When press/release power on button, TX2 can not boot up.
The debug mesg from UART0 is
\0x00[0000.084] C> post mb1bct sequence failed
[0000.087] C> ERROR: Highest Layer Module = 0x3c, Lowest Layer Module = 0x3c,
Aux Info = 0x0, Reason = 0x6
And when try to flash kernel with ./flash -r -k kernel jetson-tx2 mmcblk0p1
the log is.
./tegraflash.py --chip 0x18 --applet "/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0018 ] Generating RCM messages
[ 0.0027 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0035 ] RCM 0 is saved as rcm_0.rcm
[ 0.0040 ] RCM 1 is saved as rcm_1.rcm
[ 0.0040 ] List of rcm files are saved in rcm_list.xml
[ 0.0040 ]
[ 0.0040 ] Signing RCM messages
[ 0.0049 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0058 ] Assuming zero filled SBK key
[ 0.0101 ]
[ 0.0101 ] Copying signature to RCM mesages
[ 0.0118 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0132 ]
[ 0.0133 ] Boot Rom communication
[ 0.0148 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0161 ] RCM version 0X180001
[ 0.0171 ] Boot Rom communication completed
[ 1.0232 ]
[ 1.0244 ] tegrarcm_v2 --isapplet
[ 1.0253 ] Applet version 01.00.0000
[ 1.0277 ]
[ 1.0287 ] Retrieving EEPROM data
[ 1.0288 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 1.0297 ] Applet version 01.00.0000
[ 1.0321 ] Saved platform info in /home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 1.1097 ]
Board ID(3310) version(B01)
copying bctfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/nvtboot.bin)... done.
Existing mb2blfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/spe.bin) reused.
copying wb0boot(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/tos.img) reused.
Existing eksfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/eks.img) reused.
copying dtbfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Reusing existing system.img...
done.
Existing tbcfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/sean/kernel/tools/64_TX2/Linux_for_Tegra_tx2/bootloader/tegraflash.py) reused.
*** Updating :kernel with boot.img ***
./flash.sh: 第 1617 行: [: -eq: 需要一元表达式
./tegraflash.py --bl nvtboot_recovery_cpu.bin --chip 0x18 --applet mb1_recovery_prod.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --cfg flash.xml --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb" --cmd "write kernel-dtb tegra186-quill-p3310-1000-c03-00-base.dtb; write kernel boot.img;"
version 1.0.0
[ 0.0057 ] Generating RCM messages
[ 0.0065 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0073 ] RCM 0 is saved as rcm_0.rcm
[ 0.0078 ] RCM 1 is saved as rcm_1.rcm
[ 0.0078 ] List of rcm files are saved in rcm_list.xml
[ 0.0078 ]
[ 0.0079 ] Signing RCM messages
[ 0.0088 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0095 ] Assuming zero filled SBK key
[ 0.0137 ]
[ 0.0138 ] Copying signature to RCM mesages
[ 0.0148 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0159 ]
[ 0.0159 ] Boot Rom communication
[ 0.0168 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 0.0177 ] BootRom is not running
[ 1.0161 ]
[ 1.0172 ] tegrarcm_v2 --isapplet
[ 1.0179 ] Applet version 01.00.0000
[ 1.0201 ]
[ 1.0210 ] tegrasign_v2 --key None --getmode mode.txt
[ 1.0220 ] Assuming zero filled SBK key
[ 1.0221 ]
[ 1.0221 ] Parsing partition layout
[ 1.0230 ] tegraparser_v2 --pt flash.xml.tmp
[ 1.0251 ]
[ 1.0252 ] Creating list of images to be signed
[ 1.0274 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 1.0346 ]
[ 1.0347 ] Generating signatures
[ 1.0355 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 1.0369 ] Assuming zero filled SBK key
[ 1.1523 ]
[ 1.1524 ] Reading BCT from device for further operations
[ 1.1524 ] Generating blob
[ 1.1533 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 1.1542 ]
[ 1.1550 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 1.1564 ]
[ 1.1575 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 1.1584 ] Assuming zero filled SBK key
[ 1.1644 ]
[ 1.1656 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 1.1676 ]
[ 1.1685 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 1.1693 ]
