Jetson tx2 os flash error
When I use SDKManager to flash tx2. The progress has been stuck 99.8%. Could you teach me how to fix this problem?
09:47:46 INFO : Flash Jetson TX2 : *** Flashing target device started. ***
09:47:47 INFO : Flash Jetson TX2 : Welcome to Tegra Flash
09:47:47 INFO : Flash Jetson TX2 : version 1.0.0
09:47:47 INFO : Flash Jetson TX2 : Type ? or help for help and q or quit to exit
09:47:47 INFO : Flash Jetson TX2 : Use ! to execute system commands
09:47:47 INFO : Flash Jetson TX2 : [ 0.0256 ] tegrasign_v2 --key None --getmode mode.txt
09:47:47 INFO : Flash Jetson TX2 : [ 0.0265 ] Assuming zero filled SBK key
09:47:47 INFO : Flash Jetson TX2 : [ 0.0556 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.0557 ] Generating RCM messages
09:47:47 INFO : Flash Jetson TX2 : [ 0.0656 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
09:47:47 INFO : Flash Jetson TX2 : [ 0.0665 ] RCM 0 is saved as rcm_0.rcm
09:47:47 INFO : Flash Jetson TX2 : [ 0.0793 ] RCM 1 is saved as rcm_1.rcm
09:47:47 INFO : Flash Jetson TX2 : [ 0.0796 ] List of rcm files are saved in rcm_list.xml
09:47:47 INFO : Flash Jetson TX2 : [ 0.0853 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.0853 ] Signing RCM messages
09:47:47 INFO : Flash Jetson TX2 : [ 0.0882 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
09:47:47 INFO : Flash Jetson TX2 : [ 0.0900 ] Assuming zero filled SBK key
09:47:47 INFO : Flash Jetson TX2 : [ 0.1073 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.1074 ] Copying signature to RCM mesages
09:47:47 INFO : Flash Jetson TX2 : [ 0.1082 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
09:47:47 INFO : Flash Jetson TX2 : [ 0.1195 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.1195 ] Parsing partition layout
09:47:47 INFO : Flash Jetson TX2 : [ 0.1350 ] tegraparser_v2 --pt flash.xml.tmp
09:47:47 INFO : Flash Jetson TX2 : [ 0.1480 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.1480 ] Creating list of images to be signed
09:47:47 INFO : Flash Jetson TX2 : [ 0.1605 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
09:47:47 INFO : Flash Jetson TX2 : [ 0.3098 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.3099 ] Generating signatures
09:47:47 INFO : Flash Jetson TX2 : [ 0.3109 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
09:47:47 INFO : Flash Jetson TX2 : [ 0.3139 ] Assuming zero filled SBK key
09:47:47 INFO : Flash Jetson TX2 : [ 0.7357 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.7357 ] Generating br-bct
09:47:47 INFO : Flash Jetson TX2 : [ 0.7664 ] Updating dev and MSS params in BR BCT
09:47:47 INFO : Flash Jetson TX2 : [ 0.7665 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
09:47:47 INFO : Flash Jetson TX2 : [ 0.8315 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.8315 ] Updating bl info
09:47:47 INFO : Flash Jetson TX2 : [ 0.8324 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
09:47:47 INFO : Flash Jetson TX2 : [ 0.8487 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.8487 ] Updating smd info
09:47:47 INFO : Flash Jetson TX2 : [ 0.8496 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
09:47:47 INFO : Flash Jetson TX2 : [ 0.8624 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.8624 ] Updating Odmdata
09:47:47 INFO : Flash Jetson TX2 : [ 0.8633 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
09:47:47 INFO : Flash Jetson TX2 : [ 0.8799 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.8800 ] Get Signed section of bct
09:47:47 INFO : Flash Jetson TX2 : [ 0.8808 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
09:47:47 INFO : Flash Jetson TX2 : [ 0.8917 ]
09:47:47 INFO : Flash Jetson TX2 : [ 0.8925 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
09:47:47 INFO : Flash Jetson TX2 : [ 0.8933 ] Assuming zero filled SBK key
09:47:48 INFO : Flash Jetson TX2 : [ 0.9038 ]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9039 ] Updating BCT with signature
09:47:48 INFO : Flash Jetson TX2 : [ 0.9047 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
09:47:48 INFO : Flash Jetson TX2 : [ 0.9225 ]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9225 ] Generating coldboot mb1-bct
09:47:48 INFO : Flash Jetson TX2 : [ 0.9235 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9263 ] MB1-BCT version: 0xf
09:47:48 INFO : Flash Jetson TX2 : [ 0.9265 ] Copying Sdram info from 2 to 3 set
