thanks!
the flash worked by removing the -k APP.
[ 932.3089 ]
[ 932.3093 ] Coldbooting the device
[ 932.3128 ] tegradevflash_v2 --reboot coldboot
[ 932.3156 ] Bootloader version 01.00.0000
[ 932.3229 ]
*** The [APP] has been updated successfully. ***
but now the system keeps restarting in a loop. I don’t know if this problem is related to the clone/restore procedure or something else.
[code]
Serial Port Message1
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140 (nandagopalan@nandagopalan-PC) (gcc versio9
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_B
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_B
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_B
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible s
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f6776000 s53440 r8192 d328
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa8
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=4
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 262144 bytes
[ 0.000000] early log buf free: 29456(89%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byt)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7976100K/8220672K available (14910K kernel code, 2528K r)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 )
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 )
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f10000 ( 14912 )
[ 0.000000] .rodata : 0xffffff8008f10000 - 0xffffff80095a0000 ( 6720 )
[ 0.000000] .init : 0xffffff80095a0000 - 0xffffff8009d30000 ( 7744 )
[ 0.000000] .data : 0xffffff8009d30000 - 0xffffff8009fa8008 ( 2529 )
[ 0.000000] .bss : 0xffffff8009fa8008 - 0xffffff800a03f580 ( 606 )
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 )
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 )
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 )
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf07dc8000 ( 125 )
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f7200000 ( 8050 )
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (p.
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.010031] Console: colour dummy device 80x25
[ 0.014695] console [tty0] enabled
[ 0.018254] bootconsole [uart8250] disabled
[0000.184] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mob)
[0000.193] I> bit @ 0xd480000
[0000.196] I> Boot-device: eMMC
[0000.200] I> sdmmc bdev is already initialized
[0000.204] I> pmic: reset reason (nverc) : 0x0
[0000.210] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.217] I> Found 31 partitions in SDMMC_USER (instance 3)
[0000.223] I> A/B: bin_type (16) slot 0
[0000.227] I> Loading partition bpmp-fw at 0xd7800000
[0000.231] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.237] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.252] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.258] I> A/B: bin_type (17) slot 0
[0000.261] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.267] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.272] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.287] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.465] I> Loading SCE-FW …
[0000.468] I> A/B: bin_type (12) slot 0
[0000.472] I> Loading partition sce-fw at 0xd7300000
[0000.476] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.482] I> Addr: 0xd7300000, start-block: 58782024, num_blocks: 1
[0000.492] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.498] I> Init SCE
[0000.500] I> Loading APE-FW …
[0000.503] I> A/B: bin_type (11) slot 0
[0000.507] I> Loading partition adsp-fw at 0xd7400000
[0000.512] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.517] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.528] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.534] I> Copy BTCM section
[0000.537] I> A/B: bin_type (13) slot 0
[0000.540] I> Loading partition cpu-bootloader at 0x96000000
[0000.546] I> Reading two headers - addr:0x96000000 blocks:1
[0000.551] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.564] I> Binary(13) of size 277776 is loaded @ 0x96000000
[0000.569] I> A/B: bin_type (20) slot 0
[0000.573] I> Loading partition bootloader-dtb at 0x8520f400
[0000.579] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.584] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.599] I> Binary(20) of size 344048 is loaded @ 0x8520f400
[0000.605] I> A/B: bin_type (14) slot 0
[0000.608] I> Loading partition secure-os at 0x8530f600
[0000.613] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.619] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.632] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.639] I> TOS boot-params @ 0x85000000
