Hello to everyone,
I have a problem with Jetson TX2 and a custom designed carrier board. We planned to use the module lent from the TX2 devkit for prototyping before buy modules for production stage.
We first power up and boot the Devkit, everything went fine as expected, the module comes already flashed, we configure Ubuntu for the first time and we are ready to go.
Then, we place the TX2 on our custom designed board, we receive these message on the serial monitor:
[0000.348] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-7d3edb9d)
[0000.356] I> bit @ 0xd480000
[0000.359] I> Boot-device: eMMC
[0000.366] I> sdmmc bdev is already initialized
[0000.371] I> pmic: reset reason (nverc) : 0x40
[0000.403] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.422] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.428] W> No valid slot number is found in scratch register
[0000.433] W> Return default slot: _a
[0000.437] I> A/B: bin_type (16) slot 0
[0000.440] I> Loading partition bpmp-fw at 0xd7800000
[0000.445] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.451] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.476] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.482] W> No valid slot number is found in scratch register
[0000.487] W> Return default slot: _a
[0000.491] I> A/B: bin_type (17) slot 0
[0000.494] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.499] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.505] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.528] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.707] I> Loading SCE-FW ...
[0000.710] W> No valid slot number is found in scratch register
[0000.715] W> Return default slot: _a
[0000.719] I> A/B: bin_type (12) slot 0
[0000.722] I> Loading partition sce-fw at 0xd7300000
[0000.727] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.733] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.752] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.757] I> Init SCE
[0000.760] I> Loading APE-FW ...
[0000.763] W> No valid slot number is found in scratch register
[0000.768] W> Return default slot: _a
[0000.772] I> A/B: bin_type (11) slot 0
[0000.775] I> Loading partition adsp-fw at 0xd7400000
[0000.780] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.786] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.805] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.811] I> Copy BTCM section
[0000.814] W> No valid slot number is found in scratch register
[0000.819] W> Return default slot: _a
[0000.823] I> A/B: bin_type (13) slot 0
[0000.826] I> Loading partition cpu-bootloader at 0x96000000
[0000.832] I> Reading two headers - addr:0x96000000 blocks:1
[0000.837] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.859] I> Binary(13) of size 283728 is loaded @ 0x96000000
[0000.864] W> No valid slot number is found in scratch register
[0000.870] W> Return default slot: _a
[0000.873] I> A/B: bin_type (20) slot 0
[0000.877] I> Loading partition bootloader-dtb at 0x8520f400
[0000.882] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.888] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.910] I> Binary(20) of size 371232 is loaded @ 0x8520f400
[0000.916] W> No valid slot number is found in scratch register
[0000.922] W> Return default slot: _a
[0000.925] I> A/B: bin_type (14) slot 0
[0000.929] I> Loading partition secure-os at 0x8530f600
[0000.934] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.939] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.960] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.968] I> TOS boot-params @ 0x85000000
[0000.972] I> TOS params prepared
[0000.975] I> Loading EKS ...
[0000.977] I> A/B: bin_type (15) slot 0
[0000.981] I> Loading partition eks at 0x8590f800
[0000.986] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.991] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0001.010] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0001.015] I> EKB detected (length: 0x400) @ 0x8590f800
[0001.020] I> Copied encrypted keys
[0001.024] I> boot profiler @ 0x275844000
[0001.028] I> boot profiler for TOS @ 0x275844000
[0001.033] I> Unhalting SCE
[0001.035] I> Primary Memory Start:80000000 Size:70000000
[0001.041] I> Extended Memory Start:f0110000 Size:1856f0000
[0001.047] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 11:54:11, Dec 16 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0001.408] I> Welcome to Cboot
[0001.411] I> Cboot Version: t186-c3c778fb
[0001.414] I> CPU-BL Params @ 0x275800000
[0001.418] I> 0) Base:0x00000000 Size:0x00000000
[0001.423] I> 1) Base:0x277f00000 Size:0x00100000
[0001.427] I> 2) Base:0x277e00000 Size:0x00100000
[0001.432] I> 3) Base:0x277d00000 Size:0x00100000
[0001.436] I> 4) Base:0x277c00000 Size:0x00100000
