Problem with cloning jetpack 4.6.2, CPU Bootloader is not running on device TX2i
I wanted to find a way to get back up from installed jetpack os that I edit and installed some things on it, then restore this back up on other same tx2i.
then I find the clone instructions.
But when I run sudo ./flash.sh -r -k APP -G system.img jetson-tx2 mmcblk0p1
I got this error:
# L4T BSP Information:
# R32 , REVISION: 7.2
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0043 ] Generating RCM messages
[   0.0064 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[   0.0072 ] RCM 0 is saved as rcm_0.rcm
[   0.0077 ] RCM 1 is saved as rcm_1.rcm
[   0.0077 ] List of rcm files are saved in rcm_list.xml
[   0.0077 ]
[   0.0077 ] Signing RCM messages
[   0.0101 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0102 ] Assuming zero filled SBK key
[   0.0198 ] Copying signature to RCM mesages
[   0.0221 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0237 ]
[   0.0237 ] Boot Rom communication
[   0.0260 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[   0.0270 ] RCM version 0X180001
[   0.0589 ] Boot Rom communication completed
[   1.0655 ]
[   2.0710 ] tegrarcm_v2 --isapplet
[   2.0729 ] Applet version 01.00.0000
[   2.1044 ]
[   2.1089 ] Retrieving EEPROM data
[   2.1091 ] tegrarcm_v2 --oem platformdetails eeprom cvm /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[   2.1108 ] Applet version 01.00.0000
[   2.2014 ] Saved platform info in /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[   2.2745 ]
Board ID(3489) version(300) sku(0000) revision(S.0)
copying bctfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)... done.
copying misc_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg)... done.
copying pmic_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg)... done.
copying pmc_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg)... done.
copying prod_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg)... done.
copying scr_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg)... done.
copying dev_params(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key  --cmd sign boot.img kernel
version 1.0.0
[   0.0004 ] Generating signature
[   0.0028 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0029 ] Assuming zero filled SBK key : not reading
[   0.0032 ] sign_type   : 0
[   0.0033 ] header_magic: 414e4452
[   0.0052 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[   0.0061 ]
[   0.0081 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img zerosbk
[   0.0109 ]
[   0.0143 ] tegrasign_v3.py --key  --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[   0.0144 ] Assuming zero filled SBK key : not reading
[   0.0323 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[   0.0346 ]
[   0.0355 ] Signed file: /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don't need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Existing sosfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb)... done.
Existing scefile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb)... done.
Copying nv_boot_control.conf to rootfs
/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key  --cmd sign kernel_tegra186-quill-p3310-1000-a00-00-base.dtb kernel_dtb
version 1.0.0
[   0.0006 ] Generating signature
[   0.0031 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0032 ] Assuming zero filled SBK key : not reading
[   0.0036 ] sign_type   : 808464433
[   0.0037 ] header_magic: d00dfeed
[   0.0059 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-quill-p3310-1000-a00-00-base.dtb
[   0.0068 ]
[   0.0089 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_kernel_tegra186-quill-p3310-1000-a00-00-base.dtb zerosbk
[   0.0105 ]
[   0.0138 ] tegrasign_v3.py --key  --list 1_kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0139 ] Assuming zero filled SBK key : not reading
[   0.0272 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt 1_kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.hash zerosbk
[   0.0290 ]
[   0.0298 ] Signed file: /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt
done.
Skip generating system.img
Existing tbcfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb)... done.
