sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
L4T BSP Information:
R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
DATE: Wed Mar 13 07:41:08 UTC 2019
Target Board Information:
Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
OpMode: production, Boot Authentication: NS,
./tegraflash.py --chip 0x18 --applet “/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0048 ] Generating RCM messages
[ 0.0056 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0063 ] RCM 0 is saved as rcm_0.rcm
[ 0.0067 ] RCM 1 is saved as rcm_1.rcm
[ 0.0067 ] List of rcm files are saved in rcm_list.xml
[ 0.0067 ]
[ 0.0067 ] Signing RCM messages
[ 0.0073 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0079 ] Assuming zero filled SBK key
[ 0.0108 ]
[ 0.0108 ] Copying signature to RCM mesages
[ 0.0114 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0123 ]
[ 0.0123 ] Boot Rom communication
[ 0.0129 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0135 ] RCM version 0X180001
[ 0.0144 ] Boot Rom communication completed
[ 1.0207 ]
[ 2.0245 ] tegrarcm_v2 --isapplet
[ 2.0268 ] Applet version 01.00.0000
[ 2.0451 ]
[ 2.0478 ] Retrieving EEPROM data
[ 2.0481 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0487 ] Applet version 01.00.0000
[ 2.0805 ] Saved platform info in /home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1543 ]
Board ID(3310) version(D01) sku(1000) revision(B.0)
copying bctfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing cpu_bootloader(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/spe.bin) reused.
Existing drameccfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Reusing existing system.img…
done.
Existing tbcfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
copying cfgfile(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/bear/nvidia/nvidia_sdk/JetPack_4.2_Linux_P3310/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [kernel-dtb] with tegra186-quill-p3310-1000-c03-00-base.dtb ***
./tegraflash.py --bl nvtboot_recovery_cpu.bin --chip 0x18 --applet mb1_recovery_prod.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --cfg flash.xml --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-mon-only.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb” --cmd “signwrite kernel-dtb tegra186-quill-p3310-1000-c03-00-base.dtb; reboot”
version 1.0.0
[ 0.0110 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0116 ] Assuming zero filled SBK key
[ 0.0116 ]
[ 0.0117 ] sign_type : 909652321
[ 0.0117 ] header_magic: d00dfeed
[ 0.0123 ] tegrahost_v2 --chip 0x18 --align 1_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 0.0129 ]
[ 0.0136 ] tegrahost_v2 --appendsigheader 1_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 0.0146 ]
[ 0.0153 ] tegrasign_v2 --key None --list 1_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 0.0158 ] Assuming zero filled SBK key
[ 0.0224 ]
[ 0.0231 ] tegrahost_v2 --updatesigheader 1_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt 1_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 0.0240 ]
[ 0.0240 ] Generating RCM messages
[ 0.0245 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0249 ] RCM 0 is saved as rcm_0.rcm
[ 0.0251 ] RCM 1 is saved as rcm_1.rcm
[ 0.0251 ] List of rcm files are saved in rcm_list.xml
[ 0.0251 ]
[ 0.0251 ] Signing RCM messages
[ 0.0256 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0261 ] Assuming zero filled SBK key
[ 0.0281 ]
[ 0.0281 ] Copying signature to RCM mesages
[ 0.0286 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0293 ]
[ 0.0293 ] Boot Rom communication
[ 0.0298 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.0302 ] BootRom is not running
[ 5.1065 ]
[ 6.1104 ] tegrarcm_v2 --isapplet
[ 6.1126 ] Applet version 01.00.0000
[ 6.1292 ]
[ 6.1318 ] tegrasign_v2 --key None --getmode mode.txt
[ 6.1342 ] Assuming zero filled SBK key
[ 6.1345 ]
[ 6.1347 ] Parsing partition layout
[ 6.1371 ] tegraparser_v2 --pt flash.xml.tmp
[ 6.1409 ]
[ 6.1410 ] Creating list of images to be signed
[ 6.1438 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 6.1837 ]
[ 6.1837 ] Generating signatures
[ 6.1847 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 6.1855 ] Assuming zero filled SBK key
[ 6.3733 ]
[ 6.3734 ] Reading BCT from device for further operations
[ 6.3734 ] Generating blob
[ 6.3744 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 6.3750 ]
[ 6.3756 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 6.3766 ]
[ 6.3773 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 6.3778 ] Assuming zero filled SBK key
[ 6.3815 ]
[ 6.3823 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 6.3830 ]