[0001.441] I> 5) Base:0x277b00000 Size:0x00100000
[0001.445] I> 6) Base:0x277800000 Size:0x00200000
[0001.450] I> 7) Base:0x277400000 Size:0x00400000
[0001.454] I> 8) Base:0x277a00000 Size:0x00100000
[0001.459] I> 9) Base:0x277300000 Size:0x00100000
[0001.463] I> 10) Base:0x276800000 Size:0x00800000
[0001.468] I> 11) Base:0x30000000 Size:0x00040000
[0001.472] I> 12) Base:0xf0000000 Size:0x00100000
[0001.477] I> 13) Base:0x30040000 Size:0x00001000
[0001.481] I> 14) Base:0x30048000 Size:0x00001000
[0001.485] I> 15) Base:0x30049000 Size:0x00001000
[0001.490] I> 16) Base:0x3004a000 Size:0x00001000
[0001.494] I> 17) Base:0x3004b000 Size:0x00001000
[0001.499] I> 18) Base:0x3004c000 Size:0x00001000
[0001.503] I> 19) Base:0x3004d000 Size:0x00001000
[0001.508] I> 20) Base:0x3004e000 Size:0x00001000
[0001.512] I> 21) Base:0x3004f000 Size:0x00001000
[0001.516] I> 22) Base:0x00000000 Size:0x00000000
[0001.521] I> 23) Base:0xf0100000 Size:0x00010000
[0001.525] I> 24) Base:0x00000000 Size:0x00000000
[0001.530] I> 25) Base:0x00000000 Size:0x00000000
[0001.534] I> 26) Base:0x00000000 Size:0x00000000
[0001.539] I> 27) Base:0x00000000 Size:0x00000000
[0001.543] I> 28) Base:0x84400000 Size:0x00400000
[0001.547] I> 29) Base:0x30000000 Size:0x00010000
[0001.552] I> 30) Base:0x278000000 Size:0x08000000
[0001.556] I> 31) Base:0x00000000 Size:0x00000000
[0001.561] I> 32) Base:0x276000000 Size:0x00600000
[0001.565] I> 33) Base:0x80000000 Size:0x70000000
[0001.570] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.574] I> 35) Base:0x00000000 Size:0x00000000
[0001.579] I> 36) Base:0x00000000 Size:0x00000000
[0001.583] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.588] I> 38) Base:0x84000000 Size:0x00400000
[0001.592] I> 39) Base:0x96000000 Size:0x02000000
[0001.597] I> 40) Base:0x85000000 Size:0x01200000
[0001.601] I> 41) Base:0x275800000 Size:0x00500000
[0001.606] I> 42) Base:0x00000000 Size:0x00000000
[0001.610] I> 43) Base:0x00000000 Size:0x00000000
[0001.614] GIC-SPI Target CPU: 4
[0001.618] Interrupts Init done
[0001.621] calling constructors
[0001.624] initializing heap
[0001.627] initializing threads
[0001.630] initializing timers
[0001.633] creating bootstrap completion thread
[0001.638] top of bootstrap2()
[0001.641] CPU: ARM Cortex A57
[0001.644] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.649] initializing platform
[0001.652] I> Bl_dtb @0x8520f400
[0001.655] I> gpio framework initialized
[0001.662] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.672] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.679] I> GPIO framework and drivers are initialized.
[0001.685] I> Boot-device: eMMC
[0001.692] I> sdmmc bdev is already initialized
[0001.722] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0001.740] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.745] W> opt-in fuse is not set, skip fuse_burning
[0001.750] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.756] W> No valid slot number is found in scratch register
[0001.762] W> Return default slot: _a
[0001.765] I> A/B: bin_type (21) slot 0
[0001.769] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.786] I> Kernel_dtb @0x80000000
[0001.790] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.798] E> I2C: slave not found in slaves.
[0001.802] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.810] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.816] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.825] E> tca9539_device_init: failed to write polar reg
[0001.830] E> tegrabl_tca9539_init: failed to init device!
[0001.835] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.842] E> I2C: slave not found in slaves.
[0001.846] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.854] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.860] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.869] E> tca9539_device_init: failed to write polar reg
[0001.874] E> tegrabl_tca9539_init: failed to init device!
[0001.883] I> fixed regulator driver initialized
[0001.915] I> register 'maxim' power off handle
[0001.922] I> virtual i2c enabled
[0001.925] I> registered 'maxim,max77620' pmic
[0001.929] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.942] I> Find /i2c@c250000's alias i2c7
[0001.946] I> Reading eeprom i2c=7 address=0x50
[0001.976] I> Device at /i2c@c250000:0x50
[0001.979] I> Reading eeprom i2c=7 address=0x57
[0002.008] I> Device at /i2c@c250000:0x57
[0002.012] I> Find /i2c@c240000's alias i2c1
[0002.016] I> Reading eeprom i2c=1 address=0x51
[0002.022] E> I2C: slave not found in slaves.
[0002.026] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0002.033] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.039] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0002.049] E> eeprom: Retry to read I2C slave device.
