Boot up issues with custom carrier
We just got our custom carrier back from the PCB manufacturer. When we try to turn on the TX2 it turns on for about three seconds and then turns itself and the carrier board off. In the brief moments it is on, we checked that the power related signals such as ‘CARRIER_PWR_ON’, ‘RESET_OUT_L’, ‘CARRIER_PWR_GOOD’, etc. behaved as excepted according to the documentation. But it turns itself off shortly after. The appears to be no response on the serial port or the HDMI either. Maybe it’s not even getting to UBoot? How can we debug this?
Just kidding it’s now not powering off. It’s powers up and stays up but it’s not booting. We are sure the SoC has the OS on it already as it boots up correctly when we move it back to the OEM carrier.
Hi, randyzhg,
Please see the chapter 12.7 of OEM DG to check your board if any difference on the PU/PD setting of strapping pins. That could cause the boot fail.
Hi Trumany,
Correct me if I’m wrong but all the 4.7k pull-ups/pull-downs are all internal on the TX2 module right? We did have a FTDI chip on UART0 and UART1, but now we’ve cut all the traces to it. Unfortunately, it still does not boot up. What else could be wrong?
Yes, pu/pd are in module, that’s why ask you to check the custom board. So all strapping pins are checked ok, right? If so, I’m afraid that you might need to compare your design to the dev kit to find out the difference which might cause such issue.
We got it working. Our hardware engineering found that his FPGA was holding a pin during boot up. Thanks for your help!
hi all,
I am using jetson TX2 module with carrier board J120 and the host ubuntu version 16.04 LTS
I observed boot logs on the serial console through UART0
I came across with boot issue after booting the board I am unable to find the shell and at the end of the boot logs it was showing
[ 9.608915] CPU1: shutdown
[ 9.611838] psci: CPU1 killed.
[ 9.644778] CPU2: shutdown
[ 9.647488] psci: CPU2 killed.
I flashed the board using eMMC
steps I followed to flash the board
  1. sudo tar xpf $<L4T_RELEASE_PACKAGE>
  2. cd Linux_for_Tegra/rootfs/
    3 sudo tar xpf …/…/$Tegra_Linux_Sample-Root-Filesystem_R28.2_aarch64.tbz2
    4 cd …
    5 sudo ./apply_binaries.sh
    6 Hold the recovery button and pressed reset button
    7 sudo ./flash.sh jetson-tx2 mmcblk0p1
I am adding full boot logs here
v1.4.0
Enter ‘mcu --help’ for a list of available commands
.692] starting app android_boot_app
[0001.696] I> Gpio keyboard init success
[0003.220] I> Kernel type = Normal
[0003.22eturn default slot: _a
[0003.237] I> A/B: bin_type (0) slot 0
[0003.241] I> Loading ot: _a
[0003.261] I> A/B: bin_type (1) slot 0
[0003.264] I> Loading partition kernel-dtb3.285] I> Valid boot.img @ 0xa8000000
[0003.3.300] I> Done
[0003.302] I> Move ramdisk (len: 0) from 0xa8071000 initrd info to DTB
[0003.323] I> disabled_rw rootwait console=ttyS0,115200n8 console=teserved=0x2772e0000 gpt tegraid=18.1.2.0.0 taccess=1
[0003.367] I> Updated bootarg info to DTB
[5:94:cb
[0003.385] I> eeprom_get_mac_addr: MA
[0003.399] E> “configs” doesn’t exist, creat,modem-config:00,touch-config:00,display-confsn’t exist, creag
[0003.431] E> “module@0x50” doesn’t exist, creating51] I> Adding plugin-manager/configs/3310-poweodem-config 00
[0003.468] I> Adding plugin-madoesn’t exist, creating
[0003.484] I> Adding plugin-manager/chip-id/A02sn’t exist, creating
[0003.506] E> “pmic-reset-reason” doesn’t exist, creating
[0003.511] I> disabled_core_mask: 0xffffff0c
[0003.523] I> Add serial number as DT property
[0003.528] I> tegrabl_load_ker7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
213 bytes read in 82 ms (2 KiB/s)
p2771-0000 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
20280368 bytes read in 534 ms (36.2 MiB/s)
rafb no_console_suspend=1 earlycon=uart8250,1818030931 bl_prof_dataptr=0x10000@0x2772400
Booting using the fdt blob at 0x9200000064f
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x10cgroup subsys cpuacct
[ 0.000000] Linux versi0] Boot CPU: AArch64 Processor [411fd073]
[ 0.000 Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method f.000000] psci: MIGRATE_INFO_TYPE not supported.