[0000.643] I> TOS params prepared
[0000.646] I> Loading EKS …
[0000.649] I> A/B: bin_type (15) slot 0
[0000.653] I> Loading partition eks at 0x8590f800
[0000.657] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.663] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.671] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.676] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.681] I> Copied encrypted keys
[0000.685] I> boot profiler @ 0x275844000
[0000.689] I> boot profiler for TOS @ 0x275844000
[0000.694] I> Unhalting SCE
[0000.696] I> Primary Memory Start:80000000 Size:70000000
[0000.702] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.708] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 16:56:00, Jul 16 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0001.068] I> Welcome to Cboot
[0001.071] I> Cboot Version: t186-dcb303f9
[0001.075] I> CPU-BL Params @ 0x275800000
[0001.079] I> 0) Base:0x00000000 Size:0x00000000
[0001.083] I> 1) Base:0x277f00000 Size:0x00100000
[0001.087] I> 2) Base:0x277e00000 Size:0x00100000
[0001.092] I> 3) Base:0x277d00000 Size:0x00100000
[0001.097] I> 4) Base:0x277c00000 Size:0x00100000
[0001.101] I> 5) Base:0x277b00000 Size:0x00100000
[0001.106] I> 6) Base:0x277800000 Size:0x00200000
[0001.110] I> 7) Base:0x277400000 Size:0x00400000
[0001.115] I> 8) Base:0x277a00000 Size:0x00100000
[0001.119] I> 9) Base:0x277300000 Size:0x00100000
[0001.124] I> 10) Base:0x276800000 Size:0x00800000
[0001.128] I> 11) Base:0x30000000 Size:0x00040000
[0001.133] I> 12) Base:0xf0000000 Size:0x00100000
[0001.137] I> 13) Base:0x30040000 Size:0x00001000
[0001.141] I> 14) Base:0x30048000 Size:0x00001000
[0001.146] I> 15) Base:0x30049000 Size:0x00001000
[0001.150] I> 16) Base:0x3004a000 Size:0x00001000
[0001.155] I> 17) Base:0x3004b000 Size:0x00001000
[0001.159] I> 18) Base:0x3004c000 Size:0x00001000
[0001.164] I> 19) Base:0x3004d000 Size:0x00001000
[0001.168] I> 20) Base:0x3004e000 Size:0x00001000
[0001.172] I> 21) Base:0x3004f000 Size:0x00001000
[0001.177] I> 22) Base:0x00000000 Size:0x00000000
[0001.181] I> 23) Base:0xf0100000 Size:0x00010000
[0001.186] I> 24) Base:0x00000000 Size:0x00000000
[0001.190] I> 25) Base:0x00000000 Size:0x00000000
[0001.195] I> 26) Base:0x00000000 Size:0x00000000
[0001.199] I> 27) Base:0x00000000 Size:0x00000000
[0001.203] I> 28) Base:0x84400000 Size:0x00400000
[0001.208] I> 29) Base:0x30000000 Size:0x00010000
[0001.212] I> 30) Base:0x278000000 Size:0x08000000
[0001.217] I> 31) Base:0x00000000 Size:0x00000000
[0001.221] I> 32) Base:0x276000000 Size:0x00600000
[0001.226] I> 33) Base:0x80000000 Size:0x70000000
[0001.230] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.235] I> 35) Base:0x00000000 Size:0x00000000
[0001.239] I> 36) Base:0x00000000 Size:0x00000000
[0001.244] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.248] I> 38) Base:0x84000000 Size:0x00400000
[0001.253] I> 39) Base:0x96000000 Size:0x02000000
[0001.257] I> 40) Base:0x85000000 Size:0x01200000
[0001.261] I> 41) Base:0x275800000 Size:0x00500000
[0001.266] I> 42) Base:0x00000000 Size:0x00000000
[0001.270] I> 43) Base:0x00000000 Size:0x00000000
[0001.275] GIC-SPI Target CPU: 4
[0001.278] Interrupts Init done
[0001.281] calling constructors
[0001.285] initializing heap
[0001.287] initializing threads
[0001.290] initializing timers
[0001.293] creating bootstrap completion thread
[0001.298] top of bootstrap2()
[0001.301] CPU: ARM Cortex A57
[0001.304] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.309] initializing platform
[0001.313] I> Boot-device: eMMC
[0001.318] I> sdmmc bdev is already initialized
[0001.323] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.333] I> Found 31 partitions in SDMMC_USER (instance 3)
[0001.338] W> opt-in fuse is not set, skip fuse_burning
[0001.343] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.349] W> No valid slot number is found in scratch register
[0001.355] W> Return default slot: _a
[0001.358] I> A/B: bin_type (21) slot 0
[0001.361] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.376] I> Kernel_dtb @0x80000000
[0001.379] I> Bl_dtb @0x8520f400
[0001.382] I> gpio framework initialized
[0001.388] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ drir
[0001.398] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon’r
[0001.405] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.414] E> I2C: slave not found in slaves.
[0001.418] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start f.
[0001.426] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.431] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0.