[0002.054] E> I2C: slave not found in slaves.
[0002.058] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0002.065] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.071] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at0x00000000 via instance 1.
[0002.081] E> eeprom: Failed to read I2C slave device
[0002.086] I> Eeprom read failed 0x3526070d
[0002.090] I> Find /i2c@3160000's alias i2c0
[0002.094] I> Reading eeprom i2c=0 address=0x50
[0002.098] E> I2C: slave not found in slaves.
[0002.103] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.110] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.116] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0002.126] E> eeprom: Failed to read I2C slave device
[0002.130] I> Eeprom read failed 0x3526070d
[0002.135] I> Find /i2c@3180000's alias i2c2
[0002.139] I> Reading eeprom i2c=2 address=0x54
[0002.143] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.148] C> GPIO driver for chip_id 0x2 could not be found
[0002.154] E> cam_eeprom_read: Can't get gpio driver
[0002.158] I> Eeprom read failed 0x4d4d000d
[0002.162] I> Reading eeprom i2c=2 address=0x57
[0002.166] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.171] C> GPIO driver for chip_id 0x2 could not be found
[0002.177] E> cam_eeprom_read: Can't get gpio driver
[0002.181] I> Eeprom read failed 0x4d4d000d
[0002.185] I> create_pm_ids: id: 3310-1000-D00-K, len: 15
[0002.190] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.201] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.206] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0002.241] I> enabling 'vdd-hdmi' regulator
[0002.245] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.254] E> cannot find any other nvdisp nodes
[0002.258] E> no valid display unit config found in dtb
[0002.264] W> display init failed
[0002.267] initializing target
[0002.270] calling apps_init()
[0002.273] starting app kernel_boot_app
[0002.296] I> found decompressor handler: lz4-legacy
[0002.301] I> decompressing BMP blob ...
[0002.311] I> Kernel type = Normal
[0002.314] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.328] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.335] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.342] I> ########## Fixed storage boot ##########
[0002.347] I> Loading kernel from partition ...
[0002.351] W> No valid slot number is found in scratch register
[0002.357] W> Return default slot: _a
[0002.360] I> A/B: bin_type (24) slot 0
[0002.376] I> Boot image size read from image header: f2f08
[0002.381] I> Boot image load address: 0x0x80400000
[0002.386] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.329] I> Validate kernel ...
[0003.332] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.339] I> kernel-dtb is already loaded
[0003.343] I> Validate kernel-dtb ...
[0003.346] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.354] I> Checking boot.img header magic ... [0003.358] I> [OK]
[0003.360] I> Kernel hdr @0x80400000
[0003.363] I> Kernel dtb @0x80000000
[0003.367] I> decompressor handler not found
[0003.371] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80800000 ... [0003.378] I> Done
[0003.380] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0003.387] I> Updated bpmp info to DTB
[0003.393] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0003.398] I> Updated initrd info to DTB
[0003.401] W> WARN: Fail to override "console=none" in commandline
[0003.407] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.414] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.422] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.429] I> disabled_core_mask: 0xffffff0c
[0003.433] W> No valid slot number is found in scratch register
[0003.438] W> Return default slot: _a
[0003.442] I> Active slot suffix:
[0003.445] I> add_boot_slot_suffix: slot_suffix =
[0003.449] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.486] I> Updated bootarg info to DTB
[0003.490] I> eeprom_get_mac_addr: MAC (type: 0): 48:b0:2d:0e:fd:6d
[0003.496] I> eeprom_get_mac_addr: MAC (type: 1): 48:b0:2d:0e:fd:6e
[0003.502] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:0e:fd:6f
[0003.508] E> Found no plugin manager ids in source DT
[0003.513] W> Add plugin manager ids from board info
[0003.518] E> "plugin-manager" doesn't exist, creating
[0003.523] E> "ids" doesn't exist, creating
[0003.527] E> "connection" doesn't exist, creating
[0003.532] E> "configs" doesn't exist, creating
[0003.536] I> create_pm_ids: id: 3310-1000-D00-K, len: 15
[0003.541] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.552] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0003.557] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0003.568] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0003.575] E> "i2c@c250000" doesn't exist, creating
[0003.580] E> "module@0x50" doesn't exist, creating
[0003.585] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@c250000:module@0x57
[0003.592] E> "module@0x57" doesn't exist, creating
[0003.599] I> Adding plugin-manager/ids/3310-1000-D00-K
[0003.606] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.611] I> Adding plugin-manager/configs/3310-power-config 00
[0003.617] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.623] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.629] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.635] I> Adding plugin-manager/configs/3310-display-config 00
[0003.641] I> Adding plugin-manager/cvm
[0003.645] E> "chip-id" doesn't exist, creating
[0003.650] I> Adding plugin-manager/chip-id/A02P
[0003.654] E> "odm-data" doesn't exist, creating
[0003.659] I> Adding /chosen/plugin-manager/odm-data
[0003.669] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.674] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.680] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.686] I> added [base:0x276600000, size:0x200000] to /memory
[0003.692] I> added [base:0x277000000, size:0x200000] to /memory
[0003.697] I> Updated memory info to DTB
[0003.702] E> add_disp_param: failed to get display params for du=0
[0003.710] E> "reset" doesn't exist, creating
[0003.714] E> "pmc-reset-reason" doesn't exist, creating
[0003.720] E> "pmic-reset-reason" doesn't exist, creating
[0003.726] I> Adding ecid(00000001646dd5c41c0000000e048140) to DT
[0003.732] I> disabled_core_mask: 0xffffff0c
[0003.745] I> Add serial number:1422220011124 as DT property
[0003.754] I> Plugin-manager override starting
[0003.759] I> node /plugin-manager/fragement@0 matches
[0003.769] I> node /plugin-manager/fragement@4 matches
[0003.782] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.802] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.811] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.820] I> node /plugin-manager/fragment-devslp@0 matches
[0003.832] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.847] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.870] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.883] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.894] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.907] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.945] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.972] I> Disable plugin-manager status in FDT
[0003.976] I> Plugin-manager override finished successfully
[0003.982] I> tegrabl_load_kernel_and_dtb: Done
[0003.986] E> tegrabl_display_clear: display is not initialized
[0003.992] W> Boot logo display failed...