[ e order, mobility grouping on. Total pages: 2018net.ifnames=0 memtype=0 video=tegrafb no_console_s=6 androidboot.serialno=0421818030931 bl_)
[ 0.000000] Dentry c194304 bytes)
[ 0.000000] Memory: 7972328K/8204288K availablVirtual kernel memory layout:
[ 0.000000] 000000 ( 8 GB maximum)
[ 0.000000] ffbffac00000 ( 4108 KB)
[ 0.000000] PC000 ( 64 MB)
[ 0.000000] memory : 01164 KB)
[ 0.000000] .text : 0xffffffc0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObleaf fanout to 64.
[ 0.000000] RCU restricting CPUs _IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.080x25
[ 0.014533] console [tty0] enabled
[ 0.018087] bootconsole [uart0] disabled
[ 0.000000] Booting Linux on physical CPU ing cgroup subsys cpuacct
[ 0.000000] Lin 0.000000] Boot CPU: AArch64 Processor [411fd
[ 0.000000] Reserved memory: initialize psci: probing for conduit method from DT.
[sci: MIGRATE_INFO_TYPE not supported.
) rder, mobility grouping on. Total pages: 200 net.ifnames=0 memtype=0 video=tegrafb no_c maxcpus=6 androidboot.serialno=04218180309300000)
[ 0.000000] vmemmap : 0xffffffbdc05 MB actual)
[ 0.000000] fixed : 0 16 MB)
[ 0.000000] modules : 0xfff MB)
[ 0.000000] .init : 0xffffffc
[ 0.000000] .data : 0xffffffc001210] Preemptible hierarchical RCU implementati_ids=6.
[ 0.000000] RCU: Adjusting geome mode
[ 0.000000] Architected cp15 timerax_idle_ns: 881590405314 ns
[ 0.000002] s 0.014533] console [tty0] enabled
[ 0 delay loop (skipped), value calculated usinamework initialized
[ 0.022280] Mount-ca072 bytes)
[ 0.022638] Initializing cgrou 0.022802] CPU2 ipc=1024
[ 0.022810] CPes
[ 0.046364] tegra-id: chipid=21817.
.047024] DTS File Name: /dvs/git/dirty/git-ml-p3310-1000-c03-00-base.dts
[ 0.047043] condary processor [4e0f0030]
[ 0.085853]ooted secondary processor [411fd073]
[ 0.[ 0.110362] devtmpfs: initialized
[ 0e_ns: 7645041785100000 ns
[ 0.137913] pineters
[ 0.138383] Initializing plugin-ma
[ 0.139178] node /plugin-manager/fragemdt
[ 0.140943] node /plugin-manager/fragmtch with board >=3310-1000-300
[ 0.14156ment-devslp@0 match with board >=3310-1000-20nager/fragment-500-xusb-config match with bo] node /plugin-manager/fragment-p3310-c000
[ 0.143760] node /plugin-manager/fragm000-B00
[ 0.145955] node /plugin-manager/163] NET: Registered protocol family 16
[ moops: attached 0x200000@0x96080000, ecc: 0/0andshake
[ 0.167014] bpmp: handshake comok
[ 0.167410] vdso: 2 pages (1 code @ ff.168367] atomic_pool_init():526: DMA: preallirty/git-master_linux/kernel/kernel-4.4/arch 0.169877] DTn
[ 0.174027] arm-smmu 120.iommu: stream matching with 128 register (0x1000000)!
