Authentication init Done
[0000.879] I> parsing oem signed section of ape header done
[0000.884] I> ape binary init read from storage
[0000.889] I> rce: Authentication Finalize Done
[0000.893] I> oem authentication of ape header done
[0000.898] I> ape binary done read from storage
[0000.902] I> ape: Authentication init Done
[0000.906] I> parsing oem signed section of tos header done
[0000.911] I> tos binary init read from storage
[0000.915] I> ape: Authentication Finalize Done
[0000.920] I> oem authentication of tos header done
[0000.927] I> tos binary done read from storage
[0000.929] I> tos: Authentication init Done
[0000.933] I> parsing oem signed section of bpmp-fw-dtb header done
[0000.939] I> bpmp-fw-dtb binary init read from storage
[0000.944] I> tos: Authentication Finalize Done
[0000.950] I> oem authentication of bpmp-fw-dtb header done
[0000.953] I> bpmp-fw-dtb binary done read from storage
[0000.958] I> bpmp-fw-dtb: Authentication init Done
[0000.963] I> parsing oem signed section of cpubl-dtb header done
[0000.969] I> cpubl-dtb binary init read from storage
[0000.973] I> bpmp-fw-dtb: Authentication Finalize Done
[0001.030] I> oem authentication of cpubl-dtb header done
[0001.031] I> cpubl-dtb binary done read from storage
[0001.032] I> cpubl-dtb: Authentication init Done
[0001.033] I> parsing oem signed section of eks header done
[0001.034] I> eks binary init read from storage
[0001.034] I> cpubl-dtb: Authentication Finalize Done
[0001.035] I> oem authentication of eks header done
[0001.039] I> eks binary done read from storage
[0001.043] I> eks: Authentication init Done
[0001.047] I> eks: Authentication Finalize Done
[0001.052] I> EKB detected (length: 0x410) @ VA:0x52714400
ÿ㍏TICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 14:42:47, Jan 15 2021
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 197: key_mgnt_processing …
hwkey-agent: 189: Setting EKB key 0 to slot 14
hwkey-agent: 167: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
ÿ
welcome to lk
calling constructors
initializing heap
creating bootstrap completion thread
top of bootstrap2()
initializing platform
bpmp: platform_init
tag is e73a758761f0c6d24a1e69a2ac6b5035
tag_show initialized
dt initialized
mail initialized
chipid initialized
fuse initialized
sku initialized
speedo initialized
ec_get_ec_list: found 45 ecs
ec initialized
ec_mrq initialized
vmon_populate_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
fmon initialized
fmon_mrq initialized
reset initialized
nvhs initialized
391 clocks registered
clk_mrq_init: mrq handler registered
clk initialized
nvlink initialized
io_dpd initialized
io_dpd initialized
thermal initialized
i2c5 controller initialized
initialized i2c mrq handling
i2c initialized
regulator initialized
avfs_clk_platform_init: bad clk id in clock@cluster1_avfs
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
pg_late initialized
strap initialized
tag initialized
emc initialized
clk_dt initialized
avfs_ccplex_platform initialized
tj_max: dt node not found
tj_init initialized
uphy_mrq_init: mrq handler registered
uphy_dt initialized
uphy initialized
safereg_init: period 80 ms
ec_late initialized
ÿ
ٰ001.393] I> Welcome to Cbootÿᬲq initialized
WARNING: no registered clock for FMON_NAFLL_CLUSTER1 (id 281)
fmon_post initialized
ÿ
[0001.394] I> Cboot Version: t194-9efcbc4f
[0001.396] I> CPU-BL Params @ 0xf2820000
[0001.400] I> 0) Base:0x00000000 Size:0x00000000
[0001.404] I> 1) Base:0xf1100000 Size:0x00100000
[0001.408] I> 2) Base:0xf2000000 Size:0x00200000
ÿk_set_parent failed for clk i2c2, parent pll_aon (-22)
clk_set_parent failed for clk i2c8, parent pll_aon (-22)
clk_dt_late initialized
machine_check initialized
pm_post initialized
dbells initialized
avfs_clk_platform_post initialized
dmce initialized
cvc initialized
ccplex_avfs_hw_init: nafll_cluster0: not monitored
ccplex_avfs_hw_init: nafll_cluster2: not monitored
ccplex_avfs_hw_init: nafll_cluster3: not monitored
avfs_clk_mach_post initialized
regulator_post initialized
rm initialized
sc7_diag initialized
thermal_test initialized