[0003.995] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-g0536cf2a27 (Dec 16 2019 - 13:29:52 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 117 ms (5.9 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565149 bytes read in 202 ms (26.3 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 853 ms (38.2 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
## Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 000000008005f9b7
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-2390-d3000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Mon Dec 16 13:32:15 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
<hit enter to activate fiq debugger>
[ 0.535942] pca953x 0-0074: failed reading register
[ 0.536500] pca953x 0-0077: failed reading register
[ 1.097976] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.163187] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 1.357340] FAN: coudln't get the regulator
[ 11.337832] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.344207] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 11.350836] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 11.355892] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.362502] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.367987] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.373732] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 11.378868] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 11.384124] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.577888] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.584282] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 21.590931] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 21.596015] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.602660] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.608182] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.613954] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 21.619118] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 21.624402] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.646057] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 21.653004] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 21.923687] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.937584] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.952712] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.473339] cgroup: cgroup2: unknown option "nsdelegate"
[ 22.926201] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.006420] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 23.209833] random: crng init done
[ 23.213257] random: 7 urandom warning(s) missed due to ratelimiting
[ 24.005306] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.541775] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.561255] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.577195] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.860261] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 24.875422] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 25.222328] CPU1: shutdown
[ 25.290632] CPU2: shutdown
[ 25.946236] vdd-1v8: voltage operation not allowed
[ 25.951082] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 25.978082] vdd-1v8: voltage operation not allowed
[ 25.982961] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 26.006802] vdd-1v8: voltage operation not allowed
[ 26.011616] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 26.020655] vdd-1v8: voltage operation not allowed
[ 26.025498] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 26.137948] vdd-1v8: voltage operation not allowed
[ 26.143090] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 26.152092] vdd-1v8: voltage operation not allowed
[ 26.156928] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 26.166102] vdd-1v8: voltage operation not allowed
[ 26.170998] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 31.817834] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 31.824326] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 31.832162] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 31.838308] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 31.845507] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 31.851102] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 31.856937] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 31.862126] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 31.867448] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
Ubuntu 18.04.3 LTS jetson-desktop ttyS0
jetson-desktop login: [ 42.058170] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 42.064965] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 42.071958] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 42.077096] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 42.083805] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 42.089332] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 42.095115] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 42.100283] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 42.105560] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 52.298230] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 52.305171] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 52.312146] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 52.317332] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 52.324059] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 52.329603] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 52.335384] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 52.340564] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 52.345848] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 62.538253] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 62.545106] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 62.556731] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 62.561914] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 62.568654] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 62.574176] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 62.579952] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 62.585113] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 62.590423] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 72.777823] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 72.784337] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 72.791220] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 72.796440] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 72.803128] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 72.808683] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 72.814474] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 72.819641] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 72.824936] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 83.018212] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 83.024989] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 83.032062] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 83.037352] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 83.044067] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 83.049665] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 83.055479] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 83.060701] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 83.066022] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 93.258261] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 93.265081] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 93.273459] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 93.278744] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 