[code]
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc versi
on 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@969ee000
[ 0.000000] Found lut_mem2: 00002008@969eb000
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id
nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d300
80 u69632
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag
es: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS
0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb
no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x27
72e0000 gpt tegra_fbmem2=0x800000@0x969ee000 lut_mem2=0x2008@0x969eb000 tegraid=
18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues
=0.2.1 androidboot.serialno=0324817094137 bl_prof_dataptr=0x10000@0x277040000 sd
hci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 byte
s)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7967772K/8208384K available (11296K kernel code, 1841K rw
data, 5796K rodata, 1168K init, 691K bss, 175076K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 G
B)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 G
B maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 M
B actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 K
B)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 M
B)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 M
B)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 M
B)
[ 0.000000] .init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 K
B)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 K
B)
[ 0.000000] .data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 K
B)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:
0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 43980
46511088ns
[ 0.009813] Console: colour dummy device 80x25
[ 0.014472] console [tty0] enabled
[ 0.018030] bootconsole [uart0] disabled
nvidia,ramoops
80 u69632
es: 2019936
s)
B)
B maximum)
B actual)
B)
B)
B)
B)
B)
B)
B)
46511088ns
[ 0.022133] kmemleak: Kernel memory leak detector disabled
[ 0.022146] Calibrating delay loop (skipped), value calculated using timer fr
equency… 62.50 BogoMIPS (lpj=125000)
[ 0.022158] pid_max: default: 32768 minimum: 301
[ 0.022206] Security Framework initialized
[ 0.022243] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022254] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 byte
s)
[ 0.022636] Initializing cgroup subsys io
[ 0.022649] Initializing cgroup subsys memory
[ 0.022666] Initializing cgroup subsys devices
[ 0.022675] Initializing cgroup subsys freezer
[ 0.022683] Initializing cgroup subsys net_cls
[ 0.022693] Initializing cgroup subsys perf_event
[ 0.022702] Initializing cgroup subsys net_prio
[ 0.022712] Initializing cgroup subsys pids
[ 0.022721] Initializing cgroup subsys debug
[ 0.022859] CPU0 ipc=752
[ 0.022868] CPU1 ipc=1024
[ 0.022876] CPU2 ipc=1024
[ 0.022885] CPU3 ipc=752
[ 0.022894] CPU4 ipc=752
[ 0.022904] CPU5 ipc=752
[ 0.022940] ASID allocator initialised with 65536 entries
[ 0.046053] tegra-id: chipid=21817.
[ 0.046070] tegra-id: opt_subrevision=1.
[ 0.046083] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046748] DTS File Name: arch/arm64/boot/dts//…/…/…/…/…/…/hardware/nv
idia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046770] DTB Build time: Nov 22 2018 19:42:33
[ 0.062534] CPU1: Booted secondary processor [4e0f0030]
[ 0.074083] CPU2: Booted secondary processor [4e0f0030]
[ 0.085776] CPU3: Booted secondary processor [411fd073]
[ 0.097785] CPU4: Booted secondary processor [411fd073]
[ 0.109773] CPU5: Booted secondary processor [411fd073]
[ 0.109836] Brought up 6 CPUs
[ 0.109891] SMP: Total of 6 processors activated.
[ 0.109903] CPU: All CPU(s) started at EL2
[ 0.110327] devtmpfs: initialized
[ 0.137430] Initilizing CustomIPI irq domain
[ 0.137622] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 7645041785100000 ns
[ 0.138372] pinctrl core: initialized pinctrl subsystem
[ 0.138549] OS set in device tree is not L4T.