serial_late initialized
clk_post initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
dyn_modules initialized
sku_debugfs initialized
speedo_debugfs initialized
adc_debugfs initialized
Failed to register PTO counter for id 281
clk_debugfs initialized
emc_debugfs initialized
dvs_debugfs initialized
fmon_debugfs_init_one: no clock debugfs node to attach FMON_NAFLL_CLUSTER1
fmon_debugfs initialized
vmon_debugfs initialized
pg_debugfs initialized
profile_fs initialized
debugfs_cons initialized
mail_fs initialized
profile initialized
cvc_debugfs initialized
dmce_debugfs initialized
ec_debugfs initialized
rm_rail_debugfs_init: /rm/vdd_cpu: failed
rm_debugfs initialized
soctherm_debug initialized
gr_reader initialized
mods initialized
dt_fs initialized
debugfs_mrq initialized
debug_mrq initialized
debug_safereg initialized
initializing target
calling apps_init()
starting app shell
entering main console loop
] ÿٰ001.413] I> 3) Base:0xf1200000 Size:0x00200000
[0001.567] I> 4) Base:0xf1000000 Size:0x00100000
[0001.572] I> 5) Base:0xf0f00000 Size:0x00100000
[0001.576] I> 6) Base:0xf3800000 Size:0x00400000
[0001.581] I> 7) Base:0xf1c00000 Size:0x00400000
[0001.585] I> 8) Base:0xf0e00000 Size:0x00100000
[0001.589] I> 9) Base:0xf0d00000 Size:0x00100000
[0001.594] I> 10) Base:0xf3000000 Size:0x00800000
[0001.598] I> 11) Base:0x40000000 Size:0x00040000
[0001.603] I> 12) Base:0xf0c00000 Size:0x00100000
[0001.607] I> 13) Base:0x40046000 Size:0x00002000
[0001.612] I> 14) Base:0x40048000 Size:0x00002000
[0001.616] I> 15) Base:0xac000000 Size:0x00004000
[0001.621] I> 16) Base:0x4004a000 Size:0x00002000
[0001.625] I> 17) Base:0xf0b00000 Size:0x00100000
[0001.630] I> 18) Base:0x4004c000 Size:0x00002000
[0001.634] I> 19) Base:0xf2200000 Size:0x00600000
[0001.639] I> 20) Base:0x4004e000 Size:0x00002000
[0001.643] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.647] I> 22) Base:0x00000000 Size:0x00000000
[0001.652] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.656] I> 24) Base:0xf6000000 Size:0x02000000
[0001.661] I> 25) Base:0x40050000 Size:0x00002000
[0001.665] I> 26) Base:0x40040000 Size:0x00006000
[0001.670] I> 27) Base:0xf1800000 Size:0x00400000
[0001.674] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.679] I> 29) Base:0xf1400000 Size:0x00400000
[0001.683] I> 30) Base:0x00000000 Size:0x00000000
[0001.688] I> 31) Base:0x00000000 Size:0x00000000
[0001.692] I> 32) Base:0xf8000000 Size:0x08000000
[0001.697] I> 33) Base:0x00000000 Size:0x00000000
[0001.701] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.705] I> 35) Base:0xab000000 Size:0x01000000
[0001.710] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.714] I> 37) Base:0xf2800000 Size:0x00800000
[0001.719] I> 38) Base:0x80000000 Size:0x20000000
[0001.723] I> 39) Base:0xb0000000 Size:0x08000000
[0001.728] I> 40) Base:0x00000000 Size:0x00000000
[0001.732] I> 41) Base:0x00000000 Size:0x00000000
[0001.737] I> 42) Base:0x00000000 Size:0x00000000
[0001.741] I> 43) Base:0x00000000 Size:0x00000000
[0001.746] I> 44) Base:0x00000000 Size:0x00000000
[0001.750] I> 45) Base:0x00000000 Size:0x00000000
[0001.755] GIC-SPI Target CPU: 0
[0001.758] Interrupts Init done
[0001.760] calling constructors
[0001.763] initializing heap
[0001.766] I> Heap: [0xa06945e8 … 0xab000000]
[0001.770] initializing threads
[0001.773] initializing timers
[0001.776] creating bootstrap completion thread
[0001.780] top of bootstrap2()
[0001.783] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.788] initializing platform
[0001.791] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.796] W> device prod register failed
[0001.800] I> Bl_dtb @0xaaf00000
[0001.805] W> “plugin-manager” doesn’t exist, creating
[0001.808] W> “ids” doesn’t exist, creating
[0001.812] W> “connection” doesn’t exist, creating
[0001.816] W> “configs” doesn’t exist, creating
[0001.828] I> Find /i2c@3160000’s alias i2c0
[0001.828] I> Reading eeprom i2c=0 address=0x50
[0001.854] I> Device at /i2c@3160000:0x50
[0001.854] I> Reading eeprom i2c=0 address=0x57
[0001.879] I> Device at /i2c@3160000:0x57