[0001.441] E> tca9539_device_init: failed to write polar reg
[0001.446] E> tegrabl_tca9539_init: failed to init device!
[0001.451] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.458] E> I2C: slave not found in slaves.
[0001.462] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start f.
[0001.470] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.476] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0.
[0001.485] E> tca9539_device_init: failed to write polar reg
[0001.490] E> tegrabl_tca9539_init: failed to init device!
[0001.498] I> fixed regulator driver initialized
[0001.530] I> register ‘maxim’ power off handle
[0001.536] I> virtual i2c enabled
[0001.539] I> registered ‘maxim,max77620’ pmic
[0001.543] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.556] I> Find /i2c@c250000’s alias i2c7
[0001.560] I> Reading eeprom i2c=7 address=0x50
[0001.589] I> Device at /i2c@c250000:0x50
[0001.593] I> Reading eeprom i2c=7 address=0x57
[0001.597] E> I2C: slave not found in slaves.
[0001.601] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.609] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.615] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.624] E> eeprom: Failed to read I2C slave device
[0001.629] I> Eeprom read failed 0x3526070d
[0001.634] I> Find /i2c@c240000’s alias i2c1
[0001.638] I> Reading eeprom i2c=1 address=0x51
[0001.643] E> I2C: slave not found in slaves.
[0001.647] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0001.655] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.661] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0001.670] E> eeprom: Retry to read I2C slave device.
[0001.675] E> I2C: slave not found in slaves.
[0001.679] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0001.687] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.693] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0001.702] E> eeprom: Failed to read I2C slave device
[0001.707] I> Eeprom read failed 0x3526070d
[0001.712] I> Find /i2c@3160000’s alias i2c0
[0001.716] I> Reading eeprom i2c=0 address=0x50
[0001.720] E> I2C: slave not found in slaves.
[0001.724] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.732] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.738] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.747] E> eeprom: Failed to read I2C slave device
[0001.752] I> Eeprom read failed 0x3526070d
[0001.757] I> Find /i2c@3180000’s alias i2c2
[0001.761] I> Reading eeprom i2c=2 address=0x54
[0001.765] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.770] C> GPIO driver for chip_id 0x2 could not be found
[0001.775] E> cam_eeprom_read: Can’t get gpio driver
[0001.780] I> Eeprom read failed 0x4d4d000d
[0001.784] I> Reading eeprom i2c=2 address=0x57
[0001.788] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.793] C> GPIO driver for chip_id 0x2 could not be found
[0001.798] E> cam_eeprom_read: Can’t get gpio driver
[0001.803] I> Eeprom read failed 0x4d4d000d
[0001.807] I> create_pm_ids: id: 3310-1000-D00-F, len: 15
[0001.812] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.844] I> enabling ‘vdd-hdmi’ regulator
[0001.848] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.857] E> cannot find any other nvdisp nodes
[0001.861] E> no valid display unit config found in dtb
[0001.867] W> display init failed
[0001.870] initializing target
[0001.873] calling apps_init()
[0001.876] starting app kernel_boot_app
[0001.887] I> found decompressor handler: lz4-legacy
[0001.891] I> decompressing BMP blob …
[0001.901] I> Kernel type = Normal
[0001.904] I> Loading kernel from partition …
[0001.909] W> No valid slot number is found in scratch register
[0001.914] W> Return default slot: _a
[0001.918] I> A/B: bin_type (24) slot 0
[0001.923] I> Boot image size read from image header: f2d10
[0001.929] I> Boot image load address: 0x0x80400000
[0001.933] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.686] I> Kernel hdr @0x80400000
[0002.689] I> Kernel dtb @0x80000000
[0002.692] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0002.700] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 20
[0002.710] I> Checking boot.img header magic … [0002.714] I> [OK]
[0002.716] I> Valid boot.img @ 0x80400000
[0002.719] I> decompressor handler not found
[0002.723] I> Copying kernel image (477378 bytes) from 0x80400800 to 0x80800000e
[0002.733] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0002.740] I> Updated bpmp info to DTB
[0002.746] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0002.750] I> Updated initrd info to DTB
