TX2 Module Failure?
There was a utility power failure and the TX2 Module/dev board that I had been using just up to the time of the failure now does not boot.
In the serial console on boot this is all I get:
[0002.006] C> MTS error (2) : dram alias check failure
[0002.011] C> cpu waypoint 0.5 failed
[0002.014] C> ERROR: Highest Layer Module = 0x32, Lowest Layer Module = 0x32,
Aux Info = 0x1, Reason = 0x6
On a host it shows up in lsusb, but flashing fails as show below:
troll@ubuntu:~$ lsusb
Bus 001 Device 004: ID 0955:7c18 NVidia Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
troll@ubuntu:~$ cd JetPack31/64_TX2/Linux_for_Tegra_tx2/
troll@ubuntu:~/JetPack31/64_TX2/Linux_for_Tegra_tx2$ ls
apply_binaries.sh  jetson-tx2.conf  p2771-0000.conf.common       rootfs
bootloader         kernel           p2771-0000-devkit.conf       source_sync.sh
flash.sh           nv_tegra         p2771-0000-dsi-hdmi-dp.conf
troll@ubuntu:~/JetPack31/64_TX2/Linux_for_Tegra_tx2$ sudo ./flash.sh -r jetson-tx2 mmcblk0p1
[sudo] password for troll:
./tegraflash.py --chip 0x18 --applet "/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0342 ] Generating RCM messages
[   0.0371 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[   0.0379 ] RCM 0 is saved as rcm_0.rcm
[   0.0506 ] RCM 1 is saved as rcm_1.rcm
[   0.0506 ] List of rcm files are saved in rcm_list.xml
[   0.0506 ]
[   0.0506 ] Signing RCM messages
[   0.0606 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0617 ] Assuming zero filled SBK key
[   0.0769 ]
[   0.0769 ] Copying signature to RCM mesages
[   0.0778 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[   0.0795 ]
[   0.0796 ] Boot Rom communication
[   0.0803 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[   0.0815 ] RCM version 0X180001
[   0.1867 ] Boot Rom communication completed
[   1.2065 ]
[   1.2079 ] tegrarcm_v2 --isapplet
[   1.2087 ] USB communication failed.Check if device is in recovery
[   1.3142 ]
[   1.3194 ] tegradevflash_v2 --iscpubl
[   1.3203 ] CPU Bootloader is not running on device.
[   1.4503 ]
[   2.5961 ] Retrieving EEPROM data
[   2.5962 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[   2.5971 ] Applet version 01.00.0000
[   2.8630 ] Saved platform info in /home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[   3.0050 ]
Board ID(3310) version(B00)
copying bctfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg)... done.
copying pmc_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_cpu.bin) reused.
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating extlinux.conf.emmc to rootfs... done.
	populating /home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/nvtboot.bin)... done.
Existing mb2blfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/spe.bin) reused.
copying wb0boot(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/tos.img) reused.
Existing eksfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/eks.img) reused.
copying dtbfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Reusing existing system.img...
done.