[ 0.174084] arm-smmu 120000074109] arm-smmu 12000000.iommu: Stage-2: 39 3460000.sdhci to group 0
[ 0.228989] iommu: Adding device 3160000.i2c to group 3
[ 107] iommu: Adding device 3190000.i2c to grou 0.235244] iommu: Adding device c250000.i2cup 11
[ 0.237882] iommu: Adding device c2serial to group 14
[ 0.239260] iommu: Adding device 3130000.serial to group 17
[ 0.242112] iommu: Adding device c1a0000.aonpped MMIO address: 0xffffff8000560000 → 0x2f8000660000 → 0x2c30000
for irq=19933] mc:[ 0.243999] mc-err: Set intmask: 0xf3140
[ 0.245071] Wake78 for irq=192 for irq=199
ctrl driver initializedeset status reg: 0x0eg offset dts data not present
[ 0.246979] tegra
[ 0.247507] iommu: Adding device 13e100013e10000.host1x:ctx1 to group 26
[ 0.2482
[ 0.248676] iommu: Adding device 13e1000vice 13e10000.host1x:ctx6 to group 31
[ 0.250236] iommu: Adding device 15700000splay to group 36
[ 0.251171] iommu: Addg device 15480000.nvdec to group 39
[ 0.22343] iommu: Adding device 15100000.tsecb to 44
[ 0.253430] iommu: Adding device 1583p10b to group 47
[ 0.255477] tegra-resetstatus is 0
[ 0.257911] bpmp d000000.bpmpice 2600000.dma to group 49
[ 0.261521] O line 457 (cam1-rst) hogged as output/low
[ 0.261932] GPIO line 445 (sdmmc-wake-inpgistered GPIOs 320 to 511 on device: tegra-gon device: tegra-gpio-aon
[ 0.265115] iommmu: Adding device 3510000.hda to group 52
.279302] vdd-ac-bat: 5000 mV
[ 0.281536]r gpio=59(FF:3)
[ 0.300663] SCSI subsystdriver hub
[ 0.301266] usbcore: registerefailed reading register
[ 0.304730] pca951] pca953x 0-0077: failed reading register
3] Linux video capture interface: v2.00
[ Giometti giometti@linux.it
[ 0.321852]tegra_wdt_t18x 30c0000.watchdog: Registered s hogged as input
[ 0.326367] GPIO line 2
[ 0.330267] vddio-ddr: at 1125 mV
[ do0: at 1800 mV
[ 0.343952] spmic-ldo1: tc: at 800 mV
[ 0.350901] avdd-ts-hv: 1-pex: 1000 mV
[ 0.358688] max77620 4-00300 mV
vdd-sys-bl: 3300 mV b0-5v: 5000 mV
[ 0.362742] gpio t] clocksource: Switched to clocksource arch_se_ops() set roc flush ops to replace cache oool size: 251183 pages (981 MB)
[ 0.3847599
[ 0.389342] Wake78 for irq=199
[ 0=199
[ 0.390097] thermal thermal_zone0: al_zone1 for type MCPU-therm
[ 0.390412]ring thermal zone thermal_zone3 for type PLL-ermal_zone5: Registering thermal zone thermaa
[ 0.391301] thermal thermal_zone7: Regisomgr_init(): max_iso_bw=26870400KB
[ 0. 0.392246] TCP bind hash table entries: 65h table entries: 4096 (order: 5, 131072 bytes[ 0.393004] RPC: Registered named UNIX soe.
[ 0.393037] RPC: Registered tcp NFSv4.st1x: initialized
[ 0.407914] hw perfevebytes)
[ 0.409685] audit: initializing ned (default)
[ 0.424220] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.42831.tsecb: initialized
[ 0.438677] nvdec 15 0.446300] falcon 15380000.nvjpg: initiali.host1x:ctx1: initialized (streamid=57)
[ ctx3: initialized (streamid=59)
[ 0.4509itialized (streamid=61)
[ 0.452409] iommu (streamid=63)
[ 0.456744] DC OR NODE cosplay: Display dc.ffffff8002320000 registere.457314] misc tegra_camera_ctrl: tegra_camer00, vi_iso_bw=1500000, max0
[ 0gister_max_config: max config EMC floor = 6615210000.nvdisplay: vblank syncpt # 7 for dc_5v0: -517
[ 0.467094] tegra-adma 2930000ault range
SP2 index4 DOWNPD DISP0 index2 U 0.470319] kfuse 3830000.kfuse: initialized
[ 0.471866] PD DISP1 ind70] Serial: 8250/16550 driver, 4 ports, IRQ s000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) ia
[ 2.523823] consol6023] Console: switching to colour frame buffer device 80x30
[ 00.serial: RX in PIO mode
[ 2.527766] 3130000.serial: ttyTHS3 at MMIO 0x3130033] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.556853] nct1008_nct72 7-004c: success parsing dt
[ 2.557054] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.634865] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 2.661179] tmp451: Enabled overheat logging at 104.00C
[ 2.667612] gpio teT: found 3 subdevs
[ 2.688018] THERMAL EST num_resources: 0
[ 2.693015] [THERMone8: Registering thermal zone thermal_zone8 for type thermal-fan tegra_profiler: Branch: Dev
[ 2.733681] tegra_profiler: Version: 1.109
: 0x41, idcode: 0x1