[0001.881] I> Find /i2c@c240000’s alias i2c1
[0001.881] I> Reading eeprom i2c=1 address=0x50
[0001.883] E> I2C: slave not found in slaves.
[0001.883] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.884] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.885] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.893] E> eeprom: Retry to read I2C slave device.
[0001.898] E> I2C: slave not found in slaves.
[0001.902] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.910] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.915] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.925] E> eeprom: Failed to read I2C slave device
[0001.930] I> Eeprom read failed 0x3526070d
[0001.933] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0001.939] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.950] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0001.955] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.966] I> Adding plugin-manager/ids/3668-0001-300=/i2c@3160000:module@0x50
[0001.973] W> “i2c@3160000” doesn’t exist, creating
[0001.978] W> “module@0x50” doesn’t exist, creating
[0001.982] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@3160000:module@0x57
[0001.989] W> “module@0x57” doesn’t exist, creating
[0001.996] I> Adding plugin-manager/cvm
[0001.998] W> “chip-id” doesn’t exist, creating
[0002.002] I> Adding plugin-manager/chip-id/A02P
[0002.006] I> Plugin-manager override starting
[0002.011] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.021] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.025] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0002.033] I> Disable plugin-manager status in FDT
[0002.033] I> Plugin-manager override finished successfully
[0002.038] I> gpio framework initialized
[0002.043] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0002.050] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0002.057] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.064] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.072] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.078] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.084] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.092] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.100] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.106] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.114] I> fixed regulator driver initialized
[0002.122] I> register ‘maxim’ power off handle
[0002.123] I> virtual i2c enabled
[0002.124] I> registered ‘maxim,max20024’ pmic
[0002.128] I> tegrabl_gpio_driver_register: register ‘max20024-gpio’ driver
[0002.135] I> Boot-device: QSPI
[0002.138] I> Boot_device: QSPI_FLASH instance: 0
[0002.143] I> QSPI source rate = 204000 Khz
[0002.146] I> Requested rate for QSPI clock = 34000 Khz
[0002.151] I> BPMP-set rate for QSPI clk = 34000 Khz
[0002.156] I> QSPI Flash Size = 32 MB
[0002.164] I> Qspi initialized successfully
[0002.164] I> qspi flash-0 params source = boot args
[0002.168] I> create_pm_ids: id: 3668-0001-300-B, len: 15
[0002.173] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.184] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.189] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0002.205] I> sdmmc-3 params source = safe params
[0002.207] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0002.226] W> Cannot find any partition table for 00000003
[0002.239] I> Found 11 partitions in SDMMC_USER (instance 3)
[0002.248] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.252] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0002.252] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.253] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.256] E> invalid display type
[0002.258] E> cannot find any other nvdisp nodes
[0002.258] E> no valid display unit config found in dtb
[0002.259] W> display init failed
[0002.261] I> Load in CBoot Boot Options partition and parse it
[0002.267] E> Error -9 when finding node with path /boot-configuration
[0002.273] E> tegrabl_cbo_parse_info: “boot-configuration” not found in CBO file.