Existing tbcfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg  --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb"
saving flash command in /home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/flashcmd.txt
saving flash parameters in /home/troll/JetPack31/64_TX2/Linux_for_Tegra_tx2/bootloader/flash_parameters.txt
*** Flashing target device started. ***
version 1.0.0
[   0.0031 ] tegrasign_v2 --key None --getmode mode.txt
[   0.0048 ] Assuming zero filled SBK key
[   0.0049 ]
[   0.0049 ] Generating RCM messages
[   0.0063 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[   0.0071 ] RCM 0 is saved as rcm_0.rcm
[   0.0074 ] RCM 1 is saved as rcm_1.rcm
[   0.0074 ] List of rcm files are saved in rcm_list.xml
[   0.0074 ]
[   0.0074 ] Signing RCM messages
[   0.0082 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0090 ] Assuming zero filled SBK key
[   0.0120 ]
[   0.0120 ] Copying signature to RCM mesages
[   0.0128 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[   0.0143 ]
[   0.0143 ] Parsing partition layout
[   0.0185 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0256 ]
[   0.0256 ] Creating list of images to be signed
[   0.0282 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[   0.0841 ]
[   0.0843 ] Generating signatures
[   0.0856 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[   0.0865 ] Assuming zero filled SBK key
[   0.1932 ]
[   0.1934 ] Generating br-bct
[   0.1976 ] Updating dev and MSS params in BR BCT
[   0.1977 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[   0.2236 ]
[   0.2237 ] Updating bl info
[   0.2256 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   0.2294 ]
[   0.2295 ] Updating smd info
[   0.2309 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[   0.2325 ]
[   0.2325 ] Updating Odmdata
[   0.2333 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[   0.2345 ]
[   0.2345 ] Get Signed section bct
[   0.2352 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[   0.2377 ]
[   0.2378 ] Signing BCT
[   0.2392 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[   0.2399 ] Assuming zero filled SBK key
[   0.2402 ]
[   0.2403 ] Updating BCT with signature
[   0.2410 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[   0.2423 ]
[   0.2423 ] Generating coldboot mb1-bct
[   0.2431 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   0.2438 ] MB1-BCT version: 0xe
[   0.2440 ] Copying Sdram info from 2 to 3 set
[   0.2535 ] Copying Sdram info from 0 to 1 set
[   0.2567 ] Packing sdram param for instance[0]
[   0.2570 ] Packing sdram param for instance[1]
[   0.2573 ] Packing sdram param for instance[2]
[   0.2587 ] Packing sdram param for instance[3]
[   0.2588 ]
[   0.2588 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[   0.2588 ] Appending platform config data of size :- 2904
[   0.2588 ]
[   0.2588 ] Parsing config file :mobile_scr.cfg
[   0.2588 ] Appending platform config data of size :- 12240
[   0.2588 ]
[   0.2588 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[   0.2588 ] Appending platform config data of size :- 24
[   0.2588 ]
[   0.2588 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[   0.2588 ] Appending platform config data of size :- 744
[   0.2588 ]
[   0.2588 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[   0.2588 ] Appending platform config data of size :- 64
[   0.2589 ]
[   0.2589 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   0.2589 ] Appending platform config data of size :- 1628
[   0.2589 ]
[   0.2589 ] Updating mb1-bct with firmware information
[   0.2601 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   0.2610 ] MB1-BCT version: 0xe
[   0.2625 ]
[   0.2626 ] Updating mb1-bct with storage information
[   0.2637 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   0.2646 ] MB1-BCT version: 0xe
[   0.2669 ]
[   0.2678 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[   0.2686 ]
[   0.2693 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   0.2702 ]
[   0.2711 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[   0.2718 ] Assuming zero filled SBK key
[   0.2733 ]
[   0.2742 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   0.2754 ]
[   0.2754 ] Generating recovery mb1-bct
[   0.2769 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   0.2778 ] MB1-BCT version: 0xe
[   0.2779 ] Copying Sdram info from 2 to 3 set
[   0.2907 ] Copying Sdram info from 0 to 1 set
[   0.2910 ] Packing sdram param for instance[0]
[   0.2914 ] Packing sdram param for instance[1]
[   0.2928 ] Packing sdram param for instance[2]
[   0.2928 ] Packing sdram param for instance[3]
[   0.2929 ]
[   0.2929 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[   0.2929 ] Appending platform config data of size :- 2904
[   0.2929 ]
[   0.2929 ] Parsing config file :minimal_scr.cfg
[   0.2929 ] Appending platform config data of size :- 12240
[   0.2929 ]
[   0.2929 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[   0.2929 ] Appending platform config data of size :- 24
[   0.2929 ]
[   0.2929 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[   0.2929 ] Appending platform config data of size :- 744
[   0.2929 ]
[   0.2929 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[   0.2929 ] Appending platform config data of size :- 64
[   0.2929 ]
[   0.2929 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[   0.2930 ] Appending platform config data of size :- 1628
[   0.2930 ]
[   0.2930 ] Updating mb1-bct with firmware information
[   0.2940 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   0.2949 ] MB1-BCT version: 0xe
[   0.2963 ]
