Hello everyone,
i am using a computer with an new and fresh installed Ubuntu 16.04 LTS. My computer is complete empty and new, the disk has 500 GB of data.
I downloaded the Jetpack 3.2 and i tried installing it with my Host PC almost the whole day.
I can download and install everything correctly until it comes to the flashing of the TX2. I tried different USB ports on my host PC, i checked the USB connection everytime and i can see the NVIDIA Corp. when i enter the “lsusb” command.
Everytime i try to flash the Jetson i get the following error:
Error: Return value 3 Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
This is an excerpt from the Log
tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 9.0216 ] MB1-BCT version: 0xe
[ 9.0219 ] Copying Sdram info from 2 to 3 set
[ 9.0429 ] Packing sdram param for instance[0]
[ 9.0434 ] Packing sdram param for instance[1]
[ 9.0439 ] Packing sdram param for instance[2]
[ 9.0445 ] Packing sdram param for instance[3]
[ 9.0448 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 9.0459 ] Appending platform config data of size :- 2904
[ 9.0465 ] Parsing config file :minimal_scr.cfg
[ 9.0469 ] Appending platform config data of size :- 12240
[ 9.0777 ]
[ 9.0777 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 9.0777 ] Appending platform config data of size :- 24
[ 9.0777 ]
[ 9.0777 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 9.0777 ] Appending platform config data of size :- 744
[ 9.0778 ]
[ 9.0778 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 9.0778 ] Appending platform config data of size :- 64
[ 9.0778 ]
[ 9.0778 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 9.0778 ] Appending platform config data of size :- 1652
[ 9.0778 ]
[ 9.0779 ] Updating mb1-bct with firmware information
[ 9.0799 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 9.0814 ] MB1-BCT version: 0xe
[ 9.0965 ]
[ 9.0966 ] Updating mb1-bct with storage information
[ 9.0984 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 9.0999 ] MB1-BCT version: 0xe
[ 9.1551 ]
[ 9.1574 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 9.1593 ]
[ 9.1613 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 9.1631 ]
[ 9.1659 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 9.1678 ] Assuming zero filled SBK key
[ 9.1717 ]
[ 9.1737 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 9.1751 ]
[ 9.1752 ] Copying signatures
[ 9.1769 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 9.4438 ]
[ 9.4439 ] Boot Rom communication
[ 9.4453 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 9.4474 ] BootRom is not running
[ 10.4794 ]
[ 10.4825 ] tegrarcm_v2 --isapplet
[ 10.4853 ] Applet version 01.00.0000
[ 10.5018 ]
[ 10.5019 ] Retrieving board information
[ 10.5058 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 10.5083 ] Applet version 01.00.0000
[ 10.5421 ] Saved platform info in chip_info.bin
[ 10.5444 ] Chip minor revision: 2
[ 10.5459 ]
[ 10.5459 ] Sending BCTs
[ 10.5496 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 10.5506 ] Applet version 01.00.0000
[ 10.5697 ] Sending bct_bootrom
[ 1015.1831 ]
Failed flashing t186ref.
Right now, i have no idea where the issue is coming from. I tried a lot of things, nothing helped so far. In adittion, i tried it with another computer → Same problem. Please find attached the log file.Can you recommend something?
flash_os_tx2.log (445 Bytes)