[ 1.1701 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 1.1713 ]
[ 1.1724 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 1.1732 ] Assuming zero filled SBK key
[ 1.1761 ]
[ 1.1771 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 1.1780 ]
[ 1.1789 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 1.1800 ]
[ 1.1812 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 1.1823 ]
[ 1.1847 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 1.1857 ] Assuming zero filled SBK key
[ 1.1880 ]
[ 1.1890 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 1.1900 ]
[ 1.1909 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 1.1918 ]
[ 1.1928 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 1.1973 ]
[ 1.1983 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 1.1991 ] Assuming zero filled SBK key
[ 1.2586 ]
[ 1.2600 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 1.2635 ]
[ 1.2646 ] tegrahost_v2 --align blob_bpmp.bin
[ 1.2654 ]
[ 1.2662 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 1.2680 ]
[ 1.2690 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 1.2698 ] Assuming zero filled SBK key
[ 1.2856 ]
[ 1.2869 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 1.2889 ]
[ 1.2908 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 1.2918 ]
[ 1.2929 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 1.2947 ]
[ 1.2958 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 1.2966 ] Assuming zero filled SBK key
[ 1.3106 ]
[ 1.3117 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 1.3131 ]
[ 1.3140 ] tegrahost_v2 --align blob_tos.img
[ 1.3148 ]
[ 1.3156 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 1.3170 ]
[ 1.3185 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 1.3196 ] Assuming zero filled SBK key
[ 1.3219 ]
[ 1.3229 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 1.3238 ]
[ 1.3247 ] tegrahost_v2 --align blob_eks.img
[ 1.3255 ]
[ 1.3264 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 1.3273 ]
[ 1.3286 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 1.3294 ] Assuming zero filled SBK key
[ 1.3297 ]
[ 1.3308 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 1.3317 ]
[ 1.3327 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 1.3336 ]
[ 1.3346 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 1.3360 ]
[ 1.3369 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 1.3376 ] Assuming zero filled SBK key
[ 1.3460 ]
[ 1.3469 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 1.3482 ]
[ 1.3496 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 1.3505 ] number of images in blob are 9
[ 1.3509 ] blobsize is 3723704
[ 1.3511 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 184576
[ 1.3541 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 78080
[ 1.3546 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 61472
[ 1.3552 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2077088
[ 1.3562 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 528800
[ 1.3568 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 1.3577 ] Added binary blob_tos_sigheader.img.encrypt of size 58880
[ 1.3581 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 1.3586 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 267008
[ 1.3599 ]
[ 1.3599 ] Sending bootloader and pre-requisite binaries
[ 1.3608 ] tegrarcm_v2 --download blob blob.bin
[ 1.3615 ] Applet version 01.00.0000
[ 1.3638 ] Sending blob
log got from Uart0 is
\0x00[0008.033] I> Welcome to MB1-recovery(prd-version : 12.01.170704-t186-M-00.00-17d56c3b)
[0008.041] I> rst_source : 0x0
[0008.043] I> rst_level : 0x0
[0008.046] I> Read lock all AES keyslots
[0008.050] I> Read lock all RSA keyslots
[0008.053] I> Clear SE keyslots left open by BR
[0008.058] I> Boot-device: eMMC
[0008.081] I> sdmmc ddr50 mode
[0008.084] I> Entering into 3p server..
[0008.088] I> Transport interface is USB
[0008.092] I> tegrabl_usbf_priv_init:2576 full init:: [0008.096] I> HIGH SPEED
[0008.498] W> Get desc.Unsupported req: desc_index = 0