[ 0.138736] regulator-dummy: no parameters
[ 0.138842] Initializing plugin-manager
[ 0.138895] Plugin module not found
[ 0.139299] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02
P
[ 0.139631] node /plugin-manager/fragement@0 match with odm-data enable-denve
r-wdt
[ 0.140231] node /plugin-manager/fragement@4 match with odm-data enable-denve
r-wdt
[ 0.141397] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with bo
ard >=3310-1000-300
[ 0.141749] node /plugin-manager/fragement-pmon-p3310-1000-300 match with boa
rd >=3310-1000-300
[ 0.142001] node /plugin-manager/fragement-pmon-p3310-1000-800 match with boa
rd >=3310-1000-800
[ 0.142220] node /plugin-manager/fragment-devslp@0 match with board >=3310-10
00-200
[ 0.142638] node /plugin-manager/fragment-500-pcie-config match with board >=
3310-1000-500
[ 0.143072] node /plugin-manager/fragment-500-xusb-config match with board >=
3310-1000-500
[ 0.143346] node /plugin-manager/fragment-500-e3325-pcie match with board >=3
310-1000-500
[ 0.143723] node /plugin-manager/fragment-p3310-c00-comm match with board >=3
310-1000-800
[ 0.143966] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3
310-1000-800
[ 0.144186] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1
000-900
[ 0.144440] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1
000-B00
[ 0.145993] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.147075] node /plugin-manager/fragment-p3310-c00-camera match with board >
=3310-1000-800
[ 0.148824] Adding domain adsp-pd to PM domain ape-pd
[ 0.151130] NET: Registered protocol family 16
[ 0.151988] console [pstore-1] enabled
[ 0.151999] pstore: Registered ramoops as persistent store backend
[ 0.152012] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161323] cpuidle: using governor ladder
[ 0.165776] cpuidle: using governor menu
[ 0.166925] bpmp: waiting for handshake
[ 0.166940] bpmp: handshake completed
[ 0.166980] bpmp: synchronizing channels
[ 0.167008] bpmp: channels synchronized
[ 0.167019] bpmp: mail init ok
[ 0.167378] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c0
00)
[ 0.167410] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168338] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomi
c allocations
[ 0.169780] tegra_powergate_init: DONE
[ 0.169802] DTS File Name: arch/arm64/boot/dts//…/…/…/…/…/…/hardware/nv
[ 0.169823] DTB Build time: Nov 22 2018 19:42:33
[ 0.170741] Tegra reboot handler registered.
[ 0.171781] Registering Tegra186 clocks (this may take a while)…done
[ 0.173889] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173907] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173921] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173932] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173944] arm-smmu 12000000.iommu: nested translation
[ 0.173958] arm-smmu 12000000.iommu: stream matching with 128 registe
r groups, mask 0x7f80
[ 0.173976] arm-smmu 12000000.iommu: SMMU address space size (0x800000) diffe
rs from mapped region size (0x1000000)!
[ 0.173994] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only
[ 0.174008] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174021] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.222083] arm-smmu 12000000.iommu: registered 66 master devices
[ 0.227842] iommu: Adding device 3460000.sdhci to group 0
[ 0.228748] iommu: Adding device 3400000.sdhci to group 1
[ 0.232311] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232801] iommu: Adding device 3160000.i2c to group 3
[ 0.233217] iommu: Adding device c240000.i2c to group 4
[ 0.233555] iommu: Adding device 3180000.i2c to group 5
[ 0.233981] iommu: Adding device 3190000.i2c to group 6
[ 0.234449] iommu: Adding device 31b0000.i2c to group 7
[ 0.234857] iommu: Adding device 31c0000.i2c to group 8
[ 0.235165] iommu: Adding device c250000.i2c to group 9
[ 0.235496] iommu: Adding device 31e0000.i2c to group 10
[ 0.237479] iommu: Adding device 3210000.spi to group 11
[ 0.237831] iommu: Adding device c260000.spi to group 12
[ 0.238207] iommu: Adding device 3240000.spi to group 13
[ 0.239021] iommu: Adding device 3100000.serial to group 14
[ 0.239345] iommu: Adding device 3110000.serial to group 15
[ 0.239644] iommu: Adding device c280000.serial to group 16
[ 0.239980] iommu: Adding device 3130000.serial to group 17
[ 0.241241] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241858] iommu: Adding device b000000.rtcpu to group 19
[ 0.242343] iommu: Adding device c1a0000.aon to group 20
[ 0.243256] Wake73 for irq=42
[ 0.243561] iommu: Adding device smmu_test to group 21
[ 0.244079] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.244120] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.244157] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.244206] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.244268] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.244307] mc-err: Set intmask: 0xf3140
[ 0.244522] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.245379] Wake76 for irq=199
[ 0.245403] Wake77 for irq=199
[ 0.245423] Wake78 for irq=199
[ 0.245443] Wake79 for irq=199
[ 0.245462] Wake80 for irq=199
[ 0.245481] Wake81 for irq=199
[ 0.245528] Wake82 for irq=199