93.285560] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 93.291105] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 93.296907] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 93.302128] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 93.307420] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 103.498123] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 103.504961] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 103.513169] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 103.518430] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 103.525204] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 103.530744] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 103.536539] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 103.541756] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 103.547041] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 113.738161] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 113.745033] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 113.752003] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 113.757178] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 113.763895] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 113.769437] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 113.775225] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 113.780399] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 113.785681] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 123.978252] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 123.985070] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 123.992043] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 123.997224] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 124.003936] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 124.009474] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 124.015264] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 124.020438] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 124.025728] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 124.032727] tegradc 15210000.nvdisplay: hdmi: edid read failed
[ 134.217912] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 134.217925] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 134.217940] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 134.217951] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 134.217961] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 134.217973] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 134.217983] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 134.217993] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 134.218038] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 144.457910] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 144.457923] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 144.457935] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 144.457947] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 144.457957] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 144.457968] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 144.457978] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 144.457988] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 144.458033] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 154.697946] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 154.697959] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 154.697974] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 154.697986] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 154.697996] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 154.698007] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 154.698017] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 154.698027] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 154.698072] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
jetson-desktop login: jetson
Password:
Welcome to Ubuntu 18.04.3 LTS (GNU/Linux 4.9.140-tegra aarch64)
As you can see the Jetson boot up and log us to Ubuntu.
We test Ethernet and it work, same as USB for recovery mode. Other peripherals has still to be configured, we didn’t change the Device Tree yet
After some time, while we didn’t do hardware modification, the jetson stop the boot process ad it autoshotdown
Here’s the log:
0000.275] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-7d3edb9d)
[0000.283] I> bit @ 0xd480000
[0000.286] I> Boot-device: eMMC
[0000.294] I> sdmmc bdev is already initialized
[0000.298] I> pmic: reset reason (nverc) : 0x40
[0000.330] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.349] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.355] W> No valid slot number is found in scratch register
[0000.361] W> Return default slot: _a
[0000.364] I> A/B: bin_type (16) slot 0
[0000.368] I> Loading partition bpmp-fw at 0xd7800000
[0000.372] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.378] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.403] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.408] W> No valid slot number is found in scratch register
[0000.414] W> Return default slot: _a
[0000.417] I> A/B: bin_type (17) slot 0
[0000.421] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.426] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.432] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.455] I> Binary(17) of size 465840 is loaded @ 0xd798e200
[0000.633] I> Loading SCE-FW ...
[0000.636] W> No valid slot number is found in scratch register
[0000.642] W> Return default slot: _a
[0000.645] I> A/B: bin_type (12) slot 0
[0000.649] I> Loading partition sce-fw at 0xd7300000
[0000.654] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.659] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.679] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.684] I> Init SCE
[0000.687] I> Loading APE-FW ...
[0000.690] W> No valid slot number is found in scratch register
[0000.695] W> Return default slot: _a
[0000.699] I> A/B: bin_type (11) slot 0
[0000.702] I> Loading partition adsp-fw at 0xd7400000
[0000.707] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.713] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.732] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.738] I> Copy BTCM section
[0000.741] W> No valid slot number is found in scratch register
[0000.746] W> Return default slot: _a
[0000.750] I> A/B: bin_type (13) slot 0
[0000.753] I> Loading partition cpu-bootloader at 0x96000000
[0000.759] I> Reading two headers - addr:0x96000000 blocks:1
[0000.764] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.785] I> Binary(13) of size 283728 is loaded @ 0x96000000
[0000.791] W> No valid slot number is found in scratch register
[0000.797] W> Return default slot: _a
[0000.800] I> A/B: bin_type (20) slot 0
[0000.804] I> Loading partition bootloader-dtb at 0x8520f400
[0000.809] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.815] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.836] I> Binary(20) of size 371232 is loaded @ 0x8520f400
[0000.842] W> No valid slot number is found in scratch register
[0000.848] W> Return default slot: _a
[0000.851] I> A/B: bin_type (14) slot 0
[0000.855] I> Loading partition secure-os at 0x8530f600
[0000.860] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.865] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.886] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.894] I> TOS boot-params @ 0x85000000
[0000.898] I> TOS params prepared
[0000.901] I> Loading EKS ...
