Yup, not hotplugging. Thanks/
[code][ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-592) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu Mar 1 20:49:20 PST 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@969ec000
[ 0.000000] Found lut_mem2: 00002008@969e9000
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=174096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x969ec000 lut_mem2=0x2008@0x969e9000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0324617130254 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7967772K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 175076K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)
.text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)
.data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009792] Console: colour dummy device 80x25
[ 0.014452] console [tty0] enabled
[ 0.018010] bootconsole [uart0] disabled
[ 0.022114] kmemleak: Kernel memory leak detector disabled
[ 0.022126] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022139] pid_max: default: 32768 minimum: 301
[ 0.022187] Security Framework initialized
[ 0.022224] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022235] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022616] Initializing cgroup subsys io
[ 0.022629] Initializing cgroup subsys memory
[ 0.022646] Initializing cgroup subsys devices
[ 0.022656] Initializing cgroup subsys freezer
[ 0.022666] Initializing cgroup subsys net_cls
[ 0.022676] Initializing cgroup subsys perf_event
[ 0.022685] Initializing cgroup subsys net_prio
[ 0.022695] Initializing cgroup subsys pids
[ 0.022704] Initializing cgroup subsys debug
[ 0.022842] CPU0 ipc=752
[ 0.022852] CPU1 ipc=1024
[ 0.022860] CPU2 ipc=1024
[ 0.022868] CPU3 ipc=752
[ 0.022877] CPU4 ipc=752
[ 0.022887] CPU5 ipc=752
[ 0.022924] ASID allocator initialised with 65536 entries
[ 0.046052] tegra-id: chipid=21817.
[ 0.046070] tegra-id: opt_subrevision=1.
[ 0.046082] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046725] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046750] DTB Build time: Mar 1 2018 20:50:46
[ 0.062542] CPU1: Booted secondary processor [4e0f0030]
[ 0.074053] CPU2: Booted secondary processor [4e0f0030]
[ 0.085783] CPU3: Booted secondary processor [411fd073]
[ 0.097790] CPU4: Booted secondary processor [411fd073]
[ 0.109784] CPU5: Booted secondary processor [411fd073]
[ 0.109848] Brought up 6 CPUs
[ 0.109904] SMP: Total of 6 processors activated.
[ 0.109915] CPU: All CPU(s) started at EL2
[ 0.110337] devtmpfs: initialized
[ 0.137252] Initilizing CustomIPI irq domain
[ 0.137467] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138216] pinctrl core: initialized pinctrl subsystem
[ 0.138391] OS set in device tree is not L4T.
[ 0.138583] regulator-dummy: no parameters
[ 0.138686] Initializing plugin-manager
[ 0.138739] Plugin module not found
[ 0.139141] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139472] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140069] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141203] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141575] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141824] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142041] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142458] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142892] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143161] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143535] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143777] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.143995] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144251] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.145793] node /plugin-manager/fragment-e3326@0 match with board 3326-
[ 0.146847] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148598] Adding domain adsp-pd to PM domain ape-pd
[ 0.150868] NET: Registered protocol family 16
[ 0.151718] console [pstore-1] enabled
[ 0.151730] pstore: Registered ramoops as persistent store backend
[ 0.151743] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161322] cpuidle: using governor ladder
[ 0.165783] cpuidle: using governor menu
[ 0.166898] bpmp: waiting for handshake
[ 0.166913] bpmp: handshake completed
[ 0.166953] bpmp: synchronizing channels
[ 0.166982] bpmp: channels synchronized
[ 0.166992] bpmp: mail init ok
[ 0.167352] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167384] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168312] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169689] tegra_powergate_init: DONE
[ 0.169710] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169735] DTB Build time: Mar 1 2018 20:50:46
[ 0.170668] Tegra reboot handler registered.