[   0.2964 ] Updating mb1-bct with storage information
[   0.2975 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   0.2984 ] MB1-BCT version: 0xe
[   0.3011 ]
[   0.3021 ] tegrahost_v2 --align mb1_bct_MB1.bct
[   0.3029 ]
[   0.3038 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[   0.3057 ]
[   0.3066 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[   0.3074 ] Assuming zero filled SBK key
[   0.3086 ]
[   0.3096 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   0.3106 ]
[   0.3107 ] Copying signatures
[   0.3114 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   0.3318 ]
[   0.3319 ] Boot Rom communication
[   0.3327 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[   0.3335 ] BootRom is not running
[   1.4601 ]
[   1.4611 ] tegrarcm_v2 --isapplet
[   1.4619 ] Applet version 01.00.0000
[   1.7275 ]
[   1.7276 ] Retrieving board information
[   1.7286 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   1.7296 ] Applet version 01.00.0000
[   1.9958 ] Saved platform info in chip_info.bin
[   2.0345 ] Chip minor revision: 2
[   2.0601 ]
[   2.0601 ] Sending BCTs
[   2.0617 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   2.0628 ] Applet version 01.00.0000
[   2.3248 ] Sending bct_bootrom
[   2.3251 ] [................................................] 100%
[   2.3657 ] Sending bct_mb1
[   2.3929 ] [................................................] 100%
[   2.8084 ]
[   2.8085 ] Generating blob
[   2.8094 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[   2.8102 ]
[   2.8113 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[   2.8124 ]
[   2.8133 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[   2.8139 ] Assuming zero filled SBK key
[   2.8205 ]
[   2.8219 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[   2.8238 ]
[   2.8253 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[   2.8266 ]
[   2.8275 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[   2.8284 ]
[   2.8293 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[   2.8300 ] Assuming zero filled SBK key
[   2.8326 ]
[   2.8341 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[   2.8352 ]
[   2.8388 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[   2.8413 ]
[   2.8422 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[   2.8438 ]
[   2.8453 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[   2.8460 ] Assuming zero filled SBK key
[   2.8483 ]
[   2.8498 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[   2.8508 ]
[   2.8517 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[   2.8525 ]
[   2.8532 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[   2.8676 ]
[   2.8686 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[   2.8723 ] Assuming zero filled SBK key
[   2.9286 ]
[   2.9304 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[   2.9342 ]
[   2.9352 ] tegrahost_v2 --align blob_bpmp.bin
[   2.9360 ]
[   2.9369 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[   2.9445 ]
[   2.9457 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[   2.9465 ] Assuming zero filled SBK key
[   2.9598 ]
[   2.9610 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[   2.9625 ]
[   2.9633 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb
[   2.9641 ]
[   2.9649 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb zerosbk
[   2.9665 ]
[   2.9675 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb_list.xml
[   2.9682 ] Assuming zero filled SBK key
[   2.9813 ]
[   2.9826 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[   2.9841 ]
[   2.9850 ] tegrahost_v2 --align blob_tos.img
[   2.9858 ]
[   2.9868 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[   2.9886 ]
[   2.9895 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[   2.9910 ] Assuming zero filled SBK key
[   2.9927 ]
[   2.9936 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[   2.9960 ]
[   2.9969 ] tegrahost_v2 --align blob_eks.img
[   2.9975 ]
[   2.9983 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[   3.0001 ]
[   3.0010 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[   3.0016 ] Assuming zero filled SBK key
[   3.0018 ]
[   3.0028 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   3.0038 ]
[   3.0073 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[   3.0082 ]
[   3.0095 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[   3.0108 ]
[   3.0123 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[   3.0136 ] Assuming zero filled SBK key
[   3.0204 ]
[   3.0215 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[   3.0228 ]
[   3.0239 ] tegrahost_v2 --generateblob blob.xml blob.bin
[   3.0253 ] number of images in blob are 9
[   3.0256 ] blobsize is 3725048
[   3.0258 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 184576
[   3.0434 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 78080
[   3.0438 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 61472
[   3.0443 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2077088
[   3.0532 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 528800
[   3.0541 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[   3.0553 ] Added binary blob_tos_sigheader.img.encrypt of size 58880
[   3.0559 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[   3.0564 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 268352
[   3.0667 ]
[   3.0668 ] Sending bootloader and pre-requisite binaries
[   3.0677 ] tegrarcm_v2 --download blob blob.bin
[   3.0694 ] Applet version 01.00.0000
[   3.3382 ] Sending blob
[   3.5810 ]
Error: Return value 1
Command tegrarcm_v2 --download blob blob.bin
Failed flashing t186ref.