[ 2.755774] armv8_pmu: [0] arch: AA6A64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.776455] 8] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.794374] armv8_8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, v ver: 0
[ 2.827814] tegra_profiler: auth: init
[ 2.835806] tegra-ahci 3507000.ahci-satsntf pm led pmp pio slum part deso sadm apst
[ 2.858663] scsi host0: 0x100 irq 25
[ 2.876877] ata2: DUMMY
[ 2.881076] spi-tegra114 3210000tegra114 3240000.spi: Static pin configuration used
[ 2.9039456] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
  • version 5.3.0-k
    [ 2.937893] igb: Copyright (c) 2007-2014 I4 4b a5 94 cc
    [ 2.948789] libphy: dwc_phy: probed
    [ 2.961mpression module registered
    [ 2.978536] NET: Registererface driver asix
    [ 2.995984] usbcore: registered new ered new interface driver smsc95xx
    [ 3.013801] gpio tgistered new interface driver net1080
    [ 3.033857] usb usbcore: registered new interface driver cdc_ncm
    [ 3.059
    [ 3.067418] Wake80 for irq=199
    [ 3.070919] Wake81 foore: registered new interface driver usb-storage
    [io
    [ 3.103320] usbserial: USB Serial support registerial support registered for GSM modem (1-port)
    [ 3.137746] tegra-usb-cd usb_cd: otg phy is not available yet
    [ 3.146034] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
    [ 3.196802] ata1: SATA link down (SStatus 0 SControl 300)
    [ 3.285331] max77686-rtc max77620-rtc: rtc core: registered max77620tc: Tegra internal Real Time Clock
    [ 3.311566] i2c /dev entries driver
    [ max77620-power max77620-power: Event recorder REG_NVERC : 0x0
    [ 3.338726] FAN: coudln’t 10-28) initialised: dm-devel@redhat.com
    [ 3.361728] sdhci: Securplatform and OF driver helper
    [ 3.381515] sdhci-tegra 3460000.sdhci:idraw: raw HID events driver (C) Jiri Kosina
    [ 3.384640] usbcore:knowledge from address 0x42
    [ 3.387460] ina3221x 0-0042: ina32260000.i2c: no acknowledge from address 0x43
    [ 3.3885[ 3.389071] nvadsp 2993000.adsp: in probe()…
    [ 3.390488] nvadsp 2993000.adsp: nvadsp_app_module_probe
    [ 3.coresight-tmc 8050000.etr: TMC initialized
    [ 3.395[ 3.396380] coresight-funnel 8010000.funnel_major:or 8040000.replicator: REPLICATOR initialized
    [ 3.39804342] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
    [ gra186-cam-rtcpu b000000.rtcpu: Trace buffer configured u: region 0: iova=0xa0110000-0xa011957f size=38272
    [ 3.410-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=01 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
    [ 3.410665] tegra-ivc ivc-b000000.rtcpu:ivccapture@72: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x80
    [ 3.410942] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCP-b000000.rtcpu:echo@0: ivc channel driver missing
    [ 3.411949vc channel driver missing
    [ 3.411957] tegra-ivc ivc-b000000.rtcpu:ing
    [ 3.411964] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channetcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cegra-ivc-cK
    [ 3.422038] register_ari_mca_banks: Registered MCprobed OK
    [ 3.422489] tegra18-bridge 23a0000.axi2apb: brbridge probed OK
    [ 3.422584] tegra18-bridge 23d0000.axiip2p: bridge probed OK
    [ 3.422699] tegra18-bridge 2140000.axip2p: bridge probed OK
    [ 3.422790] tegra18-bridge 2170000.axip2p: bridge probed OK
    [ 3.422899] tegra18_a57_serr_init: on CPU 1 a Denver Core
    [arse_throttle_dt_data: clk=bcpu type=2
    [ 3.423e_probe: probe successful. #cdevs=4
    [ 3.423802ed for the device mc_all
    [ 3.424637] hw perfeve
    [ 3.427660] tegra-se-nvhost 15810000.se: tegra_e_probe: complete
    [ 3.428968] tegra-se-nvhost 1580000.se: initialized
    [ 3.430019] tegra-se-nvhost 15] cpufreq: platform driver Initialization: pass
    [ : passed
    [ 3.439262] tegra186-padctl 3520000.pinctrl: pad0003540000 end 0x0000000003540fff
    [ 3.439306] teg0 0x8
    [ 3.440714] tegra186-padctl 3520000.pinctrl: usin Initializing cpuidle driver init for Denver cluster
    [ ver tegra-tachometer registered
    [ 3.446444] Tachometer ed
    [ 3.451561] tegra210-adsp adsp_audio: Default param-type to BYTEegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/cardio: Default param-c
    [ 3.457760]to BYTE for aec
    [ 3.458227] tegra210-adsp adsp_audio: adma cha0_adsp_audio_platform_probe probe successfull.