[0002.754] W> WARN: Fail to override “console=none” in commandline
[0002.760] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0002.767] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0002.774] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0002.781] I> disabled_core_mask: 0xffffff0c
[0002.785] W> No valid slot number is found in scratch register
[0002.791] W> Return default slot: _a
[0002.794] I> Active slot suffix:
[0002.797] I> add_boot_slot_suffix: slot_suffix =
[0002.802] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 co
[0002.838] I> Updated bootarg info to DTB
[0002.842] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:de:3d:f3
[0002.848] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:de:3d:f4
[0002.855] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:de:3d:f5
[0002.863] E> Found no plugin manager ids in source DT
[0002.867] W> Add plugin manager ids from board info
[0002.872] E> “plugin-manager” doesn’t exist, creating
[0002.877] E> “ids” doesn’t exist, creating
[0002.881] E> “connection” doesn’t exist, creating
[0002.886] E> “configs” doesn’t exist, creating
[0002.890] I> create_pm_ids: id: 3310-1000-D00-F, len: 15
[0002.895] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.906] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0002.913] E> “i2c@c250000” doesn’t exist, creating
[0002.918] E> “module@0x50” doesn’t exist, creating
[0002.925] I> Adding plugin-manager/ids/3310-1000-D00-F
[0002.932] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.937] I> Adding plugin-manager/configs/3310-power-config 00
[0002.943] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.949] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.955] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.961] I> Adding plugin-manager/configs/3310-display-config 00
[0002.967] I> Adding plugin-manager/cvm
[0002.971] E> “chip-id” doesn’t exist, creating
[0002.975] I> Adding plugin-manager/chip-id/A02P
[0002.980] E> “odm-data” doesn’t exist, creating
[0002.984] I> Adding /chosen/plugin-manager/odm-data
[0002.994] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.000] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.006] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.011] I> added [base:0x276600000, size:0x200000] to /memory
[0003.017] I> added [base:0x277000000, size:0x200000] to /memory
[0003.023] I> Updated memory info to DTB
[0003.027] E> add_disp_param: failed to get display params for du=0
[0003.035] E> “reset” doesn’t exist, creating
[0003.039] E> “pmc-reset-reason” doesn’t exist, creating
[0003.045] E> “pmic-reset-reason” doesn’t exist, creating
[0003.051] I> Adding ecid(00000001645cf3090000000007fe8480) to DT
[0003.057] I> disabled_core_mask: 0xffffff0c
[0003.069] I> Add serial number:1422719019268 as DT property
[0003.078] I> Plugin-manager override starting
[0003.084] I> node /plugin-manager/fragement@0 matches
[0003.093] I> node /plugin-manager/fragement@4 matches
[0003.106] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.124] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.134] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.142] I> node /plugin-manager/fragment-devslp@0 matches
[0003.154] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.168] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.191] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.204] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.214] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.226] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.262] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.287] I> Disable plugin-manager status in FDT
[0003.292] I> Plugin-manager override finished successfully
[0003.297] I> tegrabl_load_kernel_and_dtb: Done
[0003.302] E> tegrabl_display_clear: display is not initialized
[0003.307] W> Boot logo display failed…
[0003.311] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-gd917e08cec (Jul 16 2019 - 16:56:43 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 98 ms (2 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
32669704 bytes read in 813 ms (38.3 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 4
Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 0000000080058f8e
Starting kernel …
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398s
[ 0.010034] Console: colour dummy device 80x25
[ 0.014696] console [tty0] enabled
[ 0.018247] bootconsole [uart8250] disabled
