Hello, I am trying to flash JetPack 4.6 on my Jetson TX2 P3310 with a host Ubuntu 20.04. I have flashed JetPack 4.3 before but cannot flash JetPack 4.6.
I have tried running sdkmanager and also with the flash.sh file in the Linux_for_Tegra directory using sudo ./flash.sh jetson-tx2 mmcblk0p1, both fail at the message “CPU Bootloader is not running on device”.
I have also tried the command sudo ./flash.sh -r jetson-tx2 mmcblk0p1 to use the build image created in the first attempt. This helped me with JetPack 4.3 but does not work on JetPack 4.6.
The complete output looks like:
# L4T BSP Information:
# R32 , REVISION: 6.1
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0052 ] Generating RCM messages
[ 0.0073 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0081 ] RCM 0 is saved as rcm_0.rcm
[ 0.0085 ] RCM 1 is saved as rcm_1.rcm
[ 0.0085 ] List of rcm files are saved in rcm_list.xml
[ 0.0085 ]
[ 0.0085 ] Signing RCM messages
[ 0.0107 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0107 ] Assuming zero filled SBK key
[ 0.0166 ] Copying signature to RCM mesages
[ 0.0188 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0199 ]
[ 0.0200 ] Boot Rom communication
[ 0.0218 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0227 ] RCM version 0X180001
[ 0.0236 ] Boot Rom communication completed
[ 1.0299 ]
[ 2.0342 ] tegrarcm_v2 --isapplet
[ 2.0358 ] Applet version 01.00.0000
[ 2.0382 ]
[ 2.0412 ] Retrieving EEPROM data
[ 2.0414 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0430 ] Applet version 01.00.0000
[ 2.0453 ] Saved platform info in /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1185 ]
Board ID(3310) version(D00) sku(1000) revision(E.0)
Copy /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec
copying bctfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)... done.
copying misc_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img kernel
version 1.0.0
[ 0.0004 ] Generating signature
[ 0.0029 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0030 ] Assuming zero filled SBK key : not reading
[ 0.0029 ] sign_type : 0
[ 0.0029 ] header_magic: 414e4452
[ 0.0039 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0049 ]
[ 0.0067 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img zerosbk
[ 0.0083 ]
[ 0.0110 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0110 ] Assuming zero filled SBK key : not reading
[ 0.0267 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0293 ]
[ 0.0303 ] Signed file: /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don't need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/ramdisk_tmp /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/ramdisk_tmp/lib /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/ramdisk_tmp /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra
66121 blocks
Making Recovery image...
copying recdtbfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0,00018649 s, 107 kB/s
Existing sosfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-quill-p3310-1000-c03-00-base.dtb kernel_dtb
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0032 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0033 ] Assuming zero filled SBK key : not reading
[ 0.0032 ] sign_type : 808464433
[ 0.0032 ] header_magic: d00dfeed
[ 0.0053 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 0.0061 ]
[ 0.0082 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 0.0096 ]
[ 0.0124 ] tegrasign_v3.py --key --list 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0124 ] Assuming zero filled SBK key : not reading
[ 0.0243 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 0.0256 ]
[ 0.0261 ] Signed file: /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
done.
Reusing existing system.img...
done.