[ 0.171698] Registering Tegra186 clocks (this may take a while)…done
[ 0.173749] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173767] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173795] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173808] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173819] arm-smmu 12000000.iommu: nested translation
[ 0.173833] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173852] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.173870] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.173884] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.173896] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.221827] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.227417] iommu: Adding device 3460000.sdhci to group 0
[ 0.228257] iommu: Adding device 3400000.sdhci to group 1
[ 0.231924] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232390] iommu: Adding device 3160000.i2c to group 3
[ 0.232796] iommu: Adding device c240000.i2c to group 4
[ 0.233136] iommu: Adding device 3180000.i2c to group 5
[ 0.233516] iommu: Adding device 3190000.i2c to group 6
[ 0.233990] iommu: Adding device 31b0000.i2c to group 7
[ 0.234328] iommu: Adding device 31c0000.i2c to group 8
[ 0.234684] iommu: Adding device c250000.i2c to group 9
[ 0.235040] iommu: Adding device 31e0000.i2c to group 10
[ 0.237104] iommu: Adding device 3210000.spi to group 11
[ 0.237450] iommu: Adding device c260000.spi to group 12
[ 0.237766] iommu: Adding device 3240000.spi to group 13
[ 0.238576] iommu: Adding device 3100000.serial to group 14
[ 0.238913] iommu: Adding device 3110000.serial to group 15
[ 0.239207] iommu: Adding device c280000.serial to group 16
[ 0.239528] iommu: Adding device 3130000.serial to group 17
[ 0.240757] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241366] iommu: Adding device b000000.rtcpu to group 19
[ 0.241834] iommu: Adding device c1a0000.aon to group 20
[ 0.242795] Wake73 for irq=42
[ 0.243178] iommu: Adding device smmu_test to group 21
[ 0.243689] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.243729] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.243787] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.243825] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.243860] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.243893] mc-err: Set intmask: 0xf3140
[ 0.244117] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.244973] Wake76 for irq=199
[ 0.244997] Wake77 for irq=199
[ 0.245017] Wake78 for irq=199
[ 0.245036] Wake79 for irq=199
[ 0.245056] Wake80 for irq=199
[ 0.245074] Wake81 for irq=199
[ 0.245118] Wake82 for irq=199
[ 0.245233] iommu: Adding device 3530000.xhci to group 22
[ 0.245578] iommu: Adding device 3550000.xudc to group 23
[ 0.246354] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246384] tegra-pmc: ### PMC reset source: Software reset
[ 0.246407] tegra-pmc: ### PMC reset level: L1
[ 0.246429] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.246721] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.246759] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.246939] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.246968] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.247427] iommu: Adding device 13e10000.host1x to group 24
[ 0.247686] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.247911] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.248168] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.248437] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.248671] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.248886] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.249147] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.249422] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.249839] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.250444] iommu: Adding device 15700000.vi to group 34
[ 0.250789] iommu: Adding device 15600000.isp to group 35
[ 0.251151] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.251351] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ec000(800000)
[ 0.251416] platform 15210000.nvdisplay: IOVA linear map 0x00000000969e9000(3000)
[ 0.251607] iommu: Adding device 15340000.vic to group 37
[ 0.251805] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252038] iommu: Adding device 15480000.nvdec to group 39
[ 0.252365] iommu: Adding device 15380000.nvjpg to group 40
[ 0.252593] iommu: Adding device 15500000.tsec to group 41
[ 0.252791] iommu: Adding device 15100000.tsecb to group 42
[ 0.253536] iommu: Adding device 15810000.se to group 43
[ 0.253742] iommu: Adding device 15820000.se to group 44
[ 0.253935] iommu: Adding device 15830000.se to group 45
[ 0.254153] iommu: Adding device 15840000.se to group 46
[ 0.254697] iommu: Adding device 17000000.gp10b to group 47
[ 0.256048] tegra-reset 5000000.clock: registered 193 resets.
[ 0.258092] iommu: Adding device d000000.bpmp to group 48
[ 0.258347] bpmp: ping status is 0
[ 0.258547] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.258919] bpmp d000000.bpmp: probe ok
[ 0.262141] iommu: Adding device 2600000.dma to group 49
[ 0.263002] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.263067] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.263125] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263179] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.263255] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.263311] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.263368] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.263479] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.265335] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.265457] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.266383] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.266705] iommu: Adding device sound to group 51
[ 0.268481] iommu: Adding device 3510000.hda to group 52
[ 0.269684] iommu: Adding device adsp_audio to group 53
[ 0.271148] iommu: Adding device 2993000.adsp to group 54
[ 0.280264] vdd-ac-bat: 5000 mV
[ 0.282402] vdd-1v8-ap: 1800 mV
[ 0.300629] SCSI subsystem initialized
[ 0.300814] libata version 3.00 loaded.