    [ 3.470570] OPget HP Det GPIO, should be handled by codec
    [ 3.569652] tegra–> ADMAIF2 mapping ok
    [ 3.569845] tegra-snd-t186ref-mobile-rt56[ 3.570025] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 ↔ Ad-t186ref-mobile-rt565x sound: k
    [ 3.und: ADMAIF9 ↔ ADMAIF9 mapping ok
    [ 3.570457] tegra-snd-t186ref-m1 mapping ok
    [ 3.570657] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 ↔ ADMAIFt186ref-mobile-rt565x sound: ADMAIF14 ↔ ADMAIF14 mapping ok
    [ 3.570nd: ADMAIF16 ↔ ADMAIF16 mapping ok
    [ 3.571121] tegra-snd-t186ref-mobmapping ok
    [ 3.571297] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 ↔ ADMAIF1186ref-mobile-rt565x sound: ADSP-FE1 ↔ ADSP PCM1 mapping ok
    [ ADSP COMPR1 mapping ok
    [ 3.574760] compress asoc: ADSP-FE4 <-ut2
    [ 3.609394] tegra-snd-t186ref-mobile-rt565x sound: codeobability NOT on
    [ 3.609859] Mirror/redirect action on
    [ 3.609)
    [ 3.610566] ipip: IPv4 over IPv4 tunneling driver
    [ 3.62006 Netfilter Core Team
    [ 3.611883] NET: Registered protocol s been deprecated. Update your scripts to load br_netfi
    [ 3.627103] Registered setend emulation handler
    [ 3ialized
    [ 3.637319] Wake76 for irq=199
    [ 3.637320] Wake77 fo3] Wake81 for irq=199
    [ 3.637323] Wake82 for irq=1figuration used
    [ 3.638503] spi-tegra114 c260000.s for irq=199
    [ 3.639619] Wake77 for irq=199
    [ 3.639
    [ 3.639622] Wake82 for irq=199
    [ 3.639647] tegra-xudc-new 3550000.xudc: usb2 phy is not availabl7] tegra186-padctl 3520000.pinctrl: ao mmio start 0640355] tegra186-padct9
    [ 3.643405] Wake78 for irq=e82 for irq=199
    [ 3.643582] xhci-tegra 3530000.xh wake67 for gpio=57(FF:1)
    [ 3.644460] gpio tegra-girq=199
    [ 3.644881] Wake77 for irq=199
    [ 3.644881] Wake644884] Wake82 for irq=199
    [ 3.644907] tegra-xotdc-new 3550000.xudc: usb2 phy is not available yet
    [ 86-padctl 3520000.pinctrl: ao mmio start 0x0000000tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 ] Wake77 for irq=199
    [ 3.648576] Wake78 for irq=199
    [ irq=199
    [ 3.648749] xhci-tegra 3530000.xhci: can’t ge22400] bpmp: mounted debugfs mirror
    [ 3.723461] [dram-t] vddio-sdmmc1: disabling
    [ 3.727820] avdd-ts-hv: disabli7997] vdd-3v3: disabling
    [ 3.727999] en-vdd-vcm-2v8 irq 400
    [ 3.734952] #1: tegra-snd-t186ref-mob
    [ 3.736678] Wake76 for irq=199
    [ 3.736679] Wake77 fo1] Wake81 for irq=199
    [ 3.736682] Wake82 for irle yet
    [ 3.737275] tegra-xudc-new 3550000.xudc:00003520fff
    [ 3.737429] tegra186-padctl 3520000.pLIB_0 0x2cac96
    [ 3.737467] tegra186-padctl 3520000.e76 for irq=199
    [ 3.740352] Wake77 for irq=199
    [ 3.799
    [ 3.740355] Wake82 for irq=199
    [ 3.740529] xhc249804
    [ 5.104943] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
    [ 5.148816] mmc0: SDHCI controller on 3460000.sdhci Parent select= pll_p rate=408000000
    [ 5.170459] Wake77 for iWake81 for irq=199
    [ 5.188870] Wake82 for irq=199
    [[ 5.205006] sdhci-tegra 3440000.sdhci: Client registdctl 3520000.pinctrl: padctl mmio start 0x0000000003540fff
    [ 5.205594] tegra186-padctl 3520000.pinctrl: FUSdctl 3520000.pinctrl: using UTMI port 0 for otg
    [ 5.20863[ 5.208638] Wake80 for irq=199
    [ 5.208639] Wake81 f2] mmc0: MAN_BKOPS_EN bit is not set
    [ 5.226204] mmcard at address 0001
    [ 5.233849] mmcblk0: mmc0:0001 G34 partition 2 4.00 MiB
    [ 5.234188] mmcblk0rpmb: mmc0:6784] Wake76 for irq=199
    [ 5.236785] Wake77 for irq=191 for irq=199
    [ 5.236789] Wake82 for irq=199
    [ 5.237409] tegra-xudc-new 3550000.xudc: usb2 phy i