[0000.185] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mob)
[0000.194] I> bit @ 0xd480000
[0000.197] I> Boot-device: eMMC
[0000.201] I> sdmmc bdev is already initialized
[0000.206] I> pmic: reset reason (nverc) : 0x0
[0000.212] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.219] I> Found 31 partitions in SDMMC_USER (instance 3)
[0000.225] I> A/B: bin_type (16) slot 0
[0000.228] I> Loading partition bpmp-fw at 0xd7800000
[0000.233] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.239] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.253] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.259] I> A/B: bin_type (17) slot 0
[0000.263] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.268] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.273] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.288] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.467] I> Loading SCE-FW …
[0000.470] I> A/B: bin_type (12) slot 0
[0000.474] I> Loading partition sce-fw at 0xd7300000
[0000.479] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.484] I> Addr: 0xd7300000, start-block: 58782024, num_blocks: 1
[0000.495] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.501] I> Init SCE
[0000.503] I> Loading APE-FW …
[0000.506] I> A/B: bin_type (11) slot 0
[0000.510] I> Loading partition adsp-fw at 0xd7400000
[0000.514] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.520] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.530] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.536] I> Copy BTCM section
[0000.539] I> A/B: bin_type (13) slot 0
[0000.543] I> Loading partition cpu-bootloader at 0x96000000
[0000.548] I> Reading two headers - addr:0x96000000 blocks:1
[0000.554] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.566] I> Binary(13) of size 277776 is loaded @ 0x96000000
[0000.572] I> A/B: bin_type (20) slot 0
[0000.576] I> Loading partition bootloader-dtb at 0x8520f400
[0000.581] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.586] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.601] I> Binary(20) of size 344048 is loaded @ 0x8520f400
[0000.607] I> A/B: bin_type (14) slot 0
[0000.611] I> Loading partition secure-os at 0x8530f600
[0000.616] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.621] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.634] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.642] I> TOS boot-params @ 0x85000000
[0000.646] I> TOS params prepared
[0000.649] I> Loading EKS …
[0000.651] I> A/B: bin_type (15) slot 0
[0000.655] I> Loading partition eks at 0x8590f800
[0000.660] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.665] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.673] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.679] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.684] I> Copied encrypted keys
[0000.687] I> boot profiler @ 0x275844000
[0000.691] I> boot profiler for TOS @ 0x275844000
[0000.696] I> Unhalting SCE
[0000.699] I> Primary Memory Start:80000000 Size:70000000
[0000.704] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.711] I> MB2(TBoot-BPMP) done
[0001.071] I> Welcome to Cboot
[0001.074] I> Cboot Version: t186-dcb303f9
[0001.077] I> CPU-BL Params @ 0x275800000
[0001.081] I> 0) Base:0x00000000 Size:0x00000000
[0001.086] I> 1) Base:0x277f00000 Size:0x00100000
[0001.090] I> 2) Base:0x277e00000 Size:0x00100000
[0001.095] I> 3) Base:0x277d00000 Size:0x00100000
[0001.099] I> 4) Base:0x277c00000 Size:0x00100000
[0001.104] I> 5) Base:0x277b00000 Size:0x00100000
[0001.108] I> 6) Base:0x277800000 Size:0x00200000
[0001.113] I> 7) Base:0x277400000 Size:0x00400000
[0001.117] I> 8) Base:0x277a00000 Size:0x00100000
[0001.122] I> 9) Base:0x277300000 Size:0x00100000
[0001.126] I> 10) Base:0x276800000 Size:0x00800000
[0001.131] I> 11) Base:0x30000000 Size:0x00040000
[0001.135] I> 12) Base:0xf0000000 Size:0x00100000
[0001.140] I> 13) Base:0x30040000 Size:0x00001000
[0001.144] I> 14) Base:0x30048000 Size:0x00001000
[0001.149] I> 15) Base:0x30049000 Size:0x00001000
[0001.153] I> 16) Base:0x3004a000 Size:0x00001000
[0001.157] I> 17) Base:0x3004b000 Size:0x00001000
[0001.162] I> 18) Base:0x3004c000 Size:0x00001000
[0001.166] I> 19) Base:0x3004d000 Size:0x00001000
[0001.171] I> 20) Base:0x3004e000 Size:0x00001000
[0001.175] I> 21) Base:0x3004f000 Size:0x00001000
[0001.180] I> 22) Base:0x00000000 Size:0x00000000
[0001.184] I> 23) Base:0xf0100000 Size:0x00010000
[0001.188] I> 24) Base:0x00000000 Size:0x00000000
[0001.193] I> 25) Base:0x00000000 Size:0x00000000
