TX2 will auto reboot after flash OS
Hi all,
Yesterday we tried flash OS for TX2, but unfortunately, our TX2 will auto reboot after flash, now we can not nothing on it.
Reboot image url here: 百度网盘-免费云盘丨文件共享软件丨超大容量丨存储安全
Is there anybody met the same issue?
Do you flash Jetson from 64 bit 16.04 Ubuntu host ?
Flash probably succeeded, but video auto-configuration failed. Have you checked your router to see if there is a DHCP request? You may be able to log in via ssh. Serial console is also a very good way to see what is actually going on.
I have also encountered the same problem!
I am so curious that why it is so hard to get ready after buying this board。
Somebody come to save me plz!
Thank god!
Hi Andrey1984,
My VMWare Ubuntu version is 64bits 14.04, thanks.
Hi linuxdev,
We can not login via ssh, maybe because TX2 is not booting completely, now i am try to use serial console to capture some logs…
If you could connect to your router and see if there are entries for the jetson device at DHCP section - most likely you would be able to connect via ssh to the jetson with the default username and password
Hey All
According to the display, the linux kernel is crashing during the init
as u all know, init is the first process in linux
there is no way to get information through ssh
i advice to use the uart interface to get information
working on it!
For reference you may use: Serial Console - NVIDIA Jetson TX2 - JetsonHacks
hello Yugui/ JasonLeeeeeeee,
could you share more details.
which JetPack version you used? any console logs? are you able to enter force-recovery?
thanks
Hi JerryChang,
My JetPack version is L4T-3.0, and I can enter force-recovery successfully.
Currently, we do not have console logs, cause UART can not be used yet, but there is /_installer/logs/64_TX2/flash_os_tx2.log below, hope you give some advise. Thanks a lot.
./tegraflash.py --chip 0x18 --applet “/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0829 ] Generating RCM messages
[ 0.0844 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0867 ] RCM 0 is saved as rcm_0.rcm
[ 0.1302 ] RCM 1 is saved as rcm_1.rcm
[ 0.1302 ] List of rcm files are saved in rcm_list.xml
[ 0.1302 ]
[ 0.1302 ] Signing RCM messages
[ 0.1751 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1914 ] Assuming zero filled SBK key
[ 0.2247 ]
[ 0.2248 ] Copying signature to RCM mesages
[ 0.2268 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.2482 ]
[ 0.2483 ] Boot Rom communication
[ 0.2532 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.2554 ] RCM version 0X180001
[ 0.3381 ] Boot Rom communication completed
[ 1.3757 ]
[ 6.3842 ] Retrieving EEPROM data
[ 6.3843 ] tegrarcm_v2 --oem platformdetails eeprom cvm /mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 6.3891 ] Applet version 01.00.0000
[ 6.7745 ] Saved platform info in /mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 6.9288 ]
Board version(B00)
copying bctfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg)… done.
copying pmc_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying bootrom_config(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_prod.bin) reused.
Existing bpffile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb)… done.
Existing scefile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/spe.bin) reused.
copying wb0boot(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/tos.img) reused.
Existing eksfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/eks.img) reused.
copying dtbfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Making system.img…
populating rootfs from /mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4243456( 1036 blks) ==> 28:4243468
1: SKP: 20480( 5 blks) ==> 4243496:12
2891: SKP: 1864982528( 455318 blks) ==> 3346311072:12
– Total: -----------------------------------------------------------
2892 CHUNK 30064771072(7340032 blks) ==> 3346311084(816962 blks)
done.
system.img built successfully.
Existing tbcfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/cboot.bin) reused.