[ 0.300986] usbcore: registered new interface driver usbfs
[ 0.301050] usbcore: registered new interface driver hub
[ 0.301175] usbcore: registered new device driver usb
[ 0.305007] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305468] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305576] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.306995] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307102] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.317711] media: Linux media interface: v0.10
[ 0.317785] Linux video capture interface: v2.00
[ 0.320910] pps_core: LinuxPPS API ver. 1 registered
[ 0.320947] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.321003] PTP clock support registered
[ 0.321896] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.321954] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.323421] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.325547] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.325748] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.325878] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.330712] vddio-ddr: at 1125 mV
[ 0.334553] avdd_dsi_csi: 1200 mV
[ 0.338552] vdd-1v8: 1800 mV
[ 0.342552] vdd-3v3-sys: 3300 mV
[ 0.343637] spmic-ldo0: at 1800 mV
[ 0.344412] spmic-ldo1: at 800 mV
[ 0.350549] vddio-3v3: 3300 mV
[ 0.351221] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.354556] vdd-rtc: at 800 mV
[ 0.355318] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.357319] spmic-ldo6: at 1500 mV
[ 0.361317] vdd-pex-1v05: 1000 mV
[ 0.361856] dvdd-pex: 1000 mV
[ 0.362122] max77620 4-003c: max77620 probe successful
[ 0.362374] Advanced Linux Sound Architecture Driver Initialized.
[ 0.363391] en-vdd-sd: 3300 mV
[ 0.363945] en-vdd-cam: 1800 mV
[ 0.365321] vdd-hdmi: 5000 mV
[ 0.365508] vdd-usb0-5v: 5000 mV
[ 0.365678] vdd-usb1-5v: 5000 mV
[ 0.369316] en-vdd-ts-1v8: 1800 mV
[ 0.373316] en-vdd-ts-hv-3v3: 3300 mV
[ 0.373832] en-vdd-disp-3v3: 3300 mV
[ 0.374348] en-mdm-pwr-3v7: 3700 mV
[ 0.374881] en-vdd-disp-1v8: 1800 mV
[ 0.375396] en-vdd-cam-hv-2v8: 2800 mV
[ 0.375906] en-vdd-cam-1v2: 1200 mV
[ 0.376424] vdd-fan: 5000 mV
[ 0.376529] vdd-3v3: 3300 mV
[ 0.377257] dis-vdd-1v2: 1200 mV
[ 0.377379] en-vdd-vcm-2v8: 2800 mV
[ 0.377901] vdd-usb2-5v: 5000 mV
[ 0.378007] vdd-sys-bl: 3300 mV
[ 0.378517] en-vdd-sys: 1200 mV
[ 0.381809] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.382223] clocksource: Switched to clocksource arch_sys_counter
[ 0.400417] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.400676] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.401151] nvmap_page_pool_init: Total RAM pages: 2008327
[ 0.401168] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB)
[ 0.401359] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.405853] Wake76 for irq=199
[ 0.405866] Wake77 for irq=199
[ 0.405877] Wake78 for irq=199
[ 0.405888] Wake79 for irq=199
[ 0.405897] Wake80 for irq=199
[ 0.405907] Wake81 for irq=199
[ 0.405917] Wake82 for irq=199
[ 0.406678] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.406881] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.407264] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.407342] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.407490] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.407631] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.407776] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.408068] isomgr_init(): iso emc max clk=1866000KHz
[ 0.408080] isomgr_init(): max_iso_bw=26870400KB
[ 0.408165] NET: Registered protocol family 2
[ 0.408465] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.408694] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.408990] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.409047] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409102] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409266] NET: Registered protocol family 1
[ 0.409462] RPC: Registered named UNIX socket transport module.
[ 0.409478] RPC: Registered udp transport module.
[ 0.409489] RPC: Registered tcp transport module.