copying cfgfile(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Reading [APP] and storing to /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/system.img ***
./tegraflash.py --bl nvtboot_recovery_cpu.bin  --chip 0x18 --applet mb1_recovery_prod.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --dev_params emmc.cfg  --cfg  flash.xml --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-a00-00-base.dtb"  --odmdata 0x1090000  --cmd "read APP /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/system.img"
version 1.0.0
[   0.0075 ] Generating RCM messages
[   0.0098 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[   0.0107 ] RCM 0 is saved as rcm_0.rcm
[   0.0112 ] RCM 1 is saved as rcm_1.rcm
[   0.0112 ] List of rcm files are saved in rcm_list.xml
[   0.0112 ]
[   0.0112 ] Signing RCM messages
[   0.0136 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0137 ] Assuming zero filled SBK key
[   0.0210 ] Copying signature to RCM mesages
[   0.0233 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[   0.0246 ]
[   0.0247 ] Boot Rom communication
[   0.0269 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[   0.0278 ] BootRom is not running
[   5.2657 ]
[   6.2715 ] tegrarcm_v2 --isapplet
[   6.2735 ] Applet version 01.00.0000
[   6.3038 ]
[   6.3075 ] tegrasign_v3.py --getmode mode.txt --key None
[   6.3077 ] Assuming zero filled SBK key
[   6.3077 ] Parsing partition layout
[   6.3102 ] tegraparser_v2 --pt flash.xml.tmp
[   6.3126 ]
[   6.3127 ] Creating list of images to be signed
[   6.3154 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   6.3745 ]
[   6.3746 ] Generating signatures
[   6.3771 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   6.3772 ] Assuming zero filled SBK key
[   6.6891 ] Reading BCT from device for further operations
[   6.6891 ] Generating blob
[   6.6916 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[   6.6926 ]
[   6.6948 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[   6.6963 ]
[   6.6993 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.6994 ] Assuming zero filled SBK key
[   6.7098 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[   6.7113 ]
[   6.7139 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[   6.7150 ]
[   6.7172 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[   6.7193 ]
[   6.7227 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.7228 ] Assuming zero filled SBK key
[   6.7326 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[   6.7343 ]
[   6.7368 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[   6.7380 ]
[   6.7403 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[   6.7418 ]
[   6.7447 ] tegrasign_v3.py --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.7448 ] Assuming zero filled SBK key
[   6.7521 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[   6.7535 ]
[   6.7562 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[   6.7572 ]
[   6.7594 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[   6.7648 ]
[   6.7688 ] tegrasign_v3.py --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.7689 ] Assuming zero filled SBK key
[   6.8114 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[   6.8184 ]
[   6.8211 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[   6.8223 ]
[   6.8247 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_bpmp.bin zerosbk
[   6.8267 ]
[   6.8295 ] tegrasign_v3.py --key None --list blob_bpmp_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   6.8296 ] Assuming zero filled SBK key
[   6.8473 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[   6.8494 ]
[   6.8517 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb
[   6.8527 ]
[   6.8549 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb zerosbk
[   6.8578 ]
[   6.8611 ] tegrasign_v3.py --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   6.8612 ] Assuming zero filled SBK key
[   6.8795 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[   6.8824 ]
[   6.8851 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[   6.8863 ]
[   6.8887 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tos-trusty.img zerosbk
[   6.8908 ]
[   6.8939 ] tegrasign_v3.py --key None --list blob_tos-trusty_sigheader.img_list.xml --pubkeyhash pub_key.key
[   6.8940 ] Assuming zero filled SBK key
[   6.9099 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[   6.9119 ]
[   6.9147 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[   6.9159 ]
[   6.9182 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_eks.img zerosbk
[   6.9193 ]
[   6.9223 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   6.9223 ] Assuming zero filled SBK key
[   6.9281 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   6.9292 ]
[   6.9314 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-a00-00-base.dtb
[   6.9329 ]
[   6.9353 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tegra186-quill-p3310-1000-a00-00-base.dtb zerosbk
[   6.9377 ]
[   6.9410 ] tegrasign_v3.py --key None --list blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   6.9411 ] Assuming zero filled SBK key
[   6.9540 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.hash zerosbk
[   6.9561 ]
[   6.9590 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[   6.9602 ] number of images in blob are 9
[   6.9607 ] blobsize is 4561896
[   6.9609 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 225168
[   6.9642 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 122272
[   6.9650 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 58384
[   6.9655 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2236640
[   6.9665 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 534816
[   6.9675 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt of size 604880
[   6.9687 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 403264
[   6.9692 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[   6.9696 ] Added binary blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt of size 374880
[   6.9725 ]
[   6.9726 ] Sending bootloader and pre-requisite binaries
[   6.9749 ] tegrarcm_v2 --download blob blob.bin
[   6.9757 ] Applet version 01.00.0000
[   7.0533 ] Sending blob
[   7.0535 ] [................................................] 100%
[  16.8677 ]
[  16.8713 ] tegrarcm_v2 --boot recovery
[  16.8724 ] Applet version 01.00.0000
[  16.9454 ]
[  17.9509 ] tegrarcm_v2 --isapplet
[  17.9824 ]
[  17.9859 ] tegradevflash_v2 --iscpubl
[  17.9876 ] CPU Bootloader is not running on device.