[ 0.245641] iommu: Adding device 3530000.xhci to group 22
[ 0.245986] iommu: Adding device 3550000.xudc to group 23
[ 0.246794] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246825] tegra-pmc: ### PMC reset source: Power on reset
[ 0.246848] tegra-pmc: ### PMC reset level: L0
[ 0.246869] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.247157] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registere
d
[ 0.247195] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.247353] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.247382] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.247902] iommu: Adding device 13e10000.host1x to group 24
[ 0.248185] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.248434] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.248685] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.248922] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.249136] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.249382] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.249593] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.249864] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.250264] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.250827] iommu: Adding device 15700000.vi to group 34
[ 0.251147] iommu: Adding device 15600000.isp to group 35
[ 0.251482] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.251708] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ee000(8
00000)
[ 0.251751] platform 15210000.nvdisplay: IOVA linear map 0x00000000969eb000(3
000)
[ 0.251961] iommu: Adding device 15340000.vic to group 37
[ 0.252155] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252369] iommu: Adding device 15480000.nvdec to group 39
[ 0.252686] iommu: Adding device 15380000.nvjpg to group 40
[ 0.252907] iommu: Adding device 15500000.tsec to group 41
[ 0.253136] iommu: Adding device 15100000.tsecb to group 42
[ 0.253818] iommu: Adding device 15810000.se to group 43
[ 0.254058] iommu: Adding device 15820000.se to group 44
[ 0.254256] iommu: Adding device 15830000.se to group 45
[ 0.254437] iommu: Adding device 15840000.se to group 46
[ 0.255008] iommu: Adding device 17000000.gp10b to group 47
[ 0.256412] tegra-reset 5000000.clock: registered 193 resets.
[ 0.258495] iommu: Adding device d000000.bpmp to group 48
[ 0.258773] bpmp: ping status is 0
[ 0.258960] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff8
1e
[ 0.259357] bpmp d000000.bpmp: probe ok
[ 0.262472] iommu: Adding device 2600000.dma to group 49
[ 0.263456] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.263542] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.263602] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263657] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.263716] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.263772] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.263849] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.263996] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-g
pio
[ 0.265807] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.265925] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-g
pio-aon
[ 0.266943] iommu: Adding device sound to group 50
[ 0.268629] iommu: Adding device 3510000.hda to group 51
[ 0.269781] iommu: Adding device adsp_audio to group 52
[ 0.271260] iommu: Adding device 2993000.adsp to group 53
[ 0.280292] vdd-ac-bat: 5000 mV
[ 0.282394] vdd-1v8-ap: 1800 mV
[ 0.300614] SCSI subsystem initialized
[ 0.300994] usbcore: registered new interface driver usbfs
[ 0.301059] usbcore: registered new interface driver hub
[ 0.301179] usbcore: registered new device driver usb
[ 0.305055] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305514] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305628] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.307042] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307152] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.318235] media: Linux media interface: v0.10
[ 0.318310] Linux video capture interface: v2.00
[ 0.321311] pps_core: LinuxPPS API ver. 1 registered
[ 0.321348] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti giometti@linux.it
[ 0.321454] PTP clock support registered
[ 0.322317] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.322394] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.323920] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.326026] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.326242] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.326378] gpiochip_add_data: registered GPIOs 216 to 223 on device: max7762
0-gpio
[ 0.334711] vddio-ddr: at 1125 mV
[ 0.338549] avdd_dsi_csi: 1200 mV
[ 0.342563] vdd-1v8: 1800 mV
[ 0.346545] vdd-3v3-sys: 3300 mV
[ 0.347628] spmic-ldo0: at 1800 mV
[ 0.348451] spmic-ldo1: at 800 mV
[ 0.354542] vddio-3v3: 3300 mV
[ 0.355149] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.357321] vdd-rtc: at 800 mV
[ 0.358001] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.361318] spmic-ldo6: at 1500 mV
[ 0.365320] vdd-pex-1v05: 1000 mV
[ 0.365863] dvdd-pex: 1000 mV
[ 0.366121] max77620 4-003c: max77620 probe successful
[ 0.366373] Advanced Linux Sound Architecture Driver Initialized.
