Hello, during the recent batch of p3310 modules flashing, I encountered some problems, which have never been encountered before:
- Using the command “sudo ./flash.sh jetson-tx2 mmcblk0p1”, the flashing process stays as shown in the figure below
- The whole brushing process is as follows:
yongle@yongle-ubuntu:~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra$ sudo ./flash.sh jetson-tx2 mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0018 ] Generating RCM messages
[ 0.0025 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0030 ] RCM 0 is saved as rcm_0.rcm
[ 0.0032 ] RCM 1 is saved as rcm_1.rcm
[ 0.0032 ] List of rcm files are saved in rcm_list.xml
[ 0.0032 ]
[ 0.0032 ] Signing RCM messages
[ 0.0038 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0042 ] Assuming zero filled SBK key
[ 0.0063 ]
[ 0.0063 ] Copying signature to RCM mesages
[ 0.0069 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0075 ]
[ 0.0075 ] Boot Rom communication
[ 0.0080 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0085 ] RCM version 0X180001
[ 0.0095 ] Boot Rom communication completed
[ 1.0167 ]
[ 2.0201 ] tegrarcm_v2 --isapplet
[ 2.0218 ] Applet version 01.00.0000
[ 2.0249 ]
[ 2.0267 ] Retrieving EEPROM data
[ 2.0269 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0286 ] Applet version 01.00.0000
[ 2.0621 ] Saved platform info in /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1360 ]
Board ID(3310) version(D02) sku(1000) revision(L.0)
Copy /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec
copying bctfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)... done.
copying misc_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
Making Boot image... done.
/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img
version 1.0.0
[ 0.0002 ] Generating signature
[ 0.0011 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0016 ] Assuming zero filled SBK key
[ 0.0017 ]
[ 0.0018 ] sign_type : 0
[ 0.0018 ] header_magic: 414e4452
[ 0.0023 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0028 ]
[ 0.0034 ] tegrahost_v2 --appendsigheader 1_boot.img zerosbk
[ 0.0044 ]
[ 0.0053 ] tegrasign_v2 --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0057 ] Assuming zero filled SBK key
[ 0.0166 ]
[ 0.0175 ] tegrahost_v2 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0186 ]
[ 0.0190 ] Signed file: /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don't need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/ramdisk_tmp ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra
30402 块
_BASE_KERNEL_VERSION=4.9.201-tegra
~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/ramdisk_tmp ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader ~/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra
65752 块
Making Recovery image...
copying recdtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec)... done.
记录了20+0 的读入
记录了20+0 的写出
20 bytes copied, 0.000140241 s, 143 kB/s
Existing sosfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/spe.bin) reused.
Existing drameccfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
version 1.0.0
[ 0.0003 ] Generating signature
[ 0.0010 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0017 ] Assuming zero filled SBK key
[ 0.0017 ]
[ 0.0018 ] sign_type : 758133043
[ 0.0018 ] header_magic: d00dfeed
[ 0.0024 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 0.0031 ]
[ 0.0037 ] tegrahost_v2 --appendsigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 0.0047 ]
[ 0.0057 ] tegrasign_v2 --key --list 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0064 ] Assuming zero filled SBK key
[ 0.0110 ]
[ 0.0119 ] tegrahost_v2 --updatesigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 0.0128 ]
[ 0.0131 ] Signed file: /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
done.
Making system.img...
populating rootfs from /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/rootfs ... done.
populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x7090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb"
saving flash command in /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/yongle/myfile/TX2_SOURCE/Tegra186_Linux_R32.5.1_aarch64/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0015 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0021 ] Assuming zero filled SBK key
[ 0.0055 ]
[ 0.0056 ] Generating RCM messages
[ 0.0065 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0069 ] RCM 0 is saved as rcm_0.rcm
[ 0.0075 ] RCM 1 is saved as rcm_1.rcm
[ 0.0075 ] List of rcm files are saved in rcm_list.xml
[ 0.0075 ]
[ 0.0075 ] Signing RCM messages
[ 0.0080 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0084 ] Assuming zero filled SBK key
[ 0.0107 ]
[ 0.0107 ] Copying signature to RCM mesages
[ 0.0113 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0120 ]
[ 0.0120 ] Parsing partition layout
[ 0.0134 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0158 ]
[ 0.0158 ] Creating list of images to be signed
[ 0.0173 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.1765 ]
[ 0.1765 ] Generating signatures
[ 0.1773 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1778 ] Assuming zero filled SBK key
[ 1.2636 ]
[ 1.2636 ] Generating br-bct
[ 1.2654 ] Updating dev and MSS params in BR BCT
[ 1.2654 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 1.2854 ]
[ 1.2855 ] Updating bl info
[ 1.2863 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.2874 ]
[ 1.2874 ] Updating smd info
[ 1.2880 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 1.2886 ]
[ 1.2886 ] Updating Odmdata
[ 1.2891 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x7090000
[ 1.2897 ]
[ 1.2897 ] Get Signed section of bct
[ 1.2902 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 1.2910 ]
[ 1.2917 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 1.2923 ] Assuming zero filled SBK key
[ 1.2925 ]
[ 1.2925 ] Updating BCT with signature
[ 1.2934 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 1.2942 ]
[ 1.2942 ] Generating coldboot mb1-bct
[ 1.2950 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.3048 ] MB1-BCT version: 0xf
[ 1.3069 ] Packing sdram param for instance[0]
[ 1.4667 ] Packing sdram param for instance[1]
[ 1.4668 ] Packing sdram param for instance[2]
[ 1.4669 ] Packing sdram param for instance[3]
[ 1.4747 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.4750 ] Appending platform config data of size :- 3032
[ 1.4753 ] Parsing config file :mobile_scr.cfg
[ 1.4754 ] Appending platform config data of size :- 12240
[ 1.4767 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.4771 ] Appending platform config data of size :- 24
[ 1.4773 ]
[ 1.4773 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.4773 ] Appending platform config data of size :- 672
[ 1.4773 ]
[ 1.4773 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.4773 ] Appending platform config data of size :- 64
[ 1.4774 ]
[ 1.4774 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.4774 ] Appending platform config data of size :- 1628
[ 1.4774 ]
[ 1.4774 ] Updating mb1-bct with firmware information
[ 1.4789 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.4800 ] MB1-BCT version: 0xf
[ 1.4805 ]
[ 1.4805 ] Updating mb1-bct with storage information
[ 1.4817 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.4828 ] MB1-BCT version: 0xf
[ 1.4833 ]
[ 1.4844 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 1.4856 ]
[ 1.4869 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 1.4883 ]
[ 1.4899 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.4911 ] Assuming zero filled SBK key
[ 1.4939 ]
[ 1.4960 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 1.4981 ]
[ 1.4983 ] Generating recovery mb1-bct
[ 1.5000 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.5016 ] MB1-BCT version: 0xf
[ 1.5020 ] Packing sdram param for instance[0]
[ 1.5815 ] Packing sdram param for instance[1]
[ 1.5817 ] Packing sdram param for instance[2]
[ 1.5819 ] Packing sdram param for instance[3]
[ 1.5931 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.5979 ] Appending platform config data of size :- 3032
[ 1.5981 ] Parsing config file :minimal_scr.cfg
[ 1.5982 ] Appending platform config data of size :- 12240
[ 1.6020 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.6023 ] Appending platform config data of size :- 24
[ 1.6023 ]
[ 1.6023 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.6023 ] Appending platform config data of size :- 672
[ 1.6023 ]
[ 1.6023 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.6023 ] Appending platform config data of size :- 64
[ 1.6023 ]
[ 1.6023 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.6023 ] Appending platform config data of size :- 1628
[ 1.6023 ]
[ 1.6023 ] Updating mb1-bct with firmware information
[ 1.6037 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.6042 ] MB1-BCT version: 0xf
[ 1.6045 ]
[ 1.6045 ] Updating mb1-bct with storage information
[ 1.6050 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.6057 ] MB1-BCT version: 0xf
[ 1.6062 ]
[ 1.6070 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 1.6076 ]
[ 1.6082 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.6093 ]