[ 0.409500] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.409521] PCI: CLS 0 bytes, default 128
[ 0.409613] Trying to unpack rootfs image as initramfs…
[ 0.423348] host1x 13e10000.host1x: initialized
[ 0.424169] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.425751] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.425844] audit: initializing netlink subsys (disabled)
[ 0.425874] audit: type=2000 audit(0.412:1): initialized
[ 0.432720] io scheduler noop registered
[ 0.432825] io scheduler cfq registered (default)
[ 0.435694] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.436845] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.437910] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.438972] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.442336] tsec 15500000.tsec: initialized
[ 0.443450] tsec 15100000.tsecb: initialized
[ 0.445707] nvdec 15480000.nvdec: initialized
[ 0.449237] falcon 15340000.vic: initialized
[ 0.450245] falcon 154c0000.nvenc: initialized
[ 0.451249] falcon 15380000.nvjpg: initialized
[ 0.451986] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.452480] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.452971] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.453465] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.453954] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.454462] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.454954] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.455450] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.457946] DC OR NODE connected to /host1x/sor1
[ 0.458060] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.458066] generic_infoframe_type: 0x87
[ 0.458157] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.458166] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.458170] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.458244] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.465493] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.465513] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.465529] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.465573] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.465588] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.465754] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.466464] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.468149] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.468495] kfuse 3830000.kfuse: initialized
[ 0.468634] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.470044] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.470054] tegradc 15210000.nvdisplay: probed
[ 0.470806] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.472785] console [ttyS0] disabled
[ 0.472837] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.600370] console [ttyS0] enabled
[ 2.602357] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.603435] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.603636] serial-tegra 3130000.serial: RX in PIO mode
[ 2.604534] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.614262] Console: switching to colour frame buffer device 240x67
[ 2.614533] brd: module loaded
[ 2.619062] loop: module loaded
[ 2.619283] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.619288] nct1008_nct72 7-004c: starting parse dt
[ 2.619370] nct1008_nct72 7-004c: success parsing dt
[ 2.619489] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.632524] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.656326] tmp451: Enabled overheat logging at 104.00C
[ 2.656480] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.658818] THERMAL EST: found 3 subdevs
[ 2.658822] THERMAL EST num_resources: 0
[ 2.658825] [THERMAL EST subdev 0]
[ 2.658830] [THERMAL EST subdev 1]
[ 2.658833] [THERMAL EST subdev 2]
[ 2.659119] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.659121] THERMAL EST: thz register success.
[ 2.659235] THERMAL EST: end of probe, return err: 0
[ 2.659285] tegra_profiler: Branch: Dev
[ 2.659287] tegra_profiler: Version: 1.117
[ 2.659289] tegra_profiler: Samples version: 41
[ 2.659290] tegra_profiler: IO version: 22
[ 2.659297] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.659301] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.659304] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.659309] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.659311] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.659314] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.659317] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.659320] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.659323] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.659326] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.659328] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.659331] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.659540] tegra_profiler: auth: init
[ 2.662892] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.662903] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.663881] scsi host0: tegra_ahci
[ 2.664291] scsi host1: tegra_ahci
[ 2.664478] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.664481] ata2: DUMMY
[ 2.665451] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.665912] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.666371] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.667188] tun: Universal TUN/TAP device driver, 1.6
[ 2.667190] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.667368] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.667370] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.667404] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.667406] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.668463] PPP generic driver version 2.4.2
[ 2.668586] PPP BSD Compression module registered
[ 2.668593] PPP Deflate Compression module registered
[ 2.668615] PPP MPPE Compression module registered
[ 2.668628] NET: Registered protocol family 24
[ 2.668678] usbcore: registered new interface driver r8152
[ 2.668713] usbcore: registered new interface driver asix
[ 2.668740] usbcore: registered new interface driver ax88179_178a
[ 2.668766] usbcore: registered new interface driver cdc_ether
[ 2.668800] usbcore: registered new interface driver smsc75xx
[ 2.668850] usbcore: registered new interface driver net1080
[ 2.668880] usbcore: registered new interface driver cdc_subset
[ 2.668906] usbcore: registered new interface driver zaurus
[ 2.668950] usbcore: registered new interface driver cdc_ncm
[ 2.669187] Wake76 for irq=199
[ 2.669189] Wake77 for irq=199
[ 2.669191] Wake78 for irq=199
[ 2.669192] Wake79 for irq=199
[ 2.669194] Wake80 for irq=199
[ 2.669196] Wake81 for irq=199
[ 2.669197] Wake82 for irq=199
[ 2.669259] tegra-xotg xotg: usb2 phy is not available yet
[ 2.669980] usbcore: registered new interface driver cdc_acm
[ 2.669983] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.670020] usbcore: registered new interface driver usb-storage
[ 2.670081] usbcore: registered new interface driver usbserial
[ 2.670104] usbcore: registered new interface driver cp210x
[ 2.670122] usbserial: USB Serial support registered for cp210x
[ 2.670147] usbcore: registered new interface driver ftdi_sio
[ 2.670164] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.670186] usbcore: registered new interface driver option
[ 2.670231] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.670255] usbcore: registered new interface driver pl2303
[ 2.670275] usbserial: USB Serial support registered for pl2303
[ 2.670485] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.689082] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 94 37
[ 2.689615] libphy: dwc_phy: probed
[ 2.690708] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.751387] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.807073] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.809305] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.809328] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.809475] i2c /dev entries driver
[ 2.810233] [OV5693]: probing v4l2 sensor.
