Hi Guys,
Do you know what could cause this rebooting all the time? (from a freshly flashed jetson)
I have made a mistake in pinmux or something else?
[0000.186] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-7d3edb9d)
[0000.195] I> bit @ 0xd480000
[0000.198] I> Boot-device: eMMC
[0000.205] I> sdmmc bdev is already initialized
[0000.210] I> pmic: reset reason (nverc) : 0x0
[0000.241] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.260] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.266] W> No valid slot number is found in scratch register
[0000.272] W> Return default slot: _a
[0000.275] I> A/B: bin_type (16) slot 0
[0000.279] I> Loading partition bpmp-fw at 0xd7800000
[0000.283] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.289] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.314] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.319] W> No valid slot number is found in scratch register
[0000.325] W> Return default slot: _a
[0000.329] I> A/B: bin_type (17) slot 0
[0000.332] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.337] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.343] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.366] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.544] I> Loading SCE-FW …
[0000.547] W> No valid slot number is found in scratch register
[0000.553] W> Return default slot: _a
[0000.556] I> A/B: bin_type (12) slot 0
[0000.560] I> Loading partition sce-fw at 0xd7300000
[0000.565] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.570] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.589] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.595] I> Init SCE
[0000.597] I> Loading APE-FW …
[0000.600] W> No valid slot number is found in scratch register
[0000.606] W> Return default slot: _a
[0000.609] I> A/B: bin_type (11) slot 0
[0000.613] I> Loading partition adsp-fw at 0xd7400000
[0000.618] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.623] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.642] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.648] I> Copy BTCM section
[0000.651] W> No valid slot number is found in scratch register
[0000.657] W> Return default slot: _a
[0000.660] I> A/B: bin_type (13) slot 0
[0000.664] I> Loading partition cpu-bootloader at 0x96000000
[0000.669] I> Reading two headers - addr:0x96000000 blocks:1
[0000.675] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.696] I> Binary(13) of size 283728 is loaded @ 0x96000000
[0000.701] W> No valid slot number is found in scratch register
[0000.707] W> Return default slot: _a
[0000.710] I> A/B: bin_type (20) slot 0
[0000.714] I> Loading partition bootloader-dtb at 0x8520f400
[0000.719] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.725] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.745] I> Binary(20) of size 264480 is loaded @ 0x8520f400
[0000.751] W> No valid slot number is found in scratch register
[0000.757] W> Return default slot: _a
[0000.760] I> A/B: bin_type (14) slot 0
[0000.764] I> Loading partition secure-os at 0x8530f600
[0000.769] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.774] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.795] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.803] I> TOS boot-params @ 0x85000000
[0000.807] I> TOS params prepared
[0000.810] I> Loading EKS …
[0000.813] I> A/B: bin_type (15) slot 0
[0000.816] I> Loading partition eks at 0x8590f800
[0000.821] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.826] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.845] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.850] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.856] I> Copied encrypted keys
[0000.859] I> boot profiler @ 0x275844000
[0000.863] I> boot profiler for TOS @ 0x275844000
[0000.868] I> Unhalting SCE
[0000.871] I> Primary Memory Start:80000000 Size:70000000
[0000.876] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.882] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:43:09, Dec 9 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0001.243] I> Welcome to Cboot
[0001.246] I> Cboot Version: t186-c3c778fb
[0001.250] I> CPU-BL Params @ 0x275800000
[0001.254] I> 0) Base:0x00000000 Size:0x00000000
[0001.258] I> 1) Base:0x277f00000 Size:0x00100000
[0001.263] I> 2) Base:0x277e00000 Size:0x00100000
[0001.267] I> 3) Base:0x277d00000 Size:0x00100000
[0001.272] I> 4) Base:0x277c00000 Size:0x00100000
[0001.276] I> 5) Base:0x277b00000 Size:0x00100000
[0001.281] I> 6) Base:0x277800000 Size:0x00200000
[0001.285] I> 7) Base:0x277400000 Size:0x00400000
[0001.290] I> 8) Base:0x277a00000 Size:0x00100000