    [ 5.237564] tegra186-padctl 3520000.pinctrl: 2cac96
    [ 5.237604] tegra186-padctl 3520000.pinctrl:irq=199
    [ 5.240584] Wake77 for irq=199
    [ 5.240585] Wake740587] Wake82 for irq=199
    [ 5.240765] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
    [ 5.500852] mmc1: SDHCI controller on 3440000.sdhci: Got CD GPIO
    [ 5.511186] sdhci-tegra 3400000.sdhci.sdhci: wakeup init done, cd_irq: 256
    [ 5.51152es)
    [ 5.552822] gpio tegra-gpio wake71 for gpio=125(P:5e77 for irq=199
    [ 5.573091] Wake78 for irq=199
    [ 5.199
    [ 5.590742] tegra-xotg xotg: usb2 phy is not avaiy is not available yet
    [ 5.610627] tegra186-padctl 3mmio start 0x0000000003540000 end 0x0000000003540rl: FUSE_USB_CALIB_EXT_0 0x8
    [ 5.649209] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
    [ 5.662312] Wake76 040] Wake80 for irq=199
    or irq=199427] Wake81 for irq=199
    [ 5.696795] Wake77 for irq=199
    [ 5.199
    [ 5.713586] Wake82 for irq=199
    [ 5.717017] tegra-xotg xotg: usb2 phy is not available yet
    [ 5ffffffff
    [ 5.744592] mmc1: tuning_window[1]: 0mmc1: tuning_window[4]: 0x0
    [ 5.762644] mmc1d
    [ 5.767820] EXT4-fs (mmcblk0p1): recovery co root (ext4 filesystem) on device 179:1.
    [ 5.77396reeing alternatives memory: 96K (ffffffc0011f0000 - ffffdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
    [ 0001
    [ 5.851590] systemd[1]: System time before build time, advancing clock.
    [ 5.874355] random: systemd: uninitialized urandom read (1s of entropy available)
    [ 5.897326] systemd[1]: systemd 22Z4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
    [ 5.918059] systemd[1]: Detected architecture arm64.
    [ 5.930740] systemd[1]: Set hostname to .
    [ 5.947372] random: systemd: uninitim read (16 bytes read, 102 bits of entropy available)
    [ 5.972140] random: systemd: uninitialized urandom read (16 bytes r of entropy available)
    [ 5.990825] random: systemd-gpt-aut: uninitialiead (16 bytes read, 103 bits of entropy available)
    [ 5.990907] rangpt-aut: uninitialized urandom read (16 bytes read, 103 bits of entropy available)
    [ 6.115943] systemd[1]: Reached target Remote File Systems (Pre).
    [ 6.124525] systemd[1]: Listening on LVM2 metadata daemon socket.
    [ 6.147954] systemd[1]: Reached slice system-getty.slice.
    [ 6.171156] systemd[1]: Listening on udev Kernel Socket.
    [ 6.g on Journal Socket.
    [ 6.201839] systemd[1]: Starting Load Kernel Modules…
    [ 6.208945] ggra-xudc-new 3550000.xudc: usb2 phy is not available yet
    [ 6.230l 3520000.pinctrl: ao mmio start 0x0000000003540000 end l 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
    [ 6.260309] systemd[1]: Rstemd[1]: Started Forward Password Requests to Wall Directory Watch.=199
    [ 6.294100] Wake78 for irq=199
    [ 6.294101] Wake79 for irq=19tegra 3530000.xhci: can’t get usb3-0 phy (-517)
    [ 6.29463[ 6.294633] Wake80 for irq=199
    [ 6.294634] Wake81 for irq=199
    [ ng Create list of required static device nodes for the current kernel…VM2 mirrors, snapshots etc. using dmeventd or progress polling…
    [ 6.397926]
    [ 6.417132] systemd[1]: Listening on Journal Socket (/dev/log).
    [ 6.427283] s3] systemd[1]: Listening on Syslog Socket.
    [ 6.449865] systemd[1]: Starting Journal Seret.
    [ 6.472589] systemd[1]: Starting Remount Root and Kernel File Systems…
    [ 6.483044] systemdate list of required static device nodes for the current kernel.
    [ 6.509604] systemd[1]: Started Remount Root and Kernel File Systems.
    [ 6.517800] systemd[1]: Started Journal Service.