[ 2.982245] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.292254] tegradc 15210000.nvdisplay: fb registered
[ 3.298957] PD DISP0 index2 UP
[ 3.304155] PD DISP1 index3 UP
[ 3.308710] PD DISP2 index4 UP
[ 3.322416] Parent Clock set for DC plld2
[ 3.328854] edid invalid
[ 3.380285] edid invalid
[ 3.384140] edid invalid
[ 3.387990] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[ 3.542684] tegradc 15210000.nvdisplay: blank - normal
[ 3.547099] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.605824] PD DISP2 index4 DOWN
[ 3.607035] PD DISP1 index3 DOWN
[ 3.607709] PD DISP0 index2 DOWN
[ 3.643592] tegradc 15210000.nvdisplay: unblank
[ 3.643695] PD DISP0 index2 UP
[ 3.650053] PD DISP1 index3 UP
[ 3.650571] PD DISP2 index4 UP
[ 3.666597] Parent Clock set for DC plld2
[ 3.669530] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 3.680456] random: nonblocking pool is initialized
[ 3.682319] gspca_main: v2.14.0 registered
[ 3.682367] usbcore: registered new interface driver gspca_zc3xx
[ 3.682692] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.684583] FAN dev name: pwm-fan
[ 3.684631] FAN:gpio request success.
[ 3.684637] FAN: can’t find tach_gpio
[ 3.684658] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.684823] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.684826] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.685136] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.685139] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.685142] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.685145] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.685148] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.685151] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.685154] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.685157] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.685160] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.685163] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.685879] device-mapper: uevent: version 1.0.3
[ 3.686059] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.686416] sdhci: Secure Digital Host Controller Interface driver
[ 3.686417] sdhci: Copyright(c) Pierre Ossman
[ 3.686422] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.686706] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.686988] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.687230] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.688363] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.688485] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.690061] usbcore: registered new interface driver usbhid
[ 3.690062] usbhid: USB HID core driver
[ 3.694855] nvadsp 2993000.adsp: in probe()…
[ 3.709828] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.709856] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.710046] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.710748] Denver: backdoor interface is NOT available.
[ 3.712376] coresight-tmc 8030000.etf: TMC initialized
[ 3.713412] coresight-tmc 8050000.etr: TMC initialized
[ 3.713744] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.714215] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.714628] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.715025] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.715431] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.716013] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.716550] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.717081] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.717610] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.717635] Module initialized successfully
[ 3.720803] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.722111] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.722228] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.722441] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.722479] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.722715] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.722906] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.722953] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.722990] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.723051] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.723092] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.723133] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.723168] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.723322] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.723325] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.724331] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.724334] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.724336] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.724339] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.724341] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.724343] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.724345] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.724371] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.728255] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.729050] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.729144] camchar: rtcpu character device driver loaded
[ 3.732664] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.732900] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.732991] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.733339] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.733365] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.733390] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.733413] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.733439] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.733462] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.733485] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.733509] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.733534] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.733559] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.733583] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.733608] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.733632] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.733656] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.733678] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.733727] **** A57 ECC: Enabled
[ 3.733729] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.733862] parse_throttle_dt_data: Num cap clks = 4
[ 3.733865] parse_throttle_dt_data: clk=mcpu type=1
[ 3.733867] parse_throttle_dt_data: clk=bcpu type=2
[ 3.733872] parse_throttle_dt_data: clk=gpu type=4
[ 3.733874] parse_throttle_dt_data: clk=emc type=3
[ 3.734332] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.734414] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.736866] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.737152] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.739097] tegra-se-nvhost 15810000.se: initialized
[ 3.739538] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.739860] tegra-se-nvhost 15820000.se: initialized
[ 3.740190] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.740483] tegra-se-nvhost 15830000.se: initialized
[ 3.740570] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.740843] tegra-se-nvhost 15840000.se: initialized
[ 3.741087] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.744736] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.758231] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.758503] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.758554] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.760582] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.760626] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.761123] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.761785] cpufreq: platform driver Initialization: pass
[ 3.761918] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.761974] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.762127] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.762132] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.762166] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x30b897
[ 3.762169] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x7
[ 3.763231] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.763808] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.764329] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.764659] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.766054] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.766161] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.767092] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.767096] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.769674] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.770191] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.770452] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.770745] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.771002] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.771293] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.771297] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.771298] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.782122] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.782122] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.782251] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.784244] mmc0: MAN_BKOPS_EN bit is not set
[ 3.785098] OPE platform probe
[ 3.785177] OPE platform probe successful
[ 3.791746] mmc0: Skipping tuning since strobe enabled
[ 3.800028] mmc0: periodic cache flush enabled
[ 3.800035] mmc0: new HS400 MMC card at address 0001
[ 3.800337] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.800515] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.800710] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.800857] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.802127] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.806393] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.838726] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.861424] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.861493] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.861561] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.861631] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.861696] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.861762] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.861831] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.861899] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.861968] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.862032] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.862099] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.862165] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.862274] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.862345] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.862411] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.862478] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.862548] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.862616] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.862682] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.862748] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.865621] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.865692] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.865715] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.865740] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.889908] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.891662] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.891666] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.892292] GACT probability NOT on
[ 3.892301] Mirror/redirect action on
[ 3.892313] u32 classifier
[ 3.892314] Actions configured
[ 3.892343] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.892992] IPVS: Registered protocols ()
[ 3.893020] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.893086] IPVS: Creating netns size=1424 id=0
[ 3.893118] IPVS: ipvs loaded.