[ 0.367333] en-vdd-sd: 3300 mV
[ 0.367940] en-vdd-cam: 1800 mV
[ 0.369780] vdd-hdmi: 5000 mV
[ 0.369959] vdd-usb0-5v: 5000 mV
[ 0.370131] vdd-usb1-5v: 5000 mV
[ 0.373779] en-vdd-ts-1v8: 1800 mV
[ 0.377778] en-vdd-ts-hv-3v3: 3300 mV
[ 0.378312] en-vdd-disp-3v3: 3300 mV
[ 0.378823] en-mdm-pwr-3v7: 3700 mV
[ 0.379335] en-vdd-disp-1v8: 1800 mV
[ 0.379860] en-vdd-cam-hv-2v8: 2800 mV
[ 0.380390] en-vdd-cam-1v2: 1200 mV
[ 0.380911] vdd-fan: 5000 mV
[ 0.381030] vdd-3v3: 3300 mV
[ 0.381761] dis-vdd-1v2: 1200 mV
[ 0.381882] en-vdd-vcm-2v8: 2800 mV
[ 0.382409] vdd-usb2-5v: 5000 mV
[ 0.382517] vdd-sys-bl: 3300 mV
[ 0.383050] en-vdd-sys: 1200 mV
[ 0.386358] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.386755] clocksource: Switched to clocksource arch_sys_counter
[ 0.405028] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.405310] nvmap: nvmap_override_cache_ops() set roc flush ops to replace ca
che ops by set/ways
[ 0.405784] nvmap_page_pool_init: Total RAM pages: 2008327
[ 0.405802] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB)
[ 0.405951] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.410523] Wake76 for irq=199
[ 0.410536] Wake77 for irq=199
[ 0.410547] Wake78 for irq=199
[ 0.410557] Wake79 for irq=199
[ 0.410566] Wake80 for irq=199
[ 0.410575] Wake81 for irq=199
[ 0.410585] Wake82 for irq=199
[ 0.411333] thermal thermal_zone0: Registering thermal zone thermal_zone0 for
type BCPU-therm
[ 0.411529] thermal thermal_zone1: Registering thermal zone thermal_zone1 for
type MCPU-therm
[ 0.411643] thermal thermal_zone2: Registering thermal zone thermal_zone2 for
type GPU-therm
[ 0.411718] thermal thermal_zone3: Registering thermal zone thermal_zone3 for
type PLL-therm
[ 0.412099] thermal thermal_zone4: Registering thermal zone thermal_zone4 for
type AO-therm
[ 0.412240] thermal thermal_zone5: Registering thermal zone thermal_zone5 for
type Tboard_tegra
[ 0.412382] thermal thermal_zone6: Registering thermal zone thermal_zone6 for
type Tdiode_tegra
[ 0.412526] thermal thermal_zone7: Registering thermal zone thermal_zone7 for
type PMIC-Die
[ 0.412816] isomgr_init(): iso emc max clk=1866000KHz
[ 0.412829] isomgr_init(): max_iso_bw=26870400KB
[ 0.412912] NET: Registered protocol family 2
[ 0.413211] TCP established hash table entries: 65536 (order: 7, 524288 bytes
[ 0.413437] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.413742] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.413804] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.413862] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.414032] NET: Registered protocol family 1
[ 0.414250] RPC: Registered named UNIX socket transport module.