[0001.294] I> 9) Base:0x277300000 Size:0x00100000
[0001.299] I> 10) Base:0x276800000 Size:0x00800000
[0001.303] I> 11) Base:0x30000000 Size:0x00040000
[0001.308] I> 12) Base:0xf0000000 Size:0x00100000
[0001.312] I> 13) Base:0x30040000 Size:0x00001000
[0001.317] I> 14) Base:0x30048000 Size:0x00001000
[0001.321] I> 15) Base:0x30049000 Size:0x00001000
[0001.325] I> 16) Base:0x3004a000 Size:0x00001000
[0001.330] I> 17) Base:0x3004b000 Size:0x00001000
[0001.334] I> 18) Base:0x3004c000 Size:0x00001000
[0001.339] I> 19) Base:0x3004d000 Size:0x00001000
[0001.343] I> 20) Base:0x3004e000 Size:0x00001000
[0001.348] I> 21) Base:0x3004f000 Size:0x00001000
[0001.352] I> 22) Base:0x00000000 Size:0x00000000
[0001.356] I> 23) Base:0xf0100000 Size:0x00010000
[0001.361] I> 24) Base:0x00000000 Size:0x00000000
[0001.365] I> 25) Base:0x00000000 Size:0x00000000
[0001.370] I> 26) Base:0x00000000 Size:0x00000000
[0001.374] I> 27) Base:0x00000000 Size:0x00000000
[0001.379] I> 28) Base:0x84400000 Size:0x00400000
[0001.383] I> 29) Base:0x30000000 Size:0x00010000
[0001.387] I> 30) Base:0x278000000 Size:0x08000000
[0001.392] I> 31) Base:0x00000000 Size:0x00000000
[0001.396] I> 32) Base:0x276000000 Size:0x00600000
[0001.401] I> 33) Base:0x80000000 Size:0x70000000
[0001.405] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.410] I> 35) Base:0x00000000 Size:0x00000000
[0001.414] I> 36) Base:0x00000000 Size:0x00000000
[0001.419] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.423] I> 38) Base:0x84000000 Size:0x00400000
[0001.428] I> 39) Base:0x96000000 Size:0x02000000
[0001.432] I> 40) Base:0x85000000 Size:0x01200000
[0001.437] I> 41) Base:0x275800000 Size:0x00500000
[0001.441] I> 42) Base:0x00000000 Size:0x00000000
[0001.446] I> 43) Base:0x00000000 Size:0x00000000
[0001.450] GIC-SPI Target CPU: 4
[0001.453] Interrupts Init done
[0001.456] calling constructors
[0001.460] initializing heap
[0001.462] initializing threads
[0001.465] initializing timers
[0001.469] creating bootstrap completion thread
[0001.473] top of bootstrap2()
[0001.476] CPU: ARM Cortex A57
[0001.480] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.485] initializing platform
[0001.488] I> Bl_dtb @0x8520f400
[0001.491] I> gpio framework initialized
[0001.496] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ driver
[0001.505] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio-aon’ driver
[0001.513] I> GPIO framework and drivers are initialized.
[0001.518] I> Boot-device: eMMC
[0001.525] I> sdmmc bdev is already initialized
[0001.556] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0001.573] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.578] W> opt-in fuse is not set, skip fuse_burning
[0001.583] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.589] W> No valid slot number is found in scratch register
[0001.595] W> Return default slot: _a
[0001.598] I> A/B: bin_type (21) slot 0
[0001.602] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.619] I> Kernel_dtb @0x80000000
[0001.622] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.631] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.641] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.649] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.655] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.664] E> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.674] E> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.682] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.690] I> fixed regulator driver initialized
[0001.716] I> register ‘maxim’ power off handle
[0001.721] I> virtual i2c enabled
[0001.724] I> registered ‘maxim,max77620’ pmic
[0001.728] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.738] I> Find /i2c@c250000’s alias i2c7
[0001.742] I> Reading eeprom i2c=7 address=0x50
[0001.772] I> Device at /i2c@c250000:0x50
[0001.775] I> Reading eeprom i2c=7 address=0x57
[0001.780] E> I2C: slave not found in slaves.
[0001.784] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.792] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.797] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.807] E> eeprom: Failed to read I2C slave device
[0001.812] I> Eeprom read failed 0x3526070d
[0001.816] I> Find /i2c@c240000’s alias i2c1
[0001.820] I> Reading eeprom i2c=1 address=0x51
[0001.825] E> I2C: slave not found in slaves.
[0001.830] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.837] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.843] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.853] E> eeprom: Retry to read I2C slave device.
[0001.858] E> I2C: slave not found in slaves.