[0001.197] I> 26) Base:0x00000000 Size:0x00000000
[0001.202] I> 27) Base:0x00000000 Size:0x00000000
[0001.206] I> 28) Base:0x84400000 Size:0x00400000
[0001.211] I> 29) Base:0x30000000 Size:0x00010000
[0001.215] I> 30) Base:0x278000000 Size:0x08000000
[0001.220] I> 31) Base:0x00000000 Size:0x00000000
[0001.224] I> 32) Base:0x276000000 Size:0x00600000
[0001.228] I> 33) Base:0x80000000 Size:0x70000000
[0001.233] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.237] I> 35) Base:0x00000000 Size:0x00000000
[0001.242] I> 36) Base:0x00000000 Size:0x00000000
[0001.246] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.251] I> 38) Base:0x84000000 Size:0x00400000
[0001.255] I> 39) Base:0x96000000 Size:0x02000000
[0001.260] I> 40) Base:0x85000000 Size:0x01200000
[0001.264] I> 41) Base:0x275800000 Size:0x00500000
[0001.269] I> 42) Base:0x00000000 Size:0x00000000
[0001.273] I> 43) Base:0x00000000 Size:0x00000000
[0001.277] GIC-SPI Target CPU: 4
[0001.281] Interrupts Init done
[0001.284] calling constructors
[0001.287] initializing heap
[0001.290] initializing threads
[0001.293] initializing timers
[0001.296] creating bootstrap completion thread
[0001.301] top of bootstrap2()
[0001.304] CPU: ARM Cortex A57
[0001.307] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.312] initializing platform
[0001.315] I> Boot-device: eMMC
[0001.321] I> sdmmc bdev is already initialized
[0001.326] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.335] I> Found 31 partitions in SDMMC_USER (instance 3)
[0001.341] W> opt-in fuse is not set, skip fuse_burning
[0001.346] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.352] W> No valid slot number is found in scratch register
[0001.357] W> Return default slot: _a
[0001.361] I> A/B: bin_type (21) slot 0
[0001.364] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.378] I> Kernel_dtb @0x80000000
[0001.381] I> Bl_dtb @0x8520f400
[0001.384] I> gpio framework initialized
[0001.391] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ drir
[0001.400] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon’r
[0001.408] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.416] E> I2C: slave not found in slaves.
[0001.420] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start f.
[0001.428] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.434] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0.
[0001.443] E> tca9539_device_init: failed to write polar reg
[0001.449] E> tegrabl_tca9539_init: failed to init device!
[0001.454] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.461] E> I2C: slave not found in slaves.
[0001.465] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start f.
[0001.473] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.479] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0.
[0001.488] E> tca9539_device_init: failed to write polar reg
[0001.493] E> tegrabl_tca9539_init: failed to init device!
[0001.501] I> fixed regulator driver initialized
[0001.532] I> register ‘maxim’ power off handle
[0001.538] I> virtual i2c enabled
[0001.541] I> registered ‘maxim,max77620’ pmic
[0001.546] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.558] I> Find /i2c@c250000’s alias i2c7
[0001.562] I> Reading eeprom i2c=7 address=0x50
[0001.592] I> Device at /i2c@c250000:0x50
[0001.596] I> Reading eeprom i2c=7 address=0x57
[0001.600] E> I2C: slave not found in slaves.
[0001.604] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0001.612] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.618] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0001.627] E> eeprom: Failed to read I2C slave device
[0001.632] I> Eeprom read failed 0x3526070d
[0001.637] I> Find /i2c@c240000’s alias i2c1
[0001.641] I> Reading eeprom i2c=1 address=0x51
[0001.646] E> I2C: slave not found in slaves.
[0001.650] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0001.658] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.663] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0001.673] E> eeprom: Retry to read I2C slave device.
[0001.678] E> I2C: slave not found in slaves.
[0001.682] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0001.690] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.696] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0001.705] E> eeprom: Failed to read I2C slave device
[0001.710] I> Eeprom read failed 0x3526070d
[0001.714] I> Find /i2c@3160000’s alias i2c0
[0001.718] I> Reading eeprom i2c=0 address=0x50
[0001.723] E> I2C: slave not found in slaves.