[ 0.414265] RPC: Registered udp transport module.
[ 0.414276] RPC: Registered tcp transport module.
[ 0.414288] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.414406] Trying to unpack rootfs image as initramfs…
[ 0.428170] host1x 13e10000.host1x: initialized
[ 0.429008] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av
ailable
[ 0.430661] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.430826] audit: initializing netlink subsys (disabled)
[ 0.430859] audit: type=2000 audit(0.420:1): initialized
[ 0.437380] io scheduler noop registered
[ 0.437489] io scheduler cfq registered (default)
[ 0.440417] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.441605] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.442673] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.443733] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.447135] tsec 15500000.tsec: initialized
[ 0.448239] tsec 15100000.tsecb: initialized
[ 0.450514] nvdec 15480000.nvdec: initialized
[ 0.454038] falcon 15340000.vic: initialized
[ 0.455036] falcon 154c0000.nvenc: initialized
[ 0.456018] falcon 15380000.nvjpg: initialized
[ 0.456763] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.457258] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.457776] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.458278] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.458799] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.459303] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.459805] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.460306] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.462827] DC OR NODE connected to /host1x/sor1
[ 0.462952] generic_infoframe_type: 0x87
[ 0.462966] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:c
amera_platform_driver probe
[ 0.463053] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.463066] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso
= 3916800KBs
[ 0.463086] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4
687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.463096] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registere
d with id=0
[ 0.470464] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 1
6727000 KB/s
[ 0.470484] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor
= 665600000 Hz
[ 0.470500] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 3
57620000 Hz
[ 0.470543] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.470558] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.470701] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.471450] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detec
ted mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.472797] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initia
lized
[ 0.473352] kfuse 3830000.kfuse: initialized
[ 0.473640] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use de
fault range
[ 0.474859] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.475192] tegradc 15210000.nvdisplay: probed
[ 0.475321] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.477271] console [ttyS0] disabled
[ 0.477320] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25
500000) is a Tegra
[ 2.598020] console [ttyS0] enabled
[ 2.599937] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud =
0) is a TEGRA_UART
[ 2.601006] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud =
0) is a TEGRA_UART
[ 2.601210] serial-tegra 3130000.serial: RX in PIO mode
[ 2.602090] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud =
0) is a TEGRA_UART
[ 2.611763] Console: switching to colour frame buffer device 240x67
[ 2.612466] brd: module loaded
[ 2.616799] loop: module loaded
[ 2.617026] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.617030] nct1008_nct72 7-004c: starting parse dt
[ 2.617111] nct1008_nct72 7-004c: success parsing dt
[ 2.617228] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.629898] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.654024] tmp451: Enabled overheat logging at 104.00C
[ 2.654168] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.656581] THERMAL EST: found 3 subdevs
[ 2.656585] THERMAL EST num_resources: 0
[ 2.656588] [THERMAL EST subdev 0]
[ 2.656593] [THERMAL EST subdev 1]
[ 2.656596] [THERMAL EST subdev 2]
[ 2.656870] thermal thermal_zone8: Registering thermal zone thermal_zone8 for
type thermal-fan-est
[ 2.656872] THERMAL EST: thz register success.