[0001.862] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.869] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.875] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.885] E> eeprom: Failed to read I2C slave device
[0001.889] I> Eeprom read failed 0x3526070d
[0001.894] I> Find /i2c@3160000’s alias i2c0
[0001.898] I> Reading eeprom i2c=0 address=0x50
[0001.903] E> I2C: slave not found in slaves.
[0001.907] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.915] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.921] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.930] E> eeprom: Failed to read I2C slave device
[0001.935] I> Eeprom read failed 0x3526070d
[0001.940] I> Find /i2c@3180000’s alias i2c2
[0001.944] I> Reading eeprom i2c=2 address=0x54
[0001.948] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.953] C> GPIO driver for chip_id 0x2 could not be found
[0001.958] E> cam_eeprom_read: Can’t get gpio driver
[0001.963] I> Eeprom read failed 0x4d4d000d
[0001.967] I> Reading eeprom i2c=2 address=0x57
[0001.971] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.976] C> GPIO driver for chip_id 0x2 could not be found
[0001.981] E> cam_eeprom_read: Can’t get gpio driver
[0001.986] I> Eeprom read failed 0x4d4d000d
[0001.990] I> create_pm_ids: id: 3310-1000-D00-E, len: 15
[0001.995] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.020] E> could not find regulator
[0002.023] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.031] E> cannot find any other nvdisp nodes
[0002.036] E> no valid display unit config found in dtb
[0002.041] W> display init failed
[0002.044] initializing target
[0002.047] calling apps_init()
[0002.051] starting app kernel_boot_app
[0002.073] I> found decompressor handler: lz4-legacy
[0002.078] I> decompressing BMP blob …
[0002.088] I> Kernel type = Normal
[0002.091] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.106] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.113] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.119] I> ########## Fixed storage boot ##########
[0002.124] I> Loading kernel from partition …
[0002.129] W> No valid slot number is found in scratch register
[0002.134] W> Return default slot: _a
[0002.138] I> A/B: bin_type (24) slot 0
[0002.153] I> Boot image size read from image header: f2f08
[0002.159] I> Boot image load address: 0x0x80400000
[0002.163] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.106] I> Validate kernel …
[0003.109] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.116] I> kernel-dtb is already loaded
[0003.120] I> Validate kernel-dtb …
[0003.123] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.131] I> Checking boot.img header magic … [0003.135] I> [OK]
[0003.137] I> Kernel hdr @0x80400000
[0003.140] I> Kernel dtb @0x80000000
[0003.143] I> decompressor handler not found
[0003.147] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80800000 … [0003.155] I> Done
[0003.157] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0003.164] I> Updated bpmp info to DTB
[0003.169] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0003.173] I> Updated initrd info to DTB
[0003.177] W> WARN: Fail to override “console=none” in commandline
[0003.183] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.190] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.197] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.204] I> disabled_core_mask: 0xffffff0c
[0003.208] W> No valid slot number is found in scratch register
[0003.214] W> Return default slot: _a
[0003.217] I> Active slot suffix:
[0003.221] I> add_boot_slot_suffix: slot_suffix =
[0003.225] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.263] I> Updated bootarg info to DTB
[0003.267] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:c7:77:62
[0003.273] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:c7:77:63
[0003.279] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:c7:77:64
[0003.285] E> Found no plugin manager ids in source DT
[0003.290] W> Add plugin manager ids from board info
[0003.295] E> “plugin-manager” doesn’t exist, creating
[0003.300] E> “ids” doesn’t exist, creating
[0003.304] E> “connection” doesn’t exist, creating
[0003.308] E> “configs” doesn’t exist, creating
[0003.313] I> create_pm_ids: id: 3310-1000-D00-E, len: 15
[0003.318] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.329] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0003.336] E> “i2c@c250000” doesn’t exist, creating
[0003.340] E> “module@0x50” doesn’t exist, creating
[0003.346] I> Adding plugin-manager/ids/3310-1000-D00-E
[0003.353] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.358] I> Adding plugin-manager/configs/3310-power-config 00