[0000.904] I> A/B: bin_type (15) slot 0
[0000.907] I> Loading partition eks at 0x8590f800
[0000.912] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.917] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.936] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.942] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.947] I> Copied encrypted keys
[0000.950] I> boot profiler @ 0x275844000
[0000.954] I> boot profiler for TOS @ 0x275844000
[0000.959] I> Unhalting SCE
[0000.962] I> Primary Memory Start:80000000 Size:70000000
[0000.967] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.974] I> MB2(TBoot-BPMP) done
NOTICE: BL31: Built : 22:43:09, Dec 9 2019
[0001.334] I> Welcome to Cboot
[0001.337] I> Cboot Version: t186-c3c778fb
[0001.341] I> CPU-BL Params @ 0x275800000
[0001.344] I> 0) Base:0x00000000 Size:0x00000000
[0001.349] I> 1) Base:0x277f00000 Size:0x00100000
[0001.353] I> 2) Base:0x277e00000 Size:0x00100000
[0001.358] I> 3) Base:0x277d00000 Size:0x00100000
[0001.362] I> 4) Base:0x277c00000 Size:0x00100000
[0001.367] I> 5) Base:0x277b00000 Size:0x00100000
[0001.371] I> 6) Base:0x277800000 Size:0x00200000
[0001.376] I> 7) Base:0x277400000 Size:0x00400000
[0001.380] I> 8) Base:0x277a00000 Size:0x00100000
[0001.385] I> 9) Base:0x277300000 Size:0x00100000
[0001.389] I> 10) Base:0x276800000 Size:0x00800000
[0001.394] I> 11) Base:0x30000000 Size:0x00040000
[0001.398] I> 12) Base:0xf0000000 Size:0x00100000
[0001.403] I> 13) Base:0x30040000 Size:0x00001000
[0001.407] I> 14) Base:0x30048000 Size:0x00001000
[0001.412] I> 15) Base:0x30049000 Size:0x00001000
[0001.416] I> 16) Base:0x3004a000 Size:0x00001000
[0001.421] I> 17) Base:0x3004b000 Size:0x00001000
[0001.425] I> 18) Base:0x3004c000 Size:0x00001000
[0001.429] I> 19) Base:0x3004d000 Size:0x00001000
[0001.434] I> 20) Base:0x3004e000 Size:0x00001000
[0001.438] I> 21) Base:0x3004f000 Size:0x00001000
[0001.443] I> 22) Base:0x00000000 Size:0x00000000
[0001.447] I> 23) Base:0xf0100000 Size:0x00010000
[0001.452] I> 24) Base:0x00000000 Size:0x00000000
[0001.456] I> 25) Base:0x00000000 Size:0x00000000
[0001.460] I> 26) Base:0x00000000 Size:0x00000000
[0001.465] I> 27) Base:0x00000000 Size:0x00000000
[0001.469] I> 28) Base:0x84400000 Size:0x00400000
[0001.474] I> 29) Base:0x30000000 Size:0x00010000
[0001.478] I> 30) Base:0x278000000 Size:0x08000000
[0001.483] I> 31) Base:0x00000000 Size:0x00000000
[0001.487] I> 32) Base:0x276000000 Size:0x00600000
[0001.492] I> 33) Base:0x80000000 Size:0x70000000
[0001.496] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.501] I> 35) Base:0x00000000 Size:0x00000000
[0001.505] I> 36) Base:0x00000000 Size:0x00000000
[0001.509] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.514] I> 38) Base:0x84000000 Size:0x00400000
[0001.518] I> 39) Base:0x96000000 Size:0x02000000
[0001.523] I> 40) Base:0x85000000 Size:0x01200000
[0001.527] I> 41) Base:0x275800000 Size:0x00500000
[0001.532] I> 42) Base:0x00000000 Size:0x00000000
[0001.536] I> 43) Base:0x00000000 Size:0x00000000
[0001.541] GIC-SPI Target CPU: 4
[0001.544] Interrupts Init done
[0001.547] calling constructors
[0001.550] initializing heap
[0001.553] initializing threads
[0001.556] initializing timers
[0001.559] creating bootstrap completion thread
[0001.564] top of bootstrap2()
[0001.567] CPU: ARM Cortex A57
[0001.570] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.575] initializing platform
[0001.579] I> Bl_dtb @0x8520f400
[0001.582] I> gpio framework initialized
[0001.588] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.598] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.606] I> GPIO framework and drivers are initialized.
[0001.611] I> Boot-device: eMMC
[0001.618] I> sdmmc bdev is already initialized
[0001.648] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0001.666] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.671] W> opt-in fuse is not set, skip fuse_burning
[0001.676] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.682] W> No valid slot number is found in scratch register
[0001.688] W> Return default slot: _a
[0001.691] I> A/B: bin_type (21) slot 0
[0001.695] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.712] I> Kernel_dtb @0x80000000
[0001.715] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.723] E> I2C: slave not found in slaves.