[0002.280] I> Using default boot order
[0002.284] I> boot-dev-order :-
[0002.286] I> 1.sd
[0002.288] I> 2.usb
[0002.290] I> 3.nvme
[0002.292] I> 4.emmc
[0002.294] I> 5.net
[0002.296] I> Hit any key to stop autoboot: 4 3 2 1
[0004.303] initializing target
[0004.303] calling apps_init()
[0004.304] starting app kernel_boot_app
[0004.315] I> found decompressor handler: lz4-legacy
[0004.315] I> decompressing BMP blob …
[0004.326] I> Kernel type = Normal
[0004.326] I> Loading kernel-bootctrl from partition
[0004.327] I> Loading partition kernel-bootctrl at 0xa42d0000 from device(0x1)
[0004.334] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.335] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.335] I> ########## SD (0) boot ##########
[0004.336] W> Error: failed to get sd-card params
[0004.338] I> -0 params source =
[0004.342] W> Failed to initialize device 6-0
[0004.346] E> SD boot failed, err: 252641293
[0004.350] I> ########## USB (0) boot ##########
[0004.359] W> No valid slot number is found in scratch register
[0004.360] W> Return default slot: _a
[0004.371] I> USB Firmware Version: 60.06 release
[0004.425] I> regulator of usb2-0 already enabled
[0004.430] I> regulator of usb2-1 already enabled
[0004.434] I> regulator of usb2-2 already enabled
[0005.501] I> USB 2.0 port 2 new high-speed USB device detected
[0005.502] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa92d0000, cmd_ring.dma = 0xa92d0040
[0005.603] I> Start to enumerate device
[0005.605] W> WARNING: event and command not matching, cmd_trb_ptr = 0xa92d0000, cmd_ring.dma = 0xa92d0040
[0005.609] I>
[0005.610] I> Enumerated USB Device 2109:2813
[0005.610] I>
[0005.611] I> Hub:
[0005.611] I> Downstream ports : 4
[0005.612] I> Power switching : Ganged
[0005.612] I> Compound device : No
[0005.612] I> Over-current protection : Global
[0005.616] I> Hub avg delay : 4 ns
[0005.620] I> Enable hub ports
[0006.654] E> No device found on any of the hub ports
[0006.654] E> failed to start xhci controller
[0006.655] E> Error in init of XUSB host driver, err: 7979000d
[0006.655] W> Failed to initialize device 5-0
[0006.655] E> USB boot failed, err: 2037973005
[0006.656] I> ########## Fixed storage boot ##########
[0006.657] I> Already published: 00010003
[0006.660] I> Look for boot partition
[0006.664] I> Fallback: assuming 0th partition is boot partition
[0006.670] I> Detect filesystem
[0006.697] I> Loading extlinux.conf …
[0006.697] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0006.734] I> L4T boot options
[0006.734] I> [1]: “primary kernel”
[0006.734] I> Enter choice:
[0009.736] I> Continuing with default option: 1
[0009.736] I> Loading kernel sig file from rootfs …
[0009.736] I> rootfs path: /sdmmc_user/boot/Image_lhz.sig
[0015.933] I> lookup_linear_dir:447: Invalid file block num
[0015.933] I> ext2_walk:142: ‘Image_lhz.sig’ lookup failed
[0015.933] I> ext4_open_file:666: ‘/boot/Image_lhz.sig’ lookup failed
[0015.934] E> file /sdmmc_user/boot/Image_lhz.sig open failed!!