[0003.364] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.370] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.376] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.382] I> Adding plugin-manager/configs/3310-display-config 00
[0003.388] I> Adding plugin-manager/cvm
[0003.392] E> “chip-id” doesn’t exist, creating
[0003.396] I> Adding plugin-manager/chip-id/A02P
[0003.401] E> “odm-data” doesn’t exist, creating
[0003.405] I> Adding /chosen/plugin-manager/odm-data
[0003.414] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.420] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.426] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.431] I> added [base:0x276600000, size:0x200000] to /memory
[0003.437] I> added [base:0x277000000, size:0x200000] to /memory
[0003.443] I> Updated memory info to DTB
[0003.447] E> add_disp_param: failed to get display params for du=0
[0003.454] E> “reset” doesn’t exist, creating
[0003.458] E> “pmc-reset-reason” doesn’t exist, creating
[0003.464] E> “pmic-reset-reason” doesn’t exist, creating
[0003.470] I> Adding ecid(0000000164511842040000000cfb0340) to DT
[0003.476] I> disabled_core_mask: 0xffffff0c
[0003.486] I> Add serial number:0420319015847 as DT property
[0003.494] I> Plugin-manager override starting
[0003.499] I> node /plugin-manager/fragement@0 matches
[0003.507] I> node /plugin-manager/fragement@4 matches
[0003.517] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.532] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.541] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.549] I> node /plugin-manager/fragment-devslp@0 matches
[0003.558] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.569] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.586] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.596] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.604] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.613] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.633] I> Disable plugin-manager status in FDT
[0003.637] I> Plugin-manager override finished successfully
[0003.643] I> tegrabl_load_kernel_and_dtb: Done
[0003.647] E> tegrabl_display_clear: display is not initialized
[0003.653] W> Boot logo display failed…
[0003.656] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:43:10 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 104 ms (6.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565140 bytes read in 205 ms (25.9 MiB/s)
Retrieving file: /boot/Image
34258952 bytes read in 855 ms (38.2 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 00000000800458bc
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-magellan (rodolfo@pc-logmar) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #8 SMP PREEMPT Sun Apr 26 19:53:18 CEST 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 3.022633] CPU0: SError detected, daif=140, spsr=0x80000045, mpidr=80000100, esr=bf40c000
[ 3.022636] CPU5: SError detected, daif=1c0, spsr=0x600000c5, mpidr=80000103, esr=bf40c000
[ 3.022639] CPU3: SError detected, daif=140, spsr=0x40000045, mpidr=80000101, esr=bf40c000
[ 3.022642] CPU4: SError detected, daif=1c0, spsr=0xc5, mpidr=80000102, esr=bf40c000
[ 24.169649] Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 1
[ 24.176920] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.9.140-magellan #8
[ 24.183744] Hardware name: quill (DT)
[ 24.187426] Call trace:
[ 24.189896] [] dump_backtrace+0x0/0x198
[ 24.195326] [] show_stack+0x24/0x30
[ 24.200406] [] dump_stack+0x98/0xc0
[ 24.205489] [] panic+0x11c/0x298
[ 24.210309] [] watchdog_check_hardlockup_other_cpu+0x11c/0x120
[ 24.217743] [] watchdog_timer_fn+0x98/0x2c0
[ 24.223521] [] __hrtimer_run_queues+0xd8/0x360
[ 24.229558] [] hrtimer_interrupt+0xa8/0x1e0
[ 24.235336] [] tegra186_timer_isr+0x34/0x48
[ 24.241114] [] __handle_irq_event_percpu+0x68/0x288
[ 24.247586] [] handle_irq_event_percpu+0x28/0x60
[ 24.253796] [] handle_irq_event+0x50/0x80
[ 24.259397] [] handle_fasteoi_irq+0xc8/0x1b8
[ 24.265260] [] generic_handle_irq+0x34/0x50
[ 24.271034] [] __handle_domain_irq+0x68/0xc0
[ 24.276897] [] gic_handle_irq+0x5c/0xb0
[ 24.282323] [] el1_irq+0xe8/0x18c
[ 24.287227] [] arch_cpu_idle+0x30/0x1b0
[ 24.292654] [] cpu_startup_entry+0x140/0x200
[ 24.298519] [] rest_init+0x84/0x90
[ 24.303513] [] start_kernel+0x370/0x384
[ 24.308939] [] __primary_switched+0x80/0x94
[ 24.314716] SMP: stopping secondary CPUs
[ 25.400417] SMP: failed to stop secondary CPUs 0-2,4
[ 25.405408] Kernel Offset: disabled
[ 25.408914] Memory Limit: none
[ 25.416015] Rebooting in 5 seconds…
[ 30.420000] SMP: stopping secondary CPUs
[ 31.505551] SMP: failed to stop secondary CPUs 0-2,4
Reboots from here and starts over…