[ 6.3836 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 6.3840 ]
[ 6.3845 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 6.3851 ]
[ 6.3858 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 6.3864 ] Assuming zero filled SBK key
[ 6.3880 ]
[ 6.3887 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 6.3894 ]
[ 6.3900 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 6.3907 ]
[ 6.3914 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 6.3921 ]
[ 6.3927 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 6.3931 ] Assuming zero filled SBK key
[ 6.3944 ]
[ 6.3953 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.3959 ]
[ 6.3964 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 6.3969 ]
[ 6.3973 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 6.3999 ]
[ 6.4007 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 6.4012 ] Assuming zero filled SBK key
[ 6.4368 ]
[ 6.4376 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.4397 ]
[ 6.4405 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 6.4412 ]
[ 6.4418 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 6.4428 ]
[ 6.4434 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 6.4439 ] Assuming zero filled SBK key
[ 6.4531 ]
[ 6.4539 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 6.4548 ]
[ 6.4554 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 6.4559 ]
[ 6.4563 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 6.4574 ]
[ 6.4583 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 6.4588 ] Assuming zero filled SBK key
[ 6.4670 ]
[ 6.4679 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 6.4687 ]
[ 6.4692 ] tegrahost_v2 --chip 0x18 --align blob_tos-mon-only.img
[ 6.4697 ]
[ 6.4702 ] tegrahost_v2 --appendsigheader blob_tos-mon-only.img zerosbk
[ 6.4708 ]
[ 6.4714 ] tegrasign_v2 --key None --list blob_tos-mon-only_sigheader.img_list.xml
[ 6.4718 ] Assuming zero filled SBK key
[ 6.4733 ]
[ 6.4739 ] tegrahost_v2 --updatesigheader blob_tos-mon-only_sigheader.img.encrypt blob_tos-mon-only_sigheader.img.hash zerosbk
[ 6.4745 ]
[ 6.4751 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 6.4755 ]
[ 6.4760 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 6.4765 ]
[ 6.4770 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 6.4775 ] Assuming zero filled SBK key
[ 6.4776 ]
[ 6.4782 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 6.4787 ]
[ 6.4792 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 6.4797 ]
[ 6.4801 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 6.4809 ]
[ 6.4814 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 6.4819 ] Assuming zero filled SBK key
[ 6.4878 ]
[ 6.4885 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 6.4893 ]
[ 6.4899 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 6.4903 ] number of images in blob are 9
[ 6.4904 ] blobsize is 3866488
[ 6.4905 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 202832
[ 6.4914 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89184
[ 6.4916 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 6.4918 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 6.4922 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533056
[ 6.4925 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466240
[ 6.4929 ] Added binary blob_tos-mon-only_sigheader.img.encrypt of size 83760
[ 6.4931 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 6.4932 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 344576
[ 6.4943 ]
[ 6.4943 ] Sending bootloader and pre-requisite binaries
[ 6.4949 ] tegrarcm_v2 --download blob blob.bin
[ 6.4954 ] Applet version 01.00.0000
[ 6.5121 ] Sending blob
[ 6.5122 ] […] 100%
[ 6.9793 ]
[ 6.9819 ] tegrarcm_v2 --boot recovery
[ 6.9844 ] Applet version 01.00.0000
[ 7.0071 ]
[ 8.0109 ] tegrarcm_v2 --isapplet
[ 8.0356 ]
[ 8.0385 ] tegradevflash_v2 --iscpubl
[ 8.0410 ] CPU Bootloader is not running on device.
[ 8.0551 ]
[ 9.0590 ] tegrarcm_v2 --isapplet
[ 9.0810 ]
[ 9.0837 ] tegradevflash_v2 --iscpubl
[ 9.0860 ] Bootloader version 01.00.0000
[ 9.1051 ] Bootloader version 01.00.0000
[ 9.1061 ]
[ 9.1062 ] Writing partition
[ 9.1087 ] tegradevflash_v2 --write kernel-dtb 1_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 9.1111 ] Bootloader version 01.00.0000
[ 9.1332 ] Writing partition kernel-dtb with 1_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 9.1347 ] […] 100%
[ 9.1550 ]
[ 9.1552 ] Coldbooting the device
[ 9.1578 ] tegradevflash_v2 --reboot coldboot
[ 9.1602 ] Bootloader version 01.00.0000
[ 9.1676 ]
*** The [kernel-dtb] has been updated successfully. ***