[0001.728] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.735] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.741] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.750] E> tca9539_device_init: failed to write polar reg
[0001.756] E> tegrabl_tca9539_init: failed to init device!
[0001.761] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.768] E> I2C: slave not found in slaves.
[0001.772] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.780] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.786] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.795] E> tca9539_device_init: failed to write polar reg
[0001.800] E> tegrabl_tca9539_init: failed to init device!
[0001.808] I> fixed regulator driver initialized
[0001.841] I> register 'maxim' power off handle
[0001.847] I> virtual i2c enabled
[0001.850] I> registered 'maxim,max77620' pmic
[0001.855] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.868] I> Find /i2c@c250000's alias i2c7
[0001.872] I> Reading eeprom i2c=7 address=0x50
[0001.901] I> Device at /i2c@c250000:0x50
[0001.905] I> Reading eeprom i2c=7 address=0x57
[0001.934] I> Device at /i2c@c250000:0x57
[0001.938] I> Find /i2c@c240000's alias i2c1
[0001.942] I> Reading eeprom i2c=1 address=0x51
[0001.947] E> I2C: slave not found in slaves.
[0001.951] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.959] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.965] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.974] E> eeprom: Retry to read I2C slave device.
[0001.979] E> I2C: slave not found in slaves.
[0001.983] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.991] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.997] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0002.006] E> eeprom: Failed to read I2C slave device
[0002.011] I> Eeprom read failed 0x3526070d
[0002.016] I> Find /i2c@3160000's alias i2c0
[0002.020] I> Reading eeprom i2c=0 address=0x50
[0002.024] E> I2C: slave not found in slaves.
[0002.028] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.036] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.042] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0002.051] E> eeprom: Failed to read I2C slave device
[0002.056] I> Eeprom read failed 0x3526070d
[0002.061] I> Find /i2c@3180000's alias i2c2
[0002.065] I> Reading eeprom i2c=2 address=0x54
[0002.069] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.074] C> GPIO driver for chip_id 0x2 could not be found
[0002.079] E> cam_eeprom_read: Can't get gpio driver
[0002.084] I> Eeprom read failed 0x4d4d000d
[0002.088] I> Reading eeprom i2c=2 address=0x57
[0002.092] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.097] C> GPIO driver for chip_id 0x2 could not be found
[0002.102] E> cam_eeprom_read: Can't get gpio driver
[0002.107] I> Eeprom read failed 0x4d4d000d
[0002.111] I> create_pm_ids: id: 3310-1000-D00-K, len: 15
[0002.116] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.127] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0002.132] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0002.167] I> enabling 'vdd-hdmi' regulator
[0002.171] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.180] E> cannot find any other nvdisp nodes
[0002.184] E> no valid display unit config found in dtb
[0002.190] W> display init failed
[0002.193] initializing target
[0002.196] calling apps_init()
[0002.199] starting app kernel_boot_app
[0002.222] I> found decompressor handler: lz4-legacy
[0002.226] I> decompressing BMP blob ...
[0002.236] I> Kernel type = Normal
[0002.239] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.253] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.260] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.267] I> ########## Fixed storage boot ##########
[0002.272] I> Loading kernel from partition ...
[0002.276] W> No valid slot number is found in scratch register
[0002.282] W> Return default slot: _a
[0002.286] I> A/B: bin_type (24) slot 0
[0002.301] I> Boot image size read from image header: f2f08
[0002.306] I> Boot image load address: 0x0x80400000
[0002.311] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.253] I> Validate kernel ...
[0003.257] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.264] I> kernel-dtb is already loaded
[0003.268] I> Validate kernel-dtb ...