[ 1.6100 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.6104 ] Assuming zero filled SBK key
[ 1.6115 ]
[ 1.6123 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.6130 ]
[ 1.6131 ] Copying signatures
[ 1.6137 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.8851 ]
[ 1.8852 ] Boot Rom communication
[ 1.8871 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 1.8883 ] BootRom is not running
[ 6.9706 ]
[ 7.9741 ] tegrarcm_v2 --isapplet
[ 7.9758 ] Applet version 01.00.0000
[ 7.9787 ]
[ 7.9788 ] Sending BCTs
[ 7.9807 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 7.9824 ] Applet version 01.00.0000
[ 8.0013 ] Sending bct_bootrom
[ 8.0016 ] [................................................] 100%
[ 8.0032 ] Sending bct_mb1
[ 8.0035 ] [................................................] 100%
[ 8.0223 ]
[ 8.0228 ] Generating blob
[ 8.0290 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 8.0409 ]
[ 8.0439 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 8.0449 ]
[ 8.0457 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.0463 ] Assuming zero filled SBK key
[ 8.0508 ]
[ 8.0523 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 8.0535 ]
[ 8.0600 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 8.0698 ]
[ 8.0759 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 8.0931 ]
[ 8.1109 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.1185 ] Assuming zero filled SBK key
[ 8.1204 ]
[ 8.1213 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 8.1221 ]
[ 8.1229 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 8.1314 ]
[ 8.1429 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 8.1527 ]
[ 8.1622 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.1723 ] Assuming zero filled SBK key
[ 8.1766 ]
[ 8.1775 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 8.1783 ]
[ 8.1791 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 8.1797 ]
[ 8.1803 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 8.1942 ]
[ 8.2057 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.2160 ] Assuming zero filled SBK key
[ 8.4101 ]
[ 8.4113 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 8.4137 ]
[ 8.4145 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 8.4151 ]
[ 8.4158 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 8.4169 ]
[ 8.4176 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 8.4180 ] Assuming zero filled SBK key
[ 8.4284 ]
[ 8.4292 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 8.4303 ]
[ 8.4309 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 8.4314 ]
[ 8.4320 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 8.4331 ]
[ 8.4337 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.4341 ] Assuming zero filled SBK key
[ 8.4914 ]
[ 8.5064 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 8.5218 ]
[ 8.5238 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 8.5246 ]
[ 8.5252 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img zerosbk
[ 8.5269 ]
[ 8.5281 ] tegrasign_v2 --key None --list blob_tos-trusty_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.5287 ] Assuming zero filled SBK key
[ 8.5366 ]
[ 8.5377 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 8.5391 ]
[ 8.5401 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 8.5412 ]
[ 8.5424 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 8.5431 ]
[ 8.5441 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 8.5463 ] Assuming zero filled SBK key
[ 8.5575 ]
[ 8.5660 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 8.5673 ]
[ 8.5686 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 8.5697 ]
[ 8.5711 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 8.5738 ]
[ 8.5759 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 8.5775 ] Assuming zero filled SBK key
[ 8.5923 ]
[ 8.5939 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 8.5957 ]
[ 8.5971 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 8.5982 ] number of images in blob are 9
[ 8.5985 ] blobsize is 4247112
[ 8.5986 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 221776
[ 8.6071 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 90176
[ 8.6071 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 8.6071 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 8.6071 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 534816
[ 8.6071 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 605120
[ 8.6071 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 395072
[ 8.6071 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 8.6071 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 253312
[ 8.6071 ]
[ 8.6072 ] Sending bootloader and pre-requisite binaries
[ 8.6085 ] tegrarcm_v2 --download blob blob.bin
[ 8.6093 ] Applet version 01.00.0000
[ 8.6121 ] Sending blob
[ 8.6122 ] [................................................] 100%
[ 9.0842 ]
[ 9.0862 ] tegrarcm_v2 --boot recovery
[ 9.0877 ] Applet version 01.00.0000
[ 9.1058 ]
[ 10.1082 ] tegrarcm_v2 --isapplet
[ 10.7889 ]
[ 10.7919 ] tegradevflash_v2 --iscpubl
[ 10.7936 ] Cannot Open USB
[ 11.2495 ]
[ 12.2524 ] tegrarcm_v2 --isapplet
- The numbers of the p3310 modules are:S/N:1420622073116
- The two modes of 7c18 and 7c20 cannot be switched normally, they must be powered off and restarted to take effect