[0008.504] I> transport_usbf_priv_open USB configuration success
[0009.014] W> Get desc.Unsupported req: desc_index = 0
[0009.044] I> Populate eeprom info for module cvm
[0012.023] I> bit @ 0xd480000
[0012.026] I> BCT @ 0x0
[0012.028] I> Boot-device: eMMC
[0012.033] I> Binary(18) of size 3584 is loaded @ 0x4004e800
[0012.038] I> Binary(18) of size 3584 is loaded @ 0x4004e800
[0012.044] E> Blob is not set
[0012.046] I> Boot-device: eMMC
[0012.049] I> BR-BCT @ 0x4004e800
[0012.052] I> MB1-BCT @ block-576 (partition-size: 0x10000)
[0012.060] I> Binary(0) of size 49600 is loaded @ 0x40041000
[0012.066] I> Binary(0) of size 49600 is loaded @ 0x40041000
[0012.071] I> MB1-BCT relocated to 0xd48bc00 from 0x40041000
[0012.077] I> Supported mb1-bct versions 9-14
[0012.081] I> Version of mb1 bct binary 14
[0012.085] W> MB1 BCT does not have controller prod config data
[0012.091] I> Bootrom patch version : 31 (correctly patched)
[0012.096] I> ATE fuse revision : 0x508a0
[0012.100] I> chip revision : A02P
[0012.103] I> disabled_core_mask: 0xffffff0c
[0012.107] I> Enabled Cores: 0xf3
[0012.110] I> TPC disable fuse status: 0
[0012.114] I> Booting Parker Sku
[0012.117] I> Ram repair fuse : 0x0
[0012.120] I> Mem length:2000
[0012.123] I> tegrabl_ast_init_mapper: AST-cache dump
[0012.128] I> allocated(CO:30) base:0x278000000 size:0x8000000 align: 0x8000000
[0012.135] I> allocated(CO:23) base:0xf0100000 size:0x10000 align: 0x10000
[0012.142] I> allocated(CO:31) base:0x0 size:0x0 align: 0x0
[0012.147] I> allocated(CO:1) base:0x277f00000 size:0x100000 align: 0x100000
[0012.154] I> allocated(CO:2) base:0x277e00000 size:0x100000 align: 0x100000
[0012.161] I> allocated(CO:3) base:0x277d00000 size:0x100000 align: 0x100000
[0012.168] I> allocated(CO:4) base:0x277c00000 size:0x100000 align: 0x100000
[0012.174] I> allocated(CO:5) base:0x277b00000 size:0x100000 align: 0x100000
[0012.181] I> allocated(CO:27) base:0x0 size:0x0 align: 0x0
[0012.187] I> allocated(CO:6) base:0x277800000 size:0x200000 align: 0x200000
[0012.194] I> allocated(CO:7) base:0x277400000 size:0x400000 align: 0x400000
[0012.200] I> allocated(CO:8) base:0x277a00000 size:0x100000 align: 0x100000
[0012.207] I> allocated(CO:9) base:0x277300000 size:0x100000 align: 0x100000
[0012.214] I> allocated(CO:10) base:0x276800000 size:0x800000 align: 0x800000
[0012.221] I> allocated(CO:11) base:0x30000000 size:0x40000 align: 0x0
[0012.228] I> allocated(CO:12) base:0xf0000000 size:0x100000 align: 0x100000
[0012.234] I> allocated(CO:13) base:0x30040000 size:0x1000 align: 0x0
[0012.241] I> allocated(CO:14) base:0x30048000 size:0x1000 align: 0x0
[0012.247] I> allocated(CO:15) base:0x30049000 size:0x1000 align: 0x0
[0012.253] I> allocated(CO:16) base:0x3004a000 size:0x1000 align: 0x0
[0012.259] I> allocated(CO:17) base:0x3004b000 size:0x1000 align: 0x0
[0012.266] I> allocated(CO:19) base:0x3004d000 size:0x1000 align: 0x0
[0012.272] I> allocated(CO:18) base:0x3004c000 size:0x1000 align: 0x0
[0012.278] I> allocated(CO:20) base:0x3004e000 size:0x1000 align: 0x0
[0012.284] I> allocated(CO:21) base:0x3004f000 size:0x1000 align: 0x0
[0012.291] I> allocated(CO:22) base:0x0 size:0x0 align: 0x0
[0012.296] I> allocated(CO:32) base:0x276000000 size:0x600000 align: 0x400000
[0012.303] I> allocated(CO:24) base:0x0 size:0x0 align: 0x0
[0012.308] I> allocated(CO:25) base:0x0 size:0x0 align: 0x0
[0012.314] I> allocated(CO:26) base:0x0 size:0x0 align: 0x0
[0012.319] I> allocated(CO:39) base:0x96000000 size:0x2000000 align: 0x2000000
[0012.326] I> allocated(CO:38) base:0x84000000 size:0x400000 align: 0x400000
[0012.333] I> allocated(CO:37) base:0x2772e0000 size:0x20000 align: 0x20000
[0012.340] I> allocated(CO:40) base:0x84800000 size:0xb00000 align: 0x800000
[0012.347] I> allocated(CO:41) base:0x277200000 size:0x80000 align: 0x80000
[0012.353] I> allocated(CO:28) base:0x84400000 size:0x400000 align: 0x400000
[0012.525] !!! Exception !!! [lr:0x4002245c, dfar:0x5851000, dfsr:0x1808]
[0012.532] MB1-BIT() boot status dump :
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0012.560] Last seen error : 0x00000000