[  18.0302 ]
[  19.0357 ] tegrarcm_v2 --isapplet
[  19.1143 ]
[  19.1186 ] tegradevflash_v2 --iscpubl
[  19.1203 ] CPU Bootloader is not running on device.
[  19.1623 ]
[  20.1677 ] tegrarcm_v2 --isapplet
[  20.1980 ]
[  20.2018 ] tegradevflash_v2 --iscpubl
[  20.2040 ] CPU Bootloader is not running on device.
[  20.2503 ]
[  21.2562 ] tegrarcm_v2 --isapplet
[  21.2860 ]
[  21.2897 ] tegradevflash_v2 --iscpubl
[  21.2914 ] CPU Bootloader is not running on device.
[  21.3342 ]
[  22.3400 ] tegrarcm_v2 --isapplet
[  22.3700 ]
[  22.3740 ] tegradevflash_v2 --iscpubl
[  22.3758 ] CPU Bootloader is not running on device.
[  22.4222 ]
[  23.4270 ] tegrarcm_v2 --isapplet
[  23.4580 ]
[  23.4622 ] tegradevflash_v2 --iscpubl
[  23.4638 ] CPU Bootloader is not running on device.
[  23.5059 ]
[  24.5112 ] tegrarcm_v2 --isapplet
[  24.5859 ]
[  24.5896 ] tegradevflash_v2 --iscpubl
[  24.5913 ] CPU Bootloader is not running on device.
[  24.6341 ]
[  25.6401 ] tegrarcm_v2 --isapplet
[  25.7181 ]
[  25.7228 ] tegradevflash_v2 --iscpubl
[  25.7249 ] CPU Bootloader is not running on device.
[  25.7704 ]
[  26.7762 ] tegrarcm_v2 --isapplet
[  26.8541 ]
[  26.8589 ] tegradevflash_v2 --iscpubl
[  26.8613 ] CPU Bootloader is not running on device.
[  26.9101 ]
[  27.9160 ] tegrarcm_v2 --isapplet
[  27.9498 ]
[  27.9534 ] tegradevflash_v2 --iscpubl
[  27.9553 ] CPU Bootloader is not running on device.
[  27.9982 ]
[  29.0042 ] tegrarcm_v2 --isapplet
[  29.0864 ]
[  29.0911 ] tegradevflash_v2 --iscpubl
[  29.0935 ] CPU Bootloader is not running on device.
[  29.1420 ]
[  30.1479 ] tegrarcm_v2 --isapplet
[  30.2259 ]
[  30.2300 ] tegradevflash_v2 --iscpubl
[  30.2325 ] CPU Bootloader is not running on device.
[  30.2782 ]
[  31.2836 ] tegrarcm_v2 --isapplet
[  31.3139 ]
[  31.3176 ] tegradevflash_v2 --iscpubl
[  31.3193 ] CPU Bootloader is not running on device.
[  31.3660 ]
[  32.3721 ] tegrarcm_v2 --isapplet
[  32.4020 ]
[  32.4051 ] tegradevflash_v2 --iscpubl
[  32.4064 ] CPU Bootloader is not running on device.
[  32.4502 ]
[  33.4549 ] tegrarcm_v2 --isapplet
[  33.5342 ]
[  33.5389 ] tegradevflash_v2 --iscpubl
[  33.5405 ] CPU Bootloader is not running on device.
