Jetson TX2 Not Booting Past Autoboot
Hi all,
We’re having trouble getting a Jetson TX2 to boot. Every time it tries to boot it gets up until the autoboot section, but it doesn’t count down. It just goes straight to 0 and skips right past, then on the next line it hangs and doesn’t continue.
Here’s the UART serial output:
[0000.198] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobi le-e75fdd51)
[0000.207] I> Boot-device: eMMC
[0000.214] I> sdmmc bdev is already initialized
[0000.219] I> pmic: reset reason (nverc) : 0x40
[0000.252] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.272] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.277] W> No valid slot number is found in scratch register
[0000.283] W> Return default slot: _a
[0000.287] I> A/B: bin_type (16) slot 0
[0000.290] I> Loading partition bpmp-fw at 0xd7800000
[0000.295] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.301] I> Addr: 0xd7800000, start-block: 29417480, num_blocks: 1
[0000.325] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.331] W> No valid slot number is found in scratch register
[0000.337] W> Return default slot: _a
[0000.340] I> A/B: bin_type (17) slot 0
[0000.344] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.349] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.354] I> Addr: 0xd79f0000, start-block: 29419896, num_blocks: 1
[0000.374] I> Binary(17) of size 113248 is loaded @ 0xd79e4400
[0000.402] I> Loading SCE-FW …
[0000.405] W> No valid slot number is found in scratch register
[0000.410] W> Return default slot: _a
[0000.414] I> A/B: bin_type (12) slot 0
[0000.417] I> Loading partition sce-fw at 0xd7300000
[0000.422] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.428] I> Addr: 0xd7300000, start-block: 29423992, num_blocks: 1
[0000.447] I> Binary(12) of size 125632 is loaded @ 0xd7300000
[0000.452] I> Init SCE
[0000.455] I> Loading APE-FW …
[0000.458] W> No valid slot number is found in scratch register
[0000.463] W> Return default slot: _a
[0000.467] I> A/B: bin_type (11) slot 0
[0000.470] I> Loading partition adsp-fw at 0xd7400000
[0000.475] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.481] I> Addr: 0xd7400000, start-block: 29401096, num_blocks: 1
[0000.500] I> Binary(11) of size 77216 is loaded @ 0xd7400000
[0000.506] I> Copy BTCM section
[0000.508] W> No valid slot number is found in scratch register
[0000.514] W> Return default slot: _a
[0000.518] I> A/B: bin_type (13) slot 0
[0000.521] I> Loading partition cpu-bootloader at 0x96000000
[0000.527] I> Reading two headers - addr:0x96000000 blocks:1
[0000.532] I> Addr: 0x96000000, start-block: 29380616, num_blocks: 1
[0000.553] I> Binary(13) of size 309152 is loaded @ 0x96000000
[0000.559] W> No valid slot number is found in scratch register
[0000.564] W> Return default slot: _a
[0000.568] I> A/B: bin_type (20) slot 0
[0000.571] I> Loading partition bootloader-dtb at 0x85205400
[0000.577] I> Reading two headers - addr:0x85205400 blocks:1
[0000.582] I> Addr: 0x85205400, start-block: 29382664, num_blocks: 1
[0000.602] I> Binary(20) of size 192336 is loaded @ 0x85205400
[0000.607] W> No valid slot number is found in scratch register
[0000.613] W> Return default slot: _a
[0000.617] I> A/B: bin_type (14) slot 0
[0000.620] I> Loading partition secure-os at 0x85305600
[0000.625] I> Reading two headers - addr:0x85305600 blocks:1
[0000.631] I> Addr: 0x85305600, start-block: 29384712, num_blocks: 1
[0000.653] I> Binary(14) of size 402864 is loaded @ 0x85305600
[0000.661] I> TOS boot-params @ 0x85000000
[0000.664] I> TOS params prepared
[0000.668] I> Loading EKS …
[0000.670] I> A/B: bin_type (15) slot 0
[0000.674] I> Loading partition eks at 0x85905800