[0015.934] W> Failed to load kernel sig file (err=202113041)
[0015.935] I> Loading kernel binary from rootfs …
[0015.940] I> rootfs path: /sdmmc_user/boot/Image_lhz
[0016.372] I> Validate kernel …
[0016.372] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0016.373] E> Stage2Signature validation failed with SHA2!!
[0016.373] C> OEM authentication of kernel header failed!
[0016.374] W> Failed to validate kernel binary (err=1077936152, fail=1)
[0016.374] W> Security fuse not burned, ignore validation failure
[0016.386] I> Loading kernel-dtb sig file from rootfs …
[0016.387] I> rootfs path: /sdmmc_user/boot/tegra194-p3668-all-p3509-0000-48.dtb.sig
[0022.588] I> lookup_linear_dir:447: Invalid file block num
[0022.588] I> ext2_walk:142: ‘tegra194-p3668-all-p3509-0000-48.dtb.sig’ lookup failed
[0022.589] I> ext4_open_file:666: ‘/boot/tegra194-p3668-all-p3509-0000-48.dtb.sig’ lookup failed
[0022.589] E> file /sdmmc_user/boot/tegra194-p3668-all-p3509-0000-48.dtb.sig open failed!!
[0022.592] W> Failed to load kernel-dtb sig file (err=202113041)
[0022.598] I> Loading kernel-dtb binary from rootfs …
[0022.603] I> rootfs path: /sdmmc_user/boot/tegra194-p3668-all-p3509-0000-48.dtb
[0022.636] I> Validate kernel-dtb …
[0022.636] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0022.637] E> Stage2Signature validation failed with SHA2!!
[0022.637] C> OEM authentication of kernel-dtb header failed!
[0022.637] W> Failed to validate kernel-dtb binary (err=1077936152, fail=1)
[0022.639] W> Security fuse not burned, ignore validation failure
[0022.644] I> Loading ramdisk from rootfs …
[0022.649] I> Loading initrd sig file from rootfs …
[0022.653] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0022.676] I> Loading initrd binary from rootfs …
[0022.677] I> rootfs path: /sdmmc_user/boot/initrd
[0022.773] I> overload load_size to 7236790 (from 7236800)
[0022.776] I> Validate initrd …
[0022.776] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0022.842] I> Encryption fuse is not ON
[0022.856] I> Kernel hdr @0xa42d0000
[0022.856] I> Kernel dtb @0x90000000
[0022.856] I> decompressor handler not found
[0022.857] I> Copying kernel image (34273288 bytes) from 0xa42d0000 to 0x80080000 … [0022.867] I> Done
[0022.868] I> Updated bpmp info to DTB
[0022.869] I> Ramdisk: Base: 0x91000000; Size: 0x6e6cb6
[0022.869] I> Updated initrd info to DTB
[0022.869] W> WARN: Fail to override “console=none” in commandline
[0022.870] I> Active rootfs suffix:
[0022.872] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0022.879] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0022.887] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0022.894] W> No valid slot number is found in scratch register
[0022.900] W> Return default slot: _a
[0022.903] I> Active slot suffix:
[0022.906] I> add_boot_slot_suffix: slot_suffix =
[0022.911] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0022.937] I> Updated bootarg info to DTB
[0022.941] W> MAC addr invalid!
[0022.944] E> Failed to get WIFI MAC address
[0022.948] W> MAC addr invalid!