[  33.5861 ]
[  34.5915 ] tegrarcm_v2 --isapplet
[  34.6662 ]
[  34.6710 ] tegradevflash_v2 --iscpubl
[  34.6730 ] CPU Bootloader is not running on device.
[  34.7184 ]
[  35.7233 ] tegrarcm_v2 --isapplet
[  35.7540 ]
[  35.7576 ] tegradevflash_v2 --iscpubl
[  35.7595 ] CPU Bootloader is not running on device.
[  35.8020 ]
[  36.8056 ] tegrarcm_v2 --isapplet
[  36.8342 ]
[  36.8386 ] tegradevflash_v2 --iscpubl
[  36.8410 ] CPU Bootloader is not running on device.
[  36.8861 ]
[  37.8909 ] tegrarcm_v2 --isapplet
[  37.9700 ]
[  37.9740 ] tegradevflash_v2 --iscpubl
[  37.9762 ] CPU Bootloader is not running on device.
[  38.0184 ]
[  39.0243 ] tegrarcm_v2 --isapplet
[  39.0982 ]
[  39.1026 ] tegradevflash_v2 --iscpubl
[  39.1046 ] CPU Bootloader is not running on device.
[  39.1543 ]
[  40.1603 ] tegrarcm_v2 --isapplet
[  40.1938 ]
[  40.1972 ] tegradevflash_v2 --iscpubl
[  40.1989 ] CPU Bootloader is not running on device.
[  40.2461 ]
[  41.2519 ] tegrarcm_v2 --isapplet
[  41.3303 ]
[  41.3348 ] tegradevflash_v2 --iscpubl
[  41.3369 ] CPU Bootloader is not running on device.
[  41.3863 ]
[  42.3908 ] tegrarcm_v2 --isapplet
[  42.4621 ]
[  42.4664 ] tegradevflash_v2 --iscpubl
[  42.4682 ] CPU Bootloader is not running on device.
[  42.5184 ]
[  43.5244 ] tegrarcm_v2 --isapplet
[  43.5540 ]
[  43.5574 ] tegradevflash_v2 --iscpubl
[  43.5590 ] CPU Bootloader is not running on device.
[  43.6062 ]
[  44.6104 ] tegrarcm_v2 --isapplet
[  44.6380 ]
[  44.6416 ] tegradevflash_v2 --iscpubl
[  44.6434 ] CPU Bootloader is not running on device.
[  44.6859 ]
[  45.6917 ] tegrarcm_v2 --isapplet
[  45.7663 ]
[  45.7707 ] tegradevflash_v2 --iscpubl
[  45.7727 ] CPU Bootloader is not running on device.
[  45.8141 ]
[  46.8196 ] tegrarcm_v2 --isapplet
[  46.8940 ]
[  46.8989 ] tegradevflash_v2 --iscpubl
[  46.9014 ] CPU Bootloader is not running on device.
[  46.9460 ]
[  47.9518 ] tegrarcm_v2 --isapplet
[  48.0259 ]
[  48.0296 ] tegradevflash_v2 --iscpubl
[  48.0313 ] CPU Bootloader is not running on device.
[  48.0743 ]
[  49.0799 ] tegrarcm_v2 --isapplet
[  49.1542 ]
[  49.1590 ] tegradevflash_v2 --iscpubl
[  49.1619 ] CPU Bootloader is not running on device.
[  49.2058 ]
[  50.2117 ] tegrarcm_v2 --isapplet
[  50.2862 ]
[  50.2909 ] tegradevflash_v2 --iscpubl
[  50.2932 ] CPU Bootloader is not running on device.
[  50.3383 ]
Error: None of the bootloaders are running on device. Check the UART log.
*** The [APP] has been read successfully. ***
	Converting RAW image to Sparse image... mv: cannot stat '/media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/system.img': No such file or directory
open input file /media/mohsen1javadian/programs/jetson/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/system.img.raw failed.
I read some related problems in forums but I didn’t find any solution.
Your module is TX2i, right?
Please make sure the specifies the configuration to be applied to the device to be flashed is correct. Values are listed in the table of device names