09:47:48 INFO : Flash Jetson TX2 : [ 0.9570 ] Packing sdram param for instance[0]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9592 ] Packing sdram param for instance[1]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9595 ] Packing sdram param for instance[2]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9597 ] Packing sdram param for instance[3]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9607 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9611 ] Appending platform config data of size :- 3048
09:47:48 INFO : Flash Jetson TX2 : [ 0.9643 ] Parsing config file :mobile_scr.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9649 ] Appending platform config data of size :- 12240
09:47:48 INFO : Flash Jetson TX2 : [ 0.9673 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9676 ] Appending platform config data of size :- 24
09:47:48 INFO : Flash Jetson TX2 : [ 0.9685 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9689 ] Appending platform config data of size :- 648
09:47:48 INFO : Flash Jetson TX2 : [ 0.9704 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9722 ] Appending platform config data of size :- 64
09:47:48 INFO : Flash Jetson TX2 : [ 0.9746 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 0.9756 ] Appending platform config data of size :- 1628
09:47:48 INFO : Flash Jetson TX2 : [ 0.9759 ]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9759 ] Updating mb1-bct with firmware information
09:47:48 INFO : Flash Jetson TX2 : [ 0.9767 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
09:47:48 INFO : Flash Jetson TX2 : [ 0.9799 ] MB1-BCT version: 0xf
09:47:48 INFO : Flash Jetson TX2 : [ 0.9878 ]
09:47:48 INFO : Flash Jetson TX2 : [ 0.9879 ] Updating mb1-bct with storage information
09:47:48 INFO : Flash Jetson TX2 : [ 0.9886 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
09:47:48 INFO : Flash Jetson TX2 : [ 0.9919 ] MB1-BCT version: 0xf
09:47:48 INFO : Flash Jetson TX2 : [ 1.0053 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0062 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
09:47:48 INFO : Flash Jetson TX2 : [ 1.0157 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0165 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
09:47:48 INFO : Flash Jetson TX2 : [ 1.0265 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0276 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
09:47:48 INFO : Flash Jetson TX2 : [ 1.0285 ] Assuming zero filled SBK key
09:47:48 INFO : Flash Jetson TX2 : [ 1.0396 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0408 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
09:47:48 INFO : Flash Jetson TX2 : [ 1.0551 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0551 ] Generating recovery mb1-bct
09:47:48 INFO : Flash Jetson TX2 : [ 1.0560 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.0570 ] MB1-BCT version: 0xf
09:47:48 INFO : Flash Jetson TX2 : [ 1.0572 ] Copying Sdram info from 2 to 3 set
09:47:48 INFO : Flash Jetson TX2 : [ 1.0888 ] Packing sdram param for instance[0]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0906 ] Packing sdram param for instance[1]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0908 ] Packing sdram param for instance[2]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0911 ] Packing sdram param for instance[3]
09:47:48 INFO : Flash Jetson TX2 : [ 1.0915 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.0930 ] Appending platform config data of size :- 3048
09:47:48 INFO : Flash Jetson TX2 : [ 1.0947 ] Parsing config file :minimal_scr.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.0972 ] Appending platform config data of size :- 12240
09:47:48 INFO : Flash Jetson TX2 : [ 1.1289 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.1293 ] Appending platform config data of size :- 24
09:47:48 INFO : Flash Jetson TX2 : [ 1.1300 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.1320 ] Appending platform config data of size :- 648
09:47:48 INFO : Flash Jetson TX2 : [ 1.1347 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.1347 ] Appending platform config data of size :- 64
09:47:48 INFO : Flash Jetson TX2 : [ 1.1347 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
09:47:48 INFO : Flash Jetson TX2 : [ 1.1347 ] Appending platform config data of size :- 1628
09:47:48 INFO : Flash Jetson TX2 : [ 1.1348 ] Updating mb1-bct with firmware information
09:47:48 INFO : Flash Jetson TX2 : [ 1.1356 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
09:47:48 INFO : Flash Jetson TX2 : [ 1.1386 ] MB1-BCT version: 0xf
09:47:48 INFO : Flash Jetson TX2 : [ 1.1480 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.1480 ] Updating mb1-bct with storage information
09:47:48 INFO : Flash Jetson TX2 : [ 1.1489 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