And from the serial console:
[0076.891] I> Welcome to MB1-recovery(prd-version : 12.01.170704-t186-M-00.00-17
d56c3b)
[0076.899] I> rst_source : 0xb
[0076.902] I> rst_level : 0x1
[0076.905] I> Read lock all AES keyslots
[0076.909] I> Read lock all RSA keyslots
[0076.912] I> Clear SE keyslots left open by BR
[0076.917] I> Boot-device: eMMC
[0076.970] I> sdmmc ddr50 mode
[0076.974] I> Entering into 3p server..
[0076.978] I> Transport interface is USB
[0076.981] I> tegrabl_usbf_priv_init:2576 full init:: [0076.986] I>  HIGH SPEED
[0077.209] W> Get desc.Unsupported req: desc_index = 0
[0077.984] W> Get desc.Unsupported req: desc_index = 0
[0077.997] I> transport_usbf_priv_open USB configuration success
[0078.505] W> Get desc.Unsupported req: desc_index = 0
[0079.581] I> Populate eeprom info for module cvm
[0083.070] I> bit @ 0xd480000
[0083.083] I> Downloading bct_bootrom at 0x000000004004e800
[0083.098] I> downloaded image bct_bootrom successfully
[0083.150] I> Downloading bct_mb1 at 0x0000000040041000
[0083.170] I> MB1-BCT relocated to 0xd48bc00 from 0x40041000
[0083.176] I> Supported mb1-bct versions 9-14
[0083.180] I> Version of mb1 bct binary 14
[0083.184] W> MB1 BCT does not have controller prod config data
[0083.190] I> Last boot error = 0x190c8106
[0083.194] I> Bootrom patch version : 31 (correctly patched)
[0083.199] I> ATE fuse revision : 0x30880
[0083.203] I> chip revision : A02P
[0083.206] I> disabled_core_mask: 0xffffff0c
[0083.210] I> Enabled Cores: 0xf3
[0083.213] I> TPC disable fuse status: 0
[0083.217] I> Booting Parker Sku
[0083.220] I> Ram repair fuse : 0x0
[0083.223] I> Mem length:2000
[0083.226] I> tegrabl_ast_init_mapper: AST-cache dump
[0083.231] I> allocated(CO:30) base:0x278000000 size:0x8000000 align: 0x8000000
[0083.238] I> allocated(CO:23) base:0xf0100000 size:0x10000 align: 0x10000
[0083.245] I> allocated(CO:31) base:0x0 size:0x0 align: 0x0
[0083.250] I> allocated(CO:1) base:0x277f00000 size:0x100000 align: 0x100000
[0083.257] I> allocated(CO:2) base:0x277e00000 size:0x100000 align: 0x100000
[0083.264] I> allocated(CO:3) base:0x277d00000 size:0x100000 align: 0x100000
[0083.271] I> allocated(CO:4) base:0x277c00000 size:0x100000 align: 0x100000
[0083.278] I> allocated(CO:5) base:0x277b00000 size:0x100000 align: 0x100000
[0083.285] I> allocated(CO:27) base:0x0 size:0x0 align: 0x0
[0083.290] I> allocated(CO:6) base:0x277800000 size:0x200000 align: 0x200000
[0083.297] I> allocated(CO:7) base:0x277400000 size:0x400000 align: 0x400000
[0083.304] I> allocated(CO:8) base:0x277a00000 size:0x100000 align: 0x100000
[0083.311] I> allocated(CO:9) base:0x277300000 size:0x100000 align: 0x100000