[0000.678] I> Reading two headers - addr:0x85905800 blocks:1
[0000.684] I> Addr: 0x85905800, start-block: 29397000, num_blocks: 1
[0000.703] I> Binary(15) of size 1040 is loaded @ 0x85905800
[0000.708] I> EKB detected (length: 0x400) @ 0x85905800
[0000.713] I> Copied encrypted keys
[0000.717] I> boot profiler @ 0x175844000
[0000.721] I> boot profiler for TOS @ 0x175844000
[0000.726] I> Unhalting SCE
[0000.728] I> Primary Memory Start:80000000 Size:70000000
[0000.733] I> Extended Memory Start:f0110000 Size:856f0000
[0000.740] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 02:21:00, Apr 17 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing …
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0000.961] I> Welcome to Cboot
[0000.964] I> Cboot Version: t186-acf1ddbd
[0000.968] I> CPU-BL Params @ 0x175800000
[0000.972] I> 0) Base:0x00000000 Size:0x00000000
[0000.976] I> 1) Base:0x177f00000 Size:0x00100000
[0000.981] I> 2) Base:0x177e00000 Size:0x00100000
[0000.985] I> 3) Base:0x177d00000 Size:0x00100000
[0000.990] I> 4) Base:0x177c00000 Size:0x00100000
[0000.994] I> 5) Base:0x177b00000 Size:0x00100000
[0000.999] I> 6) Base:0x177800000 Size:0x00200000
[0001.003] I> 7) Base:0x177400000 Size:0x00400000
[0001.008] I> 8) Base:0x177a00000 Size:0x00100000
[0001.012] I> 9) Base:0x177300000 Size:0x00100000
[0001.017] I> 10) Base:0x176800000 Size:0x00800000
[0001.021] I> 11) Base:0x30000000 Size:0x00040000
[0001.026] I> 12) Base:0xf0000000 Size:0x00100000
[0001.030] I> 13) Base:0x30040000 Size:0x00001000
[0001.035] I> 14) Base:0x30048000 Size:0x00001000
[0001.039] I> 15) Base:0x30049000 Size:0x00001000
[0001.044] I> 16) Base:0x3004a000 Size:0x00001000
[0001.048] I> 17) Base:0x3004b000 Size:0x00001000
[0001.052] I> 18) Base:0x3004c000 Size:0x00001000
[0001.057] I> 19) Base:0x3004d000 Size:0x00001000
[0001.061] I> 20) Base:0x3004e000 Size:0x00001000
[0001.066] I> 21) Base:0x3004f000 Size:0x00001000
[0001.070] I> 22) Base:0x00000000 Size:0x00000000
[0001.075] I> 23) Base:0xf0100000 Size:0x00010000
[0001.079] I> 24) Base:0x00000000 Size:0x00000000
[0001.083] I> 25) Base:0x00000000 Size:0x00000000
[0001.088] I> 26) Base:0x00000000 Size:0x00000000
[0001.092] I> 27) Base:0x00000000 Size:0x00000000
[0001.097] I> 28) Base:0x84400000 Size:0x00400000
[0001.101] I> 29) Base:0x30000000 Size:0x00010000
[0001.106] I> 30) Base:0x178000000 Size:0x08000000
[0001.110] I> 31) Base:0x00000000 Size:0x00000000
[0001.115] I> 32) Base:0x176000000 Size:0x00600000
[0001.119] I> 33) Base:0x80000000 Size:0x70000000
[0001.123] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.128] I> 35) Base:0x00000000 Size:0x00000000
[0001.132] I> 36) Base:0x00000000 Size:0x00000000
[0001.137] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.141] I> 38) Base:0x84000000 Size:0x00400000
[0001.146] I> 39) Base:0x96000000 Size:0x02000000
[0001.150] I> 40) Base:0x85000000 Size:0x01200000
[0001.155] I> 41) Base:0x175800000 Size:0x00500000
[0001.159] I> 42) Base:0x00000000 Size:0x00000000
[0001.164] I> 43) Base:0x00000000 Size:0x00000000
[0001.168] GIC-SPI Target CPU: 4
[0001.171] Interrupts Init done
[0001.175] calling constructors
[0001.178] initializing heap
[0001.180] initializing threads
[0001.184] initializing timers
[0001.187] creating bootstrap completion thread
[0001.192] top of bootstrap2()
[0001.195] CPU: ARM Cortex A57
[0001.198] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.203] initializing platform
[0001.206] I> Bl_dtb @0x85205400
[0001.209] I> gpio framework initialized
[0001.214] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ driv er
[0001.223] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio-aon’ driver
[0001.231] I> GPIO framework and drivers are initialized.