copying tbcdtbfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
copying cfgfile(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash;reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb”
saving flash command in /mnt/virtual_hdd/nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/flashcmd.txt
*** Flashing target device started. ***
version 1.0.0
[ 0.0430 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0486 ] Assuming zero filled SBK key
[ 0.0741 ]
[ 0.0743 ] Generating RCM messages
[ 0.0887 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0943 ] RCM 0 is saved as rcm_0.rcm
[ 0.1063 ] RCM 1 is saved as rcm_1.rcm
[ 0.1090 ] List of rcm files are saved in rcm_list.xml
[ 0.1152 ]
[ 0.1152 ] Signing RCM messages
[ 0.1185 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1247 ] Assuming zero filled SBK key
[ 0.1536 ]
[ 0.1537 ] Copying signature to RCM mesages
[ 0.1626 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.1839 ]
[ 0.1840 ] Parsing partition layout
[ 0.2218 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.2732 ]
[ 0.2733 ] Creating list of images to be signed
[ 0.2898 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.5490 ]
[ 0.5491 ] Generating signatures
[ 0.5542 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.5562 ] Assuming zero filled SBK key
[ 0.8563 ]
[ 0.8563 ] Generating br-bct
[ 0.8805 ] Updating dev and MSS params in BR BCT
[ 0.8806 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.8867 ] MB1 BCT version is : c
[ 0.9002 ] Copying Sdram info from 0 to 1 set
[ 0.9445 ] Copying Sdram info from 1 to 2 set
[ 0.9513 ] Copying Sdram info from 2 to 3 set
[ 0.9641 ]
[ 0.9641 ] Updating bl info
[ 0.9687 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.9973 ]
[ 0.9973 ] Updating Odmdata
[ 1.0025 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 1.0146 ]
[ 1.0146 ] Get Signed section bct
[ 1.0174 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 1.0376 ]
[ 1.0376 ] Signing BCT
[ 1.0391 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 1.0411 ] Assuming zero filled SBK key
[ 1.0608 ]
[ 1.0608 ] Updating BCT with signature
[ 1.0631 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 1.0789 ]
[ 1.0790 ] Generating coldboot mb1-bct
[ 1.0839 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.0929 ] MB1 BCT version is : c
[ 1.1001 ] Copying Sdram info from 0 to 1 set
[ 1.1319 ] Copying Sdram info from 1 to 2 set
[ 1.1395 ] Copying Sdram info from 2 to 3 set
[ 1.1459 ] Packing sdram param for instance[0]
[ 1.1521 ] Packing sdram param for instance[1]
[ 1.1590 ] Packing sdram param for instance[2]
[ 1.1639 ] Packing sdram param for instance[3]
[ 1.1707 ] Parsing platform config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.1711 ] Appending platform config data of size :- 2904
[ 1.1912 ] Parsing platform config file :minimal_scr.cfg
[ 1.1914 ] Appending platform config data of size :- 12240
[ 1.2112 ] Parsing platform config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.2142 ] Appending platform config data of size :- 24
[ 1.2209 ] Parsing platform config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 1.2213 ] Appending platform config data of size :- 684
[ 1.2225 ] Parsing platform config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.2229 ] Appending platform config data of size :- 64
[ 1.2352 ] Parsing platform config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.2357 ] Appending platform config data of size :- 1628
[ 1.2410 ]
[ 1.2411 ] Updating mb1-bct with firmware information
[ 1.2453 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.2683 ]
[ 1.2750 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 1.2894 ]
[ 1.2937 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 1.3095 ]
[ 1.3115 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 1.3168 ] Assuming zero filled SBK key
[ 1.3575 ]
[ 1.3670 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 1.3861 ]
[ 1.3862 ] Generating recovery mb1-bct
[ 1.3879 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.3915 ] MB1 BCT version is : c
[ 1.3997 ] Copying Sdram info from 0 to 1 set
[ 1.4216 ] Copying Sdram info from 1 to 2 set
[ 1.4298 ] Copying Sdram info from 2 to 3 set
[ 1.4362 ] Packing sdram param for instance[0]
[ 1.4440 ] Packing sdram param for instance[1]
[ 1.4515 ] Packing sdram param for instance[2]
[ 1.4603 ] Packing sdram param for instance[3]
[ 1.4705 ] Parsing platform config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.4820 ] Appending platform config data of size :- 2904
[ 1.4820 ]
[ 1.4820 ] Parsing platform config file :minimal_scr.cfg
[ 1.4820 ] Appending platform config data of size :- 12240
[ 1.4820 ]
[ 1.4820 ] Parsing platform config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.4820 ] Appending platform config data of size :- 24
[ 1.4820 ]
[ 1.4820 ] Parsing platform config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 1.4820 ] Appending platform config data of size :- 684
[ 1.4820 ]