[0083.317] I> allocated(CO:10) base:0x276800000 size:0x800000 align: 0x800000
[0083.324] I> allocated(CO:11) base:0x30000000 size:0x40000 align: 0x0
[0083.331] I> allocated(CO:12) base:0xf0000000 size:0x100000 align: 0x100000
[0083.338] I> allocated(CO:13) base:0x30040000 size:0x1000 align: 0x0
[0083.344] I> allocated(CO:14) base:0x30048000 size:0x1000 align: 0x0
[0083.350] I> allocated(CO:15) base:0x30049000 size:0x1000 align: 0x0
[0083.356] I> allocated(CO:16) base:0x3004a000 size:0x1000 align: 0x0
[0083.363] I> allocated(CO:17) base:0x3004b000 size:0x1000 align: 0x0
[0083.369] I> allocated(CO:19) base:0x3004d000 size:0x1000 align: 0x0
[0083.375] I> allocated(CO:18) base:0x3004c000 size:0x1000 align: 0x0
[0083.381] I> allocated(CO:20) base:0x3004e000 size:0x1000 align: 0x0
[0083.388] I> allocated(CO:21) base:0x3004f000 size:0x1000 align: 0x0
[0083.394] I> allocated(CO:22) base:0x0 size:0x0 align: 0x0
[0083.399] I> allocated(CO:32) base:0x276000000 size:0x600000 align: 0x400000
[0083.406] I> allocated(CO:24) base:0x0 size:0x0 align: 0x0
[0083.412] I> allocated(CO:25) base:0x0 size:0x0 align: 0x0
[0083.417] I> allocated(CO:26) base:0x0 size:0x0 align: 0x0
[0083.422] I> allocated(CO:39) base:0x96000000 size:0x2000000 align: 0x2000000
[0083.429] I> allocated(CO:38) base:0x84000000 size:0x400000 align: 0x400000
[0083.436] I> allocated(CO:37) base:0x2772e0000 size:0x20000 align: 0x20000
[0083.443] I> allocated(CO:40) base:0x84800000 size:0xb00000 align: 0x800000
[0083.450] I> allocated(CO:41) base:0x277200000 size:0x80000 align: 0x80000
[0083.457] I> allocated(CO:28) base:0x84400000 size:0x400000 align: 0x400000
[0083.465] I> Boot-device: eMMC
[0083.467] I> sdmmc bdev is already initialized
[0083.472] W> MB1 PMIC CFG is version 1.2
[0083.476] W> Rail ID 7 is not found on MB1 BCT
[0083.480] W> MB1 PMIC CFG is version 1.2
[0083.488] W> MB1 PMIC CFG is version 1.2
[0083.495] W> MB1 PMIC CFG is version 1.2
[0083.499] I> sdram slot : 1
[0083.502] I> Initializing SDRAM
[0083.508] I> mss encrypt status check successful
[0083.513] I> downloaded image bct_mb1 successfully
[0084.093] I> Downloading blob at 0x0000000085300000
[0084.303] E> Checksum verification failed.
[0084.307] E> Sending nack 0x0b85c11c
[0084.313] E> Failed to receive data
[0084.317] E> (0b85c11c): Failed to receive data from host
It sort of looks like a hardware failure, but it is somewhat concerning if a power fail can do this, it is and was powered by the provided devkit power supply.
Hello, can you go to http://www.nvidia.com/nvcc and open an RMA case with the agent through the Live Chat. Perhaps there was a power surge or the TX2 chip was otherwise unable to shut down correctly due to the loss of standby power.