[0001.236] I> Boot-device: eMMC
[0001.243] I> sdmmc bdev is already initialized
[0001.274] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.291] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.297] W> opt-in fuse is not set, skip fuse_burning
[0001.302] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.308] W> No valid slot number is found in scratch register
[0001.313] W> Return default slot: _a
[0001.323] I> A/B: bin_type (21) slot 0
[0001.326] I> Loading kernel-dtb from partition
[0001.331] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.348] I> Kernel_dtb @0x80000000
[0001.351] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.359] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0001.369] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0001.377] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.383] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.391] W> fetch_driver_phandle_from_dt: failed to get node with compatible t i,tca9539
[0001.401] W> fetch_driver_phandle_from_dt: failed to get node with compatible n xp,tca9539
[0001.409] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.417] I> fixed regulator driver initialized
[0001.439] I> register ‘maxim’ power off handle
[0001.444] I> virtual i2c enabled
[0001.447] I> registered ‘maxim,max77620’ pmic
[0001.451] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.461] E> failed to read label property for node 149952: 13
[0001.468] E> failed to read reg property for node 150048: 13
[0001.475] E> failed to read reg property for node 150100: 13
[0001.482] E> failed to read label property for node 150184: 13
[0001.489] E> failed to read reg property for node 150252: 13
[0001.495] E> failed to read reg property for node 150324: 13
[0001.503] I> Find /i2c@c250000’s alias i2c7
[0001.507] I> Reading eeprom i2c=7 address=0x50
[0001.536] I> Device at /i2c@c250000:0x50
[0001.540] I> Reading eeprom i2c=7 address=0x57
[0001.544] E> I2C: slave not found in slaves.
[0001.548] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start tr ue.
[0001.556] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.562] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.571] E> eeprom: Failed to read I2C slave device
[0001.576] I> Eeprom read failed 0x3526070d
[0001.581] I> Find /i2c@3160000’s alias i2c0
[0001.585] I> Reading eeprom i2c=0 address=0x50
[0001.590] E> I2C: slave not found in slaves.
[0001.594] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start tr ue.
[0001.601] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.607] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.617] E> eeprom: Failed to read I2C slave device
[0001.621] I> Eeprom read failed 0x3526070d
[0001.626] I> Find /i2c@3180000’s alias i2c2
[0001.630] I> Reading eeprom i2c=2 address=0x54
[0001.634] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.639] C> GPIO driver for chip_id 0x2 could not be found
[0001.644] E> cam_eeprom_read: Can’t get gpio driver
[0001.649] I> Eeprom read failed 0x4d4d000d
[0001.653] I> Reading eeprom i2c=2 address=0x57
[0001.657] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.662] C> GPIO driver for chip_id 0x2 could not be found
[0001.667] E> cam_eeprom_read: Can’t get gpio driver
[0001.672] I> Eeprom read failed 0x4d4d000d
[0001.676] I> create_pm_ids: id: 3636-0001-301-D, len: 15
[0001.681] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0001.704] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0001.716] I> regulator ‘vdd-hdmi-5v0’ already enabled
[0001.720] I> hdmi cable connected
[0001.725] I> setting ‘vdd-pex-1v00’ regulator to 1000000 micro volts
[0001.733] I> setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0001.739] I> retrieved tmds range from prod_list_hdmi_soc
[0001.745] E> cannot find any other nvdisp nodes
[0001.765] I> edid read success
[0001.780] I> edid read success
[0001.783] I> width = 640, height = 480, frequency = 25174825
[0001.788] I> width = 3840, height = 2160, frequency = 297000000
[0001.794] I> width = 2560, height = 1440, frequency = 241500requency = 14835164 8
[0001.811] I> width = 1920, height = 1080, frequency = 74175824
[0001.817] I> width = 1280, height = 720, frequency = 74175824
[0001.822] I> width = 720, height = 480, frequency = 26973026
[0001.828] I> width = 640, height = 480, frequency = 25174825
[0001.833] I> width = 3840, height = 2160, frequency = 296703296
[0001.839] I> width = 3840, height = 2160, frequency = 296703296
[0001.845] I> width = 3840, height = 2160, frequency = 296703296
[0001.851] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0001.860] I> hdmi_enable, starting HDMI initialisation
[0001.867] I> hdmi_enable, HDMI initialisation complete
[0001.880] initializing target
[0001.883] calling apps_init()
[0001.887] starting app kernel_boot_app
[0001.909] I> found decompressor handler: lz4-legacy
[0001.913] I> decompressing BMP blob …
[0001.925] I> Kernel type = Normal
[0001.928] I> ########## Fixed storage boot ##########
[0001.933] I> Loading kernel-bootctrl from partition
[0001.938] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0001.952] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0001.959] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0001.966] W> No valid slot number is found in scratch register
[0001.972] W> Return default slot: _a
[0001.975] I> A/B: bin_type (24) slot 0
[0001.991] I> Boot image size read from image header: 9902d
[0001.996] I> Boot image load address: 0x80400000
[0002.001] I> Loading kernel from partition
[0002.005] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.948] I> Validate kernel …
[0002.951] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0002.959] I> Decrypt the buffer … [0002.962] W> tegrabl_decrypt_block: fuse ( 0x0) is not burnt to do encryption (0x4); skip decryption.
[0002.971] I> done
[0002.973] I> Checking boot.img header magic … [0002.977] I> [OK]
[0002.979] I> kernel-dtb is already loaded
[0002.982] I> Validate kernel-dtb …
[0002.986] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0002.993] I> Decrypt the buffer … [0002.996] W> tegrabl_decrypt_block: fuse ( 0x0) is not burnt to do encryption (0x4); skip decryption.
[0003.005] I> done
[0003.007] I> Kernel hdr @0x80400000
[0003.010] I> Kernel dtb @0x80000000
[0003.014] I> decompressor handler not found
[0003.018] I> Copying kernel image (626733 bytes) from 0x80400800 to 0x80600000 … [0003.025] I> Done
[0003.027] I> Move ramdisk (len: 0) from 0x8049a000 to 0x947d0000
[0003.034] I> Updated bpmp info to DTB
[0003.039] I> Ramdisk: Base: 0x947d0000; Size: 0x0
[0003.043] I> Updated initrd info to DTB
[0003.047] W> WARN: Fail to override “console=none” in commandline
[0003.053] I> Active rootfs suffix:
[0003.056] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display param s
[0003.063] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display param s
[0003.070] I> disabled_core_mask: 0xffffff0c
[0003.074] W> No valid slot number is found in scratch register
[0003.080] W> Return default slot: _a
[0003.084] I> Active slot suffix:
[0003.087] I> add_boot_slot_suffix: slot_suffix =
[0003.091] I> Linux Cmdline: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwai t rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved =0x1772e0000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0x96085000 lut_mem=0x2 008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_consol e_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_da taptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1
[0003.138] I> Updated bootarg info to DTB
[0003.142] W> MAC addr invalid!
[0003.145] E> Failed to get WIFI MAC address
[0003.149] W> MAC addr invalid!
[0003.152] E> Failed to get Bluetooth MAC address
[0003.156] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:88:b0:a2
[0003.162] E> Found no plugin manager ids in source DT
[0003.167] W> Add plugin manager ids from board info
[0003.172] W> “plugin-manager” doesn’t exist, creating
[0003.177] W> “ids” doesn’t exist, creating
[0003.181] W> “connection” doesn’t exist, creating
[0003.185] W> “configs” doesn’t exist, creating
[0003.190] I> create_pm_ids: id: 3636-0001-301-D, len: 15
[0003.195] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00 ,touch-config:00,display-config:00, len: 93
[0003.206] I> Adding plugin-manager/ids/3636-0001-301=/i2c@c250000:module@0x50
[0003.213] W> “i2c@c250000” doesn’t exist, creating
[0003.218] W> “module@0x50” doesn’t exist, creating
[0003.223] I> Adding plugin-manager/ids/3636-0001-301-D
[0003.229] I> Adding plugin-manager/configs/3636-mem-type 00
[0003.235] I> Adding plugin-manager/configs/3636-power-config 00
[0003.241] I> Adding plugin-manager/configs/3636-misc-config 00
[0003.247] I> Adding plugin-manager/configs/3636-modem-config 00
[0003.253] I> Adding plugin-manager/configs/3636-touch-config 00
[0003.258] I> Adding plugin-manager/configs/3636-display-config 00
[0003.265] I> Adding plugin-manager/cvm
[0003.268] W> “chip-id” doesn’t exist, creating
[0003.273] I> Adding plugin-manager/chip-id/A02P
[0003.277] W> “odm-data” doesn’t exist, creating
[0003.282] I> Adding /chosen/plugin-manager/odm-data
[0003.290] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.296] I> added [base:0xf0200000, size:0x85600000] to /memory
[0003.301] I> added [base:0x175e00000, size:0x200000] to /memory
[0003.307] I> added [base:0x176600000, size:0x200000] to /memory
[0003.313] I> added [base:0x177000000, size:0x200000] to /memory
[0003.319] I> Updated memory info to DTB
[0003.323] E> add_disp_param: failed to get display params for du=1
[0003.330] W> “reset” doesn’t exist, creating
[0003.334] W> “pmc-reset-reason” doesn’t exist, creating
[0003.339] W> “pmic-reset-reason” doesn’t exist, creating
[0003.345] I> Adding ecid(00000001644191090800000008fd03c0) to DT
[0003.351] I> disabled_core_mask: 0xffffff0c
[0003.360] I> Add serial number:1422422094988 as DT property
[0003.367] I> Plugin-manager override starting
[0003.372] I> node /plugin-manager/fragement@0 matches
[0003.380] I> node /plugin-manager/fragement@3 matches
[0003.393] I> Disable plugin-manager status in FDT
[0003.397] I> Plugin-manager override finished successfully
[0003.403] I> tegrabl_load_kernel_and_dtb: Done
[0003.447] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2020.04-g4335beb (Apr 17 2022 - 02:21:01 -0700)
SoC: tegra186
Model: NVIDIA P3636-0001
Board: NVIDIA P3636-0001
DRAM: 3.8 GiB
MMC: sdhci@3400000: 1, sdhci@3460000: 0
Loading Environment from MMC… OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
Tegra186 (P3636-0001) # MC: sdhci@3400000: 1, sdhci@346000y▒Kk3۸▒
What was changed here? Have you tired to reflash the board?
Hi, this problem has been solved. There was something weird going on with the debug UART on our custom carrier board where it was getting a bit of loopback. During boot when it got to the “press key to pause autoboot” section it was getting a key press, as it was looped back. This was halting the boot. Fixed with a soldering iron and now it boots fine.