Existing tbcfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb"
saving flash command in /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/kcarvajal/work/devdirs/dso/JetPack_4.6_Jetson_TX2/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0097 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0098 ] Assuming zero filled SBK key
[ 0.0023 ] Generating RCM messages
[ 0.0042 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0048 ] RCM 0 is saved as rcm_0.rcm
[ 0.0051 ] RCM 1 is saved as rcm_1.rcm
[ 0.0051 ] List of rcm files are saved in rcm_list.xml
[ 0.0051 ]
[ 0.0051 ] Signing RCM messages
[ 0.0145 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0146 ] Assuming zero filled SBK key
[ 0.0261 ] Copying signature to RCM mesages
[ 0.0290 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0541 ]
[ 0.0542 ] Parsing partition layout
[ 0.0581 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0741 ]
[ 0.0743 ] Using default ramcode: 0
[ 0.0743 ] Disable BPMP dtb trim, using default dtb
[ 0.0743 ]
[ 0.0743 ] Creating list of images to be signed
[ 0.0777 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.2052 ]
[ 0.2052 ] Generating signatures
[ 0.2153 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2153 ] Assuming zero filled SBK key
[ 1.4836 ] Generating br-bct
[ 1.4866 ] Updating dev and MSS params in BR BCT
[ 1.4868 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 1.5253 ]
[ 1.5254 ] Updating bl info
[ 1.5284 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.5302 ]
[ 1.5302 ] Updating smd info
[ 1.5322 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 1.5332 ]
[ 1.5332 ] Updating Odmdata
[ 1.5350 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
[ 1.5359 ]
[ 1.5359 ] Get Signed section of bct
[ 1.5377 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 1.5386 ]
[ 1.5405 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 1.5414 ] Assuming zero filled SBK key
[ 1.5668 ]
[ 1.5668 ] Updating BCT with signature
[ 1.5692 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 1.5705 ]
[ 1.5706 ] Generating coldboot mb1-bct
[ 1.5726 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.5734 ] MB1-BCT version: 0xf
[ 1.5736 ] Packing sdram param for instance[0]
[ 1.5994 ] Packing sdram param for instance[1]
[ 1.5996 ] Packing sdram param for instance[2]
[ 1.5997 ] Packing sdram param for instance[3]
[ 1.5999 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.6001 ] Appending platform config data of size :- 3032
[ 1.6003 ] Parsing config file :mobile_scr.cfg
[ 1.6004 ] Appending platform config data of size :- 12240
[ 1.6011 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.6013 ] Appending platform config data of size :- 24
[ 1.6013 ]
[ 1.6013 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.6013 ] Appending platform config data of size :- 672
[ 1.6013 ]
[ 1.6013 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.6014 ] Appending platform config data of size :- 64
[ 1.6014 ]
[ 1.6014 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.6014 ] Appending platform config data of size :- 1628
[ 1.6014 ]
[ 1.6014 ] Updating mb1-bct with firmware information
[ 1.6037 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.6046 ] MB1-BCT version: 0xf
[ 1.6049 ]
[ 1.6049 ] Updating mb1-bct with storage information
[ 1.6070 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.6079 ] MB1-BCT version: 0xf
[ 1.6083 ]
[ 1.6107 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 1.6117 ]
[ 1.6139 ] tegrahost_v2 --chip 0x18 0 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 1.6148 ]
[ 1.6245 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.6246 ] Assuming zero filled SBK key
[ 1.6220 ] tegrahost_v2 --chip 0x18 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 1.6230 ]
[ 1.6231 ] Generating recovery mb1-bct
[ 1.6255 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.6273 ] MB1-BCT version: 0xf
[ 1.6275 ] Packing sdram param for instance[0]
[ 1.6515 ] Packing sdram param for instance[1]
[ 1.6517 ] Packing sdram param for instance[2]
[ 1.6518 ] Packing sdram param for instance[3]
[ 1.6519 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.6521 ] Appending platform config data of size :- 3032
[ 1.6523 ] Parsing config file :minimal_scr.cfg
[ 1.6524 ] Appending platform config data of size :- 12240
[ 1.6538 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.6540 ] Appending platform config data of size :- 24
[ 1.6542 ]
[ 1.6542 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.6542 ] Appending platform config data of size :- 672
[ 1.6543 ]
[ 1.6543 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.6543 ] Appending platform config data of size :- 64
[ 1.6543 ]
[ 1.6543 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.6543 ] Appending platform config data of size :- 1628
[ 1.6543 ]
[ 1.6543 ] Updating mb1-bct with firmware information
[ 1.6568 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.6580 ] MB1-BCT version: 0xf
[ 1.6588 ]
[ 1.6589 ] Updating mb1-bct with storage information
[ 1.6615 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.6626 ] MB1-BCT version: 0xf
[ 1.6630 ]
[ 1.6650 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 1.6659 ]
[ 1.6678 ] tegrahost_v2 --chip 0x18 0 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.6688 ]
[ 1.6788 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.6789 ] Assuming zero filled SBK key
[ 1.6768 ] tegrahost_v2 --chip 0x18 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.6783 ]
[ 1.6784 ] Copying signatures
[ 1.6806 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.8167 ]
[ 1.8168 ] Boot Rom communication
[ 1.8190 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 1.8197 ] BootRom is not running
[ 7.3865 ]
[ 8.3911 ] tegrarcm_v2 --isapplet
[ 1022.1709 ]
[ 1022.1746 ] tegradevflash_v2 --iscpubl
[ 1022.1764 ] CPU Bootloader is not running on device.
[ 2037.9785 ]
[ 2038.9835 ] tegrarcm_v2 --isapplet
Do you have any suggestions?