09:47:48 INFO : Flash Jetson TX2 : [ 1.1522 ] MB1-BCT version: 0xf
09:47:48 INFO : Flash Jetson TX2 : [ 1.1597 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.1605 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
09:47:48 INFO : Flash Jetson TX2 : [ 1.1719 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.1727 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
09:47:48 INFO : Flash Jetson TX2 : [ 1.1837 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.1848 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
09:47:48 INFO : Flash Jetson TX2 : [ 1.1869 ] Assuming zero filled SBK key
09:47:48 INFO : Flash Jetson TX2 : [ 1.1998 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.2010 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
09:47:48 INFO : Flash Jetson TX2 : [ 1.2113 ]
09:47:48 INFO : Flash Jetson TX2 : [ 1.2114 ] Copying signatures
09:47:48 INFO : Flash Jetson TX2 : [ 1.2123 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
09:47:53 INFO : Flash Jetson TX2 : [ 1.3037 ]
09:47:53 INFO : Flash Jetson TX2 : [ 1.3038 ] Boot Rom communication
09:47:53 INFO : Flash Jetson TX2 : [ 1.3046 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
09:47:53 INFO : Flash Jetson TX2 : [ 1.3078 ] BootRom is not running
10:04:34 INFO : Flash Jetson TX2 : [ 6.4595 ]
10:04:34 INFO : Flash Jetson TX2 : [ 7.4607 ] tegrarcm_v2 --isapplet
10:21:30 INFO : Flash Jetson TX2 : [ 1007.6756 ]
10:21:30 INFO : Flash Jetson TX2 : [ 1007.6968 ] tegradevflash_v2 --iscpubl
10:21:30 INFO : Flash Jetson TX2 : [ 1007.6976 ] CPU Bootloader is not running on device.
Please use flash script directly and see if it stuck at same place
cd Linux_for_Tegra
sudo ./flash jetson-tx2 mmcblk0p1
  1. Are you using a VM?
  2. Could you change another usb cable?
I have the same problem. Using Linux OS, tried various USB cables… Was the problem solved?
Below is the final part of installation process
[ 0.3532 ] MB1-BCT version: 0xf
[ 0.3534 ] Copying Sdram info from 2 to 3 set
[ 0.3651 ] Packing sdram param for instance[0]
[ 0.3652 ] Packing sdram param for instance[1]
[ 0.3654 ] Packing sdram param for instance[2]
[ 0.3656 ] Packing sdram param for instance[3]
[ 0.3657 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.3660 ] Appending platform config data of size :- 3048
[ 0.3662 ] Parsing config file :minimal_scr.cfg
[ 0.3664 ] Appending platform config data of size :- 12240
[ 0.3673 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.3675 ] Appending platform config data of size :- 24
[ 0.3675 ]
[ 0.3675 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.3675 ] Appending platform config data of size :- 648
[ 0.3675 ]
[ 0.3675 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.3675 ]
[ 0.3675 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.3675 ] Appending platform config data of size :- 1628
[ 0.3675 ]
[ 0.3675 ] Updating mb1-bct with firmware information
[ 0.3681 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.3688 ] MB1-BCT version: 0xf
[ 0.3690 ]
[ 0.3691 ] Updating mb1-bct with storage information
[ 0.3697 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.3705 ] MB1-BCT version: 0xf
[ 0.3709 ]
[ 0.3716 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 0.3723 ]
[ 0.3729 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.3737 ]
[ 0.3745 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.3751 ] Assuming zero filled SBK key
[ 0.3762 ]
[ 0.3770 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.3777 ]
[ 0.3778 ] Copying signatures
[ 0.3784 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.3959 ]
[ 0.3960 ] Boot Rom communication
[ 0.3967 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.3974 ] BootRom is not running
[ 5.9104 ]
[ 6.9150 ] tegrarcm_v2 --isapplet
[ 1015.1311 ]
[ 1015.1418 ] tegradevflash_v2 --iscpubl
[ 1015.1448 ] CPU Bootloader is not running on device.
[ 2030.9394 ]
[ 2031.9441 ] tegrarcm_v2 --isapplet
[ 3046.7496 ]
[ 3046.7528 ] tegradevflash_v2 --iscpubl
[ 3046.7555 ] CPU Bootloader is not running on device.
[ 4062.5545 ]
[ 4063.5585 ] tegrarcm_v2 --isapplet
Are you using a VM? Was the log from JetPack, or from a command line? If command line, what was the command? Just noticed, this is a duplicate of:
https://devtalk.nvidia.com/default/topic/1072874/jetson-tx2/jetson-tx2-flash-problem/
(put any reply there)
To debug a flash problem, if you’ve clarified not using a VM, then please try to dump the UART log from serial console.
During the flash process, the device would still dump debug message from uart. Please share that log with us. Thanks.