[0022.950] E> Failed to get Bluetooth MAC address
[0022.955] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:17:1e
[0022.961] W> “plugin-manager” doesn’t exist, creating
[0022.966] I> Adding /chosen/plugin-manager/cvm
[0022.970] W> “chip-id” doesn’t exist, creating
[0022.974] I> Adding /chosen/plugin-manager/chip-id
[0022.979] W> “configs” doesn’t exist, creating
[0022.983] I> Adding /chosen/plugin-manager/configs
[0022.988] W> “ids” doesn’t exist, creating
[0022.992] I> Adding /chosen/plugin-manager/ids
[0022.996] W> “odm-data” doesn’t exist, creating
[0023.001] I> Adding /chosen/plugin-manager/odm-data
[0023.008] W> “memory” doesn’t exist, creating
[0023.010] I> [0] START: 0x80000000, END: 0xac000000
[0023.014] I> [1] START: 0xac004000, END: 0xf0ad0000
[0023.019] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0023.024] I> dram_block larger than 80000000
[0023.028] I> [3] START: 0x100000000, END: 0x280000000
[0023.033] I> added [base:0x80000000, size:0x2c000000] to /memory
[0023.039] I> added [base:0xac200000, size:0x44800000] to /memory
[0023.044] I> added [base:0x100000000, size:0x180000000] to /memory
[0023.051] I> Updated memory info to DTB
[0023.054] E> add_disp_param: failed to get display params for du=0
[0023.060] W> “reset” doesn’t exist, creating
[0023.065] I> Adding ecid(00000001647df5010c00000010018080) to DT
[0023.070] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0023.075] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0023.080] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0023.084] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0023.089] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0023.094] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0023.099] I> Deleted cpu@6 node in DT
[0023.102] I> Deleted cpu@7 node in DT
[0023.106] I> Deleted cluster3 node in FDT
[0023.110] I> Update arm-pmu in FDT
[0023.113] I> - update property: interrupts
[0023.117] I> - update property: interrupt-affinity
[0023.122] W> “misc-data” doesn’t exist, creating
[0023.126] I> Boot-device: QSPI
[0023.129] W> Unknown boot device
[0023.132] I> Add storage-qspi to plugin-manager/misc-data
[0023.137] W> Unknown storage device
[0023.141] I> Add serial number:142092X087350 as DT property
[0023.146] I> Plugin-manager override starting
[0023.150] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0023.157] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0023.163] I> node /plugin-manager/fragement-tegra-sdhci-sd-dis matches
[0023.170] I> Disable plugin-manager status in FDT
[0023.172] I> Plugin-manager override finished successfully
[0023.178] I> tegrabl_load_kernel_and_dtb: Done
[0023.182] E> tegrabl_display_clear: display is not initialized
[0023.187] W> Boot logo display failed…
[0023.191] I> Kernel EP: 0x80080000, DTB: 0x90000000
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.201-tegra (root@sensoro) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #10 SMP PREEMPT Tue Feb 22 11:24:07 CST 2022
[ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[ 0.000000] OF: fdt:memory scan node memory, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 2c000000
[ 0.000000] OF: fdt: - ac200000 , 44800000
[ 0.000000] OF: fdt: - 100000000 , 180000000
[ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
[ 0.000000] bootconsole [tegra_comb_uart0] enabled
[ 2.071746] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.072048] imx219 9-0010: board setup failed
[ 2.095909] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.096153] imx219 10-0010: board setup failed
[ 2.244737] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 2.244943] tegra-asoc: sound: snd_soc_register_card failed (-517)
ÿᖁRNING: at platform/drivers/pg/pg-gpu-t194.c:185
WARNING: at platform/drivers/pg/pg-gpu-t194.c:185
ÿ٠ 3.057098] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 3.057303] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.060474] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 3.060662] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 3.582084] cgroup: cgroup2: unknown option “nsdelegate”
ÿ٠ 5.022521] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 5.022710] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.025675] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 5.025858] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 5.027807] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 5.027980] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.050777] using random self ethernet address
[ 6.050900] using random host ethernet address
[ 6.096559] random: crng init done
[ 6.096666] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.110873] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.111069] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.117458] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.117664] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.172461] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.172672] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.175376] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.175576] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.563121] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.563362] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.565701] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.565899] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.568078] tegra-asoc: sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.568272] tegra-asoc: sound: snd_soc_register_card failed (-517)
[ 6.748399] using random self ethernet address
[ 6.748551] using random host ethernet address
[ 8.243903] Bridge firewalling registered
Ubuntu 18.04.5 LTS nx-desktop ttyTCU0
nx-desktop login:
