Jetpack downgrade in TX2 and connection failed
I want to downgrade Jetpack version from 4.6.4 to 4.6.3. So I used SDK Manager to flash my TX2.After the System Configuration appeared on the Jetson HDMI display,but it didn’t finish it.My TX2 showed…
At the same time,my PC (Ubuntu 18.04.6 LTS )showed “connection failed” I don’t know if this is the reason that it failed to flash TX2.
My computer is wired to the router ,and the TX2 is connected to the computer.
please help me to solve this,thank you!
your video was not uploaded successfully, so I cannot know what happened.
Can you please check it?
Sorry about that,I has already uploaded the video again.Please check it.
then are you still able to login via serial console?
No,I followed this video (https://www.youtube.com/watch?v=eQCJy9iUvTA&t=67s)to set up TX2 via serial console.And my PC showed that
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 12:07:44
Press CTRL-A Z for help on special keys
[0000.261] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mob)
[0000.269] I> Boot-device: eMMC
[0000.277] I> sdmmc bdev is already initialized
[0000.281] I> pmic: reset reason (nverc)        : 0x50
[0000.314] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0000.334] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.340] W> No valid slot number is found in scratch register
[0000.346] W> Return default slot: _a
[0000.349] I> A/B: bin_type (16) slot 0
[0000.353] I> Loading partition bpmp-fw at 0xd7800000
[0000.358] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.363] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.388] I> Binary(16) of size 534416 is loaded @ 0xd7800000
[0000.394] W> No valid slot number is found in scratch register
[0000.399] W> Return default slot: _a
[0000.403] I> A/B: bin_type (17) slot 0
[0000.406] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.412] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.417] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.443] I> Binary(17) of size 617520 is loaded @ 0xd7969200
[0000.677] I> Loading SCE-FW ...
[0000.680] W> No valid slot number is found in scratch register
[0000.685] W> Return default slot: _a
[0000.689] I> A/B: bin_type (12) slot 0
[0000.692] I> Loading partition sce-fw at 0xd7300000
[0000.697] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.702] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.722] I> Binary(12) of size 125632 is loaded @ 0xd7300000
[0000.727] I> Init SCE
[0000.730] I> Loading APE-FW ...
[0000.733] W> No valid slot number is found in scratch register
[0000.738] W> Return default slot: _a
[0000.742] I> A/B: bin_type (11) slot 0
[0000.745] I> Loading partition adsp-fw at 0xd7400000
[0000.750] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.756] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.775] I> Binary(11) of size 77232 is loaded @ 0xd7400000
[0000.780] I> Copy BTCM section
[0000.783] W> No valid slot number is found in scratch register
[0000.789] W> Return default slot: _a
[0000.793] I> A/B: bin_type (13) slot 0
[0000.796] I> Loading partition cpu-bootloader at 0x96000000
[0000.802] I> Reading two headers - addr:0x96000000 blocks:1
[0000.807] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.829] I> Binary(13) of size 309424 is loaded @ 0x96000000
[0000.834] W> No valid slot number is found in scratch register
[0000.840] W> Return default slot: _a
[0000.843] I> A/B: bin_type (20) slot 0
[0000.847] I> Loading partition bootloader-dtb at 0x85205400
[0000.852] I> Reading two headers - addr:0x85205400 blocks:1
[0000.858] I> Addr: 0x85205400, start-block: 58742792, num_blocks: 1
[0000.880] I> Binary(20) of size 375488 is loaded @ 0x85205400
[0000.886] W> No valid slot number is found in scratch register
[0000.892] W> Return default slot: _a
[0000.895] I> A/B: bin_type (14) slot 0
[0000.899] I> Loading partition secure-os at 0x85305600
[0000.904] I> Reading two headers - addr:0x85305600 blocks:1
[0000.909] I> Addr: 0x85305600, start-block: 58744840, num_blocks: 1
[0000.932] I> Binary(14) of size 406960 is loaded @ 0x85305600
[0000.940] I> TOS boot-params @ 0x85000000
[0000.944] I> TOS params prepared
[0000.947] I> Loading EKS ...
[0000.949] I> A/B: bin_type (15) slot 0
[0000.953] I> Loading partition eks at 0x85905800
[0000.957] I> Reading two headers - addr:0x85905800 blocks:1
[0000.963] I> Addr: 0x85905800, start-block: 58757128, num_blocks: 1
[0000.982] I> Binary(15) of size 1040 is loaded @ 0x85905800
[0000.987] I> EKB detected (length: 0x400) @ 0x85905800
[0000.992] I> Copied encrypted keys
[0000.996] I> boot profiler @ 0x275844000
[0001.000] I> boot profiler for TOS @ 0x275844000
[0001.005] I> Unhalting SCE
[0001.007] I> Primary Memory Start:80000000 Size:70000000
[0001.012] I> Extended Memory Start:f0110000 Size:1856f0000
[0001.019] I> MB2(TBoot-BPMP) done
NOTICE:  BL31: v1.3(release):9892ce1
NOTICE:  BL31: Built : 09:21:30, Nov 22 2022
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 41: hwkey-agent is running!!
hwkey-agent: 347: key_mgnt_processing .......
hwkey-agent: 255: Setting EKB key 0 to slot 14
hwkey-agent: 178: Init hweky-agent services!!
luks-srv: 40: luks-srv is running!!
luks-srv: 157: Init luks-srv IPC services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.392] I> Welcome to Cboot
[0001.395] I> Cboot Version: t186-cf8d3df5
[0001.399] I> CPU-BL Params @ 0x275800000
[0001.403] I>  0) Base:0x00000000 Size:0x00000000
[0001.407] I>  1) Base:0x277f00000 Size:0x00100000
[0001.412] I>  2) Base:0x277e00000 Size:0x00100000
[0001.416] I>  3) Base:0x277d00000 Size:0x00100000
[0001.421] I>  4) Base:0x277c00000 Size:0x00100000
[0001.425] I>  5) Base:0x277b00000 Size:0x00100000
[0001.430] I>  6) Base:0x277800000 Size:0x00200000
[0001.434] I>  7) Base:0x277400000 Size:0x00400000
[0001.439] I>  8) Base:0x277a00000 Size:0x00100000
[0001.443] I>  9) Base:0x277300000 Size:0x00100000
[0001.448] I> 10) Base:0x276800000 Size:0x00800000
[0001.452] I> 11) Base:0x30000000 Size:0x00040000
[0001.457] I> 12) Base:0xf0000000 Size:0x00100000
[0001.461] I> 13) Base:0x30040000 Size:0x00001000
[0001.466] I> 14) Base:0x30048000 Size:0x00001000
[0001.470] I> 15) Base:0x30049000 Size:0x00001000
[0001.474] I> 16) Base:0x3004a000 Size:0x00001000
[0001.479] I> 17) Base:0x3004b000 Size:0x00001000
[0001.483] I> 18) Base:0x3004c000 Size:0x00001000
[0001.488] I> 19) Base:0x3004d000 Size:0x00001000
[0001.492] I> 20) Base:0x3004e000 Size:0x00001000
[0001.497] I> 21) Base:0x3004f000 Size:0x00001000
[0001.501] I> 22) Base:0x00000000 Size:0x00000000
[0001.506] I> 23) Base:0xf0100000 Size:0x00010000
[0001.510] I> 24) Base:0x00000000 Size:0x00000000
[0001.514] I> 25) Base:0x00000000 Size:0x00000000
[0001.519] I> 26) Base:0x00000000 Size:0x00000000
[0001.523] I> 27) Base:0x00000000 Size:0x00000000
[0001.528] I> 28) Base:0x84400000 Size:0x00400000
[0001.532] I> 29) Base:0x30000000 Size:0x00010000
[0001.537] I> 30) Base:0x278000000 Size:0x08000000
[0001.541] I> 31) Base:0x00000000 Size:0x00000000
[0001.545] I> 32) Base:0x276000000 Size:0x00600000
[0001.550] I> 33) Base:0x80000000 Size:0x70000000
[0001.554] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.559] I> 35) Base:0x00000000 Size:0x00000000
[0001.563] I> 36) Base:0x00000000 Size:0x00000000
[0001.568] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.572] I> 38) Base:0x84000000 Size:0x00400000
[0001.577] I> 39) Base:0x96000000 Size:0x02000000
[0001.581] I> 40) Base:0x85000000 Size:0x01200000
[0001.586] I> 41) Base:0x275800000 Size:0x00500000
[0001.590] I> 42) Base:0x00000000 Size:0x00000000
[0001.595] I> 43) Base:0x00000000 Size:0x00000000
[0001.599] GIC-SPI Target CPU: 4
[0001.602] Interrupts Init done
[0001.606] calling constructors
[0001.609] initializing heap
[0001.611] initializing threads
[0001.615] initializing timers
[0001.618] creating bootstrap completion thread
[0001.622] top of bootstrap2()
[0001.625] CPU: ARM Cortex A57
[0001.629] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.634] initializing platform
[0001.637] I> Bl_dtb @0x85205400
[0001.640] I> gpio framework initialized
[0001.646] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' drir
[0001.657] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon'r
[0001.664] I> GPIO framework and drivers are initialized.
[0001.669] I> Boot-device: eMMC
[0001.676] I> sdmmc bdev is already initialized
[0001.707] I> Found 19 partitions in SDMMC_BOOT (instance 3)
[0001.725] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.730] W> opt-in fuse is not set, skip fuse_burning
[0001.735] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.741] W> No valid slot number is found in scratch register
[0001.747] W> Return default slot: _a
[0001.756] I> A/B: bin_type (21) slot 0
[0001.760] I> Loading kernel-dtb from partition
[0001.764] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.781] I> Kernel_dtb @0x80000000
[0001.784] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.795] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' drivr
[0001.802] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.811] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' drivr
[0001.821] I> fixed regulator driver initialized
[0001.854] I> register 'maxim' power off handle
[0001.861] I> virtual i2c enabled
[0001.864] I> registered 'maxim,max77620' pmic
[0001.868] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.882] E> failed to read label property for node 324868: 13
[0001.890] E> failed to read reg property for node 324964: 13
[0001.899] E> failed to read reg property for node 325016: 13
[0001.907] E> failed to read label property for node 325100: 13
[0001.915] E> failed to read label property for node 325168: 13
[0001.924] E> failed to read reg property for node 325236: 13
[0001.932] E> failed to read reg property for node 325308: 13
[0001.942] I> Find /i2c@c250000's alias i2c7
[0001.946] I> Reading eeprom i2c=7 address=0x50
[0001.976] I> Device at /i2c@c250000:0x50
[0001.979] I> Reading eeprom i2c=7 address=0x57
[0002.008] I> Device at /i2c@c250000:0x57
[0002.012] I> Find /i2c@c240000's alias i2c1
[0002.016] I> Reading eeprom i2c=1 address=0x51
[0002.022] E> I2C: slave not found in slaves.
[0002.026] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0002.033] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.039] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0002.049] E> eeprom: Retry to read I2C slave device.
[0002.054] E> I2C: slave not found in slaves.
[0002.058] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start t.
[0002.066] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.071] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 a.
[0002.081] E> eeprom: Failed to read I2C slave device
[0002.086] I> Eeprom read failed 0x3526070d
[0002.090] I> Find /i2c@3160000's alias i2c0
[0002.094] I> Reading eeprom i2c=0 address=0x50
[0002.099] E> I2C: slave not found in slaves.
[0002.103] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0002.110] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.116] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0002.126] E> eeprom: Failed to read I2C slave device
[0002.131] I> Eeprom read failed 0x3526070d
[0002.135] I> Find /i2c@3180000's alias i2c2
[0002.139] I> Reading eeprom i2c=2 address=0x54
[0002.144] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.174] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.179] I> Device at /i2c@3180000:0x54
[0002.183] I> Reading eeprom i2c=2 address=0x57
[0002.187] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.193] E> I2C: slave not found in slaves.
[0002.197] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start t.
[0002.205] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.211] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae a.
[0002.220] E> eeprom: Failed to read I2C slave device
[0002.225] I> Disabling gpio chip_id = 2, gpio pin = 9
[0002.230] I> Eeprom read failed 0x00000000
[0002.234] I> create_pm_ids: id: 3310-1000-B02-D, len: 15
[0002.239] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.250] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0002.255] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0002.266] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0002.271] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:f3
[0002.306] I> enabling 'vdd-hdmi' regulator
[0002.322] I> regulator 'vdd-hdmi' already enabled
[0002.327] E> tegrabl_display_init_regulator: hdmi cable is not connected
[0002.333] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0002.342] E> cannot find any other nvdisp nodes
[0002.346] E> no valid display unit config found in dtb
[0002.352] W> display init failed
[0002.355] initializing target
[0002.358] calling apps_init()
[0002.361] starting app kernel_boot_app
[0002.384] I> found decompressor handler: lz4-legacy
[0002.388] I> decompressing BMP blob ...
[0002.461] I> Kernel type = Normal
[0002.464] I> ########## Fixed storage boot ##########
[0002.469] I> Loading kernel-bootctrl from partition
[0002.473] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.488] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.495] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.502] W> No valid slot number is found in scratch register
[0002.507] W> Return default slot: _a
[0002.511] I> A/B: bin_type (24) slot 0
[0002.527] I> Boot image size read from image header: 990e5
[0002.532] I> Boot image load address: 0x80400000
[0002.536] I> Loading kernel from partition
[0002.540] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.500] I> Validate kernel ...
[0003.503] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.511] I> Decrypt the buffer ... [0003.514] W> tegrabl_decrypt_block: fuse .
[0003.523] I> done
[0003.525] I> Checking boot.img header magic ... [0003.529] I> [OK]
[0003.531] I> kernel-dtb is already loaded
[0003.535] I> Validate kernel-dtb ...
[0003.538] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.546] I> Decrypt the buffer ... [0003.549] W> tegrabl_decrypt_block: fuse .
[0003.558] I> done
[0003.559] I> Kernel hdr @0x80400000
[0003.563] I> Kernel dtb @0x80000000
[0003.566] I> decompressor handler not found
[0003.570] I> Copying kernel image (626917 bytes) from 0x80400800 to 0x80600000e
[0003.579] I> Move ramdisk (len: 0) from 0x8049a000 to 0x947d0000
[0003.587] I> Updated bpmp info to DTB
[0003.593] I> Ramdisk: Base: 0x947d0000; Size: 0x0
[0003.597] I> Updated initrd info to DTB
[0003.601] W> WARN: Fail to override "console=none" in commandline
[0003.607] I> Active rootfs suffix:
[0003.610] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0003.617] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0003.625] W> tegrabl_linuxboot_add_disp_param, du 0 failed to get display paras
[0003.632] I> disabled_core_mask: 0xffffff0c
[0003.636] W> No valid slot number is found in scratch register
[0003.642] W> Return default slot: _a
[0003.645] I> Active slot suffix:
[0003.648] I> add_boot_slot_suffix: slot_suffix =
[0003.653] I> Linux Cmdline: console=ttyS0,115200 androidboot.presilicon=true f
[0003.701] I> Updated bootarg info to DTB
[0003.705] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:a8:1a:e9
[0003.711] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:a8:1a:ea
[0003.717] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:a8:1a:eb
[0003.724] E> Found no plugin manager ids in source DT
[0003.729] W> Add plugin manager ids from board info
[0003.733] W> "plugin-manager" doesn't exist, creating
[0003.738] W> "ids" doesn't exist, creating
[0003.742] W> "connection" doesn't exist, creating
[0003.747] W> "configs" doesn't exist, creating
[0003.751] I> create_pm_ids: id: 3310-1000-B02-D, len: 15
[0003.756] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0003.767] I> create_pm_ids: id: 2597-0000-501-C, len: 15
[0003.772] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:03
[0003.783] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0003.788] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:f3
[0003.799] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50
[0003.807] W> "i2c@c250000" doesn't exist, creating
[0003.811] W> "module@0x50" doesn't exist, creating
[0003.816] I> Adding plugin-manager/ids/2597-0000-501=/i2c@c250000:module@0x57
[0003.823] W> "module@0x57" doesn't exist, creating
[0003.828] I> Adding plugin-manager/ids/3326-1000-100=/i2c@3180000:module@0x54
[0003.836] W> "i2c@3180000" doesn't exist, creating
[0003.840] W> "module@0x54" doesn't exist, creating
[0003.847] I> Adding plugin-manager/ids/3310-1000-B02-D
[0003.854] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.860] I> Adding plugin-manager/configs/3310-power-config 00
[0003.866] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.872] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.877] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.883] I> Adding plugin-manager/configs/3310-display-config 00
[0003.890] I> Adding plugin-manager/cvm
[0003.893] W> "chip-id" doesn't exist, creating
[0003.898] I> Adding plugin-manager/chip-id/A02P
[0003.902] W> "odm-data" doesn't exist, creating
[0003.907] I> Adding /chosen/plugin-manager/odm-data
[0003.917] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.922] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.928] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.934] I> added [base:0x276600000, size:0x200000] to /memory
[0003.940] I> added [base:0x277000000, size:0x200000] to /memory
[0003.945] I> Updated memory info to DTB
[0003.950] W> add_disp_param: failed to get display params for du=0
[0003.958] W> "reset" doesn't exist, creating
[0003.962] W> "pmc-reset-reason" doesn't exist, creating
[0003.968] W> "pmic-reset-reason" doesn't exist, creating
[0003.974] I> Adding ecid(000000016440b4061800000018fd0480) to DT
[0003.980] I> disabled_core_mask: 0xffffff0c
[0003.993] I> Add serial number:0320318054748 as DT property
[0004.001] I> Plugin-manager override starting
[0004.007] I> node /plugin-manager/fragement@0 matches
[0004.017] I> node /plugin-manager/fragement@4 matches
[0004.030] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0004.050] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0004.060] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0004.068] I> node /plugin-manager/fragment-devslp@0 matches
[0004.081] I> node /plugin-manager/fragment-500-pcie-config matches
[0004.096] I> node /plugin-manager/fragment-500-xusb-config matches
[0004.119] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0004.132] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0004.143] I> node /plugin-manager/fragment-p3310-c01 matches
[0004.156] I> node /plugin-manager/fragment-p3310-c03 matches
[0004.199] I> node /plugin-manager/fragment-e3326@0 matches
[0004.287] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0004.314] I> Disable plugin-manager status in FDT
[0004.318] I> Plugin-manager override finished successfully
[0004.324] I> tegrabl_load_kernel_and_dtb: Done
[0004.328] W> tegrabl_display_clear: display is not initialized
[0004.334] W> Boot logo display failed...
[0004.337] I> Kernel EP: 0x80600000, DTB: 0x80000000
U-Boot 2020.04-g4335beb (Nov 22 2022 - 09:21:33 -0800)
SoC: tegra186
Model: NVIDIA P2771-0000-500
Board: NVIDIA P2771-0000
DRAM:  7.8 GiB
MMC:   sdhci@3400000: 1, sdhci@3460000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:
Warning: ethernet@2490000 using MAC address from ROM
eth0: ethernet@2490000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1093 bytes read in 21 ms (50.8 KiB/s)
L4T boot options
1:      Boot from SD card
2:      Boot from eMMc
3:      Boot from USB, SATA
Enter choice: 1:        Boot from SD card
Retrieving file: /boot/initrd
7238484 bytes read in 796 ms (8.7 MiB/s)
Retrieving file: /boot/Image
34707464 bytes read in 3757 ms (8.8 MiB/s)
append: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/e
Retrieving file: /tmp/tegra186-quill-p3310-1000-c03-00-base.dtb
Skipping SDcard for failure retrieving FDT
2:      Boot from eMMc
7238484 bytes read in 797 ms (8.7 MiB/s)
## Flattened Device Tree blob at 80000000
   Booting using the fdt blob at 0x80000000
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000080000000, end 0000000080060a5f
copying carveout for /host1x@13e00000/display-hub@15200000/display@15200000...
copying carveout for /host1x@13e00000/display-hub@15200000/display@15210000...
copying carveout for /host1x@13e00000/display-hub@15200000/display@15220000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5418-d8000) (3
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[    0.000000] OF: fdt: - 80000000 ,  70000000
[    0.000000] OF: fdt: - f0200000 ,  185600000
[    0.000000] OF: fdt: - 275e00000 ,  200000
[    0.000000] OF: fdt: - 276600000 ,  200000
[    0.000000] OF: fdt: - 277000000 ,  200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[    0.000000] bootconsole [uart8250] enabled
Unhandled Exception in EL3.
x30 =           0x0000000030008b94
x0 =            0x0000000000000000
x1 =            0x0000000080003fff
x2 =            0x0000000080000001
x3 =            0x0000000000000000
x4 =            0x0000000000000000
x5 =            0x0000000000000000
x6 =            0x0000000030016870
x7 =            0x0000000000000001
x8 =            0xffffff8008f8c1b0
x9 =            0x0000000000001122
x10 =           0x0000000000000020
x11 =           0x00000000300115e8
x12 =           0x00000000300147c0
x13 =           0x0000000000000000
x14 =           0x000000003001bae4
x15 =           0x0000000030004968
x16 =           0x00000000600001c5
x17 =           0xffffff8008091b64
x18 =           0x0000000000000735
x19 =           0x0000000030004a44
x20 =           0x0000000000000000
x21 =           0xffffff80093e3b48
x22 =           0xffffff80093e3ce8
x23 =           0xffffff800a19d000
x24 =           0x0000000000000000
x25 =           0x0000000000000000
x26 =           0x0000000000000000
x27 =           0x0000000000000000
x28 =           0x0000000000000000
x29 =           0x00000000300147a0
scr_el3 =               0x0000000000000735
sctlr_el3 =             0x0000000030cd183f
cptr_el3 =              0x0000000000000000
tcr_el3 =               0x000000008081351d
daif =          0x00000000000003c0
mair_el3 =              0x00000000004404ff
spsr_el3 =              0x00000000200002cc
elr_el3 =               0x0000000030004a2c
ttbr0_el3 =             0x000000003001b600
esr_el3 =               0x0000000096000061
far_el3 =               0x0000000030004a44
spsr_el1 =              0x0000000000000000
elr_el1 =               0x0000000000000000
spsr_abt =              0x0000000000000000
spsr_und =              0x0000000000000000
spsr_irq =              0x0000000000000000
spsr_fiq =              0x0000000000000000
sctlr_el1 =             0x0000000034d5d91d
actlr_el1 =             0x0000000000000001
cpacr_el1 =             0x0000000000300000
csselr_el1 =            0x0000000000000000
sp_el1 =                0xffffffc1ecb8ff00
esr_el1 =               0x0000000000000000
ttbr0_el1 =             0x000000008239c000
ttbr1_el1 =             0x0000000082437000
mair_el1 =              0x0000bbff440c0400
amair_el1 =             0x0000000000000000
tcr_el1 =               0x00000032b5593519
tpidr_el1 =             0x00000041ec721000
tpidr_el0 =             0x0000000000000000
tpidrro_el0 =           0x0000000000000000
dacr32_el2 =            0x0000000000000000
ifsr32_el2 =            0x0000000000000000
par_el1 =               0x0000000000000000
mpidr_el1 =             0x0000000080000000
afsr0_el1 =             0x0000000000000000
afsr1_el1 =             0x0000000000000000
contextidr_el1 =                0x0000000000000000
vbar_el1 =              0xffffff8008081800
cntp_ctl_el0 =          0x0000000000000000
cntp_cval_el0 =         0x0000000000000000
cntv_ctl_el0 =          0x0000000000000000
cntv_cval_el0 =         0x0000000000000000
cntkctl_el1 =           0x0000000000000002
fpexc32_el2 =           0x0000000000000700
sp_el0 =                0x00000000300147a0
isr_el1 =               0x0000000000000000
gicc_hppir =            0x00000000000003ff
gicc_ahppir =           0x00000000000003ff
gicc_ctlr =             0x000000000000000b
gicd_ispendr regs (Offsets 0x200 - 0x278)
 Offset:                        value
0000000000000200:               0x0000000000000000
0000000000000204:               0x0000000000000000
0000000000000208:               0x0000000000000000
000000000000020c:               0x0000000000000000
0000000000000210:               0x0000000000000000
0000000000000214:               0x0000000000000000
0000000000000218:               0x0000000000010000
000000000000021c:               0x0000000000000010
0000000000000220:               0x0000000000000000
0000000000000224:               0x0000000000000000
0000000000000228:               0x0000000000000000
000000000000022c:               0x0000000000000000
0000000000000230:               0x0000000000000000
0000000000000234:               0x0000000000000000
0000000000000238:               0x0000000000000000
000000000000023c:               0x0000000000000000
0000000000000240:               0x0000000000000000
0000000000000244:               0x0000000000000000
0000000000000248:               0x0000000000000000
000000000000024c:               0x0000000000000000
0000000000000250:               0x0000000000000000
0000000000000254:               0x0000000000000000
0000000000000258:               0x0000000000000000
000000000000025c:               0x0000000000000000
0000000000000260:               0x0000000000000000
0000000000000264:               0x0000000000000000
0000000000000268:               0x0000000000000000
000000000000026c:               0x0000000000000000
0000000000000270:               0x0000000000000000
0000000000000274:               0x0000000000000000
0000000000000278:               0x0000000000000000
000000000000027c:               0x0000000000000000
x6 =            0x0000000030016aa0
x12 =           0x0000000030014bc0
x29 =           0x0000000030014ba0
sp_el1 =                0xffffffc1ecb93f00
tpidr_el1 =             0x00000041ec739000
mpidr_el1 =             0x0000000080000001
sp_el0 =                0x0000000030014ba0
 Offset:                        value
[   10.320709] CPU1: failed to come online
[   10.320721] CPU1: failed in unknown state : 0x0
[   20.560720] CPU2: failed to come online
[   20.560729] CPU2: failed in unknown state : 0x0
[   22.646312] cgroup: cgroup2: unknown option "nsdelegate"
[   23.763706] using random self ethernet address
[   23.781576] using random host ethernet address
[   23.898981] random: systemd: uninitialized urandom read (16 bytes read)
[   23.909501] random: systemd: uninitialized urandom read (16 bytes read)
[   23.918607] random: systemd: uninitialized urandom read (16 bytes read)
[   24.101456] random: crng init done
[   24.101460] random: 172 urandom warning(s) missed due to ratelimiting
[   24.560429] using random self ethernet address
[   24.569459] using random host ethernet address
[   25.649817] device-mapper: table: 253:0: thin-pool: unknown target type
[   25.669452] device-mapper: ioctl: error adding target to table
Ubuntu 18.04.6 LTS ubuntu ttyS0
ubuntu login: [   31.103786] device-mapper: table: 253:0: thin-pool: unknown tae
[   31.103788] device-mapper: ioctl: error adding target to table
[   35.253785] device-mapper: table: 253:0: thin-pool: unknown target type
[   35.253787] device-mapper: ioctl: error adding target to table
At the same time,my TX2 still showed like my post’s video just now.
Then does everything work fine with 4.6.4 before you downgrade it?
Is there any reason you have to use 4.6.3 instead of 4.6.4?
Does re-flashing make any difference?
Because I want to run the model on Jetpack 4.6.3.I have posted the question,and a person said that my model can run on Jetpack 4.6.3(
Failed to build engine.py on the Jetson TX2 jetpack 4.4 - #4 by p12115803156),I have tried to run the same model on Jetpack 4.6.4,but it failed. I’m wondering if the Jetpack version is the reason why the model doesn’t run.So I want to try to downgrade the Jetpack version to 4.6.3.
hello,I can use ssh to connect my TX2.Does this help with the problem I’m having
After black screen,now,my TX2 showed…
then is everything working fine after logging in via SSH except the EL3 exception and GUI not working?
Can you remove the quiet option in /boot/extlinux/extlinux.conf, reboot, and collect kernel log with sudo dmesg?
Please also show the content of /var/log/Xorg.0.log.
I changed the content in /boot/extlinux/extlinux.conf,maybe the reason is that I have changed the default boot option from eMMc to SD card before I flashed the TX2,and the SD card is always inserted in the machine when refreshing and booting,so it got wrong.After I restored the contents of the extlinux.conf like this
and reboot it. It can worked!And its JetPack version successfully refreshed to the version 4.6.3.
Thank you!