[ 2.656993] THERMAL EST: end of probe, return err: 0
[ 2.657048] tegra_profiler: Branch: Dev
[ 2.657049] tegra_profiler: Version: 1.117
[ 2.657052] tegra_profiler: Samples version: 41
[ 2.657053] tegra_profiler: IO version: 22
[ 2.657060] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.657064] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.657097] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.657101] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2,
pmu ver: 0x1
[ 2.657104] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.657107] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2,
pmu ver: 0x1
[ 2.657110] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.657113] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.657116] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.657119] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.657122] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.657125] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0,
pmu ver: 0x1
[ 2.657301] tegra_profiler: auth: init
[ 2.660600] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 G
bps 0x1 impl platform mode
[ 2.660612] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pi
o slum part deso sadm apst
[ 2.661553] scsi host0: tegra_ahci
[ 2.661911] scsi host1: tegra_ahci
[ 2.662047] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x1
00 irq 25
[ 2.662050] ata2: DUMMY
[ 2.662969] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.663408] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.663805] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.664549] tun: Universal TUN/TAP device driver, 1.6
[ 2.664552] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.664717] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.664719] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.664754] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.664756] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.665697] PPP generic driver version 2.4.2
[ 2.665817] PPP BSD Compression module registered
[ 2.665824] PPP Deflate Compression module registered
[ 2.665848] PPP MPPE Compression module registered
[ 2.665861] NET: Registered protocol family 24
[ 2.665914] usbcore: registered new interface driver r8152
[ 2.665948] usbcore: registered new interface driver asix
[ 2.665979] usbcore: registered new interface driver ax88179_178a
[ 2.666004] usbcore: registered new interface driver cdc_ether
[ 2.666038] usbcore: registered new interface driver smsc75xx
[ 2.666066] usbcore: registered new interface driver net1080
[ 2.666092] usbcore: registered new interface driver cdc_subset
[ 2.666117] usbcore: registered new interface driver zaurus
[ 2.666160] usbcore: registered new interface driver cdc_ncm
[ 2.666387] Wake76 for irq=199
[ 2.666390] Wake77 for irq=199
[ 2.666392] Wake78 for irq=199
[ 2.666394] Wake79 for irq=199
[ 2.666395] Wake80 for irq=199
[ 2.666397] Wake81 for irq=199
[ 2.666399] Wake82 for irq=199
[ 2.666451] tegra-xotg xotg: usb2 phy is not available yet
[ 2.667049] usbcore: registered new interface driver cdc_acm
[ 2.667052] cdc_acm: USB Abstract Control Model driver for USB modems and ISD
N adapters
[ 2.667087] usbcore: registered new interface driver usb-storage
[ 2.667146] usbcore: registered new interface driver usbserial
[ 2.667173] usbcore: registered new interface driver cp210x
[ 2.667192] usbserial: USB Serial support registered for cp210x
[ 2.667213] usbcore: registered new interface driver ftdi_sio
[ 2.667231] usbserial: USB Serial support registered for FTDI USB Serial Devi
ce
[ 2.667252] usbcore: registered new interface driver option
[ 2.667269] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.667290] usbcore: registered new interface driver pl2303
[ 2.667306] usbserial: USB Serial support registered for pl2303
[ 2.667546] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.686585] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a7 ca fd
[ 2.687122] libphy: dwc_phy: probed
[ 2.687497] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.751930] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.816450] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as r
tc0
[ 2.818701] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.818725] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.818884] i2c /dev entries driver
[ 2.819662] [OV5693]: probing v4l2 sensor.
[ 2.978791] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.295430] tegradc 15210000.nvdisplay: fb registered
[ 3.302133] PD DISP0 index2 UP
[ 3.307349] PD DISP1 index3 UP
[ 3.311913] PD DISP2 index4 UP
[ 3.325509] Parent Clock set for DC plld2
[ 3.331958] edid invalid
[ 3.382719] edid invalid
[ 3.386602] edid invalid
[ 3.390454] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:
prod_c_150M
[ 3.546995] tegradc 15210000.nvdisplay: blank - normal
[ 3.549530] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.607830] PD DISP2 index4 DOWN
[ 3.608937] PD DISP1 index3 DOWN
[ 3.609588] PD DISP0 index2 DOWN
[ 3.640118] tegradc 15210000.nvdisplay: unblank
[ 3.640199] PD DISP0 index2 UP
[ 3.646526] PD DISP1 index3 UP
[ 3.647071] PD DISP2 index4 UP
[ 3.662266] Parent Clock set for DC plld2
[ 3.665217] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:
prod_c_150M
[ 3.678253] random: nonblocking pool is initialized
[ 3.692079] gspca_main: v2.14.0 registered
[ 3.692128] usbcore: registered new interface driver gspca_zc3xx
[ 3.692454] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.694432] FAN dev name: pwm-fan
[ 3.694481] FAN:gpio request success.