[ 3.893124] IPVS: [rr] scheduler registered.
[ 3.893201] ipip: IPv4 over IPv4 tunneling driver
[ 3.893519] Initializing XFRM netlink socket
[ 3.893845] NET: Registered protocol family 10
[ 3.894541] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.894601] NET: Registered protocol family 17
[ 3.894614] NET: Registered protocol family 15
[ 3.894654] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.894660] 8021q: 802.1Q VLAN Support v1.8
[ 3.894941] Registered cp15_barrier emulation handler
[ 3.894955] Registered setend emulation handler
[ 3.896886] registered taskstats version 1
[ 3.900553] isp 15600000.isp: initialized
[ 3.922481] nvcsi 150c0000.nvcsi: initialized
[ 3.923651] Wake76 for irq=199
[ 3.923652] Wake77 for irq=199
[ 3.923653] Wake78 for irq=199
[ 3.923654] Wake79 for irq=199
[ 3.923654] Wake80 for irq=199
[ 3.923655] Wake81 for irq=199
[ 3.923656] Wake82 for irq=199
[ 3.923963] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.923965] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.946500] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.946648] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.946649] xhci-tegra 3530000.xhci: Falling back to user helper
[ 3.947183] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.947872] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.948570] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 3.948614] tegra-xotg xotg: update_id_state: ID floating
[ 3.948618] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 3.948631] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 3.950334] tegra-xotg xotg: otg: gadget gadget registered
[ 3.950335] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 3.950337] tegra-xotg xotg: otg: host not registered yet
[ 3.950338] tegra-xotg xotg: otg: start OTG finite state machine
[ 3.950378] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.950882] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.951534] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.986132] tegra_rtc c2a0000.rtc: setting system clock to 2018-03-20 03:46:29 UTC (1521517589)
[ 4.015981] bpmp: mounted debugfs mirror
[ 4.016469] [dram-timers] DRAM derating cdev registered.
[ 4.020673] spmic-ldo0: disabling
[ 4.020841] spmic-ldo1: disabling
[ 4.021021] en-vdd-cam: disabling
[ 4.021023] vdd-usb0-5v: disabling
[ 4.021024] vdd-usb1-5v: disabling
[ 4.021027] en-vdd-disp-3v3: disabling
[ 4.021028] en-mdm-pwr-3v7: disabling
[ 4.021030] en-vdd-disp-1v8: disabling
[ 4.021031] en-vdd-cam-hv-2v8: disabling
[ 4.021032] en-vdd-cam-1v2: disabling
[ 4.021034] vdd-fan: disabling
[ 4.021035] vdd-3v3: disabling
[ 4.021037] en-vdd-vcm-2v8: disabling
[ 4.021038] vdd-usb2-5v: disabling
[ 4.021040] vdd-sys-bl: disabling
[ 4.021041] en-vdd-sys: disabling
[ 4.027313] ALSA device list:
[ 4.027315] #0: tegra-hda at 0x3518000 irq 400
[ 4.027316] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.045683] tegra-vi4 15700000.vi: initialized
[ 4.046845] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.046848] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.050877] mmc1 tuning done saved tap delay=59
[ 4.050878] mmc1: hw tuning done …
[ 4.050884] mmc1: tuning_window[0]: 0xffffffff
[ 4.050889] mmc1: tuning_window[1]: 0xffffff3f
[ 4.050893] mmc1: tuning_window[2]: 0xfffe7fff
[ 4.050898] mmc1: tuning_window[3]: 0x7c7fffff
[ 4.050902] mmc1: tuning_window[4]: 0x0
[ 4.050906] mmc1: tuning_window[5]: 0x0
[ 4.050929] mmc1: tuning_window[6]: 0x0
[ 4.050934] mmc1: tuning_window[7]: 0x0
[ 4.050937] sdhci: Tap value: 59 | Trim value: 5
[ 4.050940] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.056568] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.056609] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.094273] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 4.094276] tegra-usb-cd usb_cd: set current 0ma
[ 4.094284] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.095202] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.095205] tegra-xudc-new 3550000.xudc: device mode on
[ 6.680163] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.684722] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.684735] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.685617] devtmpfs: mounted
[ 6.685909] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[ 6.685932] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[ 6.690642] btb inv war enabled
[ 6.746147] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.766188] systemd[1]: Detected architecture arm64.