[ 1.4820 ] Parsing platform config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.4820 ] Appending platform config data of size :- 64
[ 1.4820 ]
[ 1.4820 ] Parsing platform config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.4820 ] Appending platform config data of size :- 1628
[ 1.4820 ]
[ 1.4821 ] Updating mb1-bct with firmware information
[ 1.4854 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.5083 ]
[ 1.5133 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 1.5414 ]
[ 1.5429 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.5575 ]
[ 1.5633 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 1.5654 ] Assuming zero filled SBK key
[ 1.5902 ]
[ 1.5943 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.6109 ]
[ 1.6111 ] Copying signatures
[ 1.6180 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.7148 ]
[ 1.7148 ] Boot Rom communication
[ 1.7212 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 1.7234 ] BootRom is not running
[ 1.9358 ]
[ 6.9640 ] Retrieving board information
[ 6.9701 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 6.9742 ] Applet version 01.00.0000
[ 7.5405 ] Saved platform info in chip_info.bin
[ 7.5803 ] Chip minor revision: 2
[ 7.6136 ]
[ 7.6136 ] Sending BCTs
[ 7.6174 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 7.6219 ] Applet version 01.00.0000
[ 7.7591 ] Sending bct_bootrom
[ 7.7599 ] […] 100%
[ 7.8020 ] Sending bct_mb1
[ 7.8338 ] […] 100%
[ 8.2344 ]
[ 8.2345 ] Generating blob
[ 8.2377 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 8.2657 ]
[ 8.2677 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 8.2858 ]
[ 8.2910 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 8.2932 ] Assuming zero filled SBK key
[ 8.3221 ]
[ 8.3243 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 8.3467 ]
[ 8.3543 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 8.3796 ]
[ 8.3821 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 8.4036 ]
[ 8.4098 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 8.4116 ] Assuming zero filled SBK key
[ 8.4326 ]
[ 8.4397 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 8.4620 ]
[ 8.4639 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 8.4773 ]
[ 8.4828 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 8.4975 ]
[ 8.4994 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 8.5025 ] Assuming zero filled SBK key
[ 8.5252 ]
[ 8.5272 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 8.5431 ]
[ 8.5593 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 8.5780 ]
[ 8.5797 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 8.6295 ]
[ 8.6473 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 8.6499 ] Assuming zero filled SBK key
[ 8.8259 ]
[ 8.8279 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 8.8550 ]
[ 8.8652 ] tegrahost_v2 --align blob_bpmp.bin
[ 8.8815 ]
[ 8.8857 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 8.9054 ]
[ 8.9141 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 8.9161 ] Assuming zero filled SBK key
[ 8.9858 ]
[ 8.9901 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 9.0097 ]
[ 9.0143 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb
[ 9.0312 ]
[ 9.0341 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb zerosbk
[ 9.0554 ]
[ 9.0649 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb_list.xml
[ 9.0724 ] Assuming zero filled SBK key
[ 9.1257 ]
[ 9.1277 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 9.1456 ]
[ 9.1502 ] tegrahost_v2 --align blob_tos.img
[ 9.1712 ]
[ 9.1780 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 9.2053 ]
[ 9.2083 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 9.2102 ] Assuming zero filled SBK key
[ 9.2339 ]
[ 9.2422 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 9.2617 ]
[ 9.2636 ] tegrahost_v2 --align blob_eks.img
[ 9.2878 ]
[ 9.2939 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 9.3221 ]
[ 9.3242 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 9.3302 ] Assuming zero filled SBK key
[ 9.3460 ]
[ 9.3484 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 9.3661 ]
[ 9.3685 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 9.3707 ] number of images in blob are 9
[ 9.3784 ] blobsize is 3497944
[ 9.3825 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 144272
[ 9.4050 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 60096
[ 9.4153 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 59824
[ 9.4171 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2077344
[ 9.4309 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 524880
[ 9.4402 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.encrypt of size 327072
[ 9.4418 ] Added binary blob_tos_sigheader.img.encrypt of size 54784
[ 9.4484 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 9.4600 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base.dtb of size 248032
[ 9.5011 ]
[ 9.5012 ] Sending bootloader and pre-requisite binaries
[ 9.5065 ] tegrarcm_v2 --download blob blob.bin
[ 9.5083 ] Applet version 01.00.0000
[ 9.6405 ] Sending blob
[ 9.6406 ] [… ] 029%