[0003.271] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.279] I> Checking boot.img header magic ... [0003.283] I> [OK]
[0003.285] I> Kernel hdr @0x80400000
[0003.288] I> Kernel dtb @0x80000000
[0003.292] I> decompressor handler not found
[0003.296] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80800000... [0003.303] I> Done
[0003.305] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0003.312] I> Updated bpmp info to DTB
[0003.318] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0003.322] I> Updated initrd info to DTB
[0003.326] W> WARN: Fail to override "console=none" in commandline
[0003.332] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.339] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.346] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.354] I> disabled_core_mask: 0xffffff0c
[0003.358] W> No valid slot number is found in scratch register
[0003.363] W> Return default slot: _a
[0003.367] I> Active slot suffix:
[0003.370] I> add_boot_slot_suffix: slot_suffix =
[0003.374] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.411] I> Updated bootarg info to DTB
[0003.415] I> eeprom_get_mac_addr: MAC (type: 0): 48:b0:2d:0e:fd:6d
[0003.421] I> eeprom_get_mac_addr: MAC (type: 1): 48:b0:2d:0e:fd:6e
[0003.427] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:0e:fd:6f
[0003.433] E> Found no plugin manager ids in source DT
[0003.438] W> Add plugin manager ids from board info
[0003.443] E> "plugin-manager" doesn't exist, creating
[0003.448] E> "ids" doesn't exist, creating
[0003.452] E> "connection" doesn't exist, creating
[0003.456] E> "configs" doesn't exist, creating
[0003.461] I> create_pm_ids: id: 3310-1000-D00-K, len: 15
[0003.466] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0003.477] I> create_pm_ids: id: XXXX-XXXX-XXX-X, len: 15
[0003.482] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, len: 93
[0003.493] I> Adding plugin-manager/ids/3310-1000-D00=/i2c@c250000:module@0x50
[0003.500] E> "i2c@c250000" doesn't exist, creating
[0003.505] E> "module@0x50" doesn't exist, creating
[0003.510] I> Adding plugin-manager/ids/XXXX-XXXX-XXX=/i2c@c250000:module@0x57
[0003.517] E> "module@0x57" doesn't exist, creating
[0003.524] I> Adding plugin-manager/ids/3310-1000-D00-K
[0003.531] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.536] I> Adding plugin-manager/configs/3310-power-config 00
[0003.542] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.548] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.554] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.560] I> Adding plugin-manager/configs/3310-display-config 00
[0003.566] I> Adding plugin-manager/cvm
[0003.570] E> "chip-id" doesn't exist, creating
[0003.575] I> Adding plugin-manager/chip-id/A02P
[0003.579] E> "odm-data" doesn't exist, creating
[0003.584] I> Adding /chosen/plugin-manager/odm-data
[0003.593] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.599] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.605] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.611] I> added [base:0x276600000, size:0x200000] to /memory
[0003.617] I> added [base:0x277000000, size:0x200000] to /memory
[0003.622] I> Updated memory info to DTB
[0003.627] E> add_disp_param: failed to get display params for du=0
[0003.635] E> "reset" doesn't exist, creating
[0003.639] E> "pmc-reset-reason" doesn't exist, creating
[0003.645] E> "pmic-reset-reason" doesn't exist, creating
[0003.651] I> Adding ecid(00000001646dd5c41c0000000e048140) to DT
[0003.657] I> disabled_core_mask: 0xffffff0c
[0003.670] I> Add serial number:1422220011124 as DT property
[0003.678] I> Plugin-manager override starting
[0003.684] I> node /plugin-manager/fragement@0 matches
[0003.694] I> node /plugin-manager/fragement@4 matches
[0003.707] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.727] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.736] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.745] I> node /plugin-manager/fragment-devslp@0 matches
[0003.757] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.772] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.795] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.809] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.819] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.832] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.871] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.897] I> Disable plugin-manager status in FDT
[0003.902] I> Plugin-manager override finished successfully
[0003.907] I> tegrabl_load_kernel_and_dtb: Done
[0003.911] E> tegrabl_display_clear: display is not initialized
[0003.917] W> Boot logo display failed...
[0003.921] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:43:10 -0800)
TEGRA186
DRAM: 7.8 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
733 bytes read in 132 ms (4.9 KiB/s)
1: primary kernel
5565140 bytes read in 205 ms (25.9 MiB/s)
34191368 bytes read in 852 ms (38.3 MiB/s)
Starting kernel ...
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-1935) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Mon Dec 9 22:52:02 PST 2019
[ 0.518056] pca953x 0-0074: failed reading register
[ 0.518799] pca953x 0-0077: failed reading register
[ 1.082138] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 1.147938] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 1.364235] FAN: coudln't get the regulator
[ 11.338094] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 11.344468] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 11.351090] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 11.356144] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 11.362755] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 11.368239] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 11.373985] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 11.379122] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 11.384378] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.578126] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 21.584543] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 21.591188] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 21.596271] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 21.602904] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 21.608419] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 21.614192] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 21.619354] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 21.624634] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 21.645679] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 21.652866] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 21.939293] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.960190] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 21.975781] tegra-xusb-padctl 3520000.xusb_padctl: failed to setup XUSB ports: -517
[ 22.344621] cgroup: cgroup2: unknown option "nsdelegate"
At [ 22.344621] the Jetson shutdown and the serial link is interrupted
The same thing happen while we put the TX2 in recovery mode.
boot as recovery mode
SDK Manager reveals the TX2 as adevice
After approx 20 second the jetson goes to reset.
Do you have any clue on how to debug this?
Thank you