[ 3.694486] FAN: can’t find tach_gpio
[ 3.694508] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.694656] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.694660] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.694664] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.694977] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, st
ate:2
[ 3.694981] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2,
state:2
[ 3.694984] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1,
state:2
[ 3.694987] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1,
state:2
[ 3.694990] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1,
state:3
[ 3.694993] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1,
state:3
[ 3.694995] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1,
state:3
[ 3.694998] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1,
state:4
[ 3.695001] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1
, state:4
[ 3.695004] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1
, state:4
[ 3.695732] device-mapper: uevent: version 1.0.3
[ 3.695921] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-d
evel@redhat.com
[ 3.696298] sdhci: Secure Digital Host Controller Interface driver
[ 3.696299] sdhci: Copyright(c) Pierre Ossman
[ 3.696303] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.696632] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.696932] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249
804
[ 3.697176] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.698329] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.698456] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.700068] usbcore: registered new interface driver usbhid
[ 3.700069] usbhid: USB HID core driver
[ 3.704919] nvadsp 2993000.adsp: in probe()…
[ 3.719016] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.719042] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.719233] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.719947] Denver: backdoor interface is NOT available.
[ 3.721624] coresight-tmc 8030000.etf: TMC initialized
[ 3.722699] coresight-tmc 8050000.etr: TMC initialized
[ 3.723075] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.723553] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.723966] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.724364] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.724771] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.725358] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.725878] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.726399] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.726944] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.726969] Module initialized successfully
[ 3.730230] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA
=0xa0000000
[ 3.731521] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.731782] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f
size=38272
[ 3.732158] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0
x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.732200] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1
RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.732237] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]
=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.732274] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 gr
p=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.732313] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 gr
p=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.732349] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=
0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.732385] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=
0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.732538] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.732541] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is succ
essful
[ 3.733572] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.733574] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver mis
sing
[ 3.733577] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.733579] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver m
issing
[ 3.733581] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver m
issing
[ 3.733584] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.733586] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.733612] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4
sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.734782] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADM
A 64-bit with 64 bit addr
[ 3.735004] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.735479] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.738382] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-ech
o
[ 3.739159] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-d
bg
[ 3.739284] camchar: rtcpu character device driver loaded
[ 3.742944] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.743172] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.743260] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.743587] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.743613] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.743635] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.743658] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.743679] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.743703] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.743726] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.743748] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.743770] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.743793] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.743816] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.743839] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.743860] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.743883] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.743905] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.743953] **** A57 ECC: Enabled
[ 3.743955] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.744085] parse_throttle_dt_data: Num cap clks = 4
[ 3.744088] parse_throttle_dt_data: clk=mcpu type=1
[ 3.744090] parse_throttle_dt_data: clk=bcpu type=2
[ 3.744095] parse_throttle_dt_data: clk=gpu type=4
[ 3.744097] parse_throttle_dt_data: clk=emc type=3
[ 3.744546] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.744626] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.747070] tegra18x_actmon d230000.actmon: initialization Completed for the
device mc_all
[ 3.747355] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 cou
nters available
[ 3.749330] tegra-se-nvhost 15810000.se: initialized
[ 3.749767] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.750073] tegra-se-nvhost 15820000.se: initialized
[ 3.750473] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.750773] tegra-se-nvhost 15830000.se: initialized
[ 3.750