[ 9.6406 ] [… ] 059%
[ 9.6406 ] [… ] 089%
[ 9.6406 ] […] 100%
[ 10.4656 ]
[ 10.4672 ] tegrarcm_v2 --boot recovery
[ 10.4702 ] Applet version 01.00.0000
[ 10.6419 ]
[ 15.6460 ] Retrieving storage infomation
[ 15.6494 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 15.6571 ] Applet is not running on device. Continue with Bootloader
[ 16.0543 ]
[ 16.0897 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 16.1038 ] Bootloader version 01.00.0000
[ 16.2381 ] Saved platform info in storage_info.bin
[ 16.3213 ]
[ 16.3213 ] Flashing the device
[ 16.3258 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 16.3453 ]
[ 16.3478 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 16.3514 ] Bootloader version 01.00.0000
[ 16.4884 ] Erasing sdmmc_boot: 3 … [Done]
[ 16.5694 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[ 16.5698 ] […] 100%
[ 16.6986 ] Erasing sdmmc_user: 3 … [Done]
[ 17.2126 ] Writing partition master_boot_record with mbr_1_3.bin
[ 17.2132 ] […] 100%
[ 17.2584 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 17.2852 ] […] 100%
[ 17.3287 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 17.3685 ] […] 100%
[ 17.4549 ] Writing partition mb1 with mb1_prod.bin.encrypt
[ 17.4555 ] […] 100%
[ 17.5075 ] Writing partition spe-fw with spe_sigheader.bin.encrypt
[ 17.5542 ] […] 100%
[ 17.6029 ] Writing partition mb2 with nvtboot_sigheader.bin.encrypt
[ 17.6558 ] […] 100%
[ 17.7036 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 17.7556 ] […] 100%
[ 17.8064 ] Writing partition master_boot_record with mbr_1_3.bin
[ 17.8894 ] […] 100%
[ 17.9316 ] Writing partition APP with system.img
[ 17.9803 ] [ ] 000%
[ 17.9803 ] […] 100%
[ 543.9290 ] Writing partition mts-bootpack with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 543.9675 ] [… ] 050%
[ 543.9675 ] […] 100%
[ 544.3696 ] Writing partition cpu-bootloader with cboot_sigheader.bin.encrypt
[ 544.4102 ] […] 100%
[ 544.4795 ] Writing partition bootloader-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 544.5129 ] […] 100%
[ 544.6064 ] Writing partition secure-os with tos_sigheader.img.encrypt
[ 544.6420 ] […] 100%
[ 544.7010 ] Writing partition eks with eks_sigheader.img.encrypt
[ 544.7281 ] […] 100%
[ 544.7819 ] Writing partition bpmp-fw with bpmp_sigheader.bin.encrypt
[ 544.8118 ] […] 100%
[ 544.9181 ] Writing partition bpmp-fw-dtb with tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.encrypt
[ 544.9522 ] […] 100%
[ 545.0443 ] Writing partition sce-fw with camera-rtcpu-sce_sigheader.bin.encrypt
[ 545.0788 ] […] 100%
[ 545.1497 ] Writing partition sc7 with warmboot_wbheader.bin.encrypt
[ 545.1809 ] […] 100%
[ 545.2267 ] Writing partition kernel with boot.img
[ 545.2677 ] [… ] 015%
[ 545.2677 ] [… ] 031%
[ 545.2677 ] [… ] 046%
[ 545.2677 ] [… ] 062%
[ 545.2677 ] [… ] 078%
[ 545.2677 ] [… ] 093%
[ 545.2677 ] […] 100%
[ 546.3310 ] Writing partition kernel-dtb with tegra186-quill-p3310-1000-c03-00-base.dtb
[ 546.3665 ] […] 100%
[ 546.4802 ]
[ 546.5242 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 546.5300 ] Bootloader version 01.00.0000
[ 546.6692 ] Writing partition BCT with br_bct_BR.bct
[ 546.6742 ] […] 100%
[ 546.7888 ]
[ 546.8252 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 546.8276 ] Bootloader version 01.00.0000
[ 546.9954 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 547.0061 ] […] 100%
[ 547.1736 ]
[ 547.1737 ] Flashing completed
[ 547.1737 ] Coldbooting the device
[ 547.1780 ] tegradevflash_v2 --reboot coldboot
[ 547.1799 ] Bootloader version 01.00.0000
[ 547.3614 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
It says “flashed successfully”.
Does it appear at dhcp section at your router, when you do reboot?
There exist a similar thread: https://devtalk.nvidia.com/default/topic/999913/l4t-3-0-hangs-on-post-installation/?offset=1 ,
as it seems to me.
Flash really does look like it succeeded…this strongly suggests video auto configuration is failing, but otherwise things are working. SSH login or serial console are very likely to give more information (this is why people are asking to check for DHCP request on the router…if you know the IP address you can do network login via ssh).
Hey everybody!
Thanks for u kindly reply!
As i mentioned before, linux kernel is crasing during the “init” process.
it is impossible to get information through ssh or network
i am working on get some information torough the uart interface
if i can get some console infomation ,i am glad to share
had you keep HDMI connected for the whole flashing procedure?
guessing this was video auto configuration failure, could you please try to disconnect HDMI and bootup the device?
here’s topic for reference.
[url]https://devtalk.nvidia.com/default/topic/1003072/[/url]
@JasonLeeeeeeee: Your failure is probably different than that of @Yugui. In all cases the serial console is of course recommended for information. In the case of @Yugui it seems there is no crash, just an HDMI issue. In the case of @JasonLeeeeeeee that serial console boot log would be quite useful.