[0001.727] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0001.735] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.740] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0001.750] E> eeprom: Failed to read I2C slave device
[0001.755] I> Eeprom read failed 0x3526070d
[0001.760] I> Find /i2c@3180000’s alias i2c2
[0001.764] I> Reading eeprom i2c=2 address=0x54
[0001.768] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.773] C> GPIO driver for chip_id 0x2 could not be found
[0001.778] E> cam_eeprom_read: Can’t get gpio driver
[0001.783] I> Eeprom read failed 0x4d4d000d
[0001.787] I> Reading eeprom i2c=2 address=0x57
[0001.791] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.796] C> GPIO driver for chip_id 0x2 could not be found
[0001.801] E> cam_eeprom_read: Can’t get gpio driver
[0001.806] I> Eeprom read failed 0x4d4d000d
[0001.810] I> create_pm_ids: id: 3310-1000-D00-F, len: 15
[0001.815] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0001.847] I> enabling ‘vdd-hdmi’ regulator
[0001.851] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.860] E> cannot find any other nvdisp nodes
[0001.864] E> no valid display unit config found in dtb
[0001.870] W> display init failed
[0001.873] initializing target
[0001.876] calling apps_init()
[0001.879] starting app kernel_boot_app
[0001.889] I> found decompressor handler: lz4-legacy
[0001.894] I> decompressing BMP blob …
[0001.904] I> Kernel type = Normal
[0001.907] I> Loading kernel from partition …
[0001.911] W> No valid slot number is found in scratch register
[0001.917] W> Return default slot: _a
[0001.920] I> A/B: bin_type (24) slot 0
[0001.926] I> Boot image size read from image header: f2d10
[0001.931] I> Boot image load address: 0x0x80400000
[0001.936] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.684] I> Kernel hdr @0x80400000
[0002.688] I> Kernel dtb @0x80000000
[0002.691] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0002.699] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 20
[0002.708] I> Checking boot.img header magic … [0002.713] I> [OK]
[0002.714] I> Valid boot.img @ 0x80400000
[0002.718] I> decompressor handler not found
[0002.722] I> Copying kernel image (477378 bytes) from 0x80400800 to 0x80800000e
[0002.731] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0002.739] I> Updated bpmp info to DTB
[0002.744] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0002.749] I> Updated initrd info to DTB
[0002.753] W> WARN: Fail to override “console=none” in commandline
[0002.758] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0002.766] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0002.773] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0002.780] I> disabled_core_mask: 0xffffff0c
[0002.784] W> No valid slot number is found in scratch register
[0002.790] W> Return default slot: _a
[0002.793] I> Active slot suffix:
[0002.796] I> add_boot_slot_suffix: slot_suffix =
[0002.801] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 co
[0002.837] I> Updated bootarg info to DTB
[0002.841] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:de:3d:f3
[0002.847] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:de:3d:f4
[0002.853] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:de:3d:f5
[0002.861] E> Found no plugin manager ids in source DT
[0002.866] W> Add plugin manager ids from board info
[0002.871] E> “plugin-manager” doesn’t exist, creating
[0002.876] E> “ids” doesn’t exist, creating
[0002.880] E> “connection” doesn’t exist, creating
[0002.885] E> “configs” doesn’t exist, creating
[0002.889] I> create_pm_ids: id: 3310-1000-D00-F, len: 15
[0002.894] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.905] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0002.912] E> “i2c@c250000” doesn’t exist, creating
[0002.917] E> “module@0x50” doesn’t exist, creating
[0002.924] I> Adding plugin-manager/ids/3310-1000-D00-F
[0002.930] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.936] I> Adding plugin-manager/configs/3310-power-config 00
[0002.942] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.948] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.954] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.960] I> Adding plugin-manager/configs/3310-display-config 00
[0002.966] I> Adding plugin-manager/cvm
[0002.970] E> “chip-id” doesn’t exist, creating
[0002.974] I> Adding plugin-manager/chip-id/A02P
[0002.979] E> “odm-data” doesn’t exist, creating
[0002.983] I> Adding /chosen/plugin-manager/odm-data
[0002.993] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.999] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.004] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.010] I> added [base:0x276600000, size:0x200000] to /memory
[0003.016] I> added [base:0x277000000, size:0x200000] to /memory
[0003.022] I> Updated memory info to DTB
[0003.026] E> add_disp_param: failed to get display params for du=0
[0003.034] E> “reset” doesn’t exist, creating
[0003.038] E> “pmc-reset-reason” doesn’t exist, creating
[0003.044] E> “pmic-reset-reason” doesn’t exist, creating
[0003.050] I> Adding ecid(00000001645cf3090000000007fe8480) to DT
[0003.056] I> disabled_core_mask: 0xffffff0c
[0003.068] I> Add serial number:1422719019268 as DT property
[0003.077] I> Plugin-manager override starting
[0003.082] I> node /plugin-manager/fragement@0 matches
[0003.092] I> node /plugin-manager/fragement@4 matches
[0003.104] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.123] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.132] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.141] I> node /plugin-manager/fragment-devslp@0 matches
[0003.153] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.167] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.190] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.202] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.