    [ 6.599747] random: nonblocking pool is initialized
    [ 6.626544] systemd-journald[282]: Received request to flush runtime journal from PID 1
    [ 6.778916] tegra-pcie 10003000.pcie-controller: 4x1, 1xoller: PCIE: Enable power rails
    [ 6.788015] tegra-pcie 1001 lanes
    [ 6.819538] tegra-xudc-new 3550000.xudc: usb2 phy is not available] tegra186-padctl 3520000.pinctrl: ao mmio start 0x000000 tegra186-padctl8
    [ 6.872967] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
    [ 6.8844
    [ 6.898954] Wake80 for irq=199
    [ 6.902514] Wake81 for irq=76 for irq=199
    [ 6.920774] Wake77 for irq=199
    [ 6=199
    [ 6.938093] Wake82 for irq=199
    [ 6.941624] tegra-xotg xotg: usb2 phy is not available yet
    [ 6.989382] cfg80211: World regulatory domain updated:
    [ 7.003261] dhd_module_init in
    [ 7.006885] cfg802- end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_ti(N/A, 2000 mBm), (N/A)
    [ 7.045287] gpio tegra-gpio-aon wake69 for gpio=59(:platform country code map is not available
    [ 7.051254] cfg80211: KHz), (N/A, 2000 mBm), (N/A)
    [ 7.051259] cfg80211: (5170000 KHz000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
    [ 7.051263] cfg80210000 KHz), (N/A, 2000 mBm), (N/A)
    [ 7.051268] cfg80211: (57240000ifi_platform_set_power = 1
    [ 7.252797] wifi_platform_bus_enumerate device present 1
    [ 7.260803] tegra-usb-cd usb_cd86-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520fff
    [ 7.268716] tegra186-padctl 3520000.pinctrl: FUSE_SKU_US0000.pinctrl: using UTMI port 0 for otg
    [ 7.273332] Wake76 for irq=199
    [ irq=199
    [ 7.273336] Wake81 for irq=199
    [ 7.273336] Wake73921] Wake77 for irq=199
    [ 7.273921] Wake78 for irq=199 for irq=199
    [ 7.273951] tegra-xotg xotg: usb2 ph is not available yet
    [ 7.277521] F1 signature readtl 3520000.pinctrl: padctl mmio start 0x0000000003540fff
    for irq=19927] tegra186-padctl 3520000.pinctr186-padctl 3520000.pinctrl: using UTMI port 0 for otg
    [ 7.281333] Wake80 for irq=199
    [ 7.pkg:0x2
    [ 7.281534] xhci-tegra 3530000.xhci: can’t get usb3-0 phy Wake79 for irq=199
    yet 7.281849] Wake80 for irq=199
    [ 7.281906] DHD: dongle ram size is set to 7_platform_get_mac_addr
    [ 7.308821] tegra-pcie 1000407] wl_create_event_handler(): thread:wl_event_handh(): thread:dhd_watchdog_thread:1da started
    [ 7.3erred_work_init: work queue initialized
    [ 7.333
    [ 7.334241] tegra_sysfs_register
    [ 7.334265] Reto do
    [ 7.334348] sdhci-tegra 3440000.sdhci: Tuning altg phy is not available yet
    [ 7.541679] tegra-xudc-n0000 end 0x0000000003520fff
    [ 7.541943] tegra186-padcE_SKU_USB_CALIB_0 0x2cac96
    [ 7.541984] tegra186-padct45901] Wake76 for irq=199
    [ 7.545902] Wake77 for irq=199
    [r irq=199
    [ 7.545905] Wake82 for irq=199
    [ 7.546135] x7.549228] Wake78 for irq=199
    [ 7.549229] Wake79 for irqgra-xotg xotg: usb2 phy is not available yet
    [ 7.710792] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
    [ 8.122764] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
    [ host bridge to bus 0000:00
    [ 8.149140] pci_bus 0000:00: ]
    [ 8.149148] pci_bus 0000:00: root bus resource [bus 00- class 0x060400
    [ 8.149269] pci 0000:00:01.0: PME# supported frconfiguration invalid ([bus 00-00]), reconfiguring
    [ 003fff 64bit]
    [ 8.150070] iommu: Adding device 0000:01:AR 8: assigned [mem 0x50100000-0x501fffff]
    [ 8.15696
    [ 8.156982] pci 0000:00:01.0: bridge window [mem1.0: Signaling PME through PCIe PME interrupt
    [ r pcie_pme loaded
    [ 8.157236] aer 0000:00:01.0:pcie020000.xudc: usb2 phy is not available yet
    [ 8.158310] tegr.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
    [ 8.159250] tegra186.164656] Wake78 for irq=199
    [ 8.000 → 0002)
    [ 8.167782] Wake76 for irq=199
    [ 8.16778[ 8.167786] Wake81 for irq=199
    [ 8.167786] Wakot available yet
    [ 8.168615] tegra-xudc-new 3550d 0x0000000003520fff
    [ 8.168872] tegra186-padctl KU_USB_CALIB_0 0x2cac96
    [ 8.168912] tegra186-pad.174132] Wake76 for irq=199
    [ 8.174134] Wake77 for irqke81 for irq=199
    [ 8.174137] Wake82 for irq=199
    [ irq=199
    [ 8.175443] Wake78 for irq=199
    [ 8.17544[ 8.175505] tegra-xotg xotg: usb2 phy is not available yet
    [ 8.785547] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not readyhd on Jul 20 2017 at 00:47:12
    [ 8.809432] wl_android_wifi_on in
    [ 8.813583] wifi_platform_set_power = 1
    [ 8.918119] gk20a 17000000.gp10b: railgate is disabled.