[ 6.781744] systemd[1]: Set hostname to .
[ 6.899115] systemd[1]: Listening on Journal Audit Socket.
[ 6.908081] systemd[1]: Reached target User and Group Name Lookups.
[ 6.917762] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.927800] systemd[1]: Listening on Syslog Socket.
[ 6.936181] systemd[1]: Reached target Encrypted Volumes.
[ 6.945106] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.957200] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.966273] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.975277] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.985898] systemd[1]: Reached target Remote File Systems (Pre).
[ 6.995006] systemd[1]: Reached target Remote File Systems.
[ 7.003707] systemd[1]: Listening on Journal Socket.
[ 7.014678] systemd[1]: Created slice System Slice.
[ 7.024351] systemd[1]: Starting Journal Service…
[ 7.033702] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 7.049298] systemd[1]: Mounting Debug File System…
[ 7.060068] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.070841] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.081676] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.087245] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.099413] systemd[1]: Created slice system-getty.slice.
[ 7.111691] systemd[1]: Started Braille Device Support.
[ 7.122714] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 7.140972] systemd[1]: Starting Load Kernel Modules…
[ 7.150343] systemd[1]: Listening on udev Kernel Socket.
[ 7.159793] systemd[1]: Listening on udev Control Socket.
[ 7.169394] systemd[1]: Created slice User and Session Slice.
[ 7.179057] systemd[1]: Reached target Slices.
[ 7.187411] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.196981] systemd[1]: Reached target Swap.
[ 7.208494] systemd[1]: Mounted Debug File System.
[ 7.217190] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.227006] systemd[1]: Started Journal Service.
[ 7.380280] systemd-journald[263]: Received request to flush runtime journal from PID 1
[ 7.549113] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 7.561428] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 7.574551] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 7.576826] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 7.603383] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 7.712803] dhd_module_init in
[ 7.721586] tegra_net_perf_init: cannot get wifi sclk
[ 7.731335] found wifi platform device bcmdhd_wlan
[ 7.746117] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.757647] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.775600] Power-up adapter ‘DHD generic adapter’
[ 7.783147] wifi_platform_set_power = 1
[ 7.990228] wifi_platform_bus_enumerate device present 1
[ 8.008105] wifi_platform_bus_enumerate device present 0
[ 8.016076] F1 signature read @0x18000000=0x17214354
[ 8.026997] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.036119] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.045269] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.045276] wifi_platform_get_mac_addr
[ 8.046368] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.047102] wl_create_event_handler(): thread:wl_event_handler:214 started
[ 8.047134] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1e10c1a70
[ 8.047248] dhd_attach(): thread:dhd_watchdog_thread:215 started
[ 8.047278] dhd_attach(): thread:dhd_dpc:216 started
[ 8.047304] dhd_attach(): thread:dhd_rxf:217 started
[ 8.047308] dhd_deferred_work_init: work queue initialized
[ 8.047476] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on Mar 1 2018 at 20:46:20
[ 8.047740] tegra_sysfs_register
[ 8.047765] Register interface [wlan0] MAC: 00:04:4b:8d:94:35
[ 8.047768] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.047854] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 59
[ 8.048895] wifi_platform_set_power = 0
[ 8.102229] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.288038] using random self ethernet address
[ 8.295624] using random host ethernet address
[ 8.316228] Mass Storage Function, version: 2009/09/11
[ 8.322809] LUN: removable file: (no medium)
[ 8.334147] using random self ethernet address
[ 8.340673] using random host ethernet address
[ 8.351963] usb0: HOST MAC 36:11:31:ca:ca:46
[ 8.358587] usb0: MAC f6:22:e3:0f:05:72
[ 8.364859] usb1: HOST MAC 5a:34:8e:1d:60:5c
[ 8.371429] usb1: MAC 4e:bd:cf:00:af:b0
[ 8.377553] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.403915] device usb0 entered promiscuous mode
[ 8.414632] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 8.427988] device usb1 entered promiscuous mode
[ 8.441453] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 8.441459] l4tbr0: port 2(usb1) entered forwarding state
[ 8.441473] l4tbr0: port 2(usb1) entered forwarding state
[ 8.520256] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.553191] android_work: did not send uevent (0 0 (null))
[ 8.575441] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 8.577484] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.577500] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 8.578313] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 8.578338] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 8.578453] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.578456] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.578458] usb usb1: Product: xHCI Host Controller
[ 8.578460] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.578461] usb usb1: SerialNumber: 3530000.xhci
[ 8.578742] hub 1-0:1.0: USB hub found