    [ 9.097767] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
    [ 9.171154] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the bx4354 rev:0x1 pkg:0x2
    [ 9.197006] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
    [ 9.294200] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
    [ 9.363680] dhd_bus_init: enable 0x06, readypio=59(FF:3)
    [ 9.380607] Enabling wake69
    [ 9.394191] wifi_platform_get_mac_addr
    [ 9.399841] Firmware up: op_mode=0x0005, MAC=00:04:4b:a5:94:ca
    [ 9.412285] dhd_preinit_.21 (r697384) FWID 01-58d9d0b3
    [ 9.437050] dhd_interworking_enable: failed to set WNM info, ret=-23
    [ 9.443770] tegra_sysfs_on
    [ 9.525918] IPv6: ADDRCONF(NETDEV_UP): ethink is not ready
    [ 9.737518] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
    [ 9.755894] WLC_E_IF: NO_IF set, event Ignored
    [ 9.874538] device-mapper: table: 253:0: thin-pool: unknown target type
    [ 9.885379] device-mapper: ioctl: error adding target to table
Ubuntu 16.04 LTS tegra-ubuntu ttyS0
tegra-ubuntu login: nvidia (automatic login)
Last login: Fri May 6 05:40:16 UTC 2016 on ttyS0
Welcome to Ubuntu 16.04 LTS (GNU/Linux 4.4.3s.
To run a command as administrator (user “root”), use “sudo ”.
See “man sudo_root” for details.
nvidia@tegra-ubuntu:~$ [ 10.606536] fuse init (API version 7.23)
     (instead of shell it is showing arrow marks)
I am supplying 12v and 5amps input supply to the j120 carrier board
Thank you
hi all,
    4 cd …
v1.4.0
[5:94:cb
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
1: primary kernel
Starting kernel …
[ 0.080x25
[ 0.022810] CPes
[ 0.246979] tegra
[ 0.2482
[ do0: at 1800 mV
[ 0.3847599
[ 0=199
: 0x41, idcode: 0x1
  • version 5.3.0-k
    [ 3.059
    [io
    [ : passed
    [ 3.609)
    [ 3ialized
    [ 3.639
    [ irq=199
    [ 3.799
    [ 5.51152es)
    [ 5.199
    [ 5.199
    [ 5ffffffff
    [ 5.762644] mmc1d
    [ 0001
    [ 6.397926]
    [ 6.8844
    [ 6=199
    [ irq=199
    [ 7.pkg:0x2
    [ 7.333
    [ 7.334265] Reto do
    [r irq=199
    [ 003fff 64bit]
    [ 8.15696
    [ r pcie_pme loaded
    [ 8.000 → 0002)
    [ irq=199
Thank you
FYI, CPU1 and 2 are the Denver cores. These, by default, are not enabled (you could run “sudo nvpmodel -m 0” and those cores would become available). I only mention this because this is where you mention “I flashed the board using eMMC”, and I’m not sure if you are considering CPU1 and 2 shutdown as errors. This is in fact the part which is normal.
The problem with the “>” in prompt though is an issue. However, there are a lot of possibilities about what could be going on. The first thing which catches my attention is the note:
To run a command as administrator (user "root"), use "sudo <command>".
A normal boot does not show this. It is possible that permissions on your “sudo” binary are incorrect and this is causing a non-standard start. This happens (in the most common case) if the file system the flash was run from was not a native Linux type, e.g., VFAT or NTFS are not capable of preserving Linux file system permissions. From where you did your flash you might check with:
df -H -T <b>.</b>
(the " ." is important, this means “the current directory”)
Was this flashed from ext4?