[ 8.578762] hub 1-0:1.0: 4 ports detected
[ 8.598355] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 8.598362] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 8.598513] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.598516] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.598517] usb usb2: Product: xHCI Host Controller
[ 8.598519] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 8.598521] usb usb2: SerialNumber: 3530000.xhci
[ 8.598782] hub 2-0:1.0: USB hub found
[ 8.598801] hub 2-0:1.0: 3 ports detected
[ 8.599159] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 8.612886] android_work: sent uevent USB_STATE=CONNECTED
[ 8.673083] android_work: sent uevent USB_STATE=DISCONNECTED
[ 8.760881] android_work: sent uevent USB_STATE=CONNECTED
[ 8.769671] configfs-gadget gadget: high-speed config #1: c
[ 8.777244] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 8.785949] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 8.794716] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 8.803513] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 8.812141] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 8.820740] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 8.829446] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 8.838122] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 8.846814] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 8.846992] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 8.847058] l4tbr0: port 1(usb0) entered forwarding state
[ 8.847074] l4tbr0: port 1(usb0) entered forwarding state
[ 8.847125] android_work: sent uevent USB_STATE=CONFIGURED
[ 8.888972] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 8.897723] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 8.906964] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 8.958233] usb 1-2: new high-speed USB device number 2 using xhci-tegra
[ 8.970779] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 8.990228] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 9.002456] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 9.054627] IPVS: Creating netns size=1424 id=1
[ 9.088104] usb 1-2: New USB device found, idVendor=2109, idProduct=2811
[ 9.096782] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.096785] usb 1-2: Product: USB2.0 Hub
[ 9.096787] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 9.097411] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 9.097641] hub 1-2:1.0: USB hub found
[ 9.098024] hub 1-2:1.0: 4 ports detected
[ 9.132417] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.135040] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.143822] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 9.143903]
[ 9.143904] wl_android_wifi_on in
[ 9.143907] wifi_platform_set_power = 1
[ 9.219408] usb 2-1: New USB device found, idVendor=2109, idProduct=8110
[ 9.228386] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.237492] usb 2-1: Product: USB3.0 Hub
[ 9.244606] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 9.255322] hub 2-1:1.0: USB hub found
[ 9.261858] hub 2-1:1.0: 4 ports detected
[ 9.307438] tegradc 15210000.nvdisplay: blank - normal
[ 9.386220] usb 1-2.2: new full-speed USB device number 3 using xhci-tegra
[ 9.412225] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.414663] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 9.480791] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 59
[ 9.481180] F1 signature read @0x18000000=0x17214354
[ 9.484605] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 9.485072] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 9.490122] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c534
[ 9.490125] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.490127] usb 1-2.2: Product: USB Receiver
[ 9.490129] usb 1-2.2: Manufacturer: Logitech
[ 9.492636] input: Logitech USB Receiver as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C534.0001/input/input4
[ 9.544983] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 9.546590] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3530000.xhci-2.2/input0
[ 9.549693] input: Logitech USB Receiver as /devices/3530000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/input/input5
[ 9.587093] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 9.587299] Enabling wake69
[ 9.587862] wifi_platform_get_mac_addr
[ 9.589531] Firmware up: op_mode=0x0005, MAC=00:04:4b:8d:94:35
[ 9.594758] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 9.598964] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-e35dbe99
[ 9.601148] dhd_interworking_enable: failed to set WNM info, ret=-23
[ 9.601317] tegra_sysfs_on
[ 9.602414] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3530000.xhci-2.2/input1
[ 9.816230] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.816895] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if : P2P interface registered
[ 9.828793] WLC_E_IF: NO_IF set, event Ignored
[ 9.913368] cfg80211: World regulatory domain updated:
[ 9.913374] cfg80211: DFS Master region: unset
[ 9.913375] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 9.913380] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.913383] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.913385] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.913389] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 9.913393] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 9.913396] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 9.913398] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 9.913401] cfg80211:
